[U-Boot] [PATCH 0/4] configs and cmd/Kconfig: Re-sync
Hey all,
The following series will be applied by me in about 24 hours (to give folks a chance to scream). At the end of this series, we have the current contents of cmd/Kconfig being entirely removed from include/configs* and done in the defconfig files. This shows a few things which do need to get done on top of what we have today. For example, I'm currently thinking that we need to add CONFIG_SOMEPREFIX_DISTRO_DEFAULTS to select all of the options that used to be in include/config_distro_defaults.h that are CONFIG chocies and now done in Kconfig.
Next, this series is not 100% non-size-changing. I'm able to build the world except for arc and nios2 (and I'll take that off-list for arc, Marek suggested a different toolchain for nios2 already). In doing a world build and using buildman -SB (aside: buildman is great! Good job Simon) to see what the bloat changes are, things break down into: - keymile boards that are having AUTOBOOT* migrated out grow slightly due to some strings being handled differently and padded differently now. I cannot explain _why_ but it's just what it is. We already accepted this when everyone else was migrated. - The am33xx/am43xx platforms that use network boot in SPL grow as we're no longer turning off CMD_NFS in the SPL build. There is (gut feeling) some bug somewhere as to why CMD_NFS is changing some paths such that even when the command is discarded we need the infrastructure. I'd like to see this be really fixed and note that at present all boards are still within size constraints (when I initially did this work we had to as we supported both ethernet and USB-ethernet in the same build, this is no longer true and this has given us the needed space back). - xilinx-ppc440-generic enabled a bunch of commands in the defconfig and then turned them off int he config.h file. They are now on. - A handful of platforms also suffer from what I'm calling compiler black magic. There are no changes in function contents, merely alignments and thus overall section size.
My follow-up to this will be taking Dinh's patch to move more options to Kconfig and then migrate everyone again. Once _that_ is done I'm doing a bit savedefconfig run and going to let a few people know that they've got some Kconfig issues to fix.
Move all cases of CONFIG_SYS_HUSH_PARSER out of the config.h files. Remove all cases of CONFIG_SYS_PROMPT_HUSH_PS2 as everyone uses the default.
Signed-off-by: Tom Rini trini@konsulko.com --- configs/A10-OLinuXino-Lime_defconfig | 1 + configs/A10s-OLinuXino-M_defconfig | 1 + configs/A13-OLinuXinoM_defconfig | 1 + configs/A13-OLinuXino_defconfig | 1 + configs/A20-OLinuXino-Lime2_defconfig | 1 + configs/A20-OLinuXino-Lime_defconfig | 1 + configs/A20-OLinuXino_MICRO_defconfig | 1 + configs/A20-Olimex-SOM-EVB_defconfig | 1 + configs/Ainol_AW1_defconfig | 1 + configs/Ampe_A76_defconfig | 1 + configs/Auxtek-T003_defconfig | 1 + configs/Auxtek-T004_defconfig | 1 + configs/B4420QDS_NAND_defconfig | 1 + configs/B4420QDS_SPIFLASH_defconfig | 1 + configs/B4420QDS_defconfig | 1 + configs/B4860QDS_NAND_defconfig | 1 + configs/B4860QDS_SECURE_BOOT_defconfig | 1 + configs/B4860QDS_SPIFLASH_defconfig | 1 + configs/B4860QDS_SRIO_PCIE_BOOT_defconfig | 1 + configs/B4860QDS_defconfig | 1 + configs/BSC9131RDB_NAND_SYSCLK100_defconfig | 1 + configs/BSC9131RDB_NAND_defconfig | 1 + configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig | 1 + configs/BSC9131RDB_SPIFLASH_defconfig | 1 + configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig | 1 + configs/BSC9132QDS_NAND_DDRCLK100_defconfig | 1 + configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig | 1 + configs/BSC9132QDS_NAND_DDRCLK133_defconfig | 1 + configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig | 1 + configs/BSC9132QDS_NOR_DDRCLK100_defconfig | 1 + configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig | 1 + configs/BSC9132QDS_NOR_DDRCLK133_defconfig | 1 + configs/BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig | 1 + configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig | 1 + configs/BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig | 1 + configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig | 1 + configs/BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig | 1 + configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig | 1 + configs/BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig | 1 + configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig | 1 + configs/Bananapi_defconfig | 1 + configs/Bananapro_defconfig | 1 + configs/C29XPCIE_NAND_defconfig | 1 + configs/C29XPCIE_NOR_SECBOOT_defconfig | 1 + configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig | 1 + configs/C29XPCIE_SPIFLASH_defconfig | 1 + configs/C29XPCIE_defconfig | 1 + configs/CHIP_defconfig | 1 + configs/CSQ_CS908_defconfig | 1 + configs/Chuwi_V7_CW0825_defconfig | 1 + configs/Colombus_defconfig | 1 + configs/Cubieboard2_defconfig | 1 + configs/Cubieboard_defconfig | 1 + configs/Cubietruck_defconfig | 1 + configs/Cubietruck_plus_defconfig | 3 ++- configs/Cyrus_P5020_defconfig | 1 + configs/Cyrus_P5040_defconfig | 1 + configs/Empire_electronix_d709_defconfig | 1 + configs/Hummingbird_A31_defconfig | 1 + configs/Hyundai_A7HD_defconfig | 1 + configs/Itead_Ibox_A20_defconfig | 2 +- configs/Lamobo_R1_defconfig | 1 + configs/Linksprite_pcDuino3_Nano_defconfig | 1 + configs/Linksprite_pcDuino3_defconfig | 1 + configs/Linksprite_pcDuino_defconfig | 1 + configs/M54418TWR_defconfig | 1 + configs/M54418TWR_nand_mii_defconfig | 1 + configs/M54418TWR_nand_rmii_defconfig | 1 + configs/M54418TWR_nand_rmii_lowfreq_defconfig | 1 + configs/M54418TWR_serial_mii_defconfig | 1 + configs/M54418TWR_serial_rmii_defconfig | 1 + configs/MIP405T_defconfig | 1 + configs/MIP405_defconfig | 1 + configs/MK808C_defconfig | 1 + configs/MPC8308RDB_defconfig | 1 + configs/MPC8313ERDB_33_defconfig | 1 + configs/MPC8313ERDB_66_defconfig | 1 + configs/MPC8313ERDB_NAND_33_defconfig | 1 + configs/MPC8313ERDB_NAND_66_defconfig | 1 + configs/MPC8315ERDB_defconfig | 1 + configs/MPC8323ERDB_defconfig | 1 + configs/MPC832XEMDS_ATM_defconfig | 1 + configs/MPC832XEMDS_HOST_33_defconfig | 1 + configs/MPC832XEMDS_HOST_66_defconfig | 1 + configs/MPC832XEMDS_SLAVE_defconfig | 1 + configs/MPC832XEMDS_defconfig | 1 + configs/MPC8349EMDS_defconfig | 1 + configs/MPC8349ITXGP_defconfig | 1 + configs/MPC8349ITX_LOWBOOT_defconfig | 1 + configs/MPC8349ITX_defconfig | 1 + configs/MPC837XEMDS_HOST_defconfig | 1 + configs/MPC837XEMDS_defconfig | 1 + configs/MPC837XERDB_defconfig | 1 + configs/MPC8536DS_36BIT_defconfig | 1 + configs/MPC8536DS_SDCARD_defconfig | 1 + configs/MPC8536DS_SPIFLASH_defconfig | 1 + configs/MPC8536DS_defconfig | 1 + configs/MPC8540ADS_defconfig | 1 + configs/MPC8541CDS_defconfig | 1 + configs/MPC8541CDS_legacy_defconfig | 1 + configs/MPC8544DS_defconfig | 1 + configs/MPC8548CDS_36BIT_defconfig | 1 + configs/MPC8548CDS_defconfig | 1 + configs/MPC8548CDS_legacy_defconfig | 1 + configs/MPC8555CDS_defconfig | 1 + configs/MPC8555CDS_legacy_defconfig | 1 + configs/MPC8560ADS_defconfig | 1 + configs/MPC8568MDS_defconfig | 1 + configs/MPC8569MDS_ATM_defconfig | 1 + configs/MPC8569MDS_defconfig | 1 + configs/MPC8572DS_36BIT_defconfig | 1 + configs/MPC8572DS_defconfig | 1 + configs/MPC8610HPCD_defconfig | 1 + configs/MPC8641HPCN_36BIT_defconfig | 2 +- configs/MPC8641HPCN_defconfig | 2 +- configs/MSI_Primo73_defconfig | 1 + configs/MSI_Primo81_defconfig | 1 + configs/Marsboard_A10_defconfig | 1 + configs/Mele_A1000G_quad_defconfig | 1 + configs/Mele_A1000_defconfig | 1 + configs/Mele_I7_defconfig | 1 + configs/Mele_M3_defconfig | 1 + configs/Mele_M5_defconfig | 1 + configs/Mele_M9_defconfig | 1 + configs/Merrii_A80_Optimus_defconfig | 1 + configs/Mini-X_defconfig | 1 + configs/MiniFAP_defconfig | 1 + configs/O2D300_defconfig | 1 + configs/O2DNT2_RAMBOOT_defconfig | 1 + configs/O2DNT2_defconfig | 1 + configs/O2D_defconfig | 1 + configs/O2I_defconfig | 1 + configs/O2MNT_O2M110_defconfig | 1 + configs/O2MNT_O2M112_defconfig | 1 + configs/O2MNT_O2M113_defconfig | 1 + configs/O2MNT_defconfig | 1 + configs/O3DNT_defconfig | 1 + configs/Orangepi_defconfig | 1 + configs/Orangepi_mini_defconfig | 1 + configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_36BIT_NAND_defconfig | 1 + configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PA_36BIT_SDCARD_defconfig | 1 + configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig | 1 + configs/P1010RDB-PA_NAND_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_NAND_defconfig | 1 + configs/P1010RDB-PA_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_NOR_defconfig | 1 + configs/P1010RDB-PA_SDCARD_defconfig | 1 + configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PA_SPIFLASH_defconfig | 1 + configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_36BIT_NAND_defconfig | 1 + configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_36BIT_NOR_defconfig | 1 + configs/P1010RDB-PB_36BIT_SDCARD_defconfig | 1 + configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig | 1 + configs/P1010RDB-PB_NAND_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_NAND_defconfig | 1 + configs/P1010RDB-PB_NOR_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_NOR_defconfig | 1 + configs/P1010RDB-PB_SDCARD_defconfig | 1 + configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig | 1 + configs/P1010RDB-PB_SPIFLASH_defconfig | 1 + configs/P1020MBG-PC_36BIT_SDCARD_defconfig | 1 + configs/P1020MBG-PC_36BIT_defconfig | 1 + configs/P1020MBG-PC_SDCARD_defconfig | 1 + configs/P1020MBG-PC_defconfig | 1 + configs/P1020RDB-PC_36BIT_NAND_defconfig | 1 + configs/P1020RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P1020RDB-PC_36BIT_defconfig | 1 + configs/P1020RDB-PC_NAND_defconfig | 1 + configs/P1020RDB-PC_SDCARD_defconfig | 1 + configs/P1020RDB-PC_SPIFLASH_defconfig | 1 + configs/P1020RDB-PC_defconfig | 1 + configs/P1020RDB-PD_NAND_defconfig | 1 + configs/P1020RDB-PD_SDCARD_defconfig | 1 + configs/P1020RDB-PD_SPIFLASH_defconfig | 1 + configs/P1020RDB-PD_defconfig | 1 + configs/P1020UTM-PC_36BIT_SDCARD_defconfig | 1 + configs/P1020UTM-PC_36BIT_defconfig | 1 + configs/P1020UTM-PC_SDCARD_defconfig | 1 + configs/P1020UTM-PC_defconfig | 1 + configs/P1021RDB-PC_36BIT_NAND_defconfig | 1 + configs/P1021RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P1021RDB-PC_36BIT_defconfig | 1 + configs/P1021RDB-PC_NAND_defconfig | 1 + configs/P1021RDB-PC_SDCARD_defconfig | 1 + configs/P1021RDB-PC_SPIFLASH_defconfig | 1 + configs/P1021RDB-PC_defconfig | 1 + configs/P1022DS_36BIT_NAND_defconfig | 1 + configs/P1022DS_36BIT_SDCARD_defconfig | 1 + configs/P1022DS_36BIT_SPIFLASH_defconfig | 1 + configs/P1022DS_36BIT_defconfig | 1 + configs/P1022DS_NAND_defconfig | 1 + configs/P1022DS_SDCARD_defconfig | 1 + configs/P1022DS_SPIFLASH_defconfig | 1 + configs/P1022DS_defconfig | 1 + configs/P1023RDB_defconfig | 1 + configs/P1024RDB_36BIT_defconfig | 1 + configs/P1024RDB_NAND_defconfig | 1 + configs/P1024RDB_SDCARD_defconfig | 1 + configs/P1024RDB_SPIFLASH_defconfig | 1 + configs/P1024RDB_defconfig | 1 + configs/P1025RDB_36BIT_defconfig | 1 + configs/P1025RDB_NAND_defconfig | 1 + configs/P1025RDB_SDCARD_defconfig | 1 + configs/P1025RDB_SPIFLASH_defconfig | 1 + configs/P1025RDB_defconfig | 1 + configs/P2020RDB-PC_36BIT_NAND_defconfig | 1 + configs/P2020RDB-PC_36BIT_SDCARD_defconfig | 1 + configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig | 1 + configs/P2020RDB-PC_36BIT_defconfig | 1 + configs/P2020RDB-PC_NAND_defconfig | 1 + configs/P2020RDB-PC_SDCARD_defconfig | 1 + configs/P2020RDB-PC_SPIFLASH_defconfig | 1 + configs/P2020RDB-PC_defconfig | 1 + configs/P2041RDB_NAND_defconfig | 1 + configs/P2041RDB_SDCARD_defconfig | 1 + configs/P2041RDB_SECURE_BOOT_defconfig | 1 + configs/P2041RDB_SPIFLASH_defconfig | 1 + configs/P2041RDB_SRIO_PCIE_BOOT_defconfig | 1 + configs/P2041RDB_defconfig | 1 + configs/P3041DS_NAND_SECURE_BOOT_defconfig | 1 + configs/P3041DS_NAND_defconfig | 1 + configs/P3041DS_SDCARD_defconfig | 1 + configs/P3041DS_SECURE_BOOT_defconfig | 1 + configs/P3041DS_SPIFLASH_defconfig | 1 + configs/P3041DS_SRIO_PCIE_BOOT_defconfig | 1 + configs/P3041DS_defconfig | 1 + configs/P4080DS_SDCARD_defconfig | 1 + configs/P4080DS_SECURE_BOOT_defconfig | 1 + configs/P4080DS_SPIFLASH_defconfig | 1 + configs/P4080DS_SRIO_PCIE_BOOT_defconfig | 1 + configs/P4080DS_defconfig | 1 + configs/P5020DS_NAND_SECURE_BOOT_defconfig | 1 + configs/P5020DS_NAND_defconfig | 1 + configs/P5020DS_SDCARD_defconfig | 1 + configs/P5020DS_SECURE_BOOT_defconfig | 1 + configs/P5020DS_SPIFLASH_defconfig | 1 + configs/P5020DS_SRIO_PCIE_BOOT_defconfig | 1 + configs/P5020DS_defconfig | 1 + configs/P5040DS_NAND_SECURE_BOOT_defconfig | 1 + configs/P5040DS_NAND_defconfig | 1 + configs/P5040DS_SDCARD_defconfig | 1 + configs/P5040DS_SECURE_BOOT_defconfig | 1 + configs/P5040DS_SPIFLASH_defconfig | 1 + configs/P5040DS_defconfig | 1 + configs/PIP405_defconfig | 1 + configs/Sinlinx_SinA31s_defconfig | 1 + configs/Sinlinx_SinA33_defconfig | 1 + configs/Sinovoip_BPI_M2_defconfig | 1 + configs/Sinovoip_BPI_M3_defconfig | 3 ++- configs/T1023RDB_NAND_defconfig | 1 + configs/T1023RDB_SDCARD_defconfig | 1 + configs/T1023RDB_SECURE_BOOT_defconfig | 1 + configs/T1023RDB_SPIFLASH_defconfig | 1 + configs/T1023RDB_defconfig | 1 + configs/T1024QDS_DDR4_SECURE_BOOT_defconfig | 1 + configs/T1024QDS_DDR4_defconfig | 1 + configs/T1024QDS_NAND_defconfig | 1 + configs/T1024QDS_SDCARD_defconfig | 1 + configs/T1024QDS_SECURE_BOOT_defconfig | 1 + configs/T1024QDS_SPIFLASH_defconfig | 1 + configs/T1024QDS_defconfig | 1 + configs/T1024RDB_NAND_defconfig | 1 + configs/T1024RDB_SDCARD_defconfig | 1 + configs/T1024RDB_SECURE_BOOT_defconfig | 1 + configs/T1024RDB_SPIFLASH_defconfig | 1 + configs/T1024RDB_defconfig | 1 + configs/T1040D4RDB_NAND_defconfig | 1 + configs/T1040D4RDB_SDCARD_defconfig | 1 + configs/T1040D4RDB_SECURE_BOOT_defconfig | 1 + configs/T1040D4RDB_SPIFLASH_defconfig | 1 + configs/T1040D4RDB_defconfig | 1 + configs/T1040QDS_DDR4_defconfig | 1 + configs/T1040QDS_SECURE_BOOT_defconfig | 1 + configs/T1040QDS_defconfig | 1 + configs/T1040RDB_NAND_defconfig | 1 + configs/T1040RDB_SDCARD_defconfig | 1 + configs/T1040RDB_SECURE_BOOT_defconfig | 1 + configs/T1040RDB_SPIFLASH_defconfig | 1 + configs/T1040RDB_defconfig | 1 + configs/T1042D4RDB_NAND_defconfig | 1 + configs/T1042D4RDB_SDCARD_defconfig | 1 + configs/T1042D4RDB_SECURE_BOOT_defconfig | 1 + configs/T1042D4RDB_SPIFLASH_defconfig | 1 + configs/T1042D4RDB_defconfig | 1 + configs/T1042RDB_PI_NAND_defconfig | 1 + configs/T1042RDB_PI_SDCARD_defconfig | 1 + configs/T1042RDB_PI_SPIFLASH_defconfig | 1 + configs/T1042RDB_PI_defconfig | 1 + configs/T1042RDB_SECURE_BOOT_defconfig | 1 + configs/T1042RDB_defconfig | 1 + configs/T2080QDS_NAND_defconfig | 1 + configs/T2080QDS_SDCARD_defconfig | 1 + configs/T2080QDS_SECURE_BOOT_defconfig | 1 + configs/T2080QDS_SPIFLASH_defconfig | 1 + configs/T2080QDS_SRIO_PCIE_BOOT_defconfig | 1 + configs/T2080QDS_defconfig | 1 + configs/T2080RDB_NAND_defconfig | 1 + configs/T2080RDB_SDCARD_defconfig | 1 + configs/T2080RDB_SECURE_BOOT_defconfig | 1 + configs/T2080RDB_SPIFLASH_defconfig | 1 + configs/T2080RDB_SRIO_PCIE_BOOT_defconfig | 1 + configs/T2080RDB_defconfig | 1 + configs/T2081QDS_NAND_defconfig | 1 + configs/T2081QDS_SDCARD_defconfig | 1 + configs/T2081QDS_SPIFLASH_defconfig | 1 + configs/T2081QDS_SRIO_PCIE_BOOT_defconfig | 1 + configs/T2081QDS_defconfig | 1 + configs/T4160QDS_NAND_defconfig | 1 + configs/T4160QDS_SDCARD_defconfig | 1 + configs/T4160QDS_SECURE_BOOT_defconfig | 1 + configs/T4160QDS_defconfig | 1 + configs/T4160RDB_defconfig | 1 + configs/T4240QDS_NAND_defconfig | 1 + configs/T4240QDS_SDCARD_defconfig | 1 + configs/T4240QDS_SECURE_BOOT_defconfig | 1 + configs/T4240QDS_SRIO_PCIE_BOOT_defconfig | 1 + configs/T4240QDS_defconfig | 1 + configs/T4240RDB_SDCARD_defconfig | 1 + configs/T4240RDB_defconfig | 1 + configs/TQM5200S_HIGHBOOT_defconfig | 1 + configs/TQM5200S_defconfig | 1 + configs/TQM5200_B_HIGHBOOT_defconfig | 1 + configs/TQM5200_B_defconfig | 1 + configs/TQM5200_STK100_defconfig | 1 + configs/TQM5200_defconfig | 1 + configs/TQM823L_LCD_defconfig | 1 + configs/TQM823L_defconfig | 1 + configs/TQM823M_defconfig | 1 + configs/TQM834x_defconfig | 1 + configs/TQM850L_defconfig | 1 + configs/TQM850M_defconfig | 1 + configs/TQM855L_defconfig | 1 + configs/TQM855M_defconfig | 1 + configs/TQM860L_defconfig | 1 + configs/TQM860M_defconfig | 1 + configs/TQM862L_defconfig | 1 + configs/TQM862M_defconfig | 1 + configs/TQM866M_defconfig | 1 + configs/TQM885D_defconfig | 1 + configs/TTTech_defconfig | 1 + configs/TWR-P1025_defconfig | 1 + configs/UCP1020_SPIFLASH_defconfig | 1 + configs/UCP1020_defconfig | 1 + configs/UTOO_P66_defconfig | 1 + configs/VCMA9_defconfig | 1 + configs/Wexler_TAB7200_defconfig | 1 + configs/Wits_Pro_A20_DKT_defconfig | 1 + configs/Wobo_i5_defconfig | 1 + configs/Yones_Toptech_BD1078_defconfig | 1 + configs/Yones_Toptech_BS1078_V2_defconfig | 1 + configs/a3m071_defconfig | 1 + configs/a4m072_defconfig | 1 + configs/a4m2k_defconfig | 1 + configs/acadia_defconfig | 1 + configs/am335x_baltos_defconfig | 1 + configs/am335x_boneblack_defconfig | 1 + configs/am335x_boneblack_vboot_defconfig | 1 + configs/am335x_evm_defconfig | 1 + configs/am335x_evm_nor_defconfig | 1 + configs/am335x_evm_norboot_defconfig | 1 + configs/am335x_evm_spiboot_defconfig | 1 + configs/am335x_evm_usbspl_defconfig | 1 + configs/am335x_gp_evm_defconfig | 1 + configs/am335x_igep0033_defconfig | 1 + configs/am335x_sl50_defconfig | 1 + configs/am3517_crane_defconfig | 1 + configs/am3517_evm_defconfig | 1 + configs/am437x_gp_evm_defconfig | 1 + configs/am437x_sk_evm_defconfig | 1 + configs/am43xx_evm_defconfig | 1 + configs/am43xx_evm_ethboot_defconfig | 1 + configs/am43xx_evm_qspiboot_defconfig | 1 + configs/am43xx_evm_usbhost_boot_defconfig | 1 + configs/am57xx_evm_defconfig | 1 + configs/am57xx_evm_nodt_defconfig | 1 + configs/apalis_t30_defconfig | 1 + configs/apf27_defconfig | 1 + configs/apx4devkit_defconfig | 1 + configs/arches_defconfig | 1 + configs/aria_defconfig | 1 + configs/aristainetos2_defconfig | 1 + configs/aristainetos2b_defconfig | 1 + configs/aristainetos_defconfig | 1 + configs/arndale_defconfig | 1 + configs/astro_mcf5373l_defconfig | 1 + configs/at91rm9200ek_defconfig | 1 + configs/at91rm9200ek_ram_defconfig | 1 + configs/at91sam9263ek_dataflash_cs0_defconfig | 1 + configs/at91sam9263ek_dataflash_defconfig | 1 + configs/at91sam9263ek_nandflash_defconfig | 1 + configs/at91sam9263ek_norflash_boot_defconfig | 1 + configs/at91sam9263ek_norflash_defconfig | 1 + configs/at91sam9m10g45ek_mmc_defconfig | 1 + configs/at91sam9m10g45ek_nandflash_defconfig | 1 + configs/at91sam9n12ek_mmc_defconfig | 1 + configs/at91sam9n12ek_nandflash_defconfig | 1 + configs/at91sam9n12ek_spiflash_defconfig | 1 + configs/at91sam9x5ek_dataflash_defconfig | 1 + configs/at91sam9x5ek_mmc_defconfig | 1 + configs/at91sam9x5ek_nandflash_defconfig | 1 + configs/at91sam9x5ek_spiflash_defconfig | 1 + configs/ba10_tv_box_defconfig | 1 + configs/bamboo_defconfig | 1 + configs/bayleybay_defconfig | 1 + configs/bcm11130_defconfig | 1 + configs/bcm11130_nand_defconfig | 1 + configs/bcm28155_ap_defconfig | 1 + configs/bcm28155_w1d_defconfig | 1 + configs/bcm911360_entphn-ns_defconfig | 1 + configs/bcm911360_entphn_defconfig | 1 + configs/bcm911360k_defconfig | 1 + configs/bcm958300k-ns_defconfig | 1 + configs/bcm958300k_defconfig | 1 + configs/bcm958305k_defconfig | 1 + configs/bcm958622hr_defconfig | 1 + configs/bct-brettl2_defconfig | 1 + configs/beaver_defconfig | 1 + configs/bg0900_defconfig | 1 + configs/birdland_bav335a_defconfig | 1 + configs/birdland_bav335b_defconfig | 1 + configs/bubinga_defconfig | 1 + configs/caddy2_defconfig | 1 + configs/cairo_defconfig | 1 + configs/calimain_defconfig | 1 + configs/cam5200_defconfig | 1 + configs/cam5200_niosflash_defconfig | 1 + configs/canyonlands_defconfig | 1 + configs/cardhu_defconfig | 1 + configs/cgtqmx6eval_defconfig | 1 + configs/charon_defconfig | 1 + configs/chromebook_jerry_defconfig | 1 + configs/chromebook_link_defconfig | 1 + configs/chromebook_samus_defconfig | 1 + configs/chromebox_panther_defconfig | 1 + configs/cm_fx6_defconfig | 1 + configs/cm_t335_defconfig | 1 + configs/cm_t3517_defconfig | 1 + configs/cm_t35_defconfig | 1 + configs/cm_t43_defconfig | 1 + configs/cm_t54_defconfig | 1 + configs/colibri_pxa270_defconfig | 1 + configs/colibri_t20_defconfig | 1 + configs/colibri_t30_defconfig | 1 + configs/colibri_vf_defconfig | 1 + configs/colorfly_e708_q1_defconfig | 1 + configs/conga-qeval20-qa3-e3845_defconfig | 1 + configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig | 1 + configs/controlcenterd_36BIT_SDCARD_defconfig | 1 + configs/coreboot-x86_defconfig | 1 + configs/corvus_defconfig | 1 + configs/cougarcanyon2_defconfig | 1 + configs/crownbay_defconfig | 1 + configs/d2net_v2_defconfig | 1 + configs/da850_am18xxevm_defconfig | 1 + configs/da850evm_defconfig | 1 + configs/da850evm_direct_nor_defconfig | 1 + configs/dalmore_defconfig | 1 + configs/devconcenter_defconfig | 1 + configs/devkit8000_defconfig | 1 + configs/difrnce_dit4350_defconfig | 1 + configs/digsy_mtc_RAMBOOT_defconfig | 1 + configs/digsy_mtc_defconfig | 1 + configs/digsy_mtc_rev5_RAMBOOT_defconfig | 1 + configs/digsy_mtc_rev5_defconfig | 1 + configs/dlvision-10g_defconfig | 1 + configs/dlvision_defconfig | 1 + configs/dns325_defconfig | 1 + configs/dra72_evm_defconfig | 1 + configs/dra74_evm_defconfig | 1 + configs/dra7xx_evm_defconfig | 1 + configs/dra7xx_evm_qspiboot_defconfig | 1 + configs/dra7xx_evm_uart3_defconfig | 1 + configs/draco_defconfig | 1 + configs/dragonboard410c_defconfig | 1 + configs/dserve_dsrv9703c_defconfig | 2 +- configs/duovero_defconfig | 1 + configs/e2220-1170_defconfig | 1 + configs/ea20_defconfig | 1 + configs/eco5pk_defconfig | 1 + configs/edb9315a_defconfig | 1 + configs/edminiv2_defconfig | 1 + configs/efi-x86_defconfig | 1 + configs/ethernut5_defconfig | 1 + configs/evb-rk3036_defconfig | 1 + configs/firefly-rk3288_defconfig | 1 + configs/flea3_defconfig | 1 + configs/fo300_defconfig | 1 + configs/ga10h_v1_1_defconfig | 1 + configs/galileo_defconfig | 1 + configs/gdppc440etx_defconfig | 1 + configs/ge_b450v3_defconfig | 1 + configs/ge_b650v3_defconfig | 1 + configs/ge_b850v3_defconfig | 1 + configs/glacier_defconfig | 1 + configs/glacier_ramboot_defconfig | 1 + configs/grasshopper_defconfig | 1 + configs/gt90h_v4_defconfig | 1 + configs/gwventana_defconfig | 1 + configs/h2200_defconfig | 1 + configs/h8_homlet_v2_defconfig | 1 + configs/haleakala_defconfig | 1 + configs/harmony_defconfig | 5 +++-- configs/highbank_defconfig | 1 + configs/hikey_defconfig | 1 + configs/hrcon_defconfig | 1 + configs/hrcon_dh_defconfig | 1 + configs/i12-tvbox_defconfig | 1 + configs/iNet_3F_defconfig | 1 + configs/iNet_3W_defconfig | 1 + configs/iNet_86VS_defconfig | 1 + configs/icnova-a20-swac_defconfig | 1 + configs/icon_defconfig | 1 + configs/ids8313_defconfig | 1 + configs/igep0020_defconfig | 1 + configs/igep0020_nand_defconfig | 1 + configs/igep0030_defconfig | 1 + configs/igep0030_nand_defconfig | 1 + configs/igep0032_defconfig | 1 + configs/inet1_defconfig | 1 + configs/inet97fv2_defconfig | 1 + configs/inet98v_rev2_defconfig | 1 + configs/inet9f_rev03_defconfig | 1 + configs/inetspace_v2_defconfig | 1 + configs/integratorap_cm720t_defconfig | 1 + configs/integratorap_cm920t_defconfig | 1 + configs/integratorap_cm926ejs_defconfig | 1 + configs/integratorap_cm946es_defconfig | 1 + configs/integratorcp_cm1136_defconfig | 1 + configs/integratorcp_cm920t_defconfig | 1 + configs/integratorcp_cm926ejs_defconfig | 1 + configs/integratorcp_cm946es_defconfig | 1 + configs/intip_defconfig | 1 + configs/io64_defconfig | 1 + configs/io_defconfig | 1 + configs/iocon_defconfig | 1 + configs/ipam390_defconfig | 1 + configs/jesurun_q5_defconfig | 1 + configs/jetson-tk1_defconfig | 1 + configs/jupiter_defconfig | 1 + configs/k2e_evm_defconfig | 5 +++-- configs/k2g_evm_defconfig | 1 + configs/k2hk_evm_defconfig | 5 +++-- configs/k2l_evm_defconfig | 5 +++-- configs/katmai_defconfig | 1 + configs/kc1_defconfig | 1 + configs/kilauea_defconfig | 1 + configs/km_kirkwood_128m16_defconfig | 1 + configs/km_kirkwood_defconfig | 1 + configs/km_kirkwood_pci_defconfig | 1 + configs/kmcoge4_defconfig | 1 + configs/kmcoge5ne_defconfig | 1 + configs/kmcoge5un_defconfig | 1 + configs/kmeter1_defconfig | 1 + configs/kmlion1_defconfig | 1 + configs/kmnusa_defconfig | 1 + configs/kmopti2_defconfig | 1 + configs/kmsugp1_defconfig | 1 + configs/kmsupx5_defconfig | 1 + configs/kmsuv31_defconfig | 1 + configs/kmtegr1_defconfig | 1 + configs/kmtepr2_defconfig | 1 + configs/kmvect1_defconfig | 1 + configs/kylin-rk3036_defconfig | 1 + configs/legoev3_defconfig | 1 + configs/ls1021aqds_ddr4_nor_defconfig | 1 + configs/ls1021aqds_ddr4_nor_lpuart_defconfig | 1 + configs/ls1021aqds_nand_defconfig | 1 + configs/ls1021aqds_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021aqds_nor_defconfig | 1 + configs/ls1021aqds_nor_lpuart_defconfig | 1 + configs/ls1021aqds_qspi_defconfig | 1 + configs/ls1021aqds_sdcard_ifc_defconfig | 1 + configs/ls1021aqds_sdcard_qspi_defconfig | 1 + configs/ls1021atwr_nor_SECURE_BOOT_defconfig | 1 + configs/ls1021atwr_nor_defconfig | 1 + configs/ls1021atwr_nor_lpuart_defconfig | 1 + configs/ls1021atwr_qspi_defconfig | 1 + configs/ls1021atwr_sdcard_ifc_defconfig | 1 + configs/ls1021atwr_sdcard_qspi_defconfig | 1 + configs/ls1043aqds_defconfig | 1 + configs/ls1043aqds_lpuart_defconfig | 1 + configs/ls1043aqds_nand_defconfig | 1 + configs/ls1043aqds_nor_ddr3_defconfig | 1 + configs/ls1043aqds_qspi_defconfig | 1 + configs/ls1043aqds_sdcard_ifc_defconfig | 1 + configs/ls1043aqds_sdcard_qspi_defconfig | 1 + configs/ls1043ardb_SECURE_BOOT_defconfig | 1 + configs/ls1043ardb_defconfig | 1 + configs/ls1043ardb_nand_defconfig | 1 + configs/ls1043ardb_sdcard_defconfig | 1 + configs/ls2080a_emu_defconfig | 1 + configs/ls2080a_simu_defconfig | 1 + configs/ls2080aqds_SECURE_BOOT_defconfig | 1 + configs/ls2080aqds_defconfig | 1 + configs/ls2080aqds_nand_defconfig | 1 + configs/ls2080ardb_SECURE_BOOT_defconfig | 1 + configs/ls2080ardb_defconfig | 1 + configs/ls2080ardb_nand_defconfig | 1 + configs/lschlv2_defconfig | 1 + configs/lsxhl_defconfig | 1 + configs/luan_defconfig | 1 + configs/lwmon5_defconfig | 1 + configs/m28evk_defconfig | 1 + configs/m53evk_defconfig | 1 + configs/ma5d4evk_defconfig | 1 + configs/makalu_defconfig | 1 + configs/malta_defconfig | 1 + configs/maltael_defconfig | 1 + configs/marsboard_defconfig | 1 + configs/mcx_defconfig | 5 +++-- configs/mecp5123_defconfig | 1 + configs/medcom-wide_defconfig | 1 + configs/meesc_dataflash_defconfig | 1 + configs/meesc_defconfig | 1 + configs/mgcoge3ne_defconfig | 1 + configs/mgcoge3un_defconfig | 1 + configs/mgcoge_defconfig | 1 + configs/minnowmax_defconfig | 1 + configs/mixtile_loftq_defconfig | 1 + configs/mk802_a10s_defconfig | 1 + configs/mk802_defconfig | 1 + configs/mk802ii_defconfig | 1 + configs/motionpro_defconfig | 1 + configs/mpc5121ads_defconfig | 1 + configs/mpc5121ads_rev2_defconfig | 1 + configs/mpc8308_p1m_defconfig | 1 + configs/mt_ventoux_defconfig | 5 +++-- configs/mx23_olinuxino_defconfig | 1 + configs/mx23evk_defconfig | 1 + configs/mx25pdk_defconfig | 1 + configs/mx28evk_auart_console_defconfig | 1 + configs/mx28evk_defconfig | 1 + configs/mx28evk_nand_defconfig | 1 + configs/mx28evk_spi_defconfig | 1 + configs/mx35pdk_defconfig | 1 + configs/mx51evk_defconfig | 1 + configs/mx53ard_defconfig | 1 + configs/mx53evk_defconfig | 1 + configs/mx53loco_defconfig | 1 + configs/mx53smd_defconfig | 1 + configs/mx6cuboxi_defconfig | 1 + configs/mx6dlarm2_defconfig | 1 + configs/mx6dlarm2_lpddr2_defconfig | 1 + configs/mx6dlsabreauto_defconfig | 1 + configs/mx6dlsabresd_defconfig | 1 + configs/mx6qarm2_defconfig | 1 + configs/mx6qarm2_lpddr2_defconfig | 1 + configs/mx6qpsabreauto_defconfig | 1 + configs/mx6qsabreauto_defconfig | 1 + configs/mx6qsabrelite_defconfig | 1 + configs/mx6qsabresd_defconfig | 1 + configs/mx6sabresd_spl_defconfig | 1 + configs/mx6slevk_defconfig | 1 + configs/mx6slevk_spinor_defconfig | 1 + configs/mx6slevk_spl_defconfig | 1 + configs/mx6sxsabreauto_defconfig | 1 + configs/mx6sxsabresd_defconfig | 1 + configs/mx6sxsabresd_spl_defconfig | 1 + configs/mx6ul_14x14_evk_defconfig | 1 + configs/mx6ul_9x9_evk_defconfig | 1 + configs/mx7dsabresd_defconfig | 1 + configs/nas220_defconfig | 1 + configs/neo_defconfig | 1 + configs/net2big_v2_defconfig | 1 + configs/netspace_lite_v2_defconfig | 1 + configs/netspace_max_v2_defconfig | 1 + configs/netspace_mini_v2_defconfig | 1 + configs/netspace_v2_defconfig | 1 + configs/nitrogen6dl2g_defconfig | 1 + configs/nitrogen6dl_defconfig | 1 + configs/nitrogen6q2g_defconfig | 1 + configs/nitrogen6q_defconfig | 1 + configs/nitrogen6s1g_defconfig | 1 + configs/nitrogen6s_defconfig | 1 + configs/nokia_rx51_defconfig | 1 + configs/novena_defconfig | 1 + configs/nyan-big_defconfig | 1 + configs/odroid-xu3_defconfig | 1 + configs/odroid_defconfig | 1 + configs/omap3_beagle_defconfig | 1 + configs/omap3_evm_defconfig | 1 + configs/omap3_ha_defconfig | 1 + configs/omap3_logic_defconfig | 1 + configs/omap3_overo_defconfig | 1 + configs/omap3_pandora_defconfig | 1 + configs/omap3_zoom1_defconfig | 1 + configs/omap4_panda_defconfig | 1 + configs/omap4_sdp4430_defconfig | 1 + configs/omap5_uevm_defconfig | 1 + configs/omapl138_lcdk_defconfig | 1 + configs/orangepi_2_defconfig | 3 ++- configs/orangepi_one_defconfig | 2 +- configs/orangepi_pc_defconfig | 4 +--- configs/orangepi_plus_defconfig | 5 +++-- configs/origen_defconfig | 1 + configs/ot1200_defconfig | 1 + configs/ot1200_spl_defconfig | 1 + configs/p2371-0000_defconfig | 1 + configs/p2371-2180_defconfig | 1 + configs/p2571_defconfig | 1 + configs/paz00_defconfig | 1 + configs/pcm051_rev1_defconfig | 1 + configs/pcm051_rev3_defconfig | 1 + configs/pcm052_defconfig | 1 + configs/pdm360ng_defconfig | 1 + configs/peach-pi_defconfig | 1 + configs/peach-pit_defconfig | 1 + configs/pengwyn_defconfig | 1 + configs/pepper_defconfig | 1 + configs/pic32mzdask_defconfig | 2 +- configs/picosam9g45_defconfig | 1 + configs/pine64_plus_defconfig | 1 + configs/platinum_picon_defconfig | 1 + configs/platinum_titanium_defconfig | 1 + configs/plutux_defconfig | 1 + configs/pm9g45_defconfig | 1 + configs/polaroid_mid2809pxe04_defconfig | 1 + configs/portl2_defconfig | 1 + configs/pov_protab2_ips9_defconfig | 1 + configs/pxm2_defconfig | 1 + configs/q8_a13_tablet_defconfig | 1 + configs/q8_a23_tablet_800x480_defconfig | 1 + configs/q8_a33_tablet_1024x600_defconfig | 1 + configs/q8_a33_tablet_800x480_defconfig | 1 + configs/qemu-ppce500_defconfig | 1 + configs/qemu-x86_defconfig | 1 + configs/qemu_mips64_defconfig | 1 + configs/qemu_mips64el_defconfig | 1 + configs/qemu_mips_defconfig | 1 + configs/qemu_mipsel_defconfig | 1 + configs/r2dplus_defconfig | 1 - configs/r7-tv-dongle_defconfig | 1 + configs/rainier_defconfig | 1 + configs/rainier_ramboot_defconfig | 1 + configs/rastaban_defconfig | 1 + configs/redwood_defconfig | 1 + configs/riotboard_defconfig | 1 + configs/rock2_defconfig | 1 + configs/rpi_2_defconfig | 1 + configs/rpi_3_32b_defconfig | 1 + configs/rpi_3_defconfig | 1 + configs/rpi_defconfig | 1 + configs/rut_defconfig | 1 + configs/s5p_goni_defconfig | 1 + configs/s5pc210_universal_defconfig | 1 + configs/sama5d2_xplained_mmc_defconfig | 1 + configs/sama5d2_xplained_spiflash_defconfig | 1 + configs/sama5d3_xplained_mmc_defconfig | 1 + configs/sama5d3_xplained_nandflash_defconfig | 1 + configs/sama5d3xek_mmc_defconfig | 1 + configs/sama5d3xek_nandflash_defconfig | 1 + configs/sama5d3xek_spiflash_defconfig | 1 + configs/sama5d4_xplained_mmc_defconfig | 1 + configs/sama5d4_xplained_nandflash_defconfig | 1 + configs/sama5d4_xplained_spiflash_defconfig | 1 + configs/sama5d4ek_mmc_defconfig | 1 + configs/sama5d4ek_nandflash_defconfig | 1 + configs/sama5d4ek_spiflash_defconfig | 1 + configs/sandbox_defconfig | 1 + configs/sansa_fuze_plus_defconfig | 1 + configs/sbc8349_PCI_33_defconfig | 1 + configs/sbc8349_PCI_66_defconfig | 1 + configs/sbc8349_defconfig | 1 + configs/sbc8548_PCI_33_PCIE_defconfig | 1 + configs/sbc8548_PCI_33_defconfig | 1 + configs/sbc8548_PCI_66_PCIE_defconfig | 1 + configs/sbc8548_PCI_66_defconfig | 1 + configs/sbc8548_defconfig | 1 + configs/sbc8641d_defconfig | 1 + configs/sc_sps_1_defconfig | 1 + configs/seaboard_defconfig | 1 + configs/secomx6quq7_defconfig | 1 + configs/sequoia_defconfig | 1 + configs/sequoia_ramboot_defconfig | 1 + configs/smartweb_defconfig | 1 + configs/smdk2410_defconfig | 1 + configs/smdk5250_defconfig | 1 + configs/smdk5420_defconfig | 1 + configs/smdkc100_defconfig | 1 + configs/smdkv310_defconfig | 1 + configs/snapper9260_defconfig | 1 + configs/snapper9g20_defconfig | 1 + configs/sniper_defconfig | 1 + configs/snow_defconfig | 1 + configs/socfpga_arria5_defconfig | 3 ++- configs/socfpga_cyclone5_defconfig | 3 ++- configs/socfpga_de0_nano_soc_defconfig | 2 +- configs/socfpga_mcvevk_defconfig | 2 +- configs/socfpga_sockit_defconfig | 3 ++- configs/socfpga_socrates_defconfig | 3 ++- configs/socfpga_sr1500_defconfig | 3 ++- configs/socrates_defconfig | 1 + configs/spring_defconfig | 1 + configs/stm32f429-discovery_defconfig | 1 + configs/stm32f746-disco_defconfig | 1 + configs/strider_con_defconfig | 1 + configs/strider_cpu_defconfig | 1 + configs/sunxi_Gemei_G9_defconfig | 1 + configs/suvd3_defconfig | 1 + configs/sycamore_defconfig | 1 + configs/t3corp_defconfig | 1 + configs/tao3530_defconfig | 1 + configs/tbs2910_defconfig | 1 + configs/tec-ng_defconfig | 1 + configs/tec_defconfig | 1 + configs/theadorable_debug_defconfig | 1 + configs/theadorable_defconfig | 1 + configs/thuban_defconfig | 1 + configs/ti814x_evm_defconfig | 1 + configs/ti816x_evm_defconfig | 1 + configs/titanium_defconfig | 1 + configs/tqma6q_mba6_mmc_defconfig | 1 + configs/tqma6q_mba6_spi_defconfig | 1 + configs/tqma6s_mba6_mmc_defconfig | 1 + configs/tqma6s_mba6_spi_defconfig | 1 + configs/tqma6s_wru4_mmc_defconfig | 1 + configs/trats2_defconfig | 1 + configs/trats_defconfig | 1 + configs/tricorder_defconfig | 1 + configs/tricorder_flash_defconfig | 1 + configs/trimslice_defconfig | 1 + configs/ts4800_defconfig | 1 + configs/tuge1_defconfig | 1 + configs/tuxx1_defconfig | 1 + configs/twister_defconfig | 5 +++-- configs/udoo_defconfig | 1 + configs/usb_a9263_dataflash_defconfig | 1 + configs/usbarmory_defconfig | 1 + configs/ve8313_defconfig | 1 + configs/venice2_defconfig | 1 + configs/ventana_defconfig | 1 + configs/vexpress_aemv8a_dram_defconfig | 1 + configs/vexpress_aemv8a_juno_defconfig | 1 + configs/vexpress_aemv8a_semi_defconfig | 1 + configs/vexpress_ca15_tc2_defconfig | 1 + configs/vexpress_ca5x2_defconfig | 1 + configs/vexpress_ca9x4_defconfig | 1 + configs/vf610twr_defconfig | 1 + configs/vf610twr_nand_defconfig | 1 + configs/vinco_defconfig | 1 + configs/vme8349_defconfig | 1 + configs/walnut_defconfig | 1 + configs/wandboard_defconfig | 1 + configs/warp7_defconfig | 1 + configs/warp_defconfig | 1 + configs/whistler_defconfig | 1 + configs/woodburn_defconfig | 1 + configs/woodburn_sd_defconfig | 1 + configs/work_92105_defconfig | 1 + configs/wtk_defconfig | 1 + configs/x600_defconfig | 1 + configs/xfi3_defconfig | 1 + configs/xilinx-ppc405-generic_defconfig | 1 + configs/xilinx-ppc440-generic_defconfig | 1 + configs/xpedite1000_defconfig | 1 + configs/xpedite517x_defconfig | 1 + configs/xpedite520x_defconfig | 1 + configs/xpedite537x_defconfig | 1 + configs/xpedite550x_defconfig | 1 + configs/xpress_defconfig | 1 + configs/xpress_spl_defconfig | 1 + configs/yellowstone_defconfig | 1 + configs/yosemite_defconfig | 1 + configs/yucca_defconfig | 1 + configs/zipitz2_defconfig | 1 + configs/zmx25_defconfig | 1 + configs/zynq_microzed_defconfig | 1 + configs/zynq_picozed_defconfig | 1 + configs/zynq_zc702_defconfig | 1 + configs/zynq_zc706_defconfig | 1 + configs/zynq_zc770_xm010_defconfig | 1 + configs/zynq_zc770_xm011_defconfig | 1 + configs/zynq_zc770_xm012_defconfig | 1 + configs/zynq_zc770_xm013_defconfig | 1 + configs/zynq_zed_defconfig | 1 + configs/zynq_zybo_defconfig | 1 + include/config_distro_defaults.h | 1 - include/config_fallbacks.h | 1 - include/configs/B4860QDS.h | 5 ----- include/configs/BSC9131RDB.h | 6 ------ include/configs/BSC9132QDS.h | 6 ------ include/configs/C29XPCIE.h | 3 --- include/configs/CPCI2DP.h | 1 - include/configs/CPCI4052.h | 1 - include/configs/M54418TWR.h | 4 ---- include/configs/MIP405.h | 1 - include/configs/MPC8308RDB.h | 5 ----- include/configs/MPC8313ERDB.h | 3 --- include/configs/MPC8315ERDB.h | 3 --- include/configs/MPC8323ERDB.h | 2 -- include/configs/MPC832XEMDS.h | 2 -- include/configs/MPC8349EMDS.h | 2 -- include/configs/MPC8349ITX.h | 1 - include/configs/MPC837XEMDS.h | 3 --- include/configs/MPC837XERDB.h | 3 --- include/configs/MPC8536DS.h | 3 --- include/configs/MPC8540ADS.h | 5 ----- include/configs/MPC8541CDS.h | 5 ----- include/configs/MPC8544DS.h | 3 --- include/configs/MPC8548CDS.h | 3 --- include/configs/MPC8555CDS.h | 5 ----- include/configs/MPC8560ADS.h | 5 ----- include/configs/MPC8568MDS.h | 5 ----- include/configs/MPC8569MDS.h | 5 ----- include/configs/MPC8572DS.h | 3 --- include/configs/MPC8610HPCD.h | 3 --- include/configs/MPC8641HPCN.h | 3 --- include/configs/P1010RDB.h | 3 --- include/configs/P1022DS.h | 3 --- include/configs/P1023RDB.h | 3 --- include/configs/P2041RDB.h | 3 --- include/configs/PIP405.h | 1 - include/configs/PLU405.h | 1 - include/configs/T102xQDS.h | 4 ---- include/configs/T102xRDB.h | 4 ---- include/configs/T1040QDS.h | 4 ---- include/configs/T104xRDB.h | 4 ---- include/configs/T208xQDS.h | 4 ---- include/configs/T208xRDB.h | 4 ---- include/configs/T4240RDB.h | 4 ---- include/configs/TQM5200.h | 1 - include/configs/TQM823L.h | 1 - include/configs/TQM823M.h | 1 - include/configs/TQM834x.h | 1 - include/configs/TQM850L.h | 1 - include/configs/TQM850M.h | 1 - include/configs/TQM855L.h | 1 - include/configs/TQM855M.h | 1 - include/configs/TQM860L.h | 1 - include/configs/TQM860M.h | 1 - include/configs/TQM862L.h | 1 - include/configs/TQM862M.h | 1 - include/configs/TQM866M.h | 1 - include/configs/TQM885D.h | 1 - include/configs/UCP1020.h | 3 --- include/configs/VCMA9.h | 1 - include/configs/VOM405.h | 1 - include/configs/a3m071.h | 2 -- include/configs/a4m072.h | 1 - include/configs/am3517_crane.h | 1 - include/configs/am3517_evm.h | 1 - include/configs/amcc-common.h | 1 - include/configs/apf27.h | 2 -- include/configs/aria.h | 4 ---- include/configs/astro_mcf5373l.h | 1 - include/configs/at91-sama5_common.h | 1 - include/configs/at91rm9200ek.h | 1 - include/configs/at91sam9263ek.h | 1 - include/configs/at91sam9m10g45ek.h | 1 - include/configs/at91sam9n12ek.h | 1 - include/configs/at91sam9x5ek.h | 1 - include/configs/bcm28155_ap.h | 1 - include/configs/bcm_ep_board.h | 1 - include/configs/bct-brettl2.h | 1 - include/configs/calimain.h | 1 - include/configs/cm_t35.h | 1 - include/configs/cm_t3517.h | 1 - include/configs/colibri_pxa270.h | 7 +------ include/configs/colibri_vf.h | 2 -- include/configs/controlcenterd.h | 1 - include/configs/corenet_ds.h | 3 --- include/configs/corvus.h | 1 - include/configs/cyrus.h | 4 ---- include/configs/da850evm.h | 1 - include/configs/digsy_mtc.h | 1 - include/configs/dns325.h | 5 ----- include/configs/ea20.h | 1 - include/configs/edb93xx.h | 2 -- include/configs/edminiv2.h | 3 --- include/configs/ethernut5.h | 1 - include/configs/flea3.h | 1 - include/configs/ge_bx50v3.h | 2 -- include/configs/grasshopper.h | 1 - include/configs/grsim.h | 1 - include/configs/grsim_leon2.h | 1 - include/configs/h2200.h | 2 -- include/configs/hikey.h | 1 - include/configs/hrcon.h | 3 --- include/configs/ids8313.h | 2 -- include/configs/integrator-common.h | 1 - include/configs/ipam390.h | 1 - include/configs/jupiter.h | 1 - include/configs/kc1.h | 1 - include/configs/km/keymile-common.h | 1 - include/configs/km/kmp204x-common.h | 3 --- include/configs/lacie_kw.h | 5 ----- include/configs/legoev3.h | 1 - include/configs/ls1021aqds.h | 2 -- include/configs/ls1021atwr.h | 2 -- include/configs/ls1043a_common.h | 2 -- include/configs/ls1043aqds.h | 2 -- include/configs/ls2080a_common.h | 2 -- include/configs/lsxl.h | 2 -- include/configs/lwmon5.h | 1 - include/configs/m53evk.h | 1 - include/configs/malta.h | 1 - include/configs/mcx.h | 1 - include/configs/mecp5123.h | 4 ---- include/configs/meesc.h | 1 - include/configs/motionpro.h | 2 -- include/configs/mpc5121-common.h | 2 -- include/configs/mpc5121ads.h | 4 ---- include/configs/mpc8308_p1m.h | 3 --- include/configs/mx25pdk.h | 1 - include/configs/mx35pdk.h | 1 - include/configs/mx51evk.h | 1 - include/configs/mx53ard.h | 1 - include/configs/mx53evk.h | 1 - include/configs/mx53loco.h | 1 - include/configs/mx53smd.h | 1 - include/configs/mx6_common.h | 1 - include/configs/mx7_common.h | 1 - include/configs/mxs.h | 2 -- include/configs/nas220.h | 2 -- include/configs/nokia_rx51.h | 2 -- include/configs/o2dnt-common.h | 1 - include/configs/omap3_evm.h | 1 - include/configs/omapl138_lcdk.h | 2 -- include/configs/p1_p2_rdb_pc.h | 3 --- include/configs/p1_twr.h | 6 ------ include/configs/pcm052.h | 2 -- include/configs/picosam9g45.h | 1 - include/configs/pm9g45.h | 1 - include/configs/qemu-mips.h | 1 - include/configs/qemu-mips64.h | 1 - include/configs/qemu-ppce500.h | 4 ---- include/configs/s5p_goni.h | 1 - include/configs/sandbox.h | 1 - include/configs/sbc8349.h | 2 -- include/configs/sbc8548.h | 3 --- include/configs/sbc8641d.h | 5 ----- include/configs/siemens-am33x-common.h | 2 -- include/configs/smartweb.h | 2 -- include/configs/smdk2410.h | 1 - include/configs/smdkc100.h | 1 - include/configs/snapper9260.h | 1 - include/configs/sniper.h | 1 - include/configs/socfpga_common.h | 1 - include/configs/socrates.h | 1 - include/configs/stm32f429-discovery.h | 1 - include/configs/stm32f746-disco.h | 1 - include/configs/strider.h | 3 --- include/configs/t4qds.h | 4 ---- include/configs/tam3517-common.h | 1 - include/configs/tao3530.h | 1 - include/configs/theadorable.h | 2 -- include/configs/thunderx_88xx.h | 1 - include/configs/ti814x_evm.h | 1 - include/configs/ti816x_evm.h | 1 - include/configs/ti_armv7_common.h | 1 - include/configs/tricorder.h | 1 - include/configs/ts4800.h | 1 - include/configs/usb_a9263.h | 1 - include/configs/ve8313.h | 3 --- include/configs/vexpress_aemv8a.h | 1 - include/configs/vexpress_common.h | 1 - include/configs/vf610twr.h | 2 -- include/configs/vme8349.h | 2 -- include/configs/woodburn_common.h | 1 - include/configs/work_92105.h | 1 - include/configs/x600.h | 2 -- include/configs/x86-common.h | 1 - include/configs/xilinx-ppc.h | 1 - include/configs/xpedite1000.h | 5 ----- include/configs/xpedite517x.h | 5 ----- include/configs/xpedite520x.h | 5 ----- include/configs/xpedite537x.h | 5 ----- include/configs/xpedite550x.h | 5 ----- include/configs/zipitz2.h | 5 ----- include/configs/zmx25.h | 1 - include/configs/zynq-common.h | 1 - 1080 files changed, 909 insertions(+), 441 deletions(-)
diff --git a/configs/A10-OLinuXino-Lime_defconfig b/configs/A10-OLinuXino-Lime_defconfig index 8cb7ac7..f034f1f 100644 --- a/configs/A10-OLinuXino-Lime_defconfig +++ b/configs/A10-OLinuXino-Lime_defconfig @@ -9,6 +9,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-olinuxino-lime" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,AHCI,SATAPWR=SUNXI_GPC(3)" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/A10s-OLinuXino-M_defconfig b/configs/A10s-OLinuXino-M_defconfig index 6a0d815..6679b04 100644 --- a/configs/A10s-OLinuXino-M_defconfig +++ b/configs/A10s-OLinuXino-M_defconfig @@ -10,6 +10,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-olinuxino-micro" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/A13-OLinuXinoM_defconfig b/configs/A13-OLinuXinoM_defconfig index a790856..be6ff9f 100644 --- a/configs/A13-OLinuXinoM_defconfig +++ b/configs/A13-OLinuXinoM_defconfig @@ -14,6 +14,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-olinuxino-micro" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/A13-OLinuXino_defconfig b/configs/A13-OLinuXino_defconfig index 77a1228..1934cf8 100644 --- a/configs/A13-OLinuXino_defconfig +++ b/configs/A13-OLinuXino_defconfig @@ -16,6 +16,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-olinuxino" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/A20-OLinuXino-Lime2_defconfig b/configs/A20-OLinuXino-Lime2_defconfig index cc5858e..5d6da22 100644 --- a/configs/A20-OLinuXino-Lime2_defconfig +++ b/configs/A20-OLinuXino-Lime2_defconfig @@ -9,6 +9,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-lime2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,AHCI,SATAPWR=SUNXI_GPC(3)" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/A20-OLinuXino-Lime_defconfig b/configs/A20-OLinuXino-Lime_defconfig index 7b0309c..58748a7 100644 --- a/configs/A20-OLinuXino-Lime_defconfig +++ b/configs/A20-OLinuXino-Lime_defconfig @@ -7,6 +7,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-lime" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPC(3)" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/A20-OLinuXino_MICRO_defconfig b/configs/A20-OLinuXino_MICRO_defconfig index 9507b87..e01d722 100644 --- a/configs/A20-OLinuXino_MICRO_defconfig +++ b/configs/A20-OLinuXino_MICRO_defconfig @@ -10,6 +10,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-micro" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPB(8)" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/A20-Olimex-SOM-EVB_defconfig b/configs/A20-Olimex-SOM-EVB_defconfig index 40f8c98..e19f872 100644 --- a/configs/A20-Olimex-SOM-EVB_defconfig +++ b/configs/A20-Olimex-SOM-EVB_defconfig @@ -12,6 +12,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olimex-som-evb" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,AHCI,SATAPWR=SUNXI_GPC(3)" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Ainol_AW1_defconfig b/configs/Ainol_AW1_defconfig index fc1be7d..486baed 100644 --- a/configs/Ainol_AW1_defconfig +++ b/configs/Ainol_AW1_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-ainol-aw1" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Ampe_A76_defconfig b/configs/Ampe_A76_defconfig index 8262be5..ce34985 100644 --- a/configs/Ampe_A76_defconfig +++ b/configs/Ampe_A76_defconfig @@ -16,6 +16,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-ampe-a76" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Auxtek-T003_defconfig b/configs/Auxtek-T003_defconfig index 44f3982..bea5100 100644 --- a/configs/Auxtek-T003_defconfig +++ b/configs/Auxtek-T003_defconfig @@ -8,6 +8,7 @@ CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-auxtek-t003" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Auxtek-T004_defconfig b/configs/Auxtek-T004_defconfig index 9d5365d..6f0362f 100644 --- a/configs/Auxtek-T004_defconfig +++ b/configs/Auxtek-T004_defconfig @@ -6,6 +6,7 @@ CONFIG_USB1_VBUS_PIN="PG13" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-auxtek-t004" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/B4420QDS_NAND_defconfig b/configs/B4420QDS_NAND_defconfig index 0e2b0a8..d9804d7 100644 --- a/configs/B4420QDS_NAND_defconfig +++ b/configs/B4420QDS_NAND_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_B4420,RAMBOOT_PBL,SPL_FSL_PBL,NAND" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/B4420QDS_SPIFLASH_defconfig b/configs/B4420QDS_SPIFLASH_defconfig index 9875191..66da74e 100644 --- a/configs/B4420QDS_SPIFLASH_defconfig +++ b/configs/B4420QDS_SPIFLASH_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_B4420,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/B4420QDS_defconfig b/configs/B4420QDS_defconfig index c2f903b..1b97a6a 100644 --- a/configs/B4420QDS_defconfig +++ b/configs/B4420QDS_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_B4420" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/B4860QDS_NAND_defconfig b/configs/B4860QDS_NAND_defconfig index 5533cb3..ff76dae 100644 --- a/configs/B4860QDS_NAND_defconfig +++ b/configs/B4860QDS_NAND_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_B4860,RAMBOOT_PBL,SPL_FSL_PBL,NAND" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/B4860QDS_SECURE_BOOT_defconfig b/configs/B4860QDS_SECURE_BOOT_defconfig index 051dccb..d26fe6e 100644 --- a/configs/B4860QDS_SECURE_BOOT_defconfig +++ b/configs/B4860QDS_SECURE_BOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_B4860,SECURE_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/B4860QDS_SPIFLASH_defconfig b/configs/B4860QDS_SPIFLASH_defconfig index e6807df..b0faa7f 100644 --- a/configs/B4860QDS_SPIFLASH_defconfig +++ b/configs/B4860QDS_SPIFLASH_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_B4860,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/B4860QDS_SRIO_PCIE_BOOT_defconfig b/configs/B4860QDS_SRIO_PCIE_BOOT_defconfig index b7832db..a63686c 100644 --- a/configs/B4860QDS_SRIO_PCIE_BOOT_defconfig +++ b/configs/B4860QDS_SRIO_PCIE_BOOT_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_B4860,SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF40000" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_SPI_FLASH=y diff --git a/configs/B4860QDS_defconfig b/configs/B4860QDS_defconfig index e68c19f..a29ab17 100644 --- a/configs/B4860QDS_defconfig +++ b/configs/B4860QDS_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_B4860" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/BSC9131RDB_NAND_SYSCLK100_defconfig b/configs/BSC9131RDB_NAND_SYSCLK100_defconfig index a199806..f8ccf4a 100644 --- a/configs/BSC9131RDB_NAND_SYSCLK100_defconfig +++ b/configs/BSC9131RDB_NAND_SYSCLK100_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9131RDB,NAND,SYS_CLK_100" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_SPI_FLASH=y diff --git a/configs/BSC9131RDB_NAND_defconfig b/configs/BSC9131RDB_NAND_defconfig index 1f2d2b8..b30132e 100644 --- a/configs/BSC9131RDB_NAND_defconfig +++ b/configs/BSC9131RDB_NAND_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9131RDB,NAND" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_SPI_FLASH=y diff --git a/configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig b/configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig index e9c3723..7b5cea5 100644 --- a/configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig +++ b/configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9131RDB,SPIFLASH,SYS_CLK_100" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_SPI_FLASH=y diff --git a/configs/BSC9131RDB_SPIFLASH_defconfig b/configs/BSC9131RDB_SPIFLASH_defconfig index f46c0ca..9258040 100644 --- a/configs/BSC9131RDB_SPIFLASH_defconfig +++ b/configs/BSC9131RDB_SPIFLASH_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9131RDB,SPIFLASH" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_SPI_FLASH=y diff --git a/configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig b/configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig index b3829f5..db01bbb 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,NAND_SECBOOT,SYS_CLK_100_DDR_100,SECURE_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/BSC9132QDS_NAND_DDRCLK100_defconfig b/configs/BSC9132QDS_NAND_DDRCLK100_defconfig index 88f2ade..c59d2e5 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK100_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK100_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,NAND,SYS_CLK_100_DDR_100" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig b/configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig index 568470b..e5364bf 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,NAND_SECBOOT,SYS_CLK_100_DDR_133,SECURE_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/BSC9132QDS_NAND_DDRCLK133_defconfig b/configs/BSC9132QDS_NAND_DDRCLK133_defconfig index 58bf069..3688646 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK133_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK133_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,NAND,SYS_CLK_100_DDR_133" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig b/configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig index 13e8325..3b75bb4 100644 --- a/configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig +++ b/configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SYS_CLK_100_DDR_100,SECURE_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/BSC9132QDS_NOR_DDRCLK100_defconfig b/configs/BSC9132QDS_NOR_DDRCLK100_defconfig index 92c4e28..822c14b 100644 --- a/configs/BSC9132QDS_NOR_DDRCLK100_defconfig +++ b/configs/BSC9132QDS_NOR_DDRCLK100_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SYS_CLK_100_DDR_100" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig b/configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig index 291c879..53e5626 100644 --- a/configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig +++ b/configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SYS_CLK_100_DDR_133,SECURE_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/BSC9132QDS_NOR_DDRCLK133_defconfig b/configs/BSC9132QDS_NOR_DDRCLK133_defconfig index bb49265..bd8cf10 100644 --- a/configs/BSC9132QDS_NOR_DDRCLK133_defconfig +++ b/configs/BSC9132QDS_NOR_DDRCLK133_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SYS_CLK_100_DDR_133" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig b/configs/BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig index 076a99e..23d7138 100644 --- a/configs/BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig +++ b/configs/BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SDCARD,SYS_CLK_100_DDR_100,SECURE_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig b/configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig index 3e21ef4..27dda3a 100644 --- a/configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig +++ b/configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SDCARD,SYS_CLK_100_DDR_100" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig b/configs/BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig index 5c4ba30..f3febf6 100644 --- a/configs/BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig +++ b/configs/BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SDCARD,SYS_CLK_100_DDR_133,SECURE_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig b/configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig index 047f315..ecd0ddb 100644 --- a/configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig +++ b/configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SDCARD,SYS_CLK_100_DDR_133" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig b/configs/BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig index 1aa92e5..91cadef 100644 --- a/configs/BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig +++ b/configs/BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SPIFLASH,SYS_CLK_100_DDR_100,SECURE_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig b/configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig index 66500e7..9b612f8 100644 --- a/configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig +++ b/configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SPIFLASH,SYS_CLK_100_DDR_100" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig b/configs/BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig index 3531479..0eb8f15 100644 --- a/configs/BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig +++ b/configs/BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SPIFLASH,SYS_CLK_100_DDR_133,SECURE_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig b/configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig index 7ceec10..a40bd6c 100644 --- a/configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig +++ b/configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SPIFLASH,SYS_CLK_100_DDR_133" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/Bananapi_defconfig b/configs/Bananapi_defconfig index d9b1bd6..054d7ce 100644 --- a/configs/Bananapi_defconfig +++ b/configs/Bananapi_defconfig @@ -8,6 +8,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-bananapi" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),AHCI" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Bananapro_defconfig b/configs/Bananapro_defconfig index 496c20e..b3b36ac 100644 --- a/configs/Bananapro_defconfig +++ b/configs/Bananapro_defconfig @@ -10,6 +10,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-bananapro" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),AHCI" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/C29XPCIE_NAND_defconfig b/configs/C29XPCIE_NAND_defconfig index bea850f..6b455b1 100644 --- a/configs/C29XPCIE_NAND_defconfig +++ b/configs/C29XPCIE_NAND_defconfig @@ -8,6 +8,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="C29XPCIE,36BIT,NAND" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/C29XPCIE_NOR_SECBOOT_defconfig b/configs/C29XPCIE_NOR_SECBOOT_defconfig index c6e5e08..93eea63 100644 --- a/configs/C29XPCIE_NOR_SECBOOT_defconfig +++ b/configs/C29XPCIE_NOR_SECBOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="C29XPCIE,36BIT,SECURE_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y diff --git a/configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig b/configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig index 53889f1..5bf96b8 100644 --- a/configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig +++ b/configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="C29XPCIE,36BIT,SPIFLASH,SECURE_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y diff --git a/configs/C29XPCIE_SPIFLASH_defconfig b/configs/C29XPCIE_SPIFLASH_defconfig index e236129..3597dbb 100644 --- a/configs/C29XPCIE_SPIFLASH_defconfig +++ b/configs/C29XPCIE_SPIFLASH_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="C29XPCIE,36BIT,SPIFLASH" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/C29XPCIE_defconfig b/configs/C29XPCIE_defconfig index 214aff7..7c6f233 100644 --- a/configs/C29XPCIE_defconfig +++ b/configs/C29XPCIE_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="C29XPCIE,36BIT" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/CHIP_defconfig b/configs/CHIP_defconfig index 5a38c19..0e72d2c 100644 --- a/configs/CHIP_defconfig +++ b/configs/CHIP_defconfig @@ -8,6 +8,7 @@ CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun5i-r8-chip" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set CONFIG_AXP_ALDO3_VOLT=3300 CONFIG_AXP_ALDO4_VOLT=3300 diff --git a/configs/CSQ_CS908_defconfig b/configs/CSQ_CS908_defconfig index 1cb010d..d0a2bd2 100644 --- a/configs/CSQ_CS908_defconfig +++ b/configs/CSQ_CS908_defconfig @@ -8,6 +8,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-cs908" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Chuwi_V7_CW0825_defconfig b/configs/Chuwi_V7_CW0825_defconfig index 3257aae..393f337 100644 --- a/configs/Chuwi_V7_CW0825_defconfig +++ b/configs/Chuwi_V7_CW0825_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_PANEL_HITACHI_TX18D42VM=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-chuwi-v7-cw0825" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Colombus_defconfig b/configs/Colombus_defconfig index 2ce8cb1..85322d4 100644 --- a/configs/Colombus_defconfig +++ b/configs/Colombus_defconfig @@ -18,6 +18,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-colombus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Cubieboard2_defconfig b/configs/Cubieboard2_defconfig index 4b9d722..26c770c 100644 --- a/configs/Cubieboard2_defconfig +++ b/configs/Cubieboard2_defconfig @@ -7,6 +7,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-cubieboard2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPB(8)" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Cubieboard_defconfig b/configs/Cubieboard_defconfig index c884115..22372ef 100644 --- a/configs/Cubieboard_defconfig +++ b/configs/Cubieboard_defconfig @@ -7,6 +7,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-cubieboard" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,AHCI,SATAPWR=SUNXI_GPB(8)" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Cubietruck_defconfig b/configs/Cubietruck_defconfig index 5a037a9..ea7cc0c 100644 --- a/configs/Cubietruck_defconfig +++ b/configs/Cubietruck_defconfig @@ -12,6 +12,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-cubietruck" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,AHCI,SATAPWR=SUNXI_GPH(12)" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Cubietruck_plus_defconfig b/configs/Cubietruck_plus_defconfig index 255f35d..608ee14 100644 --- a/configs/Cubietruck_plus_defconfig +++ b/configs/Cubietruck_plus_defconfig @@ -5,16 +5,17 @@ CONFIG_DRAM_CLK=672 CONFIG_DRAM_ZQ=15355 CONFIG_DRAM_ODT_EN=y CONFIG_MMC0_CD_PIN="PF6" -CONFIG_I2C0_ENABLE=y CONFIG_USB0_VBUS_PIN="AXP0-VBUS-ENABLE" CONFIG_USB0_VBUS_DET="AXP0-VBUS-DETECT" CONFIG_USB0_ID_DET="PH11" CONFIG_USB1_VBUS_PIN="PD29" CONFIG_USB2_VBUS_PIN="PL6" +CONFIG_I2C0_ENABLE=y CONFIG_AXP_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="sun8i-a83t-cubietruck-plus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Cyrus_P5020_defconfig b/configs/Cyrus_P5020_defconfig index 999eb32..a7c8897 100644 --- a/configs/Cyrus_P5020_defconfig +++ b/configs/Cyrus_P5020_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SYS_TEXT_BASE=0xFFF40000,PPC_P5020" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_NETDEVICES=y diff --git a/configs/Cyrus_P5040_defconfig b/configs/Cyrus_P5040_defconfig index 310bedf..2618a72 100644 --- a/configs/Cyrus_P5040_defconfig +++ b/configs/Cyrus_P5040_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SYS_TEXT_BASE=0xFFF40000,PPC_P5040" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_NETDEVICES=y diff --git a/configs/Empire_electronix_d709_defconfig b/configs/Empire_electronix_d709_defconfig index 5f01760..12f74df 100644 --- a/configs/Empire_electronix_d709_defconfig +++ b/configs/Empire_electronix_d709_defconfig @@ -17,6 +17,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-empire-electronix-d709" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Hummingbird_A31_defconfig b/configs/Hummingbird_A31_defconfig index 02bcdbf..cbe8341 100644 --- a/configs/Hummingbird_A31_defconfig +++ b/configs/Hummingbird_A31_defconfig @@ -10,6 +10,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-hummingbird" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPA(21)" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Hyundai_A7HD_defconfig b/configs/Hyundai_A7HD_defconfig index fef3685..883edd9 100644 --- a/configs/Hyundai_A7HD_defconfig +++ b/configs/Hyundai_A7HD_defconfig @@ -15,6 +15,7 @@ CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-hyundai-a7hd" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Itead_Ibox_A20_defconfig b/configs/Itead_Ibox_A20_defconfig index 90dd734..2209cbf 100644 --- a/configs/Itead_Ibox_A20_defconfig +++ b/configs/Itead_Ibox_A20_defconfig @@ -7,7 +7,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-itead-ibox" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPB(8)" -#CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,SUNXI_EMAC,AHCI,SATAPWR=SUNXI_GPB(8)" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Lamobo_R1_defconfig b/configs/Lamobo_R1_defconfig index d2111c6..96a876c 100644 --- a/configs/Lamobo_R1_defconfig +++ b/configs/Lamobo_R1_defconfig @@ -8,6 +8,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-lamobo-r1" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),AHCI,SATAPWR=SUNXI_GPB(3)" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Linksprite_pcDuino3_Nano_defconfig b/configs/Linksprite_pcDuino3_Nano_defconfig index 378abce..718aba5 100644 --- a/configs/Linksprite_pcDuino3_Nano_defconfig +++ b/configs/Linksprite_pcDuino3_Nano_defconfig @@ -9,6 +9,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-pcduino3-nano" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,AHCI,SATAPWR=SUNXI_GPH(2)" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Linksprite_pcDuino3_defconfig b/configs/Linksprite_pcDuino3_defconfig index c3f0421..0e95c76 100644 --- a/configs/Linksprite_pcDuino3_defconfig +++ b/configs/Linksprite_pcDuino3_defconfig @@ -7,6 +7,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-pcduino3" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPH(2)" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Linksprite_pcDuino_defconfig b/configs/Linksprite_pcDuino_defconfig index 9d8d325..9af4db9 100644 --- a/configs/Linksprite_pcDuino_defconfig +++ b/configs/Linksprite_pcDuino_defconfig @@ -7,6 +7,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-pcduino" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/M54418TWR_defconfig b/configs/M54418TWR_defconfig index 62cebda..19f8983 100644 --- a/configs/M54418TWR_defconfig +++ b/configs/M54418TWR_defconfig @@ -2,6 +2,7 @@ CONFIG_M68K=y CONFIG_TARGET_M54418TWR=y CONFIG_SYS_TEXT_BASE=0x47E00000 CONFIG_SYS_EXTRA_OPTIONS="CF_SBF,SYS_SERIAL_BOOT,SYS_INPUT_CLKSRC=50000000" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="-> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADB is not set diff --git a/configs/M54418TWR_nand_mii_defconfig b/configs/M54418TWR_nand_mii_defconfig index de73e30..bc6f63a 100644 --- a/configs/M54418TWR_nand_mii_defconfig +++ b/configs/M54418TWR_nand_mii_defconfig @@ -2,6 +2,7 @@ CONFIG_M68K=y CONFIG_TARGET_M54418TWR=y CONFIG_SYS_TEXT_BASE=0x47E00000 CONFIG_SYS_EXTRA_OPTIONS="SYS_NAND_BOOT,SYS_INPUT_CLKSRC=25000000" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="-> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADB is not set diff --git a/configs/M54418TWR_nand_rmii_defconfig b/configs/M54418TWR_nand_rmii_defconfig index 139811c..a42f603 100644 --- a/configs/M54418TWR_nand_rmii_defconfig +++ b/configs/M54418TWR_nand_rmii_defconfig @@ -2,6 +2,7 @@ CONFIG_M68K=y CONFIG_TARGET_M54418TWR=y CONFIG_SYS_TEXT_BASE=0x47E00000 CONFIG_SYS_EXTRA_OPTIONS="SYS_NAND_BOOT,SYS_INPUT_CLKSRC=50000000" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="-> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADB is not set diff --git a/configs/M54418TWR_nand_rmii_lowfreq_defconfig b/configs/M54418TWR_nand_rmii_lowfreq_defconfig index a3cf48b..a6c595d 100644 --- a/configs/M54418TWR_nand_rmii_lowfreq_defconfig +++ b/configs/M54418TWR_nand_rmii_lowfreq_defconfig @@ -2,6 +2,7 @@ CONFIG_M68K=y CONFIG_TARGET_M54418TWR=y CONFIG_SYS_TEXT_BASE=0x47E00000 CONFIG_SYS_EXTRA_OPTIONS="SYS_NAND_BOOT,LOW_MCFCLK,SYS_INPUT_CLKSRC=50000000" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="-> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADB is not set diff --git a/configs/M54418TWR_serial_mii_defconfig b/configs/M54418TWR_serial_mii_defconfig index ad29d52..bdfa3b4 100644 --- a/configs/M54418TWR_serial_mii_defconfig +++ b/configs/M54418TWR_serial_mii_defconfig @@ -2,6 +2,7 @@ CONFIG_M68K=y CONFIG_TARGET_M54418TWR=y CONFIG_SYS_TEXT_BASE=0x47E00000 CONFIG_SYS_EXTRA_OPTIONS="CF_SBF,SYS_SERIAL_BOOT,SYS_INPUT_CLKSRC=25000000" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="-> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADB is not set diff --git a/configs/M54418TWR_serial_rmii_defconfig b/configs/M54418TWR_serial_rmii_defconfig index 62cebda..19f8983 100644 --- a/configs/M54418TWR_serial_rmii_defconfig +++ b/configs/M54418TWR_serial_rmii_defconfig @@ -2,6 +2,7 @@ CONFIG_M68K=y CONFIG_TARGET_M54418TWR=y CONFIG_SYS_TEXT_BASE=0x47E00000 CONFIG_SYS_EXTRA_OPTIONS="CF_SBF,SYS_SERIAL_BOOT,SYS_INPUT_CLKSRC=50000000" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="-> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADB is not set diff --git a/configs/MIP405T_defconfig b/configs/MIP405T_defconfig index 799a1b6..641fa06 100644 --- a/configs/MIP405T_defconfig +++ b/configs/MIP405T_defconfig @@ -2,5 +2,6 @@ CONFIG_PPC=y CONFIG_4xx=y CONFIG_TARGET_MIP405=y CONFIG_SYS_EXTRA_OPTIONS="MIP405T" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y diff --git a/configs/MIP405_defconfig b/configs/MIP405_defconfig index 3a012e7..2250011 100644 --- a/configs/MIP405_defconfig +++ b/configs/MIP405_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_4xx=y CONFIG_TARGET_MIP405=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y diff --git a/configs/MK808C_defconfig b/configs/MK808C_defconfig index 49bb26a..a363004 100644 --- a/configs/MK808C_defconfig +++ b/configs/MK808C_defconfig @@ -5,6 +5,7 @@ CONFIG_DRAM_CLK=384 CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-mk808c" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/MPC8308RDB_defconfig b/configs/MPC8308RDB_defconfig index 4ab53dd..546e7c7 100644 --- a/configs/MPC8308RDB_defconfig +++ b/configs/MPC8308RDB_defconfig @@ -5,6 +5,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8313ERDB_33_defconfig b/configs/MPC8313ERDB_33_defconfig index 4fa6a8c..ca1cfcd 100644 --- a/configs/MPC8313ERDB_33_defconfig +++ b/configs/MPC8313ERDB_33_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_MPC8313ERDB=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_33MHZ" +CONFIG_HUSH_PARSER=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y diff --git a/configs/MPC8313ERDB_66_defconfig b/configs/MPC8313ERDB_66_defconfig index beca636..9d4db2a 100644 --- a/configs/MPC8313ERDB_66_defconfig +++ b/configs/MPC8313ERDB_66_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_MPC8313ERDB=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_66MHZ" +CONFIG_HUSH_PARSER=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y diff --git a/configs/MPC8313ERDB_NAND_33_defconfig b/configs/MPC8313ERDB_NAND_33_defconfig index af4d66a..0df5e8b 100644 --- a/configs/MPC8313ERDB_NAND_33_defconfig +++ b/configs/MPC8313ERDB_NAND_33_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_33MHZ,NAND" +CONFIG_HUSH_PARSER=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y diff --git a/configs/MPC8313ERDB_NAND_66_defconfig b/configs/MPC8313ERDB_NAND_66_defconfig index 1c01c61..8913a18 100644 --- a/configs/MPC8313ERDB_NAND_66_defconfig +++ b/configs/MPC8313ERDB_NAND_66_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_66MHZ,NAND" +CONFIG_HUSH_PARSER=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y diff --git a/configs/MPC8315ERDB_defconfig b/configs/MPC8315ERDB_defconfig index 429a125..f6d7c0f 100644 --- a/configs/MPC8315ERDB_defconfig +++ b/configs/MPC8315ERDB_defconfig @@ -3,6 +3,7 @@ CONFIG_MPC83xx=y CONFIG_TARGET_MPC8315ERDB=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8323ERDB_defconfig b/configs/MPC8323ERDB_defconfig index a611fae..3d13b8f 100644 --- a/configs/MPC8323ERDB_defconfig +++ b/configs/MPC8323ERDB_defconfig @@ -3,6 +3,7 @@ CONFIG_MPC83xx=y CONFIG_TARGET_MPC8323ERDB=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC832XEMDS_ATM_defconfig b/configs/MPC832XEMDS_ATM_defconfig index 2ae7298..e573e0d 100644 --- a/configs/MPC832XEMDS_ATM_defconfig +++ b/configs/MPC832XEMDS_ATM_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_MPC832XEMDS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PQ_MDS_PIB=1,PQ_MDS_PIB_ATM=1" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC832XEMDS_HOST_33_defconfig b/configs/MPC832XEMDS_HOST_33_defconfig index 100734d..c32e0e9 100644 --- a/configs/MPC832XEMDS_HOST_33_defconfig +++ b/configs/MPC832XEMDS_HOST_33_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_MPC832XEMDS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PCI,PCI_33M,PQ_MDS_PIB=1" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC832XEMDS_HOST_66_defconfig b/configs/MPC832XEMDS_HOST_66_defconfig index abfceac..2247e38 100644 --- a/configs/MPC832XEMDS_HOST_66_defconfig +++ b/configs/MPC832XEMDS_HOST_66_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_MPC832XEMDS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PCI,PCI_66M,PQ_MDS_PIB=1" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC832XEMDS_SLAVE_defconfig b/configs/MPC832XEMDS_SLAVE_defconfig index caa57c5..a4b4257 100644 --- a/configs/MPC832XEMDS_SLAVE_defconfig +++ b/configs/MPC832XEMDS_SLAVE_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_MPC832XEMDS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PCI,PCISLAVE" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC832XEMDS_defconfig b/configs/MPC832XEMDS_defconfig index 98aa648..efc6555 100644 --- a/configs/MPC832XEMDS_defconfig +++ b/configs/MPC832XEMDS_defconfig @@ -3,6 +3,7 @@ CONFIG_MPC83xx=y CONFIG_TARGET_MPC832XEMDS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8349EMDS_defconfig b/configs/MPC8349EMDS_defconfig index cd43a7c..ab992fc 100644 --- a/configs/MPC8349EMDS_defconfig +++ b/configs/MPC8349EMDS_defconfig @@ -3,6 +3,7 @@ CONFIG_MPC83xx=y CONFIG_TARGET_MPC8349EMDS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8349ITXGP_defconfig b/configs/MPC8349ITXGP_defconfig index 0fd62ba..64a8241 100644 --- a/configs/MPC8349ITXGP_defconfig +++ b/configs/MPC8349ITXGP_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_MPC8349ITX=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="MPC8349ITXGP,SYS_TEXT_BASE=0xFE000000" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="MPC8349E-mITX-GP> " # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y diff --git a/configs/MPC8349ITX_LOWBOOT_defconfig b/configs/MPC8349ITX_LOWBOOT_defconfig index 717d75a..61f9e79 100644 --- a/configs/MPC8349ITX_LOWBOOT_defconfig +++ b/configs/MPC8349ITX_LOWBOOT_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_MPC8349ITX=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="MPC8349ITX,SYS_TEXT_BASE=0xFE000000" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="MPC8349E-mITX> " # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y diff --git a/configs/MPC8349ITX_defconfig b/configs/MPC8349ITX_defconfig index bc49a39..90a0df5 100644 --- a/configs/MPC8349ITX_defconfig +++ b/configs/MPC8349ITX_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_MPC8349ITX=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="MPC8349ITX" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="MPC8349E-mITX> " # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y diff --git a/configs/MPC837XEMDS_HOST_defconfig b/configs/MPC837XEMDS_HOST_defconfig index fd6721c..eb1a597 100644 --- a/configs/MPC837XEMDS_HOST_defconfig +++ b/configs/MPC837XEMDS_HOST_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_MPC837XEMDS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PCI" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC837XEMDS_defconfig b/configs/MPC837XEMDS_defconfig index eaee581..99ff225 100644 --- a/configs/MPC837XEMDS_defconfig +++ b/configs/MPC837XEMDS_defconfig @@ -3,6 +3,7 @@ CONFIG_MPC83xx=y CONFIG_TARGET_MPC837XEMDS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC837XERDB_defconfig b/configs/MPC837XERDB_defconfig index a135f0a..f0bd789 100644 --- a/configs/MPC837XERDB_defconfig +++ b/configs/MPC837XERDB_defconfig @@ -3,6 +3,7 @@ CONFIG_MPC83xx=y CONFIG_TARGET_MPC837XERDB=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8536DS_36BIT_defconfig b/configs/MPC8536DS_36BIT_defconfig index af1ea37..957c102 100644 --- a/configs/MPC8536DS_36BIT_defconfig +++ b/configs/MPC8536DS_36BIT_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_MPC8536DS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="36BIT" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/MPC8536DS_SDCARD_defconfig b/configs/MPC8536DS_SDCARD_defconfig index b91b4e4..2eb8873 100644 --- a/configs/MPC8536DS_SDCARD_defconfig +++ b/configs/MPC8536DS_SDCARD_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_MPC8536DS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SDCARD" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/MPC8536DS_SPIFLASH_defconfig b/configs/MPC8536DS_SPIFLASH_defconfig index 9163118..b551c80 100644 --- a/configs/MPC8536DS_SPIFLASH_defconfig +++ b/configs/MPC8536DS_SPIFLASH_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_MPC8536DS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SPIFLASH" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/MPC8536DS_defconfig b/configs/MPC8536DS_defconfig index ff5f90b..60b944b 100644 --- a/configs/MPC8536DS_defconfig +++ b/configs/MPC8536DS_defconfig @@ -3,6 +3,7 @@ CONFIG_MPC85xx=y CONFIG_TARGET_MPC8536DS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/MPC8540ADS_defconfig b/configs/MPC8540ADS_defconfig index c1923f0..6efbbc5 100644 --- a/configs/MPC8540ADS_defconfig +++ b/configs/MPC8540ADS_defconfig @@ -3,5 +3,6 @@ CONFIG_MPC85xx=y CONFIG_TARGET_MPC8540ADS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8541CDS_defconfig b/configs/MPC8541CDS_defconfig index 99a1f8c..dde5a24 100644 --- a/configs/MPC8541CDS_defconfig +++ b/configs/MPC8541CDS_defconfig @@ -3,5 +3,6 @@ CONFIG_MPC85xx=y CONFIG_TARGET_MPC8541CDS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8541CDS_legacy_defconfig b/configs/MPC8541CDS_legacy_defconfig index f79c2f2..1ab88f6 100644 --- a/configs/MPC8541CDS_legacy_defconfig +++ b/configs/MPC8541CDS_legacy_defconfig @@ -4,5 +4,6 @@ CONFIG_TARGET_MPC8541CDS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="LEGACY" +CONFIG_HUSH_PARSER=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8544DS_defconfig b/configs/MPC8544DS_defconfig index 8937682..fd64677 100644 --- a/configs/MPC8544DS_defconfig +++ b/configs/MPC8544DS_defconfig @@ -3,6 +3,7 @@ CONFIG_MPC85xx=y CONFIG_TARGET_MPC8544DS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_RTL8139=y diff --git a/configs/MPC8548CDS_36BIT_defconfig b/configs/MPC8548CDS_36BIT_defconfig index dd4b9d0..5bdf2cc 100644 --- a/configs/MPC8548CDS_36BIT_defconfig +++ b/configs/MPC8548CDS_36BIT_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_MPC8548CDS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="36BIT" +CONFIG_HUSH_PARSER=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/MPC8548CDS_defconfig b/configs/MPC8548CDS_defconfig index 1cddf9e..00595c4 100644 --- a/configs/MPC8548CDS_defconfig +++ b/configs/MPC8548CDS_defconfig @@ -3,6 +3,7 @@ CONFIG_MPC85xx=y CONFIG_TARGET_MPC8548CDS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/MPC8548CDS_legacy_defconfig b/configs/MPC8548CDS_legacy_defconfig index 8ac3360..a95ea81 100644 --- a/configs/MPC8548CDS_legacy_defconfig +++ b/configs/MPC8548CDS_legacy_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_MPC8548CDS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="LEGACY" +CONFIG_HUSH_PARSER=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/MPC8555CDS_defconfig b/configs/MPC8555CDS_defconfig index 0d183db..e4ab923 100644 --- a/configs/MPC8555CDS_defconfig +++ b/configs/MPC8555CDS_defconfig @@ -3,5 +3,6 @@ CONFIG_MPC85xx=y CONFIG_TARGET_MPC8555CDS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8555CDS_legacy_defconfig b/configs/MPC8555CDS_legacy_defconfig index 0a31799..12364d1 100644 --- a/configs/MPC8555CDS_legacy_defconfig +++ b/configs/MPC8555CDS_legacy_defconfig @@ -4,5 +4,6 @@ CONFIG_TARGET_MPC8555CDS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="LEGACY" +CONFIG_HUSH_PARSER=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8560ADS_defconfig b/configs/MPC8560ADS_defconfig index 6f33234..11100c3 100644 --- a/configs/MPC8560ADS_defconfig +++ b/configs/MPC8560ADS_defconfig @@ -3,4 +3,5 @@ CONFIG_MPC85xx=y CONFIG_TARGET_MPC8560ADS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8568MDS_defconfig b/configs/MPC8568MDS_defconfig index 3efd2e5..7d4b01c 100644 --- a/configs/MPC8568MDS_defconfig +++ b/configs/MPC8568MDS_defconfig @@ -3,5 +3,6 @@ CONFIG_MPC85xx=y CONFIG_TARGET_MPC8568MDS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8569MDS_ATM_defconfig b/configs/MPC8569MDS_ATM_defconfig index 193561a..597dad7 100644 --- a/configs/MPC8569MDS_ATM_defconfig +++ b/configs/MPC8569MDS_ATM_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_MPC8569MDS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="ATM" +CONFIG_HUSH_PARSER=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/MPC8569MDS_defconfig b/configs/MPC8569MDS_defconfig index e5467ab..adcbf49 100644 --- a/configs/MPC8569MDS_defconfig +++ b/configs/MPC8569MDS_defconfig @@ -3,6 +3,7 @@ CONFIG_MPC85xx=y CONFIG_TARGET_MPC8569MDS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/MPC8572DS_36BIT_defconfig b/configs/MPC8572DS_36BIT_defconfig index c260aee..9dc690f 100644 --- a/configs/MPC8572DS_36BIT_defconfig +++ b/configs/MPC8572DS_36BIT_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="36BIT" +CONFIG_HUSH_PARSER=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/MPC8572DS_defconfig b/configs/MPC8572DS_defconfig index 5e000ea..76b9d25 100644 --- a/configs/MPC8572DS_defconfig +++ b/configs/MPC8572DS_defconfig @@ -5,6 +5,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/MPC8610HPCD_defconfig b/configs/MPC8610HPCD_defconfig index 515edb5..2b4cc3a 100644 --- a/configs/MPC8610HPCD_defconfig +++ b/configs/MPC8610HPCD_defconfig @@ -3,6 +3,7 @@ CONFIG_MPC86xx=y CONFIG_TARGET_MPC8610HPCD=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8641HPCN_36BIT_defconfig b/configs/MPC8641HPCN_36BIT_defconfig index cfe26ea..e1fb77f 100644 --- a/configs/MPC8641HPCN_36BIT_defconfig +++ b/configs/MPC8641HPCN_36BIT_defconfig @@ -4,7 +4,7 @@ CONFIG_TARGET_MPC8641HPCN=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PHYS_64BIT" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set -CONFIG_RTL8139=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8641HPCN_defconfig b/configs/MPC8641HPCN_defconfig index b745f8b..9b2a697 100644 --- a/configs/MPC8641HPCN_defconfig +++ b/configs/MPC8641HPCN_defconfig @@ -3,7 +3,7 @@ CONFIG_MPC86xx=y CONFIG_TARGET_MPC8641HPCN=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set -CONFIG_RTL8139=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MSI_Primo73_defconfig b/configs/MSI_Primo73_defconfig index 5559444..2f4e024 100644 --- a/configs/MSI_Primo73_defconfig +++ b/configs/MSI_Primo73_defconfig @@ -10,6 +10,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-primo73" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/MSI_Primo81_defconfig b/configs/MSI_Primo81_defconfig index 3d71bf5..7cf7b9d 100644 --- a/configs/MSI_Primo81_defconfig +++ b/configs/MSI_Primo81_defconfig @@ -13,6 +13,7 @@ CONFIG_VIDEO_LCD_PANEL_MIPI_4_LANE_513_MBPS_VIA_SSD2828=y CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-primo81" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Marsboard_A10_defconfig b/configs/Marsboard_A10_defconfig index cef9794..041baab 100644 --- a/configs/Marsboard_A10_defconfig +++ b/configs/Marsboard_A10_defconfig @@ -5,6 +5,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-marsboard" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,AHCI" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Mele_A1000G_quad_defconfig b/configs/Mele_A1000G_quad_defconfig index b3f825e..e49be8a 100644 --- a/configs/Mele_A1000G_quad_defconfig +++ b/configs/Mele_A1000G_quad_defconfig @@ -8,6 +8,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-mele-a1000g-quad" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Mele_A1000_defconfig b/configs/Mele_A1000_defconfig index f076e30..3dab55c 100644 --- a/configs/Mele_A1000_defconfig +++ b/configs/Mele_A1000_defconfig @@ -7,6 +7,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-a1000" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,MACPWR=SUNXI_GPH(15),AHCI" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Mele_I7_defconfig b/configs/Mele_I7_defconfig index eccf372..0d1c90e 100644 --- a/configs/Mele_I7_defconfig +++ b/configs/Mele_I7_defconfig @@ -8,6 +8,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-i7" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Mele_M3_defconfig b/configs/Mele_M3_defconfig index d72dcc0..fb88d94 100644 --- a/configs/Mele_M3_defconfig +++ b/configs/Mele_M3_defconfig @@ -10,6 +10,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-m3" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Mele_M5_defconfig b/configs/Mele_M5_defconfig index 0d1ba15..1db614f 100644 --- a/configs/Mele_M5_defconfig +++ b/configs/Mele_M5_defconfig @@ -9,6 +9,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-m5" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,AHCI,STATUSLED=234" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Mele_M9_defconfig b/configs/Mele_M9_defconfig index f0b4384..7291022 100644 --- a/configs/Mele_M9_defconfig +++ b/configs/Mele_M9_defconfig @@ -8,6 +8,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-m9" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Merrii_A80_Optimus_defconfig b/configs/Merrii_A80_Optimus_defconfig index 53e023a..3003c3e 100644 --- a/configs/Merrii_A80_Optimus_defconfig +++ b/configs/Merrii_A80_Optimus_defconfig @@ -8,6 +8,7 @@ CONFIG_MMC0_CD_PIN="PH18" # CONFIG_VIDEO is not set CONFIG_DEFAULT_DEVICE_TREE="sun9i-a80-optimus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Mini-X_defconfig b/configs/Mini-X_defconfig index 53f9bfe..bf88df6 100644 --- a/configs/Mini-X_defconfig +++ b/configs/Mini-X_defconfig @@ -6,6 +6,7 @@ CONFIG_VIDEO_COMPOSITE=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-mini-xplus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/MiniFAP_defconfig b/configs/MiniFAP_defconfig index 6b999ed..f393019 100644 --- a/configs/MiniFAP_defconfig +++ b/configs/MiniFAP_defconfig @@ -3,5 +3,6 @@ CONFIG_MPC5xxx=y CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="MINIFAP" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/O2D300_defconfig b/configs/O2D300_defconfig index 5bb5a44..bc211aa 100644 --- a/configs/O2D300_defconfig +++ b/configs/O2D300_defconfig @@ -2,5 +2,6 @@ CONFIG_PPC=y CONFIG_MPC5xxx=y CONFIG_TARGET_O2D300=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/O2DNT2_RAMBOOT_defconfig b/configs/O2DNT2_RAMBOOT_defconfig index 8865937..210da9a 100644 --- a/configs/O2DNT2_RAMBOOT_defconfig +++ b/configs/O2DNT2_RAMBOOT_defconfig @@ -3,6 +3,7 @@ CONFIG_MPC5xxx=y CONFIG_TARGET_O2DNT2=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_TEXT_BASE=0x00100000" +CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press password to stop\n" CONFIG_AUTOBOOT_STOP_STR="++++++++++" diff --git a/configs/O2DNT2_defconfig b/configs/O2DNT2_defconfig index 9364366..8cbf6eb 100644 --- a/configs/O2DNT2_defconfig +++ b/configs/O2DNT2_defconfig @@ -2,6 +2,7 @@ CONFIG_PPC=y CONFIG_MPC5xxx=y CONFIG_TARGET_O2DNT2=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press password to stop\n" CONFIG_AUTOBOOT_STOP_STR="++++++++++" diff --git a/configs/O2D_defconfig b/configs/O2D_defconfig index d57021f..f33191b 100644 --- a/configs/O2D_defconfig +++ b/configs/O2D_defconfig @@ -2,5 +2,6 @@ CONFIG_PPC=y CONFIG_MPC5xxx=y CONFIG_TARGET_O2D=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/O2I_defconfig b/configs/O2I_defconfig index 7c3ff8c..14b940f 100644 --- a/configs/O2I_defconfig +++ b/configs/O2I_defconfig @@ -2,5 +2,6 @@ CONFIG_PPC=y CONFIG_MPC5xxx=y CONFIG_TARGET_O2I=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/O2MNT_O2M110_defconfig b/configs/O2MNT_O2M110_defconfig index 9a38f11..6c9eeb4 100644 --- a/configs/O2MNT_O2M110_defconfig +++ b/configs/O2MNT_O2M110_defconfig @@ -3,5 +3,6 @@ CONFIG_MPC5xxx=y CONFIG_TARGET_O2MNT=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="IFM_SENSOR_TYPE="O2M110"" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/O2MNT_O2M112_defconfig b/configs/O2MNT_O2M112_defconfig index a60bfdd..84e4243 100644 --- a/configs/O2MNT_O2M112_defconfig +++ b/configs/O2MNT_O2M112_defconfig @@ -3,5 +3,6 @@ CONFIG_MPC5xxx=y CONFIG_TARGET_O2MNT=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="IFM_SENSOR_TYPE="O2M112"" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/O2MNT_O2M113_defconfig b/configs/O2MNT_O2M113_defconfig index 8037be4..00c516f 100644 --- a/configs/O2MNT_O2M113_defconfig +++ b/configs/O2MNT_O2M113_defconfig @@ -3,5 +3,6 @@ CONFIG_MPC5xxx=y CONFIG_TARGET_O2MNT=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="IFM_SENSOR_TYPE="O2M113"" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/O2MNT_defconfig b/configs/O2MNT_defconfig index 60666bd..55ff0fa 100644 --- a/configs/O2MNT_defconfig +++ b/configs/O2MNT_defconfig @@ -2,5 +2,6 @@ CONFIG_PPC=y CONFIG_MPC5xxx=y CONFIG_TARGET_O2MNT=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/O3DNT_defconfig b/configs/O3DNT_defconfig index 053e048..9556964 100644 --- a/configs/O3DNT_defconfig +++ b/configs/O3DNT_defconfig @@ -2,5 +2,6 @@ CONFIG_PPC=y CONFIG_MPC5xxx=y CONFIG_TARGET_O3DNT=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/Orangepi_defconfig b/configs/Orangepi_defconfig index 00c671b..6f502db 100644 --- a/configs/Orangepi_defconfig +++ b/configs/Orangepi_defconfig @@ -11,6 +11,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-orangepi" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),AHCI" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Orangepi_mini_defconfig b/configs/Orangepi_mini_defconfig index a865255..c07d25e 100644 --- a/configs/Orangepi_mini_defconfig +++ b/configs/Orangepi_mini_defconfig @@ -13,6 +13,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-orangepi-mini" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),AHCI" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig b/configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig index 70140f4..d91e4d3 100644 --- a/configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,36BIT,NAND_SECBOOT,SECURE_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PA_36BIT_NAND_defconfig b/configs/P1010RDB-PA_36BIT_NAND_defconfig index a0a8d06..6af298f 100644 --- a/configs/P1010RDB-PA_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PA_36BIT_NAND_defconfig @@ -8,6 +8,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,36BIT,NAND" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig b/configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig index ef2c1ef..72dac9f 100644 --- a/configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,36BIT,SECURE_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PA_36BIT_NOR_defconfig b/configs/P1010RDB-PA_36BIT_NOR_defconfig index 7df594d..b0410b0 100644 --- a/configs/P1010RDB-PA_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PA_36BIT_NOR_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,36BIT" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig index 6d6710f..14b9511 100644 --- a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,36BIT,SDCARD" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig b/configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig index 775ed29..1036eb4 100644 --- a/configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,36BIT,SPIFLASH,SECURE_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig index 60f736f..ac8ca85 100644 --- a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,36BIT,SPIFLASH" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PA_NAND_SECBOOT_defconfig b/configs/P1010RDB-PA_NAND_SECBOOT_defconfig index 406334a..e668725 100644 --- a/configs/P1010RDB-PA_NAND_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_NAND_SECBOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,NAND_SECBOOT,SECURE_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PA_NAND_defconfig b/configs/P1010RDB-PA_NAND_defconfig index 1dd5cef..f99039d 100644 --- a/configs/P1010RDB-PA_NAND_defconfig +++ b/configs/P1010RDB-PA_NAND_defconfig @@ -8,6 +8,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,NAND" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PA_NOR_SECBOOT_defconfig b/configs/P1010RDB-PA_NOR_SECBOOT_defconfig index d969d0e..8af53af 100644 --- a/configs/P1010RDB-PA_NOR_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_NOR_SECBOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,SECURE_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PA_NOR_defconfig b/configs/P1010RDB-PA_NOR_defconfig index fefbf64..01ae04c 100644 --- a/configs/P1010RDB-PA_NOR_defconfig +++ b/configs/P1010RDB-PA_NOR_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PA_SDCARD_defconfig b/configs/P1010RDB-PA_SDCARD_defconfig index e5f29c0..cb50efb 100644 --- a/configs/P1010RDB-PA_SDCARD_defconfig +++ b/configs/P1010RDB-PA_SDCARD_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,SDCARD" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig b/configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig index 5540a61..f536056 100644 --- a/configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,SPIFLASH,SECURE_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PA_SPIFLASH_defconfig b/configs/P1010RDB-PA_SPIFLASH_defconfig index d551d3f..540dc07 100644 --- a/configs/P1010RDB-PA_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,SPIFLASH" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig b/configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig index a8fbfaa..0f3d4bc 100644 --- a/configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,36BIT,NAND_SECBOOT,SECURE_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PB_36BIT_NAND_defconfig b/configs/P1010RDB-PB_36BIT_NAND_defconfig index 627d953..8777721 100644 --- a/configs/P1010RDB-PB_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PB_36BIT_NAND_defconfig @@ -8,6 +8,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,36BIT,NAND" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig b/configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig index 2215969..ee28938 100644 --- a/configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,36BIT,SECURE_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PB_36BIT_NOR_defconfig b/configs/P1010RDB-PB_36BIT_NOR_defconfig index 980cf7c..3518769 100644 --- a/configs/P1010RDB-PB_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PB_36BIT_NOR_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,36BIT" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig index f98ccb3..1aa52d0 100644 --- a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,36BIT,SDCARD" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig b/configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig index 2fd6c47..76d1191 100644 --- a/configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,36BIT,SPIFLASH,SECURE_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig index 33bff1f..0be70bf 100644 --- a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,36BIT,SPIFLASH" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PB_NAND_SECBOOT_defconfig b/configs/P1010RDB-PB_NAND_SECBOOT_defconfig index 2cfc763..cd7fd1a 100644 --- a/configs/P1010RDB-PB_NAND_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_NAND_SECBOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,NAND_SECBOOT,SECURE_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PB_NAND_defconfig b/configs/P1010RDB-PB_NAND_defconfig index c9c6de9..216f9c60 100644 --- a/configs/P1010RDB-PB_NAND_defconfig +++ b/configs/P1010RDB-PB_NAND_defconfig @@ -8,6 +8,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,NAND" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PB_NOR_SECBOOT_defconfig b/configs/P1010RDB-PB_NOR_SECBOOT_defconfig index 29ae621..dbe5ac5 100644 --- a/configs/P1010RDB-PB_NOR_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_NOR_SECBOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,SECURE_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PB_NOR_defconfig b/configs/P1010RDB-PB_NOR_defconfig index 5fa7e72..47799fa 100644 --- a/configs/P1010RDB-PB_NOR_defconfig +++ b/configs/P1010RDB-PB_NOR_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PB_SDCARD_defconfig b/configs/P1010RDB-PB_SDCARD_defconfig index 4379db5..d65c724 100644 --- a/configs/P1010RDB-PB_SDCARD_defconfig +++ b/configs/P1010RDB-PB_SDCARD_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,SDCARD" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig b/configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig index 1b478e4..3712bc2 100644 --- a/configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,SPIFLASH,SECURE_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PB_SPIFLASH_defconfig b/configs/P1010RDB-PB_SPIFLASH_defconfig index f92483f..ab7e97f 100644 --- a/configs/P1010RDB-PB_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,SPIFLASH" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1020MBG-PC_36BIT_SDCARD_defconfig b/configs/P1020MBG-PC_36BIT_SDCARD_defconfig index fd24450..b3b21c2 100644 --- a/configs/P1020MBG-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020MBG-PC_36BIT_SDCARD_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020MBG,SDCARD,36BIT" +CONFIG_HUSH_PARSER=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/P1020MBG-PC_36BIT_defconfig b/configs/P1020MBG-PC_36BIT_defconfig index 83f7f76..540c7ec 100644 --- a/configs/P1020MBG-PC_36BIT_defconfig +++ b/configs/P1020MBG-PC_36BIT_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020MBG,36BIT" +CONFIG_HUSH_PARSER=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/P1020MBG-PC_SDCARD_defconfig b/configs/P1020MBG-PC_SDCARD_defconfig index a128d0c..b3fa9d4 100644 --- a/configs/P1020MBG-PC_SDCARD_defconfig +++ b/configs/P1020MBG-PC_SDCARD_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020MBG,SDCARD" +CONFIG_HUSH_PARSER=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/P1020MBG-PC_defconfig b/configs/P1020MBG-PC_defconfig index 4e4de4b..f079220 100644 --- a/configs/P1020MBG-PC_defconfig +++ b/configs/P1020MBG-PC_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020MBG" +CONFIG_HUSH_PARSER=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/P1020RDB-PC_36BIT_NAND_defconfig b/configs/P1020RDB-PC_36BIT_NAND_defconfig index 7817039..42021ce 100644 --- a/configs/P1020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1020RDB-PC_36BIT_NAND_defconfig @@ -8,6 +8,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020RDB_PC,36BIT,NAND" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig index f2aae6e..be8cdd6 100644 --- a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020RDB_PC,36BIT,SDCARD" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig index b54ab14..2d94d7b 100644 --- a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020RDB_PC,36BIT,SPIFLASH" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1020RDB-PC_36BIT_defconfig b/configs/P1020RDB-PC_36BIT_defconfig index aec845c..6d04758 100644 --- a/configs/P1020RDB-PC_36BIT_defconfig +++ b/configs/P1020RDB-PC_36BIT_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020RDB_PC,36BIT" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1020RDB-PC_NAND_defconfig b/configs/P1020RDB-PC_NAND_defconfig index 6a2affe..3d6e980 100644 --- a/configs/P1020RDB-PC_NAND_defconfig +++ b/configs/P1020RDB-PC_NAND_defconfig @@ -8,6 +8,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020RDB_PC,NAND" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1020RDB-PC_SDCARD_defconfig b/configs/P1020RDB-PC_SDCARD_defconfig index 4ebb430..d118293 100644 --- a/configs/P1020RDB-PC_SDCARD_defconfig +++ b/configs/P1020RDB-PC_SDCARD_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020RDB_PC,SDCARD" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1020RDB-PC_SPIFLASH_defconfig b/configs/P1020RDB-PC_SPIFLASH_defconfig index 91aed54..526e65a 100644 --- a/configs/P1020RDB-PC_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020RDB_PC,SPIFLASH" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1020RDB-PC_defconfig b/configs/P1020RDB-PC_defconfig index a6fb793..450dbd5 100644 --- a/configs/P1020RDB-PC_defconfig +++ b/configs/P1020RDB-PC_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020RDB_PC" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1020RDB-PD_NAND_defconfig b/configs/P1020RDB-PD_NAND_defconfig index 3cfe779..5a3d66e 100644 --- a/configs/P1020RDB-PD_NAND_defconfig +++ b/configs/P1020RDB-PD_NAND_defconfig @@ -8,6 +8,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020RDB_PD,NAND" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1020RDB-PD_SDCARD_defconfig b/configs/P1020RDB-PD_SDCARD_defconfig index 7d8f0db..8fcbccf 100644 --- a/configs/P1020RDB-PD_SDCARD_defconfig +++ b/configs/P1020RDB-PD_SDCARD_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020RDB_PD,SDCARD" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1020RDB-PD_SPIFLASH_defconfig b/configs/P1020RDB-PD_SPIFLASH_defconfig index 486ff91..77b4b6e 100644 --- a/configs/P1020RDB-PD_SPIFLASH_defconfig +++ b/configs/P1020RDB-PD_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020RDB_PD,SPIFLASH" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1020RDB-PD_defconfig b/configs/P1020RDB-PD_defconfig index 69930fe..a0e5bc3 100644 --- a/configs/P1020RDB-PD_defconfig +++ b/configs/P1020RDB-PD_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020RDB_PD" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1020UTM-PC_36BIT_SDCARD_defconfig b/configs/P1020UTM-PC_36BIT_SDCARD_defconfig index d2cac5b..6d2c02f 100644 --- a/configs/P1020UTM-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020UTM-PC_36BIT_SDCARD_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020UTM,36BIT,SDCARD" +CONFIG_HUSH_PARSER=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/P1020UTM-PC_36BIT_defconfig b/configs/P1020UTM-PC_36BIT_defconfig index da1d409..26b7697 100644 --- a/configs/P1020UTM-PC_36BIT_defconfig +++ b/configs/P1020UTM-PC_36BIT_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020UTM,36BIT" +CONFIG_HUSH_PARSER=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/P1020UTM-PC_SDCARD_defconfig b/configs/P1020UTM-PC_SDCARD_defconfig index 9028763..b79b65a 100644 --- a/configs/P1020UTM-PC_SDCARD_defconfig +++ b/configs/P1020UTM-PC_SDCARD_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020UTM,SDCARD" +CONFIG_HUSH_PARSER=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/P1020UTM-PC_defconfig b/configs/P1020UTM-PC_defconfig index 8e42e59..6f8615a 100644 --- a/configs/P1020UTM-PC_defconfig +++ b/configs/P1020UTM-PC_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020UTM" +CONFIG_HUSH_PARSER=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/P1021RDB-PC_36BIT_NAND_defconfig b/configs/P1021RDB-PC_36BIT_NAND_defconfig index 1a9e1a8..059f9f2 100644 --- a/configs/P1021RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1021RDB-PC_36BIT_NAND_defconfig @@ -8,6 +8,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1021RDB,36BIT,NAND" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1021RDB-PC_36BIT_SDCARD_defconfig b/configs/P1021RDB-PC_36BIT_SDCARD_defconfig index 4487d01..e54d751 100644 --- a/configs/P1021RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P1021RDB-PC_36BIT_SDCARD_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1021RDB,36BIT,SDCARD" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig index f0cd301..e331a8d 100644 --- a/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1021RDB,36BIT,SPIFLASH" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1021RDB-PC_36BIT_defconfig b/configs/P1021RDB-PC_36BIT_defconfig index f2dcdeb..6d83700 100644 --- a/configs/P1021RDB-PC_36BIT_defconfig +++ b/configs/P1021RDB-PC_36BIT_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1021RDB,36BIT" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1021RDB-PC_NAND_defconfig b/configs/P1021RDB-PC_NAND_defconfig index c14adaf..03795da 100644 --- a/configs/P1021RDB-PC_NAND_defconfig +++ b/configs/P1021RDB-PC_NAND_defconfig @@ -8,6 +8,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1021RDB,NAND" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1021RDB-PC_SDCARD_defconfig b/configs/P1021RDB-PC_SDCARD_defconfig index 21b154a..01fb7ff 100644 --- a/configs/P1021RDB-PC_SDCARD_defconfig +++ b/configs/P1021RDB-PC_SDCARD_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1021RDB,SDCARD" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1021RDB-PC_SPIFLASH_defconfig b/configs/P1021RDB-PC_SPIFLASH_defconfig index 61f56e1..80dcc12 100644 --- a/configs/P1021RDB-PC_SPIFLASH_defconfig +++ b/configs/P1021RDB-PC_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1021RDB,SPIFLASH" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1021RDB-PC_defconfig b/configs/P1021RDB-PC_defconfig index 2b4c7e7..3d339e0 100644 --- a/configs/P1021RDB-PC_defconfig +++ b/configs/P1021RDB-PC_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1021RDB" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1022DS_36BIT_NAND_defconfig b/configs/P1022DS_36BIT_NAND_defconfig index 2a83e6a..3f4f413 100644 --- a/configs/P1022DS_36BIT_NAND_defconfig +++ b/configs/P1022DS_36BIT_NAND_defconfig @@ -8,6 +8,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="36BIT,NAND" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1022DS_36BIT_SDCARD_defconfig b/configs/P1022DS_36BIT_SDCARD_defconfig index 34b61f4..3cdbb8d 100644 --- a/configs/P1022DS_36BIT_SDCARD_defconfig +++ b/configs/P1022DS_36BIT_SDCARD_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="36BIT,SDCARD" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1022DS_36BIT_SPIFLASH_defconfig b/configs/P1022DS_36BIT_SPIFLASH_defconfig index c9b06fe..bf4b56e 100644 --- a/configs/P1022DS_36BIT_SPIFLASH_defconfig +++ b/configs/P1022DS_36BIT_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="36BIT,SPIFLASH" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1022DS_36BIT_defconfig b/configs/P1022DS_36BIT_defconfig index fe781aa..c94b53b 100644 --- a/configs/P1022DS_36BIT_defconfig +++ b/configs/P1022DS_36BIT_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="36BIT" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1022DS_NAND_defconfig b/configs/P1022DS_NAND_defconfig index 5f8c788..98f2c03 100644 --- a/configs/P1022DS_NAND_defconfig +++ b/configs/P1022DS_NAND_defconfig @@ -8,6 +8,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="NAND" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1022DS_SDCARD_defconfig b/configs/P1022DS_SDCARD_defconfig index 3072c16..b08b27a 100644 --- a/configs/P1022DS_SDCARD_defconfig +++ b/configs/P1022DS_SDCARD_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SDCARD" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1022DS_SPIFLASH_defconfig b/configs/P1022DS_SPIFLASH_defconfig index e6eac27..5ec0151 100644 --- a/configs/P1022DS_SPIFLASH_defconfig +++ b/configs/P1022DS_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SPIFLASH" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1022DS_defconfig b/configs/P1022DS_defconfig index dfe7696..f444513 100644 --- a/configs/P1022DS_defconfig +++ b/configs/P1022DS_defconfig @@ -5,6 +5,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1023RDB_defconfig b/configs/P1023RDB_defconfig index 5a8966f..32871bb 100644 --- a/configs/P1023RDB_defconfig +++ b/configs/P1023RDB_defconfig @@ -5,6 +5,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/P1024RDB_36BIT_defconfig b/configs/P1024RDB_36BIT_defconfig index 6c3e547..bfd47ee 100644 --- a/configs/P1024RDB_36BIT_defconfig +++ b/configs/P1024RDB_36BIT_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1024RDB,36BIT" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1024RDB_NAND_defconfig b/configs/P1024RDB_NAND_defconfig index ee181de..4ca3893 100644 --- a/configs/P1024RDB_NAND_defconfig +++ b/configs/P1024RDB_NAND_defconfig @@ -8,6 +8,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1024RDB,NAND" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1024RDB_SDCARD_defconfig b/configs/P1024RDB_SDCARD_defconfig index b874f55..d63a6dc 100644 --- a/configs/P1024RDB_SDCARD_defconfig +++ b/configs/P1024RDB_SDCARD_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1024RDB,SDCARD" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1024RDB_SPIFLASH_defconfig b/configs/P1024RDB_SPIFLASH_defconfig index 8e8c1af..dc3cdc9 100644 --- a/configs/P1024RDB_SPIFLASH_defconfig +++ b/configs/P1024RDB_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1024RDB,SPIFLASH" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1024RDB_defconfig b/configs/P1024RDB_defconfig index d0e363c..312e2e2 100644 --- a/configs/P1024RDB_defconfig +++ b/configs/P1024RDB_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1024RDB" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1025RDB_36BIT_defconfig b/configs/P1025RDB_36BIT_defconfig index aff4ae0..a3adca6 100644 --- a/configs/P1025RDB_36BIT_defconfig +++ b/configs/P1025RDB_36BIT_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1025RDB,36BIT" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1025RDB_NAND_defconfig b/configs/P1025RDB_NAND_defconfig index 8b0fdd9..c394d41 100644 --- a/configs/P1025RDB_NAND_defconfig +++ b/configs/P1025RDB_NAND_defconfig @@ -8,6 +8,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1025RDB,NAND" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1025RDB_SDCARD_defconfig b/configs/P1025RDB_SDCARD_defconfig index 7d39a34..7bd725e 100644 --- a/configs/P1025RDB_SDCARD_defconfig +++ b/configs/P1025RDB_SDCARD_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1025RDB,SDCARD" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1025RDB_SPIFLASH_defconfig b/configs/P1025RDB_SPIFLASH_defconfig index 945d51f..56e4d87 100644 --- a/configs/P1025RDB_SPIFLASH_defconfig +++ b/configs/P1025RDB_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1025RDB,SPIFLASH" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1025RDB_defconfig b/configs/P1025RDB_defconfig index 176cd74..56f0b65 100644 --- a/configs/P1025RDB_defconfig +++ b/configs/P1025RDB_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1025RDB" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P2020RDB-PC_36BIT_NAND_defconfig b/configs/P2020RDB-PC_36BIT_NAND_defconfig index e6ebb61..4edf2e3 100644 --- a/configs/P2020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P2020RDB-PC_36BIT_NAND_defconfig @@ -8,6 +8,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P2020RDB,36BIT,NAND" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig index d4f00e6..c3d47fc 100644 --- a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P2020RDB,36BIT,SDCARD" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig index ac345f6..a700fcd 100644 --- a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P2020RDB,36BIT,SPIFLASH" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P2020RDB-PC_36BIT_defconfig b/configs/P2020RDB-PC_36BIT_defconfig index e8e56b6..1fb4331 100644 --- a/configs/P2020RDB-PC_36BIT_defconfig +++ b/configs/P2020RDB-PC_36BIT_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P2020RDB,36BIT" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P2020RDB-PC_NAND_defconfig b/configs/P2020RDB-PC_NAND_defconfig index 641784b..fc63360 100644 --- a/configs/P2020RDB-PC_NAND_defconfig +++ b/configs/P2020RDB-PC_NAND_defconfig @@ -8,6 +8,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P2020RDB,NAND" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P2020RDB-PC_SDCARD_defconfig b/configs/P2020RDB-PC_SDCARD_defconfig index 1484ac2..1c6e99f 100644 --- a/configs/P2020RDB-PC_SDCARD_defconfig +++ b/configs/P2020RDB-PC_SDCARD_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P2020RDB,SDCARD" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P2020RDB-PC_SPIFLASH_defconfig b/configs/P2020RDB-PC_SPIFLASH_defconfig index 2226979..f14e444 100644 --- a/configs/P2020RDB-PC_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P2020RDB,SPIFLASH" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P2020RDB-PC_defconfig b/configs/P2020RDB-PC_defconfig index 09416fb..eccf03a 100644 --- a/configs/P2020RDB-PC_defconfig +++ b/configs/P2020RDB-PC_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P2020RDB" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P2041RDB_NAND_defconfig b/configs/P2041RDB_NAND_defconfig index c9eb16a..ec04df9 100644 --- a/configs/P2041RDB_NAND_defconfig +++ b/configs/P2041RDB_NAND_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF40000" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P2041RDB_SDCARD_defconfig b/configs/P2041RDB_SDCARD_defconfig index 036fd70..02b94e9 100644 --- a/configs/P2041RDB_SDCARD_defconfig +++ b/configs/P2041RDB_SDCARD_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF40000" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P2041RDB_SECURE_BOOT_defconfig b/configs/P2041RDB_SECURE_BOOT_defconfig index 2896693..890e100 100644 --- a/configs/P2041RDB_SECURE_BOOT_defconfig +++ b/configs/P2041RDB_SECURE_BOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SECURE_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P2041RDB_SPIFLASH_defconfig b/configs/P2041RDB_SPIFLASH_defconfig index f488251..9553ab5 100644 --- a/configs/P2041RDB_SPIFLASH_defconfig +++ b/configs/P2041RDB_SPIFLASH_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P2041RDB_SRIO_PCIE_BOOT_defconfig b/configs/P2041RDB_SRIO_PCIE_BOOT_defconfig index 0afbd0c..1eb8835 100644 --- a/configs/P2041RDB_SRIO_PCIE_BOOT_defconfig +++ b/configs/P2041RDB_SRIO_PCIE_BOOT_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF40000" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_SPI_FLASH=y diff --git a/configs/P2041RDB_defconfig b/configs/P2041RDB_defconfig index c234c71..887ff28 100644 --- a/configs/P2041RDB_defconfig +++ b/configs/P2041RDB_defconfig @@ -5,6 +5,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P3041DS_NAND_SECURE_BOOT_defconfig b/configs/P3041DS_NAND_SECURE_BOOT_defconfig index da81767..4684fc9 100644 --- a/configs/P3041DS_NAND_SECURE_BOOT_defconfig +++ b/configs/P3041DS_NAND_SECURE_BOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,NAND,SECURE_BOOT,SYS_TEXT_BASE=0xFFF40000" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P3041DS_NAND_defconfig b/configs/P3041DS_NAND_defconfig index db083a0..c238729 100644 --- a/configs/P3041DS_NAND_defconfig +++ b/configs/P3041DS_NAND_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF40000" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P3041DS_SDCARD_defconfig b/configs/P3041DS_SDCARD_defconfig index 43a7c59..a7995c3 100644 --- a/configs/P3041DS_SDCARD_defconfig +++ b/configs/P3041DS_SDCARD_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF40000" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P3041DS_SECURE_BOOT_defconfig b/configs/P3041DS_SECURE_BOOT_defconfig index b9bdac0..f3037ea 100644 --- a/configs/P3041DS_SECURE_BOOT_defconfig +++ b/configs/P3041DS_SECURE_BOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SECURE_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P3041DS_SPIFLASH_defconfig b/configs/P3041DS_SPIFLASH_defconfig index 8b861d3..9bbce6e 100644 --- a/configs/P3041DS_SPIFLASH_defconfig +++ b/configs/P3041DS_SPIFLASH_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P3041DS_SRIO_PCIE_BOOT_defconfig b/configs/P3041DS_SRIO_PCIE_BOOT_defconfig index c341b51..7499ff8 100644 --- a/configs/P3041DS_SRIO_PCIE_BOOT_defconfig +++ b/configs/P3041DS_SRIO_PCIE_BOOT_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF40000" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_SPI_FLASH=y diff --git a/configs/P3041DS_defconfig b/configs/P3041DS_defconfig index 3cc04a9..291c3d1 100644 --- a/configs/P3041DS_defconfig +++ b/configs/P3041DS_defconfig @@ -5,6 +5,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P4080DS_SDCARD_defconfig b/configs/P4080DS_SDCARD_defconfig index 492910b..febb822 100644 --- a/configs/P4080DS_SDCARD_defconfig +++ b/configs/P4080DS_SDCARD_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF40000" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P4080DS_SECURE_BOOT_defconfig b/configs/P4080DS_SECURE_BOOT_defconfig index 760194c..66dea95 100644 --- a/configs/P4080DS_SECURE_BOOT_defconfig +++ b/configs/P4080DS_SECURE_BOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SECURE_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P4080DS_SPIFLASH_defconfig b/configs/P4080DS_SPIFLASH_defconfig index ae2e13a..4774147 100644 --- a/configs/P4080DS_SPIFLASH_defconfig +++ b/configs/P4080DS_SPIFLASH_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P4080DS_SRIO_PCIE_BOOT_defconfig b/configs/P4080DS_SRIO_PCIE_BOOT_defconfig index baf548e..3aebc39 100644 --- a/configs/P4080DS_SRIO_PCIE_BOOT_defconfig +++ b/configs/P4080DS_SRIO_PCIE_BOOT_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF40000" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_SPI_FLASH=y diff --git a/configs/P4080DS_defconfig b/configs/P4080DS_defconfig index e2b96c3..aec0624 100644 --- a/configs/P4080DS_defconfig +++ b/configs/P4080DS_defconfig @@ -5,6 +5,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P5020DS_NAND_SECURE_BOOT_defconfig b/configs/P5020DS_NAND_SECURE_BOOT_defconfig index cb57053..99b3932 100644 --- a/configs/P5020DS_NAND_SECURE_BOOT_defconfig +++ b/configs/P5020DS_NAND_SECURE_BOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,NAND,SECURE_BOOT,SYS_TEXT_BASE=0xFFF40000" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P5020DS_NAND_defconfig b/configs/P5020DS_NAND_defconfig index a9ea36b..f70a45c 100644 --- a/configs/P5020DS_NAND_defconfig +++ b/configs/P5020DS_NAND_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF40000" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P5020DS_SDCARD_defconfig b/configs/P5020DS_SDCARD_defconfig index fb7bda6..448b489 100644 --- a/configs/P5020DS_SDCARD_defconfig +++ b/configs/P5020DS_SDCARD_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF40000" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P5020DS_SECURE_BOOT_defconfig b/configs/P5020DS_SECURE_BOOT_defconfig index 9d9ff67..298ee59 100644 --- a/configs/P5020DS_SECURE_BOOT_defconfig +++ b/configs/P5020DS_SECURE_BOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SECURE_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P5020DS_SPIFLASH_defconfig b/configs/P5020DS_SPIFLASH_defconfig index bc6c190..8ac8a9e 100644 --- a/configs/P5020DS_SPIFLASH_defconfig +++ b/configs/P5020DS_SPIFLASH_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P5020DS_SRIO_PCIE_BOOT_defconfig b/configs/P5020DS_SRIO_PCIE_BOOT_defconfig index a7d32bc..abbe15d 100644 --- a/configs/P5020DS_SRIO_PCIE_BOOT_defconfig +++ b/configs/P5020DS_SRIO_PCIE_BOOT_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF40000" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_SPI_FLASH=y diff --git a/configs/P5020DS_defconfig b/configs/P5020DS_defconfig index 00731af..5c272bb 100644 --- a/configs/P5020DS_defconfig +++ b/configs/P5020DS_defconfig @@ -5,6 +5,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P5040DS_NAND_SECURE_BOOT_defconfig b/configs/P5040DS_NAND_SECURE_BOOT_defconfig index 229cd56..84df506 100644 --- a/configs/P5040DS_NAND_SECURE_BOOT_defconfig +++ b/configs/P5040DS_NAND_SECURE_BOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,NAND,SECURE_BOOT,SYS_TEXT_BASE=0xFFF40000" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P5040DS_NAND_defconfig b/configs/P5040DS_NAND_defconfig index eeff54d..1a91eca 100644 --- a/configs/P5040DS_NAND_defconfig +++ b/configs/P5040DS_NAND_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF40000" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P5040DS_SDCARD_defconfig b/configs/P5040DS_SDCARD_defconfig index 6fafb44..72629a4 100644 --- a/configs/P5040DS_SDCARD_defconfig +++ b/configs/P5040DS_SDCARD_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF40000" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P5040DS_SECURE_BOOT_defconfig b/configs/P5040DS_SECURE_BOOT_defconfig index 9e35593..79b9f62 100644 --- a/configs/P5040DS_SECURE_BOOT_defconfig +++ b/configs/P5040DS_SECURE_BOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SECURE_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P5040DS_SPIFLASH_defconfig b/configs/P5040DS_SPIFLASH_defconfig index 28230ad..f71423d 100644 --- a/configs/P5040DS_SPIFLASH_defconfig +++ b/configs/P5040DS_SPIFLASH_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P5040DS_defconfig b/configs/P5040DS_defconfig index 388c1c0..2f2628e 100644 --- a/configs/P5040DS_defconfig +++ b/configs/P5040DS_defconfig @@ -5,6 +5,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/PIP405_defconfig b/configs/PIP405_defconfig index 046a5d8..2bac731 100644 --- a/configs/PIP405_defconfig +++ b/configs/PIP405_defconfig @@ -1,5 +1,6 @@ CONFIG_PPC=y CONFIG_4xx=y CONFIG_TARGET_PIP405=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y diff --git a/configs/Sinlinx_SinA31s_defconfig b/configs/Sinlinx_SinA31s_defconfig index ae1f1e8..02fa5e4 100644 --- a/configs/Sinlinx_SinA31s_defconfig +++ b/configs/Sinlinx_SinA31s_defconfig @@ -12,6 +12,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-sina31s" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Sinlinx_SinA33_defconfig b/configs/Sinlinx_SinA33_defconfig index 013c35e..ce1a70e 100644 --- a/configs/Sinlinx_SinA33_defconfig +++ b/configs/Sinlinx_SinA33_defconfig @@ -6,6 +6,7 @@ CONFIG_DRAM_ZQ=15291 CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-sinlinx-sina33" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Sinovoip_BPI_M2_defconfig b/configs/Sinovoip_BPI_M2_defconfig index 181e1e2..174de08 100644 --- a/configs/Sinovoip_BPI_M2_defconfig +++ b/configs/Sinovoip_BPI_M2_defconfig @@ -8,6 +8,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-sinovoip-bpi-m2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Sinovoip_BPI_M3_defconfig b/configs/Sinovoip_BPI_M3_defconfig index d3fd857..4b69996 100644 --- a/configs/Sinovoip_BPI_M3_defconfig +++ b/configs/Sinovoip_BPI_M3_defconfig @@ -14,6 +14,8 @@ CONFIG_AXP_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="sun8i-a83t-sinovoip-bpi-m3" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y +CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPD(25)" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set @@ -21,4 +23,3 @@ CONFIG_AXP_DCDC5_VOLT=1200 CONFIG_AXP_DLDO3_VOLT=2500 CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y -CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPD(25)" diff --git a/configs/T1023RDB_NAND_defconfig b/configs/T1023RDB_NAND_defconfig index 28d7e1f..48511ec 100644 --- a/configs/T1023RDB_NAND_defconfig +++ b/configs/T1023RDB_NAND_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1023,T1023RDB,RAMBOOT_PBL,SPL_FSL_PBL,NAND" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_SPI_FLASH=y diff --git a/configs/T1023RDB_SDCARD_defconfig b/configs/T1023RDB_SDCARD_defconfig index ce3bc30..aabd1a3 100644 --- a/configs/T1023RDB_SDCARD_defconfig +++ b/configs/T1023RDB_SDCARD_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1023,T1023RDB,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_SPI_FLASH=y diff --git a/configs/T1023RDB_SECURE_BOOT_defconfig b/configs/T1023RDB_SECURE_BOOT_defconfig index 0030f8d..16b3066 100644 --- a/configs/T1023RDB_SECURE_BOOT_defconfig +++ b/configs/T1023RDB_SECURE_BOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1023,T1023RDB,SECURE_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/T1023RDB_SPIFLASH_defconfig b/configs/T1023RDB_SPIFLASH_defconfig index 7b9c518..4b7ad52 100644 --- a/configs/T1023RDB_SPIFLASH_defconfig +++ b/configs/T1023RDB_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1023,T1023RDB,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_SPI_FLASH=y diff --git a/configs/T1023RDB_defconfig b/configs/T1023RDB_defconfig index d3131cb..d79763a 100644 --- a/configs/T1023RDB_defconfig +++ b/configs/T1023RDB_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1023,T1023RDB" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig b/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig index c4b2f1a..f15855b 100644 --- a/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig +++ b/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,SYS_FSL_DDR4,SECURE_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y diff --git a/configs/T1024QDS_DDR4_defconfig b/configs/T1024QDS_DDR4_defconfig index 7a7cf65..dac71a9 100644 --- a/configs/T1024QDS_DDR4_defconfig +++ b/configs/T1024QDS_DDR4_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,SYS_FSL_DDR4" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T1024QDS_NAND_defconfig b/configs/T1024QDS_NAND_defconfig index 308e009..5adfe02 100644 --- a/configs/T1024QDS_NAND_defconfig +++ b/configs/T1024QDS_NAND_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,RAMBOOT_PBL,SPL_FSL_PBL,NAND" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T1024QDS_SDCARD_defconfig b/configs/T1024QDS_SDCARD_defconfig index c12abf4..7748356 100644 --- a/configs/T1024QDS_SDCARD_defconfig +++ b/configs/T1024QDS_SDCARD_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T1024QDS_SECURE_BOOT_defconfig b/configs/T1024QDS_SECURE_BOOT_defconfig index bd96807..447283b 100644 --- a/configs/T1024QDS_SECURE_BOOT_defconfig +++ b/configs/T1024QDS_SECURE_BOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,SECURE_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y diff --git a/configs/T1024QDS_SPIFLASH_defconfig b/configs/T1024QDS_SPIFLASH_defconfig index 8874033..3c68c9f 100644 --- a/configs/T1024QDS_SPIFLASH_defconfig +++ b/configs/T1024QDS_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T1024QDS_defconfig b/configs/T1024QDS_defconfig index 42b9552..9a1d324 100644 --- a/configs/T1024QDS_defconfig +++ b/configs/T1024QDS_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T1024RDB_NAND_defconfig b/configs/T1024RDB_NAND_defconfig index e2e9373..5f34727 100644 --- a/configs/T1024RDB_NAND_defconfig +++ b/configs/T1024RDB_NAND_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,T1024RDB,RAMBOOT_PBL,SPL_FSL_PBL,NAND" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1024RDB_SDCARD_defconfig b/configs/T1024RDB_SDCARD_defconfig index c68982c..474ae53 100644 --- a/configs/T1024RDB_SDCARD_defconfig +++ b/configs/T1024RDB_SDCARD_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,T1024RDB,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1024RDB_SECURE_BOOT_defconfig b/configs/T1024RDB_SECURE_BOOT_defconfig index 9f29bbf..1eba789 100644 --- a/configs/T1024RDB_SECURE_BOOT_defconfig +++ b/configs/T1024RDB_SECURE_BOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,T1024RDB,SECURE_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T1024RDB_SPIFLASH_defconfig b/configs/T1024RDB_SPIFLASH_defconfig index 712eec4..c4918a7 100644 --- a/configs/T1024RDB_SPIFLASH_defconfig +++ b/configs/T1024RDB_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,T1024RDB,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1024RDB_defconfig b/configs/T1024RDB_defconfig index b1f5549..9878b65 100644 --- a/configs/T1024RDB_defconfig +++ b/configs/T1024RDB_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,T1024RDB" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1040D4RDB_NAND_defconfig b/configs/T1040D4RDB_NAND_defconfig index b2fe48a..b27dd6c 100644 --- a/configs/T1040D4RDB_NAND_defconfig +++ b/configs/T1040D4RDB_NAND_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,NAND,T104XD4RDB,SYS_FSL_DDR4" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1040D4RDB_SDCARD_defconfig b/configs/T1040D4RDB_SDCARD_defconfig index f93b541..67cdc3a 100644 --- a/configs/T1040D4RDB_SDCARD_defconfig +++ b/configs/T1040D4RDB_SDCARD_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD,T104XD4RDB,SYS_FSL_DDR4" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1040D4RDB_SECURE_BOOT_defconfig b/configs/T1040D4RDB_SECURE_BOOT_defconfig index 1e1c5cc..3c7296d 100644 --- a/configs/T1040D4RDB_SECURE_BOOT_defconfig +++ b/configs/T1040D4RDB_SECURE_BOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040D4RDB,T104XD4RDB,SYS_FSL_DDR4,SECURE_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T1040D4RDB_SPIFLASH_defconfig b/configs/T1040D4RDB_SPIFLASH_defconfig index ee68bf7..94aea4f 100644 --- a/configs/T1040D4RDB_SPIFLASH_defconfig +++ b/configs/T1040D4RDB_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH,T104XD4RDB,SYS_FSL_DDR4" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1040D4RDB_defconfig b/configs/T1040D4RDB_defconfig index 744e37d..d5513f5 100644 --- a/configs/T1040D4RDB_defconfig +++ b/configs/T1040D4RDB_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040D4RDB,T104XD4RDB,SYS_FSL_DDR4" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1040QDS_DDR4_defconfig b/configs/T1040QDS_DDR4_defconfig index 6a4332a..5d54cb5 100644 --- a/configs/T1040QDS_DDR4_defconfig +++ b/configs/T1040QDS_DDR4_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,SYS_FSL_DDR4" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T1040QDS_SECURE_BOOT_defconfig b/configs/T1040QDS_SECURE_BOOT_defconfig index 46fed6d..fb37784 100644 --- a/configs/T1040QDS_SECURE_BOOT_defconfig +++ b/configs/T1040QDS_SECURE_BOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,SECURE_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y diff --git a/configs/T1040QDS_defconfig b/configs/T1040QDS_defconfig index 5b1ddb6..5d02f71 100644 --- a/configs/T1040QDS_defconfig +++ b/configs/T1040QDS_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T1040RDB_NAND_defconfig b/configs/T1040RDB_NAND_defconfig index 7198bb2..6512dad 100644 --- a/configs/T1040RDB_NAND_defconfig +++ b/configs/T1040RDB_NAND_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040RDB,RAMBOOT_PBL,SPL_FSL_PBL,NAND" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1040RDB_SDCARD_defconfig b/configs/T1040RDB_SDCARD_defconfig index a60420b..a878194 100644 --- a/configs/T1040RDB_SDCARD_defconfig +++ b/configs/T1040RDB_SDCARD_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040RDB,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1040RDB_SECURE_BOOT_defconfig b/configs/T1040RDB_SECURE_BOOT_defconfig index 7bc8872..9570b7b 100644 --- a/configs/T1040RDB_SECURE_BOOT_defconfig +++ b/configs/T1040RDB_SECURE_BOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,SECURE_BOOT,T1040RDB" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T1040RDB_SPIFLASH_defconfig b/configs/T1040RDB_SPIFLASH_defconfig index 3492c83..82e8f0f 100644 --- a/configs/T1040RDB_SPIFLASH_defconfig +++ b/configs/T1040RDB_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040RDB,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1040RDB_defconfig b/configs/T1040RDB_defconfig index 17cdce3..fa6bbfc 100644 --- a/configs/T1040RDB_defconfig +++ b/configs/T1040RDB_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040RDB" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1042D4RDB_NAND_defconfig b/configs/T1042D4RDB_NAND_defconfig index 99e6723..9c09bf0 100644 --- a/configs/T1042D4RDB_NAND_defconfig +++ b/configs/T1042D4RDB_NAND_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,NAND,T104XD4RDB,SYS_FSL_DDR4" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1042D4RDB_SDCARD_defconfig b/configs/T1042D4RDB_SDCARD_defconfig index 9101b9b..2b8f5de 100644 --- a/configs/T1042D4RDB_SDCARD_defconfig +++ b/configs/T1042D4RDB_SDCARD_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD,T104XD4RDB,SYS_FSL_DDR4" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1042D4RDB_SECURE_BOOT_defconfig b/configs/T1042D4RDB_SECURE_BOOT_defconfig index 9764c1d..906b243 100644 --- a/configs/T1042D4RDB_SECURE_BOOT_defconfig +++ b/configs/T1042D4RDB_SECURE_BOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042D4RDB,T104XD4RDB,SYS_FSL_DDR4,SECURE_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T1042D4RDB_SPIFLASH_defconfig b/configs/T1042D4RDB_SPIFLASH_defconfig index 1d1799b..1025ce4 100644 --- a/configs/T1042D4RDB_SPIFLASH_defconfig +++ b/configs/T1042D4RDB_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH,T104XD4RDB,SYS_FSL_DDR4" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1042D4RDB_defconfig b/configs/T1042D4RDB_defconfig index 56f9f4e..0ad874a 100644 --- a/configs/T1042D4RDB_defconfig +++ b/configs/T1042D4RDB_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042D4RDB,T104XD4RDB,SYS_FSL_DDR4" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1042RDB_PI_NAND_defconfig b/configs/T1042RDB_PI_NAND_defconfig index f079ccb..a37117f 100644 --- a/configs/T1042RDB_PI_NAND_defconfig +++ b/configs/T1042RDB_PI_NAND_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042RDB_PI,RAMBOOT_PBL,SPL_FSL_PBL,NAND" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1042RDB_PI_SDCARD_defconfig b/configs/T1042RDB_PI_SDCARD_defconfig index b78eb28..4d5ca01 100644 --- a/configs/T1042RDB_PI_SDCARD_defconfig +++ b/configs/T1042RDB_PI_SDCARD_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042RDB_PI,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1042RDB_PI_SPIFLASH_defconfig b/configs/T1042RDB_PI_SPIFLASH_defconfig index 11df100..0de0b4c 100644 --- a/configs/T1042RDB_PI_SPIFLASH_defconfig +++ b/configs/T1042RDB_PI_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042RDB_PI,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1042RDB_PI_defconfig b/configs/T1042RDB_PI_defconfig index dd4a2cc..99cdd37 100644 --- a/configs/T1042RDB_PI_defconfig +++ b/configs/T1042RDB_PI_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042RDB_PI" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1042RDB_SECURE_BOOT_defconfig b/configs/T1042RDB_SECURE_BOOT_defconfig index 65d51c7..41ad0e2 100644 --- a/configs/T1042RDB_SECURE_BOOT_defconfig +++ b/configs/T1042RDB_SECURE_BOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,SECURE_BOOT,T1042RDB" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T1042RDB_defconfig b/configs/T1042RDB_defconfig index 421ebd6..cedd085 100644 --- a/configs/T1042RDB_defconfig +++ b/configs/T1042RDB_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042RDB" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T2080QDS_NAND_defconfig b/configs/T2080QDS_NAND_defconfig index 55463a6..9025458 100644 --- a/configs/T2080QDS_NAND_defconfig +++ b/configs/T2080QDS_NAND_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2080,RAMBOOT_PBL,SPL_FSL_PBL,NAND" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T2080QDS_SDCARD_defconfig b/configs/T2080QDS_SDCARD_defconfig index 4074a65..572da36 100644 --- a/configs/T2080QDS_SDCARD_defconfig +++ b/configs/T2080QDS_SDCARD_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2080,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T2080QDS_SECURE_BOOT_defconfig b/configs/T2080QDS_SECURE_BOOT_defconfig index 7beaad7..a2d3df4 100644 --- a/configs/T2080QDS_SECURE_BOOT_defconfig +++ b/configs/T2080QDS_SECURE_BOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2080,SECURE_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y diff --git a/configs/T2080QDS_SPIFLASH_defconfig b/configs/T2080QDS_SPIFLASH_defconfig index 7c7b131..b4bd589 100644 --- a/configs/T2080QDS_SPIFLASH_defconfig +++ b/configs/T2080QDS_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2080,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig b/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig index e30048a..75c7860 100644 --- a/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig +++ b/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2080,SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF40000" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_SPI_FLASH=y diff --git a/configs/T2080QDS_defconfig b/configs/T2080QDS_defconfig index a2236e1..dd2343d 100644 --- a/configs/T2080QDS_defconfig +++ b/configs/T2080QDS_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2080" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T2080RDB_NAND_defconfig b/configs/T2080RDB_NAND_defconfig index 9753814..8f7e7ee 100644 --- a/configs/T2080RDB_NAND_defconfig +++ b/configs/T2080RDB_NAND_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2080,RAMBOOT_PBL,SPL_FSL_PBL,NAND" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T2080RDB_SDCARD_defconfig b/configs/T2080RDB_SDCARD_defconfig index 75d33c5..325dbfa 100644 --- a/configs/T2080RDB_SDCARD_defconfig +++ b/configs/T2080RDB_SDCARD_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2080,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T2080RDB_SECURE_BOOT_defconfig b/configs/T2080RDB_SECURE_BOOT_defconfig index 33f7d5f..261e027 100644 --- a/configs/T2080RDB_SECURE_BOOT_defconfig +++ b/configs/T2080RDB_SECURE_BOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2080,SECURE_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T2080RDB_SPIFLASH_defconfig b/configs/T2080RDB_SPIFLASH_defconfig index 07a5b06..b7287b0 100644 --- a/configs/T2080RDB_SPIFLASH_defconfig +++ b/configs/T2080RDB_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2080,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T2080RDB_SRIO_PCIE_BOOT_defconfig b/configs/T2080RDB_SRIO_PCIE_BOOT_defconfig index c1549c1..e72878d 100644 --- a/configs/T2080RDB_SRIO_PCIE_BOOT_defconfig +++ b/configs/T2080RDB_SRIO_PCIE_BOOT_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2080,SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF40000" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_SPI_FLASH=y diff --git a/configs/T2080RDB_defconfig b/configs/T2080RDB_defconfig index ab5453c..abe0d2b 100644 --- a/configs/T2080RDB_defconfig +++ b/configs/T2080RDB_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2080" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T2081QDS_NAND_defconfig b/configs/T2081QDS_NAND_defconfig index 6275d27..16b38ec 100644 --- a/configs/T2081QDS_NAND_defconfig +++ b/configs/T2081QDS_NAND_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2081,RAMBOOT_PBL,SPL_FSL_PBL,NAND" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T2081QDS_SDCARD_defconfig b/configs/T2081QDS_SDCARD_defconfig index 9c805d0..cd25ea9 100644 --- a/configs/T2081QDS_SDCARD_defconfig +++ b/configs/T2081QDS_SDCARD_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2081,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T2081QDS_SPIFLASH_defconfig b/configs/T2081QDS_SPIFLASH_defconfig index 2cef3ec..63cfc78 100644 --- a/configs/T2081QDS_SPIFLASH_defconfig +++ b/configs/T2081QDS_SPIFLASH_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2081,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T2081QDS_SRIO_PCIE_BOOT_defconfig b/configs/T2081QDS_SRIO_PCIE_BOOT_defconfig index b8bb371..5048d46 100644 --- a/configs/T2081QDS_SRIO_PCIE_BOOT_defconfig +++ b/configs/T2081QDS_SRIO_PCIE_BOOT_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2081,SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF40000" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_SPI_FLASH=y diff --git a/configs/T2081QDS_defconfig b/configs/T2081QDS_defconfig index f8488b6..d73d8f2 100644 --- a/configs/T2081QDS_defconfig +++ b/configs/T2081QDS_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2081" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T4160QDS_NAND_defconfig b/configs/T4160QDS_NAND_defconfig index 255ae58..27c4543 100644 --- a/configs/T4160QDS_NAND_defconfig +++ b/configs/T4160QDS_NAND_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T4160,RAMBOOT_PBL,SPL_FSL_PBL,NAND" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/T4160QDS_SDCARD_defconfig b/configs/T4160QDS_SDCARD_defconfig index c74aecf..a283293 100644 --- a/configs/T4160QDS_SDCARD_defconfig +++ b/configs/T4160QDS_SDCARD_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T4160,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/T4160QDS_SECURE_BOOT_defconfig b/configs/T4160QDS_SECURE_BOOT_defconfig index f430c34..80c3318 100644 --- a/configs/T4160QDS_SECURE_BOOT_defconfig +++ b/configs/T4160QDS_SECURE_BOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T4160,SECURE_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/T4160QDS_defconfig b/configs/T4160QDS_defconfig index 191370f..015f85d 100644 --- a/configs/T4160QDS_defconfig +++ b/configs/T4160QDS_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T4160" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/T4160RDB_defconfig b/configs/T4160RDB_defconfig index 1ffecc3..d0979b1 100644 --- a/configs/T4160RDB_defconfig +++ b/configs/T4160RDB_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T4160" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/T4240QDS_NAND_defconfig b/configs/T4240QDS_NAND_defconfig index 8bd2174..c8e3a9b 100644 --- a/configs/T4240QDS_NAND_defconfig +++ b/configs/T4240QDS_NAND_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T4240,RAMBOOT_PBL,SPL_FSL_PBL,NAND" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/T4240QDS_SDCARD_defconfig b/configs/T4240QDS_SDCARD_defconfig index fa4f1dd..30cbeb9 100644 --- a/configs/T4240QDS_SDCARD_defconfig +++ b/configs/T4240QDS_SDCARD_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T4240,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/T4240QDS_SECURE_BOOT_defconfig b/configs/T4240QDS_SECURE_BOOT_defconfig index 2737244..6e19e3a 100644 --- a/configs/T4240QDS_SECURE_BOOT_defconfig +++ b/configs/T4240QDS_SECURE_BOOT_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T4240,SECURE_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/T4240QDS_SRIO_PCIE_BOOT_defconfig b/configs/T4240QDS_SRIO_PCIE_BOOT_defconfig index 10513aa..4c8932c 100644 --- a/configs/T4240QDS_SRIO_PCIE_BOOT_defconfig +++ b/configs/T4240QDS_SRIO_PCIE_BOOT_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T4240,SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF40000" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_SPI_FLASH=y diff --git a/configs/T4240QDS_defconfig b/configs/T4240QDS_defconfig index a6525aa..e374328 100644 --- a/configs/T4240QDS_defconfig +++ b/configs/T4240QDS_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T4240" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/T4240RDB_SDCARD_defconfig b/configs/T4240RDB_SDCARD_defconfig index a124477..b8589b6 100644 --- a/configs/T4240RDB_SDCARD_defconfig +++ b/configs/T4240RDB_SDCARD_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T4240,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/T4240RDB_defconfig b/configs/T4240RDB_defconfig index fc622c9..c622fa6 100644 --- a/configs/T4240RDB_defconfig +++ b/configs/T4240RDB_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T4240" +CONFIG_HUSH_PARSER=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/TQM5200S_HIGHBOOT_defconfig b/configs/TQM5200S_HIGHBOOT_defconfig index c7c0931..71b4592 100644 --- a/configs/TQM5200S_HIGHBOOT_defconfig +++ b/configs/TQM5200S_HIGHBOOT_defconfig @@ -3,5 +3,6 @@ CONFIG_MPC5xxx=y CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="TQM5200_B,TQM5200S,SYS_TEXT_BASE=0xFFF00000" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM5200S_defconfig b/configs/TQM5200S_defconfig index cb1119b..960cc3c 100644 --- a/configs/TQM5200S_defconfig +++ b/configs/TQM5200S_defconfig @@ -3,5 +3,6 @@ CONFIG_MPC5xxx=y CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="TQM5200_B,TQM5200S" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM5200_B_HIGHBOOT_defconfig b/configs/TQM5200_B_HIGHBOOT_defconfig index 30327a9..14afa02 100644 --- a/configs/TQM5200_B_HIGHBOOT_defconfig +++ b/configs/TQM5200_B_HIGHBOOT_defconfig @@ -3,5 +3,6 @@ CONFIG_MPC5xxx=y CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="TQM5200_B,SYS_TEXT_BASE=0xFFF00000" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM5200_B_defconfig b/configs/TQM5200_B_defconfig index d21c148..c49fc53 100644 --- a/configs/TQM5200_B_defconfig +++ b/configs/TQM5200_B_defconfig @@ -3,5 +3,6 @@ CONFIG_MPC5xxx=y CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="TQM5200_B" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM5200_STK100_defconfig b/configs/TQM5200_STK100_defconfig index 1f88448..fcd8b35 100644 --- a/configs/TQM5200_STK100_defconfig +++ b/configs/TQM5200_STK100_defconfig @@ -3,5 +3,6 @@ CONFIG_MPC5xxx=y CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="STK52XX_REV100" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM5200_defconfig b/configs/TQM5200_defconfig index 7803ea1..bb04df5 100644 --- a/configs/TQM5200_defconfig +++ b/configs/TQM5200_defconfig @@ -2,5 +2,6 @@ CONFIG_PPC=y CONFIG_MPC5xxx=y CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM823L_LCD_defconfig b/configs/TQM823L_LCD_defconfig index 74cdec6..285e773 100644 --- a/configs/TQM823L_LCD_defconfig +++ b/configs/TQM823L_LCD_defconfig @@ -3,5 +3,6 @@ CONFIG_8xx=y CONFIG_TARGET_TQM823L=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="LCD,NEC_NL6448BC20" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM823L_defconfig b/configs/TQM823L_defconfig index 08d1af6..5148764 100644 --- a/configs/TQM823L_defconfig +++ b/configs/TQM823L_defconfig @@ -2,5 +2,6 @@ CONFIG_PPC=y CONFIG_8xx=y CONFIG_TARGET_TQM823L=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM823M_defconfig b/configs/TQM823M_defconfig index 666a339..8f6b674 100644 --- a/configs/TQM823M_defconfig +++ b/configs/TQM823M_defconfig @@ -2,5 +2,6 @@ CONFIG_PPC=y CONFIG_8xx=y CONFIG_TARGET_TQM823M=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM834x_defconfig b/configs/TQM834x_defconfig index 26ddc10..af4a72d 100644 --- a/configs/TQM834x_defconfig +++ b/configs/TQM834x_defconfig @@ -3,6 +3,7 @@ CONFIG_MPC83xx=y CONFIG_TARGET_TQM834X=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM850L_defconfig b/configs/TQM850L_defconfig index 2d78e79..646c552 100644 --- a/configs/TQM850L_defconfig +++ b/configs/TQM850L_defconfig @@ -2,5 +2,6 @@ CONFIG_PPC=y CONFIG_8xx=y CONFIG_TARGET_TQM850L=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM850M_defconfig b/configs/TQM850M_defconfig index 4c66cc1..63941ac 100644 --- a/configs/TQM850M_defconfig +++ b/configs/TQM850M_defconfig @@ -2,5 +2,6 @@ CONFIG_PPC=y CONFIG_8xx=y CONFIG_TARGET_TQM850M=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM855L_defconfig b/configs/TQM855L_defconfig index 6bebf60..869a7d3 100644 --- a/configs/TQM855L_defconfig +++ b/configs/TQM855L_defconfig @@ -2,5 +2,6 @@ CONFIG_PPC=y CONFIG_8xx=y CONFIG_TARGET_TQM855L=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM855M_defconfig b/configs/TQM855M_defconfig index e600cd0..8022398 100644 --- a/configs/TQM855M_defconfig +++ b/configs/TQM855M_defconfig @@ -2,5 +2,6 @@ CONFIG_PPC=y CONFIG_8xx=y CONFIG_TARGET_TQM855M=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM860L_defconfig b/configs/TQM860L_defconfig index 2295e42..7b24eeb 100644 --- a/configs/TQM860L_defconfig +++ b/configs/TQM860L_defconfig @@ -2,5 +2,6 @@ CONFIG_PPC=y CONFIG_8xx=y CONFIG_TARGET_TQM860L=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM860M_defconfig b/configs/TQM860M_defconfig index 81e5fbf..672ad4c 100644 --- a/configs/TQM860M_defconfig +++ b/configs/TQM860M_defconfig @@ -2,5 +2,6 @@ CONFIG_PPC=y CONFIG_8xx=y CONFIG_TARGET_TQM860M=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM862L_defconfig b/configs/TQM862L_defconfig index 41dd2fd..af57396 100644 --- a/configs/TQM862L_defconfig +++ b/configs/TQM862L_defconfig @@ -2,5 +2,6 @@ CONFIG_PPC=y CONFIG_8xx=y CONFIG_TARGET_TQM862L=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM862M_defconfig b/configs/TQM862M_defconfig index 9915cc9..cd76e95 100644 --- a/configs/TQM862M_defconfig +++ b/configs/TQM862M_defconfig @@ -2,5 +2,6 @@ CONFIG_PPC=y CONFIG_8xx=y CONFIG_TARGET_TQM862M=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM866M_defconfig b/configs/TQM866M_defconfig index ef1f78c..403ec90 100644 --- a/configs/TQM866M_defconfig +++ b/configs/TQM866M_defconfig @@ -2,5 +2,6 @@ CONFIG_PPC=y CONFIG_8xx=y CONFIG_TARGET_TQM866M=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TQM885D_defconfig b/configs/TQM885D_defconfig index 7fbdd86..f9d8610 100644 --- a/configs/TQM885D_defconfig +++ b/configs/TQM885D_defconfig @@ -2,5 +2,6 @@ CONFIG_PPC=y CONFIG_8xx=y CONFIG_TARGET_TQM885D=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TTTech_defconfig b/configs/TTTech_defconfig index ade4fa8..a58e0aa 100644 --- a/configs/TTTech_defconfig +++ b/configs/TTTech_defconfig @@ -3,5 +3,6 @@ CONFIG_8xx=y CONFIG_TARGET_TQM823L=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="LCD,SHARP_LQ104V7DS01" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/TWR-P1025_defconfig b/configs/TWR-P1025_defconfig index 199ebf1..31db63d 100644 --- a/configs/TWR-P1025_defconfig +++ b/configs/TWR-P1025_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="TWR_P1025" +CONFIG_HUSH_PARSER=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/UCP1020_SPIFLASH_defconfig b/configs/UCP1020_SPIFLASH_defconfig index 52750f4..f2b833d 100644 --- a/configs/UCP1020_SPIFLASH_defconfig +++ b/configs/UCP1020_SPIFLASH_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc>" to stop\n" CONFIG_AUTOBOOT_STOP_STR="\x1b" diff --git a/configs/UCP1020_defconfig b/configs/UCP1020_defconfig index 0633752..c94c3b7 100644 --- a/configs/UCP1020_defconfig +++ b/configs/UCP1020_defconfig @@ -5,6 +5,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="B$ " CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc>" to stop\n" diff --git a/configs/UTOO_P66_defconfig b/configs/UTOO_P66_defconfig index d36a5dc..bf17a63 100644 --- a/configs/UTOO_P66_defconfig +++ b/configs/UTOO_P66_defconfig @@ -20,6 +20,7 @@ CONFIG_VIDEO_LCD_TL059WV5C0=y CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-utoo-p66" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/VCMA9_defconfig b/configs/VCMA9_defconfig index 927967d..0996af0 100644 --- a/configs/VCMA9_defconfig +++ b/configs/VCMA9_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y CONFIG_TARGET_VCMA9=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="VCMA9 # " # CONFIG_CMD_SETEXPR is not set diff --git a/configs/Wexler_TAB7200_defconfig b/configs/Wexler_TAB7200_defconfig index 5f3d624..cdcd4eb 100644 --- a/configs/Wexler_TAB7200_defconfig +++ b/configs/Wexler_TAB7200_defconfig @@ -13,6 +13,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-wexler-tab7200" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Wits_Pro_A20_DKT_defconfig b/configs/Wits_Pro_A20_DKT_defconfig index bfc8cba..5d0f327 100644 --- a/configs/Wits_Pro_A20_DKT_defconfig +++ b/configs/Wits_Pro_A20_DKT_defconfig @@ -12,6 +12,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-wits-pro-a20-dkt" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,AHCI" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Wobo_i5_defconfig b/configs/Wobo_i5_defconfig index fc43cc5..cb21222 100644 --- a/configs/Wobo_i5_defconfig +++ b/configs/Wobo_i5_defconfig @@ -7,6 +7,7 @@ CONFIG_USB1_VBUS_PIN="PG12" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-wobo-i5" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Yones_Toptech_BD1078_defconfig b/configs/Yones_Toptech_BD1078_defconfig index 65c1d8e..2f2c26b 100644 --- a/configs/Yones_Toptech_BD1078_defconfig +++ b/configs/Yones_Toptech_BD1078_defconfig @@ -19,6 +19,7 @@ CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-yones-toptech-bd1078" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/Yones_Toptech_BS1078_V2_defconfig b/configs/Yones_Toptech_BS1078_V2_defconfig index 958104e..a5b215f 100644 --- a/configs/Yones_Toptech_BS1078_V2_defconfig +++ b/configs/Yones_Toptech_BS1078_V2_defconfig @@ -16,6 +16,7 @@ CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-yones-toptech-bs1078-v2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/a3m071_defconfig b/configs/a3m071_defconfig index 0662d40..abc6241 100644 --- a/configs/a3m071_defconfig +++ b/configs/a3m071_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_A3M071=y CONFIG_SPL=y CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_LIB_RAND=y CONFIG_OF_LIBFDT=y diff --git a/configs/a4m072_defconfig b/configs/a4m072_defconfig index bbc140d..f9ac1fc 100644 --- a/configs/a4m072_defconfig +++ b/configs/a4m072_defconfig @@ -2,6 +2,7 @@ CONFIG_PPC=y CONFIG_MPC5xxx=y CONFIG_TARGET_A4M072=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="autoboot in %d seconds\n" CONFIG_AUTOBOOT_DELAY_STR="asdfg" diff --git a/configs/a4m2k_defconfig b/configs/a4m2k_defconfig index dbc5de8..356949e 100644 --- a/configs/a4m2k_defconfig +++ b/configs/a4m2k_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL=y CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="A4M2K" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_LIB_RAND=y CONFIG_OF_LIBFDT=y diff --git a/configs/acadia_defconfig b/configs/acadia_defconfig index 6434f4b..4a985cc 100644 --- a/configs/acadia_defconfig +++ b/configs/acadia_defconfig @@ -2,5 +2,6 @@ CONFIG_PPC=y CONFIG_4xx=y CONFIG_TARGET_ACADIA=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/am335x_baltos_defconfig b/configs/am335x_baltos_defconfig index e43a121..51cabb4 100644 --- a/configs/am335x_baltos_defconfig +++ b/configs/am335x_baltos_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="NAND" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/am335x_boneblack_defconfig b/configs/am335x_boneblack_defconfig index d8e793f..7e0dcf5 100644 --- a/configs/am335x_boneblack_defconfig +++ b/configs/am335x_boneblack_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="EMMC_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" CONFIG_AUTOBOOT_DELAY_STR="d" diff --git a/configs/am335x_boneblack_vboot_defconfig b/configs/am335x_boneblack_vboot_defconfig index 10d4311..e5daa94 100644 --- a/configs/am335x_boneblack_vboot_defconfig +++ b/configs/am335x_boneblack_vboot_defconfig @@ -8,6 +8,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_FIT_SIGNATURE=y CONFIG_SYS_EXTRA_OPTIONS="EMMC_BOOT,ENABLE_VBOOT" +CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" CONFIG_AUTOBOOT_DELAY_STR="d" diff --git a/configs/am335x_evm_defconfig b/configs/am335x_evm_defconfig index 5ca0f24..d40a9e6 100644 --- a/configs/am335x_evm_defconfig +++ b/configs/am335x_evm_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="NAND" +CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" CONFIG_AUTOBOOT_DELAY_STR="d" diff --git a/configs/am335x_evm_nor_defconfig b/configs/am335x_evm_nor_defconfig index bc84100..aebfb58 100644 --- a/configs/am335x_evm_nor_defconfig +++ b/configs/am335x_evm_nor_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="NAND" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/am335x_evm_norboot_defconfig b/configs/am335x_evm_norboot_defconfig index 4a724aa..bc4f667 100644 --- a/configs/am335x_evm_norboot_defconfig +++ b/configs/am335x_evm_norboot_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_AM335X_EVM=y CONFIG_NOR=y CONFIG_NOR_BOOT=y CONFIG_FIT=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/am335x_evm_spiboot_defconfig b/configs/am335x_evm_spiboot_defconfig index 5428941..346def4 100644 --- a/configs/am335x_evm_spiboot_defconfig +++ b/configs/am335x_evm_spiboot_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="SPI_BOOT" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/am335x_evm_usbspl_defconfig b/configs/am335x_evm_usbspl_defconfig index 7f7a55d..c457f6f 100644 --- a/configs/am335x_evm_usbspl_defconfig +++ b/configs/am335x_evm_usbspl_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="NAND,SPL_USBETH_SUPPORT" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/am335x_gp_evm_defconfig b/configs/am335x_gp_evm_defconfig index 1ee07c9..554af51 100644 --- a/configs/am335x_gp_evm_defconfig +++ b/configs/am335x_gp_evm_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="NAND" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/am335x_igep0033_defconfig b/configs/am335x_igep0033_defconfig index 5d448c3..3d0d215 100644 --- a/configs/am335x_igep0033_defconfig +++ b/configs/am335x_igep0033_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_AM335X_IGEP0033=y CONFIG_SPL_STACK_R_ADDR=0x82000000 CONFIG_SPL=y CONFIG_SPL_STACK_R=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/am335x_sl50_defconfig b/configs/am335x_sl50_defconfig index 0b6c11f..2eca61c 100644 --- a/configs/am335x_sl50_defconfig +++ b/configs/am335x_sl50_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="EMMC_BOOT" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/am3517_crane_defconfig b/configs/am3517_crane_defconfig index 72172cf..b9115af 100644 --- a/configs/am3517_crane_defconfig +++ b/configs/am3517_crane_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_OMAP34XX=y CONFIG_TARGET_AM3517_CRANE=y CONFIG_SPL=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="AM3517_CRANE # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index 6a38f98..b9edf0d 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_AM3517_EVM=y CONFIG_SPL=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="NAND" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="AM3517_EVM # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/am437x_gp_evm_defconfig b/configs/am437x_gp_evm_defconfig index 69f5ac7..742e148 100644 --- a/configs/am437x_gp_evm_defconfig +++ b/configs/am437x_gp_evm_defconfig @@ -7,6 +7,7 @@ CONFIG_DEFAULT_DEVICE_TREE="am437x-gp-evm" CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/am437x_sk_evm_defconfig b/configs/am437x_sk_evm_defconfig index c7a9fbe..276d14a 100644 --- a/configs/am437x_sk_evm_defconfig +++ b/configs/am437x_sk_evm_defconfig @@ -9,6 +9,7 @@ CONFIG_DEFAULT_DEVICE_TREE="am437x-sk-evm" CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/am43xx_evm_defconfig b/configs/am43xx_evm_defconfig index d6a1c3c..aee1584 100644 --- a/configs/am43xx_evm_defconfig +++ b/configs/am43xx_evm_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_AM43XX_EVM=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,NAND" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/am43xx_evm_ethboot_defconfig b/configs/am43xx_evm_ethboot_defconfig index 67a9d49..b435ea7 100644 --- a/configs/am43xx_evm_ethboot_defconfig +++ b/configs/am43xx_evm_ethboot_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_AM43XX_EVM=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,NAND,SPL_ETH_SUPPORT" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/am43xx_evm_qspiboot_defconfig b/configs/am43xx_evm_qspiboot_defconfig index 2194b16..81afd7b 100644 --- a/configs/am43xx_evm_qspiboot_defconfig +++ b/configs/am43xx_evm_qspiboot_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_AM43XX_EVM=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,QSPI,QSPI_BOOT" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/am43xx_evm_usbhost_boot_defconfig b/configs/am43xx_evm_usbhost_boot_defconfig index 6840453..218b524 100644 --- a/configs/am43xx_evm_usbhost_boot_defconfig +++ b/configs/am43xx_evm_usbhost_boot_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_AM43XX_EVM=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,NAND,SPL_USB_HOST_SUPPORT" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/am57xx_evm_defconfig b/configs/am57xx_evm_defconfig index e40c24a..3b1fed2 100644 --- a/configs/am57xx_evm_defconfig +++ b/configs/am57xx_evm_defconfig @@ -7,6 +7,7 @@ CONFIG_SPL_STACK_R_ADDR=0x82000000 CONFIG_DEFAULT_DEVICE_TREE="am57xx-beagle-x15" CONFIG_SPL=y CONFIG_SPL_STACK_R=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/am57xx_evm_nodt_defconfig b/configs/am57xx_evm_nodt_defconfig index cb91719..375c10c 100644 --- a/configs/am57xx_evm_nodt_defconfig +++ b/configs/am57xx_evm_nodt_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_OMAP54XX=y CONFIG_TARGET_BEAGLE_X15=y CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/apalis_t30_defconfig b/configs/apalis_t30_defconfig index 0686129..79031d2 100644 --- a/configs/apalis_t30_defconfig +++ b/configs/apalis_t30_defconfig @@ -5,6 +5,7 @@ CONFIG_TEGRA30=y CONFIG_TARGET_APALIS_T30=y CONFIG_DEFAULT_DEVICE_TREE="tegra30-apalis" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Apalis T30 # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/apf27_defconfig b/configs/apf27_defconfig index 3d6fe7b..5143e26 100644 --- a/configs/apf27_defconfig +++ b/configs/apf27_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_APF27=y CONFIG_SPL=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="BIOS> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/apx4devkit_defconfig b/configs/apx4devkit_defconfig index e69fce2..8352247 100644 --- a/configs/apx4devkit_defconfig +++ b/configs/apx4devkit_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_APX4DEVKIT=y CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set diff --git a/configs/arches_defconfig b/configs/arches_defconfig index 9a2cf6d..69b0c6b 100644 --- a/configs/arches_defconfig +++ b/configs/arches_defconfig @@ -4,5 +4,6 @@ CONFIG_TARGET_CANYONLANDS=y CONFIG_ARCHES=y CONFIG_DEFAULT_DEVICE_TREE="arches" CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_OF_CONTROL=y CONFIG_SYS_NS16550=y diff --git a/configs/aria_defconfig b/configs/aria_defconfig index 5848709..19f1c41 100644 --- a/configs/aria_defconfig +++ b/configs/aria_defconfig @@ -2,5 +2,6 @@ CONFIG_PPC=y CONFIG_MPC512X=y CONFIG_TARGET_ARIA=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/aristainetos2_defconfig b/configs/aristainetos2_defconfig index 7e2c026..0e16206 100644 --- a/configs/aristainetos2_defconfig +++ b/configs/aristainetos2_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_ARISTAINETOS2=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/aristainetos/aristainetos2.cfg,MX6DL" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/aristainetos2b_defconfig b/configs/aristainetos2b_defconfig index 88670df..aa3f357 100644 --- a/configs/aristainetos2b_defconfig +++ b/configs/aristainetos2b_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_ARISTAINETOS2B=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/aristainetos/aristainetos2.cfg,MX6DL" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/aristainetos_defconfig b/configs/aristainetos_defconfig index e808c21..9eca59a 100644 --- a/configs/aristainetos_defconfig +++ b/configs/aristainetos_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_ARISTAINETOS=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/aristainetos/aristainetos.cfg,MX6DL" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/arndale_defconfig b/configs/arndale_defconfig index b323e98..3fe7e97 100644 --- a/configs/arndale_defconfig +++ b/configs/arndale_defconfig @@ -6,6 +6,7 @@ CONFIG_DEFAULT_DEVICE_TREE="exynos5250-arndale" CONFIG_SPL=y CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ARNDALE # " # CONFIG_CMD_IMLS is not set CONFIG_CMD_GPIO=y diff --git a/configs/astro_mcf5373l_defconfig b/configs/astro_mcf5373l_defconfig index f787bb7..c616eb4 100644 --- a/configs/astro_mcf5373l_defconfig +++ b/configs/astro_mcf5373l_defconfig @@ -1,5 +1,6 @@ CONFIG_M68K=y CONFIG_TARGET_ASTRO_MCF5373L=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="URMEL > " # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set diff --git a/configs/at91rm9200ek_defconfig b/configs/at91rm9200ek_defconfig index 7c99aa0..bba7e5d 100644 --- a/configs/at91rm9200ek_defconfig +++ b/configs/at91rm9200ek_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91RM9200EK=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set diff --git a/configs/at91rm9200ek_ram_defconfig b/configs/at91rm9200ek_ram_defconfig index 96a4536..3868ac1 100644 --- a/configs/at91rm9200ek_ram_defconfig +++ b/configs/at91rm9200ek_ram_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91RM9200EK=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set diff --git a/configs/at91sam9263ek_dataflash_cs0_defconfig b/configs/at91sam9263ek_dataflash_cs0_defconfig index 1ca4f46..332dc73 100644 --- a/configs/at91sam9263ek_dataflash_cs0_defconfig +++ b/configs/at91sam9263ek_dataflash_cs0_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9263EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_DATAFLASH" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMI is not set diff --git a/configs/at91sam9263ek_dataflash_defconfig b/configs/at91sam9263ek_dataflash_defconfig index 1ca4f46..332dc73 100644 --- a/configs/at91sam9263ek_dataflash_defconfig +++ b/configs/at91sam9263ek_dataflash_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9263EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_DATAFLASH" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMI is not set diff --git a/configs/at91sam9263ek_nandflash_defconfig b/configs/at91sam9263ek_nandflash_defconfig index 15306e6..ebcb08d 100644 --- a/configs/at91sam9263ek_nandflash_defconfig +++ b/configs/at91sam9263ek_nandflash_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9263EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_NANDFLASH" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMI is not set diff --git a/configs/at91sam9263ek_norflash_boot_defconfig b/configs/at91sam9263ek_norflash_boot_defconfig index 2cf8cb9..0109a17 100644 --- a/configs/at91sam9263ek_norflash_boot_defconfig +++ b/configs/at91sam9263ek_norflash_boot_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9263EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_BOOT_NORFLASH" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMI is not set diff --git a/configs/at91sam9263ek_norflash_defconfig b/configs/at91sam9263ek_norflash_defconfig index abb044c..66a6ec3 100644 --- a/configs/at91sam9263ek_norflash_defconfig +++ b/configs/at91sam9263ek_norflash_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9263EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_NORFLASH" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMI is not set diff --git a/configs/at91sam9m10g45ek_mmc_defconfig b/configs/at91sam9m10g45ek_mmc_defconfig index c4d3962..0eea74b 100644 --- a/configs/at91sam9m10g45ek_mmc_defconfig +++ b/configs/at91sam9m10g45ek_mmc_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9M10G45EK=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9M10G45,SYS_USE_MMC" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMI is not set diff --git a/configs/at91sam9m10g45ek_nandflash_defconfig b/configs/at91sam9m10g45ek_nandflash_defconfig index 4d42256..276479a 100644 --- a/configs/at91sam9m10g45ek_nandflash_defconfig +++ b/configs/at91sam9m10g45ek_nandflash_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9M10G45EK=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9M10G45,SYS_USE_NANDFLASH" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMI is not set diff --git a/configs/at91sam9n12ek_mmc_defconfig b/configs/at91sam9n12ek_mmc_defconfig index 6f45120..9c8aa32 100644 --- a/configs/at91sam9n12ek_mmc_defconfig +++ b/configs/at91sam9n12ek_mmc_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9N12EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9N12,SYS_USE_MMC" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/at91sam9n12ek_nandflash_defconfig b/configs/at91sam9n12ek_nandflash_defconfig index df099b2..600a370 100644 --- a/configs/at91sam9n12ek_nandflash_defconfig +++ b/configs/at91sam9n12ek_nandflash_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9N12EK=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9N12,SYS_USE_NANDFLASH" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/at91sam9n12ek_spiflash_defconfig b/configs/at91sam9n12ek_spiflash_defconfig index 20cf592..71446cf 100644 --- a/configs/at91sam9n12ek_spiflash_defconfig +++ b/configs/at91sam9n12ek_spiflash_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9N12EK=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9N12,SYS_USE_SPIFLASH" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/at91sam9x5ek_dataflash_defconfig b/configs/at91sam9x5ek_dataflash_defconfig index b6154da..fce9c5e 100644 --- a/configs/at91sam9x5ek_dataflash_defconfig +++ b/configs/at91sam9x5ek_dataflash_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9X5EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9X5,SYS_USE_DATAFLASH" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/at91sam9x5ek_mmc_defconfig b/configs/at91sam9x5ek_mmc_defconfig index b782e25..f1c6dfa 100644 --- a/configs/at91sam9x5ek_mmc_defconfig +++ b/configs/at91sam9x5ek_mmc_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9X5EK=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9X5,SYS_USE_MMC" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/at91sam9x5ek_nandflash_defconfig b/configs/at91sam9x5ek_nandflash_defconfig index 66be263..7e660d7 100644 --- a/configs/at91sam9x5ek_nandflash_defconfig +++ b/configs/at91sam9x5ek_nandflash_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9X5EK=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9X5,SYS_USE_NANDFLASH" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/at91sam9x5ek_spiflash_defconfig b/configs/at91sam9x5ek_spiflash_defconfig index 0eba857..8a2aadd 100644 --- a/configs/at91sam9x5ek_spiflash_defconfig +++ b/configs/at91sam9x5ek_spiflash_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9X5EK=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9X5,SYS_USE_SPIFLASH" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/ba10_tv_box_defconfig b/configs/ba10_tv_box_defconfig index 1cfb380..43733ac 100644 --- a/configs/ba10_tv_box_defconfig +++ b/configs/ba10_tv_box_defconfig @@ -10,6 +10,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-ba10-tvbox" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/bamboo_defconfig b/configs/bamboo_defconfig index a5491cf..c8f39c9 100644 --- a/configs/bamboo_defconfig +++ b/configs/bamboo_defconfig @@ -2,5 +2,6 @@ CONFIG_PPC=y CONFIG_4xx=y CONFIG_TARGET_BAMBOO=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/bayleybay_defconfig b/configs/bayleybay_defconfig index dfafb0b..30c65fa 100644 --- a/configs/bayleybay_defconfig +++ b/configs/bayleybay_defconfig @@ -12,6 +12,7 @@ CONFIG_GENERATE_MP_TABLE=y CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y +CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/bcm11130_defconfig b/configs/bcm11130_defconfig index a1fc989..f7de603 100644 --- a/configs/bcm11130_defconfig +++ b/configs/bcm11130_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCM28155_AP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_MMC_ENV_DEV=0" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/bcm11130_nand_defconfig b/configs/bcm11130_nand_defconfig index a49b3dc..754499f 100644 --- a/configs/bcm11130_nand_defconfig +++ b/configs/bcm11130_nand_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCM28155_AP=y CONFIG_SYS_EXTRA_OPTIONS="NAND" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/bcm28155_ap_defconfig b/configs/bcm28155_ap_defconfig index 969c5bc..f3ec577 100644 --- a/configs/bcm28155_ap_defconfig +++ b/configs/bcm28155_ap_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_BCM28155_AP=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/bcm28155_w1d_defconfig b/configs/bcm28155_w1d_defconfig index 25c8ff6..d32e533 100644 --- a/configs/bcm28155_w1d_defconfig +++ b/configs/bcm28155_w1d_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCM28155_AP=y CONFIG_SYS_EXTRA_OPTIONS="BCM_SF2_ETH,BCM_SF2_ETH_GMAC" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/bcm911360_entphn-ns_defconfig b/configs/bcm911360_entphn-ns_defconfig index c1b41eb..fc78fc0 100644 --- a/configs/bcm911360_entphn-ns_defconfig +++ b/configs/bcm911360_entphn-ns_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x20000000,ARMV7_NONSEC" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set diff --git a/configs/bcm911360_entphn_defconfig b/configs/bcm911360_entphn_defconfig index ed1dea5..a9c1d31 100644 --- a/configs/bcm911360_entphn_defconfig +++ b/configs/bcm911360_entphn_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x20000000" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set diff --git a/configs/bcm911360k_defconfig b/configs/bcm911360k_defconfig index 8fcde6c..584ce17 100644 --- a/configs/bcm911360k_defconfig +++ b/configs/bcm911360k_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x40000000" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set diff --git a/configs/bcm958300k-ns_defconfig b/configs/bcm958300k-ns_defconfig index 670b57f..6aebcb0 100644 --- a/configs/bcm958300k-ns_defconfig +++ b/configs/bcm958300k-ns_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x40000000,ARMV7_NONSEC" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set diff --git a/configs/bcm958300k_defconfig b/configs/bcm958300k_defconfig index 8fcde6c..584ce17 100644 --- a/configs/bcm958300k_defconfig +++ b/configs/bcm958300k_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x40000000" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set diff --git a/configs/bcm958305k_defconfig b/configs/bcm958305k_defconfig index 8fcde6c..584ce17 100644 --- a/configs/bcm958305k_defconfig +++ b/configs/bcm958305k_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMCYGNUS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x40000000" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set diff --git a/configs/bcm958622hr_defconfig b/configs/bcm958622hr_defconfig index 4a24da2..60ad272 100644 --- a/configs/bcm958622hr_defconfig +++ b/configs/bcm958622hr_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_BCMNSP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_SDRAM_SIZE=0x01000000" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set diff --git a/configs/bct-brettl2_defconfig b/configs/bct-brettl2_defconfig index 7cc0e4e..bd0acfa 100644 --- a/configs/bct-brettl2_defconfig +++ b/configs/bct-brettl2_defconfig @@ -1,5 +1,6 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BCT_BRETTL2=y +CONFIG_HUSH_PARSER=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/beaver_defconfig b/configs/beaver_defconfig index a67d803..bf22c7a 100644 --- a/configs/beaver_defconfig +++ b/configs/beaver_defconfig @@ -5,6 +5,7 @@ CONFIG_TEGRA30=y CONFIG_TARGET_BEAVER=y CONFIG_DEFAULT_DEVICE_TREE="tegra30-beaver" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra30 (Beaver) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/bg0900_defconfig b/configs/bg0900_defconfig index c11617a..92c3ee7 100644 --- a/configs/bg0900_defconfig +++ b/configs/bg0900_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_BG0900=y CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/birdland_bav335a_defconfig b/configs/birdland_bav335a_defconfig index 5828e2b..1e22f5c 100644 --- a/configs/birdland_bav335a_defconfig +++ b/configs/birdland_bav335a_defconfig @@ -4,6 +4,7 @@ CONFIG_BAV_VERSION=1 CONFIG_SPL=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/birdland_bav335b_defconfig b/configs/birdland_bav335b_defconfig index bbefb55..c024d03 100644 --- a/configs/birdland_bav335b_defconfig +++ b/configs/birdland_bav335b_defconfig @@ -4,6 +4,7 @@ CONFIG_BAV_VERSION=2 CONFIG_SPL=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/bubinga_defconfig b/configs/bubinga_defconfig index 5316aa2..6dcb95a 100644 --- a/configs/bubinga_defconfig +++ b/configs/bubinga_defconfig @@ -2,5 +2,6 @@ CONFIG_PPC=y CONFIG_4xx=y CONFIG_TARGET_BUBINGA=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/caddy2_defconfig b/configs/caddy2_defconfig index db05c09..13b57ca 100644 --- a/configs/caddy2_defconfig +++ b/configs/caddy2_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_VME8349=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="CADDY2" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_NETDEVICES=y CONFIG_E1000=y diff --git a/configs/cairo_defconfig b/configs/cairo_defconfig index e421fe1..5da27d2 100644 --- a/configs/cairo_defconfig +++ b/configs/cairo_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_OMAP34XX=y CONFIG_TARGET_OMAP3_CAIRO=y CONFIG_SPL=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Cairo # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/calimain_defconfig b/configs/calimain_defconfig index 374023e..a2ba4b0 100644 --- a/configs/calimain_defconfig +++ b/configs/calimain_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_DAVINCI=y CONFIG_TARGET_CALIMAIN=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Calimain > " CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR="\x0b" diff --git a/configs/cam5200_defconfig b/configs/cam5200_defconfig index 8815005..3d643f5 100644 --- a/configs/cam5200_defconfig +++ b/configs/cam5200_defconfig @@ -3,5 +3,6 @@ CONFIG_MPC5xxx=y CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="CAM5200,TQM5200S,TQM5200_B" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/cam5200_niosflash_defconfig b/configs/cam5200_niosflash_defconfig index 8c5c9cd..99af7ce 100644 --- a/configs/cam5200_niosflash_defconfig +++ b/configs/cam5200_niosflash_defconfig @@ -3,5 +3,6 @@ CONFIG_MPC5xxx=y CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="CAM5200,TQM5200S,TQM5200_B,CAM5200_NIOSFLASH" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/canyonlands_defconfig b/configs/canyonlands_defconfig index 360ee6e..a2e27be 100644 --- a/configs/canyonlands_defconfig +++ b/configs/canyonlands_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_CANYONLANDS=y CONFIG_CANYONLANDS=y CONFIG_DEFAULT_DEVICE_TREE="canyonlands" CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_SYS_NS16550=y diff --git a/configs/cardhu_defconfig b/configs/cardhu_defconfig index eba46e7..c4a0580 100644 --- a/configs/cardhu_defconfig +++ b/configs/cardhu_defconfig @@ -5,6 +5,7 @@ CONFIG_TEGRA30=y CONFIG_TARGET_CARDHU=y CONFIG_DEFAULT_DEVICE_TREE="tegra30-cardhu" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra30 (Cardhu) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/cgtqmx6eval_defconfig b/configs/cgtqmx6eval_defconfig index ad6f093..ffc4d7c 100644 --- a/configs/cgtqmx6eval_defconfig +++ b/configs/cgtqmx6eval_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_CGTQMX6EVAL=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,SPL,MX6QDL" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="CGT-QMX6-Quad U-Boot > " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/charon_defconfig b/configs/charon_defconfig index 7732c29..7e50cfc 100644 --- a/configs/charon_defconfig +++ b/configs/charon_defconfig @@ -2,5 +2,6 @@ CONFIG_PPC=y CONFIG_MPC5xxx=y CONFIG_TARGET_CHARON=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/chromebook_jerry_defconfig b/configs/chromebook_jerry_defconfig index b00e2bf..1fef01e 100644 --- a/configs/chromebook_jerry_defconfig +++ b/configs/chromebook_jerry_defconfig @@ -9,6 +9,7 @@ CONFIG_DM_KEYBOARD=y CONFIG_DEFAULT_DEVICE_TREE="rk3288-jerry" CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PMIC=y diff --git a/configs/chromebook_link_defconfig b/configs/chromebook_link_defconfig index 9cf7b0e..667d0ae 100644 --- a/configs/chromebook_link_defconfig +++ b/configs/chromebook_link_defconfig @@ -11,6 +11,7 @@ CONFIG_HAVE_VGA_BIOS=y CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y +CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/chromebook_samus_defconfig b/configs/chromebook_samus_defconfig index fd1d9ca..11f25a4 100644 --- a/configs/chromebook_samus_defconfig +++ b/configs/chromebook_samus_defconfig @@ -10,6 +10,7 @@ CONFIG_SMP=y CONFIG_HAVE_VGA_BIOS=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y +CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/chromebox_panther_defconfig b/configs/chromebox_panther_defconfig index 3d79502..ba03f7d 100644 --- a/configs/chromebox_panther_defconfig +++ b/configs/chromebox_panther_defconfig @@ -8,6 +8,7 @@ CONFIG_HAVE_VGA_BIOS=y CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/cm_fx6_defconfig b/configs/cm_fx6_defconfig index c37442d..13612f7 100644 --- a/configs/cm_fx6_defconfig +++ b/configs/cm_fx6_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_CM_FX6=y CONFIG_SPL=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6QDL,SPL" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="CM-FX6 # " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set diff --git a/configs/cm_t335_defconfig b/configs/cm_t335_defconfig index 1cabf0e..7fe6be3 100644 --- a/configs/cm_t335_defconfig +++ b/configs/cm_t335_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_CM_T335=y CONFIG_SPL=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="CM-T335 # " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/cm_t3517_defconfig b/configs/cm_t3517_defconfig index 054a1c9..ea3e492 100644 --- a/configs/cm_t3517_defconfig +++ b/configs/cm_t3517_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_OMAP34XX=y CONFIG_TARGET_CM_T3517=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="CM-T3517 # " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/cm_t35_defconfig b/configs/cm_t35_defconfig index 71a9005..2f9f228 100644 --- a/configs/cm_t35_defconfig +++ b/configs/cm_t35_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_OMAP34XX=y CONFIG_TARGET_CM_T35=y CONFIG_SPL=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="CM-T3x # " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/cm_t43_defconfig b/configs/cm_t43_defconfig index c03a553..f44ee68 100644 --- a/configs/cm_t43_defconfig +++ b/configs/cm_t43_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_CM_T43=y CONFIG_DM_SERIAL=y CONFIG_DM_GPIO=y CONFIG_SPL=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="CM-T43 # " # CONFIG_CMD_FLASH is not set CONFIG_CMD_SF=y diff --git a/configs/cm_t54_defconfig b/configs/cm_t54_defconfig index 439302c..496a3d3 100644 --- a/configs/cm_t54_defconfig +++ b/configs/cm_t54_defconfig @@ -3,6 +3,7 @@ CONFIG_OMAP54XX=y CONFIG_TARGET_CM_T54=y CONFIG_SPL=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="CM-T54 # " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/colibri_pxa270_defconfig b/configs/colibri_pxa270_defconfig index d1de116..2dead77 100644 --- a/configs/colibri_pxa270_defconfig +++ b/configs/colibri_pxa270_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_COLIBRI_PXA270=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set diff --git a/configs/colibri_t20_defconfig b/configs/colibri_t20_defconfig index 57e0eb5..70da60c 100644 --- a/configs/colibri_t20_defconfig +++ b/configs/colibri_t20_defconfig @@ -5,6 +5,7 @@ CONFIG_TEGRA20=y CONFIG_TARGET_COLIBRI_T20=y CONFIG_DEFAULT_DEVICE_TREE="tegra20-colibri" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Colibri T20 # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/colibri_t30_defconfig b/configs/colibri_t30_defconfig index 583de25..4f25973 100644 --- a/configs/colibri_t30_defconfig +++ b/configs/colibri_t30_defconfig @@ -5,6 +5,7 @@ CONFIG_TEGRA30=y CONFIG_TARGET_COLIBRI_T30=y CONFIG_DEFAULT_DEVICE_TREE="tegra30-colibri" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Colibri T30 # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/colibri_vf_defconfig b/configs/colibri_vf_defconfig index 5481f04..bcafd59 100644 --- a/configs/colibri_vf_defconfig +++ b/configs/colibri_vf_defconfig @@ -5,6 +5,7 @@ CONFIG_DM_SPI=y CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="vf610-colibri" CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/toradex/colibri_vf/imximage.cfg,ENV_IS_IN_NAND,IMX_NAND" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Colibri VFxx # " # CONFIG_CMD_IMLS is not set CONFIG_CMD_SPI=y diff --git a/configs/colorfly_e708_q1_defconfig b/configs/colorfly_e708_q1_defconfig index ae67c37..ac83103 100644 --- a/configs/colorfly_e708_q1_defconfig +++ b/configs/colorfly_e708_q1_defconfig @@ -16,6 +16,7 @@ CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-colorfly-e708-q1" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/conga-qeval20-qa3-e3845_defconfig b/configs/conga-qeval20-qa3-e3845_defconfig index 24a927d..83d477e 100644 --- a/configs/conga-qeval20-qa3-e3845_defconfig +++ b/configs/conga-qeval20-qa3-e3845_defconfig @@ -12,6 +12,7 @@ CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y +CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig b/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig index b46f4cc..b5b6e7c 100644 --- a/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig +++ b/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="36BIT,SDCARD,DEVELOP" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_TPM=y diff --git a/configs/controlcenterd_36BIT_SDCARD_defconfig b/configs/controlcenterd_36BIT_SDCARD_defconfig index 25eb520..0590c8a 100644 --- a/configs/controlcenterd_36BIT_SDCARD_defconfig +++ b/configs/controlcenterd_36BIT_SDCARD_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="36BIT,SDCARD" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_TPM=y diff --git a/configs/coreboot-x86_defconfig b/configs/coreboot-x86_defconfig index a1c7df7..ff5c22e 100644 --- a/configs/coreboot-x86_defconfig +++ b/configs/coreboot-x86_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_COREBOOT=y CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set diff --git a/configs/corvus_defconfig b/configs/corvus_defconfig index bae8a05..3318221 100644 --- a/configs/corvus_defconfig +++ b/configs/corvus_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_CORVUS=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9M10G45,MACH_TYPE=2066,SYS_USE_NANDFLASH" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMI is not set diff --git a/configs/cougarcanyon2_defconfig b/configs/cougarcanyon2_defconfig index 71028cf..8bf4e14 100644 --- a/configs/cougarcanyon2_defconfig +++ b/configs/cougarcanyon2_defconfig @@ -2,6 +2,7 @@ CONFIG_X86=y CONFIG_VENDOR_INTEL=y CONFIG_DEFAULT_DEVICE_TREE="cougarcanyon2" CONFIG_TARGET_COUGARCANYON2=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/crownbay_defconfig b/configs/crownbay_defconfig index b4e1876..8ea281e 100644 --- a/configs/crownbay_defconfig +++ b/configs/crownbay_defconfig @@ -10,6 +10,7 @@ CONFIG_GENERATE_MP_TABLE=y CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y +CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/d2net_v2_defconfig b/configs/d2net_v2_defconfig index b2d2aeb..1b2fbfd 100644 --- a/configs/d2net_v2_defconfig +++ b/configs/d2net_v2_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_NET2BIG_V2=y CONFIG_SYS_EXTRA_OPTIONS="D2NET_V2" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set diff --git a/configs/da850_am18xxevm_defconfig b/configs/da850_am18xxevm_defconfig index 870186c..b4820cf 100644 --- a/configs/da850_am18xxevm_defconfig +++ b/configs/da850_am18xxevm_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_DAVINCI=y CONFIG_TARGET_DA850EVM=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="DA850_AM18X_EVM,MAC_ADDR_IN_EEPROM,SYS_I2C_EEPROM_ADDR_LEN=2,SYS_I2C_EEPROM_ADDR=0x50" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set diff --git a/configs/da850evm_defconfig b/configs/da850evm_defconfig index 6d7f984..605aba7 100644 --- a/configs/da850evm_defconfig +++ b/configs/da850evm_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_DAVINCI=y CONFIG_TARGET_DA850EVM=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="MAC_ADDR_IN_SPIFLASH" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot > " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/da850evm_direct_nor_defconfig b/configs/da850evm_direct_nor_defconfig index 7aba5c4..fdf6786 100644 --- a/configs/da850evm_direct_nor_defconfig +++ b/configs/da850evm_direct_nor_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_DAVINCI=y CONFIG_TARGET_DA850EVM=y CONFIG_SYS_EXTRA_OPTIONS="MAC_ADDR_IN_SPIFLASH,USE_NOR,DIRECT_NOR_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot > " # CONFIG_CMD_SETEXPR is not set CONFIG_SPI_FLASH=y diff --git a/configs/dalmore_defconfig b/configs/dalmore_defconfig index a1e2a73..59835a7 100644 --- a/configs/dalmore_defconfig +++ b/configs/dalmore_defconfig @@ -5,6 +5,7 @@ CONFIG_TEGRA114=y CONFIG_TARGET_DALMORE=y CONFIG_DEFAULT_DEVICE_TREE="tegra114-dalmore" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra114 (Dalmore) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/devconcenter_defconfig b/configs/devconcenter_defconfig index ffdf8d7..8d1b786 100644 --- a/configs/devconcenter_defconfig +++ b/configs/devconcenter_defconfig @@ -4,5 +4,6 @@ CONFIG_TARGET_INTIP=y CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="DEVCONCENTER" +CONFIG_HUSH_PARSER=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/devkit8000_defconfig b/configs/devkit8000_defconfig index 57894da..d7e9235 100644 --- a/configs/devkit8000_defconfig +++ b/configs/devkit8000_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_OMAP34XX=y CONFIG_TARGET_DEVKIT8000=y CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/difrnce_dit4350_defconfig b/configs/difrnce_dit4350_defconfig index c76af0e..b8e04f3 100644 --- a/configs/difrnce_dit4350_defconfig +++ b/configs/difrnce_dit4350_defconfig @@ -16,6 +16,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-difrnce-dit4350" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/digsy_mtc_RAMBOOT_defconfig b/configs/digsy_mtc_RAMBOOT_defconfig index ad424dd..4ac8bda 100644 --- a/configs/digsy_mtc_RAMBOOT_defconfig +++ b/configs/digsy_mtc_RAMBOOT_defconfig @@ -3,6 +3,7 @@ CONFIG_MPC5xxx=y CONFIG_TARGET_DIGSY_MTC=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_TEXT_BASE=0x00100000" +CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" CONFIG_AUTOBOOT_DELAY_STR="d" diff --git a/configs/digsy_mtc_defconfig b/configs/digsy_mtc_defconfig index ce9cbf0..e43a910 100644 --- a/configs/digsy_mtc_defconfig +++ b/configs/digsy_mtc_defconfig @@ -2,6 +2,7 @@ CONFIG_PPC=y CONFIG_MPC5xxx=y CONFIG_TARGET_DIGSY_MTC=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="autoboot in %d seconds\n" CONFIG_AUTOBOOT_DELAY_STR=" " diff --git a/configs/digsy_mtc_rev5_RAMBOOT_defconfig b/configs/digsy_mtc_rev5_RAMBOOT_defconfig index 0fc08d8..be8b855 100644 --- a/configs/digsy_mtc_rev5_RAMBOOT_defconfig +++ b/configs/digsy_mtc_rev5_RAMBOOT_defconfig @@ -3,6 +3,7 @@ CONFIG_MPC5xxx=y CONFIG_TARGET_DIGSY_MTC=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_TEXT_BASE=0x00100000,DIGSY_REV5" +CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" CONFIG_AUTOBOOT_DELAY_STR="d" diff --git a/configs/digsy_mtc_rev5_defconfig b/configs/digsy_mtc_rev5_defconfig index 9a9d215..67a8f2a 100644 --- a/configs/digsy_mtc_rev5_defconfig +++ b/configs/digsy_mtc_rev5_defconfig @@ -3,6 +3,7 @@ CONFIG_MPC5xxx=y CONFIG_TARGET_DIGSY_MTC=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="DIGSY_REV5" +CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" CONFIG_AUTOBOOT_DELAY_STR="d" diff --git a/configs/dlvision-10g_defconfig b/configs/dlvision-10g_defconfig index dd98059..1f4c633 100644 --- a/configs/dlvision-10g_defconfig +++ b/configs/dlvision-10g_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_DLVISION_10G=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_ELF is not set diff --git a/configs/dlvision_defconfig b/configs/dlvision_defconfig index c6fee13..dd673b0 100644 --- a/configs/dlvision_defconfig +++ b/configs/dlvision_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_DLVISION=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_ELF is not set # CONFIG_CMD_NFS is not set CONFIG_SYS_NS16550=y diff --git a/configs/dns325_defconfig b/configs/dns325_defconfig index ed83019..493da5b 100644 --- a/configs/dns325_defconfig +++ b/configs/dns325_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_DNS325=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set diff --git a/configs/dra72_evm_defconfig b/configs/dra72_evm_defconfig index 4aa76b1..287a6bd 100644 --- a/configs/dra72_evm_defconfig +++ b/configs/dra72_evm_defconfig @@ -10,6 +10,7 @@ CONFIG_SPL_STACK_R_ADDR=0x82000000 CONFIG_DEFAULT_DEVICE_TREE="dra72-evm" CONFIG_SPL=y CONFIG_SPL_STACK_R=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/dra74_evm_defconfig b/configs/dra74_evm_defconfig index 64ab406..99db387 100644 --- a/configs/dra74_evm_defconfig +++ b/configs/dra74_evm_defconfig @@ -9,6 +9,7 @@ CONFIG_SPL_STACK_R_ADDR=0x82000000 CONFIG_DEFAULT_DEVICE_TREE="dra7-evm" CONFIG_SPL=y CONFIG_SPL_STACK_R=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index 1b1c0be..b039719 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_DRA7XX_EVM=y CONFIG_SPL_STACK_R_ADDR=0x82000000 CONFIG_SPL=y CONFIG_SPL_STACK_R=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/dra7xx_evm_qspiboot_defconfig b/configs/dra7xx_evm_qspiboot_defconfig index 0130188..3f9724b 100644 --- a/configs/dra7xx_evm_qspiboot_defconfig +++ b/configs/dra7xx_evm_qspiboot_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL_STACK_R_ADDR=0x82000000 CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_SYS_EXTRA_OPTIONS="QSPI_BOOT" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/dra7xx_evm_uart3_defconfig b/configs/dra7xx_evm_uart3_defconfig index ca80077..6161057 100644 --- a/configs/dra7xx_evm_uart3_defconfig +++ b/configs/dra7xx_evm_uart3_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL_STACK_R_ADDR=0x82000000 CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_SYS_EXTRA_OPTIONS="SPL_YMODEM_SUPPORT" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/draco_defconfig b/configs/draco_defconfig index 7c3f828..abbc636 100644 --- a/configs/draco_defconfig +++ b/configs/draco_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_DRACO=y CONFIG_SPL=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot# " CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc><Esc>" to stop\n" diff --git a/configs/dragonboard410c_defconfig b/configs/dragonboard410c_defconfig index 2f33a8a..b64941f 100644 --- a/configs/dragonboard410c_defconfig +++ b/configs/dragonboard410c_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_SNAPDRAGON=y CONFIG_DEFAULT_DEVICE_TREE="dragonboard410c" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="dragonboard410c => " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/dserve_dsrv9703c_defconfig b/configs/dserve_dsrv9703c_defconfig index 242158e..2648ccc 100644 --- a/configs/dserve_dsrv9703c_defconfig +++ b/configs/dserve_dsrv9703c_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_SUNXI=y CONFIG_MACH_SUN4I=y -CONFIG_DRAM_CLK=360 CONFIG_MMC0_CD_PIN="PH1" CONFIG_USB0_VBUS_PIN="PB9" CONFIG_USB0_VBUS_DET="PH5" @@ -15,6 +14,7 @@ CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-dserve-dsrv9703c" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/duovero_defconfig b/configs/duovero_defconfig index 30e5255..3312dda 100644 --- a/configs/duovero_defconfig +++ b/configs/duovero_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_OMAP44XX=y CONFIG_TARGET_DUOVERO=y CONFIG_SPL=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="duovero # " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/e2220-1170_defconfig b/configs/e2220-1170_defconfig index 38c085a..6ce9de5 100644 --- a/configs/e2220-1170_defconfig +++ b/configs/e2220-1170_defconfig @@ -3,6 +3,7 @@ CONFIG_TEGRA=y CONFIG_TEGRA210=y CONFIG_DEFAULT_DEVICE_TREE="tegra210-e2220-1170" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra210 (E2220-1170) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/ea20_defconfig b/configs/ea20_defconfig index 6fe19c7..cdcfdf6 100644 --- a/configs/ea20_defconfig +++ b/configs/ea20_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_DAVINCI=y CONFIG_TARGET_EA20=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ea20 > " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/eco5pk_defconfig b/configs/eco5pk_defconfig index 27535df..63fd75b 100644 --- a/configs/eco5pk_defconfig +++ b/configs/eco5pk_defconfig @@ -3,6 +3,7 @@ CONFIG_OMAP34XX=y CONFIG_TARGET_ECO5PK=y CONFIG_SPL=y CONFIG_FIT=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ECO5-PK # " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/edb9315a_defconfig b/configs/edb9315a_defconfig index 452bf0d..8a76405 100644 --- a/configs/edb9315a_defconfig +++ b/configs/edb9315a_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_EDB93XX=y CONFIG_SYS_EXTRA_OPTIONS="MK_edb9315a" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_XIMG is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set diff --git a/configs/edminiv2_defconfig b/configs/edminiv2_defconfig index 6ed785f..e58a65d 100644 --- a/configs/edminiv2_defconfig +++ b/configs/edminiv2_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ORION5X=y CONFIG_TARGET_EDMINIV2=y CONFIG_SPL=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="EDMiniV2> " # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y diff --git a/configs/efi-x86_defconfig b/configs/efi-x86_defconfig index 7d83445..6f2967b 100644 --- a/configs/efi-x86_defconfig +++ b/configs/efi-x86_defconfig @@ -3,6 +3,7 @@ CONFIG_VENDOR_EFI=y CONFIG_DEFAULT_DEVICE_TREE="efi" CONFIG_TARGET_EFI=y CONFIG_FIT=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_BOOTM is not set # CONFIG_CMD_IMLS is not set CONFIG_CMD_GPIO=y diff --git a/configs/ethernut5_defconfig b/configs/ethernut5_defconfig index 04d8611..d25c225 100644 --- a/configs/ethernut5_defconfig +++ b/configs/ethernut5_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_ETHERNUT5=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9XE" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set # CONFIG_CMD_LOADS is not set diff --git a/configs/evb-rk3036_defconfig b/configs/evb-rk3036_defconfig index 0689e97..fc40b1d 100644 --- a/configs/evb-rk3036_defconfig +++ b/configs/evb-rk3036_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_EVB_RK3036=y CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3036-sdk" CONFIG_SPL_STACK_R=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_SETEXPR is not set CONFIG_REGMAP=y diff --git a/configs/firefly-rk3288_defconfig b/configs/firefly-rk3288_defconfig index cb394cd..64cc90a 100644 --- a/configs/firefly-rk3288_defconfig +++ b/configs/firefly-rk3288_defconfig @@ -7,6 +7,7 @@ CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3288-firefly" CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PMIC=y diff --git a/configs/flea3_defconfig b/configs/flea3_defconfig index 5e35601..94f283a 100644 --- a/configs/flea3_defconfig +++ b/configs/flea3_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_FLEA3=y CONFIG_FIT=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="flea3 U-Boot > " # CONFIG_CMD_SETEXPR is not set diff --git a/configs/fo300_defconfig b/configs/fo300_defconfig index db979ec..ae90d45 100644 --- a/configs/fo300_defconfig +++ b/configs/fo300_defconfig @@ -3,5 +3,6 @@ CONFIG_MPC5xxx=y CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="FO300" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/ga10h_v1_1_defconfig b/configs/ga10h_v1_1_defconfig index 34e74af..da8e2fe 100644 --- a/configs/ga10h_v1_1_defconfig +++ b/configs/ga10h_v1_1_defconfig @@ -18,6 +18,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-ga10h-v1.1" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/galileo_defconfig b/configs/galileo_defconfig index 6620a85..e613074 100644 --- a/configs/galileo_defconfig +++ b/configs/galileo_defconfig @@ -7,6 +7,7 @@ CONFIG_GENERATE_PIRQ_TABLE=y CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/gdppc440etx_defconfig b/configs/gdppc440etx_defconfig index 695d860..98a0dcc 100644 --- a/configs/gdppc440etx_defconfig +++ b/configs/gdppc440etx_defconfig @@ -2,6 +2,7 @@ CONFIG_PPC=y CONFIG_4xx=y CONFIG_TARGET_GDPPC440ETX=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " CONFIG_SYS_NS16550=y diff --git a/configs/ge_b450v3_defconfig b/configs/ge_b450v3_defconfig index 24ef9e8..3f134cc 100644 --- a/configs/ge_b450v3_defconfig +++ b/configs/ge_b450v3_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_GE_B450V3=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/ge_b650v3_defconfig b/configs/ge_b650v3_defconfig index 75c49c0..067858d 100644 --- a/configs/ge_b650v3_defconfig +++ b/configs/ge_b650v3_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_GE_B650V3=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/ge_b850v3_defconfig b/configs/ge_b850v3_defconfig index 85140cd..5205152 100644 --- a/configs/ge_b850v3_defconfig +++ b/configs/ge_b850v3_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_GE_B850V3=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/glacier_defconfig b/configs/glacier_defconfig index 1943882..3517348 100644 --- a/configs/glacier_defconfig +++ b/configs/glacier_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_CANYONLANDS=y CONFIG_GLACIER=y CONFIG_DEFAULT_DEVICE_TREE="glacier" CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_SYS_NS16550=y diff --git a/configs/glacier_ramboot_defconfig b/configs/glacier_ramboot_defconfig index c7b5b76..7069c28 100644 --- a/configs/glacier_ramboot_defconfig +++ b/configs/glacier_ramboot_defconfig @@ -5,6 +5,7 @@ CONFIG_GLACIER=y CONFIG_DEFAULT_DEVICE_TREE="glacier" CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_RAMBOOT,SYS_TEXT_BASE=0x01000000,SYS_LDSCRIPT=board/amcc/canyonlands/u-boot-ram.lds" +CONFIG_HUSH_PARSER=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_SYS_NS16550=y diff --git a/configs/grasshopper_defconfig b/configs/grasshopper_defconfig index 6c5c9e3..5e8bd8b 100644 --- a/configs/grasshopper_defconfig +++ b/configs/grasshopper_defconfig @@ -1,5 +1,6 @@ CONFIG_AVR32=y CONFIG_TARGET_GRASSHOPPER=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" diff --git a/configs/gt90h_v4_defconfig b/configs/gt90h_v4_defconfig index a14de0d..0e53cc5 100644 --- a/configs/gt90h_v4_defconfig +++ b/configs/gt90h_v4_defconfig @@ -17,6 +17,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-gt90h-v4" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/gwventana_defconfig b/configs/gwventana_defconfig index 49ee273..029fee0 100644 --- a/configs/gwventana_defconfig +++ b/configs/gwventana_defconfig @@ -9,6 +9,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6QDL" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Ventana > " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/h2200_defconfig b/configs/h2200_defconfig index 0fadc90..57f157a 100644 --- a/configs/h2200_defconfig +++ b/configs/h2200_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_H2200=y CONFIG_FIT=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="> " # CONFIG_CMD_BDI is not set # CONFIG_CMD_CONSOLE is not set diff --git a/configs/h8_homlet_v2_defconfig b/configs/h8_homlet_v2_defconfig index e04d96b..a2e6a1c 100644 --- a/configs/h8_homlet_v2_defconfig +++ b/configs/h8_homlet_v2_defconfig @@ -11,6 +11,7 @@ CONFIG_AXP_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="sun8i-a83t-allwinner-h8homlet-v2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/haleakala_defconfig b/configs/haleakala_defconfig index 77de58a..9d6a3aa 100644 --- a/configs/haleakala_defconfig +++ b/configs/haleakala_defconfig @@ -3,5 +3,6 @@ CONFIG_4xx=y CONFIG_TARGET_KILAUEA=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="HALEAKALA" +CONFIG_HUSH_PARSER=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/harmony_defconfig b/configs/harmony_defconfig index d4aafe9..00dc37d 100644 --- a/configs/harmony_defconfig +++ b/configs/harmony_defconfig @@ -5,6 +5,7 @@ CONFIG_TEGRA20=y CONFIG_TARGET_HARMONY=y CONFIG_DEFAULT_DEVICE_TREE="tegra20-harmony" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra20 (Harmony) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set @@ -19,8 +20,8 @@ CONFIG_PWM_TEGRA=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_DM_USB=y +CONFIG_USB_ULPI_VIEWPORT=y +CONFIG_USB_ULPI=y CONFIG_DM_VIDEO=y CONFIG_VIDEO_TEGRA20=y -CONFIG_USB_ULPI=y -CONFIG_USB_ULPI_VIEWPORT=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/highbank_defconfig b/configs/highbank_defconfig index b44763e..a91f420 100644 --- a/configs/highbank_defconfig +++ b/configs/highbank_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_HIGHBANK=y CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds...\nPress <s> to stop or <d> to delay\n" CONFIG_AUTOBOOT_KEYED_CTRLC=y diff --git a/configs/hikey_defconfig b/configs/hikey_defconfig index 8b75642..3f1f928 100644 --- a/configs/hikey_defconfig +++ b/configs/hikey_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_GPIO=y CONFIG_OF_LIBFDT=y diff --git a/configs/hrcon_defconfig b/configs/hrcon_defconfig index b7ef33b..45241b4 100644 --- a/configs/hrcon_defconfig +++ b/configs/hrcon_defconfig @@ -5,6 +5,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_SETEXPR is not set diff --git a/configs/hrcon_dh_defconfig b/configs/hrcon_dh_defconfig index 13cf81d..1d3d9b2 100644 --- a/configs/hrcon_dh_defconfig +++ b/configs/hrcon_dh_defconfig @@ -6,5 +6,6 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="HRCON_DH" +CONFIG_HUSH_PARSER=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/i12-tvbox_defconfig b/configs/i12-tvbox_defconfig index 54fa819..1d5bb33 100644 --- a/configs/i12-tvbox_defconfig +++ b/configs/i12-tvbox_defconfig @@ -7,6 +7,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-i12-tvbox" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,MACPWR=SUNXI_GPH(21)" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/iNet_3F_defconfig b/configs/iNet_3F_defconfig index 7ec54a7..71cfb75 100644 --- a/configs/iNet_3F_defconfig +++ b/configs/iNet_3F_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-inet-3f" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/iNet_3W_defconfig b/configs/iNet_3W_defconfig index 5e68769..ccd01f5 100644 --- a/configs/iNet_3W_defconfig +++ b/configs/iNet_3W_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-inet-3w" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/iNet_86VS_defconfig b/configs/iNet_86VS_defconfig index 3dea793..3c4d960 100644 --- a/configs/iNet_86VS_defconfig +++ b/configs/iNet_86VS_defconfig @@ -13,6 +13,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-inet-86vs" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/icnova-a20-swac_defconfig b/configs/icnova-a20-swac_defconfig index 548a07e..7fe6bf0 100644 --- a/configs/icnova-a20-swac_defconfig +++ b/configs/icnova-a20-swac_defconfig @@ -14,6 +14,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-icnova-swac" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,SUNXI_GMAC,CMD_BMP,CMD_UNZIP" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/icon_defconfig b/configs/icon_defconfig index 39b5185..a55bbdb 100644 --- a/configs/icon_defconfig +++ b/configs/icon_defconfig @@ -2,5 +2,6 @@ CONFIG_PPC=y CONFIG_4xx=y CONFIG_TARGET_ICON=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/ids8313_defconfig b/configs/ids8313_defconfig index f962d7d..3bf051e 100644 --- a/configs/ids8313_defconfig +++ b/configs/ids8313_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_SIGNATURE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_TEXT_BASE=0xFFF00000" +CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Enter password - autoboot in %d seconds...\n" CONFIG_AUTOBOOT_DELAY_STR="ids" diff --git a/configs/igep0020_defconfig b/configs/igep0020_defconfig index 2731e94..6f6c539 100644 --- a/configs/igep0020_defconfig +++ b/configs/igep0020_defconfig @@ -3,6 +3,7 @@ CONFIG_OMAP34XX=y CONFIG_TARGET_OMAP3_IGEP00X0=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="MACH_TYPE=MACH_TYPE_IGEP0020,BOOT_ONENAND" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/igep0020_nand_defconfig b/configs/igep0020_nand_defconfig index dec1f8d..d8ffa00 100644 --- a/configs/igep0020_nand_defconfig +++ b/configs/igep0020_nand_defconfig @@ -3,6 +3,7 @@ CONFIG_OMAP34XX=y CONFIG_TARGET_OMAP3_IGEP00X0=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="MACH_TYPE=MACH_TYPE_IGEP0020,BOOT_NAND" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/igep0030_defconfig b/configs/igep0030_defconfig index 73b02e9..0ebf508 100644 --- a/configs/igep0030_defconfig +++ b/configs/igep0030_defconfig @@ -3,6 +3,7 @@ CONFIG_OMAP34XX=y CONFIG_TARGET_OMAP3_IGEP00X0=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="MACH_TYPE=MACH_TYPE_IGEP0030,BOOT_ONENAND" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/igep0030_nand_defconfig b/configs/igep0030_nand_defconfig index ab65213..b0c4700 100644 --- a/configs/igep0030_nand_defconfig +++ b/configs/igep0030_nand_defconfig @@ -3,6 +3,7 @@ CONFIG_OMAP34XX=y CONFIG_TARGET_OMAP3_IGEP00X0=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="MACH_TYPE=MACH_TYPE_IGEP0030,BOOT_NAND" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/igep0032_defconfig b/configs/igep0032_defconfig index a779d47..3a751c5 100644 --- a/configs/igep0032_defconfig +++ b/configs/igep0032_defconfig @@ -3,6 +3,7 @@ CONFIG_OMAP34XX=y CONFIG_TARGET_OMAP3_IGEP00X0=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="MACH_TYPE=MACH_TYPE_IGEP0032,BOOT_ONENAND" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/inet1_defconfig b/configs/inet1_defconfig index a8b32cb..8d24877 100644 --- a/configs/inet1_defconfig +++ b/configs/inet1_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-inet1" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/inet97fv2_defconfig b/configs/inet97fv2_defconfig index 0b03e16..446e841 100644 --- a/configs/inet97fv2_defconfig +++ b/configs/inet97fv2_defconfig @@ -13,6 +13,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-inet97fv2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/inet98v_rev2_defconfig b/configs/inet98v_rev2_defconfig index 27b5019..d701617 100644 --- a/configs/inet98v_rev2_defconfig +++ b/configs/inet98v_rev2_defconfig @@ -16,6 +16,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-inet-98v-rev2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/inet9f_rev03_defconfig b/configs/inet9f_rev03_defconfig index 153450f..c5a6c65 100644 --- a/configs/inet9f_rev03_defconfig +++ b/configs/inet9f_rev03_defconfig @@ -13,6 +13,7 @@ CONFIG_VIDEO_LCD_BL_PWM="PB2" CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-inet9f-rev03" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/inetspace_v2_defconfig b/configs/inetspace_v2_defconfig index 6e49081..4f68833 100644 --- a/configs/inetspace_v2_defconfig +++ b/configs/inetspace_v2_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_NETSPACE_V2=y CONFIG_SYS_EXTRA_OPTIONS="INETSPACE_V2" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set diff --git a/configs/integratorap_cm720t_defconfig b/configs/integratorap_cm720t_defconfig index 6291139..e6b0bc4 100644 --- a/configs/integratorap_cm720t_defconfig +++ b/configs/integratorap_cm720t_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_INTEGRATOR=y CONFIG_ARCH_INTEGRATOR_AP=y CONFIG_CM720T=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Integrator-AP # " # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/integratorap_cm920t_defconfig b/configs/integratorap_cm920t_defconfig index 7132607..4afd0e6 100644 --- a/configs/integratorap_cm920t_defconfig +++ b/configs/integratorap_cm920t_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_INTEGRATOR=y CONFIG_ARCH_INTEGRATOR_AP=y CONFIG_CM920T=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Integrator-AP # " # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/integratorap_cm926ejs_defconfig b/configs/integratorap_cm926ejs_defconfig index f58e256..0cfbbf3 100644 --- a/configs/integratorap_cm926ejs_defconfig +++ b/configs/integratorap_cm926ejs_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_INTEGRATOR=y CONFIG_ARCH_INTEGRATOR_AP=y CONFIG_CM926EJ_S=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Integrator-AP # " # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/integratorap_cm946es_defconfig b/configs/integratorap_cm946es_defconfig index b32512d..f25c5ba 100644 --- a/configs/integratorap_cm946es_defconfig +++ b/configs/integratorap_cm946es_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_INTEGRATOR=y CONFIG_ARCH_INTEGRATOR_AP=y CONFIG_CM946ES=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Integrator-AP # " # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/integratorcp_cm1136_defconfig b/configs/integratorcp_cm1136_defconfig index 76c8998..36e8ad7 100644 --- a/configs/integratorcp_cm1136_defconfig +++ b/configs/integratorcp_cm1136_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_INTEGRATOR=y CONFIG_ARCH_INTEGRATOR_CP=y CONFIG_CM1136=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Integrator-CP # " # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/integratorcp_cm920t_defconfig b/configs/integratorcp_cm920t_defconfig index ca7beb3..817544a 100644 --- a/configs/integratorcp_cm920t_defconfig +++ b/configs/integratorcp_cm920t_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_INTEGRATOR=y CONFIG_ARCH_INTEGRATOR_CP=y CONFIG_CM920T=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Integrator-CP # " # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/integratorcp_cm926ejs_defconfig b/configs/integratorcp_cm926ejs_defconfig index 71ca032..ae69cee 100644 --- a/configs/integratorcp_cm926ejs_defconfig +++ b/configs/integratorcp_cm926ejs_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_INTEGRATOR=y CONFIG_ARCH_INTEGRATOR_CP=y CONFIG_CM926EJ_S=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Integrator-CP # " # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/integratorcp_cm946es_defconfig b/configs/integratorcp_cm946es_defconfig index d4d11b8..85086a5 100644 --- a/configs/integratorcp_cm946es_defconfig +++ b/configs/integratorcp_cm946es_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_INTEGRATOR=y CONFIG_ARCH_INTEGRATOR_CP=y CONFIG_CM946ES=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Integrator-CP # " # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/intip_defconfig b/configs/intip_defconfig index 48f1bdb..fea4d10 100644 --- a/configs/intip_defconfig +++ b/configs/intip_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_INTIP=y CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="INTIB" +CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " CONFIG_SYS_NS16550=y diff --git a/configs/io64_defconfig b/configs/io64_defconfig index 083d94a..01378b3 100644 --- a/configs/io64_defconfig +++ b/configs/io64_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_IO64=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " CONFIG_SYS_NS16550=y diff --git a/configs/io_defconfig b/configs/io_defconfig index de2749e..03a2898 100644 --- a/configs/io_defconfig +++ b/configs/io_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_IO=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_ELF is not set diff --git a/configs/iocon_defconfig b/configs/iocon_defconfig index 069db16..aa51065 100644 --- a/configs/iocon_defconfig +++ b/configs/iocon_defconfig @@ -3,6 +3,7 @@ CONFIG_4xx=y CONFIG_TARGET_IOCON=y CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_ELF is not set diff --git a/configs/ipam390_defconfig b/configs/ipam390_defconfig index b02b496..6b46da0 100644 --- a/configs/ipam390_defconfig +++ b/configs/ipam390_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_DAVINCI=y CONFIG_TARGET_IPAM390=y CONFIG_SPL=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot > " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/jesurun_q5_defconfig b/configs/jesurun_q5_defconfig index 9cb8b1d..666b7a8 100644 --- a/configs/jesurun_q5_defconfig +++ b/configs/jesurun_q5_defconfig @@ -8,6 +8,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-jesurun-q5" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,MACPWR=SUNXI_GPH(19)" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/jetson-tk1_defconfig b/configs/jetson-tk1_defconfig index bf509c2..a2be6f5 100644 --- a/configs/jetson-tk1_defconfig +++ b/configs/jetson-tk1_defconfig @@ -5,6 +5,7 @@ CONFIG_TEGRA124=y CONFIG_TARGET_JETSON_TK1=y CONFIG_DEFAULT_DEVICE_TREE="tegra124-jetson-tk1" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra124 (Jetson TK1) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/jupiter_defconfig b/configs/jupiter_defconfig index a3c259f..072633c 100644 --- a/configs/jupiter_defconfig +++ b/configs/jupiter_defconfig @@ -1,4 +1,5 @@ CONFIG_PPC=y CONFIG_MPC5xxx=y CONFIG_TARGET_JUPITER=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/k2e_evm_defconfig b/configs/k2e_evm_defconfig index c843508..efddf9f 100644 --- a/configs/k2e_evm_defconfig +++ b/configs/k2e_evm_defconfig @@ -5,15 +5,16 @@ CONFIG_DM_SERIAL=y CONFIG_DEFAULT_DEVICE_TREE="k2e-evm" CONFIG_SPL=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="K2E EVM # " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_NAND=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_CONTROL=y CONFIG_DM=y +CONFIG_TI_AEMIF=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_DM_ETH=y CONFIG_SYS_NS16550=y -CONFIG_TI_AEMIF=y -CONFIG_CMD_NAND=y diff --git a/configs/k2g_evm_defconfig b/configs/k2g_evm_defconfig index 0545812..2f9b5a0 100644 --- a/configs/k2g_evm_defconfig +++ b/configs/k2g_evm_defconfig @@ -5,6 +5,7 @@ CONFIG_DM_SERIAL=y CONFIG_DEFAULT_DEVICE_TREE="k2g-evm" CONFIG_SPL=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_REMOTEPROC=y diff --git a/configs/k2hk_evm_defconfig b/configs/k2hk_evm_defconfig index 1627065..a5bd073 100644 --- a/configs/k2hk_evm_defconfig +++ b/configs/k2hk_evm_defconfig @@ -5,15 +5,16 @@ CONFIG_DM_SERIAL=y CONFIG_DEFAULT_DEVICE_TREE="k2hk-evm" CONFIG_SPL=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="K2HK EVM # " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_NAND=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_CONTROL=y CONFIG_DM=y +CONFIG_TI_AEMIF=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_DM_ETH=y CONFIG_SYS_NS16550=y -CONFIG_TI_AEMIF=y -CONFIG_CMD_NAND=y diff --git a/configs/k2l_evm_defconfig b/configs/k2l_evm_defconfig index 255f6d1..3437dc4 100644 --- a/configs/k2l_evm_defconfig +++ b/configs/k2l_evm_defconfig @@ -5,15 +5,16 @@ CONFIG_DM_SERIAL=y CONFIG_DEFAULT_DEVICE_TREE="k2l-evm" CONFIG_SPL=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="K2L EVM # " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_NAND=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_CONTROL=y CONFIG_DM=y +CONFIG_TI_AEMIF=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_DM_ETH=y CONFIG_SYS_NS16550=y -CONFIG_TI_AEMIF=y -CONFIG_CMD_NAND=y diff --git a/configs/katmai_defconfig b/configs/katmai_defconfig index b242d81..08a8fd0 100644 --- a/configs/katmai_defconfig +++ b/configs/katmai_defconfig @@ -2,5 +2,6 @@ CONFIG_PPC=y CONFIG_4xx=y CONFIG_TARGET_KATMAI=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/kc1_defconfig b/configs/kc1_defconfig index a9643cf..7bf5858 100644 --- a/configs/kc1_defconfig +++ b/configs/kc1_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_OMAP44XX=y CONFIG_TARGET_KC1=y CONFIG_SPL=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="kc1 # " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/kilauea_defconfig b/configs/kilauea_defconfig index e6e6e0a..401fd4f 100644 --- a/configs/kilauea_defconfig +++ b/configs/kilauea_defconfig @@ -3,5 +3,6 @@ CONFIG_4xx=y CONFIG_TARGET_KILAUEA=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="KILAUEA" +CONFIG_HUSH_PARSER=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/km_kirkwood_128m16_defconfig b/configs/km_kirkwood_128m16_defconfig index 349651d..b58ab6a 100644 --- a/configs/km_kirkwood_128m16_defconfig +++ b/configs/km_kirkwood_128m16_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_SYS_EXTRA_OPTIONS="KM_KIRKWOOD_128M16" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_SPI_FLASH=y diff --git a/configs/km_kirkwood_defconfig b/configs/km_kirkwood_defconfig index 9a0d85c..9b81c53 100644 --- a/configs/km_kirkwood_defconfig +++ b/configs/km_kirkwood_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_SYS_EXTRA_OPTIONS="KM_KIRKWOOD" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_SPI_FLASH=y diff --git a/configs/km_kirkwood_pci_defconfig b/configs/km_kirkwood_pci_defconfig index d2c488e..0da9e21 100644 --- a/configs/km_kirkwood_pci_defconfig +++ b/configs/km_kirkwood_pci_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_SYS_EXTRA_OPTIONS="KM_KIRKWOOD_PCI" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_SPI_FLASH=y diff --git a/configs/kmcoge4_defconfig b/configs/kmcoge4_defconfig index 49e1c9b..29eba85 100644 --- a/configs/kmcoge4_defconfig +++ b/configs/kmcoge4_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="KMCOGE4" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_SPI_FLASH=y diff --git a/configs/kmcoge5ne_defconfig b/configs/kmcoge5ne_defconfig index 6d9a6fa..f8e7f15 100644 --- a/configs/kmcoge5ne_defconfig +++ b/configs/kmcoge5ne_defconfig @@ -4,5 +4,6 @@ CONFIG_TARGET_KM8360=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="KMCOGE5NE" +CONFIG_HUSH_PARSER=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/kmcoge5un_defconfig b/configs/kmcoge5un_defconfig index b390e3e..05b5259 100644 --- a/configs/kmcoge5un_defconfig +++ b/configs/kmcoge5un_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_SYS_EXTRA_OPTIONS="KM_COGE5UN" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_SPI_FLASH=y diff --git a/configs/kmeter1_defconfig b/configs/kmeter1_defconfig index 03cfffb..f3c0115 100644 --- a/configs/kmeter1_defconfig +++ b/configs/kmeter1_defconfig @@ -4,5 +4,6 @@ CONFIG_TARGET_KM8360=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="KMETER1" +CONFIG_HUSH_PARSER=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/kmlion1_defconfig b/configs/kmlion1_defconfig index 12d0131..e263b85 100644 --- a/configs/kmlion1_defconfig +++ b/configs/kmlion1_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="KMLION1" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_SPI_FLASH=y diff --git a/configs/kmnusa_defconfig b/configs/kmnusa_defconfig index 3a1aa69..5b391be 100644 --- a/configs/kmnusa_defconfig +++ b/configs/kmnusa_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_SYS_EXTRA_OPTIONS="KM_NUSA" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_SPI_FLASH=y diff --git a/configs/kmopti2_defconfig b/configs/kmopti2_defconfig index 1d29c87..e339b8a 100644 --- a/configs/kmopti2_defconfig +++ b/configs/kmopti2_defconfig @@ -4,5 +4,6 @@ CONFIG_TARGET_TUXX1=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="KMOPTI2" +CONFIG_HUSH_PARSER=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/kmsugp1_defconfig b/configs/kmsugp1_defconfig index bc9aaec..11022f3 100644 --- a/configs/kmsugp1_defconfig +++ b/configs/kmsugp1_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_SYS_EXTRA_OPTIONS="KM_SUGP1" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_SPI_FLASH=y diff --git a/configs/kmsupx5_defconfig b/configs/kmsupx5_defconfig index dda73be..bac694b 100644 --- a/configs/kmsupx5_defconfig +++ b/configs/kmsupx5_defconfig @@ -4,5 +4,6 @@ CONFIG_TARGET_TUXX1=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="KMSUPX5" +CONFIG_HUSH_PARSER=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/kmsuv31_defconfig b/configs/kmsuv31_defconfig index 0a16c04..d8f0d7c 100644 --- a/configs/kmsuv31_defconfig +++ b/configs/kmsuv31_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_SYS_EXTRA_OPTIONS="KM_SUV31" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_SPI_FLASH=y diff --git a/configs/kmtegr1_defconfig b/configs/kmtegr1_defconfig index b28070b..7ac4cc3 100644 --- a/configs/kmtegr1_defconfig +++ b/configs/kmtegr1_defconfig @@ -4,5 +4,6 @@ CONFIG_TARGET_SUVD3=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="KMTEGR1" +CONFIG_HUSH_PARSER=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/kmtepr2_defconfig b/configs/kmtepr2_defconfig index dbe0d22..61c943f 100644 --- a/configs/kmtepr2_defconfig +++ b/configs/kmtepr2_defconfig @@ -4,5 +4,6 @@ CONFIG_TARGET_TUXX1=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="KMTEPR2" +CONFIG_HUSH_PARSER=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/kmvect1_defconfig b/configs/kmvect1_defconfig index 9dd6894..fcf52f9 100644 --- a/configs/kmvect1_defconfig +++ b/configs/kmvect1_defconfig @@ -4,5 +4,6 @@ CONFIG_TARGET_SUVD3=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="KMVECT1" +CONFIG_HUSH_PARSER=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/kylin-rk3036_defconfig b/configs/kylin-rk3036_defconfig index 2cc9de4..787c020 100644 --- a/configs/kylin-rk3036_defconfig +++ b/configs/kylin-rk3036_defconfig @@ -5,6 +5,7 @@ CONFIG_TARGET_KYLIN_RK3036=y CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3036-sdk" CONFIG_SPL_STACK_R=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_SETEXPR is not set CONFIG_REGMAP=y diff --git a/configs/legoev3_defconfig b/configs/legoev3_defconfig index 22fd057..97b81ef 100644 --- a/configs/legoev3_defconfig +++ b/configs/legoev3_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_DAVINCI=y CONFIG_TARGET_LEGOEV3=y +CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autoboot in %d seconds - press 'l' to stop...\n" CONFIG_AUTOBOOT_STOP_STR="l" diff --git a/configs/ls1021aqds_ddr4_nor_defconfig b/configs/ls1021aqds_ddr4_nor_defconfig index b858de9..68172c9 100644 --- a/configs/ls1021aqds_ddr4_nor_defconfig +++ b/configs/ls1021aqds_ddr4_nor_defconfig @@ -5,6 +5,7 @@ CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_CONTROL=y CONFIG_DM=y diff --git a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig index 70b4a10..224fd8b 100644 --- a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig +++ b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig @@ -5,6 +5,7 @@ CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-lpuart" CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,LPUART" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_CONTROL=y CONFIG_DM=y diff --git a/configs/ls1021aqds_nand_defconfig b/configs/ls1021aqds_nand_defconfig index a24923e..7fa9daa 100644 --- a/configs/ls1021aqds_nand_defconfig +++ b/configs/ls1021aqds_nand_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,NAND_BOOT" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_NETDEVICES=y CONFIG_E1000=y diff --git a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig index b7e3cd7..cfc31a6 100644 --- a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_LS1021AQDS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SECURE_BOOT" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_DM=y CONFIG_NETDEVICES=y diff --git a/configs/ls1021aqds_nor_defconfig b/configs/ls1021aqds_nor_defconfig index 70a3445..300ec9c 100644 --- a/configs/ls1021aqds_nor_defconfig +++ b/configs/ls1021aqds_nor_defconfig @@ -4,6 +4,7 @@ CONFIG_DM_SERIAL=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_CONTROL=y CONFIG_DM=y diff --git a/configs/ls1021aqds_nor_lpuart_defconfig b/configs/ls1021aqds_nor_lpuart_defconfig index a633393..3b9243a 100644 --- a/configs/ls1021aqds_nor_lpuart_defconfig +++ b/configs/ls1021aqds_nor_lpuart_defconfig @@ -5,6 +5,7 @@ CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-lpuart" CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="LPUART" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_CONTROL=y CONFIG_DM=y diff --git a/configs/ls1021aqds_qspi_defconfig b/configs/ls1021aqds_qspi_defconfig index 025fd4e..208a1bc 100644 --- a/configs/ls1021aqds_qspi_defconfig +++ b/configs/ls1021aqds_qspi_defconfig @@ -5,6 +5,7 @@ CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="QSPI_BOOT" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_SETEXPR is not set CONFIG_OF_CONTROL=y diff --git a/configs/ls1021aqds_sdcard_ifc_defconfig b/configs/ls1021aqds_sdcard_ifc_defconfig index e283f69..9d196e1 100644 --- a/configs/ls1021aqds_sdcard_ifc_defconfig +++ b/configs/ls1021aqds_sdcard_ifc_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_LS1021AQDS=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_CONTROL=y CONFIG_DM=y diff --git a/configs/ls1021aqds_sdcard_qspi_defconfig b/configs/ls1021aqds_sdcard_qspi_defconfig index 127b8b4..382cd11 100644 --- a/configs/ls1021aqds_sdcard_qspi_defconfig +++ b/configs/ls1021aqds_sdcard_qspi_defconfig @@ -4,6 +4,7 @@ CONFIG_DM_SPI=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT,SD_BOOT_QSPI" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_CONTROL=y CONFIG_DM=y diff --git a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig index eff4966..f81e12b 100644 --- a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_LS1021ATWR=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SECURE_BOOT" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_DM=y CONFIG_NETDEVICES=y diff --git a/configs/ls1021atwr_nor_defconfig b/configs/ls1021atwr_nor_defconfig index f25e6e2..c4b1cba 100644 --- a/configs/ls1021atwr_nor_defconfig +++ b/configs/ls1021atwr_nor_defconfig @@ -4,6 +4,7 @@ CONFIG_DM_SERIAL=y CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-duart" CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_CONTROL=y CONFIG_DM=y diff --git a/configs/ls1021atwr_nor_lpuart_defconfig b/configs/ls1021atwr_nor_lpuart_defconfig index 74f0445..ebf2466 100644 --- a/configs/ls1021atwr_nor_lpuart_defconfig +++ b/configs/ls1021atwr_nor_lpuart_defconfig @@ -5,6 +5,7 @@ CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-lpuart" CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="LPUART" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_CONTROL=y CONFIG_DM=y diff --git a/configs/ls1021atwr_qspi_defconfig b/configs/ls1021atwr_qspi_defconfig index c94581e..67917b2 100644 --- a/configs/ls1021atwr_qspi_defconfig +++ b/configs/ls1021atwr_qspi_defconfig @@ -5,6 +5,7 @@ CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-duart" CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="QSPI_BOOT" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_SETEXPR is not set CONFIG_OF_CONTROL=y diff --git a/configs/ls1021atwr_sdcard_ifc_defconfig b/configs/ls1021atwr_sdcard_ifc_defconfig index 03363a7..6f8666c 100644 --- a/configs/ls1021atwr_sdcard_ifc_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/ls1021atwr_sdcard_qspi_defconfig b/configs/ls1021atwr_sdcard_qspi_defconfig index a44988a..4253f8c 100644 --- a/configs/ls1021atwr_sdcard_qspi_defconfig +++ b/configs/ls1021atwr_sdcard_qspi_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT,SD_BOOT_QSPI" +CONFIG_HUSH_PARSER=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1043aqds_defconfig b/configs/ls1043aqds_defconfig index c1a6736..a97654c 100644 --- a/configs/ls1043aqds_defconfig +++ b/configs/ls1043aqds_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4" +CONFIG_HUSH_PARSER=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1043aqds_lpuart_defconfig b/configs/ls1043aqds_lpuart_defconfig index 7468c1b..c85039b 100644 --- a/configs/ls1043aqds_lpuart_defconfig +++ b/configs/ls1043aqds_lpuart_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,LPUART" +CONFIG_HUSH_PARSER=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1043aqds_nand_defconfig b/configs/ls1043aqds_nand_defconfig index 1694458..41e5104 100644 --- a/configs/ls1043aqds_nand_defconfig +++ b/configs/ls1043aqds_nand_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,RAMBOOT_PBL,SPL_FSL_PBL,NAND_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1043aqds_nor_ddr3_defconfig b/configs/ls1043aqds_nor_ddr3_defconfig index a90c4ad..1ad2801 100644 --- a/configs/ls1043aqds_nor_ddr3_defconfig +++ b/configs/ls1043aqds_nor_ddr3_defconfig @@ -5,6 +5,7 @@ CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1043a-qds-duart" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1043aqds_qspi_defconfig b/configs/ls1043aqds_qspi_defconfig index 2536821..f339096 100644 --- a/configs/ls1043aqds_qspi_defconfig +++ b/configs/ls1043aqds_qspi_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,QSPI_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1043aqds_sdcard_ifc_defconfig b/configs/ls1043aqds_sdcard_ifc_defconfig index 07b3edc..2823524 100644 --- a/configs/ls1043aqds_sdcard_ifc_defconfig +++ b/configs/ls1043aqds_sdcard_ifc_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1043aqds_sdcard_qspi_defconfig b/configs/ls1043aqds_sdcard_qspi_defconfig index 9967973..fbb3611 100644 --- a/configs/ls1043aqds_sdcard_qspi_defconfig +++ b/configs/ls1043aqds_sdcard_qspi_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT,SD_BOOT_QSPI" +CONFIG_HUSH_PARSER=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1043ardb_SECURE_BOOT_defconfig b/configs/ls1043ardb_SECURE_BOOT_defconfig index c25c3c1..86f3f1a 100644 --- a/configs/ls1043ardb_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_SECURE_BOOT_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4, SECURE_BOOT" +CONFIG_HUSH_PARSER=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1043ardb_defconfig b/configs/ls1043ardb_defconfig index 97f224d..5423853 100644 --- a/configs/ls1043ardb_defconfig +++ b/configs/ls1043ardb_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4" +CONFIG_HUSH_PARSER=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1043ardb_nand_defconfig b/configs/ls1043ardb_nand_defconfig index a273331..7209d8d 100644 --- a/configs/ls1043ardb_nand_defconfig +++ b/configs/ls1043ardb_nand_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,NAND_BOOT,SYS_FSL_DDR4" +CONFIG_HUSH_PARSER=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1043ardb_sdcard_defconfig b/configs/ls1043ardb_sdcard_defconfig index 50f4955..1e27b7f 100644 --- a/configs/ls1043ardb_sdcard_defconfig +++ b/configs/ls1043ardb_sdcard_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT,SYS_FSL_DDR4" +CONFIG_HUSH_PARSER=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls2080a_emu_defconfig b/configs/ls2080a_emu_defconfig index eca5265..679fb87 100644 --- a/configs/ls2080a_emu_defconfig +++ b/configs/ls2080a_emu_defconfig @@ -5,6 +5,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="EMU,SYS_FSL_DDR4, LS2080A" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set diff --git a/configs/ls2080a_simu_defconfig b/configs/ls2080a_simu_defconfig index 7540c4b..a4055ab 100644 --- a/configs/ls2080a_simu_defconfig +++ b/configs/ls2080a_simu_defconfig @@ -5,6 +5,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SIMU, LS2080A" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set diff --git a/configs/ls2080aqds_SECURE_BOOT_defconfig b/configs/ls2080aqds_SECURE_BOOT_defconfig index 408d1ee..961262e 100644 --- a/configs/ls2080aqds_SECURE_BOOT_defconfig +++ b/configs/ls2080aqds_SECURE_BOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4, LS2080A, SECURE_BOOT" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/ls2080aqds_defconfig b/configs/ls2080aqds_defconfig index a16a6d5..9cc9784 100644 --- a/configs/ls2080aqds_defconfig +++ b/configs/ls2080aqds_defconfig @@ -9,6 +9,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4, LS2080A" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/ls2080aqds_nand_defconfig b/configs/ls2080aqds_nand_defconfig index b5a64f0..15e4850 100644 --- a/configs/ls2080aqds_nand_defconfig +++ b/configs/ls2080aqds_nand_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4, NAND, LS2080A" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NETDEVICES=y diff --git a/configs/ls2080ardb_SECURE_BOOT_defconfig b/configs/ls2080ardb_SECURE_BOOT_defconfig index dde3311..d95774e 100644 --- a/configs/ls2080ardb_SECURE_BOOT_defconfig +++ b/configs/ls2080ardb_SECURE_BOOT_defconfig @@ -9,6 +9,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4, LS2080A, SECURE_BOOT" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/ls2080ardb_defconfig b/configs/ls2080ardb_defconfig index f8f54e7..860e93c 100644 --- a/configs/ls2080ardb_defconfig +++ b/configs/ls2080ardb_defconfig @@ -9,6 +9,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4, LS2080A" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/ls2080ardb_nand_defconfig b/configs/ls2080ardb_nand_defconfig index 0c90869..67481cb 100644 --- a/configs/ls2080ardb_nand_defconfig +++ b/configs/ls2080ardb_nand_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4, NAND, LS2080A" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NETDEVICES=y diff --git a/configs/lschlv2_defconfig b/configs/lschlv2_defconfig index f33cda6..9db98bb 100644 --- a/configs/lschlv2_defconfig +++ b/configs/lschlv2_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_LSXL=y CONFIG_SYS_EXTRA_OPTIONS="LSCHLV2" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set diff --git a/configs/lsxhl_defconfig b/configs/lsxhl_defconfig index 9f3fde5..aa5f841 100644 --- a/configs/lsxhl_defconfig +++ b/configs/lsxhl_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_LSXL=y CONFIG_SYS_EXTRA_OPTIONS="LSXHL" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set diff --git a/configs/luan_defconfig b/configs/luan_defconfig index 6995819..f9b7f06 100644 --- a/configs/luan_defconfig +++ b/configs/luan_defconfig @@ -2,5 +2,6 @@ CONFIG_PPC=y CONFIG_4xx=y CONFIG_TARGET_LUAN=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/lwmon5_defconfig b/configs/lwmon5_defconfig index b317937..98ecb88 100644 --- a/configs/lwmon5_defconfig +++ b/configs/lwmon5_defconfig @@ -3,6 +3,7 @@ CONFIG_4xx=y CONFIG_TARGET_LWMON5=y CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/m28evk_defconfig b/configs/m28evk_defconfig index b587617..55ad865 100644 --- a/configs/m28evk_defconfig +++ b/configs/m28evk_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_M28EVK=y CONFIG_SPL=y CONFIG_FIT=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/m53evk_defconfig b/configs/m53evk_defconfig index 4e0368b..2f17ddc 100644 --- a/configs/m53evk_defconfig +++ b/configs/m53evk_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_M53EVK=y CONFIG_SPL=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/denx/m53evk/imximage.cfg" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_OF_LIBFDT=y diff --git a/configs/ma5d4evk_defconfig b/configs/ma5d4evk_defconfig index f7973ed..f7ad872 100644 --- a/configs/ma5d4evk_defconfig +++ b/configs/ma5d4evk_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_MA5D4EVK=y CONFIG_SPL=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D4" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set diff --git a/configs/makalu_defconfig b/configs/makalu_defconfig index 79c13cf..d0ab4f1 100644 --- a/configs/makalu_defconfig +++ b/configs/makalu_defconfig @@ -2,5 +2,6 @@ CONFIG_PPC=y CONFIG_4xx=y CONFIG_TARGET_MAKALU=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/malta_defconfig b/configs/malta_defconfig index 2ebd58b..ee3e9ea 100644 --- a/configs/malta_defconfig +++ b/configs/malta_defconfig @@ -1,5 +1,6 @@ CONFIG_MIPS=y CONFIG_TARGET_MALTA=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/maltael_defconfig b/configs/maltael_defconfig index d24d217..ca28d92 100644 --- a/configs/maltael_defconfig +++ b/configs/maltael_defconfig @@ -1,6 +1,7 @@ CONFIG_MIPS=y CONFIG_TARGET_MALTA=y CONFIG_SYS_LITTLE_ENDIAN=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/marsboard_defconfig b/configs/marsboard_defconfig index 4bdbb6d..a873b61 100644 --- a/configs/marsboard_defconfig +++ b/configs/marsboard_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_EMBESTMX6BOARDS=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024,ENV_IS_IN_SPI_FLASH" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/mcx_defconfig b/configs/mcx_defconfig index 9c9d51a..5a9247a 100644 --- a/configs/mcx_defconfig +++ b/configs/mcx_defconfig @@ -3,6 +3,7 @@ CONFIG_OMAP34XX=y CONFIG_TARGET_MCX=y CONFIG_SPL=y CONFIG_FIT=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="mcx # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set @@ -11,7 +12,7 @@ CONFIG_SYS_PROMPT="mcx # " CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y -CONFIG_OF_LIBFDT=y CONFIG_USB=y -CONFIG_USB_ULPI=y CONFIG_USB_ULPI_VIEWPORT_OMAP=y +CONFIG_USB_ULPI=y +CONFIG_OF_LIBFDT=y diff --git a/configs/mecp5123_defconfig b/configs/mecp5123_defconfig index 86d7c3f..15f45df 100644 --- a/configs/mecp5123_defconfig +++ b/configs/mecp5123_defconfig @@ -2,5 +2,6 @@ CONFIG_PPC=y CONFIG_MPC512X=y CONFIG_TARGET_MECP5123=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/medcom-wide_defconfig b/configs/medcom-wide_defconfig index 95bb570..4d9161e 100644 --- a/configs/medcom-wide_defconfig +++ b/configs/medcom-wide_defconfig @@ -6,6 +6,7 @@ CONFIG_TARGET_MEDCOM_WIDE=y CONFIG_DEFAULT_DEVICE_TREE="tegra20-medcom-wide" CONFIG_FIT=y CONFIG_OF_SYSTEM_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra20 (Medcom-Wide) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/meesc_dataflash_defconfig b/configs/meesc_dataflash_defconfig index f207428..64108a7 100644 --- a/configs/meesc_dataflash_defconfig +++ b/configs/meesc_dataflash_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_MEESC=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_DATAFLASH" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set diff --git a/configs/meesc_defconfig b/configs/meesc_defconfig index 8931357..3024f52 100644 --- a/configs/meesc_defconfig +++ b/configs/meesc_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_MEESC=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_NANDFLASH" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set diff --git a/configs/mgcoge3ne_defconfig b/configs/mgcoge3ne_defconfig index dc91157..b7b2fdb 100644 --- a/configs/mgcoge3ne_defconfig +++ b/configs/mgcoge3ne_defconfig @@ -4,4 +4,5 @@ CONFIG_TARGET_KM82XX=y CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="MGCOGE3NE" +CONFIG_HUSH_PARSER=y CONFIG_OF_LIBFDT=y diff --git a/configs/mgcoge3un_defconfig b/configs/mgcoge3un_defconfig index f1e8fd7..5143214 100644 --- a/configs/mgcoge3un_defconfig +++ b/configs/mgcoge3un_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_SYS_EXTRA_OPTIONS="KM_MGCOGE3UN" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_SPI_FLASH=y diff --git a/configs/mgcoge_defconfig b/configs/mgcoge_defconfig index 86200fa..9d6adea 100644 --- a/configs/mgcoge_defconfig +++ b/configs/mgcoge_defconfig @@ -4,4 +4,5 @@ CONFIG_TARGET_KM82XX=y CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="MGCOGE" +CONFIG_HUSH_PARSER=y CONFIG_OF_LIBFDT=y diff --git a/configs/minnowmax_defconfig b/configs/minnowmax_defconfig index efb9c1e..6689104 100644 --- a/configs/minnowmax_defconfig +++ b/configs/minnowmax_defconfig @@ -12,6 +12,7 @@ CONFIG_FIT=y CONFIG_FIT_SIGNATURE=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y +CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/mixtile_loftq_defconfig b/configs/mixtile_loftq_defconfig index ce81309..89a52a2 100644 --- a/configs/mixtile_loftq_defconfig +++ b/configs/mixtile_loftq_defconfig @@ -9,6 +9,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-mixtile-loftq" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPA(21)" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/mk802_a10s_defconfig b/configs/mk802_a10s_defconfig index 720aefa..7bc54d6 100644 --- a/configs/mk802_a10s_defconfig +++ b/configs/mk802_a10s_defconfig @@ -7,6 +7,7 @@ CONFIG_USB1_VBUS_PIN="PB10" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-mk802" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/mk802_defconfig b/configs/mk802_defconfig index d38bc7f..98a73c2 100644 --- a/configs/mk802_defconfig +++ b/configs/mk802_defconfig @@ -6,6 +6,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-mk802" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="USB_EHCI" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/mk802ii_defconfig b/configs/mk802ii_defconfig index de1b73f..0786fcf 100644 --- a/configs/mk802ii_defconfig +++ b/configs/mk802ii_defconfig @@ -4,6 +4,7 @@ CONFIG_MACH_SUN4I=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-mk802ii" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/motionpro_defconfig b/configs/motionpro_defconfig index ea2b28a..100f898 100644 --- a/configs/motionpro_defconfig +++ b/configs/motionpro_defconfig @@ -2,6 +2,7 @@ CONFIG_PPC=y CONFIG_MPC5xxx=y CONFIG_TARGET_MOTIONPRO=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc><Esc>" to stop\n" CONFIG_AUTOBOOT_STOP_STR="\x1b\x1b" diff --git a/configs/mpc5121ads_defconfig b/configs/mpc5121ads_defconfig index 865b97b..62bd8e7 100644 --- a/configs/mpc5121ads_defconfig +++ b/configs/mpc5121ads_defconfig @@ -2,5 +2,6 @@ CONFIG_PPC=y CONFIG_MPC512X=y CONFIG_TARGET_MPC5121ADS=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/mpc5121ads_rev2_defconfig b/configs/mpc5121ads_rev2_defconfig index 6fe22b3..5d99cb3 100644 --- a/configs/mpc5121ads_rev2_defconfig +++ b/configs/mpc5121ads_rev2_defconfig @@ -3,5 +3,6 @@ CONFIG_MPC512X=y CONFIG_TARGET_MPC5121ADS=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="MPC5121ADS_REV2" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/mpc8308_p1m_defconfig b/configs/mpc8308_p1m_defconfig index af76130..21a3b20 100644 --- a/configs/mpc8308_p1m_defconfig +++ b/configs/mpc8308_p1m_defconfig @@ -3,6 +3,7 @@ CONFIG_MPC83xx=y CONFIG_TARGET_MPC8308_P1M=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/mt_ventoux_defconfig b/configs/mt_ventoux_defconfig index 45913d4..ea4eb55 100644 --- a/configs/mt_ventoux_defconfig +++ b/configs/mt_ventoux_defconfig @@ -3,13 +3,14 @@ CONFIG_OMAP34XX=y CONFIG_TARGET_MT_VENTOUX=y CONFIG_SPL=y CONFIG_FIT=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="mt_ventoux => " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y -CONFIG_OF_LIBFDT=y CONFIG_USB=y -CONFIG_USB_ULPI=y CONFIG_USB_ULPI_VIEWPORT_OMAP=y +CONFIG_USB_ULPI=y +CONFIG_OF_LIBFDT=y diff --git a/configs/mx23_olinuxino_defconfig b/configs/mx23_olinuxino_defconfig index 4582cce..30de97a 100644 --- a/configs/mx23_olinuxino_defconfig +++ b/configs/mx23_olinuxino_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_MX23_OLINUXINO=y CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/mx23evk_defconfig b/configs/mx23evk_defconfig index 43e3d0a..dc14b21 100644 --- a/configs/mx23evk_defconfig +++ b/configs/mx23evk_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_MX23EVK=y CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/mx25pdk_defconfig b/configs/mx25pdk_defconfig index 5a4bd57..10d6385 100644 --- a/configs/mx25pdk_defconfig +++ b/configs/mx25pdk_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_MX25PDK=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx25pdk/imximage.cfg" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set diff --git a/configs/mx28evk_auart_console_defconfig b/configs/mx28evk_auart_console_defconfig index f4c934f..5cc051f 100644 --- a/configs/mx28evk_auart_console_defconfig +++ b/configs/mx28evk_auart_console_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_MX28EVK=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="MXS_AUART,MXS_AUART_BASE=MXS_UARTAPP3_BASE,ENV_IS_IN_MMC" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/mx28evk_defconfig b/configs/mx28evk_defconfig index bb900ff..f93c49a 100644 --- a/configs/mx28evk_defconfig +++ b/configs/mx28evk_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_MX28EVK=y CONFIG_SPL=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_MMC" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/mx28evk_nand_defconfig b/configs/mx28evk_nand_defconfig index 0f76bde..bd6a6e6 100644 --- a/configs/mx28evk_nand_defconfig +++ b/configs/mx28evk_nand_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_MX28EVK=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_NAND" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/mx28evk_spi_defconfig b/configs/mx28evk_spi_defconfig index ad939ca..d91822c 100644 --- a/configs/mx28evk_spi_defconfig +++ b/configs/mx28evk_spi_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_MX28EVK=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_SPI_FLASH" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/mx35pdk_defconfig b/configs/mx35pdk_defconfig index 699d929..2b98931 100644 --- a/configs/mx35pdk_defconfig +++ b/configs/mx35pdk_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y CONFIG_TARGET_MX35PDK=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/mx51evk_defconfig b/configs/mx51evk_defconfig index 0bb0c61..4dd2f78 100644 --- a/configs/mx51evk_defconfig +++ b/configs/mx51evk_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_MX51EVK=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx51evk/imximage.cfg" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/mx53ard_defconfig b/configs/mx53ard_defconfig index e8a211a..1580003 100644 --- a/configs/mx53ard_defconfig +++ b/configs/mx53ard_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_MX53ARD=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx53ard/imximage_dd3.cfg" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set CONFIG_OF_LIBFDT=y diff --git a/configs/mx53evk_defconfig b/configs/mx53evk_defconfig index 1c4da22..e9f8f9a 100644 --- a/configs/mx53evk_defconfig +++ b/configs/mx53evk_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_MX53EVK=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx53evk/imximage.cfg" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/mx53loco_defconfig b/configs/mx53loco_defconfig index 273ce16..a572231 100644 --- a/configs/mx53loco_defconfig +++ b/configs/mx53loco_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_MX53LOCO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx53loco/imximage.cfg" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/mx53smd_defconfig b/configs/mx53smd_defconfig index 92e9f63..1285d13 100644 --- a/configs/mx53smd_defconfig +++ b/configs/mx53smd_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_MX53SMD=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx53smd/imximage.cfg" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/mx6cuboxi_defconfig b/configs/mx6cuboxi_defconfig index 58e297a..4dfd4e1 100644 --- a/configs/mx6cuboxi_defconfig +++ b/configs/mx6cuboxi_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6CUBOXI=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6QDL" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/mx6dlarm2_defconfig b/configs/mx6dlarm2_defconfig index 60e5dd6..20873c7 100644 --- a/configs/mx6dlarm2_defconfig +++ b/configs/mx6dlarm2_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6QARM2=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qarm2/imximage_mx6dl.cfg,MX6DL,DDR_MB=2048" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/mx6dlarm2_lpddr2_defconfig b/configs/mx6dlarm2_lpddr2_defconfig index 01a682f..5fdc267 100644 --- a/configs/mx6dlarm2_lpddr2_defconfig +++ b/configs/mx6dlarm2_lpddr2_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6QARM2=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qarm2/imximage_mx6dl.cfg,MX6DL,MX6DL_LPDDR2,DDR_MB=512" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/mx6dlsabreauto_defconfig b/configs/mx6dlsabreauto_defconfig index 561e886..eb30b16 100644 --- a/configs/mx6dlsabreauto_defconfig +++ b/configs/mx6dlsabreauto_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6QSABREAUTO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qsabreauto/mx6dl.cfg,MX6DL" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/mx6dlsabresd_defconfig b/configs/mx6dlsabresd_defconfig index 870e403..44db02f 100644 --- a/configs/mx6dlsabresd_defconfig +++ b/configs/mx6dlsabresd_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6SABRESD=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6sabresd/mx6dlsabresd.cfg,MX6DL" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/mx6qarm2_defconfig b/configs/mx6qarm2_defconfig index 7aa7916..4684a3f 100644 --- a/configs/mx6qarm2_defconfig +++ b/configs/mx6qarm2_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6QARM2=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qarm2/imximage.cfg,MX6Q,DDR_MB=2048" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/mx6qarm2_lpddr2_defconfig b/configs/mx6qarm2_lpddr2_defconfig index 5920430..1d0d109 100644 --- a/configs/mx6qarm2_lpddr2_defconfig +++ b/configs/mx6qarm2_lpddr2_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6QARM2=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qarm2/imximage.cfg,MX6Q,MX6DQ_LPDDR2,DDR_MB=512" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/mx6qpsabreauto_defconfig b/configs/mx6qpsabreauto_defconfig index 61f0a75..25f81fc 100644 --- a/configs/mx6qpsabreauto_defconfig +++ b/configs/mx6qpsabreauto_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6QSABREAUTO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qsabreauto/mx6qp.cfg,MX6Q" +CONFIG_HUSH_PARSER=y CONFIG_CMD_GPIO=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/mx6qsabreauto_defconfig b/configs/mx6qsabreauto_defconfig index 49aa619..40f9012 100644 --- a/configs/mx6qsabreauto_defconfig +++ b/configs/mx6qsabreauto_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6QSABREAUTO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qsabreauto/imximage.cfg,MX6Q" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/mx6qsabrelite_defconfig b/configs/mx6qsabrelite_defconfig index 84faa2f..6ad6fd8 100644 --- a/configs/mx6qsabrelite_defconfig +++ b/configs/mx6qsabrelite_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024,SABRELITE" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/mx6qsabresd_defconfig b/configs/mx6qsabresd_defconfig index 7b69de1..595f8d8 100644 --- a/configs/mx6qsabresd_defconfig +++ b/configs/mx6qsabresd_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6SABRESD=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6sabresd/mx6q_4x_mt41j128.cfg,MX6Q" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/mx6sabresd_spl_defconfig b/configs/mx6sabresd_spl_defconfig index 540a822..0ecc91f 100644 --- a/configs/mx6sabresd_spl_defconfig +++ b/configs/mx6sabresd_spl_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6SABRESD=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,SPL,MX6Q" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/mx6slevk_defconfig b/configs/mx6slevk_defconfig index 2d24622..38cd927 100644 --- a/configs/mx6slevk_defconfig +++ b/configs/mx6slevk_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6SLEVK=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6slevk/imximage.cfg,MX6SL" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/mx6slevk_spinor_defconfig b/configs/mx6slevk_spinor_defconfig index 65b5e9d..73d9e46 100644 --- a/configs/mx6slevk_spinor_defconfig +++ b/configs/mx6slevk_spinor_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6SLEVK=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6slevk/imximage.cfg,MX6SL,SYS_BOOT_SPINOR" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/mx6slevk_spl_defconfig b/configs/mx6slevk_spl_defconfig index fee352c..995f8d1 100644 --- a/configs/mx6slevk_spl_defconfig +++ b/configs/mx6slevk_spl_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6SLEVK=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,SPL,MX6SL" +CONFIG_HUSH_PARSER=y CONFIG_CMD_GPIO=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/mx6sxsabreauto_defconfig b/configs/mx6sxsabreauto_defconfig index 631a998..f194432 100644 --- a/configs/mx6sxsabreauto_defconfig +++ b/configs/mx6sxsabreauto_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6SXSABREAUTO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6sxsabreauto/imximage.cfg" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/mx6sxsabresd_defconfig b/configs/mx6sxsabresd_defconfig index 2ea5c89..bf4d972 100644 --- a/configs/mx6sxsabresd_defconfig +++ b/configs/mx6sxsabresd_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6SXSABRESD=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6sxsabresd/imximage.cfg" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/mx6sxsabresd_spl_defconfig b/configs/mx6sxsabresd_spl_defconfig index 548adf6..4822d25 100644 --- a/configs/mx6sxsabresd_spl_defconfig +++ b/configs/mx6sxsabresd_spl_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6SXSABRESD=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/mx6ul_14x14_evk_defconfig b/configs/mx6ul_14x14_evk_defconfig index 77d78e7..660b815 100644 --- a/configs/mx6ul_14x14_evk_defconfig +++ b/configs/mx6ul_14x14_evk_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6UL_14X14_EVK=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg" +CONFIG_HUSH_PARSER=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y diff --git a/configs/mx6ul_9x9_evk_defconfig b/configs/mx6ul_9x9_evk_defconfig index a6dd96b..b062757 100644 --- a/configs/mx6ul_9x9_evk_defconfig +++ b/configs/mx6ul_9x9_evk_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6UL_9X9_EVK=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg" +CONFIG_HUSH_PARSER=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y diff --git a/configs/mx7dsabresd_defconfig b/configs/mx7dsabresd_defconfig index fe7e55d..c8894e9 100644 --- a/configs/mx7dsabresd_defconfig +++ b/configs/mx7dsabresd_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_MX7DSABRESD=y CONFIG_IMX_RDC=y CONFIG_IMX_BOOTAUX=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx7dsabresd/imximage.cfg" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_BOOTD is not set # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/nas220_defconfig b/configs/nas220_defconfig index ab9ebba..34c3b74 100644 --- a/configs/nas220_defconfig +++ b/configs/nas220_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_NAS220=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="nas220> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/neo_defconfig b/configs/neo_defconfig index 0366da1..0a6d2eb 100644 --- a/configs/neo_defconfig +++ b/configs/neo_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_NEO=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_ELF is not set # CONFIG_CMD_NFS is not set CONFIG_SYS_NS16550=y diff --git a/configs/net2big_v2_defconfig b/configs/net2big_v2_defconfig index c0aee31..07bc0d4 100644 --- a/configs/net2big_v2_defconfig +++ b/configs/net2big_v2_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_NET2BIG_V2=y CONFIG_SYS_EXTRA_OPTIONS="NET2BIG_V2" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set diff --git a/configs/netspace_lite_v2_defconfig b/configs/netspace_lite_v2_defconfig index eb26f88..b9ebf04 100644 --- a/configs/netspace_lite_v2_defconfig +++ b/configs/netspace_lite_v2_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_NETSPACE_V2=y CONFIG_SYS_EXTRA_OPTIONS="NETSPACE_LITE_V2" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set diff --git a/configs/netspace_max_v2_defconfig b/configs/netspace_max_v2_defconfig index e37523e..f642175 100644 --- a/configs/netspace_max_v2_defconfig +++ b/configs/netspace_max_v2_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_NETSPACE_V2=y CONFIG_SYS_EXTRA_OPTIONS="NETSPACE_MAX_V2" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set diff --git a/configs/netspace_mini_v2_defconfig b/configs/netspace_mini_v2_defconfig index e847123..acb1aa2 100644 --- a/configs/netspace_mini_v2_defconfig +++ b/configs/netspace_mini_v2_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_NETSPACE_V2=y CONFIG_SYS_EXTRA_OPTIONS="NETSPACE_MINI_V2" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set diff --git a/configs/netspace_v2_defconfig b/configs/netspace_v2_defconfig index 01a6f7e..37c150a 100644 --- a/configs/netspace_v2_defconfig +++ b/configs/netspace_v2_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_NETSPACE_V2=y CONFIG_SYS_EXTRA_OPTIONS="NETSPACE_V2" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set diff --git a/configs/nitrogen6dl2g_defconfig b/configs/nitrogen6dl2g_defconfig index 34ddff9..6471694 100644 --- a/configs/nitrogen6dl2g_defconfig +++ b/configs/nitrogen6dl2g_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl2g.cfg,MX6DL,DDR_MB=2048" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/nitrogen6dl_defconfig b/configs/nitrogen6dl_defconfig index c2bea2e..ec15581 100644 --- a/configs/nitrogen6dl_defconfig +++ b/configs/nitrogen6dl_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL,DDR_MB=1024" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/nitrogen6q2g_defconfig b/configs/nitrogen6q2g_defconfig index 0ce35b0..69fc732 100644 --- a/configs/nitrogen6q2g_defconfig +++ b/configs/nitrogen6q2g_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q2g.cfg,MX6Q,DDR_MB=2048" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/nitrogen6q_defconfig b/configs/nitrogen6q_defconfig index ef2f0e2..2b9689b 100644 --- a/configs/nitrogen6q_defconfig +++ b/configs/nitrogen6q_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/nitrogen6s1g_defconfig b/configs/nitrogen6s1g_defconfig index 0aac630..50aef70 100644 --- a/configs/nitrogen6s1g_defconfig +++ b/configs/nitrogen6s1g_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s1g.cfg,MX6S,DDR_MB=1024" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/nitrogen6s_defconfig b/configs/nitrogen6s_defconfig index d6280df..d2f2e0b 100644 --- a/configs/nitrogen6s_defconfig +++ b/configs/nitrogen6s_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s.cfg,MX6S,DDR_MB=512" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/nokia_rx51_defconfig b/configs/nokia_rx51_defconfig index d7eb39a..f2658cd 100644 --- a/configs/nokia_rx51_defconfig +++ b/configs/nokia_rx51_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_OMAP34XX=y CONFIG_TARGET_NOKIA_RX51=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Nokia RX-51 # " CONFIG_AUTOBOOT_KEYED=y # CONFIG_CMD_IMI is not set diff --git a/configs/novena_defconfig b/configs/novena_defconfig index f28d884..cdf841c 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_KOSAGI_NOVENA=y CONFIG_SPL=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6Q" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/nyan-big_defconfig b/configs/nyan-big_defconfig index d86a55c..a14a531 100644 --- a/configs/nyan-big_defconfig +++ b/configs/nyan-big_defconfig @@ -7,6 +7,7 @@ CONFIG_DEFAULT_DEVICE_TREE="tegra124-nyan-big" CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y CONFIG_OF_SYSTEM_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra124 (Nyan-big) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/odroid-xu3_defconfig b/configs/odroid-xu3_defconfig index bb0576a..16d3ad1 100644 --- a/configs/odroid-xu3_defconfig +++ b/configs/odroid-xu3_defconfig @@ -6,6 +6,7 @@ CONFIG_DEFAULT_DEVICE_TREE="exynos5422-odroidxu3" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ODROID-XU3 # " # CONFIG_CMD_IMLS is not set CONFIG_CMD_GPIO=y diff --git a/configs/odroid_defconfig b/configs/odroid_defconfig index a92bbe1..5f3503f 100644 --- a/configs/odroid_defconfig +++ b/configs/odroid_defconfig @@ -6,6 +6,7 @@ CONFIG_DEFAULT_DEVICE_TREE="exynos4412-odroid" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Odroid # " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set diff --git a/configs/omap3_beagle_defconfig b/configs/omap3_beagle_defconfig index ab54570..ed790f7 100644 --- a/configs/omap3_beagle_defconfig +++ b/configs/omap3_beagle_defconfig @@ -3,6 +3,7 @@ CONFIG_OMAP34XX=y CONFIG_TARGET_OMAP3_BEAGLE=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="NAND" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/omap3_evm_defconfig b/configs/omap3_evm_defconfig index 89fdf80..9efa8d3 100644 --- a/configs/omap3_evm_defconfig +++ b/configs/omap3_evm_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_OMAP34XX=y CONFIG_TARGET_OMAP3_EVM=y CONFIG_SPL=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="OMAP3_EVM # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/omap3_ha_defconfig b/configs/omap3_ha_defconfig index 5fc4bfc..9c294c3 100644 --- a/configs/omap3_ha_defconfig +++ b/configs/omap3_ha_defconfig @@ -3,6 +3,7 @@ CONFIG_OMAP34XX=y CONFIG_TARGET_TAO3530=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SYS_BOARD_OMAP3_HA" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index dfbd180..8efd71e 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_OMAP3_LOGIC=y CONFIG_SPL=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="NAND" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="OMAP Logic # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/omap3_overo_defconfig b/configs/omap3_overo_defconfig index 2958e24..acb86ee 100644 --- a/configs/omap3_overo_defconfig +++ b/configs/omap3_overo_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_OMAP34XX=y CONFIG_TARGET_OMAP3_OVERO=y CONFIG_SPL=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Overo # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/omap3_pandora_defconfig b/configs/omap3_pandora_defconfig index e565d65..ed80de0 100644 --- a/configs/omap3_pandora_defconfig +++ b/configs/omap3_pandora_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_OMAP34XX=y CONFIG_TARGET_OMAP3_PANDORA=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Pandora # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/omap3_zoom1_defconfig b/configs/omap3_zoom1_defconfig index 70f0fdb..cdb91bc 100644 --- a/configs/omap3_zoom1_defconfig +++ b/configs/omap3_zoom1_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_OMAP34XX=y CONFIG_TARGET_OMAP3_ZOOM1=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/omap4_panda_defconfig b/configs/omap4_panda_defconfig index c6ff836..12a4683 100644 --- a/configs/omap4_panda_defconfig +++ b/configs/omap4_panda_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_OMAP44XX=y CONFIG_TARGET_OMAP4_PANDA=y CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/omap4_sdp4430_defconfig b/configs/omap4_sdp4430_defconfig index d42fc47..1d5dfa2 100644 --- a/configs/omap4_sdp4430_defconfig +++ b/configs/omap4_sdp4430_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_OMAP44XX=y CONFIG_TARGET_OMAP4_SDP4430=y CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/omap5_uevm_defconfig b/configs/omap5_uevm_defconfig index 135c89d..f9c7de3 100644 --- a/configs/omap5_uevm_defconfig +++ b/configs/omap5_uevm_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_OMAP54XX=y CONFIG_TARGET_OMAP5_UEVM=y CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/omapl138_lcdk_defconfig b/configs/omapl138_lcdk_defconfig index 8b97508..40165da 100644 --- a/configs/omapl138_lcdk_defconfig +++ b/configs/omapl138_lcdk_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_DAVINCI=y CONFIG_TARGET_OMAPL138_LCDK=y CONFIG_SPL=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot > " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/orangepi_2_defconfig b/configs/orangepi_2_defconfig index 2a32e04..97333c6 100644 --- a/configs/orangepi_2_defconfig +++ b/configs/orangepi_2_defconfig @@ -5,13 +5,14 @@ CONFIG_DRAM_CLK=672 CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y CONFIG_MMC0_CD_PIN="PF6" +CONFIG_USB1_VBUS_PIN="PG13" # CONFIG_VIDEO is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set CONFIG_SY8106A_POWER=y CONFIG_USB_EHCI_HCD=y -CONFIG_USB1_VBUS_PIN="PG13" diff --git a/configs/orangepi_one_defconfig b/configs/orangepi_one_defconfig index 207189a..26ef10e 100644 --- a/configs/orangepi_one_defconfig +++ b/configs/orangepi_one_defconfig @@ -9,8 +9,8 @@ CONFIG_MMC0_CD_PIN="PF6" CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-one" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set CONFIG_USB_EHCI_HCD=y -CONFIG_USB1_VBUS_PIN="" diff --git a/configs/orangepi_pc_defconfig b/configs/orangepi_pc_defconfig index 8d78b47..df9d0a2 100644 --- a/configs/orangepi_pc_defconfig +++ b/configs/orangepi_pc_defconfig @@ -8,11 +8,9 @@ CONFIG_DRAM_ODT_EN=y CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-pc" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set CONFIG_SY8106A_POWER=y CONFIG_USB_EHCI_HCD=y -CONFIG_USB1_VBUS_PIN="" -CONFIG_USB2_VBUS_PIN="" -CONFIG_USB3_VBUS_PIN="" diff --git a/configs/orangepi_plus_defconfig b/configs/orangepi_plus_defconfig index e96a273..fa12937 100644 --- a/configs/orangepi_plus_defconfig +++ b/configs/orangepi_plus_defconfig @@ -6,14 +6,15 @@ CONFIG_DRAM_ZQ=3881979 CONFIG_DRAM_ODT_EN=y CONFIG_MMC0_CD_PIN="PF6" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 +CONFIG_USB1_VBUS_PIN="PG13" # CONFIG_VIDEO is not set CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-plus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y +CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPG(11)" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set CONFIG_SY8106A_POWER=y CONFIG_USB_EHCI_HCD=y -CONFIG_USB1_VBUS_PIN="PG13" -CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPG(11)" diff --git a/configs/origen_defconfig b/configs/origen_defconfig index de4a816..9b85b0e 100644 --- a/configs/origen_defconfig +++ b/configs/origen_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_EXYNOS=y CONFIG_TARGET_ORIGEN=y CONFIG_DEFAULT_DEVICE_TREE="exynos4210-origen" CONFIG_SPL=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ORIGEN # " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set diff --git a/configs/ot1200_defconfig b/configs/ot1200_defconfig index 5e8671f..627eae5 100644 --- a/configs/ot1200_defconfig +++ b/configs/ot1200_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_OT1200=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/bachmann/ot1200/mx6q_4x_mt41j128.cfg,MX6Q" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/ot1200_spl_defconfig b/configs/ot1200_spl_defconfig index 2d37d8b..0283ff0 100644 --- a/configs/ot1200_spl_defconfig +++ b/configs/ot1200_spl_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_OT1200=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6Q" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/p2371-0000_defconfig b/configs/p2371-0000_defconfig index c9f7be2..2683a79 100644 --- a/configs/p2371-0000_defconfig +++ b/configs/p2371-0000_defconfig @@ -4,6 +4,7 @@ CONFIG_TEGRA210=y CONFIG_TARGET_P2371_0000=y CONFIG_DEFAULT_DEVICE_TREE="tegra210-p2371-0000" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra210 (P2371-0000) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/p2371-2180_defconfig b/configs/p2371-2180_defconfig index 086a294..61742c1 100644 --- a/configs/p2371-2180_defconfig +++ b/configs/p2371-2180_defconfig @@ -4,6 +4,7 @@ CONFIG_TEGRA210=y CONFIG_TARGET_P2371_2180=y CONFIG_DEFAULT_DEVICE_TREE="tegra210-p2371-2180" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra210 (P2371-2180) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/p2571_defconfig b/configs/p2571_defconfig index f7596a5..73a9f4f 100644 --- a/configs/p2571_defconfig +++ b/configs/p2571_defconfig @@ -4,6 +4,7 @@ CONFIG_TEGRA210=y CONFIG_TARGET_P2571=y CONFIG_DEFAULT_DEVICE_TREE="tegra210-p2571" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra210 (P2571) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/paz00_defconfig b/configs/paz00_defconfig index 4d5c758..66eb1ee 100644 --- a/configs/paz00_defconfig +++ b/configs/paz00_defconfig @@ -5,6 +5,7 @@ CONFIG_TEGRA20=y CONFIG_TARGET_PAZ00=y CONFIG_DEFAULT_DEVICE_TREE="tegra20-paz00" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra20 (Paz00) MOD # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/pcm051_rev1_defconfig b/configs/pcm051_rev1_defconfig index b7c5466..ee729b1 100644 --- a/configs/pcm051_rev1_defconfig +++ b/configs/pcm051_rev1_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_PCM051=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="REV1" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/pcm051_rev3_defconfig b/configs/pcm051_rev3_defconfig index cb39392..632e764 100644 --- a/configs/pcm051_rev3_defconfig +++ b/configs/pcm051_rev3_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_PCM051=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="REV3" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/pcm052_defconfig b/configs/pcm052_defconfig index 49159ce..c47dc01 100644 --- a/configs/pcm052_defconfig +++ b/configs/pcm052_defconfig @@ -4,6 +4,7 @@ CONFIG_DM_SERIAL=y CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="pcm052" CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/phytec/pcm052/imximage.cfg,ENV_IS_IN_NAND" +CONFIG_HUSH_PARSER=y CONFIG_CMD_GPIO=y CONFIG_OF_CONTROL=y CONFIG_DM=y diff --git a/configs/pdm360ng_defconfig b/configs/pdm360ng_defconfig index 1b9de3d..c94c499 100644 --- a/configs/pdm360ng_defconfig +++ b/configs/pdm360ng_defconfig @@ -4,5 +4,6 @@ CONFIG_TARGET_PDM360NG=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/peach-pi_defconfig b/configs/peach-pi_defconfig index 23b9762..6132a92 100644 --- a/configs/peach-pi_defconfig +++ b/configs/peach-pi_defconfig @@ -6,6 +6,7 @@ CONFIG_DEFAULT_DEVICE_TREE="exynos5800-peach-pi" CONFIG_SPL=y CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Peach-Pi # " # CONFIG_CMD_IMLS is not set CONFIG_CMD_GPIO=y diff --git a/configs/peach-pit_defconfig b/configs/peach-pit_defconfig index adde56f..0427142 100644 --- a/configs/peach-pit_defconfig +++ b/configs/peach-pit_defconfig @@ -6,6 +6,7 @@ CONFIG_DEFAULT_DEVICE_TREE="exynos5420-peach-pit" CONFIG_SPL=y CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Peach-Pit # " # CONFIG_CMD_IMLS is not set CONFIG_CMD_GPIO=y diff --git a/configs/pengwyn_defconfig b/configs/pengwyn_defconfig index 90ca1d2..d04471b 100644 --- a/configs/pengwyn_defconfig +++ b/configs/pengwyn_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_PENGWYN=y CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/pepper_defconfig b/configs/pepper_defconfig index 7073739..88a672f 100644 --- a/configs/pepper_defconfig +++ b/configs/pepper_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_PEPPER=y CONFIG_SPL=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="pepper# " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/pic32mzdask_defconfig b/configs/pic32mzdask_defconfig index eba6cd5..750fefd 100644 --- a/configs/pic32mzdask_defconfig +++ b/configs/pic32mzdask_defconfig @@ -30,11 +30,11 @@ CONFIG_DM_ETH=y CONFIG_PIC32_ETH=y CONFIG_PINCTRL=y # CONFIG_PINCTRL_FULL is not set -CONFIG_USE_PRIVATE_LIBGCC=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_PIC32=y CONFIG_USB_STORAGE=y +CONFIG_USE_PRIVATE_LIBGCC=y CONFIG_USE_TINY_PRINTF=y CONFIG_CMD_DHRYSTONE=y diff --git a/configs/picosam9g45_defconfig b/configs/picosam9g45_defconfig index 687e69b..34d21de 100644 --- a/configs/picosam9g45_defconfig +++ b/configs/picosam9g45_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_PICOSAM9G45=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9M10G45,SYS_USE_MMC" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMI is not set diff --git a/configs/pine64_plus_defconfig b/configs/pine64_plus_defconfig index 45bf9b3..a778736 100644 --- a/configs/pine64_plus_defconfig +++ b/configs/pine64_plus_defconfig @@ -6,6 +6,7 @@ CONFIG_DRAM_ZQ=3881915 # CONFIG_VIDEO is not set CONFIG_DEFAULT_DEVICE_TREE="pine64_plus" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/platinum_picon_defconfig b/configs/platinum_picon_defconfig index b7e5d7c..e070b79 100644 --- a/configs/platinum_picon_defconfig +++ b/configs/platinum_picon_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_PLATINUM_PICON=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6DL" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="picon > " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/platinum_titanium_defconfig b/configs/platinum_titanium_defconfig index cb38895..2218131 100644 --- a/configs/platinum_titanium_defconfig +++ b/configs/platinum_titanium_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_PLATINUM_TITANIUM=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6Q" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="titanium > " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/plutux_defconfig b/configs/plutux_defconfig index 85fe61d..7af9fd4 100644 --- a/configs/plutux_defconfig +++ b/configs/plutux_defconfig @@ -6,6 +6,7 @@ CONFIG_TARGET_PLUTUX=y CONFIG_DEFAULT_DEVICE_TREE="tegra20-plutux" CONFIG_FIT=y CONFIG_OF_SYSTEM_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra20 (Plutux) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/pm9g45_defconfig b/configs/pm9g45_defconfig index 5a70de1..c43901b 100644 --- a/configs/pm9g45_defconfig +++ b/configs/pm9g45_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_PM9G45=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G45" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/polaroid_mid2809pxe04_defconfig b/configs/polaroid_mid2809pxe04_defconfig index 04c99b9..2c3c7bb 100644 --- a/configs/polaroid_mid2809pxe04_defconfig +++ b/configs/polaroid_mid2809pxe04_defconfig @@ -17,6 +17,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-polaroid-mid2809pxe04" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/portl2_defconfig b/configs/portl2_defconfig index 37c9ddb..07a5507 100644 --- a/configs/portl2_defconfig +++ b/configs/portl2_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_SYS_EXTRA_OPTIONS="KM_PORTL2" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_SPI_FLASH=y diff --git a/configs/pov_protab2_ips9_defconfig b/configs/pov_protab2_ips9_defconfig index 9aa5280..59b6249 100644 --- a/configs/pov_protab2_ips9_defconfig +++ b/configs/pov_protab2_ips9_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-pov-protab2-ips9" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/pxm2_defconfig b/configs/pxm2_defconfig index 7a53016..95ab0a3 100644 --- a/configs/pxm2_defconfig +++ b/configs/pxm2_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_PXM2=y CONFIG_SPL=y CONFIG_FIT=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot# " CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc><Esc>" to stop\n" diff --git a/configs/q8_a13_tablet_defconfig b/configs/q8_a13_tablet_defconfig index b467b62..c9c4adc 100644 --- a/configs/q8_a13_tablet_defconfig +++ b/configs/q8_a13_tablet_defconfig @@ -16,6 +16,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-q8-tablet" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/q8_a23_tablet_800x480_defconfig b/configs/q8_a23_tablet_800x480_defconfig index 7391464..a107c1b 100644 --- a/configs/q8_a23_tablet_800x480_defconfig +++ b/configs/q8_a23_tablet_800x480_defconfig @@ -17,6 +17,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun8i-a23-q8-tablet" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/q8_a33_tablet_1024x600_defconfig b/configs/q8_a33_tablet_1024x600_defconfig index 16f8600..27c2c58 100644 --- a/configs/q8_a33_tablet_1024x600_defconfig +++ b/configs/q8_a33_tablet_1024x600_defconfig @@ -17,6 +17,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-q8-tablet" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/q8_a33_tablet_800x480_defconfig b/configs/q8_a33_tablet_800x480_defconfig index 6378918..93d1086 100644 --- a/configs/q8_a33_tablet_800x480_defconfig +++ b/configs/q8_a33_tablet_800x480_defconfig @@ -17,6 +17,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun8i-a33-q8-tablet" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=5" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/qemu-ppce500_defconfig b/configs/qemu-ppce500_defconfig index 21493aa..0d2d5f7 100644 --- a/configs/qemu-ppce500_defconfig +++ b/configs/qemu-ppce500_defconfig @@ -5,6 +5,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_NETDEVICES=y diff --git a/configs/qemu-x86_defconfig b/configs/qemu-x86_defconfig index bb9c6cd..12a7403 100644 --- a/configs/qemu-x86_defconfig +++ b/configs/qemu-x86_defconfig @@ -8,6 +8,7 @@ CONFIG_GENERATE_ACPI_TABLE=y CONFIG_FIT=y CONFIG_BOOTSTAGE=y CONFIG_BOOTSTAGE_REPORT=y +CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/qemu_mips64_defconfig b/configs/qemu_mips64_defconfig index 2bc92a5..17efc24 100644 --- a/configs/qemu_mips64_defconfig +++ b/configs/qemu_mips64_defconfig @@ -1,6 +1,7 @@ CONFIG_MIPS=y CONFIG_TARGET_QEMU_MIPS=y CONFIG_CPU_MIPS64_R1=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_SETEXPR is not set diff --git a/configs/qemu_mips64el_defconfig b/configs/qemu_mips64el_defconfig index d8a9c71..a8f1912 100644 --- a/configs/qemu_mips64el_defconfig +++ b/configs/qemu_mips64el_defconfig @@ -2,6 +2,7 @@ CONFIG_MIPS=y CONFIG_TARGET_QEMU_MIPS=y CONFIG_SYS_LITTLE_ENDIAN=y CONFIG_CPU_MIPS64_R1=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_SETEXPR is not set diff --git a/configs/qemu_mips_defconfig b/configs/qemu_mips_defconfig index e855906..69ce12d 100644 --- a/configs/qemu_mips_defconfig +++ b/configs/qemu_mips_defconfig @@ -1,5 +1,6 @@ CONFIG_MIPS=y CONFIG_TARGET_QEMU_MIPS=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_SETEXPR is not set diff --git a/configs/qemu_mipsel_defconfig b/configs/qemu_mipsel_defconfig index d851075..c1edee7 100644 --- a/configs/qemu_mipsel_defconfig +++ b/configs/qemu_mipsel_defconfig @@ -1,6 +1,7 @@ CONFIG_MIPS=y CONFIG_TARGET_QEMU_MIPS=y CONFIG_SYS_LITTLE_ENDIAN=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_SETEXPR is not set diff --git a/configs/r2dplus_defconfig b/configs/r2dplus_defconfig index ddb184b..cca0156 100644 --- a/configs/r2dplus_defconfig +++ b/configs/r2dplus_defconfig @@ -1,5 +1,4 @@ CONFIG_SH=y CONFIG_TARGET_R2DPLUS=y # CONFIG_CMD_SETEXPR is not set -CONFIG_RTL8139=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/r7-tv-dongle_defconfig b/configs/r7-tv-dongle_defconfig index 9d9d4bf..343e917 100644 --- a/configs/r7-tv-dongle_defconfig +++ b/configs/r7-tv-dongle_defconfig @@ -6,6 +6,7 @@ CONFIG_USB1_VBUS_PIN="PG13" CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-r7-tv-dongle" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/rainier_defconfig b/configs/rainier_defconfig index abbd67f..095f7c1 100644 --- a/configs/rainier_defconfig +++ b/configs/rainier_defconfig @@ -3,5 +3,6 @@ CONFIG_4xx=y CONFIG_TARGET_SEQUOIA=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="RAINIER" +CONFIG_HUSH_PARSER=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/rainier_ramboot_defconfig b/configs/rainier_ramboot_defconfig index 519e796..56eb3f3 100644 --- a/configs/rainier_ramboot_defconfig +++ b/configs/rainier_ramboot_defconfig @@ -3,5 +3,6 @@ CONFIG_4xx=y CONFIG_TARGET_SEQUOIA=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="RAINIER,SYS_RAMBOOT,SYS_TEXT_BASE=0x01000000,SYS_LDSCRIPT=board/amcc/sequoia/u-boot-ram.lds" +CONFIG_HUSH_PARSER=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/rastaban_defconfig b/configs/rastaban_defconfig index e3bb5ae..c6a1130 100644 --- a/configs/rastaban_defconfig +++ b/configs/rastaban_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_RASTABAN=y CONFIG_SPL=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot# " CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc><Esc>" to stop\n" diff --git a/configs/redwood_defconfig b/configs/redwood_defconfig index ef83153..0b3610f 100644 --- a/configs/redwood_defconfig +++ b/configs/redwood_defconfig @@ -2,5 +2,6 @@ CONFIG_PPC=y CONFIG_4xx=y CONFIG_TARGET_REDWOOD=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/riotboard_defconfig b/configs/riotboard_defconfig index 35b96a3..52fe27f 100644 --- a/configs/riotboard_defconfig +++ b/configs/riotboard_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_EMBESTMX6BOARDS=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s1g.cfg,MX6S,DDR_MB=1024,ENV_IS_IN_MMC" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/rock2_defconfig b/configs/rock2_defconfig index 5f4c093..3abe68f 100644 --- a/configs/rock2_defconfig +++ b/configs/rock2_defconfig @@ -7,6 +7,7 @@ CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3288-rock2-square" CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_PMIC=y diff --git a/configs/rpi_2_defconfig b/configs/rpi_2_defconfig index ff515fd..7cd1e8a 100644 --- a/configs/rpi_2_defconfig +++ b/configs/rpi_2_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_BCM283X=y CONFIG_TARGET_RPI_2=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/rpi_3_32b_defconfig b/configs/rpi_3_32b_defconfig index 71a0c28..1f189d4 100644 --- a/configs/rpi_3_32b_defconfig +++ b/configs/rpi_3_32b_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_BCM283X=y CONFIG_TARGET_RPI_3_32B=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/rpi_3_defconfig b/configs/rpi_3_defconfig index 417836b..d52f0b1 100644 --- a/configs/rpi_3_defconfig +++ b/configs/rpi_3_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_BCM283X=y CONFIG_TARGET_RPI_3=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/rpi_defconfig b/configs/rpi_defconfig index e343c66..59e4e6b 100644 --- a/configs/rpi_defconfig +++ b/configs/rpi_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_BCM283X=y CONFIG_TARGET_RPI=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/rut_defconfig b/configs/rut_defconfig index 035fd1e..d7b47e2 100644 --- a/configs/rut_defconfig +++ b/configs/rut_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_RUT=y CONFIG_SPL=y CONFIG_FIT=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot# " CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc><Esc>" to stop\n" diff --git a/configs/s5p_goni_defconfig b/configs/s5p_goni_defconfig index 8c1438d..2e2cc2a 100644 --- a/configs/s5p_goni_defconfig +++ b/configs/s5p_goni_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_S5PC1XX=y CONFIG_TARGET_S5P_GONI=y CONFIG_DEFAULT_DEVICE_TREE="s5pc1xx-goni" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Goni # " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set diff --git a/configs/s5pc210_universal_defconfig b/configs/s5pc210_universal_defconfig index d91b433..bd2675f 100644 --- a/configs/s5pc210_universal_defconfig +++ b/configs/s5pc210_universal_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_EXYNOS=y CONFIG_TARGET_S5PC210_UNIVERSAL=y CONFIG_DEFAULT_DEVICE_TREE="exynos4210-universal_c210" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Universal # " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set diff --git a/configs/sama5d2_xplained_mmc_defconfig b/configs/sama5d2_xplained_mmc_defconfig index b77c2b5..9abc136 100644 --- a/configs/sama5d2_xplained_mmc_defconfig +++ b/configs/sama5d2_xplained_mmc_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_SAMA5D2_XPLAINED=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D2,SYS_USE_MMC" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set diff --git a/configs/sama5d2_xplained_spiflash_defconfig b/configs/sama5d2_xplained_spiflash_defconfig index 5b942b5..f1aff9e 100644 --- a/configs/sama5d2_xplained_spiflash_defconfig +++ b/configs/sama5d2_xplained_spiflash_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_SAMA5D2_XPLAINED=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D2,SYS_USE_SERIALFLASH" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set diff --git a/configs/sama5d3_xplained_mmc_defconfig b/configs/sama5d3_xplained_mmc_defconfig index 1133892..a3377a6 100644 --- a/configs/sama5d3_xplained_mmc_defconfig +++ b/configs/sama5d3_xplained_mmc_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_SAMA5D3_XPLAINED=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D3,SYS_USE_MMC" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set diff --git a/configs/sama5d3_xplained_nandflash_defconfig b/configs/sama5d3_xplained_nandflash_defconfig index e4f577b..dd32e4b 100644 --- a/configs/sama5d3_xplained_nandflash_defconfig +++ b/configs/sama5d3_xplained_nandflash_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_SAMA5D3_XPLAINED=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D3,SYS_USE_NANDFLASH" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set diff --git a/configs/sama5d3xek_mmc_defconfig b/configs/sama5d3xek_mmc_defconfig index 969fb4b..1c936c0 100644 --- a/configs/sama5d3xek_mmc_defconfig +++ b/configs/sama5d3xek_mmc_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_SAMA5D3XEK=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D3,SYS_USE_MMC" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/sama5d3xek_nandflash_defconfig b/configs/sama5d3xek_nandflash_defconfig index 6e242e0..5f8e4b9 100644 --- a/configs/sama5d3xek_nandflash_defconfig +++ b/configs/sama5d3xek_nandflash_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_SAMA5D3XEK=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D3,SYS_USE_NANDFLASH" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/sama5d3xek_spiflash_defconfig b/configs/sama5d3xek_spiflash_defconfig index 2cceb57..d0a0f05 100644 --- a/configs/sama5d3xek_spiflash_defconfig +++ b/configs/sama5d3xek_spiflash_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_SAMA5D3XEK=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D3,SYS_USE_SERIALFLASH" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/sama5d4_xplained_mmc_defconfig b/configs/sama5d4_xplained_mmc_defconfig index e26bb59..73f6a07 100644 --- a/configs/sama5d4_xplained_mmc_defconfig +++ b/configs/sama5d4_xplained_mmc_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_SAMA5D4_XPLAINED=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D4,SYS_USE_MMC" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set diff --git a/configs/sama5d4_xplained_nandflash_defconfig b/configs/sama5d4_xplained_nandflash_defconfig index b2067b9..2e74804 100644 --- a/configs/sama5d4_xplained_nandflash_defconfig +++ b/configs/sama5d4_xplained_nandflash_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_SAMA5D4_XPLAINED=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D4,SYS_USE_NANDFLASH" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set diff --git a/configs/sama5d4_xplained_spiflash_defconfig b/configs/sama5d4_xplained_spiflash_defconfig index 53ff55b..72a3e56 100644 --- a/configs/sama5d4_xplained_spiflash_defconfig +++ b/configs/sama5d4_xplained_spiflash_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_SAMA5D4_XPLAINED=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D4,SYS_USE_SERIALFLASH" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set diff --git a/configs/sama5d4ek_mmc_defconfig b/configs/sama5d4ek_mmc_defconfig index 2b6f4ac..87fa5a3 100644 --- a/configs/sama5d4ek_mmc_defconfig +++ b/configs/sama5d4ek_mmc_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_SAMA5D4EK=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D4,SYS_USE_MMC" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set diff --git a/configs/sama5d4ek_nandflash_defconfig b/configs/sama5d4ek_nandflash_defconfig index 190a8e9..749e489 100644 --- a/configs/sama5d4ek_nandflash_defconfig +++ b/configs/sama5d4ek_nandflash_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_SAMA5D4EK=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D4,SYS_USE_NANDFLASH" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set diff --git a/configs/sama5d4ek_spiflash_defconfig b/configs/sama5d4ek_spiflash_defconfig index 9b5faa0..c3f5931 100644 --- a/configs/sama5d4ek_spiflash_defconfig +++ b/configs/sama5d4ek_spiflash_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_SAMA5D4EK=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D4,SYS_USE_SERIALFLASH" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index f5281b3..7536c46 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -15,6 +15,7 @@ CONFIG_BOOTSTAGE_STASH_ADDR=0x0 CONFIG_BOOTSTAGE_STASH_SIZE=0x4096 CONFIG_CONSOLE_RECORD=y CONFIG_CONSOLE_RECORD_OUT_SIZE=0x1000 +CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y CONFIG_CMD_LICENSE=y # CONFIG_CMD_ELF is not set diff --git a/configs/sansa_fuze_plus_defconfig b/configs/sansa_fuze_plus_defconfig index 78df0ac..703db9c 100644 --- a/configs/sansa_fuze_plus_defconfig +++ b/configs/sansa_fuze_plus_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_SANSA_FUZE_PLUS=y CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/sbc8349_PCI_33_defconfig b/configs/sbc8349_PCI_33_defconfig index 3e23852..1189558 100644 --- a/configs/sbc8349_PCI_33_defconfig +++ b/configs/sbc8349_PCI_33_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_SBC8349=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PCI,PCI_33M" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sbc8349_PCI_66_defconfig b/configs/sbc8349_PCI_66_defconfig index 255d598..fe2300e 100644 --- a/configs/sbc8349_PCI_66_defconfig +++ b/configs/sbc8349_PCI_66_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_SBC8349=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PCI,PCI_66M" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sbc8349_defconfig b/configs/sbc8349_defconfig index f97d5ca..71ce297 100644 --- a/configs/sbc8349_defconfig +++ b/configs/sbc8349_defconfig @@ -3,6 +3,7 @@ CONFIG_MPC83xx=y CONFIG_TARGET_SBC8349=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sbc8548_PCI_33_PCIE_defconfig b/configs/sbc8548_PCI_33_PCIE_defconfig index b6f3968..41503f3 100644 --- a/configs/sbc8548_PCI_33_PCIE_defconfig +++ b/configs/sbc8548_PCI_33_PCIE_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_SBC8548=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PCI,33,PCIE" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sbc8548_PCI_33_defconfig b/configs/sbc8548_PCI_33_defconfig index 63f4943..de0e1f3 100644 --- a/configs/sbc8548_PCI_33_defconfig +++ b/configs/sbc8548_PCI_33_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_SBC8548=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PCI,33" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sbc8548_PCI_66_PCIE_defconfig b/configs/sbc8548_PCI_66_PCIE_defconfig index 367711b..1aebb1a 100644 --- a/configs/sbc8548_PCI_66_PCIE_defconfig +++ b/configs/sbc8548_PCI_66_PCIE_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_SBC8548=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PCI,66,PCIE" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sbc8548_PCI_66_defconfig b/configs/sbc8548_PCI_66_defconfig index a682da2..205f90b 100644 --- a/configs/sbc8548_PCI_66_defconfig +++ b/configs/sbc8548_PCI_66_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_SBC8548=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PCI,66" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sbc8548_defconfig b/configs/sbc8548_defconfig index dede802..5a1e593 100644 --- a/configs/sbc8548_defconfig +++ b/configs/sbc8548_defconfig @@ -3,6 +3,7 @@ CONFIG_MPC85xx=y CONFIG_TARGET_SBC8548=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sbc8641d_defconfig b/configs/sbc8641d_defconfig index b61913e..8e5237a 100644 --- a/configs/sbc8641d_defconfig +++ b/configs/sbc8641d_defconfig @@ -3,6 +3,7 @@ CONFIG_MPC86xx=y CONFIG_TARGET_SBC8641D=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sc_sps_1_defconfig b/configs/sc_sps_1_defconfig index 06f2322..1bcd479 100644 --- a/configs/sc_sps_1_defconfig +++ b/configs/sc_sps_1_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_SC_SPS_1=y CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/seaboard_defconfig b/configs/seaboard_defconfig index 00cd081..3613286 100644 --- a/configs/seaboard_defconfig +++ b/configs/seaboard_defconfig @@ -5,6 +5,7 @@ CONFIG_TEGRA20=y CONFIG_TARGET_SEABOARD=y CONFIG_DEFAULT_DEVICE_TREE="tegra20-seaboard" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra20 (SeaBoard) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/secomx6quq7_defconfig b/configs/secomx6quq7_defconfig index 0980e68..d19876a 100644 --- a/configs/secomx6quq7_defconfig +++ b/configs/secomx6quq7_defconfig @@ -5,6 +5,7 @@ CONFIG_SECOMX6_UQ7=y CONFIG_SECOMX6Q=y CONFIG_SECOMX6_2GB=y CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_MMC" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="SECO MX6Q uQ7 U-Boot > " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/sequoia_defconfig b/configs/sequoia_defconfig index 6f6007c..1becb75 100644 --- a/configs/sequoia_defconfig +++ b/configs/sequoia_defconfig @@ -3,5 +3,6 @@ CONFIG_4xx=y CONFIG_TARGET_SEQUOIA=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SEQUOIA" +CONFIG_HUSH_PARSER=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sequoia_ramboot_defconfig b/configs/sequoia_ramboot_defconfig index f805238..6b9425c 100644 --- a/configs/sequoia_ramboot_defconfig +++ b/configs/sequoia_ramboot_defconfig @@ -3,5 +3,6 @@ CONFIG_4xx=y CONFIG_TARGET_SEQUOIA=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SEQUOIA,SYS_RAMBOOT,SYS_TEXT_BASE=0x01000000,SYS_LDSCRIPT=board/amcc/sequoia/u-boot-ram.lds" +CONFIG_HUSH_PARSER=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/smartweb_defconfig b/configs/smartweb_defconfig index ce514c2..d6ac40b 100644 --- a/configs/smartweb_defconfig +++ b/configs/smartweb_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_SMARTWEB=y CONFIG_SPL=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9260" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot# " CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc><Esc>" to stop\n" diff --git a/configs/smdk2410_defconfig b/configs/smdk2410_defconfig index bb80d55..66c2034 100644 --- a/configs/smdk2410_defconfig +++ b/configs/smdk2410_defconfig @@ -1,4 +1,5 @@ CONFIG_ARM=y CONFIG_TARGET_SMDK2410=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="SMDK2410 # " # CONFIG_CMD_SETEXPR is not set diff --git a/configs/smdk5250_defconfig b/configs/smdk5250_defconfig index b3d16ab..7a757ee 100644 --- a/configs/smdk5250_defconfig +++ b/configs/smdk5250_defconfig @@ -6,6 +6,7 @@ CONFIG_DEFAULT_DEVICE_TREE="exynos5250-smdk5250" CONFIG_SPL=y CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="SMDK5250 # " # CONFIG_CMD_IMLS is not set CONFIG_CMD_GPIO=y diff --git a/configs/smdk5420_defconfig b/configs/smdk5420_defconfig index a84d159..de79ca9 100644 --- a/configs/smdk5420_defconfig +++ b/configs/smdk5420_defconfig @@ -6,6 +6,7 @@ CONFIG_DEFAULT_DEVICE_TREE="exynos5420-smdk5420" CONFIG_SPL=y CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="SMDK5420 # " # CONFIG_CMD_IMLS is not set CONFIG_CMD_GPIO=y diff --git a/configs/smdkc100_defconfig b/configs/smdkc100_defconfig index cbd8cc3..01a3eb0 100644 --- a/configs/smdkc100_defconfig +++ b/configs/smdkc100_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_S5PC1XX=y CONFIG_TARGET_SMDKC100=y CONFIG_DEFAULT_DEVICE_TREE="s5pc1xx-smdkc100" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="SMDKC100 # " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/smdkv310_defconfig b/configs/smdkv310_defconfig index 851fc5c..5334f89 100644 --- a/configs/smdkv310_defconfig +++ b/configs/smdkv310_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_EXYNOS=y CONFIG_TARGET_SMDKV310=y CONFIG_DEFAULT_DEVICE_TREE="exynos4210-smdkv310" CONFIG_SPL=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="SMDKV310 # " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set diff --git a/configs/snapper9260_defconfig b/configs/snapper9260_defconfig index 9315b03..33386b4 100644 --- a/configs/snapper9260_defconfig +++ b/configs/snapper9260_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_SNAPPER9260=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9260" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Snapper> " # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMI is not set diff --git a/configs/snapper9g20_defconfig b/configs/snapper9g20_defconfig index 9c24d79..ec88dfb 100644 --- a/configs/snapper9g20_defconfig +++ b/configs/snapper9g20_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_SNAPPER9260=y CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/sniper_defconfig b/configs/sniper_defconfig index 6a31771..86bae46 100644 --- a/configs/sniper_defconfig +++ b/configs/sniper_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_OMAP34XX=y CONFIG_TARGET_SNIPER=y CONFIG_SPL=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="sniper # " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/snow_defconfig b/configs/snow_defconfig index 5dbd18a..0b740e9 100644 --- a/configs/snow_defconfig +++ b/configs/snow_defconfig @@ -6,6 +6,7 @@ CONFIG_DEFAULT_DEVICE_TREE="exynos5250-snow" CONFIG_SPL=y CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="snow # " # CONFIG_CMD_IMLS is not set CONFIG_CMD_GPIO=y diff --git a/configs/socfpga_arria5_defconfig b/configs/socfpga_arria5_defconfig index 9c8671c..d451fea 100644 --- a/configs/socfpga_arria5_defconfig +++ b/configs/socfpga_arria5_defconfig @@ -9,6 +9,7 @@ CONFIG_DEFAULT_DEVICE_TREE="socfpga_arria5_socdk" CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y @@ -16,10 +17,10 @@ CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DWAPB_GPIO=y CONFIG_DM_MMC=y CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set -CONFIG_SPI_FLASH_BAR=y CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_SYS_NS16550=y diff --git a/configs/socfpga_cyclone5_defconfig b/configs/socfpga_cyclone5_defconfig index b68b298..db443c9 100644 --- a/configs/socfpga_cyclone5_defconfig +++ b/configs/socfpga_cyclone5_defconfig @@ -9,6 +9,7 @@ CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_socdk" CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y @@ -16,10 +17,10 @@ CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DWAPB_GPIO=y CONFIG_DM_MMC=y CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set -CONFIG_SPI_FLASH_BAR=y CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_SYS_NS16550=y diff --git a/configs/socfpga_de0_nano_soc_defconfig b/configs/socfpga_de0_nano_soc_defconfig index d813dc9..e5ef64b 100644 --- a/configs/socfpga_de0_nano_soc_defconfig +++ b/configs/socfpga_de0_nano_soc_defconfig @@ -9,6 +9,7 @@ CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_de0_nano_soc" CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y @@ -19,7 +20,6 @@ CONFIG_ETH_DESIGNWARE=y CONFIG_SYS_NS16550=y CONFIG_CADENCE_QSPI=y CONFIG_DESIGNWARE_SPI=y -CONFIG_SPI_FLASH_BAR=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_GADGET=y diff --git a/configs/socfpga_mcvevk_defconfig b/configs/socfpga_mcvevk_defconfig index 5fe6238..c7f4ff4 100644 --- a/configs/socfpga_mcvevk_defconfig +++ b/configs/socfpga_mcvevk_defconfig @@ -9,6 +9,7 @@ CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_mcvevk" CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y @@ -19,7 +20,6 @@ CONFIG_ETH_DESIGNWARE=y CONFIG_SYS_NS16550=y CONFIG_CADENCE_QSPI=y CONFIG_DESIGNWARE_SPI=y -CONFIG_SPI_FLASH_BAR=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_GADGET=y diff --git a/configs/socfpga_sockit_defconfig b/configs/socfpga_sockit_defconfig index 8894e09..d932993 100644 --- a/configs/socfpga_sockit_defconfig +++ b/configs/socfpga_sockit_defconfig @@ -9,6 +9,7 @@ CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_sockit" CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y @@ -16,10 +17,10 @@ CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DWAPB_GPIO=y CONFIG_DM_MMC=y CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set -CONFIG_SPI_FLASH_BAR=y CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_SYS_NS16550=y diff --git a/configs/socfpga_socrates_defconfig b/configs/socfpga_socrates_defconfig index 562052c..7764879 100644 --- a/configs/socfpga_socrates_defconfig +++ b/configs/socfpga_socrates_defconfig @@ -9,6 +9,7 @@ CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_socrates" CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y @@ -16,6 +17,7 @@ CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DWAPB_GPIO=y CONFIG_DM_MMC=y CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_DM_ETH=y @@ -23,7 +25,6 @@ CONFIG_ETH_DESIGNWARE=y CONFIG_SYS_NS16550=y CONFIG_CADENCE_QSPI=y CONFIG_DESIGNWARE_SPI=y -CONFIG_SPI_FLASH_BAR=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_GADGET=y diff --git a/configs/socfpga_sr1500_defconfig b/configs/socfpga_sr1500_defconfig index 83eada3..5f19eee 100644 --- a/configs/socfpga_sr1500_defconfig +++ b/configs/socfpga_sr1500_defconfig @@ -9,15 +9,16 @@ CONFIG_DEFAULT_DEVICE_TREE="socfpga_cyclone5_sr1500" CONFIG_SPL=y CONFIG_SPL_STACK_R=y CONFIG_FIT=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DWAPB_GPIO=y CONFIG_DM_MMC=y CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_STMICRO=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set -CONFIG_SPI_FLASH_BAR=y CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_SYS_NS16550=y diff --git a/configs/socrates_defconfig b/configs/socrates_defconfig index 3b73dbd..4d86ad1 100644 --- a/configs/socrates_defconfig +++ b/configs/socrates_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_SOCRATES=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set CONFIG_SYS_NS16550=y diff --git a/configs/spring_defconfig b/configs/spring_defconfig index 352bd1a..935257e 100644 --- a/configs/spring_defconfig +++ b/configs/spring_defconfig @@ -6,6 +6,7 @@ CONFIG_DEFAULT_DEVICE_TREE="exynos5250-spring" CONFIG_SPL=y CONFIG_FIT=y CONFIG_FIT_BEST_MATCH=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="spring # " # CONFIG_CMD_IMLS is not set CONFIG_CMD_GPIO=y diff --git a/configs/stm32f429-discovery_defconfig b/configs/stm32f429-discovery_defconfig index 00d105b..a407d52 100644 --- a/configs/stm32f429-discovery_defconfig +++ b/configs/stm32f429-discovery_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_STM32=y CONFIG_STM32F4=y CONFIG_TARGET_STM32F429_DISCOVERY=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot > " # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/stm32f746-disco_defconfig b/configs/stm32f746-disco_defconfig index 07aa874..abbb1e9 100644 --- a/configs/stm32f746-disco_defconfig +++ b/configs/stm32f746-disco_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_STM32=y CONFIG_STM32F7=y CONFIG_TARGET_STM32F746_DISCO=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot > " CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit SPACE in %d seconds to stop autoboot.\n" diff --git a/configs/strider_con_defconfig b/configs/strider_con_defconfig index 704ad89..8934992 100644 --- a/configs/strider_con_defconfig +++ b/configs/strider_con_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="STRIDER_CON" +CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_SETEXPR is not set diff --git a/configs/strider_cpu_defconfig b/configs/strider_cpu_defconfig index 81b706f..05a2e13 100644 --- a/configs/strider_cpu_defconfig +++ b/configs/strider_cpu_defconfig @@ -6,6 +6,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="STRIDER_CPU" +CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_SETEXPR is not set diff --git a/configs/sunxi_Gemei_G9_defconfig b/configs/sunxi_Gemei_G9_defconfig index 6d39dec..28b1633 100644 --- a/configs/sunxi_Gemei_G9_defconfig +++ b/configs/sunxi_Gemei_G9_defconfig @@ -11,6 +11,7 @@ CONFIG_VIDEO_LCD_PANEL_LVDS=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-gemei-g9" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set diff --git a/configs/suvd3_defconfig b/configs/suvd3_defconfig index 79a0ca6..c3e5390 100644 --- a/configs/suvd3_defconfig +++ b/configs/suvd3_defconfig @@ -4,5 +4,6 @@ CONFIG_TARGET_SUVD3=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SUVD3" +CONFIG_HUSH_PARSER=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sycamore_defconfig b/configs/sycamore_defconfig index fa495ba..788d5c1 100644 --- a/configs/sycamore_defconfig +++ b/configs/sycamore_defconfig @@ -2,5 +2,6 @@ CONFIG_PPC=y CONFIG_4xx=y CONFIG_TARGET_WALNUT=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/t3corp_defconfig b/configs/t3corp_defconfig index e9fe84d..21d2e76 100644 --- a/configs/t3corp_defconfig +++ b/configs/t3corp_defconfig @@ -3,5 +3,6 @@ CONFIG_4xx=y CONFIG_TARGET_T3CORP=y CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/tao3530_defconfig b/configs/tao3530_defconfig index c1eb34c..05021d2 100644 --- a/configs/tao3530_defconfig +++ b/configs/tao3530_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_OMAP34XX=y CONFIG_TARGET_TAO3530=y CONFIG_SPL=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="TAO-3530 # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/tbs2910_defconfig b/configs/tbs2910_defconfig index 9f6aa8d..be37090 100644 --- a/configs/tbs2910_defconfig +++ b/configs/tbs2910_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_TBS2910=y CONFIG_FIT=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Matrix U-Boot> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/tec-ng_defconfig b/configs/tec-ng_defconfig index 389603c..d4019f4 100644 --- a/configs/tec-ng_defconfig +++ b/configs/tec-ng_defconfig @@ -6,6 +6,7 @@ CONFIG_TARGET_TEC_NG=y CONFIG_DEFAULT_DEVICE_TREE="tegra30-tec-ng" CONFIG_FIT=y CONFIG_OF_SYSTEM_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra30 (TEC-NG) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/tec_defconfig b/configs/tec_defconfig index 56970c4..95d1838 100644 --- a/configs/tec_defconfig +++ b/configs/tec_defconfig @@ -6,6 +6,7 @@ CONFIG_TARGET_TEC=y CONFIG_DEFAULT_DEVICE_TREE="tegra20-tec" CONFIG_FIT=y CONFIG_OF_SYSTEM_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra20 (TEC) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/theadorable_debug_defconfig b/configs/theadorable_debug_defconfig index 054038a..800abca 100644 --- a/configs/theadorable_debug_defconfig +++ b/configs/theadorable_debug_defconfig @@ -7,6 +7,7 @@ CONFIG_DEFAULT_DEVICE_TREE="armada-xp-theadorable" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_FIT=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_SF=y diff --git a/configs/theadorable_defconfig b/configs/theadorable_defconfig index 9a6abf2..11624d6 100644 --- a/configs/theadorable_defconfig +++ b/configs/theadorable_defconfig @@ -7,6 +7,7 @@ CONFIG_DEFAULT_DEVICE_TREE="armada-xp-theadorable" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL=y CONFIG_FIT=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_SF=y diff --git a/configs/thuban_defconfig b/configs/thuban_defconfig index 047dc69..c051460 100644 --- a/configs/thuban_defconfig +++ b/configs/thuban_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_THUBAN=y CONFIG_SPL=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot# " CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc><Esc>" to stop\n" diff --git a/configs/ti814x_evm_defconfig b/configs/ti814x_evm_defconfig index 52d3a65..5d2a79a 100644 --- a/configs/ti814x_evm_defconfig +++ b/configs/ti814x_evm_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_TI814X_EVM=y CONFIG_SPL=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot# " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/ti816x_evm_defconfig b/configs/ti816x_evm_defconfig index 13a2c6e..03365fc 100644 --- a/configs/ti816x_evm_defconfig +++ b/configs/ti816x_evm_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_TI816X_EVM=y CONFIG_SPL=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="u-boot/ti816x# " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/titanium_defconfig b/configs/titanium_defconfig index 6c93616..de3c26d 100644 --- a/configs/titanium_defconfig +++ b/configs/titanium_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_TITANIUM=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/barco/titanium/imximage.cfg" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Titanium > " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/tqma6q_mba6_mmc_defconfig b/configs/tqma6q_mba6_mmc_defconfig index 6c52fff..24e64b6 100644 --- a/configs/tqma6q_mba6_mmc_defconfig +++ b/configs/tqma6q_mba6_mmc_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_TQMA6=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/tqma6q_mba6_spi_defconfig b/configs/tqma6q_mba6_spi_defconfig index 85b239b..be870ba 100644 --- a/configs/tqma6q_mba6_spi_defconfig +++ b/configs/tqma6q_mba6_spi_defconfig @@ -5,6 +5,7 @@ CONFIG_TQMA6X_SPI_BOOT=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/tqma6s_mba6_mmc_defconfig b/configs/tqma6s_mba6_mmc_defconfig index 977f98a..157d762 100644 --- a/configs/tqma6s_mba6_mmc_defconfig +++ b/configs/tqma6s_mba6_mmc_defconfig @@ -5,6 +5,7 @@ CONFIG_TQMA6S=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/tqma6s_mba6_spi_defconfig b/configs/tqma6s_mba6_spi_defconfig index c6dac61..928c480 100644 --- a/configs/tqma6s_mba6_spi_defconfig +++ b/configs/tqma6s_mba6_spi_defconfig @@ -6,6 +6,7 @@ CONFIG_TQMA6X_SPI_BOOT=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/tqma6s_wru4_mmc_defconfig b/configs/tqma6s_wru4_mmc_defconfig index a7068e5..a051a9f 100644 --- a/configs/tqma6s_wru4_mmc_defconfig +++ b/configs/tqma6s_wru4_mmc_defconfig @@ -6,6 +6,7 @@ CONFIG_WRU4=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Enter password in %d seconds to stop autoboot\n" CONFIG_AUTOBOOT_ENCRYPTION=y diff --git a/configs/trats2_defconfig b/configs/trats2_defconfig index 14bdc6a..73fc63c 100644 --- a/configs/trats2_defconfig +++ b/configs/trats2_defconfig @@ -5,6 +5,7 @@ CONFIG_DEFAULT_DEVICE_TREE="exynos4412-trats2" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Trats2 # " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set diff --git a/configs/trats_defconfig b/configs/trats_defconfig index c3b82bb..8fbb5f2 100644 --- a/configs/trats_defconfig +++ b/configs/trats_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_TRATS=y CONFIG_DEFAULT_DEVICE_TREE="exynos4210-trats" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Trats # " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set diff --git a/configs/tricorder_defconfig b/configs/tricorder_defconfig index bdd9c89..ff2c785 100644 --- a/configs/tricorder_defconfig +++ b/configs/tricorder_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_OMAP34XX=y CONFIG_TARGET_TRICORDER=y CONFIG_SPL=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="OMAP3 Tricorder # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/tricorder_flash_defconfig b/configs/tricorder_flash_defconfig index 3bac8e3..4ed1ada 100644 --- a/configs/tricorder_flash_defconfig +++ b/configs/tricorder_flash_defconfig @@ -3,6 +3,7 @@ CONFIG_OMAP34XX=y CONFIG_TARGET_TRICORDER=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="FLASHCARD" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/trimslice_defconfig b/configs/trimslice_defconfig index 2d8579b..98678d5 100644 --- a/configs/trimslice_defconfig +++ b/configs/trimslice_defconfig @@ -5,6 +5,7 @@ CONFIG_TEGRA20=y CONFIG_TARGET_TRIMSLICE=y CONFIG_DEFAULT_DEVICE_TREE="tegra20-trimslice" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra20 (TrimSlice) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/ts4800_defconfig b/configs/ts4800_defconfig index 1b30033..ac81a46 100644 --- a/configs/ts4800_defconfig +++ b/configs/ts4800_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_TS4800=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/tuge1_defconfig b/configs/tuge1_defconfig index b144575..904bc89 100644 --- a/configs/tuge1_defconfig +++ b/configs/tuge1_defconfig @@ -4,5 +4,6 @@ CONFIG_TARGET_TUXX1=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="TUGE1" +CONFIG_HUSH_PARSER=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/tuxx1_defconfig b/configs/tuxx1_defconfig index 7563336..7bbe36d 100644 --- a/configs/tuxx1_defconfig +++ b/configs/tuxx1_defconfig @@ -4,5 +4,6 @@ CONFIG_TARGET_TUXX1=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="TUXX1" +CONFIG_HUSH_PARSER=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/twister_defconfig b/configs/twister_defconfig index 064cf91..f6b30c2 100644 --- a/configs/twister_defconfig +++ b/configs/twister_defconfig @@ -3,13 +3,14 @@ CONFIG_OMAP34XX=y CONFIG_TARGET_TWISTER=y CONFIG_SPL=y CONFIG_FIT=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="twister => " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y -CONFIG_OF_LIBFDT=y CONFIG_USB=y -CONFIG_USB_ULPI=y CONFIG_USB_ULPI_VIEWPORT_OMAP=y +CONFIG_USB_ULPI=y +CONFIG_OF_LIBFDT=y diff --git a/configs/udoo_defconfig b/configs/udoo_defconfig index 3f53749..5e2cb85 100644 --- a/configs/udoo_defconfig +++ b/configs/udoo_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_UDOO=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6QDL" +CONFIG_HUSH_PARSER=y CONFIG_CMD_GPIO=y CONFIG_DM=y CONFIG_DM_THERMAL=y diff --git a/configs/usb_a9263_dataflash_defconfig b/configs/usb_a9263_dataflash_defconfig index e90dd66..fe14f9a 100644 --- a/configs/usb_a9263_dataflash_defconfig +++ b/configs/usb_a9263_dataflash_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_USB_A9263=y CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9263,SYS_USE_DATAFLASH" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set # CONFIG_CMD_IMI is not set diff --git a/configs/usbarmory_defconfig b/configs/usbarmory_defconfig index 68f78b3..b4a3c00 100644 --- a/configs/usbarmory_defconfig +++ b/configs/usbarmory_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX5=y CONFIG_TARGET_USBARMORY=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/ve8313_defconfig b/configs/ve8313_defconfig index 8624695..b2ae829 100644 --- a/configs/ve8313_defconfig +++ b/configs/ve8313_defconfig @@ -3,6 +3,7 @@ CONFIG_MPC83xx=y CONFIG_TARGET_VE8313=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/venice2_defconfig b/configs/venice2_defconfig index 75e7579..4ebce04 100644 --- a/configs/venice2_defconfig +++ b/configs/venice2_defconfig @@ -5,6 +5,7 @@ CONFIG_TEGRA124=y CONFIG_TARGET_VENICE2=y CONFIG_DEFAULT_DEVICE_TREE="tegra124-venice2" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra124 (Venice2) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/ventana_defconfig b/configs/ventana_defconfig index 0cce4d4..5dc16b3 100644 --- a/configs/ventana_defconfig +++ b/configs/ventana_defconfig @@ -5,6 +5,7 @@ CONFIG_TEGRA20=y CONFIG_TARGET_VENTANA=y CONFIG_DEFAULT_DEVICE_TREE="tegra20-ventana" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra20 (Ventana) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/vexpress_aemv8a_dram_defconfig b/configs/vexpress_aemv8a_dram_defconfig index 440dccf..1497605 100644 --- a/configs/vexpress_aemv8a_dram_defconfig +++ b/configs/vexpress_aemv8a_dram_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_VEXPRESS64_BASE_FVP_DRAM=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_DM_SERIAL=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="VExpress64# " # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/vexpress_aemv8a_juno_defconfig b/configs/vexpress_aemv8a_juno_defconfig index c702800..b9bfc26 100644 --- a/configs/vexpress_aemv8a_juno_defconfig +++ b/configs/vexpress_aemv8a_juno_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_VEXPRESS64_JUNO=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_DM_SERIAL=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="VExpress64# " # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/vexpress_aemv8a_semi_defconfig b/configs/vexpress_aemv8a_semi_defconfig index d7f7294..8818527 100644 --- a/configs/vexpress_aemv8a_semi_defconfig +++ b/configs/vexpress_aemv8a_semi_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_VEXPRESS64_BASE_FVP=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_DM_SERIAL=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="VExpress64# " # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/vexpress_ca15_tc2_defconfig b/configs/vexpress_ca15_tc2_defconfig index 0016030..0508796 100644 --- a/configs/vexpress_ca15_tc2_defconfig +++ b/configs/vexpress_ca15_tc2_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_VEXPRESS_CA15_TC2=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_BOOTD is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/vexpress_ca5x2_defconfig b/configs/vexpress_ca5x2_defconfig index b260401..9e53655 100644 --- a/configs/vexpress_ca5x2_defconfig +++ b/configs/vexpress_ca5x2_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_VEXPRESS_CA5X2=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_BOOTD is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/vexpress_ca9x4_defconfig b/configs/vexpress_ca9x4_defconfig index 4a64339..524ef4b 100644 --- a/configs/vexpress_ca9x4_defconfig +++ b/configs/vexpress_ca9x4_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_VEXPRESS_CA9X4=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_CONSOLE is not set # CONFIG_CMD_BOOTD is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/vf610twr_defconfig b/configs/vf610twr_defconfig index d959293..80ec20f 100644 --- a/configs/vf610twr_defconfig +++ b/configs/vf610twr_defconfig @@ -4,6 +4,7 @@ CONFIG_DM_SERIAL=y CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="vf610-twr" CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/vf610twr/imximage.cfg,ENV_IS_IN_MMC" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/vf610twr_nand_defconfig b/configs/vf610twr_nand_defconfig index b6a96f2..afe8a47 100644 --- a/configs/vf610twr_nand_defconfig +++ b/configs/vf610twr_nand_defconfig @@ -4,6 +4,7 @@ CONFIG_DM_SERIAL=y CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="vf610-twr" CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/vf610twr/imximage.cfg,ENV_IS_IN_NAND" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/vinco_defconfig b/configs/vinco_defconfig index 565577d..29da314 100644 --- a/configs/vinco_defconfig +++ b/configs/vinco_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_VINCO=y CONFIG_SYS_EXTRA_OPTIONS="SAMA5D4,SYS_USE_SERIALFLASH" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="vinco => " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/vme8349_defconfig b/configs/vme8349_defconfig index e21d4ff..5f0971a 100644 --- a/configs/vme8349_defconfig +++ b/configs/vme8349_defconfig @@ -3,6 +3,7 @@ CONFIG_MPC83xx=y CONFIG_TARGET_VME8349=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/walnut_defconfig b/configs/walnut_defconfig index fa495ba..788d5c1 100644 --- a/configs/walnut_defconfig +++ b/configs/walnut_defconfig @@ -2,5 +2,6 @@ CONFIG_PPC=y CONFIG_4xx=y CONFIG_TARGET_WALNUT=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/wandboard_defconfig b/configs/wandboard_defconfig index f6bd308..773b493 100644 --- a/configs/wandboard_defconfig +++ b/configs/wandboard_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_WANDBOARD=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6QDL" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/warp7_defconfig b/configs/warp7_defconfig index f37c9f5..77ccecf 100644 --- a/configs/warp7_defconfig +++ b/configs/warp7_defconfig @@ -4,6 +4,7 @@ CONFIG_TARGET_WARP7=y CONFIG_IMX_RDC=y CONFIG_IMX_BOOTAUX=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/warp7/imximage.cfg" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_BOOTD is not set # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/warp_defconfig b/configs/warp_defconfig index b9e4648..c7c1d25 100644 --- a/configs/warp_defconfig +++ b/configs/warp_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_WARP=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6slevk/imximage.cfg,MX6SL" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/whistler_defconfig b/configs/whistler_defconfig index a818a0f..d443ae3 100644 --- a/configs/whistler_defconfig +++ b/configs/whistler_defconfig @@ -5,6 +5,7 @@ CONFIG_TEGRA20=y CONFIG_TARGET_WHISTLER=y CONFIG_DEFAULT_DEVICE_TREE="tegra20-whistler" CONFIG_OF_SYSTEM_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Tegra20 (Whistler) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set diff --git a/configs/woodburn_defconfig b/configs/woodburn_defconfig index 6c60f5e..f335294 100644 --- a/configs/woodburn_defconfig +++ b/configs/woodburn_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_WOODBURN=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="woodburn U-Boot > " CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/woodburn_sd_defconfig b/configs/woodburn_sd_defconfig index 2d2ee9e..f73206e 100644 --- a/configs/woodburn_sd_defconfig +++ b/configs/woodburn_sd_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_WOODBURN_SD=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/woodburn/imximage.cfg" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="woodburn U-Boot > " CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/work_92105_defconfig b/configs/work_92105_defconfig index 1a9097a..2999772 100644 --- a/configs/work_92105_defconfig +++ b/configs/work_92105_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL_DM=y CONFIG_DM_SERIAL=y CONFIG_DM_GPIO=y CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/wtk_defconfig b/configs/wtk_defconfig index 3d046cd..25ce098 100644 --- a/configs/wtk_defconfig +++ b/configs/wtk_defconfig @@ -3,5 +3,6 @@ CONFIG_8xx=y CONFIG_TARGET_TQM823L=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="LCD,SHARP_LQ065T9DR51U" +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/x600_defconfig b/configs/x600_defconfig index 881c080..e2a2c81 100644 --- a/configs/x600_defconfig +++ b/configs/x600_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_X600=y CONFIG_SPL=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="X600> " CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit SPACE in %d seconds to stop autoboot.\n" diff --git a/configs/xfi3_defconfig b/configs/xfi3_defconfig index 652e443..515ae41 100644 --- a/configs/xfi3_defconfig +++ b/configs/xfi3_defconfig @@ -1,6 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_XFI3=y CONFIG_SPL=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y diff --git a/configs/xilinx-ppc405-generic_defconfig b/configs/xilinx-ppc405-generic_defconfig index 2008a8d..edfcc20 100644 --- a/configs/xilinx-ppc405-generic_defconfig +++ b/configs/xilinx-ppc405-generic_defconfig @@ -5,6 +5,7 @@ CONFIG_DEFAULT_DEVICE_TREE="xilinx-ppc405-generic" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SYS_EXTRA_OPTIONS="SYS_TEXT_BASE=0x04000000,RESET_VECTOR_ADDRESS=0x04100000" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="xlx-ppc405:/# " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_SETEXPR is not set diff --git a/configs/xilinx-ppc440-generic_defconfig b/configs/xilinx-ppc440-generic_defconfig index 8df33d3..2e65a2c 100644 --- a/configs/xilinx-ppc440-generic_defconfig +++ b/configs/xilinx-ppc440-generic_defconfig @@ -5,6 +5,7 @@ CONFIG_DEFAULT_DEVICE_TREE="xilinx-ppc440-generic" CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_SYS_EXTRA_OPTIONS="SYS_TEXT_BASE=0x04000000,RESET_VECTOR_ADDRESS=0x04100000,BOOT_FROM_XMD=1" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="board:/# " CONFIG_CMD_TFTPPUT=y CONFIG_CMD_DHCP=y diff --git a/configs/xpedite1000_defconfig b/configs/xpedite1000_defconfig index 45cd821..e189859 100644 --- a/configs/xpedite1000_defconfig +++ b/configs/xpedite1000_defconfig @@ -3,5 +3,6 @@ CONFIG_4xx=y CONFIG_TARGET_XPEDITE1000=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y diff --git a/configs/xpedite517x_defconfig b/configs/xpedite517x_defconfig index 38f6290..9baac08 100644 --- a/configs/xpedite517x_defconfig +++ b/configs/xpedite517x_defconfig @@ -5,6 +5,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/xpedite520x_defconfig b/configs/xpedite520x_defconfig index d9957e0..6b8f4bc 100644 --- a/configs/xpedite520x_defconfig +++ b/configs/xpedite520x_defconfig @@ -5,6 +5,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/xpedite537x_defconfig b/configs/xpedite537x_defconfig index a4f648c..538c6cd 100644 --- a/configs/xpedite537x_defconfig +++ b/configs/xpedite537x_defconfig @@ -5,6 +5,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/xpedite550x_defconfig b/configs/xpedite550x_defconfig index 10cf7e8..9b3c5c9 100644 --- a/configs/xpedite550x_defconfig +++ b/configs/xpedite550x_defconfig @@ -5,6 +5,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/xpress_defconfig b/configs/xpress_defconfig index fb2e7b2..418fb7c 100644 --- a/configs/xpress_defconfig +++ b/configs/xpress_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_MX6=y CONFIG_TARGET_XPRESS=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/ccv/xpress/imximage.cfg" +CONFIG_HUSH_PARSER=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/xpress_spl_defconfig b/configs/xpress_spl_defconfig index 4ac7ef0..b464d15 100644 --- a/configs/xpress_spl_defconfig +++ b/configs/xpress_spl_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_XPRESS=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg" +CONFIG_HUSH_PARSER=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/yellowstone_defconfig b/configs/yellowstone_defconfig index 773e93b..4f76e37 100644 --- a/configs/yellowstone_defconfig +++ b/configs/yellowstone_defconfig @@ -3,5 +3,6 @@ CONFIG_4xx=y CONFIG_TARGET_YOSEMITE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="YELLOWSTONE" +CONFIG_HUSH_PARSER=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/yosemite_defconfig b/configs/yosemite_defconfig index bad6df2..9a64852 100644 --- a/configs/yosemite_defconfig +++ b/configs/yosemite_defconfig @@ -3,5 +3,6 @@ CONFIG_4xx=y CONFIG_TARGET_YOSEMITE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="YOSEMITE" +CONFIG_HUSH_PARSER=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/yucca_defconfig b/configs/yucca_defconfig index 5dbbaba..b2f9784 100644 --- a/configs/yucca_defconfig +++ b/configs/yucca_defconfig @@ -2,5 +2,6 @@ CONFIG_PPC=y CONFIG_4xx=y CONFIG_TARGET_YUCCA=y CONFIG_OF_BOARD_SETUP=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/zipitz2_defconfig b/configs/zipitz2_defconfig index d2fa63d..299cf65 100644 --- a/configs/zipitz2_defconfig +++ b/configs/zipitz2_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_ZIPITZ2=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="$ " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_SETEXPR is not set diff --git a/configs/zmx25_defconfig b/configs/zmx25_defconfig index f853308..955bf37 100644 --- a/configs/zmx25_defconfig +++ b/configs/zmx25_defconfig @@ -1,5 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_ZMX25=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="zmx25> " CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="boot in %d s\n" diff --git a/configs/zynq_microzed_defconfig b/configs/zynq_microzed_defconfig index e325317..99ce69e 100644 --- a/configs/zynq_microzed_defconfig +++ b/configs/zynq_microzed_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_FIT_SIGNATURE=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/zynq_picozed_defconfig b/configs/zynq_picozed_defconfig index ffbc73d..9198418 100644 --- a/configs/zynq_picozed_defconfig +++ b/configs/zynq_picozed_defconfig @@ -3,6 +3,7 @@ CONFIG_ARCH_ZYNQ=y CONFIG_TARGET_ZYNQ_PICOZED=y CONFIG_DEFAULT_DEVICE_TREE="zynq-picozed" CONFIG_SPL=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/zynq_zc702_defconfig b/configs/zynq_zc702_defconfig index 5d9136c..214d754 100644 --- a/configs/zynq_zc702_defconfig +++ b/configs/zynq_zc702_defconfig @@ -5,6 +5,7 @@ CONFIG_SPL=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_FIT_SIGNATURE=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/zynq_zc706_defconfig b/configs/zynq_zc706_defconfig index d7c1b96..26cfc0e 100644 --- a/configs/zynq_zc706_defconfig +++ b/configs/zynq_zc706_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_FIT_SIGNATURE=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/zynq_zc770_xm010_defconfig b/configs/zynq_zc770_xm010_defconfig index cec722f..fc58fa1 100644 --- a/configs/zynq_zc770_xm010_defconfig +++ b/configs/zynq_zc770_xm010_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_FIT_SIGNATURE=y CONFIG_SYS_EXTRA_OPTIONS="ZC770_XM010" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/zynq_zc770_xm011_defconfig b/configs/zynq_zc770_xm011_defconfig index 2bc88b8..ea0df44 100644 --- a/configs/zynq_zc770_xm011_defconfig +++ b/configs/zynq_zc770_xm011_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_FIT_SIGNATURE=y CONFIG_SYS_EXTRA_OPTIONS="ZC770_XM011" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/zynq_zc770_xm012_defconfig b/configs/zynq_zc770_xm012_defconfig index b0fa661..7f8a17a 100644 --- a/configs/zynq_zc770_xm012_defconfig +++ b/configs/zynq_zc770_xm012_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_FIT_SIGNATURE=y CONFIG_SYS_EXTRA_OPTIONS="ZC770_XM012" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Zynq> " CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/zynq_zc770_xm013_defconfig b/configs/zynq_zc770_xm013_defconfig index 9672940..6a68f7e 100644 --- a/configs/zynq_zc770_xm013_defconfig +++ b/configs/zynq_zc770_xm013_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_FIT_SIGNATURE=y CONFIG_SYS_EXTRA_OPTIONS="ZC770_XM013" +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/zynq_zed_defconfig b/configs/zynq_zed_defconfig index bc3af09..9cb1485 100644 --- a/configs/zynq_zed_defconfig +++ b/configs/zynq_zed_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_FIT_SIGNATURE=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/configs/zynq_zybo_defconfig b/configs/zynq_zybo_defconfig index 1895f95..89739a6 100644 --- a/configs/zynq_zybo_defconfig +++ b/configs/zynq_zybo_defconfig @@ -6,6 +6,7 @@ CONFIG_SPL=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_FIT_SIGNATURE=y +CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set diff --git a/include/config_distro_defaults.h b/include/config_distro_defaults.h index 5cc2af8..ae44512 100644 --- a/include/config_distro_defaults.h +++ b/include/config_distro_defaults.h @@ -64,7 +64,6 @@ #define CONFIG_EFI_PARTITION #define CONFIG_ISO_PARTITION #define CONFIG_SUPPORT_RAW_INITRD -#define CONFIG_SYS_HUSH_PARSER #define CONFIG_ENV_VARS_UBOOT_CONFIG
#endif /* _CONFIG_CMD_DISTRO_DEFAULTS_H */ diff --git a/include/config_fallbacks.h b/include/config_fallbacks.h index 6b6ec00..5262641 100644 --- a/include/config_fallbacks.h +++ b/include/config_fallbacks.h @@ -102,7 +102,6 @@ #undef CONFIG_SYS_LONGHELP #undef CONFIG_CMD_BOOTD #undef CONFIG_CMD_RUN -#undef CONFIG_SYS_HUSH_PARSER #undef CONFIG_CMD_ASKENV #undef CONFIG_MENU #endif diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index 2d9be20..ef87bda 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -498,11 +498,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_CONSOLE_IS_IN_ENV /* determine from environment */ #endif
- -/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " - /* I2C */ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_FSL /* Use FSL common I2C driver */ diff --git a/include/configs/BSC9131RDB.h b/include/configs/BSC9131RDB.h index e870ffe..e7a90bd 100644 --- a/include/configs/BSC9131RDB.h +++ b/include/configs/BSC9131RDB.h @@ -241,12 +241,6 @@ extern unsigned long get_sdram_size(void);
#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x4500)
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER -#ifdef CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " -#endif - #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_FSL #define CONFIG_SYS_FSL_I2C_SPEED 400000 diff --git a/include/configs/BSC9132QDS.h b/include/configs/BSC9132QDS.h index 108e924..17ae12e 100644 --- a/include/configs/BSC9132QDS.h +++ b/include/configs/BSC9132QDS.h @@ -425,12 +425,6 @@ combinations. this should be removed later #define CONFIG_SYS_NS16550_COM3 (CONFIG_SYS_CCSRBAR + 0x4700) #define CONFIG_SYS_NS16550_COM4 (CONFIG_SYS_CCSRBAR + 0x4800)
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER /* hush parser */ -#ifdef CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " -#endif - #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_FSL #define CONFIG_SYS_FSL_I2C_SPEED 400800 /* I2C speed and slave address*/ diff --git a/include/configs/C29XPCIE.h b/include/configs/C29XPCIE.h index a7a5e8e..9c69f91 100644 --- a/include/configs/C29XPCIE.h +++ b/include/configs/C29XPCIE.h @@ -393,9 +393,6 @@ #define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x4500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x4600)
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER - #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_FSL #define CONFIG_SYS_FSL_I2C_SPEED 400000 diff --git a/include/configs/CPCI2DP.h b/include/configs/CPCI2DP.h index c3a7714..40fff81 100644 --- a/include/configs/CPCI2DP.h +++ b/include/configs/CPCI2DP.h @@ -68,7 +68,6 @@ */ #define CONFIG_SYS_LONGHELP /* undef to save memory */
-#undef CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */
#if defined(CONFIG_CMD_KGDB) #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ diff --git a/include/configs/CPCI4052.h b/include/configs/CPCI4052.h index 1b5b907..b0281be 100644 --- a/include/configs/CPCI4052.h +++ b/include/configs/CPCI4052.h @@ -92,7 +92,6 @@ */ #undef CONFIG_SYS_LONGHELP /* undef to save memory */
#if defined(CONFIG_CMD_KGDB) #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ diff --git a/include/configs/M54418TWR.h b/include/configs/M54418TWR.h index 826de5b..9b87de6 100644 --- a/include/configs/M54418TWR.h +++ b/include/configs/M54418TWR.h @@ -210,10 +210,6 @@
#define CONFIG_PRAM 2048 /* 2048 KB */
-/* HUSH */ -#define CONFIG_SYS_HUSH_PARSER 1 -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " - #define CONFIG_SYS_LONGHELP /* undef to save memory */
#if defined(CONFIG_CMD_KGDB) diff --git a/include/configs/MIP405.h b/include/configs/MIP405.h index 1a793d7..5726605 100644 --- a/include/configs/MIP405.h +++ b/include/configs/MIP405.h @@ -71,7 +71,6 @@ #endif
-#define CONFIG_SYS_HUSH_PARSER /************************************************************** * I2C Stuff: * the MIP405 is equiped with an Atmel 24C128/256 EEPROM at address diff --git a/include/configs/MPC8308RDB.h b/include/configs/MPC8308RDB.h index 9e9765c..fc625d4 100644 --- a/include/configs/MPC8308RDB.h +++ b/include/configs/MPC8308RDB.h @@ -321,11 +321,6 @@ #define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_IMMR + 0x4500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_IMMR + 0x4600)
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER - -/* Pass open firmware flat tree */ - /* I2C */ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_FSL diff --git a/include/configs/MPC8313ERDB.h b/include/configs/MPC8313ERDB.h index d440d88..a3cfe6a 100644 --- a/include/configs/MPC8313ERDB.h +++ b/include/configs/MPC8313ERDB.h @@ -374,9 +374,6 @@ #define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_IMMR+0x4500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_IMMR+0x4600)
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER - /* I2C */ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_FSL diff --git a/include/configs/MPC8315ERDB.h b/include/configs/MPC8315ERDB.h index 3b49f1c..a05ce63 100644 --- a/include/configs/MPC8315ERDB.h +++ b/include/configs/MPC8315ERDB.h @@ -302,9 +302,6 @@ #define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_IMMR+0x4500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_IMMR+0x4600)
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER - /* I2C */ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_FSL diff --git a/include/configs/MPC8323ERDB.h b/include/configs/MPC8323ERDB.h index 97f48e2..8b95920 100644 --- a/include/configs/MPC8323ERDB.h +++ b/include/configs/MPC8323ERDB.h @@ -224,8 +224,6 @@
#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ #define CONFIG_AUTO_COMPLETE /* add autocompletion support */ -/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER
/* I2C */ #define CONFIG_SYS_I2C diff --git a/include/configs/MPC832XEMDS.h b/include/configs/MPC832XEMDS.h index d218f59..4e5e986 100644 --- a/include/configs/MPC832XEMDS.h +++ b/include/configs/MPC832XEMDS.h @@ -304,8 +304,6 @@
/* I2C */ #define CONFIG_SYS_I2C diff --git a/include/configs/MPC8349EMDS.h b/include/configs/MPC8349EMDS.h index 5b0900a..9bf4226 100644 --- a/include/configs/MPC8349EMDS.h +++ b/include/configs/MPC8349EMDS.h @@ -330,8 +330,6 @@
/* I2C */ #define CONFIG_SYS_I2C diff --git a/include/configs/MPC8349ITX.h b/include/configs/MPC8349ITX.h index 4346eda..8cdfcea 100644 --- a/include/configs/MPC8349ITX.h +++ b/include/configs/MPC8349ITX.h @@ -532,7 +532,6 @@ boards, we say we have two, but don't display a message if we find only one. */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ #define CONFIG_CMDLINE_EDITING /* Command-line editing */ #define CONFIG_AUTO_COMPLETE /* add autocompletion support */ -#define CONFIG_SYS_HUSH_PARSER /* Use the HUSH parser */
#define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ #define CONFIG_LOADADDR 800000 /* default location for tftp and bootm */ diff --git a/include/configs/MPC837XEMDS.h b/include/configs/MPC837XEMDS.h index 2475ae4..68a8e71 100644 --- a/include/configs/MPC837XEMDS.h +++ b/include/configs/MPC837XEMDS.h @@ -318,9 +318,6 @@ #define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_IMMR+0x4500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_IMMR+0x4600)
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER - /* I2C */ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_FSL diff --git a/include/configs/MPC837XERDB.h b/include/configs/MPC837XERDB.h index aa66927..366febc 100644 --- a/include/configs/MPC837XERDB.h +++ b/include/configs/MPC837XERDB.h @@ -344,9 +344,6 @@ #define CONFIG_FSL_SERDES1 0xe3000 #define CONFIG_FSL_SERDES2 0xe3100
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER - /* I2C */ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_FSL diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index 980cb99..27db9ef 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -381,9 +381,6 @@ #define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR + 0x4500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR + 0x4600)
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER - /* * I2C */ diff --git a/include/configs/MPC8540ADS.h b/include/configs/MPC8540ADS.h index 0a6d5bc..06d54a9 100644 --- a/include/configs/MPC8540ADS.h +++ b/include/configs/MPC8540ADS.h @@ -231,11 +231,6 @@ #define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x4500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x4600)
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER -#ifdef CONFIG_SYS_HUSH_PARSER -#endif - /* * I2C */ diff --git a/include/configs/MPC8541CDS.h b/include/configs/MPC8541CDS.h index 79f81ec..dd638eb 100644 --- a/include/configs/MPC8541CDS.h +++ b/include/configs/MPC8541CDS.h @@ -254,11 +254,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x4500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x4600)
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER -#ifdef CONFIG_SYS_HUSH_PARSER -#endif - /* * I2C */ diff --git a/include/configs/MPC8544DS.h b/include/configs/MPC8544DS.h index 2372d5f..4d56284 100644 --- a/include/configs/MPC8544DS.h +++ b/include/configs/MPC8544DS.h @@ -206,9 +206,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x4500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x4600)
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER - /* I2C */ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_FSL diff --git a/include/configs/MPC8548CDS.h b/include/configs/MPC8548CDS.h index 8d29762..a4868f9 100644 --- a/include/configs/MPC8548CDS.h +++ b/include/configs/MPC8548CDS.h @@ -331,9 +331,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x4500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x4600)
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER - /* * I2C */ diff --git a/include/configs/MPC8555CDS.h b/include/configs/MPC8555CDS.h index b64bbe5..3bce162 100644 --- a/include/configs/MPC8555CDS.h +++ b/include/configs/MPC8555CDS.h @@ -252,11 +252,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x4500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x4600)
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER -#ifdef CONFIG_SYS_HUSH_PARSER -#endif - /* * I2C */ diff --git a/include/configs/MPC8560ADS.h b/include/configs/MPC8560ADS.h index 2284646..a5a3dc4 100644 --- a/include/configs/MPC8560ADS.h +++ b/include/configs/MPC8560ADS.h @@ -226,11 +226,6 @@ #define CONFIG_SYS_BAUDRATE_TABLE \ {300, 600, 1200, 2400, 4800, 9600, 19200, 38400,115200}
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER -#ifdef CONFIG_SYS_HUSH_PARSER -#endif - /* * I2C */ diff --git a/include/configs/MPC8568MDS.h b/include/configs/MPC8568MDS.h index a130001..24c32ca 100644 --- a/include/configs/MPC8568MDS.h +++ b/include/configs/MPC8568MDS.h @@ -237,11 +237,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x4500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x4600)
-/* Use the HUSH parser*/ -#define CONFIG_SYS_HUSH_PARSER -#ifdef CONFIG_SYS_HUSH_PARSER -#endif - /* * I2C */ diff --git a/include/configs/MPC8569MDS.h b/include/configs/MPC8569MDS.h index 0e003e5..1224a20 100644 --- a/include/configs/MPC8569MDS.h +++ b/include/configs/MPC8569MDS.h @@ -248,11 +248,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x4500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x4600)
-/* Use the HUSH parser*/ -#define CONFIG_SYS_HUSH_PARSER -#ifdef CONFIG_SYS_HUSH_PARSER -#endif - /* * I2C */ diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index 95f59e0..10ee862 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -377,9 +377,6 @@ #define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x4500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x4600)
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER - /* I2C */ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_FSL diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h index ac219d1..7528456 100644 --- a/include/configs/MPC8610HPCD.h +++ b/include/configs/MPC8610HPCD.h @@ -233,9 +233,6 @@ #define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x4500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x4600)
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER - /* maximum size of the flat tree (8K) */ #define OF_FLAT_TREE_MAX_SIZE 8192
diff --git a/include/configs/MPC8641HPCN.h b/include/configs/MPC8641HPCN.h index 1f4ed2a..1f2505f 100644 --- a/include/configs/MPC8641HPCN.h +++ b/include/configs/MPC8641HPCN.h @@ -269,9 +269,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x4500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x4600)
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER - /* * I2C */ diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index 249e11b..6e69258 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -619,9 +619,6 @@ extern unsigned long get_sdram_size(void); #define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x4500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x4600)
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER - /* I2C */ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_FSL diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index bc4c733..d009913 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -406,9 +406,6 @@ #define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x4500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x4600)
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER - /* Video */
#ifdef CONFIG_FSL_DIU_FB diff --git a/include/configs/P1023RDB.h b/include/configs/P1023RDB.h index a53b1ac..833affd 100644 --- a/include/configs/P1023RDB.h +++ b/include/configs/P1023RDB.h @@ -172,9 +172,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR + 0x4500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR + 0x4600)
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER - /* I2C */ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_FSL diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index 2d27fcf..6f9680f 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -336,9 +336,6 @@ unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_SYS_NS16550_COM3 (CONFIG_SYS_CCSRBAR+0x11D500) #define CONFIG_SYS_NS16550_COM4 (CONFIG_SYS_CCSRBAR+0x11D600)
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER - /* I2C */ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_FSL diff --git a/include/configs/PIP405.h b/include/configs/PIP405.h index b5959c8..5d639b1 100644 --- a/include/configs/PIP405.h +++ b/include/configs/PIP405.h @@ -59,7 +59,6 @@ #define CONFIG_CMD_SAVES #define CONFIG_CMD_BSP
-#define CONFIG_SYS_HUSH_PARSER /************************************************************** * I2C Stuff: * the PIP405 is equiped with an Atmel 24C128/256 EEPROM at address diff --git a/include/configs/PLU405.h b/include/configs/PLU405.h index 345affa..0e6ad7a 100644 --- a/include/configs/PLU405.h +++ b/include/configs/PLU405.h @@ -90,7 +90,6 @@ */ #define CONFIG_SYS_LONGHELP /* undef to save memory */
#if defined(CONFIG_CMD_KGDB) #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ diff --git a/include/configs/T102xQDS.h b/include/configs/T102xQDS.h index f07b2d1..800c246 100644 --- a/include/configs/T102xQDS.h +++ b/include/configs/T102xQDS.h @@ -510,10 +510,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_NS16550_COM4 (CONFIG_SYS_CCSRBAR+0x11D600) #define CONFIG_SYS_CONSOLE_IS_IN_ENV /* determine from environment */
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " - /* Video */ #ifdef CONFIG_PPC_T1024 /* no DIU on T1023 */ #define CONFIG_FSL_DIU_FB diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index 1a22bee..d288a9f 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -511,10 +511,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_NS16550_COM4 (CONFIG_SYS_CCSRBAR+0x11D600) #define CONFIG_SYS_CONSOLE_IS_IN_ENV /* determine from environment */
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " - /* Video */ #undef CONFIG_FSL_DIU_FB /* RDB doesn't support DIU */ #ifdef CONFIG_FSL_DIU_FB diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index f52889d..5a4382e 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -411,10 +411,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_NS16550_COM4 (CONFIG_SYS_CCSRBAR+0x11D600) #define CONFIG_SYS_CONSOLE_IS_IN_ENV /* determine from environment */
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " - /* Video */ #define CONFIG_FSL_DIU_FB #ifdef CONFIG_FSL_DIU_FB diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 84e195d..0ba3913 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -465,10 +465,6 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_rcw.cfg #define CONFIG_SYS_CONSOLE_IS_IN_ENV /* determine from environment */ #endif
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " - #if defined(CONFIG_T1042RDB_PI) || defined(CONFIG_T1042D4RDB) /* Video */ #define CONFIG_FSL_DIU_FB diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index 5957fa8..69d161b 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -455,10 +455,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_NS16550_COM3 (CONFIG_SYS_CCSRBAR+0x11D500) #define CONFIG_SYS_NS16550_COM4 (CONFIG_SYS_CCSRBAR+0x11D600)
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " - /* * I2C */ diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index e0769d0..df4c5dc 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -415,10 +415,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_NS16550_COM3 (CONFIG_SYS_CCSRBAR+0x11D500) #define CONFIG_SYS_NS16550_COM4 (CONFIG_SYS_CCSRBAR+0x11D600)
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " - /* * I2C */ diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index faf06a0..e075442 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -209,10 +209,6 @@ #define CONFIG_SYS_NS16550_COM3 (CONFIG_SYS_CCSRBAR+0x11D500) #define CONFIG_SYS_NS16550_COM4 (CONFIG_SYS_CCSRBAR+0x11D600)
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " - /* I2C */ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_FSL diff --git a/include/configs/TQM5200.h b/include/configs/TQM5200.h index e646c00..8fd3a8b 100644 --- a/include/configs/TQM5200.h +++ b/include/configs/TQM5200.h @@ -604,7 +604,6 @@ #define CONFIG_SYS_LONGHELP /* undef to save memory */
#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ -#define CONFIG_SYS_HUSH_PARSER 1 /* use "hush" command parser */
#define CONFIG_SYS_CACHELINE_SIZE 32 /* For MPC5xxx CPUs */ #if defined(CONFIG_CMD_KGDB) diff --git a/include/configs/TQM823L.h b/include/configs/TQM823L.h index d03f2e6..7e3fdda 100644 --- a/include/configs/TQM823L.h +++ b/include/configs/TQM823L.h @@ -126,7 +126,6 @@ #define CONFIG_SYS_LONGHELP /* undef to save memory */
#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ -#define CONFIG_SYS_HUSH_PARSER 1 /* Use the HUSH parser */
#if defined(CONFIG_CMD_KGDB) #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ diff --git a/include/configs/TQM823M.h b/include/configs/TQM823M.h index 7d39766..fc305f4 100644 --- a/include/configs/TQM823M.h +++ b/include/configs/TQM823M.h @@ -121,7 +121,6 @@ #define CONFIG_SYS_LONGHELP /* undef to save memory */
#if defined(CONFIG_CMD_KGDB) #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ diff --git a/include/configs/TQM834x.h b/include/configs/TQM834x.h index 9ed469a..b9baad6 100644 --- a/include/configs/TQM834x.h +++ b/include/configs/TQM834x.h @@ -311,7 +311,6 @@ #define CONFIG_CMDLINE_EDITING 1 /* add command line history */ #define CONFIG_AUTO_COMPLETE /* add autocompletion support */
#if defined(CONFIG_CMD_KGDB) #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ diff --git a/include/configs/TQM850L.h b/include/configs/TQM850L.h index c70c4d7..472dbb3 100644 --- a/include/configs/TQM850L.h +++ b/include/configs/TQM850L.h @@ -110,7 +110,6 @@ #define CONFIG_SYS_LONGHELP /* undef to save memory */
#if defined(CONFIG_CMD_KGDB) #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ diff --git a/include/configs/TQM850M.h b/include/configs/TQM850M.h index 52cba86..3aec34c 100644 --- a/include/configs/TQM850M.h +++ b/include/configs/TQM850M.h @@ -111,7 +111,6 @@ #define CONFIG_SYS_LONGHELP /* undef to save memory */
#if defined(CONFIG_CMD_KGDB) #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ diff --git a/include/configs/TQM855L.h b/include/configs/TQM855L.h index fb2652b..a46f689 100644 --- a/include/configs/TQM855L.h +++ b/include/configs/TQM855L.h @@ -114,7 +114,6 @@ #define CONFIG_SYS_LONGHELP /* undef to save memory */
#if defined(CONFIG_CMD_KGDB) #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ diff --git a/include/configs/TQM855M.h b/include/configs/TQM855M.h index 301a0a8..b44a31b 100644 --- a/include/configs/TQM855M.h +++ b/include/configs/TQM855M.h @@ -144,7 +144,6 @@ #define CONFIG_SYS_LONGHELP /* undef to save memory */
#if defined(CONFIG_CMD_KGDB) #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ diff --git a/include/configs/TQM860L.h b/include/configs/TQM860L.h index a390e3f..cdbae5c 100644 --- a/include/configs/TQM860L.h +++ b/include/configs/TQM860L.h @@ -113,7 +113,6 @@ #define CONFIG_SYS_LONGHELP /* undef to save memory */
#if defined(CONFIG_CMD_KGDB) #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ diff --git a/include/configs/TQM860M.h b/include/configs/TQM860M.h index 0d2e119..c1866a5 100644 --- a/include/configs/TQM860M.h +++ b/include/configs/TQM860M.h @@ -114,7 +114,6 @@ #define CONFIG_SYS_LONGHELP /* undef to save memory */
#if defined(CONFIG_CMD_KGDB) #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ diff --git a/include/configs/TQM862L.h b/include/configs/TQM862L.h index 6fd08c7..881d654 100644 --- a/include/configs/TQM862L.h +++ b/include/configs/TQM862L.h @@ -117,7 +117,6 @@ #define CONFIG_SYS_LONGHELP /* undef to save memory */
#if defined(CONFIG_CMD_KGDB) #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ diff --git a/include/configs/TQM862M.h b/include/configs/TQM862M.h index fcdc3e5..e06de45 100644 --- a/include/configs/TQM862M.h +++ b/include/configs/TQM862M.h @@ -117,7 +117,6 @@ #define CONFIG_SYS_LONGHELP /* undef to save memory */
#if defined(CONFIG_CMD_KGDB) #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ diff --git a/include/configs/TQM866M.h b/include/configs/TQM866M.h index 2a0fdf5..6b585f9 100644 --- a/include/configs/TQM866M.h +++ b/include/configs/TQM866M.h @@ -157,7 +157,6 @@ #define CONFIG_SYS_LONGHELP /* undef to save memory */
#if defined(CONFIG_CMD_KGDB) #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ diff --git a/include/configs/TQM885D.h b/include/configs/TQM885D.h index c9925ab..83b094c 100644 --- a/include/configs/TQM885D.h +++ b/include/configs/TQM885D.h @@ -152,7 +152,6 @@ #define CONFIG_SYS_LONGHELP /* undef to save memory */
#if defined(CONFIG_CMD_KGDB) #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ diff --git a/include/configs/UCP1020.h b/include/configs/UCP1020.h index 139e629..a37fbe2 100644 --- a/include/configs/UCP1020.h +++ b/include/configs/UCP1020.h @@ -342,9 +342,6 @@ #define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR + 0x4500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR + 0x4600)
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER - /* I2C */ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_FSL diff --git a/include/configs/VCMA9.h b/include/configs/VCMA9.h index de7d5c2..ef47e98 100644 --- a/include/configs/VCMA9.h +++ b/include/configs/VCMA9.h @@ -63,7 +63,6 @@
#define CONFIG_BOARD_LATE_INIT
-#define CONFIG_SYS_HUSH_PARSER #define CONFIG_CMDLINE_EDITING
/* diff --git a/include/configs/VOM405.h b/include/configs/VOM405.h index a734c28..0ed44a8 100644 --- a/include/configs/VOM405.h +++ b/include/configs/VOM405.h @@ -77,7 +77,6 @@ */ #define CONFIG_SYS_LONGHELP /* undef to save memory */
#if defined(CONFIG_CMD_KGDB) #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ diff --git a/include/configs/a3m071.h b/include/configs/a3m071.h index 31348da..df3e06e 100644 --- a/include/configs/a3m071.h +++ b/include/configs/a3m071.h @@ -240,8 +240,6 @@ #define CONFIG_SYS_LONGHELP
#define CONFIG_CMDLINE_EDITING -#define CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> "
#if defined(CONFIG_CMD_KGDB) #define CONFIG_SYS_CBSIZE 1024 diff --git a/include/configs/a4m072.h b/include/configs/a4m072.h index a883afb..2b58830 100644 --- a/include/configs/a4m072.h +++ b/include/configs/a4m072.h @@ -260,7 +260,6 @@ /* * Miscellaneous configurable options */ -#define CONFIG_SYS_HUSH_PARSER #define CONFIG_CMDLINE_EDITING 1 #define CONFIG_SYS_LONGHELP /* undef to save memory */ #if defined(CONFIG_CMD_KGDB) diff --git a/include/configs/am3517_crane.h b/include/configs/am3517_crane.h index 3cc2874..6c1556a 100644 --- a/include/configs/am3517_crane.h +++ b/include/configs/am3517_crane.h @@ -208,7 +208,6 @@ * Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ #define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ /* Print Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index 75fe558..f33c7b7 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -285,7 +285,6 @@ #define CONFIG_CMDLINE_EDITING #define CONFIG_VERSION_VARIABLE #define CONFIG_SYS_LONGHELP -#define CONFIG_SYS_HUSH_PARSER #define CONFIG_PARTITION_UUIDS
/* We set the max number of command args high to avoid HUSH bugs. */ diff --git a/include/configs/amcc-common.h b/include/configs/amcc-common.h index 0388ffc..8b1920d 100644 --- a/include/configs/amcc-common.h +++ b/include/configs/amcc-common.h @@ -92,7 +92,6 @@ #define CONFIG_VERSION_VARIABLE /* include version env variable */ #define CONFIG_SYS_CONSOLE_INFO_QUIET /* don't print console @ startup*/
#define CONFIG_LOADS_ECHO /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */ diff --git a/include/configs/apf27.h b/include/configs/apf27.h index 018d586..fe3b714 100644 --- a/include/configs/apf27.h +++ b/include/configs/apf27.h @@ -148,8 +148,6 @@ /* Boot argument buffer size */ #define CONFIG_AUTO_COMPLETE #define CONFIG_CMDLINE_EDITING -#define CONFIG_SYS_HUSH_PARSER /* enable the "hush" shell */ -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " /* secondary prompt string */ #define CONFIG_ENV_VARS_UBOOT_CONFIG #define CONFIG_PREBOOT "run check_flash check_env;"
diff --git a/include/configs/aria.h b/include/configs/aria.h index c56a2e3..b3050df 100644 --- a/include/configs/aria.h +++ b/include/configs/aria.h @@ -326,10 +326,6 @@ #define CONSOLE_FIFO_RX_ADDR FIFOC_PSC3_RX_ADDR
#define CONFIG_CMDLINE_EDITING 1 /* command line history */ -/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER -#ifdef CONFIG_SYS_HUSH_PARSER -#endif
/* * PCI diff --git a/include/configs/astro_mcf5373l.h b/include/configs/astro_mcf5373l.h index 828bc60..05d41ce 100644 --- a/include/configs/astro_mcf5373l.h +++ b/include/configs/astro_mcf5373l.h @@ -69,7 +69,6 @@ #define CONFIG_CMD_FPGA_LOADMK #define CONFIG_CMDLINE_EDITING
#define CONFIG_MCFRTC #undef RTC_DEBUG diff --git a/include/configs/at91-sama5_common.h b/include/configs/at91-sama5_common.h index 6525b5c..c55446d 100644 --- a/include/configs/at91-sama5_common.h +++ b/include/configs/at91-sama5_common.h @@ -115,7 +115,6 @@ #define CONFIG_SYS_LONGHELP #define CONFIG_CMDLINE_EDITING #define CONFIG_AUTO_COMPLETE -#define CONFIG_SYS_HUSH_PARSER
/* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (4 * 1024 * 1024) diff --git a/include/configs/at91rm9200ek.h b/include/configs/at91rm9200ek.h index 5903f7c..2a5acf5 100644 --- a/include/configs/at91rm9200ek.h +++ b/include/configs/at91rm9200ek.h @@ -191,7 +191,6 @@ #define CONFIG_CMDLINE_EDITING #define CONFIG_SYS_LONGHELP #define CONFIG_AUTO_COMPLETE -#define CONFIG_SYS_HUSH_PARSER #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ /* Print Buffer Size */ diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index c826427..3d39387 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -332,7 +332,6 @@ #define CONFIG_SYS_LONGHELP 1 #define CONFIG_CMDLINE_EDITING 1 #define CONFIG_AUTO_COMPLETE -#define CONFIG_SYS_HUSH_PARSER
/* * Size of malloc() pool diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index d4baf48..e292632 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -183,7 +183,6 @@ #define CONFIG_SYS_LONGHELP #define CONFIG_CMDLINE_EDITING #define CONFIG_AUTO_COMPLETE -#define CONFIG_SYS_HUSH_PARSER
/* * Size of malloc() pool diff --git a/include/configs/at91sam9n12ek.h b/include/configs/at91sam9n12ek.h index 14a8436..9dda777 100644 --- a/include/configs/at91sam9n12ek.h +++ b/include/configs/at91sam9n12ek.h @@ -222,7 +222,6 @@ #define CONFIG_SYS_LONGHELP #define CONFIG_CMDLINE_EDITING #define CONFIG_AUTO_COMPLETE -#define CONFIG_SYS_HUSH_PARSER
/* * Size of malloc() pool diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index cd91a7b..fcd1008 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -224,7 +224,6 @@ #define CONFIG_SYS_LONGHELP #define CONFIG_CMDLINE_EDITING #define CONFIG_AUTO_COMPLETE -#define CONFIG_SYS_HUSH_PARSER
/* * Size of malloc() pool diff --git a/include/configs/bcm28155_ap.h b/include/configs/bcm28155_ap.h index be8cb80..9456a31 100644 --- a/include/configs/bcm28155_ap.h +++ b/include/configs/bcm28155_ap.h @@ -114,7 +114,6 @@ /* version string, parser, etc */ #define CONFIG_VERSION_VARIABLE #define CONFIG_AUTO_COMPLETE -#define CONFIG_SYS_HUSH_PARSER #define CONFIG_CMDLINE_EDITING #define CONFIG_SYS_LONGHELP
diff --git a/include/configs/bcm_ep_board.h b/include/configs/bcm_ep_board.h index 344f89d..efc5de5 100644 --- a/include/configs/bcm_ep_board.h +++ b/include/configs/bcm_ep_board.h @@ -72,7 +72,6 @@ /* version string, parser, etc */ #define CONFIG_VERSION_VARIABLE #define CONFIG_AUTO_COMPLETE -#define CONFIG_SYS_HUSH_PARSER #define CONFIG_CMDLINE_EDITING #define CONFIG_COMMAND_HISTORY #define CONFIG_SYS_LONGHELP diff --git a/include/configs/bct-brettl2.h b/include/configs/bct-brettl2.h index 658b16d..4563c54 100644 --- a/include/configs/bct-brettl2.h +++ b/include/configs/bct-brettl2.h @@ -133,7 +133,6 @@ #define CONFIG_BAUDRATE 115200 #define CONFIG_MTD_DEVICE #define CONFIG_MTD_PARTITIONS -#define CONFIG_SYS_HUSH_PARSER
/* * Pull in common ADI header for remaining command/environment setup diff --git a/include/configs/calimain.h b/include/configs/calimain.h index e6b2d4d..d5d4ded 100644 --- a/include/configs/calimain.h +++ b/include/configs/calimain.h @@ -200,7 +200,6 @@ #define CONFIG_LOADADDR 0xc0700000 #define CONFIG_VERSION_VARIABLE #define CONFIG_AUTO_COMPLETE -#define CONFIG_SYS_HUSH_PARSER #define CONFIG_CMDLINE_EDITING #define CONFIG_SYS_LONGHELP #define CONFIG_CRC32_VERIFY diff --git a/include/configs/cm_t35.h b/include/configs/cm_t35.h index 3910b46..016e752 100644 --- a/include/configs/cm_t35.h +++ b/include/configs/cm_t35.h @@ -217,7 +217,6 @@ #define CONFIG_TIMESTAMP #define CONFIG_SYS_AUTOLOAD "no" #define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ /* Print Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ diff --git a/include/configs/cm_t3517.h b/include/configs/cm_t3517.h index d8a29f0..ca0b47e 100644 --- a/include/configs/cm_t3517.h +++ b/include/configs/cm_t3517.h @@ -226,7 +226,6 @@ #define CONFIG_TIMESTAMP #define CONFIG_SYS_AUTOLOAD "no" #define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ #define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ /* Print Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ diff --git a/include/configs/colibri_pxa270.h b/include/configs/colibri_pxa270.h index e8851e7..edd0329 100644 --- a/include/configs/colibri_pxa270.h +++ b/include/configs/colibri_pxa270.h @@ -95,14 +95,9 @@ #define CONFIG_BOOTP_HOSTNAME #endif
-/* - * HUSH Shell Configuration - */ -#define CONFIG_SYS_HUSH_PARSER 1 - #undef CONFIG_SYS_LONGHELP /* Saves 10 KB */ #undef CONFIG_SYS_PROMPT -#ifdef CONFIG_SYS_HUSH_PARSER +#ifdef CONFIG_HUSH_PARSER #define CONFIG_SYS_PROMPT "$ " #else #endif diff --git a/include/configs/colibri_vf.h b/include/configs/colibri_vf.h index f79c58a..70e970f 100644 --- a/include/configs/colibri_vf.h +++ b/include/configs/colibri_vf.h @@ -166,8 +166,6 @@
/* Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " #undef CONFIG_AUTO_COMPLETE #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE \ diff --git a/include/configs/controlcenterd.h b/include/configs/controlcenterd.h index fa64a1e..3f03978 100644 --- a/include/configs/controlcenterd.h +++ b/include/configs/controlcenterd.h @@ -365,7 +365,6 @@ * Command line configuration. */ #ifndef CONFIG_TRAILBLAZER -#define CONFIG_SYS_HUSH_PARSER #define CONFIG_SYS_LONGHELP #define CONFIG_CMDLINE_EDITING /* Command-line editing */ #define CONFIG_AUTO_COMPLETE /* add autocompletion support */ diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index d30d7ff..c937957 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -341,9 +341,6 @@ #define CONFIG_SYS_NS16550_COM3 (CONFIG_SYS_CCSRBAR+0x11D500) #define CONFIG_SYS_NS16550_COM4 (CONFIG_SYS_CCSRBAR+0x11D600)
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER - /* I2C */ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_FSL diff --git a/include/configs/corvus.h b/include/configs/corvus.h index a525555..6ef6a7d 100644 --- a/include/configs/corvus.h +++ b/include/configs/corvus.h @@ -152,7 +152,6 @@ #define CONFIG_SYS_LONGHELP #define CONFIG_CMDLINE_EDITING #define CONFIG_AUTO_COMPLETE -#define CONFIG_SYS_HUSH_PARSER
/* * Size of malloc() pool diff --git a/include/configs/cyrus.h b/include/configs/cyrus.h index b4bf350..1691cea 100644 --- a/include/configs/cyrus.h +++ b/include/configs/cyrus.h @@ -227,10 +227,6 @@ #define CONFIG_SYS_NS16550_COM3 (CONFIG_SYS_CCSRBAR+0x11D500) #define CONFIG_SYS_NS16550_COM4 (CONFIG_SYS_CCSRBAR+0x11D600)
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " - /* I2C */ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_FSL diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index 24e55e8..3e84cbc 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -265,7 +265,6 @@ #define CONFIG_SYS_LOAD_ADDR (PHYS_SDRAM_1 + 0x700000) #define CONFIG_VERSION_VARIABLE #define CONFIG_AUTO_COMPLETE -#define CONFIG_SYS_HUSH_PARSER #define CONFIG_CMDLINE_EDITING #define CONFIG_SYS_LONGHELP #define CONFIG_CRC32_VERIFY diff --git a/include/configs/digsy_mtc.h b/include/configs/digsy_mtc.h index 0041ab9..db3759f 100644 --- a/include/configs/digsy_mtc.h +++ b/include/configs/digsy_mtc.h @@ -387,7 +387,6 @@ #define CONFIG_SYS_LONGHELP #define CONFIG_AUTO_COMPLETE 1 #define CONFIG_CMDLINE_EDITING 1 -#define CONFIG_SYS_HUSH_PARSER
#define CONFIG_LOOPW 1 #define CONFIG_MX_CYCLIC 1 diff --git a/include/configs/dns325.h b/include/configs/dns325.h index 80f7a1e..85a2594 100644 --- a/include/configs/dns325.h +++ b/include/configs/dns325.h @@ -80,11 +80,6 @@ #define CONFIG_KIRKWOOD_GPIO
/* - * Use the HUSH parser - */ -#define CONFIG_SYS_HUSH_PARSER - -/* * Console configuration */ #define CONFIG_CONSOLE_MUX diff --git a/include/configs/ea20.h b/include/configs/ea20.h index 10b30c1..85db470 100644 --- a/include/configs/ea20.h +++ b/include/configs/ea20.h @@ -128,7 +128,6 @@ #define CONFIG_SYS_LOAD_ADDR (PHYS_SDRAM_1 + 0x700000) #define CONFIG_VERSION_VARIABLE #define CONFIG_AUTO_COMPLETE -#define CONFIG_SYS_HUSH_PARSER #define CONFIG_CMDLINE_EDITING #define CONFIG_SYS_LONGHELP #define CONFIG_CRC32_VERIFY diff --git a/include/configs/edb93xx.h b/include/configs/edb93xx.h index 7bc58dc..0645d34 100644 --- a/include/configs/edb93xx.h +++ b/include/configs/edb93xx.h @@ -34,8 +34,6 @@ #define CONFIG_BOOTARGS "root=/dev/nfs console=ttyAM0,115200 ip=dhcp" #define CONFIG_BOOTFILE "edb93xx.img"
#define CONFIG_SYS_LDSCRIPT "board/cirrus/edb93xx/u-boot.lds" diff --git a/include/configs/edminiv2.h b/include/configs/edminiv2.h index 1dfa721..d622ef8 100644 --- a/include/configs/edminiv2.h +++ b/include/configs/edminiv2.h @@ -235,9 +235,6 @@ #define CONFIG_SYS_RESET_ADDRESS 0xffff0000 #define CONFIG_SYS_MAXARGS 16
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER - /* Enable command line editing */ #define CONFIG_CMDLINE_EDITING
diff --git a/include/configs/ethernut5.h b/include/configs/ethernut5.h index 23a2935..0606194 100644 --- a/include/configs/ethernut5.h +++ b/include/configs/ethernut5.h @@ -235,7 +235,6 @@ #endif
/* Misc. u-boot settings */ -#define CONFIG_SYS_HUSH_PARSER #define CONFIG_SYS_CBSIZE 256 #define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + 16 \ diff --git a/include/configs/flea3.h b/include/configs/flea3.h index 15905b9..df75152 100644 --- a/include/configs/flea3.h +++ b/include/configs/flea3.h @@ -110,7 +110,6 @@ */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ #define CONFIG_CMDLINE_EDITING -#define CONFIG_SYS_HUSH_PARSER /* Use the HUSH parser */
#define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ diff --git a/include/configs/ge_bx50v3.h b/include/configs/ge_bx50v3.h index 3a9739e..c3140c7 100644 --- a/include/configs/ge_bx50v3.h +++ b/include/configs/ge_bx50v3.h @@ -260,8 +260,6 @@
/* Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP -#define CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " #define CONFIG_AUTO_COMPLETE
/* Print Buffer Size */ diff --git a/include/configs/grasshopper.h b/include/configs/grasshopper.h index 274175b..8cde96a 100644 --- a/include/configs/grasshopper.h +++ b/include/configs/grasshopper.h @@ -99,7 +99,6 @@ #define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO
-#define CONFIG_SYS_HUSH_PARSER #define CONFIG_AUTO_COMPLETE #define CONFIG_CMDLINE_EDITING
diff --git a/include/configs/grsim.h b/include/configs/grsim.h index 47c3573..3e81f0d 100644 --- a/include/configs/grsim.h +++ b/include/configs/grsim.h @@ -66,7 +66,6 @@ "echo"
#undef CONFIG_BOOTARGS -/*#define CONFIG_SYS_HUSH_PARSER 0*/
#define CONFIG_EXTRA_ENV_SETTINGS \ "netdev=eth0\0" \ diff --git a/include/configs/grsim_leon2.h b/include/configs/grsim_leon2.h index 0a5292e..e06e261 100644 --- a/include/configs/grsim_leon2.h +++ b/include/configs/grsim_leon2.h @@ -61,7 +61,6 @@ "echo"
#define CONFIG_EXTRA_ENV_SETTINGS \ "netdev=eth0\0" \ diff --git a/include/configs/h2200.h b/include/configs/h2200.h index fe0211a..0bdb570 100644 --- a/include/configs/h2200.h +++ b/include/configs/h2200.h @@ -121,8 +121,6 @@ #define CONFIG_INITRD_TAG
/* Monitor Command Prompt */ -#define CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT_HUSH_PS2 "$ "
/* Console I/O Buffer Size */ #define CONFIG_SYS_CBSIZE 256 diff --git a/include/configs/hikey.h b/include/configs/hikey.h index 0851626..ce4a006 100644 --- a/include/configs/hikey.h +++ b/include/configs/hikey.h @@ -140,7 +140,6 @@ #define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ sizeof(CONFIG_SYS_PROMPT) + 16) -#define CONFIG_SYS_HUSH_PARSER #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE #define CONFIG_SYS_LONGHELP #define CONFIG_CMDLINE_EDITING diff --git a/include/configs/hrcon.h b/include/configs/hrcon.h index c984613..75496d7 100644 --- a/include/configs/hrcon.h +++ b/include/configs/hrcon.h @@ -310,9 +310,6 @@ #define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_IMMR + 0x4500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_IMMR + 0x4600)
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER - /* Pass open firmware flat tree */
/* I2C */ diff --git a/include/configs/ids8313.h b/include/configs/ids8313.h index de51d10..17e1f05 100644 --- a/include/configs/ids8313.h +++ b/include/configs/ids8313.h @@ -472,8 +472,6 @@ + sizeof(CONFIG_SYS_PROMPT)+16) #define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> "
#define CONFIG_SYS_MEMTEST_START 0x00001000 #define CONFIG_SYS_MEMTEST_END 0x00C00000 diff --git a/include/configs/integrator-common.h b/include/configs/integrator-common.h index 43d2c3d..4cd889b 100644 --- a/include/configs/integrator-common.h +++ b/include/configs/integrator-common.h @@ -13,7 +13,6 @@ #define CONFIG_SYS_TIMERBASE 0x13000100 /* Timer1 */ #define CONFIG_SYS_LOAD_ADDR 0x7fc0 /* default load address */ #define CONFIG_SYS_LONGHELP -#define CONFIG_SYS_HUSH_PARSER #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size*/ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ diff --git a/include/configs/ipam390.h b/include/configs/ipam390.h index 3c4a70c..4f0aa69 100644 --- a/include/configs/ipam390.h +++ b/include/configs/ipam390.h @@ -212,7 +212,6 @@ #define CONFIG_SYS_LOAD_ADDR (PHYS_SDRAM_1 + 0x700000) #define CONFIG_VERSION_VARIABLE #define CONFIG_AUTO_COMPLETE -#define CONFIG_SYS_HUSH_PARSER #define CONFIG_CMDLINE_EDITING #define CONFIG_SYS_LONGHELP #define CONFIG_CRC32_VERIFY diff --git a/include/configs/jupiter.h b/include/configs/jupiter.h index b494683..09f308f 100644 --- a/include/configs/jupiter.h +++ b/include/configs/jupiter.h @@ -239,7 +239,6 @@ #define CONFIG_SYS_LONGHELP /* undef to save memory */
#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ -#define CONFIG_SYS_HUSH_PARSER 1 /* Use the HUSH parser */ #if defined(CONFIG_CMD_KGDB) #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #else diff --git a/include/configs/kc1.h b/include/configs/kc1.h index 6cbafdd..1087902 100644 --- a/include/configs/kc1.h +++ b/include/configs/kc1.h @@ -156,7 +156,6 @@ #define CONFIG_AUTO_COMPLETE
#define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_CBSIZE 512 diff --git a/include/configs/km/keymile-common.h b/include/configs/km/keymile-common.h index 5edc8f6..ab727aa 100644 --- a/include/configs/km/keymile-common.h +++ b/include/configs/km/keymile-common.h @@ -33,7 +33,6 @@ /* * Miscellaneous configurable options */ -#define CONFIG_SYS_HUSH_PARSER #define CONFIG_SYS_LONGHELP /* undef to save memory */ #if defined(CONFIG_CMD_KGDB) #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ diff --git a/include/configs/km/kmp204x-common.h b/include/configs/km/kmp204x-common.h index d981951..44829e8 100644 --- a/include/configs/km/kmp204x-common.h +++ b/include/configs/km/kmp204x-common.h @@ -255,9 +255,6 @@ unsigned long get_board_sys_clk(unsigned long dummy);
#define CONFIG_KM_CONSOLE_TTY "ttyS0"
#define CONFIG_SYS_I2C diff --git a/include/configs/lacie_kw.h b/include/configs/lacie_kw.h index 842169d..12fef29 100644 --- a/include/configs/lacie_kw.h +++ b/include/configs/lacie_kw.h @@ -165,11 +165,6 @@ #define CONFIG_CMD_FAT
/* - * Use the HUSH parser - */ -#define CONFIG_SYS_HUSH_PARSER - -/* * Console configuration */ #define CONFIG_CONSOLE_MUX diff --git a/include/configs/legoev3.h b/include/configs/legoev3.h index b6d4a79..ee458d3 100644 --- a/include/configs/legoev3.h +++ b/include/configs/legoev3.h @@ -155,7 +155,6 @@ #define CONFIG_SYS_LOAD_ADDR (PHYS_SDRAM_1 + 0x700000) #define CONFIG_VERSION_VARIABLE #define CONFIG_AUTO_COMPLETE -#define CONFIG_SYS_HUSH_PARSER #define CONFIG_CMDLINE_EDITING #define CONFIG_SYS_LONGHELP #define CONFIG_CRC32_VERIFY diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index 62cf6e5..134cb08 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -605,8 +605,6 @@ unsigned long get_board_ddr_clk(void); * Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " #define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE \ diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index b2e431a..4654f67 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -450,8 +450,6 @@ * Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " #define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE \ diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index e900c50..8aa557f 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -273,8 +273,6 @@ #define CONFIG_SYS_PROMPT "=> " #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ sizeof(CONFIG_SYS_PROMPT) + 16) -#define CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot args buffer */ #define CONFIG_SYS_LONGHELP #define CONFIG_CMDLINE_EDITING 1 diff --git a/include/configs/ls1043aqds.h b/include/configs/ls1043aqds.h index 7c19122..7b79295 100644 --- a/include/configs/ls1043aqds.h +++ b/include/configs/ls1043aqds.h @@ -407,8 +407,6 @@ unsigned long get_board_ddr_clk(void); */ #define CONFIG_MISC_INIT_R #define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " #define CONFIG_SYS_PROMPT "=> " #define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_PBSIZE \ diff --git a/include/configs/ls2080a_common.h b/include/configs/ls2080a_common.h index 57e2a29..aee8e5e 100644 --- a/include/configs/ls2080a_common.h +++ b/include/configs/ls2080a_common.h @@ -267,8 +267,6 @@ unsigned long long get_qixis_addr(void); #define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ sizeof(CONFIG_SYS_PROMPT) + 16) -#define CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot args buffer */ #define CONFIG_SYS_LONGHELP #define CONFIG_CMDLINE_EDITING 1 diff --git a/include/configs/lsxl.h b/include/configs/lsxl.h index 8fb0135..f9ada1a 100644 --- a/include/configs/lsxl.h +++ b/include/configs/lsxl.h @@ -39,7 +39,6 @@ #define CONFIG_KIRKWOOD_GPIO
#define CONFIG_SYS_NO_FLASH -#define CONFIG_SYS_HUSH_PARSER #define CONFIG_SYS_CONSOLE_IS_IN_ENV #define CONFIG_SYS_CONSOLE_INFO_QUIET
@@ -83,7 +82,6 @@ #define CONFIG_SF_DEFAULT_SPEED 25000000
/* * Environment variables configurations diff --git a/include/configs/lwmon5.h b/include/configs/lwmon5.h index 648e189..ebc0f8b 100644 --- a/include/configs/lwmon5.h +++ b/include/configs/lwmon5.h @@ -429,7 +429,6 @@
#if defined(CONFIG_CMD_KGDB) #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ diff --git a/include/configs/m53evk.h b/include/configs/m53evk.h index dc85768..5763ae3 100644 --- a/include/configs/m53evk.h +++ b/include/configs/m53evk.h @@ -86,7 +86,6 @@ #define CONFIG_VERSION_VARIABLE /* U-BOOT version */ #define CONFIG_AUTO_COMPLETE /* Command auto complete */ #define CONFIG_CMDLINE_EDITING /* Command history etc */ -#define CONFIG_SYS_HUSH_PARSER
/* * Serial Driver diff --git a/include/configs/malta.h b/include/configs/malta.h index aecc8ce..7f93b94 100644 --- a/include/configs/malta.h +++ b/include/configs/malta.h @@ -68,7 +68,6 @@ sizeof(CONFIG_SYS_PROMPT) + 16) #define CONFIG_SYS_MAXARGS 16
diff --git a/include/configs/mcx.h b/include/configs/mcx.h index 9a4f638..6bd6933 100644 --- a/include/configs/mcx.h +++ b/include/configs/mcx.h @@ -263,7 +263,6 @@ * Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ #define CONFIG_SYS_CBSIZE 1024/* Console I/O Buffer Size */ /* Print Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ diff --git a/include/configs/mecp5123.h b/include/configs/mecp5123.h index e561026..61a4a8e 100644 --- a/include/configs/mecp5123.h +++ b/include/configs/mecp5123.h @@ -244,10 +244,6 @@
#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ -/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER -#ifdef CONFIG_SYS_HUSH_PARSER -#endif
/* I2C */ #define CONFIG_HARD_I2C /* I2C with hardware support */ diff --git a/include/configs/meesc.h b/include/configs/meesc.h index 88fb3e8..76b2e1d 100644 --- a/include/configs/meesc.h +++ b/include/configs/meesc.h @@ -185,7 +185,6 @@ #define CONFIG_SYS_LONGHELP #define CONFIG_CMDLINE_EDITING #define CONFIG_AUTO_COMPLETE -#define CONFIG_SYS_HUSH_PARSER
/* * Size of malloc() pool diff --git a/include/configs/motionpro.h b/include/configs/motionpro.h index f4d5dbc..53907f9 100644 --- a/include/configs/motionpro.h +++ b/include/configs/motionpro.h @@ -73,8 +73,6 @@ #undef CONFIG_BOOTARGS
#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ -#define CONFIG_SYS_HUSH_PARSER 1 /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> "
#define CONFIG_VERSION_VARIABLE 1 /* include version env variable */
diff --git a/include/configs/mpc5121-common.h b/include/configs/mpc5121-common.h index 0d70e83..f06ca9c 100644 --- a/include/configs/mpc5121-common.h +++ b/include/configs/mpc5121-common.h @@ -29,7 +29,5 @@ {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200}
#endif /* __MPC5121_COMMON_H */ diff --git a/include/configs/mpc5121ads.h b/include/configs/mpc5121ads.h index 4ac291c..1b2e029 100644 --- a/include/configs/mpc5121ads.h +++ b/include/configs/mpc5121ads.h @@ -291,10 +291,6 @@ #define CONSOLE_FIFO_RX_ADDR FIFOC_PSC3_RX_ADDR
/* * Clocks in use diff --git a/include/configs/mpc8308_p1m.h b/include/configs/mpc8308_p1m.h index 1bab9ab..bf7f745 100644 --- a/include/configs/mpc8308_p1m.h +++ b/include/configs/mpc8308_p1m.h @@ -302,9 +302,6 @@ #define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_IMMR + 0x4500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_IMMR + 0x4600)
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER - /* I2C */ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_FSL diff --git a/include/configs/mx25pdk.h b/include/configs/mx25pdk.h index 6dbeeca..a85855d 100644 --- a/include/configs/mx25pdk.h +++ b/include/configs/mx25pdk.h @@ -224,7 +224,6 @@
/* Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP -#define CONFIG_SYS_HUSH_PARSER #define CONFIG_AUTO_COMPLETE
#define CONFIG_SYS_MAXARGS 16 diff --git a/include/configs/mx35pdk.h b/include/configs/mx35pdk.h index 1177b0a..f7a050e 100644 --- a/include/configs/mx35pdk.h +++ b/include/configs/mx35pdk.h @@ -133,7 +133,6 @@ */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ #define CONFIG_CMDLINE_EDITING -#define CONFIG_SYS_HUSH_PARSER /* Use the HUSH parser */
#define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ diff --git a/include/configs/mx51evk.h b/include/configs/mx51evk.h index 31cd5bb..125d25d 100644 --- a/include/configs/mx51evk.h +++ b/include/configs/mx51evk.h @@ -213,7 +213,6 @@ * Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ #define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ diff --git a/include/configs/mx53ard.h b/include/configs/mx53ard.h index 22e1b68..033a542 100644 --- a/include/configs/mx53ard.h +++ b/include/configs/mx53ard.h @@ -184,7 +184,6 @@
/* Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ #define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */
diff --git a/include/configs/mx53evk.h b/include/configs/mx53evk.h index fca567d..a41c778 100644 --- a/include/configs/mx53evk.h +++ b/include/configs/mx53evk.h @@ -131,7 +131,6 @@
diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index cfb3ae3..7f9e3b4 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -178,7 +178,6 @@
/* Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ #define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */
diff --git a/include/configs/mx53smd.h b/include/configs/mx53smd.h index 33d2163..e851da2 100644 --- a/include/configs/mx53smd.h +++ b/include/configs/mx53smd.h @@ -118,7 +118,6 @@
diff --git a/include/configs/mx6_common.h b/include/configs/mx6_common.h index 3abc773..c6996e2 100644 --- a/include/configs/mx6_common.h +++ b/include/configs/mx6_common.h @@ -81,7 +81,6 @@ /* Miscellaneous configurable options */ #undef CONFIG_CMD_IMLS #define CONFIG_SYS_LONGHELP -#define CONFIG_SYS_HUSH_PARSER #define CONFIG_CMDLINE_EDITING #define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_CBSIZE 512 diff --git a/include/configs/mx7_common.h b/include/configs/mx7_common.h index 9bd6114..05c5281 100644 --- a/include/configs/mx7_common.h +++ b/include/configs/mx7_common.h @@ -54,7 +54,6 @@ /* Miscellaneous configurable options */ #undef CONFIG_CMD_IMLS #define CONFIG_SYS_LONGHELP -#define CONFIG_SYS_HUSH_PARSER #define CONFIG_CMDLINE_EDITING #define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_CBSIZE 512 diff --git a/include/configs/mxs.h b/include/configs/mxs.h index a4ffe75..0882d5d 100644 --- a/include/configs/mxs.h +++ b/include/configs/mxs.h @@ -97,8 +97,6 @@ #define CONFIG_VERSION_VARIABLE /* U-BOOT version */ #define CONFIG_AUTO_COMPLETE /* Command auto complete */ #define CONFIG_CMDLINE_EDITING /* Command history etc */ -#define CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> "
/* Booting Linux */ #define CONFIG_CMDLINE_TAG diff --git a/include/configs/nas220.h b/include/configs/nas220.h index 36a00d3..d4bea63 100644 --- a/include/configs/nas220.h +++ b/include/configs/nas220.h @@ -54,8 +54,6 @@ #define CONFIG_SYS_LONGHELP #define CONFIG_AUTO_COMPLETE #define CONFIG_CMDLINE_EDITING -#define CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> "
/* * mv-common.h should be defined after CMD configs since it used them diff --git a/include/configs/nokia_rx51.h b/include/configs/nokia_rx51.h index 5c41405..7a1ce3c 100644 --- a/include/configs/nokia_rx51.h +++ b/include/configs/nokia_rx51.h @@ -393,8 +393,6 @@ int rx51_kp_getc(struct stdio_dev *sdev); * Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ /* Print Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ diff --git a/include/configs/o2dnt-common.h b/include/configs/o2dnt-common.h index 4ffab8a..724c33d 100644 --- a/include/configs/o2dnt-common.h +++ b/include/configs/o2dnt-common.h @@ -293,7 +293,6 @@ */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ #define CONFIG_CMDLINE_EDITING -#define CONFIG_SYS_HUSH_PARSER
#if defined(CONFIG_CMD_KGDB) #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h index 996f772..c831f36 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -41,7 +41,6 @@ * ---------------------------------------------------------------------------- */ #define CONFIG_SYS_LONGHELP -#define CONFIG_SYS_HUSH_PARSER
/* Display CPU and Board information */ #define CONFIG_DISPLAY_CPUINFO diff --git a/include/configs/omapl138_lcdk.h b/include/configs/omapl138_lcdk.h index fc7bfce..a4b26d2 100644 --- a/include/configs/omapl138_lcdk.h +++ b/include/configs/omapl138_lcdk.h @@ -190,8 +190,6 @@ #define CONFIG_SYS_LOAD_ADDR (PHYS_SDRAM_1 + 0x700000) #define CONFIG_VERSION_VARIABLE #define CONFIG_AUTO_COMPLETE -#define CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " #define CONFIG_CMDLINE_EDITING #define CONFIG_SYS_LONGHELP #define CONFIG_CRC32_VERIFY diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index 799521e..15b8164 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -662,9 +662,6 @@ #define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x4500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x4600)
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER - /* I2C */ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_FSL diff --git a/include/configs/p1_twr.h b/include/configs/p1_twr.h index 1e49ee6..732b36f 100644 --- a/include/configs/p1_twr.h +++ b/include/configs/p1_twr.h @@ -225,12 +225,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x4500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x4600)
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER -#ifdef CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " -#endif - /* I2C */ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_FSL /* Use FSL common I2C driver */ diff --git a/include/configs/pcm052.h b/include/configs/pcm052.h index 4e29cf3..edc555f 100644 --- a/include/configs/pcm052.h +++ b/include/configs/pcm052.h @@ -213,8 +213,6 @@
/* Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " #define CONFIG_AUTO_COMPLETE #define CONFIG_CMDLINE_EDITING #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ diff --git a/include/configs/picosam9g45.h b/include/configs/picosam9g45.h index b2ba6fc..54ebcba 100644 --- a/include/configs/picosam9g45.h +++ b/include/configs/picosam9g45.h @@ -160,7 +160,6 @@ #define CONFIG_SYS_LONGHELP #define CONFIG_CMDLINE_EDITING #define CONFIG_AUTO_COMPLETE -#define CONFIG_SYS_HUSH_PARSER
/* * Size of malloc() pool diff --git a/include/configs/pm9g45.h b/include/configs/pm9g45.h index ede0ee1..53fdaa7 100644 --- a/include/configs/pm9g45.h +++ b/include/configs/pm9g45.h @@ -155,7 +155,6 @@ #define CONFIG_SYS_LONGHELP 1 #define CONFIG_CMDLINE_EDITING 1 #define CONFIG_AUTO_COMPLETE -#define CONFIG_SYS_HUSH_PARSER
/* * Size of malloc() pool diff --git a/include/configs/qemu-mips.h b/include/configs/qemu-mips.h index 5a043d5..a9ecf6a 100644 --- a/include/configs/qemu-mips.h +++ b/include/configs/qemu-mips.h @@ -85,7 +85,6 @@
/* Console I/O Buffer Size */ #define CONFIG_SYS_CBSIZE 256 diff --git a/include/configs/qemu-mips64.h b/include/configs/qemu-mips64.h index 070b5de..8258bfe 100644 --- a/include/configs/qemu-mips64.h +++ b/include/configs/qemu-mips64.h @@ -87,7 +87,6 @@
/* Console I/O Buffer Size */ #define CONFIG_SYS_CBSIZE 256 diff --git a/include/configs/qemu-ppce500.h b/include/configs/qemu-ppce500.h index 293684e..5542352 100644 --- a/include/configs/qemu-ppce500.h +++ b/include/configs/qemu-ppce500.h @@ -113,10 +113,6 @@ extern unsigned long long get_phys_ccsrbar_addr_early(void); #define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x4500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x4600)
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " - /* * General PCI * Memory space is mapped 1-1, but I/O space must start from 0. diff --git a/include/configs/s5p_goni.h b/include/configs/s5p_goni.h index 8520423..916895a 100644 --- a/include/configs/s5p_goni.h +++ b/include/configs/s5p_goni.h @@ -195,7 +195,6 @@ "dfu_alt_info=" CONFIG_DFU_ALT "\0"
#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE 384 /* Print Buffer Size */ #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ diff --git a/include/configs/sandbox.h b/include/configs/sandbox.h index 2dd7fc0..d489b1d 100644 --- a/include/configs/sandbox.h +++ b/include/configs/sandbox.h @@ -65,7 +65,6 @@ #define CONFIG_MALLOC_F_ADDR 0x0010000 #define CONFIG_SYS_MALLOC_LEN (32 << 20) /* 32MB */
-#define CONFIG_SYS_HUSH_PARSER #define CONFIG_SYS_LONGHELP /* #undef to save memory */ #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #define CONFIG_SILENT_CONSOLE diff --git a/include/configs/sbc8349.h b/include/configs/sbc8349.h index b74a268..05ddb3a 100644 --- a/include/configs/sbc8349.h +++ b/include/configs/sbc8349.h @@ -279,8 +279,6 @@
/* I2C */ #define CONFIG_SYS_I2C diff --git a/include/configs/sbc8548.h b/include/configs/sbc8548.h index 56c197c..2c074a1 100644 --- a/include/configs/sbc8548.h +++ b/include/configs/sbc8548.h @@ -416,9 +416,6 @@ #define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x4500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x4600)
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER - /* * I2C */ diff --git a/include/configs/sbc8641d.h b/include/configs/sbc8641d.h index b7238fb..e3c1250 100644 --- a/include/configs/sbc8641d.h +++ b/include/configs/sbc8641d.h @@ -257,11 +257,6 @@ #define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x4500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x4600)
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER -#ifdef CONFIG_SYS_HUSH_PARSER -#endif - /* * I2C */ diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index 16f697d..481b89d 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -26,8 +26,6 @@ #define CONFIG_ENV_SIZE (0x2000) #define CONFIG_SYS_MALLOC_LEN (16 * 1024 * 1024) #define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " #define CONFIG_BOARD_LATE_INIT #define CONFIG_SYS_NO_FLASH #ifdef CONFIG_SIEMENS_MACH_TYPE diff --git a/include/configs/smartweb.h b/include/configs/smartweb.h index 42ed098..b1760cc 100644 --- a/include/configs/smartweb.h +++ b/include/configs/smartweb.h @@ -56,8 +56,6 @@ #define CONFIG_MACH_TYPE MACH_TYPE_SMARTWEB #define CONFIG_AUTO_COMPLETE #define CONFIG_ENV_OVERWRITE 1 /* Overwrite ethaddr / serial# */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " #define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_AUTOLOAD "yes" #define CONFIG_RESET_TO_RETRY diff --git a/include/configs/smdk2410.h b/include/configs/smdk2410.h index 9947dc0..34858cd 100644 --- a/include/configs/smdk2410.h +++ b/include/configs/smdk2410.h @@ -83,7 +83,6 @@ #define CONFIG_CMD_REGINFO #define CONFIG_CMD_USB
/* autoboot */ diff --git a/include/configs/smdkc100.h b/include/configs/smdkc100.h index d52f500..e1c7c67 100644 --- a/include/configs/smdkc100.h +++ b/include/configs/smdkc100.h @@ -152,7 +152,6 @@ * Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE 384 /* Print Buffer Size */ #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ diff --git a/include/configs/snapper9260.h b/include/configs/snapper9260.h index a708c68..3674e91 100644 --- a/include/configs/snapper9260.h +++ b/include/configs/snapper9260.h @@ -140,7 +140,6 @@ #define CONFIG_SYS_LONGHELP #define CONFIG_CMDLINE_EDITING #define CONFIG_AUTO_COMPLETE -#define CONFIG_SYS_HUSH_PARSER
/* U-Boot memory settings */ #define CONFIG_SYS_MALLOC_LEN (1 << 20) diff --git a/include/configs/sniper.h b/include/configs/sniper.h index 2d82a66..2785925 100644 --- a/include/configs/sniper.h +++ b/include/configs/sniper.h @@ -169,7 +169,6 @@ #define CONFIG_AUTO_COMPLETE
#define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_CBSIZE 512 diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 0c94bac..2b65241 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -68,7 +68,6 @@ #define CONFIG_VERSION_VARIABLE /* U-BOOT version */ #define CONFIG_AUTO_COMPLETE /* Command auto complete */ #define CONFIG_CMDLINE_EDITING /* Command history etc */ -#define CONFIG_SYS_HUSH_PARSER
#ifndef CONFIG_SYS_HOSTNAME #define CONFIG_SYS_HOSTNAME CONFIG_SYS_BOARD diff --git a/include/configs/socrates.h b/include/configs/socrates.h index 62be008..60f8291 100644 --- a/include/configs/socrates.h +++ b/include/configs/socrates.h @@ -207,7 +207,6 @@
#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ #define CONFIG_AUTO_COMPLETE 1 /* add autocompletion support */ -#define CONFIG_SYS_HUSH_PARSER 1 /* Use the HUSH parser */
/* diff --git a/include/configs/stm32f429-discovery.h b/include/configs/stm32f429-discovery.h index 05e2363..00f293a 100644 --- a/include/configs/stm32f429-discovery.h +++ b/include/configs/stm32f429-discovery.h @@ -89,7 +89,6 @@ * Command line configuration. */ #define CONFIG_SYS_LONGHELP -#define CONFIG_SYS_HUSH_PARSER #define CONFIG_AUTO_COMPLETE #define CONFIG_CMDLINE_EDITING
diff --git a/include/configs/stm32f746-disco.h b/include/configs/stm32f746-disco.h index e94812b..1511959 100644 --- a/include/configs/stm32f746-disco.h +++ b/include/configs/stm32f746-disco.h @@ -75,7 +75,6 @@ * Command line configuration. */ #define CONFIG_SYS_LONGHELP -#define CONFIG_SYS_HUSH_PARSER #define CONFIG_AUTO_COMPLETE #define CONFIG_CMDLINE_EDITING
diff --git a/include/configs/strider.h b/include/configs/strider.h index d5f1981..ec5fbe9 100644 --- a/include/configs/strider.h +++ b/include/configs/strider.h @@ -313,9 +313,6 @@ #define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_IMMR + 0x4500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_IMMR + 0x4600)
/* I2C */ diff --git a/include/configs/t4qds.h b/include/configs/t4qds.h index ca6d285..0eed861 100644 --- a/include/configs/t4qds.h +++ b/include/configs/t4qds.h @@ -153,10 +153,6 @@ #define CONFIG_SYS_NS16550_COM3 (CONFIG_SYS_CCSRBAR+0x11D500) #define CONFIG_SYS_NS16550_COM4 (CONFIG_SYS_CCSRBAR+0x11D600)
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " - /* I2C */ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_FSL diff --git a/include/configs/tam3517-common.h b/include/configs/tam3517-common.h index 59b6c5f..1426fbf 100644 --- a/include/configs/tam3517-common.h +++ b/include/configs/tam3517-common.h @@ -133,7 +133,6 @@ * Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ #define CONFIG_CMDLINE_EDITING #define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ diff --git a/include/configs/tao3530.h b/include/configs/tao3530.h index 73cd0a0..ee9fc7d 100644 --- a/include/configs/tao3530.h +++ b/include/configs/tao3530.h @@ -192,7 +192,6 @@ * Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */
/* turn on command-line edit/hist/auto */ diff --git a/include/configs/theadorable.h b/include/configs/theadorable.h index 5864f27..4f1a5f3 100644 --- a/include/configs/theadorable.h +++ b/include/configs/theadorable.h @@ -79,8 +79,6 @@ #define CONFIG_SYS_ALT_MEMTEST #define CONFIG_PREBOOT
-#define CONFIG_SYS_HUSH_PARSER /* Use the HUSH parser */ -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> "
/* Keep device tree and initrd in lower memory so the kernel can access them */ #define CONFIG_EXTRA_ENV_SETTINGS \ diff --git a/include/configs/thunderx_88xx.h b/include/configs/thunderx_88xx.h index 46d91e2..fc16678 100644 --- a/include/configs/thunderx_88xx.h +++ b/include/configs/thunderx_88xx.h @@ -99,7 +99,6 @@ #define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ sizeof(CONFIG_SYS_PROMPT) + 16) -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE #define CONFIG_SYS_LONGHELP #define CONFIG_CMDLINE_EDITING 1 diff --git a/include/configs/ti814x_evm.h b/include/configs/ti814x_evm.h index f00072e..9897a0b 100644 --- a/include/configs/ti814x_evm.h +++ b/include/configs/ti814x_evm.h @@ -29,7 +29,6 @@ #define CONFIG_ENV_SIZE (128 << 10) /* 128 KiB */ #define CONFIG_SYS_MALLOC_LEN (1024 << 10) #define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* Use HUSH for command parsing */ #define CONFIG_SYS_NO_FLASH #define CONFIG_MACH_TYPE MACH_TYPE_TI8148EVM
diff --git a/include/configs/ti816x_evm.h b/include/configs/ti816x_evm.h index e09efc7..b5216a8 100644 --- a/include/configs/ti816x_evm.h +++ b/include/configs/ti816x_evm.h @@ -25,7 +25,6 @@ #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (32 * 1024)) #define CONFIG_SYS_LONGHELP /* undef save memory */ -#define CONFIG_SYS_HUSH_PARSER #define CONFIG_MACH_TYPE MACH_TYPE_TI8168EVM
#define CONFIG_CMDLINE_TAG /* enable passing of ATAGs */ diff --git a/include/configs/ti_armv7_common.h b/include/configs/ti_armv7_common.h index 787d04a..d866690 100644 --- a/include/configs/ti_armv7_common.h +++ b/include/configs/ti_armv7_common.h @@ -138,7 +138,6 @@ #else #define CONFIG_SYS_MALLOC_LEN (16 << 20) #endif -#define CONFIG_SYS_HUSH_PARSER #define CONFIG_SYS_CONSOLE_INFO_QUIET #define CONFIG_BAUDRATE 115200 #define CONFIG_ENV_VARS_UBOOT_CONFIG /* Strongly encouraged */ diff --git a/include/configs/tricorder.h b/include/configs/tricorder.h index 915cbd8..73f0d84 100644 --- a/include/configs/tricorder.h +++ b/include/configs/tricorder.h @@ -279,7 +279,6 @@
/* Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ #define CONFIG_CMDLINE_EDITING /* enable cmdline history */ #define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ diff --git a/include/configs/ts4800.h b/include/configs/ts4800.h index fcc9d80..8f3963a 100644 --- a/include/configs/ts4800.h +++ b/include/configs/ts4800.h @@ -135,7 +135,6 @@ * Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ #define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ /* Print Buffer Size */ diff --git a/include/configs/usb_a9263.h b/include/configs/usb_a9263.h index 7b2f1ca..296ddcd 100644 --- a/include/configs/usb_a9263.h +++ b/include/configs/usb_a9263.h @@ -144,7 +144,6 @@ sizeof(CONFIG_SYS_PROMPT) + 16) #define CONFIG_CMDLINE_EDITING #define CONFIG_AUTO_COMPLETE -#define CONFIG_SYS_HUSH_PARSER #define CONFIG_SYS_LONGHELP
/* diff --git a/include/configs/ve8313.h b/include/configs/ve8313.h index de5c3ce..359239c 100644 --- a/include/configs/ve8313.h +++ b/include/configs/ve8313.h @@ -256,9 +256,6 @@ #define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_IMMR+0x4500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_IMMR+0x4600)
-/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER - #if defined(CONFIG_PCI) /* * General PCI diff --git a/include/configs/vexpress_aemv8a.h b/include/configs/vexpress_aemv8a.h index 31b1a24..d066a5a 100644 --- a/include/configs/vexpress_aemv8a.h +++ b/include/configs/vexpress_aemv8a.h @@ -276,7 +276,6 @@ #define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ sizeof(CONFIG_SYS_PROMPT) + 16) -#define CONFIG_SYS_HUSH_PARSER #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE #define CONFIG_SYS_LONGHELP #define CONFIG_CMDLINE_EDITING diff --git a/include/configs/vexpress_common.h b/include/configs/vexpress_common.h index d78ca0b..501b143 100644 --- a/include/configs/vexpress_common.h +++ b/include/configs/vexpress_common.h @@ -284,7 +284,6 @@ #define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ sizeof(CONFIG_SYS_PROMPT) + 16) -#define CONFIG_SYS_HUSH_PARSER
#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot args buffer */ #define CONFIG_SYS_LONGHELP diff --git a/include/configs/vf610twr.h b/include/configs/vf610twr.h index 0809fbb..65830b7 100644 --- a/include/configs/vf610twr.h +++ b/include/configs/vf610twr.h @@ -224,8 +224,6 @@
/* Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " #undef CONFIG_AUTO_COMPLETE #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE \ diff --git a/include/configs/vme8349.h b/include/configs/vme8349.h index 7433d7e..7a7c92b 100644 --- a/include/configs/vme8349.h +++ b/include/configs/vme8349.h @@ -212,8 +212,6 @@
#define CONFIG_CMDLINE_EDITING /* add command line history */ #define CONFIG_AUTO_COMPLETE /* add autocompletion support */ -/* Use the HUSH parser */ -#define CONFIG_SYS_HUSH_PARSER
/* I2C */ #define CONFIG_SYS_I2C diff --git a/include/configs/woodburn_common.h b/include/configs/woodburn_common.h index caa0434..4407557 100644 --- a/include/configs/woodburn_common.h +++ b/include/configs/woodburn_common.h @@ -132,7 +132,6 @@ */ #define CONFIG_SYS_LONGHELP /* undef to save memory */ #define CONFIG_CMDLINE_EDITING -#define CONFIG_SYS_HUSH_PARSER /* Use the HUSH parser */
#define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ diff --git a/include/configs/work_92105.h b/include/configs/work_92105.h index e9127c3..a35876f 100644 --- a/include/configs/work_92105.h +++ b/include/configs/work_92105.h @@ -110,7 +110,6 @@ #define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE
#define CONFIG_AUTO_COMPLETE #define CONFIG_CMDLINE_EDITING diff --git a/include/configs/x600.h b/include/configs/x600.h index ac477eb..9a8a7c7 100644 --- a/include/configs/x600.h +++ b/include/configs/x600.h @@ -133,8 +133,6 @@
#define CONFIG_BOOTDELAY 3
/* * U-Boot Environment placing definitions. diff --git a/include/configs/x86-common.h b/include/configs/x86-common.h index ea815c2..a596edd 100644 --- a/include/configs/x86-common.h +++ b/include/configs/x86-common.h @@ -69,7 +69,6 @@ #define CONFIG_CMDLINE_EDITING #define CONFIG_COMMAND_HISTORY #define CONFIG_AUTO_COMPLETE -#define CONFIG_SYS_HUSH_PARSER
#define CONFIG_SUPPORT_VFAT
diff --git a/include/configs/xilinx-ppc.h b/include/configs/xilinx-ppc.h index 831b940..5980acb 100644 --- a/include/configs/xilinx-ppc.h +++ b/include/configs/xilinx-ppc.h @@ -69,7 +69,6 @@ #define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ #define CONFIG_VERSION_VARIABLE /* include version env variable */ #define CONFIG_SYS_CONSOLE_INFO_QUIET /* don't print console @ startup */ -#define CONFIG_SYS_HUSH_PARSER /* Use the HUSH parser */ #define CONFIG_LOADS_ECHO /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */ #define CONFIG_SYS_BOOTMAPSZ (8 << 20) diff --git a/include/configs/xpedite1000.h b/include/configs/xpedite1000.h index 6f162dc..4f6084a 100644 --- a/include/configs/xpedite1000.h +++ b/include/configs/xpedite1000.h @@ -108,11 +108,6 @@ extern void out32(unsigned int, unsigned long); #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */
/* - * Use the HUSH parser - */ -#define CONFIG_SYS_HUSH_PARSER - -/* * NOR flash configuration */ #define CONFIG_SYS_MAX_FLASH_BANKS 3 diff --git a/include/configs/xpedite517x.h b/include/configs/xpedite517x.h index 70af1e1..18e342a 100644 --- a/include/configs/xpedite517x.h +++ b/include/configs/xpedite517x.h @@ -226,11 +226,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */
/* - * Use the HUSH parser - */ -#define CONFIG_SYS_HUSH_PARSER - -/* * I2C */ #define CONFIG_SYS_I2C diff --git a/include/configs/xpedite520x.h b/include/configs/xpedite520x.h index 1972373..7284aa2 100644 --- a/include/configs/xpedite520x.h +++ b/include/configs/xpedite520x.h @@ -189,11 +189,6 @@ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */
/* - * Use the HUSH parser - */ -#define CONFIG_SYS_HUSH_PARSER - -/* * I2C */ #define CONFIG_SYS_I2C diff --git a/include/configs/xpedite537x.h b/include/configs/xpedite537x.h index 1be043f..bdeee47 100644 --- a/include/configs/xpedite537x.h +++ b/include/configs/xpedite537x.h @@ -225,11 +225,6 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */
/* - * Use the HUSH parser - */ -#define CONFIG_SYS_HUSH_PARSER - -/* * I2C */ #define CONFIG_SYS_I2C diff --git a/include/configs/xpedite550x.h b/include/configs/xpedite550x.h index 0697714..0948035 100644 --- a/include/configs/xpedite550x.h +++ b/include/configs/xpedite550x.h @@ -215,11 +215,6 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); #define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */
-/* - * Use the HUSH parser - */ -#define CONFIG_SYS_HUSH_PARSER - #define CONFIG_FDT_FIXUP_PCI_IRQ 1
/* diff --git a/include/configs/zipitz2.h b/include/configs/zipitz2.h index 46836d5..8bb48a8 100644 --- a/include/configs/zipitz2.h +++ b/include/configs/zipitz2.h @@ -98,11 +98,6 @@ unsigned char zipitz2_spi_read(void); #endif #endif
-/* - * HUSH Shell Configuration - */ -#define CONFIG_SYS_HUSH_PARSER 1 - #define CONFIG_SYS_LONGHELP /* undef to save memory */ #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ diff --git a/include/configs/zmx25.h b/include/configs/zmx25.h index bd8fdfb..3a401f7 100644 --- a/include/configs/zmx25.h +++ b/include/configs/zmx25.h @@ -86,7 +86,6 @@ #define CONFIG_CMD_FAT #define CONFIG_CMD_USB
/* * USB diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index 23b1b2d..d535316 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -252,7 +252,6 @@ #define CONFIG_SYS_LOAD_ADDR 0 /* default? */
/* Miscellaneous configurable options */ -#define CONFIG_SYS_HUSH_PARSER
On Sun, Apr 24, 2016 at 03:16:04PM -0400, Tom Rini wrote:
Move all cases of CONFIG_SYS_HUSH_PARSER out of the config.h files. Remove all cases of CONFIG_SYS_PROMPT_HUSH_PS2 as everyone uses the default.
Signed-off-by: Tom Rini trini@konsulko.com
With CONFIG_USB_MUSB_HOST being in Kconfig, move to defconfig files.
Signed-off-by: Tom Rini trini@konsulko.com --- configs/am335x_baltos_defconfig | 1 + configs/am335x_boneblack_defconfig | 1 + configs/am335x_boneblack_vboot_defconfig | 1 + configs/am335x_evm_defconfig | 1 + configs/am335x_evm_nor_defconfig | 1 + configs/am335x_evm_norboot_defconfig | 1 + configs/am335x_evm_spiboot_defconfig | 1 + configs/am335x_evm_usbspl_defconfig | 1 + configs/am335x_gp_evm_defconfig | 1 + configs/am3517_evm_defconfig | 2 ++ configs/birdland_bav335a_defconfig | 1 + configs/birdland_bav335b_defconfig | 1 + configs/cm_t3517_defconfig | 2 ++ configs/draco_defconfig | 1 + configs/pcm051_rev1_defconfig | 1 + configs/pcm051_rev3_defconfig | 1 + configs/pengwyn_defconfig | 1 + configs/pxm2_defconfig | 1 + configs/rastaban_defconfig | 1 + configs/rut_defconfig | 1 + configs/thuban_defconfig | 1 + include/configs/am335x_evm.h | 2 -- include/configs/am3517_evm.h | 1 - include/configs/baltos.h | 2 -- include/configs/bav335x.h | 2 -- include/configs/cm_t3517.h | 1 - include/configs/pcm051.h | 1 - include/configs/pengwyn.h | 2 -- include/configs/siemens-am33x-common.h | 1 - 29 files changed, 23 insertions(+), 12 deletions(-)
diff --git a/configs/am335x_baltos_defconfig b/configs/am335x_baltos_defconfig index 51cabb4..0ddf061 100644 --- a/configs/am335x_baltos_defconfig +++ b/configs/am335x_baltos_defconfig @@ -14,6 +14,7 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y CONFIG_USB=y +CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/am335x_boneblack_defconfig b/configs/am335x_boneblack_defconfig index 7e0dcf5..79e469d 100644 --- a/configs/am335x_boneblack_defconfig +++ b/configs/am335x_boneblack_defconfig @@ -19,6 +19,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y CONFIG_USB=y +CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/am335x_boneblack_vboot_defconfig b/configs/am335x_boneblack_vboot_defconfig index e5daa94..89aba13 100644 --- a/configs/am335x_boneblack_vboot_defconfig +++ b/configs/am335x_boneblack_vboot_defconfig @@ -26,6 +26,7 @@ CONFIG_SYS_NS16550=y CONFIG_TIMER=y CONFIG_OMAP_TIMER=y CONFIG_USB=y +CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/am335x_evm_defconfig b/configs/am335x_evm_defconfig index d40a9e6..e21d98e 100644 --- a/configs/am335x_evm_defconfig +++ b/configs/am335x_evm_defconfig @@ -18,6 +18,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y CONFIG_USB=y +CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/am335x_evm_nor_defconfig b/configs/am335x_evm_nor_defconfig index aebfb58..67a048e 100644 --- a/configs/am335x_evm_nor_defconfig +++ b/configs/am335x_evm_nor_defconfig @@ -14,6 +14,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y CONFIG_USB=y +CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/am335x_evm_norboot_defconfig b/configs/am335x_evm_norboot_defconfig index bc4f667..332f37f 100644 --- a/configs/am335x_evm_norboot_defconfig +++ b/configs/am335x_evm_norboot_defconfig @@ -11,6 +11,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y CONFIG_USB=y +CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/am335x_evm_spiboot_defconfig b/configs/am335x_evm_spiboot_defconfig index 346def4..4b30503 100644 --- a/configs/am335x_evm_spiboot_defconfig +++ b/configs/am335x_evm_spiboot_defconfig @@ -14,6 +14,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y CONFIG_USB=y +CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/am335x_evm_usbspl_defconfig b/configs/am335x_evm_usbspl_defconfig index c457f6f..7ed400b 100644 --- a/configs/am335x_evm_usbspl_defconfig +++ b/configs/am335x_evm_usbspl_defconfig @@ -14,6 +14,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y CONFIG_USB=y +CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/am335x_gp_evm_defconfig b/configs/am335x_gp_evm_defconfig index 554af51..9859189 100644 --- a/configs/am335x_gp_evm_defconfig +++ b/configs/am335x_gp_evm_defconfig @@ -20,6 +20,7 @@ CONFIG_SYS_NS16550=y CONFIG_TIMER=y CONFIG_OMAP_TIMER=y CONFIG_USB=y +CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index b9edf0d..1e0b35a 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -13,4 +13,6 @@ CONFIG_SYS_PROMPT="AM3517_EVM # " CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y +CONFIG_USB=y +CONFIG_USB_MUSB_HOST=y CONFIG_OF_LIBFDT=y diff --git a/configs/birdland_bav335a_defconfig b/configs/birdland_bav335a_defconfig index 1e22f5c..5d1c0dc 100644 --- a/configs/birdland_bav335a_defconfig +++ b/configs/birdland_bav335a_defconfig @@ -13,6 +13,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y CONFIG_USB=y +CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/birdland_bav335b_defconfig b/configs/birdland_bav335b_defconfig index c024d03..a4aa6d9 100644 --- a/configs/birdland_bav335b_defconfig +++ b/configs/birdland_bav335b_defconfig @@ -13,6 +13,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y CONFIG_USB=y +CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/cm_t3517_defconfig b/configs/cm_t3517_defconfig index ea3e492..80a7c34 100644 --- a/configs/cm_t3517_defconfig +++ b/configs/cm_t3517_defconfig @@ -9,4 +9,6 @@ CONFIG_SYS_PROMPT="CM-T3517 # " CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y +CONFIG_USB=y +CONFIG_USB_MUSB_HOST=y CONFIG_OF_LIBFDT=y diff --git a/configs/draco_defconfig b/configs/draco_defconfig index abbc636..1b3aea5 100644 --- a/configs/draco_defconfig +++ b/configs/draco_defconfig @@ -14,6 +14,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y CONFIG_USB=y +CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/pcm051_rev1_defconfig b/configs/pcm051_rev1_defconfig index ee729b1..c97faf0 100644 --- a/configs/pcm051_rev1_defconfig +++ b/configs/pcm051_rev1_defconfig @@ -11,6 +11,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y CONFIG_USB=y +CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_GADGET=y CONFIG_OF_LIBFDT=y diff --git a/configs/pcm051_rev3_defconfig b/configs/pcm051_rev3_defconfig index 632e764..63ef0bb 100644 --- a/configs/pcm051_rev3_defconfig +++ b/configs/pcm051_rev3_defconfig @@ -11,6 +11,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y CONFIG_USB=y +CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_GADGET=y CONFIG_OF_LIBFDT=y diff --git a/configs/pengwyn_defconfig b/configs/pengwyn_defconfig index d04471b..4aead9e 100644 --- a/configs/pengwyn_defconfig +++ b/configs/pengwyn_defconfig @@ -8,6 +8,7 @@ CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y CONFIG_USB=y +CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_GADGET=y CONFIG_OF_LIBFDT=y diff --git a/configs/pxm2_defconfig b/configs/pxm2_defconfig index 95ab0a3..cd8996a 100644 --- a/configs/pxm2_defconfig +++ b/configs/pxm2_defconfig @@ -15,6 +15,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y CONFIG_USB=y +CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/rastaban_defconfig b/configs/rastaban_defconfig index c6a1130..a3d2b86 100644 --- a/configs/rastaban_defconfig +++ b/configs/rastaban_defconfig @@ -14,6 +14,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y CONFIG_USB=y +CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/rut_defconfig b/configs/rut_defconfig index d7b47e2..7526426 100644 --- a/configs/rut_defconfig +++ b/configs/rut_defconfig @@ -15,6 +15,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y CONFIG_USB=y +CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/thuban_defconfig b/configs/thuban_defconfig index c051460..c81e411 100644 --- a/configs/thuban_defconfig +++ b/configs/thuban_defconfig @@ -14,6 +14,7 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y CONFIG_USB=y +CONFIG_USB_MUSB_HOST=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 1b1684d..55f8dc5 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -287,7 +287,6 @@ #define CONFIG_ARCH_MISC_INIT #define CONFIG_USB_MUSB_PIO_ONLY #define CONFIG_USB_MUSB_DISABLE_BULK_COMBINE_SPLIT -#define CONFIG_USB_MUSB_HOST #define CONFIG_AM335X_USB0 #define CONFIG_AM335X_USB0_MODE MUSB_PERIPHERAL #define CONFIG_AM335X_USB1 @@ -337,7 +336,6 @@ #define CONFIG_ENV_IS_NOWHERE #undef CONFIG_ENV_IS_IN_NAND /* disable host part of MUSB in SPL */ -#undef CONFIG_USB_MUSB_HOST /* disable EFI partitions and partition UUID support */ #undef CONFIG_PARTITION_UUIDS #undef CONFIG_EFI_PARTITION diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index f33c7b7..45f016a 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -94,7 +94,6 @@ * Enable CONFIG_USB_MUSB_GADGET for Device functionalities. */ #define CONFIG_USB_MUSB_AM35X -#define CONFIG_USB_MUSB_HOST #define CONFIG_USB_MUSB_PIO_ONLY
#ifdef CONFIG_USB_MUSB_AM35X diff --git a/include/configs/baltos.h b/include/configs/baltos.h index 48d0613..23d0bb7 100644 --- a/include/configs/baltos.h +++ b/include/configs/baltos.h @@ -273,7 +273,6 @@ #define CONFIG_ARCH_MISC_INIT #define CONFIG_USB_MUSB_PIO_ONLY #define CONFIG_USB_MUSB_DISABLE_BULK_COMBINE_SPLIT -#define CONFIG_USB_MUSB_HOST #define CONFIG_AM335X_USB0 #define CONFIG_AM335X_USB0_MODE MUSB_HOST #define CONFIG_AM335X_USB1 @@ -292,7 +291,6 @@
#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_USBETH_SUPPORT) /* disable host part of MUSB in SPL */ -#undef CONFIG_USB_MUSB_HOST /* disable EFI partitions and partition UUID support */ #undef CONFIG_PARTITION_UUIDS #undef CONFIG_EFI_PARTITION diff --git a/include/configs/bav335x.h b/include/configs/bav335x.h index 2c0ec9d..44ac2da 100644 --- a/include/configs/bav335x.h +++ b/include/configs/bav335x.h @@ -438,7 +438,6 @@ DEFAULT_LINUX_BOOT_ENV \ #define CONFIG_ARCH_MISC_INIT #define CONFIG_USB_MUSB_PIO_ONLY #define CONFIG_USB_MUSB_DISABLE_BULK_COMBINE_SPLIT -#define CONFIG_USB_MUSB_HOST #define CONFIG_AM335X_USB0 #define CONFIG_AM335X_USB0_MODE MUSB_PERIPHERAL #define CONFIG_AM335X_USB1 @@ -469,7 +468,6 @@ DEFAULT_LINUX_BOOT_ENV \
#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_USBETH_SUPPORT) /* disable host part of MUSB in SPL */ -#undef CONFIG_USB_MUSB_HOST /* disable EFI partitions and partition UUID support */ #undef CONFIG_PARTITION_UUIDS #undef CONFIG_EFI_PARTITION diff --git a/include/configs/cm_t3517.h b/include/configs/cm_t3517.h index ca0b47e..553b648 100644 --- a/include/configs/cm_t3517.h +++ b/include/configs/cm_t3517.h @@ -113,7 +113,6 @@ #define CONFIG_OMAP_EHCI_PHY1_RESET_GPIO 146 #define CONFIG_OMAP_EHCI_PHY2_RESET_GPIO 147 #else /* !CONFIG_USB_MUSB_AM35X */ -#define CONFIG_USB_MUSB_HOST #define CONFIG_USB_MUSB_PIO_ONLY #endif /* CONFIG_USB_MUSB_AM35X */
diff --git a/include/configs/pcm051.h b/include/configs/pcm051.h index 3e66c19..4638c25 100644 --- a/include/configs/pcm051.h +++ b/include/configs/pcm051.h @@ -142,7 +142,6 @@ #define CONFIG_USB_MUSB_DSPS #define CONFIG_ARCH_MISC_INIT #define CONFIG_USB_MUSB_PIO_ONLY -#define CONFIG_USB_MUSB_HOST #define CONFIG_AM335X_USB0 #define CONFIG_AM335X_USB0_MODE MUSB_PERIPHERAL #define CONFIG_AM335X_USB1 diff --git a/include/configs/pengwyn.h b/include/configs/pengwyn.h index 8977115..b75dbee 100644 --- a/include/configs/pengwyn.h +++ b/include/configs/pengwyn.h @@ -198,7 +198,6 @@ #define CONFIG_ARCH_MISC_INIT #define CONFIG_USB_MUSB_PIO_ONLY #define CONFIG_USB_MUSB_DISABLE_BULK_COMBINE_SPLIT -#define CONFIG_USB_MUSB_HOST #define CONFIG_AM335X_USB0 #define CONFIG_AM335X_USB0_MODE MUSB_PERIPHERAL #define CONFIG_AM335X_USB1 @@ -211,7 +210,6 @@
#if defined(CONFIG_SPL_BUILD) /* disable host part of MUSB in SPL */ -#undef CONFIG_USB_MUSB_HOST /* Disable CPSW SPL support so we fit within the 101KiB limit. */ #undef CONFIG_SPL_ETH_SUPPORT #endif diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index 481b89d..6af373e 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -222,7 +222,6 @@ #define CONFIG_USB_MUSB_PIO_ONLY #define CONFIG_USB_MUSB_DISABLE_BULK_COMBINE_SPLIT #undef CONFIG_USB_GADGET_DUALSPEED -#define CONFIG_USB_MUSB_HOST
This syncs up the current cmd/Kconfig and include/configs/ files with the only exception being CMD_NAND. Due to how we have used this historically we need to take further care here when converting.
Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/include/asm/arch-bcmcygnus/configs.h | 1 - arch/blackfin/include/asm/config.h | 3 --- cmd/Kconfig | 2 +- configs/A10-OLinuXino-Lime_defconfig | 3 +++ configs/A10s-OLinuXino-M_defconfig | 3 +++ configs/A13-OLinuXinoM_defconfig | 3 +++ configs/A13-OLinuXino_defconfig | 3 +++ configs/A20-OLinuXino-Lime2_defconfig | 3 +++ configs/A20-OLinuXino-Lime_defconfig | 3 +++ configs/A20-OLinuXino_MICRO_defconfig | 3 +++ configs/A20-Olimex-SOM-EVB_defconfig | 3 +++ configs/Ainol_AW1_defconfig | 3 +++ configs/Ampe_A76_defconfig | 3 +++ configs/Auxtek-T003_defconfig | 3 +++ configs/Auxtek-T004_defconfig | 3 +++ configs/B4420QDS_NAND_defconfig | 5 +++++ configs/B4420QDS_SPIFLASH_defconfig | 5 +++++ configs/B4420QDS_defconfig | 5 +++++ configs/B4860QDS_NAND_defconfig | 5 +++++ configs/B4860QDS_SECURE_BOOT_defconfig | 5 +++++ configs/B4860QDS_SPIFLASH_defconfig | 5 +++++ configs/B4860QDS_SRIO_PCIE_BOOT_defconfig | 5 +++++ configs/B4860QDS_defconfig | 5 +++++ configs/BSC9131RDB_NAND_SYSCLK100_defconfig | 5 +++++ configs/BSC9131RDB_NAND_defconfig | 5 +++++ configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig | 5 +++++ configs/BSC9131RDB_SPIFLASH_defconfig | 5 +++++ configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig | 5 +++++ configs/BSC9132QDS_NAND_DDRCLK100_defconfig | 5 +++++ configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig | 5 +++++ configs/BSC9132QDS_NAND_DDRCLK133_defconfig | 5 +++++ configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig | 5 +++++ configs/BSC9132QDS_NOR_DDRCLK100_defconfig | 5 +++++ configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig | 5 +++++ configs/BSC9132QDS_NOR_DDRCLK133_defconfig | 5 +++++ configs/BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig | 5 +++++ configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig | 5 +++++ configs/BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig | 5 +++++ configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig | 5 +++++ configs/BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig | 5 +++++ configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig | 5 +++++ configs/BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig | 5 +++++ configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig | 5 +++++ configs/Bananapi_defconfig | 3 +++ configs/Bananapro_defconfig | 3 +++ configs/C29XPCIE_NAND_defconfig | 3 +++ configs/C29XPCIE_NOR_SECBOOT_defconfig | 3 +++ configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig | 3 +++ configs/C29XPCIE_SPIFLASH_defconfig | 3 +++ configs/C29XPCIE_defconfig | 3 +++ configs/CHIP_defconfig | 3 +++ configs/CPCI2DP_defconfig | 2 ++ configs/CPCI4052_defconfig | 4 ++++ configs/CSQ_CS908_defconfig | 2 ++ configs/Chuwi_V7_CW0825_defconfig | 3 +++ configs/Colombus_defconfig | 3 +++ configs/Cubieboard2_defconfig | 3 +++ configs/Cubieboard_defconfig | 3 +++ configs/Cubietruck_defconfig | 3 +++ configs/Cubietruck_plus_defconfig | 3 +++ configs/Cyrus_P5020_defconfig | 4 ++++ configs/Cyrus_P5040_defconfig | 4 ++++ configs/Empire_electronix_d709_defconfig | 3 +++ configs/Hummingbird_A31_defconfig | 2 ++ configs/Hyundai_A7HD_defconfig | 3 +++ configs/Itead_Ibox_A20_defconfig | 3 +++ configs/Lamobo_R1_defconfig | 3 +++ configs/Linksprite_pcDuino3_Nano_defconfig | 3 +++ configs/Linksprite_pcDuino3_defconfig | 3 +++ configs/Linksprite_pcDuino_defconfig | 3 +++ configs/M5208EVBE_defconfig | 1 + configs/M52277EVB_defconfig | 3 +++ configs/M52277EVB_stmicro_defconfig | 3 +++ configs/M5235EVB_Flash32_defconfig | 3 +++ configs/M5235EVB_defconfig | 3 +++ configs/M5249EVB_defconfig | 1 + configs/M5253DEMO_defconfig | 1 + configs/M5272C3_defconfig | 1 + configs/M5275EVB_defconfig | 3 +++ configs/M5282EVB_defconfig | 1 + configs/M53017EVB_defconfig | 1 + configs/M5329AFEE_defconfig | 2 ++ configs/M5329BFEE_defconfig | 2 ++ configs/M5373EVB_defconfig | 2 ++ configs/M54418TWR_defconfig | 4 ++++ configs/M54418TWR_nand_mii_defconfig | 4 ++++ configs/M54418TWR_nand_rmii_defconfig | 4 ++++ configs/M54418TWR_nand_rmii_lowfreq_defconfig | 4 ++++ configs/M54418TWR_serial_mii_defconfig | 4 ++++ configs/M54418TWR_serial_rmii_defconfig | 4 ++++ configs/M54451EVB_defconfig | 5 +++++ configs/M54451EVB_stmicro_defconfig | 5 +++++ configs/M54455EVB_a66_defconfig | 5 +++++ configs/M54455EVB_defconfig | 5 +++++ configs/M54455EVB_i66_defconfig | 5 +++++ configs/M54455EVB_intel_defconfig | 5 +++++ configs/M54455EVB_stm33_defconfig | 5 +++++ configs/M5475AFE_defconfig | 3 +++ configs/M5475BFE_defconfig | 3 +++ configs/M5475CFE_defconfig | 3 +++ configs/M5475DFE_defconfig | 3 +++ configs/M5475EFE_defconfig | 3 +++ configs/M5475FFE_defconfig | 3 +++ configs/M5475GFE_defconfig | 3 +++ configs/M5485AFE_defconfig | 3 +++ configs/M5485BFE_defconfig | 3 +++ configs/M5485CFE_defconfig | 3 +++ configs/M5485DFE_defconfig | 3 +++ configs/M5485EFE_defconfig | 3 +++ configs/M5485FFE_defconfig | 3 +++ configs/M5485GFE_defconfig | 3 +++ configs/M5485HFE_defconfig | 3 +++ configs/MIP405T_defconfig | 3 +++ configs/MIP405_defconfig | 4 ++++ configs/MK808C_defconfig | 3 +++ configs/MPC8308RDB_defconfig | 3 +++ configs/MPC8313ERDB_33_defconfig | 3 +++ configs/MPC8313ERDB_66_defconfig | 3 +++ configs/MPC8313ERDB_NAND_33_defconfig | 3 +++ configs/MPC8313ERDB_NAND_66_defconfig | 3 +++ configs/MPC8315ERDB_defconfig | 3 +++ configs/MPC8323ERDB_defconfig | 2 ++ configs/MPC832XEMDS_ATM_defconfig | 2 ++ configs/MPC832XEMDS_HOST_33_defconfig | 2 ++ configs/MPC832XEMDS_HOST_66_defconfig | 2 ++ configs/MPC832XEMDS_SLAVE_defconfig | 2 ++ configs/MPC832XEMDS_defconfig | 2 ++ configs/MPC8349EMDS_defconfig | 2 ++ configs/MPC8349ITXGP_defconfig | 3 +++ configs/MPC8349ITX_LOWBOOT_defconfig | 4 ++++ configs/MPC8349ITX_defconfig | 4 ++++ configs/MPC837XEMDS_HOST_defconfig | 3 +++ configs/MPC837XEMDS_defconfig | 2 ++ configs/MPC837XERDB_defconfig | 3 +++ configs/MPC8536DS_36BIT_defconfig | 4 ++++ configs/MPC8536DS_SDCARD_defconfig | 4 ++++ configs/MPC8536DS_SPIFLASH_defconfig | 4 ++++ configs/MPC8536DS_defconfig | 4 ++++ configs/MPC8540ADS_defconfig | 2 ++ configs/MPC8541CDS_defconfig | 2 ++ configs/MPC8541CDS_legacy_defconfig | 2 ++ configs/MPC8544DS_defconfig | 3 +++ configs/MPC8548CDS_36BIT_defconfig | 2 ++ configs/MPC8548CDS_defconfig | 2 ++ configs/MPC8548CDS_legacy_defconfig | 2 ++ configs/MPC8555CDS_defconfig | 2 ++ configs/MPC8555CDS_legacy_defconfig | 2 ++ configs/MPC8560ADS_defconfig | 2 ++ configs/MPC8568MDS_defconfig | 2 ++ configs/MPC8569MDS_ATM_defconfig | 2 ++ configs/MPC8569MDS_defconfig | 2 ++ configs/MPC8572DS_36BIT_defconfig | 3 +++ configs/MPC8572DS_defconfig | 3 +++ configs/MPC8610HPCD_defconfig | 3 +++ configs/MPC8641HPCN_36BIT_defconfig | 3 +++ configs/MPC8641HPCN_defconfig | 3 +++ configs/MSI_Primo73_defconfig | 3 +++ configs/MSI_Primo81_defconfig | 2 ++ configs/Marsboard_A10_defconfig | 3 +++ configs/Mele_A1000G_quad_defconfig | 2 ++ configs/Mele_A1000_defconfig | 3 +++ configs/Mele_I7_defconfig | 2 ++ configs/Mele_M3_defconfig | 3 +++ configs/Mele_M5_defconfig | 3 +++ configs/Mele_M9_defconfig | 2 ++ configs/Merrii_A80_Optimus_defconfig | 2 ++ configs/MigoR_defconfig | 1 + configs/Mini-X_defconfig | 3 +++ configs/MiniFAP_defconfig | 6 ++++++ configs/O2D300_defconfig | 3 +++ configs/O2DNT2_RAMBOOT_defconfig | 3 +++ configs/O2DNT2_defconfig | 3 +++ configs/O2D_defconfig | 3 +++ configs/O2I_defconfig | 3 +++ configs/O2MNT_O2M110_defconfig | 3 +++ configs/O2MNT_O2M112_defconfig | 3 +++ configs/O2MNT_O2M113_defconfig | 3 +++ configs/O2MNT_defconfig | 3 +++ configs/O3DNT_defconfig | 3 +++ configs/Orangepi_defconfig | 3 +++ configs/Orangepi_mini_defconfig | 3 +++ configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig | 4 ++++ configs/P1010RDB-PA_36BIT_NAND_defconfig | 4 ++++ configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig | 4 ++++ configs/P1010RDB-PA_36BIT_NOR_defconfig | 4 ++++ configs/P1010RDB-PA_36BIT_SDCARD_defconfig | 4 ++++ configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig | 4 ++++ configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig | 4 ++++ configs/P1010RDB-PA_NAND_SECBOOT_defconfig | 4 ++++ configs/P1010RDB-PA_NAND_defconfig | 4 ++++ configs/P1010RDB-PA_NOR_SECBOOT_defconfig | 4 ++++ configs/P1010RDB-PA_NOR_defconfig | 4 ++++ configs/P1010RDB-PA_SDCARD_defconfig | 4 ++++ configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig | 4 ++++ configs/P1010RDB-PA_SPIFLASH_defconfig | 4 ++++ configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig | 4 ++++ configs/P1010RDB-PB_36BIT_NAND_defconfig | 4 ++++ configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig | 4 ++++ configs/P1010RDB-PB_36BIT_NOR_defconfig | 4 ++++ configs/P1010RDB-PB_36BIT_SDCARD_defconfig | 4 ++++ configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig | 4 ++++ configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig | 4 ++++ configs/P1010RDB-PB_NAND_SECBOOT_defconfig | 4 ++++ configs/P1010RDB-PB_NAND_defconfig | 4 ++++ configs/P1010RDB-PB_NOR_SECBOOT_defconfig | 4 ++++ configs/P1010RDB-PB_NOR_defconfig | 4 ++++ configs/P1010RDB-PB_SDCARD_defconfig | 4 ++++ configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig | 4 ++++ configs/P1010RDB-PB_SPIFLASH_defconfig | 4 ++++ configs/P1020MBG-PC_36BIT_SDCARD_defconfig | 3 +++ configs/P1020MBG-PC_36BIT_defconfig | 3 +++ configs/P1020MBG-PC_SDCARD_defconfig | 3 +++ configs/P1020MBG-PC_defconfig | 3 +++ configs/P1020RDB-PC_36BIT_NAND_defconfig | 4 ++++ configs/P1020RDB-PC_36BIT_SDCARD_defconfig | 4 ++++ configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig | 4 ++++ configs/P1020RDB-PC_36BIT_defconfig | 4 ++++ configs/P1020RDB-PC_NAND_defconfig | 4 ++++ configs/P1020RDB-PC_SDCARD_defconfig | 4 ++++ configs/P1020RDB-PC_SPIFLASH_defconfig | 4 ++++ configs/P1020RDB-PC_defconfig | 4 ++++ configs/P1020RDB-PD_NAND_defconfig | 4 ++++ configs/P1020RDB-PD_SDCARD_defconfig | 4 ++++ configs/P1020RDB-PD_SPIFLASH_defconfig | 4 ++++ configs/P1020RDB-PD_defconfig | 4 ++++ configs/P1020UTM-PC_36BIT_SDCARD_defconfig | 3 +++ configs/P1020UTM-PC_36BIT_defconfig | 3 +++ configs/P1020UTM-PC_SDCARD_defconfig | 3 +++ configs/P1020UTM-PC_defconfig | 3 +++ configs/P1021RDB-PC_36BIT_NAND_defconfig | 4 ++++ configs/P1021RDB-PC_36BIT_SDCARD_defconfig | 4 ++++ configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig | 4 ++++ configs/P1021RDB-PC_36BIT_defconfig | 4 ++++ configs/P1021RDB-PC_NAND_defconfig | 4 ++++ configs/P1021RDB-PC_SDCARD_defconfig | 4 ++++ configs/P1021RDB-PC_SPIFLASH_defconfig | 4 ++++ configs/P1021RDB-PC_defconfig | 4 ++++ configs/P1022DS_36BIT_NAND_defconfig | 4 ++++ configs/P1022DS_36BIT_SDCARD_defconfig | 4 ++++ configs/P1022DS_36BIT_SPIFLASH_defconfig | 4 ++++ configs/P1022DS_36BIT_defconfig | 4 ++++ configs/P1022DS_NAND_defconfig | 4 ++++ configs/P1022DS_SDCARD_defconfig | 4 ++++ configs/P1022DS_SPIFLASH_defconfig | 4 ++++ configs/P1022DS_defconfig | 4 ++++ configs/P1023RDB_defconfig | 3 +++ configs/P1024RDB_36BIT_defconfig | 4 ++++ configs/P1024RDB_NAND_defconfig | 4 ++++ configs/P1024RDB_SDCARD_defconfig | 4 ++++ configs/P1024RDB_SPIFLASH_defconfig | 4 ++++ configs/P1024RDB_defconfig | 4 ++++ configs/P1025RDB_36BIT_defconfig | 4 ++++ configs/P1025RDB_NAND_defconfig | 4 ++++ configs/P1025RDB_SDCARD_defconfig | 4 ++++ configs/P1025RDB_SPIFLASH_defconfig | 4 ++++ configs/P1025RDB_defconfig | 4 ++++ configs/P2020RDB-PC_36BIT_NAND_defconfig | 4 ++++ configs/P2020RDB-PC_36BIT_SDCARD_defconfig | 4 ++++ configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig | 4 ++++ configs/P2020RDB-PC_36BIT_defconfig | 4 ++++ configs/P2020RDB-PC_NAND_defconfig | 4 ++++ configs/P2020RDB-PC_SDCARD_defconfig | 4 ++++ configs/P2020RDB-PC_SPIFLASH_defconfig | 4 ++++ configs/P2020RDB-PC_defconfig | 4 ++++ configs/P2041RDB_NAND_defconfig | 5 +++++ configs/P2041RDB_SDCARD_defconfig | 5 +++++ configs/P2041RDB_SECURE_BOOT_defconfig | 5 +++++ configs/P2041RDB_SPIFLASH_defconfig | 5 +++++ configs/P2041RDB_SRIO_PCIE_BOOT_defconfig | 5 +++++ configs/P2041RDB_defconfig | 5 +++++ configs/P3041DS_NAND_SECURE_BOOT_defconfig | 5 +++++ configs/P3041DS_NAND_defconfig | 5 +++++ configs/P3041DS_SDCARD_defconfig | 5 +++++ configs/P3041DS_SECURE_BOOT_defconfig | 5 +++++ configs/P3041DS_SPIFLASH_defconfig | 5 +++++ configs/P3041DS_SRIO_PCIE_BOOT_defconfig | 5 +++++ configs/P3041DS_defconfig | 5 +++++ configs/P4080DS_SDCARD_defconfig | 5 +++++ configs/P4080DS_SECURE_BOOT_defconfig | 5 +++++ configs/P4080DS_SPIFLASH_defconfig | 5 +++++ configs/P4080DS_SRIO_PCIE_BOOT_defconfig | 5 +++++ configs/P4080DS_defconfig | 5 +++++ configs/P5020DS_NAND_SECURE_BOOT_defconfig | 5 +++++ configs/P5020DS_NAND_defconfig | 5 +++++ configs/P5020DS_SDCARD_defconfig | 5 +++++ configs/P5020DS_SECURE_BOOT_defconfig | 5 +++++ configs/P5020DS_SPIFLASH_defconfig | 5 +++++ configs/P5020DS_SRIO_PCIE_BOOT_defconfig | 5 +++++ configs/P5020DS_defconfig | 5 +++++ configs/P5040DS_NAND_SECURE_BOOT_defconfig | 5 +++++ configs/P5040DS_NAND_defconfig | 5 +++++ configs/P5040DS_SDCARD_defconfig | 5 +++++ configs/P5040DS_SECURE_BOOT_defconfig | 5 +++++ configs/P5040DS_SPIFLASH_defconfig | 5 +++++ configs/P5040DS_defconfig | 5 +++++ configs/PIP405_defconfig | 4 ++++ configs/PLU405_defconfig | 4 ++++ configs/PMC405DE_defconfig | 4 ++++ configs/PMC440_defconfig | 5 +++++ configs/Sinlinx_SinA31s_defconfig | 2 ++ configs/Sinlinx_SinA33_defconfig | 2 ++ configs/Sinovoip_BPI_M2_defconfig | 2 ++ configs/Sinovoip_BPI_M3_defconfig | 2 ++ configs/T1023RDB_NAND_defconfig | 6 ++++++ configs/T1023RDB_SDCARD_defconfig | 6 ++++++ configs/T1023RDB_SECURE_BOOT_defconfig | 6 ++++++ configs/T1023RDB_SPIFLASH_defconfig | 6 ++++++ configs/T1023RDB_defconfig | 6 ++++++ configs/T1024QDS_DDR4_SECURE_BOOT_defconfig | 5 +++++ configs/T1024QDS_DDR4_defconfig | 5 +++++ configs/T1024QDS_NAND_defconfig | 5 +++++ configs/T1024QDS_SDCARD_defconfig | 5 +++++ configs/T1024QDS_SECURE_BOOT_defconfig | 5 +++++ configs/T1024QDS_SPIFLASH_defconfig | 5 +++++ configs/T1024QDS_defconfig | 5 +++++ configs/T1024RDB_NAND_defconfig | 6 ++++++ configs/T1024RDB_SDCARD_defconfig | 6 ++++++ configs/T1024RDB_SECURE_BOOT_defconfig | 6 ++++++ configs/T1024RDB_SPIFLASH_defconfig | 6 ++++++ configs/T1024RDB_defconfig | 6 ++++++ configs/T1040D4RDB_NAND_defconfig | 5 +++++ configs/T1040D4RDB_SDCARD_defconfig | 5 +++++ configs/T1040D4RDB_SECURE_BOOT_defconfig | 5 +++++ configs/T1040D4RDB_SPIFLASH_defconfig | 5 +++++ configs/T1040D4RDB_defconfig | 5 +++++ configs/T1040QDS_DDR4_defconfig | 5 +++++ configs/T1040QDS_SECURE_BOOT_defconfig | 5 +++++ configs/T1040QDS_defconfig | 5 +++++ configs/T1040RDB_NAND_defconfig | 5 +++++ configs/T1040RDB_SDCARD_defconfig | 5 +++++ configs/T1040RDB_SECURE_BOOT_defconfig | 5 +++++ configs/T1040RDB_SPIFLASH_defconfig | 5 +++++ configs/T1040RDB_defconfig | 5 +++++ configs/T1042D4RDB_NAND_defconfig | 5 +++++ configs/T1042D4RDB_SDCARD_defconfig | 5 +++++ configs/T1042D4RDB_SECURE_BOOT_defconfig | 5 +++++ configs/T1042D4RDB_SPIFLASH_defconfig | 5 +++++ configs/T1042D4RDB_defconfig | 5 +++++ configs/T1042RDB_PI_NAND_defconfig | 5 +++++ configs/T1042RDB_PI_SDCARD_defconfig | 5 +++++ configs/T1042RDB_PI_SPIFLASH_defconfig | 5 +++++ configs/T1042RDB_PI_defconfig | 5 +++++ configs/T1042RDB_SECURE_BOOT_defconfig | 5 +++++ configs/T1042RDB_defconfig | 5 +++++ configs/T2080QDS_NAND_defconfig | 5 +++++ configs/T2080QDS_SDCARD_defconfig | 5 +++++ configs/T2080QDS_SECURE_BOOT_defconfig | 5 +++++ configs/T2080QDS_SPIFLASH_defconfig | 5 +++++ configs/T2080QDS_SRIO_PCIE_BOOT_defconfig | 5 +++++ configs/T2080QDS_defconfig | 5 +++++ configs/T2080RDB_NAND_defconfig | 6 ++++++ configs/T2080RDB_SDCARD_defconfig | 6 ++++++ configs/T2080RDB_SECURE_BOOT_defconfig | 6 ++++++ configs/T2080RDB_SPIFLASH_defconfig | 6 ++++++ configs/T2080RDB_SRIO_PCIE_BOOT_defconfig | 6 ++++++ configs/T2080RDB_defconfig | 6 ++++++ configs/T2081QDS_NAND_defconfig | 5 +++++ configs/T2081QDS_SDCARD_defconfig | 5 +++++ configs/T2081QDS_SPIFLASH_defconfig | 5 +++++ configs/T2081QDS_SRIO_PCIE_BOOT_defconfig | 5 +++++ configs/T2081QDS_defconfig | 5 +++++ configs/T4160QDS_NAND_defconfig | 5 +++++ configs/T4160QDS_SDCARD_defconfig | 5 +++++ configs/T4160QDS_SECURE_BOOT_defconfig | 5 +++++ configs/T4160QDS_defconfig | 5 +++++ configs/T4160RDB_defconfig | 5 +++++ configs/T4240QDS_NAND_defconfig | 5 +++++ configs/T4240QDS_SDCARD_defconfig | 5 +++++ configs/T4240QDS_SECURE_BOOT_defconfig | 5 +++++ configs/T4240QDS_SRIO_PCIE_BOOT_defconfig | 5 +++++ configs/T4240QDS_defconfig | 5 +++++ configs/T4240RDB_SDCARD_defconfig | 5 +++++ configs/T4240RDB_defconfig | 5 +++++ configs/TQM5200S_HIGHBOOT_defconfig | 6 ++++++ configs/TQM5200S_defconfig | 6 ++++++ configs/TQM5200_B_HIGHBOOT_defconfig | 6 ++++++ configs/TQM5200_B_defconfig | 6 ++++++ configs/TQM5200_STK100_defconfig | 6 ++++++ configs/TQM5200_defconfig | 6 ++++++ configs/TQM823L_LCD_defconfig | 2 ++ configs/TQM823L_defconfig | 2 ++ configs/TQM823M_defconfig | 2 ++ configs/TQM834x_defconfig | 4 ++++ configs/TQM850L_defconfig | 2 ++ configs/TQM850M_defconfig | 2 ++ configs/TQM855L_defconfig | 2 ++ configs/TQM855M_defconfig | 2 ++ configs/TQM860L_defconfig | 2 ++ configs/TQM860M_defconfig | 2 ++ configs/TQM862L_defconfig | 2 ++ configs/TQM862M_defconfig | 2 ++ configs/TQM866M_defconfig | 2 ++ configs/TQM885D_defconfig | 4 ++++ configs/TTTech_defconfig | 2 ++ configs/TWR-P1025_defconfig | 3 +++ configs/UCP1020_SPIFLASH_defconfig | 6 ++++++ configs/UCP1020_defconfig | 6 ++++++ configs/UTOO_P66_defconfig | 3 +++ configs/VCMA9_defconfig | 4 ++++ configs/VOM405_defconfig | 3 +++ configs/Wexler_TAB7200_defconfig | 3 +++ configs/Wits_Pro_A20_DKT_defconfig | 3 +++ configs/Wobo_i5_defconfig | 3 +++ configs/Yones_Toptech_BD1078_defconfig | 3 +++ configs/Yones_Toptech_BS1078_V2_defconfig | 2 ++ configs/a3m071_defconfig | 4 ++++ configs/a4m072_defconfig | 5 +++++ configs/a4m2k_defconfig | 4 ++++ configs/ac14xx_defconfig | 3 +++ configs/acadia_defconfig | 5 +++++ configs/adp-ag101p_defconfig | 1 + configs/alt_defconfig | 6 ++++++ configs/am335x_baltos_defconfig | 5 +++++ configs/am335x_boneblack_defconfig | 6 ++++++ configs/am335x_boneblack_vboot_defconfig | 6 ++++++ configs/am335x_evm_defconfig | 6 ++++++ configs/am335x_evm_nor_defconfig | 6 ++++++ configs/am335x_evm_norboot_defconfig | 6 ++++++ configs/am335x_evm_spiboot_defconfig | 6 ++++++ configs/am335x_evm_usbspl_defconfig | 6 ++++++ configs/am335x_gp_evm_defconfig | 6 ++++++ configs/am335x_igep0033_defconfig | 4 ++++ configs/am335x_sl50_defconfig | 4 ++++ configs/am3517_crane_defconfig | 3 +++ configs/am3517_evm_defconfig | 4 ++++ configs/am437x_gp_evm_defconfig | 6 ++++++ configs/am437x_sk_evm_defconfig | 6 ++++++ configs/am43xx_evm_defconfig | 6 ++++++ configs/am43xx_evm_ethboot_defconfig | 6 ++++++ configs/am43xx_evm_qspiboot_defconfig | 6 ++++++ configs/am43xx_evm_usbhost_boot_defconfig | 6 ++++++ configs/am57xx_evm_defconfig | 5 +++++ configs/am57xx_evm_nodt_defconfig | 5 +++++ configs/amcore_defconfig | 2 ++ configs/ap325rxa_defconfig | 1 + configs/ap_sh4a_4a_defconfig | 2 ++ configs/apalis_t30_defconfig | 4 ++++ configs/apf27_defconfig | 4 ++++ configs/apx4devkit_defconfig | 4 ++++ configs/arches_defconfig | 4 ++++ configs/aria_defconfig | 3 +++ configs/aristainetos2_defconfig | 5 +++++ configs/aristainetos2b_defconfig | 5 +++++ configs/aristainetos_defconfig | 5 +++++ configs/armadillo-800eva_defconfig | 2 ++ configs/arndale_defconfig | 5 +++++ configs/aspenite_defconfig | 1 + configs/astro_mcf5373l_defconfig | 1 + configs/at91rm9200ek_defconfig | 3 +++ configs/at91rm9200ek_ram_defconfig | 3 +++ configs/at91sam9260ek_dataflash_cs0_defconfig | 3 +++ configs/at91sam9260ek_dataflash_cs1_defconfig | 3 +++ configs/at91sam9260ek_nandflash_defconfig | 3 +++ configs/at91sam9261ek_dataflash_cs0_defconfig | 3 +++ configs/at91sam9261ek_dataflash_cs3_defconfig | 3 +++ configs/at91sam9261ek_nandflash_defconfig | 3 +++ configs/at91sam9263ek_dataflash_cs0_defconfig | 3 +++ configs/at91sam9263ek_dataflash_defconfig | 3 +++ configs/at91sam9263ek_nandflash_defconfig | 3 +++ configs/at91sam9263ek_norflash_boot_defconfig | 3 +++ configs/at91sam9263ek_norflash_defconfig | 3 +++ configs/at91sam9g10ek_dataflash_cs0_defconfig | 3 +++ configs/at91sam9g10ek_dataflash_cs3_defconfig | 3 +++ configs/at91sam9g10ek_nandflash_defconfig | 3 +++ configs/at91sam9g20ek_2mmc_defconfig | 3 +++ configs/at91sam9g20ek_2mmc_nandflash_defconfig | 3 +++ configs/at91sam9g20ek_dataflash_cs0_defconfig | 3 +++ configs/at91sam9g20ek_dataflash_cs1_defconfig | 3 +++ configs/at91sam9g20ek_nandflash_defconfig | 3 +++ configs/at91sam9m10g45ek_mmc_defconfig | 3 +++ configs/at91sam9m10g45ek_nandflash_defconfig | 3 +++ configs/at91sam9n12ek_mmc_defconfig | 4 ++++ configs/at91sam9n12ek_nandflash_defconfig | 4 ++++ configs/at91sam9n12ek_spiflash_defconfig | 4 ++++ configs/at91sam9x5ek_dataflash_defconfig | 4 ++++ configs/at91sam9x5ek_mmc_defconfig | 4 ++++ configs/at91sam9x5ek_nandflash_defconfig | 4 ++++ configs/at91sam9x5ek_spiflash_defconfig | 4 ++++ configs/at91sam9xeek_dataflash_cs0_defconfig | 3 +++ configs/at91sam9xeek_dataflash_cs1_defconfig | 3 +++ configs/at91sam9xeek_nandflash_defconfig | 3 +++ configs/atngw100_defconfig | 3 +++ configs/atngw100mkii_defconfig | 3 +++ configs/atstk1002_defconfig | 1 + configs/axm_defconfig | 4 ++++ configs/ba10_tv_box_defconfig | 3 +++ configs/bamboo_defconfig | 6 ++++++ configs/bayleybay_defconfig | 6 ++++++ configs/bcm11130_defconfig | 1 + configs/bcm11130_nand_defconfig | 1 + configs/bcm28155_ap_defconfig | 1 + configs/bcm28155_w1d_defconfig | 1 + configs/bcm911360_entphn-ns_defconfig | 2 ++ configs/bcm911360_entphn_defconfig | 2 ++ configs/bcm911360k_defconfig | 2 ++ configs/bcm958300k-ns_defconfig | 2 ++ configs/bcm958300k_defconfig | 2 ++ configs/bcm958305k_defconfig | 2 ++ configs/bcm958622hr_defconfig | 1 + configs/bct-brettl2_defconfig | 4 ++++ configs/beaver_defconfig | 6 ++++++ configs/bf518f-ezbrd_defconfig | 7 +++++++ configs/bf525-ucr2_defconfig | 1 + configs/bf526-ezbrd_defconfig | 8 ++++++++ configs/bf527-ad7160-eval_defconfig | 3 +++ configs/bf527-ezkit-v2_defconfig | 8 ++++++++ configs/bf527-ezkit_defconfig | 8 ++++++++ configs/bf527-sdp_defconfig | 3 +++ configs/bf533-ezkit_defconfig | 5 +++++ configs/bf533-stamp_defconfig | 6 ++++++ configs/bf537-minotaur_defconfig | 4 ++++ configs/bf537-pnav_defconfig | 7 +++++++ configs/bf537-srv1_defconfig | 4 ++++ configs/bf537-stamp_defconfig | 7 +++++++ configs/bf538f-ezkit_defconfig | 6 ++++++ configs/bf548-ezkit_defconfig | 8 ++++++++ configs/bf561-acvilon_defconfig | 5 +++++ configs/bf561-ezkit_defconfig | 4 ++++ configs/bf609-ezkit_defconfig | 5 +++++ configs/bg0900_defconfig | 4 ++++ configs/birdland_bav335a_defconfig | 6 ++++++ configs/birdland_bav335b_defconfig | 6 ++++++ configs/blackstamp_defconfig | 3 +++ configs/blackvme_defconfig | 3 +++ configs/br4_defconfig | 7 +++++++ configs/bubinga_defconfig | 5 +++++ configs/caddy2_defconfig | 2 ++ configs/cairo_defconfig | 4 ++++ configs/calimain_defconfig | 2 ++ configs/cam5200_defconfig | 5 +++++ configs/cam5200_niosflash_defconfig | 5 +++++ configs/canmb_defconfig | 2 ++ configs/canyonlands_defconfig | 6 ++++++ configs/cardhu_defconfig | 6 ++++++ configs/cgtqmx6eval_defconfig | 5 +++++ configs/charon_defconfig | 6 ++++++ configs/chromebook_jerry_defconfig | 7 +++++++ configs/chromebook_link_defconfig | 6 ++++++ configs/chromebook_samus_defconfig | 6 ++++++ configs/chromebox_panther_defconfig | 6 ++++++ configs/clearfog_defconfig | 7 +++++++ configs/cm-bf527_defconfig | 5 +++++ configs/cm-bf533_defconfig | 3 +++ configs/cm-bf537e_defconfig | 6 ++++++ configs/cm-bf537u_defconfig | 6 ++++++ configs/cm-bf548_defconfig | 5 +++++ configs/cm-bf561_defconfig | 3 +++ configs/cm5200_defconfig | 6 ++++++ configs/cm_t335_defconfig | 3 +++ configs/cm_t3517_defconfig | 4 ++++ configs/cm_t35_defconfig | 4 ++++ configs/cm_t43_defconfig | 5 +++++ configs/cm_t54_defconfig | 5 +++++ configs/cobra5272_defconfig | 1 + configs/colibri_pxa270_defconfig | 4 ++++ configs/colibri_t20_defconfig | 4 ++++ configs/colibri_t30_defconfig | 4 ++++ configs/colibri_vf_defconfig | 4 ++++ configs/colorfly_e708_q1_defconfig | 2 ++ configs/conga-qeval20-qa3-e3845_defconfig | 6 ++++++ configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig | 4 ++++ configs/controlcenterd_36BIT_SDCARD_defconfig | 4 ++++ configs/coreboot-x86_defconfig | 6 ++++++ configs/corvus_defconfig | 3 +++ configs/cougarcanyon2_defconfig | 6 ++++++ configs/crownbay_defconfig | 6 ++++++ configs/d2net_v2_defconfig | 6 ++++++ configs/da850_am18xxevm_defconfig | 4 ++++ configs/da850evm_defconfig | 4 ++++ configs/da850evm_direct_nor_defconfig | 3 +++ configs/dalmore_defconfig | 6 ++++++ configs/db-88f6720_defconfig | 7 +++++++ configs/db-88f6820-gp_defconfig | 7 +++++++ configs/db-mv784mp-gp_defconfig | 7 +++++++ configs/dbau1000_defconfig | 1 + configs/dbau1100_defconfig | 1 + configs/dbau1500_defconfig | 1 + configs/devconcenter_defconfig | 6 ++++++ configs/devkit3250_defconfig | 5 +++++ configs/devkit8000_defconfig | 3 +++ configs/difrnce_dit4350_defconfig | 3 +++ configs/digsy_mtc_RAMBOOT_defconfig | 6 ++++++ configs/digsy_mtc_defconfig | 6 ++++++ configs/digsy_mtc_rev5_RAMBOOT_defconfig | 6 ++++++ configs/digsy_mtc_rev5_defconfig | 6 ++++++ configs/dlvision-10g_defconfig | 3 +++ configs/dlvision_defconfig | 2 ++ configs/dnp5370_defconfig | 1 + configs/dns325_defconfig | 3 +++ configs/dockstar_defconfig | 3 +++ configs/dra72_evm_defconfig | 6 ++++++ configs/dra74_evm_defconfig | 6 ++++++ configs/dra7xx_evm_defconfig | 6 ++++++ configs/dra7xx_evm_qspiboot_defconfig | 6 ++++++ configs/dra7xx_evm_uart3_defconfig | 6 ++++++ configs/draco_defconfig | 6 ++++++ configs/dragonboard410c_defconfig | 5 +++++ configs/ds414_defconfig | 8 ++++++++ configs/dserve_dsrv9703c_defconfig | 3 +++ configs/duovero_defconfig | 5 +++++ configs/e2220-1170_defconfig | 6 ++++++ configs/ea20_defconfig | 5 +++++ configs/eb_cpu5282_defconfig | 2 ++ configs/eb_cpu5282_internal_defconfig | 2 ++ configs/eco5pk_defconfig | 3 +++ configs/ecovec_defconfig | 3 +++ configs/edb9315a_defconfig | 3 +++ configs/edminiv2_defconfig | 2 ++ configs/efi-x86_defconfig | 6 ++++++ configs/espt_defconfig | 1 + configs/ethernut5_defconfig | 10 ++++++++++ configs/evb-rk3036_defconfig | 6 ++++++ configs/firefly-rk3288_defconfig | 7 +++++++ configs/flea3_defconfig | 4 ++++ configs/fo300_defconfig | 6 ++++++ configs/ga10h_v1_1_defconfig | 2 ++ configs/galileo_defconfig | 6 ++++++ configs/gdppc440etx_defconfig | 4 ++++ configs/ge_b450v3_defconfig | 5 +++++ configs/ge_b650v3_defconfig | 5 +++++ configs/ge_b850v3_defconfig | 5 +++++ configs/glacier_defconfig | 5 +++++ configs/glacier_ramboot_defconfig | 5 +++++ configs/goflexhome_defconfig | 3 +++ configs/gose_defconfig | 5 +++++ configs/gplugd_defconfig | 5 +++++ configs/gr_cpci_ax2000_defconfig | 1 + configs/gr_ep2s60_defconfig | 1 + configs/gr_xc3s_1500_defconfig | 1 + configs/grasshopper_defconfig | 2 ++ configs/gt90h_v4_defconfig | 2 ++ configs/gwventana_defconfig | 5 +++++ configs/h2200_defconfig | 1 + configs/h8_homlet_v2_defconfig | 2 ++ configs/haleakala_defconfig | 5 +++++ configs/harmony_defconfig | 3 +++ configs/highbank_defconfig | 2 ++ configs/hikey_defconfig | 3 +++ configs/hrcon_defconfig | 2 ++ configs/hrcon_dh_defconfig | 2 ++ configs/i12-tvbox_defconfig | 3 +++ configs/iNet_3F_defconfig | 3 +++ configs/iNet_3W_defconfig | 3 +++ configs/iNet_86VS_defconfig | 3 +++ configs/ibf-dsp561_defconfig | 4 ++++ configs/icnova-a20-swac_defconfig | 3 +++ configs/icon_defconfig | 5 +++++ configs/iconnect_defconfig | 2 ++ configs/ids8313_defconfig | 5 +++++ configs/igep0020_defconfig | 4 ++++ configs/igep0020_nand_defconfig | 4 ++++ configs/igep0030_defconfig | 4 ++++ configs/igep0030_nand_defconfig | 4 ++++ configs/igep0032_defconfig | 4 ++++ configs/imx31_phycore_defconfig | 2 ++ configs/imx31_phycore_eet_defconfig | 3 +++ configs/inet1_defconfig | 3 +++ configs/inet97fv2_defconfig | 3 +++ configs/inet98v_rev2_defconfig | 3 +++ configs/inet9f_rev03_defconfig | 3 +++ configs/inetspace_v2_defconfig | 6 ++++++ configs/inka4x0_defconfig | 5 +++++ configs/integratorap_cm720t_defconfig | 1 + configs/integratorap_cm920t_defconfig | 1 + configs/integratorap_cm926ejs_defconfig | 1 + configs/integratorap_cm946es_defconfig | 1 + configs/integratorcp_cm1136_defconfig | 1 + configs/integratorcp_cm920t_defconfig | 1 + configs/integratorcp_cm926ejs_defconfig | 1 + configs/integratorcp_cm946es_defconfig | 1 + configs/intip_defconfig | 6 ++++++ configs/io64_defconfig | 4 ++++ configs/io_defconfig | 2 ++ configs/iocon_defconfig | 3 +++ configs/ip04_defconfig | 5 +++++ configs/ipam390_defconfig | 2 ++ configs/ipek01_defconfig | 4 ++++ configs/jesurun_q5_defconfig | 3 +++ configs/jetson-tk1_defconfig | 6 ++++++ configs/jupiter_defconfig | 1 + configs/k2e_evm_defconfig | 6 ++++++ configs/k2g_evm_defconfig | 6 ++++++ configs/k2hk_evm_defconfig | 6 ++++++ configs/k2l_evm_defconfig | 6 ++++++ configs/katmai_defconfig | 5 +++++ configs/kc1_defconfig | 3 +++ configs/kilauea_defconfig | 5 +++++ configs/km_kirkwood_128m16_defconfig | 7 +++++++ configs/km_kirkwood_defconfig | 7 +++++++ configs/km_kirkwood_pci_defconfig | 7 +++++++ configs/kmcoge4_defconfig | 7 +++++++ configs/kmcoge5ne_defconfig | 6 ++++++ configs/kmcoge5un_defconfig | 7 +++++++ configs/kmeter1_defconfig | 6 ++++++ configs/kmlion1_defconfig | 7 +++++++ configs/kmnusa_defconfig | 7 +++++++ configs/kmopti2_defconfig | 6 ++++++ configs/kmsugp1_defconfig | 7 +++++++ configs/kmsupx5_defconfig | 6 ++++++ configs/kmsuv31_defconfig | 7 +++++++ configs/kmtegr1_defconfig | 6 ++++++ configs/kmtepr2_defconfig | 6 ++++++ configs/kmvect1_defconfig | 6 ++++++ configs/koelsch_defconfig | 6 ++++++ configs/kylin-rk3036_defconfig | 6 ++++++ configs/kzm9g_defconfig | 3 +++ configs/lager_defconfig | 5 +++++ configs/legoev3_defconfig | 4 ++++ configs/ls1021aqds_ddr4_nor_defconfig | 6 ++++++ configs/ls1021aqds_ddr4_nor_lpuart_defconfig | 6 ++++++ configs/ls1021aqds_nand_defconfig | 6 ++++++ configs/ls1021aqds_nor_SECURE_BOOT_defconfig | 6 ++++++ configs/ls1021aqds_nor_defconfig | 6 ++++++ configs/ls1021aqds_nor_lpuart_defconfig | 6 ++++++ configs/ls1021aqds_qspi_defconfig | 7 +++++++ configs/ls1021aqds_sdcard_ifc_defconfig | 6 ++++++ configs/ls1021aqds_sdcard_qspi_defconfig | 8 ++++++++ configs/ls1021atwr_nor_SECURE_BOOT_defconfig | 6 ++++++ configs/ls1021atwr_nor_defconfig | 6 ++++++ configs/ls1021atwr_nor_lpuart_defconfig | 6 ++++++ configs/ls1021atwr_qspi_defconfig | 7 +++++++ configs/ls1021atwr_sdcard_ifc_defconfig | 6 ++++++ configs/ls1021atwr_sdcard_qspi_defconfig | 8 ++++++++ configs/ls1043aqds_defconfig | 7 +++++++ configs/ls1043aqds_lpuart_defconfig | 7 +++++++ configs/ls1043aqds_nand_defconfig | 7 +++++++ configs/ls1043aqds_nor_ddr3_defconfig | 7 +++++++ configs/ls1043aqds_qspi_defconfig | 8 ++++++++ configs/ls1043aqds_sdcard_ifc_defconfig | 7 +++++++ configs/ls1043aqds_sdcard_qspi_defconfig | 8 ++++++++ configs/ls1043ardb_SECURE_BOOT_defconfig | 5 +++++ configs/ls1043ardb_defconfig | 5 +++++ configs/ls1043ardb_nand_defconfig | 5 +++++ configs/ls1043ardb_sdcard_defconfig | 5 +++++ configs/ls2080a_emu_defconfig | 3 +++ configs/ls2080a_simu_defconfig | 3 +++ configs/ls2080aqds_SECURE_BOOT_defconfig | 5 +++++ configs/ls2080aqds_defconfig | 5 +++++ configs/ls2080aqds_nand_defconfig | 4 ++++ configs/ls2080ardb_SECURE_BOOT_defconfig | 5 +++++ configs/ls2080ardb_defconfig | 5 +++++ configs/ls2080ardb_nand_defconfig | 4 ++++ configs/lschlv2_defconfig | 5 +++++ configs/lsxhl_defconfig | 5 +++++ configs/luan_defconfig | 4 ++++ configs/lwmon5_defconfig | 5 +++++ configs/m28evk_defconfig | 6 ++++++ configs/m53evk_defconfig | 4 ++++ configs/ma5d4evk_defconfig | 4 ++++ configs/makalu_defconfig | 5 +++++ configs/malta_defconfig | 3 +++ configs/maltael_defconfig | 3 +++ configs/marsboard_defconfig | 5 +++++ configs/maxbcm_defconfig | 7 +++++++ configs/mcx_defconfig | 4 ++++ configs/mecp5123_defconfig | 3 +++ configs/medcom-wide_defconfig | 3 +++ configs/meesc_dataflash_defconfig | 2 ++ configs/meesc_defconfig | 2 ++ configs/mgcoge3ne_defconfig | 6 ++++++ configs/mgcoge3un_defconfig | 7 +++++++ configs/mgcoge_defconfig | 6 ++++++ configs/minnowmax_defconfig | 6 ++++++ configs/mixtile_loftq_defconfig | 2 ++ configs/mk802_a10s_defconfig | 3 +++ configs/mk802_defconfig | 3 +++ configs/mk802ii_defconfig | 3 +++ configs/motionpro_defconfig | 3 +++ configs/mpc5121ads_defconfig | 4 ++++ configs/mpc5121ads_rev2_defconfig | 4 ++++ configs/mpc8308_p1m_defconfig | 3 +++ configs/ms7722se_defconfig | 1 + configs/mt_ventoux_defconfig | 4 ++++ configs/munices_defconfig | 1 + configs/mx23_olinuxino_defconfig | 2 ++ configs/mx23evk_defconfig | 1 + configs/mx25pdk_defconfig | 3 +++ configs/mx28evk_auart_console_defconfig | 5 +++++ configs/mx28evk_defconfig | 5 +++++ configs/mx28evk_nand_defconfig | 5 +++++ configs/mx28evk_spi_defconfig | 5 +++++ configs/mx31ads_defconfig | 3 +++ configs/mx31pdk_defconfig | 3 +++ configs/mx35pdk_defconfig | 5 +++++ configs/mx51evk_defconfig | 4 ++++ configs/mx53ard_defconfig | 3 +++ configs/mx53evk_defconfig | 3 +++ configs/mx53loco_defconfig | 3 +++ configs/mx53smd_defconfig | 3 +++ configs/mx6cuboxi_defconfig | 3 +++ configs/mx6dlarm2_defconfig | 3 +++ configs/mx6dlarm2_lpddr2_defconfig | 3 +++ configs/mx6dlsabreauto_defconfig | 5 +++++ configs/mx6dlsabresd_defconfig | 5 +++++ configs/mx6qarm2_defconfig | 3 +++ configs/mx6qarm2_lpddr2_defconfig | 3 +++ configs/mx6qpsabreauto_defconfig | 6 ++++++ configs/mx6qsabreauto_defconfig | 5 +++++ configs/mx6qsabrelite_defconfig | 7 +++++++ configs/mx6qsabresd_defconfig | 5 +++++ configs/mx6sabresd_spl_defconfig | 5 +++++ configs/mx6slevk_defconfig | 5 +++++ configs/mx6slevk_spinor_defconfig | 5 +++++ configs/mx6slevk_spl_defconfig | 6 ++++++ configs/mx6sxsabreauto_defconfig | 6 ++++++ configs/mx6sxsabresd_defconfig | 5 +++++ configs/mx6sxsabresd_spl_defconfig | 5 +++++ configs/mx6ul_14x14_evk_defconfig | 5 +++++ configs/mx6ul_9x9_evk_defconfig | 5 +++++ configs/mx7dsabresd_defconfig | 5 +++++ configs/nas220_defconfig | 3 +++ configs/neo_defconfig | 2 ++ configs/net2big_v2_defconfig | 6 ++++++ configs/netspace_lite_v2_defconfig | 6 ++++++ configs/netspace_max_v2_defconfig | 6 ++++++ configs/netspace_mini_v2_defconfig | 5 +++++ configs/netspace_v2_defconfig | 6 ++++++ configs/nitrogen6dl2g_defconfig | 7 +++++++ configs/nitrogen6dl_defconfig | 7 +++++++ configs/nitrogen6q2g_defconfig | 7 +++++++ configs/nitrogen6q_defconfig | 7 +++++++ configs/nitrogen6s1g_defconfig | 7 +++++++ configs/nitrogen6s_defconfig | 7 +++++++ configs/nokia_rx51_defconfig | 1 + configs/novena_defconfig | 5 +++++ configs/nyan-big_defconfig | 6 ++++++ configs/odroid-xu3_defconfig | 5 +++++ configs/odroid_defconfig | 4 ++++ configs/omap3_beagle_defconfig | 5 +++++ configs/omap3_evm_defconfig | 4 ++++ configs/omap3_ha_defconfig | 4 ++++ configs/omap3_logic_defconfig | 4 ++++ configs/omap3_overo_defconfig | 5 +++++ configs/omap3_pandora_defconfig | 4 ++++ configs/omap3_zoom1_defconfig | 4 ++++ configs/omap4_panda_defconfig | 5 +++++ configs/omap4_sdp4430_defconfig | 4 ++++ configs/omap5_uevm_defconfig | 5 +++++ configs/omapl138_lcdk_defconfig | 2 ++ configs/openrd_base_defconfig | 3 +++ configs/openrd_client_defconfig | 3 +++ configs/openrd_ultimate_defconfig | 3 +++ configs/openrisc-generic_defconfig | 2 ++ configs/orangepi_2_defconfig | 3 +++ configs/orangepi_one_defconfig | 2 ++ configs/orangepi_pc_defconfig | 3 +++ configs/orangepi_plus_defconfig | 3 +++ configs/origen_defconfig | 1 + configs/ot1200_defconfig | 5 +++++ configs/ot1200_spl_defconfig | 5 +++++ configs/p2371-0000_defconfig | 6 ++++++ configs/p2371-2180_defconfig | 6 ++++++ configs/p2571_defconfig | 6 ++++++ configs/paz00_defconfig | 3 +++ configs/pb1000_defconfig | 2 ++ configs/pcm030_LOWBOOT_defconfig | 2 ++ configs/pcm030_defconfig | 2 ++ configs/pcm051_rev1_defconfig | 6 ++++++ configs/pcm051_rev3_defconfig | 6 ++++++ configs/pcm052_defconfig | 5 +++++ configs/pdm360ng_defconfig | 3 +++ configs/peach-pi_defconfig | 7 +++++++ configs/peach-pit_defconfig | 7 +++++++ configs/pengwyn_defconfig | 5 +++++ configs/pepper_defconfig | 4 ++++ configs/picosam9g45_defconfig | 3 +++ configs/pine64_plus_defconfig | 2 ++ configs/platinum_picon_defconfig | 5 +++++ configs/platinum_titanium_defconfig | 5 +++++ configs/plutux_defconfig | 3 +++ configs/pm9261_defconfig | 3 +++ configs/pm9263_defconfig | 3 +++ configs/pm9g45_defconfig | 3 +++ configs/pogo_e02_defconfig | 3 +++ configs/polaroid_mid2809pxe04_defconfig | 2 ++ configs/porter_defconfig | 6 ++++++ configs/portl2_defconfig | 7 +++++++ configs/pov_protab2_ips9_defconfig | 3 +++ configs/pr1_defconfig | 7 +++++++ configs/pxm2_defconfig | 6 ++++++ configs/q8_a13_tablet_defconfig | 3 +++ configs/q8_a23_tablet_800x480_defconfig | 2 ++ configs/q8_a33_tablet_1024x600_defconfig | 2 ++ configs/q8_a33_tablet_800x480_defconfig | 2 ++ configs/qemu-ppce500_defconfig | 2 ++ configs/qemu-x86_defconfig | 6 ++++++ configs/qemu_mips64_defconfig | 3 +++ configs/qemu_mips64el_defconfig | 3 +++ configs/qemu_mips_defconfig | 2 ++ configs/qemu_mipsel_defconfig | 2 ++ configs/r0p7734_defconfig | 2 ++ configs/r2dplus_defconfig | 1 + configs/r7-tv-dongle_defconfig | 3 +++ configs/r7780mp_defconfig | 1 + configs/rainier_defconfig | 4 ++++ configs/rainier_ramboot_defconfig | 4 ++++ configs/rastaban_defconfig | 6 ++++++ configs/redwood_defconfig | 4 ++++ configs/riotboard_defconfig | 5 +++++ configs/rock2_defconfig | 7 +++++++ configs/rpi_2_defconfig | 3 +++ configs/rpi_3_32b_defconfig | 3 +++ configs/rpi_3_defconfig | 3 +++ configs/rpi_defconfig | 3 +++ configs/rsk7203_defconfig | 1 + configs/rut_defconfig | 6 ++++++ configs/s5pc210_universal_defconfig | 3 +++ configs/sama5d2_xplained_mmc_defconfig | 3 +++ configs/sama5d2_xplained_spiflash_defconfig | 3 +++ configs/sama5d3_xplained_mmc_defconfig | 3 +++ configs/sama5d3_xplained_nandflash_defconfig | 3 +++ configs/sama5d3xek_mmc_defconfig | 4 ++++ configs/sama5d3xek_nandflash_defconfig | 4 ++++ configs/sama5d3xek_spiflash_defconfig | 4 ++++ configs/sama5d4_xplained_mmc_defconfig | 4 ++++ configs/sama5d4_xplained_nandflash_defconfig | 4 ++++ configs/sama5d4_xplained_spiflash_defconfig | 4 ++++ configs/sama5d4ek_mmc_defconfig | 4 ++++ configs/sama5d4ek_nandflash_defconfig | 4 ++++ configs/sama5d4ek_spiflash_defconfig | 4 ++++ configs/sandbox_defconfig | 11 +++++++++++ configs/sansa_fuze_plus_defconfig | 3 +++ configs/sbc8349_PCI_33_defconfig | 2 ++ configs/sbc8349_PCI_66_defconfig | 2 ++ configs/sbc8349_defconfig | 2 ++ configs/sbc8548_PCI_33_PCIE_defconfig | 2 ++ configs/sbc8548_PCI_33_defconfig | 2 ++ configs/sbc8548_PCI_66_PCIE_defconfig | 2 ++ configs/sbc8548_PCI_66_defconfig | 2 ++ configs/sbc8548_defconfig | 2 ++ configs/sbc8641d_defconfig | 2 ++ configs/sc_sps_1_defconfig | 3 +++ configs/seaboard_defconfig | 4 ++++ configs/secomx6quq7_defconfig | 2 ++ configs/sequoia_defconfig | 5 +++++ configs/sequoia_ramboot_defconfig | 5 +++++ configs/sh7752evb_defconfig | 2 ++ configs/sh7753evb_defconfig | 2 ++ configs/sh7757lcr_defconfig | 2 ++ configs/sh7763rdp_defconfig | 1 + configs/sh7785lcr_32bit_defconfig | 2 ++ configs/sh7785lcr_defconfig | 2 ++ configs/shmin_defconfig | 1 + configs/silk_defconfig | 6 ++++++ configs/smartweb_defconfig | 7 +++++++ configs/smdk2410_defconfig | 3 +++ configs/smdk5250_defconfig | 7 +++++++ configs/smdk5420_defconfig | 7 +++++++ configs/smdkv310_defconfig | 2 ++ configs/snapper9260_defconfig | 4 ++++ configs/snapper9g20_defconfig | 4 ++++ configs/sniper_defconfig | 3 +++ configs/snow_defconfig | 7 +++++++ configs/socfpga_arria5_defconfig | 6 ++++++ configs/socfpga_cyclone5_defconfig | 6 ++++++ configs/socfpga_de0_nano_soc_defconfig | 6 ++++++ configs/socfpga_mcvevk_defconfig | 6 ++++++ configs/socfpga_sockit_defconfig | 6 ++++++ configs/socfpga_socrates_defconfig | 6 ++++++ configs/socfpga_sr1500_defconfig | 8 ++++++++ configs/socrates_defconfig | 5 +++++ configs/spear300_defconfig | 3 +++ configs/spear300_nand_defconfig | 3 +++ configs/spear300_usbtty_defconfig | 3 +++ configs/spear300_usbtty_nand_defconfig | 3 +++ configs/spear310_defconfig | 3 +++ configs/spear310_nand_defconfig | 3 +++ configs/spear310_pnor_defconfig | 3 +++ configs/spear310_usbtty_defconfig | 3 +++ configs/spear310_usbtty_nand_defconfig | 3 +++ configs/spear310_usbtty_pnor_defconfig | 3 +++ configs/spear320_defconfig | 3 +++ configs/spear320_nand_defconfig | 3 +++ configs/spear320_pnor_defconfig | 3 +++ configs/spear320_usbtty_defconfig | 3 +++ configs/spear320_usbtty_nand_defconfig | 3 +++ configs/spear320_usbtty_pnor_defconfig | 3 +++ configs/spear600_defconfig | 3 +++ configs/spear600_nand_defconfig | 3 +++ configs/spear600_usbtty_defconfig | 3 +++ configs/spear600_usbtty_nand_defconfig | 3 +++ configs/spring_defconfig | 7 +++++++ configs/stm32f429-discovery_defconfig | 1 + configs/stm32f746-disco_defconfig | 2 ++ configs/stout_defconfig | 5 +++++ configs/strider_con_defconfig | 3 +++ configs/strider_cpu_defconfig | 3 +++ configs/stv0991_defconfig | 4 ++++ configs/sunxi_Gemei_G9_defconfig | 3 +++ configs/suvd3_defconfig | 6 ++++++ configs/sycamore_defconfig | 5 +++++ configs/t3corp_defconfig | 4 ++++ configs/tao3530_defconfig | 4 ++++ configs/taurus_defconfig | 5 +++++ configs/tb100_defconfig | 2 ++ configs/tbs2910_defconfig | 6 ++++++ configs/tcm-bf518_defconfig | 6 ++++++ configs/tcm-bf537_defconfig | 6 ++++++ configs/tec-ng_defconfig | 6 ++++++ configs/tec_defconfig | 3 +++ configs/theadorable_debug_defconfig | 6 ++++++ configs/theadorable_defconfig | 2 ++ configs/thuban_defconfig | 6 ++++++ configs/ti814x_evm_defconfig | 2 ++ configs/titanium_defconfig | 5 +++++ configs/tqma6q_mba6_mmc_defconfig | 6 ++++++ configs/tqma6q_mba6_spi_defconfig | 6 ++++++ configs/tqma6s_mba6_mmc_defconfig | 6 ++++++ configs/tqma6s_mba6_spi_defconfig | 6 ++++++ configs/tqma6s_wru4_mmc_defconfig | 5 +++++ configs/trats2_defconfig | 3 +++ configs/trats_defconfig | 3 +++ configs/tricorder_defconfig | 1 + configs/tricorder_flash_defconfig | 1 + configs/trimslice_defconfig | 6 ++++++ configs/ts4800_defconfig | 3 +++ configs/tuge1_defconfig | 6 ++++++ configs/tuxx1_defconfig | 6 ++++++ configs/twister_defconfig | 4 ++++ configs/udoo_defconfig | 3 +++ configs/usb_a9263_dataflash_defconfig | 2 ++ configs/usbarmory_defconfig | 5 +++++ configs/v38b_defconfig | 4 ++++ configs/vct_platinum_defconfig | 5 +++++ configs/vct_platinum_onenand_defconfig | 5 +++++ configs/vct_platinumavc_defconfig | 2 ++ configs/vct_platinumavc_onenand_defconfig | 2 ++ configs/vct_premium_defconfig | 5 +++++ configs/vct_premium_onenand_defconfig | 5 +++++ configs/ve8313_defconfig | 2 ++ configs/venice2_defconfig | 6 ++++++ configs/ventana_defconfig | 3 +++ configs/vexpress_aemv8a_dram_defconfig | 4 ++++ configs/vexpress_aemv8a_juno_defconfig | 4 ++++ configs/vexpress_aemv8a_semi_defconfig | 4 ++++ configs/vexpress_ca15_tc2_defconfig | 2 ++ configs/vexpress_ca5x2_defconfig | 2 ++ configs/vexpress_ca9x4_defconfig | 2 ++ configs/vf610twr_defconfig | 4 ++++ configs/vf610twr_nand_defconfig | 4 ++++ configs/vinco_defconfig | 4 ++++ configs/vme8349_defconfig | 2 ++ configs/walnut_defconfig | 5 +++++ configs/wandboard_defconfig | 4 ++++ configs/warp7_defconfig | 2 ++ configs/warp_defconfig | 2 ++ configs/whistler_defconfig | 4 ++++ configs/woodburn_defconfig | 4 ++++ configs/woodburn_sd_defconfig | 4 ++++ configs/work_92105_defconfig | 4 ++++ configs/wtk_defconfig | 2 ++ configs/x600_defconfig | 5 +++++ configs/xfi3_defconfig | 2 ++ configs/xilinx-ppc405-generic_defconfig | 1 + configs/xilinx-ppc440-generic_defconfig | 1 + configs/xilinx_zynqmp_ep_defconfig | 1 + configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig | 1 + configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig | 1 + configs/xilinx_zynqmp_zcu102_defconfig | 2 ++ configs/xilinx_zynqmp_zcu102_revB_defconfig | 2 ++ configs/xpedite1000_defconfig | 4 ++++ configs/xpedite517x_defconfig | 4 ++++ configs/xpedite520x_defconfig | 4 ++++ configs/xpedite537x_defconfig | 4 ++++ configs/xpedite550x_defconfig | 5 +++++ configs/xpress_defconfig | 4 ++++ configs/xpress_spl_defconfig | 4 ++++ configs/yellowstone_defconfig | 4 ++++ configs/yosemite_defconfig | 5 +++++ configs/yucca_defconfig | 4 ++++ configs/zipitz2_defconfig | 2 ++ configs/zmx25_defconfig | 3 +++ configs/zynq_microzed_defconfig | 5 +++++ configs/zynq_picozed_defconfig | 4 ++++ configs/zynq_zc702_defconfig | 6 ++++++ configs/zynq_zc706_defconfig | 6 ++++++ configs/zynq_zc770_xm010_defconfig | 4 ++++ configs/zynq_zc770_xm011_defconfig | 3 +++ configs/zynq_zc770_xm012_defconfig | 3 +++ configs/zynq_zc770_xm013_defconfig | 3 +++ configs/zynq_zed_defconfig | 5 +++++ configs/zynq_zybo_defconfig | 6 ++++++ include/config_cmd_all.h | 11 ----------- include/config_distro_defaults.h | 2 -- include/config_fallbacks.h | 6 ------ include/config_uncmd_spl.h | 10 ---------- include/configs/B4860QDS.h | 5 ----- include/configs/BSC9131RDB.h | 7 ------- include/configs/BSC9132QDS.h | 5 ----- include/configs/C29XPCIE.h | 4 ---- include/configs/CPCI2DP.h | 2 -- include/configs/CPCI4052.h | 5 ----- include/configs/M5208EVBE.h | 2 -- include/configs/M52277EVB.h | 4 ---- include/configs/M5235EVB.h | 3 --- include/configs/M5249EVB.h | 1 - include/configs/M5253DEMO.h | 1 - include/configs/M5272C3.h | 2 -- include/configs/M5275EVB.h | 3 --- include/configs/M5282EVB.h | 1 - include/configs/M53017EVB.h | 2 -- include/configs/M5329EVB.h | 2 -- include/configs/M5373EVB.h | 2 -- include/configs/M54418TWR.h | 6 ------ include/configs/M54451EVB.h | 6 ------ include/configs/M54455EVB.h | 6 ------ include/configs/M5475EVB.h | 3 --- include/configs/M5485EVB.h | 3 --- include/configs/MIP405.h | 4 ---- include/configs/MPC8308RDB.h | 5 ----- include/configs/MPC8313ERDB.h | 3 --- include/configs/MPC8315ERDB.h | 3 --- include/configs/MPC8323ERDB.h | 2 -- include/configs/MPC832XEMDS.h | 2 -- include/configs/MPC8349EMDS.h | 2 -- include/configs/MPC8349ITX.h | 7 ------- include/configs/MPC837XEMDS.h | 3 --- include/configs/MPC837XERDB.h | 3 --- include/configs/MPC8536DS.h | 4 ---- include/configs/MPC8540ADS.h | 2 -- include/configs/MPC8541CDS.h | 2 -- include/configs/MPC8544DS.h | 3 --- include/configs/MPC8548CDS.h | 2 -- include/configs/MPC8555CDS.h | 2 -- include/configs/MPC8560ADS.h | 2 -- include/configs/MPC8568MDS.h | 2 -- include/configs/MPC8569MDS.h | 2 -- include/configs/MPC8572DS.h | 3 --- include/configs/MPC8610HPCD.h | 3 --- include/configs/MPC8641HPCN.h | 3 --- include/configs/MigoR.h | 1 - include/configs/P1010RDB.h | 5 ----- include/configs/P1022DS.h | 4 ---- include/configs/P1023RDB.h | 4 ---- include/configs/P2041RDB.h | 5 ----- include/configs/PIP405.h | 4 ---- include/configs/PLU405.h | 4 ---- include/configs/PMC405DE.h | 4 ---- include/configs/PMC440.h | 5 ----- include/configs/T102xQDS.h | 5 ----- include/configs/T102xRDB.h | 9 --------- include/configs/T1040QDS.h | 5 ----- include/configs/T104xRDB.h | 5 ----- include/configs/T208xQDS.h | 5 ----- include/configs/T208xRDB.h | 6 ------ include/configs/T4240QDS.h | 2 -- include/configs/T4240RDB.h | 5 ----- include/configs/TQM5200.h | 10 ---------- include/configs/TQM823L.h | 2 -- include/configs/TQM823M.h | 4 ---- include/configs/TQM834x.h | 4 ---- include/configs/TQM850L.h | 3 --- include/configs/TQM850M.h | 2 -- include/configs/TQM855L.h | 4 ---- include/configs/TQM855M.h | 4 ---- include/configs/TQM860L.h | 3 --- include/configs/TQM860M.h | 4 ---- include/configs/TQM862L.h | 4 ---- include/configs/TQM862M.h | 4 ---- include/configs/TQM866M.h | 4 ---- include/configs/TQM885D.h | 11 ----------- include/configs/UCP1020.h | 8 -------- include/configs/VCMA9.h | 4 ---- include/configs/VOM405.h | 3 --- include/configs/a3m071.h | 4 ---- include/configs/a4m072.h | 5 ----- include/configs/ac14xx.h | 3 --- include/configs/acadia.h | 1 - include/configs/adp-ag101p.h | 1 - include/configs/alt.h | 1 - include/configs/am335x_evm.h | 2 -- include/configs/am3517_crane.h | 4 ---- include/configs/am3517_evm.h | 4 ---- include/configs/am43xx_evm.h | 5 ----- include/configs/am57xx_evm.h | 3 --- include/configs/amcc-common.h | 4 ---- include/configs/amcore.h | 2 -- include/configs/ap325rxa.h | 1 - include/configs/ap_sh4a_4a.h | 2 -- include/configs/apalis_t30.h | 3 --- include/configs/apf27.h | 4 ---- include/configs/apx4devkit.h | 4 ---- include/configs/aria.h | 3 --- include/configs/aristainetos-common.h | 5 ----- include/configs/armadillo-800eva.h | 2 -- include/configs/aspenite.h | 1 - include/configs/astro_mcf5373l.h | 1 - include/configs/at91-sama5_common.h | 2 -- include/configs/at91rm9200ek.h | 3 --- include/configs/at91sam9260ek.h | 3 --- include/configs/at91sam9261ek.h | 3 --- include/configs/at91sam9263ek.h | 3 --- include/configs/at91sam9m10g45ek.h | 3 --- include/configs/at91sam9n12ek.h | 4 ---- include/configs/at91sam9rlek.h | 1 - include/configs/at91sam9x5ek.h | 4 ---- include/configs/atngw100.h | 3 --- include/configs/atngw100mkii.h | 3 --- include/configs/atstk1002.h | 1 - include/configs/baltos.h | 1 - include/configs/bamboo.h | 2 -- include/configs/bav335x.h | 2 -- include/configs/bcm28155_ap.h | 1 - include/configs/bcm_ep_board.h | 1 - include/configs/beaver.h | 5 ----- include/configs/bf506f-ezkit.h | 4 ---- include/configs/bf525-ucr2.h | 1 - include/configs/bf537-minotaur.h | 7 ------- include/configs/bf537-srv1.h | 4 ---- include/configs/bfin_adi_common.h | 12 ------------ include/configs/bg0900.h | 4 ---- include/configs/blackstamp.h | 11 ----------- include/configs/blackvme.h | 4 ---- include/configs/bubinga.h | 1 - include/configs/calimain.h | 4 ---- include/configs/canmb.h | 5 ----- include/configs/canyonlands.h | 3 --- include/configs/cardhu.h | 5 ----- include/configs/cgtqmx6eval.h | 5 ----- include/configs/chromebook_jerry.h | 1 - include/configs/clearfog.h | 7 ------- include/configs/cm5200.h | 7 ------- include/configs/cm_t335.h | 1 - include/configs/cm_t35.h | 4 ---- include/configs/cm_t3517.h | 4 ---- include/configs/cm_t43.h | 1 - include/configs/cm_t54.h | 3 --- include/configs/cobra5272.h | 1 - include/configs/colibri_pxa270.h | 9 --------- include/configs/colibri_t20.h | 3 --- include/configs/colibri_t30.h | 3 --- include/configs/colibri_vf.h | 4 ---- include/configs/controlcenterd.h | 4 ---- include/configs/corenet_ds.h | 5 ----- include/configs/corvus.h | 3 --- include/configs/cyrus.h | 5 ----- include/configs/da850evm.h | 6 ------ include/configs/dalmore.h | 5 ----- include/configs/db-88f6720.h | 7 ------- include/configs/db-88f6820-gp.h | 7 ------- include/configs/db-mv784mp-gp.h | 7 ------- include/configs/dbau1x00.h | 2 -- include/configs/devkit3250.h | 5 ----- include/configs/devkit8000.h | 2 -- include/configs/digsy_mtc.h | 6 ------ include/configs/dlvision-10g.h | 2 -- include/configs/dlvision.h | 2 -- include/configs/dnp5370.h | 1 - include/configs/dns325.h | 4 ---- include/configs/dockstar.h | 3 --- include/configs/dra7xx_evm.h | 5 ----- include/configs/dragonboard410c.h | 3 --- include/configs/ds414.h | 8 -------- include/configs/duovero.h | 3 --- include/configs/e2220-1170.h | 5 ----- include/configs/ea20.h | 7 ------- include/configs/eb_cpu5282.h | 2 -- include/configs/eco5pk.h | 1 - include/configs/ecovec.h | 3 --- include/configs/edb93xx.h | 11 ----------- include/configs/edminiv2.h | 2 -- include/configs/embestmx6boards.h | 3 --- include/configs/espt.h | 1 - include/configs/ethernut5.h | 10 ---------- include/configs/exynos5-common.h | 5 ----- include/configs/flea3.h | 4 ---- include/configs/ge_bx50v3.h | 6 ------ include/configs/goflexhome.h | 3 --- include/configs/gplugd.h | 5 ----- include/configs/gr_cpci_ax2000.h | 1 - include/configs/gr_ep2s60.h | 2 -- include/configs/gr_xc3s_1500.h | 1 - include/configs/grasshopper.h | 2 -- include/configs/gw_ventana.h | 6 ------ include/configs/h2200.h | 1 - include/configs/harmony.h | 2 -- include/configs/hikey.h | 1 - include/configs/hrcon.h | 2 -- include/configs/icon.h | 1 - include/configs/iconnect.h | 2 -- include/configs/ids8313.h | 5 ----- include/configs/imx27lite-common.h | 2 -- include/configs/imx31_phycore.h | 3 --- include/configs/inka4x0.h | 9 --------- include/configs/integrator-common.h | 1 - include/configs/intip.h | 2 -- include/configs/io.h | 2 -- include/configs/iocon.h | 1 - include/configs/ipam390.h | 4 ---- include/configs/ipek01.h | 5 ----- include/configs/jetson-tk1.h | 5 ----- include/configs/jupiter.h | 1 - include/configs/katmai.h | 1 - include/configs/kc1.h | 1 - include/configs/kilauea.h | 1 - include/configs/km/keymile-common.h | 6 ------ include/configs/km/km_arm.h | 1 - include/configs/km/kmp204x-common.h | 1 - include/configs/koelsch.h | 1 - include/configs/kzm9g.h | 3 --- include/configs/lacie_kw.h | 13 ------------- include/configs/legoev3.h | 4 ---- include/configs/ls1021aqds.h | 11 ----------- include/configs/ls1021atwr.h | 11 ----------- include/configs/ls1043a_common.h | 5 ----- include/configs/ls1043aqds.h | 5 ----- include/configs/ls1043ardb.h | 1 - include/configs/ls2080a_common.h | 3 --- include/configs/ls2080aqds.h | 2 -- include/configs/ls2080ardb.h | 2 -- include/configs/lsxl.h | 6 ------ include/configs/lwmon5.h | 5 ----- include/configs/m28evk.h | 6 ------ include/configs/m53evk.h | 4 ---- include/configs/ma5d4evk.h | 4 ---- include/configs/makalu.h | 1 - include/configs/malta.h | 12 ------------ include/configs/manroland/common.h | 5 ----- include/configs/maxbcm.h | 7 ------- include/configs/mcx.h | 4 ---- include/configs/mecp5123.h | 3 --- include/configs/medcom-wide.h | 2 -- include/configs/meesc.h | 6 ------ include/configs/microblaze-generic.h | 1 - include/configs/motionpro.h | 3 --- include/configs/mpc5121ads.h | 4 ---- include/configs/mpc8308_p1m.h | 3 --- include/configs/ms7722se.h | 1 - include/configs/munices.h | 1 - include/configs/mx23_olinuxino.h | 2 -- include/configs/mx23evk.h | 1 - include/configs/mx25pdk.h | 3 --- include/configs/mx28evk.h | 5 ----- include/configs/mx31ads.h | 3 --- include/configs/mx31pdk.h | 3 --- include/configs/mx35pdk.h | 5 ----- include/configs/mx51evk.h | 4 ---- include/configs/mx53ard.h | 3 --- include/configs/mx53evk.h | 3 --- include/configs/mx53loco.h | 3 --- include/configs/mx53smd.h | 3 --- include/configs/mx6_common.h | 1 - include/configs/mx6cuboxi.h | 3 --- include/configs/mx6qarm2.h | 3 --- include/configs/mx6qsabreauto.h | 2 -- include/configs/mx6sabre_common.h | 3 --- include/configs/mx6sabresd.h | 2 -- include/configs/mx6slevk.h | 5 ----- include/configs/mx6sxsabreauto.h | 6 ------ include/configs/mx6sxsabresd.h | 7 ------- include/configs/mx6ul_14x14_evk.h | 4 ---- include/configs/mx7_common.h | 1 - include/configs/mx7dsabresd.h | 8 -------- include/configs/nas220.h | 3 --- include/configs/neo.h | 2 -- include/configs/nitrogen6x.h | 7 ------- include/configs/nokia_rx51.h | 1 - include/configs/novena.h | 5 ----- include/configs/nyan-big.h | 5 ----- include/configs/o2dnt-common.h | 3 --- include/configs/odroid.h | 4 ---- include/configs/omap3_beagle.h | 2 -- include/configs/omap3_evm.h | 3 --- include/configs/omap3_evm_common.h | 1 - include/configs/omap3_igep00x0.h | 2 -- include/configs/omap3_logic.h | 2 -- include/configs/omap3_overo.h | 1 - include/configs/omap3_zoom1.h | 2 -- include/configs/omap4_panda.h | 3 --- include/configs/omap5_uevm.h | 2 -- include/configs/omapl138_lcdk.h | 6 ------ include/configs/openrd.h | 3 --- include/configs/openrisc-generic.h | 2 -- include/configs/origen.h | 2 -- include/configs/ot1200.h | 5 ----- include/configs/p1_p2_rdb_pc.h | 4 ---- include/configs/p1_twr.h | 3 --- include/configs/p2371-0000.h | 5 ----- include/configs/p2371-2180.h | 5 ----- include/configs/p2571.h | 5 ----- include/configs/paz00.h | 2 -- include/configs/pb1x00.h | 2 -- include/configs/pcm030.h | 2 -- include/configs/pcm051.h | 2 -- include/configs/pcm052.h | 7 ------- include/configs/pdm360ng.h | 3 --- include/configs/pengwyn.h | 1 - include/configs/picosam9g45.h | 3 --- include/configs/platinum.h | 5 ----- include/configs/plutux.h | 2 -- include/configs/pm9261.h | 3 --- include/configs/pm9263.h | 3 --- include/configs/pm9g45.h | 3 --- include/configs/pogo_e02.h | 3 --- include/configs/porter.h | 1 - include/configs/qemu-mips.h | 9 --------- include/configs/qemu-mips64.h | 10 ---------- include/configs/qemu-ppce500.h | 2 -- include/configs/r0p7734.h | 2 -- include/configs/r2dplus.h | 1 - include/configs/r7780mp.h | 1 - include/configs/rcar-gen2-common.h | 5 ----- include/configs/rk3036_common.h | 4 ---- include/configs/rk3288_common.h | 5 ----- include/configs/rpi.h | 1 - include/configs/rsk7203.h | 1 - include/configs/s5pc210_universal.h | 1 - include/configs/sama5d2_xplained.h | 1 - include/configs/sama5d3_xplained.h | 1 - include/configs/sama5d3xek.h | 2 -- include/configs/sama5d4_xplained.h | 2 -- include/configs/sama5d4ek.h | 2 -- include/configs/sandbox.h | 9 --------- include/configs/sansa_fuze_plus.h | 3 --- include/configs/sbc8349.h | 2 -- include/configs/sbc8548.h | 2 -- include/configs/sbc8641d.h | 2 -- include/configs/sc_sps_1.h | 3 --- include/configs/seaboard.h | 3 --- include/configs/secomx6quq7.h | 2 -- include/configs/sequoia.h | 1 - include/configs/sh7752evb.h | 2 -- include/configs/sh7753evb.h | 2 -- include/configs/sh7757lcr.h | 2 -- include/configs/sh7763rdp.h | 1 - include/configs/sh7785lcr.h | 2 -- include/configs/shmin.h | 1 - include/configs/siemens-am33x-common.h | 6 ------ include/configs/silk.h | 1 - include/configs/smartweb.h | 10 ---------- include/configs/smdk2410.h | 3 --- include/configs/smdkv310.h | 2 -- include/configs/snapper9260.h | 4 ---- include/configs/sniper.h | 1 - include/configs/socfpga_arria5_socdk.h | 3 --- include/configs/socfpga_common.h | 5 ----- include/configs/socfpga_cyclone5_socdk.h | 3 --- include/configs/socfpga_de0_nano_soc.h | 3 --- include/configs/socfpga_mcvevk.h | 3 --- include/configs/socfpga_sockit.h | 3 --- include/configs/socfpga_socrates.h | 3 --- include/configs/socfpga_sr1500.h | 7 ------- include/configs/socrates.h | 5 ----- include/configs/spear-common.h | 3 --- include/configs/stm32f429-discovery.h | 1 - include/configs/stm32f746-disco.h | 2 -- include/configs/strider.h | 3 --- include/configs/stv0991.h | 4 ---- include/configs/sunxi-common.h | 1 - include/configs/t4qds.h | 3 --- include/configs/tam3517-common.h | 4 ---- include/configs/tao3530.h | 4 ---- include/configs/taurus.h | 5 ----- include/configs/tb100.h | 2 -- include/configs/tbs2910.h | 7 ------- include/configs/tec-ng.h | 5 ----- include/configs/tec.h | 2 -- include/configs/tegra-common-post.h | 2 -- include/configs/theadorable.h | 6 ------ include/configs/ti814x_evm.h | 2 -- include/configs/ti_am335x_common.h | 2 -- include/configs/ti_armv7_common.h | 2 -- include/configs/ti_armv7_keystone2.h | 4 ---- include/configs/titanium.h | 5 ----- include/configs/tqma6.h | 6 ------ include/configs/tqma6_wru4.h | 2 -- include/configs/trats.h | 1 - include/configs/trats2.h | 1 - include/configs/tricorder.h | 1 - include/configs/trimslice.h | 5 ----- include/configs/ts4800.h | 4 ---- include/configs/udoo.h | 2 -- include/configs/usb_a9263.h | 2 -- include/configs/usbarmory.h | 3 --- include/configs/v38b.h | 4 ---- include/configs/vct.h | 11 ----------- include/configs/ve8313.h | 2 -- include/configs/venice2.h | 5 ----- include/configs/ventana.h | 2 -- include/configs/vexpress_aemv8a.h | 4 ---- include/configs/vexpress_common.h | 1 - include/configs/vf610twr.h | 5 ----- include/configs/vinco.h | 2 -- include/configs/vme8349.h | 2 -- include/configs/walnut.h | 1 - include/configs/wandboard.h | 4 ---- include/configs/warp.h | 2 -- include/configs/warp7.h | 2 -- include/configs/whistler.h | 3 --- include/configs/woodburn_common.h | 4 ---- include/configs/work_92105.h | 4 ---- include/configs/x600.h | 5 ----- include/configs/x86-common.h | 6 ------ include/configs/xfi3.h | 2 -- include/configs/xilinx-ppc.h | 5 ----- include/configs/xilinx_zynqmp.h | 3 --- include/configs/xpedite1000.h | 4 ---- include/configs/xpedite517x.h | 4 ---- include/configs/xpedite520x.h | 4 ---- include/configs/xpedite537x.h | 4 ---- include/configs/xpedite550x.h | 5 ----- include/configs/xpress.h | 3 --- include/configs/yosemite.h | 1 - include/configs/zipitz2.h | 2 -- include/configs/zmx25.h | 3 --- include/configs/zynq-common.h | 7 ------- 1506 files changed, 4344 insertions(+), 1505 deletions(-)
diff --git a/arch/arm/include/asm/arch-bcmcygnus/configs.h b/arch/arm/include/asm/arch-bcmcygnus/configs.h index 3c07160..fd51531 100644 --- a/arch/arm/include/asm/arch-bcmcygnus/configs.h +++ b/arch/arm/include/asm/arch-bcmcygnus/configs.h @@ -30,7 +30,6 @@ #define CONFIG_PHY_BROADCOM #define CONFIG_PHY_RESET_DELAY 10000 /* PHY reset delay in us*/
-#define CONFIG_CMD_PING #define CONFIG_CMD_MII
#endif /* __ARCH_CONFIGS_H */ diff --git a/arch/blackfin/include/asm/config.h b/arch/blackfin/include/asm/config.h index d2cf71b..3d98a00 100644 --- a/arch/blackfin/include/asm/config.h +++ b/arch/blackfin/include/asm/config.h @@ -138,9 +138,6 @@ #ifndef CONFIG_SYS_BOOTM_LEN # define CONFIG_SYS_BOOTM_LEN 0x4000000 #endif -#ifndef CONFIG_SYS_PROMPT -# define CONFIG_SYS_PROMPT "bfin> " -#endif #ifndef CONFIG_SYS_CBSIZE # define CONFIG_SYS_CBSIZE 1024 #elif defined(CONFIG_CMD_KGDB) && CONFIG_SYS_CBSIZE < 1024 diff --git a/cmd/Kconfig b/cmd/Kconfig index 8703cdb..f4ec023 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -343,7 +343,7 @@ config CMD_FLASH protect - enable or disable FLASH write protection
config CMD_ARMFLASH - depends on FLASH_CFI_DRIVER + #depends on FLASH_CFI_DRIVER bool "armflash" help ARM Ltd reference designs flash partition access diff --git a/configs/A10-OLinuXino-Lime_defconfig b/configs/A10-OLinuXino-Lime_defconfig index f034f1f..b4d7d84 100644 --- a/configs/A10-OLinuXino-Lime_defconfig +++ b/configs/A10-OLinuXino-Lime_defconfig @@ -12,7 +12,10 @@ CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,AHCI,SATAPWR=SUNXI_GPC(3)" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_AXP_ALDO3_VOLT=2800 CONFIG_AXP_ALDO4_VOLT=2800 CONFIG_USB_EHCI_HCD=y diff --git a/configs/A10s-OLinuXino-M_defconfig b/configs/A10s-OLinuXino-M_defconfig index 6679b04..7baff24 100644 --- a/configs/A10s-OLinuXino-M_defconfig +++ b/configs/A10s-OLinuXino-M_defconfig @@ -13,6 +13,9 @@ CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_AXP152_POWER=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/A13-OLinuXinoM_defconfig b/configs/A13-OLinuXinoM_defconfig index be6ff9f..e03d9a8 100644 --- a/configs/A13-OLinuXinoM_defconfig +++ b/configs/A13-OLinuXinoM_defconfig @@ -17,6 +17,9 @@ CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SUNXI_NO_PMIC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/A13-OLinuXino_defconfig b/configs/A13-OLinuXino_defconfig index 1934cf8..1ac88a4 100644 --- a/configs/A13-OLinuXino_defconfig +++ b/configs/A13-OLinuXino_defconfig @@ -19,7 +19,10 @@ CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_GADGET=y diff --git a/configs/A20-OLinuXino-Lime2_defconfig b/configs/A20-OLinuXino-Lime2_defconfig index 5d6da22..7a1f2a8 100644 --- a/configs/A20-OLinuXino-Lime2_defconfig +++ b/configs/A20-OLinuXino-Lime2_defconfig @@ -12,7 +12,10 @@ CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,AHCI,SATAPWR=SUNXI_GPC(3)" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_RTL8211X_PHY_FORCE_MASTER=y CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_ALDO3_VOLT=2800 diff --git a/configs/A20-OLinuXino-Lime_defconfig b/configs/A20-OLinuXino-Lime_defconfig index 58748a7..3093395 100644 --- a/configs/A20-OLinuXino-Lime_defconfig +++ b/configs/A20-OLinuXino-Lime_defconfig @@ -10,7 +10,10 @@ CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPC(3)" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_ALDO3_VOLT=2800 CONFIG_AXP_ALDO4_VOLT=2800 diff --git a/configs/A20-OLinuXino_MICRO_defconfig b/configs/A20-OLinuXino_MICRO_defconfig index e01d722..da76a97 100644 --- a/configs/A20-OLinuXino_MICRO_defconfig +++ b/configs/A20-OLinuXino_MICRO_defconfig @@ -13,6 +13,9 @@ CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPB(8)" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/A20-Olimex-SOM-EVB_defconfig b/configs/A20-Olimex-SOM-EVB_defconfig index e19f872..7c9150e 100644 --- a/configs/A20-Olimex-SOM-EVB_defconfig +++ b/configs/A20-Olimex-SOM-EVB_defconfig @@ -15,7 +15,10 @@ CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,AHCI,SATAPWR=SUNXI_GPC(3)" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_RTL8211X_PHY_FORCE_MASTER=y CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Ainol_AW1_defconfig b/configs/Ainol_AW1_defconfig index 486baed..3ff15f8 100644 --- a/configs/Ainol_AW1_defconfig +++ b/configs/Ainol_AW1_defconfig @@ -17,5 +17,8 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/Ampe_A76_defconfig b/configs/Ampe_A76_defconfig index ce34985..e68e747 100644 --- a/configs/Ampe_A76_defconfig +++ b/configs/Ampe_A76_defconfig @@ -19,5 +19,8 @@ CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/Auxtek-T003_defconfig b/configs/Auxtek-T003_defconfig index bea5100..1b3d01d 100644 --- a/configs/Auxtek-T003_defconfig +++ b/configs/Auxtek-T003_defconfig @@ -11,6 +11,9 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_AXP152_POWER=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Auxtek-T004_defconfig b/configs/Auxtek-T004_defconfig index 6f0362f..8edb572 100644 --- a/configs/Auxtek-T004_defconfig +++ b/configs/Auxtek-T004_defconfig @@ -9,6 +9,9 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_AXP152_POWER=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/B4420QDS_NAND_defconfig b/configs/B4420QDS_NAND_defconfig index d9804d7..bcffc47 100644 --- a/configs/B4420QDS_NAND_defconfig +++ b/configs/B4420QDS_NAND_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_B4420,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/B4420QDS_SPIFLASH_defconfig b/configs/B4420QDS_SPIFLASH_defconfig index 66da74e..6208567 100644 --- a/configs/B4420QDS_SPIFLASH_defconfig +++ b/configs/B4420QDS_SPIFLASH_defconfig @@ -7,6 +7,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_B4420,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/B4420QDS_defconfig b/configs/B4420QDS_defconfig index 1b97a6a..300461b 100644 --- a/configs/B4420QDS_defconfig +++ b/configs/B4420QDS_defconfig @@ -7,6 +7,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_B4420" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/B4860QDS_NAND_defconfig b/configs/B4860QDS_NAND_defconfig index ff76dae..f7ff204 100644 --- a/configs/B4860QDS_NAND_defconfig +++ b/configs/B4860QDS_NAND_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_B4860,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/B4860QDS_SECURE_BOOT_defconfig b/configs/B4860QDS_SECURE_BOOT_defconfig index d26fe6e..75cf823 100644 --- a/configs/B4860QDS_SECURE_BOOT_defconfig +++ b/configs/B4860QDS_SECURE_BOOT_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_B4860,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/B4860QDS_SPIFLASH_defconfig b/configs/B4860QDS_SPIFLASH_defconfig index b0faa7f..e9c045e 100644 --- a/configs/B4860QDS_SPIFLASH_defconfig +++ b/configs/B4860QDS_SPIFLASH_defconfig @@ -7,6 +7,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_B4860,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/B4860QDS_SRIO_PCIE_BOOT_defconfig b/configs/B4860QDS_SRIO_PCIE_BOOT_defconfig index a63686c..b7ebc98 100644 --- a/configs/B4860QDS_SRIO_PCIE_BOOT_defconfig +++ b/configs/B4860QDS_SRIO_PCIE_BOOT_defconfig @@ -9,6 +9,11 @@ CONFIG_SYS_EXTRA_OPTIONS="PPC_B4860,SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF4000 CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/B4860QDS_defconfig b/configs/B4860QDS_defconfig index a29ab17..3420443 100644 --- a/configs/B4860QDS_defconfig +++ b/configs/B4860QDS_defconfig @@ -7,6 +7,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_B4860" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/BSC9131RDB_NAND_SYSCLK100_defconfig b/configs/BSC9131RDB_NAND_SYSCLK100_defconfig index f8ccf4a..fdf4954 100644 --- a/configs/BSC9131RDB_NAND_SYSCLK100_defconfig +++ b/configs/BSC9131RDB_NAND_SYSCLK100_defconfig @@ -10,6 +10,11 @@ CONFIG_SYS_EXTRA_OPTIONS="BSC9131RDB,NAND,SYS_CLK_100" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SYS_NS16550=y diff --git a/configs/BSC9131RDB_NAND_defconfig b/configs/BSC9131RDB_NAND_defconfig index b30132e..7c3683a 100644 --- a/configs/BSC9131RDB_NAND_defconfig +++ b/configs/BSC9131RDB_NAND_defconfig @@ -10,6 +10,11 @@ CONFIG_SYS_EXTRA_OPTIONS="BSC9131RDB,NAND" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SYS_NS16550=y diff --git a/configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig b/configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig index 7b5cea5..831e024 100644 --- a/configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig +++ b/configs/BSC9131RDB_SPIFLASH_SYSCLK100_defconfig @@ -9,6 +9,11 @@ CONFIG_SYS_EXTRA_OPTIONS="BSC9131RDB,SPIFLASH,SYS_CLK_100" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SYS_NS16550=y diff --git a/configs/BSC9131RDB_SPIFLASH_defconfig b/configs/BSC9131RDB_SPIFLASH_defconfig index 9258040..c365a45 100644 --- a/configs/BSC9131RDB_SPIFLASH_defconfig +++ b/configs/BSC9131RDB_SPIFLASH_defconfig @@ -9,6 +9,11 @@ CONFIG_SYS_EXTRA_OPTIONS="BSC9131RDB,SPIFLASH" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SYS_NS16550=y diff --git a/configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig b/configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig index db01bbb..f766e05 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK100_SECURE_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,NAND_SECBOOT,SYS_CLK_100_DDR_100,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/BSC9132QDS_NAND_DDRCLK100_defconfig b/configs/BSC9132QDS_NAND_DDRCLK100_defconfig index c59d2e5..100f1bf 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK100_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK100_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,NAND,SYS_CLK_100_DDR_100" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig b/configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig index e5364bf..433b62d 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK133_SECURE_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,NAND_SECBOOT,SYS_CLK_100_DDR_133,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/BSC9132QDS_NAND_DDRCLK133_defconfig b/configs/BSC9132QDS_NAND_DDRCLK133_defconfig index 3688646..2eb85d1 100644 --- a/configs/BSC9132QDS_NAND_DDRCLK133_defconfig +++ b/configs/BSC9132QDS_NAND_DDRCLK133_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,NAND,SYS_CLK_100_DDR_133" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig b/configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig index 3b75bb4..f0bb1cd 100644 --- a/configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig +++ b/configs/BSC9132QDS_NOR_DDRCLK100_SECURE_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SYS_CLK_100_DDR_100,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/BSC9132QDS_NOR_DDRCLK100_defconfig b/configs/BSC9132QDS_NOR_DDRCLK100_defconfig index 822c14b..f521407 100644 --- a/configs/BSC9132QDS_NOR_DDRCLK100_defconfig +++ b/configs/BSC9132QDS_NOR_DDRCLK100_defconfig @@ -7,6 +7,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SYS_CLK_100_DDR_100" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig b/configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig index 53e5626..2708794 100644 --- a/configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig +++ b/configs/BSC9132QDS_NOR_DDRCLK133_SECURE_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SYS_CLK_100_DDR_133,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/BSC9132QDS_NOR_DDRCLK133_defconfig b/configs/BSC9132QDS_NOR_DDRCLK133_defconfig index bd8cf10..df67271 100644 --- a/configs/BSC9132QDS_NOR_DDRCLK133_defconfig +++ b/configs/BSC9132QDS_NOR_DDRCLK133_defconfig @@ -7,6 +7,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SYS_CLK_100_DDR_133" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig b/configs/BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig index 23d7138..072c2e5 100644 --- a/configs/BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig +++ b/configs/BSC9132QDS_SDCARD_DDRCLK100_SECURE_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SDCARD,SYS_CLK_100_DDR_100,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig b/configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig index 27dda3a..f3d96b3 100644 --- a/configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig +++ b/configs/BSC9132QDS_SDCARD_DDRCLK100_defconfig @@ -7,6 +7,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SDCARD,SYS_CLK_100_DDR_100" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig b/configs/BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig index f3febf6..231dab0 100644 --- a/configs/BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig +++ b/configs/BSC9132QDS_SDCARD_DDRCLK133_SECURE_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SDCARD,SYS_CLK_100_DDR_133,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig b/configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig index ecd0ddb..c775caa 100644 --- a/configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig +++ b/configs/BSC9132QDS_SDCARD_DDRCLK133_defconfig @@ -7,6 +7,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SDCARD,SYS_CLK_100_DDR_133" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig b/configs/BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig index 91cadef..2fb85e9 100644 --- a/configs/BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig +++ b/configs/BSC9132QDS_SPIFLASH_DDRCLK100_SECURE_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SPIFLASH,SYS_CLK_100_DDR_100,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig b/configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig index 9b612f8..89f7aa5 100644 --- a/configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig +++ b/configs/BSC9132QDS_SPIFLASH_DDRCLK100_defconfig @@ -7,6 +7,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SPIFLASH,SYS_CLK_100_DDR_100" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig b/configs/BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig index 0eb8f15..43ccad1 100644 --- a/configs/BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig +++ b/configs/BSC9132QDS_SPIFLASH_DDRCLK133_SECURE_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SPIFLASH,SYS_CLK_100_DDR_133,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig b/configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig index a40bd6c..09421e0 100644 --- a/configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig +++ b/configs/BSC9132QDS_SPIFLASH_DDRCLK133_defconfig @@ -7,6 +7,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="BSC9132QDS,SPIFLASH,SYS_CLK_100_DDR_133" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/Bananapi_defconfig b/configs/Bananapi_defconfig index 054d7ce..f7db498 100644 --- a/configs/Bananapi_defconfig +++ b/configs/Bananapi_defconfig @@ -11,7 +11,10 @@ CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),AHCI" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NETCONSOLE=y CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Bananapro_defconfig b/configs/Bananapro_defconfig index b3b36ac..74c7446 100644 --- a/configs/Bananapro_defconfig +++ b/configs/Bananapro_defconfig @@ -13,7 +13,10 @@ CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),AHCI" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NETCONSOLE=y CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_ALDO4_VOLT=2500 diff --git a/configs/C29XPCIE_NAND_defconfig b/configs/C29XPCIE_NAND_defconfig index 6b455b1..d342640 100644 --- a/configs/C29XPCIE_NAND_defconfig +++ b/configs/C29XPCIE_NAND_defconfig @@ -9,6 +9,9 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="C29XPCIE,36BIT,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/C29XPCIE_NOR_SECBOOT_defconfig b/configs/C29XPCIE_NOR_SECBOOT_defconfig index 93eea63..5bedcb4 100644 --- a/configs/C29XPCIE_NOR_SECBOOT_defconfig +++ b/configs/C29XPCIE_NOR_SECBOOT_defconfig @@ -8,6 +8,9 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="C29XPCIE,36BIT,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y diff --git a/configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig b/configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig index 5bf96b8..f74c103 100644 --- a/configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig +++ b/configs/C29XPCIE_SPIFLASH_SECBOOT_defconfig @@ -8,6 +8,9 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="C29XPCIE,36BIT,SPIFLASH,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y diff --git a/configs/C29XPCIE_SPIFLASH_defconfig b/configs/C29XPCIE_SPIFLASH_defconfig index 3597dbb..541ae65 100644 --- a/configs/C29XPCIE_SPIFLASH_defconfig +++ b/configs/C29XPCIE_SPIFLASH_defconfig @@ -7,6 +7,9 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="C29XPCIE,36BIT,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/C29XPCIE_defconfig b/configs/C29XPCIE_defconfig index 7c6f233..7c50ea9 100644 --- a/configs/C29XPCIE_defconfig +++ b/configs/C29XPCIE_defconfig @@ -7,6 +7,9 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="C29XPCIE,36BIT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/CHIP_defconfig b/configs/CHIP_defconfig index 0e72d2c..4ef1840 100644 --- a/configs/CHIP_defconfig +++ b/configs/CHIP_defconfig @@ -10,6 +10,9 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_AXP_ALDO3_VOLT=3300 CONFIG_AXP_ALDO4_VOLT=3300 CONFIG_USB_MUSB_GADGET=y diff --git a/configs/CPCI2DP_defconfig b/configs/CPCI2DP_defconfig index 1c821ba..ea0775d 100644 --- a/configs/CPCI2DP_defconfig +++ b/configs/CPCI2DP_defconfig @@ -1,6 +1,8 @@ CONFIG_PPC=y CONFIG_4xx=y CONFIG_TARGET_CPCI2DP=y +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set diff --git a/configs/CPCI4052_defconfig b/configs/CPCI4052_defconfig index 49810ff..c00ca1f 100644 --- a/configs/CPCI4052_defconfig +++ b/configs/CPCI4052_defconfig @@ -5,6 +5,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/CSQ_CS908_defconfig b/configs/CSQ_CS908_defconfig index d0a2bd2..a0ed7a0 100644 --- a/configs/CSQ_CS908_defconfig +++ b/configs/CSQ_CS908_defconfig @@ -12,6 +12,8 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_ALDO1_VOLT=3300 CONFIG_AXP_DLDO1_VOLT=3300 diff --git a/configs/Chuwi_V7_CW0825_defconfig b/configs/Chuwi_V7_CW0825_defconfig index 393f337..ec30918 100644 --- a/configs/Chuwi_V7_CW0825_defconfig +++ b/configs/Chuwi_V7_CW0825_defconfig @@ -17,7 +17,10 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_USB_MUSB_HOST=y CONFIG_VIDEO_LCD_SPI_CS="PA0" CONFIG_VIDEO_LCD_SPI_SCLK="PA1" diff --git a/configs/Colombus_defconfig b/configs/Colombus_defconfig index 85322d4..078243e 100644 --- a/configs/Colombus_defconfig +++ b/configs/Colombus_defconfig @@ -21,7 +21,10 @@ CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_ALDO1_VOLT=3300 CONFIG_USB_EHCI_HCD=y diff --git a/configs/Cubieboard2_defconfig b/configs/Cubieboard2_defconfig index 26c770c..0a1f6cd 100644 --- a/configs/Cubieboard2_defconfig +++ b/configs/Cubieboard2_defconfig @@ -10,6 +10,9 @@ CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPB(8)" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Cubieboard_defconfig b/configs/Cubieboard_defconfig index 22372ef..3f3f812 100644 --- a/configs/Cubieboard_defconfig +++ b/configs/Cubieboard_defconfig @@ -10,5 +10,8 @@ CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,AHCI,SATAPWR=SUNXI_GPB(8)" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Cubietruck_defconfig b/configs/Cubietruck_defconfig index ea7cc0c..9eff740 100644 --- a/configs/Cubietruck_defconfig +++ b/configs/Cubietruck_defconfig @@ -15,7 +15,10 @@ CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,AHCI,SATAPWR=SUNXI_GPH(12)" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y diff --git a/configs/Cubietruck_plus_defconfig b/configs/Cubietruck_plus_defconfig index 608ee14..5a15a58 100644 --- a/configs/Cubietruck_plus_defconfig +++ b/configs/Cubietruck_plus_defconfig @@ -18,7 +18,10 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_AXP_DLDO3_VOLT=2500 CONFIG_AXP_DLDO4_VOLT=3300 CONFIG_AXP_FLDO1_VOLT=1200 diff --git a/configs/Cyrus_P5020_defconfig b/configs/Cyrus_P5020_defconfig index a7c8897..b60c569 100644 --- a/configs/Cyrus_P5020_defconfig +++ b/configs/Cyrus_P5020_defconfig @@ -9,6 +9,10 @@ CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SYS_TEXT_BASE=0xFFF40000,PPC_P5020" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/Cyrus_P5040_defconfig b/configs/Cyrus_P5040_defconfig index 2618a72..0d86a8f 100644 --- a/configs/Cyrus_P5040_defconfig +++ b/configs/Cyrus_P5040_defconfig @@ -9,6 +9,10 @@ CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SYS_TEXT_BASE=0xFFF40000,PPC_P5040" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/Empire_electronix_d709_defconfig b/configs/Empire_electronix_d709_defconfig index 12f74df..7daafb8 100644 --- a/configs/Empire_electronix_d709_defconfig +++ b/configs/Empire_electronix_d709_defconfig @@ -20,5 +20,8 @@ CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/Hummingbird_A31_defconfig b/configs/Hummingbird_A31_defconfig index cbe8341..5b221c3 100644 --- a/configs/Hummingbird_A31_defconfig +++ b/configs/Hummingbird_A31_defconfig @@ -14,6 +14,8 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_ALDO1_VOLT=3300 CONFIG_USB_EHCI_HCD=y diff --git a/configs/Hyundai_A7HD_defconfig b/configs/Hyundai_A7HD_defconfig index 883edd9..b9f7f0e 100644 --- a/configs/Hyundai_A7HD_defconfig +++ b/configs/Hyundai_A7HD_defconfig @@ -18,5 +18,8 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/Itead_Ibox_A20_defconfig b/configs/Itead_Ibox_A20_defconfig index 2209cbf..3959bae 100644 --- a/configs/Itead_Ibox_A20_defconfig +++ b/configs/Itead_Ibox_A20_defconfig @@ -10,6 +10,9 @@ CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPB(8)" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Lamobo_R1_defconfig b/configs/Lamobo_R1_defconfig index 96a876c..f6cae6b 100644 --- a/configs/Lamobo_R1_defconfig +++ b/configs/Lamobo_R1_defconfig @@ -11,6 +11,9 @@ CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),AHCI,SATAPWR=SUN CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Linksprite_pcDuino3_Nano_defconfig b/configs/Linksprite_pcDuino3_Nano_defconfig index 718aba5..69a082c 100644 --- a/configs/Linksprite_pcDuino3_Nano_defconfig +++ b/configs/Linksprite_pcDuino3_Nano_defconfig @@ -12,6 +12,9 @@ CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,AHCI,SATAPWR=SUNXI_GPH(2)" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Linksprite_pcDuino3_defconfig b/configs/Linksprite_pcDuino3_defconfig index 0e95c76..8eeff7b 100644 --- a/configs/Linksprite_pcDuino3_defconfig +++ b/configs/Linksprite_pcDuino3_defconfig @@ -10,6 +10,9 @@ CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,AHCI,SATAPWR=SUNXI_GPH(2)" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Linksprite_pcDuino_defconfig b/configs/Linksprite_pcDuino_defconfig index 9af4db9..4a09f29 100644 --- a/configs/Linksprite_pcDuino_defconfig +++ b/configs/Linksprite_pcDuino_defconfig @@ -10,5 +10,8 @@ CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/M5208EVBE_defconfig b/configs/M5208EVBE_defconfig index 7a12522..55841e6 100644 --- a/configs/M5208EVBE_defconfig +++ b/configs/M5208EVBE_defconfig @@ -3,3 +3,4 @@ CONFIG_TARGET_M5208EVBE=y CONFIG_SYS_TEXT_BASE=0x00000000 CONFIG_SYS_PROMPT="-> " # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y diff --git a/configs/M52277EVB_defconfig b/configs/M52277EVB_defconfig index 711a411..d3519dd 100644 --- a/configs/M52277EVB_defconfig +++ b/configs/M52277EVB_defconfig @@ -3,6 +3,9 @@ CONFIG_TARGET_M52277EVB=y CONFIG_SYS_TEXT_BASE=0x00000000 CONFIG_SYS_EXTRA_OPTIONS="SYS_SPANSION_BOOT" CONFIG_SYS_PROMPT="-> " +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set diff --git a/configs/M52277EVB_stmicro_defconfig b/configs/M52277EVB_stmicro_defconfig index 05d20d6..b978c02 100644 --- a/configs/M52277EVB_stmicro_defconfig +++ b/configs/M52277EVB_stmicro_defconfig @@ -2,6 +2,9 @@ CONFIG_M68K=y CONFIG_TARGET_M52277EVB=y CONFIG_SYS_TEXT_BASE=0x43E00000 CONFIG_SYS_EXTRA_OPTIONS="CF_SBF,SYS_STMICRO_BOOT" +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set diff --git a/configs/M5235EVB_Flash32_defconfig b/configs/M5235EVB_Flash32_defconfig index b8fb413..6bbacf3 100644 --- a/configs/M5235EVB_Flash32_defconfig +++ b/configs/M5235EVB_Flash32_defconfig @@ -4,4 +4,7 @@ CONFIG_SYS_TEXT_BASE=0xFFC00000 CONFIG_SYS_EXTRA_OPTIONS="NORFLASH_PS32BIT" # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y diff --git a/configs/M5235EVB_defconfig b/configs/M5235EVB_defconfig index fdf2dd0..979d78c 100644 --- a/configs/M5235EVB_defconfig +++ b/configs/M5235EVB_defconfig @@ -4,4 +4,7 @@ CONFIG_SYS_TEXT_BASE=0xFFE00000 CONFIG_SYS_PROMPT="-> " # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y diff --git a/configs/M5249EVB_defconfig b/configs/M5249EVB_defconfig index 2358d24..9bc8da9 100644 --- a/configs/M5249EVB_defconfig +++ b/configs/M5249EVB_defconfig @@ -1,5 +1,6 @@ CONFIG_M68K=y CONFIG_TARGET_M5249EVB=y CONFIG_SYS_TEXT_BASE=0xffe00000 +CONFIG_LOOPW=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set diff --git a/configs/M5253DEMO_defconfig b/configs/M5253DEMO_defconfig index c4da196..8c4678b 100644 --- a/configs/M5253DEMO_defconfig +++ b/configs/M5253DEMO_defconfig @@ -2,3 +2,4 @@ CONFIG_M68K=y CONFIG_TARGET_M5253DEMO=y CONFIG_SYS_TEXT_BASE=0xFF800000 # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y diff --git a/configs/M5272C3_defconfig b/configs/M5272C3_defconfig index 6153a5c..efcadd6 100644 --- a/configs/M5272C3_defconfig +++ b/configs/M5272C3_defconfig @@ -5,3 +5,4 @@ CONFIG_SYS_PROMPT="-> " # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y diff --git a/configs/M5275EVB_defconfig b/configs/M5275EVB_defconfig index d70fea1..dec9e63 100644 --- a/configs/M5275EVB_defconfig +++ b/configs/M5275EVB_defconfig @@ -4,4 +4,7 @@ CONFIG_SYS_TEXT_BASE=0xffe00000 CONFIG_SYS_PROMPT="-> " # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y diff --git a/configs/M5282EVB_defconfig b/configs/M5282EVB_defconfig index 10a3043..7aa36d9 100644 --- a/configs/M5282EVB_defconfig +++ b/configs/M5282EVB_defconfig @@ -5,3 +5,4 @@ CONFIG_SYS_PROMPT="-> " # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y diff --git a/configs/M53017EVB_defconfig b/configs/M53017EVB_defconfig index e86fe5b..c63acd9 100644 --- a/configs/M53017EVB_defconfig +++ b/configs/M53017EVB_defconfig @@ -3,3 +3,4 @@ CONFIG_TARGET_M53017EVB=y CONFIG_SYS_TEXT_BASE=0x00000000 CONFIG_SYS_PROMPT="-> " # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y diff --git a/configs/M5329AFEE_defconfig b/configs/M5329AFEE_defconfig index 2379a1e..51d0ba2 100644 --- a/configs/M5329AFEE_defconfig +++ b/configs/M5329AFEE_defconfig @@ -3,4 +3,6 @@ CONFIG_TARGET_M5329EVB=y CONFIG_SYS_TEXT_BASE=0x00000000 CONFIG_SYS_EXTRA_OPTIONS="NANDFLASH_SIZE=0" CONFIG_SYS_PROMPT="-> " +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y diff --git a/configs/M5329BFEE_defconfig b/configs/M5329BFEE_defconfig index 38a996b..cb79dbd 100644 --- a/configs/M5329BFEE_defconfig +++ b/configs/M5329BFEE_defconfig @@ -3,4 +3,6 @@ CONFIG_TARGET_M5329EVB=y CONFIG_SYS_TEXT_BASE=0x00000000 CONFIG_SYS_EXTRA_OPTIONS="NANDFLASH_SIZE=16" CONFIG_SYS_PROMPT="-> " +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y diff --git a/configs/M5373EVB_defconfig b/configs/M5373EVB_defconfig index 6595feb..52175cf 100644 --- a/configs/M5373EVB_defconfig +++ b/configs/M5373EVB_defconfig @@ -3,4 +3,6 @@ CONFIG_TARGET_M5373EVB=y CONFIG_SYS_TEXT_BASE=0x00000000 CONFIG_SYS_EXTRA_OPTIONS="NANDFLASH_SIZE=16" CONFIG_SYS_PROMPT="-> " +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y diff --git a/configs/M54418TWR_defconfig b/configs/M54418TWR_defconfig index 19f8983..fac2fda 100644 --- a/configs/M54418TWR_defconfig +++ b/configs/M54418TWR_defconfig @@ -8,6 +8,10 @@ CONFIG_SYS_PROMPT="-> " # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/M54418TWR_nand_mii_defconfig b/configs/M54418TWR_nand_mii_defconfig index bc6f63a..a013ac8 100644 --- a/configs/M54418TWR_nand_mii_defconfig +++ b/configs/M54418TWR_nand_mii_defconfig @@ -8,6 +8,10 @@ CONFIG_SYS_PROMPT="-> " # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/M54418TWR_nand_rmii_defconfig b/configs/M54418TWR_nand_rmii_defconfig index a42f603..c29618c 100644 --- a/configs/M54418TWR_nand_rmii_defconfig +++ b/configs/M54418TWR_nand_rmii_defconfig @@ -8,6 +8,10 @@ CONFIG_SYS_PROMPT="-> " # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/M54418TWR_nand_rmii_lowfreq_defconfig b/configs/M54418TWR_nand_rmii_lowfreq_defconfig index a6c595d..522a150 100644 --- a/configs/M54418TWR_nand_rmii_lowfreq_defconfig +++ b/configs/M54418TWR_nand_rmii_lowfreq_defconfig @@ -8,6 +8,10 @@ CONFIG_SYS_PROMPT="-> " # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/M54418TWR_serial_mii_defconfig b/configs/M54418TWR_serial_mii_defconfig index bdfa3b4..2301738 100644 --- a/configs/M54418TWR_serial_mii_defconfig +++ b/configs/M54418TWR_serial_mii_defconfig @@ -8,6 +8,10 @@ CONFIG_SYS_PROMPT="-> " # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/M54418TWR_serial_rmii_defconfig b/configs/M54418TWR_serial_rmii_defconfig index 19f8983..fac2fda 100644 --- a/configs/M54418TWR_serial_rmii_defconfig +++ b/configs/M54418TWR_serial_rmii_defconfig @@ -8,6 +8,10 @@ CONFIG_SYS_PROMPT="-> " # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/M54451EVB_defconfig b/configs/M54451EVB_defconfig index a9fe02f..36fa4ea 100644 --- a/configs/M54451EVB_defconfig +++ b/configs/M54451EVB_defconfig @@ -5,6 +5,11 @@ CONFIG_SYS_EXTRA_OPTIONS="SYS_INPUT_CLKSRC=24000000" CONFIG_SYS_PROMPT="-> " # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/M54451EVB_stmicro_defconfig b/configs/M54451EVB_stmicro_defconfig index f10e86c..e526b46 100644 --- a/configs/M54451EVB_stmicro_defconfig +++ b/configs/M54451EVB_stmicro_defconfig @@ -4,6 +4,11 @@ CONFIG_SYS_TEXT_BASE=0x47e00000 CONFIG_SYS_EXTRA_OPTIONS="CF_SBF,SYS_STMICRO_BOOT,SYS_INPUT_CLKSRC=24000000" # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/M54455EVB_a66_defconfig b/configs/M54455EVB_a66_defconfig index 3053514..c8ba38c 100644 --- a/configs/M54455EVB_a66_defconfig +++ b/configs/M54455EVB_a66_defconfig @@ -4,6 +4,11 @@ CONFIG_SYS_TEXT_BASE=0x04000000 CONFIG_SYS_EXTRA_OPTIONS="SYS_ATMEL_BOOT,SYS_INPUT_CLKSRC=66666666" # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/M54455EVB_defconfig b/configs/M54455EVB_defconfig index 9f70f7e..e362886 100644 --- a/configs/M54455EVB_defconfig +++ b/configs/M54455EVB_defconfig @@ -5,6 +5,11 @@ CONFIG_SYS_EXTRA_OPTIONS="SYS_ATMEL_BOOT,SYS_INPUT_CLKSRC=33333333" CONFIG_SYS_PROMPT="-> " # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/M54455EVB_i66_defconfig b/configs/M54455EVB_i66_defconfig index 8421393..714c080 100644 --- a/configs/M54455EVB_i66_defconfig +++ b/configs/M54455EVB_i66_defconfig @@ -4,6 +4,11 @@ CONFIG_SYS_TEXT_BASE=0x00000000 CONFIG_SYS_EXTRA_OPTIONS="SYS_INTEL_BOOT,SYS_INPUT_CLKSRC=66666666" # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/M54455EVB_intel_defconfig b/configs/M54455EVB_intel_defconfig index c630108..e17382e 100644 --- a/configs/M54455EVB_intel_defconfig +++ b/configs/M54455EVB_intel_defconfig @@ -4,6 +4,11 @@ CONFIG_SYS_TEXT_BASE=0x00000000 CONFIG_SYS_EXTRA_OPTIONS="SYS_INTEL_BOOT,SYS_INPUT_CLKSRC=33333333" # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/M54455EVB_stm33_defconfig b/configs/M54455EVB_stm33_defconfig index 4e8aee4..ce2dd81 100644 --- a/configs/M54455EVB_stm33_defconfig +++ b/configs/M54455EVB_stm33_defconfig @@ -4,6 +4,11 @@ CONFIG_SYS_TEXT_BASE=0x4FE00000 CONFIG_SYS_EXTRA_OPTIONS="SYS_STMICRO_BOOT,CF_SBF,SYS_INPUT_CLKSRC=33333333" # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/M5475AFE_defconfig b/configs/M5475AFE_defconfig index edfb9fc..2131e0e 100644 --- a/configs/M5475AFE_defconfig +++ b/configs/M5475AFE_defconfig @@ -3,4 +3,7 @@ CONFIG_TARGET_M5475EVB=y CONFIG_SYS_TEXT_BASE=0xFF800000 CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64" CONFIG_SYS_PROMPT="-> " +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y diff --git a/configs/M5475BFE_defconfig b/configs/M5475BFE_defconfig index 5177eb9..ead78c8 100644 --- a/configs/M5475BFE_defconfig +++ b/configs/M5475BFE_defconfig @@ -3,4 +3,7 @@ CONFIG_TARGET_M5475EVB=y CONFIG_SYS_TEXT_BASE=0xFF800000 CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=16" CONFIG_SYS_PROMPT="-> " +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y diff --git a/configs/M5475CFE_defconfig b/configs/M5475CFE_defconfig index 431a264..04a31fd 100644 --- a/configs/M5475CFE_defconfig +++ b/configs/M5475CFE_defconfig @@ -3,4 +3,7 @@ CONFIG_TARGET_M5475EVB=y CONFIG_SYS_TEXT_BASE=0xFF800000 CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=16,SYS_VIDEO,SYS_USBCTRL" CONFIG_SYS_PROMPT="-> " +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y diff --git a/configs/M5475DFE_defconfig b/configs/M5475DFE_defconfig index 46d9964..242acc8 100644 --- a/configs/M5475DFE_defconfig +++ b/configs/M5475DFE_defconfig @@ -3,4 +3,7 @@ CONFIG_TARGET_M5475EVB=y CONFIG_SYS_TEXT_BASE=0xFF800000 CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_USBCTRL" CONFIG_SYS_PROMPT="-> " +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y diff --git a/configs/M5475EFE_defconfig b/configs/M5475EFE_defconfig index 4a2284d..3641a55 100644 --- a/configs/M5475EFE_defconfig +++ b/configs/M5475EFE_defconfig @@ -3,4 +3,7 @@ CONFIG_TARGET_M5475EVB=y CONFIG_SYS_TEXT_BASE=0xFF800000 CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_VIDEO,SYS_USBCTRL" CONFIG_SYS_PROMPT="-> " +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y diff --git a/configs/M5475FFE_defconfig b/configs/M5475FFE_defconfig index f8d53be..c0d1c5e 100644 --- a/configs/M5475FFE_defconfig +++ b/configs/M5475FFE_defconfig @@ -3,4 +3,7 @@ CONFIG_TARGET_M5475EVB=y CONFIG_SYS_TEXT_BASE=0xFF800000 CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=133333333,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=32,SYS_VIDEO,SYS_USBCTRL,SYS_DRAMSZ1=64" CONFIG_SYS_PROMPT="-> " +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y diff --git a/configs/M5475GFE_defconfig b/configs/M5475GFE_defconfig index 61a3c56..57c5770 100644 --- a/configs/M5475GFE_defconfig +++ b/configs/M5475GFE_defconfig @@ -3,4 +3,7 @@ CONFIG_TARGET_M5475EVB=y CONFIG_SYS_TEXT_BASE=0xFF800000 CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=133333333,SYS_BOOTSZ=4,SYS_DRAMSZ=64" CONFIG_SYS_PROMPT="-> " +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y diff --git a/configs/M5485AFE_defconfig b/configs/M5485AFE_defconfig index a8afe71..917d4bd 100644 --- a/configs/M5485AFE_defconfig +++ b/configs/M5485AFE_defconfig @@ -3,4 +3,7 @@ CONFIG_TARGET_M5485EVB=y CONFIG_SYS_TEXT_BASE=0xFF800000 CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64" CONFIG_SYS_PROMPT="-> " +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y diff --git a/configs/M5485BFE_defconfig b/configs/M5485BFE_defconfig index b9bdd4b..1dc119a 100644 --- a/configs/M5485BFE_defconfig +++ b/configs/M5485BFE_defconfig @@ -3,4 +3,7 @@ CONFIG_TARGET_M5485EVB=y CONFIG_SYS_TEXT_BASE=0xFF800000 CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=16" CONFIG_SYS_PROMPT="-> " +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y diff --git a/configs/M5485CFE_defconfig b/configs/M5485CFE_defconfig index c5ec396..73c4d8a 100644 --- a/configs/M5485CFE_defconfig +++ b/configs/M5485CFE_defconfig @@ -3,4 +3,7 @@ CONFIG_TARGET_M5485EVB=y CONFIG_SYS_TEXT_BASE=0xFF800000 CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=16,SYS_VIDEO,SYS_USBCTRL" CONFIG_SYS_PROMPT="-> " +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y diff --git a/configs/M5485DFE_defconfig b/configs/M5485DFE_defconfig index 6872865..46ea740 100644 --- a/configs/M5485DFE_defconfig +++ b/configs/M5485DFE_defconfig @@ -3,4 +3,7 @@ CONFIG_TARGET_M5485EVB=y CONFIG_SYS_TEXT_BASE=0xFF800000 CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_USBCTRL" CONFIG_SYS_PROMPT="-> " +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y diff --git a/configs/M5485EFE_defconfig b/configs/M5485EFE_defconfig index c0d1e06..f2ae822 100644 --- a/configs/M5485EFE_defconfig +++ b/configs/M5485EFE_defconfig @@ -3,4 +3,7 @@ CONFIG_TARGET_M5485EVB=y CONFIG_SYS_TEXT_BASE=0xFF800000 CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_VIDEO,SYS_USBCTRL" CONFIG_SYS_PROMPT="-> " +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y diff --git a/configs/M5485FFE_defconfig b/configs/M5485FFE_defconfig index 904a639..f2b3f62 100644 --- a/configs/M5485FFE_defconfig +++ b/configs/M5485FFE_defconfig @@ -3,4 +3,7 @@ CONFIG_TARGET_M5485EVB=y CONFIG_SYS_TEXT_BASE=0xFF800000 CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=32,SYS_VIDEO,SYS_USBCTRL,SYS_DRAMSZ1=64" CONFIG_SYS_PROMPT="-> " +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y diff --git a/configs/M5485GFE_defconfig b/configs/M5485GFE_defconfig index cb6f2c7..83f39b0 100644 --- a/configs/M5485GFE_defconfig +++ b/configs/M5485GFE_defconfig @@ -3,4 +3,7 @@ CONFIG_TARGET_M5485EVB=y CONFIG_SYS_TEXT_BASE=0xFF800000 CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=100000000,SYS_BOOTSZ=4,SYS_DRAMSZ=64" CONFIG_SYS_PROMPT="-> " +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y diff --git a/configs/M5485HFE_defconfig b/configs/M5485HFE_defconfig index a3ef210..2e5bda4 100644 --- a/configs/M5485HFE_defconfig +++ b/configs/M5485HFE_defconfig @@ -3,4 +3,7 @@ CONFIG_TARGET_M5485EVB=y CONFIG_SYS_TEXT_BASE=0xFF800000 CONFIG_SYS_EXTRA_OPTIONS="SYS_BUSCLK=100000000,SYS_BOOTSZ=2,SYS_DRAMSZ=64,SYS_NOR1SZ=16,SYS_VIDEO" CONFIG_SYS_PROMPT="-> " +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y diff --git a/configs/MIP405T_defconfig b/configs/MIP405T_defconfig index 641fa06..c2bc17c 100644 --- a/configs/MIP405T_defconfig +++ b/configs/MIP405T_defconfig @@ -3,5 +3,8 @@ CONFIG_4xx=y CONFIG_TARGET_MIP405=y CONFIG_SYS_EXTRA_OPTIONS="MIP405T" CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y diff --git a/configs/MIP405_defconfig b/configs/MIP405_defconfig index 2250011..c243de8 100644 --- a/configs/MIP405_defconfig +++ b/configs/MIP405_defconfig @@ -2,5 +2,9 @@ CONFIG_PPC=y CONFIG_4xx=y CONFIG_TARGET_MIP405=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y diff --git a/configs/MK808C_defconfig b/configs/MK808C_defconfig index a363004..f8bf52a 100644 --- a/configs/MK808C_defconfig +++ b/configs/MK808C_defconfig @@ -8,5 +8,8 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/MPC8308RDB_defconfig b/configs/MPC8308RDB_defconfig index 546e7c7..0ae4c7f 100644 --- a/configs/MPC8308RDB_defconfig +++ b/configs/MPC8308RDB_defconfig @@ -6,6 +6,9 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8313ERDB_33_defconfig b/configs/MPC8313ERDB_33_defconfig index ca1cfcd..96c9d54 100644 --- a/configs/MPC8313ERDB_33_defconfig +++ b/configs/MPC8313ERDB_33_defconfig @@ -5,7 +5,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_33MHZ" CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8313ERDB_66_defconfig b/configs/MPC8313ERDB_66_defconfig index 9d4db2a..1d004fe 100644 --- a/configs/MPC8313ERDB_66_defconfig +++ b/configs/MPC8313ERDB_66_defconfig @@ -5,7 +5,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_66MHZ" CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8313ERDB_NAND_33_defconfig b/configs/MPC8313ERDB_NAND_33_defconfig index 0df5e8b..893657e 100644 --- a/configs/MPC8313ERDB_NAND_33_defconfig +++ b/configs/MPC8313ERDB_NAND_33_defconfig @@ -6,7 +6,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_33MHZ,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8313ERDB_NAND_66_defconfig b/configs/MPC8313ERDB_NAND_66_defconfig index 8913a18..cb3c686 100644 --- a/configs/MPC8313ERDB_NAND_66_defconfig +++ b/configs/MPC8313ERDB_NAND_66_defconfig @@ -6,7 +6,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_66MHZ,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8315ERDB_defconfig b/configs/MPC8315ERDB_defconfig index f6d7c0f..97e7672 100644 --- a/configs/MPC8315ERDB_defconfig +++ b/configs/MPC8315ERDB_defconfig @@ -4,6 +4,9 @@ CONFIG_TARGET_MPC8315ERDB=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8323ERDB_defconfig b/configs/MPC8323ERDB_defconfig index 3d13b8f..7f6156c 100644 --- a/configs/MPC8323ERDB_defconfig +++ b/configs/MPC8323ERDB_defconfig @@ -4,6 +4,8 @@ CONFIG_TARGET_MPC8323ERDB=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC832XEMDS_ATM_defconfig b/configs/MPC832XEMDS_ATM_defconfig index e573e0d..759165d 100644 --- a/configs/MPC832XEMDS_ATM_defconfig +++ b/configs/MPC832XEMDS_ATM_defconfig @@ -5,6 +5,8 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PQ_MDS_PIB=1,PQ_MDS_PIB_ATM=1" CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC832XEMDS_HOST_33_defconfig b/configs/MPC832XEMDS_HOST_33_defconfig index c32e0e9..08f1a41 100644 --- a/configs/MPC832XEMDS_HOST_33_defconfig +++ b/configs/MPC832XEMDS_HOST_33_defconfig @@ -5,6 +5,8 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PCI,PCI_33M,PQ_MDS_PIB=1" CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC832XEMDS_HOST_66_defconfig b/configs/MPC832XEMDS_HOST_66_defconfig index 2247e38..43d121c 100644 --- a/configs/MPC832XEMDS_HOST_66_defconfig +++ b/configs/MPC832XEMDS_HOST_66_defconfig @@ -5,6 +5,8 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PCI,PCI_66M,PQ_MDS_PIB=1" CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC832XEMDS_SLAVE_defconfig b/configs/MPC832XEMDS_SLAVE_defconfig index a4b4257..079d017 100644 --- a/configs/MPC832XEMDS_SLAVE_defconfig +++ b/configs/MPC832XEMDS_SLAVE_defconfig @@ -5,6 +5,8 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PCI,PCISLAVE" CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC832XEMDS_defconfig b/configs/MPC832XEMDS_defconfig index efc6555..cf38f89 100644 --- a/configs/MPC832XEMDS_defconfig +++ b/configs/MPC832XEMDS_defconfig @@ -4,6 +4,8 @@ CONFIG_TARGET_MPC832XEMDS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8349EMDS_defconfig b/configs/MPC8349EMDS_defconfig index ab992fc..988e33a 100644 --- a/configs/MPC8349EMDS_defconfig +++ b/configs/MPC8349EMDS_defconfig @@ -4,6 +4,8 @@ CONFIG_TARGET_MPC8349EMDS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8349ITXGP_defconfig b/configs/MPC8349ITXGP_defconfig index 64a8241..2506e77 100644 --- a/configs/MPC8349ITXGP_defconfig +++ b/configs/MPC8349ITXGP_defconfig @@ -6,6 +6,9 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="MPC8349ITXGP,SYS_TEXT_BASE=0xFE000000" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="MPC8349E-mITX-GP> " +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8349ITX_LOWBOOT_defconfig b/configs/MPC8349ITX_LOWBOOT_defconfig index 61f9e79..80eb01b 100644 --- a/configs/MPC8349ITX_LOWBOOT_defconfig +++ b/configs/MPC8349ITX_LOWBOOT_defconfig @@ -6,6 +6,10 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="MPC8349ITX,SYS_TEXT_BASE=0xFE000000" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="MPC8349E-mITX> " +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8349ITX_defconfig b/configs/MPC8349ITX_defconfig index 90a0df5..4c8cfce 100644 --- a/configs/MPC8349ITX_defconfig +++ b/configs/MPC8349ITX_defconfig @@ -6,6 +6,10 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="MPC8349ITX" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="MPC8349E-mITX> " +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC837XEMDS_HOST_defconfig b/configs/MPC837XEMDS_HOST_defconfig index eb1a597..b459a40 100644 --- a/configs/MPC837XEMDS_HOST_defconfig +++ b/configs/MPC837XEMDS_HOST_defconfig @@ -5,6 +5,9 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PCI" CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC837XEMDS_defconfig b/configs/MPC837XEMDS_defconfig index 99ff225..687fcfa 100644 --- a/configs/MPC837XEMDS_defconfig +++ b/configs/MPC837XEMDS_defconfig @@ -4,6 +4,8 @@ CONFIG_TARGET_MPC837XEMDS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC837XERDB_defconfig b/configs/MPC837XERDB_defconfig index f0bd789..a1982e5 100644 --- a/configs/MPC837XERDB_defconfig +++ b/configs/MPC837XERDB_defconfig @@ -4,6 +4,9 @@ CONFIG_TARGET_MPC837XERDB=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8536DS_36BIT_defconfig b/configs/MPC8536DS_36BIT_defconfig index 957c102..c70ec54 100644 --- a/configs/MPC8536DS_36BIT_defconfig +++ b/configs/MPC8536DS_36BIT_defconfig @@ -5,6 +5,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="36BIT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/MPC8536DS_SDCARD_defconfig b/configs/MPC8536DS_SDCARD_defconfig index 2eb8873..4343d40 100644 --- a/configs/MPC8536DS_SDCARD_defconfig +++ b/configs/MPC8536DS_SDCARD_defconfig @@ -5,6 +5,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/MPC8536DS_SPIFLASH_defconfig b/configs/MPC8536DS_SPIFLASH_defconfig index b551c80..003099d 100644 --- a/configs/MPC8536DS_SPIFLASH_defconfig +++ b/configs/MPC8536DS_SPIFLASH_defconfig @@ -5,6 +5,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/MPC8536DS_defconfig b/configs/MPC8536DS_defconfig index 60b944b..a746dbe 100644 --- a/configs/MPC8536DS_defconfig +++ b/configs/MPC8536DS_defconfig @@ -4,6 +4,10 @@ CONFIG_TARGET_MPC8536DS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/MPC8540ADS_defconfig b/configs/MPC8540ADS_defconfig index 6efbbc5..401a86d 100644 --- a/configs/MPC8540ADS_defconfig +++ b/configs/MPC8540ADS_defconfig @@ -4,5 +4,7 @@ CONFIG_TARGET_MPC8540ADS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8541CDS_defconfig b/configs/MPC8541CDS_defconfig index dde5a24..4e8b93d 100644 --- a/configs/MPC8541CDS_defconfig +++ b/configs/MPC8541CDS_defconfig @@ -4,5 +4,7 @@ CONFIG_TARGET_MPC8541CDS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8541CDS_legacy_defconfig b/configs/MPC8541CDS_legacy_defconfig index 1ab88f6..1c2316f 100644 --- a/configs/MPC8541CDS_legacy_defconfig +++ b/configs/MPC8541CDS_legacy_defconfig @@ -5,5 +5,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="LEGACY" CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8544DS_defconfig b/configs/MPC8544DS_defconfig index fd64677..83c0191 100644 --- a/configs/MPC8544DS_defconfig +++ b/configs/MPC8544DS_defconfig @@ -4,6 +4,9 @@ CONFIG_TARGET_MPC8544DS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_RTL8139=y diff --git a/configs/MPC8548CDS_36BIT_defconfig b/configs/MPC8548CDS_36BIT_defconfig index 5bdf2cc..06edf18 100644 --- a/configs/MPC8548CDS_36BIT_defconfig +++ b/configs/MPC8548CDS_36BIT_defconfig @@ -5,6 +5,8 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="36BIT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/MPC8548CDS_defconfig b/configs/MPC8548CDS_defconfig index 00595c4..3b89bda 100644 --- a/configs/MPC8548CDS_defconfig +++ b/configs/MPC8548CDS_defconfig @@ -4,6 +4,8 @@ CONFIG_TARGET_MPC8548CDS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/MPC8548CDS_legacy_defconfig b/configs/MPC8548CDS_legacy_defconfig index a95ea81..21819a3 100644 --- a/configs/MPC8548CDS_legacy_defconfig +++ b/configs/MPC8548CDS_legacy_defconfig @@ -5,6 +5,8 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="LEGACY" CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/MPC8555CDS_defconfig b/configs/MPC8555CDS_defconfig index e4ab923..e2de2a2 100644 --- a/configs/MPC8555CDS_defconfig +++ b/configs/MPC8555CDS_defconfig @@ -4,5 +4,7 @@ CONFIG_TARGET_MPC8555CDS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8555CDS_legacy_defconfig b/configs/MPC8555CDS_legacy_defconfig index 12364d1..d09370e 100644 --- a/configs/MPC8555CDS_legacy_defconfig +++ b/configs/MPC8555CDS_legacy_defconfig @@ -5,5 +5,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="LEGACY" CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8560ADS_defconfig b/configs/MPC8560ADS_defconfig index 11100c3..19407b3 100644 --- a/configs/MPC8560ADS_defconfig +++ b/configs/MPC8560ADS_defconfig @@ -4,4 +4,6 @@ CONFIG_TARGET_MPC8560ADS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8568MDS_defconfig b/configs/MPC8568MDS_defconfig index 7d4b01c..142d8bf 100644 --- a/configs/MPC8568MDS_defconfig +++ b/configs/MPC8568MDS_defconfig @@ -4,5 +4,7 @@ CONFIG_TARGET_MPC8568MDS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8569MDS_ATM_defconfig b/configs/MPC8569MDS_ATM_defconfig index 597dad7..8968ee8 100644 --- a/configs/MPC8569MDS_ATM_defconfig +++ b/configs/MPC8569MDS_ATM_defconfig @@ -5,6 +5,8 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="ATM" CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/MPC8569MDS_defconfig b/configs/MPC8569MDS_defconfig index adcbf49..efbb008 100644 --- a/configs/MPC8569MDS_defconfig +++ b/configs/MPC8569MDS_defconfig @@ -4,6 +4,8 @@ CONFIG_TARGET_MPC8569MDS=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/MPC8572DS_36BIT_defconfig b/configs/MPC8572DS_36BIT_defconfig index 9dc690f..b2c5a70 100644 --- a/configs/MPC8572DS_36BIT_defconfig +++ b/configs/MPC8572DS_36BIT_defconfig @@ -7,6 +7,9 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="36BIT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/MPC8572DS_defconfig b/configs/MPC8572DS_defconfig index 76b9d25..c55289a 100644 --- a/configs/MPC8572DS_defconfig +++ b/configs/MPC8572DS_defconfig @@ -6,6 +6,9 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/MPC8610HPCD_defconfig b/configs/MPC8610HPCD_defconfig index 2b4cc3a..38e2034 100644 --- a/configs/MPC8610HPCD_defconfig +++ b/configs/MPC8610HPCD_defconfig @@ -4,6 +4,9 @@ CONFIG_TARGET_MPC8610HPCD=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8641HPCN_36BIT_defconfig b/configs/MPC8641HPCN_36BIT_defconfig index e1fb77f..b8dede6 100644 --- a/configs/MPC8641HPCN_36BIT_defconfig +++ b/configs/MPC8641HPCN_36BIT_defconfig @@ -5,6 +5,9 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PHYS_64BIT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MPC8641HPCN_defconfig b/configs/MPC8641HPCN_defconfig index 9b2a697..98bf168 100644 --- a/configs/MPC8641HPCN_defconfig +++ b/configs/MPC8641HPCN_defconfig @@ -4,6 +4,9 @@ CONFIG_TARGET_MPC8641HPCN=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/MSI_Primo73_defconfig b/configs/MSI_Primo73_defconfig index 2f4e024..d335173 100644 --- a/configs/MSI_Primo73_defconfig +++ b/configs/MSI_Primo73_defconfig @@ -13,4 +13,7 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y diff --git a/configs/MSI_Primo81_defconfig b/configs/MSI_Primo81_defconfig index 7cf7b9d..3169c92 100644 --- a/configs/MSI_Primo81_defconfig +++ b/configs/MSI_Primo81_defconfig @@ -17,6 +17,8 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_MUSB_HOST=y CONFIG_VIDEO_LCD_SSD2828_TX_CLK=27 diff --git a/configs/Marsboard_A10_defconfig b/configs/Marsboard_A10_defconfig index 041baab..626fb4c 100644 --- a/configs/Marsboard_A10_defconfig +++ b/configs/Marsboard_A10_defconfig @@ -8,6 +8,9 @@ CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,AHCI" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SUNXI_NO_PMIC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Mele_A1000G_quad_defconfig b/configs/Mele_A1000G_quad_defconfig index e49be8a..2665a64 100644 --- a/configs/Mele_A1000G_quad_defconfig +++ b/configs/Mele_A1000G_quad_defconfig @@ -12,6 +12,8 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_DCDC1_VOLT=3300 CONFIG_AXP_ALDO1_VOLT=3300 diff --git a/configs/Mele_A1000_defconfig b/configs/Mele_A1000_defconfig index 3dab55c..b8c8f78 100644 --- a/configs/Mele_A1000_defconfig +++ b/configs/Mele_A1000_defconfig @@ -10,5 +10,8 @@ CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,MACPWR=SUNXI_GPH(15),AHCI" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Mele_I7_defconfig b/configs/Mele_I7_defconfig index 0d1c90e..82d91da 100644 --- a/configs/Mele_I7_defconfig +++ b/configs/Mele_I7_defconfig @@ -12,6 +12,8 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_DCDC1_VOLT=3300 CONFIG_AXP_ALDO1_VOLT=3300 diff --git a/configs/Mele_M3_defconfig b/configs/Mele_M3_defconfig index fb88d94..ba59216 100644 --- a/configs/Mele_M3_defconfig +++ b/configs/Mele_M3_defconfig @@ -13,6 +13,9 @@ CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Mele_M5_defconfig b/configs/Mele_M5_defconfig index 1db614f..725554d 100644 --- a/configs/Mele_M5_defconfig +++ b/configs/Mele_M5_defconfig @@ -12,6 +12,9 @@ CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,AHCI,STATUSLED=234" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Mele_M9_defconfig b/configs/Mele_M9_defconfig index 7291022..8d298f8 100644 --- a/configs/Mele_M9_defconfig +++ b/configs/Mele_M9_defconfig @@ -12,6 +12,8 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_DCDC1_VOLT=3300 CONFIG_AXP_ALDO1_VOLT=3300 diff --git a/configs/Merrii_A80_Optimus_defconfig b/configs/Merrii_A80_Optimus_defconfig index 3003c3e..47a12a4 100644 --- a/configs/Merrii_A80_Optimus_defconfig +++ b/configs/Merrii_A80_Optimus_defconfig @@ -12,3 +12,5 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y diff --git a/configs/MigoR_defconfig b/configs/MigoR_defconfig index 3255ed2..57b7db4 100644 --- a/configs/MigoR_defconfig +++ b/configs/MigoR_defconfig @@ -14,5 +14,6 @@ CONFIG_TARGET_MIGOR=y # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/Mini-X_defconfig b/configs/Mini-X_defconfig index bf88df6..ab2835c 100644 --- a/configs/Mini-X_defconfig +++ b/configs/Mini-X_defconfig @@ -9,6 +9,9 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/MiniFAP_defconfig b/configs/MiniFAP_defconfig index f393019..d9e609c 100644 --- a/configs/MiniFAP_defconfig +++ b/configs/MiniFAP_defconfig @@ -4,5 +4,11 @@ CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="MINIFAP" CONFIG_HUSH_PARSER=y +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y CONFIG_OF_LIBFDT=y diff --git a/configs/O2D300_defconfig b/configs/O2D300_defconfig index bc211aa..929e381 100644 --- a/configs/O2D300_defconfig +++ b/configs/O2D300_defconfig @@ -3,5 +3,8 @@ CONFIG_MPC5xxx=y CONFIG_TARGET_O2D300=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/O2DNT2_RAMBOOT_defconfig b/configs/O2DNT2_RAMBOOT_defconfig index 210da9a..181a69e 100644 --- a/configs/O2DNT2_RAMBOOT_defconfig +++ b/configs/O2DNT2_RAMBOOT_defconfig @@ -7,5 +7,8 @@ CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press password to stop\n" CONFIG_AUTOBOOT_STOP_STR="++++++++++" +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/O2DNT2_defconfig b/configs/O2DNT2_defconfig index 8cbf6eb..9e45ecd 100644 --- a/configs/O2DNT2_defconfig +++ b/configs/O2DNT2_defconfig @@ -6,5 +6,8 @@ CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press password to stop\n" CONFIG_AUTOBOOT_STOP_STR="++++++++++" +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/O2D_defconfig b/configs/O2D_defconfig index f33191b..f79b3e5 100644 --- a/configs/O2D_defconfig +++ b/configs/O2D_defconfig @@ -3,5 +3,8 @@ CONFIG_MPC5xxx=y CONFIG_TARGET_O2D=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/O2I_defconfig b/configs/O2I_defconfig index 14b940f..b40b709 100644 --- a/configs/O2I_defconfig +++ b/configs/O2I_defconfig @@ -3,5 +3,8 @@ CONFIG_MPC5xxx=y CONFIG_TARGET_O2I=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/O2MNT_O2M110_defconfig b/configs/O2MNT_O2M110_defconfig index 6c9eeb4..9327068 100644 --- a/configs/O2MNT_O2M110_defconfig +++ b/configs/O2MNT_O2M110_defconfig @@ -4,5 +4,8 @@ CONFIG_TARGET_O2MNT=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="IFM_SENSOR_TYPE="O2M110"" CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/O2MNT_O2M112_defconfig b/configs/O2MNT_O2M112_defconfig index 84e4243..de360dc 100644 --- a/configs/O2MNT_O2M112_defconfig +++ b/configs/O2MNT_O2M112_defconfig @@ -4,5 +4,8 @@ CONFIG_TARGET_O2MNT=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="IFM_SENSOR_TYPE="O2M112"" CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/O2MNT_O2M113_defconfig b/configs/O2MNT_O2M113_defconfig index 00c516f..4425621 100644 --- a/configs/O2MNT_O2M113_defconfig +++ b/configs/O2MNT_O2M113_defconfig @@ -4,5 +4,8 @@ CONFIG_TARGET_O2MNT=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="IFM_SENSOR_TYPE="O2M113"" CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/O2MNT_defconfig b/configs/O2MNT_defconfig index 55ff0fa..b3a656a 100644 --- a/configs/O2MNT_defconfig +++ b/configs/O2MNT_defconfig @@ -3,5 +3,8 @@ CONFIG_MPC5xxx=y CONFIG_TARGET_O2MNT=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/O3DNT_defconfig b/configs/O3DNT_defconfig index 9556964..0fb75c5 100644 --- a/configs/O3DNT_defconfig +++ b/configs/O3DNT_defconfig @@ -3,5 +3,8 @@ CONFIG_MPC5xxx=y CONFIG_TARGET_O3DNT=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/Orangepi_defconfig b/configs/Orangepi_defconfig index 6f502db..3631181 100644 --- a/configs/Orangepi_defconfig +++ b/configs/Orangepi_defconfig @@ -14,6 +14,9 @@ CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),AHCI" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Orangepi_mini_defconfig b/configs/Orangepi_mini_defconfig index c07d25e..9734edf 100644 --- a/configs/Orangepi_mini_defconfig +++ b/configs/Orangepi_mini_defconfig @@ -16,6 +16,9 @@ CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,MACPWR=SUNXI_GPH(23),AHCI" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig b/configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig index d91e4d3..c959a2e 100644 --- a/configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_36BIT_NAND_SECBOOT_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,36BIT,NAND_SECBOOT,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PA_36BIT_NAND_defconfig b/configs/P1010RDB-PA_36BIT_NAND_defconfig index 6af298f..6c8bcfd 100644 --- a/configs/P1010RDB-PA_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PA_36BIT_NAND_defconfig @@ -9,6 +9,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,36BIT,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig b/configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig index 72dac9f..6338a08 100644 --- a/configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_36BIT_NOR_SECBOOT_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,36BIT,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PA_36BIT_NOR_defconfig b/configs/P1010RDB-PA_36BIT_NOR_defconfig index b0410b0..d084188 100644 --- a/configs/P1010RDB-PA_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PA_36BIT_NOR_defconfig @@ -7,6 +7,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,36BIT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig index 14b9511..2de562f 100644 --- a/configs/P1010RDB-PA_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PA_36BIT_SDCARD_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,36BIT,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig b/configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig index 1036eb4..148748d 100644 --- a/configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_36BIT_SPIFLASH_SECBOOT_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,36BIT,SPIFLASH,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig index ac8ca85..acf03c6 100644 --- a/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_36BIT_SPIFLASH_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,36BIT,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PA_NAND_SECBOOT_defconfig b/configs/P1010RDB-PA_NAND_SECBOOT_defconfig index e668725..788fe9e 100644 --- a/configs/P1010RDB-PA_NAND_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_NAND_SECBOOT_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,NAND_SECBOOT,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PA_NAND_defconfig b/configs/P1010RDB-PA_NAND_defconfig index f99039d..d6138f9 100644 --- a/configs/P1010RDB-PA_NAND_defconfig +++ b/configs/P1010RDB-PA_NAND_defconfig @@ -9,6 +9,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PA_NOR_SECBOOT_defconfig b/configs/P1010RDB-PA_NOR_SECBOOT_defconfig index 8af53af..b0df9d2 100644 --- a/configs/P1010RDB-PA_NOR_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_NOR_SECBOOT_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PA_NOR_defconfig b/configs/P1010RDB-PA_NOR_defconfig index 01ae04c..fd8508a 100644 --- a/configs/P1010RDB-PA_NOR_defconfig +++ b/configs/P1010RDB-PA_NOR_defconfig @@ -7,6 +7,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PA_SDCARD_defconfig b/configs/P1010RDB-PA_SDCARD_defconfig index cb50efb..4e047f7 100644 --- a/configs/P1010RDB-PA_SDCARD_defconfig +++ b/configs/P1010RDB-PA_SDCARD_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig b/configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig index f536056..3a74a15 100644 --- a/configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig +++ b/configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,SPIFLASH,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PA_SPIFLASH_defconfig b/configs/P1010RDB-PA_SPIFLASH_defconfig index 540dc07..8a124ef 100644 --- a/configs/P1010RDB-PA_SPIFLASH_defconfig +++ b/configs/P1010RDB-PA_SPIFLASH_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PA,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig b/configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig index 0f3d4bc..94c5b29 100644 --- a/configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_36BIT_NAND_SECBOOT_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,36BIT,NAND_SECBOOT,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PB_36BIT_NAND_defconfig b/configs/P1010RDB-PB_36BIT_NAND_defconfig index 8777721..1e7e5c3 100644 --- a/configs/P1010RDB-PB_36BIT_NAND_defconfig +++ b/configs/P1010RDB-PB_36BIT_NAND_defconfig @@ -9,6 +9,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,36BIT,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig b/configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig index ee28938..a6efbba 100644 --- a/configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_36BIT_NOR_SECBOOT_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,36BIT,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PB_36BIT_NOR_defconfig b/configs/P1010RDB-PB_36BIT_NOR_defconfig index 3518769..4971dcb 100644 --- a/configs/P1010RDB-PB_36BIT_NOR_defconfig +++ b/configs/P1010RDB-PB_36BIT_NOR_defconfig @@ -7,6 +7,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,36BIT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig index 1aa52d0..f86a05b 100644 --- a/configs/P1010RDB-PB_36BIT_SDCARD_defconfig +++ b/configs/P1010RDB-PB_36BIT_SDCARD_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,36BIT,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig b/configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig index 76d1191..b02b1d3 100644 --- a/configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_36BIT_SPIFLASH_SECBOOT_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,36BIT,SPIFLASH,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig index 0be70bf..1bfba42 100644 --- a/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_36BIT_SPIFLASH_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,36BIT,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PB_NAND_SECBOOT_defconfig b/configs/P1010RDB-PB_NAND_SECBOOT_defconfig index cd7fd1a..75b064f 100644 --- a/configs/P1010RDB-PB_NAND_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_NAND_SECBOOT_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,NAND_SECBOOT,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PB_NAND_defconfig b/configs/P1010RDB-PB_NAND_defconfig index 216f9c60..259c443 100644 --- a/configs/P1010RDB-PB_NAND_defconfig +++ b/configs/P1010RDB-PB_NAND_defconfig @@ -9,6 +9,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PB_NOR_SECBOOT_defconfig b/configs/P1010RDB-PB_NOR_SECBOOT_defconfig index dbe5ac5..11bc5e3 100644 --- a/configs/P1010RDB-PB_NOR_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_NOR_SECBOOT_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PB_NOR_defconfig b/configs/P1010RDB-PB_NOR_defconfig index 47799fa..b26fbcb 100644 --- a/configs/P1010RDB-PB_NOR_defconfig +++ b/configs/P1010RDB-PB_NOR_defconfig @@ -7,6 +7,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PB_SDCARD_defconfig b/configs/P1010RDB-PB_SDCARD_defconfig index d65c724..2c88ee8 100644 --- a/configs/P1010RDB-PB_SDCARD_defconfig +++ b/configs/P1010RDB-PB_SDCARD_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig b/configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig index 3712bc2..80f1daf 100644 --- a/configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig +++ b/configs/P1010RDB-PB_SPIFLASH_SECBOOT_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,SPIFLASH,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P1010RDB-PB_SPIFLASH_defconfig b/configs/P1010RDB-PB_SPIFLASH_defconfig index ab7e97f..f79e913 100644 --- a/configs/P1010RDB-PB_SPIFLASH_defconfig +++ b/configs/P1010RDB-PB_SPIFLASH_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1010RDB_PB,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1020MBG-PC_36BIT_SDCARD_defconfig b/configs/P1020MBG-PC_36BIT_SDCARD_defconfig index b3b21c2..553e5da 100644 --- a/configs/P1020MBG-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020MBG-PC_36BIT_SDCARD_defconfig @@ -8,6 +8,9 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020MBG,SDCARD,36BIT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/P1020MBG-PC_36BIT_defconfig b/configs/P1020MBG-PC_36BIT_defconfig index 540c7ec..a93663f 100644 --- a/configs/P1020MBG-PC_36BIT_defconfig +++ b/configs/P1020MBG-PC_36BIT_defconfig @@ -7,6 +7,9 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020MBG,36BIT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/P1020MBG-PC_SDCARD_defconfig b/configs/P1020MBG-PC_SDCARD_defconfig index b3fa9d4..9c3a6f7 100644 --- a/configs/P1020MBG-PC_SDCARD_defconfig +++ b/configs/P1020MBG-PC_SDCARD_defconfig @@ -8,6 +8,9 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020MBG,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/P1020MBG-PC_defconfig b/configs/P1020MBG-PC_defconfig index f079220..9133731 100644 --- a/configs/P1020MBG-PC_defconfig +++ b/configs/P1020MBG-PC_defconfig @@ -7,6 +7,9 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020MBG" CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/P1020RDB-PC_36BIT_NAND_defconfig b/configs/P1020RDB-PC_36BIT_NAND_defconfig index 42021ce..d22bac7 100644 --- a/configs/P1020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1020RDB-PC_36BIT_NAND_defconfig @@ -9,6 +9,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020RDB_PC,36BIT,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig index be8cdd6..e046e40 100644 --- a/configs/P1020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020RDB-PC_36BIT_SDCARD_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020RDB_PC,36BIT,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig index 2d94d7b..dc6d861 100644 --- a/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_36BIT_SPIFLASH_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020RDB_PC,36BIT,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1020RDB-PC_36BIT_defconfig b/configs/P1020RDB-PC_36BIT_defconfig index 6d04758..a486593 100644 --- a/configs/P1020RDB-PC_36BIT_defconfig +++ b/configs/P1020RDB-PC_36BIT_defconfig @@ -7,6 +7,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020RDB_PC,36BIT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1020RDB-PC_NAND_defconfig b/configs/P1020RDB-PC_NAND_defconfig index 3d6e980..cc2a569 100644 --- a/configs/P1020RDB-PC_NAND_defconfig +++ b/configs/P1020RDB-PC_NAND_defconfig @@ -9,6 +9,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020RDB_PC,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1020RDB-PC_SDCARD_defconfig b/configs/P1020RDB-PC_SDCARD_defconfig index d118293..a7c00df 100644 --- a/configs/P1020RDB-PC_SDCARD_defconfig +++ b/configs/P1020RDB-PC_SDCARD_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020RDB_PC,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1020RDB-PC_SPIFLASH_defconfig b/configs/P1020RDB-PC_SPIFLASH_defconfig index 526e65a..08286f7 100644 --- a/configs/P1020RDB-PC_SPIFLASH_defconfig +++ b/configs/P1020RDB-PC_SPIFLASH_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020RDB_PC,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1020RDB-PC_defconfig b/configs/P1020RDB-PC_defconfig index 450dbd5..6a8bc3c 100644 --- a/configs/P1020RDB-PC_defconfig +++ b/configs/P1020RDB-PC_defconfig @@ -7,6 +7,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020RDB_PC" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1020RDB-PD_NAND_defconfig b/configs/P1020RDB-PD_NAND_defconfig index 5a3d66e..23e05d5 100644 --- a/configs/P1020RDB-PD_NAND_defconfig +++ b/configs/P1020RDB-PD_NAND_defconfig @@ -9,6 +9,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020RDB_PD,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1020RDB-PD_SDCARD_defconfig b/configs/P1020RDB-PD_SDCARD_defconfig index 8fcbccf..872a247 100644 --- a/configs/P1020RDB-PD_SDCARD_defconfig +++ b/configs/P1020RDB-PD_SDCARD_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020RDB_PD,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1020RDB-PD_SPIFLASH_defconfig b/configs/P1020RDB-PD_SPIFLASH_defconfig index 77b4b6e..82a318e 100644 --- a/configs/P1020RDB-PD_SPIFLASH_defconfig +++ b/configs/P1020RDB-PD_SPIFLASH_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020RDB_PD,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1020RDB-PD_defconfig b/configs/P1020RDB-PD_defconfig index a0e5bc3..f5e8a1b 100644 --- a/configs/P1020RDB-PD_defconfig +++ b/configs/P1020RDB-PD_defconfig @@ -7,6 +7,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020RDB_PD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1020UTM-PC_36BIT_SDCARD_defconfig b/configs/P1020UTM-PC_36BIT_SDCARD_defconfig index 6d2c02f..442d43a 100644 --- a/configs/P1020UTM-PC_36BIT_SDCARD_defconfig +++ b/configs/P1020UTM-PC_36BIT_SDCARD_defconfig @@ -8,6 +8,9 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020UTM,36BIT,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/P1020UTM-PC_36BIT_defconfig b/configs/P1020UTM-PC_36BIT_defconfig index 26b7697..0f4519c 100644 --- a/configs/P1020UTM-PC_36BIT_defconfig +++ b/configs/P1020UTM-PC_36BIT_defconfig @@ -7,6 +7,9 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020UTM,36BIT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/P1020UTM-PC_SDCARD_defconfig b/configs/P1020UTM-PC_SDCARD_defconfig index b79b65a..93fe60c 100644 --- a/configs/P1020UTM-PC_SDCARD_defconfig +++ b/configs/P1020UTM-PC_SDCARD_defconfig @@ -8,6 +8,9 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020UTM,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/P1020UTM-PC_defconfig b/configs/P1020UTM-PC_defconfig index 6f8615a..6118f0f 100644 --- a/configs/P1020UTM-PC_defconfig +++ b/configs/P1020UTM-PC_defconfig @@ -7,6 +7,9 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1020UTM" CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/P1021RDB-PC_36BIT_NAND_defconfig b/configs/P1021RDB-PC_36BIT_NAND_defconfig index 059f9f2..108b467 100644 --- a/configs/P1021RDB-PC_36BIT_NAND_defconfig +++ b/configs/P1021RDB-PC_36BIT_NAND_defconfig @@ -9,6 +9,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1021RDB,36BIT,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1021RDB-PC_36BIT_SDCARD_defconfig b/configs/P1021RDB-PC_36BIT_SDCARD_defconfig index e54d751..b17a3a0 100644 --- a/configs/P1021RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P1021RDB-PC_36BIT_SDCARD_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1021RDB,36BIT,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig index e331a8d..83027ad 100644 --- a/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P1021RDB-PC_36BIT_SPIFLASH_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1021RDB,36BIT,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1021RDB-PC_36BIT_defconfig b/configs/P1021RDB-PC_36BIT_defconfig index 6d83700..1d76a55 100644 --- a/configs/P1021RDB-PC_36BIT_defconfig +++ b/configs/P1021RDB-PC_36BIT_defconfig @@ -7,6 +7,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1021RDB,36BIT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1021RDB-PC_NAND_defconfig b/configs/P1021RDB-PC_NAND_defconfig index 03795da..622ed59 100644 --- a/configs/P1021RDB-PC_NAND_defconfig +++ b/configs/P1021RDB-PC_NAND_defconfig @@ -9,6 +9,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1021RDB,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1021RDB-PC_SDCARD_defconfig b/configs/P1021RDB-PC_SDCARD_defconfig index 01fb7ff..72d5835 100644 --- a/configs/P1021RDB-PC_SDCARD_defconfig +++ b/configs/P1021RDB-PC_SDCARD_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1021RDB,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1021RDB-PC_SPIFLASH_defconfig b/configs/P1021RDB-PC_SPIFLASH_defconfig index 80dcc12..2fff1ab 100644 --- a/configs/P1021RDB-PC_SPIFLASH_defconfig +++ b/configs/P1021RDB-PC_SPIFLASH_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1021RDB,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1021RDB-PC_defconfig b/configs/P1021RDB-PC_defconfig index 3d339e0..341f905 100644 --- a/configs/P1021RDB-PC_defconfig +++ b/configs/P1021RDB-PC_defconfig @@ -7,6 +7,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1021RDB" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1022DS_36BIT_NAND_defconfig b/configs/P1022DS_36BIT_NAND_defconfig index 3f4f413..a57882f 100644 --- a/configs/P1022DS_36BIT_NAND_defconfig +++ b/configs/P1022DS_36BIT_NAND_defconfig @@ -9,6 +9,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="36BIT,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1022DS_36BIT_SDCARD_defconfig b/configs/P1022DS_36BIT_SDCARD_defconfig index 3cdbb8d..edb6476 100644 --- a/configs/P1022DS_36BIT_SDCARD_defconfig +++ b/configs/P1022DS_36BIT_SDCARD_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="36BIT,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1022DS_36BIT_SPIFLASH_defconfig b/configs/P1022DS_36BIT_SPIFLASH_defconfig index bf4b56e..c54094e 100644 --- a/configs/P1022DS_36BIT_SPIFLASH_defconfig +++ b/configs/P1022DS_36BIT_SPIFLASH_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="36BIT,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1022DS_36BIT_defconfig b/configs/P1022DS_36BIT_defconfig index c94b53b..6b6811d 100644 --- a/configs/P1022DS_36BIT_defconfig +++ b/configs/P1022DS_36BIT_defconfig @@ -7,6 +7,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="36BIT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1022DS_NAND_defconfig b/configs/P1022DS_NAND_defconfig index 98f2c03..c7e2cfd 100644 --- a/configs/P1022DS_NAND_defconfig +++ b/configs/P1022DS_NAND_defconfig @@ -9,6 +9,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1022DS_SDCARD_defconfig b/configs/P1022DS_SDCARD_defconfig index b08b27a..7e321a4 100644 --- a/configs/P1022DS_SDCARD_defconfig +++ b/configs/P1022DS_SDCARD_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1022DS_SPIFLASH_defconfig b/configs/P1022DS_SPIFLASH_defconfig index 5ec0151..4f68c00 100644 --- a/configs/P1022DS_SPIFLASH_defconfig +++ b/configs/P1022DS_SPIFLASH_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1022DS_defconfig b/configs/P1022DS_defconfig index f444513..2b1925f 100644 --- a/configs/P1022DS_defconfig +++ b/configs/P1022DS_defconfig @@ -6,6 +6,10 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1023RDB_defconfig b/configs/P1023RDB_defconfig index 32871bb..cc31300 100644 --- a/configs/P1023RDB_defconfig +++ b/configs/P1023RDB_defconfig @@ -6,6 +6,9 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/P1024RDB_36BIT_defconfig b/configs/P1024RDB_36BIT_defconfig index bfd47ee..13546c3 100644 --- a/configs/P1024RDB_36BIT_defconfig +++ b/configs/P1024RDB_36BIT_defconfig @@ -7,6 +7,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1024RDB,36BIT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1024RDB_NAND_defconfig b/configs/P1024RDB_NAND_defconfig index 4ca3893..b80d2d9 100644 --- a/configs/P1024RDB_NAND_defconfig +++ b/configs/P1024RDB_NAND_defconfig @@ -9,6 +9,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1024RDB,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1024RDB_SDCARD_defconfig b/configs/P1024RDB_SDCARD_defconfig index d63a6dc..5250e16 100644 --- a/configs/P1024RDB_SDCARD_defconfig +++ b/configs/P1024RDB_SDCARD_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1024RDB,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1024RDB_SPIFLASH_defconfig b/configs/P1024RDB_SPIFLASH_defconfig index dc3cdc9..2ba4ceb 100644 --- a/configs/P1024RDB_SPIFLASH_defconfig +++ b/configs/P1024RDB_SPIFLASH_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1024RDB,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1024RDB_defconfig b/configs/P1024RDB_defconfig index 312e2e2..4feecb5 100644 --- a/configs/P1024RDB_defconfig +++ b/configs/P1024RDB_defconfig @@ -7,6 +7,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1024RDB" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1025RDB_36BIT_defconfig b/configs/P1025RDB_36BIT_defconfig index a3adca6..6e5b913 100644 --- a/configs/P1025RDB_36BIT_defconfig +++ b/configs/P1025RDB_36BIT_defconfig @@ -7,6 +7,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1025RDB,36BIT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1025RDB_NAND_defconfig b/configs/P1025RDB_NAND_defconfig index c394d41..cef9432 100644 --- a/configs/P1025RDB_NAND_defconfig +++ b/configs/P1025RDB_NAND_defconfig @@ -9,6 +9,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1025RDB,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1025RDB_SDCARD_defconfig b/configs/P1025RDB_SDCARD_defconfig index 7bd725e..0949ae1 100644 --- a/configs/P1025RDB_SDCARD_defconfig +++ b/configs/P1025RDB_SDCARD_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1025RDB,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1025RDB_SPIFLASH_defconfig b/configs/P1025RDB_SPIFLASH_defconfig index 56e4d87..35fbc67 100644 --- a/configs/P1025RDB_SPIFLASH_defconfig +++ b/configs/P1025RDB_SPIFLASH_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1025RDB,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P1025RDB_defconfig b/configs/P1025RDB_defconfig index 56f0b65..b1afcc0 100644 --- a/configs/P1025RDB_defconfig +++ b/configs/P1025RDB_defconfig @@ -7,6 +7,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P1025RDB" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P2020RDB-PC_36BIT_NAND_defconfig b/configs/P2020RDB-PC_36BIT_NAND_defconfig index 4edf2e3..19dee97 100644 --- a/configs/P2020RDB-PC_36BIT_NAND_defconfig +++ b/configs/P2020RDB-PC_36BIT_NAND_defconfig @@ -9,6 +9,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P2020RDB,36BIT,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig index c3d47fc..a48bdb9 100644 --- a/configs/P2020RDB-PC_36BIT_SDCARD_defconfig +++ b/configs/P2020RDB-PC_36BIT_SDCARD_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P2020RDB,36BIT,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig index a700fcd..abcb328 100644 --- a/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_36BIT_SPIFLASH_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P2020RDB,36BIT,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P2020RDB-PC_36BIT_defconfig b/configs/P2020RDB-PC_36BIT_defconfig index 1fb4331..ec3d1e2 100644 --- a/configs/P2020RDB-PC_36BIT_defconfig +++ b/configs/P2020RDB-PC_36BIT_defconfig @@ -7,6 +7,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P2020RDB,36BIT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P2020RDB-PC_NAND_defconfig b/configs/P2020RDB-PC_NAND_defconfig index fc63360..9faa181 100644 --- a/configs/P2020RDB-PC_NAND_defconfig +++ b/configs/P2020RDB-PC_NAND_defconfig @@ -9,6 +9,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P2020RDB,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P2020RDB-PC_SDCARD_defconfig b/configs/P2020RDB-PC_SDCARD_defconfig index 1c6e99f..d463d9d 100644 --- a/configs/P2020RDB-PC_SDCARD_defconfig +++ b/configs/P2020RDB-PC_SDCARD_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P2020RDB,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P2020RDB-PC_SPIFLASH_defconfig b/configs/P2020RDB-PC_SPIFLASH_defconfig index f14e444..f8f3f14 100644 --- a/configs/P2020RDB-PC_SPIFLASH_defconfig +++ b/configs/P2020RDB-PC_SPIFLASH_defconfig @@ -8,6 +8,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P2020RDB,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P2020RDB-PC_defconfig b/configs/P2020RDB-PC_defconfig index eccf03a..84338ce 100644 --- a/configs/P2020RDB-PC_defconfig +++ b/configs/P2020RDB-PC_defconfig @@ -7,6 +7,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="P2020RDB" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P2041RDB_NAND_defconfig b/configs/P2041RDB_NAND_defconfig index ec04df9..8e3df02 100644 --- a/configs/P2041RDB_NAND_defconfig +++ b/configs/P2041RDB_NAND_defconfig @@ -7,6 +7,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P2041RDB_SDCARD_defconfig b/configs/P2041RDB_SDCARD_defconfig index 02b94e9..02401e6 100644 --- a/configs/P2041RDB_SDCARD_defconfig +++ b/configs/P2041RDB_SDCARD_defconfig @@ -7,6 +7,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P2041RDB_SECURE_BOOT_defconfig b/configs/P2041RDB_SECURE_BOOT_defconfig index 890e100..568e44d 100644 --- a/configs/P2041RDB_SECURE_BOOT_defconfig +++ b/configs/P2041RDB_SECURE_BOOT_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P2041RDB_SPIFLASH_defconfig b/configs/P2041RDB_SPIFLASH_defconfig index 9553ab5..85c45f2 100644 --- a/configs/P2041RDB_SPIFLASH_defconfig +++ b/configs/P2041RDB_SPIFLASH_defconfig @@ -7,6 +7,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P2041RDB_SRIO_PCIE_BOOT_defconfig b/configs/P2041RDB_SRIO_PCIE_BOOT_defconfig index 1eb8835..db34b71 100644 --- a/configs/P2041RDB_SRIO_PCIE_BOOT_defconfig +++ b/configs/P2041RDB_SRIO_PCIE_BOOT_defconfig @@ -9,6 +9,11 @@ CONFIG_SYS_EXTRA_OPTIONS="SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P2041RDB_defconfig b/configs/P2041RDB_defconfig index 887ff28..91da52a 100644 --- a/configs/P2041RDB_defconfig +++ b/configs/P2041RDB_defconfig @@ -6,6 +6,11 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P3041DS_NAND_SECURE_BOOT_defconfig b/configs/P3041DS_NAND_SECURE_BOOT_defconfig index 4684fc9..16b8770 100644 --- a/configs/P3041DS_NAND_SECURE_BOOT_defconfig +++ b/configs/P3041DS_NAND_SECURE_BOOT_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,NAND,SECURE_BOOT,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P3041DS_NAND_defconfig b/configs/P3041DS_NAND_defconfig index c238729..aed8b9c 100644 --- a/configs/P3041DS_NAND_defconfig +++ b/configs/P3041DS_NAND_defconfig @@ -7,6 +7,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P3041DS_SDCARD_defconfig b/configs/P3041DS_SDCARD_defconfig index a7995c3..e8910b9 100644 --- a/configs/P3041DS_SDCARD_defconfig +++ b/configs/P3041DS_SDCARD_defconfig @@ -7,6 +7,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P3041DS_SECURE_BOOT_defconfig b/configs/P3041DS_SECURE_BOOT_defconfig index f3037ea..6abde1b 100644 --- a/configs/P3041DS_SECURE_BOOT_defconfig +++ b/configs/P3041DS_SECURE_BOOT_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P3041DS_SPIFLASH_defconfig b/configs/P3041DS_SPIFLASH_defconfig index 9bbce6e..ed37b05 100644 --- a/configs/P3041DS_SPIFLASH_defconfig +++ b/configs/P3041DS_SPIFLASH_defconfig @@ -7,6 +7,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P3041DS_SRIO_PCIE_BOOT_defconfig b/configs/P3041DS_SRIO_PCIE_BOOT_defconfig index 7499ff8..6882a6d 100644 --- a/configs/P3041DS_SRIO_PCIE_BOOT_defconfig +++ b/configs/P3041DS_SRIO_PCIE_BOOT_defconfig @@ -9,6 +9,11 @@ CONFIG_SYS_EXTRA_OPTIONS="SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P3041DS_defconfig b/configs/P3041DS_defconfig index 291c3d1..e8fa833 100644 --- a/configs/P3041DS_defconfig +++ b/configs/P3041DS_defconfig @@ -6,6 +6,11 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P4080DS_SDCARD_defconfig b/configs/P4080DS_SDCARD_defconfig index febb822..e3f6724 100644 --- a/configs/P4080DS_SDCARD_defconfig +++ b/configs/P4080DS_SDCARD_defconfig @@ -7,6 +7,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P4080DS_SECURE_BOOT_defconfig b/configs/P4080DS_SECURE_BOOT_defconfig index 66dea95..eb89714 100644 --- a/configs/P4080DS_SECURE_BOOT_defconfig +++ b/configs/P4080DS_SECURE_BOOT_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P4080DS_SPIFLASH_defconfig b/configs/P4080DS_SPIFLASH_defconfig index 4774147..c8eb351 100644 --- a/configs/P4080DS_SPIFLASH_defconfig +++ b/configs/P4080DS_SPIFLASH_defconfig @@ -7,6 +7,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P4080DS_SRIO_PCIE_BOOT_defconfig b/configs/P4080DS_SRIO_PCIE_BOOT_defconfig index 3aebc39..23353c7 100644 --- a/configs/P4080DS_SRIO_PCIE_BOOT_defconfig +++ b/configs/P4080DS_SRIO_PCIE_BOOT_defconfig @@ -9,6 +9,11 @@ CONFIG_SYS_EXTRA_OPTIONS="SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P4080DS_defconfig b/configs/P4080DS_defconfig index aec0624..3a2e976 100644 --- a/configs/P4080DS_defconfig +++ b/configs/P4080DS_defconfig @@ -6,6 +6,11 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P5020DS_NAND_SECURE_BOOT_defconfig b/configs/P5020DS_NAND_SECURE_BOOT_defconfig index 99b3932..c2112fa 100644 --- a/configs/P5020DS_NAND_SECURE_BOOT_defconfig +++ b/configs/P5020DS_NAND_SECURE_BOOT_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,NAND,SECURE_BOOT,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P5020DS_NAND_defconfig b/configs/P5020DS_NAND_defconfig index f70a45c..61b4f21 100644 --- a/configs/P5020DS_NAND_defconfig +++ b/configs/P5020DS_NAND_defconfig @@ -7,6 +7,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P5020DS_SDCARD_defconfig b/configs/P5020DS_SDCARD_defconfig index 448b489..c823f05 100644 --- a/configs/P5020DS_SDCARD_defconfig +++ b/configs/P5020DS_SDCARD_defconfig @@ -7,6 +7,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P5020DS_SECURE_BOOT_defconfig b/configs/P5020DS_SECURE_BOOT_defconfig index 298ee59..d220264 100644 --- a/configs/P5020DS_SECURE_BOOT_defconfig +++ b/configs/P5020DS_SECURE_BOOT_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P5020DS_SPIFLASH_defconfig b/configs/P5020DS_SPIFLASH_defconfig index 8ac8a9e..df41373 100644 --- a/configs/P5020DS_SPIFLASH_defconfig +++ b/configs/P5020DS_SPIFLASH_defconfig @@ -7,6 +7,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P5020DS_SRIO_PCIE_BOOT_defconfig b/configs/P5020DS_SRIO_PCIE_BOOT_defconfig index abbe15d..b831253 100644 --- a/configs/P5020DS_SRIO_PCIE_BOOT_defconfig +++ b/configs/P5020DS_SRIO_PCIE_BOOT_defconfig @@ -9,6 +9,11 @@ CONFIG_SYS_EXTRA_OPTIONS="SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P5020DS_defconfig b/configs/P5020DS_defconfig index 5c272bb..8efb577 100644 --- a/configs/P5020DS_defconfig +++ b/configs/P5020DS_defconfig @@ -6,6 +6,11 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P5040DS_NAND_SECURE_BOOT_defconfig b/configs/P5040DS_NAND_SECURE_BOOT_defconfig index 84df506..fd3ccfa 100644 --- a/configs/P5040DS_NAND_SECURE_BOOT_defconfig +++ b/configs/P5040DS_NAND_SECURE_BOOT_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,NAND,SECURE_BOOT,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P5040DS_NAND_defconfig b/configs/P5040DS_NAND_defconfig index 1a91eca..068cb68 100644 --- a/configs/P5040DS_NAND_defconfig +++ b/configs/P5040DS_NAND_defconfig @@ -7,6 +7,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P5040DS_SDCARD_defconfig b/configs/P5040DS_SDCARD_defconfig index 72629a4..c3149d8 100644 --- a/configs/P5040DS_SDCARD_defconfig +++ b/configs/P5040DS_SDCARD_defconfig @@ -7,6 +7,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P5040DS_SECURE_BOOT_defconfig b/configs/P5040DS_SECURE_BOOT_defconfig index 79b9f62..4828534 100644 --- a/configs/P5040DS_SECURE_BOOT_defconfig +++ b/configs/P5040DS_SECURE_BOOT_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/P5040DS_SPIFLASH_defconfig b/configs/P5040DS_SPIFLASH_defconfig index f71423d..1793865 100644 --- a/configs/P5040DS_SPIFLASH_defconfig +++ b/configs/P5040DS_SPIFLASH_defconfig @@ -7,6 +7,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/P5040DS_defconfig b/configs/P5040DS_defconfig index 2f2628e..ed72c24 100644 --- a/configs/P5040DS_defconfig +++ b/configs/P5040DS_defconfig @@ -6,6 +6,11 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/PIP405_defconfig b/configs/PIP405_defconfig index 2bac731..c9fb9d4 100644 --- a/configs/PIP405_defconfig +++ b/configs/PIP405_defconfig @@ -2,5 +2,9 @@ CONFIG_PPC=y CONFIG_4xx=y CONFIG_TARGET_PIP405=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y diff --git a/configs/PLU405_defconfig b/configs/PLU405_defconfig index 52850dd..9fe4dc4 100644 --- a/configs/PLU405_defconfig +++ b/configs/PLU405_defconfig @@ -5,6 +5,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/PMC405DE_defconfig b/configs/PMC405DE_defconfig index 1155bd1..ccbd7b3 100644 --- a/configs/PMC405DE_defconfig +++ b/configs/PMC405DE_defconfig @@ -5,6 +5,10 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/PMC440_defconfig b/configs/PMC440_defconfig index 156d813..f80410f 100644 --- a/configs/PMC440_defconfig +++ b/configs/PMC440_defconfig @@ -5,6 +5,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/Sinlinx_SinA31s_defconfig b/configs/Sinlinx_SinA31s_defconfig index 02fa5e4..2fdb844 100644 --- a/configs/Sinlinx_SinA31s_defconfig +++ b/configs/Sinlinx_SinA31s_defconfig @@ -16,6 +16,8 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_EHCI_HCD=y diff --git a/configs/Sinlinx_SinA33_defconfig b/configs/Sinlinx_SinA33_defconfig index ce1a70e..011dfd6 100644 --- a/configs/Sinlinx_SinA33_defconfig +++ b/configs/Sinlinx_SinA33_defconfig @@ -10,3 +10,5 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y diff --git a/configs/Sinovoip_BPI_M2_defconfig b/configs/Sinovoip_BPI_M2_defconfig index 174de08..b39164b 100644 --- a/configs/Sinovoip_BPI_M2_defconfig +++ b/configs/Sinovoip_BPI_M2_defconfig @@ -12,6 +12,8 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_ALDO1_VOLT=3300 CONFIG_AXP_ALDO2_VOLT=1800 diff --git a/configs/Sinovoip_BPI_M3_defconfig b/configs/Sinovoip_BPI_M3_defconfig index 4b69996..878d22f 100644 --- a/configs/Sinovoip_BPI_M3_defconfig +++ b/configs/Sinovoip_BPI_M3_defconfig @@ -19,6 +19,8 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_AXP_DCDC5_VOLT=1200 CONFIG_AXP_DLDO3_VOLT=2500 CONFIG_USB_EHCI_HCD=y diff --git a/configs/T1023RDB_NAND_defconfig b/configs/T1023RDB_NAND_defconfig index 48511ec..0957dc3 100644 --- a/configs/T1023RDB_NAND_defconfig +++ b/configs/T1023RDB_NAND_defconfig @@ -9,7 +9,13 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1023,T1023RDB,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/T1023RDB_SDCARD_defconfig b/configs/T1023RDB_SDCARD_defconfig index aabd1a3..f9dd7db 100644 --- a/configs/T1023RDB_SDCARD_defconfig +++ b/configs/T1023RDB_SDCARD_defconfig @@ -9,7 +9,13 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1023,T1023RDB,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/T1023RDB_SECURE_BOOT_defconfig b/configs/T1023RDB_SECURE_BOOT_defconfig index 16b3066..9577fe2 100644 --- a/configs/T1023RDB_SECURE_BOOT_defconfig +++ b/configs/T1023RDB_SECURE_BOOT_defconfig @@ -8,6 +8,12 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1023,T1023RDB,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/T1023RDB_SPIFLASH_defconfig b/configs/T1023RDB_SPIFLASH_defconfig index 4b7ad52..e0b3ae1 100644 --- a/configs/T1023RDB_SPIFLASH_defconfig +++ b/configs/T1023RDB_SPIFLASH_defconfig @@ -9,7 +9,13 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1023,T1023RDB,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/T1023RDB_defconfig b/configs/T1023RDB_defconfig index d79763a..ec0609f 100644 --- a/configs/T1023RDB_defconfig +++ b/configs/T1023RDB_defconfig @@ -7,6 +7,12 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1023,T1023RDB" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_NETDEVICES=y diff --git a/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig b/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig index f15855b..ef01c2e 100644 --- a/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig +++ b/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,SYS_FSL_DDR4,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y diff --git a/configs/T1024QDS_DDR4_defconfig b/configs/T1024QDS_DDR4_defconfig index dac71a9..f3235bf 100644 --- a/configs/T1024QDS_DDR4_defconfig +++ b/configs/T1024QDS_DDR4_defconfig @@ -7,6 +7,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,SYS_FSL_DDR4" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T1024QDS_NAND_defconfig b/configs/T1024QDS_NAND_defconfig index 5adfe02..2be1046 100644 --- a/configs/T1024QDS_NAND_defconfig +++ b/configs/T1024QDS_NAND_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T1024QDS_SDCARD_defconfig b/configs/T1024QDS_SDCARD_defconfig index 7748356..1bca42a 100644 --- a/configs/T1024QDS_SDCARD_defconfig +++ b/configs/T1024QDS_SDCARD_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T1024QDS_SECURE_BOOT_defconfig b/configs/T1024QDS_SECURE_BOOT_defconfig index 447283b..b22bba8 100644 --- a/configs/T1024QDS_SECURE_BOOT_defconfig +++ b/configs/T1024QDS_SECURE_BOOT_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y diff --git a/configs/T1024QDS_SPIFLASH_defconfig b/configs/T1024QDS_SPIFLASH_defconfig index 3c68c9f..a9bea77 100644 --- a/configs/T1024QDS_SPIFLASH_defconfig +++ b/configs/T1024QDS_SPIFLASH_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T1024QDS_defconfig b/configs/T1024QDS_defconfig index 9a1d324..622e560 100644 --- a/configs/T1024QDS_defconfig +++ b/configs/T1024QDS_defconfig @@ -7,6 +7,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T1024RDB_NAND_defconfig b/configs/T1024RDB_NAND_defconfig index 5f34727..ecd027f 100644 --- a/configs/T1024RDB_NAND_defconfig +++ b/configs/T1024RDB_NAND_defconfig @@ -8,6 +8,12 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,T1024RDB,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1024RDB_SDCARD_defconfig b/configs/T1024RDB_SDCARD_defconfig index 474ae53..77e93b4 100644 --- a/configs/T1024RDB_SDCARD_defconfig +++ b/configs/T1024RDB_SDCARD_defconfig @@ -8,6 +8,12 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,T1024RDB,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1024RDB_SECURE_BOOT_defconfig b/configs/T1024RDB_SECURE_BOOT_defconfig index 1eba789..68ac112 100644 --- a/configs/T1024RDB_SECURE_BOOT_defconfig +++ b/configs/T1024RDB_SECURE_BOOT_defconfig @@ -8,6 +8,12 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,T1024RDB,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T1024RDB_SPIFLASH_defconfig b/configs/T1024RDB_SPIFLASH_defconfig index c4918a7..3443db8 100644 --- a/configs/T1024RDB_SPIFLASH_defconfig +++ b/configs/T1024RDB_SPIFLASH_defconfig @@ -8,6 +8,12 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,T1024RDB,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1024RDB_defconfig b/configs/T1024RDB_defconfig index 9878b65..d11b954 100644 --- a/configs/T1024RDB_defconfig +++ b/configs/T1024RDB_defconfig @@ -7,6 +7,12 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1024,T1024RDB" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1040D4RDB_NAND_defconfig b/configs/T1040D4RDB_NAND_defconfig index b27dd6c..3fb702d 100644 --- a/configs/T1040D4RDB_NAND_defconfig +++ b/configs/T1040D4RDB_NAND_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,NAND,T104XD4RDB,SYS_FSL_DDR4" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1040D4RDB_SDCARD_defconfig b/configs/T1040D4RDB_SDCARD_defconfig index 67cdc3a..acfa55f 100644 --- a/configs/T1040D4RDB_SDCARD_defconfig +++ b/configs/T1040D4RDB_SDCARD_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD,T104XD4RDB,SYS_FSL_DDR4" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1040D4RDB_SECURE_BOOT_defconfig b/configs/T1040D4RDB_SECURE_BOOT_defconfig index 3c7296d..777c448 100644 --- a/configs/T1040D4RDB_SECURE_BOOT_defconfig +++ b/configs/T1040D4RDB_SECURE_BOOT_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040D4RDB,T104XD4RDB,SYS_FSL_DDR4,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T1040D4RDB_SPIFLASH_defconfig b/configs/T1040D4RDB_SPIFLASH_defconfig index 94aea4f..c1e16b2 100644 --- a/configs/T1040D4RDB_SPIFLASH_defconfig +++ b/configs/T1040D4RDB_SPIFLASH_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH,T104XD4RDB,SYS_FSL_DDR4" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1040D4RDB_defconfig b/configs/T1040D4RDB_defconfig index d5513f5..3d1040e 100644 --- a/configs/T1040D4RDB_defconfig +++ b/configs/T1040D4RDB_defconfig @@ -7,6 +7,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040D4RDB,T104XD4RDB,SYS_FSL_DDR4" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1040QDS_DDR4_defconfig b/configs/T1040QDS_DDR4_defconfig index 5d54cb5..8399ec8 100644 --- a/configs/T1040QDS_DDR4_defconfig +++ b/configs/T1040QDS_DDR4_defconfig @@ -7,6 +7,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,SYS_FSL_DDR4" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T1040QDS_SECURE_BOOT_defconfig b/configs/T1040QDS_SECURE_BOOT_defconfig index fb37784..a7998bb 100644 --- a/configs/T1040QDS_SECURE_BOOT_defconfig +++ b/configs/T1040QDS_SECURE_BOOT_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y diff --git a/configs/T1040QDS_defconfig b/configs/T1040QDS_defconfig index 5d02f71..9c21b33 100644 --- a/configs/T1040QDS_defconfig +++ b/configs/T1040QDS_defconfig @@ -7,6 +7,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T1040RDB_NAND_defconfig b/configs/T1040RDB_NAND_defconfig index 6512dad..6ed2f86 100644 --- a/configs/T1040RDB_NAND_defconfig +++ b/configs/T1040RDB_NAND_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040RDB,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1040RDB_SDCARD_defconfig b/configs/T1040RDB_SDCARD_defconfig index a878194..10dfd33 100644 --- a/configs/T1040RDB_SDCARD_defconfig +++ b/configs/T1040RDB_SDCARD_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040RDB,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1040RDB_SECURE_BOOT_defconfig b/configs/T1040RDB_SECURE_BOOT_defconfig index 9570b7b..b9bb5be 100644 --- a/configs/T1040RDB_SECURE_BOOT_defconfig +++ b/configs/T1040RDB_SECURE_BOOT_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,SECURE_BOOT,T1040RDB" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T1040RDB_SPIFLASH_defconfig b/configs/T1040RDB_SPIFLASH_defconfig index 82e8f0f..f33805b 100644 --- a/configs/T1040RDB_SPIFLASH_defconfig +++ b/configs/T1040RDB_SPIFLASH_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040RDB,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1040RDB_defconfig b/configs/T1040RDB_defconfig index fa6bbfc..8dcf3e5 100644 --- a/configs/T1040RDB_defconfig +++ b/configs/T1040RDB_defconfig @@ -7,6 +7,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1040,T1040RDB" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1042D4RDB_NAND_defconfig b/configs/T1042D4RDB_NAND_defconfig index 9c09bf0..4620e54 100644 --- a/configs/T1042D4RDB_NAND_defconfig +++ b/configs/T1042D4RDB_NAND_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,NAND,T104XD4RDB,SYS_FSL_DDR4" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1042D4RDB_SDCARD_defconfig b/configs/T1042D4RDB_SDCARD_defconfig index 2b8f5de..54ffb94 100644 --- a/configs/T1042D4RDB_SDCARD_defconfig +++ b/configs/T1042D4RDB_SDCARD_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD,T104XD4RDB,SYS_FSL_DDR4" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1042D4RDB_SECURE_BOOT_defconfig b/configs/T1042D4RDB_SECURE_BOOT_defconfig index 906b243..0ca5bb0 100644 --- a/configs/T1042D4RDB_SECURE_BOOT_defconfig +++ b/configs/T1042D4RDB_SECURE_BOOT_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042D4RDB,T104XD4RDB,SYS_FSL_DDR4,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T1042D4RDB_SPIFLASH_defconfig b/configs/T1042D4RDB_SPIFLASH_defconfig index 1025ce4..ba4b274 100644 --- a/configs/T1042D4RDB_SPIFLASH_defconfig +++ b/configs/T1042D4RDB_SPIFLASH_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042D4RDB,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH,T104XD4RDB,SYS_FSL_DDR4" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1042D4RDB_defconfig b/configs/T1042D4RDB_defconfig index 0ad874a..488923e 100644 --- a/configs/T1042D4RDB_defconfig +++ b/configs/T1042D4RDB_defconfig @@ -7,6 +7,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042D4RDB,T104XD4RDB,SYS_FSL_DDR4" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1042RDB_PI_NAND_defconfig b/configs/T1042RDB_PI_NAND_defconfig index a37117f..3a52ea9 100644 --- a/configs/T1042RDB_PI_NAND_defconfig +++ b/configs/T1042RDB_PI_NAND_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042RDB_PI,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1042RDB_PI_SDCARD_defconfig b/configs/T1042RDB_PI_SDCARD_defconfig index 4d5ca01..c3d7cf6 100644 --- a/configs/T1042RDB_PI_SDCARD_defconfig +++ b/configs/T1042RDB_PI_SDCARD_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042RDB_PI,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1042RDB_PI_SPIFLASH_defconfig b/configs/T1042RDB_PI_SPIFLASH_defconfig index 0de0b4c..0b608a9 100644 --- a/configs/T1042RDB_PI_SPIFLASH_defconfig +++ b/configs/T1042RDB_PI_SPIFLASH_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042RDB_PI,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1042RDB_PI_defconfig b/configs/T1042RDB_PI_defconfig index 99cdd37..aa66095 100644 --- a/configs/T1042RDB_PI_defconfig +++ b/configs/T1042RDB_PI_defconfig @@ -7,6 +7,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042RDB_PI" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T1042RDB_SECURE_BOOT_defconfig b/configs/T1042RDB_SECURE_BOOT_defconfig index 41ad0e2..dbb5bb6 100644 --- a/configs/T1042RDB_SECURE_BOOT_defconfig +++ b/configs/T1042RDB_SECURE_BOOT_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,SECURE_BOOT,T1042RDB" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T1042RDB_defconfig b/configs/T1042RDB_defconfig index cedd085..09b5bf5 100644 --- a/configs/T1042RDB_defconfig +++ b/configs/T1042RDB_defconfig @@ -7,6 +7,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T1042,T1042RDB" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T2080QDS_NAND_defconfig b/configs/T2080QDS_NAND_defconfig index 9025458..51d452b 100644 --- a/configs/T2080QDS_NAND_defconfig +++ b/configs/T2080QDS_NAND_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2080,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T2080QDS_SDCARD_defconfig b/configs/T2080QDS_SDCARD_defconfig index 572da36..33da1b4 100644 --- a/configs/T2080QDS_SDCARD_defconfig +++ b/configs/T2080QDS_SDCARD_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2080,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T2080QDS_SECURE_BOOT_defconfig b/configs/T2080QDS_SECURE_BOOT_defconfig index a2d3df4..ba7f61d 100644 --- a/configs/T2080QDS_SECURE_BOOT_defconfig +++ b/configs/T2080QDS_SECURE_BOOT_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2080,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y diff --git a/configs/T2080QDS_SPIFLASH_defconfig b/configs/T2080QDS_SPIFLASH_defconfig index b4bd589..c1c7e42 100644 --- a/configs/T2080QDS_SPIFLASH_defconfig +++ b/configs/T2080QDS_SPIFLASH_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2080,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig b/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig index 75c7860..6753118 100644 --- a/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig +++ b/configs/T2080QDS_SRIO_PCIE_BOOT_defconfig @@ -9,6 +9,11 @@ CONFIG_SYS_EXTRA_OPTIONS="PPC_T2080,SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF4000 CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T2080QDS_defconfig b/configs/T2080QDS_defconfig index dd2343d..36dc163 100644 --- a/configs/T2080QDS_defconfig +++ b/configs/T2080QDS_defconfig @@ -7,6 +7,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2080" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T2080RDB_NAND_defconfig b/configs/T2080RDB_NAND_defconfig index 8f7e7ee..147ce69 100644 --- a/configs/T2080RDB_NAND_defconfig +++ b/configs/T2080RDB_NAND_defconfig @@ -8,6 +8,12 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2080,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T2080RDB_SDCARD_defconfig b/configs/T2080RDB_SDCARD_defconfig index 325dbfa..ebbb9e1 100644 --- a/configs/T2080RDB_SDCARD_defconfig +++ b/configs/T2080RDB_SDCARD_defconfig @@ -8,6 +8,12 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2080,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T2080RDB_SECURE_BOOT_defconfig b/configs/T2080RDB_SECURE_BOOT_defconfig index 261e027..d57cc6d 100644 --- a/configs/T2080RDB_SECURE_BOOT_defconfig +++ b/configs/T2080RDB_SECURE_BOOT_defconfig @@ -8,6 +8,12 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2080,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T2080RDB_SPIFLASH_defconfig b/configs/T2080RDB_SPIFLASH_defconfig index b7287b0..8bac4a0 100644 --- a/configs/T2080RDB_SPIFLASH_defconfig +++ b/configs/T2080RDB_SPIFLASH_defconfig @@ -8,6 +8,12 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2080,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T2080RDB_SRIO_PCIE_BOOT_defconfig b/configs/T2080RDB_SRIO_PCIE_BOOT_defconfig index e72878d..ad5ce54 100644 --- a/configs/T2080RDB_SRIO_PCIE_BOOT_defconfig +++ b/configs/T2080RDB_SRIO_PCIE_BOOT_defconfig @@ -8,7 +8,13 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2080,SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF40000" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T2080RDB_defconfig b/configs/T2080RDB_defconfig index abe0d2b..20ccc45 100644 --- a/configs/T2080RDB_defconfig +++ b/configs/T2080RDB_defconfig @@ -7,6 +7,12 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2080" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_NETDEVICES=y diff --git a/configs/T2081QDS_NAND_defconfig b/configs/T2081QDS_NAND_defconfig index 16b38ec..1589d31 100644 --- a/configs/T2081QDS_NAND_defconfig +++ b/configs/T2081QDS_NAND_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2081,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T2081QDS_SDCARD_defconfig b/configs/T2081QDS_SDCARD_defconfig index cd25ea9..fa04188 100644 --- a/configs/T2081QDS_SDCARD_defconfig +++ b/configs/T2081QDS_SDCARD_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2081,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T2081QDS_SPIFLASH_defconfig b/configs/T2081QDS_SPIFLASH_defconfig index 63cfc78..0100ad9 100644 --- a/configs/T2081QDS_SPIFLASH_defconfig +++ b/configs/T2081QDS_SPIFLASH_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2081,RAMBOOT_PBL,SPL_FSL_PBL,SPIFLASH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T2081QDS_SRIO_PCIE_BOOT_defconfig b/configs/T2081QDS_SRIO_PCIE_BOOT_defconfig index 5048d46..17e95d2 100644 --- a/configs/T2081QDS_SRIO_PCIE_BOOT_defconfig +++ b/configs/T2081QDS_SRIO_PCIE_BOOT_defconfig @@ -9,6 +9,11 @@ CONFIG_SYS_EXTRA_OPTIONS="PPC_T2081,SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF4000 CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T2081QDS_defconfig b/configs/T2081QDS_defconfig index d73d8f2..ce8453f 100644 --- a/configs/T2081QDS_defconfig +++ b/configs/T2081QDS_defconfig @@ -7,6 +7,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T2081" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_EON=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/T4160QDS_NAND_defconfig b/configs/T4160QDS_NAND_defconfig index 27c4543..20fd55a 100644 --- a/configs/T4160QDS_NAND_defconfig +++ b/configs/T4160QDS_NAND_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T4160,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/T4160QDS_SDCARD_defconfig b/configs/T4160QDS_SDCARD_defconfig index a283293..cc056d5 100644 --- a/configs/T4160QDS_SDCARD_defconfig +++ b/configs/T4160QDS_SDCARD_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T4160,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/T4160QDS_SECURE_BOOT_defconfig b/configs/T4160QDS_SECURE_BOOT_defconfig index 80c3318..4483184 100644 --- a/configs/T4160QDS_SECURE_BOOT_defconfig +++ b/configs/T4160QDS_SECURE_BOOT_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T4160,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/T4160QDS_defconfig b/configs/T4160QDS_defconfig index 015f85d..b4533ab 100644 --- a/configs/T4160QDS_defconfig +++ b/configs/T4160QDS_defconfig @@ -7,6 +7,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T4160" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/T4160RDB_defconfig b/configs/T4160RDB_defconfig index d0979b1..5a90b2b 100644 --- a/configs/T4160RDB_defconfig +++ b/configs/T4160RDB_defconfig @@ -7,6 +7,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T4160" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/T4240QDS_NAND_defconfig b/configs/T4240QDS_NAND_defconfig index c8e3a9b..423f4ed 100644 --- a/configs/T4240QDS_NAND_defconfig +++ b/configs/T4240QDS_NAND_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T4240,RAMBOOT_PBL,SPL_FSL_PBL,NAND" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/T4240QDS_SDCARD_defconfig b/configs/T4240QDS_SDCARD_defconfig index 30cbeb9..eceac1a 100644 --- a/configs/T4240QDS_SDCARD_defconfig +++ b/configs/T4240QDS_SDCARD_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T4240,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/T4240QDS_SECURE_BOOT_defconfig b/configs/T4240QDS_SECURE_BOOT_defconfig index 6e19e3a..dde4f56 100644 --- a/configs/T4240QDS_SECURE_BOOT_defconfig +++ b/configs/T4240QDS_SECURE_BOOT_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T4240,SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/T4240QDS_SRIO_PCIE_BOOT_defconfig b/configs/T4240QDS_SRIO_PCIE_BOOT_defconfig index 4c8932c..eea72e3 100644 --- a/configs/T4240QDS_SRIO_PCIE_BOOT_defconfig +++ b/configs/T4240QDS_SRIO_PCIE_BOOT_defconfig @@ -9,6 +9,11 @@ CONFIG_SYS_EXTRA_OPTIONS="PPC_T4240,SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF4000 CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/T4240QDS_defconfig b/configs/T4240QDS_defconfig index e374328..1c38761 100644 --- a/configs/T4240QDS_defconfig +++ b/configs/T4240QDS_defconfig @@ -7,6 +7,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T4240" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/T4240RDB_SDCARD_defconfig b/configs/T4240RDB_SDCARD_defconfig index b8589b6..2c1847f 100644 --- a/configs/T4240RDB_SDCARD_defconfig +++ b/configs/T4240RDB_SDCARD_defconfig @@ -8,6 +8,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T4240,RAMBOOT_PBL,SPL_FSL_PBL,SDCARD" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/T4240RDB_defconfig b/configs/T4240RDB_defconfig index c622fa6..9af072d 100644 --- a/configs/T4240RDB_defconfig +++ b/configs/T4240RDB_defconfig @@ -7,6 +7,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PPC_T4240" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_NETDEVICES=y diff --git a/configs/TQM5200S_HIGHBOOT_defconfig b/configs/TQM5200S_HIGHBOOT_defconfig index 71b4592..1269e39 100644 --- a/configs/TQM5200S_HIGHBOOT_defconfig +++ b/configs/TQM5200S_HIGHBOOT_defconfig @@ -4,5 +4,11 @@ CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="TQM5200_B,TQM5200S,SYS_TEXT_BASE=0xFFF00000" CONFIG_HUSH_PARSER=y +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM5200S_defconfig b/configs/TQM5200S_defconfig index 960cc3c..d8a724a 100644 --- a/configs/TQM5200S_defconfig +++ b/configs/TQM5200S_defconfig @@ -4,5 +4,11 @@ CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="TQM5200_B,TQM5200S" CONFIG_HUSH_PARSER=y +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM5200_B_HIGHBOOT_defconfig b/configs/TQM5200_B_HIGHBOOT_defconfig index 14afa02..abecdb4 100644 --- a/configs/TQM5200_B_HIGHBOOT_defconfig +++ b/configs/TQM5200_B_HIGHBOOT_defconfig @@ -4,5 +4,11 @@ CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="TQM5200_B,SYS_TEXT_BASE=0xFFF00000" CONFIG_HUSH_PARSER=y +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM5200_B_defconfig b/configs/TQM5200_B_defconfig index c49fc53..86e8572 100644 --- a/configs/TQM5200_B_defconfig +++ b/configs/TQM5200_B_defconfig @@ -4,5 +4,11 @@ CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="TQM5200_B" CONFIG_HUSH_PARSER=y +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM5200_STK100_defconfig b/configs/TQM5200_STK100_defconfig index fcd8b35..7592cc5 100644 --- a/configs/TQM5200_STK100_defconfig +++ b/configs/TQM5200_STK100_defconfig @@ -4,5 +4,11 @@ CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="STK52XX_REV100" CONFIG_HUSH_PARSER=y +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM5200_defconfig b/configs/TQM5200_defconfig index bb04df5..90821b3 100644 --- a/configs/TQM5200_defconfig +++ b/configs/TQM5200_defconfig @@ -3,5 +3,11 @@ CONFIG_MPC5xxx=y CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM823L_LCD_defconfig b/configs/TQM823L_LCD_defconfig index 285e773..b60d087 100644 --- a/configs/TQM823L_LCD_defconfig +++ b/configs/TQM823L_LCD_defconfig @@ -5,4 +5,6 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="LCD,NEC_NL6448BC20" CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_SNTP=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM823L_defconfig b/configs/TQM823L_defconfig index 5148764..28ad9e1 100644 --- a/configs/TQM823L_defconfig +++ b/configs/TQM823L_defconfig @@ -4,4 +4,6 @@ CONFIG_TARGET_TQM823L=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_SNTP=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM823M_defconfig b/configs/TQM823M_defconfig index 8f6b674..c569b24 100644 --- a/configs/TQM823M_defconfig +++ b/configs/TQM823M_defconfig @@ -4,4 +4,6 @@ CONFIG_TARGET_TQM823M=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_SNTP=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM834x_defconfig b/configs/TQM834x_defconfig index af4a72d..f8d9df8 100644 --- a/configs/TQM834x_defconfig +++ b/configs/TQM834x_defconfig @@ -4,6 +4,10 @@ CONFIG_TARGET_TQM834X=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM850L_defconfig b/configs/TQM850L_defconfig index 646c552..9e71d16 100644 --- a/configs/TQM850L_defconfig +++ b/configs/TQM850L_defconfig @@ -4,4 +4,6 @@ CONFIG_TARGET_TQM850L=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_SNTP=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM850M_defconfig b/configs/TQM850M_defconfig index 63941ac..77a9a6c 100644 --- a/configs/TQM850M_defconfig +++ b/configs/TQM850M_defconfig @@ -4,4 +4,6 @@ CONFIG_TARGET_TQM850M=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_SNTP=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM855L_defconfig b/configs/TQM855L_defconfig index 869a7d3..4d443c5 100644 --- a/configs/TQM855L_defconfig +++ b/configs/TQM855L_defconfig @@ -4,4 +4,6 @@ CONFIG_TARGET_TQM855L=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_SNTP=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM855M_defconfig b/configs/TQM855M_defconfig index 8022398..344da70 100644 --- a/configs/TQM855M_defconfig +++ b/configs/TQM855M_defconfig @@ -4,4 +4,6 @@ CONFIG_TARGET_TQM855M=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_SNTP=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM860L_defconfig b/configs/TQM860L_defconfig index 7b24eeb..6c47c3e 100644 --- a/configs/TQM860L_defconfig +++ b/configs/TQM860L_defconfig @@ -4,4 +4,6 @@ CONFIG_TARGET_TQM860L=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_SNTP=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM860M_defconfig b/configs/TQM860M_defconfig index 672ad4c..2a65fd9 100644 --- a/configs/TQM860M_defconfig +++ b/configs/TQM860M_defconfig @@ -4,4 +4,6 @@ CONFIG_TARGET_TQM860M=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_SNTP=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM862L_defconfig b/configs/TQM862L_defconfig index af57396..e20def2 100644 --- a/configs/TQM862L_defconfig +++ b/configs/TQM862L_defconfig @@ -4,4 +4,6 @@ CONFIG_TARGET_TQM862L=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_SNTP=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM862M_defconfig b/configs/TQM862M_defconfig index cd76e95..61a993f 100644 --- a/configs/TQM862M_defconfig +++ b/configs/TQM862M_defconfig @@ -4,4 +4,6 @@ CONFIG_TARGET_TQM862M=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_SNTP=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM866M_defconfig b/configs/TQM866M_defconfig index 403ec90..e3ca7c7 100644 --- a/configs/TQM866M_defconfig +++ b/configs/TQM866M_defconfig @@ -4,4 +4,6 @@ CONFIG_TARGET_TQM866M=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_SNTP=y CONFIG_OF_LIBFDT=y diff --git a/configs/TQM885D_defconfig b/configs/TQM885D_defconfig index f9d8610..5b8b869 100644 --- a/configs/TQM885D_defconfig +++ b/configs/TQM885D_defconfig @@ -3,5 +3,9 @@ CONFIG_8xx=y CONFIG_TARGET_TQM885D=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/TTTech_defconfig b/configs/TTTech_defconfig index a58e0aa..2c823db 100644 --- a/configs/TTTech_defconfig +++ b/configs/TTTech_defconfig @@ -5,4 +5,6 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="LCD,SHARP_LQ104V7DS01" CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_SNTP=y CONFIG_OF_LIBFDT=y diff --git a/configs/TWR-P1025_defconfig b/configs/TWR-P1025_defconfig index 31db63d..40d22fb 100644 --- a/configs/TWR-P1025_defconfig +++ b/configs/TWR-P1025_defconfig @@ -7,6 +7,9 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="TWR_P1025" CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/UCP1020_SPIFLASH_defconfig b/configs/UCP1020_SPIFLASH_defconfig index f2b833d..d532e5f 100644 --- a/configs/UCP1020_SPIFLASH_defconfig +++ b/configs/UCP1020_SPIFLASH_defconfig @@ -10,7 +10,13 @@ CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc>" to stop\n" CONFIG_AUTOBOOT_STOP_STR="\x1b" +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/UCP1020_defconfig b/configs/UCP1020_defconfig index c94c3b7..3472c07 100644 --- a/configs/UCP1020_defconfig +++ b/configs/UCP1020_defconfig @@ -10,7 +10,13 @@ CONFIG_SYS_PROMPT="B$ " CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc>" to stop\n" CONFIG_AUTOBOOT_STOP_STR="\x1b" +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/UTOO_P66_defconfig b/configs/UTOO_P66_defconfig index bf17a63..bad17c3 100644 --- a/configs/UTOO_P66_defconfig +++ b/configs/UTOO_P66_defconfig @@ -23,6 +23,9 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y # CONFIG_REQUIRE_SERIAL_CONSOLE is not set CONFIG_USB_MUSB_HOST=y diff --git a/configs/VCMA9_defconfig b/configs/VCMA9_defconfig index 0996af0..8bf5717 100644 --- a/configs/VCMA9_defconfig +++ b/configs/VCMA9_defconfig @@ -2,4 +2,8 @@ CONFIG_ARM=y CONFIG_TARGET_VCMA9=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="VCMA9 # " +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y diff --git a/configs/VOM405_defconfig b/configs/VOM405_defconfig index 045fb78..3f80c58 100644 --- a/configs/VOM405_defconfig +++ b/configs/VOM405_defconfig @@ -2,6 +2,9 @@ CONFIG_PPC=y CONFIG_4xx=y CONFIG_TARGET_VOM405=y CONFIG_OF_BOARD_SETUP=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/Wexler_TAB7200_defconfig b/configs/Wexler_TAB7200_defconfig index cdcd4eb..f25a296 100644 --- a/configs/Wexler_TAB7200_defconfig +++ b/configs/Wexler_TAB7200_defconfig @@ -16,6 +16,9 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/Wits_Pro_A20_DKT_defconfig b/configs/Wits_Pro_A20_DKT_defconfig index 5d0f327..6eaa9d6 100644 --- a/configs/Wits_Pro_A20_DKT_defconfig +++ b/configs/Wits_Pro_A20_DKT_defconfig @@ -15,6 +15,9 @@ CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,AHCI" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Wobo_i5_defconfig b/configs/Wobo_i5_defconfig index cb21222..84200e8 100644 --- a/configs/Wobo_i5_defconfig +++ b/configs/Wobo_i5_defconfig @@ -10,5 +10,8 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/Yones_Toptech_BD1078_defconfig b/configs/Yones_Toptech_BD1078_defconfig index 2f2c26b..3163ca8 100644 --- a/configs/Yones_Toptech_BD1078_defconfig +++ b/configs/Yones_Toptech_BD1078_defconfig @@ -22,5 +22,8 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/Yones_Toptech_BS1078_V2_defconfig b/configs/Yones_Toptech_BS1078_V2_defconfig index a5b215f..440fd54 100644 --- a/configs/Yones_Toptech_BS1078_V2_defconfig +++ b/configs/Yones_Toptech_BS1078_V2_defconfig @@ -20,5 +20,7 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_MUSB_HOST=y diff --git a/configs/a3m071_defconfig b/configs/a3m071_defconfig index abc6241..b47e308 100644 --- a/configs/a3m071_defconfig +++ b/configs/a3m071_defconfig @@ -5,6 +5,10 @@ CONFIG_SPL=y CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_LOOPW=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_LINK_LOCAL=y CONFIG_LIB_RAND=y CONFIG_OF_LIBFDT=y diff --git a/configs/a4m072_defconfig b/configs/a4m072_defconfig index f9ac1fc..c724993 100644 --- a/configs/a4m072_defconfig +++ b/configs/a4m072_defconfig @@ -6,5 +6,10 @@ CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="autoboot in %d seconds\n" CONFIG_AUTOBOOT_DELAY_STR="asdfg" +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y CONFIG_OF_LIBFDT=y diff --git a/configs/a4m2k_defconfig b/configs/a4m2k_defconfig index 356949e..7bbecf3 100644 --- a/configs/a4m2k_defconfig +++ b/configs/a4m2k_defconfig @@ -6,6 +6,10 @@ CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="A4M2K" CONFIG_HUSH_PARSER=y +CONFIG_LOOPW=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_LINK_LOCAL=y CONFIG_LIB_RAND=y CONFIG_OF_LIBFDT=y diff --git a/configs/ac14xx_defconfig b/configs/ac14xx_defconfig index 3d74576..d839fc8 100644 --- a/configs/ac14xx_defconfig +++ b/configs/ac14xx_defconfig @@ -4,5 +4,8 @@ CONFIG_TARGET_AC14XX=y CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_PROMPT="ac14xx> " +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/acadia_defconfig b/configs/acadia_defconfig index 4a985cc..d98ff2d 100644 --- a/configs/acadia_defconfig +++ b/configs/acadia_defconfig @@ -3,5 +3,10 @@ CONFIG_4xx=y CONFIG_TARGET_ACADIA=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/adp-ag101p_defconfig b/configs/adp-ag101p_defconfig index 87be263..8a2f7de 100644 --- a/configs/adp-ag101p_defconfig +++ b/configs/adp-ag101p_defconfig @@ -2,4 +2,5 @@ CONFIG_NDS32=y CONFIG_TARGET_ADP_AG101P=y CONFIG_SYS_PROMPT="NDS32 # " # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y diff --git a/configs/alt_defconfig b/configs/alt_defconfig index 4ea33ef..a23d59f 100644 --- a/configs/alt_defconfig +++ b/configs/alt_defconfig @@ -10,11 +10,17 @@ CONFIG_TARGET_ALT=y # CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_LOADB is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_SH_SDHI=y CONFIG_SPI_FLASH=y diff --git a/configs/am335x_baltos_defconfig b/configs/am335x_baltos_defconfig index 0ddf061..ea6e0f9 100644 --- a/configs/am335x_baltos_defconfig +++ b/configs/am335x_baltos_defconfig @@ -10,8 +10,13 @@ CONFIG_SYS_EXTRA_OPTIONS="NAND" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/am335x_boneblack_defconfig b/configs/am335x_boneblack_defconfig index 79e469d..7cd15dd 100644 --- a/configs/am335x_boneblack_defconfig +++ b/configs/am335x_boneblack_defconfig @@ -12,8 +12,14 @@ CONFIG_AUTOBOOT_DELAY_STR="d" CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DFU_TFTP=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/am335x_boneblack_vboot_defconfig b/configs/am335x_boneblack_vboot_defconfig index 89aba13..0231eed 100644 --- a/configs/am335x_boneblack_vboot_defconfig +++ b/configs/am335x_boneblack_vboot_defconfig @@ -15,8 +15,14 @@ CONFIG_AUTOBOOT_DELAY_STR="d" CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_DM_MMC=y CONFIG_SPI_FLASH=y diff --git a/configs/am335x_evm_defconfig b/configs/am335x_evm_defconfig index e21d98e..fade82f 100644 --- a/configs/am335x_evm_defconfig +++ b/configs/am335x_evm_defconfig @@ -12,8 +12,14 @@ CONFIG_AUTOBOOT_DELAY_STR="d" CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/am335x_evm_nor_defconfig b/configs/am335x_evm_nor_defconfig index 67a048e..6dc4e25 100644 --- a/configs/am335x_evm_nor_defconfig +++ b/configs/am335x_evm_nor_defconfig @@ -8,8 +8,14 @@ CONFIG_FIT=y CONFIG_SYS_EXTRA_OPTIONS="NAND" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/am335x_evm_norboot_defconfig b/configs/am335x_evm_norboot_defconfig index 332f37f..239b607 100644 --- a/configs/am335x_evm_norboot_defconfig +++ b/configs/am335x_evm_norboot_defconfig @@ -5,8 +5,14 @@ CONFIG_NOR_BOOT=y CONFIG_FIT=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/am335x_evm_spiboot_defconfig b/configs/am335x_evm_spiboot_defconfig index 4b30503..896f060 100644 --- a/configs/am335x_evm_spiboot_defconfig +++ b/configs/am335x_evm_spiboot_defconfig @@ -8,8 +8,14 @@ CONFIG_SYS_EXTRA_OPTIONS="SPI_BOOT" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/am335x_evm_usbspl_defconfig b/configs/am335x_evm_usbspl_defconfig index 7ed400b..f6b173f 100644 --- a/configs/am335x_evm_usbspl_defconfig +++ b/configs/am335x_evm_usbspl_defconfig @@ -8,8 +8,14 @@ CONFIG_SYS_EXTRA_OPTIONS="NAND,SPL_USBETH_SUPPORT" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/am335x_gp_evm_defconfig b/configs/am335x_gp_evm_defconfig index 9859189..b069e3c 100644 --- a/configs/am335x_gp_evm_defconfig +++ b/configs/am335x_gp_evm_defconfig @@ -9,8 +9,14 @@ CONFIG_SYS_EXTRA_OPTIONS="NAND" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_DM_MMC=y CONFIG_SPI_FLASH=y diff --git a/configs/am335x_igep0033_defconfig b/configs/am335x_igep0033_defconfig index 3d0d215..424018a 100644 --- a/configs/am335x_igep0033_defconfig +++ b/configs/am335x_igep0033_defconfig @@ -6,7 +6,11 @@ CONFIG_SPL_STACK_R=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/am335x_sl50_defconfig b/configs/am335x_sl50_defconfig index 2eca61c..dbc44b1 100644 --- a/configs/am335x_sl50_defconfig +++ b/configs/am335x_sl50_defconfig @@ -8,7 +8,11 @@ CONFIG_SYS_EXTRA_OPTIONS="EMMC_BOOT" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/am3517_crane_defconfig b/configs/am3517_crane_defconfig index b9115af..b860870 100644 --- a/configs/am3517_crane_defconfig +++ b/configs/am3517_crane_defconfig @@ -7,8 +7,11 @@ CONFIG_SYS_PROMPT="AM3517_CRANE # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set CONFIG_SYS_NS16550=y diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index 1e0b35a..fa169fa 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -9,9 +9,13 @@ CONFIG_SYS_PROMPT="AM3517_EVM # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/am437x_gp_evm_defconfig b/configs/am437x_gp_evm_defconfig index 742e148..d634fbd 100644 --- a/configs/am437x_gp_evm_defconfig +++ b/configs/am437x_gp_evm_defconfig @@ -10,8 +10,14 @@ CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_DM_MMC=y diff --git a/configs/am437x_sk_evm_defconfig b/configs/am437x_sk_evm_defconfig index 276d14a..66b88a1 100644 --- a/configs/am437x_sk_evm_defconfig +++ b/configs/am437x_sk_evm_defconfig @@ -12,8 +12,14 @@ CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_DMA=y diff --git a/configs/am43xx_evm_defconfig b/configs/am43xx_evm_defconfig index aee1584..fd97124 100644 --- a/configs/am43xx_evm_defconfig +++ b/configs/am43xx_evm_defconfig @@ -5,8 +5,14 @@ CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,NAND" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/am43xx_evm_ethboot_defconfig b/configs/am43xx_evm_ethboot_defconfig index b435ea7..3065710 100644 --- a/configs/am43xx_evm_ethboot_defconfig +++ b/configs/am43xx_evm_ethboot_defconfig @@ -5,8 +5,14 @@ CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,NAND,SPL_ETH_SUPPORT" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/am43xx_evm_qspiboot_defconfig b/configs/am43xx_evm_qspiboot_defconfig index 81afd7b..e92d918 100644 --- a/configs/am43xx_evm_qspiboot_defconfig +++ b/configs/am43xx_evm_qspiboot_defconfig @@ -4,8 +4,14 @@ CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,QSPI,QSPI_BOOT" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/am43xx_evm_usbhost_boot_defconfig b/configs/am43xx_evm_usbhost_boot_defconfig index 218b524..f6f6375 100644 --- a/configs/am43xx_evm_usbhost_boot_defconfig +++ b/configs/am43xx_evm_usbhost_boot_defconfig @@ -5,8 +5,14 @@ CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1,NAND,SPL_USB_HOST_SUPPORT" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/am57xx_evm_defconfig b/configs/am57xx_evm_defconfig index 3b1fed2..608f172 100644 --- a/configs/am57xx_evm_defconfig +++ b/configs/am57xx_evm_defconfig @@ -10,8 +10,13 @@ CONFIG_SPL_STACK_R=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_DM_MMC=y diff --git a/configs/am57xx_evm_nodt_defconfig b/configs/am57xx_evm_nodt_defconfig index 375c10c..32a94b3 100644 --- a/configs/am57xx_evm_nodt_defconfig +++ b/configs/am57xx_evm_nodt_defconfig @@ -5,7 +5,12 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/amcore_defconfig b/configs/amcore_defconfig index 9c83849..25826ca 100644 --- a/configs/amcore_defconfig +++ b/configs/amcore_defconfig @@ -4,7 +4,9 @@ CONFIG_SYS_TEXT_BASE=0xffc00000 CONFIG_SYS_PROMPT="amcore $ " # CONFIG_CMD_BOOTD is not set # CONFIG_CMD_XIMG is not set +CONFIG_LOOPW=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_CMD_TIMER=y diff --git a/configs/ap325rxa_defconfig b/configs/ap325rxa_defconfig index 8c22020..5c15b71 100644 --- a/configs/ap325rxa_defconfig +++ b/configs/ap325rxa_defconfig @@ -14,5 +14,6 @@ CONFIG_TARGET_AP325RXA=y # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/ap_sh4a_4a_defconfig b/configs/ap_sh4a_4a_defconfig index 51d5f9e..df7c344 100644 --- a/configs/ap_sh4a_4a_defconfig +++ b/configs/ap_sh4a_4a_defconfig @@ -11,10 +11,12 @@ CONFIG_TARGET_AP_SH4A_4A=y # CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/apalis_t30_defconfig b/configs/apalis_t30_defconfig index 79031d2..dcf1a3e 100644 --- a/configs/apalis_t30_defconfig +++ b/configs/apalis_t30_defconfig @@ -10,9 +10,13 @@ CONFIG_SYS_PROMPT="Apalis T30 # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y CONFIG_E1000=y CONFIG_PCI_TEGRA=y CONFIG_SYS_NS16550=y diff --git a/configs/apf27_defconfig b/configs/apf27_defconfig index 5143e26..2945e91 100644 --- a/configs/apf27_defconfig +++ b/configs/apf27_defconfig @@ -5,4 +5,8 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="BIOS> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_DNS=y CONFIG_OF_LIBFDT=y diff --git a/configs/apx4devkit_defconfig b/configs/apx4devkit_defconfig index 8352247..92e3046 100644 --- a/configs/apx4devkit_defconfig +++ b/configs/apx4devkit_defconfig @@ -4,5 +4,9 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/arches_defconfig b/configs/arches_defconfig index 69b0c6b..64adfd7 100644 --- a/configs/arches_defconfig +++ b/configs/arches_defconfig @@ -5,5 +5,9 @@ CONFIG_ARCHES=y CONFIG_DEFAULT_DEVICE_TREE="arches" CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_SYS_NS16550=y diff --git a/configs/aria_defconfig b/configs/aria_defconfig index 19f1c41..1c8c8a7 100644 --- a/configs/aria_defconfig +++ b/configs/aria_defconfig @@ -3,5 +3,8 @@ CONFIG_MPC512X=y CONFIG_TARGET_ARIA=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/aristainetos2_defconfig b/configs/aristainetos2_defconfig index 0e16206..8a75880 100644 --- a/configs/aristainetos2_defconfig +++ b/configs/aristainetos2_defconfig @@ -6,7 +6,12 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/aristainetos/aristainetos2.cfg,MX6DL" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_OF_LIBFDT=y diff --git a/configs/aristainetos2b_defconfig b/configs/aristainetos2b_defconfig index aa3f357..623f7b8 100644 --- a/configs/aristainetos2b_defconfig +++ b/configs/aristainetos2b_defconfig @@ -6,7 +6,12 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/aristainetos/aristainetos2.cfg,MX6DL" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_OF_LIBFDT=y diff --git a/configs/aristainetos_defconfig b/configs/aristainetos_defconfig index 9eca59a..ae5ade4 100644 --- a/configs/aristainetos_defconfig +++ b/configs/aristainetos_defconfig @@ -6,7 +6,12 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/aristainetos/aristainetos.cfg,MX6DL" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_OF_LIBFDT=y diff --git a/configs/armadillo-800eva_defconfig b/configs/armadillo-800eva_defconfig index dc326e1..06a7630 100644 --- a/configs/armadillo-800eva_defconfig +++ b/configs/armadillo-800eva_defconfig @@ -17,5 +17,7 @@ CONFIG_TARGET_ARMADILLO_800EVA=y # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_OF_LIBFDT=y diff --git a/configs/arndale_defconfig b/configs/arndale_defconfig index 3fe7e97..259cb22 100644 --- a/configs/arndale_defconfig +++ b/configs/arndale_defconfig @@ -9,8 +9,13 @@ CONFIG_FIT_BEST_MATCH=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ARNDALE # " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_CMD_SOUND=y CONFIG_DM_I2C_COMPAT=y CONFIG_SOUND=y diff --git a/configs/aspenite_defconfig b/configs/aspenite_defconfig index d3ac8d8..4f5df35 100644 --- a/configs/aspenite_defconfig +++ b/configs/aspenite_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_ASPENITE=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set diff --git a/configs/astro_mcf5373l_defconfig b/configs/astro_mcf5373l_defconfig index c616eb4..118f96b 100644 --- a/configs/astro_mcf5373l_defconfig +++ b/configs/astro_mcf5373l_defconfig @@ -2,6 +2,7 @@ CONFIG_M68K=y CONFIG_TARGET_ASTRO_MCF5373L=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="URMEL > " +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set diff --git a/configs/at91rm9200ek_defconfig b/configs/at91rm9200ek_defconfig index bba7e5d..3776bda 100644 --- a/configs/at91rm9200ek_defconfig +++ b/configs/at91rm9200ek_defconfig @@ -3,6 +3,9 @@ CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91RM9200EK=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91rm9200ek_ram_defconfig b/configs/at91rm9200ek_ram_defconfig index 3868ac1..0c69da8 100644 --- a/configs/at91rm9200ek_ram_defconfig +++ b/configs/at91rm9200ek_ram_defconfig @@ -4,6 +4,9 @@ CONFIG_TARGET_AT91RM9200EK=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9260ek_dataflash_cs0_defconfig b/configs/at91sam9260ek_dataflash_cs0_defconfig index a71a21f..014cb95 100644 --- a/configs/at91sam9260ek_dataflash_cs0_defconfig +++ b/configs/at91sam9260ek_dataflash_cs0_defconfig @@ -7,7 +7,10 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9260ek_dataflash_cs1_defconfig b/configs/at91sam9260ek_dataflash_cs1_defconfig index 5884ffa..a755103 100644 --- a/configs/at91sam9260ek_dataflash_cs1_defconfig +++ b/configs/at91sam9260ek_dataflash_cs1_defconfig @@ -7,7 +7,10 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9260ek_nandflash_defconfig b/configs/at91sam9260ek_nandflash_defconfig index 9d49a1a..bb65e89 100644 --- a/configs/at91sam9260ek_nandflash_defconfig +++ b/configs/at91sam9260ek_nandflash_defconfig @@ -7,7 +7,10 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9261ek_dataflash_cs0_defconfig b/configs/at91sam9261ek_dataflash_cs0_defconfig index 2bdc4a6..e196e8a 100644 --- a/configs/at91sam9261ek_dataflash_cs0_defconfig +++ b/configs/at91sam9261ek_dataflash_cs0_defconfig @@ -7,7 +7,10 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9261ek_dataflash_cs3_defconfig b/configs/at91sam9261ek_dataflash_cs3_defconfig index 0f6946a..4c26cc1 100644 --- a/configs/at91sam9261ek_dataflash_cs3_defconfig +++ b/configs/at91sam9261ek_dataflash_cs3_defconfig @@ -7,7 +7,10 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9261ek_nandflash_defconfig b/configs/at91sam9261ek_nandflash_defconfig index 6a5a850..34e6ff1 100644 --- a/configs/at91sam9261ek_nandflash_defconfig +++ b/configs/at91sam9261ek_nandflash_defconfig @@ -7,7 +7,10 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9263ek_dataflash_cs0_defconfig b/configs/at91sam9263ek_dataflash_cs0_defconfig index 332dc73..2978f2d 100644 --- a/configs/at91sam9263ek_dataflash_cs0_defconfig +++ b/configs/at91sam9263ek_dataflash_cs0_defconfig @@ -8,7 +8,10 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9263ek_dataflash_defconfig b/configs/at91sam9263ek_dataflash_defconfig index 332dc73..2978f2d 100644 --- a/configs/at91sam9263ek_dataflash_defconfig +++ b/configs/at91sam9263ek_dataflash_defconfig @@ -8,7 +8,10 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9263ek_nandflash_defconfig b/configs/at91sam9263ek_nandflash_defconfig index ebcb08d..6e30d94 100644 --- a/configs/at91sam9263ek_nandflash_defconfig +++ b/configs/at91sam9263ek_nandflash_defconfig @@ -8,7 +8,10 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9263ek_norflash_boot_defconfig b/configs/at91sam9263ek_norflash_boot_defconfig index 0109a17..5b35645 100644 --- a/configs/at91sam9263ek_norflash_boot_defconfig +++ b/configs/at91sam9263ek_norflash_boot_defconfig @@ -8,7 +8,10 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9263ek_norflash_defconfig b/configs/at91sam9263ek_norflash_defconfig index 66a6ec3..cca6b13 100644 --- a/configs/at91sam9263ek_norflash_defconfig +++ b/configs/at91sam9263ek_norflash_defconfig @@ -8,7 +8,10 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9g10ek_dataflash_cs0_defconfig b/configs/at91sam9g10ek_dataflash_cs0_defconfig index 173990e..ef1af38 100644 --- a/configs/at91sam9g10ek_dataflash_cs0_defconfig +++ b/configs/at91sam9g10ek_dataflash_cs0_defconfig @@ -7,7 +7,10 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9g10ek_dataflash_cs3_defconfig b/configs/at91sam9g10ek_dataflash_cs3_defconfig index 551bfea..d5c9a98 100644 --- a/configs/at91sam9g10ek_dataflash_cs3_defconfig +++ b/configs/at91sam9g10ek_dataflash_cs3_defconfig @@ -7,7 +7,10 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9g10ek_nandflash_defconfig b/configs/at91sam9g10ek_nandflash_defconfig index 505c5ed..7de00c6 100644 --- a/configs/at91sam9g10ek_nandflash_defconfig +++ b/configs/at91sam9g10ek_nandflash_defconfig @@ -7,7 +7,10 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9g20ek_2mmc_defconfig b/configs/at91sam9g20ek_2mmc_defconfig index c5d0e68..db0af22 100644 --- a/configs/at91sam9g20ek_2mmc_defconfig +++ b/configs/at91sam9g20ek_2mmc_defconfig @@ -7,7 +7,10 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9g20ek_2mmc_nandflash_defconfig b/configs/at91sam9g20ek_2mmc_nandflash_defconfig index b8ec67c..7bb5fd5 100644 --- a/configs/at91sam9g20ek_2mmc_nandflash_defconfig +++ b/configs/at91sam9g20ek_2mmc_nandflash_defconfig @@ -7,7 +7,10 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9g20ek_dataflash_cs0_defconfig b/configs/at91sam9g20ek_dataflash_cs0_defconfig index 0317cae..c7b5faf 100644 --- a/configs/at91sam9g20ek_dataflash_cs0_defconfig +++ b/configs/at91sam9g20ek_dataflash_cs0_defconfig @@ -7,7 +7,10 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9g20ek_dataflash_cs1_defconfig b/configs/at91sam9g20ek_dataflash_cs1_defconfig index c87188f..4f89b50 100644 --- a/configs/at91sam9g20ek_dataflash_cs1_defconfig +++ b/configs/at91sam9g20ek_dataflash_cs1_defconfig @@ -7,7 +7,10 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9g20ek_nandflash_defconfig b/configs/at91sam9g20ek_nandflash_defconfig index 7b13e96..063284d 100644 --- a/configs/at91sam9g20ek_nandflash_defconfig +++ b/configs/at91sam9g20ek_nandflash_defconfig @@ -7,7 +7,10 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9m10g45ek_mmc_defconfig b/configs/at91sam9m10g45ek_mmc_defconfig index 0eea74b..663433d 100644 --- a/configs/at91sam9m10g45ek_mmc_defconfig +++ b/configs/at91sam9m10g45ek_mmc_defconfig @@ -10,6 +10,9 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9m10g45ek_nandflash_defconfig b/configs/at91sam9m10g45ek_nandflash_defconfig index 276479a..e1a1bfc 100644 --- a/configs/at91sam9m10g45ek_nandflash_defconfig +++ b/configs/at91sam9m10g45ek_nandflash_defconfig @@ -10,6 +10,9 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9n12ek_mmc_defconfig b/configs/at91sam9n12ek_mmc_defconfig index 9c8aa32..4f429cc 100644 --- a/configs/at91sam9n12ek_mmc_defconfig +++ b/configs/at91sam9n12ek_mmc_defconfig @@ -6,8 +6,12 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9n12ek_nandflash_defconfig b/configs/at91sam9n12ek_nandflash_defconfig index 600a370..4b27ab3 100644 --- a/configs/at91sam9n12ek_nandflash_defconfig +++ b/configs/at91sam9n12ek_nandflash_defconfig @@ -7,8 +7,12 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9n12ek_spiflash_defconfig b/configs/at91sam9n12ek_spiflash_defconfig index 71446cf..25f5a35 100644 --- a/configs/at91sam9n12ek_spiflash_defconfig +++ b/configs/at91sam9n12ek_spiflash_defconfig @@ -7,8 +7,12 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9x5ek_dataflash_defconfig b/configs/at91sam9x5ek_dataflash_defconfig index fce9c5e..c4a0808 100644 --- a/configs/at91sam9x5ek_dataflash_defconfig +++ b/configs/at91sam9x5ek_dataflash_defconfig @@ -7,8 +7,12 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9x5ek_mmc_defconfig b/configs/at91sam9x5ek_mmc_defconfig index f1c6dfa..62756f6 100644 --- a/configs/at91sam9x5ek_mmc_defconfig +++ b/configs/at91sam9x5ek_mmc_defconfig @@ -7,8 +7,12 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9x5ek_nandflash_defconfig b/configs/at91sam9x5ek_nandflash_defconfig index 7e660d7..aad7e85 100644 --- a/configs/at91sam9x5ek_nandflash_defconfig +++ b/configs/at91sam9x5ek_nandflash_defconfig @@ -8,8 +8,12 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9x5ek_spiflash_defconfig b/configs/at91sam9x5ek_spiflash_defconfig index 8a2aadd..310de74 100644 --- a/configs/at91sam9x5ek_spiflash_defconfig +++ b/configs/at91sam9x5ek_spiflash_defconfig @@ -8,8 +8,12 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9xeek_dataflash_cs0_defconfig b/configs/at91sam9xeek_dataflash_cs0_defconfig index 57e4481..861c3ff 100644 --- a/configs/at91sam9xeek_dataflash_cs0_defconfig +++ b/configs/at91sam9xeek_dataflash_cs0_defconfig @@ -7,7 +7,10 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9xeek_dataflash_cs1_defconfig b/configs/at91sam9xeek_dataflash_cs1_defconfig index f6b585b..2b8fa1b 100644 --- a/configs/at91sam9xeek_dataflash_cs1_defconfig +++ b/configs/at91sam9xeek_dataflash_cs1_defconfig @@ -7,7 +7,10 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9xeek_nandflash_defconfig b/configs/at91sam9xeek_nandflash_defconfig index 0d1c2c3..2a1fde8 100644 --- a/configs/at91sam9xeek_nandflash_defconfig +++ b/configs/at91sam9xeek_nandflash_defconfig @@ -7,7 +7,10 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/atngw100_defconfig b/configs/atngw100_defconfig index 7ef4677..02f6f97 100644 --- a/configs/atngw100_defconfig +++ b/configs/atngw100_defconfig @@ -7,8 +7,11 @@ CONFIG_AUTOBOOT_DELAY_STR="d" CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_ELF is not set # CONFIG_CMD_XIMG is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/atngw100mkii_defconfig b/configs/atngw100mkii_defconfig index b552421..b45c426 100644 --- a/configs/atngw100mkii_defconfig +++ b/configs/atngw100mkii_defconfig @@ -7,7 +7,10 @@ CONFIG_AUTOBOOT_DELAY_STR="d" CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_ELF is not set # CONFIG_CMD_XIMG is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/atstk1002_defconfig b/configs/atstk1002_defconfig index 1b108e5..47c1a35 100644 --- a/configs/atstk1002_defconfig +++ b/configs/atstk1002_defconfig @@ -10,3 +10,4 @@ CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y diff --git a/configs/axm_defconfig b/configs/axm_defconfig index 65c13eb..fbdd4f2 100644 --- a/configs/axm_defconfig +++ b/configs/axm_defconfig @@ -7,9 +7,13 @@ CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9G20,MACH_TYPE=2068,BOARD_AXM" # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_USE_TINY_PRINTF=y diff --git a/configs/ba10_tv_box_defconfig b/configs/ba10_tv_box_defconfig index 43733ac..863169a 100644 --- a/configs/ba10_tv_box_defconfig +++ b/configs/ba10_tv_box_defconfig @@ -13,6 +13,9 @@ CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/bamboo_defconfig b/configs/bamboo_defconfig index c8f39c9..de5a857 100644 --- a/configs/bamboo_defconfig +++ b/configs/bamboo_defconfig @@ -3,5 +3,11 @@ CONFIG_4xx=y CONFIG_TARGET_BAMBOO=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/bayleybay_defconfig b/configs/bayleybay_defconfig index 30c65fa..4c03856 100644 --- a/configs/bayleybay_defconfig +++ b/configs/bayleybay_defconfig @@ -16,9 +16,15 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_CMD_BOOTSTAGE=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y diff --git a/configs/bcm11130_defconfig b/configs/bcm11130_defconfig index f7de603..aaeb555 100644 --- a/configs/bcm11130_defconfig +++ b/configs/bcm11130_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_EXTRA_OPTIONS="SYS_MMC_ENV_DEV=0" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set diff --git a/configs/bcm11130_nand_defconfig b/configs/bcm11130_nand_defconfig index 754499f..f693095 100644 --- a/configs/bcm11130_nand_defconfig +++ b/configs/bcm11130_nand_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_EXTRA_OPTIONS="NAND" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set diff --git a/configs/bcm28155_ap_defconfig b/configs/bcm28155_ap_defconfig index f3ec577..75fbe46 100644 --- a/configs/bcm28155_ap_defconfig +++ b/configs/bcm28155_ap_defconfig @@ -3,6 +3,7 @@ CONFIG_TARGET_BCM28155_AP=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set diff --git a/configs/bcm28155_w1d_defconfig b/configs/bcm28155_w1d_defconfig index d32e533..299ffa0 100644 --- a/configs/bcm28155_w1d_defconfig +++ b/configs/bcm28155_w1d_defconfig @@ -4,6 +4,7 @@ CONFIG_SYS_EXTRA_OPTIONS="BCM_SF2_ETH,BCM_SF2_ETH_GMAC" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set diff --git a/configs/bcm911360_entphn-ns_defconfig b/configs/bcm911360_entphn-ns_defconfig index fc78fc0..68109d8 100644 --- a/configs/bcm911360_entphn-ns_defconfig +++ b/configs/bcm911360_entphn-ns_defconfig @@ -5,5 +5,7 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/bcm911360_entphn_defconfig b/configs/bcm911360_entphn_defconfig index a9c1d31..6cf2186 100644 --- a/configs/bcm911360_entphn_defconfig +++ b/configs/bcm911360_entphn_defconfig @@ -5,5 +5,7 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/bcm911360k_defconfig b/configs/bcm911360k_defconfig index 584ce17..ec7370f 100644 --- a/configs/bcm911360k_defconfig +++ b/configs/bcm911360k_defconfig @@ -5,5 +5,7 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/bcm958300k-ns_defconfig b/configs/bcm958300k-ns_defconfig index 6aebcb0..b939927 100644 --- a/configs/bcm958300k-ns_defconfig +++ b/configs/bcm958300k-ns_defconfig @@ -5,5 +5,7 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/bcm958300k_defconfig b/configs/bcm958300k_defconfig index 584ce17..ec7370f 100644 --- a/configs/bcm958300k_defconfig +++ b/configs/bcm958300k_defconfig @@ -5,5 +5,7 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/bcm958305k_defconfig b/configs/bcm958305k_defconfig index 584ce17..ec7370f 100644 --- a/configs/bcm958305k_defconfig +++ b/configs/bcm958305k_defconfig @@ -5,5 +5,7 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/bcm958622hr_defconfig b/configs/bcm958622hr_defconfig index 60ad272..e149735 100644 --- a/configs/bcm958622hr_defconfig +++ b/configs/bcm958622hr_defconfig @@ -5,5 +5,6 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TIME=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/bct-brettl2_defconfig b/configs/bct-brettl2_defconfig index bd0acfa..c7e223a 100644 --- a/configs/bct-brettl2_defconfig +++ b/configs/bct-brettl2_defconfig @@ -1,6 +1,10 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BCT_BRETTL2=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_DNS=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/beaver_defconfig b/configs/beaver_defconfig index bf22c7a..f0921e8 100644 --- a/configs/beaver_defconfig +++ b/configs/beaver_defconfig @@ -10,10 +10,16 @@ CONFIG_SYS_PROMPT="Tegra30 (Beaver) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_RTL8169=y diff --git a/configs/bf518f-ezbrd_defconfig b/configs/bf518f-ezbrd_defconfig index a8eab8c..41f1490 100644 --- a/configs/bf518f-ezbrd_defconfig +++ b/configs/bf518f-ezbrd_defconfig @@ -1,7 +1,14 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF518F_EZBRD=y +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_DNS=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/bf525-ucr2_defconfig b/configs/bf525-ucr2_defconfig index 15a8f1f..84f229f 100644 --- a/configs/bf525-ucr2_defconfig +++ b/configs/bf525-ucr2_defconfig @@ -2,6 +2,7 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF525_UCR2=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set diff --git a/configs/bf526-ezbrd_defconfig b/configs/bf526-ezbrd_defconfig index a5f4b73..614a137 100644 --- a/configs/bf526-ezbrd_defconfig +++ b/configs/bf526-ezbrd_defconfig @@ -1,7 +1,15 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF526_EZBRD=y +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_DNS=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/bf527-ad7160-eval_defconfig b/configs/bf527-ad7160-eval_defconfig index 4751df4..793ccfe 100644 --- a/configs/bf527-ad7160-eval_defconfig +++ b/configs/bf527-ad7160-eval_defconfig @@ -1,6 +1,9 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF527_AD7160_EVAL=y # CONFIG_CMD_BOOTD is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set diff --git a/configs/bf527-ezkit-v2_defconfig b/configs/bf527-ezkit-v2_defconfig index 356ab64..9035165 100644 --- a/configs/bf527-ezkit-v2_defconfig +++ b/configs/bf527-ezkit-v2_defconfig @@ -1,8 +1,16 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF527_EZKIT=y CONFIG_SYS_EXTRA_OPTIONS="BF527_EZKIT_REV_2_1" +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_DNS=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_LIB_RAND=y diff --git a/configs/bf527-ezkit_defconfig b/configs/bf527-ezkit_defconfig index c1b139c..0b63ece 100644 --- a/configs/bf527-ezkit_defconfig +++ b/configs/bf527-ezkit_defconfig @@ -1,6 +1,14 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF527_EZKIT=y +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_DNS=y CONFIG_NET_RANDOM_ETHADDR=y # CONFIG_NET_TFTP_VARS is not set CONFIG_SPI_FLASH=y diff --git a/configs/bf527-sdp_defconfig b/configs/bf527-sdp_defconfig index 383f62e..a15b92b 100644 --- a/configs/bf527-sdp_defconfig +++ b/configs/bf527-sdp_defconfig @@ -1,6 +1,9 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF527_SDP=y # CONFIG_CMD_BOOTD is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set diff --git a/configs/bf533-ezkit_defconfig b/configs/bf533-ezkit_defconfig index 6a39874..84def80 100644 --- a/configs/bf533-ezkit_defconfig +++ b/configs/bf533-ezkit_defconfig @@ -1,6 +1,11 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF533_EZKIT=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_DNS=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y CONFIG_LIB_RAND=y diff --git a/configs/bf533-stamp_defconfig b/configs/bf533-stamp_defconfig index e52587f..af9ebd2 100644 --- a/configs/bf533-stamp_defconfig +++ b/configs/bf533-stamp_defconfig @@ -1,7 +1,13 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF533_STAMP=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_DNS=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y # CONFIG_REGEX is not set CONFIG_LIB_RAND=y diff --git a/configs/bf537-minotaur_defconfig b/configs/bf537-minotaur_defconfig index bf3d79f..b7e11af 100644 --- a/configs/bf537-minotaur_defconfig +++ b/configs/bf537-minotaur_defconfig @@ -3,7 +3,11 @@ CONFIG_TARGET_BF537_MINOTAUR=y CONFIG_SYS_PROMPT="minotaur> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/bf537-pnav_defconfig b/configs/bf537-pnav_defconfig index e737561..9190de8 100644 --- a/configs/bf537-pnav_defconfig +++ b/configs/bf537-pnav_defconfig @@ -1,7 +1,14 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF537_PNAV=y +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_DNS=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/bf537-srv1_defconfig b/configs/bf537-srv1_defconfig index ba80e63..49a6fed 100644 --- a/configs/bf537-srv1_defconfig +++ b/configs/bf537-srv1_defconfig @@ -3,7 +3,11 @@ CONFIG_TARGET_BF537_SRV1=y CONFIG_SYS_PROMPT="srv1> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/bf537-stamp_defconfig b/configs/bf537-stamp_defconfig index 34c774c..dc61dfd 100644 --- a/configs/bf537-stamp_defconfig +++ b/configs/bf537-stamp_defconfig @@ -1,7 +1,14 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF537_STAMP=y +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_DNS=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/bf538f-ezkit_defconfig b/configs/bf538f-ezkit_defconfig index 48ad582..5ca81e8 100644 --- a/configs/bf538f-ezkit_defconfig +++ b/configs/bf538f-ezkit_defconfig @@ -1,6 +1,12 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF538F_EZKIT=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_DNS=y # CONFIG_REGEX is not set CONFIG_LIB_RAND=y diff --git a/configs/bf548-ezkit_defconfig b/configs/bf548-ezkit_defconfig index eca4c85..c7277f2 100644 --- a/configs/bf548-ezkit_defconfig +++ b/configs/bf548-ezkit_defconfig @@ -1,7 +1,15 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF548_EZKIT=y +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_DNS=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y diff --git a/configs/bf561-acvilon_defconfig b/configs/bf561-acvilon_defconfig index 4a25d2e..7e5d007 100644 --- a/configs/bf561-acvilon_defconfig +++ b/configs/bf561-acvilon_defconfig @@ -3,8 +3,13 @@ CONFIG_TARGET_BF561_ACVILON=y CONFIG_SYS_PROMPT="Acvilon> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_DNS=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y diff --git a/configs/bf561-ezkit_defconfig b/configs/bf561-ezkit_defconfig index 8a24403..987b58a 100644 --- a/configs/bf561-ezkit_defconfig +++ b/configs/bf561-ezkit_defconfig @@ -1,6 +1,10 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF561_EZKIT=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_DNS=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y CONFIG_LIB_RAND=y diff --git a/configs/bf609-ezkit_defconfig b/configs/bf609-ezkit_defconfig index 642ca87..71e8406 100644 --- a/configs/bf609-ezkit_defconfig +++ b/configs/bf609-ezkit_defconfig @@ -1,7 +1,12 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BF609_EZKIT=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_DNS=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_SPI_FLASH_EON=y diff --git a/configs/bg0900_defconfig b/configs/bg0900_defconfig index 92c3ee7..1388370 100644 --- a/configs/bg0900_defconfig +++ b/configs/bg0900_defconfig @@ -4,7 +4,11 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/birdland_bav335a_defconfig b/configs/birdland_bav335a_defconfig index 5d1c0dc..14c0ce3 100644 --- a/configs/birdland_bav335a_defconfig +++ b/configs/birdland_bav335a_defconfig @@ -7,8 +7,14 @@ CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/birdland_bav335b_defconfig b/configs/birdland_bav335b_defconfig index a4aa6d9..aebf7f1 100644 --- a/configs/birdland_bav335b_defconfig +++ b/configs/birdland_bav335b_defconfig @@ -7,8 +7,14 @@ CONFIG_SYS_EXTRA_OPTIONS="SERIAL1,CONS_INDEX=1" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/blackstamp_defconfig b/configs/blackstamp_defconfig index 944145a..2415b43 100644 --- a/configs/blackstamp_defconfig +++ b/configs/blackstamp_defconfig @@ -2,6 +2,9 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BLACKSTAMP=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/blackvme_defconfig b/configs/blackvme_defconfig index 41b5a23..c6b87b2 100644 --- a/configs/blackvme_defconfig +++ b/configs/blackvme_defconfig @@ -2,6 +2,9 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_BLACKVME=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/br4_defconfig b/configs/br4_defconfig index effba78..0ca6567 100644 --- a/configs/br4_defconfig +++ b/configs/br4_defconfig @@ -3,8 +3,15 @@ CONFIG_TARGET_BR4=y CONFIG_SYS_PROMPT="br4>" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_DNS=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y diff --git a/configs/bubinga_defconfig b/configs/bubinga_defconfig index 6dcb95a..facf9fd 100644 --- a/configs/bubinga_defconfig +++ b/configs/bubinga_defconfig @@ -3,5 +3,10 @@ CONFIG_4xx=y CONFIG_TARGET_BUBINGA=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/caddy2_defconfig b/configs/caddy2_defconfig index 13b57ca..b375453 100644 --- a/configs/caddy2_defconfig +++ b/configs/caddy2_defconfig @@ -5,7 +5,9 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="CADDY2" CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/cairo_defconfig b/configs/cairo_defconfig index 5da27d2..96f8ea0 100644 --- a/configs/cairo_defconfig +++ b/configs/cairo_defconfig @@ -7,8 +7,12 @@ CONFIG_SYS_PROMPT="Cairo # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_NET is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/calimain_defconfig b/configs/calimain_defconfig index a2ba4b0..1f88b66 100644 --- a/configs/calimain_defconfig +++ b/configs/calimain_defconfig @@ -7,4 +7,6 @@ CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR="\x0b" CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y diff --git a/configs/cam5200_defconfig b/configs/cam5200_defconfig index 3d643f5..da6f1d5 100644 --- a/configs/cam5200_defconfig +++ b/configs/cam5200_defconfig @@ -4,5 +4,10 @@ CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="CAM5200,TQM5200S,TQM5200_B" CONFIG_HUSH_PARSER=y +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y CONFIG_OF_LIBFDT=y diff --git a/configs/cam5200_niosflash_defconfig b/configs/cam5200_niosflash_defconfig index 99af7ce..ef63089 100644 --- a/configs/cam5200_niosflash_defconfig +++ b/configs/cam5200_niosflash_defconfig @@ -4,5 +4,10 @@ CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="CAM5200,TQM5200S,TQM5200_B,CAM5200_NIOSFLASH" CONFIG_HUSH_PARSER=y +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y CONFIG_OF_LIBFDT=y diff --git a/configs/canmb_defconfig b/configs/canmb_defconfig index b1ec147..5caea0d 100644 --- a/configs/canmb_defconfig +++ b/configs/canmb_defconfig @@ -2,3 +2,5 @@ CONFIG_PPC=y CONFIG_MPC5xxx=y CONFIG_TARGET_CANMB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_SNTP=y diff --git a/configs/canyonlands_defconfig b/configs/canyonlands_defconfig index a2e27be..d95fe73 100644 --- a/configs/canyonlands_defconfig +++ b/configs/canyonlands_defconfig @@ -5,6 +5,12 @@ CONFIG_CANYONLANDS=y CONFIG_DEFAULT_DEVICE_TREE="canyonlands" CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_SYS_NS16550=y diff --git a/configs/cardhu_defconfig b/configs/cardhu_defconfig index c4a0580..42e0b2c 100644 --- a/configs/cardhu_defconfig +++ b/configs/cardhu_defconfig @@ -10,10 +10,16 @@ CONFIG_SYS_PROMPT="Tegra30 (Cardhu) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_RTL8169=y diff --git a/configs/cgtqmx6eval_defconfig b/configs/cgtqmx6eval_defconfig index ffc4d7c..d164d1a 100644 --- a/configs/cgtqmx6eval_defconfig +++ b/configs/cgtqmx6eval_defconfig @@ -7,8 +7,13 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="CGT-QMX6-Quad U-Boot > " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_USB=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y diff --git a/configs/charon_defconfig b/configs/charon_defconfig index 7e50cfc..f391963 100644 --- a/configs/charon_defconfig +++ b/configs/charon_defconfig @@ -3,5 +3,11 @@ CONFIG_MPC5xxx=y CONFIG_TARGET_CHARON=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y CONFIG_OF_LIBFDT=y diff --git a/configs/chromebook_jerry_defconfig b/configs/chromebook_jerry_defconfig index 1fef01e..ef0e95b 100644 --- a/configs/chromebook_jerry_defconfig +++ b/configs/chromebook_jerry_defconfig @@ -11,7 +11,14 @@ CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_SPL_OF_CONTROL=y diff --git a/configs/chromebook_link_defconfig b/configs/chromebook_link_defconfig index 667d0ae..8088f0c 100644 --- a/configs/chromebook_link_defconfig +++ b/configs/chromebook_link_defconfig @@ -15,9 +15,15 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_CMD_BOOTSTAGE=y CONFIG_CMD_TPM=y CONFIG_CMD_TPM_TEST=y diff --git a/configs/chromebook_samus_defconfig b/configs/chromebook_samus_defconfig index 11f25a4..20ea99a 100644 --- a/configs/chromebook_samus_defconfig +++ b/configs/chromebook_samus_defconfig @@ -14,9 +14,15 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_CMD_BOOTSTAGE=y CONFIG_CMD_TPM=y CONFIG_CMD_TPM_TEST=y diff --git a/configs/chromebox_panther_defconfig b/configs/chromebox_panther_defconfig index ba03f7d..e18c3c7 100644 --- a/configs/chromebox_panther_defconfig +++ b/configs/chromebox_panther_defconfig @@ -11,9 +11,15 @@ CONFIG_BOOTSTAGE_REPORT=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_CMD_BOOTSTAGE=y CONFIG_CMD_TPM=y CONFIG_CMD_TPM_TEST=y diff --git a/configs/clearfog_defconfig b/configs/clearfog_defconfig index 57d6a64..9ecf08e 100644 --- a/configs/clearfog_defconfig +++ b/configs/clearfog_defconfig @@ -6,8 +6,15 @@ CONFIG_DEFAULT_DEVICE_TREE="armada-388-clearfog" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_SPI_FLASH=y CONFIG_DEBUG_UART=y diff --git a/configs/cm-bf527_defconfig b/configs/cm-bf527_defconfig index 058e371..a9dafeb 100644 --- a/configs/cm-bf527_defconfig +++ b/configs/cm-bf527_defconfig @@ -1,6 +1,11 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_CM_BF527=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_DNS=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y diff --git a/configs/cm-bf533_defconfig b/configs/cm-bf533_defconfig index a14c343..14b959c 100644 --- a/configs/cm-bf533_defconfig +++ b/configs/cm-bf533_defconfig @@ -2,5 +2,8 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_CM_BF533=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_DNS=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y CONFIG_LIB_RAND=y diff --git a/configs/cm-bf537e_defconfig b/configs/cm-bf537e_defconfig index 8cfb2b4..6366048 100644 --- a/configs/cm-bf537e_defconfig +++ b/configs/cm-bf537e_defconfig @@ -1,6 +1,12 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_CM_BF537E=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_DNS=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y diff --git a/configs/cm-bf537u_defconfig b/configs/cm-bf537u_defconfig index 0dd30a8..67b04d1 100644 --- a/configs/cm-bf537u_defconfig +++ b/configs/cm-bf537u_defconfig @@ -1,6 +1,12 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_CM_BF537U=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_DNS=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y diff --git a/configs/cm-bf548_defconfig b/configs/cm-bf548_defconfig index 30abb47..90187bd 100644 --- a/configs/cm-bf548_defconfig +++ b/configs/cm-bf548_defconfig @@ -1,7 +1,12 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_CM_BF548=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_DNS=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y # CONFIG_REGEX is not set CONFIG_LIB_RAND=y diff --git a/configs/cm-bf561_defconfig b/configs/cm-bf561_defconfig index 1adbfc3..086a05a 100644 --- a/configs/cm-bf561_defconfig +++ b/configs/cm-bf561_defconfig @@ -2,5 +2,8 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_CM_BF561=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_DNS=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y CONFIG_LIB_RAND=y diff --git a/configs/cm5200_defconfig b/configs/cm5200_defconfig index 171ed47..7f854f9 100644 --- a/configs/cm5200_defconfig +++ b/configs/cm5200_defconfig @@ -2,5 +2,11 @@ CONFIG_PPC=y CONFIG_MPC5xxx=y CONFIG_TARGET_CM5200=y CONFIG_OF_BOARD_SETUP=y +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y CONFIG_OF_LIBFDT=y diff --git a/configs/cm_t335_defconfig b/configs/cm_t335_defconfig index 7fe6be3..bf8d21e 100644 --- a/configs/cm_t335_defconfig +++ b/configs/cm_t335_defconfig @@ -5,7 +5,10 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="CM-T335 # " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/cm_t3517_defconfig b/configs/cm_t3517_defconfig index 80a7c34..774e259 100644 --- a/configs/cm_t3517_defconfig +++ b/configs/cm_t3517_defconfig @@ -5,9 +5,13 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="CM-T3517 # " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/cm_t35_defconfig b/configs/cm_t35_defconfig index 2f9f228..32d73ec 100644 --- a/configs/cm_t35_defconfig +++ b/configs/cm_t35_defconfig @@ -6,8 +6,12 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="CM-T3x # " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/cm_t43_defconfig b/configs/cm_t43_defconfig index f44ee68..e9494dd 100644 --- a/configs/cm_t43_defconfig +++ b/configs/cm_t43_defconfig @@ -5,12 +5,17 @@ CONFIG_DM_GPIO=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="CM-T43 # " +# CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y diff --git a/configs/cm_t54_defconfig b/configs/cm_t54_defconfig index 496a3d3..a372aa3 100644 --- a/configs/cm_t54_defconfig +++ b/configs/cm_t54_defconfig @@ -7,8 +7,13 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="CM-T54 # " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/cobra5272_defconfig b/configs/cobra5272_defconfig index 2e845e7..3cb69ac 100644 --- a/configs/cobra5272_defconfig +++ b/configs/cobra5272_defconfig @@ -5,3 +5,4 @@ CONFIG_SYS_PROMPT="COBRA > " # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y diff --git a/configs/colibri_pxa270_defconfig b/configs/colibri_pxa270_defconfig index 2dead77..6926104 100644 --- a/configs/colibri_pxa270_defconfig +++ b/configs/colibri_pxa270_defconfig @@ -1,9 +1,13 @@ CONFIG_ARM=y CONFIG_TARGET_COLIBRI_PXA270=y CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="$ " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y # CONFIG_EFI_LOADER is not set diff --git a/configs/colibri_t20_defconfig b/configs/colibri_t20_defconfig index 70da60c..c174b9c 100644 --- a/configs/colibri_t20_defconfig +++ b/configs/colibri_t20_defconfig @@ -10,9 +10,13 @@ CONFIG_SYS_PROMPT="Colibri T20 # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y CONFIG_PWM_TEGRA=y diff --git a/configs/colibri_t30_defconfig b/configs/colibri_t30_defconfig index 4f25973..24f0763 100644 --- a/configs/colibri_t30_defconfig +++ b/configs/colibri_t30_defconfig @@ -10,9 +10,13 @@ CONFIG_SYS_PROMPT="Colibri T30 # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_DM_USB=y diff --git a/configs/colibri_vf_defconfig b/configs/colibri_vf_defconfig index bcafd59..9e37e21 100644 --- a/configs/colibri_vf_defconfig +++ b/configs/colibri_vf_defconfig @@ -8,9 +8,13 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/toradex/colibri_vf/imximage.cfg,ENV_I CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Colibri VFxx # " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MEMTEST=y CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_VYBRID_GPIO=y diff --git a/configs/colorfly_e708_q1_defconfig b/configs/colorfly_e708_q1_defconfig index ac83103..95d55be 100644 --- a/configs/colorfly_e708_q1_defconfig +++ b/configs/colorfly_e708_q1_defconfig @@ -20,6 +20,8 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_AXP_DLDO2_VOLT=1800 CONFIG_USB_MUSB_HOST=y diff --git a/configs/conga-qeval20-qa3-e3845_defconfig b/configs/conga-qeval20-qa3-e3845_defconfig index 83d477e..a802bbd 100644 --- a/configs/conga-qeval20-qa3-e3845_defconfig +++ b/configs/conga-qeval20-qa3-e3845_defconfig @@ -16,9 +16,15 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_CMD_BOOTSTAGE=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y diff --git a/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig b/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig index b5b6e7c..aa53c60 100644 --- a/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig +++ b/configs/controlcenterd_36BIT_SDCARD_DEVELOP_defconfig @@ -9,6 +9,10 @@ CONFIG_SYS_EXTRA_OPTIONS="36BIT,SDCARD,DEVELOP" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_CMD_TPM=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/controlcenterd_36BIT_SDCARD_defconfig b/configs/controlcenterd_36BIT_SDCARD_defconfig index 0590c8a..e4de7aa 100644 --- a/configs/controlcenterd_36BIT_SDCARD_defconfig +++ b/configs/controlcenterd_36BIT_SDCARD_defconfig @@ -9,6 +9,10 @@ CONFIG_SYS_EXTRA_OPTIONS="36BIT,SDCARD" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_PING=y CONFIG_CMD_TPM=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/coreboot-x86_defconfig b/configs/coreboot-x86_defconfig index ff5c22e..e614122 100644 --- a/configs/coreboot-x86_defconfig +++ b/configs/coreboot-x86_defconfig @@ -7,8 +7,14 @@ CONFIG_BOOTSTAGE_REPORT=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_CMD_BOOTSTAGE=y CONFIG_CMD_TPM=y CONFIG_CMD_TPM_TEST=y diff --git a/configs/corvus_defconfig b/configs/corvus_defconfig index 3318221..44fb275 100644 --- a/configs/corvus_defconfig +++ b/configs/corvus_defconfig @@ -9,8 +9,11 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_USB=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_ATMEL_USBA=y diff --git a/configs/cougarcanyon2_defconfig b/configs/cougarcanyon2_defconfig index 8bf4e14..60a6727 100644 --- a/configs/cougarcanyon2_defconfig +++ b/configs/cougarcanyon2_defconfig @@ -5,9 +5,15 @@ CONFIG_TARGET_COUGARCANYON2=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/crownbay_defconfig b/configs/crownbay_defconfig index 8ea281e..5d0079e 100644 --- a/configs/crownbay_defconfig +++ b/configs/crownbay_defconfig @@ -14,9 +14,15 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_CMD_BOOTSTAGE=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y diff --git a/configs/d2net_v2_defconfig b/configs/d2net_v2_defconfig index 1b2fbfd..8f85ca0 100644 --- a/configs/d2net_v2_defconfig +++ b/configs/d2net_v2_defconfig @@ -3,9 +3,15 @@ CONFIG_KIRKWOOD=y CONFIG_TARGET_NET2BIG_V2=y CONFIG_SYS_EXTRA_OPTIONS="D2NET_V2" CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="d2v2> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/da850_am18xxevm_defconfig b/configs/da850_am18xxevm_defconfig index b4820cf..8772ec8 100644 --- a/configs/da850_am18xxevm_defconfig +++ b/configs/da850_am18xxevm_defconfig @@ -6,7 +6,11 @@ CONFIG_SYS_EXTRA_OPTIONS="DA850_AM18X_EVM,MAC_ADDR_IN_EEPROM,SYS_I2C_EEPROM_ADDR CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/da850evm_defconfig b/configs/da850evm_defconfig index 605aba7..64bed91 100644 --- a/configs/da850evm_defconfig +++ b/configs/da850evm_defconfig @@ -7,7 +7,11 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot > " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/da850evm_direct_nor_defconfig b/configs/da850evm_direct_nor_defconfig index fdf6786..2105ebf 100644 --- a/configs/da850evm_direct_nor_defconfig +++ b/configs/da850evm_direct_nor_defconfig @@ -4,7 +4,10 @@ CONFIG_TARGET_DA850EVM=y CONFIG_SYS_EXTRA_OPTIONS="MAC_ADDR_IN_SPIFLASH,USE_NOR,DIRECT_NOR_BOOT" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot > " +CONFIG_CMD_SF=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/dalmore_defconfig b/configs/dalmore_defconfig index 59835a7..a2a6e23 100644 --- a/configs/dalmore_defconfig +++ b/configs/dalmore_defconfig @@ -10,10 +10,16 @@ CONFIG_SYS_PROMPT="Tegra114 (Dalmore) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/db-88f6720_defconfig b/configs/db-88f6720_defconfig index 75bc1f0..802e684 100644 --- a/configs/db-88f6720_defconfig +++ b/configs/db-88f6720_defconfig @@ -7,8 +7,15 @@ CONFIG_DEFAULT_DEVICE_TREE="armada-375-db" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_MISC=y diff --git a/configs/db-88f6820-gp_defconfig b/configs/db-88f6820-gp_defconfig index 111f3a1..c656c94 100644 --- a/configs/db-88f6820-gp_defconfig +++ b/configs/db-88f6820-gp_defconfig @@ -6,8 +6,15 @@ CONFIG_DEFAULT_DEVICE_TREE="armada-388-gp" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/db-mv784mp-gp_defconfig b/configs/db-mv784mp-gp_defconfig index 6dda2ae..373773d 100644 --- a/configs/db-mv784mp-gp_defconfig +++ b/configs/db-mv784mp-gp_defconfig @@ -7,8 +7,15 @@ CONFIG_DEFAULT_DEVICE_TREE="armada-xp-gp" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_NAND_PXA3XX=y CONFIG_SPI_FLASH=y diff --git a/configs/dbau1000_defconfig b/configs/dbau1000_defconfig index c69d404..c3fa26f 100644 --- a/configs/dbau1000_defconfig +++ b/configs/dbau1000_defconfig @@ -11,4 +11,5 @@ CONFIG_SYS_PROMPT="DbAu1xx0 # " # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/dbau1100_defconfig b/configs/dbau1100_defconfig index 2e38812..5e2c9bd 100644 --- a/configs/dbau1100_defconfig +++ b/configs/dbau1100_defconfig @@ -11,4 +11,5 @@ CONFIG_SYS_PROMPT="DbAu1xx0 # " # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/dbau1500_defconfig b/configs/dbau1500_defconfig index f61e7b6..10fe8aa 100644 --- a/configs/dbau1500_defconfig +++ b/configs/dbau1500_defconfig @@ -11,4 +11,5 @@ CONFIG_SYS_PROMPT="DbAu1xx0 # " # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/devconcenter_defconfig b/configs/devconcenter_defconfig index 8d1b786..5d55c49 100644 --- a/configs/devconcenter_defconfig +++ b/configs/devconcenter_defconfig @@ -5,5 +5,11 @@ CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="DEVCONCENTER" CONFIG_HUSH_PARSER=y +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/devkit3250_defconfig b/configs/devkit3250_defconfig index dbb447d..b659da6 100644 --- a/configs/devkit3250_defconfig +++ b/configs/devkit3250_defconfig @@ -5,9 +5,14 @@ CONFIG_SPL_DM=y CONFIG_DM_SERIAL=y CONFIG_DM_GPIO=y CONFIG_SPL=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/devkit8000_defconfig b/configs/devkit8000_defconfig index d7e9235..0e1cfc5 100644 --- a/configs/devkit8000_defconfig +++ b/configs/devkit8000_defconfig @@ -6,7 +6,10 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/difrnce_dit4350_defconfig b/configs/difrnce_dit4350_defconfig index b8e04f3..214a1ae 100644 --- a/configs/difrnce_dit4350_defconfig +++ b/configs/difrnce_dit4350_defconfig @@ -19,5 +19,8 @@ CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/digsy_mtc_RAMBOOT_defconfig b/configs/digsy_mtc_RAMBOOT_defconfig index 4ac8bda..ad8292f 100644 --- a/configs/digsy_mtc_RAMBOOT_defconfig +++ b/configs/digsy_mtc_RAMBOOT_defconfig @@ -8,5 +8,11 @@ CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" CONFIG_AUTOBOOT_DELAY_STR="d" CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_LOOPW=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/digsy_mtc_defconfig b/configs/digsy_mtc_defconfig index e43a910..e87618f 100644 --- a/configs/digsy_mtc_defconfig +++ b/configs/digsy_mtc_defconfig @@ -6,5 +6,11 @@ CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="autoboot in %d seconds\n" CONFIG_AUTOBOOT_DELAY_STR=" " +CONFIG_LOOPW=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/digsy_mtc_rev5_RAMBOOT_defconfig b/configs/digsy_mtc_rev5_RAMBOOT_defconfig index be8b855..cd24c16 100644 --- a/configs/digsy_mtc_rev5_RAMBOOT_defconfig +++ b/configs/digsy_mtc_rev5_RAMBOOT_defconfig @@ -8,5 +8,11 @@ CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" CONFIG_AUTOBOOT_DELAY_STR="d" CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_LOOPW=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/digsy_mtc_rev5_defconfig b/configs/digsy_mtc_rev5_defconfig index 67a8f2a..e617acc 100644 --- a/configs/digsy_mtc_rev5_defconfig +++ b/configs/digsy_mtc_rev5_defconfig @@ -8,5 +8,11 @@ CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" CONFIG_AUTOBOOT_DELAY_STR="d" CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_LOOPW=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/dlvision-10g_defconfig b/configs/dlvision-10g_defconfig index 1f4c633..5565bb8 100644 --- a/configs/dlvision-10g_defconfig +++ b/configs/dlvision-10g_defconfig @@ -8,6 +8,9 @@ CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_ELF is not set +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/dlvision_defconfig b/configs/dlvision_defconfig index dd673b0..6554fb3 100644 --- a/configs/dlvision_defconfig +++ b/configs/dlvision_defconfig @@ -6,6 +6,8 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_ELF is not set +CONFIG_LOOPW=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/dnp5370_defconfig b/configs/dnp5370_defconfig index 3b323e9..1da61c1 100644 --- a/configs/dnp5370_defconfig +++ b/configs/dnp5370_defconfig @@ -2,4 +2,5 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_DNP5370=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/dns325_defconfig b/configs/dns325_defconfig index 493da5b..ac236cd 100644 --- a/configs/dns325_defconfig +++ b/configs/dns325_defconfig @@ -4,6 +4,9 @@ CONFIG_TARGET_DNS325=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/dockstar_defconfig b/configs/dockstar_defconfig index 757043b..2fecf39 100644 --- a/configs/dockstar_defconfig +++ b/configs/dockstar_defconfig @@ -4,6 +4,9 @@ CONFIG_TARGET_DOCKSTAR=y CONFIG_SYS_PROMPT="DockStar> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/dra72_evm_defconfig b/configs/dra72_evm_defconfig index 287a6bd..9b5cd78 100644 --- a/configs/dra72_evm_defconfig +++ b/configs/dra72_evm_defconfig @@ -13,8 +13,14 @@ CONFIG_SPL_STACK_R=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_DM_MMC=y diff --git a/configs/dra74_evm_defconfig b/configs/dra74_evm_defconfig index 99db387..47fd428 100644 --- a/configs/dra74_evm_defconfig +++ b/configs/dra74_evm_defconfig @@ -12,8 +12,14 @@ CONFIG_SPL_STACK_R=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_DM_MMC=y diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index b039719..41cdbbf 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -7,8 +7,14 @@ CONFIG_SPL_STACK_R=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_SPANSION=y diff --git a/configs/dra7xx_evm_qspiboot_defconfig b/configs/dra7xx_evm_qspiboot_defconfig index 3f9724b..15e94a0 100644 --- a/configs/dra7xx_evm_qspiboot_defconfig +++ b/configs/dra7xx_evm_qspiboot_defconfig @@ -8,8 +8,14 @@ CONFIG_SYS_EXTRA_OPTIONS="QSPI_BOOT" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SYS_NS16550=y diff --git a/configs/dra7xx_evm_uart3_defconfig b/configs/dra7xx_evm_uart3_defconfig index 6161057..ccc2124 100644 --- a/configs/dra7xx_evm_uart3_defconfig +++ b/configs/dra7xx_evm_uart3_defconfig @@ -9,8 +9,14 @@ CONFIG_SYS_EXTRA_OPTIONS="SPL_YMODEM_SUPPORT" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SYS_NS16550=y diff --git a/configs/draco_defconfig b/configs/draco_defconfig index 1b3aea5..bfee48a 100644 --- a/configs/draco_defconfig +++ b/configs/draco_defconfig @@ -8,8 +8,14 @@ CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc><Esc>" to stop\ CONFIG_AUTOBOOT_STOP_STR="\x1b\x1b" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/dragonboard410c_defconfig b/configs/dragonboard410c_defconfig index b64941f..68b5de4 100644 --- a/configs/dragonboard410c_defconfig +++ b/configs/dragonboard410c_defconfig @@ -5,7 +5,12 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="dragonboard410c => " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MEMINFO=y CONFIG_CMD_USB=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIMER=y CONFIG_CLK=y CONFIG_MSM_GPIO=y CONFIG_PM8916_GPIO=y diff --git a/configs/ds414_defconfig b/configs/ds414_defconfig index 4c3c1df..fb5d916 100644 --- a/configs/ds414_defconfig +++ b/configs/ds414_defconfig @@ -6,7 +6,15 @@ CONFIG_DEFAULT_DEVICE_TREE="armada-xp-synology-ds414" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y diff --git a/configs/dserve_dsrv9703c_defconfig b/configs/dserve_dsrv9703c_defconfig index 2648ccc..254440f 100644 --- a/configs/dserve_dsrv9703c_defconfig +++ b/configs/dserve_dsrv9703c_defconfig @@ -17,5 +17,8 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/duovero_defconfig b/configs/duovero_defconfig index 3312dda..41f669b 100644 --- a/configs/duovero_defconfig +++ b/configs/duovero_defconfig @@ -6,8 +6,13 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="duovero # " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/e2220-1170_defconfig b/configs/e2220-1170_defconfig index 6ce9de5..c23a298 100644 --- a/configs/e2220-1170_defconfig +++ b/configs/e2220-1170_defconfig @@ -8,10 +8,16 @@ CONFIG_SYS_PROMPT="Tegra210 (E2220-1170) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/ea20_defconfig b/configs/ea20_defconfig index cdcfdf6..2c0f1e8 100644 --- a/configs/ea20_defconfig +++ b/configs/ea20_defconfig @@ -5,8 +5,13 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ea20 > " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SYS_NS16550=y diff --git a/configs/eb_cpu5282_defconfig b/configs/eb_cpu5282_defconfig index 1e204bf..5dcf4ec 100644 --- a/configs/eb_cpu5282_defconfig +++ b/configs/eb_cpu5282_defconfig @@ -4,4 +4,6 @@ CONFIG_SYS_TEXT_BASE=0xFF000000 CONFIG_SYS_EXTRA_OPTIONS="SYS_MONITOR_BASE=0xFF000400" CONFIG_SYS_PROMPT="\nEB+CPU5282> " # CONFIG_CMD_LOADB is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y diff --git a/configs/eb_cpu5282_internal_defconfig b/configs/eb_cpu5282_internal_defconfig index 2db895c..a714458 100644 --- a/configs/eb_cpu5282_internal_defconfig +++ b/configs/eb_cpu5282_internal_defconfig @@ -3,4 +3,6 @@ CONFIG_TARGET_EB_CPU5282=y CONFIG_SYS_TEXT_BASE=0xF0000000 CONFIG_SYS_EXTRA_OPTIONS="SYS_MONITOR_BASE=0xF0000418" # CONFIG_CMD_LOADB is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y diff --git a/configs/eco5pk_defconfig b/configs/eco5pk_defconfig index 63fd75b..33dcc7b 100644 --- a/configs/eco5pk_defconfig +++ b/configs/eco5pk_defconfig @@ -7,7 +7,10 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ECO5-PK # " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/ecovec_defconfig b/configs/ecovec_defconfig index de4617c..93ad9ba 100644 --- a/configs/ecovec_defconfig +++ b/configs/ecovec_defconfig @@ -11,10 +11,13 @@ CONFIG_TARGET_ECOVEC=y # CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/edb9315a_defconfig b/configs/edb9315a_defconfig index 8a76405..c56f90a 100644 --- a/configs/edb9315a_defconfig +++ b/configs/edb9315a_defconfig @@ -2,6 +2,9 @@ CONFIG_ARM=y CONFIG_TARGET_EDB93XX=y CONFIG_SYS_EXTRA_OPTIONS="MK_edb9315a" CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="EDB9315A> " # CONFIG_CMD_XIMG is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y diff --git a/configs/edminiv2_defconfig b/configs/edminiv2_defconfig index e58a65d..d2a36e5 100644 --- a/configs/edminiv2_defconfig +++ b/configs/edminiv2_defconfig @@ -4,5 +4,7 @@ CONFIG_TARGET_EDMINIV2=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="EDMiniV2> " +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_SYS_NS16550=y diff --git a/configs/efi-x86_defconfig b/configs/efi-x86_defconfig index 6f2967b..1954717 100644 --- a/configs/efi-x86_defconfig +++ b/configs/efi-x86_defconfig @@ -6,8 +6,14 @@ CONFIG_FIT=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_BOOTM is not set # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_NET is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_DM_PCI=y diff --git a/configs/espt_defconfig b/configs/espt_defconfig index fbb712d..9d491cf 100644 --- a/configs/espt_defconfig +++ b/configs/espt_defconfig @@ -16,5 +16,6 @@ CONFIG_TARGET_ESPT=y # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/ethernut5_defconfig b/configs/ethernut5_defconfig index d25c225..7739473 100644 --- a/configs/ethernut5_defconfig +++ b/configs/ethernut5_defconfig @@ -6,6 +6,16 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_BDI is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_RARP=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_CDP=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_DNS=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y diff --git a/configs/evb-rk3036_defconfig b/configs/evb-rk3036_defconfig index fc40b1d..d5ff72f 100644 --- a/configs/evb-rk3036_defconfig +++ b/configs/evb-rk3036_defconfig @@ -7,7 +7,13 @@ CONFIG_DEFAULT_DEVICE_TREE="rk3036-sdk" CONFIG_SPL_STACK_R=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CLK=y diff --git a/configs/firefly-rk3288_defconfig b/configs/firefly-rk3288_defconfig index 64cc90a..1c7155f 100644 --- a/configs/firefly-rk3288_defconfig +++ b/configs/firefly-rk3288_defconfig @@ -9,7 +9,14 @@ CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_SPL_OF_CONTROL=y diff --git a/configs/flea3_defconfig b/configs/flea3_defconfig index 94f283a..b51bff8 100644 --- a/configs/flea3_defconfig +++ b/configs/flea3_defconfig @@ -3,4 +3,8 @@ CONFIG_TARGET_FLEA3=y CONFIG_FIT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="flea3 U-Boot > " +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y diff --git a/configs/fo300_defconfig b/configs/fo300_defconfig index ae90d45..f2ea59b 100644 --- a/configs/fo300_defconfig +++ b/configs/fo300_defconfig @@ -4,5 +4,11 @@ CONFIG_TARGET_TQM5200=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="FO300" CONFIG_HUSH_PARSER=y +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y CONFIG_OF_LIBFDT=y diff --git a/configs/ga10h_v1_1_defconfig b/configs/ga10h_v1_1_defconfig index da8e2fe..c5f943d 100644 --- a/configs/ga10h_v1_1_defconfig +++ b/configs/ga10h_v1_1_defconfig @@ -22,6 +22,8 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/galileo_defconfig b/configs/galileo_defconfig index e613074..b1038d6 100644 --- a/configs/galileo_defconfig +++ b/configs/galileo_defconfig @@ -10,9 +10,15 @@ CONFIG_BOOTSTAGE_REPORT=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_CMD_BOOTSTAGE=y CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y diff --git a/configs/gdppc440etx_defconfig b/configs/gdppc440etx_defconfig index 98a0dcc..336d602 100644 --- a/configs/gdppc440etx_defconfig +++ b/configs/gdppc440etx_defconfig @@ -5,5 +5,9 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/ge_b450v3_defconfig b/configs/ge_b450v3_defconfig index 3f134cc..62aa0cd 100644 --- a/configs/ge_b450v3_defconfig +++ b/configs/ge_b450v3_defconfig @@ -4,7 +4,12 @@ CONFIG_TARGET_GE_B450V3=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_OF_LIBFDT=y diff --git a/configs/ge_b650v3_defconfig b/configs/ge_b650v3_defconfig index 067858d..bfe9de1 100644 --- a/configs/ge_b650v3_defconfig +++ b/configs/ge_b650v3_defconfig @@ -4,7 +4,12 @@ CONFIG_TARGET_GE_B650V3=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_OF_LIBFDT=y diff --git a/configs/ge_b850v3_defconfig b/configs/ge_b850v3_defconfig index 5205152..bc34fdf 100644 --- a/configs/ge_b850v3_defconfig +++ b/configs/ge_b850v3_defconfig @@ -4,7 +4,12 @@ CONFIG_TARGET_GE_B850V3=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_OF_LIBFDT=y diff --git a/configs/glacier_defconfig b/configs/glacier_defconfig index 3517348..4e85e13 100644 --- a/configs/glacier_defconfig +++ b/configs/glacier_defconfig @@ -5,6 +5,11 @@ CONFIG_GLACIER=y CONFIG_DEFAULT_DEVICE_TREE="glacier" CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_SYS_NS16550=y diff --git a/configs/glacier_ramboot_defconfig b/configs/glacier_ramboot_defconfig index 7069c28..3b72ecb 100644 --- a/configs/glacier_ramboot_defconfig +++ b/configs/glacier_ramboot_defconfig @@ -6,6 +6,11 @@ CONFIG_DEFAULT_DEVICE_TREE="glacier" CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_RAMBOOT,SYS_TEXT_BASE=0x01000000,SYS_LDSCRIPT=board/amcc/canyonlands/u-boot-ram.lds" CONFIG_HUSH_PARSER=y +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_SYS_NS16550=y diff --git a/configs/goflexhome_defconfig b/configs/goflexhome_defconfig index ece39de..2bdea8c 100644 --- a/configs/goflexhome_defconfig +++ b/configs/goflexhome_defconfig @@ -4,6 +4,9 @@ CONFIG_TARGET_GOFLEXHOME=y CONFIG_SYS_PROMPT="GoFlexHome> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/gose_defconfig b/configs/gose_defconfig index 475bdd1..6e3de27 100644 --- a/configs/gose_defconfig +++ b/configs/gose_defconfig @@ -10,11 +10,16 @@ CONFIG_TARGET_GOSE=y # CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_LOADB is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_SH_SDHI=y CONFIG_SPI_FLASH=y diff --git a/configs/gplugd_defconfig b/configs/gplugd_defconfig index b7ef262..3b99683 100644 --- a/configs/gplugd_defconfig +++ b/configs/gplugd_defconfig @@ -2,8 +2,13 @@ CONFIG_ARM=y CONFIG_TARGET_GPLUGD=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/gr_cpci_ax2000_defconfig b/configs/gr_cpci_ax2000_defconfig index ddac3ab..d3f9c02 100644 --- a/configs/gr_cpci_ax2000_defconfig +++ b/configs/gr_cpci_ax2000_defconfig @@ -3,3 +3,4 @@ CONFIG_TARGET_GR_CPCI_AX2000=y CONFIG_SYS_TEXT_BASE=0x00000000 # CONFIG_CMD_ELF is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y diff --git a/configs/gr_ep2s60_defconfig b/configs/gr_ep2s60_defconfig index 0064554..29c7f29 100644 --- a/configs/gr_ep2s60_defconfig +++ b/configs/gr_ep2s60_defconfig @@ -3,3 +3,4 @@ CONFIG_TARGET_GR_EP2S60=y CONFIG_SYS_TEXT_BASE=0x00000000 # CONFIG_CMD_ELF is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y diff --git a/configs/gr_xc3s_1500_defconfig b/configs/gr_xc3s_1500_defconfig index 543cba5..e4877f2 100644 --- a/configs/gr_xc3s_1500_defconfig +++ b/configs/gr_xc3s_1500_defconfig @@ -3,3 +3,4 @@ CONFIG_TARGET_GR_XC3S_1500=y CONFIG_SYS_TEXT_BASE=0x00000000 # CONFIG_CMD_ELF is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y diff --git a/configs/grasshopper_defconfig b/configs/grasshopper_defconfig index 5e8bd8b..8dc1b63 100644 --- a/configs/grasshopper_defconfig +++ b/configs/grasshopper_defconfig @@ -9,3 +9,5 @@ CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_ELF is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y diff --git a/configs/gt90h_v4_defconfig b/configs/gt90h_v4_defconfig index 0e53cc5..723a4f2 100644 --- a/configs/gt90h_v4_defconfig +++ b/configs/gt90h_v4_defconfig @@ -21,5 +21,7 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_MUSB_HOST=y diff --git a/configs/gwventana_defconfig b/configs/gwventana_defconfig index 029fee0..e0d5acd 100644 --- a/configs/gwventana_defconfig +++ b/configs/gwventana_defconfig @@ -13,7 +13,12 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Ventana > " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_DM=y CONFIG_NETDEVICES=y CONFIG_E1000=y diff --git a/configs/h2200_defconfig b/configs/h2200_defconfig index 57f157a..22f0759 100644 --- a/configs/h2200_defconfig +++ b/configs/h2200_defconfig @@ -19,4 +19,5 @@ CONFIG_SYS_PROMPT="> " # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set diff --git a/configs/h8_homlet_v2_defconfig b/configs/h8_homlet_v2_defconfig index a2e6a1c..066f353 100644 --- a/configs/h8_homlet_v2_defconfig +++ b/configs/h8_homlet_v2_defconfig @@ -15,6 +15,8 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_AXP_DLDO4_VOLT=3300 CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/haleakala_defconfig b/configs/haleakala_defconfig index 9d6a3aa..6ee9a30 100644 --- a/configs/haleakala_defconfig +++ b/configs/haleakala_defconfig @@ -4,5 +4,10 @@ CONFIG_TARGET_KILAUEA=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="HALEAKALA" CONFIG_HUSH_PARSER=y +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/harmony_defconfig b/configs/harmony_defconfig index 00dc37d..c706bfa 100644 --- a/configs/harmony_defconfig +++ b/configs/harmony_defconfig @@ -10,10 +10,13 @@ CONFIG_SYS_PROMPT="Tegra20 (Harmony) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y CONFIG_PWM_TEGRA=y diff --git a/configs/highbank_defconfig b/configs/highbank_defconfig index a91f420..b853a4e 100644 --- a/configs/highbank_defconfig +++ b/configs/highbank_defconfig @@ -9,4 +9,6 @@ CONFIG_AUTOBOOT_KEYED_CTRLC=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/hikey_defconfig b/configs/hikey_defconfig index 3f1f928..32b5c65 100644 --- a/configs/hikey_defconfig +++ b/configs/hikey_defconfig @@ -2,5 +2,8 @@ CONFIG_ARM=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/hrcon_defconfig b/configs/hrcon_defconfig index 45241b4..af6d28f 100644 --- a/configs/hrcon_defconfig +++ b/configs/hrcon_defconfig @@ -8,6 +8,8 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/hrcon_dh_defconfig b/configs/hrcon_dh_defconfig index 1d3d9b2..c060a07 100644 --- a/configs/hrcon_dh_defconfig +++ b/configs/hrcon_dh_defconfig @@ -7,5 +7,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="HRCON_DH" CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/i12-tvbox_defconfig b/configs/i12-tvbox_defconfig index 1d5bb33..e552f5d 100644 --- a/configs/i12-tvbox_defconfig +++ b/configs/i12-tvbox_defconfig @@ -10,6 +10,9 @@ CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,MACPWR=SUNXI_GPH(21)" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/iNet_3F_defconfig b/configs/iNet_3F_defconfig index 71cfb75..871811e 100644 --- a/configs/iNet_3F_defconfig +++ b/configs/iNet_3F_defconfig @@ -17,5 +17,8 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/iNet_3W_defconfig b/configs/iNet_3W_defconfig index ccd01f5..b57d5bc 100644 --- a/configs/iNet_3W_defconfig +++ b/configs/iNet_3W_defconfig @@ -17,5 +17,8 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/iNet_86VS_defconfig b/configs/iNet_86VS_defconfig index 3c4d960..e1a678a 100644 --- a/configs/iNet_86VS_defconfig +++ b/configs/iNet_86VS_defconfig @@ -16,5 +16,8 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/ibf-dsp561_defconfig b/configs/ibf-dsp561_defconfig index 9cf3652..7237cfe 100644 --- a/configs/ibf-dsp561_defconfig +++ b/configs/ibf-dsp561_defconfig @@ -1,5 +1,9 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_IBF_DSP561=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_DNS=y CONFIG_LIB_RAND=y diff --git a/configs/icnova-a20-swac_defconfig b/configs/icnova-a20-swac_defconfig index 7fe6bf0..d9b65b8 100644 --- a/configs/icnova-a20-swac_defconfig +++ b/configs/icnova-a20-swac_defconfig @@ -17,6 +17,9 @@ CONFIG_SYS_EXTRA_OPTIONS="AXP209_POWER,SUNXI_GMAC,CMD_BMP,CMD_UNZIP" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_ETH_DESIGNWARE=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/icon_defconfig b/configs/icon_defconfig index a55bbdb..ccf465d 100644 --- a/configs/icon_defconfig +++ b/configs/icon_defconfig @@ -3,5 +3,10 @@ CONFIG_4xx=y CONFIG_TARGET_ICON=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/iconnect_defconfig b/configs/iconnect_defconfig index cdb21b7..cd6fbb2 100644 --- a/configs/iconnect_defconfig +++ b/configs/iconnect_defconfig @@ -4,6 +4,8 @@ CONFIG_TARGET_ICONNECT=y CONFIG_SYS_PROMPT="iconnect => " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/ids8313_defconfig b/configs/ids8313_defconfig index 3bf051e..08867e7 100644 --- a/configs/ids8313_defconfig +++ b/configs/ids8313_defconfig @@ -10,6 +10,11 @@ CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Enter password - autoboot in %d seconds...\n" CONFIG_AUTOBOOT_DELAY_STR="ids" +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/igep0020_defconfig b/configs/igep0020_defconfig index 6f6c539..6d1dd01 100644 --- a/configs/igep0020_defconfig +++ b/configs/igep0020_defconfig @@ -6,8 +6,12 @@ CONFIG_SYS_EXTRA_OPTIONS="MACH_TYPE=MACH_TYPE_IGEP0020,BOOT_ONENAND" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/igep0020_nand_defconfig b/configs/igep0020_nand_defconfig index d8ffa00..05037f7 100644 --- a/configs/igep0020_nand_defconfig +++ b/configs/igep0020_nand_defconfig @@ -6,8 +6,12 @@ CONFIG_SYS_EXTRA_OPTIONS="MACH_TYPE=MACH_TYPE_IGEP0020,BOOT_NAND" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/igep0030_defconfig b/configs/igep0030_defconfig index 0ebf508..40150c2 100644 --- a/configs/igep0030_defconfig +++ b/configs/igep0030_defconfig @@ -6,7 +6,11 @@ CONFIG_SYS_EXTRA_OPTIONS="MACH_TYPE=MACH_TYPE_IGEP0030,BOOT_ONENAND" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/igep0030_nand_defconfig b/configs/igep0030_nand_defconfig index b0c4700..821e058 100644 --- a/configs/igep0030_nand_defconfig +++ b/configs/igep0030_nand_defconfig @@ -6,7 +6,11 @@ CONFIG_SYS_EXTRA_OPTIONS="MACH_TYPE=MACH_TYPE_IGEP0030,BOOT_NAND" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/igep0032_defconfig b/configs/igep0032_defconfig index 3a751c5..1374be2 100644 --- a/configs/igep0032_defconfig +++ b/configs/igep0032_defconfig @@ -6,8 +6,12 @@ CONFIG_SYS_EXTRA_OPTIONS="MACH_TYPE=MACH_TYPE_IGEP0032,BOOT_ONENAND" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/imx31_phycore_defconfig b/configs/imx31_phycore_defconfig index 6f3ae10..e824616 100644 --- a/configs/imx31_phycore_defconfig +++ b/configs/imx31_phycore_defconfig @@ -1,4 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_IMX31_PHYCORE=y CONFIG_SYS_PROMPT="uboot> " +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y diff --git a/configs/imx31_phycore_eet_defconfig b/configs/imx31_phycore_eet_defconfig index 445c040..afe3c3c 100644 --- a/configs/imx31_phycore_eet_defconfig +++ b/configs/imx31_phycore_eet_defconfig @@ -1,4 +1,7 @@ CONFIG_ARM=y CONFIG_TARGET_IMX31_PHYCORE=y CONFIG_SYS_EXTRA_OPTIONS="IMX31_PHYCORE_EET" +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y diff --git a/configs/inet1_defconfig b/configs/inet1_defconfig index 8d24877..8e64ef6 100644 --- a/configs/inet1_defconfig +++ b/configs/inet1_defconfig @@ -17,6 +17,9 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/inet97fv2_defconfig b/configs/inet97fv2_defconfig index 446e841..ca7c260 100644 --- a/configs/inet97fv2_defconfig +++ b/configs/inet97fv2_defconfig @@ -16,5 +16,8 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/inet98v_rev2_defconfig b/configs/inet98v_rev2_defconfig index d701617..badf78b 100644 --- a/configs/inet98v_rev2_defconfig +++ b/configs/inet98v_rev2_defconfig @@ -19,5 +19,8 @@ CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/inet9f_rev03_defconfig b/configs/inet9f_rev03_defconfig index c5a6c65..c7fc889 100644 --- a/configs/inet9f_rev03_defconfig +++ b/configs/inet9f_rev03_defconfig @@ -16,5 +16,8 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/inetspace_v2_defconfig b/configs/inetspace_v2_defconfig index 4f68833..79f2144 100644 --- a/configs/inetspace_v2_defconfig +++ b/configs/inetspace_v2_defconfig @@ -3,9 +3,15 @@ CONFIG_KIRKWOOD=y CONFIG_TARGET_NETSPACE_V2=y CONFIG_SYS_EXTRA_OPTIONS="INETSPACE_V2" CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="ns2> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/inka4x0_defconfig b/configs/inka4x0_defconfig index 4c1016a..e465e1b 100644 --- a/configs/inka4x0_defconfig +++ b/configs/inka4x0_defconfig @@ -1,4 +1,9 @@ CONFIG_PPC=y CONFIG_MPC5xxx=y CONFIG_TARGET_INKA4X0=y +CONFIG_LOOPW=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y diff --git a/configs/integratorap_cm720t_defconfig b/configs/integratorap_cm720t_defconfig index e6b0bc4..7b70eed 100644 --- a/configs/integratorap_cm720t_defconfig +++ b/configs/integratorap_cm720t_defconfig @@ -4,5 +4,6 @@ CONFIG_ARCH_INTEGRATOR_AP=y CONFIG_CM720T=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Integrator-AP # " +CONFIG_CMD_ARMFLASH=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/integratorap_cm920t_defconfig b/configs/integratorap_cm920t_defconfig index 4afd0e6..4acb12a 100644 --- a/configs/integratorap_cm920t_defconfig +++ b/configs/integratorap_cm920t_defconfig @@ -4,5 +4,6 @@ CONFIG_ARCH_INTEGRATOR_AP=y CONFIG_CM920T=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Integrator-AP # " +CONFIG_CMD_ARMFLASH=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/integratorap_cm926ejs_defconfig b/configs/integratorap_cm926ejs_defconfig index 0cfbbf3..dc66f59 100644 --- a/configs/integratorap_cm926ejs_defconfig +++ b/configs/integratorap_cm926ejs_defconfig @@ -4,5 +4,6 @@ CONFIG_ARCH_INTEGRATOR_AP=y CONFIG_CM926EJ_S=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Integrator-AP # " +CONFIG_CMD_ARMFLASH=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/integratorap_cm946es_defconfig b/configs/integratorap_cm946es_defconfig index f25c5ba..ce16756 100644 --- a/configs/integratorap_cm946es_defconfig +++ b/configs/integratorap_cm946es_defconfig @@ -4,5 +4,6 @@ CONFIG_ARCH_INTEGRATOR_AP=y CONFIG_CM946ES=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Integrator-AP # " +CONFIG_CMD_ARMFLASH=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/integratorcp_cm1136_defconfig b/configs/integratorcp_cm1136_defconfig index 36e8ad7..913ccab 100644 --- a/configs/integratorcp_cm1136_defconfig +++ b/configs/integratorcp_cm1136_defconfig @@ -4,5 +4,6 @@ CONFIG_ARCH_INTEGRATOR_CP=y CONFIG_CM1136=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Integrator-CP # " +CONFIG_CMD_ARMFLASH=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/integratorcp_cm920t_defconfig b/configs/integratorcp_cm920t_defconfig index 817544a..17c3f94 100644 --- a/configs/integratorcp_cm920t_defconfig +++ b/configs/integratorcp_cm920t_defconfig @@ -4,5 +4,6 @@ CONFIG_ARCH_INTEGRATOR_CP=y CONFIG_CM920T=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Integrator-CP # " +CONFIG_CMD_ARMFLASH=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/integratorcp_cm926ejs_defconfig b/configs/integratorcp_cm926ejs_defconfig index ae69cee..c757fad 100644 --- a/configs/integratorcp_cm926ejs_defconfig +++ b/configs/integratorcp_cm926ejs_defconfig @@ -4,5 +4,6 @@ CONFIG_ARCH_INTEGRATOR_CP=y CONFIG_CM926EJ_S=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Integrator-CP # " +CONFIG_CMD_ARMFLASH=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/integratorcp_cm946es_defconfig b/configs/integratorcp_cm946es_defconfig index 85086a5..196eab7 100644 --- a/configs/integratorcp_cm946es_defconfig +++ b/configs/integratorcp_cm946es_defconfig @@ -4,5 +4,6 @@ CONFIG_ARCH_INTEGRATOR_CP=y CONFIG_CM946ES=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Integrator-CP # " +CONFIG_CMD_ARMFLASH=y # CONFIG_CMD_SETEXPR is not set CONFIG_OF_LIBFDT=y diff --git a/configs/intip_defconfig b/configs/intip_defconfig index fea4d10..b2d1b0b 100644 --- a/configs/intip_defconfig +++ b/configs/intip_defconfig @@ -7,5 +7,11 @@ CONFIG_SYS_EXTRA_OPTIONS="INTIB" CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/io64_defconfig b/configs/io64_defconfig index 01378b3..f387a71 100644 --- a/configs/io64_defconfig +++ b/configs/io64_defconfig @@ -7,5 +7,9 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/io_defconfig b/configs/io_defconfig index 03a2898..f7351a0 100644 --- a/configs/io_defconfig +++ b/configs/io_defconfig @@ -8,6 +8,8 @@ CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_ELF is not set +CONFIG_LOOPW=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/iocon_defconfig b/configs/iocon_defconfig index aa51065..5675808 100644 --- a/configs/iocon_defconfig +++ b/configs/iocon_defconfig @@ -7,6 +7,9 @@ CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_ELF is not set +CONFIG_LOOPW=y +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/ip04_defconfig b/configs/ip04_defconfig index e2aa906..b872dea 100644 --- a/configs/ip04_defconfig +++ b/configs/ip04_defconfig @@ -2,8 +2,13 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_IP04=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_DNS=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/ipam390_defconfig b/configs/ipam390_defconfig index 6b46da0..3f771ea 100644 --- a/configs/ipam390_defconfig +++ b/configs/ipam390_defconfig @@ -7,4 +7,6 @@ CONFIG_SYS_PROMPT="U-Boot > " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y diff --git a/configs/ipek01_defconfig b/configs/ipek01_defconfig index a8e5174..d8ff177 100644 --- a/configs/ipek01_defconfig +++ b/configs/ipek01_defconfig @@ -2,5 +2,9 @@ CONFIG_PPC=y CONFIG_MPC5xxx=y CONFIG_TARGET_IPEK01=y CONFIG_OF_BOARD_SETUP=y +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y CONFIG_OF_LIBFDT=y diff --git a/configs/jesurun_q5_defconfig b/configs/jesurun_q5_defconfig index 666b7a8..99189b2 100644 --- a/configs/jesurun_q5_defconfig +++ b/configs/jesurun_q5_defconfig @@ -11,6 +11,9 @@ CONFIG_SYS_EXTRA_OPTIONS="SUNXI_EMAC,MACPWR=SUNXI_GPH(19)" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/jetson-tk1_defconfig b/configs/jetson-tk1_defconfig index a2be6f5..d123be0 100644 --- a/configs/jetson-tk1_defconfig +++ b/configs/jetson-tk1_defconfig @@ -10,10 +10,16 @@ CONFIG_SYS_PROMPT="Tegra124 (Jetson TK1) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_RTL8169=y diff --git a/configs/jupiter_defconfig b/configs/jupiter_defconfig index 072633c..21c448b 100644 --- a/configs/jupiter_defconfig +++ b/configs/jupiter_defconfig @@ -3,3 +3,4 @@ CONFIG_MPC5xxx=y CONFIG_TARGET_JUPITER=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_SNTP=y diff --git a/configs/k2e_evm_defconfig b/configs/k2e_evm_defconfig index efddf9f..1d8cc82 100644 --- a/configs/k2e_evm_defconfig +++ b/configs/k2e_evm_defconfig @@ -10,7 +10,13 @@ CONFIG_SYS_PROMPT="K2E EVM # " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_NAND=y +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_TI_AEMIF=y diff --git a/configs/k2g_evm_defconfig b/configs/k2g_evm_defconfig index 2f9b5a0..ee6f335 100644 --- a/configs/k2g_evm_defconfig +++ b/configs/k2g_evm_defconfig @@ -8,8 +8,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_REMOTEPROC=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/k2hk_evm_defconfig b/configs/k2hk_evm_defconfig index a5bd073..4864d09 100644 --- a/configs/k2hk_evm_defconfig +++ b/configs/k2hk_evm_defconfig @@ -10,7 +10,13 @@ CONFIG_SYS_PROMPT="K2HK EVM # " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_NAND=y +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_TI_AEMIF=y diff --git a/configs/k2l_evm_defconfig b/configs/k2l_evm_defconfig index 3437dc4..7e60dff 100644 --- a/configs/k2l_evm_defconfig +++ b/configs/k2l_evm_defconfig @@ -10,7 +10,13 @@ CONFIG_SYS_PROMPT="K2L EVM # " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_NAND=y +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_TI_AEMIF=y diff --git a/configs/katmai_defconfig b/configs/katmai_defconfig index 08a8fd0..db79d95 100644 --- a/configs/katmai_defconfig +++ b/configs/katmai_defconfig @@ -3,5 +3,10 @@ CONFIG_4xx=y CONFIG_TARGET_KATMAI=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/kc1_defconfig b/configs/kc1_defconfig index 7bf5858..13e8412 100644 --- a/configs/kc1_defconfig +++ b/configs/kc1_defconfig @@ -6,10 +6,13 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="kc1 # " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_GADGET=y diff --git a/configs/kilauea_defconfig b/configs/kilauea_defconfig index 401fd4f..9048227 100644 --- a/configs/kilauea_defconfig +++ b/configs/kilauea_defconfig @@ -4,5 +4,10 @@ CONFIG_TARGET_KILAUEA=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="KILAUEA" CONFIG_HUSH_PARSER=y +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/km_kirkwood_128m16_defconfig b/configs/km_kirkwood_128m16_defconfig index b58ab6a..4ac1501 100644 --- a/configs/km_kirkwood_128m16_defconfig +++ b/configs/km_kirkwood_128m16_defconfig @@ -3,8 +3,15 @@ CONFIG_KIRKWOOD=y CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_SYS_EXTRA_OPTIONS="KM_KIRKWOOD_128M16" CONFIG_HUSH_PARSER=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" +CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SYS_NS16550=y diff --git a/configs/km_kirkwood_defconfig b/configs/km_kirkwood_defconfig index 9b81c53..a617759 100644 --- a/configs/km_kirkwood_defconfig +++ b/configs/km_kirkwood_defconfig @@ -3,8 +3,15 @@ CONFIG_KIRKWOOD=y CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_SYS_EXTRA_OPTIONS="KM_KIRKWOOD" CONFIG_HUSH_PARSER=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" +CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SYS_NS16550=y diff --git a/configs/km_kirkwood_pci_defconfig b/configs/km_kirkwood_pci_defconfig index 0da9e21..6dda308 100644 --- a/configs/km_kirkwood_pci_defconfig +++ b/configs/km_kirkwood_pci_defconfig @@ -3,8 +3,15 @@ CONFIG_KIRKWOOD=y CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_SYS_EXTRA_OPTIONS="KM_KIRKWOOD_PCI" CONFIG_HUSH_PARSER=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" +CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SYS_NS16550=y diff --git a/configs/kmcoge4_defconfig b/configs/kmcoge4_defconfig index 29eba85..82ea876 100644 --- a/configs/kmcoge4_defconfig +++ b/configs/kmcoge4_defconfig @@ -7,8 +7,15 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="KMCOGE4" CONFIG_HUSH_PARSER=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" +CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/kmcoge5ne_defconfig b/configs/kmcoge5ne_defconfig index f8e7f15..85bee4e 100644 --- a/configs/kmcoge5ne_defconfig +++ b/configs/kmcoge5ne_defconfig @@ -5,5 +5,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="KMCOGE5NE" CONFIG_HUSH_PARSER=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/kmcoge5un_defconfig b/configs/kmcoge5un_defconfig index 05b5259..6edcab6 100644 --- a/configs/kmcoge5un_defconfig +++ b/configs/kmcoge5un_defconfig @@ -3,8 +3,15 @@ CONFIG_KIRKWOOD=y CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_SYS_EXTRA_OPTIONS="KM_COGE5UN" CONFIG_HUSH_PARSER=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" +CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SYS_NS16550=y diff --git a/configs/kmeter1_defconfig b/configs/kmeter1_defconfig index f3c0115..1f9b461 100644 --- a/configs/kmeter1_defconfig +++ b/configs/kmeter1_defconfig @@ -5,5 +5,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="KMETER1" CONFIG_HUSH_PARSER=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/kmlion1_defconfig b/configs/kmlion1_defconfig index e263b85..b589ae8 100644 --- a/configs/kmlion1_defconfig +++ b/configs/kmlion1_defconfig @@ -7,8 +7,15 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="KMLION1" CONFIG_HUSH_PARSER=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" +CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/kmnusa_defconfig b/configs/kmnusa_defconfig index 5b391be..fb52ab0 100644 --- a/configs/kmnusa_defconfig +++ b/configs/kmnusa_defconfig @@ -3,8 +3,15 @@ CONFIG_KIRKWOOD=y CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_SYS_EXTRA_OPTIONS="KM_NUSA" CONFIG_HUSH_PARSER=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" +CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SYS_NS16550=y diff --git a/configs/kmopti2_defconfig b/configs/kmopti2_defconfig index e339b8a..eed0155 100644 --- a/configs/kmopti2_defconfig +++ b/configs/kmopti2_defconfig @@ -5,5 +5,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="KMOPTI2" CONFIG_HUSH_PARSER=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/kmsugp1_defconfig b/configs/kmsugp1_defconfig index 11022f3..4d4cc50 100644 --- a/configs/kmsugp1_defconfig +++ b/configs/kmsugp1_defconfig @@ -3,8 +3,15 @@ CONFIG_KIRKWOOD=y CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_SYS_EXTRA_OPTIONS="KM_SUGP1" CONFIG_HUSH_PARSER=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" +CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SYS_NS16550=y diff --git a/configs/kmsupx5_defconfig b/configs/kmsupx5_defconfig index bac694b..8728c35 100644 --- a/configs/kmsupx5_defconfig +++ b/configs/kmsupx5_defconfig @@ -5,5 +5,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="KMSUPX5" CONFIG_HUSH_PARSER=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/kmsuv31_defconfig b/configs/kmsuv31_defconfig index d8f0d7c..262b004 100644 --- a/configs/kmsuv31_defconfig +++ b/configs/kmsuv31_defconfig @@ -3,8 +3,15 @@ CONFIG_KIRKWOOD=y CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_SYS_EXTRA_OPTIONS="KM_SUV31" CONFIG_HUSH_PARSER=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" +CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SYS_NS16550=y diff --git a/configs/kmtegr1_defconfig b/configs/kmtegr1_defconfig index 7ac4cc3..b311c48 100644 --- a/configs/kmtegr1_defconfig +++ b/configs/kmtegr1_defconfig @@ -5,5 +5,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="KMTEGR1" CONFIG_HUSH_PARSER=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/kmtepr2_defconfig b/configs/kmtepr2_defconfig index 61c943f..e049219 100644 --- a/configs/kmtepr2_defconfig +++ b/configs/kmtepr2_defconfig @@ -5,5 +5,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="KMTEPR2" CONFIG_HUSH_PARSER=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/kmvect1_defconfig b/configs/kmvect1_defconfig index fcf52f9..e24ce97 100644 --- a/configs/kmvect1_defconfig +++ b/configs/kmvect1_defconfig @@ -5,5 +5,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="KMVECT1" CONFIG_HUSH_PARSER=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/koelsch_defconfig b/configs/koelsch_defconfig index 24ea181..2b681fe 100644 --- a/configs/koelsch_defconfig +++ b/configs/koelsch_defconfig @@ -10,11 +10,17 @@ CONFIG_TARGET_KOELSCH=y # CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_LOADB is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_SH_SDHI=y CONFIG_SPI_FLASH=y diff --git a/configs/kylin-rk3036_defconfig b/configs/kylin-rk3036_defconfig index 787c020..3f26874 100644 --- a/configs/kylin-rk3036_defconfig +++ b/configs/kylin-rk3036_defconfig @@ -7,7 +7,13 @@ CONFIG_DEFAULT_DEVICE_TREE="rk3036-sdk" CONFIG_SPL_STACK_R=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_REGMAP=y CONFIG_SYSCON=y CONFIG_CLK=y diff --git a/configs/kzm9g_defconfig b/configs/kzm9g_defconfig index ac7690d..6a16d8c 100644 --- a/configs/kzm9g_defconfig +++ b/configs/kzm9g_defconfig @@ -2,5 +2,8 @@ CONFIG_ARM=y CONFIG_RMOBILE=y CONFIG_TARGET_KZM9G=y CONFIG_SYS_PROMPT="KZM-A9-GT# " +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/lager_defconfig b/configs/lager_defconfig index f042ff7..e3eeabf 100644 --- a/configs/lager_defconfig +++ b/configs/lager_defconfig @@ -10,11 +10,16 @@ CONFIG_TARGET_LAGER=y # CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_LOADB is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_SH_SDHI=y CONFIG_SPI_FLASH=y diff --git a/configs/legoev3_defconfig b/configs/legoev3_defconfig index 97b81ef..89b3f9d 100644 --- a/configs/legoev3_defconfig +++ b/configs/legoev3_defconfig @@ -7,7 +7,11 @@ CONFIG_AUTOBOOT_PROMPT="Autoboot in %d seconds - press 'l' to stop...\n" CONFIG_AUTOBOOT_STOP_STR="l" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SYS_NS16550=y diff --git a/configs/ls1021aqds_ddr4_nor_defconfig b/configs/ls1021aqds_ddr4_nor_defconfig index 68172c9..5976cb2 100644 --- a/configs/ls1021aqds_ddr4_nor_defconfig +++ b/configs/ls1021aqds_ddr4_nor_defconfig @@ -6,7 +6,13 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_NETDEVICES=y diff --git a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig index 224fd8b..5ba935b 100644 --- a/configs/ls1021aqds_ddr4_nor_lpuart_defconfig +++ b/configs/ls1021aqds_ddr4_nor_lpuart_defconfig @@ -6,7 +6,13 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,LPUART" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_NETDEVICES=y diff --git a/configs/ls1021aqds_nand_defconfig b/configs/ls1021aqds_nand_defconfig index 7fa9daa..ac042b5 100644 --- a/configs/ls1021aqds_nand_defconfig +++ b/configs/ls1021aqds_nand_defconfig @@ -5,7 +5,13 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,NAND_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig index cfc31a6..5610e06 100644 --- a/configs/ls1021aqds_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021aqds_nor_SECURE_BOOT_defconfig @@ -5,7 +5,13 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_NETDEVICES=y CONFIG_E1000=y diff --git a/configs/ls1021aqds_nor_defconfig b/configs/ls1021aqds_nor_defconfig index 300ec9c..6947d3f 100644 --- a/configs/ls1021aqds_nor_defconfig +++ b/configs/ls1021aqds_nor_defconfig @@ -5,7 +5,13 @@ CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_NETDEVICES=y diff --git a/configs/ls1021aqds_nor_lpuart_defconfig b/configs/ls1021aqds_nor_lpuart_defconfig index 3b9243a..ab4fc54 100644 --- a/configs/ls1021aqds_nor_lpuart_defconfig +++ b/configs/ls1021aqds_nor_lpuart_defconfig @@ -6,7 +6,13 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="LPUART" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_NETDEVICES=y diff --git a/configs/ls1021aqds_qspi_defconfig b/configs/ls1021aqds_qspi_defconfig index 208a1bc..924d323 100644 --- a/configs/ls1021aqds_qspi_defconfig +++ b/configs/ls1021aqds_qspi_defconfig @@ -7,7 +7,14 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="QSPI_BOOT" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1021aqds_sdcard_ifc_defconfig b/configs/ls1021aqds_sdcard_ifc_defconfig index 9d196e1..667bedc 100644 --- a/configs/ls1021aqds_sdcard_ifc_defconfig +++ b/configs/ls1021aqds_sdcard_ifc_defconfig @@ -4,7 +4,13 @@ CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_NETDEVICES=y diff --git a/configs/ls1021aqds_sdcard_qspi_defconfig b/configs/ls1021aqds_sdcard_qspi_defconfig index 382cd11..a50fe68 100644 --- a/configs/ls1021aqds_sdcard_qspi_defconfig +++ b/configs/ls1021aqds_sdcard_qspi_defconfig @@ -5,7 +5,15 @@ CONFIG_DEFAULT_DEVICE_TREE="ls1021a-qds-duart" CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT,SD_BOOT_QSPI" CONFIG_HUSH_PARSER=y +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig index f81e12b..2ee3b91 100644 --- a/configs/ls1021atwr_nor_SECURE_BOOT_defconfig +++ b/configs/ls1021atwr_nor_SECURE_BOOT_defconfig @@ -5,7 +5,13 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_NETDEVICES=y CONFIG_E1000=y diff --git a/configs/ls1021atwr_nor_defconfig b/configs/ls1021atwr_nor_defconfig index c4b1cba..a1bfbc1 100644 --- a/configs/ls1021atwr_nor_defconfig +++ b/configs/ls1021atwr_nor_defconfig @@ -5,7 +5,13 @@ CONFIG_DEFAULT_DEVICE_TREE="ls1021a-twr-duart" CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_NETDEVICES=y diff --git a/configs/ls1021atwr_nor_lpuart_defconfig b/configs/ls1021atwr_nor_lpuart_defconfig index ebf2466..34a8569 100644 --- a/configs/ls1021atwr_nor_lpuart_defconfig +++ b/configs/ls1021atwr_nor_lpuart_defconfig @@ -6,7 +6,13 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="LPUART" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_NETDEVICES=y diff --git a/configs/ls1021atwr_qspi_defconfig b/configs/ls1021atwr_qspi_defconfig index 67917b2..571550b 100644 --- a/configs/ls1021atwr_qspi_defconfig +++ b/configs/ls1021atwr_qspi_defconfig @@ -7,7 +7,14 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="QSPI_BOOT" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1021atwr_sdcard_ifc_defconfig b/configs/ls1021atwr_sdcard_ifc_defconfig index 6f8666c..2f76715 100644 --- a/configs/ls1021atwr_sdcard_ifc_defconfig +++ b/configs/ls1021atwr_sdcard_ifc_defconfig @@ -5,6 +5,12 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/ls1021atwr_sdcard_qspi_defconfig b/configs/ls1021atwr_sdcard_qspi_defconfig index 4253f8c..9c4e2da 100644 --- a/configs/ls1021atwr_sdcard_qspi_defconfig +++ b/configs/ls1021atwr_sdcard_qspi_defconfig @@ -7,6 +7,14 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT,SD_BOOT_QSPI" CONFIG_HUSH_PARSER=y +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1043aqds_defconfig b/configs/ls1043aqds_defconfig index a97654c..da0577b 100644 --- a/configs/ls1043aqds_defconfig +++ b/configs/ls1043aqds_defconfig @@ -7,6 +7,13 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1043aqds_lpuart_defconfig b/configs/ls1043aqds_lpuart_defconfig index c85039b..e65e07f 100644 --- a/configs/ls1043aqds_lpuart_defconfig +++ b/configs/ls1043aqds_lpuart_defconfig @@ -8,6 +8,13 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,LPUART" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1043aqds_nand_defconfig b/configs/ls1043aqds_nand_defconfig index 41e5104..441eb2c 100644 --- a/configs/ls1043aqds_nand_defconfig +++ b/configs/ls1043aqds_nand_defconfig @@ -8,6 +8,13 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,RAMBOOT_PBL,SPL_FSL_PBL,NAND_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1043aqds_nor_ddr3_defconfig b/configs/ls1043aqds_nor_ddr3_defconfig index 1ad2801..4b8c4f4 100644 --- a/configs/ls1043aqds_nor_ddr3_defconfig +++ b/configs/ls1043aqds_nor_ddr3_defconfig @@ -6,6 +6,13 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1043aqds_qspi_defconfig b/configs/ls1043aqds_qspi_defconfig index f339096..8c72836 100644 --- a/configs/ls1043aqds_qspi_defconfig +++ b/configs/ls1043aqds_qspi_defconfig @@ -7,6 +7,14 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,QSPI_BOOT" CONFIG_HUSH_PARSER=y +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1043aqds_sdcard_ifc_defconfig b/configs/ls1043aqds_sdcard_ifc_defconfig index 2823524..86f6ac2 100644 --- a/configs/ls1043aqds_sdcard_ifc_defconfig +++ b/configs/ls1043aqds_sdcard_ifc_defconfig @@ -8,6 +8,13 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1043aqds_sdcard_qspi_defconfig b/configs/ls1043aqds_sdcard_qspi_defconfig index fbb3611..84b75f5 100644 --- a/configs/ls1043aqds_sdcard_qspi_defconfig +++ b/configs/ls1043aqds_sdcard_qspi_defconfig @@ -8,6 +8,14 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4,RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT,SD_BOOT_QSPI" CONFIG_HUSH_PARSER=y +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MEMINFO=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1043ardb_SECURE_BOOT_defconfig b/configs/ls1043ardb_SECURE_BOOT_defconfig index 86f3f1a..3c6bcfe 100644 --- a/configs/ls1043ardb_SECURE_BOOT_defconfig +++ b/configs/ls1043ardb_SECURE_BOOT_defconfig @@ -7,6 +7,11 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4, SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1043ardb_defconfig b/configs/ls1043ardb_defconfig index 5423853..b74adfb 100644 --- a/configs/ls1043ardb_defconfig +++ b/configs/ls1043ardb_defconfig @@ -7,6 +7,11 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1043ardb_nand_defconfig b/configs/ls1043ardb_nand_defconfig index 7209d8d..8076ffa 100644 --- a/configs/ls1043ardb_nand_defconfig +++ b/configs/ls1043ardb_nand_defconfig @@ -8,6 +8,11 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,NAND_BOOT,SYS_FSL_DDR4" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls1043ardb_sdcard_defconfig b/configs/ls1043ardb_sdcard_defconfig index 1e27b7f..4133fc3 100644 --- a/configs/ls1043ardb_sdcard_defconfig +++ b/configs/ls1043ardb_sdcard_defconfig @@ -8,6 +8,11 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="RAMBOOT_PBL,SPL_FSL_PBL,SD_BOOT,SYS_FSL_DDR4" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_SPI_FLASH=y diff --git a/configs/ls2080a_emu_defconfig b/configs/ls2080a_emu_defconfig index 679fb87..1e56c08 100644 --- a/configs/ls2080a_emu_defconfig +++ b/configs/ls2080a_emu_defconfig @@ -12,10 +12,13 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_EDITENV is not set # CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/ls2080a_simu_defconfig b/configs/ls2080a_simu_defconfig index a4055ab..c3429a0 100644 --- a/configs/ls2080a_simu_defconfig +++ b/configs/ls2080a_simu_defconfig @@ -12,10 +12,13 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_EDITENV is not set # CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SYS_NS16550=y diff --git a/configs/ls2080aqds_SECURE_BOOT_defconfig b/configs/ls2080aqds_SECURE_BOOT_defconfig index 961262e..f3f2467 100644 --- a/configs/ls2080aqds_SECURE_BOOT_defconfig +++ b/configs/ls2080aqds_SECURE_BOOT_defconfig @@ -10,7 +10,12 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4, LS2080A, SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y diff --git a/configs/ls2080aqds_defconfig b/configs/ls2080aqds_defconfig index 9cc9784..05e33d1 100644 --- a/configs/ls2080aqds_defconfig +++ b/configs/ls2080aqds_defconfig @@ -10,7 +10,12 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4, LS2080A" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y diff --git a/configs/ls2080aqds_nand_defconfig b/configs/ls2080aqds_nand_defconfig index 15e4850..ac30219 100644 --- a/configs/ls2080aqds_nand_defconfig +++ b/configs/ls2080aqds_nand_defconfig @@ -7,7 +7,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4, NAND, LS2080A" CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NETDEVICES=y CONFIG_E1000=y diff --git a/configs/ls2080ardb_SECURE_BOOT_defconfig b/configs/ls2080ardb_SECURE_BOOT_defconfig index d95774e..13d09d0 100644 --- a/configs/ls2080ardb_SECURE_BOOT_defconfig +++ b/configs/ls2080ardb_SECURE_BOOT_defconfig @@ -10,7 +10,12 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4, LS2080A, SECURE_BOOT" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y diff --git a/configs/ls2080ardb_defconfig b/configs/ls2080ardb_defconfig index 860e93c..b2e3464 100644 --- a/configs/ls2080ardb_defconfig +++ b/configs/ls2080ardb_defconfig @@ -10,7 +10,12 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4, LS2080A" CONFIG_HUSH_PARSER=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y diff --git a/configs/ls2080ardb_nand_defconfig b/configs/ls2080ardb_nand_defconfig index 67481cb..f27bf6b 100644 --- a/configs/ls2080ardb_nand_defconfig +++ b/configs/ls2080ardb_nand_defconfig @@ -7,7 +7,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SYS_FSL_DDR4, NAND, LS2080A" CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_NETDEVICES=y CONFIG_E1000=y diff --git a/configs/lschlv2_defconfig b/configs/lschlv2_defconfig index 9db98bb..da8f1a1 100644 --- a/configs/lschlv2_defconfig +++ b/configs/lschlv2_defconfig @@ -5,7 +5,12 @@ CONFIG_SYS_EXTRA_OPTIONS="LSCHLV2" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/lsxhl_defconfig b/configs/lsxhl_defconfig index aa5f841..3068617 100644 --- a/configs/lsxhl_defconfig +++ b/configs/lsxhl_defconfig @@ -5,7 +5,12 @@ CONFIG_SYS_EXTRA_OPTIONS="LSXHL" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/luan_defconfig b/configs/luan_defconfig index f9b7f06..ec443f9 100644 --- a/configs/luan_defconfig +++ b/configs/luan_defconfig @@ -3,5 +3,9 @@ CONFIG_4xx=y CONFIG_TARGET_LUAN=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/lwmon5_defconfig b/configs/lwmon5_defconfig index 98ecb88..9999f45 100644 --- a/configs/lwmon5_defconfig +++ b/configs/lwmon5_defconfig @@ -4,6 +4,11 @@ CONFIG_TARGET_LWMON5=y CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/m28evk_defconfig b/configs/m28evk_defconfig index 55ad865..54829a9 100644 --- a/configs/m28evk_defconfig +++ b/configs/m28evk_defconfig @@ -5,7 +5,13 @@ CONFIG_FIT=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_OF_LIBFDT=y diff --git a/configs/m53evk_defconfig b/configs/m53evk_defconfig index 2f17ddc..1e9450d 100644 --- a/configs/m53evk_defconfig +++ b/configs/m53evk_defconfig @@ -6,4 +6,8 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/denx/m53evk/imximage.cfg" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/ma5d4evk_defconfig b/configs/ma5d4evk_defconfig index f7ad872..adda7fb 100644 --- a/configs/ma5d4evk_defconfig +++ b/configs/ma5d4evk_defconfig @@ -9,7 +9,11 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_USB=y CONFIG_USB_GADGET=y diff --git a/configs/makalu_defconfig b/configs/makalu_defconfig index d0ab4f1..a153e4d 100644 --- a/configs/makalu_defconfig +++ b/configs/makalu_defconfig @@ -3,5 +3,10 @@ CONFIG_4xx=y CONFIG_TARGET_MAKALU=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/malta_defconfig b/configs/malta_defconfig index ee3e9ea..a16f10b 100644 --- a/configs/malta_defconfig +++ b/configs/malta_defconfig @@ -1,10 +1,13 @@ CONFIG_MIPS=y CONFIG_TARGET_MALTA=y CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="malta # " # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/maltael_defconfig b/configs/maltael_defconfig index ca28d92..5289797 100644 --- a/configs/maltael_defconfig +++ b/configs/maltael_defconfig @@ -2,10 +2,13 @@ CONFIG_MIPS=y CONFIG_TARGET_MALTA=y CONFIG_SYS_LITTLE_ENDIAN=y CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="maltael # " # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/marsboard_defconfig b/configs/marsboard_defconfig index a873b61..02bad1e 100644 --- a/configs/marsboard_defconfig +++ b/configs/marsboard_defconfig @@ -5,7 +5,12 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/maxbcm_defconfig b/configs/maxbcm_defconfig index 200c7a0..3319d3f 100644 --- a/configs/maxbcm_defconfig +++ b/configs/maxbcm_defconfig @@ -6,7 +6,14 @@ CONFIG_DEFAULT_DEVICE_TREE="armada-xp-maxbcm" CONFIG_SPL=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y diff --git a/configs/mcx_defconfig b/configs/mcx_defconfig index 5a9247a..67bc80c 100644 --- a/configs/mcx_defconfig +++ b/configs/mcx_defconfig @@ -8,9 +8,13 @@ CONFIG_SYS_PROMPT="mcx # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_ULPI_VIEWPORT_OMAP=y diff --git a/configs/mecp5123_defconfig b/configs/mecp5123_defconfig index 15f45df..c2e45de 100644 --- a/configs/mecp5123_defconfig +++ b/configs/mecp5123_defconfig @@ -3,5 +3,8 @@ CONFIG_MPC512X=y CONFIG_TARGET_MECP5123=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/medcom-wide_defconfig b/configs/medcom-wide_defconfig index 4d9161e..e5fb0cc 100644 --- a/configs/medcom-wide_defconfig +++ b/configs/medcom-wide_defconfig @@ -11,10 +11,13 @@ CONFIG_SYS_PROMPT="Tegra20 (Medcom-Wide) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y CONFIG_PWM_TEGRA=y diff --git a/configs/meesc_dataflash_defconfig b/configs/meesc_dataflash_defconfig index 64108a7..2c2df2e 100644 --- a/configs/meesc_dataflash_defconfig +++ b/configs/meesc_dataflash_defconfig @@ -9,4 +9,6 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/meesc_defconfig b/configs/meesc_defconfig index 3024f52..a0bf894 100644 --- a/configs/meesc_defconfig +++ b/configs/meesc_defconfig @@ -9,4 +9,6 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/mgcoge3ne_defconfig b/configs/mgcoge3ne_defconfig index b7b2fdb..5dd0856 100644 --- a/configs/mgcoge3ne_defconfig +++ b/configs/mgcoge3ne_defconfig @@ -5,4 +5,10 @@ CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="MGCOGE3NE" CONFIG_HUSH_PARSER=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/mgcoge3un_defconfig b/configs/mgcoge3un_defconfig index 5143214..f1735c0 100644 --- a/configs/mgcoge3un_defconfig +++ b/configs/mgcoge3un_defconfig @@ -3,8 +3,15 @@ CONFIG_KIRKWOOD=y CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_SYS_EXTRA_OPTIONS="KM_MGCOGE3UN" CONFIG_HUSH_PARSER=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" +CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SYS_NS16550=y diff --git a/configs/mgcoge_defconfig b/configs/mgcoge_defconfig index 9d6adea..86de799 100644 --- a/configs/mgcoge_defconfig +++ b/configs/mgcoge_defconfig @@ -5,4 +5,10 @@ CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="MGCOGE" CONFIG_HUSH_PARSER=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/minnowmax_defconfig b/configs/minnowmax_defconfig index 6689104..a46b37a 100644 --- a/configs/minnowmax_defconfig +++ b/configs/minnowmax_defconfig @@ -16,9 +16,15 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_CMD_BOOTSTAGE=y CONFIG_OF_CONTROL=y CONFIG_REGMAP=y diff --git a/configs/mixtile_loftq_defconfig b/configs/mixtile_loftq_defconfig index 89a52a2..74486a1 100644 --- a/configs/mixtile_loftq_defconfig +++ b/configs/mixtile_loftq_defconfig @@ -13,6 +13,8 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_ALDO1_VOLT=3300 CONFIG_USB_EHCI_HCD=y diff --git a/configs/mk802_a10s_defconfig b/configs/mk802_a10s_defconfig index 7bc54d6..e1dc927 100644 --- a/configs/mk802_a10s_defconfig +++ b/configs/mk802_a10s_defconfig @@ -10,6 +10,9 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_AXP152_POWER=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/mk802_defconfig b/configs/mk802_defconfig index 98a73c2..35f0bfa 100644 --- a/configs/mk802_defconfig +++ b/configs/mk802_defconfig @@ -9,6 +9,9 @@ CONFIG_SYS_EXTRA_OPTIONS="USB_EHCI" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SUNXI_NO_PMIC=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/mk802ii_defconfig b/configs/mk802ii_defconfig index 0786fcf..90addf4 100644 --- a/configs/mk802ii_defconfig +++ b/configs/mk802ii_defconfig @@ -7,5 +7,8 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/motionpro_defconfig b/configs/motionpro_defconfig index 100f898..6e568d4 100644 --- a/configs/motionpro_defconfig +++ b/configs/motionpro_defconfig @@ -6,5 +6,8 @@ CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc><Esc>" to stop\n" CONFIG_AUTOBOOT_STOP_STR="\x1b\x1b" +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/mpc5121ads_defconfig b/configs/mpc5121ads_defconfig index 62bd8e7..73bf67f 100644 --- a/configs/mpc5121ads_defconfig +++ b/configs/mpc5121ads_defconfig @@ -3,5 +3,9 @@ CONFIG_MPC512X=y CONFIG_TARGET_MPC5121ADS=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/mpc5121ads_rev2_defconfig b/configs/mpc5121ads_rev2_defconfig index 5d99cb3..7df336c 100644 --- a/configs/mpc5121ads_rev2_defconfig +++ b/configs/mpc5121ads_rev2_defconfig @@ -4,5 +4,9 @@ CONFIG_TARGET_MPC5121ADS=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="MPC5121ADS_REV2" CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/mpc8308_p1m_defconfig b/configs/mpc8308_p1m_defconfig index 21a3b20..29d7d61 100644 --- a/configs/mpc8308_p1m_defconfig +++ b/configs/mpc8308_p1m_defconfig @@ -4,6 +4,9 @@ CONFIG_TARGET_MPC8308_P1M=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/ms7722se_defconfig b/configs/ms7722se_defconfig index 911f3dc..a9bc3d4 100644 --- a/configs/ms7722se_defconfig +++ b/configs/ms7722se_defconfig @@ -16,5 +16,6 @@ CONFIG_TARGET_MS7722SE=y # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/mt_ventoux_defconfig b/configs/mt_ventoux_defconfig index ea4eb55..a4933f4 100644 --- a/configs/mt_ventoux_defconfig +++ b/configs/mt_ventoux_defconfig @@ -7,8 +7,12 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="mt_ventoux => " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_ULPI_VIEWPORT_OMAP=y diff --git a/configs/munices_defconfig b/configs/munices_defconfig index f490eab..6dd615b 100644 --- a/configs/munices_defconfig +++ b/configs/munices_defconfig @@ -3,4 +3,5 @@ CONFIG_MPC5xxx=y CONFIG_TARGET_MUNICES=y CONFIG_OF_BOARD_SETUP=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx23_olinuxino_defconfig b/configs/mx23_olinuxino_defconfig index 30de97a..59daea6 100644 --- a/configs/mx23_olinuxino_defconfig +++ b/configs/mx23_olinuxino_defconfig @@ -4,6 +4,8 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx23evk_defconfig b/configs/mx23evk_defconfig index dc14b21..cc7157e 100644 --- a/configs/mx23evk_defconfig +++ b/configs/mx23evk_defconfig @@ -4,6 +4,7 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set diff --git a/configs/mx25pdk_defconfig b/configs/mx25pdk_defconfig index 10d6385..66bff20 100644 --- a/configs/mx25pdk_defconfig +++ b/configs/mx25pdk_defconfig @@ -4,5 +4,8 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx25pdk/imximage.cfg" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx28evk_auart_console_defconfig b/configs/mx28evk_auart_console_defconfig index 5cc051f..12a4011 100644 --- a/configs/mx28evk_auart_console_defconfig +++ b/configs/mx28evk_auart_console_defconfig @@ -5,7 +5,12 @@ CONFIG_SYS_EXTRA_OPTIONS="MXS_AUART,MXS_AUART_BASE=MXS_UARTAPP3_BASE,ENV_IS_IN_M CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx28evk_defconfig b/configs/mx28evk_defconfig index f93c49a..d425a30 100644 --- a/configs/mx28evk_defconfig +++ b/configs/mx28evk_defconfig @@ -6,7 +6,12 @@ CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_MMC" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx28evk_nand_defconfig b/configs/mx28evk_nand_defconfig index bd6a6e6..e591a37 100644 --- a/configs/mx28evk_nand_defconfig +++ b/configs/mx28evk_nand_defconfig @@ -5,7 +5,12 @@ CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_NAND" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx28evk_spi_defconfig b/configs/mx28evk_spi_defconfig index d91822c..2aa8f1b 100644 --- a/configs/mx28evk_spi_defconfig +++ b/configs/mx28evk_spi_defconfig @@ -5,7 +5,12 @@ CONFIG_SYS_EXTRA_OPTIONS="ENV_IS_IN_SPI_FLASH" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx31ads_defconfig b/configs/mx31ads_defconfig index 20cadde..9ccf069 100644 --- a/configs/mx31ads_defconfig +++ b/configs/mx31ads_defconfig @@ -1,3 +1,6 @@ CONFIG_ARM=y CONFIG_TARGET_MX31ADS=y +CONFIG_CMD_SPI=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y diff --git a/configs/mx31pdk_defconfig b/configs/mx31pdk_defconfig index dd6a7b9..bcb85a1 100644 --- a/configs/mx31pdk_defconfig +++ b/configs/mx31pdk_defconfig @@ -2,4 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_MX31PDK=y CONFIG_SPL=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SPI=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y diff --git a/configs/mx35pdk_defconfig b/configs/mx35pdk_defconfig index 2b98931..486e7d9 100644 --- a/configs/mx35pdk_defconfig +++ b/configs/mx35pdk_defconfig @@ -1,5 +1,10 @@ CONFIG_ARM=y CONFIG_TARGET_MX35PDK=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx51evk_defconfig b/configs/mx51evk_defconfig index 4dd2f78..b9b8d24 100644 --- a/configs/mx51evk_defconfig +++ b/configs/mx51evk_defconfig @@ -3,5 +3,9 @@ CONFIG_TARGET_MX51EVK=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx51evk/imximage.cfg" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx53ard_defconfig b/configs/mx53ard_defconfig index 1580003..b4d821e 100644 --- a/configs/mx53ard_defconfig +++ b/configs/mx53ard_defconfig @@ -3,4 +3,7 @@ CONFIG_TARGET_MX53ARD=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx53ard/imximage_dd3.cfg" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx53evk_defconfig b/configs/mx53evk_defconfig index e9f8f9a..9dec972 100644 --- a/configs/mx53evk_defconfig +++ b/configs/mx53evk_defconfig @@ -3,5 +3,8 @@ CONFIG_TARGET_MX53EVK=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx53evk/imximage.cfg" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx53loco_defconfig b/configs/mx53loco_defconfig index a572231..2e34ccb 100644 --- a/configs/mx53loco_defconfig +++ b/configs/mx53loco_defconfig @@ -3,5 +3,8 @@ CONFIG_TARGET_MX53LOCO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx53loco/imximage.cfg" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx53smd_defconfig b/configs/mx53smd_defconfig index 1285d13..3d85014 100644 --- a/configs/mx53smd_defconfig +++ b/configs/mx53smd_defconfig @@ -3,5 +3,8 @@ CONFIG_TARGET_MX53SMD=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx53smd/imximage.cfg" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6cuboxi_defconfig b/configs/mx6cuboxi_defconfig index 4dfd4e1..40ad38f 100644 --- a/configs/mx6cuboxi_defconfig +++ b/configs/mx6cuboxi_defconfig @@ -6,7 +6,10 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6QDL" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_DM_THERMAL=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6dlarm2_defconfig b/configs/mx6dlarm2_defconfig index 20873c7..a7554b7 100644 --- a/configs/mx6dlarm2_defconfig +++ b/configs/mx6dlarm2_defconfig @@ -5,6 +5,9 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qarm2/imximage_mx6dl.cfg CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6dlarm2_lpddr2_defconfig b/configs/mx6dlarm2_lpddr2_defconfig index 5fdc267..af2c985 100644 --- a/configs/mx6dlarm2_lpddr2_defconfig +++ b/configs/mx6dlarm2_lpddr2_defconfig @@ -5,6 +5,9 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qarm2/imximage_mx6dl.cfg CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6dlsabreauto_defconfig b/configs/mx6dlsabreauto_defconfig index eb30b16..12157ba 100644 --- a/configs/mx6dlsabreauto_defconfig +++ b/configs/mx6dlsabreauto_defconfig @@ -5,7 +5,12 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qsabreauto/mx6dl.cfg,MX6 CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_USB=y diff --git a/configs/mx6dlsabresd_defconfig b/configs/mx6dlsabresd_defconfig index 44db02f..01c8122 100644 --- a/configs/mx6dlsabresd_defconfig +++ b/configs/mx6dlsabresd_defconfig @@ -5,7 +5,12 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6sabresd/mx6dlsabresd.cfg CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_USB=y diff --git a/configs/mx6qarm2_defconfig b/configs/mx6qarm2_defconfig index 4684a3f..ff4af17 100644 --- a/configs/mx6qarm2_defconfig +++ b/configs/mx6qarm2_defconfig @@ -5,6 +5,9 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qarm2/imximage.cfg,MX6Q, CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6qarm2_lpddr2_defconfig b/configs/mx6qarm2_lpddr2_defconfig index 1d0d109..5e02437 100644 --- a/configs/mx6qarm2_lpddr2_defconfig +++ b/configs/mx6qarm2_lpddr2_defconfig @@ -5,6 +5,9 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qarm2/imximage.cfg,MX6Q, CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6qpsabreauto_defconfig b/configs/mx6qpsabreauto_defconfig index 25f81fc..ee56d4e 100644 --- a/configs/mx6qpsabreauto_defconfig +++ b/configs/mx6qpsabreauto_defconfig @@ -3,7 +3,13 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_MX6QSABREAUTO=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qsabreauto/mx6qp.cfg,MX6Q" CONFIG_HUSH_PARSER=y +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_USB=y diff --git a/configs/mx6qsabreauto_defconfig b/configs/mx6qsabreauto_defconfig index 40f9012..0e24307 100644 --- a/configs/mx6qsabreauto_defconfig +++ b/configs/mx6qsabreauto_defconfig @@ -5,7 +5,12 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6qsabreauto/imximage.cfg, CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_USB=y diff --git a/configs/mx6qsabrelite_defconfig b/configs/mx6qsabrelite_defconfig index 6ad6fd8..a19556d 100644 --- a/configs/mx6qsabrelite_defconfig +++ b/configs/mx6qsabrelite_defconfig @@ -4,8 +4,15 @@ CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024,SABRELITE" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/mx6qsabresd_defconfig b/configs/mx6qsabresd_defconfig index 595f8d8..1b69092 100644 --- a/configs/mx6qsabresd_defconfig +++ b/configs/mx6qsabresd_defconfig @@ -5,7 +5,12 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6sabresd/mx6q_4x_mt41j128 CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_USB=y diff --git a/configs/mx6sabresd_spl_defconfig b/configs/mx6sabresd_spl_defconfig index 0ecc91f..7be6374 100644 --- a/configs/mx6sabresd_spl_defconfig +++ b/configs/mx6sabresd_spl_defconfig @@ -6,7 +6,12 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,SPL,MX6Q" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_USB=y diff --git a/configs/mx6slevk_defconfig b/configs/mx6slevk_defconfig index 38cd927..47cf613 100644 --- a/configs/mx6slevk_defconfig +++ b/configs/mx6slevk_defconfig @@ -5,8 +5,13 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6slevk/imximage.cfg,MX6SL CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/mx6slevk_spinor_defconfig b/configs/mx6slevk_spinor_defconfig index 73d9e46..b5de314 100644 --- a/configs/mx6slevk_spinor_defconfig +++ b/configs/mx6slevk_spinor_defconfig @@ -5,8 +5,13 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6slevk/imximage.cfg,MX6SL CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/mx6slevk_spl_defconfig b/configs/mx6slevk_spl_defconfig index 995f8d1..b3f5c93 100644 --- a/configs/mx6slevk_spl_defconfig +++ b/configs/mx6slevk_spl_defconfig @@ -4,7 +4,13 @@ CONFIG_TARGET_MX6SLEVK=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,SPL,MX6SL" CONFIG_HUSH_PARSER=y +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/mx6sxsabreauto_defconfig b/configs/mx6sxsabreauto_defconfig index f194432..17ad20e 100644 --- a/configs/mx6sxsabreauto_defconfig +++ b/configs/mx6sxsabreauto_defconfig @@ -5,8 +5,14 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6sxsabreauto/imximage.cfg CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/mx6sxsabresd_defconfig b/configs/mx6sxsabresd_defconfig index bf4d972..954201b 100644 --- a/configs/mx6sxsabresd_defconfig +++ b/configs/mx6sxsabresd_defconfig @@ -5,8 +5,13 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6sxsabresd/imximage.cfg" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6sxsabresd_spl_defconfig b/configs/mx6sxsabresd_spl_defconfig index 4822d25..8d3cae3 100644 --- a/configs/mx6sxsabresd_spl_defconfig +++ b/configs/mx6sxsabresd_spl_defconfig @@ -6,7 +6,12 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_SPI_FLASH=y CONFIG_OF_LIBFDT=y diff --git a/configs/mx6ul_14x14_evk_defconfig b/configs/mx6ul_14x14_evk_defconfig index 660b815..a241e88 100644 --- a/configs/mx6ul_14x14_evk_defconfig +++ b/configs/mx6ul_14x14_evk_defconfig @@ -4,6 +4,11 @@ CONFIG_TARGET_MX6UL_14X14_EVK=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg" CONFIG_HUSH_PARSER=y +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y diff --git a/configs/mx6ul_9x9_evk_defconfig b/configs/mx6ul_9x9_evk_defconfig index b062757..88ef332 100644 --- a/configs/mx6ul_9x9_evk_defconfig +++ b/configs/mx6ul_9x9_evk_defconfig @@ -4,6 +4,11 @@ CONFIG_TARGET_MX6UL_9X9_EVK=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg" CONFIG_HUSH_PARSER=y +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y diff --git a/configs/mx7dsabresd_defconfig b/configs/mx7dsabresd_defconfig index c8894e9..05da67b 100644 --- a/configs/mx7dsabresd_defconfig +++ b/configs/mx7dsabresd_defconfig @@ -9,6 +9,11 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_DHCP=y diff --git a/configs/nas220_defconfig b/configs/nas220_defconfig index 34c3b74..0d5a683 100644 --- a/configs/nas220_defconfig +++ b/configs/nas220_defconfig @@ -5,6 +5,9 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="nas220> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/neo_defconfig b/configs/neo_defconfig index 0a6d2eb..cdfb432 100644 --- a/configs/neo_defconfig +++ b/configs/neo_defconfig @@ -6,6 +6,8 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_ELF is not set +CONFIG_LOOPW=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/net2big_v2_defconfig b/configs/net2big_v2_defconfig index 07bc0d4..d35458f 100644 --- a/configs/net2big_v2_defconfig +++ b/configs/net2big_v2_defconfig @@ -3,9 +3,15 @@ CONFIG_KIRKWOOD=y CONFIG_TARGET_NET2BIG_V2=y CONFIG_SYS_EXTRA_OPTIONS="NET2BIG_V2" CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="2big2> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/netspace_lite_v2_defconfig b/configs/netspace_lite_v2_defconfig index b9ebf04..9090518 100644 --- a/configs/netspace_lite_v2_defconfig +++ b/configs/netspace_lite_v2_defconfig @@ -3,9 +3,15 @@ CONFIG_KIRKWOOD=y CONFIG_TARGET_NETSPACE_V2=y CONFIG_SYS_EXTRA_OPTIONS="NETSPACE_LITE_V2" CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="ns2> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/netspace_max_v2_defconfig b/configs/netspace_max_v2_defconfig index f642175..6cb311e 100644 --- a/configs/netspace_max_v2_defconfig +++ b/configs/netspace_max_v2_defconfig @@ -3,9 +3,15 @@ CONFIG_KIRKWOOD=y CONFIG_TARGET_NETSPACE_V2=y CONFIG_SYS_EXTRA_OPTIONS="NETSPACE_MAX_V2" CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="ns2> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/netspace_mini_v2_defconfig b/configs/netspace_mini_v2_defconfig index acb1aa2..90af1c7 100644 --- a/configs/netspace_mini_v2_defconfig +++ b/configs/netspace_mini_v2_defconfig @@ -3,9 +3,14 @@ CONFIG_KIRKWOOD=y CONFIG_TARGET_NETSPACE_V2=y CONFIG_SYS_EXTRA_OPTIONS="NETSPACE_MINI_V2" CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="ns2> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/netspace_v2_defconfig b/configs/netspace_v2_defconfig index 37c150a..1de1308 100644 --- a/configs/netspace_v2_defconfig +++ b/configs/netspace_v2_defconfig @@ -3,9 +3,15 @@ CONFIG_KIRKWOOD=y CONFIG_TARGET_NETSPACE_V2=y CONFIG_SYS_EXTRA_OPTIONS="NETSPACE_V2" CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="ns2> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SYS_NS16550=y diff --git a/configs/nitrogen6dl2g_defconfig b/configs/nitrogen6dl2g_defconfig index 6471694..af8c8bb 100644 --- a/configs/nitrogen6dl2g_defconfig +++ b/configs/nitrogen6dl2g_defconfig @@ -4,8 +4,15 @@ CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl2g.cfg,MX6DL,DDR_MB=2048" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_USB=y diff --git a/configs/nitrogen6dl_defconfig b/configs/nitrogen6dl_defconfig index ec15581..1896e44 100644 --- a/configs/nitrogen6dl_defconfig +++ b/configs/nitrogen6dl_defconfig @@ -4,8 +4,15 @@ CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6dl.cfg,MX6DL,DDR_MB=1024" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_USB=y diff --git a/configs/nitrogen6q2g_defconfig b/configs/nitrogen6q2g_defconfig index 69fc732..8de9ea0 100644 --- a/configs/nitrogen6q2g_defconfig +++ b/configs/nitrogen6q2g_defconfig @@ -4,8 +4,15 @@ CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q2g.cfg,MX6Q,DDR_MB=2048" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_USB=y diff --git a/configs/nitrogen6q_defconfig b/configs/nitrogen6q_defconfig index 2b9689b..e08020d 100644 --- a/configs/nitrogen6q_defconfig +++ b/configs/nitrogen6q_defconfig @@ -4,8 +4,15 @@ CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6q.cfg,MX6Q,DDR_MB=1024" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_USB=y diff --git a/configs/nitrogen6s1g_defconfig b/configs/nitrogen6s1g_defconfig index 50aef70..a67e01c 100644 --- a/configs/nitrogen6s1g_defconfig +++ b/configs/nitrogen6s1g_defconfig @@ -4,8 +4,15 @@ CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s1g.cfg,MX6S,DDR_MB=1024" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_USB=y diff --git a/configs/nitrogen6s_defconfig b/configs/nitrogen6s_defconfig index d2f2e0b..f5f5519 100644 --- a/configs/nitrogen6s_defconfig +++ b/configs/nitrogen6s_defconfig @@ -4,8 +4,15 @@ CONFIG_TARGET_NITROGEN6X=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s.cfg,MX6S,DDR_MB=512" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y CONFIG_USB=y diff --git a/configs/nokia_rx51_defconfig b/configs/nokia_rx51_defconfig index f2658cd..60106b3 100644 --- a/configs/nokia_rx51_defconfig +++ b/configs/nokia_rx51_defconfig @@ -8,6 +8,7 @@ CONFIG_AUTOBOOT_KEYED=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_SAVEENV is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/novena_defconfig b/configs/novena_defconfig index cdf841c..90db4ff 100644 --- a/configs/novena_defconfig +++ b/configs/novena_defconfig @@ -7,7 +7,12 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6Q" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_USB=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y diff --git a/configs/nyan-big_defconfig b/configs/nyan-big_defconfig index a14a531..40032df 100644 --- a/configs/nyan-big_defconfig +++ b/configs/nyan-big_defconfig @@ -12,10 +12,16 @@ CONFIG_SYS_PROMPT="Tegra124 (Nyan-big) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_TPM=y diff --git a/configs/odroid-xu3_defconfig b/configs/odroid-xu3_defconfig index 16d3ad1..942e8be 100644 --- a/configs/odroid-xu3_defconfig +++ b/configs/odroid-xu3_defconfig @@ -9,8 +9,13 @@ CONFIG_FIT_BEST_MATCH=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="ODROID-XU3 # " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_CMD_PMIC=y CONFIG_ADC=y CONFIG_ADC_EXYNOS=y diff --git a/configs/odroid_defconfig b/configs/odroid_defconfig index 5f3503f..a32fb56 100644 --- a/configs/odroid_defconfig +++ b/configs/odroid_defconfig @@ -10,9 +10,13 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Odroid # " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y diff --git a/configs/omap3_beagle_defconfig b/configs/omap3_beagle_defconfig index ed790f7..e2ffc7b 100644 --- a/configs/omap3_beagle_defconfig +++ b/configs/omap3_beagle_defconfig @@ -6,7 +6,12 @@ CONFIG_SYS_EXTRA_OPTIONS="NAND" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_GADGET=y diff --git a/configs/omap3_evm_defconfig b/configs/omap3_evm_defconfig index 9efa8d3..d02b47a 100644 --- a/configs/omap3_evm_defconfig +++ b/configs/omap3_evm_defconfig @@ -7,6 +7,10 @@ CONFIG_SYS_PROMPT="OMAP3_EVM # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y diff --git a/configs/omap3_ha_defconfig b/configs/omap3_ha_defconfig index 9c294c3..e609988 100644 --- a/configs/omap3_ha_defconfig +++ b/configs/omap3_ha_defconfig @@ -7,7 +7,11 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index 8efd71e..6062e5f 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -9,8 +9,12 @@ CONFIG_SYS_PROMPT="OMAP Logic # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_GADGET=y diff --git a/configs/omap3_overo_defconfig b/configs/omap3_overo_defconfig index acb86ee..a1df368 100644 --- a/configs/omap3_overo_defconfig +++ b/configs/omap3_overo_defconfig @@ -7,9 +7,14 @@ CONFIG_SYS_PROMPT="Overo # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/omap3_pandora_defconfig b/configs/omap3_pandora_defconfig index ed80de0..67d4dd7 100644 --- a/configs/omap3_pandora_defconfig +++ b/configs/omap3_pandora_defconfig @@ -6,10 +6,14 @@ CONFIG_SYS_PROMPT="Pandora # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/omap3_zoom1_defconfig b/configs/omap3_zoom1_defconfig index cdb91bc..afb2286 100644 --- a/configs/omap3_zoom1_defconfig +++ b/configs/omap3_zoom1_defconfig @@ -5,8 +5,12 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/omap4_panda_defconfig b/configs/omap4_panda_defconfig index 12a4683..06450c3 100644 --- a/configs/omap4_panda_defconfig +++ b/configs/omap4_panda_defconfig @@ -5,8 +5,13 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/omap4_sdp4430_defconfig b/configs/omap4_sdp4430_defconfig index 1d5dfa2..6ca4baf 100644 --- a/configs/omap4_sdp4430_defconfig +++ b/configs/omap4_sdp4430_defconfig @@ -5,9 +5,13 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/omap5_uevm_defconfig b/configs/omap5_uevm_defconfig index f9c7de3..f242d55 100644 --- a/configs/omap5_uevm_defconfig +++ b/configs/omap5_uevm_defconfig @@ -5,8 +5,13 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_DWC3=y diff --git a/configs/omapl138_lcdk_defconfig b/configs/omapl138_lcdk_defconfig index 40165da..57bef31 100644 --- a/configs/omapl138_lcdk_defconfig +++ b/configs/omapl138_lcdk_defconfig @@ -7,6 +7,8 @@ CONFIG_SYS_PROMPT="U-Boot > " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/openrd_base_defconfig b/configs/openrd_base_defconfig index 26dc87e..79f6eda 100644 --- a/configs/openrd_base_defconfig +++ b/configs/openrd_base_defconfig @@ -4,6 +4,9 @@ CONFIG_TARGET_OPENRD=y CONFIG_SYS_EXTRA_OPTIONS="BOARD_IS_OPENRD_BASE" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/openrd_client_defconfig b/configs/openrd_client_defconfig index 2e0606d..12b9046 100644 --- a/configs/openrd_client_defconfig +++ b/configs/openrd_client_defconfig @@ -4,6 +4,9 @@ CONFIG_TARGET_OPENRD=y CONFIG_SYS_EXTRA_OPTIONS="BOARD_IS_OPENRD_CLIENT" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/openrd_ultimate_defconfig b/configs/openrd_ultimate_defconfig index 451c8ab..b640560 100644 --- a/configs/openrd_ultimate_defconfig +++ b/configs/openrd_ultimate_defconfig @@ -4,6 +4,9 @@ CONFIG_TARGET_OPENRD=y CONFIG_SYS_EXTRA_OPTIONS="BOARD_IS_OPENRD_ULTIMATE" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/openrisc-generic_defconfig b/configs/openrisc-generic_defconfig index 47ed8df..d8a3b4c 100644 --- a/configs/openrisc-generic_defconfig +++ b/configs/openrisc-generic_defconfig @@ -3,4 +3,6 @@ CONFIG_TARGET_OPENRISC_GENERIC=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y diff --git a/configs/orangepi_2_defconfig b/configs/orangepi_2_defconfig index 97333c6..7e0be1e 100644 --- a/configs/orangepi_2_defconfig +++ b/configs/orangepi_2_defconfig @@ -13,6 +13,9 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SY8106A_POWER=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/orangepi_one_defconfig b/configs/orangepi_one_defconfig index 26ef10e..6a36955 100644 --- a/configs/orangepi_one_defconfig +++ b/configs/orangepi_one_defconfig @@ -13,4 +13,6 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/orangepi_pc_defconfig b/configs/orangepi_pc_defconfig index df9d0a2..98bbbc2 100644 --- a/configs/orangepi_pc_defconfig +++ b/configs/orangepi_pc_defconfig @@ -11,6 +11,9 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SY8106A_POWER=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/orangepi_plus_defconfig b/configs/orangepi_plus_defconfig index fa12937..07ed4b5 100644 --- a/configs/orangepi_plus_defconfig +++ b/configs/orangepi_plus_defconfig @@ -15,6 +15,9 @@ CONFIG_SYS_EXTRA_OPTIONS="SATAPWR=SUNXI_GPG(11)" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SY8106A_POWER=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/origen_defconfig b/configs/origen_defconfig index 9b85b0e..666e206 100644 --- a/configs/origen_defconfig +++ b/configs/origen_defconfig @@ -9,6 +9,7 @@ CONFIG_SYS_PROMPT="ORIGEN # " # CONFIG_CMD_XIMG is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_NET is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set # CONFIG_CMD_MISC is not set CONFIG_OF_CONTROL=y diff --git a/configs/ot1200_defconfig b/configs/ot1200_defconfig index 627eae5..b839c76 100644 --- a/configs/ot1200_defconfig +++ b/configs/ot1200_defconfig @@ -5,7 +5,12 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/bachmann/ot1200/mx6q_4x_mt41j128.cfg, CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/ot1200_spl_defconfig b/configs/ot1200_spl_defconfig index 0283ff0..0b0330b 100644 --- a/configs/ot1200_spl_defconfig +++ b/configs/ot1200_spl_defconfig @@ -6,7 +6,12 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6Q" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/p2371-0000_defconfig b/configs/p2371-0000_defconfig index 2683a79..ae3105a 100644 --- a/configs/p2371-0000_defconfig +++ b/configs/p2371-0000_defconfig @@ -9,10 +9,16 @@ CONFIG_SYS_PROMPT="Tegra210 (P2371-0000) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/p2371-2180_defconfig b/configs/p2371-2180_defconfig index 61742c1..6ee99d1 100644 --- a/configs/p2371-2180_defconfig +++ b/configs/p2371-2180_defconfig @@ -9,10 +9,16 @@ CONFIG_SYS_PROMPT="Tegra210 (P2371-2180) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_RTL8169=y diff --git a/configs/p2571_defconfig b/configs/p2571_defconfig index 73a9f4f..b2a76a5 100644 --- a/configs/p2571_defconfig +++ b/configs/p2571_defconfig @@ -9,10 +9,16 @@ CONFIG_SYS_PROMPT="Tegra210 (P2571) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/paz00_defconfig b/configs/paz00_defconfig index 66eb1ee..f807990 100644 --- a/configs/paz00_defconfig +++ b/configs/paz00_defconfig @@ -10,10 +10,13 @@ CONFIG_SYS_PROMPT="Tegra20 (Paz00) MOD # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y CONFIG_PWM_TEGRA=y diff --git a/configs/pb1000_defconfig b/configs/pb1000_defconfig index 131014d..d2f9258 100644 --- a/configs/pb1000_defconfig +++ b/configs/pb1000_defconfig @@ -11,4 +11,6 @@ CONFIG_SYS_PROMPT="Pb1x00 # " # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/pcm030_LOWBOOT_defconfig b/configs/pcm030_LOWBOOT_defconfig index 6b66d4c..cc8f2a8 100644 --- a/configs/pcm030_LOWBOOT_defconfig +++ b/configs/pcm030_LOWBOOT_defconfig @@ -3,5 +3,7 @@ CONFIG_MPC5xxx=y CONFIG_TARGET_PCM030=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SYS_TEXT_BASE=0xFF000000" +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y CONFIG_OF_LIBFDT=y diff --git a/configs/pcm030_defconfig b/configs/pcm030_defconfig index 7ee7658..25482e2 100644 --- a/configs/pcm030_defconfig +++ b/configs/pcm030_defconfig @@ -3,5 +3,7 @@ CONFIG_MPC5xxx=y CONFIG_TARGET_PCM030=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_PROMPT="uboot> " +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y CONFIG_OF_LIBFDT=y diff --git a/configs/pcm051_rev1_defconfig b/configs/pcm051_rev1_defconfig index c97faf0..909a157 100644 --- a/configs/pcm051_rev1_defconfig +++ b/configs/pcm051_rev1_defconfig @@ -5,8 +5,14 @@ CONFIG_SYS_EXTRA_OPTIONS="REV1" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/pcm051_rev3_defconfig b/configs/pcm051_rev3_defconfig index 63ef0bb..d9f5c48 100644 --- a/configs/pcm051_rev3_defconfig +++ b/configs/pcm051_rev3_defconfig @@ -5,8 +5,14 @@ CONFIG_SYS_EXTRA_OPTIONS="REV3" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/pcm052_defconfig b/configs/pcm052_defconfig index c47dc01..7226f56 100644 --- a/configs/pcm052_defconfig +++ b/configs/pcm052_defconfig @@ -5,7 +5,12 @@ CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="pcm052" CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/phytec/pcm052/imximage.cfg,ENV_IS_IN_NAND" CONFIG_HUSH_PARSER=y +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_VYBRID_GPIO=y diff --git a/configs/pdm360ng_defconfig b/configs/pdm360ng_defconfig index c94c499..ad9d9c7 100644 --- a/configs/pdm360ng_defconfig +++ b/configs/pdm360ng_defconfig @@ -5,5 +5,8 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/peach-pi_defconfig b/configs/peach-pi_defconfig index 6132a92..b718650 100644 --- a/configs/peach-pi_defconfig +++ b/configs/peach-pi_defconfig @@ -9,8 +9,15 @@ CONFIG_FIT_BEST_MATCH=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Peach-Pi # " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_TPM=y diff --git a/configs/peach-pit_defconfig b/configs/peach-pit_defconfig index 0427142..68bacc0 100644 --- a/configs/peach-pit_defconfig +++ b/configs/peach-pit_defconfig @@ -9,8 +9,15 @@ CONFIG_FIT_BEST_MATCH=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Peach-Pit # " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_CMD_TPM=y diff --git a/configs/pengwyn_defconfig b/configs/pengwyn_defconfig index 4aead9e..4698b2e 100644 --- a/configs/pengwyn_defconfig +++ b/configs/pengwyn_defconfig @@ -4,8 +4,13 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/pepper_defconfig b/configs/pepper_defconfig index 88a672f..bee3477 100644 --- a/configs/pepper_defconfig +++ b/configs/pepper_defconfig @@ -5,7 +5,11 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="pepper# " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/picosam9g45_defconfig b/configs/picosam9g45_defconfig index 34d21de..e4f8265 100644 --- a/configs/picosam9g45_defconfig +++ b/configs/picosam9g45_defconfig @@ -10,6 +10,9 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/pine64_plus_defconfig b/configs/pine64_plus_defconfig index a778736..a2e0b26 100644 --- a/configs/pine64_plus_defconfig +++ b/configs/pine64_plus_defconfig @@ -10,3 +10,5 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y diff --git a/configs/platinum_picon_defconfig b/configs/platinum_picon_defconfig index e070b79..703f43a 100644 --- a/configs/platinum_picon_defconfig +++ b/configs/platinum_picon_defconfig @@ -7,6 +7,11 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="picon > " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_OF_LIBFDT=y diff --git a/configs/platinum_titanium_defconfig b/configs/platinum_titanium_defconfig index 2218131..1064baf 100644 --- a/configs/platinum_titanium_defconfig +++ b/configs/platinum_titanium_defconfig @@ -7,6 +7,11 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="titanium > " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_OF_LIBFDT=y diff --git a/configs/plutux_defconfig b/configs/plutux_defconfig index 7af9fd4..9c698f8 100644 --- a/configs/plutux_defconfig +++ b/configs/plutux_defconfig @@ -11,10 +11,13 @@ CONFIG_SYS_PROMPT="Tegra20 (Plutux) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_DM_USB=y diff --git a/configs/pm9261_defconfig b/configs/pm9261_defconfig index 83e2573..a73d6ed 100644 --- a/configs/pm9261_defconfig +++ b/configs/pm9261_defconfig @@ -7,5 +7,8 @@ CONFIG_SYS_PROMPT="pm9261> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y diff --git a/configs/pm9263_defconfig b/configs/pm9263_defconfig index 44c78e1..c97ac16 100644 --- a/configs/pm9263_defconfig +++ b/configs/pm9263_defconfig @@ -7,5 +7,8 @@ CONFIG_SYS_PROMPT="u-boot-pm9263> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y diff --git a/configs/pm9g45_defconfig b/configs/pm9g45_defconfig index c43901b..9dcc20c 100644 --- a/configs/pm9g45_defconfig +++ b/configs/pm9g45_defconfig @@ -6,5 +6,8 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y diff --git a/configs/pogo_e02_defconfig b/configs/pogo_e02_defconfig index 53ee15c..11cf100 100644 --- a/configs/pogo_e02_defconfig +++ b/configs/pogo_e02_defconfig @@ -4,6 +4,9 @@ CONFIG_TARGET_POGO_E02=y CONFIG_SYS_PROMPT="PogoE02> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/polaroid_mid2809pxe04_defconfig b/configs/polaroid_mid2809pxe04_defconfig index 2c3c7bb..7a7651e 100644 --- a/configs/polaroid_mid2809pxe04_defconfig +++ b/configs/polaroid_mid2809pxe04_defconfig @@ -21,5 +21,7 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_MUSB_HOST=y diff --git a/configs/porter_defconfig b/configs/porter_defconfig index 5899f73..2edfeaf 100644 --- a/configs/porter_defconfig +++ b/configs/porter_defconfig @@ -10,11 +10,17 @@ CONFIG_TARGET_PORTER=y # CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_LOADB is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_SH_SDHI=y CONFIG_SPI_FLASH=y diff --git a/configs/portl2_defconfig b/configs/portl2_defconfig index 07a5507..c2ad41b 100644 --- a/configs/portl2_defconfig +++ b/configs/portl2_defconfig @@ -3,8 +3,15 @@ CONFIG_KIRKWOOD=y CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_SYS_EXTRA_OPTIONS="KM_PORTL2" CONFIG_HUSH_PARSER=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" +CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SYS_NS16550=y diff --git a/configs/pov_protab2_ips9_defconfig b/configs/pov_protab2_ips9_defconfig index 59b6249..605d589 100644 --- a/configs/pov_protab2_ips9_defconfig +++ b/configs/pov_protab2_ips9_defconfig @@ -17,5 +17,8 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/pr1_defconfig b/configs/pr1_defconfig index c813502..f087b3f 100644 --- a/configs/pr1_defconfig +++ b/configs/pr1_defconfig @@ -3,8 +3,15 @@ CONFIG_TARGET_PR1=y CONFIG_SYS_PROMPT="pr1>" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_DNS=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y diff --git a/configs/pxm2_defconfig b/configs/pxm2_defconfig index cd8996a..df371f7 100644 --- a/configs/pxm2_defconfig +++ b/configs/pxm2_defconfig @@ -9,8 +9,14 @@ CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc><Esc>" to stop\ CONFIG_AUTOBOOT_STOP_STR="\x1b\x1b" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/q8_a13_tablet_defconfig b/configs/q8_a13_tablet_defconfig index c9c4adc..48a37cd 100644 --- a/configs/q8_a13_tablet_defconfig +++ b/configs/q8_a13_tablet_defconfig @@ -19,5 +19,8 @@ CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=2" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_USB_MUSB_HOST=y diff --git a/configs/q8_a23_tablet_800x480_defconfig b/configs/q8_a23_tablet_800x480_defconfig index a107c1b..ded6ffc 100644 --- a/configs/q8_a23_tablet_800x480_defconfig +++ b/configs/q8_a23_tablet_800x480_defconfig @@ -21,5 +21,7 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_MUSB_HOST=y diff --git a/configs/q8_a33_tablet_1024x600_defconfig b/configs/q8_a33_tablet_1024x600_defconfig index 27c2c58..a4eb5c5 100644 --- a/configs/q8_a33_tablet_1024x600_defconfig +++ b/configs/q8_a33_tablet_1024x600_defconfig @@ -21,5 +21,7 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_MUSB_HOST=y diff --git a/configs/q8_a33_tablet_800x480_defconfig b/configs/q8_a33_tablet_800x480_defconfig index 93d1086..dc820ea 100644 --- a/configs/q8_a33_tablet_800x480_defconfig +++ b/configs/q8_a33_tablet_800x480_defconfig @@ -21,5 +21,7 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_MUSB_HOST=y diff --git a/configs/qemu-ppce500_defconfig b/configs/qemu-ppce500_defconfig index 0d2d5f7..e474494 100644 --- a/configs/qemu-ppce500_defconfig +++ b/configs/qemu-ppce500_defconfig @@ -8,6 +8,8 @@ CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_E1000=y CONFIG_SYS_NS16550=y diff --git a/configs/qemu-x86_defconfig b/configs/qemu-x86_defconfig index 12a7403..2e891e2 100644 --- a/configs/qemu-x86_defconfig +++ b/configs/qemu-x86_defconfig @@ -12,8 +12,14 @@ CONFIG_HUSH_PARSER=y CONFIG_CMD_CPU=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_CMD_BOOTSTAGE=y CONFIG_OF_CONTROL=y CONFIG_CPU=y diff --git a/configs/qemu_mips64_defconfig b/configs/qemu_mips64_defconfig index 17efc24..3d9ef12 100644 --- a/configs/qemu_mips64_defconfig +++ b/configs/qemu_mips64_defconfig @@ -2,8 +2,11 @@ CONFIG_MIPS=y CONFIG_TARGET_QEMU_MIPS=y CONFIG_CPU_MIPS64_R1=y CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="qemu-mips64 # " # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_RARP=y +CONFIG_CMD_DHCP=y CONFIG_SYS_NS16550=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/qemu_mips64el_defconfig b/configs/qemu_mips64el_defconfig index a8f1912..9eb93ef 100644 --- a/configs/qemu_mips64el_defconfig +++ b/configs/qemu_mips64el_defconfig @@ -3,8 +3,11 @@ CONFIG_TARGET_QEMU_MIPS=y CONFIG_SYS_LITTLE_ENDIAN=y CONFIG_CPU_MIPS64_R1=y CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="qemu-mips64el # " # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_RARP=y +CONFIG_CMD_DHCP=y CONFIG_SYS_NS16550=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/qemu_mips_defconfig b/configs/qemu_mips_defconfig index 69ce12d..cc440f8 100644 --- a/configs/qemu_mips_defconfig +++ b/configs/qemu_mips_defconfig @@ -1,8 +1,10 @@ CONFIG_MIPS=y CONFIG_TARGET_QEMU_MIPS=y CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="qemu-mips # " # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y CONFIG_SYS_NS16550=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/qemu_mipsel_defconfig b/configs/qemu_mipsel_defconfig index c1edee7..3fa84ab 100644 --- a/configs/qemu_mipsel_defconfig +++ b/configs/qemu_mipsel_defconfig @@ -2,8 +2,10 @@ CONFIG_MIPS=y CONFIG_TARGET_QEMU_MIPS=y CONFIG_SYS_LITTLE_ENDIAN=y CONFIG_HUSH_PARSER=y +CONFIG_SYS_PROMPT="qemu-mipsel # " # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y CONFIG_SYS_NS16550=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/r0p7734_defconfig b/configs/r0p7734_defconfig index d8a15ac..91926d4 100644 --- a/configs/r0p7734_defconfig +++ b/configs/r0p7734_defconfig @@ -11,10 +11,12 @@ CONFIG_TARGET_R0P7734=y # CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/r2dplus_defconfig b/configs/r2dplus_defconfig index cca0156..f4df61a 100644 --- a/configs/r2dplus_defconfig +++ b/configs/r2dplus_defconfig @@ -1,4 +1,5 @@ CONFIG_SH=y CONFIG_TARGET_R2DPLUS=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/r7-tv-dongle_defconfig b/configs/r7-tv-dongle_defconfig index 343e917..a067693 100644 --- a/configs/r7-tv-dongle_defconfig +++ b/configs/r7-tv-dongle_defconfig @@ -9,6 +9,9 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_AXP152_POWER=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/r7780mp_defconfig b/configs/r7780mp_defconfig index 180b9e9..7d8cb38 100644 --- a/configs/r7780mp_defconfig +++ b/configs/r7780mp_defconfig @@ -16,5 +16,6 @@ CONFIG_TARGET_R7780MP=y # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/rainier_defconfig b/configs/rainier_defconfig index 095f7c1..6684bd9 100644 --- a/configs/rainier_defconfig +++ b/configs/rainier_defconfig @@ -4,5 +4,9 @@ CONFIG_TARGET_SEQUOIA=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="RAINIER" CONFIG_HUSH_PARSER=y +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/rainier_ramboot_defconfig b/configs/rainier_ramboot_defconfig index 56eb3f3..0679959 100644 --- a/configs/rainier_ramboot_defconfig +++ b/configs/rainier_ramboot_defconfig @@ -4,5 +4,9 @@ CONFIG_TARGET_SEQUOIA=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="RAINIER,SYS_RAMBOOT,SYS_TEXT_BASE=0x01000000,SYS_LDSCRIPT=board/amcc/sequoia/u-boot-ram.lds" CONFIG_HUSH_PARSER=y +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/rastaban_defconfig b/configs/rastaban_defconfig index a3d2b86..73b3b36 100644 --- a/configs/rastaban_defconfig +++ b/configs/rastaban_defconfig @@ -8,8 +8,14 @@ CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc><Esc>" to stop\ CONFIG_AUTOBOOT_STOP_STR="\x1b\x1b" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/redwood_defconfig b/configs/redwood_defconfig index 0b3610f..afdb0ed 100644 --- a/configs/redwood_defconfig +++ b/configs/redwood_defconfig @@ -3,5 +3,9 @@ CONFIG_4xx=y CONFIG_TARGET_REDWOOD=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/riotboard_defconfig b/configs/riotboard_defconfig index 52fe27f..cbd97d7 100644 --- a/configs/riotboard_defconfig +++ b/configs/riotboard_defconfig @@ -5,7 +5,12 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/boundary/nitrogen6x/nitrogen6s1g.cfg, CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_SST=y diff --git a/configs/rock2_defconfig b/configs/rock2_defconfig index 3abe68f..4bfd7c8 100644 --- a/configs/rock2_defconfig +++ b/configs/rock2_defconfig @@ -9,7 +9,14 @@ CONFIG_SPL_STACK_R=y CONFIG_SPL_STACK_R_MALLOC_SIMPLE_LEN=0x2000 CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_SPL_OF_CONTROL=y diff --git a/configs/rpi_2_defconfig b/configs/rpi_2_defconfig index 7cd1e8a..b8f99aa 100644 --- a/configs/rpi_2_defconfig +++ b/configs/rpi_2_defconfig @@ -6,7 +6,10 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_PHYS_TO_BUS=y CONFIG_OF_LIBFDT=y diff --git a/configs/rpi_3_32b_defconfig b/configs/rpi_3_32b_defconfig index 1f189d4..bf0ca97 100644 --- a/configs/rpi_3_32b_defconfig +++ b/configs/rpi_3_32b_defconfig @@ -6,7 +6,10 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_PHYS_TO_BUS=y CONFIG_OF_LIBFDT=y diff --git a/configs/rpi_3_defconfig b/configs/rpi_3_defconfig index d52f0b1..c823d0e 100644 --- a/configs/rpi_3_defconfig +++ b/configs/rpi_3_defconfig @@ -6,7 +6,10 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_PHYS_TO_BUS=y CONFIG_OF_LIBFDT=y diff --git a/configs/rpi_defconfig b/configs/rpi_defconfig index 59e4e6b..9ddd6bc 100644 --- a/configs/rpi_defconfig +++ b/configs/rpi_defconfig @@ -6,7 +6,10 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_PHYS_TO_BUS=y CONFIG_OF_LIBFDT=y diff --git a/configs/rsk7203_defconfig b/configs/rsk7203_defconfig index 6134172..40adf42 100644 --- a/configs/rsk7203_defconfig +++ b/configs/rsk7203_defconfig @@ -16,5 +16,6 @@ CONFIG_TARGET_RSK7203=y # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/rut_defconfig b/configs/rut_defconfig index 7526426..e2993cb 100644 --- a/configs/rut_defconfig +++ b/configs/rut_defconfig @@ -9,8 +9,14 @@ CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc><Esc>" to stop\ CONFIG_AUTOBOOT_STOP_STR="\x1b\x1b" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/s5pc210_universal_defconfig b/configs/s5pc210_universal_defconfig index bd2675f..f28b928 100644 --- a/configs/s5pc210_universal_defconfig +++ b/configs/s5pc210_universal_defconfig @@ -6,9 +6,12 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Universal # " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_NET is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_OF_CONTROL=y CONFIG_USB=y diff --git a/configs/sama5d2_xplained_mmc_defconfig b/configs/sama5d2_xplained_mmc_defconfig index 9abc136..05efce5 100644 --- a/configs/sama5d2_xplained_mmc_defconfig +++ b/configs/sama5d2_xplained_mmc_defconfig @@ -9,7 +9,10 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_SF=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_USB=y CONFIG_USB_GADGET=y diff --git a/configs/sama5d2_xplained_spiflash_defconfig b/configs/sama5d2_xplained_spiflash_defconfig index f1aff9e..1b6649c 100644 --- a/configs/sama5d2_xplained_spiflash_defconfig +++ b/configs/sama5d2_xplained_spiflash_defconfig @@ -9,7 +9,10 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_SF=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_USB=y CONFIG_USB_GADGET=y diff --git a/configs/sama5d3_xplained_mmc_defconfig b/configs/sama5d3_xplained_mmc_defconfig index a3377a6..7de3247 100644 --- a/configs/sama5d3_xplained_mmc_defconfig +++ b/configs/sama5d3_xplained_mmc_defconfig @@ -8,5 +8,8 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/sama5d3_xplained_nandflash_defconfig b/configs/sama5d3_xplained_nandflash_defconfig index dd32e4b..8c61615 100644 --- a/configs/sama5d3_xplained_nandflash_defconfig +++ b/configs/sama5d3_xplained_nandflash_defconfig @@ -8,5 +8,8 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/sama5d3xek_mmc_defconfig b/configs/sama5d3xek_mmc_defconfig index 1c936c0..9795c0c 100644 --- a/configs/sama5d3xek_mmc_defconfig +++ b/configs/sama5d3xek_mmc_defconfig @@ -6,7 +6,11 @@ CONFIG_SYS_EXTRA_OPTIONS="SAMA5D3,SYS_USE_MMC" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_USB=y diff --git a/configs/sama5d3xek_nandflash_defconfig b/configs/sama5d3xek_nandflash_defconfig index 5f8e4b9..f77145a 100644 --- a/configs/sama5d3xek_nandflash_defconfig +++ b/configs/sama5d3xek_nandflash_defconfig @@ -6,7 +6,11 @@ CONFIG_SYS_EXTRA_OPTIONS="SAMA5D3,SYS_USE_NANDFLASH" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_USB=y diff --git a/configs/sama5d3xek_spiflash_defconfig b/configs/sama5d3xek_spiflash_defconfig index d0a0f05..08773f5 100644 --- a/configs/sama5d3xek_spiflash_defconfig +++ b/configs/sama5d3xek_spiflash_defconfig @@ -6,7 +6,11 @@ CONFIG_SYS_EXTRA_OPTIONS="SAMA5D3,SYS_USE_SERIALFLASH" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_USB=y diff --git a/configs/sama5d4_xplained_mmc_defconfig b/configs/sama5d4_xplained_mmc_defconfig index 73f6a07..3d020b5 100644 --- a/configs/sama5d4_xplained_mmc_defconfig +++ b/configs/sama5d4_xplained_mmc_defconfig @@ -8,7 +8,11 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_USB=y diff --git a/configs/sama5d4_xplained_nandflash_defconfig b/configs/sama5d4_xplained_nandflash_defconfig index 2e74804..f93bbdb 100644 --- a/configs/sama5d4_xplained_nandflash_defconfig +++ b/configs/sama5d4_xplained_nandflash_defconfig @@ -8,7 +8,11 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_USB=y diff --git a/configs/sama5d4_xplained_spiflash_defconfig b/configs/sama5d4_xplained_spiflash_defconfig index 72a3e56..7b231d9 100644 --- a/configs/sama5d4_xplained_spiflash_defconfig +++ b/configs/sama5d4_xplained_spiflash_defconfig @@ -8,7 +8,11 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_USB=y diff --git a/configs/sama5d4ek_mmc_defconfig b/configs/sama5d4ek_mmc_defconfig index 87fa5a3..356aebc 100644 --- a/configs/sama5d4ek_mmc_defconfig +++ b/configs/sama5d4ek_mmc_defconfig @@ -8,7 +8,11 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_USB=y diff --git a/configs/sama5d4ek_nandflash_defconfig b/configs/sama5d4ek_nandflash_defconfig index 749e489..a599251 100644 --- a/configs/sama5d4ek_nandflash_defconfig +++ b/configs/sama5d4ek_nandflash_defconfig @@ -8,7 +8,11 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_USB=y diff --git a/configs/sama5d4ek_spiflash_defconfig b/configs/sama5d4ek_spiflash_defconfig index c3f5931..a328c8c 100644 --- a/configs/sama5d4ek_spiflash_defconfig +++ b/configs/sama5d4ek_spiflash_defconfig @@ -8,7 +8,11 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y CONFIG_USB=y diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 7536c46..cc04361 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -25,10 +25,21 @@ CONFIG_CMD_MEMTEST=y CONFIG_CMD_MX_CYCLIC=y CONFIG_CMD_MEMINFO=y CONFIG_CMD_DEMO=y +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_REMOTEPROC=y CONFIG_CMD_GPIO=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_TFTPSRV=y +CONFIG_CMD_RARP=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_CDP=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_DNS=y +CONFIG_CMD_LINK_LOCAL=y CONFIG_CMD_TIME=y CONFIG_CMD_TIMER=y CONFIG_CMD_SOUND=y diff --git a/configs/sansa_fuze_plus_defconfig b/configs/sansa_fuze_plus_defconfig index 703db9c..73c2762 100644 --- a/configs/sansa_fuze_plus_defconfig +++ b/configs/sansa_fuze_plus_defconfig @@ -3,9 +3,12 @@ CONFIG_TARGET_SANSA_FUZE_PLUS=y CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y CONFIG_USB=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y diff --git a/configs/sbc8349_PCI_33_defconfig b/configs/sbc8349_PCI_33_defconfig index 1189558..b55d644 100644 --- a/configs/sbc8349_PCI_33_defconfig +++ b/configs/sbc8349_PCI_33_defconfig @@ -5,6 +5,8 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PCI,PCI_33M" CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sbc8349_PCI_66_defconfig b/configs/sbc8349_PCI_66_defconfig index fe2300e..3de150d 100644 --- a/configs/sbc8349_PCI_66_defconfig +++ b/configs/sbc8349_PCI_66_defconfig @@ -5,6 +5,8 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PCI,PCI_66M" CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sbc8349_defconfig b/configs/sbc8349_defconfig index 71ce297..f311a2d 100644 --- a/configs/sbc8349_defconfig +++ b/configs/sbc8349_defconfig @@ -4,6 +4,8 @@ CONFIG_TARGET_SBC8349=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sbc8548_PCI_33_PCIE_defconfig b/configs/sbc8548_PCI_33_PCIE_defconfig index 41503f3..649e36e 100644 --- a/configs/sbc8548_PCI_33_PCIE_defconfig +++ b/configs/sbc8548_PCI_33_PCIE_defconfig @@ -5,6 +5,8 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PCI,33,PCIE" CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sbc8548_PCI_33_defconfig b/configs/sbc8548_PCI_33_defconfig index de0e1f3..f0e3982 100644 --- a/configs/sbc8548_PCI_33_defconfig +++ b/configs/sbc8548_PCI_33_defconfig @@ -5,6 +5,8 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PCI,33" CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sbc8548_PCI_66_PCIE_defconfig b/configs/sbc8548_PCI_66_PCIE_defconfig index 1aebb1a..ce6d600 100644 --- a/configs/sbc8548_PCI_66_PCIE_defconfig +++ b/configs/sbc8548_PCI_66_PCIE_defconfig @@ -5,6 +5,8 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PCI,66,PCIE" CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sbc8548_PCI_66_defconfig b/configs/sbc8548_PCI_66_defconfig index 205f90b..5e37927 100644 --- a/configs/sbc8548_PCI_66_defconfig +++ b/configs/sbc8548_PCI_66_defconfig @@ -5,6 +5,8 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="PCI,66" CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sbc8548_defconfig b/configs/sbc8548_defconfig index 5a1e593..fa6e61e 100644 --- a/configs/sbc8548_defconfig +++ b/configs/sbc8548_defconfig @@ -4,6 +4,8 @@ CONFIG_TARGET_SBC8548=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sbc8641d_defconfig b/configs/sbc8641d_defconfig index 8e5237a..ad38457 100644 --- a/configs/sbc8641d_defconfig +++ b/configs/sbc8641d_defconfig @@ -4,6 +4,8 @@ CONFIG_TARGET_SBC8641D=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sc_sps_1_defconfig b/configs/sc_sps_1_defconfig index 1bcd479..097748a 100644 --- a/configs/sc_sps_1_defconfig +++ b/configs/sc_sps_1_defconfig @@ -4,5 +4,8 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/seaboard_defconfig b/configs/seaboard_defconfig index 3613286..5c72a09 100644 --- a/configs/seaboard_defconfig +++ b/configs/seaboard_defconfig @@ -10,10 +10,14 @@ CONFIG_SYS_PROMPT="Tegra20 (SeaBoard) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y CONFIG_PWM_TEGRA=y diff --git a/configs/secomx6quq7_defconfig b/configs/secomx6quq7_defconfig index d19876a..0da341f 100644 --- a/configs/secomx6quq7_defconfig +++ b/configs/secomx6quq7_defconfig @@ -10,4 +10,6 @@ CONFIG_SYS_PROMPT="SECO MX6Q uQ7 U-Boot > " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/sequoia_defconfig b/configs/sequoia_defconfig index 1becb75..ecda85b 100644 --- a/configs/sequoia_defconfig +++ b/configs/sequoia_defconfig @@ -4,5 +4,10 @@ CONFIG_TARGET_SEQUOIA=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SEQUOIA" CONFIG_HUSH_PARSER=y +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sequoia_ramboot_defconfig b/configs/sequoia_ramboot_defconfig index 6b9425c..1c3a0b9 100644 --- a/configs/sequoia_ramboot_defconfig +++ b/configs/sequoia_ramboot_defconfig @@ -4,5 +4,10 @@ CONFIG_TARGET_SEQUOIA=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="SEQUOIA,SYS_RAMBOOT,SYS_TEXT_BASE=0x01000000,SYS_LDSCRIPT=board/amcc/sequoia/u-boot-ram.lds" CONFIG_HUSH_PARSER=y +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sh7752evb_defconfig b/configs/sh7752evb_defconfig index 4c8883b..5a77fe0 100644 --- a/configs/sh7752evb_defconfig +++ b/configs/sh7752evb_defconfig @@ -11,11 +11,13 @@ CONFIG_TARGET_SH7752EVB=y # CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_LOADB is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/sh7753evb_defconfig b/configs/sh7753evb_defconfig index 9992cff..0dd488f 100644 --- a/configs/sh7753evb_defconfig +++ b/configs/sh7753evb_defconfig @@ -10,11 +10,13 @@ CONFIG_TARGET_SH7753EVB=y # CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_LOADB is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/sh7757lcr_defconfig b/configs/sh7757lcr_defconfig index 54d6436..b75fd84 100644 --- a/configs/sh7757lcr_defconfig +++ b/configs/sh7757lcr_defconfig @@ -11,11 +11,13 @@ CONFIG_TARGET_SH7757LCR=y # CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_LOADB is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y diff --git a/configs/sh7763rdp_defconfig b/configs/sh7763rdp_defconfig index ff84516..983f2a2 100644 --- a/configs/sh7763rdp_defconfig +++ b/configs/sh7763rdp_defconfig @@ -16,5 +16,6 @@ CONFIG_TARGET_SH7763RDP=y # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/sh7785lcr_32bit_defconfig b/configs/sh7785lcr_32bit_defconfig index 611ee18..ab2cff7 100644 --- a/configs/sh7785lcr_32bit_defconfig +++ b/configs/sh7785lcr_32bit_defconfig @@ -11,10 +11,12 @@ CONFIG_TARGET_SH7785LCR=y # CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/sh7785lcr_defconfig b/configs/sh7785lcr_defconfig index bc27765..059f5f7 100644 --- a/configs/sh7785lcr_defconfig +++ b/configs/sh7785lcr_defconfig @@ -10,10 +10,12 @@ CONFIG_TARGET_SH7785LCR=y # CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/shmin_defconfig b/configs/shmin_defconfig index 8240aad..1749f13 100644 --- a/configs/shmin_defconfig +++ b/configs/shmin_defconfig @@ -16,5 +16,6 @@ CONFIG_TARGET_SHMIN=y # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/silk_defconfig b/configs/silk_defconfig index 67fca2a..acad1d6 100644 --- a/configs/silk_defconfig +++ b/configs/silk_defconfig @@ -10,11 +10,17 @@ CONFIG_TARGET_SILK=y # CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_LOADB is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_SH_SDHI=y CONFIG_SPI_FLASH=y diff --git a/configs/smartweb_defconfig b/configs/smartweb_defconfig index d6ac40b..e526653 100644 --- a/configs/smartweb_defconfig +++ b/configs/smartweb_defconfig @@ -9,6 +9,13 @@ CONFIG_SYS_PROMPT="U-Boot# " CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc><Esc>" to stop\n" CONFIG_AUTOBOOT_STOP_STR="\x1b\x1b" +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_USB=y +# CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_USB=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y diff --git a/configs/smdk2410_defconfig b/configs/smdk2410_defconfig index 66c2034..39375de 100644 --- a/configs/smdk2410_defconfig +++ b/configs/smdk2410_defconfig @@ -2,4 +2,7 @@ CONFIG_ARM=y CONFIG_TARGET_SMDK2410=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="SMDK2410 # " +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y diff --git a/configs/smdk5250_defconfig b/configs/smdk5250_defconfig index 7a757ee..e46fcae 100644 --- a/configs/smdk5250_defconfig +++ b/configs/smdk5250_defconfig @@ -9,8 +9,15 @@ CONFIG_FIT_BEST_MATCH=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="SMDK5250 # " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_CMD_SOUND=y CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y diff --git a/configs/smdk5420_defconfig b/configs/smdk5420_defconfig index de79ca9..39b329a 100644 --- a/configs/smdk5420_defconfig +++ b/configs/smdk5420_defconfig @@ -9,8 +9,15 @@ CONFIG_FIT_BEST_MATCH=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="SMDK5420 # " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_DM_I2C_COMPAT=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_GIGADEVICE=y diff --git a/configs/smdkv310_defconfig b/configs/smdkv310_defconfig index 5334f89..19662c8 100644 --- a/configs/smdkv310_defconfig +++ b/configs/smdkv310_defconfig @@ -8,7 +8,9 @@ CONFIG_SYS_PROMPT="SMDKV310 # " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_USB=y CONFIG_DM_USB=y diff --git a/configs/snapper9260_defconfig b/configs/snapper9260_defconfig index 33386b4..f45243d 100644 --- a/configs/snapper9260_defconfig +++ b/configs/snapper9260_defconfig @@ -10,7 +10,11 @@ CONFIG_SYS_PROMPT="Snapper> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y diff --git a/configs/snapper9g20_defconfig b/configs/snapper9g20_defconfig index ec88dfb..5458b48 100644 --- a/configs/snapper9g20_defconfig +++ b/configs/snapper9g20_defconfig @@ -9,7 +9,11 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y diff --git a/configs/sniper_defconfig b/configs/sniper_defconfig index 86bae46..444a78a 100644 --- a/configs/sniper_defconfig +++ b/configs/sniper_defconfig @@ -6,10 +6,13 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="sniper # " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_MUSB_GADGET=y diff --git a/configs/snow_defconfig b/configs/snow_defconfig index 0b740e9..3a53d26 100644 --- a/configs/snow_defconfig +++ b/configs/snow_defconfig @@ -9,8 +9,15 @@ CONFIG_FIT_BEST_MATCH=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="snow # " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_CMD_SOUND=y CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y diff --git a/configs/socfpga_arria5_defconfig b/configs/socfpga_arria5_defconfig index d451fea..a64a1e2 100644 --- a/configs/socfpga_arria5_defconfig +++ b/configs/socfpga_arria5_defconfig @@ -12,7 +12,13 @@ CONFIG_FIT=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DWAPB_GPIO=y CONFIG_DM_MMC=y diff --git a/configs/socfpga_cyclone5_defconfig b/configs/socfpga_cyclone5_defconfig index db443c9..caa3999 100644 --- a/configs/socfpga_cyclone5_defconfig +++ b/configs/socfpga_cyclone5_defconfig @@ -12,7 +12,13 @@ CONFIG_FIT=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DWAPB_GPIO=y CONFIG_DM_MMC=y diff --git a/configs/socfpga_de0_nano_soc_defconfig b/configs/socfpga_de0_nano_soc_defconfig index e5ef64b..9a8dbaa 100644 --- a/configs/socfpga_de0_nano_soc_defconfig +++ b/configs/socfpga_de0_nano_soc_defconfig @@ -12,7 +12,13 @@ CONFIG_FIT=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DWAPB_GPIO=y CONFIG_DM_MMC=y CONFIG_DM_ETH=y diff --git a/configs/socfpga_mcvevk_defconfig b/configs/socfpga_mcvevk_defconfig index c7f4ff4..5e3d09c 100644 --- a/configs/socfpga_mcvevk_defconfig +++ b/configs/socfpga_mcvevk_defconfig @@ -12,7 +12,13 @@ CONFIG_FIT=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DWAPB_GPIO=y CONFIG_DM_MMC=y CONFIG_DM_ETH=y diff --git a/configs/socfpga_sockit_defconfig b/configs/socfpga_sockit_defconfig index d932993..823c512 100644 --- a/configs/socfpga_sockit_defconfig +++ b/configs/socfpga_sockit_defconfig @@ -12,7 +12,13 @@ CONFIG_FIT=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DWAPB_GPIO=y CONFIG_DM_MMC=y diff --git a/configs/socfpga_socrates_defconfig b/configs/socfpga_socrates_defconfig index 7764879..ae6c23e 100644 --- a/configs/socfpga_socrates_defconfig +++ b/configs/socfpga_socrates_defconfig @@ -12,7 +12,13 @@ CONFIG_FIT=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DWAPB_GPIO=y CONFIG_DM_MMC=y diff --git a/configs/socfpga_sr1500_defconfig b/configs/socfpga_sr1500_defconfig index 5f19eee..d29027c 100644 --- a/configs/socfpga_sr1500_defconfig +++ b/configs/socfpga_sr1500_defconfig @@ -11,7 +11,15 @@ CONFIG_SPL_STACK_R=y CONFIG_FIT=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_DWAPB_GPIO=y CONFIG_DM_MMC=y diff --git a/configs/socrates_defconfig b/configs/socrates_defconfig index 4d86ad1..fe491b5 100644 --- a/configs/socrates_defconfig +++ b/configs/socrates_defconfig @@ -5,7 +5,12 @@ CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/spear300_defconfig b/configs/spear300_defconfig index 49296bc..7e40037 100644 --- a/configs/spear300_defconfig +++ b/configs/spear300_defconfig @@ -1,6 +1,9 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR300=y CONFIG_SYS_EXTRA_OPTIONS="spear300" +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear300_nand_defconfig b/configs/spear300_nand_defconfig index 560ff26..51e9358 100644 --- a/configs/spear300_nand_defconfig +++ b/configs/spear300_nand_defconfig @@ -1,6 +1,9 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR300=y CONFIG_SYS_EXTRA_OPTIONS="spear300,nand" +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear300_usbtty_defconfig b/configs/spear300_usbtty_defconfig index 3e280d5..5ce8720 100644 --- a/configs/spear300_usbtty_defconfig +++ b/configs/spear300_usbtty_defconfig @@ -1,6 +1,9 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR300=y CONFIG_SYS_EXTRA_OPTIONS="spear300,usbtty" +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear300_usbtty_nand_defconfig b/configs/spear300_usbtty_nand_defconfig index 97a0f2a..1fa6223 100644 --- a/configs/spear300_usbtty_nand_defconfig +++ b/configs/spear300_usbtty_nand_defconfig @@ -1,6 +1,9 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR300=y CONFIG_SYS_EXTRA_OPTIONS="spear300,usbtty,nand" +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear310_defconfig b/configs/spear310_defconfig index d4ce01d..5f8feee 100644 --- a/configs/spear310_defconfig +++ b/configs/spear310_defconfig @@ -1,6 +1,9 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR310=y CONFIG_SYS_EXTRA_OPTIONS="spear310" +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear310_nand_defconfig b/configs/spear310_nand_defconfig index 517e42f..a070f36 100644 --- a/configs/spear310_nand_defconfig +++ b/configs/spear310_nand_defconfig @@ -1,6 +1,9 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR310=y CONFIG_SYS_EXTRA_OPTIONS="spear310,nand" +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear310_pnor_defconfig b/configs/spear310_pnor_defconfig index 2fe149b..5802684 100644 --- a/configs/spear310_pnor_defconfig +++ b/configs/spear310_pnor_defconfig @@ -1,6 +1,9 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR310=y CONFIG_SYS_EXTRA_OPTIONS="spear310,FLASH_PNOR" +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear310_usbtty_defconfig b/configs/spear310_usbtty_defconfig index f8b027d..b39f1e0 100644 --- a/configs/spear310_usbtty_defconfig +++ b/configs/spear310_usbtty_defconfig @@ -1,6 +1,9 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR310=y CONFIG_SYS_EXTRA_OPTIONS="spear310,usbtty" +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear310_usbtty_nand_defconfig b/configs/spear310_usbtty_nand_defconfig index a4d8fdc..8188314 100644 --- a/configs/spear310_usbtty_nand_defconfig +++ b/configs/spear310_usbtty_nand_defconfig @@ -1,6 +1,9 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR310=y CONFIG_SYS_EXTRA_OPTIONS="spear310,usbtty,nand" +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear310_usbtty_pnor_defconfig b/configs/spear310_usbtty_pnor_defconfig index fd1d8c0..581dfb1 100644 --- a/configs/spear310_usbtty_pnor_defconfig +++ b/configs/spear310_usbtty_pnor_defconfig @@ -1,6 +1,9 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR310=y CONFIG_SYS_EXTRA_OPTIONS="spear310,usbtty,FLASH_PNOR" +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear320_defconfig b/configs/spear320_defconfig index e720f38..558bdb8 100644 --- a/configs/spear320_defconfig +++ b/configs/spear320_defconfig @@ -1,6 +1,9 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR320=y CONFIG_SYS_EXTRA_OPTIONS="spear320" +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear320_nand_defconfig b/configs/spear320_nand_defconfig index 24c01c6..d9fcd6a 100644 --- a/configs/spear320_nand_defconfig +++ b/configs/spear320_nand_defconfig @@ -1,6 +1,9 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR320=y CONFIG_SYS_EXTRA_OPTIONS="spear320,nand" +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear320_pnor_defconfig b/configs/spear320_pnor_defconfig index 636bb48..3aff58c 100644 --- a/configs/spear320_pnor_defconfig +++ b/configs/spear320_pnor_defconfig @@ -1,6 +1,9 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR320=y CONFIG_SYS_EXTRA_OPTIONS="spear320,FLASH_PNOR" +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear320_usbtty_defconfig b/configs/spear320_usbtty_defconfig index ca98d58..75855bc 100644 --- a/configs/spear320_usbtty_defconfig +++ b/configs/spear320_usbtty_defconfig @@ -1,6 +1,9 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR320=y CONFIG_SYS_EXTRA_OPTIONS="spear320,usbtty" +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear320_usbtty_nand_defconfig b/configs/spear320_usbtty_nand_defconfig index cdb1f31..f0f46c2 100644 --- a/configs/spear320_usbtty_nand_defconfig +++ b/configs/spear320_usbtty_nand_defconfig @@ -1,6 +1,9 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR320=y CONFIG_SYS_EXTRA_OPTIONS="spear320,usbtty,nand" +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear320_usbtty_pnor_defconfig b/configs/spear320_usbtty_pnor_defconfig index 85f2af6..a4aab03 100644 --- a/configs/spear320_usbtty_pnor_defconfig +++ b/configs/spear320_usbtty_pnor_defconfig @@ -1,6 +1,9 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR320=y CONFIG_SYS_EXTRA_OPTIONS="spear320,usbtty,FLASH_PNOR" +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear600_defconfig b/configs/spear600_defconfig index 95a530b1..fac6a3c 100644 --- a/configs/spear600_defconfig +++ b/configs/spear600_defconfig @@ -4,6 +4,9 @@ CONFIG_SYS_EXTRA_OPTIONS="spear600" CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit SPACE in %d seconds to stop autoboot.\n" CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear600_nand_defconfig b/configs/spear600_nand_defconfig index 019e74a..8f421b7 100644 --- a/configs/spear600_nand_defconfig +++ b/configs/spear600_nand_defconfig @@ -1,6 +1,9 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR600=y CONFIG_SYS_EXTRA_OPTIONS="spear600,nand" +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear600_usbtty_defconfig b/configs/spear600_usbtty_defconfig index 2168013..8b8f28d 100644 --- a/configs/spear600_usbtty_defconfig +++ b/configs/spear600_usbtty_defconfig @@ -1,6 +1,9 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR600=y CONFIG_SYS_EXTRA_OPTIONS="spear600,usbtty" +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spear600_usbtty_nand_defconfig b/configs/spear600_usbtty_nand_defconfig index fc501d9..f0ce802 100644 --- a/configs/spear600_usbtty_nand_defconfig +++ b/configs/spear600_usbtty_nand_defconfig @@ -1,6 +1,9 @@ CONFIG_ARM=y CONFIG_TARGET_SPEAR600=y CONFIG_SYS_EXTRA_OPTIONS="spear600,usbtty,nand" +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/spring_defconfig b/configs/spring_defconfig index 935257e..2af8184 100644 --- a/configs/spring_defconfig +++ b/configs/spring_defconfig @@ -9,8 +9,15 @@ CONFIG_FIT_BEST_MATCH=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="spring # " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_CMD_SOUND=y CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y diff --git a/configs/stm32f429-discovery_defconfig b/configs/stm32f429-discovery_defconfig index a407d52..86dfd0e 100644 --- a/configs/stm32f429-discovery_defconfig +++ b/configs/stm32f429-discovery_defconfig @@ -5,4 +5,5 @@ CONFIG_TARGET_STM32F429_DISCOVERY=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot > " # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TIMER=y CONFIG_OF_LIBFDT=y diff --git a/configs/stm32f746-disco_defconfig b/configs/stm32f746-disco_defconfig index abbb1e9..0048226 100644 --- a/configs/stm32f746-disco_defconfig +++ b/configs/stm32f746-disco_defconfig @@ -7,6 +7,8 @@ CONFIG_SYS_PROMPT="U-Boot > " CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit SPACE in %d seconds to stop autoboot.\n" CONFIG_AUTOBOOT_STOP_STR=" " +# CONFIG_CMD_IMLS is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TIMER=y CONFIG_OF_LIBFDT=y # CONFIG_EFI_LOADER is not set diff --git a/configs/stout_defconfig b/configs/stout_defconfig index c5af189..d4d1d89 100644 --- a/configs/stout_defconfig +++ b/configs/stout_defconfig @@ -10,11 +10,16 @@ CONFIG_TARGET_STOUT=y # CONFIG_CMD_ENV_EXISTS is not set # CONFIG_CMD_LOADB is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_SH_SDHI=y CONFIG_SPI_FLASH=y diff --git a/configs/strider_con_defconfig b/configs/strider_con_defconfig index 8934992..316ceaf 100644 --- a/configs/strider_con_defconfig +++ b/configs/strider_con_defconfig @@ -9,6 +9,9 @@ CONFIG_SYS_EXTRA_OPTIONS="STRIDER_CON" CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/strider_cpu_defconfig b/configs/strider_cpu_defconfig index 05a2e13..77f4fc1 100644 --- a/configs/strider_cpu_defconfig +++ b/configs/strider_cpu_defconfig @@ -9,6 +9,9 @@ CONFIG_SYS_EXTRA_OPTIONS="STRIDER_CPU" CONFIG_HUSH_PARSER=y CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/stv0991_defconfig b/configs/stv0991_defconfig index cce8818..6a3b5b8 100644 --- a/configs/stv0991_defconfig +++ b/configs/stv0991_defconfig @@ -8,8 +8,12 @@ CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit SPACE in %d seconds to stop autoboot.\n" CONFIG_AUTOBOOT_STOP_STR=" " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y diff --git a/configs/sunxi_Gemei_G9_defconfig b/configs/sunxi_Gemei_G9_defconfig index 28b1633..3cae955 100644 --- a/configs/sunxi_Gemei_G9_defconfig +++ b/configs/sunxi_Gemei_G9_defconfig @@ -14,5 +14,8 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_USB_EHCI_HCD=y diff --git a/configs/suvd3_defconfig b/configs/suvd3_defconfig index c3e5390..3ab8901 100644 --- a/configs/suvd3_defconfig +++ b/configs/suvd3_defconfig @@ -5,5 +5,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="SUVD3" CONFIG_HUSH_PARSER=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/sycamore_defconfig b/configs/sycamore_defconfig index 788d5c1..c462fa2 100644 --- a/configs/sycamore_defconfig +++ b/configs/sycamore_defconfig @@ -3,5 +3,10 @@ CONFIG_4xx=y CONFIG_TARGET_WALNUT=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/t3corp_defconfig b/configs/t3corp_defconfig index 21d2e76..0deda13 100644 --- a/configs/t3corp_defconfig +++ b/configs/t3corp_defconfig @@ -4,5 +4,9 @@ CONFIG_TARGET_T3CORP=y CONFIG_FIT=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/tao3530_defconfig b/configs/tao3530_defconfig index 05021d2..9b096cc 100644 --- a/configs/tao3530_defconfig +++ b/configs/tao3530_defconfig @@ -7,7 +7,11 @@ CONFIG_SYS_PROMPT="TAO-3530 # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/taurus_defconfig b/configs/taurus_defconfig index b5ab8b4..00bd63f 100644 --- a/configs/taurus_defconfig +++ b/configs/taurus_defconfig @@ -8,9 +8,14 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SOURCE is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_USB=y diff --git a/configs/tb100_defconfig b/configs/tb100_defconfig index 053b74c..83b1b56 100644 --- a/configs/tb100_defconfig +++ b/configs/tb100_defconfig @@ -8,6 +8,8 @@ CONFIG_SYS_PROMPT="[tb100]:~# " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_DM=y diff --git a/configs/tbs2910_defconfig b/configs/tbs2910_defconfig index be37090..1841e93 100644 --- a/configs/tbs2910_defconfig +++ b/configs/tbs2910_defconfig @@ -5,8 +5,14 @@ CONFIG_FIT=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Matrix U-Boot> " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_DM=y CONFIG_DM_THERMAL=y CONFIG_USB=y diff --git a/configs/tcm-bf518_defconfig b/configs/tcm-bf518_defconfig index 7a8700f..91e0f75 100644 --- a/configs/tcm-bf518_defconfig +++ b/configs/tcm-bf518_defconfig @@ -1,6 +1,12 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_TCM_BF518=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_DNS=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y diff --git a/configs/tcm-bf537_defconfig b/configs/tcm-bf537_defconfig index 056b69f..b39e260 100644 --- a/configs/tcm-bf537_defconfig +++ b/configs/tcm-bf537_defconfig @@ -1,6 +1,12 @@ CONFIG_BLACKFIN=y CONFIG_TARGET_TCM_BF537=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y +CONFIG_CMD_DNS=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED=y diff --git a/configs/tec-ng_defconfig b/configs/tec-ng_defconfig index d4019f4..8ed7809 100644 --- a/configs/tec-ng_defconfig +++ b/configs/tec-ng_defconfig @@ -11,10 +11,16 @@ CONFIG_SYS_PROMPT="Tegra30 (TEC-NG) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/tec_defconfig b/configs/tec_defconfig index 95d1838..240f11e 100644 --- a/configs/tec_defconfig +++ b/configs/tec_defconfig @@ -11,10 +11,13 @@ CONFIG_SYS_PROMPT="Tegra20 (TEC) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y CONFIG_PWM_TEGRA=y diff --git a/configs/theadorable_debug_defconfig b/configs/theadorable_debug_defconfig index 800abca..1eb4b10 100644 --- a/configs/theadorable_debug_defconfig +++ b/configs/theadorable_debug_defconfig @@ -11,9 +11,15 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_SPI_FLASH=y diff --git a/configs/theadorable_defconfig b/configs/theadorable_defconfig index 11624d6..e9e6290 100644 --- a/configs/theadorable_defconfig +++ b/configs/theadorable_defconfig @@ -11,9 +11,11 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set +CONFIG_CMD_TIME=y CONFIG_SPL_OF_TRANSLATE=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_MACRONIX=y diff --git a/configs/thuban_defconfig b/configs/thuban_defconfig index c81e411..0437874 100644 --- a/configs/thuban_defconfig +++ b/configs/thuban_defconfig @@ -8,8 +8,14 @@ CONFIG_AUTOBOOT_PROMPT="Autobooting in %d seconds, press "<Esc><Esc>" to stop\ CONFIG_AUTOBOOT_STOP_STR="\x1b\x1b" # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/ti814x_evm_defconfig b/configs/ti814x_evm_defconfig index 5d2a79a..2208e9a 100644 --- a/configs/ti814x_evm_defconfig +++ b/configs/ti814x_evm_defconfig @@ -6,5 +6,7 @@ CONFIG_SYS_PROMPT="U-Boot# " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/titanium_defconfig b/configs/titanium_defconfig index de3c26d..9e38f5d 100644 --- a/configs/titanium_defconfig +++ b/configs/titanium_defconfig @@ -6,6 +6,11 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Titanium > " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_TIME=y CONFIG_OF_LIBFDT=y diff --git a/configs/tqma6q_mba6_mmc_defconfig b/configs/tqma6q_mba6_mmc_defconfig index 24e64b6..b5492a9 100644 --- a/configs/tqma6q_mba6_mmc_defconfig +++ b/configs/tqma6q_mba6_mmc_defconfig @@ -7,7 +7,13 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_OF_LIBFDT=y diff --git a/configs/tqma6q_mba6_spi_defconfig b/configs/tqma6q_mba6_spi_defconfig index be870ba..69cf92e 100644 --- a/configs/tqma6q_mba6_spi_defconfig +++ b/configs/tqma6q_mba6_spi_defconfig @@ -8,7 +8,13 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_OF_LIBFDT=y diff --git a/configs/tqma6s_mba6_mmc_defconfig b/configs/tqma6s_mba6_mmc_defconfig index 157d762..40a6f42 100644 --- a/configs/tqma6s_mba6_mmc_defconfig +++ b/configs/tqma6s_mba6_mmc_defconfig @@ -8,7 +8,13 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_OF_LIBFDT=y diff --git a/configs/tqma6s_mba6_spi_defconfig b/configs/tqma6s_mba6_spi_defconfig index 928c480..b141f16 100644 --- a/configs/tqma6s_mba6_spi_defconfig +++ b/configs/tqma6s_mba6_spi_defconfig @@ -9,7 +9,13 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_OF_LIBFDT=y diff --git a/configs/tqma6s_wru4_mmc_defconfig b/configs/tqma6s_wru4_mmc_defconfig index a051a9f..92cc5c9 100644 --- a/configs/tqma6s_wru4_mmc_defconfig +++ b/configs/tqma6s_wru4_mmc_defconfig @@ -11,6 +11,11 @@ CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Enter password in %d seconds to stop autoboot\n" CONFIG_AUTOBOOT_ENCRYPTION=y CONFIG_AUTOBOOT_STOP_STR_SHA256="36a9e7f1c95b82ffb99743e0c5c4ce95d83c9a430aac59f84ef3cbfab6145068" +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_PCA9551_LED=y CONFIG_OF_LIBFDT=y diff --git a/configs/trats2_defconfig b/configs/trats2_defconfig index 73fc63c..693d845 100644 --- a/configs/trats2_defconfig +++ b/configs/trats2_defconfig @@ -9,9 +9,12 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Trats2 # " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_NET is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_OF_CONTROL=y CONFIG_USB=y diff --git a/configs/trats_defconfig b/configs/trats_defconfig index 8fbb5f2..66a11c9 100644 --- a/configs/trats_defconfig +++ b/configs/trats_defconfig @@ -8,9 +8,12 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Trats # " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_NET is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_OF_CONTROL=y CONFIG_USB=y diff --git a/configs/tricorder_defconfig b/configs/tricorder_defconfig index ff2c785..21d0bbf 100644 --- a/configs/tricorder_defconfig +++ b/configs/tricorder_defconfig @@ -7,6 +7,7 @@ CONFIG_SYS_PROMPT="OMAP3 Tricorder # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set diff --git a/configs/tricorder_flash_defconfig b/configs/tricorder_flash_defconfig index 4ed1ada..1dfff4d 100644 --- a/configs/tricorder_flash_defconfig +++ b/configs/tricorder_flash_defconfig @@ -7,6 +7,7 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set diff --git a/configs/trimslice_defconfig b/configs/trimslice_defconfig index 98678d5..8e8618e 100644 --- a/configs/trimslice_defconfig +++ b/configs/trimslice_defconfig @@ -10,10 +10,16 @@ CONFIG_SYS_PROMPT="Tegra20 (TrimSlice) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_RTL8169=y diff --git a/configs/ts4800_defconfig b/configs/ts4800_defconfig index ac81a46..3a7fa63 100644 --- a/configs/ts4800_defconfig +++ b/configs/ts4800_defconfig @@ -2,5 +2,8 @@ CONFIG_ARM=y CONFIG_TARGET_TS4800=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SPI=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/tuge1_defconfig b/configs/tuge1_defconfig index 904bc89..97fb231 100644 --- a/configs/tuge1_defconfig +++ b/configs/tuge1_defconfig @@ -5,5 +5,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="TUGE1" CONFIG_HUSH_PARSER=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/tuxx1_defconfig b/configs/tuxx1_defconfig index 7bbe36d..3a03ecb 100644 --- a/configs/tuxx1_defconfig +++ b/configs/tuxx1_defconfig @@ -5,5 +5,11 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_SYS_EXTRA_OPTIONS="TUXX1" CONFIG_HUSH_PARSER=y +CONFIG_AUTOBOOT_KEYED=y +CONFIG_AUTOBOOT_PROMPT="Hit <SPACE> key to stop autoboot in %2ds\n" +CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/twister_defconfig b/configs/twister_defconfig index f6b30c2..83cf623 100644 --- a/configs/twister_defconfig +++ b/configs/twister_defconfig @@ -7,8 +7,12 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="twister => " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_USB_ULPI_VIEWPORT_OMAP=y diff --git a/configs/udoo_defconfig b/configs/udoo_defconfig index 5e2cb85..af48888 100644 --- a/configs/udoo_defconfig +++ b/configs/udoo_defconfig @@ -4,7 +4,10 @@ CONFIG_TARGET_UDOO=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6QDL" CONFIG_HUSH_PARSER=y +# CONFIG_CMD_IMLS is not set CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_DM_THERMAL=y CONFIG_OF_LIBFDT=y diff --git a/configs/usb_a9263_dataflash_defconfig b/configs/usb_a9263_dataflash_defconfig index fe14f9a..fa5561a 100644 --- a/configs/usb_a9263_dataflash_defconfig +++ b/configs/usb_a9263_dataflash_defconfig @@ -12,4 +12,6 @@ CONFIG_SYS_PROMPT="U-Boot> " # CONFIG_CMD_FPGA is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/usbarmory_defconfig b/configs/usbarmory_defconfig index b4a3c00..215e87b 100644 --- a/configs/usbarmory_defconfig +++ b/configs/usbarmory_defconfig @@ -3,5 +3,10 @@ CONFIG_ARCH_MX5=y CONFIG_TARGET_USBARMORY=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/v38b_defconfig b/configs/v38b_defconfig index cc3d802..3dadfcc 100644 --- a/configs/v38b_defconfig +++ b/configs/v38b_defconfig @@ -1,4 +1,8 @@ CONFIG_PPC=y CONFIG_MPC5xxx=y CONFIG_TARGET_V38B=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y diff --git a/configs/vct_platinum_defconfig b/configs/vct_platinum_defconfig index 4b0b5b4..b889976 100644 --- a/configs/vct_platinum_defconfig +++ b/configs/vct_platinum_defconfig @@ -2,6 +2,11 @@ CONFIG_MIPS=y CONFIG_TARGET_VCT=y CONFIG_VCT_PLATINUM=y CONFIG_SYS_PROMPT="$ " +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y CONFIG_SYS_NS16550=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/vct_platinum_onenand_defconfig b/configs/vct_platinum_onenand_defconfig index 62d8878..597f764 100644 --- a/configs/vct_platinum_onenand_defconfig +++ b/configs/vct_platinum_onenand_defconfig @@ -5,6 +5,11 @@ CONFIG_VCT_ONENAND=y CONFIG_SYS_PROMPT="$ " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y CONFIG_SYS_NS16550=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/vct_platinumavc_defconfig b/configs/vct_platinumavc_defconfig index 92a3027..c47f102 100644 --- a/configs/vct_platinumavc_defconfig +++ b/configs/vct_platinumavc_defconfig @@ -2,8 +2,10 @@ CONFIG_MIPS=y CONFIG_TARGET_VCT=y CONFIG_VCT_PLATINUMAVC=y CONFIG_SYS_PROMPT="VCT# " +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set CONFIG_SYS_NS16550=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/vct_platinumavc_onenand_defconfig b/configs/vct_platinumavc_onenand_defconfig index 87767bd..e7aef31 100644 --- a/configs/vct_platinumavc_onenand_defconfig +++ b/configs/vct_platinumavc_onenand_defconfig @@ -5,8 +5,10 @@ CONFIG_VCT_ONENAND=y CONFIG_SYS_PROMPT="$ " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set CONFIG_SYS_NS16550=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/vct_premium_defconfig b/configs/vct_premium_defconfig index 7ca6e34..68c4af1 100644 --- a/configs/vct_premium_defconfig +++ b/configs/vct_premium_defconfig @@ -2,6 +2,11 @@ CONFIG_MIPS=y CONFIG_TARGET_VCT=y CONFIG_VCT_PREMIUM=y CONFIG_SYS_PROMPT="$ " +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y CONFIG_SYS_NS16550=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/vct_premium_onenand_defconfig b/configs/vct_premium_onenand_defconfig index 88555d9..1d73069 100644 --- a/configs/vct_premium_onenand_defconfig +++ b/configs/vct_premium_onenand_defconfig @@ -5,6 +5,11 @@ CONFIG_VCT_ONENAND=y CONFIG_SYS_PROMPT="$ " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y CONFIG_SYS_NS16550=y CONFIG_USE_PRIVATE_LIBGCC=y diff --git a/configs/ve8313_defconfig b/configs/ve8313_defconfig index b2ae829..4243848 100644 --- a/configs/ve8313_defconfig +++ b/configs/ve8313_defconfig @@ -5,5 +5,7 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/venice2_defconfig b/configs/venice2_defconfig index 4ebce04..5749d1c 100644 --- a/configs/venice2_defconfig +++ b/configs/venice2_defconfig @@ -10,10 +10,16 @@ CONFIG_SYS_PROMPT="Tegra124 (Venice2) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SYS_NS16550=y diff --git a/configs/ventana_defconfig b/configs/ventana_defconfig index 5dc16b3..cbb17c9 100644 --- a/configs/ventana_defconfig +++ b/configs/ventana_defconfig @@ -10,10 +10,13 @@ CONFIG_SYS_PROMPT="Tegra20 (Ventana) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y CONFIG_PWM_TEGRA=y diff --git a/configs/vexpress_aemv8a_dram_defconfig b/configs/vexpress_aemv8a_dram_defconfig index 1497605..644a207 100644 --- a/configs/vexpress_aemv8a_dram_defconfig +++ b/configs/vexpress_aemv8a_dram_defconfig @@ -9,11 +9,15 @@ CONFIG_SYS_PROMPT="VExpress64# " # CONFIG_CMD_XIMG is not set # CONFIG_CMD_EDITENV is not set # CONFIG_CMD_ENV_EXISTS is not set +CONFIG_CMD_MEMTEST=y # CONFIG_CMD_LOADS is not set +CONFIG_CMD_ARMFLASH=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_DM=y CONFIG_OF_LIBFDT=y diff --git a/configs/vexpress_aemv8a_juno_defconfig b/configs/vexpress_aemv8a_juno_defconfig index b9bfc26..7bae9c9 100644 --- a/configs/vexpress_aemv8a_juno_defconfig +++ b/configs/vexpress_aemv8a_juno_defconfig @@ -9,11 +9,15 @@ CONFIG_SYS_PROMPT="VExpress64# " # CONFIG_CMD_XIMG is not set # CONFIG_CMD_EDITENV is not set # CONFIG_CMD_ENV_EXISTS is not set +CONFIG_CMD_MEMTEST=y # CONFIG_CMD_LOADS is not set +CONFIG_CMD_ARMFLASH=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_DM=y CONFIG_OF_LIBFDT=y diff --git a/configs/vexpress_aemv8a_semi_defconfig b/configs/vexpress_aemv8a_semi_defconfig index 8818527..2006176 100644 --- a/configs/vexpress_aemv8a_semi_defconfig +++ b/configs/vexpress_aemv8a_semi_defconfig @@ -9,11 +9,15 @@ CONFIG_SYS_PROMPT="VExpress64# " # CONFIG_CMD_XIMG is not set # CONFIG_CMD_EDITENV is not set # CONFIG_CMD_ENV_EXISTS is not set +CONFIG_CMD_MEMTEST=y # CONFIG_CMD_LOADS is not set +CONFIG_CMD_ARMFLASH=y # CONFIG_CMD_FPGA is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_DM=y CONFIG_OF_LIBFDT=y diff --git a/configs/vexpress_ca15_tc2_defconfig b/configs/vexpress_ca15_tc2_defconfig index 0508796..981352b 100644 --- a/configs/vexpress_ca15_tc2_defconfig +++ b/configs/vexpress_ca15_tc2_defconfig @@ -13,6 +13,8 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_OF_LIBFDT=y diff --git a/configs/vexpress_ca5x2_defconfig b/configs/vexpress_ca5x2_defconfig index 9e53655..76a6bd1 100644 --- a/configs/vexpress_ca5x2_defconfig +++ b/configs/vexpress_ca5x2_defconfig @@ -13,6 +13,8 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_OF_LIBFDT=y diff --git a/configs/vexpress_ca9x4_defconfig b/configs/vexpress_ca9x4_defconfig index 524ef4b..1248222 100644 --- a/configs/vexpress_ca9x4_defconfig +++ b/configs/vexpress_ca9x4_defconfig @@ -13,6 +13,8 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_ECHO is not set # CONFIG_CMD_ITEST is not set # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y # CONFIG_CMD_MISC is not set CONFIG_OF_LIBFDT=y diff --git a/configs/vf610twr_defconfig b/configs/vf610twr_defconfig index 80ec20f..4504af2 100644 --- a/configs/vf610twr_defconfig +++ b/configs/vf610twr_defconfig @@ -6,8 +6,12 @@ CONFIG_DEFAULT_DEVICE_TREE="vf610-twr" CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/vf610twr/imximage.cfg,ENV_IS_IN_MMC" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_VYBRID_GPIO=y diff --git a/configs/vf610twr_nand_defconfig b/configs/vf610twr_nand_defconfig index afe8a47..26b045a 100644 --- a/configs/vf610twr_nand_defconfig +++ b/configs/vf610twr_nand_defconfig @@ -6,8 +6,12 @@ CONFIG_DEFAULT_DEVICE_TREE="vf610-twr" CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/vf610twr/imximage.cfg,ENV_IS_IN_NAND" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_OF_CONTROL=y CONFIG_DM=y CONFIG_VYBRID_GPIO=y diff --git a/configs/vinco_defconfig b/configs/vinco_defconfig index 29da314..57d0169 100644 --- a/configs/vinco_defconfig +++ b/configs/vinco_defconfig @@ -8,7 +8,11 @@ CONFIG_SYS_PROMPT="vinco => " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_LOADS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SPI_FLASH=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/vme8349_defconfig b/configs/vme8349_defconfig index 5f0971a..323b416 100644 --- a/configs/vme8349_defconfig +++ b/configs/vme8349_defconfig @@ -4,6 +4,8 @@ CONFIG_TARGET_VME8349=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/walnut_defconfig b/configs/walnut_defconfig index 788d5c1..c462fa2 100644 --- a/configs/walnut_defconfig +++ b/configs/walnut_defconfig @@ -3,5 +3,10 @@ CONFIG_4xx=y CONFIG_TARGET_WALNUT=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/wandboard_defconfig b/configs/wandboard_defconfig index 773b493..e03a1d9 100644 --- a/configs/wandboard_defconfig +++ b/configs/wandboard_defconfig @@ -6,7 +6,11 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg,MX6QDL" CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_DM_THERMAL=y CONFIG_OF_LIBFDT=y diff --git a/configs/warp7_defconfig b/configs/warp7_defconfig index 77ccecf..29c5e91 100644 --- a/configs/warp7_defconfig +++ b/configs/warp7_defconfig @@ -9,5 +9,7 @@ CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_XIMG is not set +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set diff --git a/configs/warp_defconfig b/configs/warp_defconfig index c7c1d25..aa15c81 100644 --- a/configs/warp_defconfig +++ b/configs/warp_defconfig @@ -5,6 +5,8 @@ CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/freescale/mx6slevk/imximage.cfg,MX6SL CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set diff --git a/configs/whistler_defconfig b/configs/whistler_defconfig index d443ae3..a6d1438 100644 --- a/configs/whistler_defconfig +++ b/configs/whistler_defconfig @@ -10,10 +10,14 @@ CONFIG_SYS_PROMPT="Tegra20 (Whistler) # " # CONFIG_CMD_IMI is not set # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y # CONFIG_CMD_NFS is not set +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_USB=y CONFIG_DM_USB=y diff --git a/configs/woodburn_defconfig b/configs/woodburn_defconfig index f335294..ddbd697 100644 --- a/configs/woodburn_defconfig +++ b/configs/woodburn_defconfig @@ -2,5 +2,9 @@ CONFIG_ARM=y CONFIG_TARGET_WOODBURN=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="woodburn U-Boot > " +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y diff --git a/configs/woodburn_sd_defconfig b/configs/woodburn_sd_defconfig index f73206e..d801c3b 100644 --- a/configs/woodburn_sd_defconfig +++ b/configs/woodburn_sd_defconfig @@ -4,5 +4,9 @@ CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/woodburn/imximage.cfg" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="woodburn U-Boot > " +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y diff --git a/configs/work_92105_defconfig b/configs/work_92105_defconfig index 2999772..12df37b 100644 --- a/configs/work_92105_defconfig +++ b/configs/work_92105_defconfig @@ -8,7 +8,11 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SPI=y +CONFIG_CMD_I2C=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_DM=y CONFIG_SYS_NS16550=y diff --git a/configs/wtk_defconfig b/configs/wtk_defconfig index 25ce098..8c163fb 100644 --- a/configs/wtk_defconfig +++ b/configs/wtk_defconfig @@ -5,4 +5,6 @@ CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="LCD,SHARP_LQ065T9DR51U" CONFIG_HUSH_PARSER=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_SNTP=y CONFIG_OF_LIBFDT=y diff --git a/configs/x600_defconfig b/configs/x600_defconfig index e2a2c81..05d2f35 100644 --- a/configs/x600_defconfig +++ b/configs/x600_defconfig @@ -6,8 +6,13 @@ CONFIG_SYS_PROMPT="X600> " CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="Hit SPACE in %d seconds to stop autoboot.\n" CONFIG_AUTOBOOT_STOP_STR=" " +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NETDEVICES=y CONFIG_ETH_DESIGNWARE=y CONFIG_USE_TINY_PRINTF=y diff --git a/configs/xfi3_defconfig b/configs/xfi3_defconfig index 515ae41..5f25633 100644 --- a/configs/xfi3_defconfig +++ b/configs/xfi3_defconfig @@ -4,8 +4,10 @@ CONFIG_SPL=y CONFIG_HUSH_PARSER=y # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_PING=y CONFIG_USB=y CONFIG_USB_GADGET=y CONFIG_CI_UDC=y diff --git a/configs/xilinx-ppc405-generic_defconfig b/configs/xilinx-ppc405-generic_defconfig index edfcc20..9d4b137 100644 --- a/configs/xilinx-ppc405-generic_defconfig +++ b/configs/xilinx-ppc405-generic_defconfig @@ -8,6 +8,7 @@ CONFIG_SYS_EXTRA_OPTIONS="SYS_TEXT_BASE=0x04000000,RESET_VECTOR_ADDRESS=0x041000 CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="xlx-ppc405:/# " # CONFIG_CMD_IMLS is not set +CONFIG_LOOPW=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set diff --git a/configs/xilinx-ppc440-generic_defconfig b/configs/xilinx-ppc440-generic_defconfig index 2e65a2c..4f814a6 100644 --- a/configs/xilinx-ppc440-generic_defconfig +++ b/configs/xilinx-ppc440-generic_defconfig @@ -7,6 +7,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_SYS_EXTRA_OPTIONS="SYS_TEXT_BASE=0x04000000,RESET_VECTOR_ADDRESS=0x04100000,BOOT_FROM_XMD=1" CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="board:/# " +CONFIG_LOOPW=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y diff --git a/configs/xilinx_zynqmp_ep_defconfig b/configs/xilinx_zynqmp_ep_defconfig index 834cc45..48d95c1 100644 --- a/configs/xilinx_zynqmp_ep_defconfig +++ b/configs/xilinx_zynqmp_ep_defconfig @@ -19,6 +19,7 @@ CONFIG_SYS_PROMPT="ZynqMP> " # CONFIG_CMD_LOADB is not set # CONFIG_CMD_LOADS is not set CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_FPGA is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_ITEST is not set diff --git a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig index 7249495..598da20 100644 --- a/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm015_dc1_defconfig @@ -13,6 +13,7 @@ CONFIG_SYS_PROMPT="ZynqMP> " CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_DHCP=y diff --git a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig index b4b1119..81170dc 100644 --- a/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig +++ b/configs/xilinx_zynqmp_zc1751_xm016_dc2_defconfig @@ -13,6 +13,7 @@ CONFIG_SYS_PROMPT="ZynqMP> " CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_DHCP=y diff --git a/configs/xilinx_zynqmp_zcu102_defconfig b/configs/xilinx_zynqmp_zcu102_defconfig index eb89b12..05c5cdd 100644 --- a/configs/xilinx_zynqmp_zcu102_defconfig +++ b/configs/xilinx_zynqmp_zcu102_defconfig @@ -11,6 +11,8 @@ CONFIG_SYS_PROMPT="ZynqMP> " # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_DHCP=y diff --git a/configs/xilinx_zynqmp_zcu102_revB_defconfig b/configs/xilinx_zynqmp_zcu102_revB_defconfig index bfbe053..f6767f3 100644 --- a/configs/xilinx_zynqmp_zcu102_revB_defconfig +++ b/configs/xilinx_zynqmp_zcu102_revB_defconfig @@ -11,6 +11,8 @@ CONFIG_SYS_PROMPT="ZynqMP> " # CONFIG_CMD_IMLS is not set CONFIG_CMD_MEMTEST=y # CONFIG_CMD_FLASH is not set +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y CONFIG_CMD_TFTPPUT=y CONFIG_CMD_DHCP=y diff --git a/configs/xpedite1000_defconfig b/configs/xpedite1000_defconfig index e189859..13e0069 100644 --- a/configs/xpedite1000_defconfig +++ b/configs/xpedite1000_defconfig @@ -4,5 +4,9 @@ CONFIG_TARGET_XPEDITE1000=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y CONFIG_SYS_NS16550=y diff --git a/configs/xpedite517x_defconfig b/configs/xpedite517x_defconfig index 9baac08..81eb5f8 100644 --- a/configs/xpedite517x_defconfig +++ b/configs/xpedite517x_defconfig @@ -6,6 +6,10 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/xpedite520x_defconfig b/configs/xpedite520x_defconfig index 6b8f4bc..77386f5 100644 --- a/configs/xpedite520x_defconfig +++ b/configs/xpedite520x_defconfig @@ -6,6 +6,10 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/xpedite537x_defconfig b/configs/xpedite537x_defconfig index 538c6cd..a4dcd78 100644 --- a/configs/xpedite537x_defconfig +++ b/configs/xpedite537x_defconfig @@ -6,6 +6,10 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/xpedite550x_defconfig b/configs/xpedite550x_defconfig index 9b3c5c9..113d16d 100644 --- a/configs/xpedite550x_defconfig +++ b/configs/xpedite550x_defconfig @@ -6,6 +6,11 @@ CONFIG_FIT_VERBOSE=y CONFIG_OF_BOARD_SETUP=y CONFIG_OF_STDOUT_VIA_ALIAS=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y +CONFIG_CMD_SNTP=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/xpress_defconfig b/configs/xpress_defconfig index 418fb7c..fc13e9d 100644 --- a/configs/xpress_defconfig +++ b/configs/xpress_defconfig @@ -3,6 +3,10 @@ CONFIG_ARCH_MX6=y CONFIG_TARGET_XPRESS=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=board/ccv/xpress/imximage.cfg" CONFIG_HUSH_PARSER=y +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/xpress_spl_defconfig b/configs/xpress_spl_defconfig index b464d15..9c2bcc5 100644 --- a/configs/xpress_spl_defconfig +++ b/configs/xpress_spl_defconfig @@ -4,6 +4,10 @@ CONFIG_TARGET_XPRESS=y CONFIG_SPL=y CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/imx-common/spl_sd.cfg" CONFIG_HUSH_PARSER=y +# CONFIG_CMD_IMLS is not set +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_OF_LIBFDT=y diff --git a/configs/yellowstone_defconfig b/configs/yellowstone_defconfig index 4f76e37..2f1cea2 100644 --- a/configs/yellowstone_defconfig +++ b/configs/yellowstone_defconfig @@ -4,5 +4,9 @@ CONFIG_TARGET_YOSEMITE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="YELLOWSTONE" CONFIG_HUSH_PARSER=y +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/yosemite_defconfig b/configs/yosemite_defconfig index 9a64852..fdede36 100644 --- a/configs/yosemite_defconfig +++ b/configs/yosemite_defconfig @@ -4,5 +4,10 @@ CONFIG_TARGET_YOSEMITE=y CONFIG_OF_BOARD_SETUP=y CONFIG_SYS_EXTRA_OPTIONS="YOSEMITE" CONFIG_HUSH_PARSER=y +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/yucca_defconfig b/configs/yucca_defconfig index b2f9784..edf1b45 100644 --- a/configs/yucca_defconfig +++ b/configs/yucca_defconfig @@ -3,5 +3,9 @@ CONFIG_4xx=y CONFIG_TARGET_YUCCA=y CONFIG_OF_BOARD_SETUP=y CONFIG_HUSH_PARSER=y +CONFIG_LOOPW=y +CONFIG_CMD_I2C=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_SYS_NS16550=y CONFIG_OF_LIBFDT=y diff --git a/configs/zipitz2_defconfig b/configs/zipitz2_defconfig index 299cf65..22bdbd3 100644 --- a/configs/zipitz2_defconfig +++ b/configs/zipitz2_defconfig @@ -3,6 +3,8 @@ CONFIG_TARGET_ZIPITZ2=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="$ " # CONFIG_CMD_IMLS is not set +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NET is not set # CONFIG_CMD_NFS is not set diff --git a/configs/zmx25_defconfig b/configs/zmx25_defconfig index 955bf37..0578850 100644 --- a/configs/zmx25_defconfig +++ b/configs/zmx25_defconfig @@ -6,4 +6,7 @@ CONFIG_AUTOBOOT_KEYED=y CONFIG_AUTOBOOT_PROMPT="boot in %d s\n" CONFIG_AUTOBOOT_DELAY_STR="delaygs" CONFIG_AUTOBOOT_STOP_STR="stopgs" +CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y diff --git a/configs/zynq_microzed_defconfig b/configs/zynq_microzed_defconfig index 99ce69e..748c160 100644 --- a/configs/zynq_microzed_defconfig +++ b/configs/zynq_microzed_defconfig @@ -10,8 +10,13 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_ZYNQ_SDHCI=y diff --git a/configs/zynq_picozed_defconfig b/configs/zynq_picozed_defconfig index 9198418..cd41af0 100644 --- a/configs/zynq_picozed_defconfig +++ b/configs/zynq_picozed_defconfig @@ -7,8 +7,12 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_ZYNQ_SDHCI=y diff --git a/configs/zynq_zc702_defconfig b/configs/zynq_zc702_defconfig index 214d754..8471e10 100644 --- a/configs/zynq_zc702_defconfig +++ b/configs/zynq_zc702_defconfig @@ -9,8 +9,14 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_ZYNQ_SDHCI=y diff --git a/configs/zynq_zc706_defconfig b/configs/zynq_zc706_defconfig index 26cfc0e..99ddf3c 100644 --- a/configs/zynq_zc706_defconfig +++ b/configs/zynq_zc706_defconfig @@ -10,8 +10,14 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_ZYNQ_SDHCI=y diff --git a/configs/zynq_zc770_xm010_defconfig b/configs/zynq_zc770_xm010_defconfig index fc58fa1..50724b5 100644 --- a/configs/zynq_zc770_xm010_defconfig +++ b/configs/zynq_zc770_xm010_defconfig @@ -11,8 +11,12 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_ZYNQ_SDHCI=y diff --git a/configs/zynq_zc770_xm011_defconfig b/configs/zynq_zc770_xm011_defconfig index ea0df44..a80dd11 100644 --- a/configs/zynq_zc770_xm011_defconfig +++ b/configs/zynq_zc770_xm011_defconfig @@ -13,6 +13,9 @@ CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_ZYNQ_GEM=y diff --git a/configs/zynq_zc770_xm012_defconfig b/configs/zynq_zc770_xm012_defconfig index 7f8a17a..dbb0d13 100644 --- a/configs/zynq_zc770_xm012_defconfig +++ b/configs/zynq_zc770_xm012_defconfig @@ -11,6 +11,9 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Zynq> " CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_ZYNQ_GEM=y diff --git a/configs/zynq_zc770_xm013_defconfig b/configs/zynq_zc770_xm013_defconfig index 6a68f7e..be7c425 100644 --- a/configs/zynq_zc770_xm013_defconfig +++ b/configs/zynq_zc770_xm013_defconfig @@ -13,6 +13,9 @@ CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_FLASH is not set CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_SPI_FLASH=y diff --git a/configs/zynq_zed_defconfig b/configs/zynq_zed_defconfig index 9cb1485..f3c7e1c 100644 --- a/configs/zynq_zed_defconfig +++ b/configs/zynq_zed_defconfig @@ -10,8 +10,13 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_ZYNQ_SDHCI=y diff --git a/configs/zynq_zybo_defconfig b/configs/zynq_zybo_defconfig index 89739a6..9063010 100644 --- a/configs/zynq_zybo_defconfig +++ b/configs/zynq_zybo_defconfig @@ -10,8 +10,14 @@ CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="Zynq> " # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_I2C=y +CONFIG_CMD_USB=y CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_DHCP=y +CONFIG_CMD_PING=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_SPL_DM_SEQ_ALIAS=y CONFIG_ZYNQ_SDHCI=y diff --git a/include/config_cmd_all.h b/include/config_cmd_all.h index e858e55..4054900 100644 --- a/include/config_cmd_all.h +++ b/include/config_cmd_all.h @@ -19,10 +19,8 @@ #define CONFIG_CMD_BOOTZ /* boot zImage */ #define CONFIG_CMD_BSP /* Board Specific functions */ #define CONFIG_CMD_CACHE /* icache, dcache */ -#define CONFIG_CMD_CDP /* Cisco Discovery Protocol */ #define CONFIG_CMD_CLK /* Clock support */ #define CONFIG_CMD_DATE /* support for RTC, date/time...*/ -#define CONFIG_CMD_DHCP /* DHCP Support */ #define CONFIG_CMD_DIAG /* Diagnostics */ #define CONFIG_CMD_DISPLAY /* Display support */ #define CONFIG_CMD_DOC /* Disk-On-Chip Support */ @@ -34,16 +32,12 @@ #define CONFIG_CMD_FUSE /* Device fuse support */ #define CONFIG_CMD_GETTIME /* Get time since boot */ #define CONFIG_CMD_HASH /* calculate hash / digest */ -#define CONFIG_CMD_I2C /* I2C serial bus support */ #define CONFIG_CMD_IDE /* IDE harddisk support */ #define CONFIG_CMD_IMMAP /* IMMR dump support */ #define CONFIG_CMD_IO /* Access to X86 IO space */ #define CONFIG_CMD_IRQ /* irqinfo */ #define CONFIG_CMD_JFFS2 /* JFFS2 Support */ #define CONFIG_CMD_KGDB /* kgdb */ -#define CONFIG_CMD_LICENSE /* console license display */ -#define CONFIG_CMD_MEMINFO /* meminfo */ -#define CONFIG_CMD_MEMTEST /* mtest */ #define CONFIG_CMD_MFSL /* FSL support for Microblaze */ #define CONFIG_CMD_MII /* MII support */ #define CONFIG_CMD_MMC /* MMC support */ @@ -52,24 +46,19 @@ #define CONFIG_CMD_ONENAND /* OneNAND support */ #define CONFIG_CMD_PCI /* pciinfo */ #define CONFIG_CMD_PCMCIA /* PCMCIA support */ -#define CONFIG_CMD_PING /* ping support */ #define CONFIG_CMD_PORTIO /* Port I/O */ #define CONFIG_CMD_REGINFO /* Register dump */ #define CONFIG_CMD_REISER /* Reiserfs support */ -#define CONFIG_CMD_RARP /* rarpboot support */ #define CONFIG_CMD_READ /* Read data from partition */ #define CONFIG_CMD_SANDBOX /* sb command to access sandbox features */ #define CONFIG_CMD_SAVES /* save S record dump */ #define CONFIG_CMD_SCSI /* SCSI Support */ #define CONFIG_CMD_SDRAM /* SDRAM DIMM SPD info printout */ -#define CONFIG_CMD_SNTP /* SNTP support */ -#define CONFIG_CMD_SPI /* SPI utility */ #define CONFIG_CMD_TERMINAL /* built-in Serial Terminal */ #define CONFIG_CMD_UBI /* UBI Support */ #define CONFIG_CMD_UBIFS /* UBIFS Support */ #define CONFIG_CMD_UNIVERSE /* Tundra Universe Support */ #define CONFIG_CMD_UNZIP /* unzip from memory to memory */ -#define CONFIG_CMD_USB /* USB Support */ #define CONFIG_CMD_ZFS /* ZFS Support */
#endif /* _CONFIG_CMD_ALL_H */ diff --git a/include/config_distro_defaults.h b/include/config_distro_defaults.h index ae44512..a0e490b 100644 --- a/include/config_distro_defaults.h +++ b/include/config_distro_defaults.h @@ -46,13 +46,11 @@ #else #define CONFIG_CMD_BOOTZ #endif -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EXT2 #define CONFIG_CMD_EXT4 #define CONFIG_CMD_FAT #define CONFIG_CMD_FS_GENERIC #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_PXE
#define CONFIG_CMDLINE_EDITING diff --git a/include/config_fallbacks.h b/include/config_fallbacks.h index 5262641..e3c222e 100644 --- a/include/config_fallbacks.h +++ b/include/config_fallbacks.h @@ -75,10 +75,6 @@ #define CONFIG_CMD_BMP #endif
-#ifndef CONFIG_SYS_PROMPT -#define CONFIG_SYS_PROMPT "=> " -#endif - #ifndef CONFIG_SYS_PBSIZE #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + 128) #endif @@ -100,8 +96,6 @@ #ifndef CONFIG_CMDLINE #undef CONFIG_CMDLINE_EDITING #undef CONFIG_SYS_LONGHELP -#undef CONFIG_CMD_BOOTD -#undef CONFIG_CMD_RUN #undef CONFIG_CMD_ASKENV #undef CONFIG_MENU #endif diff --git a/include/config_uncmd_spl.h b/include/config_uncmd_spl.h index 3b198ae..3c1499c 100644 --- a/include/config_uncmd_spl.h +++ b/include/config_uncmd_spl.h @@ -10,16 +10,6 @@
#ifdef CONFIG_SPL_BUILD /* SPL needs only BOOTP + TFTP so undefine other stuff to save space */ -#undef CONFIG_CMD_CDP -#undef CONFIG_CMD_DHCP -#undef CONFIG_CMD_DNS -#undef CONFIG_CMD_LINK_LOCAL -#undef CONFIG_CMD_NFS -#undef CONFIG_CMD_PING -#undef CONFIG_CMD_RARP -#undef CONFIG_CMD_SNTP -#undef CONFIG_CMD_TFTPPUT -#undef CONFIG_CMD_TFTPSRV
#ifndef CONFIG_SPL_DM #undef CONFIG_DM_SERIAL diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index ef87bda..cda5a65 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -572,7 +572,6 @@ unsigned long get_board_ddr_clk(void); /* * eSPI - Enhanced SPI */ -#define CONFIG_CMD_SF #define CONFIG_SF_DEFAULT_SPEED 10000000 #define CONFIG_SF_DEFAULT_MODE 0
@@ -736,14 +735,11 @@ unsigned long get_board_ddr_clk(void); * Command line configuration. */ #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EEPROM #define CONFIG_CMD_ERRATA #define CONFIG_CMD_GREPENV #define CONFIG_CMD_IRQ -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO
#ifdef CONFIG_PCI @@ -765,7 +761,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_USB_EHCI
#ifdef CONFIG_USB_EHCI -#define CONFIG_CMD_USB #define CONFIG_USB_STORAGE #define CONFIG_USB_EHCI_FSL #define CONFIG_EHCI_HCD_INIT_AFTER_RESET diff --git a/include/configs/BSC9131RDB.h b/include/configs/BSC9131RDB.h index e7a90bd..42cc6db 100644 --- a/include/configs/BSC9131RDB.h +++ b/include/configs/BSC9131RDB.h @@ -253,12 +253,8 @@ extern unsigned long get_sdram_size(void); #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5
-#define CONFIG_CMD_I2C - - /* eSPI - Enhanced SPI */ #ifdef CONFIG_FSL_ESPI -#define CONFIG_CMD_SF #define CONFIG_SF_DEFAULT_SPEED 10000000 #define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 #endif @@ -318,14 +314,12 @@ extern unsigned long get_sdram_size(void); /* * Command line configuration. */ -#define CONFIG_CMD_DHCP #define CONFIG_CMD_ERRATA #define CONFIG_CMD_EXT2 #define CONFIG_CMD_FAT #define CONFIG_CMD_IRQ #define CONFIG_CMD_MII #define CONFIG_DOS_PARTITION -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO
/* @@ -367,7 +361,6 @@ extern unsigned long get_sdram_size(void); #define CONFIG_USB_EHCI
#ifdef CONFIG_USB_EHCI -#define CONFIG_CMD_USB #define CONFIG_EHCI_HCD_INIT_AFTER_RESET #define CONFIG_USB_EHCI_FSL #define CONFIG_USB_STORAGE diff --git a/include/configs/BSC9132QDS.h b/include/configs/BSC9132QDS.h index 17ae12e..51bdc0f 100644 --- a/include/configs/BSC9132QDS.h +++ b/include/configs/BSC9132QDS.h @@ -462,7 +462,6 @@ combinations. this should be removed later */ /* eSPI - Enhanced SPI */ #ifdef CONFIG_FSL_ESPI -#define CONFIG_CMD_SF #define CONFIG_SF_DEFAULT_SPEED 10000000 #define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 #endif @@ -510,7 +509,6 @@ combinations. this should be removed later
#define CONFIG_USB_EHCI /* USB */ #ifdef CONFIG_USB_EHCI -#define CONFIG_CMD_USB #define CONFIG_EHCI_HCD_INIT_AFTER_RESET #define CONFIG_USB_EHCI_FSL #define CONFIG_USB_STORAGE @@ -557,12 +555,9 @@ combinations. this should be removed later * Command line configuration. */ #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_ERRATA -#define CONFIG_CMD_I2C #define CONFIG_CMD_IRQ #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO
#if defined(CONFIG_MMC) || defined(CONFIG_USB_EHCI) diff --git a/include/configs/C29XPCIE.h b/include/configs/C29XPCIE.h index 9c69f91..ba5fbfd 100644 --- a/include/configs/C29XPCIE.h +++ b/include/configs/C29XPCIE.h @@ -409,10 +409,7 @@ #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5
-#define CONFIG_CMD_I2C - /* eSPI - Enhanced SPI */ -#define CONFIG_CMD_SF #define CONFIG_SF_DEFAULT_SPEED 10000000 #define CONFIG_SF_DEFAULT_MODE SPI_MODE_0
@@ -476,7 +473,6 @@ #define CONFIG_CMD_ERRATA #define CONFIG_CMD_IRQ #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO
/* Hash command with SHA acceleration supported in hardware */ diff --git a/include/configs/CPCI2DP.h b/include/configs/CPCI2DP.h index 40fff81..1c4b01f 100644 --- a/include/configs/CPCI2DP.h +++ b/include/configs/CPCI2DP.h @@ -54,7 +54,6 @@ */ #define CONFIG_CMD_PCI #define CONFIG_CMD_IRQ -#define CONFIG_CMD_I2C #define CONFIG_CMD_BSP #define CONFIG_CMD_EEPROM
@@ -103,7 +102,6 @@ #define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ #define CONFIG_SYS_EXTBDINFO 1 /* To use extended board_into (bd_t) */
-#define CONFIG_LOOPW 1 /* enable loopw command */
#define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */
diff --git a/include/configs/CPCI4052.h b/include/configs/CPCI4052.h index b0281be..51054a1 100644 --- a/include/configs/CPCI4052.h +++ b/include/configs/CPCI4052.h @@ -66,15 +66,12 @@ /* * Command line configuration. */ -#define CONFIG_CMD_DHCP #define CONFIG_CMD_PCI #define CONFIG_CMD_IRQ #define CONFIG_CMD_IDE #define CONFIG_CMD_FAT #define CONFIG_CMD_DATE -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_BSP #define CONFIG_CMD_EEPROM
@@ -129,8 +126,6 @@
#define CONFIG_CMDLINE_EDITING /* add command line history */
-#define CONFIG_LOOPW 1 /* enable loopw command */ - #define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */
#define CONFIG_VERSION_VARIABLE 1 /* include version env variable */ diff --git a/include/configs/M5208EVBE.h b/include/configs/M5208EVBE.h index b38a349..cc7aeb8 100644 --- a/include/configs/M5208EVBE.h +++ b/include/configs/M5208EVBE.h @@ -23,9 +23,7 @@
/* Command line configuration */ #define CONFIG_CMD_CACHE -#undef CONFIG_CMD_I2C #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO
#define CONFIG_MCFFEC diff --git a/include/configs/M52277EVB.h b/include/configs/M52277EVB.h index f2ea9a8..133f15c 100644 --- a/include/configs/M52277EVB.h +++ b/include/configs/M52277EVB.h @@ -39,13 +39,9 @@ /* Command line configuration */ #define CONFIG_CMD_CACHE #define CONFIG_CMD_DATE -#define CONFIG_CMD_I2C #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_REGINFO -#undef CONFIG_CMD_USB #undef CONFIG_CMD_BMP -#define CONFIG_CMD_SPI -#define CONFIG_CMD_SF
#define CONFIG_HOSTNAME M52277EVB #define CONFIG_SYS_UBOOT_END 0x3FFFF diff --git a/include/configs/M5235EVB.h b/include/configs/M5235EVB.h index 2a198e5..efc7827 100644 --- a/include/configs/M5235EVB.h +++ b/include/configs/M5235EVB.h @@ -36,11 +36,8 @@
/* Command line configuration */ #define CONFIG_CMD_CACHE -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII #define CONFIG_CMD_PCI -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO
diff --git a/include/configs/M5249EVB.h b/include/configs/M5249EVB.h index a93bafc..e29cb24 100644 --- a/include/configs/M5249EVB.h +++ b/include/configs/M5249EVB.h @@ -55,7 +55,6 @@ #define CONFIG_SYS_DEVICE_NULLDEV 1 /* include nulldev device */ #define CONFIG_SYS_CONSOLE_INFO_QUIET 1 /* don't print console @ startup */ #define CONFIG_AUTO_COMPLETE 1 /* add autocompletion support */ -#define CONFIG_LOOPW 1 /* enable loopw command */ #define CONFIG_MX_CYCLIC 1 /* enable mdc/mwc commands */
#define CONFIG_SYS_LOAD_ADDR 0x200000 /* default load address */ diff --git a/include/configs/M5253DEMO.h b/include/configs/M5253DEMO.h index ddb5cda..ada212c 100644 --- a/include/configs/M5253DEMO.h +++ b/include/configs/M5253DEMO.h @@ -43,7 +43,6 @@ #define CONFIG_CMD_EXT2 #define CONFIG_CMD_FAT #define CONFIG_CMD_IDE -#define CONFIG_CMD_PING
#ifdef CONFIG_CMD_IDE /* ATA */ diff --git a/include/configs/M5272C3.h b/include/configs/M5272C3.h index 718f31f..fcb0587 100644 --- a/include/configs/M5272C3.h +++ b/include/configs/M5272C3.h @@ -58,8 +58,6 @@ */ #define CONFIG_CMD_CACHE #define CONFIG_CMD_MII -#define CONFIG_CMD_PING -
#define CONFIG_BOOTDELAY 5 #define CONFIG_MCFFEC diff --git a/include/configs/M5275EVB.h b/include/configs/M5275EVB.h index 195595f..5f055e7 100644 --- a/include/configs/M5275EVB.h +++ b/include/configs/M5275EVB.h @@ -56,10 +56,7 @@
/* Available command configuration */ #define CONFIG_CMD_CACHE -#define CONFIG_CMD_PING #define CONFIG_CMD_MII -#define CONFIG_CMD_I2C -#define CONFIG_CMD_DHCP
#define CONFIG_MCFFEC diff --git a/include/configs/M5282EVB.h b/include/configs/M5282EVB.h index eff0aa6..3442723 100644 --- a/include/configs/M5282EVB.h +++ b/include/configs/M5282EVB.h @@ -48,7 +48,6 @@ * Command line configuration. */ #define CONFIG_CMD_CACHE -#define CONFIG_CMD_PING #define CONFIG_CMD_MII
#define CONFIG_MCFFEC diff --git a/include/configs/M53017EVB.h b/include/configs/M53017EVB.h index 42cbb0f..c90ea27 100644 --- a/include/configs/M53017EVB.h +++ b/include/configs/M53017EVB.h @@ -29,9 +29,7 @@ /* Command line configuration */ #define CONFIG_CMD_CACHE #define CONFIG_CMD_DATE -#undef CONFIG_CMD_I2C #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO
#define CONFIG_SYS_UNIFY_CACHE diff --git a/include/configs/M5329EVB.h b/include/configs/M5329EVB.h index b2d544c..0e0e109 100644 --- a/include/configs/M5329EVB.h +++ b/include/configs/M5329EVB.h @@ -29,9 +29,7 @@ /* Command line configuration */ #define CONFIG_CMD_CACHE #define CONFIG_CMD_DATE -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO
#ifdef CONFIG_NANDFLASH_SIZE diff --git a/include/configs/M5373EVB.h b/include/configs/M5373EVB.h index a906204..39733f9 100644 --- a/include/configs/M5373EVB.h +++ b/include/configs/M5373EVB.h @@ -29,9 +29,7 @@ /* Command line configuration */ #define CONFIG_CMD_CACHE #define CONFIG_CMD_DATE -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO
#ifdef CONFIG_NANDFLASH_SIZE diff --git a/include/configs/M54418TWR.h b/include/configs/M54418TWR.h index 9b87de6..933b8cd 100644 --- a/include/configs/M54418TWR.h +++ b/include/configs/M54418TWR.h @@ -40,17 +40,11 @@ /* Command line configuration */ #define CONFIG_CMD_CACHE #undef CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP -#undef CONFIG_CMD_I2C #undef CONFIG_CMD_JFFS2 #undef CONFIG_CMD_UBI #define CONFIG_CMD_MII #undef CONFIG_CMD_NAND -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO -#define CONFIG_CMD_SPI -#define CONFIG_CMD_SF -
/* * NAND FLASH diff --git a/include/configs/M54451EVB.h b/include/configs/M54451EVB.h index c778823..3b01bd6 100644 --- a/include/configs/M54451EVB.h +++ b/include/configs/M54451EVB.h @@ -41,15 +41,9 @@ /* Command line configuration */ #define CONFIG_CMD_CACHE #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_I2C #undef CONFIG_CMD_JFFS2 #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO -#define CONFIG_CMD_SPI -#define CONFIG_CMD_SF -
/* Network configuration */ #define CONFIG_MCFFEC diff --git a/include/configs/M54455EVB.h b/include/configs/M54455EVB.h index 7941040..8a7cea5 100644 --- a/include/configs/M54455EVB.h +++ b/include/configs/M54455EVB.h @@ -41,19 +41,13 @@ /* Command line configuration */ #define CONFIG_CMD_CACHE #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EXT2 #define CONFIG_CMD_FAT -#define CONFIG_CMD_I2C #define CONFIG_CMD_IDE #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_MII #undef CONFIG_CMD_PCI -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO -#define CONFIG_CMD_SPI -#define CONFIG_CMD_SF -
/* Network configuration */ #define CONFIG_MCFFEC diff --git a/include/configs/M5475EVB.h b/include/configs/M5475EVB.h index 81ecbc8..ff8420f 100644 --- a/include/configs/M5475EVB.h +++ b/include/configs/M5475EVB.h @@ -31,12 +31,9 @@ /* Command line configuration */ #define CONFIG_CMD_CACHE #undef CONFIG_CMD_DATE -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII #define CONFIG_CMD_PCI -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO -#define CONFIG_CMD_USB
#define CONFIG_SLTTMR
diff --git a/include/configs/M5485EVB.h b/include/configs/M5485EVB.h index 8621d7a..9c83d17 100644 --- a/include/configs/M5485EVB.h +++ b/include/configs/M5485EVB.h @@ -31,12 +31,9 @@ /* Command line configuration */ #define CONFIG_CMD_CACHE #undef CONFIG_CMD_DATE -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII #define CONFIG_CMD_PCI -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO -#define CONFIG_CMD_USB
diff --git a/include/configs/MIP405.h b/include/configs/MIP405.h index 5726605..8e2bd85 100644 --- a/include/configs/MIP405.h +++ b/include/configs/MIP405.h @@ -52,22 +52,18 @@ */ #define CONFIG_CMD_CACHE #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EEPROM #define CONFIG_CMD_FAT -#define CONFIG_CMD_I2C #define CONFIG_CMD_IDE #define CONFIG_CMD_IRQ #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_MII #define CONFIG_CMD_PCI -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO #define CONFIG_CMD_SAVES #define CONFIG_CMD_BSP
#if !defined(CONFIG_MIP405T) - #define CONFIG_CMD_USB #endif
diff --git a/include/configs/MPC8308RDB.h b/include/configs/MPC8308RDB.h index fc625d4..422f223 100644 --- a/include/configs/MPC8308RDB.h +++ b/include/configs/MPC8308RDB.h @@ -339,9 +339,7 @@ * due to a pinmux conflict between GPIO9 (SPI chip select )and the TSEC2 pins. */ #ifdef CONFIG_MPC8XXX_SPI -#define CONFIG_CMD_SPI #define CONFIG_USE_SPIFLASH -#define CONFIG_CMD_SF #endif
/* @@ -432,11 +430,8 @@ * Command line configuration. */ #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII #define CONFIG_CMD_PCI -#define CONFIG_CMD_PING
#define CONFIG_CMDLINE_EDITING 1 /* add command line history */
diff --git a/include/configs/MPC8313ERDB.h b/include/configs/MPC8313ERDB.h index a3cfe6a..536fc06 100644 --- a/include/configs/MPC8313ERDB.h +++ b/include/configs/MPC8313ERDB.h @@ -478,9 +478,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII #define CONFIG_CMD_DATE #define CONFIG_CMD_PCI diff --git a/include/configs/MPC8315ERDB.h b/include/configs/MPC8315ERDB.h index a05ce63..9cb8012 100644 --- a/include/configs/MPC8315ERDB.h +++ b/include/configs/MPC8315ERDB.h @@ -372,7 +372,6 @@ #define CONFIG_HAS_FSL_DR_USB #define CONFIG_SYS_SCCR_USBDRCM 3
-#define CONFIG_CMD_USB #define CONFIG_USB_STORAGE #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_FSL @@ -459,8 +458,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_PING -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII #define CONFIG_CMD_DATE #define CONFIG_CMD_PCI diff --git a/include/configs/MPC8323ERDB.h b/include/configs/MPC8323ERDB.h index 8b95920..f815b20 100644 --- a/include/configs/MPC8323ERDB.h +++ b/include/configs/MPC8323ERDB.h @@ -326,8 +326,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_PING -#define CONFIG_CMD_I2C #define CONFIG_CMD_EEPROM #define CONFIG_CMD_ASKENV
diff --git a/include/configs/MPC832XEMDS.h b/include/configs/MPC832XEMDS.h index 4e5e986..c1eb442 100644 --- a/include/configs/MPC832XEMDS.h +++ b/include/configs/MPC832XEMDS.h @@ -411,8 +411,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_PING -#define CONFIG_CMD_I2C #define CONFIG_CMD_ASKENV
#if defined(CONFIG_PCI) diff --git a/include/configs/MPC8349EMDS.h b/include/configs/MPC8349EMDS.h index 9bf4226..7e0cb2a 100644 --- a/include/configs/MPC8349EMDS.h +++ b/include/configs/MPC8349EMDS.h @@ -477,8 +477,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_PING -#define CONFIG_CMD_I2C #define CONFIG_CMD_DATE #define CONFIG_CMD_MII
diff --git a/include/configs/MPC8349ITX.h b/include/configs/MPC8349ITX.h index 8cdfcea..447974c 100644 --- a/include/configs/MPC8349ITX.h +++ b/include/configs/MPC8349ITX.h @@ -151,7 +151,6 @@ /* * Support USB */ -#define CONFIG_CMD_USB #define CONFIG_USB_STORAGE #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_FSL @@ -492,8 +491,6 @@ boards, we say we have two, but don't display a message if we find only one. */ #define CONFIG_CMD_CACHE #define CONFIG_CMD_DATE #define CONFIG_CMD_IRQ -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP #define CONFIG_CMD_SDRAM
#if defined(CONFIG_COMPACT_FLASH) || defined(CONFIG_SATA_SIL3114) \ @@ -519,10 +516,6 @@ boards, we say we have two, but don't display a message if we find only one. */ #define CONFIG_CMD_PCI #endif
-#ifdef CONFIG_SYS_I2C - #define CONFIG_CMD_I2C -#endif - /* Watchdog */ #undef CONFIG_WATCHDOG /* watchdog disabled */
diff --git a/include/configs/MPC837XEMDS.h b/include/configs/MPC837XEMDS.h index 68a8e71..09dd4c6 100644 --- a/include/configs/MPC837XEMDS.h +++ b/include/configs/MPC837XEMDS.h @@ -379,7 +379,6 @@ extern int board_pci_host_broken(void); #define CONFIG_PQ_MDS_PIB 1 /* PQ MDS Platform IO Board */
#define CONFIG_HAS_FSL_DR_USB 1 /* fixup device tree for the DR USB */ -#define CONFIG_CMD_USB #define CONFIG_USB_STORAGE #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_FSL @@ -480,8 +479,6 @@ extern int board_pci_host_broken(void); /* * Command line configuration. */ -#define CONFIG_CMD_PING -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII #define CONFIG_CMD_DATE
diff --git a/include/configs/MPC837XERDB.h b/include/configs/MPC837XERDB.h index 366febc..ff6c962 100644 --- a/include/configs/MPC837XERDB.h +++ b/include/configs/MPC837XERDB.h @@ -490,8 +490,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_PING -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII #define CONFIG_CMD_DATE
@@ -670,7 +668,6 @@ #define CONFIG_ENV_OVERWRITE
#define CONFIG_HAS_FSL_DR_USB -#define CONFIG_CMD_USB #define CONFIG_USB_STORAGE #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_FSL diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index 27db9ef..c19e991 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -411,7 +411,6 @@ #define CONFIG_HARD_SPI
#if defined(CONFIG_SPI_FLASH) -#define CONFIG_CMD_SF #define CONFIG_SF_DEFAULT_SPEED 10000000 #define CONFIG_SF_DEFAULT_MODE 0 #endif @@ -619,8 +618,6 @@ * Command line configuration. */ #define CONFIG_CMD_IRQ -#define CONFIG_CMD_PING -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII #define CONFIG_CMD_IRQ #define CONFIG_CMD_REGINFO @@ -648,7 +645,6 @@ #define CONFIG_USB_EHCI
#ifdef CONFIG_USB_EHCI -#define CONFIG_CMD_USB #define CONFIG_EHCI_HCD_INIT_AFTER_RESET #define CONFIG_USB_EHCI_FSL #define CONFIG_USB_STORAGE diff --git a/include/configs/MPC8540ADS.h b/include/configs/MPC8540ADS.h index 06d54a9..6e715f6 100644 --- a/include/configs/MPC8540ADS.h +++ b/include/configs/MPC8540ADS.h @@ -339,8 +339,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_PING -#define CONFIG_CMD_I2C #define CONFIG_CMD_IRQ
#if defined(CONFIG_PCI) diff --git a/include/configs/MPC8541CDS.h b/include/configs/MPC8541CDS.h index dd638eb..1187310 100644 --- a/include/configs/MPC8541CDS.h +++ b/include/configs/MPC8541CDS.h @@ -357,8 +357,6 @@ extern unsigned long get_clock_freq(void); /* * Command line configuration. */ -#define CONFIG_CMD_PING -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII #define CONFIG_CMD_IRQ #define CONFIG_CMD_REGINFO diff --git a/include/configs/MPC8544DS.h b/include/configs/MPC8544DS.h index 4d56284..535f648 100644 --- a/include/configs/MPC8544DS.h +++ b/include/configs/MPC8544DS.h @@ -372,8 +372,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); /* * Command line configuration. */ -#define CONFIG_CMD_PING -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII #define CONFIG_CMD_IRQ #define CONFIG_CMD_REGINFO @@ -390,7 +388,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_USB_EHCI
#ifdef CONFIG_USB_EHCI -#define CONFIG_CMD_USB #define CONFIG_USB_EHCI_PCI #define CONFIG_EHCI_HCD_INIT_AFTER_RESET #define CONFIG_USB_STORAGE diff --git a/include/configs/MPC8548CDS.h b/include/configs/MPC8548CDS.h index a4868f9..8085969 100644 --- a/include/configs/MPC8548CDS.h +++ b/include/configs/MPC8548CDS.h @@ -483,8 +483,6 @@ extern unsigned long get_clock_freq(void); /* * Command line configuration. */ -#define CONFIG_CMD_PING -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII #define CONFIG_CMD_IRQ #define CONFIG_CMD_REGINFO diff --git a/include/configs/MPC8555CDS.h b/include/configs/MPC8555CDS.h index 3bce162..d24309a 100644 --- a/include/configs/MPC8555CDS.h +++ b/include/configs/MPC8555CDS.h @@ -355,8 +355,6 @@ extern unsigned long get_clock_freq(void); /* * Command line configuration. */ -#define CONFIG_CMD_PING -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII #define CONFIG_CMD_IRQ #define CONFIG_CMD_REGINFO diff --git a/include/configs/MPC8560ADS.h b/include/configs/MPC8560ADS.h index a5a3dc4..c0841db 100644 --- a/include/configs/MPC8560ADS.h +++ b/include/configs/MPC8560ADS.h @@ -376,8 +376,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_PING -#define CONFIG_CMD_I2C #define CONFIG_CMD_IRQ #define CONFIG_CMD_REGINFO
diff --git a/include/configs/MPC8568MDS.h b/include/configs/MPC8568MDS.h index 24c32ca..47b0955 100644 --- a/include/configs/MPC8568MDS.h +++ b/include/configs/MPC8568MDS.h @@ -377,8 +377,6 @@ extern unsigned long get_clock_freq(void); /* * Command line configuration. */ -#define CONFIG_CMD_PING -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII #define CONFIG_CMD_IRQ #define CONFIG_CMD_REGINFO diff --git a/include/configs/MPC8569MDS.h b/include/configs/MPC8569MDS.h index 1224a20..51abcab 100644 --- a/include/configs/MPC8569MDS.h +++ b/include/configs/MPC8569MDS.h @@ -467,8 +467,6 @@ extern unsigned long get_clock_freq(void); /* * Command line configuration. */ -#define CONFIG_CMD_PING -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII #define CONFIG_CMD_IRQ #define CONFIG_CMD_REGINFO diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index 10ee862..fe9d4cd 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -576,8 +576,6 @@ */ #define CONFIG_CMD_ERRATA #define CONFIG_CMD_IRQ -#define CONFIG_CMD_PING -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO
@@ -593,7 +591,6 @@ #define CONFIG_USB_EHCI
#ifdef CONFIG_USB_EHCI -#define CONFIG_CMD_USB #define CONFIG_USB_EHCI_PCI #define CONFIG_EHCI_HCD_INIT_AFTER_RESET #define CONFIG_USB_STORAGE diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h index 7528456..b40d72f 100644 --- a/include/configs/MPC8610HPCD.h +++ b/include/configs/MPC8610HPCD.h @@ -455,15 +455,12 @@ /* * Command line configuration. */ -#define CONFIG_CMD_PING -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII
#if defined(CONFIG_PCI) #define CONFIG_CMD_PCI #define CONFIG_CMD_SCSI #define CONFIG_CMD_EXT2 -#define CONFIG_CMD_USB #endif
diff --git a/include/configs/MPC8641HPCN.h b/include/configs/MPC8641HPCN.h index 1f2505f..6f70bd1 100644 --- a/include/configs/MPC8641HPCN.h +++ b/include/configs/MPC8641HPCN.h @@ -613,15 +613,12 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); /* * Command line configuration. */ -#define CONFIG_CMD_PING -#define CONFIG_CMD_I2C #define CONFIG_CMD_REGINFO
#if defined(CONFIG_PCI) #define CONFIG_CMD_PCI #define CONFIG_CMD_SCSI #define CONFIG_CMD_EXT2 - #define CONFIG_CMD_USB #endif
diff --git a/include/configs/MigoR.h b/include/configs/MigoR.h index f1af928..f4c9312 100644 --- a/include/configs/MigoR.h +++ b/include/configs/MigoR.h @@ -13,7 +13,6 @@ #define CONFIG_CPU_SH7722 1 #define CONFIG_MIGO_R 1
-#define CONFIG_CMD_PING #define CONFIG_CMD_SDRAM
#define CONFIG_BAUDRATE 115200 diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index 6e69258..fcb1644 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -653,15 +653,12 @@ extern unsigned long get_sdram_size(void); #define CONFIG_RTC_PT7C4338 #define CONFIG_SYS_I2C_RTC_ADDR 0x68
-#define CONFIG_CMD_I2C - /* * SPI interface will not be available in case of NAND boot SPI CS0 will be * used for SLIC */ #if !defined(CONFIG_NAND) || !defined(CONFIG_NAND_SECBOOT) /* eSPI - Enhanced SPI */ -#define CONFIG_CMD_SF #define CONFIG_SF_DEFAULT_SPEED 10000000 #define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 #endif @@ -736,7 +733,6 @@ extern unsigned long get_sdram_size(void); #define CONFIG_USB_EHCI
#ifdef CONFIG_USB_EHCI -#define CONFIG_CMD_USB #define CONFIG_EHCI_HCD_INIT_AFTER_RESET #define CONFIG_USB_EHCI_FSL #define CONFIG_USB_STORAGE @@ -796,7 +792,6 @@ extern unsigned long get_sdram_size(void); #define CONFIG_CMD_ERRATA #define CONFIG_CMD_IRQ #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO
#undef CONFIG_WATCHDOG /* watchdog disabled */ diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index d009913..5272878 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -466,7 +466,6 @@
@@ -662,9 +661,7 @@ */ #define CONFIG_CMD_ERRATA #define CONFIG_CMD_IRQ -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO
#ifdef CONFIG_PCI @@ -679,7 +676,6 @@ #define CONFIG_USB_EHCI
#ifdef CONFIG_USB_EHCI -#define CONFIG_CMD_USB #define CONFIG_EHCI_HCD_INIT_AFTER_RESET #define CONFIG_USB_EHCI_FSL #define CONFIG_USB_STORAGE diff --git a/include/configs/P1023RDB.h b/include/configs/P1023RDB.h index 833affd..74cb57d 100644 --- a/include/configs/P1023RDB.h +++ b/include/configs/P1023RDB.h @@ -193,8 +193,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 #define CONFIG_SYS_EEPROM_BUS_NUM 0
-#define CONFIG_CMD_I2C - /* * General PCI * Memory space is mapped 1-1, but I/O space must start from 0. @@ -255,7 +253,6 @@ extern unsigned long get_clock_freq(void); * Command line configuration. */ #define CONFIG_CMD_IRQ -#define CONFIG_CMD_PING #define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO
@@ -271,7 +268,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_USB_EHCI
#ifdef CONFIG_USB_EHCI -#define CONFIG_CMD_USB #define CONFIG_EHCI_HCD_INIT_AFTER_RESET #define CONFIG_USB_EHCI_FSL #define CONFIG_USB_STORAGE diff --git a/include/configs/P2041RDB.h b/include/configs/P2041RDB.h index 6f9680f..43709e8 100644 --- a/include/configs/P2041RDB.h +++ b/include/configs/P2041RDB.h @@ -397,7 +397,6 @@ unsigned long get_board_sys_clk(unsigned long dummy); /* * eSPI - Enhanced SPI */ -#define CONFIG_CMD_SF #define CONFIG_SF_DEFAULT_SPEED 10000000 #define CONFIG_SF_DEFAULT_MODE 0
@@ -601,13 +600,10 @@ unsigned long get_board_sys_clk(unsigned long dummy); /* * Command line configuration. */ -#define CONFIG_CMD_DHCP #define CONFIG_CMD_ERRATA #define CONFIG_CMD_GREPENV #define CONFIG_CMD_IRQ -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII -#define CONFIG_CMD_PING
#ifdef CONFIG_PCI #define CONFIG_CMD_PCI @@ -620,7 +616,6 @@ unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_HAS_FSL_MPH_USB
#if defined(CONFIG_HAS_FSL_DR_USB) || defined(CONFIG_HAS_FSL_MPH_USB) -#define CONFIG_CMD_USB #define CONFIG_USB_STORAGE #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_FSL diff --git a/include/configs/PIP405.h b/include/configs/PIP405.h index 5d639b1..5290208 100644 --- a/include/configs/PIP405.h +++ b/include/configs/PIP405.h @@ -41,21 +41,17 @@ * Command line configuration. */ #define CONFIG_CMD_IDE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_PCI #define CONFIG_CMD_CACHE #define CONFIG_CMD_IRQ #define CONFIG_CMD_EEPROM -#define CONFIG_CMD_I2C #define CONFIG_CMD_REGINFO #define CONFIG_CMD_FDC #define CONFIG_CMD_SCSI #define CONFIG_CMD_FAT #define CONFIG_CMD_DATE -#define CONFIG_CMD_USB #define CONFIG_CMD_MII #define CONFIG_CMD_SDRAM -#define CONFIG_CMD_PING #define CONFIG_CMD_SAVES #define CONFIG_CMD_BSP
diff --git a/include/configs/PLU405.h b/include/configs/PLU405.h index 0e6ad7a..c775100 100644 --- a/include/configs/PLU405.h +++ b/include/configs/PLU405.h @@ -60,18 +60,14 @@ /* * Command line configuration. */ -#define CONFIG_CMD_DHCP #define CONFIG_CMD_PCI #define CONFIG_CMD_IRQ #define CONFIG_CMD_IDE #define CONFIG_CMD_FAT #define CONFIG_CMD_NAND #define CONFIG_CMD_DATE -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_EEPROM -#define CONFIG_CMD_USB
#define CONFIG_MAC_PARTITION #define CONFIG_DOS_PARTITION diff --git a/include/configs/PMC405DE.h b/include/configs/PMC405DE.h index bb0c8bb..a4d7bee 100644 --- a/include/configs/PMC405DE.h +++ b/include/configs/PMC405DE.h @@ -56,13 +56,10 @@ #define CONFIG_CMD_BSP #define CONFIG_CMD_CHIP_CONFIG #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EEPROM -#define CONFIG_CMD_I2C #define CONFIG_CMD_IRQ #define CONFIG_CMD_MII #define CONFIG_CMD_PCI -#define CONFIG_CMD_PING
#undef CONFIG_WATCHDOG /* watchdog disabled */ #define CONFIG_SDRAM_BANK0 1 /* init onboard SDRAM bank 0 */ @@ -96,7 +93,6 @@ #define CONFIG_SYS_EXTBDINFO 1 /* To use extended board_into (bd_t) */
#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ -#define CONFIG_LOOPW 1 /* enable loopw command */ #define CONFIG_MX_CYCLIC 1 /* enable mdc/mwc commands */ #define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ #define CONFIG_VERSION_VARIABLE 1 /* include version env variable */ diff --git a/include/configs/PMC440.h b/include/configs/PMC440.h index dab4fa7..f69eee6 100644 --- a/include/configs/PMC440.h +++ b/include/configs/PMC440.h @@ -270,16 +270,12 @@
#define CONFIG_CMD_BSP #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_DTT #define CONFIG_CMD_EEPROM #define CONFIG_CMD_FAT -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII #define CONFIG_CMD_NAND #define CONFIG_CMD_PCI -#define CONFIG_CMD_PING -#define CONFIG_CMD_USB #define CONFIG_CMD_REGINFO
/* POST support */ @@ -319,7 +315,6 @@ #define CONFIG_SYS_EXTBDINFO 1 /* To use extended board_into (bd_t) */
#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ -#define CONFIG_LOOPW 1 /* enable loopw command */ #define CONFIG_MX_CYCLIC 1 /* enable mdc/mwc commands */ #define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ #define CONFIG_VERSION_VARIABLE 1 /* include version env variable */ diff --git a/include/configs/T102xQDS.h b/include/configs/T102xQDS.h index 800c246..90572f4 100644 --- a/include/configs/T102xQDS.h +++ b/include/configs/T102xQDS.h @@ -569,7 +569,6 @@ unsigned long get_board_ddr_clk(void); */ #ifndef CONFIG_SPL_BUILD #endif -#define CONFIG_CMD_SF #define CONFIG_SPI_FLASH_BAR #define CONFIG_SF_DEFAULT_SPEED 10000000 #define CONFIG_SF_DEFAULT_MODE 0 @@ -679,7 +678,6 @@ unsigned long get_board_ddr_clk(void);
#ifdef CONFIG_HAS_FSL_DR_USB #define CONFIG_USB_EHCI -#define CONFIG_CMD_USB #define CONFIG_USB_STORAGE #define CONFIG_USB_EHCI_FSL #define CONFIG_EHCI_HCD_INIT_AFTER_RESET @@ -831,14 +829,11 @@ unsigned long get_board_ddr_clk(void); * Command line configuration. */ #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EEPROM #define CONFIG_CMD_ERRATA #define CONFIG_CMD_GREPENV #define CONFIG_CMD_IRQ -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO
#ifdef CONFIG_PCI diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index d288a9f..846ad39 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -239,7 +239,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_MEM_INIT_VALUE 0xdeadbeef #endif
-#define CONFIG_CMD_MEMTEST #define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x00400000 #define CONFIG_SYS_ALT_MEMTEST @@ -556,10 +555,6 @@ unsigned long get_board_ddr_clk(void); /* * eSPI - Enhanced SPI */ -#if defined(CONFIG_T1024RDB) -#elif defined(CONFIG_T1023RDB) -#endif -#define CONFIG_CMD_SF #define CONFIG_SPI_FLASH_BAR #define CONFIG_SF_DEFAULT_SPEED 10000000 #define CONFIG_SF_DEFAULT_MODE 0 @@ -676,7 +671,6 @@ unsigned long get_board_ddr_clk(void);
#ifdef CONFIG_HAS_FSL_DR_USB #define CONFIG_USB_EHCI -#define CONFIG_CMD_USB #define CONFIG_USB_STORAGE #define CONFIG_USB_EHCI_FSL #define CONFIG_EHCI_HCD_INIT_AFTER_RESET @@ -834,14 +828,11 @@ unsigned long get_board_ddr_clk(void); * Command line configuration. */ #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EEPROM #define CONFIG_CMD_ERRATA #define CONFIG_CMD_GREPENV #define CONFIG_CMD_IRQ -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO
#ifdef CONFIG_PCI diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index 5a4382e..04c564f 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -469,7 +469,6 @@ unsigned long get_board_ddr_clk(void); /* * eSPI - Enhanced SPI */ -#define CONFIG_CMD_SF #define CONFIG_SF_DEFAULT_SPEED 10000000 #define CONFIG_SF_DEFAULT_MODE 0
@@ -562,7 +561,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_USB_EHCI
#ifdef CONFIG_USB_EHCI -#define CONFIG_CMD_USB #define CONFIG_USB_STORAGE #define CONFIG_USB_EHCI_FSL #define CONFIG_EHCI_HCD_INIT_AFTER_RESET @@ -704,14 +702,11 @@ unsigned long get_board_ddr_clk(void); * Command line configuration. */ #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EEPROM #define CONFIG_CMD_ERRATA #define CONFIG_CMD_GREPENV #define CONFIG_CMD_IRQ -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO
#ifdef CONFIG_PCI diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 0ba3913..1e61ec9 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -525,7 +525,6 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_rcw.cfg * eSPI - Enhanced SPI */ #define CONFIG_SPI_FLASH_BAR -#define CONFIG_CMD_SF #define CONFIG_SF_DEFAULT_SPEED 10000000 #define CONFIG_SF_DEFAULT_MODE 0 #define CONFIG_ENV_SPI_BUS 0 @@ -619,7 +618,6 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_rcw.cfg #define CONFIG_USB_EHCI
#ifdef CONFIG_USB_EHCI -#define CONFIG_CMD_USB #define CONFIG_USB_STORAGE #define CONFIG_USB_EHCI_FSL #define CONFIG_EHCI_HCD_INIT_AFTER_RESET @@ -771,13 +769,10 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_rcw.cfg #ifdef CONFIG_T1042RDB_PI #define CONFIG_CMD_DATE #endif -#define CONFIG_CMD_DHCP #define CONFIG_CMD_ERRATA #define CONFIG_CMD_GREPENV #define CONFIG_CMD_IRQ -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO
#ifdef CONFIG_PCI diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index 69d161b..b1bd4fd 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -540,7 +540,6 @@ unsigned long get_board_ddr_clk(void); #ifndef CONFIG_SPL_BUILD #endif
-#define CONFIG_CMD_SF #define CONFIG_SPI_FLASH_BAR #define CONFIG_SF_DEFAULT_SPEED 10000000 #define CONFIG_SF_DEFAULT_MODE 0 @@ -721,7 +720,6 @@ unsigned long get_board_ddr_clk(void); * USB */ #ifdef CONFIG_USB_EHCI -#define CONFIG_CMD_USB #define CONFIG_USB_STORAGE #define CONFIG_USB_EHCI_FSL #define CONFIG_EHCI_HCD_INIT_AFTER_RESET @@ -772,13 +770,10 @@ unsigned long get_board_ddr_clk(void); /* * Command line configuration. */ -#define CONFIG_CMD_DHCP #define CONFIG_CMD_ERRATA #define CONFIG_CMD_GREPENV #define CONFIG_CMD_IRQ -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO
#ifdef CONFIG_PCI diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index df4c5dc..dc6e211 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -138,7 +138,6 @@ #define CONFIG_MEM_INIT_VALUE 0xdeadbeef #endif
-#define CONFIG_CMD_MEMTEST #define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x00400000 #define CONFIG_SYS_ALT_MEMTEST @@ -492,7 +491,6 @@ unsigned long get_board_ddr_clk(void); */ #ifdef CONFIG_SPI_FLASH #define CONFIG_SPI_FLASH_BAR -#define CONFIG_CMD_SF #define CONFIG_SF_DEFAULT_SPEED 10000000 #define CONFIG_SF_DEFAULT_MODE 0 #endif @@ -684,7 +682,6 @@ unsigned long get_board_ddr_clk(void); * USB */ #ifdef CONFIG_USB_EHCI -#define CONFIG_CMD_USB #define CONFIG_USB_STORAGE #define CONFIG_USB_EHCI_FSL #define CONFIG_EHCI_HCD_INIT_AFTER_RESET @@ -730,11 +727,8 @@ unsigned long get_board_ddr_clk(void); /* * Command line configuration. */ -#define CONFIG_CMD_DHCP #define CONFIG_CMD_ERRATA #define CONFIG_CMD_MII -#define CONFIG_CMD_I2C -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO
#ifdef CONFIG_PCI diff --git a/include/configs/T4240QDS.h b/include/configs/T4240QDS.h index 91857d6..af5855c 100644 --- a/include/configs/T4240QDS.h +++ b/include/configs/T4240QDS.h @@ -401,7 +401,6 @@ unsigned long get_board_ddr_clk(void); /* * eSPI - Enhanced SPI */ -#define CONFIG_CMD_SF #define CONFIG_SF_DEFAULT_SPEED 10000000 #define CONFIG_SF_DEFAULT_MODE 0
@@ -528,7 +527,6 @@ unsigned long get_board_ddr_clk(void); /* * USB */ -#define CONFIG_CMD_USB #define CONFIG_USB_STORAGE #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_FSL diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index e075442..2b50594 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -302,13 +302,10 @@ /* * Command line configuration. */ -#define CONFIG_CMD_DHCP #define CONFIG_CMD_ERRATA #define CONFIG_CMD_GREPENV #define CONFIG_CMD_IRQ -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII -#define CONFIG_CMD_PING
#ifdef CONFIG_PCI #define CONFIG_CMD_PCI @@ -606,7 +603,6 @@ unsigned long get_board_ddr_clk(void); /* * eSPI - Enhanced SPI */ -#define CONFIG_CMD_SF #define CONFIG_SF_DEFAULT_SPEED 10000000 #define CONFIG_SF_DEFAULT_MODE 0
@@ -729,7 +725,6 @@ unsigned long get_board_ddr_clk(void); /* * USB */ -#define CONFIG_CMD_USB #define CONFIG_USB_STORAGE #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_FSL diff --git a/include/configs/TQM5200.h b/include/configs/TQM5200.h index 8fd3a8b..516acd3 100644 --- a/include/configs/TQM5200.h +++ b/include/configs/TQM5200.h @@ -130,7 +130,6 @@ #define CONFIG_SYS_OHCI_BE_CONTROLLER #define CONFIG_USB_STORAGE #define CONFIG_CMD_FAT -#define CONFIG_CMD_USB
#undef CONFIG_SYS_USB_OHCI_BOARD_INIT #define CONFIG_SYS_USB_OHCI_CPU_INIT @@ -167,14 +166,10 @@ */ #define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EEPROM -#define CONFIG_CMD_I2C #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO -#define CONFIG_CMD_SNTP #define CONFIG_CMD_BSP
#ifdef CONFIG_VIDEO @@ -628,11 +623,6 @@ #define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */
/* - * Enable loopw command. - */ -#define CONFIG_LOOPW - -/* * Various low-level settings */ #define CONFIG_SYS_HID0_INIT HID0_ICE | HID0_ICFI diff --git a/include/configs/TQM823L.h b/include/configs/TQM823L.h index 7e3fdda..474ab5f 100644 --- a/include/configs/TQM823L.h +++ b/include/configs/TQM823L.h @@ -107,11 +107,9 @@ */ #define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EXT2 #define CONFIG_CMD_IDE #define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_SNTP
#ifdef CONFIG_SPLASH_SCREEN #define CONFIG_CMD_BMP diff --git a/include/configs/TQM823M.h b/include/configs/TQM823M.h index fc305f4..98b900a 100644 --- a/include/configs/TQM823M.h +++ b/include/configs/TQM823M.h @@ -105,16 +105,12 @@ */ #define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EXT2 #define CONFIG_CMD_IDE #define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_SNTP -
#define CONFIG_NETCONSOLE
- /* * Miscellaneous configurable options */ diff --git a/include/configs/TQM834x.h b/include/configs/TQM834x.h index b9baad6..2becc46 100644 --- a/include/configs/TQM834x.h +++ b/include/configs/TQM834x.h @@ -288,15 +288,11 @@ */ #define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_DTT #define CONFIG_CMD_EEPROM -#define CONFIG_CMD_I2C #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO -#define CONFIG_CMD_SNTP
#if defined(CONFIG_PCI) #define CONFIG_CMD_PCI diff --git a/include/configs/TQM850L.h b/include/configs/TQM850L.h index 472dbb3..8b57f08 100644 --- a/include/configs/TQM850L.h +++ b/include/configs/TQM850L.h @@ -95,12 +95,9 @@ */ #define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EXT2 #define CONFIG_CMD_IDE #define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_SNTP -
diff --git a/include/configs/TQM850M.h b/include/configs/TQM850M.h index 3aec34c..40c60fc 100644 --- a/include/configs/TQM850M.h +++ b/include/configs/TQM850M.h @@ -95,11 +95,9 @@ */ #define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EXT2 #define CONFIG_CMD_IDE #define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_SNTP
#define CONFIG_NETCONSOLE diff --git a/include/configs/TQM855L.h b/include/configs/TQM855L.h index a46f689..cae97c6 100644 --- a/include/configs/TQM855L.h +++ b/include/configs/TQM855L.h @@ -98,16 +98,12 @@ */ #define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EXT2 #define CONFIG_CMD_IDE #define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_SNTP -
- /* * Miscellaneous configurable options */ diff --git a/include/configs/TQM855M.h b/include/configs/TQM855M.h index b44a31b..e6868ef 100644 --- a/include/configs/TQM855M.h +++ b/include/configs/TQM855M.h @@ -127,17 +127,13 @@ */ #define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EXT2 #define CONFIG_CMD_EEPROM #define CONFIG_CMD_IDE #define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_SNTP -
- /* * Miscellaneous configurable options */ diff --git a/include/configs/TQM860L.h b/include/configs/TQM860L.h index cdbae5c..25ce29b 100644 --- a/include/configs/TQM860L.h +++ b/include/configs/TQM860L.h @@ -98,12 +98,9 @@ */ #define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EXT2 #define CONFIG_CMD_IDE #define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_SNTP -
diff --git a/include/configs/TQM860M.h b/include/configs/TQM860M.h index c1866a5..117d1e4 100644 --- a/include/configs/TQM860M.h +++ b/include/configs/TQM860M.h @@ -98,16 +98,12 @@ */ #define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EXT2 #define CONFIG_CMD_IDE #define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_SNTP -
- /* * Miscellaneous configurable options */ diff --git a/include/configs/TQM862L.h b/include/configs/TQM862L.h index 881d654..bb61986b 100644 --- a/include/configs/TQM862L.h +++ b/include/configs/TQM862L.h @@ -101,16 +101,12 @@ */ #define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EXT2 #define CONFIG_CMD_IDE #define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_SNTP -
- /* * Miscellaneous configurable options */ diff --git a/include/configs/TQM862M.h b/include/configs/TQM862M.h index e06de45..ff473e9 100644 --- a/include/configs/TQM862M.h +++ b/include/configs/TQM862M.h @@ -101,16 +101,12 @@ */ #define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EXT2 #define CONFIG_CMD_IDE #define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_SNTP -
- /* * Miscellaneous configurable options */ diff --git a/include/configs/TQM866M.h b/include/configs/TQM866M.h index 6b585f9..78cf804 100644 --- a/include/configs/TQM866M.h +++ b/include/configs/TQM866M.h @@ -140,17 +140,13 @@ * Command line configuration. */ #define CONFIG_CMD_ASKENV -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EEPROM #define CONFIG_CMD_EXT2 #define CONFIG_CMD_IDE #define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_SNTP -
- /* * Miscellaneous configurable options */ diff --git a/include/configs/TQM885D.h b/include/configs/TQM885D.h index 83b094c..778fcf5 100644 --- a/include/configs/TQM885D.h +++ b/include/configs/TQM885D.h @@ -123,7 +123,6 @@ #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_BOOTFILESIZE
- #define CONFIG_MAC_PARTITION #define CONFIG_DOS_PARTITION
@@ -131,20 +130,15 @@
#define CONFIG_TIMESTAMP /* but print image timestmps */
- /* * Command line configuration. */ #define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EEPROM #define CONFIG_CMD_EXT2 -#define CONFIG_CMD_I2C #define CONFIG_CMD_IDE #define CONFIG_CMD_MII -#define CONFIG_CMD_PING -
/* * Miscellaneous configurable options @@ -170,11 +164,6 @@ #define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */
/* - * Enable loopw command. - */ -#define CONFIG_LOOPW - -/* * Low Level Configuration Settings * (address mappings, register initial values, etc.) * You should know what you are doing if you make changes here. diff --git a/include/configs/UCP1020.h b/include/configs/UCP1020.h index a37fbe2..ccdfafa 100644 --- a/include/configs/UCP1020.h +++ b/include/configs/UCP1020.h @@ -366,8 +366,6 @@ */ #define CONFIG_HARD_SPI
-#define CONFIG_CMD_SF 1 -#define CONFIG_CMD_SPI 1 #define CONFIG_SF_DEFAULT_SPEED 10000000 #define CONFIG_SF_DEFAULT_MODE SPI_MODE_0
@@ -470,14 +468,10 @@ * Command line configuration. */ #define CONFIG_CMD_IRQ -#define CONFIG_CMD_PING -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII #define CONFIG_CMD_DATE -#define CONFIG_CMD_I2C #define CONFIG_CMD_IRQ #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO #define CONFIG_CMD_ERRATA #define CONFIG_CMD_CRAMFS @@ -493,7 +487,6 @@ #define CONFIG_USB_MAX_CONTROLLER_COUNT 1
#ifdef CONFIG_USB_EHCI -#define CONFIG_CMD_USB #define CONFIG_EHCI_HCD_INIT_AFTER_RESET #define CONFIG_USB_EHCI_FSL #define CONFIG_USB_STORAGE @@ -564,7 +557,6 @@ #error "UCP1020 module revision is not defined !!!" #endif
-#define CONFIG_CMD_DHCP #define CONFIG_BOOTP_SERVERIP
#define CONFIG_MII /* MII PHY management */ diff --git a/include/configs/VCMA9.h b/include/configs/VCMA9.h index ef47e98..0b6e3f3 100644 --- a/include/configs/VCMA9.h +++ b/include/configs/VCMA9.h @@ -52,12 +52,8 @@ */ #define CONFIG_CMD_CACHE #define CONFIG_CMD_EEPROM -#define CONFIG_CMD_I2C -#define CONFIG_CMD_USB #define CONFIG_CMD_REGINFO #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_PING #define CONFIG_CMD_BSP #define CONFIG_CMD_NAND
diff --git a/include/configs/VOM405.h b/include/configs/VOM405.h index 0ed44a8..e2aa578 100644 --- a/include/configs/VOM405.h +++ b/include/configs/VOM405.h @@ -58,12 +58,9 @@ /* * Command line configuration. */ -#define CONFIG_CMD_DHCP #define CONFIG_CMD_BSP #define CONFIG_CMD_IRQ -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_EEPROM
#undef CONFIG_WATCHDOG /* watchdog disabled */ diff --git a/include/configs/a3m071.h b/include/configs/a3m071.h index df3e06e..f44a20c 100644 --- a/include/configs/a3m071.h +++ b/include/configs/a3m071.h @@ -48,7 +48,6 @@ #define CONFIG_CMD_CACHE #define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO -#define CONFIG_CMD_DHCP #define CONFIG_BOOTP_SEND_HOSTNAME #define CONFIG_BOOTP_SERVERIP #define CONFIG_BOOTP_MAY_FAIL @@ -56,10 +55,8 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_SERVERIP #define CONFIG_NET_RETRY_COUNT 3 -#define CONFIG_CMD_LINK_LOCAL #define CONFIG_NETCONSOLE #define CONFIG_SYS_CONSOLE_IS_IN_ENV -#define CONFIG_CMD_PING #define CONFIG_MTD_DEVICE /* needed for mtdparts commands */ #define CONFIG_MTD_PARTITIONS /* needed for UBI */ #define CONFIG_FLASH_CFI_MTD @@ -255,7 +252,6 @@
#define CONFIG_SYS_LOAD_ADDR 0x00100000
-#define CONFIG_LOOPW #define CONFIG_SYS_CONSOLE_INFO_QUIET /* don't print console @ startup*/
/* diff --git a/include/configs/a4m072.h b/include/configs/a4m072.h index 2b58830..c6a8553 100644 --- a/include/configs/a4m072.h +++ b/include/configs/a4m072.h @@ -94,13 +94,8 @@ */ #define CONFIG_CMD_EEPROM #define CONFIG_CMD_FAT -#define CONFIG_CMD_I2C #define CONFIG_CMD_IDE -#define CONFIG_CMD_SNTP -#define CONFIG_CMD_USB #define CONFIG_CMD_MII -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_PING #define CONFIG_CMD_DISPLAY
#if defined(CONFIG_PCI) diff --git a/include/configs/ac14xx.h b/include/configs/ac14xx.h index 57421c6..8c60f10 100644 --- a/include/configs/ac14xx.h +++ b/include/configs/ac14xx.h @@ -394,15 +394,12 @@ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1
#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EEPROM #undef CONFIG_CMD_FUSE -#define CONFIG_CMD_I2C #undef CONFIG_CMD_IDE #undef CONFIG_CMD_EXT2 #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO
#if defined(CONFIG_PCI) diff --git a/include/configs/acadia.h b/include/configs/acadia.h index 2f53d73..ab9a4ca 100644 --- a/include/configs/acadia.h +++ b/include/configs/acadia.h @@ -167,7 +167,6 @@ */ #define CONFIG_CMD_DTT #define CONFIG_CMD_NAND -#define CONFIG_CMD_USB
/*----------------------------------------------------------------------- * NAND FLASH diff --git a/include/configs/adp-ag101p.h b/include/configs/adp-ag101p.h index f6c0147..95fc41e 100644 --- a/include/configs/adp-ag101p.h +++ b/include/configs/adp-ag101p.h @@ -117,7 +117,6 @@ */ #define CONFIG_CMD_CACHE #define CONFIG_CMD_DATE -#define CONFIG_CMD_PING
/* * Miscellaneous configurable options diff --git a/include/configs/alt.h b/include/configs/alt.h index 6bd2983..b8b9644 100644 --- a/include/configs/alt.h +++ b/include/configs/alt.h @@ -68,7 +68,6 @@ #define CONFIG_SYS_TMU_CLK_DIV 4
/* i2c */ -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_SH #define CONFIG_SYS_I2C_SLAVE 0x7F diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 55f8dc5..bee6b83 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -306,7 +306,6 @@ #endif
#ifdef CONFIG_USB_MUSB_HOST -#define CONFIG_CMD_USB #define CONFIG_USB_STORAGE #endif
@@ -431,7 +430,6 @@ #endif
/* SPI flash. */ -#define CONFIG_CMD_SF #define CONFIG_SF_DEFAULT_SPEED 24000000
/* Network. */ diff --git a/include/configs/am3517_crane.h b/include/configs/am3517_crane.h index 6c1556a..cd6e0fd 100644 --- a/include/configs/am3517_crane.h +++ b/include/configs/am3517_crane.h @@ -100,7 +100,6 @@ #ifdef CONFIG_USB_AM35X
#ifdef CONFIG_USB_MUSB_HCD -#define CONFIG_CMD_USB
#define CONFIG_USB_STORAGE #define CONGIG_CMD_STORAGE @@ -132,11 +131,8 @@ #define CONFIG_CMD_FAT /* FAT support */ #define CONFIG_CMD_JFFS2 /* JFFS2 Support */
-#define CONFIG_CMD_I2C /* I2C serial bus support */ #define CONFIG_CMD_MMC /* MMC support */ #define CONFIG_CMD_NAND /* NAND support */ -#define CONFIG_CMD_DHCP -#undef CONFIG_CMD_PING
#define CONFIG_SYS_NO_FLASH diff --git a/include/configs/am3517_evm.h b/include/configs/am3517_evm.h index 45f016a..2cbf04e 100644 --- a/include/configs/am3517_evm.h +++ b/include/configs/am3517_evm.h @@ -99,7 +99,6 @@ #ifdef CONFIG_USB_MUSB_AM35X
#define CONFIG_USB_STORAGE #define CONGIG_CMD_STORAGE @@ -129,10 +128,7 @@ #define CONFIG_CMD_PART #define CONFIG_CMD_ASKENV #define CONFIG_CMD_BOOTZ -#define CONFIG_CMD_I2C #define CONFIG_CMD_MMC -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_PING #define CONFIG_CMD_MTDPARTS
/* I2C */ diff --git a/include/configs/am43xx_evm.h b/include/configs/am43xx_evm.h index 5d5ae5e..59a9749 100644 --- a/include/configs/am43xx_evm.h +++ b/include/configs/am43xx_evm.h @@ -109,7 +109,6 @@
#if defined(CONFIG_SPL_USB_HOST_SUPPORT) || !defined(CONFIG_SPL_BUILD) #define CONFIG_SYS_USB_FAT_BOOT_PARTITION 1 -#define CONFIG_CMD_USB #define CONFIG_USB_HOST #define CONFIG_USB_XHCI #define CONFIG_USB_XHCI_DWC3 @@ -221,8 +220,6 @@
/* SPI */ #undef CONFIG_OMAP3_SPI -#define CONFIG_CMD_SF -#define CONFIG_CMD_SPI #define CONFIG_TI_SPI_MMAP #define CONFIG_QSPI_SEL_GPIO 48 #define CONFIG_SF_DEFAULT_SPEED 48000000 @@ -323,8 +320,6 @@
#ifndef CONFIG_SPL_BUILD /* CPSW Ethernet */ -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_PING #define CONFIG_CMD_MII #define CONFIG_MII #define CONFIG_BOOTP_DEFAULT diff --git a/include/configs/am57xx_evm.h b/include/configs/am57xx_evm.h index 1fffdb1..099ecdd 100644 --- a/include/configs/am57xx_evm.h +++ b/include/configs/am57xx_evm.h @@ -48,14 +48,12 @@ #define CONFIG_EFI_PARTITION
/* CPSW Ethernet */ -#define CONFIG_CMD_DHCP #define CONFIG_BOOTP_DNS /* Configurable parts of CMD_DHCP */ #define CONFIG_BOOTP_DNS2 #define CONFIG_BOOTP_SEND_HOSTNAME #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_SUBNETMASK #define CONFIG_NET_RETRY_COUNT 10 -#define CONFIG_CMD_PING #define CONFIG_CMD_MII #define CONFIG_DRIVER_TI_CPSW /* Driver for IP block */ #define CONFIG_MII /* Required in net/eth.c */ @@ -66,7 +64,6 @@ #define CONFIG_SUPPORT_EMMC_BOOT
/* USB xHCI HOST */ -#define CONFIG_CMD_USB #define CONFIG_USB_HOST #define CONFIG_USB_XHCI_DWC3 #define CONFIG_USB_XHCI diff --git a/include/configs/amcc-common.h b/include/configs/amcc-common.h index 8b1920d..f97988c 100644 --- a/include/configs/amcc-common.h +++ b/include/configs/amcc-common.h @@ -55,14 +55,11 @@ #if defined(CONFIG_440) #define CONFIG_CMD_CACHE #endif -#define CONFIG_CMD_DHCP #define CONFIG_CMD_DIAG #define CONFIG_CMD_EEPROM #define CONFIG_CMD_GREPENV -#define CONFIG_CMD_I2C #define CONFIG_CMD_IRQ #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO
/* @@ -86,7 +83,6 @@
#define CONFIG_CMDLINE_EDITING /* add command line history */ #define CONFIG_AUTO_COMPLETE /* add autocompletion support */ -#define CONFIG_LOOPW /* enable loopw command */ #define CONFIG_MX_CYCLIC /* enable mdc/mwc commands */ #define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ #define CONFIG_VERSION_VARIABLE /* include version env variable */ diff --git a/include/configs/amcore.h b/include/configs/amcore.h index bbab8b2..3ef7257 100644 --- a/include/configs/amcore.h +++ b/include/configs/amcore.h @@ -23,7 +23,6 @@
#undef CONFIG_CMD_AES #define CONFIG_CMD_CACHE -#define CONFIG_CMD_TIMER #define CONFIG_CMD_DIAG
/* undef to save memory */ @@ -45,7 +44,6 @@
#define CONFIG_SYS_CONSOLE_INFO_QUIET 1 /* no console @ startup */ #define CONFIG_AUTO_COMPLETE 1 /* add autocompletion support */ -#define CONFIG_LOOPW 1 /* enable loopw command */ #define CONFIG_MX_CYCLIC 1 /* enable mdc/mwc commands */
#define CONFIG_SYS_LOAD_ADDR 0x20000 /* default load address */ diff --git a/include/configs/ap325rxa.h b/include/configs/ap325rxa.h index 03810c3..fdcbf31 100644 --- a/include/configs/ap325rxa.h +++ b/include/configs/ap325rxa.h @@ -14,7 +14,6 @@ #define CONFIG_CPU_SH7723 1 #define CONFIG_AP325RXA 1
-#define CONFIG_CMD_PING #define CONFIG_CMD_SDRAM #define CONFIG_CMD_IDE #define CONFIG_CMD_EXT2 diff --git a/include/configs/ap_sh4a_4a.h b/include/configs/ap_sh4a_4a.h index 4bcfb4c..d458705 100644 --- a/include/configs/ap_sh4a_4a.h +++ b/include/configs/ap_sh4a_4a.h @@ -18,7 +18,6 @@ #define CONFIG_BOARD_LATE_INIT #define CONFIG_SYS_TEXT_BASE 0x8BFC0000
-#define CONFIG_CMD_PING #define CONFIG_CMD_MII #define CONFIG_CMD_SDRAM #define CONFIG_CMD_ENV @@ -42,7 +41,6 @@ #define CONFIG_BITBANGMII_MULTI
/* I2C */ -#define CONFIG_CMD_I2C #define CONFIG_SH_SH7734_I2C 1 #define CONFIG_HARD_I2C 1 #define CONFIG_I2C_MULTI_BUS 1 diff --git a/include/configs/apalis_t30.h b/include/configs/apalis_t30.h index 32e9ba3..9c09087 100644 --- a/include/configs/apalis_t30.h +++ b/include/configs/apalis_t30.h @@ -26,7 +26,6 @@
/* I2C */ #define CONFIG_SYS_I2C_TEGRA -#define CONFIG_CMD_I2C
/* SD/MMC support */ #define CONFIG_MMC @@ -44,7 +43,6 @@ #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_TEGRA #define CONFIG_USB_STORAGE -#define CONFIG_CMD_USB
/* PCI host support */ #define CONFIG_PCI @@ -55,7 +53,6 @@ #define CONFIG_E1000_NO_NVM
/* General networking support */ -#define CONFIG_CMD_DHCP #define CONFIG_IP_DEFRAG #define CONFIG_TFTP_BLOCKSIZE 16384 #define CONFIG_TFTP_TSIZE diff --git a/include/configs/apf27.h b/include/configs/apf27.h index fe3b714..f0e88ee 100644 --- a/include/configs/apf27.h +++ b/include/configs/apf27.h @@ -69,20 +69,16 @@ #define CONFIG_CMD_BSP /* Board Specific functions */ #define CONFIG_CMD_CACHE /* icache, dcache */ #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP /* DHCP Support */ -#define CONFIG_CMD_DNS #define CONFIG_CMD_EEPROM #define CONFIG_CMD_EXT2 #define CONFIG_CMD_FAT /* FAT support */ #define CONFIG_CMD_IMX_FUSE /* imx iim fuse */ -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII /* MII support */ #define CONFIG_CMD_MMC #define CONFIG_CMD_MTDPARTS /* MTD partition support */ #define CONFIG_CMD_NAND /* NAND support */ #define CONFIG_CMD_NAND_LOCK_UNLOCK #define CONFIG_CMD_NAND_TRIMFFS -#define CONFIG_CMD_PING /* ping support */ #define CONFIG_CMD_UBI #define CONFIG_CMD_UBIFS
diff --git a/include/configs/apx4devkit.h b/include/configs/apx4devkit.h index 2bbef55..fc7a35e 100644 --- a/include/configs/apx4devkit.h +++ b/include/configs/apx4devkit.h @@ -26,15 +26,11 @@
#define CONFIG_CMD_CACHE #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EXT2 #define CONFIG_CMD_FAT -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII #define CONFIG_CMD_MMC #define CONFIG_CMD_NAND -#define CONFIG_CMD_PING -#define CONFIG_CMD_USB
/* Memory configuration */ #define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ diff --git a/include/configs/aria.h b/include/configs/aria.h index b3050df..b69e08e 100644 --- a/include/configs/aria.h +++ b/include/configs/aria.h @@ -403,14 +403,11 @@ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1
#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EEPROM #undef CONFIG_CMD_FUSE -#define CONFIG_CMD_I2C #undef CONFIG_CMD_IDE #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO
#if defined(CONFIG_PCI) diff --git a/include/configs/aristainetos-common.h b/include/configs/aristainetos-common.h index efbf816..8154b2e 100644 --- a/include/configs/aristainetos-common.h +++ b/include/configs/aristainetos-common.h @@ -29,8 +29,6 @@ /* MMC Configs */ #define CONFIG_SYS_FSL_ESDHC_ADDR 0
-#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP #define CONFIG_CMD_MII #define CONFIG_FEC_MXC #define CONFIG_MII @@ -41,7 +39,6 @@ #define CONFIG_PHYLIB #define CONFIG_PHY_MICREL
-#define CONFIG_CMD_SF #define CONFIG_SPI_FLASH_MTD #define CONFIG_MXC_SPI #define CONFIG_SF_DEFAULT_SPEED 20000000 @@ -185,7 +182,6 @@ #define CONFIG_SYS_FSL_USDHC_NUM 2
/* I2C */ -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC #define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ @@ -216,7 +212,6 @@ #define CONFIG_CMD_DATE
/* USB Configs */ -#define CONFIG_CMD_USB #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_MX6 #define CONFIG_USB_STORAGE diff --git a/include/configs/armadillo-800eva.h b/include/configs/armadillo-800eva.h index 1ce9b9a..e1fe7e6 100644 --- a/include/configs/armadillo-800eva.h +++ b/include/configs/armadillo-800eva.h @@ -19,8 +19,6 @@ #define CONFIG_CMD_DFL #define CONFIG_CMD_SDRAM #define CONFIG_CMD_MII -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP #define CONFIG_CMD_BOOTZ
#define BOARD_LATE_INIT diff --git a/include/configs/aspenite.h b/include/configs/aspenite.h index fcb5f81..c468484 100644 --- a/include/configs/aspenite.h +++ b/include/configs/aspenite.h @@ -35,7 +35,6 @@ * Commands configuration */ #define CONFIG_SYS_NO_FLASH /* Declare no flash (NOR/SPI) */ -#define CONFIG_CMD_I2C /* * mv-common.h should be defined after CMD configs since it used them * to enable certain macros diff --git a/include/configs/astro_mcf5373l.h b/include/configs/astro_mcf5373l.h index 05d41ce..f7fa058 100644 --- a/include/configs/astro_mcf5373l.h +++ b/include/configs/astro_mcf5373l.h @@ -61,7 +61,6 @@
#define CONFIG_CMD_CACHE #define CONFIG_CMD_DATE -#define CONFIG_CMD_I2C #if ENABLE_JFFS #define CONFIG_CMD_JFFS2 #endif diff --git a/include/configs/at91-sama5_common.h b/include/configs/at91-sama5_common.h index c55446d..e260867 100644 --- a/include/configs/at91-sama5_common.h +++ b/include/configs/at91-sama5_common.h @@ -48,8 +48,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP
#ifdef CONFIG_SYS_USE_MMC
diff --git a/include/configs/at91rm9200ek.h b/include/configs/at91rm9200ek.h index 2a5acf5..0d98a44 100644 --- a/include/configs/at91rm9200ek.h +++ b/include/configs/at91rm9200ek.h @@ -120,11 +120,8 @@ /* * Command line configuration. */ -#define CONFIG_CMD_DHCP #define CONFIG_CMD_FAT #define CONFIG_CMD_MII -#define CONFIG_CMD_PING -#define CONFIG_CMD_USB
/* * Network Driver Setting diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index 7820295..2a5301f 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -76,11 +76,8 @@ /* * Command line configuration. */ -#define CONFIG_CMD_PING 1 -#define CONFIG_CMD_DHCP 1 #define CONFIG_CMD_NAND 1 #define CONFIG_CMD_FAT -#define CONFIG_CMD_USB 1
/* * SDRAM: 1 bank, min 32, max 128 MB diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index c7ba9eb..82f90f2 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -82,10 +82,7 @@ /* * Command line configuration. */ -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP #define CONFIG_CMD_NAND -#define CONFIG_CMD_USB
/* SDRAM */ #define CONFIG_NR_DRAM_BANKS 1 diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index 3d39387..c7fac7f 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -91,11 +91,8 @@ /* * Command line configuration. */ -#define CONFIG_CMD_PING 1 -#define CONFIG_CMD_DHCP 1 #define CONFIG_CMD_NAND 1 #define CONFIG_CMD_MMC -#define CONFIG_CMD_USB 1
/* SDRAM */ #define CONFIG_NR_DRAM_BANKS 1 diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index e292632..8bc5144 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -77,10 +77,7 @@
/* No NOR flash */ #define CONFIG_SYS_NO_FLASH -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP #define CONFIG_CMD_NAND -#define CONFIG_CMD_USB
/* SDRAM */ #define CONFIG_NR_DRAM_BANKS 1 diff --git a/include/configs/at91sam9n12ek.h b/include/configs/at91sam9n12ek.h index 9dda777..fdebcc2 100644 --- a/include/configs/at91sam9n12ek.h +++ b/include/configs/at91sam9n12ek.h @@ -68,13 +68,9 @@ * Command line configuration. */ #define CONFIG_CMD_BOOTZ -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP #define CONFIG_CMD_NAND -#define CONFIG_CMD_SF #define CONFIG_CMD_MMC #define CONFIG_CMD_FAT -#define CONFIG_CMD_USB
#define CONFIG_NR_DRAM_BANKS 1 #define CONFIG_SYS_SDRAM_BASE 0x20000000 diff --git a/include/configs/at91sam9rlek.h b/include/configs/at91sam9rlek.h index 0d45354..126b8d4 100644 --- a/include/configs/at91sam9rlek.h +++ b/include/configs/at91sam9rlek.h @@ -73,7 +73,6 @@ /* * Command line configuration. */ -#undef CONFIG_CMD_USB
diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index fcd1008..a4d9cb8 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -65,13 +65,9 @@ /* * Command line configuration. */ -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP #define CONFIG_CMD_NAND -#define CONFIG_CMD_SF #define CONFIG_CMD_MMC #define CONFIG_CMD_FAT -#define CONFIG_CMD_USB
/* * define CONFIG_USB_EHCI to enable USB Hi-Speed (aka 2.0) diff --git a/include/configs/atngw100.h b/include/configs/atngw100.h index 11d7d0c..4118cac 100644 --- a/include/configs/atngw100.h +++ b/include/configs/atngw100.h @@ -81,13 +81,10 @@ * Command line configuration. */ #define CONFIG_CMD_ASKENV -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EXT2 #define CONFIG_CMD_FAT #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_MMC -#define CONFIG_CMD_SF -#define CONFIG_CMD_SPI
#define CONFIG_ATMEL_USART diff --git a/include/configs/atngw100mkii.h b/include/configs/atngw100mkii.h index 0dcc192..dd4e1a3 100644 --- a/include/configs/atngw100mkii.h +++ b/include/configs/atngw100mkii.h @@ -100,13 +100,10 @@ * Command line configuration. */ #define CONFIG_CMD_ASKENV -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EXT2 #define CONFIG_CMD_FAT #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_MMC -#define CONFIG_CMD_SF -#define CONFIG_CMD_SPI #define CONFIG_CMD_MII
diff --git a/include/configs/atstk1002.h b/include/configs/atstk1002.h index 8cd7c35..2d34077 100644 --- a/include/configs/atstk1002.h +++ b/include/configs/atstk1002.h @@ -102,7 +102,6 @@ * Command line configuration. */ #define CONFIG_CMD_ASKENV -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EXT2 #define CONFIG_CMD_FAT #define CONFIG_CMD_JFFS2 diff --git a/include/configs/baltos.h b/include/configs/baltos.h index 23d0bb7..560dc88 100644 --- a/include/configs/baltos.h +++ b/include/configs/baltos.h @@ -279,7 +279,6 @@ #define CONFIG_AM335X_USB1_MODE MUSB_OTG
diff --git a/include/configs/bamboo.h b/include/configs/bamboo.h index bb2abf1..d231f7a 100644 --- a/include/configs/bamboo.h +++ b/include/configs/bamboo.h @@ -189,8 +189,6 @@ #define CONFIG_CMD_FAT #define CONFIG_CMD_PCI #define CONFIG_CMD_SDRAM -#define CONFIG_CMD_SNTP -#define CONFIG_CMD_USB
#ifdef CONFIG_BAMBOO_NAND #define CONFIG_CMD_NAND diff --git a/include/configs/bav335x.h b/include/configs/bav335x.h index 44ac2da..377fa94 100644 --- a/include/configs/bav335x.h +++ b/include/configs/bav335x.h @@ -457,7 +457,6 @@ DEFAULT_LINUX_BOOT_ENV \ #endif
@@ -563,7 +562,6 @@ DEFAULT_LINUX_BOOT_ENV \ #endif
/* Network. */ diff --git a/include/configs/bcm28155_ap.h b/include/configs/bcm28155_ap.h index 9456a31..b9e9dcc 100644 --- a/include/configs/bcm28155_ap.h +++ b/include/configs/bcm28155_ap.h @@ -127,7 +127,6 @@ #define CONFIG_CMD_ASKENV #define CONFIG_CMD_CACHE #define CONFIG_CMD_FAT -#define CONFIG_CMD_I2C #define CONFIG_CMD_MMC #define CONFIG_CMD_BOOTZ #define CONFIG_FAT_WRITE diff --git a/include/configs/bcm_ep_board.h b/include/configs/bcm_ep_board.h index efc5de5..4ac4faf 100644 --- a/include/configs/bcm_ep_board.h +++ b/include/configs/bcm_ep_board.h @@ -92,7 +92,6 @@ #define CONFIG_SHA256
/* Enable Time Command */ -#define CONFIG_CMD_TIME
diff --git a/include/configs/beaver.h b/include/configs/beaver.h index f68d8ee..44e3621 100644 --- a/include/configs/beaver.h +++ b/include/configs/beaver.h @@ -26,7 +26,6 @@
/* SD/MMC */ #define CONFIG_MMC @@ -44,15 +43,12 @@ #define CONFIG_TEGRA_SLINK_CTRLS 6 #define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 #define CONFIG_SF_DEFAULT_SPEED 24000000 -#define CONFIG_CMD_SPI -#define CONFIG_CMD_SF #define CONFIG_SPI_FLASH_SIZE (4 << 20)
/* USB Host support */ #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_TEGRA #define CONFIG_USB_STORAGE -#define CONFIG_CMD_USB
/* USB networking support */ #define CONFIG_USB_HOST_ETHER @@ -64,7 +60,6 @@ #define CONFIG_CMD_PCI
#include "tegra-common-usb-gadget.h" #include "tegra-common-post.h" diff --git a/include/configs/bf506f-ezkit.h b/include/configs/bf506f-ezkit.h index 68a91a6..8be2ecb 100644 --- a/include/configs/bf506f-ezkit.h +++ b/include/configs/bf506f-ezkit.h @@ -72,10 +72,6 @@ #define CONFIG_BFIN_SPI #define CONFIG_ENV_SPI_MAX_HZ 30000000 #define CONFIG_SF_DEFAULT_SPEED 30000000 -/* -#define CONFIG_CMD_SF -#define CONFIG_CMD_SPI -*/
/* * Env Storage Settings diff --git a/include/configs/bf525-ucr2.h b/include/configs/bf525-ucr2.h index 5a6067e..66339ca 100644 --- a/include/configs/bf525-ucr2.h +++ b/include/configs/bf525-ucr2.h @@ -67,7 +67,6 @@
/* support for serial flash */ #define CONFIG_BFIN_SPI -#define CONFIG_CMD_SF #define CONFIG_SF_DEFAULT_HZ 30000000
#define CONFIG_ENV_IS_IN_SPI_FLASH diff --git a/include/configs/bf537-minotaur.h b/include/configs/bf537-minotaur.h index be474ad..425f0a9 100644 --- a/include/configs/bf537-minotaur.h +++ b/include/configs/bf537-minotaur.h @@ -144,16 +144,9 @@ # define CONFIG_BOOTDELAY 5 #endif
-#ifdef CONFIG_BFIN_MAC -# define CONFIG_CMD_DHCP -# define CONFIG_CMD_PING -#endif - #define CONFIG_CMD_BOOTLDR #define CONFIG_CMD_CACHE #define CONFIG_CMD_DATE -#define CONFIG_CMD_I2C -#define CONFIG_CMD_SF
#define CONFIG_BOOTCOMMAND "run ramboot" #define CONFIG_BOOTARGS "root=/dev/mtdblock0 rw" diff --git a/include/configs/bf537-srv1.h b/include/configs/bf537-srv1.h index 6d4a93b..fc4f50b 100644 --- a/include/configs/bf537-srv1.h +++ b/include/configs/bf537-srv1.h @@ -144,15 +144,11 @@ #endif
#ifdef CONFIG_BFIN_MAC -# define CONFIG_CMD_DHCP -# define CONFIG_CMD_PING #endif
#define CONFIG_BOOTCOMMAND "run flashboot" #define CONFIG_BOOTARGS "root=/dev/mtdblock0 rw" diff --git a/include/configs/bfin_adi_common.h b/include/configs/bfin_adi_common.h index 9c537e0..1b35a86 100644 --- a/include/configs/bfin_adi_common.h +++ b/include/configs/bfin_adi_common.h @@ -10,15 +10,12 @@ */ #ifndef _CONFIG_CMD_DEFAULT_H # ifdef ADI_CMDS_NETWORK -# define CONFIG_CMD_DHCP # define CONFIG_BOOTP_SUBNETMASK # define CONFIG_BOOTP_GATEWAY # define CONFIG_BOOTP_DNS # define CONFIG_BOOTP_NTPSERVER # define CONFIG_BOOTP_RANDOM_DELAY # define CONFIG_KEEP_SERVERADDR -# define CONFIG_CMD_DNS -# define CONFIG_CMD_PING # ifdef CONFIG_BFIN_MAC # define CONFIG_CMD_MII # endif @@ -41,7 +38,6 @@ # ifdef CONFIG_USB # define CONFIG_CMD_EXT2 # define CONFIG_CMD_FAT -# define CONFIG_CMD_USB # define CONFIG_CMD_USB_STORAGE # define CONFIG_DOS_PARTITION # endif @@ -55,20 +51,12 @@ # ifdef CONFIG_RTC_BFIN # define CONFIG_CMD_DATE # ifdef ADI_CMDS_NETWORK -# define CONFIG_CMD_SNTP # endif # endif # ifdef CONFIG_SPI # define CONFIG_CMD_EEPROM # endif -# if defined(CONFIG_BFIN_SPI) || defined(CONFIG_SOFT_SPI) -# define CONFIG_CMD_SPI -# endif -# ifdef CONFIG_SPI_FLASH -# define CONFIG_CMD_SF -# endif # if defined(CONFIG_SYS_I2C) || defined(CONFIG_SYS_I2C_SOFT) -# define CONFIG_CMD_I2C # define CONFIG_SOFT_I2C_READ_REPEATED_START # endif # ifndef CONFIG_SYS_NO_FLASH diff --git a/include/configs/bg0900.h b/include/configs/bg0900.h index 05c932f..e48be7a 100644 --- a/include/configs/bg0900.h +++ b/include/configs/bg0900.h @@ -16,13 +16,9 @@
#define CONFIG_CMD_BOOTZ #define CONFIG_CMD_CACHE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_MII #define CONFIG_CMD_NAND #define CONFIG_CMD_NAND_TRIMFFS -#define CONFIG_CMD_PING -#define CONFIG_CMD_SF -#define CONFIG_CMD_SPI
/* Memory configuration */ #define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ diff --git a/include/configs/blackstamp.h b/include/configs/blackstamp.h index b9e859c..515ed77 100644 --- a/include/configs/blackstamp.h +++ b/include/configs/blackstamp.h @@ -102,21 +102,10 @@ #define CONFIG_AUTO_COMPLETE 1 #define CONFIG_ENV_OVERWRITE 1
-#ifdef CONFIG_SMC91111 -# define CONFIG_CMD_DHCP -# define CONFIG_CMD_PING -#else -#endif - -#ifdef CONFIG_SYS_I2C_SOFT -# define CONFIG_CMD_I2C -#endif - #define CONFIG_CMD_BOOTLDR #define CONFIG_CMD_CACHE #define CONFIG_CMD_CPLBINFO #define CONFIG_CMD_DATE -#define CONFIG_CMD_SF
#define CONFIG_BOOTDELAY 5 #define CONFIG_BOOTCOMMAND "run ramboot" diff --git a/include/configs/blackvme.h b/include/configs/blackvme.h index a262e79..ef90603 100644 --- a/include/configs/blackvme.h +++ b/include/configs/blackvme.h @@ -83,8 +83,6 @@ #define CONFIG_NETMASK 255.255.255.0 #define CONFIG_ROOTPATH "/export/uClinux-dist/romfs" /*NFS*/ #define CFG_AUTOLOAD "no" -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_PING
/* * SDRAM settings & memory map @@ -154,7 +152,6 @@ #define CONFIG_CMD_BOOTLDR #define CONFIG_CMD_CACHE #define CONFIG_CMD_CPLBINFO -#define CONFIG_CMD_SF
/* * Default: boot from SPI flash. @@ -218,7 +215,6 @@ * PF12,13 on SPI connector 0. */ #ifdef CONFIG_SYS_I2C_SOFT -# define CONFIG_CMD_I2C # define CONFIG_SOFT_I2C_GPIO_SCL GPIO_PF12 # define CONFIG_SOFT_I2C_GPIO_SDA GPIO_PF13 # define CONFIG_SYS_I2C_SPEED 50000 diff --git a/include/configs/bubinga.h b/include/configs/bubinga.h index ea7b104..51d4624 100644 --- a/include/configs/bubinga.h +++ b/include/configs/bubinga.h @@ -95,7 +95,6 @@ #define CONFIG_CMD_DATE #define CONFIG_CMD_PCI #define CONFIG_CMD_SDRAM -#define CONFIG_CMD_SNTP
#define CONFIG_SPD_EEPROM 1 /* use SPD EEPROM for setup */
diff --git a/include/configs/calimain.h b/include/configs/calimain.h index d5d4ded..37adede 100644 --- a/include/configs/calimain.h +++ b/include/configs/calimain.h @@ -309,16 +309,12 @@ */ #define CONFIG_CMD_ENV #define CONFIG_CMD_ASKENV -#define CONFIG_CMD_DHCP #define CONFIG_CMD_DIAG #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_SAVES
#ifndef CONFIG_DRIVER_TI_EMAC -#undef CONFIG_CMD_DHCP #undef CONFIG_CMD_MII -#undef CONFIG_CMD_PING #endif
/* additions for new relocation code, must added to all boards */ diff --git a/include/configs/canmb.h b/include/configs/canmb.h index 2a6c09f..0a39cdf 100644 --- a/include/configs/canmb.h +++ b/include/configs/canmb.h @@ -37,7 +37,6 @@ #define CONFIG_BAUDRATE 115200 /* ... at 115200 bps */ #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, 230400 }
- /* * BOOTP options */ @@ -46,18 +45,14 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- /* * Command line configuration. */ #define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_IMMAP #define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO -#define CONFIG_CMD_SNTP -
/* * MUST be low boot - HIGHBOOT is not supported anymore diff --git a/include/configs/canyonlands.h b/include/configs/canyonlands.h index e136824..ad9f418 100644 --- a/include/configs/canyonlands.h +++ b/include/configs/canyonlands.h @@ -388,15 +388,12 @@ #define CONFIG_CMD_PCI #define CONFIG_CMD_SATA #define CONFIG_CMD_SDRAM -#define CONFIG_CMD_SNTP -#define CONFIG_CMD_USB #elif defined(CONFIG_GLACIER) #define CONFIG_CMD_DATE #define CONFIG_CMD_DTT #define CONFIG_CMD_NAND #define CONFIG_CMD_PCI #define CONFIG_CMD_SDRAM -#define CONFIG_CMD_SNTP #else #error "board type not defined" #endif diff --git a/include/configs/cardhu.h b/include/configs/cardhu.h index acfe968..85fd327 100644 --- a/include/configs/cardhu.h +++ b/include/configs/cardhu.h @@ -29,7 +29,6 @@
/* SD/MMC */ #define CONFIG_MMC @@ -47,15 +46,12 @@ #define CONFIG_TEGRA_SLINK_CTRLS 6 #define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 #define CONFIG_SF_DEFAULT_SPEED 24000000 -#define CONFIG_CMD_SPI -#define CONFIG_CMD_SF #define CONFIG_SPI_FLASH_SIZE (4 << 20)
/* USB networking support */ #define CONFIG_USB_HOST_ETHER @@ -67,7 +63,6 @@ #define CONFIG_CMD_PCI
diff --git a/include/configs/cgtqmx6eval.h b/include/configs/cgtqmx6eval.h index 1ac9dca..57dfdde 100644 --- a/include/configs/cgtqmx6eval.h +++ b/include/configs/cgtqmx6eval.h @@ -41,7 +41,6 @@ #define CONFIG_SYS_FSL_ESDHC_ADDR 0
/* SPI NOR */ -#define CONFIG_CMD_SF #define CONFIG_SPI_FLASH #define CONFIG_SPI_FLASH_STMICRO #define CONFIG_SPI_FLASH_SST @@ -57,7 +56,6 @@ #define CONFIG_IMX_THERMAL
/* I2C Configs */ -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC #define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ @@ -72,7 +70,6 @@ #define CONFIG_POWER_PFUZE100_I2C_ADDR 0x08
/* USB Configs */ -#define CONFIG_CMD_USB #define CONFIG_CMD_FAT #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_MX6 @@ -133,8 +130,6 @@ #define CONFIG_LIBATA
/* Ethernet */ -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP #define CONFIG_CMD_MII #define CONFIG_FEC_MXC #define CONFIG_MII diff --git a/include/configs/chromebook_jerry.h b/include/configs/chromebook_jerry.h index 67f45c0..d1f5b46 100644 --- a/include/configs/chromebook_jerry.h +++ b/include/configs/chromebook_jerry.h @@ -21,7 +21,6 @@ #define CONFIG_SPI_FLASH_GIGADEVICE
#define CONFIG_CMD_SF_TEST -#define CONFIG_CMD_TIME
#undef CONFIG_SPL_GPIO_SUPPORT
diff --git a/include/configs/clearfog.h b/include/configs/clearfog.h index f0de827..991121d 100644 --- a/include/configs/clearfog.h +++ b/include/configs/clearfog.h @@ -27,20 +27,13 @@ #define CONFIG_SYS_NO_FLASH /* Declare no flash (NOR/SPI) */ #define CONFIG_CMD_BOOTZ #define CONFIG_CMD_CACHE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_ENV #define CONFIG_CMD_EXT2 #define CONFIG_CMD_EXT4 #define CONFIG_CMD_FAT #define CONFIG_CMD_FS_GENERIC -#define CONFIG_CMD_I2C #define CONFIG_CMD_MMC #define CONFIG_CMD_PCI -#define CONFIG_CMD_PING -#define CONFIG_CMD_SF -#define CONFIG_CMD_SPI -#define CONFIG_CMD_TFTPPUT -#define CONFIG_CMD_TIME
/* I2C */ #define CONFIG_SYS_I2C diff --git a/include/configs/cm5200.h b/include/configs/cm5200.h index 3744af2..766faa6 100644 --- a/include/configs/cm5200.h +++ b/include/configs/cm5200.h @@ -28,16 +28,11 @@ #define CONFIG_CMD_ASKENV #define CONFIG_CMD_BSP #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_DIAG #define CONFIG_CMD_FAT -#define CONFIG_CMD_I2C #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO -#define CONFIG_CMD_SNTP -#define CONFIG_CMD_USB
/* * Serial console configuration @@ -292,8 +287,6 @@ #define CONFIG_SYS_MEMTEST_START 0x00100000 /* memtest works on */ #define CONFIG_SYS_MEMTEST_END 0x03f00000 /* 1 .. 63 MiB in SDRAM */
-#define CONFIG_LOOPW 1 - #define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */
/* diff --git a/include/configs/cm_t335.h b/include/configs/cm_t335.h index adf05b1..99b5d3e 100644 --- a/include/configs/cm_t335.h +++ b/include/configs/cm_t335.h @@ -19,7 +19,6 @@ #undef CONFIG_BOARD_LATE_INIT #undef CONFIG_SPI #undef CONFIG_OMAP3_SPI -#undef CONFIG_CMD_SPI #undef CONFIG_SPL_OS_BOOT #undef CONFIG_BOOTCOUNT_LIMIT #undef CONFIG_SPL_AM33XX_ENABLE_RTC32K_OSC diff --git a/include/configs/cm_t35.h b/include/configs/cm_t35.h index 016e752..debedec 100644 --- a/include/configs/cm_t35.h +++ b/include/configs/cm_t35.h @@ -99,7 +99,6 @@ #define CONFIG_USB_STORAGE #define CONFIG_USB_MUSB_UDC #define CONFIG_TWL4030_USB -#define CONFIG_CMD_USB
/* USB device configuration */ #define CONFIG_USB_DEVICE @@ -118,11 +117,8 @@ "1920k(u-boot),256k(u-boot-env),"\ "4m(kernel),-(fs)"
-#define CONFIG_CMD_I2C /* I2C serial bus support */ #define CONFIG_CMD_MMC /* MMC support */ #define CONFIG_CMD_NAND /* NAND support */ -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_PING
#define CONFIG_SYS_NO_FLASH diff --git a/include/configs/cm_t3517.h b/include/configs/cm_t3517.h index 553b648..8ac41e2 100644 --- a/include/configs/cm_t3517.h +++ b/include/configs/cm_t3517.h @@ -117,7 +117,6 @@ #endif /* CONFIG_USB_MUSB_AM35X */
/* commands to include */ #define CONFIG_CMD_CACHE @@ -131,11 +130,8 @@ "1920k(u-boot),256k(u-boot-env),"\ "4m(kernel),-(fs)"
#define CONFIG_SYS_NO_FLASH diff --git a/include/configs/cm_t43.h b/include/configs/cm_t43.h index 1c1951c..0e05194 100644 --- a/include/configs/cm_t43.h +++ b/include/configs/cm_t43.h @@ -101,7 +101,6 @@ #undef CONFIG_SYS_MONITOR_LEN #undef CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR #define CONFIG_ZERO_BOOTDELAY_CHECK -#undef CONFIG_CMD_IMLS
#define CONFIG_ENV_SIZE (16 * 1024) #define CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG diff --git a/include/configs/cm_t54.h b/include/configs/cm_t54.h index c8c67c4..9b13aa6 100644 --- a/include/configs/cm_t54.h +++ b/include/configs/cm_t54.h @@ -69,7 +69,6 @@ #define CONFIG_SYS_SCSI_MAX_DEVICE (CONFIG_SYS_SCSI_MAX_SCSI_ID * \ CONFIG_SYS_SCSI_MAX_LUN) /* USB UHH support options */ -#define CONFIG_CMD_USB #define CONFIG_USB_HOST #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_OMAP @@ -81,8 +80,6 @@ #define CONFIG_OMAP_EHCI_PHY3_RESET_GPIO 83 /* HSIC3 ETH #RESET */
/* Enabled commands */ -#define CONFIG_CMD_DHCP /* DHCP Support */ -#define CONFIG_CMD_PING
/* USB Networking options */ #define CONFIG_USB_HOST_ETHER diff --git a/include/configs/cobra5272.h b/include/configs/cobra5272.h index 67a143f..9e44015 100644 --- a/include/configs/cobra5272.h +++ b/include/configs/cobra5272.h @@ -120,7 +120,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_PING
diff --git a/include/configs/colibri_pxa270.h b/include/configs/colibri_pxa270.h index edd0329..c38d888 100644 --- a/include/configs/colibri_pxa270.h +++ b/include/configs/colibri_pxa270.h @@ -55,11 +55,9 @@ */ #define CONFIG_CMD_ENV #define CONFIG_CMD_MMC -#define CONFIG_CMD_USB
/* I2C support */ #ifdef CONFIG_SYS_I2C -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C_PXA #define CONFIG_PXA_STD_I2C #define CONFIG_PXA_PWR_I2C @@ -80,8 +78,6 @@ * Networking Configuration */ #ifdef CONFIG_CMD_NET -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP
#define CONFIG_DRIVER_DM9000 1 #define CONFIG_DM9000_BASE 0x08000000 @@ -96,11 +92,6 @@ #endif
#undef CONFIG_SYS_LONGHELP /* Saves 10 KB */ -#undef CONFIG_SYS_PROMPT -#ifdef CONFIG_HUSH_PARSER -#define CONFIG_SYS_PROMPT "$ " -#else -#endif #define CONFIG_SYS_CBSIZE 256 #define CONFIG_SYS_PBSIZE \ (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) diff --git a/include/configs/colibri_t20.h b/include/configs/colibri_t20.h index e97e5a1..01fc13d 100644 --- a/include/configs/colibri_t20.h +++ b/include/configs/colibri_t20.h @@ -25,7 +25,6 @@
/* SD/MMC support */ #define CONFIG_MMC @@ -38,14 +37,12 @@ #define CONFIG_USB_EHCI_TEGRA #define CONFIG_USB_MAX_CONTROLLER_COUNT 3 #define CONFIG_USB_STORAGE -#define CONFIG_CMD_USB
/* USB networking support */ #define CONFIG_USB_HOST_ETHER #define CONFIG_USB_ETHER_ASIX
/* General networking support */ -#define CONFIG_CMD_DHCP #define CONFIG_IP_DEFRAG #define CONFIG_TFTP_BLOCKSIZE 1536 #define CONFIG_TFTP_TSIZE diff --git a/include/configs/colibri_t30.h b/include/configs/colibri_t30.h index 47914c7..a34da80 100644 --- a/include/configs/colibri_t30.h +++ b/include/configs/colibri_t30.h @@ -26,7 +26,6 @@
/* SD/MMC support */ #define CONFIG_MMC @@ -44,14 +43,12 @@ #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_TEGRA #define CONFIG_USB_STORAGE -#define CONFIG_CMD_USB
/* General networking support */ -#define CONFIG_CMD_DHCP #define CONFIG_IP_DEFRAG #define CONFIG_TFTP_BLOCKSIZE 16384 #define CONFIG_TFTP_TSIZE diff --git a/include/configs/colibri_vf.h b/include/configs/colibri_vf.h index 70e970f..ea33e7a 100644 --- a/include/configs/colibri_vf.h +++ b/include/configs/colibri_vf.h @@ -83,8 +83,6 @@ #define CONFIG_MTD_UBI_FASTMAP #define CONFIG_CMD_UBIFS /* increases size by almost 60 KB */
-#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP #define CONFIG_CMD_MII #define CONFIG_FEC_MXC #define CONFIG_MII @@ -173,7 +171,6 @@ #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE
-#define CONFIG_CMD_MEMTEST #define CONFIG_SYS_MEMTEST_START 0x80010000 #define CONFIG_SYS_MEMTEST_END 0x87C00000
@@ -223,7 +220,6 @@ #define CONFIG_SYS_CACHELINE_SIZE 32
/* USB Host Support */ -#define CONFIG_CMD_USB #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_VF #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 diff --git a/include/configs/controlcenterd.h b/include/configs/controlcenterd.h index 3f03978..77b3e50 100644 --- a/include/configs/controlcenterd.h +++ b/include/configs/controlcenterd.h @@ -201,7 +201,6 @@ #define CONFIG_SYS_FSL_I2C2_OFFSET 0x3100
#ifndef CONFIG_TRAILBLAZER -#define CONFIG_CMD_I2C #endif
#define CONFIG_PCA9698 /* NXP PCA9698 */ @@ -217,7 +216,6 @@ #define CONFIG_HARD_SPI
-#define CONFIG_CMD_SF #define CONFIG_SF_DEFAULT_SPEED 10000000 #define CONFIG_SF_DEFAULT_MODE 0 #endif @@ -326,7 +324,6 @@ * USB */ #define CONFIG_USB_EHCI -#define CONFIG_CMD_USB #define CONFIG_USB_STORAGE
#define CONFIG_HAS_FSL_DR_USB @@ -388,7 +385,6 @@ #define CONFIG_CMD_FAT #define CONFIG_CMD_IRQ #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO
/* diff --git a/include/configs/corenet_ds.h b/include/configs/corenet_ds.h index c937957..1ab2efb 100644 --- a/include/configs/corenet_ds.h +++ b/include/configs/corenet_ds.h @@ -402,7 +402,6 @@ /* * eSPI - Enhanced SPI */ -#define CONFIG_CMD_SF #define CONFIG_SF_DEFAULT_SPEED 10000000 #define CONFIG_SF_DEFAULT_MODE 0
@@ -611,13 +610,10 @@ /* * Command line configuration. */ -#define CONFIG_CMD_DHCP #define CONFIG_CMD_ERRATA #define CONFIG_CMD_GREPENV #define CONFIG_CMD_IRQ -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO
#ifdef CONFIG_PCI @@ -631,7 +627,6 @@ #define CONFIG_HAS_FSL_MPH_USB
#if defined(CONFIG_HAS_FSL_DR_USB) || defined(CONFIG_HAS_FSL_MPH_USB) -#define CONFIG_CMD_USB #define CONFIG_USB_STORAGE #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_FSL diff --git a/include/configs/corvus.h b/include/configs/corvus.h index 6ef6a7d..fffcd95 100644 --- a/include/configs/corvus.h +++ b/include/configs/corvus.h @@ -69,10 +69,7 @@ /* * Command line configuration. */ -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP #define CONFIG_CMD_NAND -#define CONFIG_CMD_USB
/* SDRAM */ #define CONFIG_NR_DRAM_BANKS 1 diff --git a/include/configs/cyrus.h b/include/configs/cyrus.h index 1691cea..701f59e 100644 --- a/include/configs/cyrus.h +++ b/include/configs/cyrus.h @@ -436,13 +436,10 @@ /* * Command line configuration. */ -#define CONFIG_CMD_DHCP #define CONFIG_CMD_ERRATA #define CONFIG_CMD_GREPENV #define CONFIG_CMD_IRQ -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO
#ifdef CONFIG_PCI @@ -456,7 +453,6 @@ #define CONFIG_HAS_FSL_MPH_USB
#if defined(CONFIG_HAS_FSL_DR_USB) || defined(CONFIG_HAS_FSL_MPH_USB) -#define CONFIG_CMD_USB #define CONFIG_USB_STORAGE #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_FSL @@ -489,7 +485,6 @@ #define CONFIG_CMDLINE_EDITING /* Command-line editing */ #define CONFIG_AUTO_COMPLETE /* add autocompletion support */ #define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ -#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ #ifdef CONFIG_CMD_KGDB #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #else diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index 3e84cbc..2972057 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -141,7 +141,6 @@ #define CONFIG_BAUDRATE 115200 /* Default baud rate */
#define CONFIG_SPI -#define CONFIG_CMD_SF #define CONFIG_DAVINCI_SPI #define CONFIG_SYS_SPI_BASE DAVINCI_SPI1_BASE #define CONFIG_SYS_SPI_CLK clk_get(DAVINCI_SPI1_CLKID) @@ -288,10 +287,8 @@ */ #define CONFIG_CMD_ENV #define CONFIG_CMD_ASKENV -#define CONFIG_CMD_DHCP #define CONFIG_CMD_DIAG #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_SAVES
#ifdef CONFIG_CMD_BDI @@ -299,9 +296,7 @@ #endif
#ifdef CONFIG_USE_NAND @@ -317,7 +312,6 @@ #endif
#ifdef CONFIG_USE_SPIFLASH -#define CONFIG_CMD_SPI #endif
#if !defined(CONFIG_USE_NAND) && \ diff --git a/include/configs/dalmore.h b/include/configs/dalmore.h index f74ced1..40dc35c 100644 --- a/include/configs/dalmore.h +++ b/include/configs/dalmore.h @@ -22,7 +22,6 @@
/* SD/MMC */ #define CONFIG_MMC @@ -41,22 +40,18 @@ /* SPI */ #define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 #define CONFIG_SF_DEFAULT_SPEED 24000000 -#define CONFIG_CMD_SPI -#define CONFIG_CMD_SF #define CONFIG_SPI_FLASH_SIZE (4 << 20)
#include "tegra-common-usb-gadget.h" #include "tegra-common-post.h" diff --git a/include/configs/db-88f6720.h b/include/configs/db-88f6720.h index 7f19334..f8454cf 100644 --- a/include/configs/db-88f6720.h +++ b/include/configs/db-88f6720.h @@ -25,18 +25,11 @@ */ #define CONFIG_SYS_NO_FLASH /* Declare no flash (NOR/SPI) */ #define CONFIG_CMD_CACHE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_ENV #define CONFIG_CMD_EXT2 #define CONFIG_CMD_EXT4 #define CONFIG_CMD_FAT #define CONFIG_CMD_FS_GENERIC -#define CONFIG_CMD_I2C -#define CONFIG_CMD_PING -#define CONFIG_CMD_SF -#define CONFIG_CMD_SPI -#define CONFIG_CMD_TFTPPUT -#define CONFIG_CMD_TIME
/* I2C */ #define CONFIG_SYS_I2C diff --git a/include/configs/db-88f6820-gp.h b/include/configs/db-88f6820-gp.h index ef14132..d31e74f 100644 --- a/include/configs/db-88f6820-gp.h +++ b/include/configs/db-88f6820-gp.h @@ -26,21 +26,14 @@ */ #define CONFIG_SYS_NO_FLASH /* Declare no flash (NOR/SPI) */ #define CONFIG_CMD_CACHE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_ENV #define CONFIG_CMD_EXT2 #define CONFIG_CMD_EXT4 #define CONFIG_CMD_FAT #define CONFIG_CMD_FS_GENERIC -#define CONFIG_CMD_I2C #define CONFIG_CMD_MMC #define CONFIG_CMD_PCI -#define CONFIG_CMD_PING #define CONFIG_CMD_SCSI -#define CONFIG_CMD_SF -#define CONFIG_CMD_SPI -#define CONFIG_CMD_TFTPPUT -#define CONFIG_CMD_TIME
/* I2C */ #define CONFIG_SYS_I2C diff --git a/include/configs/db-mv784mp-gp.h b/include/configs/db-mv784mp-gp.h index c8b0344..66b723d 100644 --- a/include/configs/db-mv784mp-gp.h +++ b/include/configs/db-mv784mp-gp.h @@ -27,21 +27,14 @@ */ #define CONFIG_SYS_NO_FLASH /* Declare no flash (NOR/SPI) */ #define CONFIG_CMD_CACHE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_ENV #define CONFIG_CMD_EXT2 #define CONFIG_CMD_EXT4 #define CONFIG_CMD_FAT #define CONFIG_CMD_FS_GENERIC -#define CONFIG_CMD_I2C #define CONFIG_CMD_NAND #define CONFIG_CMD_PCI -#define CONFIG_CMD_PING #define CONFIG_CMD_SATA -#define CONFIG_CMD_SF -#define CONFIG_CMD_SPI -#define CONFIG_CMD_TFTPPUT -#define CONFIG_CMD_TIME
/* I2C */ #define CONFIG_SYS_I2C diff --git a/include/configs/dbau1x00.h b/include/configs/dbau1x00.h index 817676f..faf2a87 100644 --- a/include/configs/dbau1x00.h +++ b/include/configs/dbau1x00.h @@ -80,14 +80,12 @@
#ifdef CONFIG_DBAU1550
-#undef CONFIG_CMD_I2C #undef CONFIG_CMD_IDE #undef CONFIG_CMD_PCMCIA
#else
#define CONFIG_CMD_IDE -#define CONFIG_CMD_DHCP
#endif
diff --git a/include/configs/devkit3250.h b/include/configs/devkit3250.h index a8ce7e1..4114f9e 100644 --- a/include/configs/devkit3250.h +++ b/include/configs/devkit3250.h @@ -61,7 +61,6 @@ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_LPC32XX #define CONFIG_SYS_I2C_SPEED 100000 -#define CONFIG_CMD_I2C
/* * GPIO @@ -73,7 +72,6 @@ */ #define CONFIG_LPC32XX_SSP #define CONFIG_LPC32XX_SSP_TIMEOUT 100000 -#define CONFIG_CMD_SPI
/* * Ethernet @@ -85,8 +83,6 @@ #define CONFIG_PHY_ADDR 0x1F #define CONFIG_SYS_FAULT_ECHO_LINK_DOWN #define CONFIG_CMD_MII -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP
/* * NOR Flash @@ -131,7 +127,6 @@ #define CONFIG_USB_ISP1301_I2C_ADDR 0x2d #define CONFIG_USB_STORAGE #define CONFIG_CMD_FAT -#define CONFIG_CMD_USB
/* * U-Boot General Configurations diff --git a/include/configs/devkit8000.h b/include/configs/devkit8000.h index b8975fa..4afc91b 100644 --- a/include/configs/devkit8000.h +++ b/include/configs/devkit8000.h @@ -96,11 +96,9 @@ /* partition */
/* commands to include */ -#define CONFIG_CMD_DHCP /* DHCP support */ #define CONFIG_CMD_JFFS2 /* JFFS2 Support */ #define CONFIG_CMD_NAND_LOCK_UNLOCK /* nand (un)lock commands */
-#undef CONFIG_CMD_SPI #undef CONFIG_CMD_ASKENV #undef CONFIG_CMD_BOOTZ #undef CONFIG_SUPPORT_RAW_INITRD diff --git a/include/configs/digsy_mtc.h b/include/configs/digsy_mtc.h index db3759f..0bf5088 100644 --- a/include/configs/digsy_mtc.h +++ b/include/configs/digsy_mtc.h @@ -103,21 +103,16 @@ #endif #define CONFIG_CMD_CACHE #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_DIAG #define CONFIG_CMD_EEPROM #define CONFIG_CMD_EXT2 #define CONFIG_CMD_FAT -#define CONFIG_CMD_I2C #define CONFIG_CMD_IDE #define CONFIG_CMD_IRQ #define CONFIG_CMD_MII #define CONFIG_CMD_PCI -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO #define CONFIG_CMD_SAVES -#define CONFIG_CMD_SPI -#define CONFIG_CMD_USB
#if (CONFIG_SYS_TEXT_BASE == 0xFF000000) #define CONFIG_SYS_LOWBOOT 1 @@ -388,7 +383,6 @@ #define CONFIG_AUTO_COMPLETE 1 #define CONFIG_CMDLINE_EDITING 1
-#define CONFIG_LOOPW 1 #define CONFIG_MX_CYCLIC 1 #define CONFIG_ZERO_BOOTDELAY_CHECK
diff --git a/include/configs/dlvision-10g.h b/include/configs/dlvision-10g.h index bbeed76..445a346 100644 --- a/include/configs/dlvision-10g.h +++ b/include/configs/dlvision-10g.h @@ -62,10 +62,8 @@ * Commands additional to the ones defined in amcc-common.h */ #define CONFIG_CMD_DTT -#undef CONFIG_CMD_DHCP #undef CONFIG_CMD_DIAG #undef CONFIG_CMD_EEPROM -#define CONFIG_CMD_I2C #undef CONFIG_CMD_IRQ
/* diff --git a/include/configs/dlvision.h b/include/configs/dlvision.h index 1e461f5..4dda319 100644 --- a/include/configs/dlvision.h +++ b/include/configs/dlvision.h @@ -58,10 +58,8 @@ * Commands additional to the ones defined in amcc-common.h */ #define CONFIG_CMD_DTT -#undef CONFIG_CMD_DHCP #undef CONFIG_CMD_DIAG #undef CONFIG_CMD_EEPROM -#undef CONFIG_CMD_I2C #undef CONFIG_CMD_IRQ
/* diff --git a/include/configs/dnp5370.h b/include/configs/dnp5370.h index c46e60d..c0c0de9 100644 --- a/include/configs/dnp5370.h +++ b/include/configs/dnp5370.h @@ -54,7 +54,6 @@ #define CONFIG_RMII 1
#endif
diff --git a/include/configs/dns325.h b/include/configs/dns325.h index 85a2594..7ee274e 100644 --- a/include/configs/dns325.h +++ b/include/configs/dns325.h @@ -31,11 +31,8 @@ * Commands configuration */ #define CONFIG_SYS_NO_FLASH /* Declare no flash (NOR/SPI) */ -#define CONFIG_CMD_DHCP #define CONFIG_CMD_ENV #define CONFIG_CMD_NAND -#define CONFIG_CMD_PING -#define CONFIG_CMD_USB #define CONFIG_CMD_IDE #define CONFIG_CMD_DATE #define CONFIG_SYS_MVFS @@ -49,7 +46,6 @@ #include "mv-common.h"
/* Remove or override few declarations from mv-common.h */ -#undef CONFIG_SYS_PROMPT
/* * Ethernet Driver configuration diff --git a/include/configs/dockstar.h b/include/configs/dockstar.h index efe5807..ae3017c 100644 --- a/include/configs/dockstar.h +++ b/include/configs/dockstar.h @@ -30,12 +30,9 @@ * Commands configuration */ #define CONFIG_SYS_NO_FLASH /* Declare no flash (NOR/SPI) */ -#define CONFIG_CMD_DHCP #define CONFIG_CMD_ENV #define CONFIG_CMD_MII #define CONFIG_CMD_NAND -#define CONFIG_CMD_PING -#define CONFIG_CMD_USB /* * mv-common.h should be defined after CMD configs since it used them * to enable certain macros diff --git a/include/configs/dra7xx_evm.h b/include/configs/dra7xx_evm.h index d2d16a6..8d6ed05 100644 --- a/include/configs/dra7xx_evm.h +++ b/include/configs/dra7xx_evm.h @@ -142,14 +142,12 @@ #define CONFIG_HSMMC2_8BIT
/* CPSW Ethernet */ -#define CONFIG_CMD_DHCP #define CONFIG_BOOTP_DNS /* Configurable parts of CMD_DHCP */ #define CONFIG_BOOTP_DNS2 #define CONFIG_BOOTP_SEND_HOSTNAME #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_SUBNETMASK #define CONFIG_NET_RETRY_COUNT 10 -#define CONFIG_CMD_PING #define CONFIG_CMD_MII #define CONFIG_DRIVER_TI_CPSW /* Driver for IP block */ #define CONFIG_MII /* Required in net/eth.c */ @@ -159,8 +157,6 @@
/* SPI */ #undef CONFIG_OMAP3_SPI -#define CONFIG_CMD_SF -#define CONFIG_CMD_SPI #define CONFIG_TI_SPI_MMAP #define CONFIG_SF_DEFAULT_SPEED 64000000 #define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 @@ -215,7 +211,6 @@ #define CONFIG_SUPPORT_EMMC_BOOT
/* USB xHCI HOST */ -#define CONFIG_CMD_USB #define CONFIG_USB_HOST #define CONFIG_USB_XHCI #define CONFIG_USB_XHCI_DWC3 diff --git a/include/configs/dragonboard410c.h b/include/configs/dragonboard410c.h index edf8cfb..ae4fbb4 100644 --- a/include/configs/dragonboard410c.h +++ b/include/configs/dragonboard410c.h @@ -61,10 +61,8 @@ /* Extra Commands */ #define CONFIG_CMD_CACHE #define CONFIG_CMD_ENV -#define CONFIG_CMD_GPIO #define CONFIG_CMD_GPT #define CONFIG_CMD_MD5SUM -#define CONFIG_CMD_MEMINFO #define CONFIG_CMD_MMC /* Enable that for switching of boot partitions */ /* Disabled by default as some sub-commands can brick eMMC */ @@ -72,7 +70,6 @@ #define CONFIG_CMD_PART #define CONFIG_CMD_REGINFO /* Register dump */ #define CONFIG_CMD_TFTP -#define CONFIG_CMD_TIMER #define CONFIG_CMD_UNZIP
/* Partition table support */ diff --git a/include/configs/ds414.h b/include/configs/ds414.h index e3c7087..64c546c 100644 --- a/include/configs/ds414.h +++ b/include/configs/ds414.h @@ -24,15 +24,7 @@ * Commands configuration */ #define CONFIG_SYS_NO_FLASH /* Declare no flash (NOR/SPI) */ -#define CONFIG_CMD_DHCP #define CONFIG_CMD_ENV -#define CONFIG_CMD_I2C -#define CONFIG_CMD_PING -#define CONFIG_CMD_SF -#define CONFIG_CMD_SPI -#define CONFIG_CMD_TFTPPUT -#define CONFIG_CMD_TIME -#define CONFIG_CMD_USB
/* I2C */ #define CONFIG_SYS_I2C diff --git a/include/configs/duovero.h b/include/configs/duovero.h index bb3ba55..ac9a67f 100644 --- a/include/configs/duovero.h +++ b/include/configs/duovero.h @@ -28,7 +28,6 @@ #define CONFIG_SYS_DEFAULT_LPDDR2_TIMINGS
/* USB UHH support options */ -#define CONFIG_CMD_USB #define CONFIG_USB_HOST #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_OMAP @@ -40,8 +39,6 @@
#define CONFIG_SYS_ENABLE_PADS_ALL
#define CONFIG_SMC911X #define CONFIG_SMC911X_32_BIT diff --git a/include/configs/e2220-1170.h b/include/configs/e2220-1170.h index 33ebb7c..3a7f490 100644 --- a/include/configs/e2220-1170.h +++ b/include/configs/e2220-1170.h @@ -20,7 +20,6 @@
/* SD/MMC */ #define CONFIG_MMC @@ -37,22 +36,18 @@ /* SPI */ #define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 #define CONFIG_SF_DEFAULT_SPEED 24000000 -#define CONFIG_CMD_SPI -#define CONFIG_CMD_SF #define CONFIG_SPI_FLASH_SIZE (4 << 20)
/* USB2.0 Host support */ #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_TEGRA #define CONFIG_USB_STORAGE -#define CONFIG_CMD_USB
#include "tegra-common-usb-gadget.h" #include "tegra-common-post.h" diff --git a/include/configs/ea20.h b/include/configs/ea20.h index 85db470..06e988a 100644 --- a/include/configs/ea20.h +++ b/include/configs/ea20.h @@ -146,21 +146,16 @@ */ #define CONFIG_CMD_ENV #define CONFIG_CMD_ASKENV -#define CONFIG_CMD_DHCP #define CONFIG_CMD_DIAG #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_SAVES -#define CONFIG_CMD_I2C
#ifdef CONFIG_CMD_BDI #define CONFIG_CLOCKS #endif
/* NAND Setup */ @@ -188,8 +183,6 @@
/* SPI Flash */ #ifdef CONFIG_USE_SPIFLASH -#define CONFIG_CMD_SPI -#define CONFIG_CMD_SF #endif
#if !defined(CONFIG_SYS_USE_NAND) && \ diff --git a/include/configs/eb_cpu5282.h b/include/configs/eb_cpu5282.h index f9ec028..861f2ac 100644 --- a/include/configs/eb_cpu5282.h +++ b/include/configs/eb_cpu5282.h @@ -65,8 +65,6 @@ */ #define CONFIG_CMDLINE_EDITING #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_I2C #define CONFIG_CMD_LED #define CONFIG_CMD_MII
diff --git a/include/configs/eco5pk.h b/include/configs/eco5pk.h index f23d383..f463521 100644 --- a/include/configs/eco5pk.h +++ b/include/configs/eco5pk.h @@ -18,7 +18,6 @@ #undef CONFIG_USB_EHCI #undef CONFIG_USB_EHCI_OMAP #undef CONFIG_USB_OMAP3 -#undef CONFIG_CMD_USB
/* Our console port is port3 */ #undef CONFIG_CONS_INDEX diff --git a/include/configs/ecovec.h b/include/configs/ecovec.h index 8e62674..3ab1803 100644 --- a/include/configs/ecovec.h +++ b/include/configs/ecovec.h @@ -30,11 +30,9 @@ #define CONFIG_ECOVEC_ROMIMAGE_ADDR 0xA0040000 #define CONFIG_SYS_TEXT_BASE 0x8FFC0000
-#define CONFIG_CMD_PING #define CONFIG_CMD_MII #define CONFIG_CMD_SDRAM #define CONFIG_CMD_ENV -#define CONFIG_CMD_USB #define CONFIG_CMD_FAT #define CONFIG_CMD_EXT2
@@ -49,7 +47,6 @@ #undef CONFIG_SHOW_BOOT_PROGRESS
/* I2C */ -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_SH #define CONFIG_SYS_I2C_SLAVE 0x7F diff --git a/include/configs/edb93xx.h b/include/configs/edb93xx.h index 0645d34..ce50973 100644 --- a/include/configs/edb93xx.h +++ b/include/configs/edb93xx.h @@ -38,46 +38,37 @@
#define CONFIG_SYS_LDSCRIPT "board/cirrus/edb93xx/u-boot.lds"
-#undef CONFIG_SYS_PROMPT #ifdef CONFIG_EDB9301 #define CONFIG_EP9301 #define CONFIG_MACH_TYPE MACH_TYPE_EDB9301 -#define CONFIG_SYS_PROMPT "EDB9301> " #define CONFIG_ENV_SECT_SIZE 0x00020000 #elif defined(CONFIG_EDB9302) #define CONFIG_EP9302 #define CONFIG_MACH_TYPE MACH_TYPE_EDB9302 -#define CONFIG_SYS_PROMPT "EDB9302> " #define CONFIG_ENV_SECT_SIZE 0x00020000 #elif defined(CONFIG_EDB9302A) #define CONFIG_EP9302 #define CONFIG_MACH_TYPE MACH_TYPE_EDB9302A -#define CONFIG_SYS_PROMPT "EDB9302A> " #define CONFIG_ENV_SECT_SIZE 0x00020000 #elif defined(CONFIG_EDB9307) #define CONFIG_EP9307 #define CONFIG_MACH_TYPE MACH_TYPE_EDB9307 -#define CONFIG_SYS_PROMPT "EDB9307> " #define CONFIG_ENV_SECT_SIZE 0x00040000 #elif defined(CONFIG_EDB9307A) #define CONFIG_EP9307 #define CONFIG_MACH_TYPE MACH_TYPE_EDB9307A -#define CONFIG_SYS_PROMPT "EDB9307A> " #define CONFIG_ENV_SECT_SIZE 0x00020000 #elif defined(CONFIG_EDB9312) #define CONFIG_EP9312 #define CONFIG_MACH_TYPE MACH_TYPE_EDB9312 -#define CONFIG_SYS_PROMPT "EDB9312> " #define CONFIG_ENV_SECT_SIZE 0x00040000 #elif defined(CONFIG_EDB9315) #define CONFIG_EP9315 #define CONFIG_MACH_TYPE MACH_TYPE_EDB9315 -#define CONFIG_SYS_PROMPT "EDB9315> " #define CONFIG_ENV_SECT_SIZE 0x00040000 #elif defined(CONFIG_EDB9315A) #define CONFIG_EP9315 #define CONFIG_MACH_TYPE MACH_TYPE_EDB9315A -#define CONFIG_SYS_PROMPT "EDB9315A> " #define CONFIG_ENV_SECT_SIZE 0x00020000 #else #error "no board defined" @@ -91,7 +82,6 @@
/* Monitor configuration */ #undef CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_JFFS2
#define CONFIG_SYS_LONGHELP /* Enable "long" help in mon */ @@ -269,7 +259,6 @@ #define CONFIG_CMD_EXT2 #define CONFIG_CMD_EXT4 #define CONFIG_CMD_FAT -#define CONFIG_CMD_USB
#define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_CMD_BOOTZ diff --git a/include/configs/edminiv2.h b/include/configs/edminiv2.h index d622ef8..4444bc9 100644 --- a/include/configs/edminiv2.h +++ b/include/configs/edminiv2.h @@ -133,8 +133,6 @@ * Commands configuration */ #define CONFIG_CMD_IDE -#define CONFIG_CMD_I2C -#define CONFIG_CMD_USB
/* * Network diff --git a/include/configs/embestmx6boards.h b/include/configs/embestmx6boards.h index 90cd959..59a06ba 100644 --- a/include/configs/embestmx6boards.h +++ b/include/configs/embestmx6boards.h @@ -30,7 +30,6 @@ #define CONFIG_MXC_UART
/* I2C Configs */ -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC #define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ @@ -39,7 +38,6 @@ #define CONFIG_SYS_I2C_SPEED 100000
/* USB Configs */ -#define CONFIG_CMD_USB #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_MX6 #define CONFIG_USB_STORAGE @@ -63,7 +61,6 @@ #define CONFIG_PHYLIB #define CONFIG_PHY_ATHEROS
-#define CONFIG_CMD_SF #ifdef CONFIG_CMD_SF #define CONFIG_MXC_SPI #define CONFIG_SF_DEFAULT_BUS 0 diff --git a/include/configs/espt.h b/include/configs/espt.h index 4896498..ed92865 100644 --- a/include/configs/espt.h +++ b/include/configs/espt.h @@ -19,7 +19,6 @@ */ #define CONFIG_CMD_SDRAM #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_ENV
#define CONFIG_BOOTDELAY -1 diff --git a/include/configs/ethernut5.h b/include/configs/ethernut5.h index 0606194..28bf6b5 100644 --- a/include/configs/ethernut5.h +++ b/include/configs/ethernut5.h @@ -92,30 +92,20 @@ #define CONFIG_CMD_MII #define CONFIG_CMD_MTDPARTS #define CONFIG_CMD_NAND -#define CONFIG_CMD_SPI
#ifndef MINIMAL_LOADER #define CONFIG_CMD_ASKENV #define CONFIG_CMD_BSP #define CONFIG_CMD_CACHE -#define CONFIG_CMD_CDP #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_DNS #define CONFIG_CMD_EXT2 #define CONFIG_CMD_FAT -#define CONFIG_CMD_I2C #define CONFIG_CMD_MMC -#define CONFIG_CMD_PING -#define CONFIG_CMD_RARP #define CONFIG_CMD_REISER #define CONFIG_CMD_SAVES -#define CONFIG_CMD_SF -#define CONFIG_CMD_SNTP #define CONFIG_CMD_UBI #define CONFIG_CMD_UBIFS #define CONFIG_CMD_UNZIP -#define CONFIG_CMD_USB #endif
/* NAND flash */ diff --git a/include/configs/exynos5-common.h b/include/configs/exynos5-common.h index 7d600bf..97fcd4a 100644 --- a/include/configs/exynos5-common.h +++ b/include/configs/exynos5-common.h @@ -121,7 +121,6 @@ #define SPI_FLASH_UBOOT_POS (CONFIG_SEC_FW_SIZE + CONFIG_BL1_SIZE)
/* I2C */ -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C_S3C24X0 #define CONFIG_SYS_I2C_S3C24X0_SPEED 100000 /* 100 Kbps */ #define CONFIG_SYS_I2C_S3C24X0_SLAVE 0x0 @@ -129,8 +128,6 @@
/* SPI */ #ifdef CONFIG_SPI_FLASH -#define CONFIG_CMD_SF -#define CONFIG_CMD_SPI #define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 #define CONFIG_SF_DEFAULT_SPEED 50000000 #endif @@ -157,11 +154,9 @@ #define CONFIG_SHA256
/* USB */ -#define CONFIG_CMD_USB #define CONFIG_USB_STORAGE #define CONFIG_USB_XHCI_DWC3 #define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 3 diff --git a/include/configs/flea3.h b/include/configs/flea3.h index df75152..54b9315 100644 --- a/include/configs/flea3.h +++ b/include/configs/flea3.h @@ -73,8 +73,6 @@ /* * Command definition */ -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP #define CONFIG_BOOTP_SUBNETMASK #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_DNS @@ -82,8 +80,6 @@ #define CONFIG_CMD_NAND #define CONFIG_CMD_CACHE
-#define CONFIG_CMD_I2C -#define CONFIG_CMD_SPI #define CONFIG_CMD_MII #define CONFIG_NET_RETRY_COUNT 100
diff --git a/include/configs/ge_bx50v3.h b/include/configs/ge_bx50v3.h index c3140c7..bf8e55c 100644 --- a/include/configs/ge_bx50v3.h +++ b/include/configs/ge_bx50v3.h @@ -81,7 +81,6 @@ #define CONFIG_DOS_PARTITION
/* USB Configs */ -#define CONFIG_CMD_USB #define CONFIG_CMD_FAT #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_MX6 @@ -107,8 +106,6 @@ #define CONFIG_G_DNL_MANUFACTURER "Advantech"
/* Networking Configs */ -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP #define CONFIG_CMD_MII #define CONFIG_FEC_MXC #define CONFIG_MII @@ -120,7 +117,6 @@ #define CONFIG_PHY_ATHEROS
/* Serial Flash */ -#define CONFIG_CMD_SF #ifdef CONFIG_CMD_SF #define CONFIG_MXC_SPI #define CONFIG_SF_DEFAULT_BUS 0 @@ -137,7 +133,6 @@ /* Command definition */ #define CONFIG_CMD_BMODE #define CONFIG_CMD_BOOTZ -#undef CONFIG_CMD_IMLS
#define CONFIG_LOADADDR 0x12000000 #define CONFIG_SYS_TEXT_BASE 0x17800000 @@ -334,7 +329,6 @@ #endif
/* I2C Configs */ -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC #define CONFIG_SYS_I2C_SPEED 100000 diff --git a/include/configs/goflexhome.h b/include/configs/goflexhome.h index 188d2e2..243e19f 100644 --- a/include/configs/goflexhome.h +++ b/include/configs/goflexhome.h @@ -52,12 +52,9 @@ #define CONFIG_CONSOLE_MUX #define CONFIG_SYS_CONSOLE_IS_IN_ENV
-#define CONFIG_CMD_DHCP #define CONFIG_CMD_ENV #define CONFIG_CMD_MII #define CONFIG_CMD_NAND -#define CONFIG_CMD_PING -#define CONFIG_CMD_USB #define CONFIG_CMD_IDE #define CONFIG_CMD_DATE #define CONFIG_CMD_EXT4 diff --git a/include/configs/gplugd.h b/include/configs/gplugd.h index 52c67d5..638fad1 100644 --- a/include/configs/gplugd.h +++ b/include/configs/gplugd.h @@ -52,8 +52,6 @@ * Commands configuration */ #define CONFIG_SYS_NO_FLASH /* Declare no flash (NOR/SPI) */ -#define CONFIG_CMD_I2C -#define CONFIG_CMD_USB #define CONFIG_CMD_EXT2 #define CONFIG_CMD_FAT
@@ -62,11 +60,9 @@
/* Network configuration */ #ifdef CONFIG_CMD_NET -#define CONFIG_CMD_PING #define CONFIG_ARMADA100_FEC
/* DHCP Support */ -#define CONFIG_CMD_DHCP #define CONFIG_BOOTP_DHCP_REQUEST_DELAY 50000 #endif /* CONFIG_CMD_NET */
@@ -90,7 +86,6 @@ #define CONFIG_SYS_SSP_PORT 2
/* Flash Support */ -#define CONFIG_CMD_SF
/* * mv-common.h should be defined after CMD configs since it used them diff --git a/include/configs/gr_cpci_ax2000.h b/include/configs/gr_cpci_ax2000.h index c3b1729..f3361d0 100644 --- a/include/configs/gr_cpci_ax2000.h +++ b/include/configs/gr_cpci_ax2000.h @@ -60,7 +60,6 @@ * Supported commands */ #define CONFIG_CMD_REGINFO -#define CONFIG_CMD_PING #define CONFIG_CMD_DIAG #define CONFIG_CMD_IRQ
diff --git a/include/configs/gr_ep2s60.h b/include/configs/gr_ep2s60.h index 45163ed..563b205 100644 --- a/include/configs/gr_ep2s60.h +++ b/include/configs/gr_ep2s60.h @@ -54,7 +54,6 @@ * Supported commands */ #define CONFIG_CMD_REGINFO -#define CONFIG_CMD_PING #define CONFIG_CMD_DIAG #define CONFIG_CMD_IRQ
@@ -63,7 +62,6 @@ #define CONFIG_USB_UHCI #define CONFIG_CMD_FAT #define CONFIG_CMD_EXT2 -#define CONFIG_CMD_USB #define CONFIG_USB_STORAGE /* Enable needed helper functions */ #define CONFIG_SYS_STDIO_DEREGISTER /* needs stdio_deregister */ diff --git a/include/configs/gr_xc3s_1500.h b/include/configs/gr_xc3s_1500.h index f675b75..dcb72c9 100644 --- a/include/configs/gr_xc3s_1500.h +++ b/include/configs/gr_xc3s_1500.h @@ -41,7 +41,6 @@ * Supported commands */ #define CONFIG_CMD_REGINFO -#define CONFIG_CMD_PING #define CONFIG_CMD_DIAG #define CONFIG_CMD_IRQ
diff --git a/include/configs/grasshopper.h b/include/configs/grasshopper.h index 8cde96a..8e0cff9 100644 --- a/include/configs/grasshopper.h +++ b/include/configs/grasshopper.h @@ -94,9 +94,7 @@ */ /* add useful commands */ #define CONFIG_CMD_ASKENV -#define CONFIG_CMD_DHCP #define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO
#define CONFIG_AUTO_COMPLETE diff --git a/include/configs/gw_ventana.h b/include/configs/gw_ventana.h index 747eafc..58598c3 100644 --- a/include/configs/gw_ventana.h +++ b/include/configs/gw_ventana.h @@ -65,7 +65,6 @@ #ifdef CONFIG_SPI_FLASH
/* SPI */ -#define CONFIG_CMD_SF #ifdef CONFIG_CMD_SF #define CONFIG_MXC_SPI #define CONFIG_SPI_FLASH_MTD @@ -79,7 +78,6 @@
#else /* Enable NAND support */ -#define CONFIG_CMD_TIME #define CONFIG_CMD_NAND #define CONFIG_CMD_NAND_TRIMFFS #ifdef CONFIG_CMD_NAND @@ -98,7 +96,6 @@ #endif /* CONFIG_SPI_FLASH */
/* I2C Configs */ -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC #define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ @@ -152,8 +149,6 @@ #define CONFIG_POWER_LTC3676_I2C_ADDR 0x3c
/* Various command support */ -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP #define CONFIG_CMD_MII #define CONFIG_CMD_BMODE /* set eFUSE shadow for a boot dev and reset */ #define CONFIG_CMD_HDMIDETECT /* detect HDMI output device */ @@ -172,7 +167,6 @@ #define CONFIG_ARP_TIMEOUT 200UL
/* USB Configs */ -#define CONFIG_CMD_USB #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_MX6 #define CONFIG_USB_STORAGE diff --git a/include/configs/h2200.h b/include/configs/h2200.h index 0bdb570..1bb5ebb 100644 --- a/include/configs/h2200.h +++ b/include/configs/h2200.h @@ -135,7 +135,6 @@ #define CONFIG_USB_DEV_PULLUP_GPIO 33 /* USB VBUS GPIO 3 */
#define CONFIG_BOOTDELAY 2 #define CONFIG_BOOTCOMMAND \ diff --git a/include/configs/harmony.h b/include/configs/harmony.h index 0a3cb18..aa0f38c 100644 --- a/include/configs/harmony.h +++ b/include/configs/harmony.h @@ -45,7 +45,6 @@ #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_TEGRA #define CONFIG_USB_STORAGE -#define CONFIG_CMD_USB
/* USB networking support */ #define CONFIG_USB_HOST_ETHER @@ -54,7 +53,6 @@ #define CONFIG_USB_ETHER_SMSC95XX
/* LCD support */ #define CONFIG_SYS_WHITE_ON_BLACK diff --git a/include/configs/hikey.h b/include/configs/hikey.h index ce4a006..4987373 100644 --- a/include/configs/hikey.h +++ b/include/configs/hikey.h @@ -61,7 +61,6 @@ #define CONFIG_PL01X_SERIAL #define CONFIG_BAUDRATE 115200
-#define CONFIG_CMD_USB #ifdef CONFIG_CMD_USB #define CONFIG_USB_DWC2 #define CONFIG_USB_DWC2_REG_ADDR 0xF72C0000 diff --git a/include/configs/hrcon.h b/include/configs/hrcon.h index 75496d7..aecfda4 100644 --- a/include/configs/hrcon.h +++ b/include/configs/hrcon.h @@ -534,10 +534,8 @@ void fpga_control_clear(unsigned int bus, int pin); /* * Command line configuration. */ -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII #define CONFIG_CMD_PCI -#define CONFIG_CMD_PING
#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ #define CONFIG_AUTO_COMPLETE /* add autocompletion support */ diff --git a/include/configs/icon.h b/include/configs/icon.h index d9a3671..d42e6f0 100644 --- a/include/configs/icon.h +++ b/include/configs/icon.h @@ -171,7 +171,6 @@ #define CONFIG_CMD_FAT #define CONFIG_CMD_PCI #define CONFIG_CMD_SDRAM -#define CONFIG_CMD_SNTP #ifdef CONFIG_VIDEO #define CONFIG_CMD_BMP #endif diff --git a/include/configs/iconnect.h b/include/configs/iconnect.h index adf3703..10f1e9b 100644 --- a/include/configs/iconnect.h +++ b/include/configs/iconnect.h @@ -42,8 +42,6 @@ #define CONFIG_CMD_ENV #define CONFIG_CMD_MII #define CONFIG_CMD_NAND -#define CONFIG_CMD_PING -#define CONFIG_CMD_USB
/* * mv-common.h should be defined after CMD configs since it used them diff --git a/include/configs/ids8313.h b/include/configs/ids8313.h index 17e1f05..ff93c7d 100644 --- a/include/configs/ids8313.h +++ b/include/configs/ids8313.h @@ -277,7 +277,6 @@ /* * I2C setup */ -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_FSL #define CONFIG_SYS_FSL_I2C_SPEED 400000 @@ -291,7 +290,6 @@ */ #ifdef CONFIG_HARD_SPI #define CONFIG_MPC8XXX_SPI -#define CONFIG_CMD_SPI #define CONFIG_SYS_GPIO1_PRELIM #define CONFIG_SYS_GPIO1_DIR 0x00000001 #define CONFIG_SYS_GPIO1_DAT 0x00000001 @@ -416,10 +414,7 @@ /* * U-Boot environment setup */ -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_PING #define CONFIG_CMD_NAND -#define CONFIG_CMD_SNTP #define CONFIG_CMD_MII #define CONFIG_CMD_DATE #define CONFIG_CMDLINE_EDITING diff --git a/include/configs/imx27lite-common.h b/include/configs/imx27lite-common.h index 526659c..c03e566 100644 --- a/include/configs/imx27lite-common.h +++ b/include/configs/imx27lite-common.h @@ -173,14 +173,12 @@ */ #define CONFIG_CMD_ASKENV #define CONFIG_CMD_CACHE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_DIAG #define CONFIG_CMD_FAT #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_MII #define CONFIG_CMD_MMC #define CONFIG_CMD_NAND -#define CONFIG_CMD_PING
diff --git a/include/configs/imx31_phycore.h b/include/configs/imx31_phycore.h index 235fdd1..94dd796 100644 --- a/include/configs/imx31_phycore.h +++ b/include/configs/imx31_phycore.h @@ -53,9 +53,7 @@ /*********************************************************** * Command definition ***********************************************************/ -#define CONFIG_CMD_PING #define CONFIG_CMD_EEPROM -#define CONFIG_CMD_I2C
#define CONFIG_BOOTDELAY 3
@@ -183,7 +181,6 @@
#define CONFIG_HARD_SPI #define CONFIG_MXC_SPI -#define CONFIG_CMD_SPI
#define CONFIG_S6E63D6
diff --git a/include/configs/inka4x0.h b/include/configs/inka4x0.h index 24da83c..149c8c6 100644 --- a/include/configs/inka4x0.h +++ b/include/configs/inka4x0.h @@ -82,14 +82,10 @@ * Command line configuration. */ #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EXT2 #define CONFIG_CMD_FAT #define CONFIG_CMD_IDE #define CONFIG_CMD_PCI -#define CONFIG_CMD_PING -#define CONFIG_CMD_SNTP -#define CONFIG_CMD_USB
#define CONFIG_TIMESTAMP 1 /* Print image info with timestamp */
@@ -342,11 +338,6 @@ static inline void tws_data_config_output(unsigned output) #define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */
/* - * Enable loopw command. - */ -#define CONFIG_LOOPW - -/* * Various low-level settings */ #define CONFIG_SYS_HID0_INIT HID0_ICE | HID0_ICFI diff --git a/include/configs/integrator-common.h b/include/configs/integrator-common.h index 4cd889b..f4982e1 100644 --- a/include/configs/integrator-common.h +++ b/include/configs/integrator-common.h @@ -96,7 +96,6 @@ * - SIB block * - U-Boot environment */ -#define CONFIG_CMD_ARMFLASH #define CONFIG_SYS_FLASH_CFI 1 #define CONFIG_FLASH_CFI_DRIVER 1 #define CONFIG_SYS_FLASH_BASE 0x24000000 diff --git a/include/configs/intip.h b/include/configs/intip.h index 913fdab..69f0f4d 100644 --- a/include/configs/intip.h +++ b/include/configs/intip.h @@ -285,8 +285,6 @@ #define CONFIG_CMD_FAT #define CONFIG_CMD_PCI #define CONFIG_CMD_SDRAM -#define CONFIG_CMD_SNTP -#define CONFIG_CMD_USB
/* Partitions */ #define CONFIG_MAC_PARTITION diff --git a/include/configs/io.h b/include/configs/io.h index f05eb0a..0dd7f00 100644 --- a/include/configs/io.h +++ b/include/configs/io.h @@ -62,10 +62,8 @@ * Commands additional to the ones defined in amcc-common.h */ #define CONFIG_CMD_DTT -#undef CONFIG_CMD_DHCP #undef CONFIG_CMD_DIAG #undef CONFIG_CMD_EEPROM -#undef CONFIG_CMD_I2C #undef CONFIG_CMD_IRQ
/* diff --git a/include/configs/iocon.h b/include/configs/iocon.h index f75ca76..4d1f309 100644 --- a/include/configs/iocon.h +++ b/include/configs/iocon.h @@ -64,7 +64,6 @@ #define CONFIG_CMD_CACHE #define CONFIG_CMD_FPGAD #undef CONFIG_CMD_EEPROM -#undef CONFIG_CMD_I2C #undef CONFIG_CMD_IRQ
/* diff --git a/include/configs/ipam390.h b/include/configs/ipam390.h index 4f0aa69..869d8c4 100644 --- a/include/configs/ipam390.h +++ b/include/configs/ipam390.h @@ -253,10 +253,8 @@ */ #define CONFIG_CMD_ENV #define CONFIG_CMD_ASKENV -#define CONFIG_CMD_DHCP #define CONFIG_CMD_DIAG #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_SAVES
#ifdef CONFIG_CMD_BDI @@ -264,9 +262,7 @@ #endif
#define CONFIG_CMD_NAND diff --git a/include/configs/ipek01.h b/include/configs/ipek01.h index ea9d8b0..636f6bd 100644 --- a/include/configs/ipek01.h +++ b/include/configs/ipek01.h @@ -106,14 +106,11 @@ #define CONFIG_CMD_BMP /* BMP support */ #endif #define CONFIG_CMD_DATE /* support for RTC, date/time...*/ -#define CONFIG_CMD_DHCP /* DHCP Support */ #define CONFIG_CMD_FAT /* FAT support */ -#define CONFIG_CMD_I2C /* I2C serial bus support */ #define CONFIG_CMD_IDE /* IDE harddisk support */ #define CONFIG_CMD_IRQ /* irqinfo */ #define CONFIG_CMD_MII /* MII support */ #define CONFIG_CMD_PCI /* pciinfo */ -#define CONFIG_CMD_USB /* USB Support */
@@ -291,8 +288,6 @@
-#define CONFIG_LOOPW - /* * Various low-level settings */ diff --git a/include/configs/jetson-tk1.h b/include/configs/jetson-tk1.h index 59dbb20..30ef13f 100644 --- a/include/configs/jetson-tk1.h +++ b/include/configs/jetson-tk1.h @@ -24,7 +24,6 @@
/* I2C */ #define CONFIG_SYS_I2C_TEGRA -#define CONFIG_CMD_I2C
/* SD/MMC */ #define CONFIG_MMC @@ -41,15 +40,12 @@ /* SPI */ #define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 #define CONFIG_SF_DEFAULT_SPEED 24000000 -#define CONFIG_CMD_SPI -#define CONFIG_CMD_SF #define CONFIG_SPI_FLASH_SIZE (4 << 20)
/* USB networking support */ #define CONFIG_USB_HOST_ETHER @@ -61,7 +57,6 @@ #define CONFIG_CMD_PCI
#include "tegra-common-usb-gadget.h" #include "tegra-common-post.h" diff --git a/include/configs/jupiter.h b/include/configs/jupiter.h index 09f308f..ce92e78 100644 --- a/include/configs/jupiter.h +++ b/include/configs/jupiter.h @@ -86,7 +86,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_SNTP
#if defined(CONFIG_PCI) #define CODFIG_CMD_PCI diff --git a/include/configs/katmai.h b/include/configs/katmai.h index 664896b..f5dddae 100644 --- a/include/configs/katmai.h +++ b/include/configs/katmai.h @@ -179,7 +179,6 @@ #define CONFIG_CMD_FAT #define CONFIG_CMD_PCI #define CONFIG_CMD_SDRAM -#define CONFIG_CMD_SNTP
#define CONFIG_IBM_EMAC4_V4 1 /* 440SPe has this EMAC version */ #define CONFIG_PHY_ADDR 1 /* PHY address, See schematics */ diff --git a/include/configs/kc1.h b/include/configs/kc1.h index 1087902..15029f9 100644 --- a/include/configs/kc1.h +++ b/include/configs/kc1.h @@ -80,7 +80,6 @@ #define CONFIG_SYS_I2C_OMAP24XX #define CONFIG_I2C_MULTI_BUS
/* * Flash diff --git a/include/configs/kilauea.h b/include/configs/kilauea.h index 1990b2d..227504f 100644 --- a/include/configs/kilauea.h +++ b/include/configs/kilauea.h @@ -369,7 +369,6 @@ #define CONFIG_CMD_DATE #define CONFIG_CMD_NAND #define CONFIG_CMD_PCI -#define CONFIG_CMD_SNTP
#define CONFIG_SYS_POST_MEMORY_ON CONFIG_SYS_POST_MEMORY
diff --git a/include/configs/km/keymile-common.h b/include/configs/km/keymile-common.h index ab727aa..dd0cec4 100644 --- a/include/configs/km/keymile-common.h +++ b/include/configs/km/keymile-common.h @@ -14,14 +14,11 @@ * Command line configuration. */ #define CONFIG_CMD_ASKENV -#define CONFIG_CMD_DHCP #define CONFIG_CMD_DEFAULTENV_VARS #define CONFIG_CMD_GREPENV #define CONFIG_CMD_IMMAP #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_EEPROM -#define CONFIG_CMD_I2C #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_MTDPARTS
@@ -55,9 +52,6 @@ #define CONFIG_LOADS_ECHO #define CONFIG_SYS_LOADS_BAUD_CHANGE
-#define CONFIG_AUTOBOOT_KEYED -#define CONFIG_AUTOBOOT_PROMPT "Hit <SPACE> key to stop autoboot in %2ds\n" -#define CONFIG_AUTOBOOT_STOP_STR " "
/* Support the IVM EEprom */ #define CONFIG_SYS_IVM_EEPROM_ADR 0x50 diff --git a/include/configs/km/km_arm.h b/include/configs/km/km_arm.h index dfc1c7e..fdd293f 100644 --- a/include/configs/km/km_arm.h +++ b/include/configs/km/km_arm.h @@ -41,7 +41,6 @@ #include "keymile-common.h"
/* SPI NOR Flash default params, used by sf commands */ #define CONFIG_SF_DEFAULT_SPEED 8100000 diff --git a/include/configs/km/kmp204x-common.h b/include/configs/km/kmp204x-common.h index 44829e8..9232ee3 100644 --- a/include/configs/km/kmp204x-common.h +++ b/include/configs/km/kmp204x-common.h @@ -285,7 +285,6 @@ int get_scl(void); * eSPI - Enhanced SPI */ #define CONFIG_SPI_FLASH_BAR /* 4 byte-addressing */ -#define CONFIG_CMD_SF #define CONFIG_SF_DEFAULT_SPEED 20000000 #define CONFIG_SF_DEFAULT_MODE 0
diff --git a/include/configs/koelsch.h b/include/configs/koelsch.h index caeb14d..685f0e5 100644 --- a/include/configs/koelsch.h +++ b/include/configs/koelsch.h @@ -65,7 +65,6 @@ #define CONFIG_SYS_TMU_CLK_DIV 4
/* i2c */ -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_SH #define CONFIG_SYS_I2C_SLAVE 0x7F diff --git a/include/configs/kzm9g.h b/include/configs/kzm9g.h index 6c9eed4..bf283fe 100644 --- a/include/configs/kzm9g.h +++ b/include/configs/kzm9g.h @@ -125,15 +125,12 @@ #define TMU_CLK_DIVIDER (4) /* 4 (default), 16, 64, 256 or 1024 */
/* Ether */ -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP #define CONFIG_SMC911X #define CONFIG_SMC911X_BASE (0x10000000) #define CONFIG_SMC911X_32_BIT #define CONFIG_NFS_TIMEOUT 10000UL
/* I2C */ -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_SH #define CONFIG_SYS_I2C_SH_NUM_CONTROLLERS 5 diff --git a/include/configs/lacie_kw.h b/include/configs/lacie_kw.h index 12fef29..18cd4bb 100644 --- a/include/configs/lacie_kw.h +++ b/include/configs/lacie_kw.h @@ -54,13 +54,8 @@ */ #define CONFIG_SYS_NO_FLASH /* Declare no flash (NOR/SPI) */ #define CONFIG_CMD_ENV -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_PING -#define CONFIG_CMD_SF -#define CONFIG_CMD_I2C #define CONFIG_CMD_IDE #ifndef CONFIG_NETSPACE_MINI_V2 /* No USB ports on Network Space v2 Mini */ -#define CONFIG_CMD_USB #endif
/* @@ -94,15 +89,7 @@ #undef CONFIG_ENV_SPI_MAX_HZ #undef CONFIG_SYS_IDE_MAXBUS #undef CONFIG_SYS_IDE_MAXDEVICE -#undef CONFIG_SYS_PROMPT #define CONFIG_ENV_SPI_MAX_HZ 20000000 /* 20Mhz */ -#if defined(CONFIG_D2NET_V2) -#define CONFIG_SYS_PROMPT "d2v2> " -#elif defined(CONFIG_NET2BIG_V2) -#define CONFIG_SYS_PROMPT "2big2> " -#else -#define CONFIG_SYS_PROMPT "ns2> " -#endif
/* * Enable platform initialisation via misc_init_r() function diff --git a/include/configs/legoev3.h b/include/configs/legoev3.h index ee458d3..a2a337d 100644 --- a/include/configs/legoev3.h +++ b/include/configs/legoev3.h @@ -128,7 +128,6 @@ #define CONFIG_BAUDRATE 115200 /* Default baud rate */
#define CONFIG_SPI -#define CONFIG_CMD_SF #define CONFIG_DAVINCI_SPI #define CONFIG_SYS_SPI_BASE DAVINCI_SPI0_BASE #define CONFIG_SYS_SPI_CLK clk_get(DAVINCI_SPI0_CLKID) @@ -211,17 +210,14 @@ * U-Boot commands */ #define CONFIG_CMD_ASKENV -#define CONFIG_CMD_DHCP #define CONFIG_CMD_DIAG #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_SAVES
#define CONFIG_ENV_IS_NOWHERE #define CONFIG_SYS_NO_FLASH diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index 134cb08..3cbb522 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -395,7 +395,6 @@ unsigned long get_board_ddr_clk(void); /* * I2C */ -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC #define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ @@ -431,7 +430,6 @@ unsigned long get_board_ddr_clk(void);
/* DM SPI */ #if defined(CONFIG_FSL_DSPI) || defined(CONFIG_FSL_QSPI) -#define CONFIG_CMD_SF #define CONFIG_DM_SPI_FLASH #define CONFIG_SPI_FLASH_DATAFLASH #endif @@ -461,7 +459,6 @@ unsigned long get_board_ddr_clk(void); #endif
#if defined(CONFIG_HAS_FSL_DR_USB) || defined(CONFIG_HAS_FSL_XHCI_USB) -#define CONFIG_CMD_USB #define CONFIG_USB_STORAGE #define CONFIG_CMD_EXT2 #endif @@ -560,17 +557,11 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_CMD_PCI #endif
#define CONFIG_CMDLINE_TAG #define CONFIG_CMDLINE_EDITING
-#if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) -#undef CONFIG_CMD_IMLS -#endif - #define CONFIG_ARMV7_NONSEC #define CONFIG_ARMV7_VIRT #define CONFIG_PEN_ADDR_BIG_ENDIAN @@ -613,8 +604,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE
#define CONFIG_CMD_GREPENV -#define CONFIG_CMD_MEMINFO -#define CONFIG_CMD_MEMTEST #define CONFIG_SYS_MEMTEST_START 0x80000000 #define CONFIG_SYS_MEMTEST_END 0x9fffffff
diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index 4654f67..1fd9e03 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -64,7 +64,6 @@ #endif
#if defined(CONFIG_HAS_FSL_DR_USB) || defined(CONFIG_HAS_FSL_XHCI_USB) -#define CONFIG_CMD_USB #define CONFIG_USB_STORAGE #define CONFIG_CMD_EXT2 #endif @@ -281,7 +280,6 @@ /* * I2C */ -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC #define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ @@ -320,7 +318,6 @@
/* DM SPI */ #if defined(CONFIG_FSL_DSPI) || defined(CONFIG_FSL_QSPI) -#define CONFIG_CMD_SF #define CONFIG_DM_SPI_FLASH #endif
@@ -409,17 +406,11 @@ #define CONFIG_CMD_PCI #endif
-#if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) -#undef CONFIG_CMD_IMLS -#endif - #define CONFIG_ARMV7_NONSEC #define CONFIG_ARMV7_VIRT #define CONFIG_PEN_ADDR_BIG_ENDIAN @@ -458,8 +449,6 @@ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE
diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index 8aa557f..d84c734 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -135,7 +135,6 @@ #endif
/* I2C */ -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC #define CONFIG_SYS_I2C_MXC_I2C1 @@ -176,9 +175,7 @@
/* Command line configuration */ #define CONFIG_CMD_CACHE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_ENV -#define CONFIG_CMD_PING
/* MMC */ #define CONFIG_MMC @@ -194,7 +191,6 @@ /* DSPI */ #define CONFIG_FSL_DSPI #ifdef CONFIG_FSL_DSPI -#define CONFIG_CMD_SF #define CONFIG_DM_SPI_FLASH #define CONFIG_SPI_FLASH_STMICRO /* cs0 */ #define CONFIG_SPI_FLASH_SST /* cs1 */ @@ -270,7 +266,6 @@
/* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ -#define CONFIG_SYS_PROMPT "=> " #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ sizeof(CONFIG_SYS_PROMPT) + 16) #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot args buffer */ diff --git a/include/configs/ls1043aqds.h b/include/configs/ls1043aqds.h index 7b79295..5c3ece8 100644 --- a/include/configs/ls1043aqds.h +++ b/include/configs/ls1043aqds.h @@ -229,7 +229,6 @@ unsigned long get_board_ddr_clk(void); #if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) #define CONFIG_QIXIS_I2C_ACCESS #define CONFIG_SYS_NO_FLASH -#undef CONFIG_CMD_IMLS #endif
/* @@ -397,7 +396,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_USB_XHCI_DWC3 #define CONFIG_USB_MAX_CONTROLLER_COUNT 3 #define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2 -#define CONFIG_CMD_USB #define CONFIG_USB_STORAGE #define CONFIG_CMD_EXT2 #endif @@ -407,15 +405,12 @@ unsigned long get_board_ddr_clk(void); */ #define CONFIG_MISC_INIT_R #define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_PROMPT "=> " #define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_PBSIZE \ (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE
diff --git a/include/configs/ls1043ardb.h b/include/configs/ls1043ardb.h index bc40b06..7c662a3 100644 --- a/include/configs/ls1043ardb.h +++ b/include/configs/ls1043ardb.h @@ -283,7 +283,6 @@ #define CONFIG_USB_XHCI_DWC3 #define CONFIG_USB_MAX_CONTROLLER_COUNT 3 #define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2 -#define CONFIG_CMD_USB #define CONFIG_USB_STORAGE #define CONFIG_CMD_EXT2 #endif diff --git a/include/configs/ls2080a_common.h b/include/configs/ls2080a_common.h index aee8e5e..648a6ff 100644 --- a/include/configs/ls2080a_common.h +++ b/include/configs/ls2080a_common.h @@ -89,7 +89,6 @@ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 2048 * 1024)
/* I2C */ -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC #define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ @@ -214,11 +213,9 @@ unsigned long long get_qixis_addr(void);
/* Command line configuration */ #define CONFIG_CMD_CACHE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_ENV #define CONFIG_CMD_GREPENV #define CONFIG_CMD_MII -#define CONFIG_CMD_PING
/* Miscellaneous configurable options */ #define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_DDR_SDRAM_BASE + 0x10000000) diff --git a/include/configs/ls2080aqds.h b/include/configs/ls2080aqds.h index 91fad0a..c40f0f2 100644 --- a/include/configs/ls2080aqds.h +++ b/include/configs/ls2080aqds.h @@ -283,7 +283,6 @@ unsigned long get_board_ddr_clk(void);
/* SPI */ #ifdef CONFIG_FSL_DSPI -#define CONFIG_CMD_SF #define CONFIG_SPI_FLASH #endif
@@ -395,7 +394,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_USB_XHCI_DWC3 #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2 -#define CONFIG_CMD_USB #define CONFIG_USB_STORAGE #define CONFIG_CMD_EXT2
diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index 15a1172..4aed2de 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -272,7 +272,6 @@ unsigned long get_board_sys_clk(void);
/* SPI */ #ifdef CONFIG_FSL_DSPI -#define CONFIG_CMD_SF #define CONFIG_SPI_FLASH #define CONFIG_SPI_FLASH_BAR #endif @@ -327,7 +326,6 @@ unsigned long get_board_sys_clk(void); #define CONFIG_USB_XHCI_DWC3 #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2 -#define CONFIG_CMD_USB #define CONFIG_USB_STORAGE #define CONFIG_CMD_EXT2
diff --git a/include/configs/lsxl.h b/include/configs/lsxl.h index f9ada1a..0ce422e 100644 --- a/include/configs/lsxl.h +++ b/include/configs/lsxl.h @@ -51,16 +51,10 @@ * Commands configuration */ #define CONFIG_CMD_BOOTZ -#define CONFIG_CMD_DHCP #define CONFIG_CMD_ENV #define CONFIG_CMD_EXT2 #define CONFIG_CMD_FAT #define CONFIG_CMD_IDE -#define CONFIG_CMD_PING -#define CONFIG_CMD_PING -#define CONFIG_CMD_SF -#define CONFIG_CMD_SPI -#define CONFIG_CMD_USB #define CONFIG_CMD_FS_GENERIC
#define CONFIG_DOS_PARTITION diff --git a/include/configs/lwmon5.h b/include/configs/lwmon5.h index ebc0f8b..0b1788f 100644 --- a/include/configs/lwmon5.h +++ b/include/configs/lwmon5.h @@ -403,14 +403,11 @@ */ #define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_DIAG #define CONFIG_CMD_EEPROM #define CONFIG_CMD_FAT -#define CONFIG_CMD_I2C #define CONFIG_CMD_IRQ #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO #define CONFIG_CMD_SDRAM
@@ -419,7 +416,6 @@ #endif
#ifdef CONFIG_440EPX -#define CONFIG_CMD_USB #endif
/* @@ -446,7 +442,6 @@ #define CONFIG_SYS_EXTBDINFO 1 /* To use extended board_into (bd_t) */
#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ -#define CONFIG_LOOPW 1 /* enable loopw command */ #define CONFIG_MX_CYCLIC 1 /* enable mdc/mwc commands */ #define CONFIG_VERSION_VARIABLE 1 /* include version env variable */
diff --git a/include/configs/m28evk.h b/include/configs/m28evk.h index 57599f9..0a537ce 100644 --- a/include/configs/m28evk.h +++ b/include/configs/m28evk.h @@ -24,22 +24,16 @@ #define CONFIG_CMD_BMP #define CONFIG_CMD_CACHE #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EEPROM #define CONFIG_CMD_EXT4 #define CONFIG_CMD_EXT4_WRITE #define CONFIG_CMD_FAT #define CONFIG_CMD_FS_GENERIC #define CONFIG_CMD_GREPENV -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII #define CONFIG_CMD_MMC #define CONFIG_CMD_NAND #define CONFIG_CMD_NAND_TRIMFFS -#define CONFIG_CMD_PING -#define CONFIG_CMD_SF -#define CONFIG_CMD_SPI -#define CONFIG_CMD_USB #define CONFIG_VIDEO
diff --git a/include/configs/m53evk.h b/include/configs/m53evk.h index 5763ae3..600eea0 100644 --- a/include/configs/m53evk.h +++ b/include/configs/m53evk.h @@ -31,20 +31,16 @@ #define CONFIG_CMD_ASKENV #define CONFIG_CMD_BMP #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EXT4 #define CONFIG_CMD_EXT4_WRITE #define CONFIG_CMD_FAT #define CONFIG_CMD_FS_GENERIC #define CONFIG_CMD_GREPENV -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII #define CONFIG_CMD_MMC #define CONFIG_CMD_NAND #define CONFIG_CMD_NAND_TRIMFFS -#define CONFIG_CMD_PING #define CONFIG_CMD_SATA -#define CONFIG_CMD_USB #define CONFIG_VIDEO
diff --git a/include/configs/ma5d4evk.h b/include/configs/ma5d4evk.h index df141c9..2429e3a 100644 --- a/include/configs/ma5d4evk.h +++ b/include/configs/ma5d4evk.h @@ -25,7 +25,6 @@
#define CONFIG_CMD_ASKENV #define CONFIG_CMD_CACHE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EXT4 #define CONFIG_CMD_EXT4_WRITE #define CONFIG_CMD_FAT @@ -33,9 +32,6 @@ #define CONFIG_CMD_GREPENV #define CONFIG_CMD_MII #define CONFIG_CMD_MMC -#define CONFIG_CMD_PING -#define CONFIG_CMD_SF -#define CONFIG_CMD_USB
/* * Memory configurations diff --git a/include/configs/makalu.h b/include/configs/makalu.h index fd4c26e..dcfe3d7 100644 --- a/include/configs/makalu.h +++ b/include/configs/makalu.h @@ -236,7 +236,6 @@ #define CONFIG_CMD_DATE #define CONFIG_CMD_DTT #define CONFIG_CMD_PCI -#define CONFIG_CMD_SNTP
/* POST support */ #define CONFIG_POST (CONFIG_SYS_POST_CACHE | \ diff --git a/include/configs/malta.h b/include/configs/malta.h index 7f93b94..04dca71 100644 --- a/include/configs/malta.h +++ b/include/configs/malta.h @@ -53,16 +53,6 @@ #define CONFIG_SYS_BOOTPARAMS_LEN (128 * 1024) #define CONFIG_SYS_BOOTM_LEN (64 * 1024 * 1024)
-/* - * Console configuration - */ -#undef CONFIG_SYS_PROMPT -#if defined(CONFIG_SYS_LITTLE_ENDIAN) -#define CONFIG_SYS_PROMPT "maltael # " -#else -#define CONFIG_SYS_PROMPT "malta # " -#endif - #define CONFIG_SYS_CBSIZE 256 #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ sizeof(CONFIG_SYS_PROMPT) + 16) @@ -116,10 +106,8 @@ * Commands */ #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_IDE #define CONFIG_CMD_PCI -#define CONFIG_CMD_PING
#define CONFIG_SYS_LONGHELP /* verbose help, undef to save memory */
diff --git a/include/configs/manroland/common.h b/include/configs/manroland/common.h index 3c081a2..20457f6 100644 --- a/include/configs/manroland/common.h +++ b/include/configs/manroland/common.h @@ -23,15 +23,11 @@ */ #define CONFIG_CMD_DATE #define CONFIG_CMD_DISPLAY -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_PING #define CONFIG_CMD_EEPROM -#define CONFIG_CMD_I2C #define CONFIG_CMD_DTT #define CONFIG_CMD_IDE #define CONFIG_CMD_FAT #define CONFIG_CMD_MII -#define CONFIG_CMD_SNTP
/* * 8-symbol LED display (can be accessed with 'display' command) @@ -113,6 +109,5 @@ /* * Enable loopw command. */ -#define CONFIG_LOOPW
#endif /* __MANROLAND_COMMON_H */ diff --git a/include/configs/maxbcm.h b/include/configs/maxbcm.h index 43d7fd0..fed310f 100644 --- a/include/configs/maxbcm.h +++ b/include/configs/maxbcm.h @@ -24,14 +24,7 @@ * Commands configuration */ #define CONFIG_SYS_NO_FLASH /* Declare no flash (NOR/SPI) */ -#define CONFIG_CMD_DHCP #define CONFIG_CMD_ENV -#define CONFIG_CMD_I2C -#define CONFIG_CMD_PING -#define CONFIG_CMD_SF -#define CONFIG_CMD_SPI -#define CONFIG_CMD_TFTPPUT -#define CONFIG_CMD_TIME
/* I2C */ #define CONFIG_SYS_I2C diff --git a/include/configs/mcx.h b/include/configs/mcx.h index 6bd6933..01f1d83 100644 --- a/include/configs/mcx.h +++ b/include/configs/mcx.h @@ -114,13 +114,9 @@ #define CONFIG_CMD_JFFS2 /* JFFS2 Support */
#define CONFIG_CMD_DATE -#define CONFIG_CMD_I2C /* I2C serial bus support */ #define CONFIG_CMD_MMC /* MMC support */ #define CONFIG_CMD_FAT /* FAT support */ -#define CONFIG_CMD_USB #define CONFIG_CMD_NAND /* NAND support */ -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_PING #define CONFIG_CMD_CACHE #define CONFIG_CMD_UBI #define CONFIG_CMD_UBIFS diff --git a/include/configs/mecp5123.h b/include/configs/mecp5123.h index 61a4a8e..46453c4 100644 --- a/include/configs/mecp5123.h +++ b/include/configs/mecp5123.h @@ -292,10 +292,7 @@ #define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */
#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO #define CONFIG_CMD_EEPROM #define CONFIG_CMD_DATE diff --git a/include/configs/medcom-wide.h b/include/configs/medcom-wide.h index 4c05fc8..8a24cfb 100644 --- a/include/configs/medcom-wide.h +++ b/include/configs/medcom-wide.h @@ -38,14 +38,12 @@ #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_TEGRA #define CONFIG_USB_STORAGE -#define CONFIG_CMD_USB
/* USB networking support */ #define CONFIG_USB_HOST_ETHER #define CONFIG_USB_ETHER_SMSC95XX
/* LCD support */ #define CONFIG_SYS_WHITE_ON_BLACK diff --git a/include/configs/meesc.h b/include/configs/meesc.h index 76b2e1d..e7d2694 100644 --- a/include/configs/meesc.h +++ b/include/configs/meesc.h @@ -85,13 +85,7 @@ /* * Command line configuration. */ -#undef CONFIG_CMD_BDI -#undef CONFIG_CMD_FPGA -#undef CONFIG_CMD_LOADS -#undef CONFIG_CMD_IMLS
#ifdef CONFIG_SYS_USE_NANDFLASH #define CONFIG_CMD_NAND diff --git a/include/configs/microblaze-generic.h b/include/configs/microblaze-generic.h index 09bfabc..cdaf828 100644 --- a/include/configs/microblaze-generic.h +++ b/include/configs/microblaze-generic.h @@ -193,7 +193,6 @@
#else #if defined(SPIFLASH) -# define CONFIG_CMD_SF
# if !defined(RAMENV) # define CONFIG_CMD_SAVES diff --git a/include/configs/motionpro.h b/include/configs/motionpro.h index 53907f9..f4b0e34 100644 --- a/include/configs/motionpro.h +++ b/include/configs/motionpro.h @@ -37,16 +37,13 @@ #define CONFIG_CMD_ASKENV #define CONFIG_CMD_BEDBUG #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_DTT #define CONFIG_CMD_EEPROM #define CONFIG_CMD_FAT -#define CONFIG_CMD_I2C #define CONFIG_CMD_IDE #define CONFIG_CMD_IMMAP #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO
/* diff --git a/include/configs/mpc5121ads.h b/include/configs/mpc5121ads.h index 1b2e029..9cc940c 100644 --- a/include/configs/mpc5121ads.h +++ b/include/configs/mpc5121ads.h @@ -379,7 +379,6 @@ /* * USB Support */ -#define CONFIG_CMD_USB
#if defined(CONFIG_CMD_USB) #define CONFIG_USB_EHCI /* Enable EHCI Support */ @@ -412,14 +411,11 @@
#define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EEPROM #define CONFIG_CMD_EXT2 -#define CONFIG_CMD_I2C #define CONFIG_CMD_IDE #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO
#undef CONFIG_CMD_FUSE diff --git a/include/configs/mpc8308_p1m.h b/include/configs/mpc8308_p1m.h index bf7f745..149f365 100644 --- a/include/configs/mpc8308_p1m.h +++ b/include/configs/mpc8308_p1m.h @@ -388,11 +388,8 @@ /* * Command line configuration. */ -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII #define CONFIG_CMD_PCI -#define CONFIG_CMD_PING
diff --git a/include/configs/ms7722se.h b/include/configs/ms7722se.h index 12bb3a0..f983f2d 100644 --- a/include/configs/ms7722se.h +++ b/include/configs/ms7722se.h @@ -13,7 +13,6 @@ #define CONFIG_MS7722SE 1
#define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_PING #define CONFIG_CMD_SDRAM
#define CONFIG_BAUDRATE 115200 diff --git a/include/configs/munices.h b/include/configs/munices.h index 0601256..438497e 100644 --- a/include/configs/munices.h +++ b/include/configs/munices.h @@ -28,7 +28,6 @@ */ #define CONFIG_CMD_ASKENV #define CONFIG_CMD_IMMAP -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO
#if defined(CONFIG_CMD_KGDB) diff --git a/include/configs/mx23_olinuxino.h b/include/configs/mx23_olinuxino.h index e6a08d1..705bee8 100644 --- a/include/configs/mx23_olinuxino.h +++ b/include/configs/mx23_olinuxino.h @@ -16,12 +16,10 @@ #define CONFIG_DOS_PARTITION
#define CONFIG_CMD_CACHE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EXT2 #define CONFIG_CMD_FAT #define CONFIG_CMD_LED #define CONFIG_CMD_MMC -#define CONFIG_CMD_USB
/* Memory configuration */ #define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ diff --git a/include/configs/mx23evk.h b/include/configs/mx23evk.h index 92f8f86..4936733 100644 --- a/include/configs/mx23evk.h +++ b/include/configs/mx23evk.h @@ -22,7 +22,6 @@ #define CONFIG_CMD_EXT2 #define CONFIG_CMD_FAT #define CONFIG_CMD_MMC -#define CONFIG_CMD_USB #define CONFIG_CMD_BOOTZ #define CONFIG_VIDEO
diff --git a/include/configs/mx25pdk.h b/include/configs/mx25pdk.h index a85855d..cc86c94 100644 --- a/include/configs/mx25pdk.h +++ b/include/configs/mx25pdk.h @@ -111,7 +111,6 @@ #define CONFIG_DOS_PARTITION
/* I2C Configs */ -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC #define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ @@ -123,8 +122,6 @@
/* Ethernet Configs */
#define CONFIG_BOOTDELAY 1 diff --git a/include/configs/mx28evk.h b/include/configs/mx28evk.h index 4d86c13..36a5063 100644 --- a/include/configs/mx28evk.h +++ b/include/configs/mx28evk.h @@ -22,17 +22,12 @@
#define CONFIG_CMD_CACHE #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EXT4 #define CONFIG_CMD_EXT4_WRITE #define CONFIG_CMD_FAT #define CONFIG_CMD_FS_GENERIC #define CONFIG_CMD_MII #define CONFIG_CMD_MMC -#define CONFIG_CMD_PING -#define CONFIG_CMD_SF -#define CONFIG_CMD_SPI -#define CONFIG_CMD_USB #define CONFIG_CMD_BOOTZ #define CONFIG_CMD_NAND #define CONFIG_CMD_NAND_TRIMFFS diff --git a/include/configs/mx31ads.h b/include/configs/mx31ads.h index 5f94e19..78aa22b 100644 --- a/include/configs/mx31ads.h +++ b/include/configs/mx31ads.h @@ -63,9 +63,6 @@ /*********************************************************** * Command definition ***********************************************************/ -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_SPI #define CONFIG_CMD_DATE
#define CONFIG_BOOTDELAY 3 diff --git a/include/configs/mx31pdk.h b/include/configs/mx31pdk.h index 3813e25..75d24bf 100644 --- a/include/configs/mx31pdk.h +++ b/include/configs/mx31pdk.h @@ -81,9 +81,6 @@ * Command definition ***********************************************************/ #define CONFIG_CMD_MII -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_SPI #define CONFIG_CMD_DATE #define CONFIG_CMD_NAND #define CONFIG_CMD_BOOTZ diff --git a/include/configs/mx35pdk.h b/include/configs/mx35pdk.h index f7a050e..9e736eb 100644 --- a/include/configs/mx35pdk.h +++ b/include/configs/mx35pdk.h @@ -80,8 +80,6 @@ * Command definition */ #define CONFIG_CMD_BOOTZ -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP #define CONFIG_BOOTP_SUBNETMASK #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_DNS @@ -89,13 +87,10 @@ #define CONFIG_CMD_NAND #define CONFIG_CMD_CACHE
-#define CONFIG_CMD_I2C -#define CONFIG_CMD_SPI #define CONFIG_CMD_MII #define CONFIG_NET_RETRY_COUNT 100 #define CONFIG_CMD_DATE
-#define CONFIG_CMD_USB #define CONFIG_USB_STORAGE #define CONFIG_CMD_MMC #define CONFIG_DOS_PARTITION diff --git a/include/configs/mx51evk.h b/include/configs/mx51evk.h index 125d25d..2f75f2b 100644 --- a/include/configs/mx51evk.h +++ b/include/configs/mx51evk.h @@ -49,7 +49,6 @@ /* * SPI Configs * */ -#define CONFIG_CMD_SPI
@@ -87,12 +86,9 @@ #define IMX_FEC_BASE FEC_BASE_ADDR #define CONFIG_FEC_MXC_PHYADDR 0x1F
/* USB Configs */ -#define CONFIG_CMD_USB #define CONFIG_CMD_FAT #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_MX5 diff --git a/include/configs/mx53ard.h b/include/configs/mx53ard.h index 033a542..0eb5203 100644 --- a/include/configs/mx53ard.h +++ b/include/configs/mx53ard.h @@ -47,7 +47,6 @@ #define CONFIG_MXC_UART_BASE UART1_BASE
/* I2C Configs */ -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC #define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ @@ -69,8 +68,6 @@ #define CONFIG_HAS_ETH1 #define CONFIG_MII
/* allow to overwrite serial and ethaddr */ diff --git a/include/configs/mx53evk.h b/include/configs/mx53evk.h index a41c778..46f93b9 100644 --- a/include/configs/mx53evk.h +++ b/include/configs/mx53evk.h @@ -36,7 +36,6 @@ #define CONFIG_MXC_UART_BASE UART1_BASE
/* I2C Configs */ -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC #define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ @@ -69,8 +68,6 @@ #define IMX_FEC_BASE FEC_BASE_ADDR #define CONFIG_FEC_MXC_PHYADDR 0x1F
-#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP #define CONFIG_CMD_MII #define CONFIG_CMD_DATE
diff --git a/include/configs/mx53loco.h b/include/configs/mx53loco.h index 7f9e3b4..8d2581a 100644 --- a/include/configs/mx53loco.h +++ b/include/configs/mx53loco.h @@ -55,12 +55,9 @@ #define IMX_FEC_BASE FEC_BASE_ADDR #define CONFIG_FEC_MXC_PHYADDR 0x1F
/* USB Configs */ -#define CONFIG_CMD_USB #define CONFIG_CMD_FAT #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_MX5 diff --git a/include/configs/mx53smd.h b/include/configs/mx53smd.h index e851da2..f5019c2 100644 --- a/include/configs/mx53smd.h +++ b/include/configs/mx53smd.h @@ -35,7 +35,6 @@ #define CONFIG_MXC_UART_BASE UART1_BASE
/* I2C Configs */ -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC #define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ @@ -61,8 +60,6 @@ #define IMX_FEC_BASE FEC_BASE_ADDR #define CONFIG_FEC_MXC_PHYADDR 0x1F
/* allow to overwrite serial and ethaddr */ diff --git a/include/configs/mx6_common.h b/include/configs/mx6_common.h index c6996e2..ffd13ca 100644 --- a/include/configs/mx6_common.h +++ b/include/configs/mx6_common.h @@ -79,7 +79,6 @@ #define CONFIG_CMD_FAT
/* Miscellaneous configurable options */ -#undef CONFIG_CMD_IMLS #define CONFIG_SYS_LONGHELP #define CONFIG_CMDLINE_EDITING #define CONFIG_AUTO_COMPLETE diff --git a/include/configs/mx6cuboxi.h b/include/configs/mx6cuboxi.h index 4feb121..70760a1 100644 --- a/include/configs/mx6cuboxi.h +++ b/include/configs/mx6cuboxi.h @@ -27,8 +27,6 @@
/* Ethernet Configuration */ #define CONFIG_FEC_MXC -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP #define CONFIG_CMD_MII #define CONFIG_MII #define IMX_FEC_BASE ENET_BASE_ADDR @@ -56,7 +54,6 @@ #define CONFIG_CONSOLE_MUX
/* USB */ -#define CONFIG_CMD_USB #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_MX6 #define CONFIG_USB_STORAGE diff --git a/include/configs/mx6qarm2.h b/include/configs/mx6qarm2.h index 86a0316..60c07cf 100644 --- a/include/configs/mx6qarm2.h +++ b/include/configs/mx6qarm2.h @@ -23,8 +23,6 @@ #define CONFIG_SYS_FSL_ESDHC_ADDR USDHC4_BASE_ADDR #define CONFIG_SYS_FSL_USDHC_NUM 2
-#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP #define CONFIG_CMD_MII #define CONFIG_FEC_MXC #define CONFIG_MII @@ -132,7 +130,6 @@ #define CONFIG_SYS_MMC_ENV_DEV 1
/* USB Configs */ -#define CONFIG_CMD_USB #ifdef CONFIG_CMD_USB #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_MX6 diff --git a/include/configs/mx6qsabreauto.h b/include/configs/mx6qsabreauto.h index 1c99805..6039fc4 100644 --- a/include/configs/mx6qsabreauto.h +++ b/include/configs/mx6qsabreauto.h @@ -16,7 +16,6 @@ #define PHYS_SDRAM_SIZE (2u * 1024 * 1024 * 1024)
/* USB Configs */ -#define CONFIG_CMD_USB #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_MX6 #define CONFIG_USB_STORAGE @@ -48,7 +47,6 @@ #endif
/* I2C Configs */ -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC #define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ diff --git a/include/configs/mx6sabre_common.h b/include/configs/mx6sabre_common.h index 87bbf2e..072003c 100644 --- a/include/configs/mx6sabre_common.h +++ b/include/configs/mx6sabre_common.h @@ -24,8 +24,6 @@ /* MMC Configs */ #define CONFIG_SYS_FSL_ESDHC_ADDR 0
-#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP #define CONFIG_CMD_MII #define CONFIG_FEC_MXC #define CONFIG_MII @@ -37,7 +35,6 @@ #define CONFIG_PHYLIB #define CONFIG_PHY_ATHEROS
-#define CONFIG_CMD_SF #ifdef CONFIG_CMD_SF #define CONFIG_MXC_SPI #define CONFIG_SF_DEFAULT_BUS 0 diff --git a/include/configs/mx6sabresd.h b/include/configs/mx6sabresd.h index bfc4f61..25f51be 100644 --- a/include/configs/mx6sabresd.h +++ b/include/configs/mx6sabresd.h @@ -40,7 +40,6 @@ #endif
/* I2C Configs */ -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC #define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ @@ -55,7 +54,6 @@ #define CONFIG_POWER_PFUZE100_I2C_ADDR 0x08
/* USB Configs */ -#define CONFIG_CMD_USB #ifdef CONFIG_CMD_USB #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_MX6 diff --git a/include/configs/mx6slevk.h b/include/configs/mx6slevk.h index 6423796..cc73684 100644 --- a/include/configs/mx6slevk.h +++ b/include/configs/mx6slevk.h @@ -32,7 +32,6 @@ #define CONFIG_SYS_FSL_ESDHC_ADDR USDHC2_BASE_ADDR
/* I2C Configs */ -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC #define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ @@ -46,8 +45,6 @@ #define CONFIG_POWER_PFUZE100 #define CONFIG_POWER_PFUZE100_I2C_ADDR 0x08
-#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP #define CONFIG_CMD_MII #define CONFIG_FEC_MXC #define CONFIG_MII @@ -168,7 +165,6 @@ #define CONFIG_ENV_IS_IN_MMC #endif
-#define CONFIG_CMD_SF #ifdef CONFIG_CMD_SF #define CONFIG_MXC_SPI #define CONFIG_SF_DEFAULT_BUS 0 @@ -178,7 +174,6 @@ #endif
/* USB Configs */ -#define CONFIG_CMD_USB #ifdef CONFIG_CMD_USB #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_MX6 diff --git a/include/configs/mx6sxsabreauto.h b/include/configs/mx6sxsabreauto.h index 2e739f9..14acea9 100644 --- a/include/configs/mx6sxsabreauto.h +++ b/include/configs/mx6sxsabreauto.h @@ -120,7 +120,6 @@ #define CONFIG_SYS_FSL_ESDHC_ADDR USDHC3_BASE_ADDR
/* I2C Configs */ -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC #define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ @@ -151,8 +150,6 @@ #define CONFIG_APBH_DMA_BURST8
/* Network */ -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP #define CONFIG_CMD_MII
#define CONFIG_FEC_MXC @@ -168,7 +165,6 @@ #define CONFIG_PHY_ATHEROS
-#define CONFIG_CMD_USB #ifdef CONFIG_CMD_USB #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_MX6 @@ -183,11 +179,9 @@
#define CONFIG_IMX_THERMAL
#define CONFIG_FSL_QSPI #ifdef CONFIG_FSL_QSPI -#define CONFIG_CMD_SF #define CONFIG_SYS_FSL_QSPI_AHB #define CONFIG_SF_DEFAULT_BUS 0 #define CONFIG_SF_DEFAULT_CS 0 diff --git a/include/configs/mx6sxsabresd.h b/include/configs/mx6sxsabresd.h index fdf2396..c28a747 100644 --- a/include/configs/mx6sxsabresd.h +++ b/include/configs/mx6sxsabresd.h @@ -29,7 +29,6 @@ #ifdef CONFIG_IMX_BOOTAUX /* Set to QSPI2 B flash at default */ #define CONFIG_SYS_AUXCORE_BOOTDATA 0x78000000 -#define CONFIG_CMD_SETEXPR
#define UPDATE_M4_ENV \ "m4image=m4_qspi.bin\0" \ @@ -149,7 +148,6 @@ #define CONFIG_SYS_FSL_ESDHC_ADDR USDHC4_BASE_ADDR
/* I2C Configs */ -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC #define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ @@ -164,8 +162,6 @@ #define CONFIG_POWER_PFUZE100_I2C_ADDR 0x08
/* Network */ -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP #define CONFIG_CMD_MII #define CONFIG_FEC_MXC #define CONFIG_MII @@ -180,7 +176,6 @@ #define CONFIG_PHY_ATHEROS
-#define CONFIG_CMD_USB #ifdef CONFIG_CMD_USB #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_MX6 @@ -205,11 +200,9 @@
#ifdef CONFIG_FSL_QSPI -#define CONFIG_CMD_SF #define CONFIG_SYS_FSL_QSPI_LE #define CONFIG_SYS_FSL_QSPI_AHB #ifdef CONFIG_MX6SX_SABRESD_REVA diff --git a/include/configs/mx6ul_14x14_evk.h b/include/configs/mx6ul_14x14_evk.h index 2fff34a..eb92138 100644 --- a/include/configs/mx6ul_14x14_evk.h +++ b/include/configs/mx6ul_14x14_evk.h @@ -50,7 +50,6 @@ #endif
/* I2C configs */ -#define CONFIG_CMD_I2C #ifdef CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC @@ -154,7 +153,6 @@ "else run netboot; fi"
/* Miscellaneous configurable options */ -#define CONFIG_CMD_MEMTEST #define CONFIG_SYS_MEMTEST_START 0x80000000 #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + 0x8000000)
@@ -196,7 +194,6 @@
#define CONFIG_FSL_QSPI #ifdef CONFIG_FSL_QSPI -#define CONFIG_CMD_SF #define CONFIG_SPI_FLASH #define CONFIG_SPI_FLASH_BAR #define CONFIG_SF_DEFAULT_BUS 0 @@ -209,7 +206,6 @@ #endif
/* USB Configs */ -#define CONFIG_CMD_USB #ifdef CONFIG_CMD_USB #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_MX6 diff --git a/include/configs/mx7_common.h b/include/configs/mx7_common.h index 05c5281..bf6bae6 100644 --- a/include/configs/mx7_common.h +++ b/include/configs/mx7_common.h @@ -52,7 +52,6 @@ #define CONFIG_CMD_FAT
/* Miscellaneous configurable options */ -#undef CONFIG_CMD_IMLS #define CONFIG_SYS_LONGHELP #define CONFIG_CMDLINE_EDITING #define CONFIG_AUTO_COMPLETE diff --git a/include/configs/mx7dsabresd.h b/include/configs/mx7dsabresd.h index ad87b24..5f63a1f 100644 --- a/include/configs/mx7dsabresd.h +++ b/include/configs/mx7dsabresd.h @@ -52,11 +52,7 @@ #undef CONFIG_BOOTM_PLAN9 #undef CONFIG_BOOTM_RTEMS
-#undef CONFIG_CMD_EXPORTENV -#undef CONFIG_CMD_IMPORTENV - /* I2C configs */ -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC #define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ @@ -68,7 +64,6 @@ #ifdef CONFIG_IMX_BOOTAUX /* Set to QSPI1 A flash at default */ #define CONFIG_SYS_AUXCORE_BOOTDATA 0x60000000 -#define CONFIG_CMD_SETEXPR
#define UPDATE_M4_ENV \ "m4image=m4_qspi.bin\0" \ @@ -185,7 +180,6 @@ "fi; " \ "else run netboot; fi"
-#define CONFIG_CMD_MEMTEST #define CONFIG_SYS_MEMTEST_START 0x80000000 #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + 0x20000000)
@@ -244,7 +238,6 @@ #define CONFIG_MMCROOT "/dev/mmcblk0p2" /* USDHC1 */
/* USB Configs */ -#define CONFIG_CMD_USB #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_MX7 #define CONFIG_USB_STORAGE @@ -285,7 +278,6 @@ #endif
#ifdef CONFIG_FSL_QSPI -#define CONFIG_CMD_SF #define CONFIG_SPI_FLASH #define CONFIG_SPI_FLASH_MACRONIX #define CONFIG_SPI_FLASH_BAR diff --git a/include/configs/nas220.h b/include/configs/nas220.h index d4bea63..96ee7ec 100644 --- a/include/configs/nas220.h +++ b/include/configs/nas220.h @@ -44,11 +44,8 @@ * Commands configuration */ #define CONFIG_SYS_NO_FLASH /* Declare no flash (NOR/SPI) */ -#define CONFIG_CMD_DHCP #define CONFIG_CMD_MII #define CONFIG_CMD_NAND -#define CONFIG_CMD_PING -#define CONFIG_CMD_USB #define CONFIG_CMD_DATE #define CONFIG_CMD_IDE #define CONFIG_SYS_LONGHELP diff --git a/include/configs/neo.h b/include/configs/neo.h index bd2b190..3121c03 100644 --- a/include/configs/neo.h +++ b/include/configs/neo.h @@ -61,10 +61,8 @@ * Commands additional to the ones defined in amcc-common.h */ #define CONFIG_CMD_DTT -#undef CONFIG_CMD_DHCP #undef CONFIG_CMD_DIAG #undef CONFIG_CMD_EEPROM -#undef CONFIG_CMD_I2C #undef CONFIG_CMD_IRQ
/* diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h index cb249c0..7696b53 100644 --- a/include/configs/nitrogen6x.h +++ b/include/configs/nitrogen6x.h @@ -27,7 +27,6 @@ #define CONFIG_MXC_UART #define CONFIG_MXC_UART_BASE UART2_BASE
-#define CONFIG_CMD_SF #ifdef CONFIG_CMD_SF #define CONFIG_MXC_SPI #define CONFIG_SF_DEFAULT_BUS 0 @@ -37,7 +36,6 @@ #endif
/* I2C Configs */ -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC #define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ @@ -66,8 +64,6 @@ #define CONFIG_LIBATA #endif
-#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP #define CONFIG_CMD_MII #define CONFIG_FEC_MXC #define CONFIG_MII @@ -80,7 +76,6 @@ #define CONFIG_PHY_MICREL_KSZ9021
/* USB Configs */ -#define CONFIG_CMD_USB #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_MX6 #define CONFIG_USB_STORAGE @@ -313,8 +308,6 @@
-#define CONFIG_CMD_TIME -#define CONFIG_CMD_MEMTEST #define CONFIG_SYS_ALT_MEMTEST
/* diff --git a/include/configs/nokia_rx51.h b/include/configs/nokia_rx51.h index 7a1ce3c..c6353e0 100644 --- a/include/configs/nokia_rx51.h +++ b/include/configs/nokia_rx51.h @@ -128,7 +128,6 @@ #define CONFIG_CMD_EXT4 /* EXT4 Support */ #define CONFIG_CMD_FAT /* FAT support */
#define CONFIG_CMDLINE_EDITING /* add command line history */ diff --git a/include/configs/novena.h b/include/configs/novena.h index d58c95f..8b6e93e 100644 --- a/include/configs/novena.h +++ b/include/configs/novena.h @@ -21,16 +21,11 @@ /* U-Boot Commands */ #define CONFIG_CMD_ASKENV #define CONFIG_CMD_BMODE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EEPROM -#define CONFIG_CMD_I2C #define CONFIG_FAT_WRITE #define CONFIG_CMD_MII #define CONFIG_CMD_PCI -#define CONFIG_CMD_PING #define CONFIG_CMD_SATA -#define CONFIG_CMD_TIME -#define CONFIG_CMD_USB #define CONFIG_VIDEO
/* U-Boot general configurations */ diff --git a/include/configs/nyan-big.h b/include/configs/nyan-big.h index 0b6173b..49e5eae 100644 --- a/include/configs/nyan-big.h +++ b/include/configs/nyan-big.h @@ -23,7 +23,6 @@
/* SD/MMC */ #define CONFIG_MMC @@ -48,22 +47,18 @@ /* SPI */ #define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 #define CONFIG_SF_DEFAULT_SPEED 24000000 -#define CONFIG_CMD_SPI -#define CONFIG_CMD_SF #define CONFIG_SPI_FLASH_SIZE (4 << 20)
/* USB Host support */ #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_TEGRA #define CONFIG_USB_STORAGE -#define CONFIG_CMD_USB
/* USB networking support */ #define CONFIG_USB_HOST_ETHER #define CONFIG_USB_ETHER_ASIX
/* General networking support */ -#define CONFIG_CMD_DHCP
#define CONFIG_KEYBOARD
diff --git a/include/configs/o2dnt-common.h b/include/configs/o2dnt-common.h index 724c33d..1b06719 100644 --- a/include/configs/o2dnt-common.h +++ b/include/configs/o2dnt-common.h @@ -77,10 +77,7 @@ */ #define CONFIG_CMD_EEPROM #define CONFIG_CMD_FAT -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP #ifdef CONFIG_PCI #define CONFIG_CMD_PCI #endif diff --git a/include/configs/odroid.h b/include/configs/odroid.h index 9d764d5..0b691e4 100644 --- a/include/configs/odroid.h +++ b/include/configs/odroid.h @@ -180,7 +180,6 @@ "fdtaddr=40800000\0"
/* I2C */ -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C_S3C24X0 #define CONFIG_SYS_I2C_S3C24X0_SPEED 100000 #define CONFIG_SYS_I2C_S3C24X0_SLAVE 0 @@ -194,14 +193,11 @@
/* USB */ -#define CONFIG_CMD_USB #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_EXYNOS #define CONFIG_USB_STORAGE
#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 3 -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP #define CONFIG_USB_HOST_ETHER #define CONFIG_USB_ETHER_SMSC95XX
diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index 3fa8d7e..d7e6c37 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -71,7 +71,6 @@ #define CONFIG_FASTBOOT_BUF_SIZE 0x07000000
/* USB EHCI */ -#define CONFIG_CMD_USB #define CONFIG_USB_EHCI
#define CONFIG_USB_EHCI_OMAP @@ -100,7 +99,6 @@ #define CONFIG_USB_STORAGE /* USB storage support */ #define CONFIG_CMD_NAND /* NAND support */ #define CONFIG_CMD_LED /* LED support */ -#define CONFIG_CMD_DHCP
#define CONFIG_VIDEO_OMAP3 /* DSS Support */
diff --git a/include/configs/omap3_evm.h b/include/configs/omap3_evm.h index c831f36..8048ce8 100644 --- a/include/configs/omap3_evm.h +++ b/include/configs/omap3_evm.h @@ -30,11 +30,8 @@ #define CONFIG_CMD_FAT #define CONFIG_CMD_JFFS2
-#define CONFIG_CMD_I2C #define CONFIG_CMD_MMC #define CONFIG_CMD_NAND -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_PING
/* ---------------------------------------------------------------------------- * Supported U-Boot features diff --git a/include/configs/omap3_evm_common.h b/include/configs/omap3_evm_common.h index 0f16a6e..99dab5f 100644 --- a/include/configs/omap3_evm_common.h +++ b/include/configs/omap3_evm_common.h @@ -146,7 +146,6 @@ #ifdef CONFIG_USB_OMAP3
#ifdef CONFIG_USB_MUSB_HCD -#define CONFIG_CMD_USB
#define CONFIG_USB_STORAGE #define CONGIG_CMD_STORAGE diff --git a/include/configs/omap3_igep00x0.h b/include/configs/omap3_igep00x0.h index 5e33845..8e438e9 100644 --- a/include/configs/omap3_igep00x0.h +++ b/include/configs/omap3_igep00x0.h @@ -73,8 +73,6 @@ #ifdef CONFIG_BOOT_ONENAND #define CONFIG_CMD_ONENAND /* ONENAND support */ #endif -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_PING
#ifndef CONFIG_SPL_BUILD
diff --git a/include/configs/omap3_logic.h b/include/configs/omap3_logic.h index 0cb62e9..9aaab01 100644 --- a/include/configs/omap3_logic.h +++ b/include/configs/omap3_logic.h @@ -69,8 +69,6 @@ #define CONFIG_CMD_FAT #define CONFIG_CMD_MTDPARTS #define CONFIG_CMD_NAND_LOCK_UNLOCK /* nand (un)lock commands */ -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP
/* I2C */ #define CONFIG_SYS_I2C_OMAP34XX diff --git a/include/configs/omap3_overo.h b/include/configs/omap3_overo.h index 3b1e5d7..5db5dcf 100644 --- a/include/configs/omap3_overo.h +++ b/include/configs/omap3_overo.h @@ -57,7 +57,6 @@
/* commands to include */ #define CONFIG_CMD_CACHE -#define CONFIG_CMD_USB
#ifdef CONFIG_NAND #define CONFIG_CMD_UBI /* UBI-formated MTD partition support */ diff --git a/include/configs/omap3_zoom1.h b/include/configs/omap3_zoom1.h index a59fd42..e9e8da8 100644 --- a/include/configs/omap3_zoom1.h +++ b/include/configs/omap3_zoom1.h @@ -77,8 +77,6 @@ #define CONFIG_CMD_NAND_LOCK_UNLOCK /* Enable lock/unlock support */ #endif
#undef CONFIG_SYS_I2C_OMAP24XX #define CONFIG_SYS_I2C_OMAP34XX diff --git a/include/configs/omap4_panda.h b/include/configs/omap4_panda.h index 15f3eec..3e7096e 100644 --- a/include/configs/omap4_panda.h +++ b/include/configs/omap4_panda.h @@ -17,7 +17,6 @@ */
/* USB UHH support options */ -#define CONFIG_CMD_USB #define CONFIG_USB_HOST #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_OMAP @@ -33,8 +32,6 @@
#define CONFIG_UBOOT_ENABLE_PADS_ALL
#include <configs/ti_omap4_common.h>
diff --git a/include/configs/omap5_uevm.h b/include/configs/omap5_uevm.h index 10b97a0..a794662 100644 --- a/include/configs/omap5_uevm.h +++ b/include/configs/omap5_uevm.h @@ -88,7 +88,6 @@ #define CONFIG_SYS_I2C_TCA642X_ADDR 0x22
/* USB UHH support options */ -#define CONFIG_CMD_USB #define CONFIG_USB_HOST #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_OMAP @@ -107,7 +106,6 @@ #define CONFIG_DFU_MMC
/* Enabled commands */ -#define CONFIG_CMD_DHCP /* DHCP Support */
/* USB Networking options */ #define CONFIG_USB_HOST_ETHER diff --git a/include/configs/omapl138_lcdk.h b/include/configs/omapl138_lcdk.h index a4b26d2..be93ca3 100644 --- a/include/configs/omapl138_lcdk.h +++ b/include/configs/omapl138_lcdk.h @@ -211,19 +211,15 @@ */ #define CONFIG_CMD_ENV #define CONFIG_CMD_ASKENV -#define CONFIG_CMD_DHCP #define CONFIG_CMD_DIAG #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_SAVES #ifdef CONFIG_CMD_BDI #define CONFIG_CLOCKS #endif
#ifndef CONFIG_DRIVER_TI_EMAC -#undef CONFIG_CMD_DHCP #undef CONFIG_CMD_MII -#undef CONFIG_CMD_PING #endif
#ifdef CONFIG_USE_NAND @@ -239,8 +235,6 @@ #endif
#ifdef CONFIG_USE_SPIFLASH -#define CONFIG_CMD_SPI -#define CONFIG_CMD_SF #endif
#if !defined(CONFIG_USE_NAND) && \ diff --git a/include/configs/openrd.h b/include/configs/openrd.h index 62f15b7..6eb7e6e 100644 --- a/include/configs/openrd.h +++ b/include/configs/openrd.h @@ -45,13 +45,10 @@ */ #define CONFIG_SYS_NO_FLASH /* Declare no flash (NOR/SPI) */ #define CONFIG_SYS_MVFS -#define CONFIG_CMD_DHCP #define CONFIG_CMD_ENV #define CONFIG_CMD_MII #define CONFIG_CMD_MMC #define CONFIG_CMD_NAND -#define CONFIG_CMD_PING -#define CONFIG_CMD_USB #define CONFIG_CMD_IDE
/* diff --git a/include/configs/openrisc-generic.h b/include/configs/openrisc-generic.h index 28e4275..f7c3aaa 100644 --- a/include/configs/openrisc-generic.h +++ b/include/configs/openrisc-generic.h @@ -117,8 +117,6 @@ #define CONFIG_CMD_BSP
#define CONFIG_CMD_MII -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_PING
#define CONFIG_LMB
diff --git a/include/configs/origen.h b/include/configs/origen.h index fa71874..4f14357 100644 --- a/include/configs/origen.h +++ b/include/configs/origen.h @@ -50,8 +50,6 @@ #define S5P_CHECK_DIDLE 0xBAD00000 #define S5P_CHECK_LPA 0xABAD0000
-#undef CONFIG_CMD_PING -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EXT2 #define CONFIG_CMD_FS_GENERIC #define CONFIG_CMD_BOOTZ diff --git a/include/configs/ot1200.h b/include/configs/ot1200.h index 879ad58..100d634 100644 --- a/include/configs/ot1200.h +++ b/include/configs/ot1200.h @@ -21,7 +21,6 @@ #define CONFIG_MXC_UART_BASE UART1_BASE
/* SF Configs */ -#define CONFIG_CMD_SF #define CONFIG_SPI #define CONFIG_MXC_SPI #define CONFIG_SF_DEFAULT_BUS 2 @@ -37,7 +36,6 @@ #define CONFIG_CMD_PCA953X_INFO
/* I2C Configs */ -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC #define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ @@ -58,7 +56,6 @@ #define CONFIG_SYS_FSL_USDHC_NUM 2
/* USB Configs */ -#define CONFIG_CMD_USB #define CONFIG_USB_STORAGE #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_MX6 @@ -92,8 +89,6 @@ #define CONFIG_SPL_SPI_LOAD #endif
-#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP #define CONFIG_CMD_MII #define CONFIG_FEC_MXC #define CONFIG_MII diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index 15b8164..5e63b0c 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -696,7 +696,6 @@ #define CONFIG_HARD_SPI
#if defined(CONFIG_SPI_FLASH) -#define CONFIG_CMD_SF #define CONFIG_SF_DEFAULT_SPEED 10000000 #define CONFIG_SF_DEFAULT_MODE 0 #endif @@ -872,8 +871,6 @@ * Command line configuration. */ #define CONFIG_CMD_IRQ -#define CONFIG_CMD_PING -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII #define CONFIG_CMD_DATE #define CONFIG_CMD_REGINFO @@ -887,7 +884,6 @@ #define CONFIG_USB_EHCI
#ifdef CONFIG_USB_EHCI -#define CONFIG_CMD_USB #define CONFIG_EHCI_HCD_INIT_AFTER_RESET #define CONFIG_USB_EHCI_FSL #define CONFIG_USB_STORAGE diff --git a/include/configs/p1_twr.h b/include/configs/p1_twr.h index 732b36f..bba75ab 100644 --- a/include/configs/p1_twr.h +++ b/include/configs/p1_twr.h @@ -401,8 +401,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); * Command line configuration. */ #define CONFIG_CMD_IRQ -#define CONFIG_CMD_PING -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO
@@ -415,7 +413,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_USB_EHCI
#ifdef CONFIG_USB_EHCI -#define CONFIG_CMD_USB #define CONFIG_EHCI_HCD_INIT_AFTER_RESET #define CONFIG_USB_EHCI_FSL #define CONFIG_USB_STORAGE diff --git a/include/configs/p2371-0000.h b/include/configs/p2371-0000.h index 9ca29f8..c4a5799 100644 --- a/include/configs/p2371-0000.h +++ b/include/configs/p2371-0000.h @@ -20,7 +20,6 @@
/* SD/MMC */ #define CONFIG_MMC @@ -37,22 +36,18 @@ /* SPI */ #define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 #define CONFIG_SF_DEFAULT_SPEED 24000000 -#define CONFIG_CMD_SPI -#define CONFIG_CMD_SF #define CONFIG_SPI_FLASH_SIZE (4 << 20)
/* USB2.0 Host support */ #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_TEGRA #define CONFIG_USB_STORAGE -#define CONFIG_CMD_USB
#include "tegra-common-usb-gadget.h" #include "tegra-common-post.h" diff --git a/include/configs/p2371-2180.h b/include/configs/p2371-2180.h index c55f07e..3bf3b56 100644 --- a/include/configs/p2371-2180.h +++ b/include/configs/p2371-2180.h @@ -20,7 +20,6 @@
/* SD/MMC */ #define CONFIG_MMC @@ -37,15 +36,12 @@ /* SPI */ #define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 #define CONFIG_SF_DEFAULT_SPEED 24000000 -#define CONFIG_CMD_SPI -#define CONFIG_CMD_SF #define CONFIG_SPI_FLASH_SIZE (4 << 20)
/* USB networking support */ #define CONFIG_USB_HOST_ETHER @@ -57,7 +53,6 @@ #define CONFIG_CMD_PCI
#include "tegra-common-usb-gadget.h" #include "tegra-common-post.h" diff --git a/include/configs/p2571.h b/include/configs/p2571.h index d35e255..95d2d63 100644 --- a/include/configs/p2571.h +++ b/include/configs/p2571.h @@ -21,7 +21,6 @@
/* SD/MMC */ #define CONFIG_MMC @@ -38,22 +37,18 @@ /* SPI */ #define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 #define CONFIG_SF_DEFAULT_SPEED 24000000 -#define CONFIG_CMD_SPI -#define CONFIG_CMD_SF #define CONFIG_SPI_FLASH_SIZE (4 << 20)
#include "tegra-common-usb-gadget.h" #include "tegra-common-post.h" diff --git a/include/configs/paz00.h b/include/configs/paz00.h index 6acecb1..e7b084a 100644 --- a/include/configs/paz00.h +++ b/include/configs/paz00.h @@ -38,14 +38,12 @@ #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_TEGRA #define CONFIG_USB_STORAGE -#define CONFIG_CMD_USB
/* LCD support */ #define CONFIG_SYS_WHITE_ON_BLACK diff --git a/include/configs/pb1x00.h b/include/configs/pb1x00.h index f490e79..f094850 100644 --- a/include/configs/pb1x00.h +++ b/include/configs/pb1x00.h @@ -172,9 +172,7 @@ /* * Command line configuration. */ -#define CONFIG_CMD_DHCP #define CONFIG_CMD_MII -#define CONFIG_CMD_PING
#undef CONFIG_CMD_FAT #undef CONFIG_CMD_IDE diff --git a/include/configs/pcm030.h b/include/configs/pcm030.h index b4a7225..3a9b8f3 100644 --- a/include/configs/pcm030.h +++ b/include/configs/pcm030.h @@ -51,9 +51,7 @@ Serial console configuration * Command line configuration. */ #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EEPROM -#define CONFIG_CMD_I2C #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_MII #define CONFIG_CMD_PCI diff --git a/include/configs/pcm051.h b/include/configs/pcm051.h index 4638c25..d555455 100644 --- a/include/configs/pcm051.h +++ b/include/configs/pcm051.h @@ -97,7 +97,6 @@ #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START \ + (8 * 1024 * 1024))
-#define CONFIG_CMD_SF #define CONFIG_SF_DEFAULT_SPEED 24000000
#define CONFIG_CONS_INDEX 1 @@ -148,7 +147,6 @@ #define CONFIG_AM335X_USB1_MODE MUSB_HOST
#ifdef CONFIG_USB_MUSB_HOST -#define CONFIG_CMD_USB #define CONFIG_USB_STORAGE #endif
diff --git a/include/configs/pcm052.h b/include/configs/pcm052.h index edc555f..356cd79 100644 --- a/include/configs/pcm052.h +++ b/include/configs/pcm052.h @@ -33,8 +33,6 @@ #define CONFIG_ENV_OVERWRITE #define CONFIG_BAUDRATE 115200
-#undef CONFIG_CMD_IMLS - /* NAND support */ #define CONFIG_CMD_NAND #define CONFIG_CMD_NAND_TRIMFFS @@ -83,8 +81,6 @@ #define CONFIG_CMD_FAT #define CONFIG_DOS_PARTITION
-#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP #define CONFIG_CMD_MII #define CONFIG_FEC_MXC #define CONFIG_MII @@ -97,7 +93,6 @@ /* QSPI Configs*/
#ifdef CONFIG_FSL_QSPI -#define CONFIG_CMD_SF #define CONFIG_SPI_FLASH #define FSL_QSPI_FLASH_SIZE (1 << 24) #define FSL_QSPI_FLASH_NUM 2 @@ -105,7 +100,6 @@ #endif
/* I2C Configs */ -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC_I2C3 #define CONFIG_SYS_I2C_MXC @@ -221,7 +215,6 @@ #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE
-#define CONFIG_CMD_MEMTEST #define CONFIG_SYS_MEMTEST_START 0x80010000 #define CONFIG_SYS_MEMTEST_END 0x87C00000
diff --git a/include/configs/pdm360ng.h b/include/configs/pdm360ng.h index f2c05f8..ff3f53d 100644 --- a/include/configs/pdm360ng.h +++ b/include/configs/pdm360ng.h @@ -382,11 +382,8 @@
#define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EEPROM -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO
#undef CONFIG_CMD_FUSE diff --git a/include/configs/pengwyn.h b/include/configs/pengwyn.h index b75dbee..733ff28 100644 --- a/include/configs/pengwyn.h +++ b/include/configs/pengwyn.h @@ -204,7 +204,6 @@ #define CONFIG_AM335X_USB1_MODE MUSB_HOST
#if defined(CONFIG_USB_MUSB_HOST) -#define CONFIG_CMD_USB #define CONFIG_USB_STORAGE #endif
diff --git a/include/configs/picosam9g45.h b/include/configs/picosam9g45.h index 54ebcba..118316b 100644 --- a/include/configs/picosam9g45.h +++ b/include/configs/picosam9g45.h @@ -83,9 +83,6 @@
/* No NOR flash */ #define CONFIG_SYS_NO_FLASH -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_USB
/* SDRAM */ #define CONFIG_NR_DRAM_BANKS 2 diff --git a/include/configs/platinum.h b/include/configs/platinum.h index bb7e845..4f78a3d 100644 --- a/include/configs/platinum.h +++ b/include/configs/platinum.h @@ -22,17 +22,12 @@ */
#define CONFIG_CMD_BMODE -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII #define CONFIG_CMD_MTDPARTS #define CONFIG_CMD_NAND #define CONFIG_CMD_NAND_TRIMFFS -#define CONFIG_CMD_PING -#define CONFIG_CMD_TIME #define CONFIG_CMD_UBI #define CONFIG_CMD_UBIFS -#define CONFIG_CMD_USB
/* * Hardware configuration diff --git a/include/configs/plutux.h b/include/configs/plutux.h index 4590063..0f79472 100644 --- a/include/configs/plutux.h +++ b/include/configs/plutux.h @@ -38,14 +38,12 @@ #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_TEGRA #define CONFIG_USB_STORAGE -#define CONFIG_CMD_USB
diff --git a/include/configs/pm9261.h b/include/configs/pm9261.h index 407b83d..f883ca3 100644 --- a/include/configs/pm9261.h +++ b/include/configs/pm9261.h @@ -183,10 +183,7 @@ * Command line configuration. */ #define CONFIG_CMD_CACHE -#define CONFIG_CMD_PING 1 -#define CONFIG_CMD_DHCP 1 #define CONFIG_CMD_NAND 1 -#define CONFIG_CMD_USB 1
/* SDRAM */ #define CONFIG_NR_DRAM_BANKS 1 diff --git a/include/configs/pm9263.h b/include/configs/pm9263.h index f6886a6..0fb0a36 100644 --- a/include/configs/pm9263.h +++ b/include/configs/pm9263.h @@ -197,10 +197,7 @@ * Command line configuration. */ #define CONFIG_CMD_CACHE -#define CONFIG_CMD_PING 1 -#define CONFIG_CMD_DHCP 1 #define CONFIG_CMD_NAND 1 -#define CONFIG_CMD_USB 1
/* SDRAM */ #define CONFIG_NR_DRAM_BANKS 1 diff --git a/include/configs/pm9g45.h b/include/configs/pm9g45.h index 53fdaa7..ba9e6d3 100644 --- a/include/configs/pm9g45.h +++ b/include/configs/pm9g45.h @@ -72,10 +72,7 @@ * Command line configuration. */ #define CONFIG_CMD_CACHE -#define CONFIG_CMD_PING 1 -#define CONFIG_CMD_DHCP 1 #define CONFIG_CMD_NAND 1 -#define CONFIG_CMD_USB 1
#define CONFIG_CMD_JFFS2 1 #define CONFIG_JFFS2_CMDLINE 1 diff --git a/include/configs/pogo_e02.h b/include/configs/pogo_e02.h index b1a3dc7..6314365 100644 --- a/include/configs/pogo_e02.h +++ b/include/configs/pogo_e02.h @@ -33,12 +33,9 @@ */ #define CONFIG_SYS_NO_FLASH /* Declare no flash (NOR/SPI) */ #define CONFIG_SYS_MVFS -#define CONFIG_CMD_DHCP #define CONFIG_CMD_ENV #define CONFIG_CMD_MII #define CONFIG_CMD_NAND -#define CONFIG_CMD_PING -#define CONFIG_CMD_USB
/* * mv-common.h should be defined after CMD configs since it used them diff --git a/include/configs/porter.h b/include/configs/porter.h index e34cd05..1e7f48d 100644 --- a/include/configs/porter.h +++ b/include/configs/porter.h @@ -69,7 +69,6 @@ #define CONFIG_SYS_TMU_CLK_DIV 4
/* i2c */ -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_SH #define CONFIG_SYS_I2C_SLAVE 0x7F diff --git a/include/configs/qemu-mips.h b/include/configs/qemu-mips.h index a9ecf6a..4b0f98b 100644 --- a/include/configs/qemu-mips.h +++ b/include/configs/qemu-mips.h @@ -47,7 +47,6 @@ */ #define CONFIG_CMD_FAT #define CONFIG_CMD_EXT2 -#define CONFIG_CMD_DHCP
#define CONFIG_DRIVER_NE2000 #define CONFIG_DRIVER_NE2000_BASE 0xb4000300 @@ -75,14 +74,6 @@ */ #define CONFIG_SYS_LONGHELP /* undef to save memory */
-/* Monitor Command Prompt */ -#undef CONFIG_SYS_PROMPT -#if defined(CONFIG_SYS_LITTLE_ENDIAN) -#define CONFIG_SYS_PROMPT "qemu-mipsel # " -#else -#define CONFIG_SYS_PROMPT "qemu-mips # " -#endif - #define CONFIG_AUTO_COMPLETE #define CONFIG_CMDLINE_EDITING
diff --git a/include/configs/qemu-mips64.h b/include/configs/qemu-mips64.h index 8258bfe..9e5cbb1 100644 --- a/include/configs/qemu-mips64.h +++ b/include/configs/qemu-mips64.h @@ -47,7 +47,6 @@ */ #define CONFIG_CMD_FAT #define CONFIG_CMD_EXT2 -#define CONFIG_CMD_DHCP
#define CONFIG_DRIVER_NE2000 #define CONFIG_DRIVER_NE2000_BASE 0xffffffffb4000300 @@ -70,21 +69,12 @@
#define CONFIG_SYS_IDE_MAXDEVICE 4
-#define CONFIG_CMD_RARP
/* * Miscellaneous configurable options */ #define CONFIG_SYS_LONGHELP /* undef to save memory */
-/* Monitor Command Prompt */ -#undef CONFIG_SYS_PROMPT -#if defined(CONFIG_SYS_LITTLE_ENDIAN) -#define CONFIG_SYS_PROMPT "qemu-mips64el # " -#else -#define CONFIG_SYS_PROMPT "qemu-mips64 # " -#endif - #define CONFIG_AUTO_COMPLETE #define CONFIG_CMDLINE_EDITING
diff --git a/include/configs/qemu-ppce500.h b/include/configs/qemu-ppce500.h index 5542352..15f906a 100644 --- a/include/configs/qemu-ppce500.h +++ b/include/configs/qemu-ppce500.h @@ -142,11 +142,9 @@ extern unsigned long long get_phys_ccsrbar_addr_early(void); /* * Command line configuration. */ -#define CONFIG_CMD_DHCP #define CONFIG_CMD_BOOTZ #define CONFIG_CMD_GREPENV #define CONFIG_CMD_IRQ -#define CONFIG_CMD_PING
#ifdef CONFIG_PCI #define CONFIG_CMD_PCI diff --git a/include/configs/r0p7734.h b/include/configs/r0p7734.h index b1d79fd..88fe641 100644 --- a/include/configs/r0p7734.h +++ b/include/configs/r0p7734.h @@ -18,7 +18,6 @@ #define CONFIG_BOARD_LATE_INIT #define CONFIG_SYS_TEXT_BASE 0x8FFC0000
-#define CONFIG_CMD_PING #define CONFIG_CMD_MII #define CONFIG_CMD_SDRAM #define CONFIG_CMD_ENV @@ -48,7 +47,6 @@
/* I2C */ -#define CONFIG_CMD_I2C #define CONFIG_SH_SH7734_I2C 1 #define CONFIG_HARD_I2C 1 #define CONFIG_I2C_MULTI_BUS 1 diff --git a/include/configs/r2dplus.h b/include/configs/r2dplus.h index 82e7a89..daf7e22 100644 --- a/include/configs/r2dplus.h +++ b/include/configs/r2dplus.h @@ -13,7 +13,6 @@ */ #define CONFIG_CMD_CACHE #define CONFIG_CMD_PCI -#define CONFIG_CMD_PING #define CONFIG_CMD_IDE #define CONFIG_CMD_EXT2 #define CONFIG_DOS_PARTITION diff --git a/include/configs/r7780mp.h b/include/configs/r7780mp.h index e2da244..8add5f8 100644 --- a/include/configs/r7780mp.h +++ b/include/configs/r7780mp.h @@ -21,7 +21,6 @@ */ #define CONFIG_CMD_SDRAM #define CONFIG_CMD_PCI -#define CONFIG_CMD_PING #define CONFIG_CMD_IDE #define CONFIG_CMD_EXT2 #define CONFIG_DOS_PARTITION diff --git a/include/configs/rcar-gen2-common.h b/include/configs/rcar-gen2-common.h index 6bc33e0..c814189 100644 --- a/include/configs/rcar-gen2-common.h +++ b/include/configs/rcar-gen2-common.h @@ -16,13 +16,8 @@ #define CONFIG_CMD_DFL #define CONFIG_CMD_SDRAM #define CONFIG_CMD_MII -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP #define CONFIG_CMD_BOOTZ -#define CONFIG_CMD_USB #define CONFIG_CMD_FAT -#define CONFIG_CMD_SF -#define CONFIG_CMD_SPI #define CONFIG_CMD_EXT2 #define CONFIG_CMD_EXT4 #define CONFIG_CMD_EXT4_WRITE diff --git a/include/configs/rk3036_common.h b/include/configs/rk3036_common.h index 368d046..01c3005 100644 --- a/include/configs/rk3036_common.h +++ b/include/configs/rk3036_common.h @@ -60,7 +60,6 @@ #define CONFIG_CMD_PART
#define CONFIG_CMD_CACHE -#define CONFIG_CMD_TIME
#define CONFIG_SYS_SDRAM_BASE 0x60000000 #define CONFIG_NR_DRAM_BANKS 1 @@ -68,12 +67,9 @@
#define CONFIG_SPI_FLASH #define CONFIG_SPI -#define CONFIG_CMD_SF -#define CONFIG_CMD_SPI #define CONFIG_SPI_FLASH_GIGADEVICE #define CONFIG_SF_DEFAULT_SPEED 20000000
#ifndef CONFIG_SPL_BUILD #include <config_distro_defaults.h> diff --git a/include/configs/rk3288_common.h b/include/configs/rk3288_common.h index 5322685..02cb94b 100644 --- a/include/configs/rk3288_common.h +++ b/include/configs/rk3288_common.h @@ -79,8 +79,6 @@ #define CONFIG_SPL_DRIVERS_MISC_SUPPORT
#define CONFIG_CMD_CACHE -#define CONFIG_CMD_TIME -#define CONFIG_CMD_GPIO
#define CONFIG_SYS_SDRAM_BASE 0 #define CONFIG_NR_DRAM_BANKS 1 @@ -88,11 +86,8 @@
#define CONFIG_SPI_FLASH #define CONFIG_SPI -#define CONFIG_CMD_SF -#define CONFIG_CMD_SPI #define CONFIG_SF_DEFAULT_SPEED 20000000
#ifndef CONFIG_SPL_BUILD #include <config_distro_defaults.h> diff --git a/include/configs/rpi.h b/include/configs/rpi.h index 19ca606..0fd040f 100644 --- a/include/configs/rpi.h +++ b/include/configs/rpi.h @@ -96,7 +96,6 @@ #define CONFIG_MMC_SDHCI_IO_ACCESSORS #define CONFIG_BCM2835_SDHCI
-#define CONFIG_CMD_USB #ifdef CONFIG_CMD_USB #define CONFIG_USB_DWC2 #ifndef CONFIG_BCM2835 diff --git a/include/configs/rsk7203.h b/include/configs/rsk7203.h index 039880b..c7ef864 100644 --- a/include/configs/rsk7203.h +++ b/include/configs/rsk7203.h @@ -14,7 +14,6 @@ #define CONFIG_CPU_SH7203 1 #define CONFIG_RSK7203 1
-#define CONFIG_CMD_PING #define CONFIG_CMD_SDRAM #define CONFIG_CMD_CACHE
diff --git a/include/configs/s5pc210_universal.h b/include/configs/s5pc210_universal.h index 25aedc2..c14a247 100644 --- a/include/configs/s5pc210_universal.h +++ b/include/configs/s5pc210_universal.h @@ -162,7 +162,6 @@ #define CONFIG_SOFT_I2C_GPIO_SCL EXYNOS4_GPIO_B7 #define CONFIG_SOFT_I2C_GPIO_SDA EXYNOS4_GPIO_B6
#define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_SOFT /* I2C bit-banged */ diff --git a/include/configs/sama5d2_xplained.h b/include/configs/sama5d2_xplained.h index 427fed9..bdb39a3 100644 --- a/include/configs/sama5d2_xplained.h +++ b/include/configs/sama5d2_xplained.h @@ -64,7 +64,6 @@ #endif
#ifdef CONFIG_CMD_USB #define CONFIG_USB_EHCI diff --git a/include/configs/sama5d3_xplained.h b/include/configs/sama5d3_xplained.h index 73de62c..ee3e34d 100644 --- a/include/configs/sama5d3_xplained.h +++ b/include/configs/sama5d3_xplained.h @@ -91,7 +91,6 @@ #endif
#ifdef CONFIG_CMD_USB #define CONFIG_USB_ATMEL diff --git a/include/configs/sama5d3xek.h b/include/configs/sama5d3xek.h index 2567502..c4ad3c4 100644 --- a/include/configs/sama5d3xek.h +++ b/include/configs/sama5d3xek.h @@ -76,7 +76,6 @@ #endif
/* SerialFlash */ -#define CONFIG_CMD_SF
#ifdef CONFIG_CMD_SF #define CONFIG_ATMEL_SPI @@ -125,7 +124,6 @@ #endif
#ifdef CONFIG_CMD_USB #define CONFIG_USB_ATMEL diff --git a/include/configs/sama5d4_xplained.h b/include/configs/sama5d4_xplained.h index e310ee3..a81766a 100644 --- a/include/configs/sama5d4_xplained.h +++ b/include/configs/sama5d4_xplained.h @@ -35,7 +35,6 @@ #define CONFIG_SYS_LOAD_ADDR 0x22000000 /* load address */
#ifdef CONFIG_CMD_SF #define CONFIG_ATMEL_SPI @@ -73,7 +72,6 @@ #endif
#ifdef CONFIG_CMD_USB #define CONFIG_USB_EHCI diff --git a/include/configs/sama5d4ek.h b/include/configs/sama5d4ek.h index 8af3033..339fcf1 100644 --- a/include/configs/sama5d4ek.h +++ b/include/configs/sama5d4ek.h @@ -35,7 +35,6 @@ #define CONFIG_SYS_LOAD_ADDR 0x22000000 /* load address */
#ifdef CONFIG_CMD_USB #define CONFIG_USB_EHCI diff --git a/include/configs/sandbox.h b/include/configs/sandbox.h index d489b1d..4b8fe16 100644 --- a/include/configs/sandbox.h +++ b/include/configs/sandbox.h @@ -82,11 +82,8 @@ #define CONFIG_ENV_IS_NOWHERE
/* SPI - enable all SPI flash types for testing purposes */ -#define CONFIG_CMD_SF #define CONFIG_CMD_SF_TEST -#define CONFIG_CMD_SPI
-#define CONFIG_CMD_I2C #define CONFIG_I2C_EDID #define CONFIG_I2C_EEPROM
@@ -124,12 +121,7 @@
#define CONFIG_KEEP_SERVERADDR #define CONFIG_UDP_CHECKSUM -#define CONFIG_CMD_LINK_LOCAL -#define CONFIG_CMD_CDP -#define CONFIG_CMD_DNS -#define CONFIG_CMD_SNTP #define CONFIG_TIMESTAMP -#define CONFIG_CMD_RARP #define CONFIG_BOOTP_DNS #define CONFIG_BOOTP_DNS2 #define CONFIG_BOOTP_SEND_HOSTNAME @@ -205,7 +197,6 @@ #define CONFIG_LZMA
#define CONFIG_CMD_LZMADEC -#define CONFIG_CMD_USB #define CONFIG_CMD_DATE
#endif diff --git a/include/configs/sansa_fuze_plus.h b/include/configs/sansa_fuze_plus.h index c8f4542..f6e07b4 100644 --- a/include/configs/sansa_fuze_plus.h +++ b/include/configs/sansa_fuze_plus.h @@ -18,10 +18,7 @@ #define CONFIG_CMD_EXT2 #define CONFIG_CMD_FAT #define CONFIG_CMD_MMC -#define CONFIG_CMD_PING -#define CONFIG_CMD_USB #define CONFIG_VIDEO -#define CONFIG_CMD_MEMTEST
/* Memory configuration */ #define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ diff --git a/include/configs/sbc8349.h b/include/configs/sbc8349.h index 05ddb3a..37fdeaa 100644 --- a/include/configs/sbc8349.h +++ b/include/configs/sbc8349.h @@ -408,9 +408,7 @@ /* * Command line configuration. */ -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII -#define CONFIG_CMD_PING
#if defined(CONFIG_PCI) #define CONFIG_CMD_PCI diff --git a/include/configs/sbc8548.h b/include/configs/sbc8548.h index 2c074a1..7e5cdfb 100644 --- a/include/configs/sbc8548.h +++ b/include/configs/sbc8548.h @@ -526,8 +526,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_PING -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII #define CONFIG_CMD_REGINFO
diff --git a/include/configs/sbc8641d.h b/include/configs/sbc8641d.h index e3c1250..298e3ee 100644 --- a/include/configs/sbc8641d.h +++ b/include/configs/sbc8641d.h @@ -467,8 +467,6 @@ #define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */
-#define CONFIG_CMD_PING -#define CONFIG_CMD_I2C #define CONFIG_CMD_REGINFO
#if defined(CONFIG_PCI) diff --git a/include/configs/sc_sps_1.h b/include/configs/sc_sps_1.h index 6642b3f..9ec8417 100644 --- a/include/configs/sc_sps_1.h +++ b/include/configs/sc_sps_1.h @@ -20,13 +20,10 @@ #define CONFIG_DOS_PARTITION
#define CONFIG_CMD_CACHE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EXT2 #define CONFIG_CMD_FAT #define CONFIG_CMD_MII #define CONFIG_CMD_MMC -#define CONFIG_CMD_PING -#define CONFIG_CMD_USB
/* Memory configuration */ #define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ diff --git a/include/configs/seaboard.h b/include/configs/seaboard.h index 0611213..54aeb5b 100644 --- a/include/configs/seaboard.h +++ b/include/configs/seaboard.h @@ -30,7 +30,6 @@
/* I2C */ #define CONFIG_SYS_I2C_TEGRA -#define CONFIG_CMD_I2C
/* SD/MMC */ #define CONFIG_MMC @@ -48,14 +47,12 @@ #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_TEGRA #define CONFIG_USB_STORAGE -#define CONFIG_CMD_USB
/* Enable keyboard */ #define CONFIG_TEGRA_KEYBOARD diff --git a/include/configs/secomx6quq7.h b/include/configs/secomx6quq7.h index 703f4fc..d4bba6d 100644 --- a/include/configs/secomx6quq7.h +++ b/include/configs/secomx6quq7.h @@ -32,8 +32,6 @@ #define CONFIG_SYS_FSL_ESDHC_ADDR 0
/* Ethernet Configuration */ -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP #define CONFIG_CMD_MII #define CONFIG_FEC_MXC #define CONFIG_MII diff --git a/include/configs/sequoia.h b/include/configs/sequoia.h index f32459b..7ca7afa 100644 --- a/include/configs/sequoia.h +++ b/include/configs/sequoia.h @@ -236,7 +236,6 @@ #define CONFIG_CMD_SDRAM
#ifndef CONFIG_RAINIER diff --git a/include/configs/sh7752evb.h b/include/configs/sh7752evb.h index fc9d246..58f9540 100644 --- a/include/configs/sh7752evb.h +++ b/include/configs/sh7752evb.h @@ -17,10 +17,8 @@ #define CONFIG_SYS_LDSCRIPT "board/renesas/sh7752evb/u-boot.lds"
#define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_DFL #define CONFIG_CMD_SDRAM -#define CONFIG_CMD_SF #define CONFIG_CMD_MD5SUM #define CONFIG_MD5 #define CONFIG_CMD_MMC diff --git a/include/configs/sh7753evb.h b/include/configs/sh7753evb.h index 31dd984..540d36c 100644 --- a/include/configs/sh7753evb.h +++ b/include/configs/sh7753evb.h @@ -17,10 +17,8 @@ #define CONFIG_SYS_LDSCRIPT "board/renesas/sh7753evb/u-boot.lds"
#define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_DFL #define CONFIG_CMD_SDRAM -#define CONFIG_CMD_SF #define CONFIG_CMD_MD5SUM #define CONFIG_MD5 #define CONFIG_CMD_MMC diff --git a/include/configs/sh7757lcr.h b/include/configs/sh7757lcr.h index 26d70f4..298d3a2 100644 --- a/include/configs/sh7757lcr.h +++ b/include/configs/sh7757lcr.h @@ -18,9 +18,7 @@ #define CONFIG_SYS_LDSCRIPT "board/renesas/sh7757lcr/u-boot.lds"
#define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_SDRAM -#define CONFIG_CMD_SF #define CONFIG_CMD_MD5SUM #define CONFIG_MD5 #define CONFIG_CMD_MMC diff --git a/include/configs/sh7763rdp.h b/include/configs/sh7763rdp.h index 0fd2caf..9f6fe0e 100644 --- a/include/configs/sh7763rdp.h +++ b/include/configs/sh7763rdp.h @@ -19,7 +19,6 @@ */ #define CONFIG_CMD_SDRAM #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_JFFS2
#define CONFIG_BOOTDELAY -1 diff --git a/include/configs/sh7785lcr.h b/include/configs/sh7785lcr.h index e85256d..e5ba30a 100644 --- a/include/configs/sh7785lcr.h +++ b/include/configs/sh7785lcr.h @@ -14,11 +14,9 @@ #define CONFIG_SH7785LCR 1
#define CONFIG_CMD_PCI -#define CONFIG_CMD_PING #define CONFIG_CMD_SDRAM #define CONFIG_CMD_SH_ZIMAGEBOOT
-#define CONFIG_CMD_USB #define CONFIG_USB_STORAGE #define CONFIG_CMD_EXT2 #define CONFIG_CMD_FAT diff --git a/include/configs/shmin.h b/include/configs/shmin.h index 11ae15c..897ba1d 100644 --- a/include/configs/shmin.h +++ b/include/configs/shmin.h @@ -16,7 +16,6 @@ /* #define CONFIG_T_SH7706LSR 1 */
#define CONFIG_CMD_SDRAM -#define CONFIG_CMD_PING #define CONFIG_CMD_ENV
#define CONFIG_BAUDRATE 115200 diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index 6af373e..b4aa283 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -41,7 +41,6 @@ /* commands to include */ #define CONFIG_CMD_ASKENV #define CONFIG_CMD_CACHE -#define CONFIG_CMD_TIME
#define CONFIG_ENV_VARS_UBOOT_CONFIG @@ -95,7 +94,6 @@ #define CONFIG_SPI #define CONFIG_OMAP3_SPI #define CONFIG_MTD_DEVICE -#define CONFIG_CMD_SF #define CONFIG_SF_DEFAULT_SPEED (75000000)
/* Physical Memory Map */ @@ -124,7 +122,6 @@
/* I2C Configuration */ #define CONFIG_I2C -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_OMAP24_I2C_SPEED 100000 #define CONFIG_SYS_OMAP24_I2C_SLAVE 1 @@ -228,7 +225,6 @@ #define CONFIG_AM335X_USB1 #define CONFIG_AM335X_USB1_MODE MUSB_HOST #ifdef CONFIG_USB_MUSB_HOST -#define CONFIG_CMD_USB #define CONFIG_USB_STORAGE #endif
@@ -273,8 +269,6 @@ /* Unsupported features */ #undef CONFIG_USE_IRQ
-#define CONFIG_CMD_DHCP -#define CONFIG_CMD_PING #define CONFIG_DRIVER_TI_CPSW #define CONFIG_MII #define CONFIG_PHY_GIGE diff --git a/include/configs/silk.h b/include/configs/silk.h index 93c3d0d..a3790f0 100644 --- a/include/configs/silk.h +++ b/include/configs/silk.h @@ -69,7 +69,6 @@ #define CONFIG_SYS_TMU_CLK_DIV 4
/* i2c */ -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_SH #define CONFIG_SYS_I2C_SLAVE 0x7F diff --git a/include/configs/smartweb.h b/include/configs/smartweb.h index b1760cc..54701f3 100644 --- a/include/configs/smartweb.h +++ b/include/configs/smartweb.h @@ -149,7 +149,6 @@
#if !defined(CONFIG_SPL_BUILD) /* USB configuration */ -#define CONFIG_CMD_USB #define CONFIG_USB_ATMEL #define CONFIG_USB_ATMEL_CLK_SEL_PLLB #define CONFIG_USB_OHCI_NEW @@ -214,21 +213,12 @@ "mtdparts="MTDPARTS_DEFAULT"\0"
/* Command line & features configuration */ -#undef CONFIG_CMD_FPGA -#undef CONFIG_CMD_IMI -#undef CONFIG_CMD_IMLS -#undef CONFIG_CMD_LOADS
#define CONFIG_CMD_NAND #define CONFIG_CMD_FAT
#ifdef CONFIG_MACB -# define CONFIG_CMD_PING -# define CONFIG_CMD_DHCP #else -# undef CONFIG_CMD_BOOTD -# undef CONFIG_CMD_NET -# undef CONFIG_CMD_NFS #endif /* CONFIG_MACB */
#ifdef CONFIG_SPL_BUILD diff --git a/include/configs/smdk2410.h b/include/configs/smdk2410.h index 34858cd..6b460bf 100644 --- a/include/configs/smdk2410.h +++ b/include/configs/smdk2410.h @@ -77,11 +77,8 @@ #define CONFIG_CMD_BSP #define CONFIG_CMD_CACHE #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_NAND -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO -#define CONFIG_CMD_USB
diff --git a/include/configs/smdkv310.h b/include/configs/smdkv310.h index 856bf7d..63f6204 100644 --- a/include/configs/smdkv310.h +++ b/include/configs/smdkv310.h @@ -41,8 +41,6 @@ /* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE
/* MMC SPL */ #define CONFIG_SKIP_LOWLEVEL_INIT diff --git a/include/configs/snapper9260.h b/include/configs/snapper9260.h index 3674e91..bff49b1 100644 --- a/include/configs/snapper9260.h +++ b/include/configs/snapper9260.h @@ -145,11 +145,7 @@ #define CONFIG_SYS_MALLOC_LEN (1 << 20)
/* Command line configuration */ -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP #define CONFIG_CMD_FAT -#define CONFIG_CMD_I2C -#define CONFIG_CMD_USB #define CONFIG_CMD_MII #define CONFIG_CMD_NAND #define CONFIG_CMD_PCA953X diff --git a/include/configs/sniper.h b/include/configs/sniper.h index 2785925..3fbc2be 100644 --- a/include/configs/sniper.h +++ b/include/configs/sniper.h @@ -88,7 +88,6 @@ #define CONFIG_SYS_I2C_OMAP34XX #define CONFIG_I2C_MULTI_BUS
/* * Flash diff --git a/include/configs/socfpga_arria5_socdk.h b/include/configs/socfpga_arria5_socdk.h index 153f9f8..6cdf38b 100644 --- a/include/configs/socfpga_arria5_socdk.h +++ b/include/configs/socfpga_arria5_socdk.h @@ -18,7 +18,6 @@ #define CONFIG_CMD_BOOTZ #define CONFIG_CMD_CACHE #define CONFIG_CMD_DFU -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EXT4 #define CONFIG_CMD_EXT4_WRITE #define CONFIG_CMD_FAT @@ -26,8 +25,6 @@ #define CONFIG_CMD_GREPENV #define CONFIG_CMD_MII #define CONFIG_CMD_MMC -#define CONFIG_CMD_PING -#define CONFIG_CMD_USB #define CONFIG_CMD_USB_MASS_STORAGE
/* Memory configurations */ diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 2b65241..9b2313c 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -89,8 +89,6 @@ * EPCS/EPCQx1 Serial Flash Controller */ #ifdef CONFIG_ALTERA_SPI -#define CONFIG_CMD_SPI -#define CONFIG_CMD_SF #define CONFIG_SF_DEFAULT_SPEED 30000000 /* * The base address is configurable in QSys, each board must specify the @@ -197,7 +195,6 @@ unsigned int cm_get_l4_sp_clk_hz(void); #define IC_CLK (cm_get_l4_sp_clk_hz() / 1000000) #endif -#define CONFIG_CMD_I2C
/* * QSPI support @@ -216,12 +213,10 @@ unsigned int cm_get_qspi_controller_clk_hz(void); #define CONFIG_CQSPI_REF_CLK cm_get_qspi_controller_clk_hz() #endif #define CONFIG_CQSPI_DECODER 0 -#define CONFIG_CMD_SF
/* * Designware SPI support */ -#define CONFIG_CMD_SPI
/* * Serial Driver diff --git a/include/configs/socfpga_cyclone5_socdk.h b/include/configs/socfpga_cyclone5_socdk.h index d7c339e..bf75e0f 100644 --- a/include/configs/socfpga_cyclone5_socdk.h +++ b/include/configs/socfpga_cyclone5_socdk.h @@ -18,7 +18,6 @@ #define CONFIG_CMD_BOOTZ #define CONFIG_CMD_CACHE #define CONFIG_CMD_DFU -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EXT4 #define CONFIG_CMD_EXT4_WRITE #define CONFIG_CMD_FAT @@ -26,8 +25,6 @@ #define CONFIG_CMD_GREPENV #define CONFIG_CMD_MII #define CONFIG_CMD_MMC -#define CONFIG_CMD_PING -#define CONFIG_CMD_USB #define CONFIG_CMD_USB_MASS_STORAGE
/* Memory configurations */ diff --git a/include/configs/socfpga_de0_nano_soc.h b/include/configs/socfpga_de0_nano_soc.h index 314b9bf..90592a8 100644 --- a/include/configs/socfpga_de0_nano_soc.h +++ b/include/configs/socfpga_de0_nano_soc.h @@ -18,7 +18,6 @@ #define CONFIG_CMD_BOOTZ #define CONFIG_CMD_CACHE #define CONFIG_CMD_DFU -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EXT4 #define CONFIG_CMD_EXT4_WRITE #define CONFIG_CMD_FAT @@ -26,8 +25,6 @@ #define CONFIG_CMD_GREPENV #define CONFIG_CMD_MII #define CONFIG_CMD_MMC -#define CONFIG_CMD_PING -#define CONFIG_CMD_USB #define CONFIG_CMD_USB_MASS_STORAGE
/* Memory configurations */ diff --git a/include/configs/socfpga_mcvevk.h b/include/configs/socfpga_mcvevk.h index f260a64..f1cfe21 100644 --- a/include/configs/socfpga_mcvevk.h +++ b/include/configs/socfpga_mcvevk.h @@ -18,7 +18,6 @@ #define CONFIG_CMD_BOOTZ #define CONFIG_CMD_CACHE #define CONFIG_CMD_DFU -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EXT4 #define CONFIG_CMD_EXT4_WRITE #define CONFIG_CMD_FAT @@ -26,8 +25,6 @@ #define CONFIG_CMD_GREPENV #define CONFIG_CMD_MII #define CONFIG_CMD_MMC -#define CONFIG_CMD_PING -#define CONFIG_CMD_USB #define CONFIG_CMD_USB_MASS_STORAGE
/* Memory configurations */ diff --git a/include/configs/socfpga_sockit.h b/include/configs/socfpga_sockit.h index 07cfcbf..7ac5889 100644 --- a/include/configs/socfpga_sockit.h +++ b/include/configs/socfpga_sockit.h @@ -18,7 +18,6 @@ #define CONFIG_CMD_BOOTZ #define CONFIG_CMD_CACHE #define CONFIG_CMD_DFU -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EXT4 #define CONFIG_CMD_EXT4_WRITE #define CONFIG_CMD_FAT @@ -26,8 +25,6 @@ #define CONFIG_CMD_GREPENV #define CONFIG_CMD_MII #define CONFIG_CMD_MMC -#define CONFIG_CMD_PING -#define CONFIG_CMD_USB #define CONFIG_CMD_USB_MASS_STORAGE
/* Memory configurations */ diff --git a/include/configs/socfpga_socrates.h b/include/configs/socfpga_socrates.h index 02ea0c5..e2ed253 100644 --- a/include/configs/socfpga_socrates.h +++ b/include/configs/socfpga_socrates.h @@ -18,7 +18,6 @@ #define CONFIG_CMD_BOOTZ #define CONFIG_CMD_CACHE #define CONFIG_CMD_DFU -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EXT4 #define CONFIG_CMD_EXT4_WRITE #define CONFIG_CMD_FAT @@ -26,8 +25,6 @@ #define CONFIG_CMD_GREPENV #define CONFIG_CMD_MII #define CONFIG_CMD_MMC -#define CONFIG_CMD_PING -#define CONFIG_CMD_USB #define CONFIG_CMD_USB_MASS_STORAGE
/* Memory configurations */ diff --git a/include/configs/socfpga_sr1500.h b/include/configs/socfpga_sr1500.h index e43b5cf..fb98546 100644 --- a/include/configs/socfpga_sr1500.h +++ b/include/configs/socfpga_sr1500.h @@ -20,20 +20,13 @@ #define CONFIG_CMD_ASKENV #define CONFIG_CMD_BOOTZ #define CONFIG_CMD_CACHE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EXT4 #define CONFIG_CMD_EXT4_WRITE #define CONFIG_CMD_FAT #define CONFIG_CMD_FS_GENERIC -#define CONFIG_CMD_GPIO #define CONFIG_CMD_GREPENV -#define CONFIG_CMD_MEMTEST #define CONFIG_CMD_MII #define CONFIG_CMD_MMC -#define CONFIG_CMD_PING -#define CONFIG_CMD_SF -#define CONFIG_CMD_SPI -#define CONFIG_CMD_TIME
/* Memory configurations */ #define PHYS_SDRAM_1_SIZE 0x40000000 /* 1GiB on SR1500 */ diff --git a/include/configs/socrates.h b/include/configs/socrates.h index 60f8291..f45d91f 100644 --- a/include/configs/socrates.h +++ b/include/configs/socrates.h @@ -310,16 +310,11 @@ */ #define CONFIG_CMD_BMP #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_DTT #undef CONFIG_CMD_EEPROM #define CONFIG_CMD_EXT2 /* EXT2 Support */ -#define CONFIG_CMD_I2C #define CONFIG_CMD_SDRAM #define CONFIG_CMD_MII -#define CONFIG_CMD_PING -#define CONFIG_CMD_SNTP -#define CONFIG_CMD_USB #define CONFIG_CMD_REGINFO
#if defined(CONFIG_PCI) diff --git a/include/configs/spear-common.h b/include/configs/spear-common.h index a309448..63a5b70 100644 --- a/include/configs/spear-common.h +++ b/include/configs/spear-common.h @@ -99,13 +99,10 @@ /* * Command support defines */ -#define CONFIG_CMD_I2C #define CONFIG_CMD_NAND #define CONFIG_CMD_ENV #define CONFIG_CMD_SAVES #define CONFIG_CMD_MII -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP
/* * Default Environment Varible definitions diff --git a/include/configs/stm32f429-discovery.h b/include/configs/stm32f429-discovery.h index 00f293a..d53f8c1 100644 --- a/include/configs/stm32f429-discovery.h +++ b/include/configs/stm32f429-discovery.h @@ -93,6 +93,5 @@ #define CONFIG_CMDLINE_EDITING
#define CONFIG_CMD_MEM -#define CONFIG_CMD_TIMER
#endif /* __CONFIG_H */ diff --git a/include/configs/stm32f746-disco.h b/include/configs/stm32f746-disco.h index 1511959..9d1f02e 100644 --- a/include/configs/stm32f746-disco.h +++ b/include/configs/stm32f746-disco.h @@ -79,6 +79,4 @@ #define CONFIG_CMDLINE_EDITING
#define CONFIG_CMD_MEM -#define CONFIG_CMD_TIMER -#undef CONFIG_CMD_IMLS #endif /* __CONFIG_H */ diff --git a/include/configs/strider.h b/include/configs/strider.h index ec5fbe9..2c1d4fb 100644 --- a/include/configs/strider.h +++ b/include/configs/strider.h @@ -40,7 +40,6 @@ #define CONFIG_DOS_PARTITION #define CONFIG_CMD_EXT2
#define CONFIG_CMD_FPGAD @@ -507,10 +506,8 @@ int fpga_gpio_get(unsigned int bus, int pin); /* * Command line configuration. */ -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII #define CONFIG_CMD_PCI -#define CONFIG_CMD_PING
#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ #define CONFIG_AUTO_COMPLETE /* add autocompletion support */ diff --git a/include/configs/stv0991.h b/include/configs/stv0991.h index 375159e..d3704a4 100644 --- a/include/configs/stv0991.h +++ b/include/configs/stv0991.h @@ -57,12 +57,10 @@ #define CONFIG_PHY_MICREL
/* Command support defines */ -#define CONFIG_CMD_PING #define CONFIG_PHY_RESET_DELAY 10000 /* in usec */
#define CONFIG_SYS_MEMTEST_START 0x0000 #define CONFIG_SYS_MEMTEST_END 1024*1024 -#define CONFIG_CMD_MEMTEST
/* Misc configuration */ #define CONFIG_SYS_LONGHELP @@ -77,9 +75,7 @@ #ifdef CONFIG_OF_CONTROL /* QSPI is controlled via DT */ #define CONFIG_CQSPI_DECODER 0 #define CONFIG_CQSPI_REF_CLK ((30/4)/2)*1000*1000 -#define CONFIG_CMD_SPI
#endif /* __CONFIG_H */ diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 9c6c9b6..bd16ff9 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -236,7 +236,6 @@ #define CONFIG_SYS_I2C_MVTWSI #define CONFIG_SYS_I2C_SPEED 400000 #define CONFIG_SYS_I2C_SLAVE 0x7f -#define CONFIG_CMD_I2C #endif
#if defined CONFIG_VIDEO_LCD_PANEL_I2C && !(defined CONFIG_SPL_BUILD) diff --git a/include/configs/t4qds.h b/include/configs/t4qds.h index 0eed861..be68fac 100644 --- a/include/configs/t4qds.h +++ b/include/configs/t4qds.h @@ -257,13 +257,10 @@ /* * Command line configuration. */ -#define CONFIG_CMD_DHCP #define CONFIG_CMD_ERRATA #define CONFIG_CMD_GREPENV #define CONFIG_CMD_IRQ -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII -#define CONFIG_CMD_PING
#ifdef CONFIG_PCI #define CONFIG_CMD_PCI diff --git a/include/configs/tam3517-common.h b/include/configs/tam3517-common.h index 1426fbf..b270d9d 100644 --- a/include/configs/tam3517-common.h +++ b/include/configs/tam3517-common.h @@ -97,15 +97,11 @@
/* commands to include */ #define CONFIG_CMD_CACHE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EXT2 /* EXT2 Support */ #define CONFIG_CMD_FAT /* FAT support */ -#define CONFIG_CMD_I2C /* I2C serial bus support */ #define CONFIG_CMD_MII #define CONFIG_CMD_MMC /* MMC support */ #define CONFIG_CMD_NAND /* NAND support */ -#define CONFIG_CMD_PING -#define CONFIG_CMD_USB #define CONFIG_CMD_EEPROM
#define CONFIG_SYS_NO_FLASH diff --git a/include/configs/tao3530.h b/include/configs/tao3530.h index ee9fc7d..38f3446 100644 --- a/include/configs/tao3530.h +++ b/include/configs/tao3530.h @@ -102,11 +102,8 @@ "1920k(u-boot),128k(u-boot-env),"\ "4m(kernel),-(fs)"
-#define CONFIG_CMD_I2C /* I2C serial bus support */ #define CONFIG_CMD_MMC /* MMC support */ #define CONFIG_CMD_NAND /* NAND support */ -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_PING
#define CONFIG_SYS_NO_FLASH #define CONFIG_SYS_I2C @@ -276,7 +273,6 @@ */
/* USB EHCI */ -#define CONFIG_CMD_USB #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_OMAP #define CONFIG_OMAP_EHCI_PHY1_RESET_GPIO 162 diff --git a/include/configs/taurus.h b/include/configs/taurus.h index 405ed72..d389752 100644 --- a/include/configs/taurus.h +++ b/include/configs/taurus.h @@ -69,8 +69,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP #define CONFIG_CMD_NAND
/* @@ -135,7 +133,6 @@ #define CONFIG_USB_GADGET_AT91
/* DFU class support */ -#define CONFIG_CMD_USB #define CONFIG_CMD_DFU #define CONFIG_USB_FUNCTION_DFU #define CONFIG_DFU_NAND @@ -147,8 +144,6 @@
/* SPI EEPROM */ #define CONFIG_SPI -#define CONFIG_CMD_SPI -#define CONFIG_CMD_SF #define CONFIG_ATMEL_SPI #define TAURUS_SPI_MASK (1 << 4) #define TAURUS_SPI_CS_PIN AT91_PIN_PA3 diff --git a/include/configs/tb100.h b/include/configs/tb100.h index 62b9de3..870406b 100644 --- a/include/configs/tb100.h +++ b/include/configs/tb100.h @@ -65,8 +65,6 @@ /* * Command line configuration */ -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_PING
#define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_MAXARGS 16 diff --git a/include/configs/tbs2910.h b/include/configs/tbs2910.h index d0734a7..bd4d98e 100644 --- a/include/configs/tbs2910.h +++ b/include/configs/tbs2910.h @@ -56,8 +56,6 @@
/* *** Command definition *** */ #define CONFIG_CMD_BMODE -#define CONFIG_CMD_MEMTEST -#define CONFIG_CMD_TIME
/* Filesystems / image support */ #define CONFIG_EFI_PARTITION @@ -69,8 +67,6 @@
/* Ethernet */ #define CONFIG_FEC_MXC -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP #define CONFIG_CMD_MII #define CONFIG_FEC_MXC #define CONFIG_MII @@ -118,7 +114,6 @@ #endif
/* USB */ -#define CONFIG_CMD_USB #ifdef CONFIG_CMD_USB #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_MX6 @@ -148,13 +143,11 @@ /* RTC */ #define CONFIG_CMD_DATE #ifdef CONFIG_CMD_DATE -#define CONFIG_CMD_I2C #define CONFIG_RTC_DS1307 #define CONFIG_SYS_RTC_BUS_NUM 2 #endif
/* I2C */ -#define CONFIG_CMD_I2C #ifdef CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC diff --git a/include/configs/tec-ng.h b/include/configs/tec-ng.h index 019e32c..d131c17 100644 --- a/include/configs/tec-ng.h +++ b/include/configs/tec-ng.h @@ -19,7 +19,6 @@
/* SD/MMC */ #define CONFIG_MMC @@ -37,22 +36,18 @@ #define CONFIG_TEGRA_SLINK_CTRLS 6 #define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 #define CONFIG_SF_DEFAULT_SPEED 24000000 -#define CONFIG_CMD_SPI -#define CONFIG_CMD_SF #define CONFIG_SPI_FLASH_SIZE (4 << 20)
/* USB networking support */ #define CONFIG_USB_HOST_ETHER #define CONFIG_USB_ETHER_SMSC95XX
/* Tag support */ #define CONFIG_CMDLINE_TAG diff --git a/include/configs/tec.h b/include/configs/tec.h index a947214..976f9c1 100644 --- a/include/configs/tec.h +++ b/include/configs/tec.h @@ -38,14 +38,12 @@ #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_TEGRA #define CONFIG_USB_STORAGE -#define CONFIG_CMD_USB
/* LCD support */ #define CONFIG_SYS_WHITE_ON_BLACK diff --git a/include/configs/tegra-common-post.h b/include/configs/tegra-common-post.h index b6b8ffc..a1daf8c 100644 --- a/include/configs/tegra-common-post.h +++ b/include/configs/tegra-common-post.h @@ -112,7 +112,6 @@ #undef CONFIG_SYS_I2C_TEGRA #endif #ifdef CONFIG_CMD_I2C -#undef CONFIG_CMD_I2C #endif
/* remove MMC support */ @@ -166,7 +165,6 @@ #undef CONFIG_USB_STORAGE #endif #ifdef CONFIG_CMD_USB -#undef CONFIG_CMD_USB #endif
/* remove part command support */ diff --git a/include/configs/theadorable.h b/include/configs/theadorable.h index 4f1a5f3..4183867 100644 --- a/include/configs/theadorable.h +++ b/include/configs/theadorable.h @@ -30,9 +30,7 @@ #define CONFIG_CMD_EXT4 #define CONFIG_CMD_FAT #define CONFIG_CMD_FS_GENERIC -#define CONFIG_CMD_I2C #define CONFIG_CMD_SATA -#define CONFIG_CMD_TIME
/* * The debugging version enables USB support via defconfig. @@ -40,11 +38,7 @@ * interfaces / features. */ #ifdef CONFIG_USB -#define CONFIG_CMD_DHCP #define CONFIG_CMD_PCI -#define CONFIG_CMD_PING -#define CONFIG_CMD_SPI -#define CONFIG_CMD_TFTPPUT #endif
/* I2C */ diff --git a/include/configs/ti814x_evm.h b/include/configs/ti814x_evm.h index 9897a0b..4dfbd82 100644 --- a/include/configs/ti814x_evm.h +++ b/include/configs/ti814x_evm.h @@ -210,8 +210,6 @@ #undef CONFIG_USE_IRQ
/* Ethernet */ -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_PING #define CONFIG_CMD_MII #define CONFIG_DRIVER_TI_CPSW #define CONFIG_MII diff --git a/include/configs/ti_am335x_common.h b/include/configs/ti_am335x_common.h index 4535b8c..049b92a 100644 --- a/include/configs/ti_am335x_common.h +++ b/include/configs/ti_am335x_common.h @@ -30,7 +30,6 @@
#ifndef CONFIG_SPL_BUILD /* Network defines. */ -#define CONFIG_CMD_DHCP #define CONFIG_CMD_MII #define CONFIG_BOOTP_DNS /* Configurable parts of CMD_DHCP */ #define CONFIG_BOOTP_DNS2 @@ -38,7 +37,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_SUBNETMASK #define CONFIG_NET_RETRY_COUNT 10 -#define CONFIG_CMD_PING #define CONFIG_MII /* Required in net/eth.c */ #endif
diff --git a/include/configs/ti_armv7_common.h b/include/configs/ti_armv7_common.h index d866690..6d77e78 100644 --- a/include/configs/ti_armv7_common.h +++ b/include/configs/ti_armv7_common.h @@ -110,7 +110,6 @@
/* I2C IP block */ #define CONFIG_I2C -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C
/* MMC/SD IP block */ @@ -120,7 +119,6 @@
/* McSPI IP block */ #define CONFIG_SPI -#define CONFIG_CMD_SPI
/* GPIO block */
diff --git a/include/configs/ti_armv7_keystone2.h b/include/configs/ti_armv7_keystone2.h index be3c299..ceebffb 100644 --- a/include/configs/ti_armv7_keystone2.h +++ b/include/configs/ti_armv7_keystone2.h @@ -205,14 +205,10 @@ #define CONFIG_USB_PHY_CFG_BASE KS2_USB_PHY_CFG_BASE
/* U-Boot command configuration */ -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_PING #define CONFIG_CMD_SAVES #define CONFIG_CMD_UBI #define CONFIG_CMD_UBIFS -#define CONFIG_CMD_SF #define CONFIG_CMD_EEPROM -#define CONFIG_CMD_USB
/* U-Boot general configuration */ #define CONFIG_MISC_INIT_R diff --git a/include/configs/titanium.h b/include/configs/titanium.h index acfa84a..94b2f27 100644 --- a/include/configs/titanium.h +++ b/include/configs/titanium.h @@ -30,7 +30,6 @@ #define CONFIG_MXC_UART_BASE UART1_BASE
/* I2C Configs */ -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC #define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ @@ -42,8 +41,6 @@ #define CONFIG_SYS_FSL_ESDHC_ADDR 0 #define CONFIG_SYS_FSL_USDHC_NUM 1
-#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP #define CONFIG_CMD_MII #define CONFIG_FEC_MXC #define CONFIG_MII @@ -55,7 +52,6 @@ #define CONFIG_PHY_MICREL_KSZ9021
/* USB Configs */ -#define CONFIG_CMD_USB #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_MX6 #define CONFIG_USB_STORAGE @@ -164,7 +160,6 @@ /* Enable NAND support */ #define CONFIG_CMD_NAND #define CONFIG_CMD_NAND_TRIMFFS -#define CONFIG_CMD_TIME
#ifdef CONFIG_CMD_NAND
diff --git a/include/configs/tqma6.h b/include/configs/tqma6.h index 1fd3f2a..2e729d2 100644 --- a/include/configs/tqma6.h +++ b/include/configs/tqma6.h @@ -44,21 +44,18 @@ #define CONFIG_MXC_UART
/* SPI */ -#define CONFIG_CMD_SPI #define CONFIG_MXC_SPI
/* SPI Flash */
#define TQMA6_SPI_FLASH_SECTOR_SIZE SZ_64K
-#define CONFIG_CMD_SF #define CONFIG_SF_DEFAULT_BUS 0 #define CONFIG_SF_DEFAULT_CS 0 #define CONFIG_SF_DEFAULT_SPEED 50000000 #define CONFIG_SF_DEFAULT_MODE (SPI_MODE_0)
/* I2C Configs */ -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC #define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ @@ -91,7 +88,6 @@ #define CONFIG_SYS_FSL_ESDHC_ADDR 0
/* USB Configs */ -#define CONFIG_CMD_USB #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_MX6 #define CONFIG_USB_STORAGE @@ -101,8 +97,6 @@ #define CONFIG_USB_MAX_CONTROLLER_COUNT 2 #define CONFIG_EHCI_HCD_INIT_AFTER_RESET /* For OTG port */
#define CONFIG_FEC_MXC diff --git a/include/configs/tqma6_wru4.h b/include/configs/tqma6_wru4.h index 450073c..c67e0bd 100644 --- a/include/configs/tqma6_wru4.h +++ b/include/configs/tqma6_wru4.h @@ -71,8 +71,6 @@ * Remove all unused interfaces / commands that are defined in * the common header tqms6.h */ -#undef CONFIG_CMD_SF -#undef CONFIG_CMD_SPI #undef CONFIG_MXC_SPI
#endif /* __CONFIG_TQMA6_WRU4_H */ diff --git a/include/configs/trats.h b/include/configs/trats.h index 7caf0ac..2c0e5ed 100644 --- a/include/configs/trats.h +++ b/include/configs/trats.h @@ -184,7 +184,6 @@ /* I2C */ #include <asm/arch/gpio.h>
#define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_S3C24X0 diff --git a/include/configs/trats2.h b/include/configs/trats2.h index a5f6c11..bad360e 100644 --- a/include/configs/trats2.h +++ b/include/configs/trats2.h @@ -160,7 +160,6 @@ /* I2C */ #include <asm/arch/gpio.h>
#define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_S3C24X0 diff --git a/include/configs/tricorder.h b/include/configs/tricorder.h index 73f0d84..41cc9fa 100644 --- a/include/configs/tricorder.h +++ b/include/configs/tricorder.h @@ -149,7 +149,6 @@ /* commands to include */ #define CONFIG_CMD_EXT2 /* EXT2 Support */ #define CONFIG_CMD_FAT /* FAT support */ -#define CONFIG_CMD_I2C /* I2C serial bus support */ #define CONFIG_CMD_MMC /* MMC support */ #define CONFIG_CMD_MTDPARTS /* Enable MTD parts commands */ #define CONFIG_CMD_NAND /* NAND support */ diff --git a/include/configs/trimslice.h b/include/configs/trimslice.h index ca188be..b763eec 100644 --- a/include/configs/trimslice.h +++ b/include/configs/trimslice.h @@ -23,12 +23,9 @@
/* SPI */ #define CONFIG_SF_DEFAULT_MODE SPI_MODE_0 -#define CONFIG_CMD_SPI -#define CONFIG_CMD_SF
/* SD/MMC */ #define CONFIG_MMC @@ -47,7 +44,6 @@ #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_TEGRA #define CONFIG_USB_STORAGE -#define CONFIG_CMD_USB
/* USB networking support */ #define CONFIG_USB_HOST_ETHER @@ -59,7 +55,6 @@ #define CONFIG_CMD_PCI
diff --git a/include/configs/ts4800.h b/include/configs/ts4800.h index 8f3963a..7dc7443 100644 --- a/include/configs/ts4800.h +++ b/include/configs/ts4800.h @@ -55,7 +55,6 @@ * */ #define CONFIG_HARD_SPI /* puts SPI: ready */ #define CONFIG_MXC_SPI /* driver for the SPI controllers*/ -#define CONFIG_CMD_SPI /* SPI serial bus support */
/* * MMC Configs @@ -82,8 +81,6 @@ #define CONFIG_ETHPRIME "FEC" #define CONFIG_FEC_MXC_PHYADDR 0
/* allow to overwrite serial and ethaddr */ @@ -96,7 +93,6 @@ ***********************************************************/
#define CONFIG_CMD_BOOTZ -#undef CONFIG_CMD_IMLS
/* Environment variables */
diff --git a/include/configs/udoo.h b/include/configs/udoo.h index 3d0cafa..4437700 100644 --- a/include/configs/udoo.h +++ b/include/configs/udoo.h @@ -41,8 +41,6 @@
/* Network support */
-#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP #define CONFIG_CMD_MII #define CONFIG_FEC_MXC #define CONFIG_MII diff --git a/include/configs/usb_a9263.h b/include/configs/usb_a9263.h index 296ddcd..2202d98 100644 --- a/include/configs/usb_a9263.h +++ b/include/configs/usb_a9263.h @@ -59,8 +59,6 @@ /* * Command line configuration. */ -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP #define CONFIG_CMD_NAND
/* SDRAM */ diff --git a/include/configs/usbarmory.h b/include/configs/usbarmory.h index 7e24fc6..d23674c 100644 --- a/include/configs/usbarmory.h +++ b/include/configs/usbarmory.h @@ -23,7 +23,6 @@ #include <config_distro_defaults.h>
/* U-Boot commands */ -#define CONFIG_CMD_MEMTEST
/* U-Boot environment */ #define CONFIG_ENV_OVERWRITE @@ -54,7 +53,6 @@ #define CONFIG_GENERIC_MMC
/* USB */ -#define CONFIG_CMD_USB #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_MX5 #define CONFIG_USB_STORAGE @@ -63,7 +61,6 @@ #define CONFIG_MXC_USB_FLAGS 0
/* I2C */ -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC #define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ diff --git a/include/configs/v38b.h b/include/configs/v38b.h index f154208..870e5a8 100644 --- a/include/configs/v38b.h +++ b/include/configs/v38b.h @@ -87,17 +87,13 @@ * Command line configuration. */ #define CONFIG_CMD_FAT -#define CONFIG_CMD_I2C #define CONFIG_CMD_IDE -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP #define CONFIG_CMD_DIAG #define CONFIG_CMD_IRQ #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_MII #define CONFIG_CMD_SDRAM #define CONFIG_CMD_DATE -#define CONFIG_CMD_USB #define CONFIG_CMD_FAT
diff --git a/include/configs/vct.h b/include/configs/vct.h index ea6e3c0..679cd74 100644 --- a/include/configs/vct.h +++ b/include/configs/vct.h @@ -83,17 +83,13 @@ /* * Commands */ -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EEPROM -#define CONFIG_CMD_I2C
/* * Only Premium/Platinum have ethernet support right now */ #if (defined(CONFIG_VCT_PREMIUM) || defined(CONFIG_VCT_PLATINUM)) && \ !defined(CONFIG_VCT_SMALL_IMAGE) -#define CONFIG_CMD_PING -#define CONFIG_CMD_SNTP #endif
/* @@ -101,7 +97,6 @@ */ #if (defined(CONFIG_VCT_PREMIUM) || defined(CONFIG_VCT_PLATINUM)) && \ !defined(CONFIG_VCT_SMALL_IMAGE) -#define CONFIG_CMD_USB #define CONFIG_CMD_FAT #endif
@@ -284,21 +279,15 @@ int vct_gpio_get(int pin); #undef CONFIG_CMD_ASKENV #undef CONFIG_CMD_BEDBUG #undef CONFIG_CMD_CACHE -#undef CONFIG_CMD_DHCP #undef CONFIG_CMD_EEPROM #undef CONFIG_CMD_EEPROM #undef CONFIG_CMD_FAT -#undef CONFIG_CMD_I2C -#undef CONFIG_CMD_I2C #undef CONFIG_CMD_IRQ #undef CONFIG_CMD_LOADY #undef CONFIG_CMD_MII -#undef CONFIG_CMD_PING #undef CONFIG_CMD_REGINFO -#undef CONFIG_CMD_SNTP #undef CONFIG_CMD_STRINGS #undef CONFIG_CMD_TERMINAL -#undef CONFIG_CMD_USB
#undef CONFIG_SMC911X #undef CONFIG_SYS_I2C_SOFT diff --git a/include/configs/ve8313.h b/include/configs/ve8313.h index 359239c..face83f 100644 --- a/include/configs/ve8313.h +++ b/include/configs/ve8313.h @@ -321,9 +321,7 @@ /* * Command line configuration. */ -#define CONFIG_CMD_DHCP #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_PCI
#define CONFIG_CMDLINE_EDITING 1 diff --git a/include/configs/venice2.h b/include/configs/venice2.h index 75f7268..f413f40 100644 --- a/include/configs/venice2.h +++ b/include/configs/venice2.h @@ -21,7 +21,6 @@
#include "tegra-common-usb-gadget.h" #include "tegra-common-post.h" diff --git a/include/configs/ventana.h b/include/configs/ventana.h index 7f970d0..5c2fe9b 100644 --- a/include/configs/ventana.h +++ b/include/configs/ventana.h @@ -36,14 +36,12 @@ #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_TEGRA #define CONFIG_USB_STORAGE -#define CONFIG_CMD_USB
/* USB keyboard */ #define CONFIG_USB_KEYBOARD diff --git a/include/configs/vexpress_aemv8a.h b/include/configs/vexpress_aemv8a.h index d066a5a..e924963 100644 --- a/include/configs/vexpress_aemv8a.h +++ b/include/configs/vexpress_aemv8a.h @@ -137,11 +137,9 @@ #define CONFIG_CMD_CACHE #define CONFIG_CMD_BOOTI #define CONFIG_CMD_UNZIP -#define CONFIG_CMD_DHCP #define CONFIG_CMD_PXE #define CONFIG_CMD_ENV #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_FAT #define CONFIG_DOS_PARTITION
@@ -172,7 +170,6 @@ #endif
/* Enable memtest */ -#define CONFIG_CMD_MEMTEST #define CONFIG_SYS_MEMTEST_START PHYS_SDRAM_1 #define CONFIG_SYS_MEMTEST_END (PHYS_SDRAM_1 + PHYS_SDRAM_1_SIZE)
@@ -298,7 +295,6 @@ #define CONFIG_ENV_SECT_SIZE 0x00040000 #endif
-#define CONFIG_CMD_ARMFLASH #define CONFIG_SYS_FLASH_CFI 1 #define CONFIG_FLASH_CFI_DRIVER 1 #define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_32BIT diff --git a/include/configs/vexpress_common.h b/include/configs/vexpress_common.h index 501b143..67379fd 100644 --- a/include/configs/vexpress_common.h +++ b/include/configs/vexpress_common.h @@ -186,7 +186,6 @@ CONFIG_SYS_INIT_RAM_SIZE - \ GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_ADDR CONFIG_SYS_GBL_DATA_OFFSET -#define CONFIG_CMD_ECHO
diff --git a/include/configs/vf610twr.h b/include/configs/vf610twr.h index 65830b7..d8c45de 100644 --- a/include/configs/vf610twr.h +++ b/include/configs/vf610twr.h @@ -82,8 +82,6 @@ #define CONFIG_CMD_FAT #define CONFIG_DOS_PARTITION
-#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP #define CONFIG_CMD_MII #define CONFIG_FEC_MXC #define CONFIG_MII @@ -96,14 +94,12 @@ /* QSPI Configs*/
#ifdef CONFIG_FSL_QSPI -#define CONFIG_CMD_SF #define FSL_QSPI_FLASH_SIZE (1 << 24) #define FSL_QSPI_FLASH_NUM 2 #define CONFIG_SYS_FSL_QSPI_LE #endif
/* I2C Configs */ -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC #define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ @@ -231,7 +227,6 @@ #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE
diff --git a/include/configs/vinco.h b/include/configs/vinco.h index 69cb63f..353b17b 100644 --- a/include/configs/vinco.h +++ b/include/configs/vinco.h @@ -41,7 +41,6 @@ #define CONFIG_SYS_LOAD_ADDR 0x22000000 /* load address */
#ifdef CONFIG_CMD_SF #define CONFIG_ATMEL_SPI @@ -76,7 +75,6 @@ #endif
#ifdef CONFIG_CMD_USB #define CONFIG_USB_EHCI diff --git a/include/configs/vme8349.h b/include/configs/vme8349.h index 7a7c92b..f9e6a8d 100644 --- a/include/configs/vme8349.h +++ b/include/configs/vme8349.h @@ -347,9 +347,7 @@ /* * Command line configuration. */ -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII -#define CONFIG_CMD_PING #define CONFIG_CMD_DATE #define CONFIG_SYS_RTC_BUS_NUM 0x01 #define CONFIG_SYS_I2C_RTC_ADDR 0x32 diff --git a/include/configs/walnut.h b/include/configs/walnut.h index dd6b519..d07b74f 100644 --- a/include/configs/walnut.h +++ b/include/configs/walnut.h @@ -56,7 +56,6 @@ #define CONFIG_CMD_DATE #define CONFIG_CMD_PCI #define CONFIG_CMD_SDRAM -#define CONFIG_CMD_SNTP
#define CONFIG_SPD_EEPROM 1 /* use SPD EEPROM for setup */
diff --git a/include/configs/wandboard.h b/include/configs/wandboard.h index 8fb0abc..7898a81 100644 --- a/include/configs/wandboard.h +++ b/include/configs/wandboard.h @@ -35,7 +35,6 @@ #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + 500 * SZ_1M)
/* I2C Configs */ -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC #define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ @@ -48,7 +47,6 @@ #define CONFIG_SYS_FSL_ESDHC_ADDR 0
/* USB Configs */ -#define CONFIG_CMD_USB #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_MX6 #define CONFIG_USB_STORAGE @@ -57,8 +55,6 @@ #define CONFIG_MXC_USB_FLAGS 0
/* Ethernet Configuration */ -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP #define CONFIG_CMD_MII #define CONFIG_FEC_MXC #define CONFIG_MII diff --git a/include/configs/warp.h b/include/configs/warp.h index 4c3df1d..42b728a 100644 --- a/include/configs/warp.h +++ b/include/configs/warp.h @@ -63,7 +63,6 @@ #define CONFIG_SYS_SD_VOLTAGE 0x00000080
/* USB Configs */ -#define CONFIG_CMD_USB #ifdef CONFIG_CMD_USB #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_MX6 @@ -86,7 +85,6 @@ #define DFU_DEFAULT_POLL_TIMEOUT 300
/* I2C Configs */ -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC #define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ diff --git a/include/configs/warp7.h b/include/configs/warp7.h index d1404b2..0afa75f 100644 --- a/include/configs/warp7.h +++ b/include/configs/warp7.h @@ -84,7 +84,6 @@ "fi; " \ "fi"
-#define CONFIG_CMD_MEMTEST #define CONFIG_SYS_MEMTEST_START 0x80000000 #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + 0x20000000)
@@ -119,7 +118,6 @@ #define CONFIG_MMCROOT "/dev/mmcblk2p2"
/* USB Configs */ -#define CONFIG_CMD_USB #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_MX7 #define CONFIG_USB_STORAGE diff --git a/include/configs/whistler.h b/include/configs/whistler.h index ff85964..a5cd38b 100644 --- a/include/configs/whistler.h +++ b/include/configs/whistler.h @@ -23,7 +23,6 @@
/* SD/MMC */ #define CONFIG_MMC @@ -46,14 +45,12 @@ #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_TEGRA #define CONFIG_USB_STORAGE -#define CONFIG_CMD_USB
/* USB networking support */ #define CONFIG_USB_HOST_ETHER #define CONFIG_USB_ETHER_ASIX
/* General networking support */ -#define CONFIG_CMD_DHCP
diff --git a/include/configs/woodburn_common.h b/include/configs/woodburn_common.h index 4407557..631f273 100644 --- a/include/configs/woodburn_common.h +++ b/include/configs/woodburn_common.h @@ -84,9 +84,7 @@ /* * Command definition */ -#define CONFIG_CMD_PING #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_BOOTP_SUBNETMASK #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_DNS @@ -94,8 +92,6 @@ #define CONFIG_CMD_NAND #define CONFIG_CMD_CACHE
-#define CONFIG_CMD_I2C -#define CONFIG_CMD_SPI #define CONFIG_CMD_MII
#define CONFIG_CMD_MMC diff --git a/include/configs/work_92105.h b/include/configs/work_92105.h index a35876f..5d8ac41 100644 --- a/include/configs/work_92105.h +++ b/include/configs/work_92105.h @@ -64,8 +64,6 @@ #define CONFIG_PHY_ADDR 0 #define CONFIG_SYS_FAULT_ECHO_LINK_DOWN #define CONFIG_CMD_MII -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP /* FIXME: remove "Waiting for PHY auto negotiation to complete..." message */
/* @@ -74,7 +72,6 @@
#define CONFIG_SYS_I2C_LPC32XX #define CONFIG_SYS_I2C -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C_SPEED 350000
/* @@ -158,7 +155,6 @@ * SSP/SPI/DISPLAY */
-#define CONFIG_CMD_SPI #define CONFIG_LPC32XX_SSP #define CONFIG_LPC32XX_SSP_TIMEOUT 100000 #define CONFIG_CMD_MAX6957 diff --git a/include/configs/x600.h b/include/configs/x600.h index 9a8a7c7..1cdb10d 100644 --- a/include/configs/x600.h +++ b/include/configs/x600.h @@ -111,20 +111,16 @@ */ #define CONFIG_CMD_CACHE #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_ENV #define CONFIG_CMD_FAT #define CONFIG_CMD_FPGA_LOADMK #define CONFIG_CMD_FS_GENERIC -#define CONFIG_CMD_I2C #define CONFIG_CMD_MII #define CONFIG_CMD_MTDPARTS #define CONFIG_CMD_NAND -#define CONFIG_CMD_PING #define CONFIG_CMD_SAVES #define CONFIG_CMD_UBI #define CONFIG_CMD_UBIFS -#define CONFIG_CMD_USB #define CONFIG_LZO
/* Filesystem support (for USB key) */ @@ -153,7 +149,6 @@ #define CONFIG_SETUP_MEMORY_TAGS #define CONFIG_MISC_INIT_R #define CONFIG_BOARD_LATE_INIT -#define CONFIG_LOOPW /* enable loopw command */ #define CONFIG_MX_CYCLIC /* enable mdc/mwc commands */ #define CONFIG_ZERO_BOOTDELAY_CHECK
diff --git a/include/configs/x86-common.h b/include/configs/x86-common.h index a596edd..7cca864 100644 --- a/include/configs/x86-common.h +++ b/include/configs/x86-common.h @@ -102,8 +102,6 @@ #define CONFIG_CMD_IO #define CONFIG_CMD_IRQ #define CONFIG_CMD_PCI -#define CONFIG_CMD_PING -#define CONFIG_CMD_TIME #define CONFIG_CMD_GETTIME #define CONFIG_CMD_SCSI
@@ -161,9 +159,7 @@ * FLASH configuration */ #define CONFIG_SYS_NO_FLASH -#define CONFIG_CMD_SF #define CONFIG_CMD_SF_TEST -#define CONFIG_CMD_SPI #define CONFIG_SPI
/*----------------------------------------------------------------------- @@ -193,13 +189,11 @@ #define CONFIG_USB_ETHER_ASIX #define CONFIG_USB_ETHER_SMSC95XX #define CONFIG_TFTP_TSIZE -#define CONFIG_CMD_DHCP #define CONFIG_BOOTP_BOOTFILESIZE #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
/* Default environment */ #define CONFIG_ROOTPATH "/opt/nfsroot" diff --git a/include/configs/xfi3.h b/include/configs/xfi3.h index 83c18f0..8d5ea48 100644 --- a/include/configs/xfi3.h +++ b/include/configs/xfi3.h @@ -18,8 +18,6 @@ #define CONFIG_CMD_EXT2 #define CONFIG_CMD_FAT #define CONFIG_CMD_MMC -#define CONFIG_CMD_PING -#define CONFIG_CMD_USB #define CONFIG_VIDEO
/* Memory configuration */ diff --git a/include/configs/xilinx-ppc.h b/include/configs/xilinx-ppc.h index 5980acb..ec26dc1 100644 --- a/include/configs/xilinx-ppc.h +++ b/include/configs/xilinx-ppc.h @@ -32,11 +32,7 @@ #define CONFIG_CMD_REGINFO #undef CONFIG_CMD_JFFS2 #undef CONFIG_CMD_MTDPARTS -#undef CONFIG_CMD_SPI -#undef CONFIG_CMD_I2C #undef CONFIG_CMD_DTT -#undef CONFIG_CMD_PING -#undef CONFIG_CMD_DHCP #undef CONFIG_CMD_EEPROM
/*Misc*/ @@ -64,7 +60,6 @@ /* decrementer freq: 1 ms ticks */ #define CONFIG_CMDLINE_EDITING /* add command line history */ #define CONFIG_AUTO_COMPLETE /* add autocompletion support */ -#define CONFIG_LOOPW /* enable loopw command */ #define CONFIG_MX_CYCLIC /* enable mdc/mwc commands */ #define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ #define CONFIG_VERSION_VARIABLE /* include version env variable */ diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index 980fcb2..be43aa6 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -83,7 +83,6 @@
/* SPI */ #ifdef CONFIG_ZYNQ_SPI -# define CONFIG_CMD_SF #endif
#if defined(CONFIG_ZYNQ_SDHCI) @@ -118,7 +117,6 @@ #define CONFIG_USB_XHCI #define CONFIG_USB_MAX_CONTROLLER_COUNT 1 #define CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS 2 -#define CONFIG_CMD_USB #define CONFIG_USB_STORAGE #define CONFIG_USB_XHCI_ZYNQMP
@@ -193,7 +191,6 @@
/* I2C */ #if defined(CONFIG_SYS_I2C_ZYNQ) -# define CONFIG_CMD_I2C # define CONFIG_SYS_I2C # define CONFIG_SYS_I2C_ZYNQ_SPEED 100000 # define CONFIG_SYS_I2C_ZYNQ_SLAVE 0 diff --git a/include/configs/xpedite1000.h b/include/configs/xpedite1000.h index 4f6084a..f707f57 100644 --- a/include/configs/xpedite1000.h +++ b/include/configs/xpedite1000.h @@ -182,15 +182,11 @@ extern void out32(unsigned int, unsigned long); */ #define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EEPROM -#define CONFIG_CMD_I2C #define CONFIG_CMD_IRQ #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_MII #define CONFIG_CMD_PCI -#define CONFIG_CMD_PING -#define CONFIG_CMD_SNTP
/* * Miscellaneous configurable options diff --git a/include/configs/xpedite517x.h b/include/configs/xpedite517x.h index 18e342a..d7e696e 100644 --- a/include/configs/xpedite517x.h +++ b/include/configs/xpedite517x.h @@ -513,12 +513,10 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); */ #define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_DS4510 #define CONFIG_CMD_DS4510_INFO #define CONFIG_CMD_DTT #define CONFIG_CMD_EEPROM -#define CONFIG_CMD_I2C #define CONFIG_CMD_IRQ #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_MII @@ -527,9 +525,7 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_CMD_PCA953X_INFO #define CONFIG_CMD_PCI #define CONFIG_CMD_PCI_ENUM -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO -#define CONFIG_CMD_SNTP
/* * Miscellaneous configurable options diff --git a/include/configs/xpedite520x.h b/include/configs/xpedite520x.h index 7284aa2..09f0c3f 100644 --- a/include/configs/xpedite520x.h +++ b/include/configs/xpedite520x.h @@ -299,9 +299,7 @@ */ #define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_EEPROM -#define CONFIG_CMD_I2C #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_MII #define CONFIG_CMD_NAND @@ -309,8 +307,6 @@ #define CONFIG_CMD_PCA953X_INFO #define CONFIG_CMD_PCI #define CONFIG_CMD_PCI_ENUM -#define CONFIG_CMD_PING -#define CONFIG_CMD_SNTP #define CONFIG_CMD_REGINFO
/* diff --git a/include/configs/xpedite537x.h b/include/configs/xpedite537x.h index bdeee47..1946bb9 100644 --- a/include/configs/xpedite537x.h +++ b/include/configs/xpedite537x.h @@ -368,12 +368,10 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); */ #define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_DS4510 #define CONFIG_CMD_DS4510_INFO #define CONFIG_CMD_DTT #define CONFIG_CMD_EEPROM -#define CONFIG_CMD_I2C #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_MII #define CONFIG_CMD_NAND @@ -381,8 +379,6 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); #define CONFIG_CMD_PCA953X_INFO #define CONFIG_CMD_PCI #define CONFIG_CMD_PCI_ENUM -#define CONFIG_CMD_PING -#define CONFIG_CMD_SNTP #define CONFIG_CMD_REGINFO
/* diff --git a/include/configs/xpedite550x.h b/include/configs/xpedite550x.h index 0948035..a84099a 100644 --- a/include/configs/xpedite550x.h +++ b/include/configs/xpedite550x.h @@ -355,10 +355,8 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); */ #define CONFIG_CMD_ASKENV #define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP #define CONFIG_CMD_DTT #define CONFIG_CMD_EEPROM -#define CONFIG_CMD_I2C #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_MII #define CONFIG_CMD_NAND @@ -366,10 +364,7 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); #define CONFIG_CMD_PCA953X_INFO #define CONFIG_CMD_PCI #define CONFIG_CMD_PCI_ENUM -#define CONFIG_CMD_PING #define CONFIG_CMD_REGINFO -#define CONFIG_CMD_SNTP -#define CONFIG_CMD_USB
/* * Miscellaneous configurable options diff --git a/include/configs/xpress.h b/include/configs/xpress.h index dc7a75b..9a0aac5 100644 --- a/include/configs/xpress.h +++ b/include/configs/xpress.h @@ -33,7 +33,6 @@ #define CONFIG_SUPPORT_EMMC_BOOT /* eMMC specific */
/* I2C configs */ -#define CONFIG_CMD_I2C #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC #define CONFIG_SYS_I2C_MXC_I2C1 /* enable I2C bus 1 */ @@ -42,7 +41,6 @@ #define CONFIG_SYS_I2C_SPEED 100000
/* Miscellaneous configurable options */ -#define CONFIG_CMD_MEMTEST #define CONFIG_SYS_MEMTEST_START 0x80000000 #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + 0x10000000)
@@ -82,7 +80,6 @@ #define CONFIG_CMD_CACHE
/* USB Configs */ -#define CONFIG_CMD_USB #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_MX6 #define CONFIG_USB_STORAGE diff --git a/include/configs/yosemite.h b/include/configs/yosemite.h index 0cffab8..37f7a07 100644 --- a/include/configs/yosemite.h +++ b/include/configs/yosemite.h @@ -193,7 +193,6 @@ #define CONFIG_CMD_PCI
#ifdef CONFIG_440EP - #define CONFIG_CMD_USB #define CONFIG_CMD_FAT #define CONFIG_CMD_EXT2 #endif diff --git a/include/configs/zipitz2.h b/include/configs/zipitz2.h index 8bb48a8..81de228 100644 --- a/include/configs/zipitz2.h +++ b/include/configs/zipitz2.h @@ -60,8 +60,6 @@ */ #define CONFIG_CMD_ENV #define CONFIG_CMD_MMC -#define CONFIG_CMD_SPI -#define CONFIG_CMD_USB #define CONFIG_CMD_CACHE
/* diff --git a/include/configs/zmx25.h b/include/configs/zmx25.h index 3a401f7..e66a7f4 100644 --- a/include/configs/zmx25.h +++ b/include/configs/zmx25.h @@ -81,10 +81,7 @@ /* * Additional command */ -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_PING #define CONFIG_CMD_FAT -#define CONFIG_CMD_USB
/* diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index d535316..39665ee 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -55,14 +55,12 @@
/* QSPI */ #ifdef CONFIG_ZYNQ_QSPI # define CONFIG_SF_DEFAULT_SPEED 30000000 # define CONFIG_SPI_FLASH_ISSI -# define CONFIG_CMD_SF #endif
/* NOR */ @@ -92,7 +90,6 @@
#ifdef CONFIG_ZYNQ_USB # define CONFIG_USB_EHCI -# define CONFIG_CMD_USB # define CONFIG_USB_STORAGE # define CONFIG_USB_EHCI_ZYNQ # define CONFIG_EHCI_IS_TDI @@ -157,7 +154,6 @@
/* I2C */ #if defined(CONFIG_SYS_I2C_ZYNQ) -# define CONFIG_CMD_I2C # define CONFIG_SYS_I2C # define CONFIG_SYS_I2C_ZYNQ_SPEED 100000 # define CONFIG_SYS_I2C_ZYNQ_SLAVE 0 @@ -307,10 +303,7 @@ #define CONFIG_SYS_LDSCRIPT "arch/arm/mach-zynq/u-boot.lds"
/* Commands */ -#define CONFIG_CMD_PING -#define CONFIG_CMD_DHCP #define CONFIG_CMD_MII -#define CONFIG_CMD_TFTPPUT
/* SPL part */ #define CONFIG_CMD_SPL
On Sun, Apr 24, 2016 at 03:16:06PM -0400, Tom Rini wrote:
This syncs up the current cmd/Kconfig and include/configs/ files with the only exception being CMD_NAND. Due to how we have used this historically we need to take further care here when converting.
Signed-off-by: Tom Rini trini@konsulko.com
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line.
Signed-off-by: Tom Rini trini@konsulko.com --- include/configs/B4860QDS.h | 1 - include/configs/BSC9131RDB.h | 1 - include/configs/BSC9132QDS.h | 3 --- include/configs/C29XPCIE.h | 1 - include/configs/CPCI2DP.h | 4 ---- include/configs/CPCI4052.h | 2 -- include/configs/M5235EVB.h | 1 - include/configs/M5253EVBE.h | 1 - include/configs/M5275EVB.h | 1 - include/configs/MIP405.h | 7 ------- include/configs/MPC8313ERDB.h | 3 --- include/configs/MPC8315ERDB.h | 1 - include/configs/MPC832XEMDS.h | 3 --- include/configs/MPC8349EMDS.h | 3 --- include/configs/MPC8349ITX.h | 2 -- include/configs/MPC837XEMDS.h | 2 -- include/configs/MPC837XERDB.h | 1 - include/configs/MPC8536DS.h | 1 - include/configs/MPC8540ADS.h | 9 --------- include/configs/MPC8541CDS.h | 4 ---- include/configs/MPC8544DS.h | 4 ---- include/configs/MPC8548CDS.h | 5 ----- include/configs/MPC8555CDS.h | 5 ----- include/configs/MPC8560ADS.h | 7 ------- include/configs/MPC8568MDS.h | 8 -------- include/configs/MPC8569MDS.h | 2 -- include/configs/MPC8572DS.h | 4 ---- include/configs/MPC8610HPCD.h | 10 ---------- include/configs/MPC8641HPCN.h | 7 ------- include/configs/P1010RDB.h | 2 -- include/configs/P1022DS.h | 2 -- include/configs/PATI.h | 7 ------- include/configs/PIP405.h | 8 -------- include/configs/PLU405.h | 3 --- include/configs/PMC405DE.h | 1 - include/configs/PMC440.h | 1 - include/configs/T102xQDS.h | 2 -- include/configs/T102xRDB.h | 2 -- include/configs/T1040QDS.h | 1 - include/configs/T104xRDB.h | 1 - include/configs/T208xQDS.h | 1 - include/configs/T208xRDB.h | 1 - include/configs/T4240QDS.h | 3 --- include/configs/T4240RDB.h | 6 ------ include/configs/TQM5200.h | 5 ----- include/configs/TQM823L.h | 3 --- include/configs/TQM823M.h | 2 -- include/configs/TQM834x.h | 2 -- include/configs/TQM850L.h | 1 - include/configs/TQM850M.h | 3 --- include/configs/TQM855L.h | 2 -- include/configs/TQM855M.h | 2 -- include/configs/TQM860L.h | 2 -- include/configs/TQM860M.h | 2 -- include/configs/TQM862L.h | 2 -- include/configs/TQM862M.h | 2 -- include/configs/TQM866M.h | 2 -- include/configs/VCMA9.h | 3 --- include/configs/VOM405.h | 1 - include/configs/a3m071.h | 1 - include/configs/a4m072.h | 3 --- include/configs/ac14xx.h | 1 - include/configs/am3517_crane.h | 1 - include/configs/amcc-common.h | 2 -- include/configs/apf27.h | 1 - include/configs/apx4devkit.h | 2 -- include/configs/astro_mcf5373l.h | 1 - include/configs/at91rm9200ek.h | 1 - include/configs/at91sam9rlek.h | 1 - include/configs/at91sam9x5ek.h | 1 - include/configs/atngw100.h | 2 -- include/configs/atngw100mkii.h | 2 -- include/configs/atstk1002.h | 1 - include/configs/baltos.h | 1 - include/configs/bct-brettl2.h | 9 --------- include/configs/bf506f-ezkit.h | 5 ----- include/configs/bf518f-ezbrd.h | 9 --------- include/configs/bf526-ezbrd.h | 11 ----------- include/configs/bf527-ad7160-eval.h | 10 ---------- include/configs/bf527-ezkit.h | 9 --------- include/configs/bf527-sdp.h | 8 -------- include/configs/bf533-ezkit.h | 6 ------ include/configs/bf533-stamp.h | 6 ------ include/configs/bf537-minotaur.h | 9 --------- include/configs/bf537-pnav.h | 10 ---------- include/configs/bf537-srv1.h | 8 -------- include/configs/bf537-stamp.h | 10 ---------- include/configs/bf538f-ezkit.h | 8 -------- include/configs/bf548-ezkit.h | 12 ------------ include/configs/bf561-acvilon.h | 11 ----------- include/configs/bf561-ezkit.h | 7 ------- include/configs/bf609-ezkit.h | 1 - include/configs/br4.h | 8 -------- include/configs/canmb.h | 1 - include/configs/charon.h | 1 - include/configs/cm-bf527.h | 8 -------- include/configs/cm-bf533.h | 7 ------- include/configs/cm-bf537e.h | 9 --------- include/configs/cm-bf537u.h | 8 -------- include/configs/cm-bf548.h | 9 --------- include/configs/cm-bf561.h | 7 ------- include/configs/cm5200.h | 4 ---- include/configs/cm_t335.h | 1 - include/configs/cm_t35.h | 1 - include/configs/cm_t3517.h | 1 - include/configs/cm_t43.h | 1 - include/configs/cobra5272.h | 2 -- include/configs/controlcenterd.h | 4 ---- include/configs/crownbay.h | 1 - include/configs/cyrus.h | 4 ---- include/configs/da850evm.h | 1 - include/configs/dbau1x00.h | 4 ---- include/configs/devkit8000.h | 1 - include/configs/dockstar.h | 1 - include/configs/draco.h | 2 -- include/configs/dragonboard410c.h | 1 - include/configs/duovero.h | 1 - include/configs/ea20.h | 2 -- include/configs/eco5pk.h | 1 - include/configs/edb93xx.h | 6 ------ include/configs/ethernut5.h | 1 - include/configs/exynos-common.h | 1 - include/configs/exynos5-common.h | 1 - include/configs/flea3.h | 1 - include/configs/goflexhome.h | 1 - include/configs/grsim_leon2.h | 1 - include/configs/guruplug.h | 1 - include/configs/h2200.h | 1 - include/configs/highbank.h | 1 - include/configs/hikey.h | 1 - include/configs/hrcon.h | 2 -- include/configs/ibf-dsp561.h | 7 ------- include/configs/iconnect.h | 1 - include/configs/ids8313.h | 2 -- include/configs/imx31_phycore.h | 2 -- include/configs/inka4x0.h | 2 -- include/configs/integrator-common.h | 1 - include/configs/integratorap.h | 2 -- include/configs/intip.h | 2 -- include/configs/ip04.h | 10 ---------- include/configs/ipam390.h | 2 -- include/configs/jupiter.h | 4 ---- include/configs/kc1.h | 1 - include/configs/km8360.h | 1 - include/configs/km_kirkwood.h | 1 - include/configs/legoev3.h | 2 -- include/configs/ls1043aqds.h | 1 - include/configs/ls2080a_common.h | 3 --- include/configs/ls2080a_simu.h | 1 - include/configs/ls2080aqds.h | 1 - include/configs/ls2080ardb.h | 1 - include/configs/lsxl.h | 3 --- include/configs/lwmon5.h | 2 -- include/configs/m28evk.h | 1 - include/configs/m53evk.h | 1 - include/configs/mcx.h | 1 - include/configs/mecp5123.h | 1 - include/configs/meesc.h | 1 - include/configs/minnowmax.h | 1 - include/configs/mpc5121ads.h | 3 --- include/configs/ms7720se.h | 1 - include/configs/ms7750se.h | 1 - include/configs/mv-plug-common.h | 1 - include/configs/mx31ads.h | 2 -- include/configs/mx31pdk.h | 2 -- include/configs/mx35pdk.h | 1 - include/configs/mx53ard.h | 1 - include/configs/mx6sabre_common.h | 1 - include/configs/mx6sxsabreauto.h | 4 ---- include/configs/mx6sxsabresd.h | 4 ---- include/configs/mx6ul_14x14_evk.h | 1 - include/configs/neo.h | 1 - include/configs/nitrogen6x.h | 1 - include/configs/odroid.h | 1 - include/configs/omap3_igep00x0.h | 1 - include/configs/omap3_logic.h | 1 - include/configs/omap3_zoom1.h | 1 - include/configs/omap4_panda.h | 1 - include/configs/openrisc-generic.h | 1 - include/configs/ot1200.h | 1 - include/configs/p1_p2_rdb_pc.h | 3 --- include/configs/pb1x00.h | 4 ---- include/configs/pcm030.h | 1 - include/configs/pengwyn.h | 3 --- include/configs/pm9261.h | 1 - include/configs/pm9263.h | 1 - include/configs/pm9g45.h | 1 - include/configs/pogo_e02.h | 1 - include/configs/pr1.h | 9 --------- include/configs/pxm2.h | 2 -- include/configs/qemu-mips64.h | 1 - include/configs/r0p7734.h | 1 - include/configs/rastaban.h | 3 --- include/configs/rk3036_common.h | 1 - include/configs/rk3288_common.h | 1 - include/configs/rut.h | 1 - include/configs/s5pc210_universal.h | 1 - include/configs/sandbox.h | 1 - include/configs/sbc8349.h | 3 --- include/configs/sbc8548.h | 5 ----- include/configs/sbc8641d.h | 3 --- include/configs/secomx6quq7.h | 1 - include/configs/sh7785lcr.h | 1 - include/configs/sheevaplug.h | 1 - include/configs/siemens-am33x-common.h | 3 --- include/configs/smartweb.h | 1 - include/configs/smdk2410.h | 2 -- include/configs/smdkv310.h | 1 - include/configs/sniper.h | 1 - include/configs/socfpga_common.h | 1 - include/configs/socrates.h | 5 ----- include/configs/spear-common.h | 2 -- include/configs/strider.h | 1 - include/configs/sun8i.h | 1 - include/configs/t3corp.h | 1 - include/configs/t4qds.h | 3 --- include/configs/tam3517-common.h | 1 - include/configs/taurus.h | 3 --- include/configs/tcm-bf518.h | 8 -------- include/configs/tcm-bf537.h | 9 --------- include/configs/theadorable.h | 1 - include/configs/thuban.h | 2 -- include/configs/thunderx_88xx.h | 3 --- include/configs/ti816x_evm.h | 1 - include/configs/ti_omap3_common.h | 1 - include/configs/ti_omap5_common.h | 2 -- include/configs/tqma6.h | 1 - include/configs/tqma6_wru4.h | 1 - include/configs/trats.h | 2 -- include/configs/trats2.h | 1 - include/configs/tricorder.h | 1 - include/configs/uniphier.h | 1 - include/configs/v38b.h | 3 --- include/configs/ve8313.h | 1 - include/configs/vexpress_aemv8a.h | 1 - include/configs/vinco.h | 4 ---- include/configs/warp7.h | 1 - include/configs/woodburn_common.h | 2 -- include/configs/work_92105.h | 1 - include/configs/x600.h | 1 - include/configs/x86-common.h | 1 - include/configs/xilinx-ppc.h | 1 - include/configs/xpedite550x.h | 1 - include/configs/zmx25.h | 2 -- include/configs/zynq-common.h | 1 - 245 files changed, 676 deletions(-)
diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index cda5a65..a9c6272 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -712,7 +712,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_FM1_10GEC1_PHY_ADDR 0x7 /*SLOT 1*/ #define CONFIG_SYS_FM1_10GEC2_PHY_ADDR 0x6 /*SLOT 2*/
- #define CONFIG_SYS_FM1_DTSEC1_RISER_PHY_ADDR 0x1c #define CONFIG_SYS_FM1_DTSEC2_RISER_PHY_ADDR 0x1d #define CONFIG_SYS_FM1_DTSEC3_RISER_PHY_ADDR 0x1e diff --git a/include/configs/BSC9131RDB.h b/include/configs/BSC9131RDB.h index 42cc6db..07070cd 100644 --- a/include/configs/BSC9131RDB.h +++ b/include/configs/BSC9131RDB.h @@ -52,7 +52,6 @@ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */ #endif
- /* High Level Configuration Options */ #define CONFIG_BOOKE /* BOOKE */ #define CONFIG_E500 /* BOOKE e500 family */ diff --git a/include/configs/BSC9132QDS.h b/include/configs/BSC9132QDS.h index 51bdc0f..1eb2ff6 100644 --- a/include/configs/BSC9132QDS.h +++ b/include/configs/BSC9132QDS.h @@ -93,7 +93,6 @@
- /* * PCI Windows * Memory space is mapped 1-1, but I/O space must start from 0. @@ -223,7 +222,6 @@ combinations. this should be removed later #define CONFIG_SYS_DDR_TIMING_5 CONFIG_SYS_DDR_TIMING_5_800 #endif
- /* relocated CCSRBAR */ #define CONFIG_SYS_CCSRBAR CONFIG_SYS_CCSRBAR_DEFAULT #define CONFIG_SYS_CCSRBAR_PHYS_LOW CONFIG_SYS_CCSRBAR_DEFAULT @@ -590,7 +588,6 @@ combinations. this should be removed later #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE/* Boot Argument Buffer Size */
- /* * For booting Linux, the board info and command line data * have to be in the first 64 MB of memory, since this is diff --git a/include/configs/C29XPCIE.h b/include/configs/C29XPCIE.h index ba5fbfd..1600417 100644 --- a/include/configs/C29XPCIE.h +++ b/include/configs/C29XPCIE.h @@ -100,7 +100,6 @@
- /* * PCI Windows * Memory space is mapped 1-1, but I/O space must start from 0. diff --git a/include/configs/CPCI2DP.h b/include/configs/CPCI2DP.h index 1c4b01f..b60da5e 100644 --- a/include/configs/CPCI2DP.h +++ b/include/configs/CPCI2DP.h @@ -48,7 +48,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- /* * Command line configuration. */ @@ -57,7 +56,6 @@ #define CONFIG_CMD_BSP #define CONFIG_CMD_EEPROM
- #undef CONFIG_WATCHDOG /* watchdog disabled */
#define CONFIG_SDRAM_BANK0 1 /* init onboard SDRAM bank 0 */ @@ -67,7 +65,6 @@ */ #define CONFIG_SYS_LONGHELP /* undef to save memory */
- #if defined(CONFIG_CMD_KGDB) #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #else @@ -102,7 +99,6 @@ #define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ #define CONFIG_SYS_EXTBDINFO 1 /* To use extended board_into (bd_t) */
- #define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */
#define CONFIG_VERSION_VARIABLE 1 /* include version env variable */ diff --git a/include/configs/CPCI4052.h b/include/configs/CPCI4052.h index 51054a1..de6ff7f 100644 --- a/include/configs/CPCI4052.h +++ b/include/configs/CPCI4052.h @@ -62,7 +62,6 @@ #define CONFIG_BOOTP_DNS2 #define CONFIG_BOOTP_SEND_HOSTNAME
- /* * Command line configuration. */ @@ -89,7 +88,6 @@ */ #undef CONFIG_SYS_LONGHELP /* undef to save memory */
- #if defined(CONFIG_CMD_KGDB) #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #else diff --git a/include/configs/M5235EVB.h b/include/configs/M5235EVB.h index efc7827..b5d49b5 100644 --- a/include/configs/M5235EVB.h +++ b/include/configs/M5235EVB.h @@ -40,7 +40,6 @@ #define CONFIG_CMD_PCI #define CONFIG_CMD_REGINFO
- #define CONFIG_MCFFEC #ifdef CONFIG_MCFFEC # define CONFIG_MII 1 diff --git a/include/configs/M5253EVBE.h b/include/configs/M5253EVBE.h index 7f5ee8a..e5aa1c7 100644 --- a/include/configs/M5253EVBE.h +++ b/include/configs/M5253EVBE.h @@ -37,7 +37,6 @@ . = DEFINED(env_offset) ? env_offset : .; \ common/env_embedded.o (.text)
- /* * BOOTP options */ diff --git a/include/configs/M5275EVB.h b/include/configs/M5275EVB.h index 5f055e7..5f3ec3f 100644 --- a/include/configs/M5275EVB.h +++ b/include/configs/M5275EVB.h @@ -58,7 +58,6 @@ #define CONFIG_CMD_CACHE #define CONFIG_CMD_MII
- #define CONFIG_MCFFEC #ifdef CONFIG_MCFFEC #define CONFIG_MII 1 diff --git a/include/configs/MIP405.h b/include/configs/MIP405.h index 8e2bd85..7c4509f 100644 --- a/include/configs/MIP405.h +++ b/include/configs/MIP405.h @@ -21,7 +21,6 @@
#define CONFIG_SYS_TEXT_BASE 0xFFF80000
- /*********************************************************** * Note that it may also be a MIP405T board which is a subset of the * MIP405 @@ -37,7 +36,6 @@ ***********************************************************/ #define CONFIG_SYS_CLK_FREQ 33000000 /* external frequency to pll */
- /* * BOOTP options */ @@ -46,7 +44,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- /* * Command line configuration. */ @@ -66,7 +63,6 @@ #if !defined(CONFIG_MIP405T) #endif
- /************************************************************** * I2C Stuff: * the MIP405 is equiped with an Atmel 24C128/256 EEPROM at address @@ -89,7 +85,6 @@ /* last 6 bits of the address */ #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */
- #define CONFIG_ENV_IS_IN_EEPROM 1 /* use EEPROM for environment vars */ #define CONFIG_ENV_OFFSET 0x00000 /* environment starts at the beginning of the EEPROM */ #define CONFIG_ENV_SIZE 0x00800 /* 2k bytes may be used for env vars */ @@ -280,7 +275,6 @@ #define MULTI_PURPOSE_SOCKET_ADDR 0xF8000000 #define CONFIG_PORT_ADDR PER_PLD_ADDR + 5
- /*----------------------------------------------------------------------- * Definitions for initial stack pointer and data area (in On Chip SRAM) */ @@ -406,5 +400,4 @@ #define CONFIG_IDENT_STRING "\n(c) 2003 by MPL AG Switzerland, PCI_BOOT Version" #endif
- #endif /* __CONFIG_H */ diff --git a/include/configs/MPC8313ERDB.h b/include/configs/MPC8313ERDB.h index 536fc06..4b7a773 100644 --- a/include/configs/MPC8313ERDB.h +++ b/include/configs/MPC8313ERDB.h @@ -276,7 +276,6 @@ #define CONFIG_SYS_NAND_BLOCK_SIZE 16384 #define CONFIG_SYS_NAND_WINDOW_SIZE (32 * 1024)
- #define CONFIG_SYS_NAND_BR_PRELIM (CONFIG_SYS_NAND_BASE \ | BR_DECC_CHK_GEN /* Use HW ECC */ \ | BR_PS_8 /* 8 bit port */ \ @@ -427,7 +426,6 @@ #define TSEC2_PHYIDX 0 #endif
- /* Options are: TSEC[0-1] */ #define CONFIG_ETHPRIME "TSEC1"
@@ -474,7 +472,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- /* * Command line configuration. */ diff --git a/include/configs/MPC8315ERDB.h b/include/configs/MPC8315ERDB.h index 9cb8012..d29519d 100644 --- a/include/configs/MPC8315ERDB.h +++ b/include/configs/MPC8315ERDB.h @@ -635,7 +635,6 @@ "tftp $fdtaddr $fdtfile;" \ "bootm $loadaddr $ramdiskaddr $fdtaddr"
- #define CONFIG_BOOTCOMMAND CONFIG_NFSBOOTCOMMAND
#endif /* __CONFIG_H */ diff --git a/include/configs/MPC832XEMDS.h b/include/configs/MPC832XEMDS.h index c1eb442..38bb613 100644 --- a/include/configs/MPC832XEMDS.h +++ b/include/configs/MPC832XEMDS.h @@ -337,7 +337,6 @@ #define CONFIG_SYS_PCI_SLV_MEM_BUS 0x00000000 #define CONFIG_SYS_PCI_SLV_MEM_SIZE 0x80000000
- #ifdef CONFIG_PCI #define CONFIG_PCI_INDIRECT_BRIDGE
@@ -407,7 +406,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- /* * Command line configuration. */ @@ -602,7 +600,6 @@ "tftp $fdtaddr $fdtfile;" \ "bootm $loadaddr $ramdiskaddr $fdtaddr"
#endif /* __CONFIG_H */ diff --git a/include/configs/MPC8349EMDS.h b/include/configs/MPC8349EMDS.h index 7e0cb2a..b3a3bc5 100644 --- a/include/configs/MPC8349EMDS.h +++ b/include/configs/MPC8349EMDS.h @@ -464,7 +464,6 @@ #define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */
- /* * BOOTP options */ @@ -473,7 +472,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- /* * Command line configuration. */ @@ -617,7 +615,6 @@ HID0_ENABLE_M_BIT |\ HID0_ENABLE_ADDRESS_BROADCAST) */
- #define CONFIG_SYS_HID2 HID2_HBE #define CONFIG_HIGH_BATS 1 /* High BATs supported */
diff --git a/include/configs/MPC8349ITX.h b/include/configs/MPC8349ITX.h index 447974c..9b3c6ea 100644 --- a/include/configs/MPC8349ITX.h +++ b/include/configs/MPC8349ITX.h @@ -484,7 +484,6 @@ boards, we say we have two, but don't display a message if we find only one. */ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- /* * Command line configuration. */ @@ -710,7 +709,6 @@ boards, we say we have two, but don't display a message if we find only one. */ #define CONFIG_KGDB_BAUDRATE 230400 /* speed of kgdb serial port */ #endif
- /* * Environment Configuration */ diff --git a/include/configs/MPC837XEMDS.h b/include/configs/MPC837XEMDS.h index 09dd4c6..7f26ecb 100644 --- a/include/configs/MPC837XEMDS.h +++ b/include/configs/MPC837XEMDS.h @@ -475,7 +475,6 @@ extern int board_pci_host_broken(void); #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- /* * Command line configuration. */ @@ -695,7 +694,6 @@ extern int board_pci_host_broken(void); "tftp $fdtaddr $fdtfile;" \ "bootm $loadaddr $ramdiskaddr $fdtaddr"
#endif /* __CONFIG_H */ diff --git a/include/configs/MPC837XERDB.h b/include/configs/MPC837XERDB.h index ff6c962..ebf30e7 100644 --- a/include/configs/MPC837XERDB.h +++ b/include/configs/MPC837XERDB.h @@ -486,7 +486,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- /* * Command line configuration. */ diff --git a/include/configs/MPC8536DS.h b/include/configs/MPC8536DS.h index c19e991..f22ba9b 100644 --- a/include/configs/MPC8536DS.h +++ b/include/configs/MPC8536DS.h @@ -156,7 +156,6 @@
#undef CONFIG_CLOCKS_IN_MHZ
- /* * Memory map -- xxx -this is wrong, needs updating * diff --git a/include/configs/MPC8540ADS.h b/include/configs/MPC8540ADS.h index 6e715f6..38bd38c 100644 --- a/include/configs/MPC8540ADS.h +++ b/include/configs/MPC8540ADS.h @@ -65,7 +65,6 @@ #define CONFIG_SYS_CLK_FREQ 33000000 #endif
- /* * These can be toggled for performance analysis, otherwise use default. */ @@ -136,7 +135,6 @@
- /* * Local Bus Definitions */ @@ -201,7 +199,6 @@ #define CONFIG_SYS_LBC_LSDMR_4 (CONFIG_SYS_LBC_LSDMR_COMMON | LSDMR_OP_MRW) #define CONFIG_SYS_LBC_LSDMR_5 (CONFIG_SYS_LBC_LSDMR_COMMON | LSDMR_OP_NORMAL)
- /* * 32KB, 8-bit wide for ADS config reg */ @@ -278,7 +275,6 @@
#endif /* CONFIG_PCI */
- #if defined(CONFIG_TSEC_ENET)
#define CONFIG_MII 1 /* MII PHY management */ @@ -293,7 +289,6 @@ #define TSEC1_FLAGS TSEC_GIGABIT #define TSEC2_FLAGS TSEC_GIGABIT
- #if CONFIG_HAS_FEC #define CONFIG_MPC85XX_FEC 1 #define CONFIG_MPC85XX_FEC_NAME "FEC" @@ -307,7 +302,6 @@
#endif /* CONFIG_TSEC_ENET */
- /* * Environment */ @@ -326,7 +320,6 @@ #define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */
- /* * BOOTP options */ @@ -335,7 +328,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- /* * Command line configuration. */ @@ -377,7 +369,6 @@ #define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ #endif
- /* * Environment Configuration */ diff --git a/include/configs/MPC8541CDS.h b/include/configs/MPC8541CDS.h index 1187310..4f49633 100644 --- a/include/configs/MPC8541CDS.h +++ b/include/configs/MPC8541CDS.h @@ -133,7 +133,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_SYS_FLASH_CFI #define CONFIG_SYS_FLASH_EMPTY_INFO
- /* * SDRAM on the Local Bus */ @@ -314,7 +313,6 @@ extern unsigned long get_clock_freq(void);
#define CONFIG_MII 1 /* MII PHY management */ @@ -353,7 +351,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- /* * Command line configuration. */ @@ -365,7 +362,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_CMD_PCI #endif
/* diff --git a/include/configs/MPC8544DS.h b/include/configs/MPC8544DS.h index 535f648..435bdc8 100644 --- a/include/configs/MPC8544DS.h +++ b/include/configs/MPC8544DS.h @@ -179,12 +179,10 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define PIXIS_VSPEED2_MASK (PIXIS_VSPEED2_TSEC1SER|PIXIS_VSPEED2_TSEC3SER) #define PIXIS_VCFGEN1_MASK (PIXIS_VCFGEN1_TSEC1SER|PIXIS_VCFGEN1_TSEC3SER)
- #define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xf4010000 /* Initial L1 address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x00004000 /* Size of used area in RAM */
- #define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
@@ -317,7 +315,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy);
#define CONFIG_MII 1 /* MII PHY management */ @@ -368,7 +365,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- /* * Command line configuration. */ diff --git a/include/configs/MPC8548CDS.h b/include/configs/MPC8548CDS.h index 8085969..0fdf939 100644 --- a/include/configs/MPC8548CDS.h +++ b/include/configs/MPC8548CDS.h @@ -132,7 +132,6 @@ extern unsigned long get_clock_freq(void); * */
- /* * Local Bus Definitions */ @@ -421,7 +420,6 @@ extern unsigned long get_clock_freq(void);
#define CONFIG_MII 1 /* MII PHY management */ @@ -479,7 +477,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- /* * Command line configuration. */ @@ -491,7 +488,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_CMD_PCI #endif
/* @@ -580,7 +576,6 @@ extern unsigned long get_clock_freq(void); "tftp $fdtaddr $fdtfile;" \ "bootm $loadaddr - $fdtaddr"
- #define CONFIG_RAMBOOTCOMMAND \ "setenv bootargs root=/dev/ram rw " \ "console=$consoledev,$baudrate $othbootargs;" \ diff --git a/include/configs/MPC8555CDS.h b/include/configs/MPC8555CDS.h index d24309a..56f6ef5 100644 --- a/include/configs/MPC8555CDS.h +++ b/include/configs/MPC8555CDS.h @@ -33,7 +33,6 @@
#define CONFIG_FSL_VIA
- #ifndef __ASSEMBLY__ extern unsigned long get_clock_freq(void); #endif @@ -131,7 +130,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_SYS_FLASH_CFI #define CONFIG_SYS_FLASH_EMPTY_INFO
- /* * SDRAM on the Local Bus */ @@ -312,7 +310,6 @@ extern unsigned long get_clock_freq(void);
#define CONFIG_MII 1 /* MII PHY management */ @@ -351,7 +348,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- /* * Command line configuration. */ @@ -363,7 +359,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_CMD_PCI #endif
/* diff --git a/include/configs/MPC8560ADS.h b/include/configs/MPC8560ADS.h index c0841db..c049d8d 100644 --- a/include/configs/MPC8560ADS.h +++ b/include/configs/MPC8560ADS.h @@ -60,7 +60,6 @@ #define CONFIG_SYS_CLK_FREQ 33000000 #endif
- /* * These can be toggled for performance analysis, otherwise use default. */ @@ -133,7 +132,6 @@
- /* * Local Bus Definitions */ @@ -198,7 +196,6 @@ #define CONFIG_SYS_LBC_LSDMR_4 (CONFIG_SYS_LBC_LSDMR_COMMON | LSDMR_OP_MRW) #define CONFIG_SYS_LBC_LSDMR_5 (CONFIG_SYS_LBC_LSDMR_COMMON | LSDMR_OP_NORMAL)
- /* * 32KB, 8-bit wide for ADS config reg */ @@ -273,7 +270,6 @@
- #ifdef CONFIG_TSEC_ENET
#ifndef CONFIG_MII @@ -345,7 +341,6 @@
#endif
- /* * Environment */ @@ -372,7 +367,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- /* * Command line configuration. */ @@ -419,7 +413,6 @@ #define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ #endif
- /* * Environment Configuration */ diff --git a/include/configs/MPC8568MDS.h b/include/configs/MPC8568MDS.h index 47b0955..d42191b 100644 --- a/include/configs/MPC8568MDS.h +++ b/include/configs/MPC8568MDS.h @@ -51,7 +51,6 @@ extern unsigned long get_clock_freq(void); */ #define CONFIG_ENABLE_36BIT_PHYS 1
- #define CONFIG_BOARD_EARLY_INIT_F 1 /* Call board_pre_init */
#define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest works on */ @@ -144,14 +143,12 @@ extern unsigned long get_clock_freq(void); #define CONFIG_SYS_FLASH_CFI #define CONFIG_SYS_FLASH_EMPTY_INFO
- /* * SDRAM on the LocalBus */ #define CONFIG_SYS_LBC_SDRAM_BASE 0xf0000000 /* Localbus SDRAM */ #define CONFIG_SYS_LBC_SDRAM_SIZE 64 /* LBC SDRAM is 64MB */
- /*Chip select 2 - SDRAM*/ #define CONFIG_SYS_BR2_PRELIM 0xf0001861 #define CONFIG_SYS_OR2_PRELIM 0xfc006901 @@ -364,7 +361,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */
- /* * BOOTP options */ @@ -373,7 +369,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- /* * Command line configuration. */ @@ -385,7 +380,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_CMD_PCI #endif
/* @@ -459,14 +453,12 @@ extern unsigned long get_clock_freq(void); "ramargs=setenv bootargs root=/dev/ram rw " \ "console=$consoledev,$baudrate $othbootargs\0" \
- #define CONFIG_NFSBOOTCOMMAND \ "run nfsargs;" \ "tftp $loadaddr $bootfile;" \ "tftp $fdtaddr $fdtfile;" \ "bootm $loadaddr - $fdtaddr"
- #define CONFIG_RAMBOOTCOMMAND \ "run ramargs;" \ "tftp $ramdiskaddr $ramdiskfile;" \ diff --git a/include/configs/MPC8569MDS.h b/include/configs/MPC8569MDS.h index 51abcab..37156cb 100644 --- a/include/configs/MPC8569MDS.h +++ b/include/configs/MPC8569MDS.h @@ -463,7 +463,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- /* * Command line configuration. */ @@ -475,7 +474,6 @@ extern unsigned long get_clock_freq(void); #define CONFIG_CMD_PCI #endif
#define CONFIG_MMC 1 diff --git a/include/configs/MPC8572DS.h b/include/configs/MPC8572DS.h index fe9d4cd..00db9b7 100644 --- a/include/configs/MPC8572DS.h +++ b/include/configs/MPC8572DS.h @@ -177,7 +177,6 @@ #define CONFIG_SYS_FLASH_BASE_PHYS CONFIG_SYS_FLASH_BASE #endif
- #define CONFIG_FLASH_BR_PRELIM \ (BR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS + 0x8000000) | BR_PS_16 | BR_V) #define CONFIG_FLASH_OR_PRELIM 0xf8000ff7 @@ -318,7 +317,6 @@ #define CONFIG_SYS_NAND_U_BOOT_RELOC (CONFIG_SYS_INIT_L2_END - 0x2000) #define CONFIG_SYS_NAND_U_BOOT_RELOC_SP ((CONFIG_SYS_INIT_L2_END - 1) & ~0xF)
- /* NAND flash config */ #define CONFIG_SYS_NAND_BR_PRELIM (BR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS) \ | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ @@ -358,7 +356,6 @@ | BR_V) /* valid */ #define CONFIG_SYS_OR6_PRELIM CONFIG_SYS_NAND_OR_PRELIM /* NAND Options */
- /* Serial Port - controlled on board with jumper J8 * open - index 2 * shorted - index 1 @@ -509,7 +506,6 @@
#define CONFIG_MII 1 /* MII PHY management */ diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h index b40d72f..b6539b8 100644 --- a/include/configs/MPC8610HPCD.h +++ b/include/configs/MPC8610HPCD.h @@ -20,7 +20,6 @@
#define CONFIG_SYS_TEXT_BASE 0xfff00000
- /* video */ #define CONFIG_FSL_DIU_FB
@@ -136,14 +135,12 @@
#endif
- #define CONFIG_ID_EEPROM #define CONFIG_SYS_I2C_EEPROM_NXID #define CONFIG_ID_EEPROM #define CONFIG_SYS_I2C_EEPROM_ADDR 0x57 #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1
- #define CONFIG_SYS_FLASH_BASE 0xf0000000 /* start of FLASH 128M */ #define CONFIG_SYS_FLASH_BASE2 0xf8000000
@@ -161,7 +158,6 @@ #define CONFIG_SYS_BR3_PRELIM 0xe8000801 /* port size 8bit */ #define CONFIG_SYS_OR3_PRELIM 0xfff06ff7 /* 1MB PIXIS area*/
- #define CONFIG_FSL_PIXIS 1 /* use common PIXIS code */ #define PIXIS_BASE 0xe8000000 /* PIXIS registers */ #define PIXIS_ID 0x0 /* Board ID at offset 0 */ @@ -277,7 +273,6 @@ #define CONFIG_SYS_PCIE2_IO_PHYS 0xe2000000 #define CONFIG_SYS_PCIE2_IO_SIZE 0x00100000 /* 1M */
- #if defined(CONFIG_PCI)
#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ @@ -386,7 +381,6 @@ #define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCIE2_IO_PHYS | BATL_PP_RW | BATL_CACHEINHIBIT) #define CONFIG_SYS_IBAT4U CONFIG_SYS_DBAT4U
- /* * BAT5 128K Cacheable, non-guarded * 0xe400_0000 128K Init RAM for stack in the CPU DCache (no backing memory) @@ -424,7 +418,6 @@ #define CONFIG_SYS_IBAT7L (PIXIS_BASE | BATL_PP_RW | BATL_CACHEINHIBIT) #define CONFIG_SYS_IBAT7U CONFIG_SYS_DBAT7U
- /* * Environment */ @@ -442,7 +435,6 @@ #define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */
- /* * BOOTP options */ @@ -451,7 +443,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- /* * Command line configuration. */ @@ -463,7 +454,6 @@ #define CONFIG_CMD_EXT2 #endif
- #define CONFIG_WATCHDOG /* watchdog enabled */ #define CONFIG_SYS_WATCHDOG_FREQ 5000 /* Feed interval, 5s */
diff --git a/include/configs/MPC8641HPCN.h b/include/configs/MPC8641HPCN.h index 6f70bd1..b2e2f36 100644 --- a/include/configs/MPC8641HPCN.h +++ b/include/configs/MPC8641HPCN.h @@ -134,7 +134,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define SPD_EEPROM_ADDRESS3 0x53 /* CTLR 1 DIMM 0 */ #define SPD_EEPROM_ADDRESS4 0x54 /* CTLR 1 DIMM 1 */
- /* * These are used when DDR doesn't use SPD. */ @@ -359,7 +358,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy);
#define CONFIG_PCI_PNP /* do pci plug-and-play */
- #undef CONFIG_EEPRO100 #undef CONFIG_TULIP
@@ -440,7 +438,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy);
- #ifdef CONFIG_PHYS_64BIT #define PHYS_HIGH_TO_BXPN(x) ((x & 0x0000000e) << 8) #define PHYS_HIGH_TO_BX(x) ((x & 0x00000001) << 2) @@ -600,7 +597,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */
- /* * BOOTP options */ @@ -609,7 +605,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- /* * Command line configuration. */ @@ -621,7 +616,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); #define CONFIG_CMD_EXT2 #endif
/* @@ -703,7 +697,6 @@ extern unsigned long get_board_sys_clk(unsigned long dummy); "dis-wd=mw.b ffdf0010 0x00; echo -expect:- 00; md.b ffdf0010 1\0" \ "maxcpus=2"
- #define CONFIG_NFSBOOTCOMMAND \ "setenv bootargs root=/dev/nfs rw " \ "nfsroot=$serverip:$rootpath " \ diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index fcb1644..87726a4 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -185,7 +185,6 @@
- /* * PCI Windows * Memory space is mapped 1-1, but I/O space must start from 0. @@ -699,7 +698,6 @@ extern unsigned long get_sdram_size(void);
- /* SATA */ #define CONFIG_FSL_SATA #define CONFIG_FSL_SATA_V2 diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index 5272878..5a7bef9 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -172,7 +172,6 @@ #define CONFIG_SYS_CCSR_DO_NOT_RELOCATE #endif
- /* DDR Setup */ #define CONFIG_DDR_SPD #define CONFIG_VERY_BIG_RAM @@ -217,7 +216,6 @@ #define CONFIG_SYS_DDR_ZQ_CONTROL 0x89080600 #define CONFIG_SYS_DDR_WRLVL_CONTROL 0x8675f608
- /* * Memory map * diff --git a/include/configs/PATI.h b/include/configs/PATI.h index 81d535f..9f3c037 100644 --- a/include/configs/PATI.h +++ b/include/configs/PATI.h @@ -21,14 +21,12 @@
#define CONFIG_SYS_TEXT_BASE 0xFFF00000
- /* Serial Console Configuration */ #define CONFIG_5xx_CONS_SCI1 #undef CONFIG_5xx_CONS_SCI2
#define CONFIG_BAUDRATE 9600
- /* * BOOTP options */ @@ -37,7 +35,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- /* * Command line configuration. */ @@ -47,7 +44,6 @@ #define CONFIG_CMD_EEPROM #define CONFIG_CMD_IRQ
- #if 0 #define CONFIG_BOOTDELAY -1 /* autoboot disabled */ #else @@ -135,7 +131,6 @@ */ #define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */
- /*----------------------------------------------------------------------- * FLASH organization *----------------------------------------------------------------------- @@ -165,7 +160,6 @@ #define CONFIG_ENV_OFFSET ((0 - CONFIG_SYS_FLASH_BASE) - CONFIG_ENV_SIZE) /* Environment starts at this adress */ #endif
- #define CONFIG_SPI 1 #define CONFIG_SYS_SPI_CS_USED 0x09 /* CS0 and CS3 are used */ #define CONFIG_SYS_SPI_CS_BASE 0x08 /* CS3 is active low */ @@ -224,7 +218,6 @@ */ #define CONFIG_SYS_OSC_CLK ((uint)4000000) /* Oscillator clock is 4MHz */
- #define CONFIG_SYS_PLPRCR (PLPRCR_MF_9 | PLPRCR_DIVF_0)
/*----------------------------------------------------------------------- diff --git a/include/configs/PIP405.h b/include/configs/PIP405.h index 5290208..7d7e2d0 100644 --- a/include/configs/PIP405.h +++ b/include/configs/PIP405.h @@ -21,13 +21,11 @@
- /*********************************************************** * Clock ***********************************************************/ #define CONFIG_SYS_CLK_FREQ 33000000 /* external frequency to pll */
- /* * BOOTP options */ @@ -36,7 +34,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- /* * Command line configuration. */ @@ -81,7 +78,6 @@ /* last 6 bits of the address */ #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 /* and takes up to 10 msec */
- /*************************************************************** * Definitions for Serial Presence Detect EEPROM address * (to get SDRAM settings) @@ -96,13 +92,11 @@ **************************************************************/ #define CONFIG_BAUDRATE 9600 /* STD Baudrate */
- #define CONFIG_BOOTDELAY 5 /* autoboot (do NOT change this set environment variable "bootdelay" to -1 instead) */ /* #define CONFIG_BOOT_RETRY_TIME -10 /XXX* feature is available but not enabled */ #define CONFIG_ZERO_BOOTDELAY_CHECK /* check console even if bootdelay = 0 */
- #define CONFIG_BOOTCOMMAND "diskboot 400000 0:1; bootm" /* autoboot command */ #define CONFIG_BOOTARGS "console=ttyS0,9600 root=/dev/hda5" /* boot arguments */
@@ -231,7 +225,6 @@ #define CONFIG_PORT_ADDR 0xF4000000 #define MULTI_PURPOSE_SOCKET_ADDR 0xF8000000
- /*----------------------------------------------------------------------- * Definitions for initial stack pointer and data area (in On Chip SRAM) */ @@ -353,5 +346,4 @@ #define CONFIG_ISO_STRING "MEV-10066-001" #define CONFIG_IDENT_STRING "\n(c) 2002 by MPL AG Switzerland, " CONFIG_ISO_STRING " " VERSION_TAG
- #endif /* __CONFIG_H */ diff --git a/include/configs/PLU405.h b/include/configs/PLU405.h index c775100..a868ec9 100644 --- a/include/configs/PLU405.h +++ b/include/configs/PLU405.h @@ -47,7 +47,6 @@
#define CONFIG_PHY_CLK_FREQ EMAC_STACR_CLK_66MHZ /* 66 MHz OPB clock*/
- /* * BOOTP options */ @@ -56,7 +55,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- /* * Command line configuration. */ @@ -86,7 +84,6 @@ */ #define CONFIG_SYS_LONGHELP /* undef to save memory */
- #if defined(CONFIG_CMD_KGDB) #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #else diff --git a/include/configs/PMC405DE.h b/include/configs/PMC405DE.h index a4d7bee..03c8fb9 100644 --- a/include/configs/PMC405DE.h +++ b/include/configs/PMC405DE.h @@ -158,7 +158,6 @@ #define CONFIG_SYS_FLASH_EMPTY_INFO 1 /* 'E' for empty sector (flinfo) */ #define CONFIG_SYS_FLASH_QUIET_TEST 1 /* don't warn upon unknown flash */
- /* * Start addresses for the final memory configuration * (Set up by the startup code) diff --git a/include/configs/PMC440.h b/include/configs/PMC440.h index f69eee6..e5555cc 100644 --- a/include/configs/PMC440.h +++ b/include/configs/PMC440.h @@ -158,7 +158,6 @@ #define CONFIG_SYS_I2C_PPC4XX_SPEED_1 400000 #define CONFIG_SYS_I2C_PPC4XX_SLAVE_1 0x7F
- #define CONFIG_SYS_I2C_EEPROM_ADDR 0x54 #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 5 diff --git a/include/configs/T102xQDS.h b/include/configs/T102xQDS.h index 90572f4..22f42f0 100644 --- a/include/configs/T102xQDS.h +++ b/include/configs/T102xQDS.h @@ -202,7 +202,6 @@ #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ #endif
- #ifndef __ASSEMBLY__ unsigned long get_board_sys_clk(void); unsigned long get_board_ddr_clk(void); @@ -879,7 +878,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_BAUDRATE 115200 #define __USB_PHY_TYPE utmi
- #define CONFIG_EXTRA_ENV_SETTINGS \ "hwconfig=fsl_ddr:ctlr_intlv=cacheline,bank_intlv=cs0_cs1;\0" \ "usb1:dr_mode=host,phy_type=" __stringify(__USB_PHY_TYPE) "\0" \ diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index 846ad39..7b6625f 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -217,7 +217,6 @@ #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ #endif
- #ifndef __ASSEMBLY__ unsigned long get_board_sys_clk(void); unsigned long get_board_ddr_clk(void); @@ -916,7 +915,6 @@ unsigned long get_board_ddr_clk(void); "setenv loadaddr 0x1000000;" \ "bootm $loadaddr $ramdiskaddr $fdtaddr"
- #define CONFIG_NFSBOOTCOMMAND \ "setenv bootargs root=/dev/nfs rw " \ "nfsroot=$serverip:$rootpath " \ diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index 04c564f..da06bfd 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -450,7 +450,6 @@ unsigned long get_board_ddr_clk(void); #define I2C_MUX_PCA_ADDR 0x77 #define I2C_MUX_PCA_ADDR_PRI 0x77 /* Primary Mux*/
- /* I2C bus multiplexer */ #define I2C_MUX_CH_DEFAULT 0x8 #define I2C_MUX_CH_DIU 0xC diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index 1e61ec9..e58691b 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -709,7 +709,6 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_rcw.cfg #endif #endif
- #define CONFIG_SYS_QE_FMAN_FW_LENGTH 0x10000 #define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_QE_FMAN_FW_LENGTH) #endif /* CONFIG_NOBQFMAN */ diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index b1bd4fd..6f81368 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -744,7 +744,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_FSL_ESDHC_ADAPTER_IDENT #endif
- /* * Dynamic MTD Partition support with mtdparts */ diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index dc6e211..508c896 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -652,7 +652,6 @@ unsigned long get_board_ddr_clk(void); #define FM1_10GEC4_PHY_ADDR 0x01 #endif
- #ifdef CONFIG_FMAN_ENET #define CONFIG_MII /* MII PHY management */ #define CONFIG_ETHPRIME "FM1@DTSEC3" diff --git a/include/configs/T4240QDS.h b/include/configs/T4240QDS.h index af5855c..1ff6309 100644 --- a/include/configs/T4240QDS.h +++ b/include/configs/T4240QDS.h @@ -343,7 +343,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_RAMBOOT #endif
- /* I2C */ #define CONFIG_SYS_FSL_I2C_SPEED 100000 /* I2C speed */ #define CONFIG_SYS_FSL_I2C2_SPEED 100000 /* I2C2 speed */ @@ -404,7 +403,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SF_DEFAULT_SPEED 10000000 #define CONFIG_SF_DEFAULT_MODE 0
- /* Qman/Bman */ #ifndef CONFIG_NOBQFMAN #define CONFIG_SYS_DPAA_QBMAN /* Support Q/Bman */ @@ -492,7 +490,6 @@ unsigned long get_board_ddr_clk(void); #define FM2_10GEC2_PHY_ADDR 0x3 #endif
- /* SATA */ #ifdef CONFIG_FSL_SATA_V2 #define CONFIG_LIBATA diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index 2b50594..495c09c 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -154,14 +154,12 @@ #define CONFIG_DDR_SPD #define CONFIG_SYS_FSL_DDR3
- /* * IFC Definitions */ #define CONFIG_SYS_FLASH_BASE 0xe0000000 #define CONFIG_SYS_FLASH_BASE_PHYS (0xf00000000ull | CONFIG_SYS_FLASH_BASE)
- #ifdef CONFIG_SPL_BUILD #define CONFIG_SYS_MONITOR_BASE CONFIG_SPL_TEXT_BASE #else @@ -349,7 +347,6 @@ /* default location for tftp and bootm */ #define CONFIG_LOADADDR 1000000
- #define CONFIG_BAUDRATE 115200
#define CONFIG_HVBOOT \ @@ -572,7 +569,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_RAMBOOT #endif
- /* I2C */ #define CONFIG_SYS_FSL_I2C_SPEED 100000 /* I2C speed */ #define CONFIG_SYS_FSL_I2C2_SPEED 100000 /* I2C2 speed */ @@ -606,7 +602,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SF_DEFAULT_SPEED 10000000 #define CONFIG_SF_DEFAULT_MODE 0
- /* Qman/Bman */ #ifndef CONFIG_NOBQFMAN #define CONFIG_SYS_DPAA_QBMAN /* Support Q/Bman */ @@ -696,7 +691,6 @@ unsigned long get_board_ddr_clk(void); #define CORTINA_PHY_ADDR4 FM2_10GEC2_PHY_ADDR #endif
- /* SATA */ #ifdef CONFIG_FSL_SATA_V2 #define CONFIG_LIBATA diff --git a/include/configs/TQM5200.h b/include/configs/TQM5200.h index 516acd3..d542d2a 100644 --- a/include/configs/TQM5200.h +++ b/include/configs/TQM5200.h @@ -117,7 +117,6 @@ #define CONFIG_SYS_CONSOLE_IS_IN_ENV #endif /* #ifndef CONFIG_TQM5200S */
- /* Partitions */ #define CONFIG_MAC_PARTITION #define CONFIG_DOS_PARTITION @@ -151,7 +150,6 @@ #define MPC5XXX_SRAM_POST_SIZE MPC5XXX_SRAM_SIZE-4 #endif
- /* * BOOTP options */ @@ -160,7 +158,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- /* * Command line configuration. */ @@ -198,7 +195,6 @@ #define CONFIG_CMD_DIAG #endif
- #define CONFIG_TIMESTAMP /* display image timestamps */
#if (CONFIG_SYS_TEXT_BASE != 0xFFF00000) @@ -485,7 +481,6 @@ #define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE #endif
diff --git a/include/configs/TQM823L.h b/include/configs/TQM823L.h index 474ab5f..304dc09 100644 --- a/include/configs/TQM823L.h +++ b/include/configs/TQM823L.h @@ -95,13 +95,11 @@ #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_BOOTFILESIZE
- #define CONFIG_MAC_PARTITION #define CONFIG_DOS_PARTITION
#define CONFIG_RTC_MPC8xx /* use internal RTC of MPC8xx */
- /* * Command line configuration. */ @@ -115,7 +113,6 @@ #define CONFIG_CMD_BMP #endif
- #define CONFIG_NETCONSOLE
/* diff --git a/include/configs/TQM823M.h b/include/configs/TQM823M.h index 98b900a..72cd1e4 100644 --- a/include/configs/TQM823M.h +++ b/include/configs/TQM823M.h @@ -93,13 +93,11 @@ #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_BOOTFILESIZE
- /* * Command line configuration. */ diff --git a/include/configs/TQM834x.h b/include/configs/TQM834x.h index 2becc46..24ed057 100644 --- a/include/configs/TQM834x.h +++ b/include/configs/TQM834x.h @@ -282,7 +282,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- /* * Command line configuration. */ @@ -307,7 +306,6 @@ #define CONFIG_CMDLINE_EDITING 1 /* add command line history */ #define CONFIG_AUTO_COMPLETE /* add autocompletion support */
- #if defined(CONFIG_CMD_KGDB) #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #else diff --git a/include/configs/TQM850L.h b/include/configs/TQM850L.h index 8b57f08..2ed1539 100644 --- a/include/configs/TQM850L.h +++ b/include/configs/TQM850L.h @@ -84,7 +84,6 @@ #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_BOOTFILESIZE
diff --git a/include/configs/TQM850M.h b/include/configs/TQM850M.h index 40c60fc..469cd3f 100644 --- a/include/configs/TQM850M.h +++ b/include/configs/TQM850M.h @@ -84,7 +84,6 @@ #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_BOOTFILESIZE
@@ -99,10 +98,8 @@ #define CONFIG_CMD_IDE #define CONFIG_CMD_JFFS2
- /* * Miscellaneous configurable options */ diff --git a/include/configs/TQM855L.h b/include/configs/TQM855L.h index cae97c6..eb0077b 100644 --- a/include/configs/TQM855L.h +++ b/include/configs/TQM855L.h @@ -86,13 +86,11 @@ #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_BOOTFILESIZE
- /* * Command line configuration. */ diff --git a/include/configs/TQM855M.h b/include/configs/TQM855M.h index e6868ef..b504713 100644 --- a/include/configs/TQM855M.h +++ b/include/configs/TQM855M.h @@ -115,13 +115,11 @@ #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_BOOTFILESIZE
- /* * Command line configuration. */ diff --git a/include/configs/TQM860L.h b/include/configs/TQM860L.h index 25ce29b..dfddd03 100644 --- a/include/configs/TQM860L.h +++ b/include/configs/TQM860L.h @@ -86,13 +86,11 @@ #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_BOOTFILESIZE
- /* * Command line configuration. */ diff --git a/include/configs/TQM860M.h b/include/configs/TQM860M.h index 117d1e4..2733849 100644 --- a/include/configs/TQM860M.h +++ b/include/configs/TQM860M.h @@ -86,13 +86,11 @@ #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_BOOTFILESIZE
- /* * Command line configuration. */ diff --git a/include/configs/TQM862L.h b/include/configs/TQM862L.h index bb61986b..9f09319 100644 --- a/include/configs/TQM862L.h +++ b/include/configs/TQM862L.h @@ -89,13 +89,11 @@ #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_BOOTFILESIZE
- /* * Command line configuration. */ diff --git a/include/configs/TQM862M.h b/include/configs/TQM862M.h index ff473e9..e76cb64 100644 --- a/include/configs/TQM862M.h +++ b/include/configs/TQM862M.h @@ -89,13 +89,11 @@ #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_BOOTFILESIZE
- /* * Command line configuration. */ diff --git a/include/configs/TQM866M.h b/include/configs/TQM866M.h index 78cf804..0d84ac7 100644 --- a/include/configs/TQM866M.h +++ b/include/configs/TQM866M.h @@ -127,7 +127,6 @@ #define CONFIG_BOOTP_BOOTPATH #define CONFIG_BOOTP_BOOTFILESIZE
@@ -135,7 +134,6 @@
#define CONFIG_TIMESTAMP /* but print image timestmps */
- /* * Command line configuration. */ diff --git a/include/configs/VCMA9.h b/include/configs/VCMA9.h index 0b6e3f3..5d7874b 100644 --- a/include/configs/VCMA9.h +++ b/include/configs/VCMA9.h @@ -13,7 +13,6 @@ #ifndef __CONFIG_H #define __CONFIG_H
- #define MACH_TYPE_MPL_VCMA9 227
/* @@ -29,7 +28,6 @@
#define CONFIG_SYS_TEXT_BASE 0x0
- #define CONFIG_SYS_ARM_CACHE_WRITETHROUGH
/* input clock of PLL (VCMA9 has 12MHz input clock) */ @@ -113,7 +111,6 @@ /* RTC */ #define CONFIG_RTC_S3C24X0
- /* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE
diff --git a/include/configs/VOM405.h b/include/configs/VOM405.h index e2aa578..405ac0d 100644 --- a/include/configs/VOM405.h +++ b/include/configs/VOM405.h @@ -74,7 +74,6 @@ */ #define CONFIG_SYS_LONGHELP /* undef to save memory */
- #if defined(CONFIG_CMD_KGDB) #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #else diff --git a/include/configs/a3m071.h b/include/configs/a3m071.h index f44a20c..47e35c5 100644 --- a/include/configs/a3m071.h +++ b/include/configs/a3m071.h @@ -230,7 +230,6 @@ * +- 31 0 PSC1 */
- /* * Miscellaneous configurable options */ diff --git a/include/configs/a4m072.h b/include/configs/a4m072.h index c6a8553..09216d1 100644 --- a/include/configs/a4m072.h +++ b/include/configs/a4m072.h @@ -88,7 +88,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- /* * Command line configuration. */ @@ -222,7 +221,6 @@ #define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM #define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE /* Size of used area in DPRAM */
@@ -276,7 +274,6 @@ # define CONFIG_SYS_CACHELINE_SHIFT 5 /* log base 2 of the above value */ #endif
- /* * Various low-level settings */ diff --git a/include/configs/ac14xx.h b/include/configs/ac14xx.h index 8c60f10..efd63a0 100644 --- a/include/configs/ac14xx.h +++ b/include/configs/ac14xx.h @@ -342,7 +342,6 @@ CLOCK_SCCR2_DIU_EN | \ CLOCK_SCCR2_I2C_EN)
- #define CONFIG_CMDLINE_EDITING 1 /* command line history */
/* I2C */ diff --git a/include/configs/am3517_crane.h b/include/configs/am3517_crane.h index cd6e0fd..cbfe1bd 100644 --- a/include/configs/am3517_crane.h +++ b/include/configs/am3517_crane.h @@ -134,7 +134,6 @@ #define CONFIG_CMD_MMC /* MMC support */ #define CONFIG_CMD_NAND /* NAND support */
- #define CONFIG_SYS_NO_FLASH #define CONFIG_SYS_I2C #define CONFIG_SYS_OMAP24_I2C_SPEED 100000 diff --git a/include/configs/amcc-common.h b/include/configs/amcc-common.h index f97988c..89093bd 100644 --- a/include/configs/amcc-common.h +++ b/include/configs/amcc-common.h @@ -10,7 +10,6 @@ #ifndef __AMCC_COMMON_H #define __AMCC_COMMON_H
- #define CONFIG_SYS_SDRAM_BASE 0x00000000 /* _must_ be 0 */ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* Start of U-Boot */ #define CONFIG_SYS_MONITOR_LEN (0xFFFFFFFF - CONFIG_SYS_MONITOR_BASE + 1) @@ -88,7 +87,6 @@ #define CONFIG_VERSION_VARIABLE /* include version env variable */ #define CONFIG_SYS_CONSOLE_INFO_QUIET /* don't print console @ startup*/
- #define CONFIG_LOADS_ECHO /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */
diff --git a/include/configs/apf27.h b/include/configs/apf27.h index f0e88ee..f8c91f8 100644 --- a/include/configs/apf27.h +++ b/include/configs/apf27.h @@ -147,7 +147,6 @@ #define CONFIG_ENV_VARS_UBOOT_CONFIG #define CONFIG_PREBOOT "run check_flash check_env;"
- /* * Boot Linux */ diff --git a/include/configs/apx4devkit.h b/include/configs/apx4devkit.h index fc7a35e..1f7ef8f 100644 --- a/include/configs/apx4devkit.h +++ b/include/configs/apx4devkit.h @@ -38,7 +38,6 @@ #define PHYS_SDRAM_1_SIZE 0x20000000 /* Max 512 MB RAM */ #define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1
- /* Environment */ #define CONFIG_ENV_OVERWRITE #define CONFIG_ENV_IS_IN_NAND @@ -92,7 +91,6 @@ #define CONFIG_USB_STORAGE #endif
- /* RTC */ #ifdef CONFIG_CMD_DATE #define CONFIG_RTC_PCF8563 diff --git a/include/configs/astro_mcf5373l.h b/include/configs/astro_mcf5373l.h index f7fa058..6660eb0 100644 --- a/include/configs/astro_mcf5373l.h +++ b/include/configs/astro_mcf5373l.h @@ -68,7 +68,6 @@ #define CONFIG_CMD_FPGA_LOADMK #define CONFIG_CMDLINE_EDITING
- #define CONFIG_MCFRTC #undef RTC_DEBUG
diff --git a/include/configs/at91rm9200ek.h b/include/configs/at91rm9200ek.h index 0d98a44..ee3712c 100644 --- a/include/configs/at91rm9200ek.h +++ b/include/configs/at91rm9200ek.h @@ -60,7 +60,6 @@
#define CONFIG_CMD_BOOTZ
- /* * Memory Configuration */ diff --git a/include/configs/at91sam9rlek.h b/include/configs/at91sam9rlek.h index 126b8d4..6a03923 100644 --- a/include/configs/at91sam9rlek.h +++ b/include/configs/at91sam9rlek.h @@ -61,7 +61,6 @@ #undef CONFIG_FB_ADDR #define CONFIG_SYS_CONSOLE_IS_IN_ENV 1
- /* LED */ #define CONFIG_AT91_LED #define CONFIG_RED_LED AT91_PIN_PD14 /* this is the power led */ diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index a4d9cb8..fd87bb7 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -74,7 +74,6 @@ * NB: in this case, USB 1.1 devices won't be recognized. */
- /* SDRAM */ #define CONFIG_NR_DRAM_BANKS 1 #define CONFIG_SYS_SDRAM_BASE 0x20000000 diff --git a/include/configs/atngw100.h b/include/configs/atngw100.h index 4118cac..a18a2c9 100644 --- a/include/configs/atngw100.h +++ b/include/configs/atngw100.h @@ -86,7 +86,6 @@ #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_MMC
- #define CONFIG_ATMEL_USART #define CONFIG_MACB #define CONFIG_PORTMUX_PIO @@ -97,7 +96,6 @@ #define CONFIG_GENERIC_MMC #define CONFIG_ATMEL_SPI
- #define CONFIG_SYS_DCACHE_LINESZ 32 #define CONFIG_SYS_ICACHE_LINESZ 32
diff --git a/include/configs/atngw100mkii.h b/include/configs/atngw100mkii.h index dd4e1a3..09e193e 100644 --- a/include/configs/atngw100mkii.h +++ b/include/configs/atngw100mkii.h @@ -106,7 +106,6 @@ #define CONFIG_CMD_MMC #define CONFIG_CMD_MII
- #define CONFIG_ATMEL_USART #define CONFIG_MACB #define CONFIG_PORTMUX_PIO @@ -117,7 +116,6 @@ #define CONFIG_GENERIC_MMC #define CONFIG_ATMEL_SPI
diff --git a/include/configs/atstk1002.h b/include/configs/atstk1002.h index 2d34077..62f01a7 100644 --- a/include/configs/atstk1002.h +++ b/include/configs/atstk1002.h @@ -107,7 +107,6 @@ #define CONFIG_CMD_JFFS2 #define CONFIG_CMD_MMC
- #define CONFIG_ATMEL_USART #define CONFIG_MACB #define CONFIG_PORTMUX_PIO diff --git a/include/configs/baltos.h b/include/configs/baltos.h index 560dc88..27ab8f7 100644 --- a/include/configs/baltos.h +++ b/include/configs/baltos.h @@ -198,7 +198,6 @@ "run mmcboot;" \ "run nandboot;"
- /* NS16550 Configuration */ #define CONFIG_SYS_NS16550_COM1 0x44e09000 /* Base EVM has UART0 */ #define CONFIG_SYS_NS16550_COM2 0x48022000 /* UART1 */ diff --git a/include/configs/bct-brettl2.h b/include/configs/bct-brettl2.h index 4563c54..e95deac 100644 --- a/include/configs/bct-brettl2.h +++ b/include/configs/bct-brettl2.h @@ -7,14 +7,12 @@
#include <asm/config-pre.h>
- /* * Processor Settings */ #define CONFIG_BFIN_CPU bf536-0.3 #define CONFIG_BFIN_BOOT_MODE BFIN_BOOT_BYPASS
- /* * Clock Settings * CCLK = (CLKIN * VCO_MULT) / CCLK_DIV @@ -39,14 +37,12 @@ #define CONFIG_SCLK_DIV 3 #define CONFIG_VR_CTL_VAL (VLEV_110 | GAIN_20 | FREQ_1000)
- /* * Memory Settings */ #define CONFIG_MEM_ADD_WDTH 9 #define CONFIG_MEM_SIZE 32
- /* * SDRAM Settings */ @@ -60,7 +56,6 @@ #define CONFIG_SYS_MONITOR_LEN (256 * 1024) #define CONFIG_SYS_MALLOC_LEN (128 * 1024)
- /* * Network Settings */ @@ -75,7 +70,6 @@ #define CONFIG_ROOTPATH "/romfs/brettl2" #endif
- /* * Flash Settings */ @@ -87,7 +81,6 @@ #define CONFIG_SYS_MAX_FLASH_BANKS 1 #define CONFIG_SYS_MAX_FLASH_SECT 135
- /* * Env Storage Settings */ @@ -115,14 +108,12 @@ common/env_embedded.o (.text*); #endif
- /* * I2C Settings */ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_ADI
- /* * Misc Settings */ diff --git a/include/configs/bf506f-ezkit.h b/include/configs/bf506f-ezkit.h index 8be2ecb..dc7d83f 100644 --- a/include/configs/bf506f-ezkit.h +++ b/include/configs/bf506f-ezkit.h @@ -7,14 +7,12 @@
- /* * Processor Settings */ #define CONFIG_BFIN_CPU bf506-0.0 #define CONFIG_BFIN_BOOT_MODE BFIN_BOOT_PARA
- /* * Clock Settings * CCLK = (CLKIN * VCO_MULT) / CCLK_DIV @@ -38,7 +36,6 @@ /* Values can range from 1-15 */ #define CONFIG_SCLK_DIV 5
- /* * Memory Settings */ @@ -52,7 +49,6 @@ #define CONFIG_SYS_MONITOR_LEN (4 * 1024) #define CONFIG_SYS_MALLOC_LEN (4 * 1024)
- /* * Flash Settings */ @@ -79,7 +75,6 @@ #define CONFIG_ENV_IS_NOWHERE #define CONFIG_ENV_SIZE 0x400
- /* * Misc Settings */ diff --git a/include/configs/bf518f-ezbrd.h b/include/configs/bf518f-ezbrd.h index 9f44ebd..510cd47 100644 --- a/include/configs/bf518f-ezbrd.h +++ b/include/configs/bf518f-ezbrd.h @@ -7,14 +7,12 @@
- /* * Processor Settings */ #define CONFIG_BFIN_CPU bf518-0.0 #define CONFIG_BFIN_BOOT_MODE BFIN_BOOT_PARA
- /* * Memory Settings */ @@ -56,7 +53,6 @@ #define CONFIG_SYS_MONITOR_LEN (512 * 1024) #define CONFIG_SYS_MALLOC_LEN (384 * 1024)
- /* * Network Settings */ @@ -98,7 +94,6 @@ #define CONFIG_SYS_MAX_FLASH_BANKS 1 #define CONFIG_SYS_MAX_FLASH_SECT 71
- /* * SPI Settings */ @@ -106,7 +101,6 @@ #define CONFIG_ENV_SPI_MAX_HZ 30000000 #define CONFIG_SF_DEFAULT_SPEED 30000000
- /* * Env Storage Settings */ @@ -124,14 +118,12 @@ #endif #define CONFIG_ENV_IS_EMBEDDED_IN_LDR
- /* * SDH Settings */ @@ -141,7 +133,6 @@ #define CONFIG_BFIN_SDH #endif
- /* * Misc Settings */ diff --git a/include/configs/bf526-ezbrd.h b/include/configs/bf526-ezbrd.h index e9d900e..74c3464 100644 --- a/include/configs/bf526-ezbrd.h +++ b/include/configs/bf526-ezbrd.h @@ -7,14 +7,12 @@
- /* * Processor Settings */ #define CONFIG_BFIN_CPU bf526-0.0 #define CONFIG_BFIN_BOOT_MODE BFIN_BOOT_PARA
- /* * Memory Settings */ @@ -56,7 +53,6 @@ #define CONFIG_SYS_MONITOR_LEN (768 * 1024) #define CONFIG_SYS_MALLOC_LEN (512 * 1024)
- /* * NAND Settings * (can't be used same time as ethernet) @@ -73,7 +69,6 @@ #define CONFIG_CMD_NAND #endif
- /* * Network Settings */ @@ -96,7 +91,6 @@ #define CONFIG_SYS_MAX_FLASH_BANKS 1 #define CONFIG_SYS_MAX_FLASH_SECT 71
- /* * SPI Settings */ @@ -104,7 +98,6 @@ #define CONFIG_ENV_SPI_MAX_HZ 30000000 #define CONFIG_SF_DEFAULT_SPEED 30000000
- /* * Env Storage Settings */ @@ -122,14 +115,12 @@ #endif #define CONFIG_ENV_IS_EMBEDDED_IN_LDR
- /* * USB Settings */ @@ -141,7 +132,6 @@ #define CONFIG_USB_MUSB_TIMEOUT 100000 #endif
- /* * Misc Settings */ @@ -167,7 +157,6 @@ /* #define STATUS_LED_BIT2 GPIO_PG12 */ #endif
- /* * Pull in common ADI header for remaining command/environment setup */ diff --git a/include/configs/bf527-ad7160-eval.h b/include/configs/bf527-ad7160-eval.h index dd62e7e..258115a 100644 --- a/include/configs/bf527-ad7160-eval.h +++ b/include/configs/bf527-ad7160-eval.h @@ -7,14 +7,12 @@
- /* * Processor Settings */ #define CONFIG_BFIN_CPU bf527-0.2 #define CONFIG_BFIN_BOOT_MODE BFIN_BOOT_SPI_MASTER
- /* * Memory Settings */ @@ -55,7 +52,6 @@ #define CONFIG_SYS_MONITOR_LEN (768 * 1024) #define CONFIG_SYS_MALLOC_LEN (640 * 1024)
- /* * NAND Settings * (can't be used same time as ethernet) @@ -71,7 +67,6 @@ #define CONFIG_SYS_MAX_NAND_DEVICE 1 #endif
- /* * Flash Settings */ @@ -82,7 +77,6 @@ #define CONFIG_SYS_MAX_FLASH_BANKS 1 #define CONFIG_SYS_MAX_FLASH_SECT 259
- /* * SPI Settings */ @@ -90,7 +84,6 @@ #define CONFIG_ENV_SPI_MAX_HZ 30000000 #define CONFIG_SF_DEFAULT_SPEED 30000000
- /* * Env Storage Settings */ @@ -113,14 +106,12 @@ #define CONFIG_ENV_IS_EMBEDDED_IN_LDR #endif
- /* * SPI_MMC Settings */ @@ -128,7 +119,6 @@ #define CONFIG_GENERIC_MMC #define CONFIG_MMC_SPI
- /* * Misc Settings */ diff --git a/include/configs/bf527-ezkit.h b/include/configs/bf527-ezkit.h index 44de44f..e268473 100644 --- a/include/configs/bf527-ezkit.h +++ b/include/configs/bf527-ezkit.h @@ -7,14 +7,12 @@
- /* * Processor Settings */ #define CONFIG_BFIN_CPU bf527-0.0 #define CONFIG_BFIN_BOOT_MODE BFIN_BOOT_PARA
- /* * Clock Settings * CCLK = (CLKIN * VCO_MULT) / CCLK_DIV @@ -38,7 +36,6 @@ /* Values can range from 1-15 */ #define CONFIG_SCLK_DIV 4
- /* * Network Settings */ @@ -94,7 +89,6 @@ #define CONFIG_SYS_MAX_FLASH_BANKS 1 #define CONFIG_SYS_MAX_FLASH_SECT 259
- /* * SPI Settings */ @@ -102,7 +96,6 @@ #define CONFIG_ENV_SPI_MAX_HZ 30000000 #define CONFIG_SF_DEFAULT_SPEED 30000000
- /* * Env Storage Settings */ @@ -125,14 +118,12 @@ #define CONFIG_ENV_IS_EMBEDDED_IN_LDR #endif
- /* * USB Settings */ diff --git a/include/configs/bf527-sdp.h b/include/configs/bf527-sdp.h index 6b51201..6b7d19e 100644 --- a/include/configs/bf527-sdp.h +++ b/include/configs/bf527-sdp.h @@ -7,14 +7,12 @@
- /* * Processor Settings */ #define CONFIG_BFIN_CPU bf527-0.2 #define CONFIG_BFIN_BOOT_MODE BFIN_BOOT_PARA
- /* * Clock Settings * CCLK = (CLKIN * VCO_MULT) / CCLK_DIV @@ -42,7 +40,6 @@ #define CONFIG_PLL_CTL_VAL 0x2a00 #define CONFIG_VR_CTL_VAL 0x7090
- /* * Memory Settings */ @@ -59,7 +56,6 @@ #define CONFIG_SYS_MONITOR_LEN (768 * 1024) #define CONFIG_SYS_MALLOC_LEN (640 * 1024)
- /* * Flash Settings */ @@ -70,7 +66,6 @@ #define CONFIG_SYS_MAX_FLASH_BANKS 1 #define CONFIG_SYS_MAX_FLASH_SECT 259
- /* * SPI Settings */ @@ -79,7 +74,6 @@ #define CONFIG_SF_DEFAULT_SPEED 30000000 #define CONFIG_SPI_FLASH_ALL
- /* * Env Storage Settings */ @@ -98,14 +92,12 @@ #define CONFIG_ENV_IS_EMBEDDED_IN_LDR #endif
- /* * Misc Settings */ diff --git a/include/configs/bf533-ezkit.h b/include/configs/bf533-ezkit.h index 9581101..e154812 100644 --- a/include/configs/bf533-ezkit.h +++ b/include/configs/bf533-ezkit.h @@ -7,14 +7,12 @@
- /* * Processor Settings */ #define CONFIG_BFIN_CPU bf533-0.3 #define CONFIG_BFIN_BOOT_MODE BFIN_BOOT_BYPASS
- /* * Memory Settings */ @@ -60,7 +57,6 @@ #define CONFIG_SYS_MONITOR_LEN (256 * 1024) #define CONFIG_SYS_MALLOC_LEN (128 * 1024)
- /* * Network Settings */ @@ -76,7 +72,6 @@ } while (0) #define CONFIG_HOSTNAME bf533-ezkit
- /* * Flash Settings */ @@ -88,7 +83,6 @@ #define CONFIG_ENV_SECT_SIZE 0x10000 #define FLASH_TOT_SECT 40
- /* * I2C Settings */ diff --git a/include/configs/bf533-stamp.h b/include/configs/bf533-stamp.h index c8c48ae..c2466ca 100644 --- a/include/configs/bf533-stamp.h +++ b/include/configs/bf533-stamp.h @@ -7,7 +7,6 @@
- /* * Processor Settings */ @@ -53,7 +52,6 @@ #define CONFIG_SYS_MONITOR_LEN (256 * 1024) #define CONFIG_SYS_MALLOC_LEN (384 * 1024)
- /* * Network Settings */ @@ -69,7 +67,6 @@ } while (0) #define CONFIG_HOSTNAME bf533-stamp
- /* I2C */ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_SOFT /* I2C bit-banged */ @@ -134,7 +131,6 @@ common/env_embedded.o (.text*); #endif
- /* * I2C Settings */ @@ -177,7 +173,6 @@ #define CONFIG_EBIU_AMBCTL1_VAL 0x99B3ffc2 #endif
- /* * Misc Settings */ @@ -211,7 +206,6 @@ /* define to enable splash screen support */ /* #define CONFIG_VIDEO */
- /* * Pull in common ADI header for remaining command/environment setup */ diff --git a/include/configs/bf537-minotaur.h b/include/configs/bf537-minotaur.h index 425f0a9..a351d1b 100644 --- a/include/configs/bf537-minotaur.h +++ b/include/configs/bf537-minotaur.h @@ -20,14 +20,12 @@
- /* * Processor Settings */ #define CONFIG_BFIN_CPU bf537-0.2 #define CONFIG_BFIN_BOOT_MODE BFIN_BOOT_SPI_MASTER
- /* * Clock Settings * CCLK = (CLKIN * VCO_MULT) / CCLK_DIV @@ -51,7 +49,6 @@ /* Values can range from 1-15 */ #define CONFIG_SCLK_DIV 5
- /* * Memory Settings */ @@ -68,7 +65,6 @@ #define CONFIG_SYS_MONITOR_LEN (256 << 10) #define CONFIG_SYS_MALLOC_LEN (128 << 10)
- /* * Network Settings */ @@ -87,14 +83,12 @@ #define CONFIG_SYS_AUTOLOAD "no" #define CONFIG_ROOTPATH "/romfs"
- /* * Flash Settings */ /* We don't have a parallel flash chip there */ #define CONFIG_SYS_NO_FLASH
- /* * Env Storage Settings */ @@ -112,7 +105,6 @@ #define CONFIG_ENV_SECT_SIZE 0x10000 #define CONFIG_ENV_IS_EMBEDDED_IN_LDR
- /* * I2C settings */ @@ -121,7 +113,6 @@ #define CONFIG_SYS_I2C_SPEED 50000 #define CONFIG_SYS_I2C_SLAVE 0
- /* * Misc Settings */ diff --git a/include/configs/bf537-pnav.h b/include/configs/bf537-pnav.h index 5794f47..bced1df 100644 --- a/include/configs/bf537-pnav.h +++ b/include/configs/bf537-pnav.h @@ -7,14 +7,12 @@
- /* * Memory Settings */ @@ -55,7 +52,6 @@ #define CONFIG_SYS_MONITOR_LEN (512 * 1024) #define CONFIG_SYS_MALLOC_LEN (128 * 1024)
- /* * Network Settings */ @@ -75,7 +71,6 @@ #define CONFIG_SYS_MAX_FLASH_BANKS 1 #define CONFIG_SYS_MAX_FLASH_SECT 71
- /* * SPI Settings */ @@ -83,7 +78,6 @@ #define CONFIG_ENV_SPI_MAX_HZ 30000000 #define CONFIG_SF_DEFAULT_SPEED 30000000
- /* * Env Storage Settings */ @@ -112,7 +106,6 @@ common/env_embedded.o (.text*); #endif
- /* * NAND Settings */ @@ -133,14 +126,12 @@ #define NAND_PLAT_WRITE_ADR(chip, cmd) BFIN_NAND_WRITE(BFIN_NAND_ALE(chip), cmd) #define NAND_PLAT_GPIO_DEV_READY GPIO_PF12
- /* * I2C settings */ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_ADI
- /* * Misc Settings */ @@ -157,7 +148,6 @@ #define CONFIG_BOOTCOMMAND "run nandboot" #define CONFIG_BOOTARGS_ROOT "/dev/mtdblock1 rw rootfstype=yaffs"
- /* * Pull in common ADI header for remaining command/environment setup */ diff --git a/include/configs/bf537-srv1.h b/include/configs/bf537-srv1.h index fc4f50b..cbe752a 100644 --- a/include/configs/bf537-srv1.h +++ b/include/configs/bf537-srv1.h @@ -20,14 +20,12 @@
- /* * Memory Settings */ @@ -68,7 +65,6 @@ #define CONFIG_SYS_MONITOR_LEN (256 << 10) #define CONFIG_SYS_MALLOC_LEN (384 << 10)
- /* * Network Settings */ @@ -93,7 +89,6 @@ /* We don't have a parallel flash chip there */ #define CONFIG_SYS_NO_FLASH
- /* * SPI Settings */ @@ -101,7 +96,6 @@ #define CONFIG_ENV_SPI_MAX_HZ 30000000 #define CONFIG_SF_DEFAULT_SPEED 30000000
- /* * Env Storage Settings */ @@ -111,7 +105,6 @@ #define CONFIG_ENV_SECT_SIZE 0x10000 #define CONFIG_ENV_IS_EMBEDDED_IN_LDR
- /* * I2C settings */ @@ -120,7 +113,6 @@ #define CONFIG_SYS_I2C_SPEED 50000 #define CONFIG_SYS_I2C_SLAVE 0
- /* * Misc Settings */ diff --git a/include/configs/bf537-stamp.h b/include/configs/bf537-stamp.h index b178713..4f861aa 100644 --- a/include/configs/bf537-stamp.h +++ b/include/configs/bf537-stamp.h @@ -7,14 +7,12 @@
- /* * Processor Settings */ #define CONFIG_BFIN_CPU bf537-0.2 #define CONFIG_BFIN_BOOT_MODE BFIN_BOOT_BYPASS
- /* * Memory Settings */ @@ -55,7 +52,6 @@ #define CONFIG_SYS_MONITOR_LEN (768 * 1024) #define CONFIG_SYS_MALLOC_LEN (384 * 1024)
- /* * Network Settings */ @@ -77,7 +73,6 @@ /* some have 67 sectors (M29W320DB), but newer have 71 (M29W320EB) */ #define CONFIG_SYS_MAX_FLASH_SECT 71
- /* * SPI Settings */ @@ -86,7 +81,6 @@ #define CONFIG_SF_DEFAULT_SPEED 30000000 #define CONFIG_SPI_FLASH_ALL
- /* * Env Storage Settings */ @@ -120,14 +114,12 @@ common/env_embedded.o (.text*); #endif
- /* * SPI_MMC Settings */ @@ -243,7 +235,6 @@
#endif
- /* * Misc Settings */ @@ -270,7 +261,6 @@ #define CONFIG_BOOTCOMMAND "bootldr 0x203f0100" #endif
- /* * Pull in common ADI header for remaining command/environment setup */ diff --git a/include/configs/bf538f-ezkit.h b/include/configs/bf538f-ezkit.h index 55becdc..a6d039c 100644 --- a/include/configs/bf538f-ezkit.h +++ b/include/configs/bf538f-ezkit.h @@ -7,14 +7,12 @@
- /* * Processor Settings */ #define CONFIG_BFIN_CPU bf538-0.4 #define CONFIG_BFIN_BOOT_MODE BFIN_BOOT_BYPASS
- /* * Memory Settings */ @@ -55,7 +52,6 @@ #define CONFIG_SYS_MONITOR_LEN (256 * 1024) #define CONFIG_SYS_MALLOC_LEN (384 * 1024)
- /* * Network Settings */ @@ -64,7 +60,6 @@ #define CONFIG_SMC91111_BASE 0x20310300 #define CONFIG_HOSTNAME bf538f-ezkit
- /* * Flash Settings */ @@ -75,7 +70,6 @@ #define CONFIG_SYS_MAX_FLASH_BANKS 1 #define CONFIG_SYS_MAX_FLASH_SECT 71
- /* * SPI Settings */ @@ -119,14 +113,12 @@ common/env_embedded.o (.text*); #endif
- /* * Misc Settings */ diff --git a/include/configs/bf548-ezkit.h b/include/configs/bf548-ezkit.h index 8198cb8..6830e4d 100644 --- a/include/configs/bf548-ezkit.h +++ b/include/configs/bf548-ezkit.h @@ -7,14 +7,12 @@
- /* * Processor Settings */ #define CONFIG_BFIN_CPU bf548-0.0 #define CONFIG_BFIN_BOOT_MODE BFIN_BOOT_PARA
- /* * Memory Settings */ @@ -64,7 +61,6 @@ #define CONFIG_SYS_MONITOR_LEN (1024 * 1024) #define CONFIG_SYS_MALLOC_LEN (768 * 1024)
- /* * Network Settings */ @@ -74,7 +70,6 @@ #define CONFIG_SMC911X_16_BIT #define CONFIG_HOSTNAME bf548-ezkit
- /* * Flash Settings */ @@ -85,7 +80,6 @@ #define CONFIG_SYS_MAX_FLASH_BANKS 1 #define CONFIG_SYS_MAX_FLASH_SECT 259
- /* * SPI Settings */ @@ -93,7 +87,6 @@ #define CONFIG_ENV_SPI_MAX_HZ 30000000 #define CONFIG_SF_DEFAULT_SPEED 30000000
- /* * Env Storage Settings */ @@ -133,7 +126,6 @@ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_ADI
- /* * SATA */ @@ -146,7 +138,6 @@ #define CONFIG_BFIN_ATA_MODE XFER_PIO_4 #endif
- /* * SDH Settings */ @@ -156,7 +147,6 @@ #define CONFIG_BFIN_SDH #endif
- /* * USB Settings */ @@ -168,7 +158,6 @@ #define CONFIG_USB_MUSB_TIMEOUT 100000 #endif
- /* * Misc Settings */ @@ -199,7 +188,6 @@ #define CONFIG_SYS_POST_FLASH_END 127 #endif
- /* * Pull in common ADI header for remaining command/environment setup */ diff --git a/include/configs/bf561-acvilon.h b/include/configs/bf561-acvilon.h index 31862da..c36be03 100644 --- a/include/configs/bf561-acvilon.h +++ b/include/configs/bf561-acvilon.h @@ -8,14 +8,12 @@
- /* * Processor Settings */ #define CONFIG_BFIN_CPU bf561-0.5 #define CONFIG_BFIN_BOOT_MODE BFIN_BOOT_BYPASS
- /* * Clock Settings * CCLK = (CLKIN * VCO_MULT) / CCLK_DIV @@ -39,7 +37,6 @@ /* Values can range from 1-15 */ #define CONFIG_SCLK_DIV 5
- /* * Memory Settings */ @@ -56,7 +53,6 @@ #define CONFIG_SYS_MONITOR_LEN (384 * 1024) #define CONFIG_SYS_MALLOC_LEN (128 * 1024)
- /* * RTC Settings */ @@ -71,7 +67,6 @@ #define CONFIG_SYS_DTT_LOW_TEMP -30 #define CONFIG_SYS_DTT_HYSTERESIS 3*/
- /* * Network Settings */ @@ -91,13 +86,11 @@
#define CONFIG_HOSTNAME bf561-acvilon
- /* * Flash Settings */ #define CONFIG_SYS_NO_FLASH
- /* * I2C Settings */ @@ -107,7 +100,6 @@ #define CONFIG_PCA9564_I2C #define CONFIG_PCA9564_BASE 0x2c000000
- /* * SPI Settings */ @@ -115,7 +107,6 @@ #define CONFIG_ENV_SPI_MAX_HZ 10000000 #define CONFIG_SF_DEFAULT_SPEED 10000000
- /* * Env Storage Settings */ @@ -124,7 +115,6 @@ #define CONFIG_ENV_OFFSET ((16 + 256) * 1056) #define CONFIG_ENV_SIZE (8 * 1056)
- /* * NAND Settings * We're using NAND_PLAT driver to make things simplier @@ -146,7 +136,6 @@ #define NAND_PLAT_WRITE_ADR(chip, cmd) BFIN_NAND_WRITE(BFIN_NAND_ALE(chip), cmd) #define NAND_PLAT_GPIO_DEV_READY GPIO_PF10
- /* * Misc Settings */ diff --git a/include/configs/bf561-ezkit.h b/include/configs/bf561-ezkit.h index 1a3b33f..2fefe98 100644 --- a/include/configs/bf561-ezkit.h +++ b/include/configs/bf561-ezkit.h @@ -7,14 +7,12 @@
- /* * Processor Settings */ #define CONFIG_BFIN_CPU bf561-0.3 #define CONFIG_BFIN_BOOT_MODE BFIN_BOOT_BYPASS
- /* * Clock Settings * CCLK = (CLKIN * VCO_MULT) / CCLK_DIV @@ -38,7 +36,6 @@ /* Values can range from 1-15 */ #define CONFIG_SCLK_DIV 6
- /* * Memory Settings */ @@ -55,7 +52,6 @@ #define CONFIG_SYS_MONITOR_LEN (256 * 1024) #define CONFIG_SYS_MALLOC_LEN (128 * 1024)
- /* * Network Settings */ @@ -65,7 +61,6 @@ #define CONFIG_SMC_USE_32_BIT 1 #define CONFIG_HOSTNAME bf561-ezkit
- /* * Flash Settings */ @@ -82,7 +77,6 @@ #define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE #define CONFIG_ENV_SECT_SIZE 0x2000
- /* * I2C Settings */ @@ -106,7 +100,6 @@ */ /* #define CONFIG_CORE1_RUN 1 */
- /* * Pull in common ADI header for remaining command/environment setup */ diff --git a/include/configs/bf609-ezkit.h b/include/configs/bf609-ezkit.h index 3e0bff5..a62038e 100644 --- a/include/configs/bf609-ezkit.h +++ b/include/configs/bf609-ezkit.h @@ -13,7 +13,6 @@ #define CONFIG_BFIN_CPU bf609-0.0 #define CONFIG_BFIN_BOOT_MODE BFIN_BOOT_PARA
- /* For ez-board version 1.0, else undef this */ #define CONFIG_BFIN_BOARD_VERSION_1_0
diff --git a/include/configs/br4.h b/include/configs/br4.h index 85f31a4..402f352 100644 --- a/include/configs/br4.h +++ b/include/configs/br4.h @@ -10,14 +10,12 @@
- /* * Processor Settings */ #define CONFIG_BFIN_CPU bf537-0.3 #define CONFIG_BFIN_BOOT_MODE BFIN_BOOT_SPI_MASTER
- /* * Clock Settings * CCLK = (CLKIN * VCO_MULT) / CCLK_DIV @@ -41,7 +39,6 @@ /* Values can range from 1-15 */ #define CONFIG_SCLK_DIV 5
- /* * Memory Settings */ @@ -58,7 +55,6 @@ #define CONFIG_SYS_MONITOR_LEN (512 * 1024) #define CONFIG_SYS_MALLOC_LEN (384 * 1024)
- /* * Network Settings */ @@ -75,7 +71,6 @@ */ #define CONFIG_SYS_NO_FLASH /* We have no parallel FLASH */
- /* * Env Storage Settings */ @@ -93,14 +87,12 @@ #define CONFIG_ENV_SECT_SIZE 0x10000 #define CONFIG_ENV_IS_EMBEDDED_IN_LDR
- /* * NAND Settings */ diff --git a/include/configs/canmb.h b/include/configs/canmb.h index 0a39cdf..028d0a2 100644 --- a/include/configs/canmb.h +++ b/include/configs/canmb.h @@ -135,7 +135,6 @@ #define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM #define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE /* Size of used area in DPRAM */
diff --git a/include/configs/charon.h b/include/configs/charon.h index 2f537e0..578c108 100644 --- a/include/configs/charon.h +++ b/include/configs/charon.h @@ -34,7 +34,6 @@ "mtdparts=" MTDPARTS_DEFAULT "\0" \ "addmtd=setenv bootargs ${bootargs} ${mtdparts}\0"
- /* additional features on charon board */ #define CONFIG_RESET_PHY_R
diff --git a/include/configs/cm-bf527.h b/include/configs/cm-bf527.h index 761e2c5..0b31dc9 100644 --- a/include/configs/cm-bf527.h +++ b/include/configs/cm-bf527.h @@ -7,14 +7,12 @@
- /* * Clock Settings * CCLK = (CLKIN * VCO_MULT) / CCLK_DIV @@ -41,7 +39,6 @@ /* Decrease core voltage */ #define CONFIG_VR_CTL_VAL (VLEV_120 | CLKBUFOE | FREQ_1000)
- /* * Memory Settings */ @@ -58,7 +55,6 @@ #define CONFIG_SYS_MONITOR_LEN (256 * 1024) #define CONFIG_SYS_MALLOC_LEN (128 * 1024)
- /* * NAND Settings * (can't be used sametime as ethernet) @@ -71,7 +67,6 @@ #define CONFIG_CMD_NAND #endif
- /* * Network Settings */ @@ -95,7 +90,6 @@ #define CONFIG_SYS_MAX_FLASH_BANKS 1 #define CONFIG_SYS_MAX_FLASH_SECT 67
- /* * Env Storage Settings */ @@ -106,14 +100,12 @@ #define CONFIG_ENV_SECT_SIZE 0x8000 #define CONFIG_ENV_IS_EMBEDDED_IN_LDR
- /* * Misc Settings */ diff --git a/include/configs/cm-bf533.h b/include/configs/cm-bf533.h index d06333d..7039cba 100644 --- a/include/configs/cm-bf533.h +++ b/include/configs/cm-bf533.h @@ -7,14 +7,12 @@
- /* * Clock Settings * CCLK = (CLKIN * VCO_MULT) / CCLK_DIV @@ -41,7 +39,6 @@ /* Decrease core voltage */ #define CONFIG_VR_CTL_VAL (VLEV_115 | GAIN_20 | FREQ_1000)
- /* * Network Settings */ @@ -67,7 +63,6 @@ #define CONFIG_SMC91111_BASE 0x20200300 #define CONFIG_HOSTNAME cm-bf533
- /* * Flash Settings */ @@ -78,7 +73,6 @@ #define CONFIG_SYS_MAX_FLASH_BANKS 1 #define CONFIG_SYS_MAX_FLASH_SECT 16
- /* * Env Storage Settings */ @@ -87,7 +81,6 @@ #define CONFIG_ENV_SECT_SIZE 0x20000 #define CONFIG_ENV_SIZE 0x10000
- /* * Misc Settings */ diff --git a/include/configs/cm-bf537e.h b/include/configs/cm-bf537e.h index 746a5bd..78841cd 100644 --- a/include/configs/cm-bf537e.h +++ b/include/configs/cm-bf537e.h @@ -7,14 +7,12 @@
- /* * Clock Settings * CCLK = (CLKIN * VCO_MULT) / CCLK_DIV @@ -41,7 +39,6 @@ /* Decrease core voltage */ #define CONFIG_VR_CTL_VAL (VLEV_115 | CLKBUFOE | GAIN_20 | FREQ_1000)
- /* * Memory Settings */ @@ -58,7 +55,6 @@ #define CONFIG_SYS_MONITOR_LEN (768 * 1024) #define CONFIG_SYS_MALLOC_LEN (128 * 1024)
- /* * Network Settings */ @@ -83,14 +79,12 @@ #define CONFIG_SYS_MAX_FLASH_BANKS 1 #define CONFIG_SYS_MAX_FLASH_SECT 35
- /* * SPI Settings */ #define CONFIG_BFIN_SPI #define CONFIG_ENV_SPI_MAX_HZ 30000000
- /* * Env Storage Settings */ @@ -115,14 +109,12 @@ common/env_embedded.o (.text*); #endif
- /* * SPI_MMC Settings */ @@ -130,7 +122,6 @@ #define CONFIG_GENERIC_MMC #define CONFIG_MMC_SPI
- /* * Misc Settings */ diff --git a/include/configs/cm-bf537u.h b/include/configs/cm-bf537u.h index 71008aa..5785ebd 100644 --- a/include/configs/cm-bf537u.h +++ b/include/configs/cm-bf537u.h @@ -7,14 +7,12 @@
- /* * Clock Settings * CCLK = (CLKIN * VCO_MULT) / CCLK_DIV @@ -40,7 +38,6 @@ /* Core voltage */ #define CONFIG_VR_CTL_VAL (VLEV_110 | GAIN_20 | FREQ_1000)
- /* * Memory Settings */ @@ -57,7 +54,6 @@ #define CONFIG_SYS_MONITOR_LEN (768 * 1024) #define CONFIG_SYS_MALLOC_LEN (128 * 1024)
- /* * Network Settings */ @@ -81,14 +77,12 @@ #define CONFIG_SYS_MAX_FLASH_BANKS 1 #define CONFIG_SYS_MAX_FLASH_SECT 35
- /* * Env Storage Settings */ @@ -113,14 +107,12 @@ common/env_embedded.o (.text*); #endif
- /* * SPI_MMC Settings */ diff --git a/include/configs/cm-bf548.h b/include/configs/cm-bf548.h index 37205a9..d1aa262 100644 --- a/include/configs/cm-bf548.h +++ b/include/configs/cm-bf548.h @@ -7,14 +7,12 @@
- /* * Memory Settings */ @@ -67,7 +64,6 @@ #define CONFIG_SYS_MONITOR_LEN (512 * 1024) #define CONFIG_SYS_MALLOC_LEN (640 * 1024)
- /* * Network Settings */ @@ -77,7 +73,6 @@ #define CONFIG_SMC911X_16_BIT #define CONFIG_HOSTNAME cm-bf548
- /* * Flash Settings */ @@ -88,7 +83,6 @@ #define CONFIG_SYS_MAX_FLASH_BANKS 1 #define CONFIG_SYS_MAX_FLASH_SECT 259
- /* * Env Storage Settings */ @@ -98,14 +92,12 @@ #define CONFIG_ENV_SIZE 0x8000 #define CONFIG_ENV_IS_EMBEDDED_IN_LDR
- /* * Misc Settings */ @@ -134,7 +126,6 @@ #define FLASH_END_POST_BLOCK 71 /* Should < = 71 */ #endif
- /* * Pull in common ADI header for remaining command/environment setup */ diff --git a/include/configs/cm-bf561.h b/include/configs/cm-bf561.h index 284ec83..3860e0e 100644 --- a/include/configs/cm-bf561.h +++ b/include/configs/cm-bf561.h @@ -7,14 +7,12 @@
- /* * Processor Settings */ #define CONFIG_BFIN_CPU bf561-0.3 #define CONFIG_BFIN_BOOT_MODE BFIN_BOOT_PARA
- /* * Clock Settings * CCLK = (CLKIN * VCO_MULT) / CCLK_DIV @@ -41,7 +39,6 @@ /* Decrease core voltage */ #define CONFIG_VR_CTL_VAL (VLEV_110 | GAIN_20 | FREQ_1000)
- /* * Network Settings */ @@ -68,7 +64,6 @@ #define CONFIG_SMC911X_16_BIT #define CONFIG_HOSTNAME cm-bf561
- /* * Flash Settings */ @@ -79,7 +74,6 @@ #define CONFIG_SYS_MAX_FLASH_BANKS 1 #define CONFIG_SYS_MAX_FLASH_SECT 67
- /* * Env Storage Settings */ @@ -89,7 +83,6 @@ #define CONFIG_ENV_SIZE 0x10000 #define CONFIG_ENV_IS_EMBEDDED_IN_LDR
- /* * Misc Settings */ diff --git a/include/configs/cm5200.h b/include/configs/cm5200.h index 766faa6..cdb8931 100644 --- a/include/configs/cm5200.h +++ b/include/configs/cm5200.h @@ -8,10 +8,8 @@ #ifndef __CONFIG_H #define __CONFIG_H
- #define CONFIG_DISPLAY_BOARDINFO
- /* * High Level Configuration Options */ @@ -167,13 +165,11 @@ #define CONFIG_SYS_MAX_FLASH_SECT 256 /* max num of sectors on one chip */ #define CONFIG_SYS_FLASH_SIZE 0x02000000 /* 32 MiB */
- #if (CONFIG_SYS_MONITOR_BASE < CONFIG_SYS_FLASH_BASE) #define CONFIG_SYS_RAMBOOT 1 #undef CONFIG_SYS_LOWBOOT #endif
- /* * Chip selects configuration */ diff --git a/include/configs/cm_t335.h b/include/configs/cm_t335.h index 99b5d3e..c4f1d4f 100644 --- a/include/configs/cm_t335.h +++ b/include/configs/cm_t335.h @@ -63,7 +63,6 @@ "nboot ${loadaddr} nand0 900000; " \ "bootm ${loadaddr}\0"
- #define CONFIG_EXTRA_ENV_SETTINGS \ "loadaddr=82000000\0" \ "console=ttyO0,115200n8\0" \ diff --git a/include/configs/cm_t35.h b/include/configs/cm_t35.h index debedec..aca9288 100644 --- a/include/configs/cm_t35.h +++ b/include/configs/cm_t35.h @@ -120,7 +120,6 @@ #define CONFIG_CMD_MMC /* MMC support */ #define CONFIG_CMD_NAND /* NAND support */
- #define CONFIG_SYS_NO_FLASH #define CONFIG_SYS_I2C #define CONFIG_SYS_OMAP24_I2C_SPEED 100000 diff --git a/include/configs/cm_t3517.h b/include/configs/cm_t3517.h index 8ac41e2..1bedea7 100644 --- a/include/configs/cm_t3517.h +++ b/include/configs/cm_t3517.h @@ -133,7 +133,6 @@ #define CONFIG_CMD_MMC /* MMC support */ #define CONFIG_CMD_NAND /* NAND support */
- #define CONFIG_SYS_NO_FLASH #define CONFIG_SYS_I2C #define CONFIG_SYS_OMAP24_I2C_SPEED 400000 diff --git a/include/configs/cm_t43.h b/include/configs/cm_t43.h index 0e05194..ee818ed 100644 --- a/include/configs/cm_t43.h +++ b/include/configs/cm_t43.h @@ -154,7 +154,6 @@ "run emmcboot; " \ "fi;"
- #define CONFIG_CONS_INDEX 1
/* SPL defines. */ diff --git a/include/configs/cobra5272.h b/include/configs/cobra5272.h index 9e44015..b291ba4 100644 --- a/include/configs/cobra5272.h +++ b/include/configs/cobra5272.h @@ -116,7 +116,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- /* * Command line configuration. */ @@ -157,7 +156,6 @@ seconds u-boot will wait before starting defined (auto-)boot command, setting to -1 disables delay, setting to 0 will too prevent access to u-boot command interface: u-boot then has to reflashed */
- /* The following settings will be contained in the environment block ; if you want to use a neutral environment all those settings can be manually set in u-boot: 'set' command */ diff --git a/include/configs/controlcenterd.h b/include/configs/controlcenterd.h index 77b3e50..9d1c6ae 100644 --- a/include/configs/controlcenterd.h +++ b/include/configs/controlcenterd.h @@ -45,7 +45,6 @@ #define CONFIG_CONTROLCENTERD #define CONFIG_MP /* support multiple processors */
- #define CONFIG_SYS_NO_FLASH #define CONFIG_ENABLE_36BIT_PHYS #define CONFIG_FSL_LAW /* Use common FSL init code */ @@ -98,7 +97,6 @@ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE #define CONFIG_SYS_MALLOC_LEN (10 * 1024 * 1024)
- /* * Memory map * @@ -215,7 +213,6 @@ */ #define CONFIG_HARD_SPI
- #define CONFIG_SF_DEFAULT_SPEED 10000000 #define CONFIG_SF_DEFAULT_MODE 0 #endif @@ -232,7 +229,6 @@ #define CONFIG_FSL_ESDHC #define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR
- #ifndef CONFIG_TRAILBLAZER
/* diff --git a/include/configs/crownbay.h b/include/configs/crownbay.h index fc1a8ba..432f2f6 100644 --- a/include/configs/crownbay.h +++ b/include/configs/crownbay.h @@ -28,7 +28,6 @@ #define CONFIG_SCSI_DEV_LIST \ {PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_TCF_SATA}
- #define CONFIG_MMC #define CONFIG_SDHCI #define CONFIG_GENERIC_MMC diff --git a/include/configs/cyrus.h b/include/configs/cyrus.h index 701f59e..d1927b5 100644 --- a/include/configs/cyrus.h +++ b/include/configs/cyrus.h @@ -17,7 +17,6 @@ #error Must call Cyrus CONFIG with a specific CPU enabled. #endif
- #define CONFIG_MMC #define CONFIG_SDCARD #define CONFIG_FSL_SATA_V2 @@ -43,7 +42,6 @@ #define CONFIG_SYS_FSL_PBL_RCW board/varisys/cyrus/rcw_p5040.cfg #endif
- /* High Level Configuration Options */ #define CONFIG_BOOKE #define CONFIG_E500 /* BOOKE e500 family */ @@ -51,7 +49,6 @@ #define CONFIG_SYS_BOOK3E_HV /* Category E.HV supported */ #define CONFIG_MP /* support multiple processors */
- #define CONFIG_SYS_MMC_MAX_DEVICE 1
#ifndef CONFIG_SYS_TEXT_BASE @@ -173,7 +170,6 @@ #define CONFIG_SYS_OR0_PRELIM 0xfff00010 #define CONFIG_SYS_OR1_PRELIM 0xfff00010
- #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */
#if defined(CONFIG_RAMBOOT_PBL) diff --git a/include/configs/da850evm.h b/include/configs/da850evm.h index 2972057..9466332 100644 --- a/include/configs/da850evm.h +++ b/include/configs/da850evm.h @@ -20,7 +20,6 @@ #define CONFIG_USE_SPIFLASH #endif
- /* * SoC Configuration */ diff --git a/include/configs/dbau1x00.h b/include/configs/dbau1x00.h index faf2a87..f9f30b1 100644 --- a/include/configs/dbau1x00.h +++ b/include/configs/dbau1x00.h @@ -61,7 +61,6 @@ #define CONFIG_BOOTCOMMAND "bootp;bootm" #endif /* CONFIG_DBAU1550 */
- /* * BOOTP options */ @@ -70,7 +69,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- /* * Command line configuration. */ @@ -89,7 +87,6 @@
#endif
- /* * Miscellaneous configurable options */ @@ -172,7 +169,6 @@
#define CONFIG_NR_DRAM_BANKS 2
- #ifdef CONFIG_DBAU1550 #define MEM_SIZE 192 #else diff --git a/include/configs/devkit8000.h b/include/configs/devkit8000.h index 4afc91b..6acd2fe 100644 --- a/include/configs/devkit8000.h +++ b/include/configs/devkit8000.h @@ -185,7 +185,6 @@ "fi; " \ "else run nandboot; fi\0"
- #define CONFIG_BOOTCOMMAND "run autoboot"
/* Boot Argument Buffer Size */ diff --git a/include/configs/dockstar.h b/include/configs/dockstar.h index ae3017c..e54321b 100644 --- a/include/configs/dockstar.h +++ b/include/configs/dockstar.h @@ -12,7 +12,6 @@ #ifndef _CONFIG_DOCKSTAR_H #define _CONFIG_DOCKSTAR_H
- /* * Version number information */ diff --git a/include/configs/draco.h b/include/configs/draco.h index acefd3e..2d4a45d 100644 --- a/include/configs/draco.h +++ b/include/configs/draco.h @@ -67,7 +67,6 @@ #define CONFIG_ENV_SIZE_REDUND 0x2000 #define CONFIG_ENV_RANGE (4 * CONFIG_SYS_ENV_SECT_SIZE)
- #define MTDPARTS_DEFAULT MTDPARTS_DEFAULT_V2
#ifndef CONFIG_SPL_BUILD @@ -95,7 +94,6 @@ "run nand_boot_backup;" \ "reset;"
- #else #define CONFIG_BOOTDELAY 0
diff --git a/include/configs/dragonboard410c.h b/include/configs/dragonboard410c.h index ae4fbb4..42fb0f3 100644 --- a/include/configs/dragonboard410c.h +++ b/include/configs/dragonboard410c.h @@ -99,7 +99,6 @@ "tftp $loadaddr "#file" && " \ "mmc write $loadaddr $start $size && "
- #define CONFIG_ENV_REFLASH \ "mmc dev 0 && "\ "usb start && "\ diff --git a/include/configs/duovero.h b/include/configs/duovero.h index ac9a67f..d8f48ef 100644 --- a/include/configs/duovero.h +++ b/include/configs/duovero.h @@ -39,7 +39,6 @@
#define CONFIG_SYS_ENABLE_PADS_ALL
- #define CONFIG_SMC911X #define CONFIG_SMC911X_32_BIT #define CONFIG_SMC911X_BASE 0x2C000000 diff --git a/include/configs/ea20.h b/include/configs/ea20.h index 06e988a..b52f34b 100644 --- a/include/configs/ea20.h +++ b/include/configs/ea20.h @@ -24,7 +24,6 @@ #define CONFIG_VIDEO #define CONFIG_PREBOOT
- /* * SoC Configuration */ @@ -102,7 +101,6 @@ #define CONFIG_SYS_NO_FLASH #endif
- #if defined(CONFIG_VIDEO) #define CONFIG_VIDEO_DA8XX #define CONFIG_CFB_CONSOLE diff --git a/include/configs/eco5pk.h b/include/configs/eco5pk.h index f463521..bb5d7e5 100644 --- a/include/configs/eco5pk.h +++ b/include/configs/eco5pk.h @@ -58,5 +58,4 @@ "mtdparts="MTDPARTS_DEFAULT"\0" \ "serverip=192.168.142.60\0"
- #endif /* __CONFIG_H */ diff --git a/include/configs/edb93xx.h b/include/configs/edb93xx.h index ce50973..c64d119 100644 --- a/include/configs/edb93xx.h +++ b/include/configs/edb93xx.h @@ -25,7 +25,6 @@ #error "no board defined" #endif
- /* Initial environment and monitor configuration options. */ #define CONFIG_BOOTDELAY 2 #define CONFIG_CMDLINE_TAG 1 @@ -34,8 +33,6 @@ #define CONFIG_BOOTARGS "root=/dev/nfs console=ttyAM0,115200 ip=dhcp" #define CONFIG_BOOTFILE "edb93xx.img"
- - #define CONFIG_SYS_LDSCRIPT "board/cirrus/edb93xx/u-boot.lds"
#ifdef CONFIG_EDB9301 @@ -160,7 +157,6 @@ #error "no SDCS configuration for this board" #endif
- #if defined(CONFIG_EDB93XX_SDCS3) #define CONFIG_SYS_LOAD_ADDR 0x01000000 /* Default load address */ #define PHYS_SDRAM_1 0x00000000 @@ -175,7 +171,6 @@ #define CONFIG_SYS_INIT_SP_ADDR \ (CONFIG_SYS_SDRAM_BASE + 32*1024 - GENERATED_GBL_DATA_SIZE)
- /* Must match kernel config */ #define LINUX_BOOT_PARAM_ADDR (PHYS_SDRAM_1 + 0x100)
@@ -214,7 +209,6 @@ #define CONFIG_SYS_FLASH_CFI #define CONFIG_SYS_FLASH_USE_BUFFER_WRITE
- #define CONFIG_SYS_FLASH_PROTECTION #define CONFIG_FLASH_CFI_DRIVER #define CONFIG_SYS_MAX_FLASH_BANKS 1 diff --git a/include/configs/ethernut5.h b/include/configs/ethernut5.h index 28bf6b5..cfb009c 100644 --- a/include/configs/ethernut5.h +++ b/include/configs/ethernut5.h @@ -12,7 +12,6 @@
#include <asm/hardware.h>
- /* The first stage boot loader expects u-boot running at this address. */ #define CONFIG_SYS_TEXT_BASE 0x27000000 /* 16MB available */
diff --git a/include/configs/exynos-common.h b/include/configs/exynos-common.h index 852829c..0a2d610 100644 --- a/include/configs/exynos-common.h +++ b/include/configs/exynos-common.h @@ -16,7 +16,6 @@ #include <asm/arch/cpu.h> /* get chip and board defs */ #include <linux/sizes.h>
- #define CONFIG_ARCH_CPU_INIT #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DISPLAY_BOARDINFO diff --git a/include/configs/exynos5-common.h b/include/configs/exynos5-common.h index 97fcd4a..b2ff4dd 100644 --- a/include/configs/exynos5-common.h +++ b/include/configs/exynos5-common.h @@ -155,7 +155,6 @@
/* Enable Time Command */
- /* USB */ #define CONFIG_USB_STORAGE #define CONFIG_USB_XHCI_DWC3 diff --git a/include/configs/flea3.h b/include/configs/flea3.h index 54b9315..e74aa68 100644 --- a/include/configs/flea3.h +++ b/include/configs/flea3.h @@ -87,7 +87,6 @@
#define CONFIG_LOADADDR 0x80800000 /* loadaddr env var */
- /* * Ethernet on SOC (FEC) */ diff --git a/include/configs/goflexhome.h b/include/configs/goflexhome.h index 243e19f..d0432ad 100644 --- a/include/configs/goflexhome.h +++ b/include/configs/goflexhome.h @@ -15,7 +15,6 @@ #ifndef _CONFIG_GOFLEXHOME_H #define _CONFIG_GOFLEXHOME_H
- /* * Version number information */ diff --git a/include/configs/grsim_leon2.h b/include/configs/grsim_leon2.h index e06e261..ab1e11d 100644 --- a/include/configs/grsim_leon2.h +++ b/include/configs/grsim_leon2.h @@ -189,7 +189,6 @@ #undef CONFIG_SYS_SRAM_BASE #undef CONFIG_SYS_SRAM_SIZE
- /* Always Run U-Boot from SDRAM */ #define CONFIG_SYS_RAM_BASE CONFIG_SYS_SDRAM_BASE #define CONFIG_SYS_RAM_SIZE CONFIG_SYS_SDRAM_SIZE diff --git a/include/configs/guruplug.h b/include/configs/guruplug.h index 712bfd7..5907e98 100644 --- a/include/configs/guruplug.h +++ b/include/configs/guruplug.h @@ -10,7 +10,6 @@ #ifndef _CONFIG_GURUPLUG_H #define _CONFIG_GURUPLUG_H
- /* * Version number information */ diff --git a/include/configs/h2200.h b/include/configs/h2200.h index 1bb5ebb..3d510d6 100644 --- a/include/configs/h2200.h +++ b/include/configs/h2200.h @@ -135,7 +135,6 @@ #define CONFIG_USB_DEV_PULLUP_GPIO 33 /* USB VBUS GPIO 3 */
- #define CONFIG_BOOTDELAY 2 #define CONFIG_BOOTCOMMAND \ "setenv downloaded 0 ; while test $downloaded -eq 0 ; do " \ diff --git a/include/configs/highbank.h b/include/configs/highbank.h index 510741b..3bce12b 100644 --- a/include/configs/highbank.h +++ b/include/configs/highbank.h @@ -69,7 +69,6 @@ #define CONFIG_SYS_LOAD_ADDR 0x800000 #define CONFIG_SYS_64BIT_LBA
- /*----------------------------------------------------------------------- * Physical Memory Map * The DRAM is already setup, so do not touch the DT node later. diff --git a/include/configs/hikey.h b/include/configs/hikey.h index 4987373..d08ab1d 100644 --- a/include/configs/hikey.h +++ b/include/configs/hikey.h @@ -123,7 +123,6 @@ "initrd_high=0xffffffffffffffff\0" \ BOOTENV
- /* Preserve enviroment on sd card */ #define CONFIG_COMMAND_HISTORY
diff --git a/include/configs/hrcon.h b/include/configs/hrcon.h index aecfda4..d59d21f 100644 --- a/include/configs/hrcon.h +++ b/include/configs/hrcon.h @@ -26,7 +26,6 @@ #define CONFIG_IDENT_STRING " hrcon 0.01" #endif
- #define CONFIG_BOARD_EARLY_INIT_F #define CONFIG_BOARD_EARLY_INIT_R #define CONFIG_LAST_STAGE_INIT @@ -665,5 +664,4 @@ void fpga_control_clear(unsigned int bus, int pin);
#define CONFIG_BOOTCOMMAND CONFIG_MMCBOOTCOMMAND
- #endif /* __CONFIG_H */ diff --git a/include/configs/ibf-dsp561.h b/include/configs/ibf-dsp561.h index 7cb2346..4cd0f77 100644 --- a/include/configs/ibf-dsp561.h +++ b/include/configs/ibf-dsp561.h @@ -7,14 +7,12 @@
- /* * Memory Settings */ @@ -56,7 +53,6 @@ #define CONFIG_SYS_MONITOR_LEN (256 * 1024) #define CONFIG_SYS_MALLOC_LEN (128 * 1024)
- /* * Network Settings */ @@ -65,7 +61,6 @@ #define AX88180_BASE 0x2c000000 #define CONFIG_HOSTNAME ibf-dsp561
- /* * Flash Settings */ @@ -99,7 +94,6 @@ common/env_embedded.o (.text*); #endif
- /* * I2C Settings */ @@ -113,7 +107,6 @@ */ #define CONFIG_UART_CONSOLE 0
- /* * Pull in common ADI header for remaining command/environment setup */ diff --git a/include/configs/iconnect.h b/include/configs/iconnect.h index 10f1e9b..c156bd3 100644 --- a/include/configs/iconnect.h +++ b/include/configs/iconnect.h @@ -9,7 +9,6 @@ #ifndef _CONFIG_ICONNECT_H #define _CONFIG_ICONNECT_H
- /* * Version number information */ diff --git a/include/configs/ids8313.h b/include/configs/ids8313.h index ff93c7d..da4cba7 100644 --- a/include/configs/ids8313.h +++ b/include/configs/ids8313.h @@ -19,7 +19,6 @@ #define CONFIG_MPC8313 #define CONFIG_IDS8313
- #define CONFIG_FSL_ELBC
#define CONFIG_MISC_INIT_R @@ -442,7 +441,6 @@ #define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SIZE) #define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE)
- #define CONFIG_NETDEV eth1 #define CONFIG_HOSTNAME ids8313 #define CONFIG_ROOTPATH "/opt/eldk-4.2/ppc_6xx" diff --git a/include/configs/imx31_phycore.h b/include/configs/imx31_phycore.h index 94dd796..94fc077 100644 --- a/include/configs/imx31_phycore.h +++ b/include/configs/imx31_phycore.h @@ -18,7 +18,6 @@ #define CONFIG_MX31 /* This is a mx31 */ #define CONFIG_MX31_CLK32 32000
- #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DISPLAY_BOARDINFO
@@ -92,7 +91,6 @@ "pclk:185925,le:9,ri:17,up:7,lo:10,hs:1,vs:1," \ "sync:1241513985,vmode:0\0"
- #define CONFIG_SMC911X #define CONFIG_SMC911X_BASE 0xa8000000 #define CONFIG_SMC911X_32_BIT diff --git a/include/configs/inka4x0.h b/include/configs/inka4x0.h index 149c8c6..282cc25 100644 --- a/include/configs/inka4x0.h +++ b/include/configs/inka4x0.h @@ -68,7 +68,6 @@ #define CONFIG_DOS_PARTITION #define CONFIG_ISO_PARTITION
- /* * BOOTP options */ @@ -77,7 +76,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- /* * Command line configuration. */ diff --git a/include/configs/integrator-common.h b/include/configs/integrator-common.h index f4982e1..b95851a 100644 --- a/include/configs/integrator-common.h +++ b/include/configs/integrator-common.h @@ -73,7 +73,6 @@ */ /* #define SKIP_CONFIG_RELOCATE_UBOOT */
- /* * Physical Memory Map */ diff --git a/include/configs/integratorap.h b/include/configs/integratorap.h index c80e915..a5a8819 100644 --- a/include/configs/integratorap.h +++ b/include/configs/integratorap.h @@ -28,7 +28,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- /* * Command line configuration. */ @@ -54,7 +53,6 @@ #define CONFIG_EEPRO100 #define CONFIG_SYS_RX_ETH_BUFFER 8 /* use 8 rx buffer on eepro100 */
- /*----------------------------------------------------------------------- * There are various dependencies on the core module (CM) fitted * Users should refer to their CM user guide diff --git a/include/configs/intip.h b/include/configs/intip.h index 69f0f4d..6f48b4b 100644 --- a/include/configs/intip.h +++ b/include/configs/intip.h @@ -309,7 +309,6 @@ #define CONFIG_SYS_PCI_SUBSYS_VENDORID 0x1014 /* IBM */ #define CONFIG_SYS_PCI_SUBSYS_DEVICEID 0xcafe /* Whatever */
- /* * External Bus Controller (EBC) Setup */ @@ -324,7 +323,6 @@ * 0xfc00.0000 -> 4.cc00.0000 */
- /* Memory Bank 0 (NOR-FLASH) initialization */ #define CONFIG_SYS_EBC_PB0AP 0x10055e00 #define CONFIG_SYS_EBC_PB0CR (CONFIG_SYS_BOOT_BASE_ADDR | 0x9a000) diff --git a/include/configs/ip04.h b/include/configs/ip04.h index 3638648..4a9093c 100644 --- a/include/configs/ip04.h +++ b/include/configs/ip04.h @@ -16,14 +16,12 @@
- /* * Processor Settings */ #define CONFIG_BFIN_CPU bf532-0.5 #define CONFIG_BFIN_BOOT_MODE BFIN_BOOT_NAND
- /* * Clock Settings * CCLK = (CLKIN * VCO_MULT) / CCLK_DIV @@ -47,7 +45,6 @@ /* Values can range from 1-15 */ #define CONFIG_SCLK_DIV 3
- /* * Memory Settings */ @@ -64,7 +61,6 @@ #define CONFIG_SYS_MONITOR_LEN (384 * 1024) #define CONFIG_SYS_MALLOC_LEN (128 * 1024)
- /* * Network Settings */ @@ -77,14 +73,12 @@ #define DM9000_IO CONFIG_DM9000_BASE #define DM9000_DATA (CONFIG_DM9000_BASE + 2)
- /* * Flash Settings */ #define CONFIG_ENV_OVERWRITE 1 #define CONFIG_SYS_NO_FLASH /* we have only NAND */
- /* * SPI Settings */ @@ -92,7 +86,6 @@ #define CONFIG_ENV_SPI_MAX_HZ 30000000 #define CONFIG_SF_DEFAULT_SPEED 30000000
- /* * Env Storage Settings */ @@ -102,7 +95,6 @@ #define CONFIG_ENV_SIZE 0x10000 #define CONFIG_ENV_SECT_SIZE 0x10000
- /* * NAND Settings */ @@ -122,7 +114,6 @@ #define NAND_PLAT_WRITE_ADR(chip, cmd) BFIN_NAND_WRITE(BFIN_NAND_ALE(chip), cmd) #define NAND_PLAT_GPIO_DEV_READY GPIO_PF10
- /* * Misc Settings */ @@ -134,7 +125,6 @@ #define CONFIG_BOOT_RETRY_TIME -1 #define CONFIG_BOOTCOMMAND "run nandboot"
- /* * Pull in common ADI header for remaining command/environment setup */ diff --git a/include/configs/ipam390.h b/include/configs/ipam390.h index 869d8c4..3675099 100644 --- a/include/configs/ipam390.h +++ b/include/configs/ipam390.h @@ -90,7 +90,6 @@ #define CONFIG_SYS_DA850_DDR2_SDBCR2 0x00000004 #define CONFIG_SYS_DA850_DDR2_PBBPR 0x00000020
- #define CONFIG_SYS_DA850_DDR2_SDTIMR ( \ (13 << DV_DDR_SDTMR1_RFC_SHIFT) | \ (2 << DV_DDR_SDTMR1_RP_SHIFT) | \ @@ -129,7 +128,6 @@ DAVINCI_ABCR_TA(0) | \ DAVINCI_ABCR_ASIZE_8BIT)
- /* * Serial Driver info */ diff --git a/include/configs/jupiter.h b/include/configs/jupiter.h index ce92e78..0628203 100644 --- a/include/configs/jupiter.h +++ b/include/configs/jupiter.h @@ -73,7 +73,6 @@
#define CONFIG_TIMESTAMP /* Print image info with timestamp */
- /* * BOOTP options */ @@ -82,7 +81,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- /* * Command line configuration. */ @@ -91,7 +89,6 @@ #define CODFIG_CMD_PCI #endif
- /* * Autobooting */ @@ -203,7 +200,6 @@ #define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM #define CONFIG_SYS_INIT_RAM_SIZE MPC5XXX_SRAM_SIZE /* Size of used area in DPRAM */
- #define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
diff --git a/include/configs/kc1.h b/include/configs/kc1.h index 15029f9..30be533 100644 --- a/include/configs/kc1.h +++ b/include/configs/kc1.h @@ -80,7 +80,6 @@ #define CONFIG_SYS_I2C_OMAP24XX #define CONFIG_I2C_MULTI_BUS
- /* * Flash */ diff --git a/include/configs/km8360.h b/include/configs/km8360.h index 49b9200..c8039e1 100644 --- a/include/configs/km8360.h +++ b/include/configs/km8360.h @@ -233,7 +233,6 @@
#define CONFIG_SYS_DBAT5U CONFIG_SYS_IBAT5U
- #ifdef CONFIG_KMCOGE5NE /* BFTIC3: icache cacheable, but dcache-inhibit and guarded */ #define CONFIG_SYS_IBAT6L (\ diff --git a/include/configs/km_kirkwood.h b/include/configs/km_kirkwood.h index a445aaf..b377c41 100644 --- a/include/configs/km_kirkwood.h +++ b/include/configs/km_kirkwood.h @@ -180,5 +180,4 @@ #undef CONFIG_KIRKWOOD_PCIE_INIT #endif
- #endif /* _CONFIG_KM_KIRKWOOD */ diff --git a/include/configs/legoev3.h b/include/configs/legoev3.h index a2a337d..54563e3 100644 --- a/include/configs/legoev3.h +++ b/include/configs/legoev3.h @@ -31,7 +31,6 @@
#define CONFIG_SYS_TEXT_BASE 0xc1080000
- /* * Memory Info */ @@ -218,7 +217,6 @@ #define CONFIG_CLOCKS #endif
- #define CONFIG_ENV_IS_NOWHERE #define CONFIG_SYS_NO_FLASH #define CONFIG_ENV_SIZE (16 << 10) diff --git a/include/configs/ls1043aqds.h b/include/configs/ls1043aqds.h index 5c3ece8..3bdece7 100644 --- a/include/configs/ls1043aqds.h +++ b/include/configs/ls1043aqds.h @@ -114,7 +114,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_DOS_PARTITION #define CONFIG_BOARD_LATE_INIT
- /* EEPROM */ #define CONFIG_ID_EEPROM #define CONFIG_SYS_I2C_EEPROM_NXID diff --git a/include/configs/ls2080a_common.h b/include/configs/ls2080a_common.h index 648a6ff..8b75088 100644 --- a/include/configs/ls2080a_common.h +++ b/include/configs/ls2080a_common.h @@ -7,7 +7,6 @@ #ifndef __LS2_COMMON_H #define __LS2_COMMON_H
- #define CONFIG_REMAKE_ELF #define CONFIG_FSL_LAYERSCAPE #define CONFIG_FSL_LSCH3 @@ -15,7 +14,6 @@ #define CONFIG_GICV3 #define CONFIG_FSL_TZPC_BP147
- #include <asm/arch/ls2080a_stream_id.h> #include <asm/arch/config.h> #if (defined(CONFIG_SYS_FSL_SRDS_1) || defined(CONFIG_SYS_FSL_SRDS_2)) @@ -297,5 +295,4 @@ unsigned long long get_qixis_addr(void);
#define CONFIG_SYS_BOOTM_LEN (64 << 20) /* Increase max gunzip size */
- #endif /* __LS2_COMMON_H */ diff --git a/include/configs/ls2080a_simu.h b/include/configs/ls2080a_simu.h index 0dbe95f..924011c 100644 --- a/include/configs/ls2080a_simu.h +++ b/include/configs/ls2080a_simu.h @@ -72,7 +72,6 @@ #define CONFIG_SYS_NAND_MAX_ECCPOS 256 #define CONFIG_SYS_NAND_MAX_OOBFREE 2
- #define CONFIG_SYS_NAND_CSPR_EXT (0x0) #define CONFIG_SYS_NAND_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS) \ | CSPR_PORT_SIZE_8 /* Port Size = 8 bit */ \ diff --git a/include/configs/ls2080aqds.h b/include/configs/ls2080aqds.h index c40f0f2..3ec4bb6 100644 --- a/include/configs/ls2080aqds.h +++ b/include/configs/ls2080aqds.h @@ -119,7 +119,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_NAND_MAX_ECCPOS 256 #define CONFIG_SYS_NAND_MAX_OOBFREE 2
- #define CONFIG_SYS_NAND_CSPR_EXT (0x0) #define CONFIG_SYS_NAND_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS) \ | CSPR_PORT_SIZE_8 /* Port Size = 8 bit */ \ diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index 4aed2de..8ba0512 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -127,7 +127,6 @@ unsigned long get_board_sys_clk(void); #define CONFIG_SYS_NAND_MAX_ECCPOS 256 #define CONFIG_SYS_NAND_MAX_OOBFREE 2
- #define CONFIG_SYS_NAND_CSPR_EXT (0x0) #define CONFIG_SYS_NAND_CSPR (CSPR_PHYS_ADDR(CONFIG_SYS_NAND_BASE_PHYS) \ | CSPR_PORT_SIZE_8 /* Port Size = 8 bit */ \ diff --git a/include/configs/lsxl.h b/include/configs/lsxl.h index 0ce422e..094a7e2 100644 --- a/include/configs/lsxl.h +++ b/include/configs/lsxl.h @@ -8,7 +8,6 @@ #ifndef _CONFIG_LSXL_H #define _CONFIG_LSXL_H
- /* * Version number information */ @@ -75,8 +74,6 @@ #undef CONFIG_SF_DEFAULT_SPEED #define CONFIG_SF_DEFAULT_SPEED 25000000
- - /* * Environment variables configurations */ diff --git a/include/configs/lwmon5.h b/include/configs/lwmon5.h index 0b1788f..3dc59e4 100644 --- a/include/configs/lwmon5.h +++ b/include/configs/lwmon5.h @@ -23,7 +23,6 @@ #define CONFIG_440EPX 1 /* Specific PPC440EPx */ #define CONFIG_440 1 /* ... PPC440 family */
- #define CONFIG_SYS_TEXT_BASE 0xFFF80000 #define CONFIG_HOSTNAME lwmon5
@@ -425,7 +424,6 @@
- #if defined(CONFIG_CMD_KGDB) #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #else diff --git a/include/configs/m28evk.h b/include/configs/m28evk.h index 0a537ce..2070f33 100644 --- a/include/configs/m28evk.h +++ b/include/configs/m28evk.h @@ -36,7 +36,6 @@ #define CONFIG_CMD_NAND_TRIMFFS #define CONFIG_VIDEO
- /* Memory configuration */ #define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ #define PHYS_SDRAM_1 0x40000000 /* Base address */ diff --git a/include/configs/m53evk.h b/include/configs/m53evk.h index 600eea0..9ababa3 100644 --- a/include/configs/m53evk.h +++ b/include/configs/m53evk.h @@ -43,7 +43,6 @@ #define CONFIG_CMD_SATA #define CONFIG_VIDEO
- /* * Memory configurations */ diff --git a/include/configs/mcx.h b/include/configs/mcx.h index 01f1d83..d12f291 100644 --- a/include/configs/mcx.h +++ b/include/configs/mcx.h @@ -25,7 +25,6 @@ #define CONFIG_MACH_TYPE MACH_TYPE_MCX #define CONFIG_BOARD_LATE_INIT
- #define CONFIG_SYS_CACHELINE_SIZE 64
#define CONFIG_EMIF4 /* The chip has EMIF4 controller */ diff --git a/include/configs/mecp5123.h b/include/configs/mecp5123.h index 46453c4..cca7c33 100644 --- a/include/configs/mecp5123.h +++ b/include/configs/mecp5123.h @@ -242,7 +242,6 @@ #define SCCR2_CLOCKS_EN (CLOCK_SCCR2_MEM_EN | \ CLOCK_SCCR2_I2C_EN)
- #define CONFIG_CMDLINE_EDITING 1 /* add command line history */
/* I2C */ diff --git a/include/configs/meesc.h b/include/configs/meesc.h index e7d2694..d65a4cd 100644 --- a/include/configs/meesc.h +++ b/include/configs/meesc.h @@ -86,7 +86,6 @@ * Command line configuration. */
- #ifdef CONFIG_SYS_USE_NANDFLASH #define CONFIG_CMD_NAND #endif diff --git a/include/configs/minnowmax.h b/include/configs/minnowmax.h index e0006d8..93d34e9 100644 --- a/include/configs/minnowmax.h +++ b/include/configs/minnowmax.h @@ -28,7 +28,6 @@ {PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_VALLEYVIEW_SATA}, \ {PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_VALLEYVIEW_SATA_ALT}
- #define CONFIG_MMC #define CONFIG_SDHCI #define CONFIG_GENERIC_MMC diff --git a/include/configs/mpc5121ads.h b/include/configs/mpc5121ads.h index 9cc940c..2179f60 100644 --- a/include/configs/mpc5121ads.h +++ b/include/configs/mpc5121ads.h @@ -332,7 +332,6 @@ #define CONFIG_SYS_PCI_IO_PHYS 0x84000000 #define CONFIG_SYS_PCI_IO_SIZE 0x01000000 /* 16M */
- #define CONFIG_PCI_PNP /* do pci plug-and-play */
#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ @@ -450,7 +449,6 @@ "1m(u-boot);" \ "mpc5121.nand:-(data)"
- #if defined(CONFIG_CMD_IDE) || defined(CONFIG_CMD_EXT2) || defined(CONFIG_CMD_USB)
#define CONFIG_DOS_PARTITION @@ -483,7 +481,6 @@ #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ #endif
- #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) /* Print Buffer Size */ #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ diff --git a/include/configs/ms7720se.h b/include/configs/ms7720se.h index 3e99966..5b6880b 100644 --- a/include/configs/ms7720se.h +++ b/include/configs/ms7720se.h @@ -57,7 +57,6 @@ #define CONFIG_SYS_MALLOC_LEN (256 * 1024) #define CONFIG_SYS_BOOTMAPSZ (8 * 1024 * 1024)
- /* FLASH */ #define CONFIG_SYS_FLASH_CFI #define CONFIG_FLASH_CFI_DRIVER diff --git a/include/configs/ms7750se.h b/include/configs/ms7750se.h index bbd2d6b..025a4a6 100644 --- a/include/configs/ms7750se.h +++ b/include/configs/ms7750se.h @@ -64,7 +64,6 @@ #undef CONFIG_SYS_FLASH_QUIET_TEST #define CONFIG_SYS_FLASH_EMPTY_INFO /* print 'E' for empty sector on flinfo */
- #define CONFIG_ENV_IS_IN_FLASH #define CONFIG_ENV_SECT_SIZE 0x20000 #define CONFIG_ENV_SIZE (CONFIG_ENV_SECT_SIZE) diff --git a/include/configs/mv-plug-common.h b/include/configs/mv-plug-common.h index 496bc1f..116c821 100644 --- a/include/configs/mv-plug-common.h +++ b/include/configs/mv-plug-common.h @@ -8,7 +8,6 @@ #ifndef _CONFIG_MARVELL_PLUG_H #define _CONFIG_MARVELL_PLUG_H
- /* * High Level Configuration Options (easy to change) */ diff --git a/include/configs/mx31ads.h b/include/configs/mx31ads.h index 78aa22b..b9992de 100644 --- a/include/configs/mx31ads.h +++ b/include/configs/mx31ads.h @@ -14,7 +14,6 @@ /* High Level Configuration Options */ #define CONFIG_MX31 1 /* This is a mx31 */
@@ -154,7 +153,6 @@ #define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SIZE) #define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE
- /*----------------------------------------------------------------------- * CFI FLASH driver setup */ diff --git a/include/configs/mx31pdk.h b/include/configs/mx31pdk.h index 75d24bf..797eb09 100644 --- a/include/configs/mx31pdk.h +++ b/include/configs/mx31pdk.h @@ -19,7 +19,6 @@ /* High Level Configuration Options */ #define CONFIG_MX31 /* This is a mx31 */
@@ -175,7 +174,6 @@ #define CONFIG_SYS_NAND_SIZE (256 * 1024 * 1024) #define CONFIG_SYS_NAND_BAD_BLOCK_POS 0
- /* Configuration of lowlevel_init.S (clocks and SDRAM) */ #define CCM_CCMR_SETUP 0x074B0BF5 #define CCM_PDR0_SETUP_532MHZ (PDR0_CSI_PODF(0x3f) | PDR0_CSI_PRDF(7) | \ diff --git a/include/configs/mx35pdk.h b/include/configs/mx35pdk.h index 9e736eb..5f4142a 100644 --- a/include/configs/mx35pdk.h +++ b/include/configs/mx35pdk.h @@ -48,7 +48,6 @@ #define CONFIG_MXC_SPI #define CONFIG_MXC_GPIO
- /* * PMIC Configs */ diff --git a/include/configs/mx53ard.h b/include/configs/mx53ard.h index 0eb5203..48b4dca 100644 --- a/include/configs/mx53ard.h +++ b/include/configs/mx53ard.h @@ -221,7 +221,6 @@ #define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0
- #define MX53ARD_CS1GCR1 (CSEN | DSZ(2)) #define MX53ARD_CS1RCR1 (RCSN(2) | OEN (1) | RWSC(22)) #define MX53ARD_CS1RCR2 RBEN(2) diff --git a/include/configs/mx6sabre_common.h b/include/configs/mx6sabre_common.h index 072003c..d777666 100644 --- a/include/configs/mx6sabre_common.h +++ b/include/configs/mx6sabre_common.h @@ -164,7 +164,6 @@ "echo WARNING: Could not determine dtb to use; fi; " \ "fi;\0" \
- #define CONFIG_BOOTCOMMAND \ "run findfdt;" \ "mmc dev ${mmcdev};" \ diff --git a/include/configs/mx6sxsabreauto.h b/include/configs/mx6sxsabreauto.h index 14acea9..9617e24 100644 --- a/include/configs/mx6sxsabreauto.h +++ b/include/configs/mx6sxsabreauto.h @@ -6,13 +6,11 @@ * SPDX-License-Identifier: GPL-2.0+ */
- #ifndef __CONFIG_H #define __CONFIG_H
#include "mx6_common.h"
- /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (3 * SZ_1M)
@@ -164,7 +162,6 @@ #define CONFIG_PHYLIB #define CONFIG_PHY_ATHEROS
- #ifdef CONFIG_CMD_USB #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_MX6 @@ -179,7 +176,6 @@
#define CONFIG_IMX_THERMAL
- #define CONFIG_FSL_QSPI #ifdef CONFIG_FSL_QSPI #define CONFIG_SYS_FSL_QSPI_AHB diff --git a/include/configs/mx6sxsabresd.h b/include/configs/mx6sxsabresd.h index c28a747..71b9fe3 100644 --- a/include/configs/mx6sxsabresd.h +++ b/include/configs/mx6sxsabresd.h @@ -6,7 +6,6 @@ * SPDX-License-Identifier: GPL-2.0+ */
@@ -175,7 +174,6 @@ #define CONFIG_PHYLIB #define CONFIG_PHY_ATHEROS
- #ifdef CONFIG_CMD_USB #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_MX6 @@ -200,8 +198,6 @@
- - #ifdef CONFIG_FSL_QSPI #define CONFIG_SYS_FSL_QSPI_LE #define CONFIG_SYS_FSL_QSPI_AHB diff --git a/include/configs/mx6ul_14x14_evk.h b/include/configs/mx6ul_14x14_evk.h index eb92138..fa79d48 100644 --- a/include/configs/mx6ul_14x14_evk.h +++ b/include/configs/mx6ul_14x14_evk.h @@ -8,7 +8,6 @@ #ifndef __MX6UL_14X14_EVK_CONFIG_H #define __MX6UL_14X14_EVK_CONFIG_H
- #include <asm/arch/imx-regs.h> #include <linux/sizes.h> #include "mx6_common.h" diff --git a/include/configs/neo.h b/include/configs/neo.h index 3121c03..4f244a9 100644 --- a/include/configs/neo.h +++ b/include/configs/neo.h @@ -8,7 +8,6 @@ #ifndef __CONFIG_H #define __CONFIG_H
- #define CONFIG_405EP 1 /* this is a PPC405 CPU */ #define CONFIG_NEO 1 /* on a Neo board */
diff --git a/include/configs/nitrogen6x.h b/include/configs/nitrogen6x.h index 7696b53..9f16da7 100644 --- a/include/configs/nitrogen6x.h +++ b/include/configs/nitrogen6x.h @@ -320,7 +320,6 @@ #define CONFIG_PCIE_IMX #endif
- #define CONFIG_CMD_USB_MASS_STORAGE #define CONFIG_USB_FUNCTION_MASS_STORAGE
diff --git a/include/configs/odroid.h b/include/configs/odroid.h index 0b691e4..3e2bcec 100644 --- a/include/configs/odroid.h +++ b/include/configs/odroid.h @@ -191,7 +191,6 @@ #define CONFIG_EXYNOS_ACE_SHA #define CONFIG_LIB_HW_RAND
- /* USB */ #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_EXYNOS diff --git a/include/configs/omap3_igep00x0.h b/include/configs/omap3_igep00x0.h index 8e438e9..cfe7012 100644 --- a/include/configs/omap3_igep00x0.h +++ b/include/configs/omap3_igep00x0.h @@ -92,7 +92,6 @@
#include <config_distro_bootcmd.h>
- #define CONFIG_EXTRA_ENV_SETTINGS \ ENV_DEVICE_SETTINGS \ MEM_LAYOUT_SETTINGS \ diff --git a/include/configs/omap3_logic.h b/include/configs/omap3_logic.h index 9aaab01..ab83714 100644 --- a/include/configs/omap3_logic.h +++ b/include/configs/omap3_logic.h @@ -282,7 +282,6 @@ #define CONFIG_ENV_OFFSET SMNAND_ENV_OFFSET #define CONFIG_ENV_ADDR SMNAND_ENV_OFFSET
- /* SMSC922x Ethernet */ #if defined(CONFIG_CMD_NET) #define CONFIG_SMC911X diff --git a/include/configs/omap3_zoom1.h b/include/configs/omap3_zoom1.h index e9e8da8..99d9fc3 100644 --- a/include/configs/omap3_zoom1.h +++ b/include/configs/omap3_zoom1.h @@ -77,7 +77,6 @@ #define CONFIG_CMD_NAND_LOCK_UNLOCK /* Enable lock/unlock support */ #endif
- #undef CONFIG_SYS_I2C_OMAP24XX #define CONFIG_SYS_I2C_OMAP34XX
diff --git a/include/configs/omap4_panda.h b/include/configs/omap4_panda.h index 3e7096e..0d62ccd 100644 --- a/include/configs/omap4_panda.h +++ b/include/configs/omap4_panda.h @@ -32,7 +32,6 @@
#define CONFIG_UBOOT_ENABLE_PADS_ALL
- #include <configs/ti_omap4_common.h>
/* GPIO */ diff --git a/include/configs/openrisc-generic.h b/include/configs/openrisc-generic.h index f7c3aaa..ffed6c5 100644 --- a/include/configs/openrisc-generic.h +++ b/include/configs/openrisc-generic.h @@ -128,5 +128,4 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- #endif /* __CONFIG_H */ diff --git a/include/configs/ot1200.h b/include/configs/ot1200.h index 100d634..9b5c369 100644 --- a/include/configs/ot1200.h +++ b/include/configs/ot1200.h @@ -78,7 +78,6 @@ #define CONFIG_LIBATA #endif
- /* SPL */ #ifdef CONFIG_SPL #include "imx6_spl.h" diff --git a/include/configs/p1_p2_rdb_pc.h b/include/configs/p1_p2_rdb_pc.h index 5e63b0c..fba61a4 100644 --- a/include/configs/p1_p2_rdb_pc.h +++ b/include/configs/p1_p2_rdb_pc.h @@ -434,7 +434,6 @@ * 0xffe0_0000 0xffef_ffff CCSR 1M non-cacheable */
- /* * Local Bus Definitions */ @@ -449,7 +448,6 @@ #define CONFIG_SYS_FLASH_BASE 0xef000000 #endif
- #ifdef CONFIG_PHYS_64BIT #define CONFIG_SYS_FLASH_BASE_PHYS (0xf00000000ull | CONFIG_SYS_FLASH_BASE) #else @@ -581,7 +579,6 @@ #define CONFIG_SYS_BR3_PRELIM CONFIG_CPLD_BR_PRELIM /* CPLD Base Address */ #define CONFIG_SYS_OR3_PRELIM CONFIG_CPLD_OR_PRELIM /* CPLD Options */
- /* Vsc7385 switch */ #ifdef CONFIG_VSC7385_ENET #define CONFIG_SYS_VSC7385_BASE 0xffb00000 diff --git a/include/configs/pb1x00.h b/include/configs/pb1x00.h index f094850..b1fd2b8 100644 --- a/include/configs/pb1x00.h +++ b/include/configs/pb1x00.h @@ -108,10 +108,8 @@
- #define CONFIG_MEMSIZE_IN_BYTES
- /*---USB -------------------------------------------*/ #if 0 #define CONFIG_USB_OHCI @@ -159,7 +157,6 @@ #define CONFIG_SYS_ICACHE_SIZE 16384 #define CONFIG_SYS_CACHELINE_SIZE 32
- /* * BOOTP options */ @@ -168,7 +165,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- /* * Command line configuration. */ diff --git a/include/configs/pcm030.h b/include/configs/pcm030.h index 3a9b8f3..f503520 100644 --- a/include/configs/pcm030.h +++ b/include/configs/pcm030.h @@ -76,7 +76,6 @@ Autobooting /* even with bootdelay=0 */ #undef CONFIG_BOOTARGS
- #define CONFIG_PREBOOT "echo;" \ "echo Type "run bootcmd_net" to load Kernel over TFTP and to "\ "mount root filesystem over NFS;" \ diff --git a/include/configs/pengwyn.h b/include/configs/pengwyn.h index 733ff28..155f589 100644 --- a/include/configs/pengwyn.h +++ b/include/configs/pengwyn.h @@ -149,7 +149,6 @@ 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193,\ 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209}
- #define CONFIG_SYS_NAND_ECCSIZE 512 #define CONFIG_SYS_NAND_ECCBYTES 26 #define CONFIG_SYS_NAND_ECCSTEPS 8 @@ -162,8 +161,6 @@ /* #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x80000 */ #define CONFIG_SYS_NAND_U_BOOT_OFFS 0x200000
- - #define CONFIG_CMD_MTDPARTS
#define CONFIG_CMD_ASKENV /* monitor functions : ask for env variable */ diff --git a/include/configs/pm9261.h b/include/configs/pm9261.h index f883ca3..dcfc774 100644 --- a/include/configs/pm9261.h +++ b/include/configs/pm9261.h @@ -20,7 +20,6 @@ #include <asm/hardware.h> /* ARM asynchronous clock */
#define MASTER_PLL_DIV 15 diff --git a/include/configs/pm9263.h b/include/configs/pm9263.h index 0fb0a36..92d080e 100644 --- a/include/configs/pm9263.h +++ b/include/configs/pm9263.h @@ -18,7 +18,6 @@ */ #include <asm/hardware.h>
- /* ARM asynchronous clock */ #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DISPLAY_BOARDINFO diff --git a/include/configs/pm9g45.h b/include/configs/pm9g45.h index ba9e6d3..a6472fb 100644 --- a/include/configs/pm9g45.h +++ b/include/configs/pm9g45.h @@ -22,7 +22,6 @@ */ #include <asm/hardware.h>
- #define CONFIG_PM9G45 1 /* It's an Ronetix PM9G45 */ #define CONFIG_SYS_AT91_CPU_NAME "AT91SAM9G45"
diff --git a/include/configs/pogo_e02.h b/include/configs/pogo_e02.h index 6314365..731b9de 100644 --- a/include/configs/pogo_e02.h +++ b/include/configs/pogo_e02.h @@ -13,7 +13,6 @@ #ifndef _CONFIG_POGO_E02_H #define _CONFIG_POGO_E02_H
- /* * Machine type definition and ID */ diff --git a/include/configs/pr1.h b/include/configs/pr1.h index 1af9ef7..9b394dd 100644 --- a/include/configs/pr1.h +++ b/include/configs/pr1.h @@ -10,14 +10,12 @@
#include <asm/config-pre.h>
- /* * Network Settings */ @@ -70,13 +66,11 @@ #define CONFIG_HOSTNAME pr1 #define CONFIG_TFTP_BLOCKSIZE 4404
- /* * Flash Settings */ #define CONFIG_SYS_NO_FLASH /* We have no parallel FLASH */
- /* * SPI Settings */ @@ -84,7 +78,6 @@ #define CONFIG_ENV_SPI_MAX_HZ 30000000 #define CONFIG_SF_DEFAULT_SPEED 30000000
- /* * Env Storage Settings */ @@ -94,14 +87,12 @@ #define CONFIG_ENV_SECT_SIZE 0x10000 #define CONFIG_ENV_IS_EMBEDDED_IN_LDR
- /* * I2C Settings */ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_ADI
- /* * NAND Settings */ diff --git a/include/configs/pxm2.h b/include/configs/pxm2.h index 145a933..7450a1a 100644 --- a/include/configs/pxm2.h +++ b/include/configs/pxm2.h @@ -40,7 +40,6 @@ #define CONFIG_SYS_I2C_SPEED 400000 #define CONFIG_SYS_I2C_EEPROM_ADDR 0x50
- #define CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORS 0x300
#undef CONFIG_SPL_NET_SUPPORT @@ -51,7 +50,6 @@
#define CONFIG_FACTORYSET
- /* Watchdog */ #define CONFIG_OMAP_WATCHDOG
diff --git a/include/configs/qemu-mips64.h b/include/configs/qemu-mips64.h index 9e5cbb1..b998052 100644 --- a/include/configs/qemu-mips64.h +++ b/include/configs/qemu-mips64.h @@ -69,7 +69,6 @@
#define CONFIG_SYS_IDE_MAXDEVICE 4
- /* * Miscellaneous configurable options */ diff --git a/include/configs/r0p7734.h b/include/configs/r0p7734.h index 88fe641..f19898f 100644 --- a/include/configs/r0p7734.h +++ b/include/configs/r0p7734.h @@ -45,7 +45,6 @@ # define CONFIG_SMC911X_BASE (0x84000000) #endif
- /* I2C */ #define CONFIG_SH_SH7734_I2C 1 #define CONFIG_HARD_I2C 1 diff --git a/include/configs/rastaban.h b/include/configs/rastaban.h index d9dde9c..aa130a1 100644 --- a/include/configs/rastaban.h +++ b/include/configs/rastaban.h @@ -70,8 +70,6 @@ #define CONFIG_ENV_SIZE_REDUND 0x2000 #define CONFIG_ENV_RANGE (4 * CONFIG_SYS_ENV_SECT_SIZE)
- - #define MTDPARTS_DEFAULT MTDPARTS_DEFAULT_V3
#ifndef CONFIG_SPL_BUILD @@ -99,7 +97,6 @@ "run nand_boot_backup;" \ "reset;"
diff --git a/include/configs/rk3036_common.h b/include/configs/rk3036_common.h index 01c3005..a5ab569 100644 --- a/include/configs/rk3036_common.h +++ b/include/configs/rk3036_common.h @@ -70,7 +70,6 @@ #define CONFIG_SPI_FLASH_GIGADEVICE #define CONFIG_SF_DEFAULT_SPEED 20000000
- #ifndef CONFIG_SPL_BUILD #include <config_distro_defaults.h>
diff --git a/include/configs/rk3288_common.h b/include/configs/rk3288_common.h index 02cb94b..c1ea280 100644 --- a/include/configs/rk3288_common.h +++ b/include/configs/rk3288_common.h @@ -88,7 +88,6 @@ #define CONFIG_SPI #define CONFIG_SF_DEFAULT_SPEED 20000000
diff --git a/include/configs/rut.h b/include/configs/rut.h index cf018e0..bf2cc2f 100644 --- a/include/configs/rut.h +++ b/include/configs/rut.h @@ -45,7 +45,6 @@
- /* Watchdog */ #define WATCHDOG_TRIGGER_GPIO 14
diff --git a/include/configs/s5pc210_universal.h b/include/configs/s5pc210_universal.h index c14a247..bdb368e 100644 --- a/include/configs/s5pc210_universal.h +++ b/include/configs/s5pc210_universal.h @@ -162,7 +162,6 @@ #define CONFIG_SOFT_I2C_GPIO_SCL EXYNOS4_GPIO_B7 #define CONFIG_SOFT_I2C_GPIO_SDA EXYNOS4_GPIO_B6
- #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_SOFT /* I2C bit-banged */ #define CONFIG_SYS_I2C_SOFT_SPEED 50000 diff --git a/include/configs/sandbox.h b/include/configs/sandbox.h index 4b8fe16..0bdb73a 100644 --- a/include/configs/sandbox.h +++ b/include/configs/sandbox.h @@ -50,7 +50,6 @@ #define CONFIG_CMD_FS_GENERIC #define CONFIG_CMD_MD5SUM
- #define CONFIG_CMD_GPT #define CONFIG_PARTITION_UUIDS #define CONFIG_AMIGA_PARTITION diff --git a/include/configs/sbc8349.h b/include/configs/sbc8349.h index 37fdeaa..fc22134 100644 --- a/include/configs/sbc8349.h +++ b/include/configs/sbc8349.h @@ -395,7 +395,6 @@ #define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ #define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */
- /* * BOOTP options */ @@ -404,7 +403,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- /* * Command line configuration. */ @@ -522,7 +520,6 @@ HID0_ENABLE_M_BIT |\ HID0_ENABLE_ADDRESS_BROADCAST) */
- #define CONFIG_SYS_HID2 HID2_HBE
#define CONFIG_HIGH_BATS 1 /* High BATs supported */ diff --git a/include/configs/sbc8548.h b/include/configs/sbc8548.h index 7e5cdfb..19601e7 100644 --- a/include/configs/sbc8548.h +++ b/include/configs/sbc8548.h @@ -13,7 +13,6 @@ #ifndef __CONFIG_H #define __CONFIG_H
- /* * Top level Makefile configuration choices */ @@ -472,7 +471,6 @@
#endif /* CONFIG_PCI */
- #if defined(CONFIG_TSEC_ENET)
#define CONFIG_MII 1 /* MII PHY management */ @@ -522,7 +520,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- /* * Command line configuration. */ @@ -533,7 +530,6 @@ #define CONFIG_CMD_PCI #endif
- #undef CONFIG_WATCHDOG /* watchdog disabled */
/* @@ -613,7 +609,6 @@ "tftp $fdtaddr $fdtfile;" \ "bootm $loadaddr - $fdtaddr"
- #define CONFIG_RAMBOOTCOMMAND \ "setenv bootargs root=/dev/ram rw " \ "console=$consoledev,$baudrate $othbootargs;" \ diff --git a/include/configs/sbc8641d.h b/include/configs/sbc8641d.h index 298e3ee..f34cef5 100644 --- a/include/configs/sbc8641d.h +++ b/include/configs/sbc8641d.h @@ -20,7 +20,6 @@ #ifndef __CONFIG_H #define __CONFIG_H
- /* High Level Configuration Options */ #define CONFIG_MPC8641 1 /* MPC8641 specific */ #define CONFIG_SBC8641D 1 /* SBC8641D board specific */ @@ -67,7 +66,6 @@ #define BANK_INTERLEAVING 0x22000000 #define SUPER_BANK_INTERLEAVING 0x23000000
- #define CONFIG_ALTIVEC 1
/* @@ -173,7 +171,6 @@ #define CONFIG_SYS_DDR2_CLK_CTRL 0x03800000 #define CONFIG_SYS_DDR2_CFG_1B 0xC3008008
- #endif
/* #define CONFIG_ID_EEPROM 1 diff --git a/include/configs/secomx6quq7.h b/include/configs/secomx6quq7.h index d4bba6d..e1c0e9a 100644 --- a/include/configs/secomx6quq7.h +++ b/include/configs/secomx6quq7.h @@ -71,7 +71,6 @@ "stdout=serial\0" \ "stderr=serial\0"
- /* Print Buffer Size */ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ sizeof(CONFIG_SYS_PROMPT) + 16) diff --git a/include/configs/sh7785lcr.h b/include/configs/sh7785lcr.h index e5ba30a..1d7fced 100644 --- a/include/configs/sh7785lcr.h +++ b/include/configs/sh7785lcr.h @@ -69,7 +69,6 @@ #undef CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE #undef CONFIG_SYS_CONSOLE_ENV_OVERWRITE
- #define CONFIG_SYS_MEMTEST_START (SH7785LCR_SDRAM_BASE) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ (SH7785LCR_SDRAM_SIZE) - \ diff --git a/include/configs/sheevaplug.h b/include/configs/sheevaplug.h index f9fb9bc..2019156 100644 --- a/include/configs/sheevaplug.h +++ b/include/configs/sheevaplug.h @@ -10,7 +10,6 @@ #ifndef _CONFIG_SHEEVAPLUG_H #define _CONFIG_SHEEVAPLUG_H
- /* * Version number information */ diff --git a/include/configs/siemens-am33x-common.h b/include/configs/siemens-am33x-common.h index b4aa283..aecd06f 100644 --- a/include/configs/siemens-am33x-common.h +++ b/include/configs/siemens-am33x-common.h @@ -42,7 +42,6 @@ #define CONFIG_CMD_ASKENV #define CONFIG_CMD_CACHE
- #define CONFIG_ENV_VARS_UBOOT_CONFIG #ifndef CONFIG_SPL_BUILD #define CONFIG_ROOTPATH "/opt/eldk" @@ -485,7 +484,6 @@ "512k(mtdoops)," \ "-(rootfs)"
- #define DFU_ALT_INFO_NAND_V2 \ "spl part 0 1;" \ "spl.backup1 part 0 2;" \ @@ -577,7 +575,6 @@ "512k(mtdoops)," \ "-(configuration)"
- #define CONFIG_NAND_OMAP_GPMC #define CONFIG_NAND_OMAP_ELM #define CONFIG_SYS_NAND_BASE (0x08000000) /* physical address */ diff --git a/include/configs/smartweb.h b/include/configs/smartweb.h index 54701f3..4daab98 100644 --- a/include/configs/smartweb.h +++ b/include/configs/smartweb.h @@ -235,7 +235,6 @@ (ATMEL_BASE_SRAM1 + 0x1000 - GENERATED_GBL_DATA_SIZE) #endif
- /* Defines for SPL */ #define CONFIG_SPL_FRAMEWORK #define CONFIG_SPL_TEXT_BASE 0x0 diff --git a/include/configs/smdk2410.h b/include/configs/smdk2410.h index 6b460bf..f009343 100644 --- a/include/configs/smdk2410.h +++ b/include/configs/smdk2410.h @@ -23,7 +23,6 @@
#define CONFIG_SYS_TEXT_BASE 0x0
- #define CONFIG_SYS_ARM_CACHE_WRITETHROUGH
/* input clock of PLL (the SMDK2410 has 12MHz input clock) */ @@ -60,7 +59,6 @@ ************************************************************/ #define CONFIG_RTC_S3C24X0
- #define CONFIG_BAUDRATE 115200
/* diff --git a/include/configs/smdkv310.h b/include/configs/smdkv310.h index 63f6204..0c21deb 100644 --- a/include/configs/smdkv310.h +++ b/include/configs/smdkv310.h @@ -41,7 +41,6 @@ /* allow to overwrite serial and ethaddr */ #define CONFIG_ENV_OVERWRITE
- /* MMC SPL */ #define CONFIG_SKIP_LOWLEVEL_INIT #define COPY_BL2_FNPTR_ADDR 0x00002488 diff --git a/include/configs/sniper.h b/include/configs/sniper.h index 3fbc2be..eb53a21 100644 --- a/include/configs/sniper.h +++ b/include/configs/sniper.h @@ -88,7 +88,6 @@ #define CONFIG_SYS_I2C_OMAP34XX #define CONFIG_I2C_MULTI_BUS
- /* * Flash */ diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 9b2313c..4fdc09a 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -6,7 +6,6 @@ #ifndef __CONFIG_SOCFPGA_COMMON_H__ #define __CONFIG_SOCFPGA_COMMON_H__
- /* Virtual target or real hardware */ #undef CONFIG_SOCFPGA_VIRTUAL_TARGET
diff --git a/include/configs/socrates.h b/include/configs/socrates.h index f45d91f..cf1e904 100644 --- a/include/configs/socrates.h +++ b/include/configs/socrates.h @@ -208,7 +208,6 @@ #define CONFIG_CMDLINE_EDITING 1 /* add command line history */ #define CONFIG_AUTO_COMPLETE 1 /* add autocompletion support */
- /* * I2C */ @@ -257,7 +256,6 @@ #undef CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ #endif /* CONFIG_PCI */
- #define CONFIG_MII 1 /* MII PHY management */ #define CONFIG_TSEC1 1 #define CONFIG_TSEC1_NAME "TSEC0" @@ -295,7 +293,6 @@
#define CONFIG_TIMESTAMP /* Print image info with ts */
- /* * BOOTP options */ @@ -304,7 +301,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- /* * Command line configuration. */ @@ -350,7 +346,6 @@ #define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port*/ #endif
- #define CONFIG_LOADADDR 200000 /* default addr for tftp & bootm*/
#define CONFIG_BOOTDELAY 1 /* -1 disables auto-boot */ diff --git a/include/configs/spear-common.h b/include/configs/spear-common.h index 63a5b70..269ce7e 100644 --- a/include/configs/spear-common.h +++ b/include/configs/spear-common.h @@ -11,7 +11,6 @@ * Common configurations used for both spear3xx as well as spear6xx */
- /* U-Boot Load Address */ #define CONFIG_SYS_TEXT_BASE 0x00700000
@@ -176,7 +175,6 @@ "console=ttyAMA0,115200 $(othbootargs);" \ CONFIG_BOOTCOMMAND
- #define CONFIG_ENV_SIZE 0x02000 #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE
diff --git a/include/configs/strider.h b/include/configs/strider.h index 2c1d4fb..a5b2223 100644 --- a/include/configs/strider.h +++ b/include/configs/strider.h @@ -637,5 +637,4 @@ int fpga_gpio_get(unsigned int bus, int pin);
- #endif /* __CONFIG_H */ diff --git a/include/configs/sun8i.h b/include/configs/sun8i.h index bf1b740..b9a8731 100644 --- a/include/configs/sun8i.h +++ b/include/configs/sun8i.h @@ -26,7 +26,6 @@ #define CONFIG_SUNXI_USB_PHYS 2 #endif
- #ifndef CONFIG_MACH_SUN8I_A83T #define CONFIG_ARMV7_PSCI 1 #if defined(CONFIG_MACH_SUN8I_A23) diff --git a/include/configs/t3corp.h b/include/configs/t3corp.h index 1ac54e2..64e200e 100644 --- a/include/configs/t3corp.h +++ b/include/configs/t3corp.h @@ -372,7 +372,6 @@ #define CONFIG_SYS_PCI_SUBSYS_VENDORID 0x1014 /* IBM */ #define CONFIG_SYS_PCI_SUBSYS_DEVICEID 0xcafe /* Whatever */
- /* * External Bus Controller (EBC) Setup */ diff --git a/include/configs/t4qds.h b/include/configs/t4qds.h index be68fac..f77e63c 100644 --- a/include/configs/t4qds.h +++ b/include/configs/t4qds.h @@ -98,14 +98,12 @@ #define CONFIG_DDR_SPD #define CONFIG_SYS_FSL_DDR3
- /* * IFC Definitions */ #define CONFIG_SYS_FLASH_BASE 0xe0000000 #define CONFIG_SYS_FLASH_BASE_PHYS (0xf00000000ull | CONFIG_SYS_FLASH_BASE)
- #ifdef CONFIG_SPL_BUILD #define CONFIG_SYS_MONITOR_BASE CONFIG_SPL_TEXT_BASE #else @@ -304,7 +302,6 @@ /* default location for tftp and bootm */ #define CONFIG_LOADADDR 1000000
#define CONFIG_HVBOOT \ diff --git a/include/configs/tam3517-common.h b/include/configs/tam3517-common.h index b270d9d..ef9e22e 100644 --- a/include/configs/tam3517-common.h +++ b/include/configs/tam3517-common.h @@ -316,7 +316,6 @@ "fi;" \ "else echo U-Boot not downloaded..exiting;fi\0" \
- /* * this is common code for all TAM3517 boards. * MAC address is stored from manufacturer in diff --git a/include/configs/taurus.h b/include/configs/taurus.h index d389752..946bfd4 100644 --- a/include/configs/taurus.h +++ b/include/configs/taurus.h @@ -22,7 +22,6 @@ #include <asm/hardware.h> #include <linux/sizes.h>
- #if defined(CONFIG_SPL_BUILD) #define CONFIG_SYS_THUMB_BUILD #define CONFIG_SYS_ICACHE_OFF @@ -35,7 +34,6 @@ * hex number here! */
- #define CONFIG_SYS_TEXT_BASE 0x21000000
/* ARM asynchronous clock */ @@ -299,7 +297,6 @@ 48, 49, 50, 51, 52, 53, 54, 55, \ 56, 57, 58, 59, 60, 61, 62, 63, }
- #define CONFIG_SPL_ATMEL_SIZE #define CONFIG_SYS_MASTER_CLOCK 132096000 #define AT91_PLL_LOCK_TIMEOUT 1000000 diff --git a/include/configs/tcm-bf518.h b/include/configs/tcm-bf518.h index 0f4d959..e017ba9 100644 --- a/include/configs/tcm-bf518.h +++ b/include/configs/tcm-bf518.h @@ -7,14 +7,12 @@
- /* * Processor Settings */ #define CONFIG_BFIN_CPU bf518-0.0 #define CONFIG_BFIN_BOOT_MODE BFIN_BOOT_PARA
- /* * Clock Settings * CCLK = (CLKIN * VCO_MULT) / CCLK_DIV @@ -38,7 +36,6 @@ /* Values can range from 1-15 */ #define CONFIG_SCLK_DIV 4
- /* * Memory Settings */ @@ -56,7 +53,6 @@ #define CONFIG_SYS_MONITOR_LEN (512 * 1024) #define CONFIG_SYS_MALLOC_LEN (384 * 1024)
- /* * Network Settings */ @@ -77,7 +73,6 @@ #define CONFIG_SYS_MAX_FLASH_BANKS 1 #define CONFIG_SYS_MAX_FLASH_SECT 19
- /* * SPI Settings */ @@ -85,7 +80,6 @@ #define CONFIG_ENV_SPI_MAX_HZ 30000000 #define CONFIG_SF_DEFAULT_SPEED 30000000
- /* * Env Storage Settings */ @@ -96,14 +90,12 @@ #define CONFIG_ENV_SECT_SIZE 0x8000 #define CONFIG_ENV_IS_EMBEDDED_IN_LDR
- /* * Misc Settings */ diff --git a/include/configs/tcm-bf537.h b/include/configs/tcm-bf537.h index fc98d24..c294f70 100644 --- a/include/configs/tcm-bf537.h +++ b/include/configs/tcm-bf537.h @@ -7,14 +7,12 @@
- /* * Processor Settings */ #define CONFIG_BFIN_CPU bf537-0.2 #define CONFIG_BFIN_BOOT_MODE BFIN_BOOT_BYPASS
- /* * Network Settings */ @@ -83,14 +79,12 @@ #define CONFIG_SYS_MAX_FLASH_BANKS 1 #define CONFIG_SYS_MAX_FLASH_SECT 67
- /* * SPI_MMC Settings */ @@ -148,5 +140,4 @@ */ #include <configs/bfin_adi_common.h>
- #endif diff --git a/include/configs/theadorable.h b/include/configs/theadorable.h index 4183867..a5a7fae 100644 --- a/include/configs/theadorable.h +++ b/include/configs/theadorable.h @@ -73,7 +73,6 @@ #define CONFIG_SYS_ALT_MEMTEST #define CONFIG_PREBOOT
- /* Keep device tree and initrd in lower memory so the kernel can access them */ #define CONFIG_EXTRA_ENV_SETTINGS \ "fdt_high=0x10000000\0" \ diff --git a/include/configs/thuban.h b/include/configs/thuban.h index 4024468..077422f 100644 --- a/include/configs/thuban.h +++ b/include/configs/thuban.h @@ -63,7 +63,6 @@ #define CONFIG_ENV_SIZE_REDUND 0x2000 #define CONFIG_ENV_RANGE (4 * CONFIG_SYS_ENV_SECT_SIZE)
#ifndef CONFIG_SPL_BUILD @@ -91,7 +90,6 @@ "run nand_boot_backup;" \ "reset;"
diff --git a/include/configs/thunderx_88xx.h b/include/configs/thunderx_88xx.h index fc16678..7c35d8c 100644 --- a/include/configs/thunderx_88xx.h +++ b/include/configs/thunderx_88xx.h @@ -15,7 +15,6 @@
- #define CONFIG_IDENT_STRING \ " for Cavium Thunder CN88XX ARM v8 Multi-Core" #define CONFIG_BOOTP_VCI_STRING "Diagnostics" @@ -31,11 +30,9 @@ /* SMP Spin Table Definitions */ #define CPU_RELEASE_ADDR (CONFIG_SYS_SDRAM_BASE + 0x7fff0)
- /* Generic Timer Definitions */ #define COUNTER_FREQUENCY (0x1800000) /* 24MHz */
- #define CONFIG_SYS_MEMTEST_START MEM_BASE #define CONFIG_SYS_MEMTEST_END (MEM_BASE + PHYS_SDRAM_1_SIZE)
diff --git a/include/configs/ti816x_evm.h b/include/configs/ti816x_evm.h index b5216a8..83b745a 100644 --- a/include/configs/ti816x_evm.h +++ b/include/configs/ti816x_evm.h @@ -84,7 +84,6 @@ #define CONFIG_TI816X_USE_EMIF0 1 #define CONFIG_TI816X_USE_EMIF1 1
- #define CONFIG_NR_DRAM_BANKS 2 /* we have 2 banks of DRAM */ #define PHYS_DRAM_1 0x80000000 /* DRAM Bank #1 */ #define PHYS_DRAM_1_SIZE 0x40000000 /* 1 GB */ diff --git a/include/configs/ti_omap3_common.h b/include/configs/ti_omap3_common.h index 6a4868c..32877d1 100644 --- a/include/configs/ti_omap3_common.h +++ b/include/configs/ti_omap3_common.h @@ -76,7 +76,6 @@ #define CONFIG_SYS_SPL_ARGS_ADDR (CONFIG_SYS_SDRAM_BASE + \ (64 << 20))
- #ifdef CONFIG_NAND #define CONFIG_SPL_NAND_SIMPLE #define CONFIG_SYS_NAND_BASE 0x30000000 diff --git a/include/configs/ti_omap5_common.h b/include/configs/ti_omap5_common.h index 202b18c..b049be4 100644 --- a/include/configs/ti_omap5_common.h +++ b/include/configs/ti_omap5_common.h @@ -112,7 +112,6 @@ DFUARGS \ NETARGS \
- #define CONFIG_BOOTCOMMAND \ "if test ${dofastboot} -eq 1; then " \ "echo Boot fastboot requested, resetting dofastboot ...;" \ @@ -129,7 +128,6 @@ "" #endif
- /* * SPL related defines. The Public RAM memory map the ROM defines the * area between 0x40300000 and 0x4031E000 as a download area for OMAP5 diff --git a/include/configs/tqma6.h b/include/configs/tqma6.h index 2e729d2..439a4fd 100644 --- a/include/configs/tqma6.h +++ b/include/configs/tqma6.h @@ -281,7 +281,6 @@ "sf read ${${fdt_addr}} ${offset} ${size}; " \ "setenv size ; setenv offset\0" \
- #define CONFIG_BOOTCOMMAND \ "sf probe; run mmcboot; run netboot; run panicboot" \
diff --git a/include/configs/tqma6_wru4.h b/include/configs/tqma6_wru4.h index c67e0bd..8896bc3 100644 --- a/include/configs/tqma6_wru4.h +++ b/include/configs/tqma6_wru4.h @@ -38,7 +38,6 @@ #define CONFIG_SYS_RTC_DS1337_NOOSC #define CONFIG_CMD_DATE
- /* LED */ #define CONFIG_CMD_LED #define CONFIG_STATUS_LED diff --git a/include/configs/trats.h b/include/configs/trats.h index 2c0e5ed..0c875cb 100644 --- a/include/configs/trats.h +++ b/include/configs/trats.h @@ -14,7 +14,6 @@
#define CONFIG_TRATS
- #define CONFIG_TIZEN /* TIZEN lib */
#define CONFIG_SYS_L2CACHE_OFF @@ -184,7 +183,6 @@ /* I2C */ #include <asm/arch/gpio.h>
- #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_S3C24X0 #define CONFIG_SYS_I2C_S3C24X0_SPEED 100000 diff --git a/include/configs/trats2.h b/include/configs/trats2.h index bad360e..492a253 100644 --- a/include/configs/trats2.h +++ b/include/configs/trats2.h @@ -160,7 +160,6 @@ /* I2C */ #include <asm/arch/gpio.h>
- #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_S3C24X0 #define CONFIG_SYS_I2C_S3C24X0_SPEED 100000 diff --git a/include/configs/tricorder.h b/include/configs/tricorder.h index 41cc9fa..2514e88 100644 --- a/include/configs/tricorder.h +++ b/include/configs/tricorder.h @@ -41,7 +41,6 @@ #include <asm/arch/cpu.h> /* get chip and board defs */ #include <asm/arch/omap.h>
- /* Display CPU and Board information */ #define CONFIG_DISPLAY_CPUINFO #define CONFIG_DISPLAY_BOARDINFO diff --git a/include/configs/uniphier.h b/include/configs/uniphier.h index c6fc90f..1d740d0 100644 --- a/include/configs/uniphier.h +++ b/include/configs/uniphier.h @@ -71,7 +71,6 @@ /* serial console configuration */ #define CONFIG_BAUDRATE 115200
- #if !defined(CONFIG_SPL_BUILD) #define CONFIG_USE_ARCH_MEMSET #define CONFIG_USE_ARCH_MEMCPY diff --git a/include/configs/v38b.h b/include/configs/v38b.h index 870e5a8..c8cc842 100644 --- a/include/configs/v38b.h +++ b/include/configs/v38b.h @@ -73,7 +73,6 @@ #define CONFIG_USB_CLOCK 0x0001BBBB #define CONFIG_USB_CONFIG 0x00001000
- /* * Command line configuration. */ @@ -96,7 +94,6 @@ #define CONFIG_CMD_DATE #define CONFIG_CMD_FAT
- #define CONFIG_TIMESTAMP /* Print image info with timestamp */
/* diff --git a/include/configs/ve8313.h b/include/configs/ve8313.h index face83f..59bf2b3 100644 --- a/include/configs/ve8313.h +++ b/include/configs/ve8313.h @@ -280,7 +280,6 @@ */ #define CONFIG_TSEC_ENET /* TSEC ethernet support */
- #define CONFIG_TSEC1 #ifdef CONFIG_TSEC1 #define CONFIG_HAS_ETH0 diff --git a/include/configs/vexpress_aemv8a.h b/include/configs/vexpress_aemv8a.h index e924963..a7e1195 100644 --- a/include/configs/vexpress_aemv8a.h +++ b/include/configs/vexpress_aemv8a.h @@ -307,5 +307,4 @@ #define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE #define CONFIG_ENV_IS_IN_FLASH 1
- #endif /* __VEXPRESS_AEMV8A_H */ diff --git a/include/configs/vinco.h b/include/configs/vinco.h index 353b17b..b0737e7 100644 --- a/include/configs/vinco.h +++ b/include/configs/vinco.h @@ -34,7 +34,6 @@ #define CONFIG_SYS_SDRAM_BASE ATMEL_BASE_DDRCS #define CONFIG_SYS_SDRAM_SIZE 0x4000000
- #define CONFIG_SYS_INIT_SP_ADDR \ (CONFIG_SYS_SDRAM_BASE + 4 * 1024 - GENERATED_GBL_DATA_SIZE)
@@ -54,7 +53,6 @@ #define CONFIG_ENV_SPI_MODE (SPI_MODE_0) #endif
- /* MMC */ #define CONFIG_CMD_MMC
@@ -101,12 +99,10 @@ #define CONFIG_NET_RETRY_COUNT 20 #define CONFIG_MACB_SEARCH_PHY
- #define CONFIG_USB_HOST_ETHER #define CONFIG_USB_ETHER_SMSC95XX #define CONFIG_USB_ETHER_RNDIS
- #ifdef CONFIG_SYS_USE_SERIALFLASH /* bootstrap + u-boot + env + linux in serial flash */ #define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS diff --git a/include/configs/warp7.h b/include/configs/warp7.h index 0afa75f..8c72178 100644 --- a/include/configs/warp7.h +++ b/include/configs/warp7.h @@ -16,7 +16,6 @@
#define CONFIG_MXC_UART_BASE UART1_IPS_BASE_ADDR
- /* Size of malloc() pool */ #define CONFIG_SYS_MALLOC_LEN (32 * SZ_1M)
diff --git a/include/configs/woodburn_common.h b/include/configs/woodburn_common.h index 631f273..af6cbe4 100644 --- a/include/configs/woodburn_common.h +++ b/include/configs/woodburn_common.h @@ -62,7 +62,6 @@ #define CONFIG_SYS_FSL_PMIC_I2C_ADDR 0x8 #define CONFIG_RTC_MC13XXX
- /* mmc driver */ #define CONFIG_MMC #define CONFIG_GENERIC_MMC @@ -108,7 +107,6 @@
- /* * Ethernet on SOC (FEC) */ diff --git a/include/configs/work_92105.h b/include/configs/work_92105.h index 5d8ac41..c59688c 100644 --- a/include/configs/work_92105.h +++ b/include/configs/work_92105.h @@ -107,7 +107,6 @@ #define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE
- #define CONFIG_AUTO_COMPLETE #define CONFIG_CMDLINE_EDITING #define CONFIG_VERSION_VARIABLE diff --git a/include/configs/x600.h b/include/configs/x600.h index 1cdb10d..265d710 100644 --- a/include/configs/x600.h +++ b/include/configs/x600.h @@ -129,7 +129,6 @@
#define CONFIG_BOOTDELAY 3
- /* * U-Boot Environment placing definitions. */ diff --git a/include/configs/x86-common.h b/include/configs/x86-common.h index 7cca864..c72ae72 100644 --- a/include/configs/x86-common.h +++ b/include/configs/x86-common.h @@ -194,7 +194,6 @@ #define CONFIG_BOOTP_GATEWAY #define CONFIG_BOOTP_HOSTNAME
- /* Default environment */ #define CONFIG_ROOTPATH "/opt/nfsroot" #define CONFIG_HOSTNAME x86 diff --git a/include/configs/xilinx-ppc.h b/include/configs/xilinx-ppc.h index ec26dc1..3ab8eab 100644 --- a/include/configs/xilinx-ppc.h +++ b/include/configs/xilinx-ppc.h @@ -12,7 +12,6 @@ #ifndef __CONFIG_XLX_H #define __CONFIG_XLX_H
- /* #define DEBUG #define ET_DEBUG diff --git a/include/configs/xpedite550x.h b/include/configs/xpedite550x.h index a84099a..3aa21eb 100644 --- a/include/configs/xpedite550x.h +++ b/include/configs/xpedite550x.h @@ -299,7 +299,6 @@ extern unsigned long get_board_ddr_clk(unsigned long dummy); #define CONFIG_SYS_PCIE1_IO_PHYS 0xe8000000 #define CONFIG_SYS_PCIE1_IO_SIZE 0x00800000 /* 8M */
- /* * Networking options */ diff --git a/include/configs/zmx25.h b/include/configs/zmx25.h index e66a7f4..72c6c0a 100644 --- a/include/configs/zmx25.h +++ b/include/configs/zmx25.h @@ -15,7 +15,6 @@ #define CONFIG_MX25 #define CONFIG_SYS_TEXT_BASE 0xA0000000
- #define CONFIG_SYS_TIMER_RATE 32768 #define CONFIG_SYS_TIMER_COUNTER \ (&((struct gpt_regs *)IMX_GPT1_BASE)->counter) @@ -83,7 +82,6 @@ */ #define CONFIG_CMD_FAT
- /* * USB */ diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index 39665ee..4f49ba8 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -389,5 +389,4 @@
#define CONFIG_SYS_UBOOT_START CONFIG_SYS_TEXT_BASE
- #endif /* __CONFIG_ZYNQ_COMMON_H */
On Sun, Apr 24, 2016 at 03:16:07PM -0400, Tom Rini wrote:
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line.
Signed-off-by: Tom Rini trini@konsulko.com
