Re: [U-Boot] [PATCH v4 13/18] efi_loader: fix StartImage bootservice
On 01/19/2018 09:16 PM, xypron.glpk@gmx.de wrote:
The calling convention for the entry point of an EFI image is always 'asmlinkage'.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de
v4 rebase according to https://github.com/agraf/efi_next v3 Use efi_handle_t as type of the image handle. v2 no change
lib/efi_loader/efi_boottime.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index 7c61dfb3a7..324abe4d48 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -1530,7 +1530,8 @@ static efi_status_t EFIAPI efi_start_image(efi_handle_t image_handle, unsigned long *exit_data_size, s16 **exit_data) {
- ulong (*entry)(efi_handle_t image_handle, struct efi_system_table *st);
- asmlinkage ulong (*entry)(efi_handle_t image_handle,
Alex,
could you once again carefully review this change.
Have a look at the definition of EFIAPI in include/efi.h
In cmd/bootefi.c we assume the entry point is asmlinkage. In lib/efi_loader/helloworld.c we assume it is EFIAPI.
The definition of EFIAPI depends on CONFIG_EFI_STUB_64BIT, which is only defined in configs/qemu-x86_efi_payload64_defconfig.
Why should the definition of EFIAPI depend on whether we are consuming or offering the API? Shouldn't EFIAPI have the same definition when compiling qemu-x86_64_defconfig?
Am I right that the entry point should in cmd/bootefi.c, helloworld.c, efi_start_image() should always be defined as
EFIAPI efi_status_t (*entry)(efi_handle_t image_handle
and further when compiling for x86_64 we should always define EFIAPI as
__attribute__((ms_abi))
and on other systems as
asmlinkage
Best regards
Heinrich
struct efi_loaded_image *info = image_handle; efi_status_t ret;
Alex,
Because EFI supported started as payload support.
asmlinkage
Not quite. I guess we basically want to have EFI_LOADER select EFI_STUB_64BIT on x86_64. So maybe something like the patch below?
Alex
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index 51213c0293..c579b76b4b 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -126,8 +126,8 @@ static void *copy_fdt(void *fdt)
static efi_status_t efi_do_enter( efi_handle_t image_handle, struct efi_system_table *st, - asmlinkage ulong (*entry)(efi_handle_t image_handle, - struct efi_system_table *st)) + EFIAPI ulong (*entry)(efi_handle_t image_handle, + struct efi_system_table *st)) { efi_status_t ret = EFI_LOAD_ERROR;
@@ -138,7 +138,7 @@ static efi_status_t efi_do_enter( }
#ifdef CONFIG_ARM64 -static efi_status_t efi_run_in_el2(asmlinkage ulong (*entry)( +static efi_status_t efi_run_in_el2(EFIAPI ulong (*entry)( efi_handle_t image_handle, struct efi_system_table *st), efi_handle_t image_handle, struct efi_system_table *st) { @@ -163,7 +163,7 @@ static efi_status_t do_bootefi_exec(void *efi, void *fdt, ulong ret;
ulong (*entry)(efi_handle_t image_handle, struct efi_system_table *st) - asmlinkage; + EFIAPI; ulong fdt_pages, fdt_size, fdt_start, fdt_end; const efi_guid_t fdt_guid = EFI_FDT_GUID; bootm_headers_t img = { 0 }; diff --git a/include/efi.h b/include/efi.h index 2f0be9c86c..29f6930f53 100644 --- a/include/efi.h +++ b/include/efi.h @@ -19,7 +19,7 @@ #include <linux/string.h> #include <linux/types.h>
-#ifdef CONFIG_EFI_STUB_64BIT +#if CONFIG_EFI_STUB_64BIT || (!defined(CONFIG_EFI_STUB) && defined (__x86_64__)) /* EFI uses the Microsoft ABI which is not the default for GCC */ #define EFIAPI __attribute__((ms_abi)) #else diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index d2b6327119..827c267b60 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -1,6 +1,10 @@ config EFI_LOADER bool "Support running EFI Applications in U-Boot" depends on (ARM || X86) && OF_LIBFDT + # We need EFI_STUB_64BIT to be set on x86_64 with EFI_STUB + depends on !EFI_STUB || !X86_64 || EFI_STUB_64BIT + # We need EFI_STUB_32BIT to be set on x86_32 with EFI_STUB + depends on !EFI_STUB || !X86 || X86_64 || EFI_STUB_32BIT default y help Select this option if you want to run EFI applications (like grub2) diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index 39d8511fe3..5b78740bff 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -1534,8 +1534,8 @@ static efi_status_t EFIAPI efi_start_image(efi_handle_t image_handle, unsigned long *exit_data_size, s16 **exit_data) { - asmlinkage ulong (*entry)(efi_handle_t image_handle, - struct efi_system_table *st); + EFIAPI ulong (*entry)(efi_handle_t image_handle, + struct efi_system_table *st); struct efi_loaded_image *info = image_handle; efi_status_t ret;
Alex,
asmlinkage
Alex
We should use efi_status_t and not ulong here (and below). It dislike if the same property gets different names.
asmlinkage;
ulong fdt_pages, fdt_size, fdt_start, fdt_end; const efi_guid_t fdt_guid = EFI_FDT_GUID; bootm_headers_t img = { 0 };EFIAPI;
- # We need EFI_STUB_64BIT to be set on x86_64 with EFI_STUB
- depends on !EFI_STUB || !X86_64 || EFI_STUB_64BIT
- # We need EFI_STUB_32BIT to be set on x86_32 with EFI_STUB
- depends on !EFI_STUB || !X86 || X86_64 || EFI_STUB_32BIT
Wouldn't it be better to let EFI_API depend on CONFIG_X86_64?
Why shouldn't EFI_LOADER and EFI_STUB be built together?
Regards
Heinrich
- EFIAPI ulong (*entry)(efi_handle_t image_handle,
struct efi_loaded_image *info = image_handle; efi_status_t ret;struct efi_system_table *st);
Alex,
asmlinkage
Alex
Sure.
asmlinkage;
Why would EFI_API depend on X86_64? It works just fine on 32bit. The EFI stub (which can be used by either 64bit or 32bit U-Boot) can be compiled in either 32- or 64-bit code on x86. What we want is to disallow
EFI_LOADER && X86_64 && EFI_STUB_32BIT
as well as
EFI_LOADER && X86 && !X86_64 && EFI_STUB_64BIT
because in those 2 cases efi_api.h would need to get compiled differently for the stub and for the main U-Boot and nobody would know what the defines are supposed to be anymore.
They can be built together, but not with different bitnesses.
Alex
Alexander Graf
