[U-Boot] [PATCH 0/4] Add network support for Jaguar2 SoCs
This patch series add network support for Jaguar2 SoCs family. There are following pcb: Jaguar2-24(110), Jaguar2-48(pcb111) and Serval2(pcb112).
Horatiu Vultur (4): net: Add MSCC Jaguar2 network driver. board: mscc: jr2: Update MSCC Jaguar2 boards net: mscc: jaguar2: Add ethenet nodes for Jaguar2. configs: mscc_jr2: Add network support
arch/mips/dts/jr2_pcb110.dts | 67 ++++ arch/mips/dts/jr2_pcb111.dts | 352 ++++++++++++++++ arch/mips/dts/mscc,jr2.dtsi | 106 +++++ arch/mips/dts/serval2_pcb112.dts | 39 ++ board/mscc/jr2/jr2.c | 542 +++++++++++++++++++++++++ configs/mscc_jr2_defconfig | 6 +- drivers/net/mscc_eswitch/Kconfig | 7 + drivers/net/mscc_eswitch/Makefile | 1 + drivers/net/mscc_eswitch/jr2_switch.c | 735 ++++++++++++++++++++++++++++++++++ include/configs/vcoreiii.h | 2 +- 10 files changed, 1855 insertions(+), 2 deletions(-) create mode 100644 drivers/net/mscc_eswitch/jr2_switch.c
Add network driver for Microsemi Ethernet switch. It is present on Jaguar2 SoCs.
Signed-off-by: Horatiu Vultur horatiu.vultur@microchip.com --- drivers/net/mscc_eswitch/Kconfig | 7 + drivers/net/mscc_eswitch/Makefile | 1 + drivers/net/mscc_eswitch/jr2_switch.c | 735 ++++++++++++++++++++++++++++++++++ include/configs/vcoreiii.h | 2 +- 4 files changed, 744 insertions(+), 1 deletion(-) create mode 100644 drivers/net/mscc_eswitch/jr2_switch.c
diff --git a/drivers/net/mscc_eswitch/Kconfig b/drivers/net/mscc_eswitch/Kconfig index 88e5a97..3f9d14b 100644 --- a/drivers/net/mscc_eswitch/Kconfig +++ b/drivers/net/mscc_eswitch/Kconfig @@ -15,3 +15,10 @@ config MSCC_LUTON_SWITCH select PHYLIB help This driver supports the Luton network switch device. + +config MSCC_JR2_SWITCH + bool "Jaguar2 switch driver" + depends on DM_ETH && ARCH_MSCC + select PHYLIB + help + This driver supports the Jaguar2 network switch device. diff --git a/drivers/net/mscc_eswitch/Makefile b/drivers/net/mscc_eswitch/Makefile index 751a839..0a1b863 100644 --- a/drivers/net/mscc_eswitch/Makefile +++ b/drivers/net/mscc_eswitch/Makefile @@ -1,3 +1,4 @@
obj-$(CONFIG_MSCC_OCELOT_SWITCH) += ocelot_switch.o mscc_miim.o mscc_xfer.o mscc_mac_table.o obj-$(CONFIG_MSCC_LUTON_SWITCH) += luton_switch.o mscc_miim.o mscc_xfer.o mscc_mac_table.o +obj-$(CONFIG_MSCC_JR2_SWITCH) += jr2_switch.o mscc_xfer.o diff --git a/drivers/net/mscc_eswitch/jr2_switch.c b/drivers/net/mscc_eswitch/jr2_switch.c new file mode 100644 index 0000000..27b72ee --- /dev/null +++ b/drivers/net/mscc_eswitch/jr2_switch.c @@ -0,0 +1,735 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2018 Microsemi Corporation + */ + +#include <common.h> +#include <config.h> +#include <dm.h> +#include <dm/of_access.h> +#include <dm/of_addr.h> +#include <fdt_support.h> +#include <linux/io.h> +#include <linux/ioport.h> +#include <miiphy.h> +#include <net.h> +#include <wait_bit.h> + +#include "mscc_xfer.h" + +#define GCB_MIIM_MII_STATUS 0x0 +#define GCB_MIIM_STAT_BUSY BIT(3) +#define GCB_MIIM_MII_CMD 0x8 +#define GCB_MIIM_MII_CMD_SCAN BIT(0) +#define GCB_MIIM_MII_CMD_OPR_WRITE BIT(1) +#define GCB_MIIM_MII_CMD_OPR_READ BIT(2) +#define GCB_MIIM_MII_CMD_SINGLE_SCAN BIT(3) +#define GCB_MIIM_MII_CMD_WRDATA(x) ((x) << 4) +#define GCB_MIIM_MII_CMD_REGAD(x) ((x) << 20) +#define GCB_MIIM_MII_CMD_PHYAD(x) ((x) << 25) +#define GCB_MIIM_MII_CMD_VLD BIT(31) +#define GCB_MIIM_DATA 0xC +#define GCB_MIIM_DATA_ERROR (0x3 << 16) + +#define ANA_AC_RAM_CTRL_RAM_INIT 0x94358 +#define ANA_AC_STAT_GLOBAL_CFG_PORT_RESET 0x94370 + +#define ANA_CL_PORT_VLAN_CFG(x) (0x24018 + 0xc8 * (x)) +#define ANA_CL_PORT_VLAN_CFG_AWARE_ENA BIT(19) +#define ANA_CL_PORT_VLAN_CFG_POP_CNT(x) ((x) << 17) + +#define ANA_L2_COMMON_FWD_CFG 0x8a2a8 +#define ANA_L2_COMMON_FWD_CFG_CPU_DMAC_COPY_ENA BIT(6) + +#define ASM_CFG_STAT_CFG 0x3508 +#define ASM_CFG_PORT(x) (0x36c4 + 0x4 * (x)) +#define ASM_CFG_PORT_NO_PREAMBLE_ENA BIT(8) +#define ASM_CFG_PORT_INJ_FORMAT_CFG(x) ((x) << 1) +#define ASM_RAM_CTRL_RAM_INIT 0x39b8 + +#define DEV_DEV_CFG_DEV_RST_CTRL 0x0 +#define DEV_DEV_CFG_DEV_RST_CTRL_SPEED_SEL(x) ((x) << 20) +#define DEV_MAC_CFG_MAC_ENA 0x1c +#define DEV_MAC_CFG_MAC_ENA_RX_ENA BIT(4) +#define DEV_MAC_CFG_MAC_ENA_TX_ENA BIT(0) +#define DEV_MAC_CFG_MAC_IFG 0x34 +#define DEV_MAC_CFG_MAC_IFG_TX_IFG(x) ((x) << 8) +#define DEV_MAC_CFG_MAC_IFG_RX_IFG2(x) ((x) << 4) +#define DEV_MAC_CFG_MAC_IFG_RX_IFG1(x) (x) +#define DEV_PCS1G_CFG_PCS1G_CFG 0x40 +#define DEV_PCS1G_CFG_PCS1G_CFG_PCS_ENA BIT(0) +#define DEV_PCS1G_CFG_PCS1G_MODE 0x44 +#define DEV_PCS1G_CFG_PCS1G_SD 0x48 +#define DEV_PCS1G_CFG_PCS1G_ANEG 0x4c +#define DEV_PCS1G_CFG_PCS1G_ANEG_ADV_ABILITY(x) ((x) << 16) + +#define DSM_RAM_CTRL_RAM_INIT 0x8 + +#define HSIO_ANA_SERDES1G_DES_CFG 0xac +#define HSIO_ANA_SERDES1G_DES_CFG_BW_HYST(x) ((x) << 1) +#define HSIO_ANA_SERDES1G_DES_CFG_BW_ANA(x) ((x) << 5) +#define HSIO_ANA_SERDES1G_DES_CFG_MBTR_CTRL(x) ((x) << 8) +#define HSIO_ANA_SERDES1G_DES_CFG_PHS_CTRL(x) ((x) << 13) +#define HSIO_ANA_SERDES1G_IB_CFG 0xb0 +#define HSIO_ANA_SERDES1G_IB_CFG_RESISTOR_CTRL(x) (x) +#define HSIO_ANA_SERDES1G_IB_CFG_EQ_GAIN(x) ((x) << 6) +#define HSIO_ANA_SERDES1G_IB_CFG_ENA_OFFSET_COMP BIT(9) +#define HSIO_ANA_SERDES1G_IB_CFG_ENA_DETLEV BIT(11) +#define HSIO_ANA_SERDES1G_IB_CFG_ENA_CMV_TERM BIT(13) +#define HSIO_ANA_SERDES1G_IB_CFG_DET_LEV(x) ((x) << 19) +#define HSIO_ANA_SERDES1G_IB_CFG_ACJTAG_HYST(x) ((x) << 24) +#define HSIO_ANA_SERDES1G_OB_CFG 0xb4 +#define HSIO_ANA_SERDES1G_OB_CFG_RESISTOR_CTRL(x) (x) +#define HSIO_ANA_SERDES1G_OB_CFG_VCM_CTRL(x) ((x) << 4) +#define HSIO_ANA_SERDES1G_OB_CFG_CMM_BIAS_CTRL(x) ((x) << 10) +#define HSIO_ANA_SERDES1G_OB_CFG_AMP_CTRL(x) ((x) << 13) +#define HSIO_ANA_SERDES1G_OB_CFG_SLP(x) ((x) << 17) +#define HSIO_ANA_SERDES1G_SER_CFG 0xb8 +#define HSIO_ANA_SERDES1G_COMMON_CFG 0xbc +#define HSIO_ANA_SERDES1G_COMMON_CFG_IF_MODE BIT(0) +#define HSIO_ANA_SERDES1G_COMMON_CFG_ENA_LANE BIT(18) +#define HSIO_ANA_SERDES1G_COMMON_CFG_SYS_RST BIT(31) +#define HSIO_ANA_SERDES1G_PLL_CFG 0xc0 +#define HSIO_ANA_SERDES1G_PLL_CFG_FSM_ENA BIT(7) +#define HSIO_ANA_SERDES1G_PLL_CFG_FSM_CTRL_DATA(x) ((x) << 8) +#define HSIO_ANA_SERDES1G_PLL_CFG_ENA_RC_DIV2 BIT(21) +#define HSIO_DIG_SERDES1G_DFT_CFG0 0xc8 +#define HSIO_DIG_SERDES1G_TP_CFG 0xd4 +#define HSIO_DIG_SERDES1G_MISC_CFG 0xdc +#define HSIO_DIG_SERDES1G_MISC_CFG_LANE_RST BIT(0) +#define HSIO_MCB_SERDES1G_CFG 0xe8 +#define HSIO_MCB_SERDES1G_CFG_WR_ONE_SHOT BIT(31) +#define HSIO_MCB_SERDES1G_CFG_ADDR(x) (x) + +#define LRN_COMMON_ACCESS_CTRL 0x0 +#define LRN_COMMON_ACCESS_CTRL_MAC_TABLE_ACCESS_SHOT BIT(0) +#define LRN_COMMON_MAC_ACCESS_CFG0 0x4 +#define LRN_COMMON_MAC_ACCESS_CFG1 0x8 +#define LRN_COMMON_MAC_ACCESS_CFG2 0xc +#define LRN_COMMON_MAC_ACCESS_CFG2_MAC_ENTRY_ADDR(x) (x) +#define LRN_COMMON_MAC_ACCESS_CFG2_MAC_ENTRY_TYPE(x) ((x) << 12) +#define LRN_COMMON_MAC_ACCESS_CFG2_MAC_ENTRY_VLD BIT(15) +#define LRN_COMMON_MAC_ACCESS_CFG2_MAC_ENTRY_LOCKED BIT(16) +#define LRN_COMMON_MAC_ACCESS_CFG2_MAC_ENTRY_CPU_COPY BIT(23) +#define LRN_COMMON_MAC_ACCESS_CFG2_MAC_ENTRY_CPU_QU(x) ((x) << 24) + +#define QFWD_SYSTEM_SWITCH_PORT_MODE(x) (0x4 * (x)) +#define QFWD_SYSTEM_SWITCH_PORT_MODE_PORT_ENA BIT(17) + +#define QS_XTR_GRP_CFG(x) (0x0 + 4 * (x)) +#define QS_INJ_GRP_CFG(x) (0x24 + (x) * 4) + +#define QSYS_SYSTEM_RESET_CFG 0xf0 +#define QSYS_CALCFG_CAL_AUTO(x) (0x3d4 + 4 * (x)) +#define QSYS_CALCFG_CAL_CTRL 0x3e8 +#define QSYS_CALCFG_CAL_CTRL_CAL_MODE(x) ((x) << 11) +#define QSYS_RAM_CTRL_RAM_INIT 0x3ec + +#define REW_RAM_CTRL_RAM_INIT 0x53528 + +#define VOP_RAM_CTRL_RAM_INIT 0x43638 + +#define XTR_VALID_BYTES(x) (4 - ((x) & 3)) +#define MAC_VID 0 +#define CPU_PORT 53 +#define IFH_LEN 7 +#define JR2_BUF_CELL_SZ 60 +#define ETH_ALEN 6 +#define PGID_BROADCAST 510 +#define PGID_UNICAST 511 + +static char *regs_names[] = { + "port0", "port1", "port2", "port3", "port4", "port5", "port6", "port7", + "port8", "port9", "port10", "port11", "port12", "port13", "port14", + "port15", "port16", "port17", "port18", "port19", "port20", "port21", + "port22", "port23", "port24", "port25", "port26", "port27", "port28", + "port29", "port30", "port31", "port32", "port33", "port34", "port35", + "port36", "port37", "port38", "port39", "port40", "port41", "port42", + "port43", "port44", "port45", "port46", "port47", + "ana_ac", "ana_cl", "ana_l2", "asm", "hsio", "lrn", + "qfwd", "qs", "qsys", "rew", +}; + +#define REGS_NAMES_COUNT ARRAY_SIZE(regs_names) + 1 +#define MAX_PORT 48 + +enum jr2_ctrl_regs { + ANA_AC = MAX_PORT, + ANA_CL, + ANA_L2, + ASM, + HSIO, + LRN, + QFWD, + QS, + QSYS, + REW, +}; + +#define JR2_MIIM_BUS_COUNT 3 + +struct jr2_phy_port_t { + size_t phy_addr; + struct mii_dev *bus; +}; + +struct jr2_private { + void __iomem *regs[REGS_NAMES_COUNT]; + struct mii_dev *bus[JR2_MIIM_BUS_COUNT]; + struct jr2_phy_port_t ports[MAX_PORT]; +}; + +struct jr2_miim_dev { + void __iomem *regs; + phys_addr_t miim_base; + unsigned long miim_size; + struct mii_dev *bus; +}; + +static const unsigned long jr2_regs_qs[] = { + [MSCC_QS_XTR_RD] = 0x8, + [MSCC_QS_XTR_FLUSH] = 0x18, + [MSCC_QS_XTR_DATA_PRESENT] = 0x1c, + [MSCC_QS_INJ_WR] = 0x2c, + [MSCC_QS_INJ_CTRL] = 0x34, +}; + +static struct jr2_miim_dev miim[JR2_MIIM_BUS_COUNT]; +static int miim_count = -1; + +static int mscc_miim_wait_ready(struct jr2_miim_dev *miim) +{ + unsigned long deadline; + u32 val; + + deadline = timer_get_us() + 250000; + + do { + val = readl(miim->regs + GCB_MIIM_MII_STATUS); + } while (timer_get_us() <= deadline && (val & GCB_MIIM_STAT_BUSY)); + + if (val & GCB_MIIM_STAT_BUSY) + return -ETIMEDOUT; + + return 0; +} + +static int mscc_miim_read(struct mii_dev *bus, int addr, int devad, int reg) +{ + struct jr2_miim_dev *miim = (struct jr2_miim_dev *)bus->priv; + u32 val; + int ret; + + ret = mscc_miim_wait_ready(miim); + if (ret) + goto out; + + writel(GCB_MIIM_MII_CMD_VLD | GCB_MIIM_MII_CMD_PHYAD(addr) | + GCB_MIIM_MII_CMD_REGAD(reg) | GCB_MIIM_MII_CMD_OPR_READ, + miim->regs + GCB_MIIM_MII_CMD); + + ret = mscc_miim_wait_ready(miim); + if (ret) + goto out; + + val = readl(miim->regs + GCB_MIIM_DATA); + if (val & GCB_MIIM_DATA_ERROR) { + ret = -EIO; + goto out; + } + + ret = val & 0xFFFF; + out: + return ret; +} + +static int mscc_miim_write(struct mii_dev *bus, int addr, int devad, int reg, + u16 val) +{ + struct jr2_miim_dev *miim = (struct jr2_miim_dev *)bus->priv; + int ret; + + ret = mscc_miim_wait_ready(miim); + if (ret < 0) + goto out; + + writel(GCB_MIIM_MII_CMD_VLD | GCB_MIIM_MII_CMD_PHYAD(addr) | + GCB_MIIM_MII_CMD_REGAD(reg) | GCB_MIIM_MII_CMD_WRDATA(val) | + GCB_MIIM_MII_CMD_OPR_WRITE, miim->regs + GCB_MIIM_MII_CMD); + + out: + return ret; +} + +static struct mii_dev *jr2_mdiobus_init(phys_addr_t miim_base, + unsigned long miim_size) +{ + struct mii_dev *bus; + + bus = mdio_alloc(); + if (!bus) + return NULL; + + ++miim_count; + sprintf(bus->name, "miim-bus%d", miim_count); + + miim[miim_count].regs = ioremap(miim_base, miim_size); + miim[miim_count].miim_base = miim_base; + miim[miim_count].miim_size = miim_size; + bus->priv = &miim[miim_count]; + bus->read = mscc_miim_read; + bus->write = mscc_miim_write; + + if (mdio_register(bus)) + return NULL; + + miim[miim_count].bus = bus; + return bus; +} + +static void jr2_cpu_capture_setup(struct jr2_private *priv) +{ + /* ASM: No preamble and IFH prefix on CPU injected frames */ + writel(ASM_CFG_PORT_NO_PREAMBLE_ENA | + ASM_CFG_PORT_INJ_FORMAT_CFG(1), + priv->regs[ASM] + ASM_CFG_PORT(CPU_PORT)); + + /* Set Manual injection via DEVCPU_QS registers for CPU queue 0 */ + writel(0x5, priv->regs[QS] + QS_INJ_GRP_CFG(0)); + + /* Set Manual extraction via DEVCPU_QS registers for CPU queue 0 */ + writel(0x7, priv->regs[QS] + QS_XTR_GRP_CFG(0)); + + /* Enable CPU port for any frame transfer */ + setbits_le32(priv->regs[QFWD] + QFWD_SYSTEM_SWITCH_PORT_MODE(CPU_PORT), + QFWD_SYSTEM_SWITCH_PORT_MODE_PORT_ENA); + + /* Send a copy to CPU when found as forwarding entry */ + setbits_le32(priv->regs[ANA_L2] + ANA_L2_COMMON_FWD_CFG, + ANA_L2_COMMON_FWD_CFG_CPU_DMAC_COPY_ENA); +} + +static void jr2_port_init(struct jr2_private *priv, int port) +{ + void __iomem *regs = priv->regs[port]; + + /* Enable PCS */ + writel(DEV_PCS1G_CFG_PCS1G_CFG_PCS_ENA, + regs + DEV_PCS1G_CFG_PCS1G_CFG); + + /* Disable Signal Detect */ + writel(0, regs + DEV_PCS1G_CFG_PCS1G_SD); + + /* Enable MAC RX and TX */ + writel(DEV_MAC_CFG_MAC_ENA_RX_ENA | + DEV_MAC_CFG_MAC_ENA_TX_ENA, + regs + DEV_MAC_CFG_MAC_ENA); + + /* Clear sgmii_mode_ena */ + writel(0, regs + DEV_PCS1G_CFG_PCS1G_MODE); + + /* + * Clear sw_resolve_ena(bit 0) and set adv_ability to + * something meaningful just in case + */ + writel(DEV_PCS1G_CFG_PCS1G_ANEG_ADV_ABILITY(0x20), + regs + DEV_PCS1G_CFG_PCS1G_ANEG); + + /* Set MAC IFG Gaps */ + writel(DEV_MAC_CFG_MAC_IFG_TX_IFG(4) | + DEV_MAC_CFG_MAC_IFG_RX_IFG1(5) | + DEV_MAC_CFG_MAC_IFG_RX_IFG2(1), + regs + DEV_MAC_CFG_MAC_IFG); + + /* Set link speed and release all resets */ + writel(DEV_DEV_CFG_DEV_RST_CTRL_SPEED_SEL(2), + regs + DEV_DEV_CFG_DEV_RST_CTRL); + + /* Make VLAN aware for CPU traffic */ + writel(ANA_CL_PORT_VLAN_CFG_AWARE_ENA | + ANA_CL_PORT_VLAN_CFG_POP_CNT(1) | + MAC_VID, + priv->regs[ANA_CL] + ANA_CL_PORT_VLAN_CFG(port)); + + /* Enable CPU port for any frame transfer */ + setbits_le32(priv->regs[QFWD] + QFWD_SYSTEM_SWITCH_PORT_MODE(port), + QFWD_SYSTEM_SWITCH_PORT_MODE_PORT_ENA); +} + +static void serdes_write(void __iomem *base, u32 addr) +{ + u32 data; + + writel(HSIO_MCB_SERDES1G_CFG_WR_ONE_SHOT | + HSIO_MCB_SERDES1G_CFG_ADDR(addr), + base + HSIO_MCB_SERDES1G_CFG); + + do { + data = readl(base + HSIO_MCB_SERDES1G_CFG); + } while (data & HSIO_MCB_SERDES1G_CFG_WR_ONE_SHOT); + + mdelay(100); +} + +__weak void serdes_cfg(void __iomem *base) +{ + writel(0x0, base + HSIO_ANA_SERDES1G_SER_CFG); + writel(0x0, base + HSIO_DIG_SERDES1G_TP_CFG); + writel(0x0, base + HSIO_DIG_SERDES1G_DFT_CFG0); + writel(HSIO_ANA_SERDES1G_OB_CFG_RESISTOR_CTRL(1) | + HSIO_ANA_SERDES1G_OB_CFG_VCM_CTRL(4) | + HSIO_ANA_SERDES1G_OB_CFG_CMM_BIAS_CTRL(2) | + HSIO_ANA_SERDES1G_OB_CFG_AMP_CTRL(12) | + HSIO_ANA_SERDES1G_OB_CFG_SLP(3), + base + HSIO_ANA_SERDES1G_OB_CFG); + writel(HSIO_ANA_SERDES1G_IB_CFG_RESISTOR_CTRL(13) | + HSIO_ANA_SERDES1G_IB_CFG_EQ_GAIN(2) | + HSIO_ANA_SERDES1G_IB_CFG_ENA_OFFSET_COMP | + HSIO_ANA_SERDES1G_IB_CFG_ENA_DETLEV | + HSIO_ANA_SERDES1G_IB_CFG_ENA_CMV_TERM | + HSIO_ANA_SERDES1G_IB_CFG_DET_LEV(3) | + HSIO_ANA_SERDES1G_IB_CFG_ACJTAG_HYST(1), + base + HSIO_ANA_SERDES1G_IB_CFG); + writel(HSIO_ANA_SERDES1G_DES_CFG_BW_HYST(7) | + HSIO_ANA_SERDES1G_DES_CFG_BW_ANA(6) | + HSIO_ANA_SERDES1G_DES_CFG_MBTR_CTRL(2) | + HSIO_ANA_SERDES1G_DES_CFG_PHS_CTRL(6), + base + HSIO_ANA_SERDES1G_DES_CFG); + writel(HSIO_DIG_SERDES1G_MISC_CFG_LANE_RST, + base + HSIO_DIG_SERDES1G_MISC_CFG); + writel(HSIO_ANA_SERDES1G_PLL_CFG_FSM_ENA | + HSIO_ANA_SERDES1G_PLL_CFG_FSM_CTRL_DATA(0xc8) | + HSIO_ANA_SERDES1G_PLL_CFG_ENA_RC_DIV2, + base + HSIO_ANA_SERDES1G_PLL_CFG); + writel(HSIO_ANA_SERDES1G_COMMON_CFG_IF_MODE | + HSIO_ANA_SERDES1G_COMMON_CFG_ENA_LANE | + HSIO_ANA_SERDES1G_COMMON_CFG_SYS_RST, + base + HSIO_ANA_SERDES1G_COMMON_CFG); + + serdes_write(base, 0x1fe); + + setbits_le32(base + HSIO_ANA_SERDES1G_COMMON_CFG, + HSIO_ANA_SERDES1G_COMMON_CFG_SYS_RST); + + serdes_write(base, 0x1fe); + + clrbits_le32(base + HSIO_DIG_SERDES1G_MISC_CFG, + HSIO_DIG_SERDES1G_MISC_CFG_LANE_RST); + + serdes_write(base, 0x1fe); +} + +static int ram_init(u32 val, void __iomem *addr) +{ + writel(val, addr); + + if (wait_for_bit_le32(addr, BIT(1), false, 2000, false)) { + printf("Timeout in memory reset, reg = 0x%08x\n", val); + return 1; + } + + return 0; +} + +static int jr2_switch_init(struct jr2_private *priv) +{ + /* Initialize memories */ + ram_init(0x3, priv->regs[QSYS] + QSYS_RAM_CTRL_RAM_INIT); + ram_init(0x3, priv->regs[ASM] + ASM_RAM_CTRL_RAM_INIT); + ram_init(0x3, priv->regs[ANA_AC] + ANA_AC_RAM_CTRL_RAM_INIT); + ram_init(0x3, priv->regs[REW] + REW_RAM_CTRL_RAM_INIT); + + /* Reset counters */ + writel(0x1, priv->regs[ANA_AC] + ANA_AC_STAT_GLOBAL_CFG_PORT_RESET); + writel(0x1, priv->regs[ASM] + ASM_CFG_STAT_CFG); + + /* Enable switch-core and queue system */ + writel(0x1, priv->regs[QSYS] + QSYS_SYSTEM_RESET_CFG); + + /* enable serdes */ + serdes_cfg(priv->regs[HSIO]); + + return 0; +} + +static void jr2_switch_config(struct jr2_private *priv) +{ + writel(0x55555555, priv->regs[QSYS] + QSYS_CALCFG_CAL_AUTO(0)); + writel(0x55555555, priv->regs[QSYS] + QSYS_CALCFG_CAL_AUTO(1)); + writel(0x55555555, priv->regs[QSYS] + QSYS_CALCFG_CAL_AUTO(2)); + writel(0x55555555, priv->regs[QSYS] + QSYS_CALCFG_CAL_AUTO(3)); + + writel(readl(priv->regs[QSYS] + QSYS_CALCFG_CAL_CTRL) | + QSYS_CALCFG_CAL_CTRL_CAL_MODE(8), + priv->regs[QSYS] + QSYS_CALCFG_CAL_CTRL); +} + +static int jr2_initialize(struct jr2_private *priv) +{ + int ret, i; + + /* Initialize switch memories, enable core */ + ret = jr2_switch_init(priv); + if (ret) + return ret; + + jr2_switch_config(priv); + + for (i = 0; i < MAX_PORT; i++) + jr2_port_init(priv, i); + + jr2_cpu_capture_setup(priv); + + return 0; +} + +static inline int jr2_vlant_wait_for_completion(struct jr2_private *priv) +{ + if (wait_for_bit_le32(priv->regs[LRN] + LRN_COMMON_ACCESS_CTRL, + LRN_COMMON_ACCESS_CTRL_MAC_TABLE_ACCESS_SHOT, + false, 2000, false)) + return -ETIMEDOUT; + + return 0; +} + +static int jr2_mac_table_add(struct jr2_private *priv, + const unsigned char mac[ETH_ALEN], int pgid) +{ + u32 macl = 0, mach = 0; + + /* + * Set the MAC address to handle and the vlan associated in a format + * understood by the hardware. + */ + mach |= MAC_VID << 16; + mach |= ((u32)mac[0]) << 8; + mach |= ((u32)mac[1]) << 0; + macl |= ((u32)mac[2]) << 24; + macl |= ((u32)mac[3]) << 16; + macl |= ((u32)mac[4]) << 8; + macl |= ((u32)mac[5]) << 0; + + writel(mach, priv->regs[LRN] + LRN_COMMON_MAC_ACCESS_CFG0); + writel(macl, priv->regs[LRN] + LRN_COMMON_MAC_ACCESS_CFG1); + + writel(LRN_COMMON_MAC_ACCESS_CFG2_MAC_ENTRY_ADDR(pgid) | + LRN_COMMON_MAC_ACCESS_CFG2_MAC_ENTRY_TYPE(0x3) | + LRN_COMMON_MAC_ACCESS_CFG2_MAC_ENTRY_CPU_COPY | + LRN_COMMON_MAC_ACCESS_CFG2_MAC_ENTRY_CPU_QU(0) | + LRN_COMMON_MAC_ACCESS_CFG2_MAC_ENTRY_VLD | + LRN_COMMON_MAC_ACCESS_CFG2_MAC_ENTRY_LOCKED, + priv->regs[LRN] + LRN_COMMON_MAC_ACCESS_CFG2); + + writel(LRN_COMMON_ACCESS_CTRL_MAC_TABLE_ACCESS_SHOT, + priv->regs[LRN] + LRN_COMMON_ACCESS_CTRL); + + return jr2_vlant_wait_for_completion(priv); +} + +static int jr2_write_hwaddr(struct udevice *dev) +{ + struct jr2_private *priv = dev_get_priv(dev); + struct eth_pdata *pdata = dev_get_platdata(dev); + + return jr2_mac_table_add(priv, pdata->enetaddr, PGID_UNICAST); +} + +static int jr2_start(struct udevice *dev) +{ + struct jr2_private *priv = dev_get_priv(dev); + struct eth_pdata *pdata = dev_get_platdata(dev); + const unsigned char mac[ETH_ALEN] = {0xff, 0xff, 0xff, 0xff, 0xff, + 0xff }; + int ret; + + ret = jr2_initialize(priv); + if (ret) + return ret; + + /* Set MAC address tables entries for CPU redirection */ + ret = jr2_mac_table_add(priv, mac, PGID_BROADCAST); + if (ret) + return ret; + + ret = jr2_mac_table_add(priv, pdata->enetaddr, PGID_UNICAST); + if (ret) + return ret; + + return 0; +} + +static void jr2_stop(struct udevice *dev) +{ +} + +static int jr2_send(struct udevice *dev, void *packet, int length) +{ + struct jr2_private *priv = dev_get_priv(dev); + u32 ifh[IFH_LEN]; + u32 *buf = packet; + + memset(ifh, '\0', IFH_LEN); + + /* Set DST PORT_MASK */ + ifh[0] = htonl(0); + ifh[1] = htonl(0x1FFFFF); + ifh[2] = htonl(~0); + /* Set DST_MODE to INJECT and UPDATE_FCS */ + ifh[5] = htonl(0x4c0); + + return mscc_send(priv->regs[QS], jr2_regs_qs, + ifh, IFH_LEN, buf, length); +} + +static int jr2_recv(struct udevice *dev, int flags, uchar **packetp) +{ + struct jr2_private *priv = dev_get_priv(dev); + u32 *rxbuf = (u32 *)net_rx_packets[0]; + int byte_cnt = 0; + + byte_cnt = mscc_recv(priv->regs[QS], jr2_regs_qs, rxbuf, IFH_LEN, + false); + + *packetp = net_rx_packets[0]; + + return byte_cnt; +} + +static struct mii_dev *get_mdiobus(phys_addr_t base, unsigned long size) +{ + int i = 0; + + for (i = 0; i < JR2_MIIM_BUS_COUNT; ++i) + if (miim[i].miim_base == base && miim[i].miim_size == size) + return miim[i].bus; + + return NULL; +} + +static void add_port_entry(struct jr2_private *priv, size_t index, + size_t phy_addr, struct mii_dev *bus) +{ + priv->ports[index].phy_addr = phy_addr; + priv->ports[index].bus = bus; +} + +static int jr2_probe(struct udevice *dev) +{ + struct jr2_private *priv = dev_get_priv(dev); + int i; + struct resource res; + fdt32_t faddr; + phys_addr_t addr_base; + unsigned long addr_size; + ofnode eth_node, node, mdio_node; + size_t phy_addr; + struct mii_dev *bus; + struct ofnode_phandle_args phandle; + struct phy_device *phy; + + if (!priv) + return -EINVAL; + + /* Get registers and map them to the private structure */ + for (i = 0; i < ARRAY_SIZE(regs_names); i++) { + priv->regs[i] = dev_remap_addr_name(dev, regs_names[i]); + if (!priv->regs[i]) { + debug + ("Error can't get regs base addresses for %s\n", + regs_names[i]); + return -ENOMEM; + } + } + + /* Initialize miim buses */ + memset(&miim, 0x0, sizeof(struct jr2_miim_dev) * JR2_MIIM_BUS_COUNT); + + /* iterate all the ports and find out on which bus they are */ + i = 0; + eth_node = dev_read_first_subnode(dev); + for (node = ofnode_first_subnode(eth_node); + ofnode_valid(node); + node = ofnode_next_subnode(node)) { + if (ofnode_read_resource(node, 0, &res)) + return -ENOMEM; + i = res.start; + + ofnode_parse_phandle_with_args(node, "phy-handle", NULL, 0, 0, + &phandle); + + /* Get phy address on mdio bus */ + if (ofnode_read_resource(phandle.node, 0, &res)) + return -ENOMEM; + phy_addr = res.start; + + /* Get mdio node */ + mdio_node = ofnode_get_parent(phandle.node); + + if (ofnode_read_resource(mdio_node, 0, &res)) + return -ENOMEM; + faddr = cpu_to_fdt32(res.start); + + addr_base = ofnode_translate_address(mdio_node, &faddr); + addr_size = res.end - res.start; + + /* If the bus is new then create a new bus */ + if (!get_mdiobus(addr_base, addr_size)) + priv->bus[miim_count] = + jr2_mdiobus_init(addr_base, addr_size); + + /* Connect mdio bus with the port */ + bus = get_mdiobus(addr_base, addr_size); + add_port_entry(priv, i, phy_addr, bus); + } + + for (i = 0; i < MAX_PORT; i++) { + if (!priv->ports[i].bus) + continue; + + phy = phy_connect(priv->ports[i].bus, + priv->ports[i].phy_addr, dev, + PHY_INTERFACE_MODE_NONE); + if (phy) + board_phy_config(phy); + } + + return 0; +} + +static int jr2_remove(struct udevice *dev) +{ + struct jr2_private *priv = dev_get_priv(dev); + int i; + + for (i = 0; i < JR2_MIIM_BUS_COUNT; i++) { + mdio_unregister(priv->bus[i]); + mdio_free(priv->bus[i]); + } + + return 0; +} + +static const struct eth_ops jr2_ops = { + .start = jr2_start, + .stop = jr2_stop, + .send = jr2_send, + .recv = jr2_recv, + .write_hwaddr = jr2_write_hwaddr, +}; + +static const struct udevice_id mscc_jr2_ids[] = { + {.compatible = "mscc,vsc7454-switch" }, + { /* Sentinel */ } +}; + +U_BOOT_DRIVER(jr2) = { + .name = "jr2-switch", + .id = UCLASS_ETH, + .of_match = mscc_jr2_ids, + .probe = jr2_probe, + .remove = jr2_remove, + .ops = &jr2_ops, + .priv_auto_alloc_size = sizeof(struct jr2_private), + .platdata_auto_alloc_size = sizeof(struct eth_pdata), +}; diff --git a/include/configs/vcoreiii.h b/include/configs/vcoreiii.h index 8c30c6f..5690146 100644 --- a/include/configs/vcoreiii.h +++ b/include/configs/vcoreiii.h @@ -10,7 +10,7 @@
/* Onboard devices */
-#define CONFIG_SYS_MALLOC_LEN 0x100000 +#define CONFIG_SYS_MALLOC_LEN 0x1F0000 #define CONFIG_SYS_LOAD_ADDR 0x00100000 #define CONFIG_SYS_INIT_SP_OFFSET 0x400000
In Jaguar2 SoC family there are 3 different pcb. Each of this needs to configure the SerDes and the phys in different ways. Therefore implement the function board_phy_config and serdes_cfg and based on pcb configure them accordingly.
Signed-off-by: Horatiu Vultur horatiu.vultur@microchip.com --- board/mscc/jr2/jr2.c | 542 +++++++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 542 insertions(+)
diff --git a/board/mscc/jr2/jr2.c b/board/mscc/jr2/jr2.c index 58a4a04..94e0c5d 100644 --- a/board/mscc/jr2/jr2.c +++ b/board/mscc/jr2/jr2.c @@ -6,6 +6,140 @@ #include <common.h> #include <asm/io.h> #include <led.h> +#include <miiphy.h> + +#define HSIO_ANA_SERDES1G_DES_CFG 0xac +#define HSIO_ANA_SERDES1G_DES_CFG_BW_HYST(x) ((x) << 1) +#define HSIO_ANA_SERDES1G_DES_CFG_BW_ANA(x) ((x) << 5) +#define HSIO_ANA_SERDES1G_DES_CFG_MBTR_CTRL(x) ((x) << 8) +#define HSIO_ANA_SERDES1G_DES_CFG_PHS_CTRL(x) ((x) << 13) +#define HSIO_ANA_SERDES1G_IB_CFG 0xb0 +#define HSIO_ANA_SERDES1G_IB_CFG_RESISTOR_CTRL(x) (x) +#define HSIO_ANA_SERDES1G_IB_CFG_EQ_GAIN(x) ((x) << 6) +#define HSIO_ANA_SERDES1G_IB_CFG_ENA_OFFSET_COMP BIT(9) +#define HSIO_ANA_SERDES1G_IB_CFG_ENA_DETLEV BIT(11) +#define HSIO_ANA_SERDES1G_IB_CFG_ENA_CMV_TERM BIT(13) +#define HSIO_ANA_SERDES1G_IB_CFG_DET_LEV(x) ((x) << 19) +#define HSIO_ANA_SERDES1G_IB_CFG_ACJTAG_HYST(x) ((x) << 24) +#define HSIO_ANA_SERDES1G_OB_CFG 0xb4 +#define HSIO_ANA_SERDES1G_OB_CFG_RESISTOR_CTRL(x) (x) +#define HSIO_ANA_SERDES1G_OB_CFG_VCM_CTRL(x) ((x) << 4) +#define HSIO_ANA_SERDES1G_OB_CFG_CMM_BIAS_CTRL(x) ((x) << 10) +#define HSIO_ANA_SERDES1G_OB_CFG_AMP_CTRL(x) ((x) << 13) +#define HSIO_ANA_SERDES1G_OB_CFG_SLP(x) ((x) << 17) +#define HSIO_ANA_SERDES1G_SER_CFG 0xb8 +#define HSIO_ANA_SERDES1G_COMMON_CFG 0xbc +#define HSIO_ANA_SERDES1G_COMMON_CFG_IF_MODE BIT(0) +#define HSIO_ANA_SERDES1G_COMMON_CFG_ENA_LANE BIT(18) +#define HSIO_ANA_SERDES1G_COMMON_CFG_SYS_RST BIT(31) +#define HSIO_ANA_SERDES1G_PLL_CFG 0xc0 +#define HSIO_ANA_SERDES1G_PLL_CFG_FSM_ENA BIT(7) +#define HSIO_ANA_SERDES1G_PLL_CFG_FSM_CTRL_DATA(x) ((x) << 8) +#define HSIO_ANA_SERDES1G_PLL_CFG_ENA_RC_DIV2 BIT(21) +#define HSIO_DIG_SERDES1G_DFT_CFG0 0xc8 +#define HSIO_DIG_SERDES1G_TP_CFG 0xd4 +#define HSIO_DIG_SERDES1G_MISC_CFG 0xdc +#define HSIO_DIG_SERDES1G_MISC_CFG_LANE_RST BIT(0) +#define HSIO_MCB_SERDES1G_CFG 0xe8 +#define HSIO_MCB_SERDES1G_CFG_WR_ONE_SHOT BIT(31) +#define HSIO_MCB_SERDES1G_CFG_ADDR(x) (x) + +#define HSIO_ANA_SERDES6G_DES_CFG 0x11c +#define HSIO_ANA_SERDES6G_DES_CFG_SWAP_ANA BIT(0) +#define HSIO_ANA_SERDES6G_DES_CFG_BW_ANA(x) ((x) << 1) +#define HSIO_ANA_SERDES6G_DES_CFG_SWAP_HYST BIT(4) +#define HSIO_ANA_SERDES6G_DES_CFG_BW_HYST(x) ((x) << 5) +#define HSIO_ANA_SERDES6G_DES_CFG_CPMD_SEL(x) ((x) << 8) +#define HSIO_ANA_SERDES6G_DES_CFG_MBTR_CTRL(x) ((x) << 10) +#define HSIO_ANA_SERDES6G_DES_CFG_PHS_CTRL(x) ((x) << 13) +#define HSIO_ANA_SERDES6G_IB_CFG 0x120 +#define HSIO_ANA_SERDES6G_IB_CFG_REG_ENA BIT(0) +#define HSIO_ANA_SERDES6G_IB_CFG_EQZ_ENA BIT(1) +#define HSIO_ANA_SERDES6G_IB_CFG_SAM_ENA BIT(2) +#define HSIO_ANA_SERDES6G_IB_CFG_CAL_ENA BIT(3) +#define HSIO_ANA_SERDES6G_IB_CFG_CONCUR BIT(4) +#define HSIO_ANA_SERDES6G_IB_CFG_SIG_DET_ENA BIT(5) +#define HSIO_ANA_SERDES6G_IB_CFG_REG_PAT_SEL_OFF(x) ((x) << 7) +#define HSIO_ANA_SERDES6G_IB_CFG_REG_PAT_SEL_LP(x) ((x) << 9) +#define HSIO_ANA_SERDES6G_IB_CFG_REG_PAT_SEL_MID(x) ((x) << 11) +#define HSIO_ANA_SERDES6G_IB_CFG_REG_PAT_SEL_HP(x) ((x) << 13) +#define HSIO_ANA_SERDES6G_IB_CFG_SIG_DET_CLK_SEL(x) ((x) << 15) +#define HSIO_ANA_SERDES6G_IB_CFG_TERM_MODE_SEL(x) ((x) << 18) +#define HSIO_ANA_SERDES6G_IB_CFG_ICML_ADJ(x) ((x) << 20) +#define HSIO_ANA_SERDES6G_IB_CFG_RTRM_ADJ(x) ((x) << 24) +#define HSIO_ANA_SERDES6G_IB_CFG_VBULK_SEL BIT(28) +#define HSIO_ANA_SERDES6G_IB_CFG_SOFSI(x) ((x) << 29) +#define HSIO_ANA_SERDES6G_IB_CFG1 0x124 +#define HSIO_ANA_SERDES6G_IB_CFG1_FILT_OFFSET BIT(4) +#define HSIO_ANA_SERDES6G_IB_CFG1_FILT_LP BIT(5) +#define HSIO_ANA_SERDES6G_IB_CFG1_FILT_MID BIT(6) +#define HSIO_ANA_SERDES6G_IB_CFG1_FILT_HP BIT(7) +#define HSIO_ANA_SERDES6G_IB_CFG1_SCALY(x) ((x) << 8) +#define HSIO_ANA_SERDES6G_IB_CFG1_TSDET(x) ((x) << 12) +#define HSIO_ANA_SERDES6G_IB_CFG1_TJTAG(x) ((x) << 17) +#define HSIO_ANA_SERDES6G_IB_CFG2 0x128 +#define HSIO_ANA_SERDES6G_IB_CFG2_UREG(x) (x) +#define HSIO_ANA_SERDES6G_IB_CFG2_UMAX(x) ((x) << 3) +#define HSIO_ANA_SERDES6G_IB_CFG2_TCALV(x) ((x) << 5) +#define HSIO_ANA_SERDES6G_IB_CFG2_OCALS(x) ((x) << 10) +#define HSIO_ANA_SERDES6G_IB_CFG2_OINFS(x) ((x) << 16) +#define HSIO_ANA_SERDES6G_IB_CFG2_OINFI(x) ((x) << 22) +#define HSIO_ANA_SERDES6G_IB_CFG2_TINFV(x) ((x) << 27) +#define HSIO_ANA_SERDES6G_IB_CFG3 0x12c +#define HSIO_ANA_SERDES6G_IB_CFG3_INI_OFFSET(x) (x) +#define HSIO_ANA_SERDES6G_IB_CFG3_INI_LP(x) ((x) << 6) +#define HSIO_ANA_SERDES6G_IB_CFG3_INI_MID(x) ((x) << 12) +#define HSIO_ANA_SERDES6G_IB_CFG3_INI_HP(x) ((x) << 18) +#define HSIO_ANA_SERDES6G_IB_CFG4 0x130 +#define HSIO_ANA_SERDES6G_IB_CFG4_MAX_OFFSET(x) (x) +#define HSIO_ANA_SERDES6G_IB_CFG4_MAX_LP(x) ((x) << 6) +#define HSIO_ANA_SERDES6G_IB_CFG4_MAX_MID(x) ((x) << 12) +#define HSIO_ANA_SERDES6G_IB_CFG4_MAX_HP(x) ((x) << 18) +#define HSIO_ANA_SERDES6G_IB_CFG5 0x134 +#define HSIO_ANA_SERDES6G_IB_CFG4_MIN_OFFSET(x) (x) +#define HSIO_ANA_SERDES6G_IB_CFG4_MIN_LP(x) ((x) << 6) +#define HSIO_ANA_SERDES6G_IB_CFG4_MIN_MID(x) ((x) << 12) +#define HSIO_ANA_SERDES6G_IB_CFG4_MIN_HP(x) ((x) << 18) +#define HSIO_ANA_SERDES6G_OB_CFG 0x138 +#define HSIO_ANA_SERDES6G_OB_CFG_RESISTOR_CTRL(x) (x) +#define HSIO_ANA_SERDES6G_OB_CFG_SR(x) ((x) << 4) +#define HSIO_ANA_SERDES6G_OB_CFG_SR_H BIT(8) +#define HSIO_ANA_SERDES6G_OB_CFG_SEL_RCTRL BIT(9) +#define HSIO_ANA_SERDES6G_OB_CFG_R_COR BIT(10) +#define HSIO_ANA_SERDES6G_OB_CFG_POST1(x) ((x) << 11) +#define HSIO_ANA_SERDES6G_OB_CFG_R_ADJ_PDR BIT(16) +#define HSIO_ANA_SERDES6G_OB_CFG_R_ADJ_MUX BIT(17) +#define HSIO_ANA_SERDES6G_OB_CFG_PREC(x) ((x) << 18) +#define HSIO_ANA_SERDES6G_OB_CFG_POST0(x) ((x) << 23) +#define HSIO_ANA_SERDES6G_OB_CFG_POL BIT(29) +#define HSIO_ANA_SERDES6G_OB_CFG_ENA1V_MODE BIT(30) +#define HSIO_ANA_SERDES6G_OB_CFG_IDLE BIT(31) +#define HSIO_ANA_SERDES6G_OB_CFG1 0x13c +#define HSIO_ANA_SERDES6G_OB_CFG1_LEV(x) (x) +#define HSIO_ANA_SERDES6G_OB_CFG1_ENA_CAS(x) ((x) << 6) +#define HSIO_ANA_SERDES6G_SER_CFG 0x140 +#define HSIO_ANA_SERDES6G_COMMON_CFG 0x144 +#define HSIO_ANA_SERDES6G_COMMON_CFG_IF_MODE(x) (x) +#define HSIO_ANA_SERDES6G_COMMON_CFG_QRATE BIT(2) +#define HSIO_ANA_SERDES6G_COMMON_CFG_ENA_LANE BIT(14) +#define HSIO_ANA_SERDES6G_COMMON_CFG_SYS_RST BIT(16) +#define HSIO_ANA_SERDES6G_PLL_CFG 0x148 +#define HSIO_ANA_SERDES6G_PLL_CFG_ROT_FRQ BIT(0) +#define HSIO_ANA_SERDES6G_PLL_CFG_ROT_DIR BIT(1) +#define HSIO_ANA_SERDES6G_PLL_CFG_RB_DATA_SEL BIT(2) +#define HSIO_ANA_SERDES6G_PLL_CFG_FSM_OOR_RECAL_ENA BIT(3) +#define HSIO_ANA_SERDES6G_PLL_CFG_FSM_FORCE_SET_ENA BIT(4) +#define HSIO_ANA_SERDES6G_PLL_CFG_FSM_ENA BIT(5) +#define HSIO_ANA_SERDES6G_PLL_CFG_FSM_CTRL_DATA(x) ((x) << 6) +#define HSIO_ANA_SERDES6G_PLL_CFG_ENA_ROT BIT(14) +#define HSIO_ANA_SERDES6G_PLL_CFG_DIV4 BIT(15) +#define HSIO_ANA_SERDES6G_PLL_CFG_ENA_OFFS(x) ((x) << 16) +#define HSIO_DIG_SERDES6G_MISC_CFG 0x108 +#define HSIO_DIG_SERDES6G_MISC_CFG_LANE_RST BIT(0) +#define HSIO_MCB_SERDES6G_CFG 0x168 +#define HSIO_MCB_SERDES6G_CFG_WR_ONE_SHOT BIT(31) +#define HSIO_MCB_SERDES6G_CFG_ADDR(x) (x) +#define HSIO_HW_CFGSTAT_HW_CFG 0x16c
enum { BOARD_TYPE_PCB110 = 0xAABBCE00, @@ -64,6 +198,414 @@ static void vcoreiii_gpio_set_alternate(int gpio, int mode) } }
+int board_phy_config(struct phy_device *phydev) +{ + if (gd->board_type == BOARD_TYPE_PCB110 || + gd->board_type == BOARD_TYPE_PCB112) { + phy_write(phydev, 0, 31, 0x10); + phy_write(phydev, 0, 18, 0x80F0); + while (phy_read(phydev, 0, 18) & 0x8000) + ; + phy_write(phydev, 0, 31, 0); + } + if (gd->board_type == BOARD_TYPE_PCB111) { + phy_write(phydev, 0, 31, 0x10); + phy_write(phydev, 0, 18, 0x80A0); + while (phy_read(phydev, 0, 18) & 0x8000) + ; + phy_write(phydev, 0, 14, 0x800); + phy_write(phydev, 0, 31, 0); + } + + return 0; +} + +static void serdes6g_write(void __iomem *base, u32 addr) +{ + u32 data; + + writel(HSIO_MCB_SERDES6G_CFG_WR_ONE_SHOT | + HSIO_MCB_SERDES6G_CFG_ADDR(addr), + base + HSIO_MCB_SERDES6G_CFG); + + do { + data = readl(base + HSIO_MCB_SERDES6G_CFG); + } while (data & HSIO_MCB_SERDES6G_CFG_WR_ONE_SHOT); + + mdelay(100); +} + +static void serdes6g_pcb111_cfg(void __iomem *base) +{ + /* sets serdes6g in QSGMII mode */ + writel(0xfff, base + HSIO_HW_CFGSTAT_HW_CFG); + + writel(HSIO_ANA_SERDES6G_COMMON_CFG_IF_MODE(3), + base + HSIO_ANA_SERDES6G_COMMON_CFG); + writel(HSIO_ANA_SERDES6G_PLL_CFG_FSM_CTRL_DATA(120) | + HSIO_ANA_SERDES6G_PLL_CFG_ENA_OFFS(3), + base + HSIO_ANA_SERDES6G_PLL_CFG); + writel(HSIO_ANA_SERDES6G_IB_CFG_REG_ENA | + HSIO_ANA_SERDES6G_IB_CFG_EQZ_ENA | + HSIO_ANA_SERDES6G_IB_CFG_SAM_ENA | + HSIO_ANA_SERDES6G_IB_CFG_CONCUR | + HSIO_ANA_SERDES6G_IB_CFG_SIG_DET_ENA | + HSIO_ANA_SERDES6G_IB_CFG_REG_PAT_SEL_OFF(0) | + HSIO_ANA_SERDES6G_IB_CFG_REG_PAT_SEL_LP(2) | + HSIO_ANA_SERDES6G_IB_CFG_REG_PAT_SEL_MID(1) | + HSIO_ANA_SERDES6G_IB_CFG_REG_PAT_SEL_HP(1) | + HSIO_ANA_SERDES6G_IB_CFG_SIG_DET_CLK_SEL(7) | + HSIO_ANA_SERDES6G_IB_CFG_TERM_MODE_SEL(1) | + HSIO_ANA_SERDES6G_IB_CFG_ICML_ADJ(5) | + HSIO_ANA_SERDES6G_IB_CFG_RTRM_ADJ(13) | + HSIO_ANA_SERDES6G_IB_CFG_VBULK_SEL | + HSIO_ANA_SERDES6G_IB_CFG_SOFSI(1), + base + HSIO_ANA_SERDES6G_IB_CFG); + writel(HSIO_ANA_SERDES6G_IB_CFG1_FILT_OFFSET | + HSIO_ANA_SERDES6G_IB_CFG1_FILT_LP | + HSIO_ANA_SERDES6G_IB_CFG1_FILT_MID | + HSIO_ANA_SERDES6G_IB_CFG1_FILT_HP | + HSIO_ANA_SERDES6G_IB_CFG1_SCALY(15) | + HSIO_ANA_SERDES6G_IB_CFG1_TSDET(3) | + HSIO_ANA_SERDES6G_IB_CFG1_TJTAG(8), + base + HSIO_ANA_SERDES6G_IB_CFG1); + writel(HSIO_DIG_SERDES6G_MISC_CFG_LANE_RST, + base + HSIO_DIG_SERDES6G_MISC_CFG); + + serdes6g_write(base, 0xfff0); + + writel(HSIO_ANA_SERDES6G_OB_CFG_RESISTOR_CTRL(1) | + HSIO_ANA_SERDES6G_OB_CFG_SR(7) | + HSIO_ANA_SERDES6G_OB_CFG_SR_H | + HSIO_ANA_SERDES6G_OB_CFG_POL, base + HSIO_ANA_SERDES6G_OB_CFG); + writel(HSIO_ANA_SERDES6G_OB_CFG1_LEV(24), + base + HSIO_ANA_SERDES6G_OB_CFG1); + writel(HSIO_ANA_SERDES6G_IB_CFG_REG_ENA | + HSIO_ANA_SERDES6G_IB_CFG_EQZ_ENA | + HSIO_ANA_SERDES6G_IB_CFG_SAM_ENA | + HSIO_ANA_SERDES6G_IB_CFG_CONCUR | + HSIO_ANA_SERDES6G_IB_CFG_SIG_DET_ENA | + HSIO_ANA_SERDES6G_IB_CFG_REG_PAT_SEL_OFF(0) | + HSIO_ANA_SERDES6G_IB_CFG_REG_PAT_SEL_LP(2) | + HSIO_ANA_SERDES6G_IB_CFG_REG_PAT_SEL_MID(1) | + HSIO_ANA_SERDES6G_IB_CFG_REG_PAT_SEL_HP(1) | + HSIO_ANA_SERDES6G_IB_CFG_SIG_DET_CLK_SEL(0) | + HSIO_ANA_SERDES6G_IB_CFG_TERM_MODE_SEL(1) | + HSIO_ANA_SERDES6G_IB_CFG_ICML_ADJ(5) | + HSIO_ANA_SERDES6G_IB_CFG_RTRM_ADJ(13) | + HSIO_ANA_SERDES6G_IB_CFG_VBULK_SEL | + HSIO_ANA_SERDES6G_IB_CFG_SOFSI(1), + base + HSIO_ANA_SERDES6G_IB_CFG); + writel(HSIO_ANA_SERDES6G_IB_CFG1_FILT_OFFSET | + HSIO_ANA_SERDES6G_IB_CFG1_FILT_LP | + HSIO_ANA_SERDES6G_IB_CFG1_FILT_MID | + HSIO_ANA_SERDES6G_IB_CFG1_FILT_HP | + HSIO_ANA_SERDES6G_IB_CFG1_SCALY(15) | + HSIO_ANA_SERDES6G_IB_CFG1_TSDET(16) | + HSIO_ANA_SERDES6G_IB_CFG1_TJTAG(8), + base + HSIO_ANA_SERDES6G_IB_CFG1); + writel(0x0, base + HSIO_ANA_SERDES6G_SER_CFG); + writel(HSIO_ANA_SERDES6G_COMMON_CFG_IF_MODE(3) | + HSIO_ANA_SERDES6G_COMMON_CFG_ENA_LANE | + HSIO_ANA_SERDES6G_COMMON_CFG_SYS_RST, + base + HSIO_ANA_SERDES6G_COMMON_CFG); + writel(HSIO_DIG_SERDES6G_MISC_CFG_LANE_RST, + base + HSIO_DIG_SERDES6G_MISC_CFG); + + serdes6g_write(base, 0xfff0); + + /* set pll_fsm_ena = 1 */ + writel(HSIO_ANA_SERDES6G_PLL_CFG_FSM_ENA | + HSIO_ANA_SERDES6G_PLL_CFG_FSM_CTRL_DATA(120) | + HSIO_ANA_SERDES6G_PLL_CFG_ENA_OFFS(3), + base + HSIO_ANA_SERDES6G_PLL_CFG); + + serdes6g_write(base, 0xfff0); + + /* wait 20ms for pll bringup */ + mdelay(20); + + /* start IB calibration by setting ib_cal_ena and clearing lane_rst */ + writel(HSIO_ANA_SERDES6G_IB_CFG_REG_ENA | + HSIO_ANA_SERDES6G_IB_CFG_EQZ_ENA | + HSIO_ANA_SERDES6G_IB_CFG_SAM_ENA | + HSIO_ANA_SERDES6G_IB_CFG_CAL_ENA | + HSIO_ANA_SERDES6G_IB_CFG_CONCUR | + HSIO_ANA_SERDES6G_IB_CFG_SIG_DET_ENA | + HSIO_ANA_SERDES6G_IB_CFG_REG_PAT_SEL_OFF(0) | + HSIO_ANA_SERDES6G_IB_CFG_REG_PAT_SEL_LP(2) | + HSIO_ANA_SERDES6G_IB_CFG_REG_PAT_SEL_MID(1) | + HSIO_ANA_SERDES6G_IB_CFG_REG_PAT_SEL_HP(1) | + HSIO_ANA_SERDES6G_IB_CFG_SIG_DET_CLK_SEL(0) | + HSIO_ANA_SERDES6G_IB_CFG_TERM_MODE_SEL(1) | + HSIO_ANA_SERDES6G_IB_CFG_ICML_ADJ(5) | + HSIO_ANA_SERDES6G_IB_CFG_RTRM_ADJ(13) | + HSIO_ANA_SERDES6G_IB_CFG_VBULK_SEL | + HSIO_ANA_SERDES6G_IB_CFG_SOFSI(1), + base + HSIO_ANA_SERDES6G_IB_CFG); + writel(0x0, base + HSIO_DIG_SERDES6G_MISC_CFG); + + serdes6g_write(base, 0xfff0); + + /* wait 60 for calibration */ + mdelay(60); + + /* set ib_tsdet and ib_reg_pat_sel_offset back to correct values */ + writel(HSIO_ANA_SERDES6G_IB_CFG_REG_ENA | + HSIO_ANA_SERDES6G_IB_CFG_EQZ_ENA | + HSIO_ANA_SERDES6G_IB_CFG_SAM_ENA | + HSIO_ANA_SERDES6G_IB_CFG_CAL_ENA | + HSIO_ANA_SERDES6G_IB_CFG_CONCUR | + HSIO_ANA_SERDES6G_IB_CFG_SIG_DET_ENA | + HSIO_ANA_SERDES6G_IB_CFG_REG_PAT_SEL_OFF(0) | + HSIO_ANA_SERDES6G_IB_CFG_REG_PAT_SEL_LP(2) | + HSIO_ANA_SERDES6G_IB_CFG_REG_PAT_SEL_MID(1) | + HSIO_ANA_SERDES6G_IB_CFG_REG_PAT_SEL_HP(1) | + HSIO_ANA_SERDES6G_IB_CFG_SIG_DET_CLK_SEL(7) | + HSIO_ANA_SERDES6G_IB_CFG_TERM_MODE_SEL(1) | + HSIO_ANA_SERDES6G_IB_CFG_ICML_ADJ(5) | + HSIO_ANA_SERDES6G_IB_CFG_RTRM_ADJ(13) | + HSIO_ANA_SERDES6G_IB_CFG_VBULK_SEL | + HSIO_ANA_SERDES6G_IB_CFG_SOFSI(1), + base + HSIO_ANA_SERDES6G_IB_CFG); + writel(HSIO_ANA_SERDES6G_IB_CFG1_FILT_OFFSET | + HSIO_ANA_SERDES6G_IB_CFG1_FILT_LP | + HSIO_ANA_SERDES6G_IB_CFG1_FILT_MID | + HSIO_ANA_SERDES6G_IB_CFG1_FILT_HP | + HSIO_ANA_SERDES6G_IB_CFG1_SCALY(15) | + HSIO_ANA_SERDES6G_IB_CFG1_TSDET(16) | + HSIO_ANA_SERDES6G_IB_CFG1_TJTAG(8), + base + HSIO_ANA_SERDES6G_IB_CFG1); + + serdes6g_write(base, 0xfff0); +} + +static void serdes6g_pcb112_cfg(void __iomem *base) +{ + /* sets serdes6g in SGMII mode */ + writel(HSIO_ANA_SERDES6G_COMMON_CFG_IF_MODE(3), + base + HSIO_ANA_SERDES6G_COMMON_CFG); + writel(HSIO_ANA_SERDES6G_PLL_CFG_FSM_CTRL_DATA(120) | + HSIO_ANA_SERDES6G_PLL_CFG_ENA_OFFS(3), + base + HSIO_ANA_SERDES6G_PLL_CFG); + writel(HSIO_ANA_SERDES6G_IB_CFG_REG_ENA | + HSIO_ANA_SERDES6G_IB_CFG_EQZ_ENA | + HSIO_ANA_SERDES6G_IB_CFG_SAM_ENA | + HSIO_ANA_SERDES6G_IB_CFG_CONCUR | + HSIO_ANA_SERDES6G_IB_CFG_SIG_DET_ENA | + HSIO_ANA_SERDES6G_IB_CFG_REG_PAT_SEL_OFF(0) | + HSIO_ANA_SERDES6G_IB_CFG_REG_PAT_SEL_LP(2) | + HSIO_ANA_SERDES6G_IB_CFG_REG_PAT_SEL_MID(1) | + HSIO_ANA_SERDES6G_IB_CFG_REG_PAT_SEL_HP(1) | + HSIO_ANA_SERDES6G_IB_CFG_SIG_DET_CLK_SEL(7) | + HSIO_ANA_SERDES6G_IB_CFG_TERM_MODE_SEL(1) | + HSIO_ANA_SERDES6G_IB_CFG_ICML_ADJ(5) | + HSIO_ANA_SERDES6G_IB_CFG_RTRM_ADJ(13) | + HSIO_ANA_SERDES6G_IB_CFG_VBULK_SEL | + HSIO_ANA_SERDES6G_IB_CFG_SOFSI(1), + base + HSIO_ANA_SERDES6G_IB_CFG); + writel(HSIO_ANA_SERDES6G_IB_CFG1_FILT_OFFSET | + HSIO_ANA_SERDES6G_IB_CFG1_FILT_LP | + HSIO_ANA_SERDES6G_IB_CFG1_FILT_MID | + HSIO_ANA_SERDES6G_IB_CFG1_FILT_HP | + HSIO_ANA_SERDES6G_IB_CFG1_SCALY(15) | + HSIO_ANA_SERDES6G_IB_CFG1_TSDET(3) | + HSIO_ANA_SERDES6G_IB_CFG1_TJTAG(8), + base + HSIO_ANA_SERDES6G_IB_CFG1); + writel(HSIO_DIG_SERDES6G_MISC_CFG_LANE_RST, + base + HSIO_DIG_SERDES6G_MISC_CFG); + + serdes6g_write(base, 0xf); + + writel(HSIO_ANA_SERDES6G_OB_CFG_RESISTOR_CTRL(1) | + HSIO_ANA_SERDES6G_OB_CFG_SR(7) | + HSIO_ANA_SERDES6G_OB_CFG_SR_H | + HSIO_ANA_SERDES6G_OB_CFG_POL | + HSIO_ANA_SERDES6G_OB_CFG_ENA1V_MODE, + base + HSIO_ANA_SERDES6G_OB_CFG); + writel(HSIO_ANA_SERDES6G_OB_CFG1_LEV(48) | + HSIO_ANA_SERDES6G_OB_CFG1_ENA_CAS(2), + base + HSIO_ANA_SERDES6G_OB_CFG1); + writel(HSIO_ANA_SERDES6G_DES_CFG_BW_ANA(3) | + HSIO_ANA_SERDES6G_DES_CFG_BW_HYST(5) | + HSIO_ANA_SERDES6G_DES_CFG_MBTR_CTRL(2) | + HSIO_ANA_SERDES6G_DES_CFG_PHS_CTRL(6), + base + HSIO_ANA_SERDES6G_DES_CFG); + writel(HSIO_ANA_SERDES6G_IB_CFG_REG_ENA | + HSIO_ANA_SERDES6G_IB_CFG_EQZ_ENA | + HSIO_ANA_SERDES6G_IB_CFG_SAM_ENA | + HSIO_ANA_SERDES6G_IB_CFG_CONCUR | + HSIO_ANA_SERDES6G_IB_CFG_SIG_DET_ENA | + HSIO_ANA_SERDES6G_IB_CFG_REG_PAT_SEL_OFF(0) | + HSIO_ANA_SERDES6G_IB_CFG_REG_PAT_SEL_LP(2) | + HSIO_ANA_SERDES6G_IB_CFG_REG_PAT_SEL_MID(1) | + HSIO_ANA_SERDES6G_IB_CFG_REG_PAT_SEL_HP(1) | + HSIO_ANA_SERDES6G_IB_CFG_SIG_DET_CLK_SEL(0) | + HSIO_ANA_SERDES6G_IB_CFG_TERM_MODE_SEL(1) | + HSIO_ANA_SERDES6G_IB_CFG_ICML_ADJ(5) | + HSIO_ANA_SERDES6G_IB_CFG_RTRM_ADJ(13) | + HSIO_ANA_SERDES6G_IB_CFG_VBULK_SEL | + HSIO_ANA_SERDES6G_IB_CFG_SOFSI(1), + base + HSIO_ANA_SERDES6G_IB_CFG); + writel(HSIO_ANA_SERDES6G_IB_CFG1_FILT_OFFSET | + HSIO_ANA_SERDES6G_IB_CFG1_FILT_LP | + HSIO_ANA_SERDES6G_IB_CFG1_FILT_MID | + HSIO_ANA_SERDES6G_IB_CFG1_FILT_HP | + HSIO_ANA_SERDES6G_IB_CFG1_SCALY(15) | + HSIO_ANA_SERDES6G_IB_CFG1_TSDET(16) | + HSIO_ANA_SERDES6G_IB_CFG1_TJTAG(8), + base + HSIO_ANA_SERDES6G_IB_CFG1); + writel(HSIO_ANA_SERDES6G_PLL_CFG_FSM_CTRL_DATA(60) | + HSIO_ANA_SERDES6G_PLL_CFG_ENA_OFFS(3), + base + HSIO_ANA_SERDES6G_PLL_CFG); + writel(HSIO_ANA_SERDES6G_COMMON_CFG_IF_MODE(1) | + HSIO_ANA_SERDES6G_COMMON_CFG_QRATE | + HSIO_ANA_SERDES6G_COMMON_CFG_ENA_LANE | + HSIO_ANA_SERDES6G_COMMON_CFG_SYS_RST, + base + HSIO_ANA_SERDES6G_COMMON_CFG); + writel(0x0, base + HSIO_ANA_SERDES6G_SER_CFG); + writel(HSIO_DIG_SERDES6G_MISC_CFG_LANE_RST, + base + HSIO_DIG_SERDES6G_MISC_CFG); + + serdes6g_write(base, 0xf); + + /* set pll_fsm_ena = 1 */ + writel(HSIO_ANA_SERDES6G_PLL_CFG_FSM_ENA | + HSIO_ANA_SERDES6G_PLL_CFG_FSM_CTRL_DATA(60) | + HSIO_ANA_SERDES6G_PLL_CFG_ENA_OFFS(3), + base + HSIO_ANA_SERDES6G_PLL_CFG); + + serdes6g_write(base, 0xf); + + /* wait 20ms for pll bringup */ + mdelay(20); + + /* start IB calibration by setting ib_cal_ena and clearing lane_rst */ + writel(HSIO_ANA_SERDES6G_IB_CFG_REG_ENA | + HSIO_ANA_SERDES6G_IB_CFG_EQZ_ENA | + HSIO_ANA_SERDES6G_IB_CFG_SAM_ENA | + HSIO_ANA_SERDES6G_IB_CFG_CONCUR | + HSIO_ANA_SERDES6G_IB_CFG_SIG_DET_ENA | + HSIO_ANA_SERDES6G_IB_CFG_REG_PAT_SEL_OFF(0) | + HSIO_ANA_SERDES6G_IB_CFG_REG_PAT_SEL_LP(2) | + HSIO_ANA_SERDES6G_IB_CFG_REG_PAT_SEL_MID(1) | + HSIO_ANA_SERDES6G_IB_CFG_REG_PAT_SEL_HP(1) | + HSIO_ANA_SERDES6G_IB_CFG_SIG_DET_CLK_SEL(0) | + HSIO_ANA_SERDES6G_IB_CFG_TERM_MODE_SEL(1) | + HSIO_ANA_SERDES6G_IB_CFG_ICML_ADJ(5) | + HSIO_ANA_SERDES6G_IB_CFG_RTRM_ADJ(13) | + HSIO_ANA_SERDES6G_IB_CFG_VBULK_SEL | + HSIO_ANA_SERDES6G_IB_CFG_SOFSI(1), + base + HSIO_ANA_SERDES6G_IB_CFG); + writel(0x0, base + HSIO_DIG_SERDES6G_MISC_CFG); + + serdes6g_write(base, 0xf); + + /* wait 60ms for calibration */ + mdelay(60); + + /* set ib_tsdet and ib_reg_pat_sel_offset back to correct values */ + writel(HSIO_ANA_SERDES6G_IB_CFG_REG_ENA | + HSIO_ANA_SERDES6G_IB_CFG_EQZ_ENA | + HSIO_ANA_SERDES6G_IB_CFG_SAM_ENA | + HSIO_ANA_SERDES6G_IB_CFG_CONCUR | + HSIO_ANA_SERDES6G_IB_CFG_SIG_DET_ENA | + HSIO_ANA_SERDES6G_IB_CFG_REG_PAT_SEL_OFF(0) | + HSIO_ANA_SERDES6G_IB_CFG_REG_PAT_SEL_LP(2) | + HSIO_ANA_SERDES6G_IB_CFG_REG_PAT_SEL_MID(1) | + HSIO_ANA_SERDES6G_IB_CFG_REG_PAT_SEL_HP(1) | + HSIO_ANA_SERDES6G_IB_CFG_SIG_DET_CLK_SEL(7) | + HSIO_ANA_SERDES6G_IB_CFG_TERM_MODE_SEL(1) | + HSIO_ANA_SERDES6G_IB_CFG_ICML_ADJ(5) | + HSIO_ANA_SERDES6G_IB_CFG_RTRM_ADJ(13) | + HSIO_ANA_SERDES6G_IB_CFG_VBULK_SEL | + HSIO_ANA_SERDES6G_IB_CFG_SOFSI(1), + base + HSIO_ANA_SERDES6G_IB_CFG); + writel(HSIO_ANA_SERDES6G_IB_CFG1_FILT_OFFSET | + HSIO_ANA_SERDES6G_IB_CFG1_FILT_LP | + HSIO_ANA_SERDES6G_IB_CFG1_FILT_MID | + HSIO_ANA_SERDES6G_IB_CFG1_FILT_HP | + HSIO_ANA_SERDES6G_IB_CFG1_SCALY(15) | + HSIO_ANA_SERDES6G_IB_CFG1_TSDET(3) | + HSIO_ANA_SERDES6G_IB_CFG1_TJTAG(8), + base + HSIO_ANA_SERDES6G_IB_CFG1); + + serdes6g_write(base, 0xf); +} + +static void serdes_write(void __iomem *base, u32 addr) +{ + u32 data; + + writel(HSIO_MCB_SERDES1G_CFG_WR_ONE_SHOT | + HSIO_MCB_SERDES1G_CFG_ADDR(addr), + base + HSIO_MCB_SERDES1G_CFG); + + do { + data = readl(base + HSIO_MCB_SERDES1G_CFG); + } while (data & HSIO_MCB_SERDES1G_CFG_WR_ONE_SHOT); + + mdelay(100); +} + +static void serdes1g_pcb110_cfg(void __iomem *base) +{ + writel(0x0, base + HSIO_ANA_SERDES1G_SER_CFG); + writel(0x0, base + HSIO_DIG_SERDES1G_TP_CFG); + writel(0x0, base + HSIO_DIG_SERDES1G_DFT_CFG0); + writel(HSIO_ANA_SERDES1G_OB_CFG_RESISTOR_CTRL(1) | + HSIO_ANA_SERDES1G_OB_CFG_VCM_CTRL(4) | + HSIO_ANA_SERDES1G_OB_CFG_CMM_BIAS_CTRL(2) | + HSIO_ANA_SERDES1G_OB_CFG_AMP_CTRL(12) | + HSIO_ANA_SERDES1G_OB_CFG_SLP(3), + base + HSIO_ANA_SERDES1G_OB_CFG); + writel(HSIO_ANA_SERDES1G_IB_CFG_RESISTOR_CTRL(13) | + HSIO_ANA_SERDES1G_IB_CFG_EQ_GAIN(2) | + HSIO_ANA_SERDES1G_IB_CFG_ENA_OFFSET_COMP | + HSIO_ANA_SERDES1G_IB_CFG_ENA_DETLEV | + HSIO_ANA_SERDES1G_IB_CFG_ENA_CMV_TERM | + HSIO_ANA_SERDES1G_IB_CFG_DET_LEV(3) | + HSIO_ANA_SERDES1G_IB_CFG_ACJTAG_HYST(1), + base + HSIO_ANA_SERDES1G_IB_CFG); + writel(HSIO_ANA_SERDES1G_DES_CFG_BW_HYST(7) | + HSIO_ANA_SERDES1G_DES_CFG_BW_ANA(6) | + HSIO_ANA_SERDES1G_DES_CFG_MBTR_CTRL(2) | + HSIO_ANA_SERDES1G_DES_CFG_PHS_CTRL(6), + base + HSIO_ANA_SERDES1G_DES_CFG); + writel(HSIO_DIG_SERDES1G_MISC_CFG_LANE_RST, + base + HSIO_DIG_SERDES1G_MISC_CFG); + writel(HSIO_ANA_SERDES1G_PLL_CFG_FSM_ENA | + HSIO_ANA_SERDES1G_PLL_CFG_FSM_CTRL_DATA(0xc8) | + HSIO_ANA_SERDES1G_PLL_CFG_ENA_RC_DIV2, + base + HSIO_ANA_SERDES1G_PLL_CFG); + writel(HSIO_ANA_SERDES1G_COMMON_CFG_IF_MODE | + HSIO_ANA_SERDES1G_COMMON_CFG_ENA_LANE | + HSIO_ANA_SERDES1G_COMMON_CFG_SYS_RST, + base + HSIO_ANA_SERDES1G_COMMON_CFG); + + serdes_write(base, 0x1fe); + + setbits_le32(base + HSIO_ANA_SERDES1G_COMMON_CFG, + HSIO_ANA_SERDES1G_COMMON_CFG_SYS_RST); + + serdes_write(base, 0x1fe); + + clrbits_le32(base + HSIO_DIG_SERDES1G_MISC_CFG, + HSIO_DIG_SERDES1G_MISC_CFG_LANE_RST); + + serdes_write(base, 0x1fe); +} + +void serdes_cfg(void __iomem *base) +{ + if (gd->board_type == BOARD_TYPE_PCB111) + return serdes6g_pcb111_cfg(base); + if (gd->board_type == BOARD_TYPE_PCB112) + return serdes6g_pcb112_cfg(base); + if (gd->board_type == BOARD_TYPE_PCB110) + return serdes1g_pcb110_cfg(base); +} + void board_debug_uart_init(void) { /* too early for the pinctrl driver, so configure the UART pins here */
Am 05.03.19 um 12:57 schrieb Horatiu Vultur:
what are the differences between all boards? Can't you model the different register values somehow as custom DT properties? This method looks like a lot of code duplication and doesn't scale well when adding new boards.
- if (gd->board_type == BOARD_TYPE_PCB110 ||
- if (gd->board_type == BOARD_TYPE_PCB111) {
- u32 data;
- writel(HSIO_MCB_SERDES6G_CFG_WR_ONE_SHOT |
- do {
- } while (data & HSIO_MCB_SERDES6G_CFG_WR_ONE_SHOT);
- mdelay(100);
- /* sets serdes6g in QSGMII mode */
- writel(0xfff, base + HSIO_HW_CFGSTAT_HW_CFG);
- writel(HSIO_ANA_SERDES6G_COMMON_CFG_IF_MODE(3),
- writel(HSIO_ANA_SERDES6G_PLL_CFG_FSM_CTRL_DATA(120) |
- writel(HSIO_ANA_SERDES6G_IB_CFG_REG_ENA |
- writel(HSIO_ANA_SERDES6G_IB_CFG1_FILT_OFFSET |
- writel(HSIO_DIG_SERDES6G_MISC_CFG_LANE_RST,
- serdes6g_write(base, 0xfff0);
- writel(HSIO_ANA_SERDES6G_OB_CFG_RESISTOR_CTRL(1) |
- writel(HSIO_ANA_SERDES6G_OB_CFG1_LEV(24),
- writel(0x0, base + HSIO_ANA_SERDES6G_SER_CFG);
- writel(HSIO_ANA_SERDES6G_COMMON_CFG_IF_MODE(3) |
- /* set pll_fsm_ena = 1 */
- writel(HSIO_ANA_SERDES6G_PLL_CFG_FSM_ENA |
- /* wait 20ms for pll bringup */
- mdelay(20);
- /* start IB calibration by setting ib_cal_ena and clearing lane_rst */
- writel(0x0, base + HSIO_DIG_SERDES6G_MISC_CFG);
- /* wait 60 for calibration */
- mdelay(60);
- /* set ib_tsdet and ib_reg_pat_sel_offset back to correct values */
- /* sets serdes6g in SGMII mode */
- serdes6g_write(base, 0xf);
- writel(HSIO_ANA_SERDES6G_OB_CFG1_LEV(48) |
- writel(HSIO_ANA_SERDES6G_DES_CFG_BW_ANA(3) |
- writel(HSIO_ANA_SERDES6G_PLL_CFG_FSM_CTRL_DATA(60) |
- writel(HSIO_ANA_SERDES6G_COMMON_CFG_IF_MODE(1) |
- mdelay(20);
- /* wait 60ms for calibration */
- mdelay(60);
- u32 data;
- writel(HSIO_MCB_SERDES1G_CFG_WR_ONE_SHOT |
- do {
- } while (data & HSIO_MCB_SERDES1G_CFG_WR_ONE_SHOT);
- mdelay(100);
- writel(0x0, base + HSIO_ANA_SERDES1G_SER_CFG);
- writel(0x0, base + HSIO_DIG_SERDES1G_TP_CFG);
- writel(0x0, base + HSIO_DIG_SERDES1G_DFT_CFG0);
- writel(HSIO_ANA_SERDES1G_OB_CFG_RESISTOR_CTRL(1) |
- writel(HSIO_ANA_SERDES1G_IB_CFG_RESISTOR_CTRL(13) |
- writel(HSIO_ANA_SERDES1G_DES_CFG_BW_HYST(7) |
- writel(HSIO_DIG_SERDES1G_MISC_CFG_LANE_RST,
- writel(HSIO_ANA_SERDES1G_PLL_CFG_FSM_ENA |
- writel(HSIO_ANA_SERDES1G_COMMON_CFG_IF_MODE |
- serdes_write(base, 0x1fe);
- setbits_le32(base + HSIO_ANA_SERDES1G_COMMON_CFG,
- clrbits_le32(base + HSIO_DIG_SERDES1G_MISC_CFG,
- if (gd->board_type == BOARD_TYPE_PCB112)
- if (gd->board_type == BOARD_TYPE_PCB110)
Hi Daniel,
So there are following boards: - pcb110: it has viper phys that are connected to serdes1g using the interface sgmii - pcb111: it has atom phys that are connected to serdes6g using the interface qsgmii - pcb112: it has viper phys that are connected to serdes6g using the interface sgmii.
Do you have an example where I can look, how to add this custom properties?
Yes, it looks like a lot code duplication, but there are only few differences between them. I was thinking maybe I can create 2 functions that configure the serdes1g and serdes6g which will get as a paramenter the interface mode. In this way I think it would scale better, because then each new board it would just call these new functions.
/Horatiu
- u32 data;
- do {
- mdelay(100);
- mdelay(20);
- mdelay(60);
- mdelay(20);
- mdelay(60);
- u32 data;
- do {
- mdelay(100);
- Daniel
Hi Horatio,
Am 06.03.19 um 23:11 schrieb Horatiu Vultur:
Hi Daniel,
/Horatiu
but this code belongs to the ethernet driver. Board specific differences like PHY interface or Serdes type could be configured via appropiate device-tree bindings (PHY interface already exists as generic binding). How do you plan to do it in Linux?
I've found Documentation/devicetree/bindings/phy/phy-ocelot-serdes.txt which looks very similar to what you want to achieve here. Maybe the Bootlin guys can give you some more hints ;)
- u32 data;
- do {
- mdelay(100);
- mdelay(20);
- mdelay(60);
- mdelay(20);
- mdelay(60);
- u32 data;
- do {
- mdelay(100);
- Daniel
Hi Daniel,
The 03/15/2019 13:02, Daniel Schwierzeck wrote:
External E-Mail
Hi Horatio,
Hi Daniel,
/Horatiu
I understand now. Currently there is no Jaguar2 support on the upstream kernel, maybe at a later point in time will come this.
I managed to talk with Alexandre and he proposed to have a look over the comphy inside the u-boot. Therefore I will have a look over this and I will send a new patch series. Thank you.
- u32 data;
- do {
- mdelay(100);
- mdelay(20);
- mdelay(60);
- mdelay(20);
- mdelay(60);
- u32 data;
- do {
- mdelay(100);
- Daniel
- Daniel
Add ethernet nodes for Jaguar2 SoCs family. There are 3 pcb in this family: pcb110, pcb111 and pcb112.
Signed-off-by: Horatiu Vultur horatiu.vultur@microchip.com --- arch/mips/dts/jr2_pcb110.dts | 67 ++++++++ arch/mips/dts/jr2_pcb111.dts | 352 +++++++++++++++++++++++++++++++++++++++ arch/mips/dts/mscc,jr2.dtsi | 106 ++++++++++++ arch/mips/dts/serval2_pcb112.dts | 39 +++++ 4 files changed, 564 insertions(+)
diff --git a/arch/mips/dts/jr2_pcb110.dts b/arch/mips/dts/jr2_pcb110.dts index ddc30ff..bd89f7c 100644 --- a/arch/mips/dts/jr2_pcb110.dts +++ b/arch/mips/dts/jr2_pcb110.dts @@ -72,3 +72,70 @@ sgpio-ports = <0x3f00ffff>; gpio-ranges = <&sgpio2 0 0 96>; }; + +&mdio1 { + status = "okay"; + + phy0: ethernet-phy@0 { + reg = <0>; + }; + phy1: ethernet-phy@1 { + reg = <1>; + }; + phy2: ethernet-phy@2 { + reg = <2>; + }; + phy3: ethernet-phy@3 { + reg = <3>; + }; + phy4: ethernet-phy@4 { + reg = <4>; + }; + phy5: ethernet-phy@5 { + reg = <5>; + }; + phy6: ethernet-phy@6 { + reg = <6>; + }; + phy7: ethernet-phy@7 { + reg = <7>; + }; +}; + +&switch { + ethernet-ports { + + port0: port@0 { + reg = <0>; + phy-handle = <&phy0>; + }; + port1: port@1 { + reg = <1>; + phy-handle = <&phy1>; + }; + port2: port@2 { + reg = <2>; + phy-handle = <&phy2>; + }; + port3: port@3 { + reg = <3>; + phy-handle = <&phy3>; + }; + port4: port@4 { + reg = <4>; + phy-handle = <&phy4>; + }; + port5: port@5 { + reg = <5>; + phy-handle = <&phy5>; + }; + port6: port@6 { + reg = <6>; + phy-handle = <&phy6>; + }; + port7: port@7 { + reg = <7>; + phy-handle = <&phy7>; + }; + }; +}; diff --git a/arch/mips/dts/jr2_pcb111.dts b/arch/mips/dts/jr2_pcb111.dts index 4d411b6..8b616c8 100644 --- a/arch/mips/dts/jr2_pcb111.dts +++ b/arch/mips/dts/jr2_pcb111.dts @@ -72,3 +72,355 @@ sgpio-ports = <0xff000000>; gpio-ranges = <&sgpio2 0 0 96>; }; + +&mdio1 { + status = "okay"; + + phy0: ethernet-phy@0 { + reg = <0>; + }; + phy1: ethernet-phy@1 { + reg = <1>; + }; + phy2: ethernet-phy@2 { + reg = <2>; + }; + phy3: ethernet-phy@3 { + reg = <3>; + }; + phy4: ethernet-phy@4 { + reg = <4>; + }; + phy5: ethernet-phy@5 { + reg = <5>; + }; + phy6: ethernet-phy@6 { + reg = <6>; + }; + phy7: ethernet-phy@7 { + reg = <7>; + }; + phy8: ethernet-phy@8 { + reg = <8>; + }; + phy9: ethernet-phy@9 { + reg = <9>; + }; + phy10: ethernet-phy@10 { + reg = <10>; + }; + phy11: ethernet-phy@11 { + reg = <11>; + }; + phy12: ethernet-phy@12 { + reg = <12>; + }; + phy13: ethernet-phy@13 { + reg = <13>; + }; + phy14: ethernet-phy@14 { + reg = <14>; + }; + phy15: ethernet-phy@15 { + reg = <15>; + }; + phy16: ethernet-phy@16 { + reg = <16>; + }; + phy17: ethernet-phy@17 { + reg = <17>; + }; + phy18: ethernet-phy@18 { + reg = <18>; + }; + phy19: ethernet-phy@19 { + reg = <19>; + }; + phy20: ethernet-phy@20 { + reg = <20>; + }; + phy21: ethernet-phy@21 { + reg = <21>; + }; + phy22: ethernet-phy@22 { + reg = <22>; + }; + phy23: ethernet-phy@23 { + reg = <23>; + }; +}; + +&mdio2 { + status = "okay"; + + phy24: ethernet-phy@24 { + reg = <0>; + }; + phy25: ethernet-phy@25 { + reg = <1>; + }; + phy26: ethernet-phy@26 { + reg = <2>; + }; + phy27: ethernet-phy@27 { + reg = <3>; + }; + phy28: ethernet-phy@28 { + reg = <4>; + }; + phy29: ethernet-phy@29 { + reg = <5>; + }; + phy30: ethernet-phy@30 { + reg = <6>; + }; + phy31: ethernet-phy@31 { + reg = <7>; + }; + phy32: ethernet-phy@32 { + reg = <8>; + }; + phy33: ethernet-phy@33 { + reg = <9>; + }; + phy34: ethernet-phy@34 { + reg = <10>; + }; + phy35: ethernet-phy@35 { + reg = <11>; + }; + phy36: ethernet-phy@36 { + reg = <12>; + }; + phy37: ethernet-phy@37 { + reg = <13>; + }; + phy38: ethernet-phy@38 { + reg = <14>; + }; + phy39: ethernet-phy@39 { + reg = <15>; + }; + phy40: ethernet-phy@40 { + reg = <16>; + }; + phy41: ethernet-phy@41 { + reg = <17>; + }; + phy42: ethernet-phy@42 { + reg = <18>; + }; + phy43: ethernet-phy@43 { + reg = <19>; + }; + phy44: ethernet-phy@44 { + reg = <20>; + }; + phy45: ethernet-phy@45 { + reg = <21>; + }; + phy46: ethernet-phy@46 { + reg = <22>; + }; + phy47: ethernet-phy@47 { + reg = <23>; + }; +}; + +&switch { + ethernet-ports { + port0: port@0 { + reg = <0>; + phy-handle = <&phy0>; + }; + port1: port@1 { + reg = <1>; + phy-handle = <&phy1>; + }; + port2: port@2 { + reg = <2>; + phy-handle = <&phy2>; + }; + port3: port@3 { + reg = <3>; + phy-handle = <&phy3>; + }; + port4: port@4 { + reg = <4>; + phy-handle = <&phy4>; + }; + port5: port@5 { + reg = <5>; + phy-handle = <&phy5>; + }; + port6: port@6 { + reg = <6>; + phy-handle = <&phy6>; + }; + port7: port@7 { + reg = <7>; + phy-handle = <&phy7>; + }; + port8: port@8 { + reg = <8>; + phy-handle = <&phy8>; + }; + port9: port@9 { + reg = <9>; + phy-handle = <&phy9>; + }; + port10: port@10 { + reg = <10>; + phy-handle = <&phy10>; + }; + port11: port@11 { + reg = <11>; + phy-handle = <&phy11>; + }; + port12: port@12 { + reg = <12>; + phy-handle = <&phy12>; + }; + port13: port@13 { + reg = <13>; + phy-handle = <&phy13>; + }; + port14: port@14 { + reg = <14>; + phy-handle = <&phy14>; + }; + port15: port@15 { + reg = <15>; + phy-handle = <&phy15>; + }; + port16: port@16 { + reg = <16>; + phy-handle = <&phy16>; + }; + port17: port@17 { + reg = <17>; + phy-handle = <&phy17>; + }; + port18: port@18 { + reg = <18>; + phy-handle = <&phy18>; + }; + port19: port@19 { + reg = <19>; + phy-handle = <&phy19>; + }; + port20: port@20 { + reg = <20>; + phy-handle = <&phy20>; + }; + port21: port@21 { + reg = <21>; + phy-handle = <&phy21>; + }; + port22: port@22 { + reg = <22>; + phy-handle = <&phy22>; + }; + port23: port@23 { + reg = <23>; + phy-handle = <&phy23>; + }; + port24: port@24 { + reg = <24>; + phy-handle = <&phy24>; + }; + port25: port@25 { + reg = <25>; + phy-handle = <&phy25>; + }; + port26: port@26 { + reg = <26>; + phy-handle = <&phy26>; + }; + port27: port@27 { + reg = <27>; + phy-handle = <&phy27>; + }; + port28: port@28 { + reg = <28>; + phy-handle = <&phy28>; + }; + port29: port@29 { + reg = <29>; + phy-handle = <&phy29>; + }; + port30: port@30 { + reg = <30>; + phy-handle = <&phy30>; + }; + port31: port@31 { + reg = <31>; + phy-handle = <&phy31>; + }; + port32: port@32 { + reg = <32>; + phy-handle = <&phy32>; + }; + port33: port@33 { + reg = <33>; + phy-handle = <&phy33>; + }; + port34: port@34 { + reg = <34>; + phy-handle = <&phy34>; + }; + port35: port@35 { + reg = <35>; + phy-handle = <&phy35>; + }; + port36: port@36 { + reg = <36>; + phy-handle = <&phy36>; + }; + port37: port@37 { + reg = <37>; + phy-handle = <&phy37>; + }; + port38: port@38 { + reg = <38>; + phy-handle = <&phy38>; + }; + port39: port@39 { + reg = <39>; + phy-handle = <&phy39>; + }; + port40: port@40 { + reg = <40>; + phy-handle = <&phy40>; + }; + port41: port@41 { + reg = <41>; + phy-handle = <&phy41>; + }; + port42: port@42 { + reg = <42>; + phy-handle = <&phy42>; + }; + port43: port@43 { + reg = <43>; + phy-handle = <&phy43>; + }; + port44: port@44 { + reg = <44>; + phy-handle = <&phy44>; + }; + port45: port@45 { + reg = <45>; + phy-handle = <&phy45>; + }; + port46: port@46 { + reg = <46>; + phy-handle = <&phy46>; + }; + port47: port@47 { + reg = <47>; + phy-handle = <&phy47>; + }; + + }; +}; diff --git a/arch/mips/dts/mscc,jr2.dtsi b/arch/mips/dts/mscc,jr2.dtsi index 0900926..9592b52 100644 --- a/arch/mips/dts/mscc,jr2.dtsi +++ b/arch/mips/dts/mscc,jr2.dtsi @@ -183,5 +183,111 @@ gpio-bank-name = "sgpio2_"; sgpio-clock = <0x14>; }; + + switch: switch@1010000 { + compatible = "mscc,vsc7454-switch"; + reg = <0x01040000 0x0100>, // VTSS_TO_DEV_0 + <0x01050000 0x0100>, // VTSS_TO_DEV_1 + <0x01060000 0x0100>, // VTSS_TO_DEV_2 + <0x01070000 0x0100>, // VTSS_TO_DEV_3 + <0x01080000 0x0100>, // VTSS_TO_DEV_4 + <0x01090000 0x0100>, // VTSS_TO_DEV_5 + <0x010a0000 0x0100>, // VTSS_TO_DEV_6 + <0x010b0000 0x0100>, // VTSS_TO_DEV_7 + <0x010c0000 0x0100>, // VTSS_TO_DEV_8 + <0x010d0000 0x0100>, // VTSS_TO_DEV_9 + <0x010e0000 0x0100>, // VTSS_TO_DEV_10 + <0x010f0000 0x0100>, // VTSS_TO_DEV_11 + <0x01100000 0x0100>, // VTSS_TO_DEV_12 + <0x01110000 0x0100>, // VTSS_TO_DEV_13 + <0x01120000 0x0100>, // VTSS_TO_DEV_14 + <0x01130000 0x0100>, // VTSS_TO_DEV_15 + <0x01140000 0x0100>, // VTSS_TO_DEV_16 + <0x01150000 0x0100>, // VTSS_TO_DEV_17 + <0x01160000 0x0100>, // VTSS_TO_DEV_18 + <0x01170000 0x0100>, // VTSS_TO_DEV_19 + <0x01180000 0x0100>, // VTSS_TO_DEV_20 + <0x01190000 0x0100>, // VTSS_TO_DEV_21 + <0x011a0000 0x0100>, // VTSS_TO_DEV_22 + <0x011b0000 0x0100>, // VTSS_TO_DEV_23 + <0x011c0000 0x0100>, // VTSS_TO_DEV_24 + <0x011d0000 0x0100>, // VTSS_TO_DEV_25 + <0x011e0000 0x0100>, // VTSS_TO_DEV_26 + <0x011f0000 0x0100>, // VTSS_TO_DEV_27 + <0x01200000 0x0100>, // VTSS_TO_DEV_28 + <0x01210000 0x0100>, // VTSS_TO_DEV_29 + <0x01220000 0x0100>, // VTSS_TO_DEV_30 + <0x01230000 0x0100>, // VTSS_TO_DEV_31 + <0x01240000 0x0100>, // VTSS_TO_DEV_32 + <0x01250000 0x0100>, // VTSS_TO_DEV_33 + <0x01260000 0x0100>, // VTSS_TO_DEV_34 + <0x01270000 0x0100>, // VTSS_TO_DEV_35 + <0x01280000 0x0100>, // VTSS_TO_DEV_36 + <0x01290000 0x0100>, // VTSS_TO_DEV_37 + <0x012a0000 0x0100>, // VTSS_TO_DEV_38 + <0x012b0000 0x0100>, // VTSS_TO_DEV_39 + <0x012c0000 0x0100>, // VTSS_TO_DEV_40 + <0x012d0000 0x0100>, // VTSS_TO_DEV_41 + <0x012e0000 0x0100>, // VTSS_TO_DEV_42 + <0x012f0000 0x0100>, // VTSS_TO_DEV_43 + <0x01300000 0x0100>, // VTSS_TO_DEV_44 + <0x01310000 0x0100>, // VTSS_TO_DEV_45 + <0x01320000 0x0100>, // VTSS_TO_DEV_46 + <0x01330000 0x0100>, // VTSS_TO_DEV_47 + <0x01f00000 0x100000>, // ANA_AC + <0x01d00000 0x100000>, // ANA_CL + <0x01e00000 0x100000>, // ANA_L2 + <0x01410000 0x10000>, // ASM + <0x01460000 0x10000>, // HSIO + <0x01420000 0x00000>, // LRN + <0x017d0000 0x10000>, // QFWD + <0x01020000 0x20000>, // QS + <0x017e0000 0x10000>, // QSYS + <0x01b00000 0x80000>; // REW + reg-names = "port0", "port1", "port2", "port3", "port4", + "port5", "port6", "port7", "port8", "port9", + "port10", "port11", "port12", "port13", + "port14", "port15", "port16", "port17", + "port18", "port19", "port20", "port21", + "port22", "port23", "port24", "port25", + "port26", "port27", "port28", "port29", + "port30", "port31", "port32", "port33", + "port34", "port35", "port36", "port37", + "port38", "port39", "port40", "port41", + "port42", "port43", "port44", "port45", + "port46", "port47", "ana_ac", "ana_cl", + "ana_l2", "asm", "hsio", "lrn", "qfwd", + "qs", "qsys", "rew"; + status = "okay"; + + ethernet-ports { + #address-cells = <1>; + #size-cells = <0>; + }; + }; + + mdio0: mdio@010100c8 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "mscc,jr2-miim"; + reg = <0x010100c8 0x24>; + status = "disabled"; + }; + + mdio1: mdio@010100ec { + #address-cells = <1>; + #size-cells = <0>; + compatible = "mscc,jr2-miim"; + reg = <0x010100ec 0x24>; + status = "disabled"; + }; + + mdio2: mdio@01010110 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "mscc,jr2-miim"; + reg = <0x01010110 0x24>; + status = "disabled"; + }; }; }; diff --git a/arch/mips/dts/serval2_pcb112.dts b/arch/mips/dts/serval2_pcb112.dts index fe025f4..3353a0b 100644 --- a/arch/mips/dts/serval2_pcb112.dts +++ b/arch/mips/dts/serval2_pcb112.dts @@ -58,3 +58,42 @@ status = "okay"; sgpio-ports = <0x3fe0ffff>; }; + +&mdio0 { + status = "okay"; + + phy16: ethernet-phy@16 { + reg = <16>; + }; + phy17: ethernet-phy@17 { + reg = <17>; + }; + phy18: ethernet-phy@18 { + reg = <18>; + }; + phy19: ethernet-phy@19 { + reg = <19>; + }; +}; + +&switch { + ethernet-ports { + + port0: port@0 { + reg = <24>; + phy-handle = <&phy16>; + }; + port1: port@1 { + reg = <25>; + phy-handle = <&phy17>; + }; + port2: port@2 { + reg = <26>; + phy-handle = <&phy18>; + }; + port3: port@3 { + reg = <27>; + phy-handle = <&phy19>; + }; + }; +};
Update default confing to use network driver for Jaguar2 SoCs.
Signed-off-by: Horatiu Vultur horatiu.vultur@microchip.com --- configs/mscc_jr2_defconfig | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/configs/mscc_jr2_defconfig b/configs/mscc_jr2_defconfig index 9276df2..d6e4bd4 100644 --- a/configs/mscc_jr2_defconfig +++ b/configs/mscc_jr2_defconfig @@ -28,7 +28,10 @@ CONFIG_CMD_MEMTEST=y CONFIG_CMD_GPIO=y CONFIG_CMD_SF=y CONFIG_CMD_SPI=y -# CONFIG_CMD_NET is not set +CONFIG_CMD_DHCP=y +# CONFIG_NET_TFTP_VARS is not set +# CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y CONFIG_CMD_MTDPARTS=y CONFIG_MTDIDS_DEFAULT="nor0=spi_flash" CONFIG_MTDPARTS_DEFAULT="mtdparts=spi_flash:1m(UBoot),256k(Env),256k(Env.bk)" @@ -62,3 +65,4 @@ CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_LZMA=y +CONFIG_MSCC_JR2_SWITCH=y
Daniel Schwierzeck
Horatiu Vultur
