[U-Boot] [PATCH 1/3] ARM: rcar_gen3: fix protection area access error at Cortex-A53
From: Hiroyuki Yokoyama hiroyuki.yokoyama.vx@renesas.com
This patch fixes the problem that "main memory domain AXI secure access protection error" occurs when booting Cortex-A53. Exclude the area (0x43f00000 to 0x47DFFFFF) set by DBSC from the map area.
Signed-off-by: Hiroyuki Yokoyama hiroyuki.yokoyama.vx@renesas.com Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com --- arch/arm/mach-rmobile/memmap-gen3.c | 8 +++++++- 1 file changed, 7 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-rmobile/memmap-gen3.c b/arch/arm/mach-rmobile/memmap-gen3.c index 7e29ccc351..0429a2ac51 100644 --- a/arch/arm/mach-rmobile/memmap-gen3.c +++ b/arch/arm/mach-rmobile/memmap-gen3.c @@ -21,7 +21,13 @@ static struct mm_region gen3_mem_map[GEN3_NR_REGIONS] = { }, { .virt = 0x40000000UL, .phys = 0x40000000UL, - .size = 0x80000000UL, + .size = 0x03F00000UL, + .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE + }, { + .virt = 0x47E00000UL, + .phys = 0x47E00000UL, + .size = 0x78200000UL, .attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | PTE_BLOCK_INNER_SHARE }, {
This patch fixes the problem that "main memory domain AXI secure access protection error" occurs. Exclude the area (0x43f00000 to 0x47DFFFFF) set by DBSC from the map area.
Signed-off-by: Takeshi Kihara takeshi.kihara.df@renesas.com Signed-off-by: Hiroyuki Yokoyama hiroyuki.yokoyama.vx@renesas.com Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com --- arch/arm/mach-rmobile/memmap-gen3.c | 12 ++++++++++-- 1 file changed, 10 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-rmobile/memmap-gen3.c b/arch/arm/mach-rmobile/memmap-gen3.c index 0429a2ac51..3c0f3548cb 100644 --- a/arch/arm/mach-rmobile/memmap-gen3.c +++ b/arch/arm/mach-rmobile/memmap-gen3.c @@ -82,8 +82,16 @@ void enable_caches(void)
/* Mark memory reserved by ATF as cacheable too. */ if (start == 0x48000000) { - start = 0x40000000ULL; - size += 0x08000000ULL; + /* Unmark protection area (0x43F00000 to 0x47DFFFFF) */ + gen3_mem_map[i].virt = 0x40000000ULL; + gen3_mem_map[i].phys = 0x40000000ULL; + gen3_mem_map[i].size = 0x03F00000ULL; + gen3_mem_map[i].attrs = PTE_BLOCK_MEMTYPE(MT_NORMAL) | + PTE_BLOCK_INNER_SHARE; + i++; + + start = 0x47E00000ULL; + size += 0x00200000ULL; }
gen3_mem_map[i].virt = start;
This patch fixes the problem that u-boot will not start unless icache is enabled early.
Signed-off-by: Takeshi Kihara takeshi.kihara.df@renesas.com Signed-off-by: Hiroyuki Yokoyama hiroyuki.yokoyama.vx@renesas.com Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com --- arch/arm/mach-rmobile/cpu_info.c | 4 ++-- arch/arm/mach-rmobile/memmap-gen3.c | 4 +++- 2 files changed, 5 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-rmobile/cpu_info.c b/arch/arm/mach-rmobile/cpu_info.c index 65a9ca8c01..aa5be52dfd 100644 --- a/arch/arm/mach-rmobile/cpu_info.c +++ b/arch/arm/mach-rmobile/cpu_info.c @@ -7,8 +7,6 @@ #include <asm/io.h> #include <linux/ctype.h>
-/* R-Car Gen3 caches are enabled in memmap-gen3.c */ -#ifndef CONFIG_RCAR_GEN3 #ifdef CONFIG_ARCH_CPU_INIT int arch_cpu_init(void) { @@ -17,6 +15,8 @@ int arch_cpu_init(void) } #endif
+/* R-Car Gen3 D-cache is enabled in memmap-gen3.c */ +#ifndef CONFIG_RCAR_GEN3 #ifndef CONFIG_SYS_DCACHE_OFF void enable_caches(void) { diff --git a/arch/arm/mach-rmobile/memmap-gen3.c b/arch/arm/mach-rmobile/memmap-gen3.c index 3c0f3548cb..1a9eb72bb9 100644 --- a/arch/arm/mach-rmobile/memmap-gen3.c +++ b/arch/arm/mach-rmobile/memmap-gen3.c @@ -140,6 +140,8 @@ void enable_caches(void) gen3_mem_map[i].attrs = 0; }
- icache_enable(); + if (!icache_status()) + icache_enable(); + dcache_enable(); }
