[PATCH 0/7] Align pio3 pinctrl node with Linux
The series adds support in the pinctrl driver and additional changes in the at91 DT to align the pio3 based pinctrl nodes in the u-boot DT with that of Linux
Balamanikandan Gunasundar (1): ARM: dts: at91: sam9x60: Define pinctrl node with its label
Manikandan Muralidharan (6): ARM: dts: at91: sam9x60: Add AIC node ARM: dts: at91: sam9x60: Move pinmux node to board DTS ARM: dts: at91: sam9x60: Add missing pinctrl node properties pinctrl: at91: Bind GPIO driver to the pinctrl DT node pinctrl: at91: Add support to align with Linux Devicetree ARM: dts: at91: Align pinctrl node with Linux Devicetree
arch/arm/dts/at91-sam9x60_curiosity.dts | 71 ++++++++ arch/arm/dts/at91sam9260.dtsi | 76 ++++----- arch/arm/dts/at91sam9261.dtsi | 77 +++++---- arch/arm/dts/at91sam9263.dtsi | 117 +++++++------ arch/arm/dts/at91sam9g45.dtsi | 106 ++++++------ arch/arm/dts/at91sam9n12.dtsi | 93 +++++------ arch/arm/dts/at91sam9rl.dtsi | 93 +++++------ arch/arm/dts/at91sam9x5.dtsi | 90 +++++----- arch/arm/dts/sam9x60.dtsi | 149 +++++++---------- arch/arm/dts/sam9x60ek.dts | 209 ++++++++++++++++-------- arch/arm/dts/sama5d3.dtsi | 116 +++++++------ arch/arm/dts/sama5d4.dtsi | 118 +++++++------ drivers/pinctrl/pinctrl-at91.c | 40 ++++- 13 files changed, 720 insertions(+), 635 deletions(-)
Add Advanced Interrupt Controller node and define it as interrupt parent in sam9x60 SoC DT.
Signed-off-by: Manikandan Muralidharan manikandan.m@microchip.com --- arch/arm/dts/sam9x60.dtsi | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/arch/arm/dts/sam9x60.dtsi b/arch/arm/dts/sam9x60.dtsi index 3b684fc63d5..fdc3ad0fdcb 100644 --- a/arch/arm/dts/sam9x60.dtsi +++ b/arch/arm/dts/sam9x60.dtsi @@ -17,6 +17,7 @@ /{ model = "Microchip SAM9X60 SoC"; compatible = "microchip,sam9x60"; + interrupt-parent = <&aic>;
aliases { serial0 = &dbgu; @@ -199,6 +200,14 @@ reg = <0xffffea00 0x100>; };
+ aic: interrupt-controller@fffff100 { + compatible = "microchip,sam9x60-aic"; + reg = <0xfffff100 0x100>; + #interrupt-cells = <3>; + interrupt-controller; + atmel,external-irqs = <31>; + }; + dbgu: serial@fffff200 { compatible = "atmel,at91sam9260-dbgu", "atmel,at91sam9260-usart"; reg = <0xfffff200 0x200>;
Reg property is placed below interrupt-controller in Linux, can you make it identical please ?
From: Balamanikandan Gunasundar balamanikandan.gunasundar@microchip.com
Define the pinctrl nodes with its label and sort its child node alphabetically to align wit the Linux DT.Without this change those pinctrl nodes are grouped under an additional 'pinctrl' child node that is not identified by the pinctrl driver when the GPIO banks are made as child nodes of pinctrl node.
Signed-off-by: Balamanikandan Gunasundar balamanikandan.gunasundar@microchip.com Signed-off-by: Manikandan Muralidharan manikandan.m@microchip.com --- arch/arm/dts/sam9x60ek.dts | 138 ++++++++++++++++++------------------- 1 file changed, 69 insertions(+), 69 deletions(-)
diff --git a/arch/arm/dts/sam9x60ek.dts b/arch/arm/dts/sam9x60ek.dts index 74016f5e288..d8d7ad38b2b 100644 --- a/arch/arm/dts/sam9x60ek.dts +++ b/arch/arm/dts/sam9x60ek.dts @@ -78,75 +78,6 @@ }; }; }; - - pinctrl { - nand { - pinctrl_nand_oe_we: nand-oe-we-0 { - atmel,pins = - <AT91_PIOD 0 AT91_PERIPH_A (AT91_PINCTRL_NONE | AT91_PINCTRL_SLEWRATE_DIS) - AT91_PIOD 1 AT91_PERIPH_A (AT91_PINCTRL_NONE | AT91_PINCTRL_SLEWRATE_DIS)>; - }; - - pinctrl_nand_rb: nand-rb-0 { - atmel,pins = - <AT91_PIOD 5 AT91_PERIPH_GPIO AT91_PINCTRL_PULL_UP>; - }; - - pinctrl_nand_cs: nand-cs-0 { - atmel,pins = - <AT91_PIOD 4 AT91_PERIPH_GPIO AT91_PINCTRL_PULL_UP>; - }; - }; - - ebi { - pinctrl_ebi_data_0_7: ebi-data-lsb-0 { - atmel,pins = - <AT91_PIOD 6 AT91_PERIPH_A (AT91_PINCTRL_NONE | AT91_PINCTRL_SLEWRATE_DIS) - AT91_PIOD 7 AT91_PERIPH_A (AT91_PINCTRL_NONE | AT91_PINCTRL_SLEWRATE_DIS) - AT91_PIOD 8 AT91_PERIPH_A (AT91_PINCTRL_NONE | AT91_PINCTRL_SLEWRATE_DIS) - AT91_PIOD 9 AT91_PERIPH_A (AT91_PINCTRL_NONE | AT91_PINCTRL_SLEWRATE_DIS) - AT91_PIOD 10 AT91_PERIPH_A (AT91_PINCTRL_NONE | AT91_PINCTRL_SLEWRATE_DIS) - AT91_PIOD 11 AT91_PERIPH_A (AT91_PINCTRL_NONE | AT91_PINCTRL_SLEWRATE_DIS) - AT91_PIOD 12 AT91_PERIPH_A (AT91_PINCTRL_NONE | AT91_PINCTRL_SLEWRATE_DIS) - AT91_PIOD 13 AT91_PERIPH_A (AT91_PINCTRL_NONE | AT91_PINCTRL_SLEWRATE_DIS)>; - }; - - pinctrl_ebi_addr_nand: ebi-addr-0 { - atmel,pins = - <AT91_PIOD 2 AT91_PERIPH_A (AT91_PINCTRL_NONE | AT91_PINCTRL_SLEWRATE_DIS) - AT91_PIOD 3 AT91_PERIPH_A (AT91_PINCTRL_NONE | AT91_PINCTRL_SLEWRATE_DIS)>; - }; - }; - - pinctrl_qspi: qspi { - atmel,pins = - <AT91_PIOB 19 AT91_PERIPH_A AT91_PINCTRL_NONE - AT91_PIOB 20 AT91_PERIPH_A AT91_PINCTRL_NONE - AT91_PIOB 21 AT91_PERIPH_A AT91_PINCTRL_PULL_UP - AT91_PIOB 22 AT91_PERIPH_A AT91_PINCTRL_PULL_UP - AT91_PIOB 23 AT91_PERIPH_A AT91_PINCTRL_PULL_UP - AT91_PIOB 24 AT91_PERIPH_A AT91_PINCTRL_PULL_UP>; - }; - - pinctrl_flx0: flx0_default { - atmel,pins = - <AT91_PIOA 0 AT91_PERIPH_A AT91_PINCTRL_NONE - AT91_PIOA 1 AT91_PERIPH_A AT91_PINCTRL_NONE>; - }; - - pinctrl_onewire_tm_default: onewire_tm_default { - atmel,pins = - <AT91_PIOD 14 AT91_PERIPH_GPIO AT91_PINCTRL_PULL_UP>; - }; - - usb1 { - pinctrl_usb_default: usb_default { - atmel,pins = <AT91_PIOD 15 AT91_PERIPH_GPIO AT91_PINCTRL_NONE - AT91_PIOD 16 AT91_PERIPH_GPIO AT91_PINCTRL_NONE>; - }; - }; - - }; }; }; }; @@ -221,6 +152,75 @@ status = "okay"; };
+&pinctrl { + /* shared pinctrl settings */ + ebi { + pinctrl_ebi_data_0_7: ebi-data-lsb-0 { + atmel,pins = + <AT91_PIOD 6 AT91_PERIPH_A (AT91_PINCTRL_NONE | AT91_PINCTRL_SLEWRATE_DIS) + AT91_PIOD 7 AT91_PERIPH_A (AT91_PINCTRL_NONE | AT91_PINCTRL_SLEWRATE_DIS) + AT91_PIOD 8 AT91_PERIPH_A (AT91_PINCTRL_NONE | AT91_PINCTRL_SLEWRATE_DIS) + AT91_PIOD 9 AT91_PERIPH_A (AT91_PINCTRL_NONE | AT91_PINCTRL_SLEWRATE_DIS) + AT91_PIOD 10 AT91_PERIPH_A (AT91_PINCTRL_NONE | AT91_PINCTRL_SLEWRATE_DIS) + AT91_PIOD 11 AT91_PERIPH_A (AT91_PINCTRL_NONE | AT91_PINCTRL_SLEWRATE_DIS) + AT91_PIOD 12 AT91_PERIPH_A (AT91_PINCTRL_NONE | AT91_PINCTRL_SLEWRATE_DIS) + AT91_PIOD 13 AT91_PERIPH_A (AT91_PINCTRL_NONE | AT91_PINCTRL_SLEWRATE_DIS)>; + }; + + pinctrl_ebi_addr_nand: ebi-addr-0 { + atmel,pins = + <AT91_PIOD 2 AT91_PERIPH_A (AT91_PINCTRL_NONE | AT91_PINCTRL_SLEWRATE_DIS) + AT91_PIOD 3 AT91_PERIPH_A (AT91_PINCTRL_NONE | AT91_PINCTRL_SLEWRATE_DIS)>; + }; + }; + + nand { + pinctrl_nand_oe_we: nand-oe-we-0 { + atmel,pins = + <AT91_PIOD 0 AT91_PERIPH_A (AT91_PINCTRL_NONE | AT91_PINCTRL_SLEWRATE_DIS) + AT91_PIOD 1 AT91_PERIPH_A (AT91_PINCTRL_NONE | AT91_PINCTRL_SLEWRATE_DIS)>; + }; + + pinctrl_nand_rb: nand-rb-0 { + atmel,pins = + <AT91_PIOD 5 AT91_PERIPH_GPIO AT91_PINCTRL_PULL_UP>; + }; + + pinctrl_nand_cs: nand-cs-0 { + atmel,pins = + <AT91_PIOD 4 AT91_PERIPH_GPIO AT91_PINCTRL_PULL_UP>; + }; + }; + + pinctrl_flx0: flx0_default { + atmel,pins = + <AT91_PIOA 0 AT91_PERIPH_A AT91_PINCTRL_NONE + AT91_PIOA 1 AT91_PERIPH_A AT91_PINCTRL_NONE>; + }; + + pinctrl_onewire_tm_default: onewire_tm_default { + atmel,pins = + <AT91_PIOD 14 AT91_PERIPH_GPIO AT91_PINCTRL_PULL_UP>; + }; + + pinctrl_qspi: qspi { + atmel,pins = + <AT91_PIOB 19 AT91_PERIPH_A AT91_PINCTRL_NONE + AT91_PIOB 20 AT91_PERIPH_A AT91_PINCTRL_NONE + AT91_PIOB 21 AT91_PERIPH_A AT91_PINCTRL_PULL_UP + AT91_PIOB 22 AT91_PERIPH_A AT91_PINCTRL_PULL_UP + AT91_PIOB 23 AT91_PERIPH_A AT91_PINCTRL_PULL_UP + AT91_PIOB 24 AT91_PERIPH_A AT91_PINCTRL_PULL_UP>; + }; + + usb1 { + pinctrl_usb_default: usb_default { + atmel,pins = <AT91_PIOD 15 AT91_PERIPH_GPIO AT91_PINCTRL_NONE + AT91_PIOD 16 AT91_PERIPH_GPIO AT91_PINCTRL_NONE>; + }; + }; +}; + &usb1 { num-ports = <3>; atmel,vbus-gpio = <0
Typo: wit
Please align them as they are aligned in Linux, or, patch Linux DT first.
pinctrl {
nand {
atmel,pins =
atmel,pins =
atmel,pins =
ebi {
atmel,pins =
atmel,pins =
atmel,pins =
atmel,pins =
atmel,pins =
usb1 {
+&pinctrl {
- /* shared pinctrl settings */
- ebi {
atmel,pins =
atmel,pins =
- nand {
atmel,pins =
atmel,pins =
atmel,pins =
I see in Linux nand is before ebi or am I wrong ?
atmel,pins =
atmel,pins =
atmel,pins =
- usb1 {
Move pinmux nodes defined under the pinctrl node from sam9x60 SoC DT to its board specific DTS files.
Signed-off-by: Manikandan Muralidharan manikandan.m@microchip.com --- arch/arm/dts/at91-sam9x60_curiosity.dts | 71 +++++++++++++++++++++++++ arch/arm/dts/sam9x60.dtsi | 63 ---------------------- arch/arm/dts/sam9x60ek.dts | 71 +++++++++++++++++++++++++ 3 files changed, 142 insertions(+), 63 deletions(-)
diff --git a/arch/arm/dts/at91-sam9x60_curiosity.dts b/arch/arm/dts/at91-sam9x60_curiosity.dts index 99867d2bf8e..7f00014f13c 100644 --- a/arch/arm/dts/at91-sam9x60_curiosity.dts +++ b/arch/arm/dts/at91-sam9x60_curiosity.dts @@ -82,6 +82,11 @@ }; };
+&dbgu { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_dbgu>; +}; + &ebi { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_ebi_addr_nand &pinctrl_ebi_data_0_7>; @@ -171,10 +176,20 @@
&macb0 { phy-mode = "rmii"; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_macb0_rmii>; status = "okay"; };
&pinctrl { + dbgu { + pinctrl_dbgu: dbgu-0 { + atmel,pins = + <AT91_PIOA 9 AT91_PERIPH_A AT91_PINCTRL_PULL_UP + AT91_PIOA 10 AT91_PERIPH_A AT91_PINCTRL_NONE>; + }; + }; + ebi { pinctrl_ebi_data_0_7: ebi-data-lsb-0 { atmel,pins = @@ -217,6 +232,22 @@ }; };
+ macb0 { + pinctrl_macb0_rmii: macb0_rmii-0 { + atmel,pins = + <AT91_PIOB 0 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB0 periph A */ + AT91_PIOB 1 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB1 periph A */ + AT91_PIOB 2 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB2 periph A */ + AT91_PIOB 3 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB3 periph A */ + AT91_PIOB 4 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB4 periph A */ + AT91_PIOB 5 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB5 periph A */ + AT91_PIOB 6 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB6 periph A */ + AT91_PIOB 7 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB7 periph A */ + AT91_PIOB 9 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB9 periph A */ + AT91_PIOB 10 AT91_PERIPH_A AT91_PINCTRL_NONE>; /* PB10 periph A */ + }; + }; + nand { pinctrl_nand_oe_we: nand-oe-we-0 { atmel,pins = @@ -240,6 +271,36 @@ <AT91_PIOD 14 AT91_PERIPH_GPIO AT91_PINCTRL_PULL_UP>; };
+ sdhci0 { + pinctrl_sdhci0: sdhci0 { + atmel,pins = + <AT91_PIOA 17 AT91_PERIPH_A + (AT91_PINCTRL_DRIVE_STRENGTH_HI | AT91_PINCTRL_SLEWRATE_ENA) /* PA17 CK periph A with pullup */ + AT91_PIOA 16 AT91_PERIPH_A + (AT91_PINCTRL_PULL_UP | AT91_PINCTRL_DRIVE_STRENGTH_HI | AT91_PINCTRL_SLEWRATE_ENA) /* PA16 CMD periph A with pullup */ + AT91_PIOA 15 AT91_PERIPH_A + (AT91_PINCTRL_PULL_UP | AT91_PINCTRL_DRIVE_STRENGTH_HI | AT91_PINCTRL_SLEWRATE_ENA) /* PA15 DAT0 periph A */ + AT91_PIOA 18 AT91_PERIPH_A + (AT91_PINCTRL_PULL_UP | AT91_PINCTRL_DRIVE_STRENGTH_HI | AT91_PINCTRL_SLEWRATE_ENA) /* PA18 DAT1 periph A with pullup */ + AT91_PIOA 19 AT91_PERIPH_A + (AT91_PINCTRL_PULL_UP | AT91_PINCTRL_DRIVE_STRENGTH_HI | AT91_PINCTRL_SLEWRATE_ENA) /* PA19 DAT2 periph A with pullup */ + AT91_PIOA 20 AT91_PERIPH_A + (AT91_PINCTRL_PULL_UP | AT91_PINCTRL_DRIVE_STRENGTH_HI | AT91_PINCTRL_SLEWRATE_ENA)>; /* PA20 DAT3 periph A with pullup */ + }; + }; + + sdhci1 { + pinctrl_sdhci1: sdhci1 { + atmel,pins = + <AT91_PIOA 13 AT91_PERIPH_B (AT91_PINCTRL_DRIVE_STRENGTH_HI) /* PA13 CK periph B */ + AT91_PIOA 12 AT91_PERIPH_B (AT91_PINCTRL_PULL_UP | AT91_PINCTRL_DRIVE_STRENGTH_HI) /* PA12 CMD periph B with pullup */ + AT91_PIOA 11 AT91_PERIPH_B (AT91_PINCTRL_PULL_UP | AT91_PINCTRL_DRIVE_STRENGTH_HI) /* PA11 DAT0 periph B with pullup */ + AT91_PIOA 2 AT91_PERIPH_B (AT91_PINCTRL_PULL_UP | AT91_PINCTRL_DRIVE_STRENGTH_HI) /* PA2 DAT1 periph B with pullup */ + AT91_PIOA 3 AT91_PERIPH_B (AT91_PINCTRL_PULL_UP | AT91_PINCTRL_DRIVE_STRENGTH_HI) /* PA3 DAT2 periph B with pullup */ + AT91_PIOA 4 AT91_PERIPH_B (AT91_PINCTRL_PULL_UP | AT91_PINCTRL_DRIVE_STRENGTH_HI)>; /* PA4 DAT3 periph B with pullup */ + }; + }; + usb1 { pinctrl_usb_default: usb_default { atmel,pins = <AT91_PIOD 15 AT91_PERIPH_GPIO AT91_PINCTRL_NONE @@ -248,6 +309,16 @@ }; };
+&sdhci0 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_sdhci0>; +}; + +&sdhci1 { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_sdhci1>; +}; + &usb1 { num-ports = <3>; atmel,vbus-gpio = <0 diff --git a/arch/arm/dts/sam9x60.dtsi b/arch/arm/dts/sam9x60.dtsi index fdc3ad0fdcb..47b65d0ef56 100644 --- a/arch/arm/dts/sam9x60.dtsi +++ b/arch/arm/dts/sam9x60.dtsi @@ -123,8 +123,6 @@ assigned-clock-rates = <100000000>; assigned-clock-parents = <&pmc PMC_TYPE_CORE 10>; /* ID_PLL_A_DIV */ bus-width = <4>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_sdhci0>; };
sdhci1: sdhci-host@90000000 { @@ -136,8 +134,6 @@ assigned-clock-rates = <100000000>; assigned-clock-parents = <&pmc PMC_TYPE_CORE 10>; /* ID_PLL_A_DIV */ bus-width = <4>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_sdhci1>; };
apb { @@ -177,8 +173,6 @@ macb0: ethernet@f802c000 { compatible = "cdns,sam9x60-macb", "cdns,macb"; reg = <0xf802c000 0x100>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_macb0_rmii>; clock-names = "hclk", "pclk"; clocks = <&pmc PMC_TYPE_PERIPHERAL 24>, <&pmc PMC_TYPE_PERIPHERAL 24>; status = "disabled"; @@ -211,8 +205,6 @@ dbgu: serial@fffff200 { compatible = "atmel,at91sam9260-dbgu", "atmel,at91sam9260-usart"; reg = <0xfffff200 0x200>; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_dbgu>; clocks = <&pmc PMC_TYPE_PERIPHERAL 47>; clock-names = "usart"; }; @@ -226,61 +218,6 @@ 0xfffff600 0x200 /* pioB */ 0xfffff800 0x200 /* pioC */ 0xfffffa00 0x200>; /* pioD */ - - /* shared pinctrl settings */ - dbgu { - pinctrl_dbgu: dbgu-0 { - atmel,pins = - <AT91_PIOA 9 AT91_PERIPH_A AT91_PINCTRL_PULL_UP - AT91_PIOA 10 AT91_PERIPH_A AT91_PINCTRL_NONE>; - }; - }; - - macb0 { - pinctrl_macb0_rmii: macb0_rmii-0 { - atmel,pins = - <AT91_PIOB 0 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB0 periph A */ - AT91_PIOB 1 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB1 periph A */ - AT91_PIOB 2 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB2 periph A */ - AT91_PIOB 3 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB3 periph A */ - AT91_PIOB 4 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB4 periph A */ - AT91_PIOB 5 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB5 periph A */ - AT91_PIOB 6 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB6 periph A */ - AT91_PIOB 7 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB7 periph A */ - AT91_PIOB 9 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB9 periph A */ - AT91_PIOB 10 AT91_PERIPH_A AT91_PINCTRL_NONE>; /* PB10 periph A */ - }; - }; - - sdhci0 { - pinctrl_sdhci0: sdhci0 { - atmel,pins = - <AT91_PIOA 17 AT91_PERIPH_A - (AT91_PINCTRL_DRIVE_STRENGTH_HI | AT91_PINCTRL_SLEWRATE_ENA) /* PA17 CK periph A with pullup */ - AT91_PIOA 16 AT91_PERIPH_A - (AT91_PINCTRL_PULL_UP | AT91_PINCTRL_DRIVE_STRENGTH_HI | AT91_PINCTRL_SLEWRATE_ENA) /* PA16 CMD periph A with pullup */ - AT91_PIOA 15 AT91_PERIPH_A - (AT91_PINCTRL_PULL_UP | AT91_PINCTRL_DRIVE_STRENGTH_HI | AT91_PINCTRL_SLEWRATE_ENA) /* PA15 DAT0 periph A */ - AT91_PIOA 18 AT91_PERIPH_A - (AT91_PINCTRL_PULL_UP | AT91_PINCTRL_DRIVE_STRENGTH_HI | AT91_PINCTRL_SLEWRATE_ENA) /* PA18 DAT1 periph A with pullup */ - AT91_PIOA 19 AT91_PERIPH_A - (AT91_PINCTRL_PULL_UP | AT91_PINCTRL_DRIVE_STRENGTH_HI | AT91_PINCTRL_SLEWRATE_ENA) /* PA19 DAT2 periph A with pullup */ - AT91_PIOA 20 AT91_PERIPH_A - (AT91_PINCTRL_PULL_UP | AT91_PINCTRL_DRIVE_STRENGTH_HI | AT91_PINCTRL_SLEWRATE_ENA)>; /* PA20 DAT3 periph A with pullup */ - }; - }; - - sdhci1 { - pinctrl_sdhci1: sdhci1 { - atmel,pins = - <AT91_PIOA 13 AT91_PERIPH_B (AT91_PINCTRL_DRIVE_STRENGTH_HI) /* PA13 CK periph B */ - AT91_PIOA 12 AT91_PERIPH_B (AT91_PINCTRL_PULL_UP | AT91_PINCTRL_DRIVE_STRENGTH_HI) /* PA12 CMD periph B with pullup */ - AT91_PIOA 11 AT91_PERIPH_B (AT91_PINCTRL_PULL_UP | AT91_PINCTRL_DRIVE_STRENGTH_HI) /* PA11 DAT0 periph B with pullup */ - AT91_PIOA 2 AT91_PERIPH_B (AT91_PINCTRL_PULL_UP | AT91_PINCTRL_DRIVE_STRENGTH_HI) /* PA2 DAT1 periph B with pullup */ - AT91_PIOA 3 AT91_PERIPH_B (AT91_PINCTRL_PULL_UP | AT91_PINCTRL_DRIVE_STRENGTH_HI) /* PA3 DAT2 periph B with pullup */ - AT91_PIOA 4 AT91_PERIPH_B (AT91_PINCTRL_PULL_UP | AT91_PINCTRL_DRIVE_STRENGTH_HI)>; /* PA4 DAT3 periph B with pullup */ - }; - }; };
pioA: gpio@fffff400 { diff --git a/arch/arm/dts/sam9x60ek.dts b/arch/arm/dts/sam9x60ek.dts index d8d7ad38b2b..e74cdcdb66e 100644 --- a/arch/arm/dts/sam9x60ek.dts +++ b/arch/arm/dts/sam9x60ek.dts @@ -82,6 +82,11 @@ }; };
+&dbgu { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_dbgu>; +}; + &ebi { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_ebi_addr_nand &pinctrl_ebi_data_0_7>; @@ -149,11 +154,21 @@
&pinctrl { /* shared pinctrl settings */ + dbgu { + pinctrl_dbgu: dbgu-0 { + atmel,pins = + <AT91_PIOA 9 AT91_PERIPH_A AT91_PINCTRL_PULL_UP + AT91_PIOA 10 AT91_PERIPH_A AT91_PINCTRL_NONE>; + }; + }; + ebi { pinctrl_ebi_data_0_7: ebi-data-lsb-0 { atmel,pins = @@ -174,6 +189,22 @@ }; };
+ macb0 { + pinctrl_macb0_rmii: macb0_rmii-0 { + atmel,pins = + <AT91_PIOB 0 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB0 periph A */ + AT91_PIOB 1 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB1 periph A */ + AT91_PIOB 2 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB2 periph A */ + AT91_PIOB 3 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB3 periph A */ + AT91_PIOB 4 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB4 periph A */ + AT91_PIOB 5 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB5 periph A */ + AT91_PIOB 6 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB6 periph A */ + AT91_PIOB 7 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB7 periph A */ + AT91_PIOB 9 AT91_PERIPH_A AT91_PINCTRL_NONE /* PB9 periph A */ + AT91_PIOB 10 AT91_PERIPH_A AT91_PINCTRL_NONE>; /* PB10 periph A */ + }; + }; + nand { pinctrl_nand_oe_we: nand-oe-we-0 { atmel,pins = @@ -213,6 +244,36 @@ AT91_PIOB 24 AT91_PERIPH_A AT91_PINCTRL_PULL_UP>; };
+ sdhci0 { + pinctrl_sdhci0: sdhci0 { + atmel,pins = + <AT91_PIOA 17 AT91_PERIPH_A + (AT91_PINCTRL_DRIVE_STRENGTH_HI | AT91_PINCTRL_SLEWRATE_ENA) /* PA17 CK periph A with pullup */ + AT91_PIOA 16 AT91_PERIPH_A + (AT91_PINCTRL_PULL_UP | AT91_PINCTRL_DRIVE_STRENGTH_HI | AT91_PINCTRL_SLEWRATE_ENA) /* PA16 CMD periph A with pullup */ + AT91_PIOA 15 AT91_PERIPH_A + (AT91_PINCTRL_PULL_UP | AT91_PINCTRL_DRIVE_STRENGTH_HI | AT91_PINCTRL_SLEWRATE_ENA) /* PA15 DAT0 periph A */ + AT91_PIOA 18 AT91_PERIPH_A + (AT91_PINCTRL_PULL_UP | AT91_PINCTRL_DRIVE_STRENGTH_HI | AT91_PINCTRL_SLEWRATE_ENA) /* PA18 DAT1 periph A with pullup */ + AT91_PIOA 19 AT91_PERIPH_A + (AT91_PINCTRL_PULL_UP | AT91_PINCTRL_DRIVE_STRENGTH_HI | AT91_PINCTRL_SLEWRATE_ENA) /* PA19 DAT2 periph A with pullup */ + AT91_PIOA 20 AT91_PERIPH_A + (AT91_PINCTRL_PULL_UP | AT91_PINCTRL_DRIVE_STRENGTH_HI | AT91_PINCTRL_SLEWRATE_ENA)>; /* PA20 DAT3 periph A with pullup */ + }; + }; + + sdhci1 { + pinctrl_sdhci1: sdhci1 { + atmel,pins = + <AT91_PIOA 13 AT91_PERIPH_B (AT91_PINCTRL_DRIVE_STRENGTH_HI) /* PA13 CK periph B */ + AT91_PIOA 12 AT91_PERIPH_B (AT91_PINCTRL_PULL_UP | AT91_PINCTRL_DRIVE_STRENGTH_HI) /* PA12 CMD periph B with pullup */ + AT91_PIOA 11 AT91_PERIPH_B (AT91_PINCTRL_PULL_UP | AT91_PINCTRL_DRIVE_STRENGTH_HI) /* PA11 DAT0 periph B with pullup */ + AT91_PIOA 2 AT91_PERIPH_B (AT91_PINCTRL_PULL_UP | AT91_PINCTRL_DRIVE_STRENGTH_HI) /* PA2 DAT1 periph B with pullup */ + AT91_PIOA 3 AT91_PERIPH_B (AT91_PINCTRL_PULL_UP | AT91_PINCTRL_DRIVE_STRENGTH_HI) /* PA3 DAT2 periph B with pullup */ + AT91_PIOA 4 AT91_PERIPH_B (AT91_PINCTRL_PULL_UP | AT91_PINCTRL_DRIVE_STRENGTH_HI)>; /* PA4 DAT3 periph B with pullup */ + }; + }; + usb1 { pinctrl_usb_default: usb_default { atmel,pins = <AT91_PIOD 15 AT91_PERIPH_GPIO AT91_PINCTRL_NONE @@ -221,6 +282,16 @@ }; };
Add the missing properties for the pinctrl node and for its corresponding GPIO bank nodes to align with the Linux DT.
Signed-off-by: Manikandan Muralidharan manikandan.m@microchip.com --- arch/arm/dts/sam9x60.dtsi | 23 ++++++++++++++++++++++- 1 file changed, 22 insertions(+), 1 deletion(-)
diff --git a/arch/arm/dts/sam9x60.dtsi b/arch/arm/dts/sam9x60.dtsi index 47b65d0ef56..a45e346d4ab 100644 --- a/arch/arm/dts/sam9x60.dtsi +++ b/arch/arm/dts/sam9x60.dtsi @@ -212,43 +212,64 @@ pinctrl: pinctrl@fffff400 { #address-cells = <1>; #size-cells = <1>; - compatible = "microchip,sam9x60-pinctrl", "simple-bus"; + compatible = "microchip,sam9x60-pinctrl", "atmel,at91sam9x5-pinctrl", "atmel,at91rm9200-pinctrl", "simple-bus"; ranges = <0xfffff400 0xfffff400 0x800>; reg = <0xfffff400 0x200 /* pioA */ 0xfffff600 0x200 /* pioB */ 0xfffff800 0x200 /* pioC */ 0xfffffa00 0x200>; /* pioD */ + + /* mux-mask corresponding to sam9x60 SoC in TFBGA228L package */ + atmel,mux-mask = < + /* A B C */ + 0xffffffff 0xffe03fff 0xef00019d /* pioA */ + 0x03ffffff 0x02fc7e7f 0x00780000 /* pioB */ + 0xffffffff 0xffffffff 0xf83fffff /* pioC */ + 0x003fffff 0x003f8000 0x00000000 /* pioD */ + >; };
pioA: gpio@fffff400 { compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; reg = <0xfffff400 0x200>; + interrupts = <2 IRQ_TYPE_LEVEL_HIGH 1>; #gpio-cells = <2>; gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; clocks = <&pmc PMC_TYPE_PERIPHERAL 2>; };
pioB: gpio@fffff600 { compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; reg = <0xfffff600 0x200>; + interrupts = <3 IRQ_TYPE_LEVEL_HIGH 1>; #gpio-cells = <2>; gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; clocks = <&pmc PMC_TYPE_PERIPHERAL 3>; };
pioC: gpio@fffff800 { compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; reg = <0xfffff800 0x200>; + interrupts = <4 IRQ_TYPE_LEVEL_HIGH 1>; #gpio-cells = <2>; gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; clocks = <&pmc PMC_TYPE_PERIPHERAL 4>; };
pioD: gpio@fffffa00 { compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; reg = <0xfffffa00 0x200>; + interrupts = <44 IRQ_TYPE_LEVEL_HIGH 1>; #gpio-cells = <2>; gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; clocks = <&pmc PMC_TYPE_PERIPHERAL 44>; };
I don't see this compatible in Linux DT.
atmel,mux-mask = <
/* A B C */
>; }; pioA: gpio@fffff400 { compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; reg = <0xfffff400 0x200>;
#interrupt-cells = <2>; clocks = <&pmc PMC_TYPE_PERIPHERAL 2>; }; pioB: gpio@fffff600 { compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; reg = <0xfffff600 0x200>;
#interrupt-cells = <2>; clocks = <&pmc PMC_TYPE_PERIPHERAL 3>; }; pioC: gpio@fffff800 { compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; reg = <0xfffff800 0x200>;
#interrupt-cells = <2>; clocks = <&pmc PMC_TYPE_PERIPHERAL 4>; }; pioD: gpio@fffffa00 { compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; reg = <0xfffffa00 0x200>;
In Linux DT,the pinctrl node acts as parent nodes with all other gpio banks as child nodes and a single driver in Linux handles both pinctrl settings and gpio requests.Current U-Boot DT maintains both pinctrl and gpio nodes as separate nodes and offers two different class of U-Boot drivers: UCLASS_PINCTRL which handles pin functions and UCLASS_GPIO which handles gpio requests. In order to align the DT of U-Boot with the DT of Linux, a hook is been added in the pinctrl driver to bind the gpio driver with the pinctrl driver so that when adding gpio nodes as subnodes to pinctrl node (as per the Linux ABI), the corresponding APIs will be redirected and handled by valid drivers attached to the pinctrl driver.
Signed-off-by: Manikandan Muralidharan manikandan.m@microchip.com --- drivers/pinctrl/pinctrl-at91.c | 15 +++++++++++++++ 1 file changed, 15 insertions(+)
diff --git a/drivers/pinctrl/pinctrl-at91.c b/drivers/pinctrl/pinctrl-at91.c index 5038cb535e3..2b871143fc0 100644 --- a/drivers/pinctrl/pinctrl-at91.c +++ b/drivers/pinctrl/pinctrl-at91.c @@ -9,6 +9,8 @@ #include <dm.h> #include <log.h> #include <asm/global_data.h> +#include <dm/device-internal.h> +#include <dm/lists.h> #include <dm/pinctrl.h> #include <asm/hardware.h> #include <linux/bitops.h> @@ -492,6 +494,18 @@ const struct pinctrl_ops at91_pinctrl_ops = { .set_state = at91_pinctrl_set_state, };
+static int at91_pinctrl_bind(struct udevice *dev) +{ + ofnode gpio_node; + struct udevice *gpio; + + ofnode_for_each_subnode(gpio_node, dev_ofnode(dev)) { + lists_bind_fdt(dev, gpio_node, &gpio, NULL, false); + } + + return 0; +} + static int at91_pinctrl_probe(struct udevice *dev) { struct at91_pinctrl_priv *priv = dev_get_priv(dev); @@ -524,6 +538,7 @@ U_BOOT_DRIVER(atmel_sama5d3_pinctrl) = { .id = UCLASS_PINCTRL, .of_match = at91_pinctrl_match, .probe = at91_pinctrl_probe, + .bind = at91_pinctrl_bind, .priv_auto = sizeof(struct at91_pinctrl_priv), .ops = &at91_pinctrl_ops, };
U-Boot pinctrl driver expects a reg property explicitly unlike linux. To align the DT of U-boot with the Linux, reg property is also arrvied from child GPIO bank nodes when configured under the pinctrl node.
Signed-off-by: Manikandan Muralidharan manikandan.m@microchip.com --- drivers/pinctrl/pinctrl-at91.c | 25 +++++++++++++++++++------ 1 file changed, 19 insertions(+), 6 deletions(-)
diff --git a/drivers/pinctrl/pinctrl-at91.c b/drivers/pinctrl/pinctrl-at91.c index 2b871143fc0..64f960478fc 100644 --- a/drivers/pinctrl/pinctrl-at91.c +++ b/drivers/pinctrl/pinctrl-at91.c @@ -510,17 +510,30 @@ static int at91_pinctrl_probe(struct udevice *dev) { struct at91_pinctrl_priv *priv = dev_get_priv(dev); fdt_addr_t addr_base; + struct udevice *gpio_node; int index;
- for (index = 0; index < MAX_GPIO_BANKS; index++) { - addr_base = devfdt_get_addr_index(dev, index); - if (addr_base == FDT_ADDR_T_NONE) - break; + if (list_empty(&dev->child_head)) { + for (index = 0; index < MAX_GPIO_BANKS; index++) { + addr_base = devfdt_get_addr_index(dev, index); + if (addr_base == FDT_ADDR_T_NONE) + break;
- priv->reg_base[index] = (struct at91_port *)addr_base; + priv->reg_base[index] = (struct at91_port *)addr_base; + } + } else { + index = 0; + list_for_each_entry(gpio_node, &dev->child_head, sibling_node) { + addr_base = dev_read_addr(gpio_node); + if (addr_base == FDT_ADDR_T_NONE) + break; + + priv->reg_base[index] = (struct at91_port *)addr_base; + index++; + } }
- priv->nbanks = index; + priv->nbanks = index < MAX_GPIO_BANKS ? index : MAX_GPIO_BANKS;
return 0; }
The GPIO banks are added as sub nodes or child nodes under the pinctrl node (as per Linux ABI) and the reg property which points to an array of controllers physical base address is removed to align with the Linux devicetree.
Signed-off-by: Charan Pedumuru charan.pedumuru@microchip.com Signed-off-by: Manikandan Muralidharan manikandan.m@microchip.com --- arch/arm/dts/at91sam9260.dtsi | 76 +++++++++++----------- arch/arm/dts/at91sam9261.dtsi | 77 +++++++++++----------- arch/arm/dts/at91sam9263.dtsi | 117 ++++++++++++++++----------------- arch/arm/dts/at91sam9g45.dtsi | 106 ++++++++++++++---------------- arch/arm/dts/at91sam9n12.dtsi | 93 +++++++++++++-------------- arch/arm/dts/at91sam9rl.dtsi | 93 +++++++++++++-------------- arch/arm/dts/at91sam9x5.dtsi | 90 ++++++++++++-------------- arch/arm/dts/sam9x60.dtsi | 90 +++++++++++++------------- arch/arm/dts/sama5d3.dtsi | 116 ++++++++++++++++----------------- arch/arm/dts/sama5d4.dtsi | 118 ++++++++++++++++------------------ 10 files changed, 462 insertions(+), 514 deletions(-)
diff --git a/arch/arm/dts/at91sam9260.dtsi b/arch/arm/dts/at91sam9260.dtsi index 4ea4202737c..8d496205523 100644 --- a/arch/arm/dts/at91sam9260.dtsi +++ b/arch/arm/dts/at91sam9260.dtsi @@ -401,51 +401,11 @@ clock-names = "t0_clk", "t1_clk", "t2_clk", "slow_clk"; };
- pioA: gpio@fffff400 { - compatible = "atmel,at91rm9200-gpio"; - reg = <0xfffff400 0x200>; - interrupts = <2 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioA_clk>; - bootph-all; - }; - - pioB: gpio@fffff600 { - compatible = "atmel,at91rm9200-gpio"; - reg = <0xfffff600 0x200>; - interrupts = <3 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioB_clk>; - bootph-all; - }; - - pioC: gpio@fffff800 { - compatible = "atmel,at91rm9200-gpio"; - reg = <0xfffff800 0x200>; - interrupts = <4 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioC_clk>; - bootph-all; - }; - pinctrl: pinctrl@fffff400 { #address-cells = <1>; #size-cells = <1>; compatible = "atmel,at91rm9200-pinctrl", "simple-bus"; ranges = <0xfffff400 0xfffff400 0x600>; - reg = <0xfffff400 0x200 /* pioA */ - 0xfffff600 0x200 /* pioB */ - 0xfffff800 0x200 /* pioC */ - >;
atmel,mux-mask = < /* A B */ @@ -767,6 +727,42 @@ atmel,pins = <AT91_PIOB 19 AT91_PERIPH_B AT91_PINCTRL_NONE>; }; }; + + pioA: gpio@fffff400 { + compatible = "atmel,at91rm9200-gpio"; + reg = <0xfffff400 0x200>; + interrupts = <2 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioA_clk>; + bootph-all; + }; + + pioB: gpio@fffff600 { + compatible = "atmel,at91rm9200-gpio"; + reg = <0xfffff600 0x200>; + interrupts = <3 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioB_clk>; + bootph-all; + }; + + pioC: gpio@fffff800 { + compatible = "atmel,at91rm9200-gpio"; + reg = <0xfffff800 0x200>; + interrupts = <4 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioC_clk>; + bootph-all; + }; };
dbgu: serial@fffff200 { diff --git a/arch/arm/dts/at91sam9261.dtsi b/arch/arm/dts/at91sam9261.dtsi index 804340e75d9..65e0e4f0de0 100644 --- a/arch/arm/dts/at91sam9261.dtsi +++ b/arch/arm/dts/at91sam9261.dtsi @@ -286,51 +286,12 @@ status = "disabled"; };
- pioA: gpio@fffff400 { - compatible = "atmel,at91rm9200-gpio"; - reg = <0xfffff400 0x200>; - interrupts = <2 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioA_clk>; - bootph-all; - }; - - pioB: gpio@fffff600 { - compatible = "atmel,at91rm9200-gpio"; - reg = <0xfffff600 0x200>; - interrupts = <3 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioB_clk>; - bootph-all; - }; - - pioC: gpio@fffff800 { - compatible = "atmel,at91rm9200-gpio"; - reg = <0xfffff800 0x200>; - interrupts = <4 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioC_clk>; - bootph-all; - }; - pinctrl@fffff400 { #address-cells = <1>; #size-cells = <1>; compatible = "atmel,at91rm9200-pinctrl", "simple-bus"; ranges = <0xfffff400 0xfffff400 0x600>; - reg = <0xfffff400 0x200 /* pioA */ - 0xfffff600 0x200 /* pioB */ - 0xfffff800 0x200 /* pioC */ - >; + atmel,mux-mask = /* A B */ <0xffffffff 0xfffffff7>, /* pioA */ @@ -573,6 +534,42 @@ <AT91_PIOB 28 AT91_PERIPH_B AT91_PINCTRL_NONE>; }; }; + + pioA: gpio@fffff400 { + compatible = "atmel,at91rm9200-gpio"; + reg = <0xfffff400 0x200>; + interrupts = <2 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioA_clk>; + bootph-all; + }; + + pioB: gpio@fffff600 { + compatible = "atmel,at91rm9200-gpio"; + reg = <0xfffff600 0x200>; + interrupts = <3 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioB_clk>; + bootph-all; + }; + + pioC: gpio@fffff800 { + compatible = "atmel,at91rm9200-gpio"; + reg = <0xfffff800 0x200>; + interrupts = <4 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioC_clk>; + bootph-all; + }; };
pmc: pmc@fffffc00 { diff --git a/arch/arm/dts/at91sam9263.dtsi b/arch/arm/dts/at91sam9263.dtsi index 98cdd8ebcca..55b79667564 100644 --- a/arch/arm/dts/at91sam9263.dtsi +++ b/arch/arm/dts/at91sam9263.dtsi @@ -404,12 +404,6 @@ #size-cells = <1>; compatible = "atmel,at91rm9200-pinctrl", "simple-bus"; ranges = <0xfffff200 0xfffff200 0xa00>; - reg = <0xfffff200 0x200 - 0xfffff400 0x200 - 0xfffff600 0x200 - 0xfffff800 0x200 - 0xfffffa00 0x200 - >;
atmel,mux-mask = < /* A B */ @@ -719,66 +713,65 @@ }; };
- }; - - pioA: gpio@fffff200 { - compatible = "atmel,at91rm9200-gpio"; - reg = <0xfffff200 0x200>; - interrupts = <2 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioA_clk>; - bootph-all; - }; + pioA: gpio@fffff200 { + compatible = "atmel,at91rm9200-gpio"; + reg = <0xfffff200 0x200>; + interrupts = <2 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioA_clk>; + bootph-all; + };
- pioB: gpio@fffff400 { - compatible = "atmel,at91rm9200-gpio"; - reg = <0xfffff400 0x200>; - interrupts = <3 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioB_clk>; - bootph-all; - }; + pioB: gpio@fffff400 { + compatible = "atmel,at91rm9200-gpio"; + reg = <0xfffff400 0x200>; + interrupts = <3 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioB_clk>; + bootph-all; + };
- pioC: gpio@fffff600 { - compatible = "atmel,at91rm9200-gpio"; - reg = <0xfffff600 0x200>; - interrupts = <4 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioCDE_clk>; - bootph-all; - }; + pioC: gpio@fffff600 { + compatible = "atmel,at91rm9200-gpio"; + reg = <0xfffff600 0x200>; + interrupts = <4 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioCDE_clk>; + bootph-all; + };
- pioD: gpio@fffff800 { - compatible = "atmel,at91rm9200-gpio"; - reg = <0xfffff800 0x200>; - interrupts = <4 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioCDE_clk>; - bootph-all; - }; + pioD: gpio@fffff800 { + compatible = "atmel,at91rm9200-gpio"; + reg = <0xfffff800 0x200>; + interrupts = <4 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioCDE_clk>; + bootph-all; + };
- pioE: gpio@fffffa00 { - compatible = "atmel,at91rm9200-gpio"; - reg = <0xfffffa00 0x200>; - interrupts = <4 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioCDE_clk>; - bootph-all; + pioE: gpio@fffffa00 { + compatible = "atmel,at91rm9200-gpio"; + reg = <0xfffffa00 0x200>; + interrupts = <4 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioCDE_clk>; + bootph-all; + }; };
dbgu: serial@ffffee00 { diff --git a/arch/arm/dts/at91sam9g45.dtsi b/arch/arm/dts/at91sam9g45.dtsi index d0bcd797359..63a061354e4 100644 --- a/arch/arm/dts/at91sam9g45.dtsi +++ b/arch/arm/dts/at91sam9g45.dtsi @@ -435,12 +435,6 @@ #size-cells = <1>; compatible = "atmel,at91rm9200-pinctrl", "simple-bus"; ranges = <0xfffff200 0xfffff200 0xa00>; - reg = <0xfffff200 0x200 - 0xfffff400 0x200 - 0xfffff600 0x200 - 0xfffff800 0x200 - 0xfffffa00 0x200 - >; bootph-all;
atmel,mux-mask = < @@ -854,61 +848,61 @@ AT91_PIOE 30 AT91_PERIPH_A AT91_PINCTRL_NONE>; /* PE30 periph A */ }; }; - };
- pioA: gpio@fffff200 { - compatible = "atmel,at91rm9200-gpio"; - reg = <0xfffff200 0x200>; - interrupts = <2 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioA_clk>; - }; + pioA: gpio@fffff200 { + compatible = "atmel,at91rm9200-gpio"; + reg = <0xfffff200 0x200>; + interrupts = <2 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioA_clk>; + };
- pioB: gpio@fffff400 { - compatible = "atmel,at91rm9200-gpio"; - reg = <0xfffff400 0x200>; - interrupts = <3 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioB_clk>; - }; + pioB: gpio@fffff400 { + compatible = "atmel,at91rm9200-gpio"; + reg = <0xfffff400 0x200>; + interrupts = <3 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioB_clk>; + };
- pioC: gpio@fffff600 { - compatible = "atmel,at91rm9200-gpio"; - reg = <0xfffff600 0x200>; - interrupts = <4 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioC_clk>; - }; + pioC: gpio@fffff600 { + compatible = "atmel,at91rm9200-gpio"; + reg = <0xfffff600 0x200>; + interrupts = <4 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioC_clk>; + };
- pioD: gpio@fffff800 { - compatible = "atmel,at91rm9200-gpio"; - reg = <0xfffff800 0x200>; - interrupts = <5 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioDE_clk>; - }; + pioD: gpio@fffff800 { + compatible = "atmel,at91rm9200-gpio"; + reg = <0xfffff800 0x200>; + interrupts = <5 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioDE_clk>; + };
- pioE: gpio@fffffa00 { - compatible = "atmel,at91rm9200-gpio"; - reg = <0xfffffa00 0x200>; - interrupts = <5 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioDE_clk>; + pioE: gpio@fffffa00 { + compatible = "atmel,at91rm9200-gpio"; + reg = <0xfffffa00 0x200>; + interrupts = <5 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioDE_clk>; + }; };
dbgu: serial@ffffee00 { diff --git a/arch/arm/dts/at91sam9n12.dtsi b/arch/arm/dts/at91sam9n12.dtsi index cb3a0370b86..84089837013 100644 --- a/arch/arm/dts/at91sam9n12.dtsi +++ b/arch/arm/dts/at91sam9n12.dtsi @@ -492,11 +492,6 @@ #size-cells = <1>; compatible = "atmel,at91sam9x5-pinctrl", "atmel,at91rm9200-pinctrl", "simple-bus"; ranges = <0xfffff400 0xfffff400 0x800>; - reg = <0xfffff400 0x200 - 0xfffff600 0x200 - 0xfffff800 0x200 - 0xfffffa00 0x200 - >;
atmel,mux-mask = < /* A B C */ @@ -795,54 +790,54 @@ atmel,pins = <AT91_PIOC 13 AT91_PERIPH_C AT91_PINCTRL_NONE>; }; }; - };
- pioA: gpio@fffff400 { - compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; - reg = <0xfffff400 0x200>; - interrupts = <2 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioAB_clk>; - bootph-all; - }; + pioA: gpio@fffff400 { + compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; + reg = <0xfffff400 0x200>; + interrupts = <2 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioAB_clk>; + bootph-all; + };
- pioB: gpio@fffff600 { - compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; - reg = <0xfffff600 0x200>; - interrupts = <2 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioAB_clk>; - bootph-all; - }; + pioB: gpio@fffff600 { + compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; + reg = <0xfffff600 0x200>; + interrupts = <2 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioAB_clk>; + bootph-all; + };
- pioC: gpio@fffff800 { - compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; - reg = <0xfffff800 0x200>; - interrupts = <3 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioCD_clk>; - bootph-all; - }; + pioC: gpio@fffff800 { + compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; + reg = <0xfffff800 0x200>; + interrupts = <3 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioCD_clk>; + bootph-all; + };
- pioD: gpio@fffffa00 { - compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; - reg = <0xfffffa00 0x200>; - interrupts = <3 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioCD_clk>; - bootph-all; + pioD: gpio@fffffa00 { + compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; + reg = <0xfffffa00 0x200>; + interrupts = <3 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioCD_clk>; + bootph-all; + }; };
dbgu: serial@fffff200 { diff --git a/arch/arm/dts/at91sam9rl.dtsi b/arch/arm/dts/at91sam9rl.dtsi index b855c8fe0fe..3b99de21058 100644 --- a/arch/arm/dts/at91sam9rl.dtsi +++ b/arch/arm/dts/at91sam9rl.dtsi @@ -386,11 +386,6 @@ #size-cells = <1>; compatible = "atmel,at91rm9200-pinctrl", "simple-bus"; ranges = <0xfffff400 0xfffff400 0x800>; - reg = <0xfffff400 0x200 - 0xfffff600 0x200 - 0xfffff800 0x200 - 0xfffffa00 0x200 - >;
atmel,mux-mask = /* A B */ @@ -768,54 +763,54 @@ <AT91_PIOA 20 AT91_PERIPH_B AT91_PINCTRL_NONE>; }; }; - };
- pioA: gpio@fffff400 { - compatible = "atmel,at91rm9200-gpio"; - reg = <0xfffff400 0x200>; - interrupts = <2 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioA_clk>; - bootph-all; - }; + pioA: gpio@fffff400 { + compatible = "atmel,at91rm9200-gpio"; + reg = <0xfffff400 0x200>; + interrupts = <2 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioA_clk>; + bootph-all; + };
- pioB: gpio@fffff600 { - compatible = "atmel,at91rm9200-gpio"; - reg = <0xfffff600 0x200>; - interrupts = <3 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioB_clk>; - bootph-all; - }; + pioB: gpio@fffff600 { + compatible = "atmel,at91rm9200-gpio"; + reg = <0xfffff600 0x200>; + interrupts = <3 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioB_clk>; + bootph-all; + };
- pioC: gpio@fffff800 { - compatible = "atmel,at91rm9200-gpio"; - reg = <0xfffff800 0x200>; - interrupts = <4 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioC_clk>; - bootph-all; - }; + pioC: gpio@fffff800 { + compatible = "atmel,at91rm9200-gpio"; + reg = <0xfffff800 0x200>; + interrupts = <4 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioC_clk>; + bootph-all; + };
- pioD: gpio@fffffa00 { - compatible = "atmel,at91rm9200-gpio"; - reg = <0xfffffa00 0x200>; - interrupts = <5 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioD_clk>; - bootph-all; + pioD: gpio@fffffa00 { + compatible = "atmel,at91rm9200-gpio"; + reg = <0xfffffa00 0x200>; + interrupts = <5 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioD_clk>; + bootph-all; + }; };
pmc: pmc@fffffc00 { diff --git a/arch/arm/dts/at91sam9x5.dtsi b/arch/arm/dts/at91sam9x5.dtsi index 5fca9b13c27..4c6d8b9bb65 100644 --- a/arch/arm/dts/at91sam9x5.dtsi +++ b/arch/arm/dts/at91sam9x5.dtsi @@ -461,14 +461,8 @@ #size-cells = <1>; compatible = "atmel,at91sam9x5-pinctrl", "atmel,at91rm9200-pinctrl", "simple-bus"; ranges = <0xfffff400 0xfffff400 0x800>; - reg = <0xfffff400 0x200 /* pioA */ - 0xfffff600 0x200 /* pioB */ - 0xfffff800 0x200 /* pioC */ - 0xfffffa00 0x200 /* pioD */ - >; bootph-all;
- /* shared pinctrl settings */ dbgu { bootph-all; @@ -831,52 +825,52 @@ atmel,pins = <AT91_PIOC 13 AT91_PERIPH_C AT91_PINCTRL_NONE>; }; }; - };
- pioA: gpio@fffff400 { - compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; - reg = <0xfffff400 0x200>; - interrupts = <2 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioAB_clk>; - }; + pioA: gpio@fffff400 { + compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; + reg = <0xfffff400 0x200>; + interrupts = <2 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioAB_clk>; + };
- pioB: gpio@fffff600 { - compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; - reg = <0xfffff600 0x200>; - interrupts = <2 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - #gpio-lines = <19>; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioAB_clk>; - }; + pioB: gpio@fffff600 { + compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; + reg = <0xfffff600 0x200>; + interrupts = <2 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + #gpio-lines = <19>; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioAB_clk>; + };
- pioC: gpio@fffff800 { - compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; - reg = <0xfffff800 0x200>; - interrupts = <3 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioCD_clk>; - }; + pioC: gpio@fffff800 { + compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; + reg = <0xfffff800 0x200>; + interrupts = <3 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioCD_clk>; + };
- pioD: gpio@fffffa00 { - compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; - reg = <0xfffffa00 0x200>; - interrupts = <3 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - #gpio-lines = <22>; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioCD_clk>; + pioD: gpio@fffffa00 { + compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; + reg = <0xfffffa00 0x200>; + interrupts = <3 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + #gpio-lines = <22>; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioCD_clk>; + }; };
ssc0: ssc@f0010000 { diff --git a/arch/arm/dts/sam9x60.dtsi b/arch/arm/dts/sam9x60.dtsi index a45e346d4ab..9a20ecd2593 100644 --- a/arch/arm/dts/sam9x60.dtsi +++ b/arch/arm/dts/sam9x60.dtsi @@ -214,10 +214,6 @@ #size-cells = <1>; compatible = "microchip,sam9x60-pinctrl", "atmel,at91sam9x5-pinctrl", "atmel,at91rm9200-pinctrl", "simple-bus"; ranges = <0xfffff400 0xfffff400 0x800>; - reg = <0xfffff400 0x200 /* pioA */ - 0xfffff600 0x200 /* pioB */ - 0xfffff800 0x200 /* pioC */ - 0xfffffa00 0x200>; /* pioD */
/* mux-mask corresponding to sam9x60 SoC in TFBGA228L package */ atmel,mux-mask = < @@ -227,50 +223,50 @@ 0xffffffff 0xffffffff 0xf83fffff /* pioC */ 0x003fffff 0x003f8000 0x00000000 /* pioD */ >; - }; - - pioA: gpio@fffff400 { - compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; - reg = <0xfffff400 0x200>; - interrupts = <2 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pmc PMC_TYPE_PERIPHERAL 2>; - };
- pioB: gpio@fffff600 { - compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; - reg = <0xfffff600 0x200>; - interrupts = <3 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pmc PMC_TYPE_PERIPHERAL 3>; - }; - - pioC: gpio@fffff800 { - compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; - reg = <0xfffff800 0x200>; - interrupts = <4 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pmc PMC_TYPE_PERIPHERAL 4>; - }; - - pioD: gpio@fffffa00 { - compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; - reg = <0xfffffa00 0x200>; - interrupts = <44 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pmc PMC_TYPE_PERIPHERAL 44>; + pioA: gpio@fffff400 { + compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; + reg = <0xfffff400 0x200>; + interrupts = <2 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pmc PMC_TYPE_PERIPHERAL 2>; + }; + + pioB: gpio@fffff600 { + compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; + reg = <0xfffff600 0x200>; + interrupts = <3 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pmc PMC_TYPE_PERIPHERAL 3>; + }; + + pioC: gpio@fffff800 { + compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; + reg = <0xfffff800 0x200>; + interrupts = <4 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pmc PMC_TYPE_PERIPHERAL 4>; + }; + + pioD: gpio@fffffa00 { + compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; + reg = <0xfffffa00 0x200>; + interrupts = <44 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pmc PMC_TYPE_PERIPHERAL 44>; + }; };
pmc: pmc@fffffc00 { diff --git a/arch/arm/dts/sama5d3.dtsi b/arch/arm/dts/sama5d3.dtsi index 4c03a302ec7..10d6e74586d 100644 --- a/arch/arm/dts/sama5d3.dtsi +++ b/arch/arm/dts/sama5d3.dtsi @@ -492,12 +492,6 @@ 0xffffffff 0xc001c0e0 0x0001c1e0 /* pioD */ 0xffffffff 0xbf9f8000 0x18000000 /* pioE */ >; - reg = <0xfffff200 0x100 /* pioA */ - 0xfffff400 0x100 /* pioB */ - 0xfffff600 0x100 /* pioC */ - 0xfffff800 0x100 /* pioD */ - 0xfffffa00 0x100 /* pioE */ - >;
/* shared pinctrl settings */ adc0 { @@ -873,66 +867,66 @@ AT91_PIOE 17 AT91_PERIPH_B AT91_PINCTRL_NONE>; /* PE17 periph B, conflicts with A17 */ }; }; - };
- pioA: gpio@fffff200 { - compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; - reg = <0xfffff200 0x100>; - interrupts = <6 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioA_clk>; - bootph-all; - }; + pioA: gpio@fffff200 { + compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; + reg = <0xfffff200 0x100>; + interrupts = <6 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioA_clk>; + bootph-all; + };
- pioB: gpio@fffff400 { - compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; - reg = <0xfffff400 0x100>; - interrupts = <7 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioB_clk>; - bootph-all; - }; + pioB: gpio@fffff400 { + compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; + reg = <0xfffff400 0x100>; + interrupts = <7 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioB_clk>; + bootph-all; + };
- pioC: gpio@fffff600 { - compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; - reg = <0xfffff600 0x100>; - interrupts = <8 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioC_clk>; - bootph-all; - }; + pioC: gpio@fffff600 { + compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; + reg = <0xfffff600 0x100>; + interrupts = <8 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioC_clk>; + bootph-all; + };
- pioD: gpio@fffff800 { - compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; - reg = <0xfffff800 0x100>; - interrupts = <9 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioD_clk>; - bootph-all; - }; + pioD: gpio@fffff800 { + compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; + reg = <0xfffff800 0x100>; + interrupts = <9 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioD_clk>; + bootph-all; + };
- pioE: gpio@fffffa00 { - compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; - reg = <0xfffffa00 0x100>; - interrupts = <10 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioE_clk>; - bootph-all; + pioE: gpio@fffffa00 { + compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; + reg = <0xfffffa00 0x100>; + interrupts = <10 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioE_clk>; + bootph-all; + }; };
pmc: pmc@fffffc00 { diff --git a/arch/arm/dts/sama5d4.dtsi b/arch/arm/dts/sama5d4.dtsi index 5e2c9a1db2f..482cf03e61b 100644 --- a/arch/arm/dts/sama5d4.dtsi +++ b/arch/arm/dts/sama5d4.dtsi @@ -1361,62 +1361,6 @@ status = "disabled"; };
- pioA: gpio@fc06a000 { - compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; - reg = <0xfc06a000 0x100>; - interrupts = <23 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioA_clk>; - }; - - pioB: gpio@fc06b000 { - compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; - reg = <0xfc06b000 0x100>; - interrupts = <24 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioB_clk>; - }; - - pioC: gpio@fc06c000 { - compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; - reg = <0xfc06c000 0x100>; - interrupts = <25 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioC_clk>; - bootph-all; - }; - - pioD: gpio@fc068000 { - compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; - reg = <0xfc068000 0x100>; - interrupts = <5 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioD_clk>; - }; - - pioE: gpio@fc06d000 { - compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; - reg = <0xfc06d000 0x100>; - interrupts = <26 IRQ_TYPE_LEVEL_HIGH 1>; - #gpio-cells = <2>; - gpio-controller; - interrupt-controller; - #interrupt-cells = <2>; - clocks = <&pioE_clk>; - }; - pinctrl@fc06a000 { bootph-all; #address-cells = <1>; @@ -1433,12 +1377,62 @@ 0x0003ff00 0x8002a800 0x00000000 /* pioD */ 0xffffffff 0x7fffffff 0x76fff1bf /* pioE */ >; - reg = < 0xfc06a000 0x100 - 0xfc06b000 0x100 - 0xfc06c000 0x100 - 0xfc068000 0x100 - 0xfc06d000 0x100 - >; + + pioA: gpio@fc06a000 { + compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; + reg = <0xfc06a000 0x100>; + interrupts = <23 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioA_clk>; + }; + + pioB: gpio@fc06b000 { + compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; + reg = <0xfc06b000 0x100>; + interrupts = <24 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioB_clk>; + }; + + pioC: gpio@fc06c000 { + compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; + reg = <0xfc06c000 0x100>; + interrupts = <25 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioC_clk>; + bootph-all; + }; + + pioD: gpio@fc068000 { + compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; + reg = <0xfc068000 0x100>; + interrupts = <5 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioD_clk>; + }; + + pioE: gpio@fc06d000 { + compatible = "atmel,at91sam9x5-gpio", "atmel,at91rm9200-gpio"; + reg = <0xfc06d000 0x100>; + interrupts = <26 IRQ_TYPE_LEVEL_HIGH 1>; + #gpio-cells = <2>; + gpio-controller; + interrupt-controller; + #interrupt-cells = <2>; + clocks = <&pioE_clk>; + };
/* pinctrl pin settings */ adc0 {
Eugen Hristev
