[U-Boot] [PATCH] 4xx: Remove obsolete or unused functions from some esd boards
This patch removes initdram() and testdram() from most esd 405 platforms. Some boards also have an empty dummy implementation of misc_init_f(). This is also removed.
Signed-off-by: Matthias Fuchs matthias.fuchs@esd-electronics.com --- board/esd/apc405/apc405.c | 10 ---------- board/esd/ash405/ash405.c | 23 ----------------------- board/esd/cms700/cms700.c | 21 --------------------- board/esd/cpci2dp/cpci2dp.c | 21 --------------------- board/esd/cpci405/cpci405.c | 19 ------------------- board/esd/cpciiser4/cpciiser4.c | 19 ------------------- board/esd/dasa_sim/dasa_sim.c | 20 -------------------- board/esd/dp405/dp405.c | 36 ------------------------------------ board/esd/du405/du405.c | 15 --------------- board/esd/hh405/hh405.c | 17 ----------------- board/esd/hub405/hub405.c | 18 ------------------ board/esd/ocrtc/ocrtc.c | 32 -------------------------------- board/esd/pmc405/pmc405.c | 18 ------------------ board/esd/voh405/voh405.c | 36 ------------------------------------ board/esd/wuh405/wuh405.c | 21 --------------------- 15 files changed, 0 insertions(+), 326 deletions(-)
diff --git a/board/esd/apc405/apc405.c b/board/esd/apc405/apc405.c index 83657c8..e629fd9 100644 --- a/board/esd/apc405/apc405.c +++ b/board/esd/apc405/apc405.c @@ -423,16 +423,6 @@ int checkboard (void) return 0; }
-phys_size_t initdram (int board_type) -{ - unsigned long val; - - mtdcr(memcfga, mem_mb0cf); - val = mfdcr(memcfgd); - - return (4*1024*1024 << ((val & 0x000e0000) >> 17)); -} - #ifdef CONFIG_IDE_RESET void ide_set_reset(int on) { diff --git a/board/esd/ash405/ash405.c b/board/esd/ash405/ash405.c index 25360a6..c3710ab 100644 --- a/board/esd/ash405/ash405.c +++ b/board/esd/ash405/ash405.c @@ -82,15 +82,6 @@ int board_early_init_f (void) return 0; }
- -/* ------------------------------------------------------------------------- */ - -int misc_init_f (void) -{ - return 0; /* dummy implementation */ -} - - int misc_init_r (void) { volatile unsigned char *duart0_mcr = (unsigned char *)((ulong)DUART0_BA + 4); @@ -205,20 +196,6 @@ int checkboard (void) return 0; }
-/* ------------------------------------------------------------------------- */ - -phys_size_t initdram (int board_type) -{ - unsigned long val; - - mtdcr(memcfga, mem_mb0cf); - val = mfdcr(memcfgd); - - return (4*1024*1024 << ((val & 0x000e0000) >> 17)); -} - -/* ------------------------------------------------------------------------- */ - void reset_phy(void) { #ifdef CONFIG_LXT971_NO_SLEEP diff --git a/board/esd/cms700/cms700.c b/board/esd/cms700/cms700.c index ba27c03..806c755 100644 --- a/board/esd/cms700/cms700.c +++ b/board/esd/cms700/cms700.c @@ -77,15 +77,6 @@ int board_early_init_f (void) return 0; }
- -/* ------------------------------------------------------------------------- */ - -int misc_init_f (void) -{ - return 0; /* dummy implementation */ -} - - int misc_init_r (void) { /* adjust flash start and offset */ @@ -141,18 +132,6 @@ int checkboard (void)
-phys_size_t initdram (int board_type) -{ - unsigned long val; - - mtdcr(memcfga, mem_mb0cf); - val = mfdcr(memcfgd); - - return (4*1024*1024 << ((val & 0x000e0000) >> 17)); -} - -/* ------------------------------------------------------------------------- */ - #if defined(CFG_EEPROM_WREN) /* Input: <dev_addr> I2C address of EEPROM device to enable. * <state> -1: deliver current state diff --git a/board/esd/cpci2dp/cpci2dp.c b/board/esd/cpci2dp/cpci2dp.c index 54de0b8..8bc40d5 100644 --- a/board/esd/cpci2dp/cpci2dp.c +++ b/board/esd/cpci2dp/cpci2dp.c @@ -67,13 +67,6 @@ int board_early_init_f (void) return 0; }
- -int misc_init_f (void) -{ - return 0; /* dummy implementation */ -} - - int misc_init_r (void) { unsigned long cntrl0Reg; @@ -115,20 +108,6 @@ int checkboard (void) return 0; }
-/* ------------------------------------------------------------------------- */ - -phys_size_t initdram (int board_type) -{ - unsigned long val; - - mtdcr(memcfga, mem_mb0cf); - val = mfdcr(memcfgd); - - return (4*1024*1024 << ((val & 0x000e0000) >> 17)); -} - -/* ------------------------------------------------------------------------- */ - #if defined(CFG_EEPROM_WREN) /* Input: <dev_addr> I2C address of EEPROM device to enable. * <state> -1: deliver current state diff --git a/board/esd/cpci405/cpci405.c b/board/esd/cpci405/cpci405.c index b856705..005871c 100644 --- a/board/esd/cpci405/cpci405.c +++ b/board/esd/cpci405/cpci405.c @@ -255,11 +255,6 @@ int cpci405_version(void) } }
-int misc_init_f (void) -{ - return 0; /* dummy implementation */ -} - int misc_init_r (void) { unsigned long cntrl0Reg; @@ -493,18 +488,6 @@ int checkboard (void) return 0; }
-/* ------------------------------------------------------------------------- */ - -phys_size_t initdram (int board_type) -{ - unsigned long val; - - mtdcr(memcfga, mem_mb0cf); - val = mfdcr(memcfgd); - - return (4*1024*1024 << ((val & 0x000e0000) >> 17)); -} - void reset_phy(void) { #ifdef CONFIG_LXT971_NO_SLEEP @@ -516,8 +499,6 @@ void reset_phy(void) #endif }
-/* ------------------------------------------------------------------------- */ - #ifdef CONFIG_CPCI405_VER2 #ifdef CONFIG_IDE_RESET
diff --git a/board/esd/cpciiser4/cpciiser4.c b/board/esd/cpciiser4/cpciiser4.c index 204117e..b5d2543 100644 --- a/board/esd/cpciiser4/cpciiser4.c +++ b/board/esd/cpciiser4/cpciiser4.c @@ -183,22 +183,3 @@ int checkboard (void)
return 0; } - -/* ------------------------------------------------------------------------- */ - -phys_size_t initdram (int board_type) -{ - return (16 * 1024 * 1024); -} - -/* ------------------------------------------------------------------------- */ - -int testdram (void) -{ - /* TODO: XXX XXX XXX */ - printf ("test: 16 MB - ok\n"); - - return (0); -} - -/* ------------------------------------------------------------------------- */ diff --git a/board/esd/dasa_sim/dasa_sim.c b/board/esd/dasa_sim/dasa_sim.c index fb0c77e..def0354 100644 --- a/board/esd/dasa_sim/dasa_sim.c +++ b/board/esd/dasa_sim/dasa_sim.c @@ -202,23 +202,3 @@ int checkboard (void)
return 0; } - - -/* ------------------------------------------------------------------------- */ - -phys_size_t initdram (int board_type) -{ - return (16 * 1024 * 1024); -} - -/* ------------------------------------------------------------------------- */ - -int testdram (void) -{ - /* TODO: XXX XXX XXX */ - printf ("test: 16 MB - ok\n"); - - return (0); -} - -/* ------------------------------------------------------------------------- */ diff --git a/board/esd/dp405/dp405.c b/board/esd/dp405/dp405.c index bb3baa4..eb001da 100644 --- a/board/esd/dp405/dp405.c +++ b/board/esd/dp405/dp405.c @@ -74,15 +74,6 @@ int board_early_init_f (void) return 0; }
- -/* ------------------------------------------------------------------------- */ - -int misc_init_f (void) -{ - return 0; /* dummy implementation */ -} - - int misc_init_r (void) { /* adjust flash start and offset */ @@ -119,30 +110,3 @@ int checkboard (void)
return 0; } - -/* ------------------------------------------------------------------------- */ - -phys_size_t initdram (int board_type) -{ - unsigned long val; - - mtdcr(memcfga, mem_mb0cf); - val = mfdcr(memcfgd); - -#if 0 - printf("\nmb0cf=%x\n", val); /* test-only */ - printf("strap=%x\n", mfdcr(strap)); /* test-only */ -#endif - - return (4*1024*1024 << ((val & 0x000e0000) >> 17)); -} - -/* ------------------------------------------------------------------------- */ - -int testdram (void) -{ - /* TODO: XXX XXX XXX */ - printf ("test: 16 MB - ok\n"); - - return (0); -} diff --git a/board/esd/du405/du405.c b/board/esd/du405/du405.c index 78ae4ba..8a87d55 100644 --- a/board/esd/du405/du405.c +++ b/board/esd/du405/du405.c @@ -198,18 +198,3 @@ int checkboard (void)
return 0; } - - -phys_size_t initdram (int board_type) -{ - return (16 * 1024 * 1024); -} - - -int testdram (void) -{ - /* TODO: XXX XXX XXX */ - printf ("test: 16 MB - ok\n"); - - return (0); -} diff --git a/board/esd/hh405/hh405.c b/board/esd/hh405/hh405.c index 802491a..9fc41c8 100644 --- a/board/esd/hh405/hh405.c +++ b/board/esd/hh405/hh405.c @@ -643,23 +643,6 @@ int checkboard (void) return 0; }
- -phys_size_t initdram (int board_type) -{ - unsigned long val; - - mtdcr(memcfga, mem_mb0cf); - val = mfdcr(memcfgd); - -#if 0 - printf("\nmb0cf=%x\n", val); /* test-only */ - printf("strap=%x\n", mfdcr(strap)); /* test-only */ -#endif - - return (4*1024*1024 << ((val & 0x000e0000) >> 17)); -} - - #ifdef CONFIG_IDE_RESET void ide_set_reset(int on) { diff --git a/board/esd/hub405/hub405.c b/board/esd/hub405/hub405.c index 03b87c9..38a6f7a 100644 --- a/board/esd/hub405/hub405.c +++ b/board/esd/hub405/hub405.c @@ -101,13 +101,6 @@ int board_early_init_f (void) return 0; }
- -int misc_init_f (void) -{ - return 0; /* dummy implementation */ -} - - int misc_init_r (void) { volatile unsigned char *duart0_mcr = (unsigned char *)((ulong)DUART0_BA + 4); @@ -227,14 +220,3 @@ int checkboard (void)
return 0; } - - -phys_size_t initdram (int board_type) -{ - unsigned long val; - - mtdcr(memcfga, mem_mb0cf); - val = mfdcr(memcfgd); - - return (4*1024*1024 << ((val & 0x000e0000) >> 17)); -} diff --git a/board/esd/ocrtc/ocrtc.c b/board/esd/ocrtc/ocrtc.c index 7b0edd5..35bfa95 100644 --- a/board/esd/ocrtc/ocrtc.c +++ b/board/esd/ocrtc/ocrtc.c @@ -62,13 +62,6 @@ int board_early_init_f (void) return 0; }
- -int misc_init_f (void) -{ - return 0; /* dummy implementation */ -} - - /* * Check Board Identity: */ @@ -99,28 +92,3 @@ int checkboard (void)
return (0); } - - -phys_size_t initdram (int board_type) -{ - unsigned long val; - - mtdcr (memcfga, mem_mb0cf); - val = mfdcr (memcfgd); - -#if 0 - printf ("\nmb0cf=%x\n", val); /* test-only */ - printf ("strap=%x\n", mfdcr (strap)); /* test-only */ -#endif - - return (4 * 1024 * 1024 << ((val & 0x000e0000) >> 17)); -} - - -int testdram (void) -{ - /* TODO: XXX XXX XXX */ - printf ("test: 16 MB - ok\n"); - - return (0); -} diff --git a/board/esd/pmc405/pmc405.c b/board/esd/pmc405/pmc405.c index 326d560..90a212b 100644 --- a/board/esd/pmc405/pmc405.c +++ b/board/esd/pmc405/pmc405.c @@ -156,24 +156,6 @@ int checkboard (void) }
/* ------------------------------------------------------------------------- */ - -phys_size_t initdram (int board_type) -{ - unsigned long val; - - mtdcr(memcfga, mem_mb0cf); - val = mfdcr(memcfgd); - -#if 0 - printf("\nmb0cf=%x\n", val); /* test-only */ - printf("strap=%x\n", mfdcr(strap)); /* test-only */ -#endif - - return (4*1024*1024 << ((val & 0x000e0000) >> 17)); -} - - -/* ------------------------------------------------------------------------- */ void reset_phy(void) { #ifdef CONFIG_LXT971_NO_SLEEP diff --git a/board/esd/voh405/voh405.c b/board/esd/voh405/voh405.c index 5253422..115f8b4 100644 --- a/board/esd/voh405/voh405.c +++ b/board/esd/voh405/voh405.c @@ -104,13 +104,6 @@ int board_early_init_f (void) return 0; }
- -int misc_init_f (void) -{ - return 0; /* dummy implementation */ -} - - int misc_init_r (void) { unsigned char *duart0_mcr = (unsigned char *)((ulong)DUART0_BA + 4); @@ -303,35 +296,6 @@ int checkboard (void) return 0; }
-/* ------------------------------------------------------------------------- */ - -phys_size_t initdram (int board_type) -{ - unsigned long val; - - mtdcr(memcfga, mem_mb0cf); - val = mfdcr(memcfgd); - -#if 0 - printf("\nmb0cf=%x\n", val); /* test-only */ - printf("strap=%x\n", mfdcr(strap)); /* test-only */ -#endif - - return (4*1024*1024 << ((val & 0x000e0000) >> 17)); -} - -/* ------------------------------------------------------------------------- */ - -int testdram (void) -{ - /* TODO: XXX XXX XXX */ - printf ("test: 16 MB - ok\n"); - - return (0); -} - -/* ------------------------------------------------------------------------- */ - #ifdef CONFIG_IDE_RESET void ide_set_reset(int on) { diff --git a/board/esd/wuh405/wuh405.c b/board/esd/wuh405/wuh405.c index 0590fc7..3a94fd8 100644 --- a/board/esd/wuh405/wuh405.c +++ b/board/esd/wuh405/wuh405.c @@ -80,15 +80,6 @@ int board_early_init_f (void) return 0; }
- -/* ------------------------------------------------------------------------- */ - -int misc_init_f (void) -{ - return 0; /* dummy implementation */ -} - - int misc_init_r (void) { volatile unsigned char *duart0_mcr = (unsigned char *)((ulong)DUART0_BA + 4); @@ -202,15 +193,3 @@ int checkboard (void)
return 0; } - -/* ------------------------------------------------------------------------- */ - -phys_size_t initdram (int board_type) -{ - unsigned long val; - - mtdcr(memcfga, mem_mb0cf); - val = mfdcr(memcfgd); - - return (4*1024*1024 << ((val & 0x000e0000) >> 17)); -}
Applied to u-boot-ppc4xx. Thanks.
Best regards, Stefan
Matthias Fuchs
Stefan Roese
