[U-Boot] buildman dtc check error
Simon,
I am facing a weird issue on the latest u-boot. I can successfully build u-boot manually, but with buildman I see checkdtc error.
aarch64: + ls2085aqds +make[1]: *** [checkdtc] Error 1 +make: *** [sub-make] Error 2
I have DTC 1.4.1-ge5e6df7c. Is there any flag for buildman I can see more information? I always use -vVeu as the flag.
York
Hi York,
On 23 July 2015 at 16:10, York Sun yorksun@freescale.com wrote:
Simon,
That's not very helpful, sorry. You can always look at the raw logs. You could try an in-tree build with -i if that is what you are using normally.
On 07/23/2015 03:24 PM, Simon Glass wrote:
Hi York,
Simon,
Simon,
The raw log has been a mystery for me since beginning. Where do I find it? Using -i flag also has the same error message.
York
Hi York,
Hi York,
Simon,
Simon,
We really should solve this mystery :-) It's documented in the buildman README.
By default, ../<branch>/<commit>/<board>/
or if you are just building current source it is in ../current
On 07/23/2015 08:45 PM, Simon Glass wrote:
Hi York,
Hi York,
Simon,
Simon,
Thanks, Simon. I didn't use --force-build. So I guess repeat build didn't actually build anything. I found the file "log" but it is empty for a successful build.
York
York Sun
