[U-Boot] [PATCH] board: imx6dl_mamoj: set the value for CSF size
Default value is too high and it covers the worst case. SPL for imx6dl_mamoj becomes too big and cannot fit into the OCRAM, but CSF size can be reduced.
Signed-off-by: Stefano Babic sbabic@denx.de CC: Jagan Teki jagan@amarulasolutions.com CC: Breno Lima breno.lima@nxp.com --- configs/imx6dl_mamoj_defconfig | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/configs/imx6dl_mamoj_defconfig b/configs/imx6dl_mamoj_defconfig index 44486cbfa3..983d98536c 100644 --- a/configs/imx6dl_mamoj_defconfig +++ b/configs/imx6dl_mamoj_defconfig @@ -4,12 +4,13 @@ CONFIG_SYS_TEXT_BASE=0x17800000 CONFIG_SECURE_BOOT=y CONFIG_TARGET_MX6DL_MAMOJ=y CONFIG_NR_DRAM_BANKS=1 +CONFIG_CSF_SIZE=0x2060 # CONFIG_CMD_BMODE is not set +CONFIG_SPL_TEXT_BASE=0x00908000 CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg" CONFIG_BOOTDELAY=3 CONFIG_BOUNCE_BUFFER=y -CONFIG_SPL_TEXT_BASE=0x00908000 CONFIG_SPL_OS_BOOT=y CONFIG_CRC32_VERIFY=y CONFIG_CMD_MEMTEST=y
Stefano Babic
