[U-Boot-Users] [PATCH] Fix compiler warning in include/s3c2410.h
This patch fixes the "type qualifiers ignored on fuction return tpye" warning for include/s3c2410.h
Signed-off-by: Martin Krause martin.krause@tqs.de --- I sent this patch already some month ago to the list (March or so). Peter Pearse has it on his internal list with a "under consideration" status since then. But because Wolfgang Denk asked to help clean up build errors after the merge window has closed, I decided to send this patch again (not least, because Peter seems to be on vacation now).
include/s3c2410.h | 36 ++++++++++++++++++------------------ 1 files changed, 18 insertions(+), 18 deletions(-)
diff --git a/include/s3c2410.h b/include/s3c2410.h index 86495f6..87135b4 100644 --- a/include/s3c2410.h +++ b/include/s3c2410.h @@ -69,75 +69,75 @@ typedef enum { #include <s3c24x0.h>
-static inline S3C24X0_MEMCTL * const S3C24X0_GetBase_MEMCTL(void) +static inline S3C24X0_MEMCTL * S3C24X0_GetBase_MEMCTL(void) { return (S3C24X0_MEMCTL * const)S3C24X0_MEMCTL_BASE; } -static inline S3C24X0_USB_HOST * const S3C24X0_GetBase_USB_HOST(void) +static inline S3C24X0_USB_HOST * S3C24X0_GetBase_USB_HOST(void) { return (S3C24X0_USB_HOST * const)S3C24X0_USB_HOST_BASE; } -static inline S3C24X0_INTERRUPT * const S3C24X0_GetBase_INTERRUPT(void) +static inline S3C24X0_INTERRUPT * S3C24X0_GetBase_INTERRUPT(void) { return (S3C24X0_INTERRUPT * const)S3C24X0_INTERRUPT_BASE; } -static inline S3C24X0_DMAS * const S3C24X0_GetBase_DMAS(void) +static inline S3C24X0_DMAS * S3C24X0_GetBase_DMAS(void) { return (S3C24X0_DMAS * const)S3C24X0_DMA_BASE; } -static inline S3C24X0_CLOCK_POWER * const S3C24X0_GetBase_CLOCK_POWER(void) +static inline S3C24X0_CLOCK_POWER * S3C24X0_GetBase_CLOCK_POWER(void) { return (S3C24X0_CLOCK_POWER * const)S3C24X0_CLOCK_POWER_BASE; } -static inline S3C24X0_LCD * const S3C24X0_GetBase_LCD(void) +static inline S3C24X0_LCD * S3C24X0_GetBase_LCD(void) { return (S3C24X0_LCD * const)S3C24X0_LCD_BASE; } -static inline S3C2410_NAND * const S3C2410_GetBase_NAND(void) +static inline S3C2410_NAND * S3C2410_GetBase_NAND(void) { return (S3C2410_NAND * const)S3C2410_NAND_BASE; } -static inline S3C24X0_UART * const S3C24X0_GetBase_UART(S3C24X0_UARTS_NR nr) +static inline S3C24X0_UART * S3C24X0_GetBase_UART(S3C24X0_UARTS_NR nr) { return (S3C24X0_UART * const)(S3C24X0_UART_BASE + (nr * 0x4000)); } -static inline S3C24X0_TIMERS * const S3C24X0_GetBase_TIMERS(void) +static inline S3C24X0_TIMERS * S3C24X0_GetBase_TIMERS(void) { return (S3C24X0_TIMERS * const)S3C24X0_TIMER_BASE; } -static inline S3C24X0_USB_DEVICE * const S3C24X0_GetBase_USB_DEVICE(void) +static inline S3C24X0_USB_DEVICE * S3C24X0_GetBase_USB_DEVICE(void) { return (S3C24X0_USB_DEVICE * const)S3C24X0_USB_DEVICE_BASE; } -static inline S3C24X0_WATCHDOG * const S3C24X0_GetBase_WATCHDOG(void) +static inline S3C24X0_WATCHDOG * S3C24X0_GetBase_WATCHDOG(void) { return (S3C24X0_WATCHDOG * const)S3C24X0_WATCHDOG_BASE; } -static inline S3C24X0_I2C * const S3C24X0_GetBase_I2C(void) +static inline S3C24X0_I2C * S3C24X0_GetBase_I2C(void) { return (S3C24X0_I2C * const)S3C24X0_I2C_BASE; } -static inline S3C24X0_I2S * const S3C24X0_GetBase_I2S(void) +static inline S3C24X0_I2S * S3C24X0_GetBase_I2S(void) { return (S3C24X0_I2S * const)S3C24X0_I2S_BASE; } -static inline S3C24X0_GPIO * const S3C24X0_GetBase_GPIO(void) +static inline S3C24X0_GPIO * S3C24X0_GetBase_GPIO(void) { return (S3C24X0_GPIO * const)S3C24X0_GPIO_BASE; } -static inline S3C24X0_RTC * const S3C24X0_GetBase_RTC(void) +static inline S3C24X0_RTC * S3C24X0_GetBase_RTC(void) { return (S3C24X0_RTC * const)S3C24X0_RTC_BASE; } -static inline S3C2410_ADC * const S3C2410_GetBase_ADC(void) +static inline S3C2410_ADC * S3C2410_GetBase_ADC(void) { return (S3C2410_ADC * const)S3C2410_ADC_BASE; } -static inline S3C24X0_SPI * const S3C24X0_GetBase_SPI(void) +static inline S3C24X0_SPI * S3C24X0_GetBase_SPI(void) { return (S3C24X0_SPI * const)S3C24X0_SPI_BASE; } -static inline S3C2410_SDI * const S3C2410_GetBase_SDI(void) +static inline S3C2410_SDI * S3C2410_GetBase_SDI(void) { return (S3C2410_SDI * const)S3C2410_SDI_BASE; }
Applied. Thanks. -- Hope this is OK, Peter!
Martin Krause
