[U-Boot] [PATCH] Wandboard: Add support for Wandboard quad
Add support for the Wandboard quad.
Signed-off-by: Tapani Utriainen tapani@technexion.com
--- boards.cfg | 1 + include/configs/wandboard.h | 2 ++ 2 files changed, 3 insertions(+)
diff --git a/boards.cfg b/boards.cfg index 31483d6..b907409 100644 --- a/boards.cfg +++ b/boards.cfg @@ -268,6 +268,7 @@ nitrogen6s arm armv7 nitrogen6x boundar nitrogen6s1g arm armv7 nitrogen6x boundary mx6 nitrogen6x:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s1g.cfg,MX6S,DDR_MB=1024 wandboard_dl arm armv7 wandboard - mx6 wandboard:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL,DDR_MB=1024 wandboard_solo arm armv7 wandboard - mx6 wandboard:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s.cfg,MX6S,DDR_MB=512 +wandboard_quad arm armv7 wandboard - mx6 wandboard:IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q2g.cfg,MX6Q,DDR_MB=2048 cm_t35 arm armv7 cm_t35 - omap3 omap3_overo arm armv7 overo - omap3 omap3_pandora arm armv7 pandora - omap3 diff --git a/include/configs/wandboard.h b/include/configs/wandboard.h index 120e3f6..cf22042 100644 --- a/include/configs/wandboard.h +++ b/include/configs/wandboard.h @@ -85,6 +85,8 @@ #define CONFIG_DEFAULT_FDT_FILE "imx6dl-wandboard.dtb" #elif defined(CONFIG_MX6S) #define CONFIG_DEFAULT_FDT_FILE "imx6s-wandboard.dtb" +#elif defined(CONFIG_MX6Q) +#define CONFIG_DEFAULT_FDT_FILE "imx6q-wandboard.dtb" #endif
#define CONFIG_EXTRA_ENV_SETTINGS \
Hi Tapani,
On Mon, May 27, 2013 at 1:13 AM, Tapani Utriainen tapani@technexion.com wrote:
It looks good.
Could you also add an entry for the quad version into the README file?
Regards,
Fabio Estevam
On Mon, 27 May 2013 07:22:42 -0300 Fabio Estevam festevam@gmail.com wrote:
Hi Tapani,
It looks good.
Regards,
Fabio Estevam
Fabio,
thank you, will do (resubmitting a v2).
//Tapani
On Mon, May 27, 2013 at 1:13 AM, Tapani Utriainen tapani@technexion.comwrote:
Please put quad, dl and solo in order. It is now dl, solo, quad.
omap3
omap3
omap3
Same here.
1.8.0.3 _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
On Mon, May 27, 2013 at 9:13 AM, Otavio Salvador otavio@ossystems.com.brwrote:
mx6
mx6
mx6
omap3
omap3
omap3
Same here.
I have sent two patches for adding the Boot Splash with Wandboard logo. Please take a look on them and if you agree please base on this to avoid conflicts.
(For easyness: http://patchwork.ozlabs.org/bundle/otavio/wandboard-20130527/ )
On Mon, 27 May 2013 13:56:30 -0300 Otavio Salvador otavio@ossystems.com.br wrote:
Otavio,
while I do agree with the work you are doing (HDMI bootlogo into mainline), and would not have minded to base my patches on top of yours. However, the patches you sent seem to have been NAK:ed. The v3 does not apply on top of 2013.04 (maybe I am basing on the wrong release!?).
So for now, I am basing the resubmission on the 2013.04 release.
regards,
//Tapani
On 28/05/2013 09:44, Tapani Utriainen wrote:
Hi Tapani,
Otavio,
regards,
Even if you are not constrained to take care of underlying patches (this can maybe discussed in this mailing list if it is strictly required, but of course it helps to avoid conflicts), it is not correct to stick with a release. Basis for development is TOT on git.denx.de/u-boot.git, or, for the i.MXes, git.denx.de/u-boot-imx.
Best regards, Stefano Babic
On Tue, May 28, 2013 at 4:44 AM, Tapani Utriainen tapani@technexion.comwrote:
(For easyness:
Otavio,
You must base on imx/master as this is the custodian tree for upcoming 2013.07 release.
Fabio Estevam
Otavio Salvador
Stefano Babic
Tapani Utriainen
