[PATCH v2 00/11] toradex updates: assortment of fixes and improvements
This series contains an assortment of fixes and improvements for Toradex computer/system on modules (CoM/SoM).
We also drop support for the Apalis iMX8X and the Colibri PXA270. The former never evolved beyond the sample state and we no longer support it. The latter is EOL since a while.
Changes in v2: - Also drop setup_dcemode_uart() and setup_iomux_dce_uart() which are now unused. - Re-based on top of Stefano's imx/master-next which dropped 13 commits already applied.
Denys Drozdov (1): toradex: apalis-imx8x: drop support for apalis imx8x
Igor Opaniuk (3): toradex: globally disable video support toradex: set default dhcp distroboot scriptname toradex: drop legacy nfsboot script
Marcel Ziswiler (4): board: toradex: drop colibri pxa270 support board: colibri_imx7: fix usb start on solo configs: tdx: apalis_imx6: drop hw v1.0 support configs: tdx: apalis/colibri_imx6: use preboot as well
Oleksandr Suvorov (2): configs: toradex: enable missing fit options configs: colibri-imx7/-emmc: enable booting from usb sdp
Philippe Schenker (1): configs: tdx: Do not overwrite fdtfile if it got set manually
arch/arm/Kconfig | 6 - arch/arm/dts/Makefile | 1 - arch/arm/dts/fsl-imx8qxp-apalis-u-boot.dtsi | 139 --------- arch/arm/dts/fsl-imx8qxp-apalis.dts | 278 ------------------ arch/arm/mach-imx/imx8/Kconfig | 6 - board/toradex/apalis-imx8x/Kconfig | 33 --- board/toradex/apalis-imx8x/MAINTAINERS | 10 - board/toradex/apalis-imx8x/Makefile | 6 - .../apalis-imx8x/apalis-imx8x-imximage.cfg | 23 -- board/toradex/apalis-imx8x/apalis-imx8x.c | 155 ---------- board/toradex/apalis_imx6/apalis_imx6.c | 38 +-- board/toradex/colibri_imx7/colibri_imx7.c | 40 +-- board/toradex/colibri_pxa270/Kconfig | 23 -- board/toradex/colibri_pxa270/MAINTAINERS | 6 - board/toradex/colibri_pxa270/Makefile | 7 - board/toradex/colibri_pxa270/colibri_pxa270.c | 153 ---------- board/toradex/common/tdx-cfg-block.c | 32 +- configs/apalis-imx8_defconfig | 1 + configs/apalis-imx8x_defconfig | 82 ------ configs/apalis-tk1_defconfig | 1 + configs/apalis_imx6_defconfig | 13 +- configs/colibri-imx6ull-emmc_defconfig | 10 +- configs/colibri-imx6ull_defconfig | 11 +- configs/colibri-imx8x_defconfig | 1 + configs/colibri_imx6_defconfig | 13 +- configs/colibri_imx7_defconfig | 14 +- configs/colibri_imx7_emmc_defconfig | 11 +- configs/colibri_pxa270_defconfig | 57 ---- configs/colibri_t20_defconfig | 5 - configs/colibri_vf_defconfig | 7 +- configs/verdin-imx8mm_defconfig | 3 +- configs/verdin-imx8mp_defconfig | 2 +- doc/board/toradex/apalis-imx8x.rst | 77 ----- doc/board/toradex/index.rst | 1 - include/configs/apalis-imx8.h | 6 +- include/configs/apalis-imx8x.h | 127 -------- include/configs/apalis-tk1.h | 12 +- include/configs/apalis_imx6.h | 21 +- include/configs/apalis_t30.h | 3 +- include/configs/colibri-imx6ull.h | 11 +- include/configs/colibri-imx8x.h | 7 +- include/configs/colibri_imx6.h | 16 +- include/configs/colibri_imx7.h | 11 +- include/configs/colibri_pxa270.h | 151 ---------- include/configs/colibri_t20.h | 1 + include/configs/colibri_t30.h | 3 +- include/configs/colibri_vf.h | 11 +- include/configs/pxa-common.h | 27 -- include/configs/verdin-imx8mm.h | 7 +- include/configs/verdin-imx8mp.h | 6 - 50 files changed, 53 insertions(+), 1632 deletions(-) delete mode 100644 arch/arm/dts/fsl-imx8qxp-apalis-u-boot.dtsi delete mode 100644 arch/arm/dts/fsl-imx8qxp-apalis.dts delete mode 100644 board/toradex/apalis-imx8x/Kconfig delete mode 100644 board/toradex/apalis-imx8x/MAINTAINERS delete mode 100644 board/toradex/apalis-imx8x/Makefile delete mode 100644 board/toradex/apalis-imx8x/apalis-imx8x-imximage.cfg delete mode 100644 board/toradex/apalis-imx8x/apalis-imx8x.c delete mode 100644 board/toradex/colibri_pxa270/Kconfig delete mode 100644 board/toradex/colibri_pxa270/MAINTAINERS delete mode 100644 board/toradex/colibri_pxa270/Makefile delete mode 100644 board/toradex/colibri_pxa270/colibri_pxa270.c delete mode 100644 configs/apalis-imx8x_defconfig delete mode 100644 configs/colibri_pxa270_defconfig delete mode 100644 doc/board/toradex/apalis-imx8x.rst delete mode 100644 include/configs/apalis-imx8x.h delete mode 100644 include/configs/colibri_pxa270.h delete mode 100644 include/configs/pxa-common.h
Drop Apalis iMX8X platform as it never left sample state and is no longer supported.
Signed-off-by: Denys Drozdov denys.drozdov@toradex.com Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com ---
(no changes since v1)
arch/arm/dts/Makefile | 1 - arch/arm/dts/fsl-imx8qxp-apalis-u-boot.dtsi | 139 --------- arch/arm/dts/fsl-imx8qxp-apalis.dts | 278 ------------------ arch/arm/mach-imx/imx8/Kconfig | 6 - board/toradex/apalis-imx8x/Kconfig | 33 --- board/toradex/apalis-imx8x/MAINTAINERS | 10 - board/toradex/apalis-imx8x/Makefile | 6 - .../apalis-imx8x/apalis-imx8x-imximage.cfg | 23 -- board/toradex/apalis-imx8x/apalis-imx8x.c | 155 ---------- board/toradex/common/tdx-cfg-block.c | 13 +- configs/apalis-imx8x_defconfig | 82 ------ doc/board/toradex/apalis-imx8x.rst | 77 ----- doc/board/toradex/index.rst | 1 - include/configs/apalis-imx8x.h | 127 -------- 14 files changed, 1 insertion(+), 950 deletions(-) delete mode 100644 arch/arm/dts/fsl-imx8qxp-apalis-u-boot.dtsi delete mode 100644 arch/arm/dts/fsl-imx8qxp-apalis.dts delete mode 100644 board/toradex/apalis-imx8x/Kconfig delete mode 100644 board/toradex/apalis-imx8x/MAINTAINERS delete mode 100644 board/toradex/apalis-imx8x/Makefile delete mode 100644 board/toradex/apalis-imx8x/apalis-imx8x-imximage.cfg delete mode 100644 board/toradex/apalis-imx8x/apalis-imx8x.c delete mode 100644 configs/apalis-imx8x_defconfig delete mode 100644 doc/board/toradex/apalis-imx8x.rst delete mode 100644 include/configs/apalis-imx8x.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index df7b4addf99..fe9383fe90b 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -891,7 +891,6 @@ dtb-$(CONFIG_ARCH_IMX8) += \ imx8qm-rom7720-a1.dtb \ fsl-imx8qxp-ai_ml.dtb \ fsl-imx8qxp-colibri.dtb \ - fsl-imx8qxp-apalis.dtb \ fsl-imx8qxp-mek.dtb \ imx8-deneb.dtb \ imx8-giedi.dtb diff --git a/arch/arm/dts/fsl-imx8qxp-apalis-u-boot.dtsi b/arch/arm/dts/fsl-imx8qxp-apalis-u-boot.dtsi deleted file mode 100644 index e41911a04aa..00000000000 --- a/arch/arm/dts/fsl-imx8qxp-apalis-u-boot.dtsi +++ /dev/null @@ -1,139 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ OR MIT -/* - * Copyright 2020 Toradex - */ - -&{/imx8qx-pm} { - - u-boot,dm-pre-proper; -}; - -&mu { - u-boot,dm-pre-proper; -}; - -&clk { - u-boot,dm-pre-proper; -}; - -&iomuxc { - u-boot,dm-pre-proper; -}; - -&pd_lsio { - u-boot,dm-pre-proper; -}; - -&pd_lsio_gpio0 { - u-boot,dm-pre-proper; -}; - -&pd_lsio_gpio1 { - u-boot,dm-pre-proper; -}; - -&pd_lsio_gpio2 { - u-boot,dm-pre-proper; -}; - -&pd_lsio_gpio3 { - u-boot,dm-pre-proper; -}; - -&pd_lsio_gpio4 { - u-boot,dm-pre-proper; -}; - -&pd_lsio_gpio5 { - u-boot,dm-pre-proper; -}; - -&pd_lsio_gpio6 { - u-boot,dm-pre-proper; -}; - -&pd_lsio_gpio7 { - u-boot,dm-pre-proper; -}; - -&pd_dma { - u-boot,dm-pre-proper; -}; - -&pd_dma_lpuart0 { - u-boot,dm-pre-proper; -}; - -&pd_dma_lpuart3 { - u-boot,dm-pre-proper; -}; - -&pd_conn { - u-boot,dm-pre-proper; -}; - -&pd_conn_sdch0 { - u-boot,dm-pre-proper; -}; - -&pd_conn_sdch1 { - u-boot,dm-pre-proper; -}; - -&pd_conn_sdch2 { - u-boot,dm-pre-proper; -}; - -&pd_conn_enet0 { - u-boot,dm-pre-proper; -}; - -&gpio0 { - u-boot,dm-pre-proper; -}; - -&gpio1 { - u-boot,dm-pre-proper; -}; - -&gpio2 { - u-boot,dm-pre-proper; -}; - -&gpio3 { - u-boot,dm-pre-proper; -}; - -&gpio4 { - u-boot,dm-pre-proper; -}; - -&gpio5 { - u-boot,dm-pre-proper; -}; - -&gpio6 { - u-boot,dm-pre-proper; -}; - -&gpio7 { - u-boot,dm-pre-proper; -}; - -&lpuart3 { - u-boot,dm-pre-proper; -}; - -&lpuart0 { - u-boot,dm-pre-proper; -}; - -&usdhc1 { - u-boot,dm-pre-proper; - /delete-property/ assigned-clock-parents; -}; - -&usdhc2 { - u-boot,dm-pre-proper; - /delete-property/ assigned-clock-parents; -}; diff --git a/arch/arm/dts/fsl-imx8qxp-apalis.dts b/arch/arm/dts/fsl-imx8qxp-apalis.dts deleted file mode 100644 index 9cb3d3a809b..00000000000 --- a/arch/arm/dts/fsl-imx8qxp-apalis.dts +++ /dev/null @@ -1,278 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ OR MIT -/* - * Copyright 2020 Toradex - */ - -/dts-v1/; - -#include "fsl-imx8qxp.dtsi" -#include "fsl-imx8qxp-apalis-u-boot.dtsi" - -/ { - model = "Toradex Apalis iMX8X"; - compatible = "toradex,apalis-imx8x", "fsl,imx8qxp"; - - chosen { - bootargs = "console=ttyLP1,115200"; - stdout-path = &lpuart1; - }; - - regulators { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <0>; - - reg_usb_otg1_vbus: regulator@0 { - compatible = "regulator-fixed"; - reg = <0>; - regulator-name = "usb_otg1_vbus"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - gpio = <&gpio3 16 GPIO_ACTIVE_HIGH>; - enable-active-high; - }; - }; -}; - -&iomuxc { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_hog0>, <&pinctrl_hog1>, <&pinctrl_reset_moci>; - - apalis-imx8x { - /* Apalis UART1 */ - pinctrl_lpuart1: lpuart1grp { - fsl,pins = < - SC_P_UART1_RX_ADMA_UART1_RX 0x06000020 /* SODIMM 118 */ - SC_P_UART1_TX_ADMA_UART1_TX 0x06000020 /* SODIMM 112 */ - >; - }; - - /* On-module Gigabit Ethernet PHY Micrel KSZ9031 */ - pinctrl_fec1: fec1grp { - fsl,pins = < - SC_P_COMP_CTL_GPIO_1V8_3V3_ENET_ENETB0_PAD 0x14a0 - SC_P_COMP_CTL_GPIO_1V8_3V3_ENET_ENETB1_PAD 0x14a0 - SC_P_ENET0_MDC_CONN_ENET0_MDC 0x06000020 - SC_P_ENET0_MDIO_CONN_ENET0_MDIO 0x06000020 - SC_P_ENET0_RGMII_TX_CTL_CONN_ENET0_RGMII_TX_CTL 0x61 - SC_P_ENET0_RGMII_TXC_CONN_ENET0_RGMII_TXC 0x61 - SC_P_ENET0_RGMII_TXD0_CONN_ENET0_RGMII_TXD0 0x61 - SC_P_ENET0_RGMII_TXD1_CONN_ENET0_RGMII_TXD1 0x61 - SC_P_ENET0_RGMII_TXD2_CONN_ENET0_RGMII_TXD2 0x61 - SC_P_ENET0_RGMII_TXD3_CONN_ENET0_RGMII_TXD3 0x61 - SC_P_ENET0_RGMII_RXC_CONN_ENET0_RGMII_RXC 0x61 - SC_P_ENET0_RGMII_RX_CTL_CONN_ENET0_RGMII_RX_CTL 0x61 - SC_P_ENET0_RGMII_RXD0_CONN_ENET0_RGMII_RXD0 0x61 - SC_P_ENET0_RGMII_RXD1_CONN_ENET0_RGMII_RXD1 0x61 - SC_P_ENET0_RGMII_RXD2_CONN_ENET0_RGMII_RXD2 0x61 - SC_P_ENET0_RGMII_RXD3_CONN_ENET0_RGMII_RXD3 0x61 - /* On-module ETH_RESET# */ - SC_P_MIPI_CSI0_MCLK_OUT_LSIO_GPIO3_IO04 0x06000020 - /* On-module ETH_INT# */ - SC_P_ADC_IN2_LSIO_GPIO1_IO12 0x21 - >; - }; - - /* Apalis BKL_ON */ - pinctrl_gpio_bkl_on: gpio-bkl-on { - fsl,pins = < - SC_P_QSPI0A_DQS_LSIO_GPIO3_IO13 0x40 /* SODIMM 286 */ - >; - }; - - pinctrl_hog0: hog0grp { - fsl,pins = < - SC_P_COMP_CTL_GPIO_1V8_3V3_GPIORHB_PAD 0x000514a0 - >; - }; - - pinctrl_hog1: hog1grp { - fsl,pins = < - /* Apalis USBO1_EN */ - SC_P_QSPI0A_SCLK_LSIO_GPIO3_IO16 0x41 /* SODIMM 274 */ - >; - }; - - /* Apalis RESET_MOCI# */ - pinctrl_reset_moci: gpioresetmocigrp { - fsl,pins = < - SC_P_PCIE_CTRL0_CLKREQ_B_LSIO_GPIO4_IO01 0x21 - >; - }; - - /* On-module eMMC */ - pinctrl_usdhc1: usdhc1grp { - fsl,pins = < - SC_P_EMMC0_CLK_CONN_EMMC0_CLK 0x06000041 - SC_P_EMMC0_CMD_CONN_EMMC0_CMD 0x21 - SC_P_EMMC0_DATA0_CONN_EMMC0_DATA0 0x21 - SC_P_EMMC0_DATA1_CONN_EMMC0_DATA1 0x21 - SC_P_EMMC0_DATA2_CONN_EMMC0_DATA2 0x21 - SC_P_EMMC0_DATA3_CONN_EMMC0_DATA3 0x21 - SC_P_EMMC0_DATA4_CONN_EMMC0_DATA4 0x21 - SC_P_EMMC0_DATA5_CONN_EMMC0_DATA5 0x21 - SC_P_EMMC0_DATA6_CONN_EMMC0_DATA6 0x21 - SC_P_EMMC0_DATA7_CONN_EMMC0_DATA7 0x21 - SC_P_EMMC0_STROBE_CONN_EMMC0_STROBE 0x41 - SC_P_EMMC0_RESET_B_CONN_EMMC0_RESET_B 0x21 - >; - }; - - pinctrl_usdhc1_100mhz: usdhc1grp100mhz { - fsl,pins = < - SC_P_EMMC0_CLK_CONN_EMMC0_CLK 0x06000041 - SC_P_EMMC0_CMD_CONN_EMMC0_CMD 0x21 - SC_P_EMMC0_DATA0_CONN_EMMC0_DATA0 0x21 - SC_P_EMMC0_DATA1_CONN_EMMC0_DATA1 0x21 - SC_P_EMMC0_DATA2_CONN_EMMC0_DATA2 0x21 - SC_P_EMMC0_DATA3_CONN_EMMC0_DATA3 0x21 - SC_P_EMMC0_DATA4_CONN_EMMC0_DATA4 0x21 - SC_P_EMMC0_DATA5_CONN_EMMC0_DATA5 0x21 - SC_P_EMMC0_DATA6_CONN_EMMC0_DATA6 0x21 - SC_P_EMMC0_DATA7_CONN_EMMC0_DATA7 0x21 - SC_P_EMMC0_STROBE_CONN_EMMC0_STROBE 0x41 - SC_P_EMMC0_RESET_B_CONN_EMMC0_RESET_B 0x21 - >; - }; - - pinctrl_usdhc1_200mhz: usdhc1grp200mhz { - fsl,pins = < - SC_P_EMMC0_CLK_CONN_EMMC0_CLK 0x06000041 - SC_P_EMMC0_CMD_CONN_EMMC0_CMD 0x21 - SC_P_EMMC0_DATA0_CONN_EMMC0_DATA0 0x21 - SC_P_EMMC0_DATA1_CONN_EMMC0_DATA1 0x21 - SC_P_EMMC0_DATA2_CONN_EMMC0_DATA2 0x21 - SC_P_EMMC0_DATA3_CONN_EMMC0_DATA3 0x21 - SC_P_EMMC0_DATA4_CONN_EMMC0_DATA4 0x21 - SC_P_EMMC0_DATA5_CONN_EMMC0_DATA5 0x21 - SC_P_EMMC0_DATA6_CONN_EMMC0_DATA6 0x21 - SC_P_EMMC0_DATA7_CONN_EMMC0_DATA7 0x21 - SC_P_EMMC0_STROBE_CONN_EMMC0_STROBE 0x41 - SC_P_EMMC0_RESET_B_CONN_EMMC0_RESET_B 0x21 - >; - }; - - /* Apalis MMC1_CD# */ - pinctrl_usdhc2_gpio: mmc1gpiogrp { - fsl,pins = < - SC_P_USDHC1_CD_B_LSIO_GPIO4_IO22 0x06000021 /* SODIMM 164 */ - >; - }; - - pinctrl_usdhc2_gpio_sleep: usdhc1gpioslpgrp { - fsl,pins = < - SC_P_USDHC1_CD_B_LSIO_GPIO4_IO22 0x60 /* SODIMM 164 */ - >; - }; - - /* Apalis USBH_EN */ - pinctrl_usbh_en: usbhen { - fsl,pins = < - SC_P_USB_SS3_TC1_LSIO_GPIO4_IO04 0x40 /* SODIMM 84 */ - >; - }; - - /* Apalis MMC1 */ - pinctrl_usdhc2: usdhc2grp { - fsl,pins = < - SC_P_USDHC1_CLK_CONN_USDHC1_CLK 0x06000041 /* SODIMM 154 */ - SC_P_USDHC1_CMD_CONN_USDHC1_CMD 0x21 /* SODIMM 150 */ - SC_P_USDHC1_DATA0_CONN_USDHC1_DATA0 0x21 /* SODIMM 160 */ - SC_P_USDHC1_DATA1_CONN_USDHC1_DATA1 0x21 /* SODIMM 162 */ - SC_P_USDHC1_DATA2_CONN_USDHC1_DATA2 0x21 /* SODIMM 144 */ - SC_P_USDHC1_DATA3_CONN_USDHC1_DATA3 0x21 /* SODIMM 146 */ - SC_P_USDHC1_VSELECT_CONN_USDHC1_VSELECT 0x21 - >; - }; - - pinctrl_usdhc2_100mhz: usdhc2grp100mhz { - fsl,pins = < - SC_P_USDHC1_CLK_CONN_USDHC1_CLK 0x06000041 /* SODIMM 154 */ - SC_P_USDHC1_CMD_CONN_USDHC1_CMD 0x21 /* SODIMM 150 */ - SC_P_USDHC1_DATA0_CONN_USDHC1_DATA0 0x21 /* SODIMM 160 */ - SC_P_USDHC1_DATA1_CONN_USDHC1_DATA1 0x21 /* SODIMM 162 */ - SC_P_USDHC1_DATA2_CONN_USDHC1_DATA2 0x21 /* SODIMM 144 */ - SC_P_USDHC1_DATA3_CONN_USDHC1_DATA3 0x21 /* SODIMM 146 */ - SC_P_USDHC1_VSELECT_CONN_USDHC1_VSELECT 0x21 - >; - }; - - pinctrl_usdhc2_200mhz: usdhc2grp200mhz { - fsl,pins = < - SC_P_USDHC1_CLK_CONN_USDHC1_CLK 0x06000041 /* SODIMM 154 */ - SC_P_USDHC1_CMD_CONN_USDHC1_CMD 0x21 /* SODIMM 150 */ - SC_P_USDHC1_DATA0_CONN_USDHC1_DATA0 0x21 /* SODIMM 160 */ - SC_P_USDHC1_DATA1_CONN_USDHC1_DATA1 0x21 /* SODIMM 162 */ - SC_P_USDHC1_DATA2_CONN_USDHC1_DATA2 0x21 /* SODIMM 144 */ - SC_P_USDHC1_DATA3_CONN_USDHC1_DATA3 0x21 /* SODIMM 146 */ - SC_P_USDHC1_VSELECT_CONN_USDHC1_VSELECT 0x21 - >; - }; - - pinctrl_usdhc2_sleep: usdhc2slpgrp { - fsl,pins = < - SC_P_USDHC1_CLK_LSIO_GPIO4_IO23 0x60 /* SODIMM 154 */ - SC_P_USDHC1_CMD_LSIO_GPIO4_IO24 0x60 /* SODIMM 150 */ - SC_P_USDHC1_DATA0_LSIO_GPIO4_IO25 0x60 /* SODIMM 160 */ - SC_P_USDHC1_DATA1_LSIO_GPIO4_IO26 0x60 /* SODIMM 162 */ - SC_P_USDHC1_DATA2_LSIO_GPIO4_IO27 0x60 /* SODIMM 144 */ - SC_P_USDHC1_DATA3_LSIO_GPIO4_IO28 0x60 /* SODIMM 146 */ - SC_P_USDHC1_VSELECT_CONN_USDHC1_VSELECT 0x21 - >; - }; - }; -}; - -/* Apalis Gigabit LAN */ -&fec1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_fec1>; - fsl,magic-packet; - phy-handle = <ðphy0>; - phy-mode = "rgmii-id"; - phy-reset-duration = <10>; - phy-reset-post-delay = <150>; - phy-reset-gpios = <&gpio3 4 GPIO_ACTIVE_LOW>; - status = "okay"; - - mdio { - #address-cells = <1>; - #size-cells = <0>; - - ethphy0: ethernet-phy@4 { - compatible = "ethernet-phy-ieee802.3-c22"; - reg = <4>; - }; - }; -}; - -/* Apalis UART1 */ -&lpuart1 { - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_lpuart1>; - status = "okay"; -}; - -/* On-module eMMC */ -&usdhc1 { - bus-width = <8>; - non-removable; - pinctrl-names = "default", "state_100mhz", "state_200mhz"; - pinctrl-0 = <&pinctrl_usdhc1>; - pinctrl-1 = <&pinctrl_usdhc1_100mhz>; - pinctrl-2 = <&pinctrl_usdhc1_200mhz>; - status = "okay"; -}; - -/* Apalis MMC1 */ -&usdhc2 { - bus-width = <4>; - cd-gpios = <&gpio4 22 GPIO_ACTIVE_LOW>; - pinctrl-names = "default", "state_100mhz", "state_200mhz", "sleep"; - pinctrl-0 = <&pinctrl_usdhc2>, <&pinctrl_usdhc2_gpio>; - pinctrl-1 = <&pinctrl_usdhc2_100mhz>, <&pinctrl_usdhc2_gpio>; - pinctrl-2 = <&pinctrl_usdhc2_200mhz>, <&pinctrl_usdhc2_gpio>; - pinctrl-3 = <&pinctrl_usdhc2_sleep>, <&pinctrl_usdhc2_gpio_sleep>; - disable-wp; - status = "okay"; -}; diff --git a/arch/arm/mach-imx/imx8/Kconfig b/arch/arm/mach-imx/imx8/Kconfig index f969833baba..5e1b20a4229 100644 --- a/arch/arm/mach-imx/imx8/Kconfig +++ b/arch/arm/mach-imx/imx8/Kconfig @@ -54,11 +54,6 @@ config TARGET_COLIBRI_IMX8X select BOARD_LATE_INIT select IMX8QXP
-config TARGET_APALIS_IMX8X - bool "Support Apalis iMX8X module" - select BOARD_LATE_INIT - select IMX8QXP - config TARGET_DENEB bool "Support i.MX8QXP Capricorn Deneb board" select BOARD_LATE_INIT @@ -105,7 +100,6 @@ source "board/congatec/cgtqmx8/Kconfig" source "board/advantech/imx8qm_rom7720_a1/Kconfig" source "board/toradex/apalis-imx8/Kconfig" source "board/toradex/colibri-imx8x/Kconfig" -source "board/toradex/apalis-imx8x/Kconfig" source "board/siemens/capricorn/Kconfig"
config IMX_SNVS_SEC_SC diff --git a/board/toradex/apalis-imx8x/Kconfig b/board/toradex/apalis-imx8x/Kconfig deleted file mode 100644 index d6cda7e3ff0..00000000000 --- a/board/toradex/apalis-imx8x/Kconfig +++ /dev/null @@ -1,33 +0,0 @@ -if TARGET_APALIS_IMX8X - -config SYS_BOARD - default "apalis-imx8x" - -config SYS_VENDOR - default "toradex" - -config SYS_CONFIG_NAME - default "apalis-imx8x" - -config TDX_CFG_BLOCK - default y - -config TDX_HAVE_MMC - default y - -config TDX_CFG_BLOCK_DEV - default "0" - -config TDX_CFG_BLOCK_PART - default "1" - -# Toradex config block in eMMC, at the end of 1st "boot sector" -config TDX_CFG_BLOCK_OFFSET - default "-512" - -config IMX_CONFIG - default "board/toradex/apalis-imx8x/apalis-imx8x-imximage.cfg" - -source "board/toradex/common/Kconfig" - -endif diff --git a/board/toradex/apalis-imx8x/MAINTAINERS b/board/toradex/apalis-imx8x/MAINTAINERS deleted file mode 100644 index 93d6cdd4742..00000000000 --- a/board/toradex/apalis-imx8x/MAINTAINERS +++ /dev/null @@ -1,10 +0,0 @@ -Apalis iMX8X -M: Marcel Ziswiler marcel.ziswiler@toradex.com -W: http://developer.toradex.com/software/linux/linux-software -S: Maintained -F: arch/arm/dts/fsl-imx8x-apalis.dts -F: arch/arm/dts/fsl-imx8x-apalis-u-boot.dtsi -F: board/toradex/apalis-imx8x/ -F: configs/apalis-imx8x_defconfig -F: doc/board/toradex/apalis-imx8x.rst -F: include/configs/apalis-imx8x.h diff --git a/board/toradex/apalis-imx8x/Makefile b/board/toradex/apalis-imx8x/Makefile deleted file mode 100644 index 9d6e85b7429..00000000000 --- a/board/toradex/apalis-imx8x/Makefile +++ /dev/null @@ -1,6 +0,0 @@ -# SPDX-License-Identifier: GPL-2.0+ -# -# Copyright 2020 Toradex -# - -obj-y += apalis-imx8x.o diff --git a/board/toradex/apalis-imx8x/apalis-imx8x-imximage.cfg b/board/toradex/apalis-imx8x/apalis-imx8x-imximage.cfg deleted file mode 100644 index c229706f80a..00000000000 --- a/board/toradex/apalis-imx8x/apalis-imx8x-imximage.cfg +++ /dev/null @@ -1,23 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright 2020 Toradex - * - * Refer doc/imx/mkimage/imx8image.txt for more details about how-to configure - * and create imx8image boot image - */ - - -/* Boot from SD, sector size 0x400 */ -BOOT_FROM EMMC_FASTBOOT 0x400 -/* SoC type IMX8QX */ -SOC_TYPE IMX8QX -/* Append seco container image */ -APPEND mx8qx-ahab-container.img -/* Create the 2nd container */ -CONTAINER -/* Add scfw image with exec attribute */ -IMAGE SCU mx8qx-apalis-scfw-tcm.bin -/* Add ATF image with exec attribute */ -IMAGE A35 bl31.bin 0x80000000 -/* Add U-Boot image with load attribute */ -DATA A35 u-boot-dtb.bin 0x80020000 diff --git a/board/toradex/apalis-imx8x/apalis-imx8x.c b/board/toradex/apalis-imx8x/apalis-imx8x.c deleted file mode 100644 index ac3bac66a96..00000000000 --- a/board/toradex/apalis-imx8x/apalis-imx8x.c +++ /dev/null @@ -1,155 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Copyright 2020 Toradex - */ - -#include <common.h> -#include <cpu_func.h> -#include <init.h> - -#include <asm/arch/clock.h> -#include <asm/arch/imx8-pins.h> -#include <asm/arch/iomux.h> -#include <asm/arch/sci/sci.h> -#include <asm/arch/sys_proto.h> -#include <asm/global_data.h> -#include <asm/gpio.h> -#include <asm/io.h> -#include <env.h> -#include <errno.h> -#include <linux/libfdt.h> - -#include "../common/tdx-cfg-block.h" - -DECLARE_GLOBAL_DATA_PTR; - -#define UART_PAD_CTRL ((SC_PAD_CONFIG_OUT_IN << PADRING_CONFIG_SHIFT) | \ - (SC_PAD_ISO_OFF << PADRING_LPCONFIG_SHIFT) | \ - (SC_PAD_28FDSOI_DSE_DV_HIGH << PADRING_DSE_SHIFT) | \ - (SC_PAD_28FDSOI_PS_PU << PADRING_PULL_SHIFT)) - -static iomux_cfg_t uart1_pads[] = { - SC_P_UART1_RX | MUX_PAD_CTRL(UART_PAD_CTRL), - SC_P_UART1_TX | MUX_PAD_CTRL(UART_PAD_CTRL), -}; - -static void setup_iomux_uart(void) -{ - imx8_iomux_setup_multiple_pads(uart1_pads, ARRAY_SIZE(uart1_pads)); -} - -void board_mem_get_layout(u64 *phys_sdram_1_start, - u64 *phys_sdram_1_size, - u64 *phys_sdram_2_start, - u64 *phys_sdram_2_size) -{ - u32 is_dualx = 0, val = 0; - sc_err_t scierr = sc_misc_otp_fuse_read(-1, 6, &val); - - if (scierr == SC_ERR_NONE) { - /* DX has two A35 cores disabled */ - is_dualx = (val & 0xf) != 0x0; - } - - *phys_sdram_1_start = PHYS_SDRAM_1; - if (is_dualx) - /* Our DX based SKUs only have 1 GB RAM */ - *phys_sdram_1_size = SZ_1G; - else - *phys_sdram_1_size = PHYS_SDRAM_1_SIZE; - *phys_sdram_2_start = PHYS_SDRAM_2; - *phys_sdram_2_size = PHYS_SDRAM_2_SIZE; -} - -int board_early_init_f(void) -{ - sc_pm_clock_rate_t rate; - sc_err_t err = 0; - - /* - * This works around that having only UART3 up the baudrate is 1.2M - * instead of 115.2k. Set UART0 clock root to 80 MHz - */ - rate = 80000000; - err = sc_pm_set_clock_rate(-1, SC_R_UART_0, SC_PM_CLK_PER, &rate); - if (err != SC_ERR_NONE) - return 0; - - /* Set UART3 clock root to 80 MHz and enable it */ - rate = SC_80MHZ; - err = sc_pm_setup_uart(SC_R_UART_1, rate); - if (err != SC_ERR_NONE) - return 0; - - setup_iomux_uart(); - - return 0; -} - -#if IS_ENABLED(CONFIG_DM_GPIO) -static void board_gpio_init(void) -{ - /* TODO */ -} -#else -static inline void board_gpio_init(void) {} -#endif - -#if IS_ENABLED(CONFIG_FEC_MXC) -#include <miiphy.h> - -int board_phy_config(struct phy_device *phydev) -{ - if (phydev->drv->config) - phydev->drv->config(phydev); - - return 0; -} -#endif - -int checkboard(void) -{ - puts("Model: Toradex Apalis iMX8X\n"); - - build_info(); - print_bootinfo(); - - return 0; -} - -int board_init(void) -{ - board_gpio_init(); - - return 0; -} - -/* - * Board specific reset that is system reset. - */ -void reset_cpu(void) -{ - /* TODO */ -} - -#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) -int ft_board_setup(void *blob, struct bd_info *bd) -{ - return ft_common_board_setup(blob, bd); -} -#endif - -int board_mmc_get_env_dev(int devno) -{ - return devno; -} - -int board_late_init(void) -{ -#ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG -/* TODO move to common */ - env_set("board_name", "Apalis iMX8X"); -#endif - - return 0; -} diff --git a/board/toradex/common/tdx-cfg-block.c b/board/toradex/common/tdx-cfg-block.c index 7cadd05c0a7..0e657a2a0a9 100644 --- a/board/toradex/common/tdx-cfg-block.c +++ b/board/toradex/common/tdx-cfg-block.c @@ -13,7 +13,6 @@
#if defined(CONFIG_TARGET_APALIS_IMX6) || \ defined(CONFIG_TARGET_APALIS_IMX8) || \ - defined(CONFIG_TARGET_APALIS_IMX8X) || \ defined(CONFIG_TARGET_COLIBRI_IMX6) || \ defined(CONFIG_TARGET_COLIBRI_IMX8X) || \ defined(CONFIG_TARGET_VERDIN_IMX8MM) || \ @@ -379,7 +378,6 @@ static int get_cfgblock_interactive(void) it = console_buffer[0];
#if defined(CONFIG_TARGET_APALIS_IMX8) || \ - defined(CONFIG_TARGET_APALIS_IMX8X) || \ defined(CONFIG_TARGET_COLIBRI_IMX6ULL) || \ defined(CONFIG_TARGET_COLIBRI_IMX8X) || \ defined(CONFIG_TARGET_VERDIN_IMX8MM) || \ @@ -451,16 +449,7 @@ static int get_cfgblock_interactive(void) tdx_hw_tag.prodid = APALIS_IMX8QP; } } else if (is_cpu_type(MXC_CPU_IMX8QXP)) { -#ifdef CONFIG_TARGET_APALIS_IMX8X - if (it == 'y' || it == 'Y' || wb == 'y' || wb == 'Y') { - tdx_hw_tag.prodid = APALIS_IMX8QXP_WIFI_BT_IT; - } else { - if (gd->ram_size == 0x40000000) - tdx_hw_tag.prodid = APALIS_IMX8DXP; - else - tdx_hw_tag.prodid = APALIS_IMX8QXP; - } -#elif CONFIG_TARGET_COLIBRI_IMX8X +#ifdef CONFIG_TARGET_COLIBRI_IMX8X if (it == 'y' || it == 'Y') { if (wb == 'y' || wb == 'Y') tdx_hw_tag.prodid = COLIBRI_IMX8QXP_WIFI_BT_IT; diff --git a/configs/apalis-imx8x_defconfig b/configs/apalis-imx8x_defconfig deleted file mode 100644 index b67cdece71c..00000000000 --- a/configs/apalis-imx8x_defconfig +++ /dev/null @@ -1,82 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_IMX8=y -CONFIG_SYS_TEXT_BASE=0x80020000 -CONFIG_SYS_MALLOC_LEN=0x2800000 -CONFIG_SYS_MALLOC_F_LEN=0x4000 -CONFIG_NR_DRAM_BANKS=3 -CONFIG_ENV_SIZE=0x2000 -CONFIG_ENV_OFFSET=0xFFFFDE00 -CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="fsl-imx8qxp-apalis" -CONFIG_TARGET_APALIS_IMX8X=y -CONFIG_SYS_LOAD_ADDR=0x89000000 -CONFIG_SYS_MEMTEST_START=0x88000000 -CONFIG_SYS_MEMTEST_END=0x89000000 -CONFIG_DISTRO_DEFAULTS=y -CONFIG_REMAKE_ELF=y -CONFIG_FIT=y -CONFIG_OF_SYSTEM_SETUP=y -CONFIG_BOOTDELAY=1 -CONFIG_LOG=y -# CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_BOARD_EARLY_INIT_F=y -CONFIG_SYS_PROMPT="Apalis iMX8X # " -CONFIG_CMD_CPU=y -# CONFIG_BOOTM_NETBSD is not set -CONFIG_CMD_ASKENV=y -CONFIG_CMD_MEMTEST=y -CONFIG_CMD_CLK=y -CONFIG_CMD_DM=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y -CONFIG_CMD_PCI=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_UUID=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_ENV_OVERWRITE=y -CONFIG_ENV_IS_IN_MMC=y -CONFIG_SYS_RELOC_GD_ENV_ADDR=y -CONFIG_SYS_MMC_ENV_PART=1 -CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y -CONFIG_USE_ETHPRIME=y -CONFIG_ETHPRIME="eth0" -CONFIG_VERSION_VARIABLE=y -CONFIG_NET_RANDOM_ETHADDR=y -CONFIG_IP_DEFRAG=y -CONFIG_TFTP_BLOCKSIZE=4096 -CONFIG_TFTP_TSIZE=y -CONFIG_BOOTCOUNT_LIMIT=y -CONFIG_BOOTCOUNT_ENV=y -CONFIG_CLK_IMX8=y -CONFIG_CPU=y -CONFIG_MXC_GPIO=y -CONFIG_DM_I2C=y -CONFIG_SYS_I2C_IMX_LPI2C=y -CONFIG_I2C_MUX=y -CONFIG_I2C_MUX_PCA954x=y -CONFIG_MISC=y -CONFIG_SUPPORT_EMMC_BOOT=y -CONFIG_FSL_USDHC=y -CONFIG_PHYLIB=y -CONFIG_PHY_ADDR_ENABLE=y -CONFIG_PHY_MICREL=y -CONFIG_PHY_MICREL_KSZ90X1=y -CONFIG_DM_ETH=y -CONFIG_FEC_MXC_SHARE_MDIO=y -CONFIG_FEC_MXC_MDIO_BASE=0x5B040000 -CONFIG_FEC_MXC=y -CONFIG_MII=y -CONFIG_PCI=y -CONFIG_PINCTRL=y -CONFIG_PINCTRL_IMX8=y -CONFIG_POWER_DOMAIN=y -CONFIG_IMX8_POWER_DOMAIN=y -CONFIG_DM_REGULATOR=y -CONFIG_DM_REGULATOR_FIXED=y -CONFIG_DM_REGULATOR_GPIO=y -CONFIG_DM_SERIAL=y -CONFIG_FSL_LPUART=y -CONFIG_DM_THERMAL=y -CONFIG_IMX_SCU_THERMAL=y -# CONFIG_EFI_LOADER is not set diff --git a/doc/board/toradex/apalis-imx8x.rst b/doc/board/toradex/apalis-imx8x.rst deleted file mode 100644 index e62578b1527..00000000000 --- a/doc/board/toradex/apalis-imx8x.rst +++ /dev/null @@ -1,77 +0,0 @@ -.. SPDX-License-Identifier: GPL-2.0+ - -Apalis iMX8X V1.1A Module (SoC NXP i.MX8QXP RevB) -================================================= - -Quick Start ------------ - -- Get and Build the ARM trusted firmware -- Get System Controller firmware -- Get SECO container -- Build U-Boot -- Load U-Boot binary using uuu -- Flash U-Boot binary into the eMMC -- Boot - -Note: builddir is U-Boot build directory (source directory for in-tree builds) - -Get and Build the ARM Trusted Firmware --------------------------------------- - -.. code-block:: bash - - $ cd $(builddir) - $ git clone -b toradex_imx_5.4.70_2.3.0 http://git.toradex.com/cgit/imx-atf.git - $ make PLAT=imx8qx bl31 -C imx-atf - $ cp imx-atf/build/imx8qx/release/bl31.bin $(builddir) - -Get System Controller firmware ---------------------------------------- - -.. code-block:: bash - - $ wget https://github.com/toradex/i.MX-System-Controller-Firmware/raw/master/src/sc... - -Get SECO container ---------------------------------------- - -.. code-block:: bash - - $ wget https://www.nxp.com/lgfiles/NMG/MAD/YOCTO/imx-seco-3.7.4.bin - $ sh imx-seco-3.7.4.bin - $ cp imx-seco-3.7.4/firmware/seco/mx8qxb0-ahab-container.img $(builddir)/mx8qx-ahab-container.img - -Build U-Boot ------------- -.. code-block:: bash - - $ make apalis-imx8x_defconfig - $ make u-boot-dtb.imx - -Load the U-Boot Binary Using UUU --------------------------------- - -Get the latest version of the universal update utility (uuu) aka ``mfgtools 3.0``: - -https://community.nxp.com/external-link.jspa?url=https%3A%2F%2Fgithub.com%2F... - -Put the module into USB recovery aka serial downloader mode, connect USB device -to your host and execute uuu: - -.. code-block:: bash - - sudo ./uuu $(builddir)/u-boot-dtb.imx - -Flash the U-Boot Binary into the eMMC -------------------------------------- - -Burn the ``u-boot-dtb.imx`` binary to the primary eMMC hardware boot area -partition and boot: - -.. code-block:: bash - - load mmc 1:1 $loadaddr u-boot-dtb.imx - setexpr blkcnt ${filesize} + 0x1ff && setexpr blkcnt ${blkcnt} / 0x200 - mmc dev 0 1 - mmc write ${loadaddr} 0x0 ${blkcnt} diff --git a/doc/board/toradex/index.rst b/doc/board/toradex/index.rst index 1cd926a7303..ead5efbb955 100644 --- a/doc/board/toradex/index.rst +++ b/doc/board/toradex/index.rst @@ -7,7 +7,6 @@ Toradex :maxdepth: 2
apalis-imx8 - apalis-imx8x colibri_imx7 colibri-imx8x verdin-imx8mm diff --git a/include/configs/apalis-imx8x.h b/include/configs/apalis-imx8x.h deleted file mode 100644 index 71a80f38bbb..00000000000 --- a/include/configs/apalis-imx8x.h +++ /dev/null @@ -1,127 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright 2020 Toradex - */ - -#ifndef __APALIS_IMX8X_H -#define __APALIS_IMX8X_H - -#include <asm/arch/imx-regs.h> -#include <linux/sizes.h> -#include <linux/stringify.h> - -#define CONFIG_SYS_FSL_ESDHC_ADDR 0 -#define USDHC1_BASE_ADDR 0x5b010000 -#define USDHC2_BASE_ADDR 0x5b020000 - -#define CONFIG_IPADDR 192.168.10.2 -#define CONFIG_NETMASK 255.255.255.0 -#define CONFIG_SERVERIP 192.168.10.1 - -#define MEM_LAYOUT_ENV_SETTINGS \ - "kernel_addr_r=0x80280000\0" \ - "fdt_addr_r=0x83100000\0" \ - "ramdisk_addr_r=0x8a000000\0" \ - "scriptaddr=0x83200000\0" - -#ifdef CONFIG_AHAB_BOOT -#define AHAB_ENV "sec_boot=yes\0" -#else -#define AHAB_ENV "sec_boot=no\0" -#endif - -/* Boot M4 */ -#define M4_BOOT_ENV \ - "m4_0_image=m4_0.bin\0" \ - "loadm4image_0=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} " \ - "${m4_0_image}\0" \ - "m4boot_0=run loadm4image_0; dcache flush; bootaux ${loadaddr} 0\0" \ - -#define MFG_NAND_PARTITION "" - -#define BOOT_TARGET_DEVICES(func) \ - func(MMC, mmc, 1) \ - func(MMC, mmc, 0) \ - func(DHCP, dhcp, na) -#include <config_distro_bootcmd.h> -#undef BOOTENV_RUN_NET_USB_START -#define BOOTENV_RUN_NET_USB_START "" - -#define CONFIG_MFG_ENV_SETTINGS \ - "mfgtool_args=setenv bootargs ${consoleargs} " \ - "rdinit=/linuxrc g_mass_storage.stall=0 " \ - "g_mass_storage.removable=1 g_mass_storage.idVendor=0x066F " \ - "g_mass_storage.idProduct=0x37FF " \ - "g_mass_storage.iSerialNumber="" " MFG_NAND_PARTITION \ - "${vidargs} clk_ignore_unused\0" \ - "initrd_addr=0x83800000\0" \ - "bootcmd_mfg=run mfgtool_args;booti ${loadaddr} ${initrd_addr} " \ - "${fdt_addr};\0" \ - -/* Initial environment variables */ -#define CONFIG_EXTRA_ENV_SETTINGS \ - AHAB_ENV \ - BOOTENV \ - CONFIG_MFG_ENV_SETTINGS \ - M4_BOOT_ENV \ - MEM_LAYOUT_ENV_SETTINGS \ - "boot_file=Image\0" \ - "consoleargs=console=ttyLP3,${baudrate} earlycon\0" \ - "fdt_file=imx8qxp-apalis-eval.dtb\0" \ - "fdtfile=imx8qxp-apalis-eval.dtb\0" \ - "finduuid=part uuid mmc ${mmcdev}:2 uuid\0" \ - "image=Image\0" \ - "initrd_addr=0x83800000\0" \ - "mmcargs=setenv bootargs ${consoleargs} " \ - "root=PARTUUID=${uuid} rootwait " \ - "mmcdev=" __stringify(CONFIG_SYS_MMC_ENV_DEV) "\0" \ - "mmcpart=1\0" \ - "netargs=setenv bootargs ${consoleargs} " \ - "root=/dev/nfs ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp " \ - "${vidargs}\0" \ - "nfsboot=run netargs; dhcp ${loadaddr} ${image}; tftp ${fdt_addr} " \ - "apalis-imx8x/${fdt_file}; booti ${loadaddr} - " \ - "${fdt_addr}\0" \ - "panel=NULL\0" \ - "script=boot.scr\0" \ - "update_uboot=askenv confirm Did you load u-boot-dtb.imx (y/N)?; " \ - "if test "$confirm" = "y"; then " \ - "setexpr blkcnt ${filesize} + 0x1ff && setexpr blkcnt " \ - "${blkcnt} / 0x200; mmc dev 0 1; mmc write ${loadaddr} 0x0 " \ - "${blkcnt}; fi\0" \ - "vidargs=video=imxdpufb5:off video=imxdpufb6:off video=imxdpufb7:off\0" - -/* Link Definitions */ - -#define CONFIG_SYS_INIT_SP_ADDR 0x80200000 - -/* Environment in eMMC, before config block at the end of 1st "boot sector" */ - -/* On Apalis iMX8X USDHC1 is eMMC, USDHC2 is 4-bit SD */ -#define CONFIG_SYS_FSL_USDHC_NUM 2 - -#define CONFIG_SYS_BOOTM_LEN SZ_64M /* Increase max gunzip size */ - -#define CONFIG_SYS_SDRAM_BASE 0x80000000 -#define PHYS_SDRAM_1 0x80000000 -#define PHYS_SDRAM_2 0x880000000 -#define PHYS_SDRAM_1_SIZE SZ_2G /* 2 GB */ -#define PHYS_SDRAM_2_SIZE 0x00000000 /* 0 GB */ - -/* Monitor Command Prompt */ -#define CONFIG_SYS_CBSIZE SZ_2K -#define CONFIG_SYS_MAXARGS 64 -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ - sizeof(CONFIG_SYS_PROMPT) + 16) - -/* Generic Timer Definitions */ -#define COUNTER_FREQUENCY 8000000 /* 8MHz */ - -/* Networking */ -#define CONFIG_FEC_ENET_DEV 0 -#define IMX_FEC_BASE 0x5b040000 -#define CONFIG_FEC_MXC_PHYADDR 0x4 -#define PHY_ANEG_TIMEOUT 20000 - -#endif /* __APALIS_IMX8X_H */
From: Denys Drozdov denys.drozdov@toradex.com Drop Apalis iMX8X platform as it never left sample state and is no longer supported. Signed-off-by: Denys Drozdov denys.drozdov@toradex.com Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com
Best regards, Stefano Babic
As video support is very specific depending on the exact display customisation we decided to disable video support for all out modules by default.
Signed-off-by: Igor Opaniuk igor.opaniuk@toradex.com Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com ---
configs/apalis_imx6_defconfig | 10 ---------- configs/colibri-imx6ull-emmc_defconfig | 7 ------- configs/colibri-imx6ull_defconfig | 8 -------- configs/colibri_imx6_defconfig | 10 ---------- configs/colibri_imx7_defconfig | 8 -------- configs/colibri_imx7_emmc_defconfig | 7 ------- configs/colibri_t20_defconfig | 5 ----- configs/colibri_vf_defconfig | 5 ----- 8 files changed, 60 deletions(-)
diff --git a/configs/apalis_imx6_defconfig b/configs/apalis_imx6_defconfig index 3fa1bb58a43..cdf169df046 100644 --- a/configs/apalis_imx6_defconfig +++ b/configs/apalis_imx6_defconfig @@ -56,7 +56,6 @@ CONFIG_CMD_USB=y CONFIG_CMD_USB_SDP=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_NFS is not set -CONFIG_CMD_BMP=y CONFIG_CMD_BOOTCOUNT=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y @@ -106,13 +105,4 @@ CONFIG_USB_GADGET_VENDOR_NUM=0x1b67 CONFIG_USB_GADGET_PRODUCT_NUM=0x4000 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_DM_VIDEO=y -CONFIG_VIDEO_LOGO=y -# CONFIG_VIDEO_BPP8 is not set -# CONFIG_VIDEO_BPP32 is not set -CONFIG_SYS_WHITE_ON_BLACK=y -CONFIG_VIDEO_IPUV3=y -CONFIG_SPLASH_SCREEN=y -CONFIG_SPLASH_SCREEN_ALIGN=y -CONFIG_BMP_16BPP=y CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/colibri-imx6ull-emmc_defconfig b/configs/colibri-imx6ull-emmc_defconfig index 8811d7749d9..0e7f29b56bc 100644 --- a/configs/colibri-imx6ull-emmc_defconfig +++ b/configs/colibri-imx6ull-emmc_defconfig @@ -37,7 +37,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_USB_SDP=y CONFIG_CMD_USB_MASS_STORAGE=y -CONFIG_CMD_BMP=y CONFIG_CMD_BOOTCOUNT=y CONFIG_CMD_CACHE=y CONFIG_CMD_REGULATOR=y @@ -79,10 +78,4 @@ CONFIG_USB_GADGET_VENDOR_NUM=0x1b67 CONFIG_USB_GADGET_PRODUCT_NUM=0x4000 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_DM_VIDEO=y -CONFIG_VIDEO_LOGO=y -CONFIG_SYS_WHITE_ON_BLACK=y -CONFIG_SPLASH_SCREEN=y -CONFIG_SPLASH_SCREEN_ALIGN=y -CONFIG_BMP_16BPP=y CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/colibri-imx6ull_defconfig b/configs/colibri-imx6ull_defconfig index b75e21799e1..b04f171549b 100644 --- a/configs/colibri-imx6ull_defconfig +++ b/configs/colibri-imx6ull_defconfig @@ -42,7 +42,6 @@ CONFIG_CMD_NAND_TORTURE=y CONFIG_CMD_USB=y CONFIG_CMD_USB_SDP=y CONFIG_CMD_USB_MASS_STORAGE=y -CONFIG_CMD_BMP=y CONFIG_CMD_BOOTCOUNT=y CONFIG_CMD_CACHE=y CONFIG_CMD_REGULATOR=y @@ -95,12 +94,5 @@ CONFIG_USB_GADGET_VENDOR_NUM=0x1b67 CONFIG_USB_GADGET_PRODUCT_NUM=0x4000 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_DM_VIDEO=y -CONFIG_VIDEO_LOGO=y -CONFIG_SYS_WHITE_ON_BLACK=y -CONFIG_VIDEO_MXS=y -CONFIG_SPLASH_SCREEN=y -CONFIG_SPLASH_SCREEN_ALIGN=y -CONFIG_BMP_16BPP=y CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_FDT_FIXUP_PARTITIONS=y diff --git a/configs/colibri_imx6_defconfig b/configs/colibri_imx6_defconfig index 04b73a8b9cb..4aecb283332 100644 --- a/configs/colibri_imx6_defconfig +++ b/configs/colibri_imx6_defconfig @@ -55,7 +55,6 @@ CONFIG_CMD_USB=y CONFIG_CMD_USB_SDP=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_NFS is not set -CONFIG_CMD_BMP=y CONFIG_CMD_BOOTCOUNT=y CONFIG_CMD_CACHE=y CONFIG_CMD_TIME=y @@ -104,13 +103,4 @@ CONFIG_USB_GADGET_VENDOR_NUM=0x1b67 CONFIG_USB_GADGET_PRODUCT_NUM=0x4000 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_DM_VIDEO=y -CONFIG_VIDEO_LOGO=y -# CONFIG_VIDEO_BPP8 is not set -# CONFIG_VIDEO_BPP32 is not set -CONFIG_SYS_WHITE_ON_BLACK=y -CONFIG_VIDEO_IPUV3=y -CONFIG_SPLASH_SCREEN=y -CONFIG_SPLASH_SCREEN_ALIGN=y -CONFIG_BMP_16BPP=y CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/colibri_imx7_defconfig b/configs/colibri_imx7_defconfig index 1ccc7163cfb..f3cd7a4d5ae 100644 --- a/configs/colibri_imx7_defconfig +++ b/configs/colibri_imx7_defconfig @@ -40,7 +40,6 @@ CONFIG_CMD_NAND_TORTURE=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_BOOTP_PXE is not set -CONFIG_CMD_BMP=y CONFIG_CMD_BOOTCOUNT=y CONFIG_CMD_CACHE=y # CONFIG_CMD_HASH is not set @@ -90,12 +89,5 @@ CONFIG_USB_GADGET_VENDOR_NUM=0x1b67 CONFIG_USB_GADGET_PRODUCT_NUM=0x4000 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_DM_VIDEO=y -CONFIG_VIDEO_LOGO=y -CONFIG_SYS_WHITE_ON_BLACK=y -CONFIG_VIDEO_MXS=y -CONFIG_SPLASH_SCREEN=y -CONFIG_SPLASH_SCREEN_ALIGN=y -CONFIG_BMP_16BPP=y CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_FDT_FIXUP_PARTITIONS=y diff --git a/configs/colibri_imx7_emmc_defconfig b/configs/colibri_imx7_emmc_defconfig index dcac585ab38..2b97890497c 100644 --- a/configs/colibri_imx7_emmc_defconfig +++ b/configs/colibri_imx7_emmc_defconfig @@ -38,7 +38,6 @@ CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y -CONFIG_CMD_BMP=y CONFIG_CMD_BOOTCOUNT=y CONFIG_CMD_CACHE=y # CONFIG_CMD_HASH is not set @@ -83,10 +82,4 @@ CONFIG_USB_GADGET_MANUFACTURER="Toradex" CONFIG_USB_GADGET_VENDOR_NUM=0x1b67 CONFIG_USB_GADGET_PRODUCT_NUM=0x4000 CONFIG_CI_UDC=y -CONFIG_DM_VIDEO=y -CONFIG_VIDEO_LOGO=y -CONFIG_SYS_WHITE_ON_BLACK=y -CONFIG_SPLASH_SCREEN=y -CONFIG_SPLASH_SCREEN_ALIGN=y -CONFIG_BMP_16BPP=y CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/colibri_t20_defconfig b/configs/colibri_t20_defconfig index b883fc105f5..00f45dc115f 100644 --- a/configs/colibri_t20_defconfig +++ b/configs/colibri_t20_defconfig @@ -25,7 +25,6 @@ CONFIG_CMD_MMC=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_NFS is not set -CONFIG_CMD_BMP=y CONFIG_CMD_CACHE=y CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y @@ -69,8 +68,4 @@ CONFIG_USB_GADGET_VENDOR_NUM=0x1b67 CONFIG_USB_GADGET_PRODUCT_NUM=0x4000 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_DM_VIDEO=y -# CONFIG_VIDEO_BPP8 is not set -CONFIG_VIDEO_TEGRA20=y -CONFIG_CONSOLE_SCROLL_LINES=10 CONFIG_OF_LIBFDT_OVERLAY=y diff --git a/configs/colibri_vf_defconfig b/configs/colibri_vf_defconfig index 44f370f57d7..cf230508f2b 100644 --- a/configs/colibri_vf_defconfig +++ b/configs/colibri_vf_defconfig @@ -53,7 +53,6 @@ CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set CONFIG_CMD_MII=y CONFIG_CMD_PING=y -CONFIG_CMD_BMP=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y @@ -100,10 +99,6 @@ CONFIG_USB_GADGET_VENDOR_NUM=0x1b67 CONFIG_USB_GADGET_PRODUCT_NUM=0x4000 CONFIG_CI_UDC=y CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_DM_VIDEO=y -# CONFIG_VIDEO_BPP8 is not set -# CONFIG_VIDEO_BPP16 is not set -CONFIG_SPLASH_SCREEN_ALIGN=y CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_FDT_FIXUP_PARTITIONS=y # CONFIG_EFI_LOADER is not set
From: Igor Opaniuk igor.opaniuk@toradex.com As video support is very specific depending on the exact display customisation we decided to disable video support for all out modules by default. Signed-off-by: Igor Opaniuk igor.opaniuk@toradex.com Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com
Use the same name of DHCP Distroboot script as in regular eMMC case.
include/configs/apalis-imx8.h | 1 + include/configs/apalis-tk1.h | 1 + include/configs/apalis_imx6.h | 1 + include/configs/apalis_t30.h | 3 ++- include/configs/colibri-imx6ull.h | 1 + include/configs/colibri-imx8x.h | 1 + include/configs/colibri_imx6.h | 1 + include/configs/colibri_imx7.h | 1 + include/configs/colibri_t20.h | 1 + include/configs/colibri_t30.h | 3 ++- include/configs/colibri_vf.h | 1 + include/configs/verdin-imx8mm.h | 1 + 12 files changed, 14 insertions(+), 2 deletions(-)
diff --git a/include/configs/apalis-imx8.h b/include/configs/apalis-imx8.h index c87bcd475ef..a45a6ffe7c9 100644 --- a/include/configs/apalis-imx8.h +++ b/include/configs/apalis-imx8.h @@ -38,6 +38,7 @@ BOOTENV \ MEM_LAYOUT_ENV_SETTINGS \ "boot_file=Image\0" \ + "boot_script_dhcp=boot.scr\0" \ "console=ttyLP1 earlycon\0" \ "fdt_addr=0x83000000\0" \ "fdt_file=fsl-imx8qm-apalis-eval.dtb\0" \ diff --git a/include/configs/apalis-tk1.h b/include/configs/apalis-tk1.h index 59c901994fd..10cfe1e3490 100644 --- a/include/configs/apalis-tk1.h +++ b/include/configs/apalis-tk1.h @@ -71,6 +71,7 @@
#define BOARD_EXTRA_ENV_SETTINGS \ "boot_file=zImage\0" \ + "boot_script_dhcp=boot.scr\0" \ "console=ttyS0\0" \ "defargs=lp0_vec=2064@0xf46ff000 core_edp_mv=1150 core_edp_ma=4000 " \ "usb_port_owner_info=2 lane_owner_info=6 emc_max_dvfs=0 " \ diff --git a/include/configs/apalis_imx6.h b/include/configs/apalis_imx6.h index ea5711dba87..afdcf9b2f60 100644 --- a/include/configs/apalis_imx6.h +++ b/include/configs/apalis_imx6.h @@ -108,6 +108,7 @@ #define CONFIG_EXTRA_ENV_SETTINGS \ BOOTENV \ "boot_file=zImage\0" \ + "boot_script_dhcp=boot.scr\0" \ "console=ttymxc0\0" \ "defargs=enable_wait_mode=off vmalloc=400M\0" \ "fdt_file=" FDT_FILE "\0" \ diff --git a/include/configs/apalis_t30.h b/include/configs/apalis_t30.h index b7a2fb695e2..d1d518a5340 100644 --- a/include/configs/apalis_t30.h +++ b/include/configs/apalis_t30.h @@ -47,7 +47,8 @@ "mmc write ${loadaddr} ${uboot_blk} ${blkcnt}\0" \
#define BOARD_EXTRA_ENV_SETTINGS \ - UBOOT_UPDATE + UBOOT_UPDATE \ + "boot_script_dhcp=boot.scr\0"
#include "tegra-common-post.h"
diff --git a/include/configs/colibri-imx6ull.h b/include/configs/colibri-imx6ull.h index 281815e0863..fa4f8ce9813 100644 --- a/include/configs/colibri-imx6ull.h +++ b/include/configs/colibri-imx6ull.h @@ -101,6 +101,7 @@ NFS_BOOTCMD \ UBI_BOOTCMD \ UBOOT_UPDATE \ + "boot_script_dhcp=boot.scr\0" \ "bootubipart=ubi\0" \ "console=ttymxc0\0" \ "defargs=user_debug=30\0" \ diff --git a/include/configs/colibri-imx8x.h b/include/configs/colibri-imx8x.h index 008fa6ef076..ee070408d41 100644 --- a/include/configs/colibri-imx8x.h +++ b/include/configs/colibri-imx8x.h @@ -67,6 +67,7 @@ M4_BOOT_ENV \ MEM_LAYOUT_ENV_SETTINGS \ "boot_file=Image\0" \ + "boot_script_dhcp=boot.scr\0" \ "consoleargs=console=ttyLP3,${baudrate} earlycon\0" \ "fdt_addr=0x83000000\0" \ "fdt_file=fsl-imx8qxp-colibri-dsihdmi-eval-v3.dtb\0" \ diff --git a/include/configs/colibri_imx6.h b/include/configs/colibri_imx6.h index 0d1a1bcf3df..956b59f692b 100644 --- a/include/configs/colibri_imx6.h +++ b/include/configs/colibri_imx6.h @@ -92,6 +92,7 @@ #define CONFIG_EXTRA_ENV_SETTINGS \ BOOTENV \ "boot_file=zImage\0" \ + "boot_script_dhcp=boot.scr\0" \ "console=ttymxc0\0" \ "defargs=enable_wait_mode=off galcore.contiguousSize=50331648\0" \ "fdt_file=" FDT_FILE "\0" \ diff --git a/include/configs/colibri_imx7.h b/include/configs/colibri_imx7.h index 0382724ae10..ff2c30c7f92 100644 --- a/include/configs/colibri_imx7.h +++ b/include/configs/colibri_imx7.h @@ -140,6 +140,7 @@ MODULE_EXTRA_ENV_SETTINGS \ UBOOT_UPDATE \ "boot_file=zImage\0" \ + "boot_script_dhcp=boot.scr\0" \ "bootubipart=ubi\0" \ "console=ttymxc0\0" \ "defargs=\0" \ diff --git a/include/configs/colibri_t20.h b/include/configs/colibri_t20.h index fdf6bb28419..f6b3ab1b041 100644 --- a/include/configs/colibri_t20.h +++ b/include/configs/colibri_t20.h @@ -24,6 +24,7 @@
/* Environment in NAND, 64K is a bit excessive but erase block is 512K anyway */ #define BOARD_EXTRA_ENV_SETTINGS \ + "boot_script_dhcp=boot.scr\0" \ "mtdparts=" CONFIG_MTDPARTS_DEFAULT "\0" \ UBOOT_UPDATE
diff --git a/include/configs/colibri_t30.h b/include/configs/colibri_t30.h index cbe73bf86ba..1ce0def4ddf 100644 --- a/include/configs/colibri_t30.h +++ b/include/configs/colibri_t30.h @@ -45,7 +45,8 @@ "mmc write ${loadaddr} ${uboot_blk} ${blkcnt}\0" \
diff --git a/include/configs/colibri_vf.h b/include/configs/colibri_vf.h index c5366722914..dfc023c6bfa 100644 --- a/include/configs/colibri_vf.h +++ b/include/configs/colibri_vf.h @@ -71,6 +71,7 @@ NFS_BOOTCMD \ UBI_BOOTCMD \ UBOOT_UPDATE \ + "boot_script_dhcp=boot.scr\0" \ "console=ttyLP0\0" \ "defargs=user_debug=30\0" \ "dfu_alt_info=" DFU_ALT_NAND_INFO "\0" \ diff --git a/include/configs/verdin-imx8mm.h b/include/configs/verdin-imx8mm.h index 6c5b190dd95..132edf7b36c 100644 --- a/include/configs/verdin-imx8mm.h +++ b/include/configs/verdin-imx8mm.h @@ -52,6 +52,7 @@ MEM_LAYOUT_ENV_SETTINGS \ "bootcmd_mfg=fastboot 0\0" \ "boot_file=Image\0" \ + "boot_script_dhcp=boot.scr\0" \ "console=ttymxc0\0" \ "fdt_addr=0x43000000\0" \ "fdt_board=dev\0" \
From: Igor Opaniuk igor.opaniuk@toradex.com Use the same name of DHCP Distroboot script as in regular eMMC case. Signed-off-by: Igor Opaniuk igor.opaniuk@toradex.com Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com
Drop legacy nfsboot script in favor of distroboot DHCP boot.
include/configs/apalis-imx8.h | 5 ----- include/configs/apalis-tk1.h | 11 ----------- include/configs/apalis_imx6.h | 11 ----------- include/configs/colibri-imx6ull.h | 10 ---------- include/configs/colibri-imx8x.h | 6 ------ include/configs/colibri_imx6.h | 11 ----------- include/configs/colibri_imx7.h | 10 ---------- include/configs/colibri_vf.h | 10 ---------- include/configs/verdin-imx8mm.h | 6 ------ include/configs/verdin-imx8mp.h | 6 ------ 10 files changed, 86 deletions(-)
diff --git a/include/configs/apalis-imx8.h b/include/configs/apalis-imx8.h index a45a6ffe7c9..a9e0dee3f56 100644 --- a/include/configs/apalis-imx8.h +++ b/include/configs/apalis-imx8.h @@ -50,11 +50,6 @@ "root=PARTUUID=${uuid} rootwait " \ "mmcdev=" __stringify(CONFIG_SYS_MMC_ENV_DEV) "\0" \ "mmcpart=1\0" \ - "netargs=setenv bootargs console=${console},${baudrate} " \ - "root=/dev/nfs ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp" \ - "\0" \ - "nfsboot=run netargs; dhcp ${loadaddr} ${boot_file}; tftp ${fdt_addr} " \ - "apalis-imx8/${fdt_file}; booti ${loadaddr} - ${fdt_addr}\0" \ "panel=NULL\0" \ "script=boot.scr\0" \ "update_uboot=askenv confirm Did you load u-boot-dtb.imx (y/N)?; " \ diff --git a/include/configs/apalis-tk1.h b/include/configs/apalis-tk1.h index 10cfe1e3490..face78e1dd4 100644 --- a/include/configs/apalis-tk1.h +++ b/include/configs/apalis-tk1.h @@ -59,16 +59,6 @@ "update_uboot=run set_blkcnt && mmc dev 0 ${uboot_hwpart} && " \ "mmc write ${loadaddr} ${uboot_blk} ${blkcnt}\0" \
-#define NFS_BOOTCMD \ - "nfsargs=ip=:::::eth0:on root=/dev/nfs rw\0" \ - "nfsboot=pci enum; run setup; setenv bootargs ${defargs} ${nfsargs} " \ - "${setupargs} ${vidargs}; echo Booting via DHCP/TFTP/NFS...; " \ - "run nfsdtbload; dhcp ${kernel_addr_r} " \ - "&& run fdt_fixup && bootz ${kernel_addr_r} - ${dtbparam}\0" \ - "nfsdtbload=setenv dtbparam; tftp ${fdt_addr_r} " \ - "${soc}-${fdt_module}-${fdt_board}.dtb " \ - "&& setenv dtbparam ${fdt_addr_r}\0" - #define BOARD_EXTRA_ENV_SETTINGS \ "boot_file=zImage\0" \ "boot_script_dhcp=boot.scr\0" \ @@ -80,7 +70,6 @@ "fdt_board=eval\0" \ "fdt_fixup=;\0" \ "fdt_module=" FDT_MODULE "\0" \ - NFS_BOOTCMD \ UBOOT_UPDATE \ "setethupdate=if env exists ethaddr; then; else setenv ethaddr " \ "00:14:2d:00:00:00; fi; pci enum && tftpboot ${loadaddr} " \ diff --git a/include/configs/apalis_imx6.h b/include/configs/apalis_imx6.h index afdcf9b2f60..3a27bbb6c87 100644 --- a/include/configs/apalis_imx6.h +++ b/include/configs/apalis_imx6.h @@ -89,16 +89,6 @@ "ramdisk_addr_r=0x12200000\0" \ "scriptaddr=0x17000000\0"
-#define NFS_BOOTCMD \ - "nfsargs=ip=:::::eth0:on root=/dev/nfs ro\0" \ - "nfsboot=run setup; " \ - "setenv bootargs ${defargs} ${nfsargs} ${setupargs} " \ - "${vidargs}; echo Booting via DHCP/TFTP/NFS...; " \ - "run nfsdtbload; dhcp ${kernel_addr_r} " \ - "&& run fdt_fixup && bootz ${kernel_addr_r} ${dtbparam}\0" \ - "nfsdtbload=setenv dtbparam; tftp ${fdt_addr_r} ${fdt_file} " \ - "&& setenv dtbparam " - ${fdt_addr_r}" && true\0" - #ifndef CONFIG_TDX_APALIS_IMX6_V1_0 #define FDT_FILE "imx6q-apalis-eval.dtb" #define FDT_FILE_V1_0 "imx6q-apalis_v1_0-eval.dtb" @@ -115,7 +105,6 @@ "fdtfile=" FDT_FILE "\0" \ "fdt_fixup=;\0" \ MEM_LAYOUT_ENV_SETTINGS \ - NFS_BOOTCMD \ UBOOT_UPDATE \ "setethupdate=if env exists ethaddr; then; else setenv ethaddr " \ "00:14:2d:00:00:00; fi; tftpboot ${loadaddr} " \ diff --git a/include/configs/colibri-imx6ull.h b/include/configs/colibri-imx6ull.h index fa4f8ce9813..11791cee6ac 100644 --- a/include/configs/colibri-imx6ull.h +++ b/include/configs/colibri-imx6ull.h @@ -50,15 +50,6 @@ "ramdisk_addr_r=0x82200000\0" \ "scriptaddr=0x87000000\0"
-#define NFS_BOOTCMD \ - "nfsargs=ip=:::::eth0: root=/dev/nfs\0" \ - "nfsboot=run setup; " \ - "setenv bootargs ${defargs} ${nfsargs} " \ - "${setupargs} ${vidargs}; echo Booting from NFS...;" \ - "dhcp ${kernel_addr_r} && " \ - "tftp ${fdt_addr_r} ${fdtfile} && " \ - "run fdt_fixup && bootz ${kernel_addr_r} - ${fdt_addr_r}\0" \ - #define UBI_BOOTCMD \ "ubiargs=ubi.mtd=ubi root=ubi0:rootfs rw rootfstype=ubifs " \ "ubi.fm_autoconvert=1\0" \ @@ -98,7 +89,6 @@ #define CONFIG_EXTRA_ENV_SETTINGS \ BOOTENV \ MEM_LAYOUT_ENV_SETTINGS \ - NFS_BOOTCMD \ UBI_BOOTCMD \ UBOOT_UPDATE \ "boot_script_dhcp=boot.scr\0" \ diff --git a/include/configs/colibri-imx8x.h b/include/configs/colibri-imx8x.h index ee070408d41..ae5a8ff6a93 100644 --- a/include/configs/colibri-imx8x.h +++ b/include/configs/colibri-imx8x.h @@ -80,12 +80,6 @@ "root=PARTUUID=${uuid} rootwait " \ "mmcdev=" __stringify(CONFIG_SYS_MMC_ENV_DEV) "\0" \ "mmcpart=1\0" \ - "netargs=setenv bootargs ${consoleargs} " \ - "root=/dev/nfs ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp " \ - "${vidargs}\0" \ - "nfsboot=run netargs; dhcp ${loadaddr} ${image}; tftp ${fdt_addr} " \ - "colibri-imx8x/${fdt_file}; booti ${loadaddr} - " \ - "${fdt_addr}\0" \ "panel=NULL\0" \ "script=boot.scr\0" \ "update_uboot=askenv confirm Did you load u-boot-dtb.imx (y/N)?; " \ diff --git a/include/configs/colibri_imx6.h b/include/configs/colibri_imx6.h index 956b59f692b..f7e9709e122 100644 --- a/include/configs/colibri_imx6.h +++ b/include/configs/colibri_imx6.h @@ -78,16 +78,6 @@ "ramdisk_addr_r=0x12200000\0" \ "scriptaddr=0x17000000\0"
-#define NFS_BOOTCMD \ - "nfsargs=ip=:::::eth0:on root=/dev/nfs rw\0" \ - "nfsboot=run setup; " \ - "setenv bootargs ${defargs} ${nfsargs} ${setupargs} " \ - "${vidargs}; echo Booting via DHCP/TFTP/NFS...; " \ - "run nfsdtbload; dhcp ${kernel_addr_r} " \ - "&& run fdt_fixup && bootz ${kernel_addr_r} ${dtbparam}\0" \ - "nfsdtbload=setenv dtbparam; tftp ${fdt_addr_r} ${fdt_file} " \ - "&& setenv dtbparam " - ${fdt_addr_r}" && true\0" - #define FDT_FILE "imx6dl-colibri-eval-v3.dtb" #define CONFIG_EXTRA_ENV_SETTINGS \ BOOTENV \ @@ -99,7 +89,6 @@ "fdtfile=" FDT_FILE "\0" \ "fdt_fixup=;\0" \ MEM_LAYOUT_ENV_SETTINGS \ - NFS_BOOTCMD \ UBOOT_UPDATE \ "setethupdate=if env exists ethaddr; then; else setenv ethaddr " \ "00:14:2d:00:00:00; fi; tftpboot ${loadaddr} " \ diff --git a/include/configs/colibri_imx7.h b/include/configs/colibri_imx7.h index ff2c30c7f92..3dba7bcef25 100644 --- a/include/configs/colibri_imx7.h +++ b/include/configs/colibri_imx7.h @@ -89,15 +89,6 @@ "ramdisk_addr_r=0x82100000\0" \ "scriptaddr=0x87000000\0"
-#define NFS_BOOTCMD \ - "nfsargs=ip=:::::eth0: root=/dev/nfs\0" \ - "nfsboot=run setup; " \ - "setenv bootargs ${defargs} ${nfsargs} " \ - "${setupargs} ${vidargs}; echo Booting from NFS...;" \ - "dhcp ${kernel_addr_r} && " \ - "tftp ${fdt_addr_r} ${soc}-colibri${variant}-${fdt_board}.dtb && " \ - "run fdt_fixup && bootz ${kernel_addr_r} - ${fdt_addr_r}\0" \ - #define UBI_BOOTCMD \ "ubiargs=ubi.mtd=ubi root=ubi0:rootfs rootfstype=ubifs " \ "ubi.fm_autoconvert=1\0" \ @@ -136,7 +127,6 @@ #define CONFIG_EXTRA_ENV_SETTINGS \ BOOTENV \ MEM_LAYOUT_ENV_SETTINGS \ - NFS_BOOTCMD \ MODULE_EXTRA_ENV_SETTINGS \ UBOOT_UPDATE \ "boot_file=zImage\0" \ diff --git a/include/configs/colibri_vf.h b/include/configs/colibri_vf.h index dfc023c6bfa..99b0cbb3420 100644 --- a/include/configs/colibri_vf.h +++ b/include/configs/colibri_vf.h @@ -35,15 +35,6 @@ "update_uboot=nand erase.part u-boot && " \ "nand write ${loadaddr} u-boot ${filesize}\0" \
-#define NFS_BOOTCMD \ - "nfsargs=ip=:::::eth0: root=/dev/nfs\0" \ - "nfsboot=run setup; " \ - "setenv bootargs ${defargs} ${nfsargs} ${mtdparts} " \ - "${setupargs} ${vidargs}; echo Booting from NFS...;" \ - "dhcp ${kernel_addr_r} && " \ - "tftp ${fdt_addr_r} ${soc}-colibri-${fdt_board}.dtb && " \ - "run fdt_fixup && bootz ${kernel_addr_r} - ${fdt_addr_r}\0" \ - #define UBI_BOOTCMD \ "ubiargs=ubi.mtd=ubi root=ubi0:rootfs rootfstype=ubifs " \ "ubi.fm_autoconvert=1\0" \ @@ -68,7 +59,6 @@ #define CONFIG_EXTRA_ENV_SETTINGS \ BOOTENV \ MEM_LAYOUT_ENV_SETTINGS \ - NFS_BOOTCMD \ UBI_BOOTCMD \ UBOOT_UPDATE \ "boot_script_dhcp=boot.scr\0" \ diff --git a/include/configs/verdin-imx8mm.h b/include/configs/verdin-imx8mm.h index 132edf7b36c..65a01f9fadc 100644 --- a/include/configs/verdin-imx8mm.h +++ b/include/configs/verdin-imx8mm.h @@ -58,12 +58,6 @@ "fdt_board=dev\0" \ "initrd_addr=0x43800000\0" \ "initrd_high=0xffffffffffffffff\0" \ - "netargs=setenv bootargs console=${console},${baudrate} " \ - "root=/dev/nfs ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp" \ - "\0" \ - "nfsboot=run netargs; dhcp ${loadaddr} ${boot_file}; " \ - "tftp ${fdt_addr} verdin/${fdtfile}; " \ - "booti ${loadaddr} - ${fdt_addr}\0" \ "setup=setenv setupargs console=${console},${baudrate} " \ "console=tty1 consoleblank=0 earlycon\0" \ "update_uboot=askenv confirm Did you load flash.bin (y/N)?; " \ diff --git a/include/configs/verdin-imx8mp.h b/include/configs/verdin-imx8mp.h index 9e29dc19033..da95b8bbc23 100644 --- a/include/configs/verdin-imx8mp.h +++ b/include/configs/verdin-imx8mp.h @@ -76,12 +76,6 @@ "fdt_board=dev\0" \ "initrd_addr=0x43800000\0" \ "initrd_high=0xffffffffffffffff\0" \ - "netargs=setenv bootargs console=${console},${baudrate} " \ - "root=/dev/nfs ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp" \ - "\0" \ - "nfsboot=run netargs; dhcp ${loadaddr} ${boot_file}; " \ - "tftp ${fdt_addr} verdin/${fdtfile}; " \ - "booti ${loadaddr} - ${fdt_addr}\0" \ "setup=setenv setupargs console=${console},${baudrate} console=tty1 " \ "consoleblank=0 earlycon\0" \ "update_uboot=askenv confirm Did you load flash.bin (y/N)?; " \
From: Igor Opaniuk igor.opaniuk@toradex.com Drop legacy nfsboot script in favor of distroboot DHCP boot. Signed-off-by: Igor Opaniuk igor.opaniuk@toradex.com Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com
From: Oleksandr Suvorov oleksandr.suvorov@toradex.com
Add missing support of FIT-images and enable a verbosity for this feature.
Signed-off-by: Oleksandr Suvorov oleksandr.suvorov@toradex.com Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com ---
configs/apalis-imx8_defconfig | 1 + configs/apalis-tk1_defconfig | 1 + configs/apalis_imx6_defconfig | 1 + configs/colibri-imx6ull-emmc_defconfig | 1 + configs/colibri-imx6ull_defconfig | 1 + configs/colibri-imx8x_defconfig | 1 + configs/colibri_imx6_defconfig | 1 + configs/colibri_imx7_defconfig | 2 ++ configs/colibri_imx7_emmc_defconfig | 1 + configs/verdin-imx8mm_defconfig | 1 + 10 files changed, 11 insertions(+)
diff --git a/configs/apalis-imx8_defconfig b/configs/apalis-imx8_defconfig index 19edbbb6978..beb20f6e1c0 100644 --- a/configs/apalis-imx8_defconfig +++ b/configs/apalis-imx8_defconfig @@ -15,6 +15,7 @@ CONFIG_SYS_MEMTEST_END=0x89000000 CONFIG_DISTRO_DEFAULTS=y CONFIG_REMAKE_ELF=y CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y CONFIG_OF_SYSTEM_SETUP=y CONFIG_LOG=y # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/apalis-tk1_defconfig b/configs/apalis-tk1_defconfig index 9645c2f2108..e098b1171ee 100644 --- a/configs/apalis-tk1_defconfig +++ b/configs/apalis-tk1_defconfig @@ -12,6 +12,7 @@ CONFIG_TEGRA124=y CONFIG_TARGET_APALIS_TK1=y CONFIG_SYS_LOAD_ADDR=0x81000000 CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y CONFIG_OF_SYSTEM_SETUP=y CONFIG_BOOTDELAY=1 CONFIG_BOOTCOMMAND="setenv fdtfile ${soc}-${fdt_module}-${fdt_board}.dtb && run distro_bootcmd" diff --git a/configs/apalis_imx6_defconfig b/configs/apalis_imx6_defconfig index cdf169df046..00c9a24a5dd 100644 --- a/configs/apalis_imx6_defconfig +++ b/configs/apalis_imx6_defconfig @@ -26,6 +26,7 @@ CONFIG_SYS_MEMTEST_START=0x10000000 CONFIG_SYS_MEMTEST_END=0x10010000 CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y CONFIG_BOOTDELAY=1 CONFIG_BOOTCOMMAND="run distro_bootcmd; usb start; setenv stdout serial,vidconsole; setenv stdin serial,usbkbd" CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y diff --git a/configs/colibri-imx6ull-emmc_defconfig b/configs/colibri-imx6ull-emmc_defconfig index 0e7f29b56bc..8c616178670 100644 --- a/configs/colibri-imx6ull-emmc_defconfig +++ b/configs/colibri-imx6ull-emmc_defconfig @@ -13,6 +13,7 @@ CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x88000000 CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y CONFIG_BOOTDELAY=1 CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="setenv fdtfile imx6ull-colibri${variant}-${fdt_board}.dtb" diff --git a/configs/colibri-imx6ull_defconfig b/configs/colibri-imx6ull_defconfig index b04f171549b..3ef7a6aa8d5 100644 --- a/configs/colibri-imx6ull_defconfig +++ b/configs/colibri-imx6ull_defconfig @@ -14,6 +14,7 @@ CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x88000000 CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y CONFIG_BOOTDELAY=1 CONFIG_BOOTCOMMAND="run ubiboot || run distro_bootcmd;" CONFIG_USE_PREBOOT=y diff --git a/configs/colibri-imx8x_defconfig b/configs/colibri-imx8x_defconfig index 80bc27b1881..0c9d6b64c1b 100644 --- a/configs/colibri-imx8x_defconfig +++ b/configs/colibri-imx8x_defconfig @@ -15,6 +15,7 @@ CONFIG_SYS_MEMTEST_END=0x89000000 CONFIG_DISTRO_DEFAULTS=y CONFIG_REMAKE_ELF=y CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y CONFIG_LOG=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y diff --git a/configs/colibri_imx6_defconfig b/configs/colibri_imx6_defconfig index 4aecb283332..1c65d8a7fe1 100644 --- a/configs/colibri_imx6_defconfig +++ b/configs/colibri_imx6_defconfig @@ -25,6 +25,7 @@ CONFIG_SYS_MEMTEST_START=0x10000000 CONFIG_SYS_MEMTEST_END=0x10010000 CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y CONFIG_BOOTDELAY=1 CONFIG_BOOTCOMMAND="run distro_bootcmd; usb start; setenv stdout serial,vidconsole; setenv stdin serial,usbkbd" CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y diff --git a/configs/colibri_imx7_defconfig b/configs/colibri_imx7_defconfig index f3cd7a4d5ae..3fb50a49bd6 100644 --- a/configs/colibri_imx7_defconfig +++ b/configs/colibri_imx7_defconfig @@ -13,6 +13,8 @@ CONFIG_IMX_HAB=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x8c000000 CONFIG_DISTRO_DEFAULTS=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y CONFIG_BOOTDELAY=1 CONFIG_BOOTCOMMAND="run ubiboot ; echo ; echo ubiboot failed ; run distro_bootcmd;" CONFIG_USE_PREBOOT=y diff --git a/configs/colibri_imx7_emmc_defconfig b/configs/colibri_imx7_emmc_defconfig index 2b97890497c..e66d94bf7d9 100644 --- a/configs/colibri_imx7_emmc_defconfig +++ b/configs/colibri_imx7_emmc_defconfig @@ -15,6 +15,7 @@ CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x8c000000 CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y CONFIG_BOOTDELAY=1 CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="setenv fdtfile ${soc}-colibri-emmc-${fdt_board}.dtb" diff --git a/configs/verdin-imx8mm_defconfig b/configs/verdin-imx8mm_defconfig index 94ba1f50fbb..ce567b770ab 100644 --- a/configs/verdin-imx8mm_defconfig +++ b/configs/verdin-imx8mm_defconfig @@ -21,6 +21,7 @@ CONFIG_SYS_MEMTEST_END=0x80000000 CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 +CONFIG_FIT_VERBOSE=y CONFIG_SPL_LOAD_FIT=y # CONFIG_USE_SPL_FIT_GENERATOR is not set CONFIG_OF_SYSTEM_SETUP=y
From: Oleksandr Suvorov oleksandr.suvorov@toradex.com Add missing support of FIT-images and enable a verbosity for this feature. Signed-off-by: Oleksandr Suvorov oleksandr.suvorov@toradex.com Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com
For recovery purpose allow booting via SDP over USB as well.
configs/colibri_imx7_defconfig | 1 + configs/colibri_imx7_emmc_defconfig | 1 + 2 files changed, 2 insertions(+)
diff --git a/configs/colibri_imx7_defconfig b/configs/colibri_imx7_defconfig index 3fb50a49bd6..d2051a5f262 100644 --- a/configs/colibri_imx7_defconfig +++ b/configs/colibri_imx7_defconfig @@ -40,6 +40,7 @@ CONFIG_CMD_MTD=y CONFIG_CMD_NAND_TRIMFFS=y CONFIG_CMD_NAND_TORTURE=y CONFIG_CMD_USB=y +CONFIG_CMD_USB_SDP=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_BOOTP_PXE is not set CONFIG_CMD_BOOTCOUNT=y diff --git a/configs/colibri_imx7_emmc_defconfig b/configs/colibri_imx7_emmc_defconfig index e66d94bf7d9..d0f6bf3accf 100644 --- a/configs/colibri_imx7_emmc_defconfig +++ b/configs/colibri_imx7_emmc_defconfig @@ -38,6 +38,7 @@ CONFIG_CMD_GPT=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y CONFIG_CMD_USB=y +CONFIG_CMD_USB_SDP=y CONFIG_CMD_USB_MASS_STORAGE=y CONFIG_CMD_BOOTCOUNT=y CONFIG_CMD_CACHE=y
From: Oleksandr Suvorov oleksandr.suvorov@toradex.com For recovery purpose allow booting via SDP over USB as well. Signed-off-by: Oleksandr Suvorov oleksandr.suvorov@toradex.com Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com
From: Philippe Schenker philippe.schenker@toradex.com
In case a customer wants to set fdtfile currently preboot overrides it always with preboot just before the bootdelay. Use test -n to check if fdtfile is already set and only set it if nothing got touched manually
Signed-off-by: Philippe Schenker philippe.schenker@toradex.com Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com ---
configs/colibri-imx6ull-emmc_defconfig | 2 +- configs/colibri-imx6ull_defconfig | 2 +- configs/colibri_imx7_defconfig | 2 +- configs/colibri_imx7_emmc_defconfig | 2 +- configs/colibri_vf_defconfig | 2 +- configs/verdin-imx8mm_defconfig | 2 +- configs/verdin-imx8mp_defconfig | 2 +- 7 files changed, 7 insertions(+), 7 deletions(-)
diff --git a/configs/colibri-imx6ull-emmc_defconfig b/configs/colibri-imx6ull-emmc_defconfig index 8c616178670..b22a19b5b0b 100644 --- a/configs/colibri-imx6ull-emmc_defconfig +++ b/configs/colibri-imx6ull-emmc_defconfig @@ -16,7 +16,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_BOOTDELAY=1 CONFIG_USE_PREBOOT=y -CONFIG_PREBOOT="setenv fdtfile imx6ull-colibri${variant}-${fdt_board}.dtb" +CONFIG_PREBOOT="test -n ${fdtfile} || setenv fdtfile imx6ull-colibri${variant}-${fdt_board}.dtb" # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/colibri-imx6ull_defconfig b/configs/colibri-imx6ull_defconfig index 3ef7a6aa8d5..2fba7aaae4d 100644 --- a/configs/colibri-imx6ull_defconfig +++ b/configs/colibri-imx6ull_defconfig @@ -18,7 +18,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_BOOTDELAY=1 CONFIG_BOOTCOMMAND="run ubiboot || run distro_bootcmd;" CONFIG_USE_PREBOOT=y -CONFIG_PREBOOT="setenv fdtfile imx6ull-colibri${variant}-${fdt_board}.dtb" +CONFIG_PREBOOT="test -n ${fdtfile} || setenv fdtfile imx6ull-colibri${variant}-${fdt_board}.dtb" # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/colibri_imx7_defconfig b/configs/colibri_imx7_defconfig index d2051a5f262..2f61223c9eb 100644 --- a/configs/colibri_imx7_defconfig +++ b/configs/colibri_imx7_defconfig @@ -18,7 +18,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_BOOTDELAY=1 CONFIG_BOOTCOMMAND="run ubiboot ; echo ; echo ubiboot failed ; run distro_bootcmd;" CONFIG_USE_PREBOOT=y -CONFIG_PREBOOT="setenv fdtfile ${soc}-colibri-${fdt_board}.dtb " +CONFIG_PREBOOT="test -n ${fdtfile} || setenv fdtfile ${soc}-colibri-${fdt_board}.dtb " # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/colibri_imx7_emmc_defconfig b/configs/colibri_imx7_emmc_defconfig index d0f6bf3accf..918585da495 100644 --- a/configs/colibri_imx7_emmc_defconfig +++ b/configs/colibri_imx7_emmc_defconfig @@ -18,7 +18,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_BOOTDELAY=1 CONFIG_USE_PREBOOT=y -CONFIG_PREBOOT="setenv fdtfile ${soc}-colibri-emmc-${fdt_board}.dtb" +CONFIG_PREBOOT="test -n ${fdtfile} || setenv fdtfile ${soc}-colibri-emmc-${fdt_board}.dtb" # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set diff --git a/configs/colibri_vf_defconfig b/configs/colibri_vf_defconfig index cf230508f2b..e140ee0f300 100644 --- a/configs/colibri_vf_defconfig +++ b/configs/colibri_vf_defconfig @@ -21,7 +21,7 @@ CONFIG_BOOTDELAY=1 CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run ubiboot || run distro_bootcmd;" CONFIG_USE_PREBOOT=y -CONFIG_PREBOOT="setenv fdtfile ${soc}-colibri-${fdt_board}.dtb" +CONFIG_PREBOOT="test -n ${fdtfile} || setenv fdtfile ${soc}-colibri-${fdt_board}.dtb" CONFIG_LOGLEVEL=3 # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y diff --git a/configs/verdin-imx8mm_defconfig b/configs/verdin-imx8mm_defconfig index ce567b770ab..e6d9f37623c 100644 --- a/configs/verdin-imx8mm_defconfig +++ b/configs/verdin-imx8mm_defconfig @@ -27,7 +27,7 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_OF_SYSTEM_SETUP=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_USE_PREBOOT=y -CONFIG_PREBOOT="setenv fdtfile imx8mm-verdin-${variant}-${fdt_board}.dtb" +CONFIG_PREBOOT="test -n ${fdtfile} || setenv fdtfile imx8mm-verdin-${variant}-${fdt_board}.dtb" CONFIG_LOG=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y diff --git a/configs/verdin-imx8mp_defconfig b/configs/verdin-imx8mp_defconfig index 44fcfa1352e..a74033c8ba7 100644 --- a/configs/verdin-imx8mp_defconfig +++ b/configs/verdin-imx8mp_defconfig @@ -34,7 +34,7 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_OF_SYSTEM_SETUP=y CONFIG_BOOTDELAY=1 CONFIG_USE_PREBOOT=y -CONFIG_PREBOOT="setenv fdtfile imx8mp-verdin-${variant}-${fdt_board}.dtb" +CONFIG_PREBOOT="test -n ${fdtfile} || setenv fdtfile imx8mp-verdin-${variant}-${fdt_board}.dtb" CONFIG_LOG=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y
From: Philippe Schenker philippe.schenker@toradex.com In case a customer wants to set fdtfile currently preboot overrides it always with preboot just before the bootdelay. Use test -n to check if fdtfile is already set and only set it if nothing got touched manually Signed-off-by: Philippe Schenker philippe.schenker@toradex.com Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com
The Colibri PXA270 has been end-of-life since quite a while and would require more and more maintenance (e.g. DM conversions).
(no changes since v1)
arch/arm/Kconfig | 6 - board/toradex/colibri_pxa270/Kconfig | 23 --- board/toradex/colibri_pxa270/MAINTAINERS | 6 - board/toradex/colibri_pxa270/Makefile | 7 - board/toradex/colibri_pxa270/colibri_pxa270.c | 153 ------------------ board/toradex/common/tdx-cfg-block.c | 19 +-- configs/colibri_pxa270_defconfig | 57 ------- include/configs/colibri_pxa270.h | 151 ----------------- include/configs/pxa-common.h | 27 ---- 9 files changed, 1 insertion(+), 448 deletions(-) delete mode 100644 board/toradex/colibri_pxa270/Kconfig delete mode 100644 board/toradex/colibri_pxa270/MAINTAINERS delete mode 100644 board/toradex/colibri_pxa270/Makefile delete mode 100644 board/toradex/colibri_pxa270/colibri_pxa270.c delete mode 100644 configs/colibri_pxa270_defconfig delete mode 100644 include/configs/colibri_pxa270.h delete mode 100644 include/configs/pxa-common.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index efe33a58e1e..ed34fa59bd7 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1833,11 +1833,6 @@ config TARGET_TEN64 Support for Traverse Technologies Ten64 board, based on NXP LS1088A.
-config TARGET_COLIBRI_PXA270 - bool "Support colibri_pxa270" - select CPU_PXA27X - select GPIO_EXTRA_HEADER - config ARCH_UNIPHIER bool "Socionext UniPhier SoCs" select BOARD_LATE_INIT @@ -2301,7 +2296,6 @@ source "board/seeed/npi_imx6ull/Kconfig" source "board/socionext/developerbox/Kconfig" source "board/st/stv0991/Kconfig" source "board/tcl/sl50/Kconfig" -source "board/toradex/colibri_pxa270/Kconfig" source "board/traverse/ten64/Kconfig" source "board/variscite/dart_6ul/Kconfig" source "board/vscom/baltos/Kconfig" diff --git a/board/toradex/colibri_pxa270/Kconfig b/board/toradex/colibri_pxa270/Kconfig deleted file mode 100644 index f646baa3f05..00000000000 --- a/board/toradex/colibri_pxa270/Kconfig +++ /dev/null @@ -1,23 +0,0 @@ -if TARGET_COLIBRI_PXA270 - -config SYS_BOARD - default "colibri_pxa270" - -config SYS_VENDOR - default "toradex" - -config SYS_CONFIG_NAME - default "colibri_pxa270" - -config TDX_CFG_BLOCK - default y - -config TDX_HAVE_NOR - default y - -config TDX_CFG_BLOCK_OFFSET - default "262144" - -source "board/toradex/common/Kconfig" - -endif diff --git a/board/toradex/colibri_pxa270/MAINTAINERS b/board/toradex/colibri_pxa270/MAINTAINERS deleted file mode 100644 index b378d7be5a4..00000000000 --- a/board/toradex/colibri_pxa270/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -COLIBRI_PXA270 BOARD -M: Marek Vasut marek.vasut@gmail.com -S: Maintained -F: board/toradex/colibri_pxa270/ -F: include/configs/colibri_pxa270.h -F: configs/colibri_pxa270_defconfig diff --git a/board/toradex/colibri_pxa270/Makefile b/board/toradex/colibri_pxa270/Makefile deleted file mode 100644 index ea610cfea92..00000000000 --- a/board/toradex/colibri_pxa270/Makefile +++ /dev/null @@ -1,7 +0,0 @@ -# SPDX-License-Identifier: GPL-2.0+ -# -# Toradex Colibri PXA270 Support -# -# Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com - -obj-y := colibri_pxa270.o diff --git a/board/toradex/colibri_pxa270/colibri_pxa270.c b/board/toradex/colibri_pxa270/colibri_pxa270.c deleted file mode 100644 index 25fbf412095..00000000000 --- a/board/toradex/colibri_pxa270/colibri_pxa270.c +++ /dev/null @@ -1,153 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * Toradex Colibri PXA270 Support - * - * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com - * Copyright (C) 2016-2019 Marcel Ziswiler marcel.ziswiler@toradex.com - */ - -#include <common.h> -#include <cpu_func.h> -#include <dm.h> -#include <init.h> -#include <net.h> -#include <asm/arch/hardware.h> -#include <asm/arch/pxa.h> -#include <asm/arch/regs-mmc.h> -#include <asm/arch/regs-uart.h> -#include <asm/global_data.h> -#include <asm/io.h> -#include <dm/platdata.h> -#include <dm/platform_data/pxa_mmc_gen.h> -#include <dm/platform_data/serial_pxa.h> -#include <netdev.h> -#include <serial.h> -#include <usb.h> -#include <asm/mach-types.h> -#include <linux/delay.h> -#include "../common/tdx-common.h" - -DECLARE_GLOBAL_DATA_PTR; - -int board_init(void) -{ - /* We have RAM, disable cache */ - dcache_disable(); - icache_disable(); - - /* arch number of Toradex Colibri PXA270 */ - gd->bd->bi_arch_number = MACH_TYPE_COLIBRI; - - /* address of boot parameters */ - gd->bd->bi_boot_params = 0xa0000100; - - return 0; -} - -int checkboard(void) -{ - puts("Model: Toradex Colibri PXA270\n"); - - return 0; -} - -#if defined(CONFIG_OF_LIBFDT) && defined(CONFIG_OF_BOARD_SETUP) -int ft_board_setup(void *blob, struct bd_info *bd) -{ - return ft_common_board_setup(blob, bd); -} -#endif - -int dram_init(void) -{ - pxa2xx_dram_init(); - gd->ram_size = PHYS_SDRAM_1_SIZE; - return 0; -} - -#ifdef CONFIG_CMD_USB -int board_usb_init(int index, enum usb_init_type init) -{ - writel((readl(UHCHR) | UHCHR_PCPL | UHCHR_PSPL) & - ~(UHCHR_SSEP0 | UHCHR_SSEP1 | UHCHR_SSEP2 | UHCHR_SSE), - UHCHR); - - writel(readl(UHCHR) | UHCHR_FSBIR, UHCHR); - - while (UHCHR & UHCHR_FSBIR) - ; - - writel(readl(UHCHR) & ~UHCHR_SSE, UHCHR); - writel((UHCHIE_UPRIE | UHCHIE_RWIE), UHCHIE); - - /* Clear any OTG Pin Hold */ - if (readl(PSSR) & PSSR_OTGPH) - writel(readl(PSSR) | PSSR_OTGPH, PSSR); - - writel(readl(UHCRHDA) & ~(0x200), UHCRHDA); - writel(readl(UHCRHDA) | 0x100, UHCRHDA); - - /* Set port power control mask bits, only 3 ports. */ - writel(readl(UHCRHDB) | (0x7 << 17), UHCRHDB); - - /* enable port 2 */ - writel(readl(UP2OCR) | UP2OCR_HXOE | UP2OCR_HXS | - UP2OCR_DMPDE | UP2OCR_DPPDE, UP2OCR); - - return 0; -} - -int board_usb_cleanup(int index, enum usb_init_type init) -{ - return 0; -} - -void usb_board_stop(void) -{ - writel(readl(UHCHR) | UHCHR_FHR, UHCHR); - udelay(11); - writel(readl(UHCHR) & ~UHCHR_FHR, UHCHR); - - writel(readl(UHCCOMS) | 1, UHCCOMS); - udelay(10); - - writel(readl(CKEN) & ~CKEN10_USBHOST, CKEN); -} -#endif - -#ifdef CONFIG_DRIVER_DM9000 -int board_eth_init(struct bd_info *bis) -{ - return dm9000_initialize(bis); -} -#endif - -#ifdef CONFIG_CMD_MMC -#if !CONFIG_IS_ENABLED(DM_MMC) -int board_mmc_init(struct bd_info *bis) -{ - pxa_mmc_register(0); - return 0; -} -#else /* !CONFIG_IS_ENABLED(DM_MMC) */ -static const struct pxa_mmc_plat mmc_plat = { - .base = (struct pxa_mmc_regs *)MMC0_BASE, -}; - -U_BOOT_DRVINFO(pxa_mmcs) = { - .name = "pxa_mmc", - .plat = &mmc_plat, -}; -#endif /* !CONFIG_IS_ENABLED(DM_MMC) */ -#endif - -static const struct pxa_serial_plat serial_plat = { - .base = (struct pxa_uart_regs *)FFUART_BASE, - .port = FFUART_INDEX, - .baudrate = CONFIG_BAUDRATE, -}; - -U_BOOT_DRVINFO(pxa_serials) = { - .name = "serial_pxa", - .plat = &serial_plat, -}; diff --git a/board/toradex/common/tdx-cfg-block.c b/board/toradex/common/tdx-cfg-block.c index 0e657a2a0a9..9c87289ae93 100644 --- a/board/toradex/common/tdx-cfg-block.c +++ b/board/toradex/common/tdx-cfg-block.c @@ -22,11 +22,6 @@ #else #define is_cpu_type(cpu) (0) #endif -#if defined(CONFIG_CPU_PXA27X) -#include <asm/arch-pxa/pxa.h> -#else -#define cpu_is_pxa27x(cpu) (0) -#endif #include <cli.h> #include <console.h> #include <env.h> @@ -369,10 +364,7 @@ static int get_cfgblock_interactive(void) /* Unknown module by default */ tdx_hw_tag.prodid = 0;
- if (cpu_is_pxa27x()) - sprintf(message, "Is the module the 312 MHz version? [y/N] "); - else - sprintf(message, "Is the module an IT version? [y/N] "); + sprintf(message, "Is the module an IT version? [y/N] ");
len = cli_readline(message); it = console_buffer[0]; @@ -500,11 +492,6 @@ static int get_cfgblock_interactive(void) tdx_hw_tag.prodid = COLIBRI_T20_256MB; else tdx_hw_tag.prodid = COLIBRI_T20_512MB; - } else if (cpu_is_pxa27x()) { - if (it == 'y' || it == 'Y') - tdx_hw_tag.prodid = COLIBRI_PXA270_312MHZ; - else - tdx_hw_tag.prodid = COLIBRI_PXA270_520MHZ; } #if defined(CONFIG_TARGET_APALIS_T30) || defined(CONFIG_TARGET_COLIBRI_T30) else if (!strcmp("tegra30", soc)) { @@ -552,10 +539,6 @@ static int get_cfgblock_interactive(void) tdx_hw_tag.ver_minor = console_buffer[2] - '0'; tdx_hw_tag.ver_assembly = console_buffer[3] - 'A';
- if (cpu_is_pxa27x() && tdx_hw_tag.ver_major == 1) - tdx_hw_tag.prodid -= (COLIBRI_PXA270_312MHZ - - COLIBRI_PXA270_V1_312MHZ); - while (len < 8) { sprintf(message, "Enter module serial number: "); len = cli_readline(message); diff --git a/configs/colibri_pxa270_defconfig b/configs/colibri_pxa270_defconfig deleted file mode 100644 index 9ce65861046..00000000000 --- a/configs/colibri_pxa270_defconfig +++ /dev/null @@ -1,57 +0,0 @@ -CONFIG_ARM=y -CONFIG_SYS_DCACHE_OFF=y -CONFIG_ARCH_CPU_INIT=y -CONFIG_TARGET_COLIBRI_PXA270=y -CONFIG_SYS_TEXT_BASE=0x0 -CONFIG_SYS_MALLOC_LEN=0x20000 -CONFIG_SYS_MALLOC_F_LEN=0x2000 -CONFIG_NR_DRAM_BANKS=1 -CONFIG_ENV_SIZE=0x40000 -CONFIG_ENV_SECT_SIZE=0x40000 -CONFIG_SYS_LOAD_ADDR=0xa0000000 -CONFIG_ENV_ADDR=0x80000 -CONFIG_ENV_VARS_UBOOT_CONFIG=y -CONFIG_HAS_BOARD_SIZE_LIMIT=y -CONFIG_BOARD_SIZE_LIMIT=262144 -CONFIG_TIMESTAMP=y -CONFIG_SYS_MONITOR_BASE=0x00000000 -CONFIG_USE_BOOTARGS=y -CONFIG_BOOTARGS="console=tty0 console=ttyS0,115200" -CONFIG_USE_BOOTCOMMAND=y -CONFIG_BOOTCOMMAND="if fatload mmc 0 0xa0000000 uImage; then bootm 0xa0000000; fi; if usb reset && fatload usb 0 0xa0000000 uImage; then bootm 0xa0000000; fi; bootm 0xc0000;" -CONFIG_SYS_DEVICE_NULLDEV=y -# CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_DISPLAY_BOARDINFO_LATE=y -# CONFIG_CMDLINE_EDITING is not set -# CONFIG_AUTO_COMPLETE is not set -# CONFIG_SYS_LONGHELP is not set -CONFIG_SYS_PROMPT="$ " -# CONFIG_CMD_ELF is not set -# CONFIG_CMD_EXPORTENV is not set -# CONFIG_CMD_IMPORTENV is not set -CONFIG_CMD_DM=y -# CONFIG_CMD_LOADB is not set -# CONFIG_CMD_LOADS is not set -CONFIG_CMD_MMC=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_BOOTP_BOOTFILESIZE=y -CONFIG_CMD_PING=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y -CONFIG_ENV_OVERWRITE=y -CONFIG_ENV_IS_IN_FLASH=y -CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y -CONFIG_NET_RETRY_COUNT=10 -CONFIG_DM=y -CONFIG_PXA_MMC_GENERIC=y -CONFIG_MTD_NOR_FLASH=y -CONFIG_FLASH_CFI_DRIVER=y -CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y -CONFIG_SYS_FLASH_PROTECTION=y -CONFIG_SYS_FLASH_CFI=y -CONFIG_DM_SERIAL=y -CONFIG_PXA_SERIAL=y -CONFIG_USB=y -# CONFIG_REGEX is not set -CONFIG_OF_LIBFDT=y diff --git a/include/configs/colibri_pxa270.h b/include/configs/colibri_pxa270.h deleted file mode 100644 index a5ba916279a..00000000000 --- a/include/configs/colibri_pxa270.h +++ /dev/null @@ -1,151 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Toradex Colibri PXA270 configuration file - * - * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com - * Copyright (C) 2015-2016 Marcel Ziswiler marcel@ziswiler.com - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Board Configuration Options - */ - -/* - * Environment settings - */ - -/* - * Serial Console Configuration - */ - -/* - * Bootloader Components Configuration - */ - -/* I2C support */ -#if CONFIG_IS_ENABLED(SYS_I2C_LEGACY) -#define CONFIG_SYS_I2C_PXA -#define CONFIG_PXA_STD_I2C -#define CONFIG_PXA_PWR_I2C -#endif - -/* LCD support */ -#ifdef CONFIG_LCD -#define CONFIG_PXA_LCD -#define CONFIG_PXA_VGA -#endif - -/* - * Networking Configuration - */ -#ifdef CONFIG_CMD_NET - -#define CONFIG_DRIVER_DM9000 1 -#define CONFIG_DM9000_BASE 0x08000000 -#define DM9000_IO (CONFIG_DM9000_BASE) -#define DM9000_DATA (CONFIG_DM9000_BASE + 4) -#endif - -/* - * Clock Configuration - */ -#define CONFIG_SYS_CPUSPEED 0x290 /* 520MHz */ - -/* - * DRAM Map - */ -#define PHYS_SDRAM_1 0xa0000000 /* SDRAM Bank #1 */ -#define PHYS_SDRAM_1_SIZE 0x04000000 /* 64 MB */ - -#define CONFIG_SYS_DRAM_BASE 0xa0000000 /* CS0 */ -#define CONFIG_SYS_DRAM_SIZE 0x04000000 /* 64 MB DRAM */ - -#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 -#define CONFIG_SYS_INIT_SP_ADDR 0x5c010000 - -/* - * NOR FLASH - */ -#ifdef CONFIG_CMD_FLASH -#define PHYS_FLASH_1 0x00000000 /* Flash Bank #1 */ -#define PHYS_FLASH_SIZE 0x02000000 /* 32 MB */ -#define CONFIG_SYS_FLASH_BASE PHYS_FLASH_1 - -#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_32BIT - -#define CONFIG_SYS_MAX_FLASH_SECT (4 + 255) - -#define CONFIG_SYS_FLASH_ERASE_TOUT (25 * CONFIG_SYS_HZ) -#define CONFIG_SYS_FLASH_WRITE_TOUT (25 * CONFIG_SYS_HZ) -#define CONFIG_SYS_FLASH_LOCK_TOUT (25 * CONFIG_SYS_HZ) -#define CONFIG_SYS_FLASH_UNLOCK_TOUT (25 * CONFIG_SYS_HZ) -#endif - -#define CONFIG_SYS_MONITOR_LEN 0x40000 - -/* Skip factory configuration block */ - -/* - * GPIO settings - */ -#define CONFIG_SYS_GPSR0_VAL 0x00000000 -#define CONFIG_SYS_GPSR1_VAL 0x00020000 -#define CONFIG_SYS_GPSR2_VAL 0x0002c000 -#define CONFIG_SYS_GPSR3_VAL 0x00000000 - -#define CONFIG_SYS_GPCR0_VAL 0x00000000 -#define CONFIG_SYS_GPCR1_VAL 0x00000000 -#define CONFIG_SYS_GPCR2_VAL 0x00000000 -#define CONFIG_SYS_GPCR3_VAL 0x00000000 - -#define CONFIG_SYS_GPDR0_VAL 0xc8008000 -#define CONFIG_SYS_GPDR1_VAL 0xfc02a981 -#define CONFIG_SYS_GPDR2_VAL 0x92c3ffff -#define CONFIG_SYS_GPDR3_VAL 0x0061e804 - -#define CONFIG_SYS_GAFR0_L_VAL 0x80100000 -#define CONFIG_SYS_GAFR0_U_VAL 0xa5c00010 -#define CONFIG_SYS_GAFR1_L_VAL 0x6992901a -#define CONFIG_SYS_GAFR1_U_VAL 0xaaa50008 -#define CONFIG_SYS_GAFR2_L_VAL 0xaaaaaaaa -#define CONFIG_SYS_GAFR2_U_VAL 0x4109a002 -#define CONFIG_SYS_GAFR3_L_VAL 0x54000310 -#define CONFIG_SYS_GAFR3_U_VAL 0x00005401 - -#define CONFIG_SYS_PSSR_VAL 0x30 - -/* - * Clock settings - */ -#define CONFIG_SYS_CKEN 0x00500240 -#define CONFIG_SYS_CCCR 0x02000290 - -/* - * Memory settings - */ -#define CONFIG_SYS_MSC0_VAL 0x9ee1c5f2 -#define CONFIG_SYS_MSC1_VAL 0x9ee1f994 -#define CONFIG_SYS_MSC2_VAL 0x9ee19ee1 -#define CONFIG_SYS_MDCNFG_VAL 0x090009c9 -#define CONFIG_SYS_MDREFR_VAL 0x2003a031 -#define CONFIG_SYS_MDMRS_VAL 0x00220022 -#define CONFIG_SYS_FLYCNFG_VAL 0x00010001 -#define CONFIG_SYS_SXCNFG_VAL 0x40044004 - -/* - * PCMCIA and CF Interfaces - */ -#define CONFIG_SYS_MECR_VAL 0x00000000 -#define CONFIG_SYS_MCMEM0_VAL 0x00028307 -#define CONFIG_SYS_MCMEM1_VAL 0x00014307 -#define CONFIG_SYS_MCATT0_VAL 0x00038787 -#define CONFIG_SYS_MCATT1_VAL 0x0001c787 -#define CONFIG_SYS_MCIO0_VAL 0x0002830f -#define CONFIG_SYS_MCIO1_VAL 0x0001430f - -#include "pxa-common.h" - -#endif /* __CONFIG_H */ diff --git a/include/configs/pxa-common.h b/include/configs/pxa-common.h deleted file mode 100644 index 7a78f98eb15..00000000000 --- a/include/configs/pxa-common.h +++ /dev/null @@ -1,27 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Toradex Colibri PXA270 configuration file - * - * Copyright (C) 2010 Marek Vasut marek.vasut@gmail.com - */ - -#ifndef __CONFIG_PXA_COMMON_H__ -#define __CONFIG_PXA_COMMON_H__ - -/* - * OHCI USB - */ -#ifdef CONFIG_CMD_USB -#define CONFIG_USB_OHCI_NEW -#define CONFIG_SYS_USB_OHCI_CPU_INIT -#define CONFIG_SYS_USB_OHCI_BOARD_INIT -#ifdef CONFIG_CPU_PXA27X -#define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 3 -#else -#define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 -#endif -#define CONFIG_SYS_USB_OHCI_REGS_BASE 0x4c000000 -#define CONFIG_SYS_USB_OHCI_SLOT_NAME "pxa-ohci" -#endif - -#endif /* __CONFIG_PXA_COMMON_H__ */
From: Marcel Ziswiler marcel.ziswiler@toradex.com The Colibri PXA270 has been end-of-life since quite a while and would require more and more maintenance (e.g. DM conversions). Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com
This fixes the following crash when run on a Colibri iMX7S aka solo:
Colibri iMX7 # usb start starting USB... Bus usb@30b10000: USB EHCI 1.00 Bus usb@30b20000:
The i.MX 7Solo has only one single USB OTG1 but no USB host port. Trying to initialize the nonexisting port just crashes.
While at it also drop board_usb_phy_mode() which is also no longer used in the driver model age.
board/toradex/colibri_imx7/colibri_imx7.c | 40 +++++------------------ configs/colibri_imx7_defconfig | 1 + 2 files changed, 9 insertions(+), 32 deletions(-)
diff --git a/board/toradex/colibri_imx7/colibri_imx7.c b/board/toradex/colibri_imx7/colibri_imx7.c index 6822102d2c3..486299b5e93 100644 --- a/board/toradex/colibri_imx7/colibri_imx7.c +++ b/board/toradex/colibri_imx7/colibri_imx7.c @@ -319,40 +319,16 @@ int ft_board_setup(void *blob, struct bd_info *bd) #endif
#ifdef CONFIG_USB_EHCI_MX7 -static iomux_v3_cfg_t const usb_otg2_pads[] = { - MX7D_PAD_UART3_CTS_B__USB_OTG2_PWR | MUX_PAD_CTRL(NO_PAD_CTRL), -}; - -int board_ehci_hcd_init(int port) +int board_fix_fdt(void *rw_fdt_blob) { - switch (port) { - case 0: - break; - case 1: - if (is_cpu_type(MXC_CPU_MX7S)) - return -ENODEV; - - imx_iomux_v3_setup_multiple_pads(usb_otg2_pads, - ARRAY_SIZE(usb_otg2_pads)); - break; - default: - return -EINVAL; - } - return 0; -} + /* i.MX 7Solo has only one single USB OTG1 but no USB host port */ + if (is_cpu_type(MXC_CPU_MX7S)) { + int offset = fdt_path_offset(rw_fdt_blob, "/soc/bus@30800000/usb@30b20000");
-int board_usb_phy_mode(int port) -{ - switch (port) { - case 0: - if (gpio_get_value(USB_CDET_GPIO)) - return USB_INIT_DEVICE; - else - return USB_INIT_HOST; - case 1: - default: - return USB_INIT_HOST; + return fdt_status_disabled(rw_fdt_blob, offset); } + + return 0; }
#if defined(CONFIG_BOARD_LATE_INIT) @@ -373,4 +349,4 @@ int board_late_init(void) } #endif /* CONFIG_BOARD_LATE_INIT */
-#endif +#endif /* CONFIG_USB_EHCI_MX7 */ diff --git a/configs/colibri_imx7_defconfig b/configs/colibri_imx7_defconfig index 2f61223c9eb..0e254fd7d15 100644 --- a/configs/colibri_imx7_defconfig +++ b/configs/colibri_imx7_defconfig @@ -10,6 +10,7 @@ CONFIG_TARGET_COLIBRI_IMX7=y CONFIG_IMX_RDC=y CONFIG_IMX_BOOTAUX=y CONFIG_IMX_HAB=y +CONFIG_OF_BOARD_FIXUP=y CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x8c000000 CONFIG_DISTRO_DEFAULTS=y
From: Marcel Ziswiler marcel.ziswiler@toradex.com This fixes the following crash when run on a Colibri iMX7S aka solo: Colibri iMX7 # usb start starting USB... Bus usb@30b10000: USB EHCI 1.00 Bus usb@30b20000: The i.MX 7Solo has only one single USB OTG1 but no USB host port. Trying to initialize the nonexisting port just crashes. While at it also drop board_usb_phy_mode() which is also no longer used in the driver model age. Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com
Drop optional support for the ancient Apalis iMX6 V1.0 hardware which had the UART wired as DCE rather than DTE.
Changes in v2: - Also drop setup_dcemode_uart() and setup_iomux_dce_uart() which are now unused.
board/toradex/apalis_imx6/apalis_imx6.c | 38 ++----------------------- include/configs/apalis_imx6.h | 6 +--- 2 files changed, 3 insertions(+), 41 deletions(-)
diff --git a/board/toradex/apalis_imx6/apalis_imx6.c b/board/toradex/apalis_imx6/apalis_imx6.c index a78d52d3fac..5604c4646cf 100644 --- a/board/toradex/apalis_imx6/apalis_imx6.c +++ b/board/toradex/apalis_imx6/apalis_imx6.c @@ -304,13 +304,6 @@ static void setup_dtemode_uart(void) clrbits_le32((u32 *)(UART4_BASE + UCR3), UCR3_DCD | UCR3_RI); clrbits_le32((u32 *)(UART5_BASE + UCR3), UCR3_DCD | UCR3_RI); } -static void setup_dcemode_uart(void) -{ - clrbits_le32((u32 *)(UART1_BASE + UFCR), UFCR_DCEDTE); - clrbits_le32((u32 *)(UART2_BASE + UFCR), UFCR_DCEDTE); - clrbits_le32((u32 *)(UART4_BASE + UFCR), UFCR_DCEDTE); - clrbits_le32((u32 *)(UART5_BASE + UFCR), UFCR_DCEDTE); -}
static void setup_iomux_dte_uart(void) { @@ -318,12 +311,6 @@ static void setup_iomux_dte_uart(void) imx_iomux_v3_setup_multiple_pads(uart1_pads_dte, ARRAY_SIZE(uart1_pads_dte)); } -static void setup_iomux_dce_uart(void) -{ - setup_dcemode_uart(); - imx_iomux_v3_setup_multiple_pads(uart1_pads_dce, - ARRAY_SIZE(uart1_pads_dce)); -}
#ifdef CONFIG_USB_EHCI_MX6 int board_ehci_hcd_init(int port) @@ -665,11 +652,8 @@ int board_early_init_f(void) { imx_iomux_v3_setup_multiple_pads(pwr_intb_pads, ARRAY_SIZE(pwr_intb_pads)); -#ifndef CONFIG_TDX_APALIS_IMX6_V1_0 setup_iomux_dte_uart(); -#else - setup_iomux_dce_uart(); -#endif + return 0; }
@@ -714,23 +698,7 @@ int board_late_init(void) rev = get_board_revision(); snprintf(env_str, ARRAY_SIZE(env_str), "%.4x", rev); env_set("board_rev", env_str); - -#ifndef CONFIG_TDX_APALIS_IMX6_V1_0 - if ((rev & 0xfff0) == 0x0100) { - char *fdt_env; - - /* reconfigure the UART to DCE mode dynamically if on V1.0 HW */ - setup_iomux_dce_uart(); - - /* if using the default device tree, use version for V1.0 HW */ - fdt_env = env_get("fdt_file"); - if ((fdt_env != NULL) && (strcmp(FDT_FILE, fdt_env) == 0)) { - env_set("fdt_file", FDT_FILE_V1_0); - printf("patching fdt_file to " FDT_FILE_V1_0 "\n"); - } - } -#endif /* CONFIG_TDX_APALIS_IMX6_V1_0 */ -#endif /* CONFIG_REVISION_TAG */ +#endif /* CONFIG_BOARD_LATE_INIT */
#ifdef CONFIG_CMD_USB_SDP if (is_boot_from_usb()) { @@ -1129,10 +1097,8 @@ void board_init_f(ulong dummy) /* UART clocks enabled and gd valid - init serial console */ preloader_console_init();
-#ifndef CONFIG_TDX_APALIS_IMX6_V1_0 /* Make sure we use dte mode */ setup_dtemode_uart(); -#endif
/* DDR initialization */ spl_dram_init(); diff --git a/include/configs/apalis_imx6.h b/include/configs/apalis_imx6.h index 3a27bbb6c87..57fd3ce12d0 100644 --- a/include/configs/apalis_imx6.h +++ b/include/configs/apalis_imx6.h @@ -89,12 +89,8 @@ "ramdisk_addr_r=0x12200000\0" \ "scriptaddr=0x17000000\0"
-#ifndef CONFIG_TDX_APALIS_IMX6_V1_0 #define FDT_FILE "imx6q-apalis-eval.dtb" -#define FDT_FILE_V1_0 "imx6q-apalis_v1_0-eval.dtb" -#else -#define FDT_FILE "imx6q-apalis_v1_0-eval.dtb" -#endif + #define CONFIG_EXTRA_ENV_SETTINGS \ BOOTENV \ "boot_file=zImage\0" \
From: Marcel Ziswiler marcel.ziswiler@toradex.com Drop optional support for the ancient Apalis iMX6 V1.0 hardware which had the UART wired as DCE rather than DTE. Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com
Use PREBOOT as well. This allows a customer to just set fdt_board as on any other module to customize the device tree for his carrier board.
Changes in v2: - Re-based on top of Stefano's imx/master-next which dropped 13 commits already applied.
configs/apalis_imx6_defconfig | 2 ++ configs/colibri_imx6_defconfig | 2 ++ include/configs/apalis_imx6.h | 5 +---- include/configs/colibri_imx6.h | 4 +--- 4 files changed, 6 insertions(+), 7 deletions(-)
diff --git a/configs/apalis_imx6_defconfig b/configs/apalis_imx6_defconfig index 00c9a24a5dd..ea4ad276e7f 100644 --- a/configs/apalis_imx6_defconfig +++ b/configs/apalis_imx6_defconfig @@ -29,6 +29,8 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_BOOTDELAY=1 CONFIG_BOOTCOMMAND="run distro_bootcmd; usb start; setenv stdout serial,vidconsole; setenv stdin serial,usbkbd" +CONFIG_USE_PREBOOT=y +CONFIG_PREBOOT="test -n ${fdtfile} || setenv fdtfile imx6q-apalis-${fdt_board}.dtb" CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y diff --git a/configs/colibri_imx6_defconfig b/configs/colibri_imx6_defconfig index 1c65d8a7fe1..4f38d5cb483 100644 --- a/configs/colibri_imx6_defconfig +++ b/configs/colibri_imx6_defconfig @@ -28,6 +28,8 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_BOOTDELAY=1 CONFIG_BOOTCOMMAND="run distro_bootcmd; usb start; setenv stdout serial,vidconsole; setenv stdin serial,usbkbd" +CONFIG_USE_PREBOOT=y +CONFIG_PREBOOT="test -n ${fdtfile} || setenv fdtfile imx6dl-colibri-${fdt_board}.dtb" CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y diff --git a/include/configs/apalis_imx6.h b/include/configs/apalis_imx6.h index 57fd3ce12d0..aa93d10f852 100644 --- a/include/configs/apalis_imx6.h +++ b/include/configs/apalis_imx6.h @@ -89,16 +89,13 @@ "ramdisk_addr_r=0x12200000\0" \ "scriptaddr=0x17000000\0"
-#define FDT_FILE "imx6q-apalis-eval.dtb" - #define CONFIG_EXTRA_ENV_SETTINGS \ BOOTENV \ "boot_file=zImage\0" \ "boot_script_dhcp=boot.scr\0" \ "console=ttymxc0\0" \ "defargs=enable_wait_mode=off vmalloc=400M\0" \ - "fdt_file=" FDT_FILE "\0" \ - "fdtfile=" FDT_FILE "\0" \ + "fdt_board=eval\0" \ "fdt_fixup=;\0" \ MEM_LAYOUT_ENV_SETTINGS \ UBOOT_UPDATE \ diff --git a/include/configs/colibri_imx6.h b/include/configs/colibri_imx6.h index f7e9709e122..9ca6bef192f 100644 --- a/include/configs/colibri_imx6.h +++ b/include/configs/colibri_imx6.h @@ -78,15 +78,13 @@ "ramdisk_addr_r=0x12200000\0" \ "scriptaddr=0x17000000\0"
-#define FDT_FILE "imx6dl-colibri-eval-v3.dtb" #define CONFIG_EXTRA_ENV_SETTINGS \ BOOTENV \ "boot_file=zImage\0" \ "boot_script_dhcp=boot.scr\0" \ "console=ttymxc0\0" \ "defargs=enable_wait_mode=off galcore.contiguousSize=50331648\0" \ - "fdt_file=" FDT_FILE "\0" \ - "fdtfile=" FDT_FILE "\0" \ + "fdt_board=eval-v3\0" \ "fdt_fixup=;\0" \ MEM_LAYOUT_ENV_SETTINGS \ UBOOT_UPDATE \
From: Marcel Ziswiler marcel.ziswiler@toradex.com Use PREBOOT as well. This allows a customer to just set fdt_board as on any other module to customize the device tree for his carrier board. Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com
Marcel Ziswiler
sbabic@denx.de
