[U-Boot] [PATCH v2] MAKEALL: add -b (--board) option
Some board have multiple configurations. For example, the board "m54455evb" has many configurations: M54455EVB, M54455EVB_a66, M54455EVB_i66, M54455EVB_intel, ...
When we modify board-related files, we need to test all configurations based on such a board.
In such a case, the new option -b is useful.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com ---
Changes in v2: - fix a typo in log s/usefull/useful/
MAKEALL | 17 +++++++++++++++-- 1 file changed, 15 insertions(+), 2 deletions(-)
diff --git a/MAKEALL b/MAKEALL index 80cd4f8..a74f0fc 100755 --- a/MAKEALL +++ b/MAKEALL @@ -18,6 +18,7 @@ usage() -c CPU, --cpu CPU Build all boards with cpu CPU -v VENDOR, --vendor VENDOR Build all boards with vendor VENDOR -s SOC, --soc SOC Build all boards with soc SOC + -b BOARD, --board BOARD Build all boards with board name BOARD -l, --list List all targets to be built -m, --maintainers List all targets and maintainer email -M, --mails List all targets and all affilated emails @@ -59,8 +60,8 @@ usage() exit ${ret} }
-SHORT_OPTS="ha:c:v:s:lmMCnr" -LONG_OPTS="help,arch:,cpu:,vendor:,soc:,list,maintainers,mails,check,continue,rebuild-errors" +SHORT_OPTS="ha:c:v:s:b:lmMCnr" +LONG_OPTS="help,arch:,cpu:,vendor:,soc:,board:,list,maintainers,mails,check,continue,rebuild-errors"
# Option processing based on util-linux-2.13/getopt-parse.bash
@@ -121,6 +122,17 @@ while true ; do fi SELECTED='y' shift 2 ;; + -b|--board) + # echo "Option BOARD: argument `$2'" + if [ "$opt_b" ] ; then + opt_b="${opt_b%)} || $6 == "$2" || $7 == "$2")" + else + # We need to check the 7th field too + # for boards whose 6th field is "-" + opt_b="($6 == "$2" || $7 == "$2")" + fi + SELECTED='y' + shift 2 ;; -C|--check) CHECK='C=1' shift ;; @@ -158,6 +170,7 @@ FILTER="$1 !~ /^#/" [ "$opt_c" ] && FILTER="${FILTER} && $opt_c" [ "$opt_s" ] && FILTER="${FILTER} && $opt_s" [ "$opt_v" ] && FILTER="${FILTER} && $opt_v" +[ "$opt_b" ] && FILTER="${FILTER} && $opt_b"
if [ "$SELECTED" ] ; then SELECTED=$(awk '('"$FILTER"') { print $7 }' boards.cfg)
Masahiro Yamada
