[PATCH 1/2] efi_loader: Implement FileLoad2 for initramfs loading
Following kernel's proposal for an arch-agnostic initrd loading mechanism [1] let's implement the U-boot counterpart. This new approach has a number of advantages compared to what we did up to now. The file is loaded into memory only when requested limiting the area of TOCTOU attacks. Users will be allowed to place the initramfs file on any u-boot accessible partition instead of just the ESP one. Finally this is an attempt of a generic interface across architectures in the linux kernel so it makes sense to support that.
The file location is intentionally only supported as a config option argument(CONFIG_EFI_INITRD_FILESPEC), in an effort to enhance security. Although U-boot is not responsible for verifying the integrity of the initramfs, we can enhance the offered security by only accepting a built-in option, which will be naturally verified by UEFI Secure Boot. This can easily change in the future if needed and configure that via ENV or UEFI variable.
[1] https://lore.kernel.org/linux-efi/20200207202637.GA3464906@rani.riverdale.la...
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- cmd/efidebug.c | 4 + include/efi_api.h | 17 +++ include/efi_load_initrd.h | 25 ++++ include/efi_loader.h | 1 + lib/efi_loader/Kconfig | 15 +++ lib/efi_loader/Makefile | 1 + lib/efi_loader/efi_load_initrd.c | 198 +++++++++++++++++++++++++++++++ lib/efi_loader/efi_setup.c | 5 + 8 files changed, 266 insertions(+) create mode 100644 include/efi_load_initrd.h create mode 100644 lib/efi_loader/efi_load_initrd.c
diff --git a/cmd/efidebug.c b/cmd/efidebug.c index 576e95b395dc..f450518c9e83 100644 --- a/cmd/efidebug.c +++ b/cmd/efidebug.c @@ -264,6 +264,10 @@ static const struct { "SMBIOS table", SMBIOS_TABLE_GUID, }, + { + "Load File2", + EFI_LOAD_FILE2_PROTOCOL_GUID, + }, };
/** diff --git a/include/efi_api.h b/include/efi_api.h index 22396172e15f..8ffed1334b84 100644 --- a/include/efi_api.h +++ b/include/efi_api.h @@ -319,6 +319,14 @@ struct efi_runtime_services { EFI_GUID(0xeb9d2d31, 0x2d88, 0x11d3, \ 0x9a, 0x16, 0x00, 0x90, 0x27, 0x3f, 0xc1, 0x4d)
+#define EFI_LOAD_FILE_PROTOCOL_GUID \ + EFI_GUID(0x56ec3091, 0x954c, 0x11d2, \ + 0x8e, 0x3f, 0x00, 0xa0, 0xc9, 0x69, 0x72, 0x3b) + +#define EFI_LOAD_FILE2_PROTOCOL_GUID \ + EFI_GUID(0x4006c0c1, 0xfcb3, 0x403e, \ + 0x99, 0x6d, 0x4a, 0x6c, 0x87, 0x24, 0xe0, 0x6d) + struct efi_configuration_table { efi_guid_t guid; void *table; @@ -474,6 +482,7 @@ struct efi_device_path_nvme { #define DEVICE_PATH_TYPE_MEDIA_DEVICE 0x04 # define DEVICE_PATH_SUB_TYPE_HARD_DRIVE_PATH 0x01 # define DEVICE_PATH_SUB_TYPE_CDROM_PATH 0x02 +# define DEVICE_PATH_SUB_TYPE_VENDOR_PATH 0x03 # define DEVICE_PATH_SUB_TYPE_FILE_PATH 0x04
struct efi_device_path_hard_drive_path { @@ -1607,6 +1616,14 @@ struct efi_unicode_collation_protocol { char *supported_languages; };
+struct efi_load_file_protocol { + efi_status_t (EFIAPI *load_file)(struct efi_load_file_protocol *this, + struct efi_device_path *file_path, + bool boot_policy, + efi_uintn_t *buffer_size, + void *buffer); +}; + /* Boot manager load options */ #define LOAD_OPTION_ACTIVE 0x00000001 #define LOAD_OPTION_FORCE_RECONNECT 0x00000002 diff --git a/include/efi_load_initrd.h b/include/efi_load_initrd.h new file mode 100644 index 000000000000..478ae807c685 --- /dev/null +++ b/include/efi_load_initrd.h @@ -0,0 +1,25 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) 2020, Linaro Limited + */ + +#if !defined _EFI_LOAD_INITRD_H_ +#define _EFI_LOAD_INITRD_H_ + +#include <efi.h> +#include <efi_api.h> + +/* + * Vendor GUID used by Linux to identify the handle with the + * EFI_LOAD_FILE2_PROTOCOL and load an initial ramdisk. + */ +#define EFI_INITRD_MEDIA_GUID \ + EFI_GUID(0x5568e427, 0x68fc, 0x4f3d, \ + 0xac, 0x74, 0xca, 0x55, 0x52, 0x31, 0xcc, 0x68) + +struct efi_initrd_dp { + struct efi_device_path_vendor vendor; + struct efi_device_path end; +} __packed; + +#endif diff --git a/include/efi_loader.h b/include/efi_loader.h index d4c59b54c48b..8e3437983391 100644 --- a/include/efi_loader.h +++ b/include/efi_loader.h @@ -378,6 +378,7 @@ efi_status_t efi_gop_register(void); efi_status_t efi_net_register(void); /* Called by bootefi to make the watchdog available */ efi_status_t efi_watchdog_register(void); +efi_status_t efi_initrd_register(void); /* Called by bootefi to make SMBIOS tables available */ /** * efi_acpi_register() - write out ACPI tables diff --git a/lib/efi_loader/Kconfig b/lib/efi_loader/Kconfig index a7afa3f29e88..50d4f81e6207 100644 --- a/lib/efi_loader/Kconfig +++ b/lib/efi_loader/Kconfig @@ -130,4 +130,19 @@ config EFI_RNG_PROTOCOL "Support for EFI_RNG_PROTOCOL implementation. Uses the rng device on the platform"
+config EFI_LOAD_FILE2_INITRD + bool "EFI_FILE_LOAD2_PROTOCOL for Linux initial ramdisk" + default n + help + Expose a EFI_FILE_LOAD2_PROTOCOL that the Linux UEFI stub can + use to load the initial ramdisk. Once this is enabled using + initrd=<ramdisk> will stop working. + +config EFI_INITRD_FILESPEC + string "initramfs path" + default "host 0:1 initrd" + depends on EFI_LOAD_FILE2_INITRD + help + Full path of the initramfs file, e.g. mmc 0:2 initramfs.cpio.gz. + endif diff --git a/lib/efi_loader/Makefile b/lib/efi_loader/Makefile index 04dc8648512b..9b3b70447336 100644 --- a/lib/efi_loader/Makefile +++ b/lib/efi_loader/Makefile @@ -43,3 +43,4 @@ obj-$(CONFIG_NET) += efi_net.o obj-$(CONFIG_GENERATE_ACPI_TABLE) += efi_acpi.o obj-$(CONFIG_GENERATE_SMBIOS_TABLE) += efi_smbios.o obj-$(CONFIG_EFI_RNG_PROTOCOL) += efi_rng.o +obj-$(CONFIG_EFI_LOAD_FILE2_INITRD) += efi_load_initrd.o diff --git a/lib/efi_loader/efi_load_initrd.c b/lib/efi_loader/efi_load_initrd.c new file mode 100644 index 000000000000..574a83d7e308 --- /dev/null +++ b/lib/efi_loader/efi_load_initrd.c @@ -0,0 +1,198 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2020, Linaro Limited + */ + +#include <common.h> +#include <env.h> +#include <malloc.h> +#include <mapmem.h> +#include <dm.h> +#include <fs.h> +#include <efi_loader.h> +#include <efi_load_initrd.h> + +static const efi_guid_t efi_guid_load_file2_protocol = + EFI_LOAD_FILE2_PROTOCOL_GUID; + +static efi_status_t EFIAPI +efi_load_file2_initrd(struct efi_load_file_protocol *this, + struct efi_device_path *file_path, bool boot_policy, + efi_uintn_t *buffer_size, void *buffer); + +static const struct efi_load_file_protocol efi_lf2_protocol = { + .load_file = efi_load_file2_initrd, +}; + +/* + * Device path defined by Linux to identify the handle providing the + * EFI_LOAD_FILE2_PROTOCOL used for loading the initial ramdisk. + */ +static const struct efi_initrd_dp dp = { + .vendor = { + { + DEVICE_PATH_TYPE_MEDIA_DEVICE, + DEVICE_PATH_SUB_TYPE_VENDOR_PATH, + sizeof(dp.vendor), + }, + EFI_INITRD_MEDIA_GUID, + }, + .end = { + DEVICE_PATH_TYPE_END, + DEVICE_PATH_SUB_TYPE_END, + sizeof(dp.end), + } +}; + +/** + * get_file_size() - retrieve the size of initramfs, set efi status on error + * + * @dev: device to read from. i.e "mmc" + * @part: device partition. i.e "0:1" + * @file: name fo file + * @status: EFI exit code in case of failure + * + * Return: size of file + */ +static loff_t get_file_size(const char *dev, const char *part, const char *file, + efi_status_t *status) +{ + loff_t sz = 0; + int ret; + + ret = fs_set_blk_dev(dev, part, FS_TYPE_ANY); + if (ret) { + *status = EFI_NO_MEDIA; + goto out; + } + + ret = fs_size(file, &sz); + if (ret) { + sz = 0; + *status = EFI_NOT_FOUND; + goto out; + } + +out: + return sz; +} + +/** + * load_file2() - get information about random number generation + * + * This function implement the LoadFile2() service in order to load an initram + * disk requested by the Linux kernel stub. + * See the UEFI spec for details. + * + * @this: loadfile2 protocol instance + * @file_path: relative path of the file. "" in this case + * @boot_policy: must be false for Loadfile2 + * @buffer_size: size of allocated buffer + * @buffer: buffer to load the file + * + * Return: status code + */ +static efi_status_t EFIAPI +efi_load_file2_initrd(struct efi_load_file_protocol *this, + struct efi_device_path *file_path, bool boot_policy, + efi_uintn_t *buffer_size, void *buffer) +{ + const char *filespec = CONFIG_EFI_INITRD_FILESPEC; + efi_status_t status = EFI_NOT_FOUND; + loff_t file_sz = 0, read_sz = 0; + char *dev, *part, *file; + char *s; + int ret; + + EFI_ENTRY("%p, %p, %d, %p, %p", this, file_path, boot_policy, + buffer_size, buffer); + + s = strdup(filespec); + if (!s) + goto out; + + if (!this || this != &efi_lf2_protocol || + !buffer_size) { + status = EFI_INVALID_PARAMETER; + goto out; + } + + if (file_path->type != dp.end.type || + file_path->sub_type != dp.end.sub_type) { + status = EFI_INVALID_PARAMETER; + goto out; + } + + if (boot_policy) { + status = EFI_UNSUPPORTED; + goto out; + } + + /* expect something like 'mmc 0:1 initrd.cpio.gz' */ + dev = strsep(&s, " "); + if (!dev) + goto out; + part = strsep(&s, " "); + if (!part) + goto out; + file = strsep(&s, " "); + if (!file) + goto out; + + file_sz = get_file_size(dev, part, file, &status); + if (!file_sz) + goto out; + + if (!buffer || *buffer_size < file_sz) { + status = EFI_BUFFER_TOO_SMALL; + *buffer_size = file_sz; + } else { + ret = fs_set_blk_dev(dev, part, FS_TYPE_ANY); + if (ret) { + status = EFI_NO_MEDIA; + goto out; + } + + ret = fs_read(file, map_to_sysmem(buffer), 0, *buffer_size, + &read_sz); + if (ret || read_sz != file_sz) + goto out; + *buffer_size = read_sz; + + status = EFI_SUCCESS; + } + +out: + free(s); + return EFI_EXIT(status); +} + +/** + * efi_initrd_register() - Register a handle and loadfile2 protocol + * + * This function creates a new handle and installs a linux specific GUID + * to handle initram disk loading during boot. + * See the UEFI spec for details. + * + * Return: status code + */ +efi_status_t efi_initrd_register(void) +{ + efi_handle_t efi_initrd_handle = NULL; + efi_status_t ret; + + /* + * Set up the handle with the EFI_LOAD_FILE2_PROTOCOL which Linux may + * use to load the initial ramdisk. + */ + ret = EFI_CALL(efi_install_multiple_protocol_interfaces + (&efi_initrd_handle, + /* initramfs */ + &efi_guid_device_path, &dp, + /* LOAD_FILE2 */ + &efi_guid_load_file2_protocol, + (void *)&efi_lf2_protocol, + NULL)); + + return ret; +} diff --git a/lib/efi_loader/efi_setup.c b/lib/efi_loader/efi_setup.c index de7b616c6daa..f03685b11559 100644 --- a/lib/efi_loader/efi_setup.c +++ b/lib/efi_loader/efi_setup.c @@ -155,6 +155,11 @@ efi_status_t efi_init_obj_list(void) if (ret != EFI_SUCCESS) goto out; #endif +#ifdef CONFIG_EFI_LOAD_FILE2_INITRD + ret = efi_initrd_register(); + if (ret != EFI_SUCCESS) + goto out; +#endif #ifdef CONFIG_NET ret = efi_net_register(); if (ret != EFI_SUCCESS)
Provide a unit test loading an initial ramdisk using the EFI_LOAD_FILE2_PROTOCOL. The test is only executed on request.
An example usage - given a file image with a file system in partition 1 holding file initrd - is:
* Configure the sandbox with
CONFIG_EFI_SELFTEST=y CONFIG_EFI_LOAD_FILE2_INITRD=y CONFIG_EFI_INITRD_FILESPEC="host 0:1 initrd"
* Run ./u-boot and execute
host bind 0 image setenv efi_selftest load initrd bootefi selftest
This would provide a test output like:
Testing EFI API implementation
Selected test: 'load initrd'
Setting up 'load initrd' Setting up 'load initrd' succeeded
Executing 'load initrd' Loaded 12378613 bytes CRC32 2997478465 Executing 'load initrd' succeeded
Now the size and CRC32 can be compared to the provided file.
Signed-off-by: Ilias Apalodimas ilias.apalodimas@linaro.org Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/efi_selftest/Makefile | 1 + lib/efi_selftest/efi_selftest_load_initrd.c | 220 ++++++++++++++++++++ 2 files changed, 221 insertions(+) create mode 100644 lib/efi_selftest/efi_selftest_load_initrd.c
diff --git a/lib/efi_selftest/Makefile b/lib/efi_selftest/Makefile index 3ad96e1cbf08..cf132c372e17 100644 --- a/lib/efi_selftest/Makefile +++ b/lib/efi_selftest/Makefile @@ -49,6 +49,7 @@ obj-$(CONFIG_CPU_V7) += efi_selftest_unaligned.o obj-$(CONFIG_EFI_LOADER_HII) += efi_selftest_hii.o obj-$(CONFIG_EFI_RNG_PROTOCOL) += efi_selftest_rng.o obj-$(CONFIG_EFI_GET_TIME) += efi_selftest_rtc.o +obj-$(CONFIG_EFI_LOAD_FILE2_INITRD) += efi_selftest_load_initrd.o
ifeq ($(CONFIG_GENERATE_ACPI_TABLE),) obj-y += efi_selftest_fdt.o diff --git a/lib/efi_selftest/efi_selftest_load_initrd.c b/lib/efi_selftest/efi_selftest_load_initrd.c new file mode 100644 index 000000000000..e16163caca85 --- /dev/null +++ b/lib/efi_selftest/efi_selftest_load_initrd.c @@ -0,0 +1,220 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * efi_selftest_load_initrd + * + * Copyright (c) 2020 Ilias Apalodimas ilias.apalodimas@linaro.org + * + * This test checks the FileLoad2 protocol. + * A known file is read from the file system and verified. + * + * An example usage - given a file image with a file system in partition 1 + * holding file initrd - is: + * + * * Configure the sandbox with + * + * CONFIG_EFI_SELFTEST=y + * CONFIG_EFI_LOAD_FILE2_INITRD=y + * CONFIG_EFI_INITRD_FILESPEC="host 0:1 initrd" + * + * * Run ./u-boot and execute + * + * host bind 0 image + * setenv efi_selftest load initrd + * bootefi selftest + * + * This would provide a test output like: + * + * Testing EFI API implementation + * + * Selected test: 'load initrd' + * + * Setting up 'load initrd' + * Setting up 'load initrd' succeeded + * + * Executing 'load initrd' + * Loaded 12378613 bytes + * CRC32 2997478465 + * + * Now the size and CRC32 can be compared to the provided file. + */ + +#include <efi_selftest.h> +#include <efi_loader.h> +#include <efi_load_initrd.h> + +static struct efi_boot_services *boottime; + +static struct efi_initrd_dp dp = { + .vendor = { + { + DEVICE_PATH_TYPE_MEDIA_DEVICE, + DEVICE_PATH_SUB_TYPE_VENDOR_PATH, + sizeof(dp.vendor), + }, + EFI_INITRD_MEDIA_GUID, + }, + .end = { + DEVICE_PATH_TYPE_END, + DEVICE_PATH_SUB_TYPE_END, + sizeof(dp.end), + } +}; + +static struct efi_initrd_dp dp_invalid = { + .vendor = { + { + DEVICE_PATH_TYPE_MEDIA_DEVICE, + DEVICE_PATH_SUB_TYPE_VENDOR_PATH, + sizeof(dp.vendor), + }, + EFI_INITRD_MEDIA_GUID, + }, + .end = { + 0x8f, /* invalid */ + 0xfe, /* invalid */ + sizeof(dp.end), + } +}; + +static int setup(const efi_handle_t handle, + const struct efi_system_table *systable) +{ + boottime = systable->boottime; + + return EFI_ST_SUCCESS; +} + +static int execute(void) +{ + efi_guid_t lf2_proto_guid = EFI_LOAD_FILE2_PROTOCOL_GUID; + struct efi_load_file_protocol *lf2; + struct efi_device_path *dp2, *dp2_invalid; + efi_status_t status; + efi_handle_t handle; + char buffer[64]; + efi_uintn_t buffer_size; + void *buf; + u32 crc32; + + memset(buffer, 0, sizeof(buffer)); + + dp2 = (struct efi_device_path *)&dp; + status = boottime->locate_device_path(&lf2_proto_guid, &dp2, &handle); + if (status != EFI_SUCCESS) { + efi_st_error("Unable to locate device path\n"); + return EFI_ST_FAILURE; + } + + status = boottime->handle_protocol(handle, &lf2_proto_guid, + (void **)&lf2); + if (status != EFI_SUCCESS) { + efi_st_error("Unable to locate protocol\n"); + return EFI_ST_FAILURE; + } + + /* Case 1: + * buffer_size can't be NULL + * protocol can't be NULL + */ + status = lf2->load_file(lf2, dp2, false, NULL, &buffer); + if (status != EFI_INVALID_PARAMETER) { + efi_st_error("Buffer size can't be NULL\n"); + return EFI_ST_FAILURE; + } + buffer_size = sizeof(buffer); + status = lf2->load_file(NULL, dp2, false, &buffer_size, &buffer); + if (status != EFI_INVALID_PARAMETER) { + efi_st_error("Protocol can't be NULL\n"); + return EFI_ST_FAILURE; + } + + /* + * Case 2: Match end node type/sub-type on device path + */ + dp2_invalid = (struct efi_device_path *)&dp_invalid; + buffer_size = sizeof(buffer); + status = lf2->load_file(lf2, dp2_invalid, false, &buffer_size, &buffer); + if (status != EFI_INVALID_PARAMETER) { + efi_st_error("Invalid device path type must return EFI_INVALID_PARAMETER\n"); + return EFI_ST_FAILURE; + } + + status = lf2->load_file(lf2, dp2_invalid, false, &buffer_size, &buffer); + if (status != EFI_INVALID_PARAMETER) { + efi_st_error("Invalid device path sub-type must return EFI_INVALID_PARAMETER\n"); + return EFI_ST_FAILURE; + } + + /* + * Case 3: + * BootPolicy 'true' must return EFI_UNSUPPORTED + */ + buffer_size = sizeof(buffer); + status = lf2->load_file(lf2, dp2, true, &buffer_size, &buffer); + if (status != EFI_UNSUPPORTED) { + efi_st_error("BootPolicy true must return EFI_UNSUPPORTED\n"); + return EFI_ST_FAILURE; + } + + /* + * Case: Pass buffer size as zero, firmware must return + * EFI_BUFFER_TOO_SMALL and an appropriate size + */ + buffer_size = 0; + status = lf2->load_file(lf2, dp2, false, &buffer_size, NULL); + if (status != EFI_BUFFER_TOO_SMALL || !buffer_size) { + efi_st_printf("buffer_size: %u\n", (unsigned int)buffer_size); + efi_st_printf("status: %x\n", (unsigned int)status); + efi_st_error("Buffer size not updated\n"); + return EFI_ST_FAILURE; + } + + /* + * Case: Pass buffer size as smaller than the file_size, + * firmware must return * EFI_BUFFER_TOO_SMALL and an appropriate size + */ + buffer_size = 1; + status = lf2->load_file(lf2, dp2, false, &buffer_size, &buffer); + if (status != EFI_BUFFER_TOO_SMALL || buffer_size <= 1) { + efi_st_error("Buffer size not updated\n"); + return EFI_ST_FAILURE; + } + + status = boottime->allocate_pool(EFI_BOOT_SERVICES_DATA, buffer_size, + &buf); + if (status != EFI_SUCCESS) { + efi_st_error("Cannot allocate buffer\n"); + return EFI_ST_FAILURE; + } + + /* Case: Pass correct buffer, load the file and verify checksum*/ + status = lf2->load_file(lf2, dp2, false, &buffer_size, buf); + if (status != EFI_SUCCESS) { + efi_st_error("Loading initrd failed\n"); + return EFI_ST_FAILURE; + } + + efi_st_printf("Loaded %u bytes\n", (unsigned int)buffer_size); + status = boottime->calculate_crc32(buf, buffer_size, &crc32); + if (status != EFI_SUCCESS) { + efi_st_error("Could not determine CRC32\n"); + return EFI_ST_FAILURE; + } + efi_st_printf("CRC32 %u\n", (unsigned int)crc32); + + status = boottime->free_pool(buf); + if (status != EFI_SUCCESS) { + efi_st_error("Cannot free buffer\n"); + return EFI_ST_FAILURE; + } + + return EFI_ST_SUCCESS; +} + +EFI_UNIT_TEST(load_initrd) = { + .name = "load initrd", + .phase = EFI_EXECUTE_BEFORE_BOOTTIME_EXIT, + .setup = setup, + .execute = execute, + .on_request = true, +};
Ilias,
I haven't followed this thread.
What if we have several bootable images with different initrd required at the same time? For example, we may install ubuntu 16.04, 18.04 etc to the same device (and then boot one of them via grub).
Since the guid is unique, U-Boot doesn't have any measure to identify which initrd be exported via FILE2_PROTOCOL. In this sense, I don't think using a config option is a good idea in general.
"Load File2",
- EFI_GUID(0x56ec3091, 0x954c, 0x11d2, \
Do you need this definition?
- EFI_GUID(0x4006c0c1, 0xfcb3, 0x403e, \
- efi_status_t (EFIAPI *load_file)(struct efi_load_file_protocol *this,
bool boot_policy,
void *buffer);
It might be unlikely, but the file name should be more generic for potential enhancement.
- Copyright (c) 2020, Linaro Limited
- Vendor GUID used by Linux to identify the handle with the
- EFI_LOAD_FILE2_PROTOCOL and load an initial ramdisk.
- EFI_GUID(0x5568e427, 0x68fc, 0x4f3d, \
- struct efi_device_path_vendor vendor;
- struct efi_device_path end;
+} __packed;
- efi_acpi_register() - write out ACPI tables
- bool "EFI_FILE_LOAD2_PROTOCOL for Linux initial ramdisk"
- default n
- help
- string "initramfs path"
- default "host 0:1 initrd"
"host" interface makes sense only on sandbox, which will not be expected to be able to boot any linux kernel. So this default value is inappropriate anyway.
- depends on EFI_LOAD_FILE2_INITRD
- help
I'd prefer efi_file_initrd.c for similarity to efi_file.c, or more specifically efi_linux.c.
Do you need env.h and dm.h?
- .load_file = efi_load_file2_initrd,
- Device path defined by Linux to identify the handle providing the
- EFI_LOAD_FILE2_PROTOCOL used for loading the initial ramdisk.
- .vendor = {
sizeof(dp.vendor),
- .end = {
sizeof(dp.end),
- get_file_size() - retrieve the size of initramfs, set efi status on error
- @dev: device to read from. i.e "mmc"
- @part: device partition. i.e "0:1"
- @file: name fo file
- @status: EFI exit code in case of failure
- Return: size of file
- loff_t sz = 0;
- int ret;
- ret = fs_set_blk_dev(dev, part, FS_TYPE_ANY);
- if (ret) {
goto out;
- ret = fs_size(file, &sz);
- if (ret) {
sz = 0;
goto out;
+out:
- return sz;
- load_file2() - get information about random number generation
Please correct the message.
- This function implement the LoadFile2() service in order to load an initram
- disk requested by the Linux kernel stub.
- See the UEFI spec for details.
- @this: loadfile2 protocol instance
- @file_path: relative path of the file. "" in this case
- @boot_policy: must be false for Loadfile2
- @buffer_size: size of allocated buffer
- @buffer: buffer to load the file
- Return: status code
- const char *filespec = CONFIG_EFI_INITRD_FILESPEC;
- efi_status_t status = EFI_NOT_FOUND;
- loff_t file_sz = 0, read_sz = 0;
- char *dev, *part, *file;
- char *s;
- int ret;
- EFI_ENTRY("%p, %p, %d, %p, %p", this, file_path, boot_policy,
- s = strdup(filespec);
- if (!s)
goto out;
I think that we should return a better error code rather than NOT_FOUND.
- if (!this || this != &efi_lf2_protocol ||
Please use guidcmp() here.
!buffer_size) {
goto out;
- if (file_path->type != dp.end.type ||
goto out;
- if (boot_policy) {
goto out;
- /* expect something like 'mmc 0:1 initrd.cpio.gz' */
- dev = strsep(&s, " ");
- if (!dev)
goto out;
- part = strsep(&s, " ");
- if (!part)
goto out;
- file = strsep(&s, " ");
- if (!file)
goto out;
- file_sz = get_file_size(dev, part, file, &status);
- if (!file_sz)
goto out;
ditto.
- if (!buffer || *buffer_size < file_sz) {
- } else {
if (ret) {
goto out;
&read_sz);
goto out;
+out:
- free(s);
- return EFI_EXIT(status);
- efi_initrd_register() - Register a handle and loadfile2 protocol
- This function creates a new handle and installs a linux specific GUID
- to handle initram disk loading during boot.
- efi_handle_t efi_initrd_handle = NULL;
- efi_status_t ret;
- ret = EFI_CALL(efi_install_multiple_protocol_interfaces
/* initramfs */
/* LOAD_FILE2 */
NULL));
- return ret;
- ret = efi_initrd_register();
- if (ret != EFI_SUCCESS)
goto out;
+#endif #ifdef CONFIG_NET ret = efi_net_register(); if (ret != EFI_SUCCESS) -- 2.25.1
Akashi-san,
On Thu, Mar 12, 2020 at 02:28:45PM +0900, AKASHI Takahiro wrote:
Ilias,
Can't you concatenate multiple cpio archives for this? I haven't checked this personally but i remember distros doing it to add firmware files they need for example. It might not be ideal because you may need different user-space program versions or different versions of the same script(??) but the linux module loading part, of different kernel revisions, should be there.
I don't have any strong preference on this anyway hence my commit message, it's just another naive protection, since the user can always replace the initramfs using the same name and break out of this. I never needed multiple initrd files so I preferred the config option. If people need a config option it's easily extensible.
Not really it just felt weird adding LOAD_FILE2 without the LOAD_FILE definition.
--- /dev/null
This is defining a very specific GUID for initramfs that Linux consumes to load the file, I'd rather keep it as is.
@@ -0,0 +1,25 @@
Not really. The user *must* have an idea on what he is doing and this is the default config we need to run on the sandbox. So it serves both as an example and a defult config for the sandbox testing.
- help
I can send a patch renaming those but i think it's pointless. The filename describes exactly what's the intent imho.
No, I'll remove those.
- .vendor = {
sizeof(dp.vendor),
- .end = {
sizeof(dp.end),
- loff_t sz = 0;
- int ret;
- if (ret) {
goto out;
- if (ret) {
sz = 0;
goto out;
+out:
- return sz;
Ooops
- char *s;
- int ret;
- if (!s)
goto out;
Like? The spec has a specific set of returns codes you can use there, EFI_UNSUPPORTED EFI_INVALID_PARAMETER EFI_NO_MEDIA EFI_DEVICE_ERROR EFI_NO_RESPONSE EFI_NOT_FOUND EFI_ABORTED EFI_BUFFER_TOO_SMALL
Is there anything you like better?
Sure
!buffer_size) {
- if (!file_sz)
goto out;
ditto.
Sure
2.25.1
Regards /Ilias
On Thu, Mar 12, 2020 at 08:29:38AM +0200, Ilias Apalodimas wrote:
Akashi-san,
Ilias,
I wonder think why it is not a problem.
Can we assume that this is only the use of initrd?
How? I don't think it's trivial.
--- /dev/null
I didn't intent the guid, but a file name.
@@ -0,0 +1,25 @@
I don't think we can boot a linux kernel from U-Boot on sandbox.
- help
What if we will want to add another FILE2_PROTOCOL or linux-specifc hack? Now I believe that OS (or platform)-dependent implementation should go into a separate directory, like lib/efi_linux/... for clarification.
- .vendor = {
sizeof(dp.vendor),
- .end = {
sizeof(dp.end),
- loff_t sz = 0;
- int ret;
- if (ret) {
goto out;
- if (ret) {
sz = 0;
goto out;
+out:
- return sz;
Ooops
- char *s;
- int ret;
- if (!s)
goto out;
In most of all cases, OUT_OF_RESOURCES.
Thanks, -Takahiro Akashi
Sure
!buffer_size) {
- if (!file_sz)
goto out;
ditto.
Sure
2.25.1
Regards /Ilias
Akashi-san,
Ilias,
I never said it wasn't, on the contrary, i pointed out cases were concatenating cpio's might not be enough.
Of course not.
Parse an env variable and override the config option? Something like: setenv efi_initrd 'mmc 0:1 foo.cpio.gz' -> env_get("efi_initrd") wouldn't work?
--- /dev/null
Yes my response is for the file name. It serves a sole purpose, define the explicit GUID linux expects.
@@ -0,0 +1,25 @@
We run the sefltest though, which is replicating the Linux efi stub functionality.
- help
I am not against that, i just think the tons of comments are already enough. But i see the point in the long run, assuming we'll add enough OS-specific options to justify this.
If i am not reading the spec wrong you *can't* return that here and even if you could, the majority of error cases fail if the file was not found. Maybe apart from this: ret = fs_set_blk_dev(dev, part, FS_TYPE_ANY); if (ret) { status = EFI_NO_MEDIA; goto out; }
Thanks /Ilias
AKASHI Takahiro
Ilias Apalodimas
