[U-Boot] [PATCH] omap4: Use a smaller M,N couple for IVA DPLL
Signed-off-by: Sebastien Jan s-jan@ti.com --- arch/arm/cpu/armv7/omap4/clocks.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv7/omap4/clocks.c b/arch/arm/cpu/armv7/omap4/clocks.c index c568951..1d92e66 100644 --- a/arch/arm/cpu/armv7/omap4/clocks.c +++ b/arch/arm/cpu/armv7/omap4/clocks.c @@ -146,7 +146,7 @@ static const struct dpll_params iva_dpll_params_1862mhz[NUM_SYS_CLKS] = { {727, 14, -1, -1, 4, 7, -1, -1}, /* 19.2 MHz */ {931, 25, -1, -1, 4, 7, -1, -1}, /* 26 MHz */ {931, 26, -1, -1, 4, 7, -1, -1}, /* 27 MHz */ - {412, 16, -1, -1, 4, 7, -1, -1} /* 38.4 MHz */ + {291, 11, -1, -1, 4, 7, -1, -1} /* 38.4 MHz */ };
/* ABE M & N values with sys_clk as source */
Please explain what / why you are changing things here (based on docs, testing, ?). Thanks!
Hi Tom,
Sure, sorry for missing that. The reduced M,N couple in this patch corresponds to the advised value from our HW team. It tested with it, and it also provides peripheral clocks closer to the advised values.
Regards, Seb
On 06/13/2012 12:30 AM, Jan, Sebastien wrote:
Hi Tom,
On Tue, Jun 12, 2012 at 7:41 PM, Tom Rini <trini@ti.com mailto:trini@ti.com> wrote:
On Tue, Jun 12, 2012 at 12:34 AM, Sebastien Jan <s-jan@ti.com <mailto:s-jan@ti.com>> wrote: > Signed-off-by: Sebastien Jan <s-jan@ti.com <mailto:s-jan@ti.com>> Please explain what / why you are changing things here (based on docs, testing, ?). Thanks!
Thanks. Can you please submit a v2 with that explanation in the commit message?
Hi Tom,
docs,
Yes, will do
Jan, Sebastien
Sebastien Jan
