Re: [U-Boot] [U-BOOT PATCH v3 2/4] x86: Added support for ACPI table generation at the generic layer.
+ML
Hi Saket,
On Sun, Aug 16, 2015 at 5:39 AM, Saket Sinha saket.sinha89@gmail.com wrote:
Hi Bin,
Please find my response inline.
On Thu, Aug 13, 2015 at 3:31 PM, Bin Meng bmeng.cn@gmail.com wrote:
Hi Saket,
On Thu, Aug 13, 2015 at 11:01 AM, Saket Sinha saket.sinha89@gmail.com wrote:
Please see my comments in your [1/4] patch regarding to patch title and commit message.
Addressed in patchset series v4.
Signed-off-by: Saket Sinha saket.sinha89@gmail.com
arch/x86/include/asm/acpi_table.h | 387 +++++++++++++++++++++++++++++++++++ arch/x86/lib/Makefile | 1 + arch/x86/lib/acpi_table.c | 413 ++++++++++++++++++++++++++++++++++++++ arch/x86/lib/tables.c | 5 + scripts/Makefile.lib | 11 + 5 files changed, 817 insertions(+) create mode 100644 arch/x86/include/asm/acpi_table.h create mode 100644 arch/x86/lib/acpi_table.c
[snip]
diff --git a/arch/x86/lib/Makefile b/arch/x86/lib/Makefile index dcfe9ee..6ecd6db 100644 --- a/arch/x86/lib/Makefile +++ b/arch/x86/lib/Makefile @@ -30,6 +30,7 @@ obj-y += physmem.o obj-$(CONFIG_X86_RAMTEST) += ramtest.o obj-y += sfi.o obj-y += string.o +obj-$(CONFIG_GENERATE_ACPI_TABLE) += acpi_table.o obj-y += tables.o obj-$(CONFIG_SYS_X86_TSC_TIMER) += tsc_timer.o obj-$(CONFIG_CMD_ZBOOT) += zimage.o diff --git a/arch/x86/lib/acpi_table.c b/arch/x86/lib/acpi_table.c new file mode 100644 index 0000000..2e20317 --- /dev/null +++ b/arch/x86/lib/acpi_table.c @@ -0,0 +1,413 @@ +/*
- Copyright (C) 2015, Saket Sinha saket.sinha89@gmail.com
Please add comments to give others some hints on where this file is ported from.
Yes. Addressed in patchset series v4.
+#include <asm/acpi_table.h> +#include <asm/cpu.h> +#include <asm/ioapic.h> +#include <asm/lapic.h> +#include <asm/tables.h> +#include <asm/pci.h> +#include <cpu.h> +#include <dm.h> +#include <dm/uclass-internal.h> +#include <dm/lists.h>
+extern const unsigned char AmlCode[];
Can we avoid using CamelCase here?
No. iasl -tc dumps the aamlcode into an array called AmlCode[]. I do not see any option to change that.
Kindly refer official iasl documntation at below link - https://github.com/disdi/ACPI/blob/master/aslcompiler.pdf - Section 6.4.2 Output of –tc (make C hex table) Option
Please add a comment block to explain this is required by the IASL and we cannot rename it to conform U-Boot coding convention.
[snip]
Regards, Bin
Bin Meng
