dm: core: Board failing to boot since commit 82de42fa1468 (parent data/probe)
Hello Simon,
Since commit 82de42fa1468 ("dm: core: Allocate parent data separate from probing parent") I have trouble booting my board (a custom Apollo Lake design booted via Coreboot + U-Boot).
I think this is because the function ns16550_serial_ofdata_to_platdata() of the UART driver noew tries to access the PCI bus before it is probed. I'm aware of the comment which you have added to pci-uclass.c [1].
So the correct way to fix this would be to adapt the uart driver in ns16550.c?
regards, Wolfgang
Detail information:
As far as I understand the situation the following things happen: * My debug UART is probed * This triggers a call to ns16550_serial_ofdata_to_platdata() * This function tries to read BAR0 from the PCI devices * Reading BAR0 returns 0xffffffff, as the PCI bus has not been probed yet * The serial driver tries to read from a non-existing register based on this invalid BAR0 value and hangs indefinitely.
This is confirmed by the warning which you have introduced a few commits ealier in commit 4886287ee4f9 ("pci: Print a warning if the bus is accessed before probing"):
"dm_pci_get_bdf() PCI: Device 'uart@18,2' on unprobed bus 'pci'"
[1] "A common cause of this problem is that this function is called in the ofdata_to_platdata() method of @dev. Accessing the PCI bus in that method is not allowed, since it has not yet been probed. To fix this, move that access to the probe() method of @dev instead."
+Bin
Hi Wolfgang,
On Tue, 11 Feb 2020 at 06:59, Wolfgang Wallner wolfgang.wallner@br-automation.com wrote:
Hello Simon,
Why is the UART being used so early? Also, if you are booting from coreboot you really shouldn't need to auto-config PCI at all, so perhaps just disable CONFIG_PCI_PNP? But I understand that that changes the build.
The way I fixed it is to allow the UART to stay at a fixed PCI address:
9e11293319 dm: pci: Allow disabling auto-config for a device
That's in u-boot-dm/coral-working
regards, Wolfgang
Detail information:
- My debug UART is probed
- This triggers a call to ns16550_serial_ofdata_to_platdata()
- This function tries to read BAR0 from the PCI devices
- Reading BAR0 returns 0xffffffff, as the PCI bus has not been probed yet
- The serial driver tries to read from a non-existing register based on this invalid BAR0 value and hangs indefinitely.
Hi Wolfgang,
On Wed, Feb 12, 2020 at 1:14 AM Simon Glass sjg@chromium.org wrote:
+Bin
Hi Wolfgang,
Hello Simon,
Please suggest whether I should get the above patch applied to fix the issue you saw on your board.
regards, Wolfgang
Detail information:
Regards, Bin
Hi Bin, Simon,
-----"Bin Meng" bmeng.cn@gmail.com schrieb: -----
Hi Wolfgang,
+Bin
Hi Wolfgang,
Hello Simon,
board_init_f() calls serial_init(), because it is part of init_sequence_f. This leads to device_probe() being called for my UART.
The detailed call stack looks as follows:
File Function --------------------------------------------------------------------- board_f.c board_init_f() serial-uclass.c serial_init() serial_find_console_or_panic() serial_check_stdout() // stdout-path is set to serial0:115200n8 // serial0 is an alias for the device pciuart2, // which is called uart@18,2 in my device tree // This device is similar to what is called // serial@18,2 in chromebook_coral.dts uclass.c uclass_get_device_by_of_offset() uclass_get_device_tail() device.c device_probe() // device_probe calls drv->ofdata_to_platdata(), // which points to // ns16550_serial_ofdata_to_platdata in my case ns16550.c ns16550_serial_ofdata_to_platdata() // This is where the PCI access to the // uninitialized bus 'pci' happens
CONFIG_PCI_PNP is already disabled in my configuration.
I think commit 9e11293319 would be a solution if the problem would be CONFIG_PCI_PNP, but that is not the case here.
Just to be sure I have cherry-picked 9e11293319 and added "pci,no-autoconfig;" to my UART, but that does not solve my issue.
I think the issue I see is something different.
And I can't provide a proper review for commit 9e11293319 as I don't know the PCI subsystem in U-Boot well enough.
regards, Wolfgang
Detail information:
Regards, Bin
regards, Wolfgang
Hi Wolfgang,
On Mon, 17 Feb 2020 at 03:39, Wolfgang Wallner wolfgang.wallner@br-automation.com wrote:
Hi Bin, Simon,
Hi Wolfgang,
+Bin
Hi Wolfgang,
Hello Simon,
File Function
It looks like the dev_read_addr_pci() needs to move into a probe() function in that driver.
Hi Simon,
On Fri, Feb 28, 2020 at 7:41 AM Simon Glass sjg@chromium.org wrote:
Hi Wolfgang,
Hi Bin, Simon,
Hi Wolfgang,
+Bin
Hi Wolfgang,
Hello Simon,
File Function
This is http://patchwork.ozlabs.org/patch/1239995/ already in the queue.
Regards, Bin
Bin Meng
Wolfgang Wallner
