[U-Boot] Please pull ARC changes
Hi Tom,
The following changes since commit 3d5ced9e22d32112a20f9dc0f5fb1f22ef088079:
Merge tag 'dm-9oct18' of git://git.denx.de/u-boot-dm (2018-10-10 13:35:17 -0400)
git://git.denx.de/u-boot-arc.git tags/arc-more-updates-for-2018.11-rc2
for you to fetch changes up to a2110918559b34219721cf31bbe8bd94a843e1ac:
iot_dk: Link for eFlash (2018-10-12 15:14:41 +0300)
---------------------------------------------------------------- More fixes and improvements for ARC here:
Fixes: * Take care of global uninitialized variables They used to be put right after .bss section and were never zeroed as they should be. Now merged with normal .bss
Improvements: * Print more verbose CPU info for boards built on real silicon * Add support for SD-card detection on all ARC boards * Quite a few fixes for IoT DK - Support reset by command - Print of CPU freq on boot - Link for eFlash etc
---------------------------------------------------------------- Alexey Brodkin (9): iot_dk: Add localversion string iot_dk: Disable networking support ARC: make generic print_cpuinfo() weak iot_dk/hsdk: Implement its own print_cpuinfo() iot_dk: Implement board reset iot_dk: Add support of 136 MHz clock iot_dk: Save CPU clock value to gd->cpu_clk axs10x/emdk/hsdk/iot_dk: Implement board_mmc_getcd() iot_dk: Link for eFlash
arch/arc/lib/cpu.c | 2 +- board/synopsys/axs10x/axs10x.c | 7 +++++++ board/synopsys/emdk/emdk.c | 7 +++++++ board/synopsys/hsdk/hsdk.c | 15 +++++++++++++++ board/synopsys/iot_devkit/iot_devkit.c | 43 ++++++++++++++++++++++++++++++++++++++----- configs/iot_devkit_defconfig | 5 +++-- 6 files changed, 71 insertions(+), 8 deletions(-)
Regards, Alexey
Hi Tom,
Not sure why that duplicate email appeared... Either my mailer became crazy or I'm fatfingering :(
Sorry for that!
Though I'll re-send a pull-request as I did miss one important patch.
-Alexey
On Mon, 2018-10-15 at 10:22 +0000, Alexey Brodkin wrote:
Hi Tom,
Fixes:
- Take care of global uninitialized variables They used to be put right after .bss section and were never zeroed as they should be. Now merged with normal .bss
Improvements:
- Print more verbose CPU info for boards built on real silicon
- Add support for SD-card detection on all ARC boards
- Quite a few fixes for IoT DK
Regards, Alexey
Alexey Brodkin
