[GIT PULL] xilinx patches for v2023.10-rc1
Hi Tom,
please pull these patches for next version. CI didn't show any issue on previous base but I see a lot of times that 32bit arm builds are failing because of 1h limit.
I had to rebase the branch based on latest master branch and hope that this won't be an issue for you. Please let me know if you want me something to change.
The biggest change is that s/u-boot/U-Boot replacement which touches a lot of files.
Thanks, Michal
The following changes since commit addd47379df54a3eb247c6db4f799f14af43e523:
Merge https://source.denx.de/u-boot/custodians/u-boot-usb (2023-06-08 18:23:06 -0400)
git@source.denx.de:u-boot/custodians/u-boot-microblaze.git tags/xilinx-for-v2023.10-rc1
for you to fetch changes up to 89240bc0c44b985e461a4220475cb462263df5be:
arm64: versal: Add missing prototypes (2023-06-12 13:25:02 +0200)
---------------------------------------------------------------- Xilinx changes for v2023.10-rc1
global: - Use proper U-Boot project name
Fix sparse warnings in zynqmp-clk, zynqmp handoff, board
cmd: - Cover incorrect 0 length entries
Versal NET: - Add bootmode logic - Support SPP production version - Add loadpdi command
ZynqMP: - Clear pmufw node command ID handling - Change power domain behavior around zynqmp_pmufw_node() - Fix zynqmp cmd return values and pmufw command - Fix R5 tcm init and modes
mmc: - Sync Versal NET emmc DT binding
pcie: - Add support for ZynqMP PCIe root port
video: - Add support for ZynqMP DP
tools: - Fix debug message in relocate-rela
---------------------------------------------------------------- Algapally Santosh Sagar (6): clk: zynqmp: Add fallthrough statement in the switch case mach-zynqmp: handoff: Add missing header xilinx: versal-net: Add new versalnet loadpdi command board: xilinx: Add missing prototypes arm64: versal: Add missing prototype for initialize_tcm arm64: versal: Add missing prototypes
Ashok Reddy Soma (2): arm64: versal-net: Detect and display bootmode cmd: sf/nand: Print and return failure when 0 length is passed
Marek Vasut (1): tools: relocate-rela: Fix typo
Michal Simek (10): arm64: versal-net: Add support for SPP production version mmc: zynq: Sync with upstream DT binding global: Use proper project name U-Boot arm64: zynqmp: Check 0 node ID video: Add support for RGBA8888 format video: bmp: Support rgba8888 pixel format video: zynqmp: Enable 1024x768 resolution arm64: zynqmp: Fix command error values properly arm64: zynqmp: Fix return code from do_zynqmp_pmufw() firmware: zynqmp: Extend debug message to show parameters
Stefan Herbrechtsmeier (5): firmware: zynqmp: Remove extraordinary return value firmware: zynqmp: Remove redundant child device bind power: zynqmp: Mask node already configured error firmware: zynqmp: Move permission to change config object message firmware: zynqmp: Store driver data in data section
Stefan Roese (1): PCI: zynqmp: Add ZynqMP NWL PCIe root port driver
Venkatesh Yadav Abbarapu (5): video: move zynqmp files to subdirectory video: zynqmp: Driver for Xilinx ZynqMP DisplayPort Subsystem xilinx: zynqmp: Enable the vidconsole by default arm64: zynqmp: Fix tcminit mode param arm64: zynqmp: Fix lockstep mode cpu release functionality
MAINTAINERS | 2 + arch/Kconfig.nxp | 2 +- arch/arc/include/asm/io.h | 2 +- arch/arm/cpu/armv7/Kconfig | 2 +- arch/arm/cpu/armv8/Kconfig | 2 +- arch/arm/cpu/armv8/fsl-layerscape/doc/README.lsch3 | 2 +- arch/arm/dts/fsl-ls1028a.dtsi | 2 +- arch/arm/dts/meson-g12-common-u-boot.dtsi | 2 +- arch/arm/dts/meson-gx-u-boot.dtsi | 2 +- arch/arm/dts/rk3328-evb-u-boot.dtsi | 2 +- arch/arm/dts/rk3328.dtsi | 2 +- arch/arm/include/asm/arch-fsl-layerscape/stream_id_lsch2.h | 2 +- arch/arm/include/asm/arch-fsl-layerscape/stream_id_lsch3.h | 2 +- arch/arm/mach-versal-net/include/mach/hardware.h | 22 + arch/arm/mach-versal/include/mach/sys_proto.h | 1 + arch/arm/mach-versal/mp.c | 8 +- arch/arm/mach-zynqmp/handoff.c | 1 + arch/arm/mach-zynqmp/mp.c | 4 + board/bosch/acc/acc.c | 2 +- board/bosch/shc/README | 2 +- board/compulab/cl-som-imx7/cl-som-imx7.c | 2 +- board/hisilicon/poplar/README | 2 +- board/isee/igep003x/board.c | 2 +- board/isee/igep00x0/igep00x0.c | 2 +- board/keymile/Kconfig | 8 +- board/keymile/README | 2 +- board/kontron/sl-mx6ul/spl.c | 2 +- board/phytec/pcm058/README | 18 +- board/synopsys/hsdk/hsdk.c | 14 +- board/xilinx/common/board.h | 7 + board/xilinx/versal-net/Kconfig | 8 + board/xilinx/versal-net/Makefile | 1 + board/xilinx/versal-net/board.c | 149 +- board/xilinx/versal-net/cmds.c | 81 + board/xilinx/zynqmp/cmds.c | 26 +- boot/boot_fit.c | 2 +- cmd/legacy-mtd-utils.c | 5 + cmd/sf.c | 5 + cmd/ufs.c | 2 +- common/spl/spl.c | 2 +- common/spl/spl_mmc.c | 2 +- doc/README.pcap | 2 +- doc/README.s5p4418 | 2 +- doc/SPL/README.spl-secure-boot | 4 +- doc/board/amlogic/p201.rst | 2 +- doc/board/amlogic/p212.rst | 2 +- doc/board/amlogic/s400.rst | 2 +- doc/board/emulation/qemu-arm.rst | 2 +- doc/board/nxp/ls1046ardb.rst | 2 +- doc/board/nxp/mx6sabresd.rst | 2 +- doc/board/rockchip/rockchip.rst | 6 +- doc/board/sifive/unmatched.rst | 2 +- doc/board/st/stm32mp1.rst | 2 +- doc/board/xen/xenguest_arm64.rst | 10 +- doc/develop/driver-model/bind.rst | 2 +- doc/develop/driver-model/fs_firmware_loader.rst | 6 +- doc/develop/uefi/uefi.rst | 2 +- doc/usage/cmd/source.rst | 2 +- doc/usage/dfu.rst | 2 +- drivers/clk/clk-mux.c | 2 +- drivers/clk/clk_zynqmp.c | 1 + drivers/firmware/firmware-zynqmp.c | 48 +- drivers/gpio/gpio-fxl6408.c | 2 +- drivers/mmc/zynq_sdhci.c | 10 +- drivers/mtd/nand/raw/Kconfig | 6 +- drivers/mtd/nand/raw/fsl_ifc_spl.c | 4 +- drivers/net/pfe_eth/pfe_hw.c | 2 +- drivers/pci/Kconfig | 7 + drivers/pci/Makefile | 1 + drivers/pci/pcie-xilinx-nwl.c | 352 ++++ drivers/phy/marvell/comphy_cp110.c | 2 +- drivers/power/domain/zynqmp-power-domain.c | 11 +- drivers/spi/spi-qup.c | 2 +- drivers/video/Kconfig | 9 +- drivers/video/Makefile | 2 +- drivers/video/video-uclass.c | 10 +- drivers/video/video_bmp.c | 36 + drivers/video/zynqmp/Kconfig | 8 + drivers/video/zynqmp/Makefile | 5 + drivers/video/zynqmp/zynqmp_dpsub.c | 2225 ++++++++++++++++++++ drivers/video/zynqmp/zynqmp_dpsub.h | 680 ++++++ drivers/video/zynqmp_dpsub.c | 66 - dts/Kconfig | 4 +- fs/btrfs/compat.h | 2 +- fs/btrfs/extent-io.h | 2 +- include/configs/xilinx_zynqmp.h | 3 + include/fsl_validate.h | 4 +- include/video.h | 1 + include/zynqmp_firmware.h | 2 +- test/py/tests/test_android/test_avb.py | 2 +- test/py/tests/test_cat/conftest.py | 2 +- test/py/tests/test_efi_bootmgr/conftest.py | 2 +- test/py/tests/test_efi_capsule/conftest.py | 2 +- test/py/tests/test_efi_secboot/conftest.py | 4 +- test/py/tests/test_eficonfig/conftest.py | 2 +- test/py/tests/test_fs/conftest.py | 12 +- test/py/tests/test_scp03.py | 2 +- test/py/tests/test_xxd/conftest.py | 2 +- tools/relocate-rela.c | 2 +- 99 files changed, 3767 insertions(+), 236 deletions(-) create mode 100644 board/xilinx/versal-net/cmds.c create mode 100644 drivers/pci/pcie-xilinx-nwl.c create mode 100644 drivers/video/zynqmp/Kconfig create mode 100644 drivers/video/zynqmp/Makefile create mode 100644 drivers/video/zynqmp/zynqmp_dpsub.c create mode 100644 drivers/video/zynqmp/zynqmp_dpsub.h delete mode 100644 drivers/video/zynqmp_dpsub.c
On Mon, Jun 12, 2023 at 07:30:38PM +0200, Michal Simek wrote:
Hi Tom,
Note that this is a per-project setting, so I can't change the defaults for everyone. But, you can bump this up under General pipelines portion of CI/CD settings.
I don't like that exactly, but since I needed to do -rc4 today anyhow, I've merged that in first.
Thanks, Michal
Michal Simek
