[U-Boot] Problem with SD card and ext2ls
I have an SD card with an ext2 partition and I am trying to access it through ext2ls command but this is what I get:
# ext2ls mmc 0:1 / ** Bad partition - mmc 0:1 **
I have read some previous mails of some people complaining about a similar problem: http://www.mail-archive.com/u-boot@lists.denx.de/msg12776.html
Here also Wolfgang Denk says that ext2 is currently broken in u-boot for newer ext2 images.
Is this still true or has it been fixed since then?
Thank you.
Also if I issue a "mmc rescan 0" I get the following:
# mmc rescan 0 # ext2ls mmc 0:1 / get partition info called raise: Signal # 8 caught raise: Signal # 8 caught raise: Signal # 8 caught
What could be happening here?
Thank you.
Looking deeply in the list I found someone that had the same problem with an AT91: http://www.mail-archive.com/u-boot@lists.denx.de/msg23442.html
I submit here all useful information about my case.
Board: imx27lite Toolchains: eldk-4.2 GIT commit: f67066b6b0740b826ed862615c5ab022aaf4779a SD card formatted in ext2 with gparted.
How to reproduce:
=> mmc rescan 0 => ext2ls mmc 0:1 / <2, 0, 204> ext2fs read inode 2 ext2fs read 0 group descriptor (blkno 2 blkoff 0) <4, 0, 32> raise: Signal # 8 caught ext2fs read inode blkno 0 blkoff 0 raise: Signal # 8 caught raise: Signal # 8 caught ext2fs read inode blkno 6 blkoff 0 <12, 0, 128>
Dear javier Martin,
In message eedb5540911200403r5a4dfb8el7fd73965f33a7c4f@mail.gmail.com you wrote:
Sorry, the batteries of my crystal ball are running low...
It _might_ help if you provided a _little_ information, at least the most vital pieces like which architecture / board you are speaking of, and which exact version (which git commit id) you are running.
Please see my last mail. I sent three mails without reply and maybe this lead to some confusion, sorry. In that, my previous mail, you have all the information: Board, SD card, how to reproduce...
Thank you.
Dear javier Martin,
In message eedb5540911230109k9b3b6f7ibc261b6f6f4c838f@mail.gmail.com you wrote:
Found it, indeed. Thanks.
Dear javier Martin,
In message eedb5540911200347t5f11bdcat9206e2d9f1a7f971@mail.gmail.com you wrote:
Well, that was a long, long time ago. And the problem reported there (and fixed since) was about newer (bigger) inode sizes - this has nothing to do with "Bad partition" errors.
The problems referred to in the posting you quote have long been fixed.
Hello,
I rather would say it is broken for rev 0, i.e. old ext2 images and images generated with genext2fs
I just posted a patch: [PATCH] EXT2FS: fix inode size for ext2fs rev#0.
Michael.
javier Martin
Michael Brandt
