[U-Boot] [PATCH] fsl_diu: fix alignment error that caused malloc corruption
commit 81489a85c4c3536ec54290ac9216b746ec346663 Author: Nikita V. Youshchenko yoush@debian.org Date: Thu Sep 25 00:44:00 2008 +0400
When aligning malloc()ed screen_base, invalid offset was added. This not only caused misaligned result (which did not cause hardware misbehaviour), but - worse - caused screen_base + smem_len to be out of malloc()ed space, which in turn caused breakage of futher malloc()/free() operation.
This patch fixes screen_base alignment.
Also this patch makes memset() that cleans framebuffer to be executed on first initialization of diu, not only on re-initialization. It looks correct to clean the framebuffer instead of displaying random garbage; I believe that was disabled only because that memset caused breakage of malloc/free described above - which no longer happens with the fix described above.
Signed-off-by: Nikita V. Youshchenko yoush@debian.org
diff --git a/board/freescale/common/fsl_diu_fb.c b/board/freescale/common/fsl_diu_fb.c index 75f782e..4d4b0a1 100644 --- a/board/freescale/common/fsl_diu_fb.c +++ b/board/freescale/common/fsl_diu_fb.c @@ -242,10 +242,10 @@ int fsl_diu_init(int xres, printf("Unable to allocate fb memory 1\n"); return -1; } - } else { - memset(info->screen_base, 0, info->smem_len); }
+ memset(info->screen_base, 0, info->smem_len); + dr.diu_reg->desc[0] = (unsigned int) &dummy_ad; dr.diu_reg->desc[1] = (unsigned int) &dummy_ad; dr.diu_reg->desc[2] = (unsigned int) &dummy_ad; @@ -403,7 +403,7 @@ static int map_video_memory(struct fb_info *info, unsigned long bytes_align) mask = bytes_align - 1; offset = (unsigned long)info->screen_base & mask; if (offset) { - info->screen_base += offset; + info->screen_base += (bytes_align - offset); info->smem_len = info->smem_len - (bytes_align - offset); } else info->smem_len = info->smem_len - bytes_align;
Dear "Nikita V. Youshchenko",
fsl_diu: fix alignment error that caused malloc corruption When aligning malloc()ed screen_base, invalid offset was added. This not only caused misaligned result (which did not cause hardware misbehaviour), but - worse - caused screen_base + smem_len to be out of malloc()ed space, which in turn caused breakage of futher malloc()/free() operation. This patch fixes screen_base alignment. Also this patch makes memset() that cleans framebuffer to be executed on first initialization of diu, not only on re-initialization. It looks correct to clean the framebuffer instead of displaying random garbage; I believe that was disabled only because that memset caused breakage of malloc/free described above - which no longer happens with the fix described above. Signed-off-by: Nikita V. Youshchenko <yoush@debian.org>
The indentation of the commit message is wrong.
Please use git-format-patch to create patches.
Applied, thanks.
