[PATCH] riscv: Add Zbb support for building U-Boot
This patch adds ISA string to the -march to generate zbb instructions for U-Boot binaries, along with optimized string functions introduced from Linux kernel.
Signed-off-by: Yu Chien Peter Lin peterlin@andestech.com --- arch/riscv/Kconfig | 92 +++++++++++++++++++++++++++++ arch/riscv/Makefile | 5 +- arch/riscv/include/asm/string.h | 18 ++++++ arch/riscv/lib/Makefile | 3 + arch/riscv/lib/strcmp_zbb.S | 81 +++++++++++++++++++++++++ arch/riscv/lib/strlen_zbb.S | 101 ++++++++++++++++++++++++++++++++ arch/riscv/lib/strncmp_zbb.S | 94 +++++++++++++++++++++++++++++ 7 files changed, 393 insertions(+), 1 deletion(-) create mode 100644 arch/riscv/lib/strcmp_zbb.S create mode 100644 arch/riscv/lib/strlen_zbb.S create mode 100644 arch/riscv/lib/strncmp_zbb.S
diff --git a/arch/riscv/Kconfig b/arch/riscv/Kconfig index 867cbcbe74..49dd714e99 100644 --- a/arch/riscv/Kconfig +++ b/arch/riscv/Kconfig @@ -177,6 +177,98 @@ config RISCV_ISA_D riscv32 ABI from ilp32 to ilp32d and the riscv64 ABI from lp64 to lp64d.
+config RISCV_ISA_ZBB + bool "Zbb extension support for bit manipulation instructions" + default n + help + Adds ZBB extension (basic bit manipulation) to the ISA subsets + that the toolchain is allowed to emit when building U-Boot. + The Zbb extension provides instructions to accelerate a number + of bit-specific operations (count bit population, sign extending, + bitrotation, etc) and enables optimized string routines. + +menu "Use assembly optimized implementation of string routines" + +config USE_ARCH_STRLEN + bool "Use an assembly optimized implementation of strlen" + default y + depends on RISCV_ISA_ZBB + help + Enable the generation of an optimized version of strlen using + Zbb extension. + +config SPL_USE_ARCH_STRLEN + bool "Use an assembly optimized implementation of strlen for SPL" + default y if USE_ARCH_STRLEN + depends on RISCV_ISA_ZBB + depends on SPL + help + Enable the generation of an optimized version of strlen using + Zbb extension. + +config TPL_USE_ARCH_STRLEN + bool "Use an assembly optimized implementation of strlen for TPL" + default y if USE_ARCH_STRLEN + depends on RISCV_ISA_ZBB + depends on TPL + help + Enable the generation of an optimized version of strlen using + Zbb extension. + +config USE_ARCH_STRCMP + bool "Use an assembly optimized implementation of strcmp" + default y + depends on RISCV_ISA_ZBB + help + Enable the generation of an optimized version of strcmp using + Zbb extension. + +config SPL_USE_ARCH_STRCMP + bool "Use an assembly optimized implementation of strcmp for SPL" + default y if USE_ARCH_STRCMP + depends on RISCV_ISA_ZBB + depends on SPL + help + Enable the generation of an optimized version of strcmp using + Zbb extension. + +config TPL_USE_ARCH_STRCMP + bool "Use an assembly optimized implementation of strcmp for TPL" + default y if USE_ARCH_STRCMP + depends on RISCV_ISA_ZBB + depends on TPL + help + Enable the generation of an optimized version of strcmp using + Zbb extension. + +config USE_ARCH_STRNCMP + bool "Use an assembly optimized implementation of strncmp" + default y + depends on RISCV_ISA_ZBB + help + Enable the generation of an optimized version of strncmp using + Zbb extension. + +config SPL_USE_ARCH_STRNCMP + bool "Use an assembly optimized implementation of strncmp for SPL" + default y if USE_ARCH_STRNCMP + depends on RISCV_ISA_ZBB + depends on SPL + help + Enable the generation of an optimized version of strncmp using + Zbb extension. + +config TPL_USE_ARCH_STRNCMP + bool "Use an assembly optimized implementation of strncmp for TPL" + default y if USE_ARCH_STRNCMP + depends on RISCV_ISA_ZBB + depends on TPL + help + Enable the generation of an optimized version of strncmp using + Zbb extension. + +endmenu + config RISCV_ISA_A def_bool y
diff --git a/arch/riscv/Makefile b/arch/riscv/Makefile index 4963b5109b..b3ef87078b 100644 --- a/arch/riscv/Makefile +++ b/arch/riscv/Makefile @@ -24,6 +24,9 @@ endif ifeq ($(CONFIG_RISCV_ISA_C),y) ARCH_C = c endif +ifeq ($(CONFIG_RISCV_ISA_ZBB),y) + ARCH_ZBB = _zbb +endif ifeq ($(CONFIG_CMODEL_MEDLOW),y) CMODEL = medlow endif @@ -32,7 +35,7 @@ ifeq ($(CONFIG_CMODEL_MEDANY),y) endif
-RISCV_MARCH = $(ARCH_BASE)$(ARCH_A)$(ARCH_F)$(ARCH_D)$(ARCH_C) +RISCV_MARCH = $(ARCH_BASE)$(ARCH_A)$(ARCH_F)$(ARCH_D)$(ARCH_C)$(ARCH_ZBB) ABI = $(ABI_BASE)$(ABI_D)
# Newer binutils versions default to ISA spec version 20191213 which moves some diff --git a/arch/riscv/include/asm/string.h b/arch/riscv/include/asm/string.h index 7dee3e4c9f..38ad85fe3b 100644 --- a/arch/riscv/include/asm/string.h +++ b/arch/riscv/include/asm/string.h @@ -40,4 +40,22 @@ extern void *memmove(void *, const void *, __kernel_size_t); #endif extern void *memset(void *, int, __kernel_size_t);
+#undef __HAVE_ARCH_STRLEN +#if CONFIG_IS_ENABLED(USE_ARCH_STRLEN) +#define __HAVE_ARCH_STRLEN +#endif +extern __kernel_size_t strlen(const char *); + +#undef __HAVE_ARCH_STRCMP +#if CONFIG_IS_ENABLED(USE_ARCH_STRCMP) +#define __HAVE_ARCH_STRCMP +#endif +extern int strcmp(const char *, const char *); + +#undef __HAVE_ARCH_STRNCMP +#if CONFIG_IS_ENABLED(USE_ARCH_STRNCMP) +#define __HAVE_ARCH_STRNCMP +#endif +extern int strncmp(const char *, const char *, size_t __kernel_size_t); + #endif /* __ASM_RISCV_STRING_H */ diff --git a/arch/riscv/lib/Makefile b/arch/riscv/lib/Makefile index 02c4d8fcc6..9a05b662fd 100644 --- a/arch/riscv/lib/Makefile +++ b/arch/riscv/lib/Makefile @@ -42,5 +42,8 @@ extra-$(CONFIG_EFI) += $(EFI_CRT0) $(EFI_RELOC) obj-$(CONFIG_$(SPL_TPL_)USE_ARCH_MEMSET) += memset.o obj-$(CONFIG_$(SPL_TPL_)USE_ARCH_MEMMOVE) += memmove.o obj-$(CONFIG_$(SPL_TPL_)USE_ARCH_MEMCPY) += memcpy.o +obj-$(CONFIG_$(SPL_TPL_)USE_ARCH_STRLEN) += strlen_zbb.o +obj-$(CONFIG_$(SPL_TPL_)USE_ARCH_STRCMP) += strcmp_zbb.o +obj-$(CONFIG_$(SPL_TPL_)USE_ARCH_STRNCMP) += strncmp_zbb.o
obj-$(CONFIG_$(SPL_TPL_)SEMIHOSTING) += semihosting.o diff --git a/arch/riscv/lib/strcmp_zbb.S b/arch/riscv/lib/strcmp_zbb.S new file mode 100644 index 0000000000..e5a367c0e5 --- /dev/null +++ b/arch/riscv/lib/strcmp_zbb.S @@ -0,0 +1,81 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Taken from Linux arch/riscv/lib/strcmp.S + */ + +#include <linux/linkage.h> +#include <asm/asm.h> + +ENTRY(__strcmp) +WEAK(strcmp) +.option push +.option arch,+zbb + /* + * Returns + * a0 - comparison result, value like strcmp + * + * Parameters + * a0 - string1 + * a1 - string2 + * + * Clobbers + * t0, t1, t2, t3, t4 + */ + + or t2, a0, a1 + li t4, -1 + and t2, t2, SZREG-1 + bnez t2, 3f + + /* Main loop for aligned string. */ + .p2align 3 +1: + REG_L t0, 0(a0) + REG_L t1, 0(a1) + orc.b t3, t0 + bne t3, t4, 2f + addi a0, a0, SZREG + addi a1, a1, SZREG + beq t0, t1, 1b + + /* + * Words don't match, and no null byte in the first + * word. Get bytes in big-endian order and compare. + */ +#if __BYTE_ORDER__ == __ORDER_LITTLE_ENDIAN__ + rev8 t0, t0 + rev8 t1, t1 +#endif + + /* Synthesize (t0 >= t1) ? 1 : -1 in a branchless sequence. */ + sltu a0, t0, t1 + neg a0, a0 + ori a0, a0, 1 + ret + +2: + /* + * Found a null byte. + * If words don't match, fall back to simple loop. + */ + bne t0, t1, 3f + + /* Otherwise, strings are equal. */ + li a0, 0 + ret + + /* Simple loop for misaligned strings. */ + .p2align 3 +3: + lbu t0, 0(a0) + lbu t1, 0(a1) + addi a0, a0, 1 + addi a1, a1, 1 + bne t0, t1, 4f + bnez t0, 3b + +4: + sub a0, t0, t1 + ret +.option pop +END(__strcmp) diff --git a/arch/riscv/lib/strlen_zbb.S b/arch/riscv/lib/strlen_zbb.S new file mode 100644 index 0000000000..bd8fa4c0bd --- /dev/null +++ b/arch/riscv/lib/strlen_zbb.S @@ -0,0 +1,101 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Taken from Linux arch/riscv/lib/strlen.S + */ + +#include <linux/linkage.h> +#include <asm/asm.h> + +#if __BYTE_ORDER__ == __ORDER_LITTLE_ENDIAN__ +# define CZ ctz +# define SHIFT srl +#else +# define CZ clz +# define SHIFT sll +#endif + +ENTRY(__strlen) +WEAK(strlen) +.option push +.option arch,+zbb + /* + * Returns + * a0 - string length + * + * Parameters + * a0 - String to measure + * + * Clobbers + * t0, t1, t2, t3 + */ + + /* Number of irrelevant bytes in the first word. */ + andi t2, a0, SZREG-1 + + /* Align pointer. */ + andi t0, a0, -SZREG + + li t3, SZREG + sub t3, t3, t2 + slli t2, t2, 3 + + /* Get the first word. */ + REG_L t1, 0(t0) + + /* + * Shift away the partial data we loaded to remove the irrelevant bytes + * preceding the string with the effect of adding NUL bytes at the + * end of the string's first word. + */ + SHIFT t1, t1, t2 + + /* Convert non-NUL into 0xff and NUL into 0x00. */ + orc.b t1, t1 + + /* Convert non-NUL into 0x00 and NUL into 0xff. */ + not t1, t1 + + /* + * Search for the first set bit (corresponding to a NUL byte in the + * original chunk). + */ + CZ t1, t1 + + /* + * The first chunk is special: compare against the number + * of valid bytes in this chunk. + */ + srli a0, t1, 3 + bgtu t3, a0, 2f + + /* Prepare for the word comparison loop. */ + addi t2, t0, SZREG + li t3, -1 + + /* + * Our critical loop is 4 instructions and processes data in + * 4 byte or 8 byte chunks. + */ + .p2align 3 +1: + REG_L t1, SZREG(t0) + addi t0, t0, SZREG + orc.b t1, t1 + beq t1, t3, 1b + + not t1, t1 + CZ t1, t1 + srli t1, t1, 3 + + /* Get number of processed bytes. */ + sub t2, t0, t2 + + /* Add number of characters in the first word. */ + add a0, a0, t2 + + /* Add number of characters in the last word. */ + add a0, a0, t1 +2: + ret +.option pop +END(__strlen) diff --git a/arch/riscv/lib/strncmp_zbb.S b/arch/riscv/lib/strncmp_zbb.S new file mode 100644 index 0000000000..00e0fec3a6 --- /dev/null +++ b/arch/riscv/lib/strncmp_zbb.S @@ -0,0 +1,94 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Taken from Linux arch/riscv/lib/strncmp.S + */ + +#include <linux/linkage.h> +#include <asm/asm.h> + +ENTRY(__strncmp) +WEAK(strncmp) +.option push +.option arch,+zbb + /* + * Returns + * a0 - comparison result, like strncmp + * + * Parameters + * a0 - string1 + * a1 - string2 + * a2 - number of characters to compare + * + * Clobbers + * t0, t1, t2, t3, t4, t5, t6 + */ + + or t2, a0, a1 + li t5, -1 + and t2, t2, SZREG-1 + add t4, a0, a2 + bnez t2, 3f + + /* Adjust limit for fast-path. */ + andi t6, t4, -SZREG + + /* Main loop for aligned string. */ + .p2align 3 +1: + bge a0, t6, 3f + REG_L t0, 0(a0) + REG_L t1, 0(a1) + orc.b t3, t0 + bne t3, t5, 2f + orc.b t3, t1 + bne t3, t5, 2f + addi a0, a0, SZREG + addi a1, a1, SZREG + beq t0, t1, 1b + + /* + * Words don't match, and no null byte in the first + * word. Get bytes in big-endian order and compare. + */ +#if __BYTE_ORDER__ == __ORDER_LITTLE_ENDIAN__ + rev8 t0, t0 + rev8 t1, t1 +#endif + + /* Synthesize (t0 >= t1) ? 1 : -1 in a branchless sequence. */ + sltu a0, t0, t1 + neg a0, a0 + ori a0, a0, 1 + ret + +2: + /* + * Found a null byte. + * If words don't match, fall back to simple loop. + */ + bne t0, t1, 3f + + /* Otherwise, strings are equal. */ + li a0, 0 + ret + + /* Simple loop for misaligned strings. */ + .p2align 3 +3: + bge a0, t4, 5f + lbu t0, 0(a0) + lbu t1, 0(a1) + addi a0, a0, 1 + addi a1, a1, 1 + bne t0, t1, 4f + bnez t0, 3b + +4: + sub a0, t0, t1 + ret + +5: + li a0, 0 + ret +.option pop +END(__strncmp)
Reviewed-by: Leo Yu-Chi Liang ycliang@andestech.com
[snip]
- bool "Zbb extension support for bit manipulation instructions"
- default n
The default is 'n' so we don't need this line. This can be fixed in-line while applying if there's no other feedback, thanks.
-- Tom
[snip]
- default n
Hi Tom,
Got it! Thanks for the heads-up!
Best regards, Leo
-- Tom
Leo Liang
Yu Chien Peter Lin
