[U-Boot] [PATCH] mx6sabresd: Remove non-SPL targets
Now that mx6sabresd_spl_defconfig can be used to boot all mx6sabresd variants, the non-SPL targets can be safely removed.
Signed-off-by: Fabio Estevam fabio.estvam@nxp.com --- This patch depends on my previous series where mx6dlsabresd SPL support has been added.
board/freescale/mx6sabresd/mx6dlsabresd.cfg | 131 ------------------ board/freescale/mx6sabresd/mx6q_4x_mt41j128.cfg | 169 ------------------------ configs/mx6dlsabresd_defconfig | 44 ------ configs/mx6qsabresd_defconfig | 44 ------ 4 files changed, 388 deletions(-) delete mode 100644 board/freescale/mx6sabresd/mx6dlsabresd.cfg delete mode 100644 board/freescale/mx6sabresd/mx6q_4x_mt41j128.cfg delete mode 100644 configs/mx6dlsabresd_defconfig delete mode 100644 configs/mx6qsabresd_defconfig
diff --git a/board/freescale/mx6sabresd/mx6dlsabresd.cfg b/board/freescale/mx6sabresd/mx6dlsabresd.cfg deleted file mode 100644 index be9f87f..0000000 --- a/board/freescale/mx6sabresd/mx6dlsabresd.cfg +++ /dev/null @@ -1,131 +0,0 @@ -/* - * Copyright (C) 2014 Freescale Semiconductor, Inc. - * - * SPDX-License-Identifier: GPL-2.0+ - * - * Refer doc/README.imximage for more details about how-to configure - * and create imximage boot image - * - * The syntax is taken as close as possible with the kwbimage - */ - -/* image version */ - -IMAGE_VERSION 2 - -/* - * Boot Device : one of - * spi, sd (the board has no nand neither onenand) - */ - -BOOT_FROM sd - -/* - * Device Configuration Data (DCD) - * - * Each entry must have the format: - * Addr-type Address Value - * - * where: - * Addr-type register length (1,2 or 4 bytes) - * Address absolute address of the register - * value value to be stored in the register - */ -DATA 4 0x020e0774 0x000C0000 -DATA 4 0x020e0754 0x00000000 -DATA 4 0x020e04ac 0x00000030 -DATA 4 0x020e04b0 0x00000030 -DATA 4 0x020e0464 0x00000030 -DATA 4 0x020e0490 0x00000030 -DATA 4 0x020e074c 0x00000030 -DATA 4 0x020e0494 0x00000030 -DATA 4 0x020e04a0 0x00000000 -DATA 4 0x020e04b4 0x00000030 -DATA 4 0x020e04b8 0x00000030 -DATA 4 0x020e076c 0x00000030 -DATA 4 0x020e0750 0x00020000 -DATA 4 0x020e04bc 0x00000030 -DATA 4 0x020e04c0 0x00000030 -DATA 4 0x020e04c4 0x00000030 -DATA 4 0x020e04c8 0x00000030 -DATA 4 0x020e04cc 0x00000030 -DATA 4 0x020e04d0 0x00000030 -DATA 4 0x020e04d4 0x00000030 -DATA 4 0x020e04d8 0x00000030 -DATA 4 0x020e0760 0x00020000 -DATA 4 0x020e0764 0x00000030 -DATA 4 0x020e0770 0x00000030 -DATA 4 0x020e0778 0x00000030 -DATA 4 0x020e077c 0x00000030 -DATA 4 0x020e0780 0x00000030 -DATA 4 0x020e0784 0x00000030 -DATA 4 0x020e078c 0x00000030 -DATA 4 0x020e0748 0x00000030 -DATA 4 0x020e0470 0x00000030 -DATA 4 0x020e0474 0x00000030 -DATA 4 0x020e0478 0x00000030 -DATA 4 0x020e047c 0x00000030 -DATA 4 0x020e0480 0x00000030 -DATA 4 0x020e0484 0x00000030 -DATA 4 0x020e0488 0x00000030 -DATA 4 0x020e048c 0x00000030 -DATA 4 0x021b0800 0xa1390003 -DATA 4 0x021b080c 0x001F001F -DATA 4 0x021b0810 0x001F001F -DATA 4 0x021b480c 0x001F001F -DATA 4 0x021b4810 0x001F001F -DATA 4 0x021b083c 0x4220021F -DATA 4 0x021b0840 0x0207017E -DATA 4 0x021b483c 0x4201020C -DATA 4 0x021b4840 0x01660172 -DATA 4 0x021b0848 0x4A4D4E4D -DATA 4 0x021b4848 0x4A4F5049 -DATA 4 0x021b0850 0x3F3C3D31 -DATA 4 0x021b4850 0x3238372B -DATA 4 0x021b081c 0x33333333 -DATA 4 0x021b0820 0x33333333 -DATA 4 0x021b0824 0x33333333 -DATA 4 0x021b0828 0x33333333 -DATA 4 0x021b481c 0x33333333 -DATA 4 0x021b4820 0x33333333 -DATA 4 0x021b4824 0x33333333 -DATA 4 0x021b4828 0x33333333 -DATA 4 0x021b08b8 0x00000800 -DATA 4 0x021b48b8 0x00000800 -DATA 4 0x021b0004 0x0002002D -DATA 4 0x021b0008 0x00333030 -DATA 4 0x021b000c 0x3F435313 -DATA 4 0x021b0010 0xB66E8B63 -DATA 4 0x021b0014 0x01FF00DB -DATA 4 0x021b0018 0x00001740 -DATA 4 0x021b001c 0x00008000 -DATA 4 0x021b002c 0x000026d2 -DATA 4 0x021b0030 0x00431023 -DATA 4 0x021b0040 0x00000027 -DATA 4 0x021b0000 0x831A0000 -DATA 4 0x021b001c 0x04008032 -DATA 4 0x021b001c 0x00008033 -DATA 4 0x021b001c 0x00048031 -DATA 4 0x021b001c 0x05208030 -DATA 4 0x021b001c 0x04008040 -DATA 4 0x021b0020 0x00005800 -DATA 4 0x021b0818 0x00011117 -DATA 4 0x021b4818 0x00011117 -DATA 4 0x021b0004 0x0002556D -DATA 4 0x021b0404 0x00011006 -DATA 4 0x021b001c 0x00000000 - -/* set the default clock gate to save power */ -DATA 4 0x020c4068 0x00C03F3F -DATA 4 0x020c406c 0x0030FC03 -DATA 4 0x020c4070 0x0FFFC000 -DATA 4 0x020c4074 0x3FF00000 -DATA 4 0x020c4078 0x00FFF300 -DATA 4 0x020c407c 0x0F0000C3 -DATA 4 0x020c4080 0x000003FF - -/* enable AXI cache for VDOA/VPU/IPU */ -DATA 4 0x020e0010 0xF00000CF -/* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ -DATA 4 0x020e0018 0x007F007F -DATA 4 0x020e001c 0x007F007F diff --git a/board/freescale/mx6sabresd/mx6q_4x_mt41j128.cfg b/board/freescale/mx6sabresd/mx6q_4x_mt41j128.cfg deleted file mode 100644 index bb6c60b..0000000 --- a/board/freescale/mx6sabresd/mx6q_4x_mt41j128.cfg +++ /dev/null @@ -1,169 +0,0 @@ -/* - * Copyright (C) 2011 Freescale Semiconductor, Inc. - * Jason Liu r64343@freescale.com - * - * SPDX-License-Identifier: GPL-2.0+ - * - * Refer doc/README.imximage for more details about how-to configure - * and create imximage boot image - * - * The syntax is taken as close as possible with the kwbimage - */ - -/* image version */ -IMAGE_VERSION 2 - -/* - * Boot Device : one of - * spi, sd (the board has no nand neither onenand) - */ -BOOT_FROM sd - -/* - * Device Configuration Data (DCD) - * - * Each entry must have the format: - * Addr-type Address Value - * - * where: - * Addr-type register length (1,2 or 4 bytes) - * Address absolute address of the register - * value value to be stored in the register - */ -DATA 4 0x020e05a8 0x00000030 -DATA 4 0x020e05b0 0x00000030 -DATA 4 0x020e0524 0x00000030 -DATA 4 0x020e051c 0x00000030 - -DATA 4 0x020e0518 0x00000030 -DATA 4 0x020e050c 0x00000030 -DATA 4 0x020e05b8 0x00000030 -DATA 4 0x020e05c0 0x00000030 - -DATA 4 0x020e05ac 0x00020030 -DATA 4 0x020e05b4 0x00020030 -DATA 4 0x020e0528 0x00020030 -DATA 4 0x020e0520 0x00020030 - -DATA 4 0x020e0514 0x00020030 -DATA 4 0x020e0510 0x00020030 -DATA 4 0x020e05bc 0x00020030 -DATA 4 0x020e05c4 0x00020030 - -DATA 4 0x020e056c 0x00020030 -DATA 4 0x020e0578 0x00020030 -DATA 4 0x020e0588 0x00020030 -DATA 4 0x020e0594 0x00020030 - -DATA 4 0x020e057c 0x00020030 -DATA 4 0x020e0590 0x00003000 -DATA 4 0x020e0598 0x00003000 -DATA 4 0x020e058c 0x00000000 - -DATA 4 0x020e059c 0x00003030 -DATA 4 0x020e05a0 0x00003030 -DATA 4 0x020e0784 0x00000030 -DATA 4 0x020e0788 0x00000030 - -DATA 4 0x020e0794 0x00000030 -DATA 4 0x020e079c 0x00000030 -DATA 4 0x020e07a0 0x00000030 -DATA 4 0x020e07a4 0x00000030 - -DATA 4 0x020e07a8 0x00000030 -DATA 4 0x020e0748 0x00000030 -DATA 4 0x020e074c 0x00000030 -DATA 4 0x020e0750 0x00020000 - -DATA 4 0x020e0758 0x00000000 -DATA 4 0x020e0774 0x00020000 -DATA 4 0x020e078c 0x00000030 -DATA 4 0x020e0798 0x000C0000 - -DATA 4 0x021b081c 0x33333333 -DATA 4 0x021b0820 0x33333333 -DATA 4 0x021b0824 0x33333333 -DATA 4 0x021b0828 0x33333333 - -DATA 4 0x021b481c 0x33333333 -DATA 4 0x021b4820 0x33333333 -DATA 4 0x021b4824 0x33333333 -DATA 4 0x021b4828 0x33333333 - -DATA 4 0x021b0018 0x00081740 - -DATA 4 0x021b001c 0x00008000 -DATA 4 0x021b000c 0x555A7974 -DATA 4 0x021b0010 0xDB538F64 -DATA 4 0x021b0014 0x01FF00DB -DATA 4 0x021b002c 0x000026D2 - -DATA 4 0x021b0030 0x005A1023 -DATA 4 0x021b0008 0x09444040 -DATA 4 0x021b0004 0x00025576 -DATA 4 0x021b0040 0x00000027 -DATA 4 0x021b0000 0x831A0000 - -DATA 4 0x021b001c 0x04088032 -DATA 4 0x021b001c 0x0408803A -DATA 4 0x021b001c 0x00008033 -DATA 4 0x021b001c 0x0000803B -DATA 4 0x021b001c 0x00428031 -DATA 4 0x021b001c 0x00428039 -DATA 4 0x021b001c 0x19308030 -DATA 4 0x021b001c 0x19308038 - -DATA 4 0x021b001c 0x04008040 -DATA 4 0x021b001c 0x04008048 -DATA 4 0x021b0800 0xA1380003 -DATA 4 0x021b4800 0xA1380003 -DATA 4 0x021b0020 0x00005800 -DATA 4 0x021b0818 0x00022227 -DATA 4 0x021b4818 0x00022227 - -DATA 4 0x021b083c 0x434B0350 -DATA 4 0x021b0840 0x034C0359 -DATA 4 0x021b483c 0x434B0350 -DATA 4 0x021b4840 0x03650348 -DATA 4 0x021b0848 0x4436383B -DATA 4 0x021b4848 0x39393341 -DATA 4 0x021b0850 0x35373933 -DATA 4 0x021b4850 0x48254A36 - -DATA 4 0x021b080c 0x001F001F -DATA 4 0x021b0810 0x001F001F - -DATA 4 0x021b480c 0x00440044 -DATA 4 0x021b4810 0x00440044 - -DATA 4 0x021b08b8 0x00000800 -DATA 4 0x021b48b8 0x00000800 - -DATA 4 0x021b001c 0x00000000 -DATA 4 0x021b0404 0x00011006 - -/* set the default clock gate to save power */ -DATA 4 0x020c4068 0x00C03F3F -DATA 4 0x020c406c 0x0030FC03 -DATA 4 0x020c4070 0x0FFFC000 -DATA 4 0x020c4074 0x3FF00000 -DATA 4 0x020c4078 0x00FFF300 -DATA 4 0x020c407c 0x0F0000C3 -DATA 4 0x020c4080 0x000003FF - -/* enable AXI cache for VDOA/VPU/IPU */ -DATA 4 0x020e0010 0xF00000CF -/* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ -DATA 4 0x020e0018 0x007F007F -DATA 4 0x020e001c 0x007F007F - -/* - * Setup CCM_CCOSR register as follows: - * - * cko1_en = 1 --> CKO1 enabled - * cko1_div = 111 --> divide by 8 - * cko1_sel = 1011 --> ahb_clk_root - * - * This sets CKO1 at ahb_clk_root/8 = 132/8 = 16.5 MHz - */ -DATA 4 0x020c4060 0x000000fb diff --git a/configs/mx6dlsabresd_defconfig b/configs/mx6dlsabresd_defconfig deleted file mode 100644 index 0254a53..0000000 --- a/configs/mx6dlsabresd_defconfig +++ /dev/null @@ -1,44 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_MX6=y -CONFIG_TARGET_MX6SABRESD=y -CONFIG_VIDEO=y -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6sabresd/mx6dlsabresd.cfg,MX6DL" -CONFIG_BOOTDELAY=3 -# CONFIG_CONSOLE_MUX is not set -CONFIG_SYS_CONSOLE_IS_IN_ENV=y -CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y -CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y -# CONFIG_CMD_IMLS is not set -# CONFIG_CMD_FLASH is not set -CONFIG_CMD_MMC=y -CONFIG_CMD_SF=y -CONFIG_CMD_I2C=y -CONFIG_CMD_USB=y -CONFIG_CMD_DFU=y -CONFIG_CMD_USB_MASS_STORAGE=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_DFU_MMC=y -CONFIG_DFU_SF=y -CONFIG_SPI_FLASH=y -CONFIG_SPI_FLASH_STMICRO=y -CONFIG_PCI=y -CONFIG_USB=y -CONFIG_USB_STORAGE=y -CONFIG_USB_GADGET=y -CONFIG_CI_UDC=y -CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="FSL" -CONFIG_G_DNL_VENDOR_NUM=0x0525 -CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 -# CONFIG_VIDEO_SW_CURSOR is not set -CONFIG_OF_LIBFDT=y diff --git a/configs/mx6qsabresd_defconfig b/configs/mx6qsabresd_defconfig deleted file mode 100644 index cef7f1a..0000000 --- a/configs/mx6qsabresd_defconfig +++ /dev/null @@ -1,44 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_MX6=y -CONFIG_TARGET_MX6SABRESD=y -CONFIG_VIDEO=y -CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6sabresd/mx6q_4x_mt41j128.cfg,MX6Q" -CONFIG_BOOTDELAY=3 -# CONFIG_CONSOLE_MUX is not set -CONFIG_SYS_CONSOLE_IS_IN_ENV=y -CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE=y -CONFIG_HUSH_PARSER=y -CONFIG_CMD_BOOTZ=y -# CONFIG_CMD_IMLS is not set -# CONFIG_CMD_FLASH is not set -CONFIG_CMD_MMC=y -CONFIG_CMD_SF=y -CONFIG_CMD_I2C=y -CONFIG_CMD_USB=y -CONFIG_CMD_DFU=y -CONFIG_CMD_USB_MASS_STORAGE=y -CONFIG_CMD_GPIO=y -CONFIG_CMD_DHCP=y -CONFIG_CMD_MII=y -CONFIG_CMD_PING=y -CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_EXT4=y -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_FAT=y -CONFIG_CMD_FS_GENERIC=y -CONFIG_DFU_MMC=y -CONFIG_DFU_SF=y -CONFIG_SPI_FLASH=y -CONFIG_SPI_FLASH_STMICRO=y -CONFIG_PCI=y -CONFIG_USB=y -CONFIG_USB_STORAGE=y -CONFIG_USB_GADGET=y -CONFIG_CI_UDC=y -CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_G_DNL_MANUFACTURER="FSL" -CONFIG_G_DNL_VENDOR_NUM=0x0525 -CONFIG_G_DNL_PRODUCT_NUM=0xa4a5 -# CONFIG_VIDEO_SW_CURSOR is not set -CONFIG_OF_LIBFDT=y
Fabio Estevam
