[PATCH] x86: Don't build some unused objects in TPL
In the future if we have separate symbols for DM_SPI_FLASH and SPL_DM_SPI_FLASH we will not always have function declarations available for some DM calls. This in turn leads to build warnings but not failures as the code isn't used and is discarded at link time. Restructure things to not build code we won't use for TPL anyways.
Cc: Bin Meng bmeng.cn@gmail.com Signed-off-by: Tom Rini trini@konsulko.com --- I ran in to this as part of testing http://patchwork.ozlabs.org/project/uboot/patch/20200604151153.3980-4-Zhiqia... which we do need to bring in. I think we might be building a lot of codde that's then discarded for TPL builds, but didn't think this is the right place to tackle that in. --- arch/x86/cpu/apollolake/Makefile | 2 +- arch/x86/lib/Makefile | 4 +++- 2 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/arch/x86/cpu/apollolake/Makefile b/arch/x86/cpu/apollolake/Makefile index 3aa2a556765a..11621256aebc 100644 --- a/arch/x86/cpu/apollolake/Makefile +++ b/arch/x86/cpu/apollolake/Makefile @@ -3,7 +3,6 @@ # Copyright 2019 Google LLC
obj-$(CONFIG_SPL_BUILD) += cpu_spl.o -obj-$(CONFIG_SPL_BUILD) += spl.o obj-$(CONFIG_SPL_BUILD) += systemagent.o obj-y += cpu_common.o
@@ -12,6 +11,7 @@ obj-y += cpu.o obj-y += punit.o obj-y += fsp_bindings.o ifdef CONFIG_SPL_BUILD +obj-y += spl.o obj-y += fsp_m.o endif endif diff --git a/arch/x86/lib/Makefile b/arch/x86/lib/Makefile index 5cd458748038..1079bf20226a 100644 --- a/arch/x86/lib/Makefile +++ b/arch/x86/lib/Makefile @@ -22,7 +22,6 @@ obj-y += init_helpers.o obj-y += interrupts.o obj-y += lpc-uclass.o obj-y += mpspec.o -obj-$(CONFIG_ENABLE_MRC_CACHE) += mrccache.o obj-y += northbridge-uclass.o obj-$(CONFIG_I8259_PIC) += i8259.o obj-$(CONFIG_I8254_TIMER) += i8254.o @@ -45,9 +44,12 @@ ifndef CONFIG_SPL_BUILD obj-$(CONFIG_CMD_ZBOOT) += zimage.o endif obj-$(CONFIG_USE_HOB) += hob.o +ifndef CONFIG_TPL_BUILD +obj-$(CONFIG_ENABLE_MRC_CACHE) += mrccache.o obj-$(CONFIG_HAVE_FSP) += fsp/ obj-$(CONFIG_FSP_VERSION1) += fsp1/ obj-$(CONFIG_FSP_VERSION2) += fsp2/ +endif
ifdef CONFIG_SPL_BUILD ifdef CONFIG_TPL_BUILD
+Simon,
On Sat, 27 Jun 2020 at 07:10, Bin Meng bmeng.cn@gmail.com wrote:
+Simon,
Yes we build far too much with TPL at present I think.
Bin Meng
