[U-Boot] [PATCH] dm: core: Kconfig: set OF_TRANSLATE default value to n
Based on the OF_TRANSLATE Kconfig description, this is required only on platforms with complex "ranges" in the DT nodes. For simpler platforms using SIMPLE_BUS should be sufficient. Since this a set to default y, simple bus is never used in any platform. So make the default value as "n" and enable OF_TRANSLATE only on required platform.
Signed-off-by: Mugunthan V N mugunthanvnm@ti.com ---
Tested this patch on TI DRA72 platform.
--- drivers/core/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/core/Kconfig b/drivers/core/Kconfig index 15681df..74e0caf 100644 --- a/drivers/core/Kconfig +++ b/drivers/core/Kconfig @@ -123,7 +123,7 @@ config SPL_SIMPLE_BUS config OF_TRANSLATE bool "Translate addresses using fdt_translate_address" depends on DM && OF_CONTROL - default y + default n help If this option is enabled, the reg property will be translated using the fdt_translate_address() function. This is necessary
+Stefan
Hi Mugunthan,
How do you know it is not used? This is surprising because Stefan presumably added it to fix something.
default y
-- 2.6.2.280.g74301d6
+Stephan Warren & Thomas Chou
On 06.11.2015 13:08, Simon Glass wrote:
+Stefan
Hi Mugunthan,
I assume Mugunthan meant, that simple bus is never used. This is not quite correct, as its at least used per default in the SPL (because of size reasons).
And yes, this translation via fdt_translate_address() is needed. At least for some platforms, like mvebu & nios2 (IIRC). Stephen also made some quite striking comments about this a few weeks ago. And I really think that we should make use of this function per default. Platforms that know for sure that they don't need this functionality can always disable it selectively.
Mugunthan, why do you want to disable this functionality? Does it cause problems on your platform? If yes, which ones?
Thanks, Stefan
+Stefan
Hi Mugunthan,
Processing of ranges is a fundamental part of handling DT in general. It should be enabled by default. If there are well-researched cases where (a) including the code is problematic (e.g. due to code size restrictions) and (b) someone is watching the DTs processed on those platforms like a hawk to ensure no ranges properties are introduced into the DT, *then* we could make a special-case exception to disable the feature in those specific cases. As such, I think enable-by-default, disable-when-chosen is the appropriate default.
+Stefan
Hi Mugunthan,
In the Kconfig help it is mentioned that this is needed only on some platforms which uses complex ranges, so when I tried disabling OF_TRANSLATE on omap platform it still works.
Since OF_TRANSLATE is defined as 'y' as default, SIMPLE_BUS is never used until OF_TRANSLATE is set to 'n' in defconfig. So I thought of making the default kconfig option as 'n' and select this which ever platform needs it like mvebu and nios2.
But if community wants OF_TRANSLATE to be used by default, I am okay to drop this patch.
Regards Mugunthan V N
Mugunthan V N
Stefan Roese
Stephen Warren
