[PATCH] ARM: zynq: Add Z-turn board V5
Adding Z-turn board V5 to resolve the change between:
"Z-TURNBOARD_schematic.pdf" schematics state version 1 to 4 has Atheros AR8035 "Z-Turn_Board_sch_V15_20160303.pdf" schematics state version 5 has Micrel KSZ9031
At this time the S25FL128SAGNFI003 doesn't work because of bug:
*** Warning - spi_flash_probe_bus_cs() failed, using default environment
zynq-zturn was checked on V5 board, same error.
Maybe Z-turn board have the same problem (board with W25Q128BVFIG).
Signed-off-by: Alexandre GRIVEAUX agriveaux@deutnet.info --- arch/arm/dts/Makefile | 1 + arch/arm/dts/zynq-zturn-common.dtsi | 120 ++++++++ arch/arm/dts/zynq-zturn-v5.dts | 15 + arch/arm/dts/zynq-zturn.dts | 109 +------ .../xilinx/zynq/zynq-zturn-v5/ps7_init_gpl.c | 273 ++++++++++++++++++ configs/xilinx_zynq_virt_defconfig | 4 +- 6 files changed, 413 insertions(+), 109 deletions(-) create mode 100644 arch/arm/dts/zynq-zturn-common.dtsi create mode 100644 arch/arm/dts/zynq-zturn-v5.dts create mode 100644 board/xilinx/zynq/zynq-zturn-v5/ps7_init_gpl.c
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index f8f529435b..0f8973b1c8 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -277,6 +277,7 @@ dtb-$(CONFIG_ARCH_ZYNQ) += \ zynq-zc770-xm013.dtb \ zynq-zed.dtb \ zynq-zturn.dtb \ + zynq-zturn-v5.dtb \ zynq-zybo.dtb \ zynq-zybo-z7.dtb dtb-$(CONFIG_ARCH_ZYNQMP) += \ diff --git a/arch/arm/dts/zynq-zturn-common.dtsi b/arch/arm/dts/zynq-zturn-common.dtsi new file mode 100644 index 0000000000..1d7af02893 --- /dev/null +++ b/arch/arm/dts/zynq-zturn-common.dtsi @@ -0,0 +1,120 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2015 Andrea Merello adnrea.merello@gmail.com + * Copyright (C) 2017 Alexander Graf agraf@suse.de + * + * Based on zynq-zed.dts which is: + * Copyright (C) 2011 - 2014 Xilinx + * Copyright (C) 2012 National Instruments Corp. + * + */ + +/dts-v1/; +/include/ "zynq-7000.dtsi" + +/ { + compatible = "xlnx,zynq-7000"; + + aliases { + ethernet0 = &gem0; + serial0 = &uart1; + serial1 = &uart0; + mmc0 = &sdhci0; + }; + + memory@0 { + device_type = "memory"; + reg = <0x0 0x40000000>; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; + + gpio-leds { + compatible = "gpio-leds"; + usr-led1 { + label = "usr-led1"; + gpios = <&gpio0 0x0 0x1>; + default-state = "off"; + }; + + usr-led2 { + label = "usr-led2"; + gpios = <&gpio0 0x9 0x1>; + default-state = "off"; + }; + }; + + gpio-keys { + compatible = "gpio-keys"; + autorepeat; + K1 { + label = "K1"; + gpios = <&gpio0 0x32 0x1>; + linux,code = <0x66>; + wakeup-source; + autorepeat; + }; + }; +}; + +&clkc { + ps-clk-frequency = <33333333>; +}; + +&qspi { + u-boot,dm-pre-reloc; + status = "okay"; +}; + +&gem0 { + status = "okay"; + phy-mode = "rgmii-id"; + phy-handle = <ðernet_phy>; + + ethernet_phy: ethernet-phy@0 { + }; +}; + +&sdhci0 { + u-boot,dm-pre-reloc; + status = "okay"; +}; + +&uart0 { + u-boot,dm-pre-reloc; + status = "okay"; +}; + +&uart1 { + u-boot,dm-pre-reloc; + status = "okay"; +}; + +&usb0 { + status = "okay"; + dr_mode = "host"; +}; + +&can0 { + status = "okay"; +}; + +&i2c0 { + status = "okay"; + clock-frequency = <400000>; + + stlm75@49 { + status = "okay"; + compatible = "lm75"; + reg = <0x49>; + }; + + accelerometer@53 { + compatible = "adi,adxl345", "adxl345", "adi,adxl34x", "adxl34x"; + reg = <0x53>; + interrupt-parent = <&intc>; + interrupts = <0x0 0x1e 0x4>; + }; +}; diff --git a/arch/arm/dts/zynq-zturn-v5.dts b/arch/arm/dts/zynq-zturn-v5.dts new file mode 100644 index 0000000000..536632a09a --- /dev/null +++ b/arch/arm/dts/zynq-zturn-v5.dts @@ -0,0 +1,15 @@ +// SPDX-License-Identifier: GPL-2.0 + +/dts-v1/; +/include/ "zynq-zturn-common.dtsi" + +/ { + model = "Zynq Z-Turn MYIR Board V5"; + compatible = "myir,zynq-zturn-v5", "xlnx,zynq-7000"; +}; + +&gem0 { + ethernet_phy: ethernet-phy@0 { + reg = <0x3>; + }; +}; diff --git a/arch/arm/dts/zynq-zturn.dts b/arch/arm/dts/zynq-zturn.dts index 600e8ee025..620b24a25e 100644 --- a/arch/arm/dts/zynq-zturn.dts +++ b/arch/arm/dts/zynq-zturn.dts @@ -1,122 +1,15 @@ // SPDX-License-Identifier: GPL-2.0 -/* - * Copyright (C) 2015 Andrea Merello adnrea.merello@gmail.com - * Copyright (C) 2017 Alexander Graf agraf@suse.de - * - * Based on zynq-zed.dts which is: - * Copyright (C) 2011 - 2014 Xilinx - * Copyright (C) 2012 National Instruments Corp. - * - */
/dts-v1/; -/include/ "zynq-7000.dtsi" +/include/ "zynq-zturn-common.dtsi"
/ { model = "Zynq Z-Turn MYIR Board"; compatible = "myir,zynq-zturn", "xlnx,zynq-7000"; - - aliases { - ethernet0 = &gem0; - serial0 = &uart1; - serial1 = &uart0; - mmc0 = &sdhci0; - }; - - memory@0 { - device_type = "memory"; - reg = <0x0 0x40000000>; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - gpio-leds { - compatible = "gpio-leds"; - usr-led1 { - label = "usr-led1"; - gpios = <&gpio0 0x0 0x1>; - default-state = "off"; - }; - - usr-led2 { - label = "usr-led2"; - gpios = <&gpio0 0x9 0x1>; - default-state = "off"; - }; - }; - - gpio-keys { - compatible = "gpio-keys"; - autorepeat; - K1 { - label = "K1"; - gpios = <&gpio0 0x32 0x1>; - linux,code = <0x66>; - wakeup-source; - autorepeat; - }; - }; -}; - -&clkc { - ps-clk-frequency = <33333333>; -}; - -&qspi { - u-boot,dm-pre-reloc; - status = "okay"; };
&gem0 { - status = "okay"; - phy-mode = "rgmii-id"; - phy-handle = <ðernet_phy>; - ethernet_phy: ethernet-phy@0 { reg = <0x0>; }; }; - -&sdhci0 { - u-boot,dm-pre-reloc; - status = "okay"; -}; - -&uart0 { - u-boot,dm-pre-reloc; - status = "okay"; -}; - -&uart1 { - u-boot,dm-pre-reloc; - status = "okay"; -}; - -&usb0 { - status = "okay"; - dr_mode = "host"; -}; - -&can0 { - status = "okay"; -}; - -&i2c0 { - status = "okay"; - clock-frequency = <400000>; - - stlm75@49 { - status = "okay"; - compatible = "lm75"; - reg = <0x49>; - }; - - accelerometer@53 { - compatible = "adi,adxl345", "adxl345", "adi,adxl34x", "adxl34x"; - reg = <0x53>; - interrupt-parent = <&intc>; - interrupts = <0x0 0x1e 0x4>; - }; -}; diff --git a/board/xilinx/zynq/zynq-zturn-v5/ps7_init_gpl.c b/board/xilinx/zynq/zynq-zturn-v5/ps7_init_gpl.c new file mode 100644 index 0000000000..5d573868cb --- /dev/null +++ b/board/xilinx/zynq/zynq-zturn-v5/ps7_init_gpl.c @@ -0,0 +1,273 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) Xilinx, Inc. + */ + +#include <asm/arch/ps7_init_gpl.h> + +static unsigned long ps7_pll_init_data[] = { + EMIT_WRITE(0xF8000008, 0x0000DF0DU), + EMIT_MASKWRITE(0xF8000110, 0x003FFFF0U, 0x000FA220U), + EMIT_MASKWRITE(0xF8000100, 0x0007F000U, 0x00028000U), + EMIT_MASKWRITE(0xF8000100, 0x00000010U, 0x00000010U), + EMIT_MASKWRITE(0xF8000100, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0xF8000100, 0x00000001U, 0x00000000U), + EMIT_MASKPOLL(0xF800010C, 0x00000001U), + EMIT_MASKWRITE(0xF8000100, 0x00000010U, 0x00000000U), + EMIT_MASKWRITE(0xF8000120, 0x1F003F30U, 0x1F000200U), + EMIT_MASKWRITE(0xF8000114, 0x003FFFF0U, 0x0012C220U), + EMIT_MASKWRITE(0xF8000104, 0x0007F000U, 0x00020000U), + EMIT_MASKWRITE(0xF8000104, 0x00000010U, 0x00000010U), + EMIT_MASKWRITE(0xF8000104, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0xF8000104, 0x00000001U, 0x00000000U), + EMIT_MASKPOLL(0xF800010C, 0x00000002U), + EMIT_MASKWRITE(0xF8000104, 0x00000010U, 0x00000000U), + EMIT_MASKWRITE(0xF8000124, 0xFFF00003U, 0x0C200003U), + EMIT_MASKWRITE(0xF8000118, 0x003FFFF0U, 0x001452C0U), + EMIT_MASKWRITE(0xF8000108, 0x0007F000U, 0x0001E000U), + EMIT_MASKWRITE(0xF8000108, 0x00000010U, 0x00000010U), + EMIT_MASKWRITE(0xF8000108, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0xF8000108, 0x00000001U, 0x00000000U), + EMIT_MASKPOLL(0xF800010C, 0x00000004U), + EMIT_MASKWRITE(0xF8000108, 0x00000010U, 0x00000000U), + EMIT_WRITE(0xF8000004, 0x0000767BU), + EMIT_EXIT(), +}; + +static unsigned long ps7_clock_init_data[] = { + EMIT_WRITE(0xF8000008, 0x0000DF0DU), + EMIT_MASKWRITE(0xF8000128, 0x03F03F01U, 0x00700F01U), + EMIT_MASKWRITE(0xF8000138, 0x00000011U, 0x00000001U), + EMIT_MASKWRITE(0xF8000140, 0x03F03F71U, 0x00100801U), + EMIT_MASKWRITE(0xF800014C, 0x00003F31U, 0x00000501U), + EMIT_MASKWRITE(0xF8000150, 0x00003F33U, 0x00001401U), + EMIT_MASKWRITE(0xF8000154, 0x00003F33U, 0x00000A03U), + EMIT_MASKWRITE(0xF800015C, 0x03F03F33U, 0x00200501U), + EMIT_MASKWRITE(0xF8000160, 0x007F007FU, 0x00000000U), + EMIT_MASKWRITE(0xF8000168, 0x00003F31U, 0x00000501U), + EMIT_MASKWRITE(0xF8000170, 0x03F03F30U, 0x00200500U), + EMIT_MASKWRITE(0xF8000180, 0x03F03F30U, 0x00400500U), + EMIT_MASKWRITE(0xF80001C4, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0xF800012C, 0x01FFCCCDU, 0x01FD044DU), + EMIT_WRITE(0xF8000004, 0x0000767BU), + EMIT_EXIT(), +}; + +static unsigned long ps7_ddr_init_data[] = { + EMIT_MASKWRITE(0xF8006000, 0x0001FFFFU, 0x00000080U), + EMIT_MASKWRITE(0xF8006004, 0x0007FFFFU, 0x00001082U), + EMIT_MASKWRITE(0xF8006008, 0x03FFFFFFU, 0x03C0780FU), + EMIT_MASKWRITE(0xF800600C, 0x03FFFFFFU, 0x02001001U), + EMIT_MASKWRITE(0xF8006010, 0x03FFFFFFU, 0x00014001U), + EMIT_MASKWRITE(0xF8006014, 0x001FFFFFU, 0x0004285BU), + EMIT_MASKWRITE(0xF8006018, 0xF7FFFFFFU, 0x44E458D3U), + EMIT_MASKWRITE(0xF800601C, 0xFFFFFFFFU, 0x7282BCE5U), + EMIT_MASKWRITE(0xF8006020, 0x7FDFFFFCU, 0x270872D0U), + EMIT_MASKWRITE(0xF8006024, 0x0FFFFFC3U, 0x00000000U), + EMIT_MASKWRITE(0xF8006028, 0x00003FFFU, 0x00002007U), + EMIT_MASKWRITE(0xF800602C, 0xFFFFFFFFU, 0x00000008U), + EMIT_MASKWRITE(0xF8006030, 0xFFFFFFFFU, 0x00040B30U), + EMIT_MASKWRITE(0xF8006034, 0x13FF3FFFU, 0x000116D4U), + EMIT_MASKWRITE(0xF8006038, 0x00000003U, 0x00000000U), + EMIT_MASKWRITE(0xF800603C, 0x000FFFFFU, 0x00000777U), + EMIT_MASKWRITE(0xF8006040, 0xFFFFFFFFU, 0xFFF00000U), + EMIT_MASKWRITE(0xF8006044, 0x0FFFFFFFU, 0x0F666666U), + EMIT_MASKWRITE(0xF8006048, 0x0003F03FU, 0x0003C008U), + EMIT_MASKWRITE(0xF8006050, 0xFF0F8FFFU, 0x77010800U), + EMIT_MASKWRITE(0xF8006058, 0x00010000U, 0x00000000U), + EMIT_MASKWRITE(0xF800605C, 0x0000FFFFU, 0x00005003U), + EMIT_MASKWRITE(0xF8006060, 0x000017FFU, 0x0000003EU), + EMIT_MASKWRITE(0xF8006064, 0x00021FE0U, 0x00020000U), + EMIT_MASKWRITE(0xF8006068, 0x03FFFFFFU, 0x00284141U), + EMIT_MASKWRITE(0xF800606C, 0x0000FFFFU, 0x00001610U), + EMIT_MASKWRITE(0xF8006078, 0x03FFFFFFU, 0x00466111U), + EMIT_MASKWRITE(0xF800607C, 0x000FFFFFU, 0x00032222U), + EMIT_MASKWRITE(0xF80060A4, 0xFFFFFFFFU, 0x10200802U), + EMIT_MASKWRITE(0xF80060A8, 0x0FFFFFFFU, 0x0690CB73U), + EMIT_MASKWRITE(0xF80060AC, 0x000001FFU, 0x000001FEU), + EMIT_MASKWRITE(0xF80060B0, 0x1FFFFFFFU, 0x1CFFFFFFU), + EMIT_MASKWRITE(0xF80060B4, 0x00000200U, 0x00000200U), + EMIT_MASKWRITE(0xF80060B8, 0x01FFFFFFU, 0x00200066U), + EMIT_MASKWRITE(0xF80060C4, 0x00000003U, 0x00000000U), + EMIT_MASKWRITE(0xF80060C8, 0x000000FFU, 0x00000000U), + EMIT_MASKWRITE(0xF80060DC, 0x00000001U, 0x00000000U), + EMIT_MASKWRITE(0xF80060F0, 0x0000FFFFU, 0x00000000U), + EMIT_MASKWRITE(0xF80060F4, 0x0000000FU, 0x00000008U), + EMIT_MASKWRITE(0xF8006114, 0x000000FFU, 0x00000000U), + EMIT_MASKWRITE(0xF8006118, 0x7FFFFFCFU, 0x40000001U), + EMIT_MASKWRITE(0xF800611C, 0x7FFFFFCFU, 0x40000001U), + EMIT_MASKWRITE(0xF8006120, 0x7FFFFFCFU, 0x40000001U), + EMIT_MASKWRITE(0xF8006124, 0x7FFFFFCFU, 0x40000001U), + EMIT_MASKWRITE(0xF800612C, 0x000FFFFFU, 0x0002A81FU), + EMIT_MASKWRITE(0xF8006130, 0x000FFFFFU, 0x00029822U), + EMIT_MASKWRITE(0xF8006134, 0x000FFFFFU, 0x00026C10U), + EMIT_MASKWRITE(0xF8006138, 0x000FFFFFU, 0x00026013U), + EMIT_MASKWRITE(0xF8006140, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0xF8006144, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0xF8006148, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0xF800614C, 0x000FFFFFU, 0x00000035U), + EMIT_MASKWRITE(0xF8006154, 0x000FFFFFU, 0x0000009FU), + EMIT_MASKWRITE(0xF8006158, 0x000FFFFFU, 0x000000A2U), + EMIT_MASKWRITE(0xF800615C, 0x000FFFFFU, 0x00000090U), + EMIT_MASKWRITE(0xF8006160, 0x000FFFFFU, 0x00000093U), + EMIT_MASKWRITE(0xF8006168, 0x001FFFFFU, 0x000000FFU), + EMIT_MASKWRITE(0xF800616C, 0x001FFFFFU, 0x000000FBU), + EMIT_MASKWRITE(0xF8006170, 0x001FFFFFU, 0x000000F0U), + EMIT_MASKWRITE(0xF8006174, 0x001FFFFFU, 0x000000EDU), + EMIT_MASKWRITE(0xF800617C, 0x000FFFFFU, 0x000000DFU), + EMIT_MASKWRITE(0xF8006180, 0x000FFFFFU, 0x000000E2U), + EMIT_MASKWRITE(0xF8006184, 0x000FFFFFU, 0x000000D0U), + EMIT_MASKWRITE(0xF8006188, 0x000FFFFFU, 0x000000D3U), + EMIT_MASKWRITE(0xF8006190, 0x6FFFFEFEU, 0x00040080U), + EMIT_MASKWRITE(0xF8006194, 0x000FFFFFU, 0x0001FC82U), + EMIT_MASKWRITE(0xF8006204, 0xFFFFFFFFU, 0x00000000U), + EMIT_MASKWRITE(0xF8006208, 0x000703FFU, 0x000003FFU), + EMIT_MASKWRITE(0xF800620C, 0x000703FFU, 0x000003FFU), + EMIT_MASKWRITE(0xF8006210, 0x000703FFU, 0x000003FFU), + EMIT_MASKWRITE(0xF8006214, 0x000703FFU, 0x000003FFU), + EMIT_MASKWRITE(0xF8006218, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0xF800621C, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0xF8006220, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0xF8006224, 0x000F03FFU, 0x000003FFU), + EMIT_MASKWRITE(0xF80062A8, 0x00000FF5U, 0x00000000U), + EMIT_MASKWRITE(0xF80062AC, 0xFFFFFFFFU, 0x00000000U), + EMIT_MASKWRITE(0xF80062B0, 0x003FFFFFU, 0x00005125U), + EMIT_MASKWRITE(0xF80062B4, 0x0003FFFFU, 0x000012A8U), + EMIT_MASKPOLL(0xF8000B74, 0x00002000U), + EMIT_MASKWRITE(0xF8006000, 0x0001FFFFU, 0x00000081U), + EMIT_MASKPOLL(0xF8006054, 0x00000007U), + EMIT_EXIT(), +}; + +static unsigned long ps7_mio_init_data[] = { + EMIT_WRITE(0xF8000008, 0x0000DF0DU), + EMIT_MASKWRITE(0xF8000B40, 0x00000FFFU, 0x00000600U), + EMIT_MASKWRITE(0xF8000B44, 0x00000FFFU, 0x00000600U), + EMIT_MASKWRITE(0xF8000B48, 0x00000FFFU, 0x00000672U), + EMIT_MASKWRITE(0xF8000B4C, 0x00000FFFU, 0x00000672U), + EMIT_MASKWRITE(0xF8000B50, 0x00000FFFU, 0x00000674U), + EMIT_MASKWRITE(0xF8000B54, 0x00000FFFU, 0x00000674U), + EMIT_MASKWRITE(0xF8000B58, 0x00000FFFU, 0x00000600U), + EMIT_MASKWRITE(0xF8000B5C, 0xFFFFFFFFU, 0x0018C61CU), + EMIT_MASKWRITE(0xF8000B60, 0xFFFFFFFFU, 0x00F9861CU), + EMIT_MASKWRITE(0xF8000B64, 0xFFFFFFFFU, 0x00F9861CU), + EMIT_MASKWRITE(0xF8000B68, 0xFFFFFFFFU, 0x00F9861CU), + EMIT_MASKWRITE(0xF8000B6C, 0x00007FFFU, 0x00000260U), + EMIT_MASKWRITE(0xF8000B70, 0x00000001U, 0x00000001U), + EMIT_MASKWRITE(0xF8000B70, 0x00000021U, 0x00000020U), + EMIT_MASKWRITE(0xF8000B70, 0x07FEFFFFU, 0x00000823U), + EMIT_MASKWRITE(0xF8000700, 0x00003FFFU, 0x00001600U), + EMIT_MASKWRITE(0xF8000704, 0x00003FFFU, 0x00000602U), + EMIT_MASKWRITE(0xF8000708, 0x00003FFFU, 0x00000602U), + EMIT_MASKWRITE(0xF800070C, 0x00003FFFU, 0x00000602U), + EMIT_MASKWRITE(0xF8000710, 0x00003FFFU, 0x00000602U), + EMIT_MASKWRITE(0xF8000714, 0x00003FFFU, 0x00000602U), + EMIT_MASKWRITE(0xF8000718, 0x00003FFFU, 0x00000602U), + EMIT_MASKWRITE(0xF800071C, 0x00003FFFU, 0x00000600U), + EMIT_MASKWRITE(0xF8000720, 0x00003FFFU, 0x00000602U), + EMIT_MASKWRITE(0xF8000724, 0x00003FFFU, 0x00000600U), + EMIT_MASKWRITE(0xF8000728, 0x00003FFFU, 0x000016E1U), + EMIT_MASKWRITE(0xF800072C, 0x00003FFFU, 0x000016E0U), + EMIT_MASKWRITE(0xF8000730, 0x00003FFFU, 0x00001640U), + EMIT_MASKWRITE(0xF8000734, 0x00003FFFU, 0x00001640U), + EMIT_MASKWRITE(0xF8000738, 0x00003FFFU, 0x00001621U), + EMIT_MASKWRITE(0xF800073C, 0x00003FFFU, 0x00001620U), + EMIT_MASKWRITE(0xF8000740, 0x00003FFFU, 0x00001202U), + EMIT_MASKWRITE(0xF8000744, 0x00003FFFU, 0x00001202U), + EMIT_MASKWRITE(0xF8000748, 0x00003FFFU, 0x00001202U), + EMIT_MASKWRITE(0xF800074C, 0x00003FFFU, 0x00001202U), + EMIT_MASKWRITE(0xF8000750, 0x00003FFFU, 0x00001202U), + EMIT_MASKWRITE(0xF8000754, 0x00003FFFU, 0x00001202U), + EMIT_MASKWRITE(0xF8000758, 0x00003FFFU, 0x00001203U), + EMIT_MASKWRITE(0xF800075C, 0x00003FFFU, 0x00001203U), + EMIT_MASKWRITE(0xF8000760, 0x00003FFFU, 0x00001203U), + EMIT_MASKWRITE(0xF8000764, 0x00003FFFU, 0x00001203U), + EMIT_MASKWRITE(0xF8000768, 0x00003FFFU, 0x00001203U), + EMIT_MASKWRITE(0xF800076C, 0x00003FFFU, 0x00001203U), + EMIT_MASKWRITE(0xF8000770, 0x00003FFFU, 0x00001204U), + EMIT_MASKWRITE(0xF8000774, 0x00003FFFU, 0x00001205U), + EMIT_MASKWRITE(0xF8000778, 0x00003FFFU, 0x00001204U), + EMIT_MASKWRITE(0xF800077C, 0x00003FFFU, 0x00001205U), + EMIT_MASKWRITE(0xF8000780, 0x00003FFFU, 0x00001204U), + EMIT_MASKWRITE(0xF8000784, 0x00003FFFU, 0x00001204U), + EMIT_MASKWRITE(0xF8000788, 0x00003FFFU, 0x00001204U), + EMIT_MASKWRITE(0xF800078C, 0x00003FFFU, 0x00001204U), + EMIT_MASKWRITE(0xF8000790, 0x00003FFFU, 0x00001205U), + EMIT_MASKWRITE(0xF8000794, 0x00003FFFU, 0x00001204U), + EMIT_MASKWRITE(0xF8000798, 0x00003FFFU, 0x00001204U), + EMIT_MASKWRITE(0xF800079C, 0x00003FFFU, 0x00001204U), + EMIT_MASKWRITE(0xF80007A0, 0x00003FFFU, 0x00001280U), + EMIT_MASKWRITE(0xF80007A4, 0x00003FFFU, 0x00001280U), + EMIT_MASKWRITE(0xF80007A8, 0x00003FFFU, 0x00001280U), + EMIT_MASKWRITE(0xF80007AC, 0x00003FFFU, 0x00001280U), + EMIT_MASKWRITE(0xF80007B0, 0x00003FFFU, 0x00001280U), + EMIT_MASKWRITE(0xF80007B4, 0x00003FFFU, 0x00001280U), + EMIT_MASKWRITE(0xF80007B8, 0x00003F01U, 0x00000201U), + EMIT_MASKWRITE(0xF80007BC, 0x00003F01U, 0x00000201U), + EMIT_MASKWRITE(0xF80007C0, 0x00003FFFU, 0x000012E0U), + EMIT_MASKWRITE(0xF80007C4, 0x00003FFFU, 0x000012E1U), + EMIT_MASKWRITE(0xF80007C8, 0x00003FFFU, 0x00000200U), + EMIT_MASKWRITE(0xF80007CC, 0x00003FFFU, 0x00000200U), + EMIT_MASKWRITE(0xF80007D0, 0x00003FFFU, 0x00001280U), + EMIT_MASKWRITE(0xF80007D4, 0x00003FFFU, 0x00001280U), + EMIT_MASKWRITE(0xF8000830, 0x003F003FU, 0x002E002FU), + EMIT_WRITE(0xF8000004, 0x0000767BU), + EMIT_EXIT(), +}; + +static unsigned long ps7_peripherals_init_data[] = { + EMIT_WRITE(0xF8000008, 0x0000DF0DU), + EMIT_MASKWRITE(0xF8000B48, 0x00000180U, 0x00000180U), + EMIT_MASKWRITE(0xF8000B4C, 0x00000180U, 0x00000180U), + EMIT_MASKWRITE(0xF8000B50, 0x00000180U, 0x00000180U), + EMIT_MASKWRITE(0xF8000B54, 0x00000180U, 0x00000180U), + EMIT_WRITE(0xF8000004, 0x0000767BU), + EMIT_MASKWRITE(0xE000D000, 0x00080000U, 0x00080000U), + EMIT_MASKWRITE(0xF8007000, 0x20000000U, 0x00000000U), + EMIT_MASKWRITE(0xE000A244, 0x003FFFFFU, 0x00080000U), + EMIT_MASKWRITE(0xE000A00C, 0x003F003FU, 0x00370008U), + EMIT_MASKWRITE(0xE000A248, 0x003FFFFFU, 0x00080000U), + EMIT_MASKWRITE(0xE000A00C, 0x003F003FU, 0x00370000U), + EMIT_MASKDELAY(0xF8F00200, 1), + EMIT_MASKWRITE(0xE000A00C, 0x003F003FU, 0x00370008U), + EMIT_EXIT(), +}; + +static unsigned long ps7_post_config_0[] = { + EMIT_WRITE(0xF8000008, 0x0000DF0DU), + EMIT_MASKWRITE(0xF8000900, 0x0000000FU, 0x0000000FU), + EMIT_MASKWRITE(0xF8000240, 0xFFFFFFFFU, 0x00000000U), + EMIT_WRITE(0xF8000004, 0x0000767BU), + EMIT_EXIT(), +}; + +int ps7_post_config(void) +{ + return ps7_config(ps7_post_config_0); +} + +int ps7_init(void) +{ + int ret; + + ret = ps7_config(ps7_mio_init_data); + if (ret != PS7_INIT_SUCCESS) + return ret; + + ret = ps7_config(ps7_pll_init_data); + if (ret != PS7_INIT_SUCCESS) + return ret; + + ret = ps7_config(ps7_clock_init_data); + if (ret != PS7_INIT_SUCCESS) + return ret; + + ret = ps7_config(ps7_ddr_init_data); + if (ret != PS7_INIT_SUCCESS) + return ret; + + ret = ps7_config(ps7_peripherals_init_data); + if (ret != PS7_INIT_SUCCESS) + return ret; + return PS7_INIT_SUCCESS; +} diff --git a/configs/xilinx_zynq_virt_defconfig b/configs/xilinx_zynq_virt_defconfig index 8acdab25b7..afbc81afd1 100644 --- a/configs/xilinx_zynq_virt_defconfig +++ b/configs/xilinx_zynq_virt_defconfig @@ -49,7 +49,7 @@ CONFIG_CMD_MTDPARTS=y CONFIG_CMD_MTDPARTS_SPREAD=y CONFIG_CMD_MTDPARTS_SHOW_NET_SIZES=y CONFIG_CMD_UBI=y -CONFIG_OF_LIST="zynq-zc702 zynq-zc706 zynq-zc770-xm010 zynq-zc770-xm011 zynq-zc770-xm011-x16 zynq-zc770-xm012 zynq-zc770-xm013 zynq-cc108 zynq-microzed zynq-minized zynq-picozed zynq-zed zynq-zturn zynq-zybo zynq-zybo-z7 zynq-dlc20-rev1.0" +CONFIG_OF_LIST="zynq-zc702 zynq-zc706 zynq-zc770-xm010 zynq-zc770-xm011 zynq-zc770-xm011-x16 zynq-zc770-xm012 zynq-zc770-xm013 zynq-cc108 zynq-microzed zynq-minized zynq-picozed zynq-zed zynq-zturn zynq-zturn-v5 zynq-zybo zynq-zybo-z7 zynq-dlc20-rev1.0" CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y @@ -90,6 +90,8 @@ CONFIG_SPI_FLASH_WINBOND=y CONFIG_PHY_MARVELL=y CONFIG_PHY_REALTEK=y CONFIG_PHY_XILINX=y +CONFIG_PHY_MICREL=y +CONFIG_PHY_MICREL_KSZ90X1=y CONFIG_MII=y CONFIG_ZYNQ_GEM=y CONFIG_ARM_DCC=y
st 23. 9. 2020 v 19:33 odesílatel agriveaux@deutnet.info napsal:
please send this as v2 version with changelog.
M
Michal Simek
