Please pull u-boot-marvell/master (watchdog related)
Hi Tom,
please pull the following watchdog related patches:
---------------------------------------------------------------- - designware_wdt: reset watchdog in designware_wdt_stop() function (Meng) - socfpga_stratix10: enable wdt command (Meng) - wdt-uclass: Use IS_ENABLED for WATCHDOG_AUTOSTART (Teresa) ----------------------------------------------------------------
Here the Azure build, without any issues:
https://dev.azure.com/sr0718/u-boot/_build/results?buildId=99&view=resul...
Thanks, Stefan
The following changes since commit d3fc3da9a4fb98104d004b025149ec6dadccc2cd:
Merge https://source.denx.de/u-boot/custodians/u-boot-x86 (2021-07-15 11:06:24 -0400)
git@source.denx.de:u-boot/custodians/u-boot-marvell.git
for you to fetch changes up to 5fc094351381c4254098a25404d8712324b6918e:
drivers: watchdog: wdt-uclass: Use IS_ENABLED for WATCHDOG_AUTOSTART (2021-07-16 10:28:35 +0200)
---------------------------------------------------------------- MengLi (2): driver: watchdog: reset watchdog in designware_wdt_stop() function arm: socfpga: socfpga_stratix10: enable wdt command by default
Teresa Remmet (1): drivers: watchdog: wdt-uclass: Use IS_ENABLED for WATCHDOG_AUTOSTART
configs/socfpga_stratix10_defconfig | 1 + drivers/watchdog/designware_wdt.c | 19 +++++++++++++++---- drivers/watchdog/wdt-uclass.c | 2 +- 3 files changed, 17 insertions(+), 5 deletions(-)
Stefan Roese
