[PATCH v2 0/5] Move video memory reservation for SPL to the
Move video memory reservation for SPL at end of RAM so that it does not interefere with reservations for next stage so that the next stage need not have holes in between for passed regions and instead it can maintain continuity in reservations.
Also catch the bloblist before starting reservations to avoid the same problem.
While at it, also fill missing fields in video handoff struct before passing it to next stage.
This is as per discussions at : For moving SPL framebuffer reservation at end of RAM:
https://lore.kernel.org/all/CAPnjgZ3xSoe_G3yrqwuAvoiVjUfZ+YQgkOR0ZTVXGT9VK8T...
For filling missing video handoff fields : https://lore.kernel.org/all/CAPnjgZ1Hs0rNf0JDirp6YPsOQ5=QqQSP9g9qRwLoOASUV8a...
Changelog (w.r.t previous RFC series that was sent before): V2: - Make a generic function to reserve video memory at SPL stage - Add debug prints while skipping framebuffer allocation at uboot - Correct commenting style as suggested
Previous RFC series: https://lore.kernel.org/all/20231016160611.1353458-1-devarsht@ti.com/
Test logs (at tip of U-Boot 2024.01-rc1+ this series (with debugs)): https://gist.github.com/devarsht/43dbcc02c585a0b18f8f99e910bf5ef9
Devarsh Thakkar (5): arm: mach-k3: common: Reserve video memory from end of the RAM board: ti: am62x: evm: Remove video_setup from spl_board_init common/board_f: Catch bloblist before starting resevations video: Skip framebuffer reservation if already reserved video: Fill video handoff in video post probe
arch/arm/mach-k3/common.c | 2 ++ board/ti/am62x/evm.c | 18 ------------------ common/board_f.c | 33 +++++++++++++++++++++++++++++--- common/spl/spl.c | 19 ++++++++++++++++++ drivers/video/video-uclass.c | 37 ++++++++++++++++++++++++++---------- include/spl.h | 4 ++++ 6 files changed, 82 insertions(+), 31 deletions(-)
Add function spl_reserve_video which is a wrapper around video_reserve to setup video memory and update the relocation address pointer.
Setup video memory before page table reservation so that framebuffer memory gets reserved from the end of RAM.
This is as per the new policy being discussed for passing blobs where each of the reserved areas for bloblists to be passed need to be reserved at the end of RAM.
This is done to enable the next stage to directly skip the pre-reserved area from previous stage right from the end of RAM without having to make any gaps/holes to accommodate those regions which was the case before as previous stage reserved region not from the end of RAM.
Suggested-by: Simon Glass sjg@chromium.org Signed-off-by: Devarsh Thakkar devarsht@ti.com --- V2: Make a generic function "spl_reserve_video" under common/spl which can be re-used by other platforms too for reserving video memory from spl. --- arch/arm/mach-k3/common.c | 2 ++ common/spl/spl.c | 19 +++++++++++++++++++ include/spl.h | 4 ++++ 3 files changed, 25 insertions(+)
diff --git a/arch/arm/mach-k3/common.c b/arch/arm/mach-k3/common.c index c3006ba387..03e3b46282 100644 --- a/arch/arm/mach-k3/common.c +++ b/arch/arm/mach-k3/common.c @@ -537,6 +537,8 @@ void spl_enable_dcache(void) if (ram_top >= 0x100000000) ram_top = (phys_addr_t) 0x100000000;
+ gd->relocaddr = ram_top; + spl_reserve_video(); gd->arch.tlb_addr = ram_top - gd->arch.tlb_size; gd->arch.tlb_addr &= ~(0x10000 - 1); debug("TLB table from %08lx to %08lx\n", gd->arch.tlb_addr, diff --git a/common/spl/spl.c b/common/spl/spl.c index 732d90d39e..89172f2ebf 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -41,6 +41,7 @@ #include <fdt_support.h> #include <bootcount.h> #include <wdt.h> +#include <video.h>
DECLARE_GLOBAL_DATA_PTR; DECLARE_BINMAN_MAGIC_SYM; @@ -151,6 +152,24 @@ void spl_fixup_fdt(void *fdt_blob) #endif }
+int spl_reserve_video(void) +{ + if (CONFIG_IS_ENABLED(VIDEO)) { + ulong addr; + int ret; + + addr = gd->relocaddr; + ret = video_reserve(&addr); + if (ret) + return ret; + debug("Reserving %luk for video at: %08lx\n", + ((unsigned long)gd->relocaddr - addr) >> 10, addr); + gd->relocaddr = addr; + } + + return 0; +} + ulong spl_get_image_pos(void) { if (!CONFIG_IS_ENABLED(BINMAN_UBOOT_SYMBOLS)) diff --git a/include/spl.h b/include/spl.h index 0d49e4a454..9682e51fc1 100644 --- a/include/spl.h +++ b/include/spl.h @@ -825,6 +825,10 @@ int spl_usb_load(struct spl_image_info *spl_image,
int spl_ymodem_load_image(struct spl_image_info *spl_image, struct spl_boot_device *bootdev); +/** + * spl_reserve_video() - Reserve video and update relocation address + */ +int spl_reserve_video(void);
/** * spl_invoke_atf - boot using an ARM trusted firmware image
Hi Devarsh,
Need to check error here
ulong addr;
int ret;
if (ret)
return ret;
- spl_reserve_video() - Reserve video and update relocation address
This needs more detail about: - gd->relocaddr - where the video memory is allocated - where the allocation is stored (in the video-device plat?) - return value
- spl_invoke_atf - boot using an ARM trusted firmware image
-- 2.34.1
Hi Simon,
Thanks for the review.
On 03/11/23 04:16, Simon Glass wrote:
Hi Devarsh,
Ok, I can check for error and print a message, but would still proceed with build (similar to reserve_video in u-boot proper (from which this is derived)), I hope that is fine.
ulong addr;
int ret;
if (ret)
return ret;
- ulong spl_get_image_pos(void) { if (!CONFIG_IS_ENABLED(BINMAN_UBOOT_SYMBOLS))
- gd->relocaddr
Points to current relocation address which points to region below reserved area ?
I didn't get you, allocation is stored in RAM, is that what you mean ?
- where the allocation is stored (in the video-device plat?)ok
- return value
Just a point of note, this spl_reserve_video is inspired by reserve_video from u-boot proper and we are essentially leaving upto users to follow the "guideline" to reserve video from RAM by setting gd->relocaddr to end of RAM before calling to function.
But if we want to directly enforce the guideline, I can move that logic inside this API and we can have spl_reserve_video_from_ramtop, let me know your opinion on this if we want to go this way.
Regards Devarsh
-- 2.34.1
Hi Devarsh,
On Fri, 3 Nov 2023 at 11:48, Devarsh Thakkar devarsht@ti.com wrote:
Hi Simon,
Hi Devarsh,
No, we need to fail if something is wrong.
ulong addr;
int ret;
if (ret)
return ret;
- gd->relocaddr
Yes, but specifically at the top of RAM, I believe?
- return value
That seems OK to me, so far as I understand what you are saying.
Hi Simon,
On 05/11/23 01:13, Simon Glass wrote:
Hi Devarsh,
Hi Simon,
Hi Devarsh,
Yes the caller of the function is having void return value so can't propagate it but I can still do a exit or hang. But besides this the API as such returns the success/failure and it is left upto user to decide. As the user in this case is TI (mack-k3) the previous behavior was preserved where it proceed with boot on video reservation failure, I guess I will check again with more folks here at TI and based on that take a decision.
ulong addr;
int ret;
if (ret)
return ret;
- gd->relocaddr
- return value
Ok, will make it spl_video_reserve_from_ram_top, thanks!.
Regards Devarsh
Remove video_setup from evm_init sequence since video memory is getting called at an earlier place to make sure video memory is reserved at the end of RAM.
Suggested-by: Simon Glass sjg@chromium.org Signed-off-by: Devarsh Thakkar devarsht@ti.com --- V2: No change --- board/ti/am62x/evm.c | 18 ------------------ 1 file changed, 18 deletions(-)
diff --git a/board/ti/am62x/evm.c b/board/ti/am62x/evm.c index ad93908840..88e02155ee 100644 --- a/board/ti/am62x/evm.c +++ b/board/ti/am62x/evm.c @@ -60,27 +60,9 @@ int dram_init_banksize(void) }
#if defined(CONFIG_SPL_BUILD) -static int video_setup(void) -{ - if (CONFIG_IS_ENABLED(VIDEO)) { - ulong addr; - int ret; - - addr = gd->relocaddr; - ret = video_reserve(&addr); - if (ret) - return ret; - debug("Reserving %luk for video at: %08lx\n", - ((unsigned long)gd->relocaddr - addr) >> 10, addr); - gd->relocaddr = addr; - } - - return 0; -}
void spl_board_init(void) { - video_setup(); enable_caches(); if (IS_ENABLED(CONFIG_SPL_SPLASH_SCREEN) && IS_ENABLED(CONFIG_SPL_BMP)) splash_display();
Start reservations needed for init sequence only after catching bloblists from previous stage.
This is to avoid catching bloblists in the middle causing gaps while u-boot is reserving.
Adjust the relocaddr as per video hand-off information received from previous stage so that further reservations start only after regions reserved for previous stages
Skip reservation for video memory if it was already filled by a bloblist.
Signed-off-by: Devarsh Thakkar devarsht@ti.com --- V2: Fix typo in commit title and checkpatch warnings/checks --- common/board_f.c | 33 ++++++++++++++++++++++++++++++--- 1 file changed, 30 insertions(+), 3 deletions(-)
diff --git a/common/board_f.c b/common/board_f.c index d4d7d01f8f..acf802c9cb 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -403,7 +403,7 @@ __weak int arch_reserve_mmu(void) return 0; }
-static int reserve_video(void) +static int reserve_video_from_videoblob(void) { if (IS_ENABLED(CONFIG_SPL_VIDEO_HANDOFF) && spl_phase() > PHASE_SPL) { struct video_handoff *ho; @@ -412,8 +412,34 @@ static int reserve_video(void) if (!ho) return log_msg_ret("blf", -ENOENT); video_reserve_from_bloblist(ho); - gd->relocaddr = ho->fb; - } else if (CONFIG_IS_ENABLED(VIDEO)) { + + /* Sanity check fb from blob is before current relocaddr */ + if (likely(gd->relocaddr > (unsigned long)ho->fb)) + gd->relocaddr = ho->fb; + } + + return 0; +} + +/* + * Check if any bloblist received specifying reserved areas from previous stage and adjust + * gd->relocaddr accordingly, so that we start reserving after pre-reserved areas + * from previous stage. + * + * NOTE: + * IT is recommended that all bloblists from previous stage are reserved from ram_top + * as next stage will simply start reserving further regions after them. + */ +static int setup_relocaddr_from_bloblist(void) +{ + reserve_video_from_videoblob(); + + return 0; +} + +static int reserve_video(void) +{ + if (CONFIG_IS_ENABLED(VIDEO)) { ulong addr; int ret;
@@ -923,6 +949,7 @@ static const init_fnc_t init_sequence_f[] = { reserve_pram, #endif reserve_round_4k, + setup_relocaddr_from_bloblist, arch_reserve_mmu, reserve_video, reserve_trace,
Hi Devarsh,
- Check if any bloblist received specifying reserved areas from previous stage and adjust
- gd->relocaddr accordingly, so that we start reserving after pre-reserved areas
- from previous stage.
- NOTE:
- IT is recommended that all bloblists from previous stage are reserved from ram_top
- as next stage will simply start reserving further regions after them.
But you have renamed this function, so how does this commit build?
buildman -b <branch> --board sandbox_spl
might help?
reserve_trace,
-- 2.34.1
Hi Simon,
Hi Devarsh,
- NOTE:
[1] Here.
Sorry I didn't get you, maybe the diff is creating an illusion, this is a new function to reserve from bloblist and a wrapper around reserve_video_from_bloblist. I created the wrapper so that in future if any new blobs are getting passed they can be added inside this (they need to be after video region which is from end of ram) and relocaddr adjusted accordingly before proceeding with uboot proper reservations. This is inline with our strategy to have SPL regions reserved from end of RAM so that uboot starts reserving right after them.
The existing function to reserve_video is still there [1]
I remember testing this with make and also testing the functionality part of it, will try check with this command too.
Regards Devarsh
might help?
reserve_trace,
-- 2.34.1
Skip framebufer reservation if it was already reserved from previous stage and whose information was passed using a bloblist.
Signed-off-by: Devarsh Thakkar devarsht@ti.com Reviewed-by: Simon Glass sjg@chromium.org --- V2: - Add debug prints - Fix commenting style --- drivers/video/video-uclass.c | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/drivers/video/video-uclass.c b/drivers/video/video-uclass.c index f743ed74c8..335a1a1828 100644 --- a/drivers/video/video-uclass.c +++ b/drivers/video/video-uclass.c @@ -123,6 +123,18 @@ int video_reserve(ulong *addrp) struct udevice *dev; ulong size;
+ if (IS_ENABLED(CONFIG_SPL_VIDEO_HANDOFF) && spl_phase() > PHASE_SPL) { + /* Skip allocation if already received a bloblist which + * filled below fields + */ + if (gd->fb_base && gd->video_top && gd->video_bottom) { + debug("Found pre-reserved video memory from %lx to %lx\n", + gd->video_bottom, gd->video_top); + debug("Skipping video frame buffer allocation\n"); + return 0; + } + } + gd->video_top = *addrp; for (uclass_find_first_device(UCLASS_VIDEO, &dev); dev;
V2:
- Add debug prints
comment style
/* * Skip ...
-- 2.34.1
Hi Simon,
V2:
- Add debug prints
comment style
- Skip ...
Oops, thanks for the nitpick, will correct this, I wonder why checkpatch didn't catch this :)
Regards Devarsh
-- 2.34.1
Fill video handoff fields in video_post_probe as at this point we have full framebuffer related information.
Also fill all the fields available in video hand-off struct as those were missing earlier and u-boot framework expects them to be filled for some of the functionalities.
Reported-by: Simon Glass sjg@chromium.org Signed-off-by: Devarsh Thakkar devarsht@ti.com --- V2: No change --- drivers/video/video-uclass.c | 25 +++++++++++++++---------- 1 file changed, 15 insertions(+), 10 deletions(-)
diff --git a/drivers/video/video-uclass.c b/drivers/video/video-uclass.c index 335a1a1828..635b70f668 100644 --- a/drivers/video/video-uclass.c +++ b/drivers/video/video-uclass.c @@ -153,16 +153,6 @@ int video_reserve(ulong *addrp) debug("Video frame buffers from %lx to %lx\n", gd->video_bottom, gd->video_top);
- if (spl_phase() == PHASE_SPL && CONFIG_IS_ENABLED(VIDEO_HANDOFF)) { - struct video_handoff *ho; - - ho = bloblist_add(BLOBLISTT_U_BOOT_VIDEO, sizeof(*ho), 0); - if (!ho) - return log_msg_ret("blf", -ENOENT); - ho->fb = *addrp; - ho->size = size; - } - return 0; }
@@ -558,6 +548,21 @@ static int video_post_probe(struct udevice *dev)
priv->fb_size = priv->line_length * priv->ysize;
+ /* Set up video handoff fields for passing video blob to next stage */ + if (spl_phase() == PHASE_SPL && CONFIG_IS_ENABLED(BLOBLIST)) { + struct video_handoff *ho; + + ho = bloblist_add(BLOBLISTT_U_BOOT_VIDEO, sizeof(*ho), 0); + if (!ho) + return log_msg_ret("blf", -ENOENT); + ho->fb = gd->video_bottom; + ho->size = gd->video_top - gd->video_bottom; + ho->xsize = priv->xsize; + ho->ysize = priv->ysize; + ho->line_length = priv->line_length; + ho->bpix = priv->bpix; + } + if (IS_ENABLED(CONFIG_VIDEO_COPY) && plat->copy_base) priv->copy_fb = map_sysmem(plat->copy_base, plat->size);
Hi Devarsh,
framebuffer-related
information.
U-Boot
V2: No change
if (!ho)
ho->fb = *addrp;
ho->size = size;
You also need to fill out the other fields in there:
struct video_handoff { u64 fb; u32 size; u16 xsize; u16 ysize; u32 line_length; u8 bpix; };
if (!ho)
This is a bit odd, since it assumes there is a single video framebuffer. I suppose that is normally the case, but please add a comment saying that only one is supported.
-- 2.34.1
Please can you add some documentation to doc/develop/spl.rst or similar?
Devarsh Thakkar
