[U-Boot] [PATCH v12 0/6] efi_loader: Code refactoring and improvement
This collects the patches previously sent to break up the very large functions in efi_loader into smaller pieces. Now that the other sandbox stuff is applied, perhaps it is time to apply these patches.
This also adds a few new patches to fix more recent breakages. Unfortunately we still cannot enable the efi loader tests since one of the tests fails. Thus we should expect additional failures to appear until that is resolved.
Changes in v12: - Rename image to image_prot - Update CPU nodes to comply with the DT spec
Changes in v11: - Add a new patch to drop setup_ok - Add a new patch to put CPUs under a cpu-bus node - Drop patches previously applied - Fix the EFI code that has since been added and relies on broken behaviour
Changes in v9: - Add comments to bootefi_test_prepare() about the memset()s
Changes in v7: - Drop patch "efi: Init the 'rows' and 'cols' variables" - Drop patches previous applied
Changes in v5: - Drop call to efi_init_obj_list() which is now done in do_bootefi() - Introduce load_options_path to specifyc U-Boot env var for load_options_path - Rebase to master
Changes in v4: - Rebase to master
Changes in v3: - Add new patch to rename bootefi_test_finish() to bootefi_run_finish() - Add new patch to split out test init/uninit into functions - Add patch to create a function to set up for running EFI code - Drop incorrect map_sysmem() in write_smbios_table()
Simon Glass (6): sandbox: Put CPUs under a cpu-bus node efi_loader: Drop setup_ok sandbox: smbios: Update to support sandbox efi: Split out test init/uninit into functions efi: Create a function to set up for running EFI code efi: Rename bootefi_test_finish() to bootefi_run_finish()
arch/sandbox/dts/test.dts | 38 +++++++-- cmd/bootefi.c | 135 ++++++++++++++++++++++---------- include/efi_selftest.h | 2 - lib/efi_loader/efi_smbios.c | 20 +++-- lib/efi_selftest/efi_selftest.c | 14 ++-- lib/smbios.c | 32 ++++++-- 6 files changed, 169 insertions(+), 72 deletions(-)
The CPU uclass expects that all CPUs have a parent device which is a cpu-bus. Fix up the sandbox test DT to follow this convention. This allow the code in smbios_write_type4_dm() to work, since it calls dev_get_parent_platdata() on each CPU.
Changes in v12: - Update CPU nodes to comply with the DT spec
Changes in v11: - Add a new patch to put CPUs under a cpu-bus node
Changes in v9: None Changes in v7: None Changes in v5: None Changes in v4: None Changes in v3: None
arch/sandbox/dts/test.dts | 38 ++++++++++++++++++++++++++++++-------- 1 file changed, 30 insertions(+), 8 deletions(-)
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index 57e0dd76631..bec912f917f 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -344,16 +344,38 @@ mbox-names = "other", "test"; };
- cpu-test1 { - compatible = "sandbox,cpu_sandbox"; - }; + cpus { + #address-cells = <1>; + #size-cells = <0>;
- cpu-test2 { - compatible = "sandbox,cpu_sandbox"; - }; + cpu@0 { + reg = <0>; + compatible = "sandbox,cpu_sandbox"; + device-type = "cpu";
- cpu-test3 { - compatible = "sandbox,cpu_sandbox"; + /* + * These are not used by sandbox, but are required by + * the latest DT spec (v0.2). + */ + clock-frequency = <0>; + timebase-frequency = <0>; + }; + + cpu@1 { + reg = <1>; + compatible = "sandbox,cpu_sandbox"; + device-type = "cpu"; + clock-frequency = <0>; + timebase-frequency = <0>; + }; + + cpu@2 { + reg = <2>; + compatible = "sandbox,cpu_sandbox"; + device-type = "cpu"; + clock-frequency = <0>; + timebase-frequency = <0>; + }; };
misc-test {
Thanks, applied to efi-next
Alex
This patch breaks the built-in unit tests:
=> ut dm cpu Test: dm_test_cpu: cpu.c test/dm/cpu.c:28, dm_test_cpu(): 0 == uclass_get_device_by_name(UCLASS_CPU, "cpu-test1", &dev): Expected 0, got -19 Test: dm_test_cpu: cpu.c (flat tree) test/dm/cpu.c:28, dm_test_cpu(): 0 == uclass_get_device_by_name(UCLASS_CPU, "cpu-test1", &dev): Expected 0, got -19 Failures: 2
I'll remove it from my queue again.
Alex
Hi Alex,
Yes unfortunately there was a revert on master which affected this I think.
I can pick this one up once things land.
On 15.11.18 21:01, Simon Glass wrote:
Hi Alex,
I'd appreciate that, yes, thanks :).
Alex
This value is stored in data which appears to be read-only with sandbox on my Ubuntu 18.04 machine. In any case it is not good practice to store run-time data in a build-time linker list.
The value does not seem to be that useful, since tests that fail to setup are likely to fail to run also. Let's drop it for now.
Changes in v12: None Changes in v11: - Add a new patch to drop setup_ok
include/efi_selftest.h | 2 -- lib/efi_selftest/efi_selftest.c | 14 +++++++------- 2 files changed, 7 insertions(+), 9 deletions(-)
diff --git a/include/efi_selftest.h b/include/efi_selftest.h index 56beac305ec..49d3d6d0b47 100644 --- a/include/efi_selftest.h +++ b/include/efi_selftest.h @@ -129,7 +129,6 @@ u16 efi_st_get_key(void); * @setup: set up the unit test * @teardown: tear down the unit test * @execute: execute the unit test - * @setup_ok: setup was successful (set at runtime) * @on_request: test is only executed on request */ struct efi_unit_test { @@ -139,7 +138,6 @@ struct efi_unit_test { const struct efi_system_table *systable); int (*execute)(void); int (*teardown)(void); - int setup_ok; bool on_request; };
diff --git a/lib/efi_selftest/efi_selftest.c b/lib/efi_selftest/efi_selftest.c index dd338db687e..dfd11be2302 100644 --- a/lib/efi_selftest/efi_selftest.c +++ b/lib/efi_selftest/efi_selftest.c @@ -74,20 +74,20 @@ void efi_st_exit_boot_services(void) */ static int setup(struct efi_unit_test *test, unsigned int *failures) { - if (!test->setup) { - test->setup_ok = EFI_ST_SUCCESS; + int ret; + + if (!test->setup) return EFI_ST_SUCCESS; - } efi_st_printc(EFI_LIGHTBLUE, "\nSetting up '%s'\n", test->name); - test->setup_ok = test->setup(handle, systable); - if (test->setup_ok != EFI_ST_SUCCESS) { + ret = test->setup(handle, systable); + if (ret) { efi_st_error("Setting up '%s' failed\n", test->name); ++*failures; } else { efi_st_printc(EFI_LIGHTGREEN, "Setting up '%s' succeeded\n", test->name); } - return test->setup_ok; + return ret; }
/* @@ -197,7 +197,7 @@ void efi_st_do_tests(const u16 *testname, unsigned int phase, continue; if (steps & EFI_ST_SETUP) setup(test, failures); - if (steps & EFI_ST_EXECUTE && test->setup_ok == EFI_ST_SUCCESS) + if (steps & EFI_ST_EXECUTE) execute(test, failures); if (steps & EFI_ST_TEARDOWN) teardown(test, failures);
I think I already have this as "efi_selftest: do not write to linker generated array" in my queue?
Alex
Hi Alex,
Yes that's right, we can drop this.
I still don't really understand why we have this write-to-rwdata problem.
At present this code casts addresses to pointers so cannot be used with sandbox. Update it to use mapmem instead.
Changes in v12: None Changes in v11: - Fix the EFI code that has since been added and relies on broken behaviour
Changes in v9: None Changes in v7: None Changes in v5: None Changes in v4: None Changes in v3: - Drop incorrect map_sysmem() in write_smbios_table()
lib/efi_loader/efi_smbios.c | 20 +++++++++++++------- lib/smbios.c | 32 ++++++++++++++++++++++++-------- 2 files changed, 37 insertions(+), 15 deletions(-)
diff --git a/lib/efi_loader/efi_smbios.c b/lib/efi_loader/efi_smbios.c index 38e42fa2432..a81488495e2 100644 --- a/lib/efi_loader/efi_smbios.c +++ b/lib/efi_loader/efi_smbios.c @@ -7,6 +7,7 @@
#include <common.h> #include <efi_loader.h> +#include <mapmem.h> #include <smbios.h>
static const efi_guid_t smbios_guid = SMBIOS_TABLE_GUID; @@ -19,17 +20,19 @@ static const efi_guid_t smbios_guid = SMBIOS_TABLE_GUID; efi_status_t efi_smbios_register(void) { /* Map within the low 32 bits, to allow for 32bit SMBIOS tables */ - u64 dmi = U32_MAX; + u64 dmi_addr = U32_MAX; efi_status_t ret; + void *dmi;
/* Reserve 4kiB page for SMBIOS */ ret = efi_allocate_pages(EFI_ALLOCATE_MAX_ADDRESS, - EFI_RUNTIME_SERVICES_DATA, 1, &dmi); + EFI_RUNTIME_SERVICES_DATA, 1, &dmi_addr);
if (ret != EFI_SUCCESS) { /* Could not find space in lowmem, use highmem instead */ ret = efi_allocate_pages(EFI_ALLOCATE_ANY_PAGES, - EFI_RUNTIME_SERVICES_DATA, 1, &dmi); + EFI_RUNTIME_SERVICES_DATA, 1, + &dmi_addr);
if (ret != EFI_SUCCESS) return ret; @@ -39,11 +42,14 @@ efi_status_t efi_smbios_register(void) * Generate SMBIOS tables - we know that efi_allocate_pages() returns * a 4k-aligned address, so it is safe to assume that * write_smbios_table() will write the table at that address. + * + * Note that on sandbox, efi_allocate_pages() unfortunately returns a + * pointer even though it uses a uint64_t type. Convert it. */ - assert(!(dmi & 0xf)); - write_smbios_table(dmi); + assert(!(dmi_addr & 0xf)); + dmi = (void *)(uintptr_t)dmi_addr; + write_smbios_table(map_to_sysmem(dmi));
/* And expose them to our EFI payload */ - return efi_install_configuration_table(&smbios_guid, - (void *)(uintptr_t)dmi); + return efi_install_configuration_table(&smbios_guid, dmi); } diff --git a/lib/smbios.c b/lib/smbios.c index 326eb00230d..87109d431a2 100644 --- a/lib/smbios.c +++ b/lib/smbios.c @@ -6,6 +6,7 @@ */
#include <common.h> +#include <mapmem.h> #include <smbios.h> #include <tables_csum.h> #include <version.h> @@ -72,9 +73,10 @@ static int smbios_string_table_len(char *start)
static int smbios_write_type0(ulong *current, int handle) { - struct smbios_type0 *t = (struct smbios_type0 *)*current; + struct smbios_type0 *t; int len = sizeof(struct smbios_type0);
+ t = map_sysmem(*current, len); memset(t, 0, sizeof(struct smbios_type0)); fill_smbios_header(t, SMBIOS_BIOS_INFORMATION, len, handle); t->vendor = smbios_add_string(t->eos, "U-Boot"); @@ -101,16 +103,18 @@ static int smbios_write_type0(ulong *current, int handle)
len = t->length + smbios_string_table_len(t->eos); *current += len; + unmap_sysmem(t);
return len; }
static int smbios_write_type1(ulong *current, int handle) { - struct smbios_type1 *t = (struct smbios_type1 *)*current; + struct smbios_type1 *t; int len = sizeof(struct smbios_type1); char *serial_str = env_get("serial#");
+ t = map_sysmem(*current, len); memset(t, 0, sizeof(struct smbios_type1)); fill_smbios_header(t, SMBIOS_SYSTEM_INFORMATION, len, handle); t->manufacturer = smbios_add_string(t->eos, CONFIG_SMBIOS_MANUFACTURER); @@ -122,15 +126,17 @@ static int smbios_write_type1(ulong *current, int handle)
return len; }
static int smbios_write_type2(ulong *current, int handle) { - struct smbios_type2 *t = (struct smbios_type2 *)*current; + struct smbios_type2 *t; int len = sizeof(struct smbios_type2);
+ t = map_sysmem(*current, len); memset(t, 0, sizeof(struct smbios_type2)); fill_smbios_header(t, SMBIOS_BOARD_INFORMATION, len, handle); t->manufacturer = smbios_add_string(t->eos, CONFIG_SMBIOS_MANUFACTURER); @@ -140,15 +146,17 @@ static int smbios_write_type2(ulong *current, int handle)
return len; }
static int smbios_write_type3(ulong *current, int handle) { - struct smbios_type3 *t = (struct smbios_type3 *)*current; + struct smbios_type3 *t; int len = sizeof(struct smbios_type3);
+ t = map_sysmem(*current, len); memset(t, 0, sizeof(struct smbios_type3)); fill_smbios_header(t, SMBIOS_SYSTEM_ENCLOSURE, len, handle); t->manufacturer = smbios_add_string(t->eos, CONFIG_SMBIOS_MANUFACTURER); @@ -160,6 +168,7 @@ static int smbios_write_type3(ulong *current, int handle)
return len; } @@ -198,9 +207,10 @@ static void smbios_write_type4_dm(struct smbios_type4 *t)
static int smbios_write_type4(ulong *current, int handle) { - struct smbios_type4 *t = (struct smbios_type4 *)*current; + struct smbios_type4 *t; int len = sizeof(struct smbios_type4);
+ t = map_sysmem(*current, len); memset(t, 0, sizeof(struct smbios_type4)); fill_smbios_header(t, SMBIOS_PROCESSOR_INFORMATION, len, handle); t->processor_type = SMBIOS_PROCESSOR_TYPE_CENTRAL; @@ -214,32 +224,37 @@ static int smbios_write_type4(ulong *current, int handle)
return len; }
static int smbios_write_type32(ulong *current, int handle) { - struct smbios_type32 *t = (struct smbios_type32 *)*current; + struct smbios_type32 *t; int len = sizeof(struct smbios_type32);
+ t = map_sysmem(*current, len); memset(t, 0, sizeof(struct smbios_type32)); fill_smbios_header(t, SMBIOS_SYSTEM_BOOT_INFORMATION, len, handle);
return len; }
static int smbios_write_type127(ulong *current, int handle) { - struct smbios_type127 *t = (struct smbios_type127 *)*current; + struct smbios_type127 *t; int len = sizeof(struct smbios_type127);
+ t = map_sysmem(*current, len); memset(t, 0, sizeof(struct smbios_type127)); fill_smbios_header(t, SMBIOS_END_OF_TABLE, len, handle);
return len; } @@ -268,7 +283,7 @@ ulong write_smbios_table(ulong addr) /* 16 byte align the table address */ addr = ALIGN(addr, 16);
- se = (struct smbios_entry *)(uintptr_t)addr; + se = map_sysmem(addr, sizeof(struct smbios_entry)); memset(se, 0, sizeof(struct smbios_entry));
addr += sizeof(struct smbios_entry); @@ -298,6 +313,7 @@ ulong write_smbios_table(ulong addr) isize = sizeof(struct smbios_entry) - SMBIOS_INTERMEDIATE_OFFSET; se->intermediate_checksum = table_compute_checksum(istart, isize); se->checksum = table_compute_checksum(se, sizeof(struct smbios_entry)); + unmap_sysmem(se);
return addr; }
void *dmi;
&dmi_addr);
*/* pointer even though it uses a uint64_t type. Convert it.
- return efi_install_configuration_table(&smbios_guid, dmi);
unmap_sysmem(t);
return len;
unmap_sysmem(t);
return len;
unmap_sysmem(t);
return len;
unmap_sysmem(t);
return len;
unmap_sysmem(t);
return len;
*current += len;
unmap_sysmem(t);
return len;
*current += len;
unmap_sysmem(t);
return len;
This will not work. In this function, you have a variable called "tables" which now gets an "address" rather than a pointer. It writes that value to se->struct_table_address later on though which is shared with (binary) payloads which expect it to be a pointer.
Please convert that one as well :).
Alex
unmap_sysmem(se);
return addr;
The functions in bootefi are very long because they mix high-level code and control with the low-level implementation. To help with this, create functions which handle preparing for running the test and cleaning up afterwards.
Also shorten the awfully long variable names here.
Changes in v11: None Changes in v9: - Add comments to bootefi_test_prepare() about the memset()s
Changes in v7: None Changes in v5: - Drop call to efi_init_obj_list() which is now done in do_bootefi()
Changes in v4: None Changes in v3: - Add new patch to split out test init/uninit into functions
cmd/bootefi.c | 85 +++++++++++++++++++++++++++++++++++++++------------ 1 file changed, 65 insertions(+), 20 deletions(-)
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index 4d68d807480..0dd18d594d5 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -455,6 +455,64 @@ exit: return ret; }
+#ifdef CONFIG_CMD_BOOTEFI_SELFTEST +/** + * bootefi_test_prepare() - prepare to run an EFI test + * + * This sets things up so we can call EFI functions. This involves preparing + * the 'gd' pointer and setting up the load ed image data structures. + * + * @image: Pointer to a struct which will hold the loaded image info. + * This struct will be inited by this function before use. + * @obj: Pointer to a struct which will hold the loaded image object + * This struct will be inited by this function before use. + * @path: File path to the test being run (often just the test name with a + * backslash before it + * @test_func: Address of the test function that is being run + * @return 0 if OK, -ve on error + */ +static efi_status_t bootefi_test_prepare(struct efi_loaded_image **imagep, + struct efi_loaded_image_obj **objp, + const char *path, ulong test_func) +{ + efi_status_t r; + + /* Construct a dummy device path */ + bootefi_device_path = efi_dp_from_mem(EFI_RESERVED_MEMORY_TYPE, + (uintptr_t)test_func, + (uintptr_t)test_func); + bootefi_image_path = efi_dp_from_file(NULL, 0, path); + r = efi_setup_loaded_image(bootefi_device_path, bootefi_image_path, + objp, imagep); + if (r) + return r; + /* + * gd lives in a fixed register which may get clobbered while we execute + * the payload. So save it here and restore it on every callback entry + */ + efi_save_gd(); + + /* Transfer environment variable efi_selftest as load options */ + set_load_options(*imagep, "efi_selftest"); + + return 0; +} + +/** + * bootefi_test_finish() - finish up after running an EFI test + * + * @image: Pointer to a struct which holds the loaded image info + * @obj: Pointer to a struct which holds the loaded image object + */ +static void bootefi_test_finish(struct efi_loaded_image *image, + struct efi_loaded_image_obj *obj) +{ + efi_restore_gd(); + free(image->load_options); + efi_delete_handle(&obj->parent); +} +#endif /* CONFIG_CMD_BOOTEFI_SELFTEST */ + static int do_bootefi_bootmgr_exec(void) { struct efi_device_path *device_path, *file_path; @@ -527,29 +585,16 @@ static int do_bootefi(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) #endif #ifdef CONFIG_CMD_BOOTEFI_SELFTEST if (!strcmp(argv[1], "selftest")) { - struct efi_loaded_image_obj *image_handle; - struct efi_loaded_image *loaded_image_info; - - /* Construct a dummy device path. */ - bootefi_device_path = efi_dp_from_mem(EFI_RESERVED_MEMORY_TYPE, - (uintptr_t)&efi_selftest, - (uintptr_t)&efi_selftest); - bootefi_image_path = efi_dp_from_file(NULL, 0, "\selftest"); - - r = efi_setup_loaded_image(bootefi_device_path, - bootefi_image_path, &image_handle, - &loaded_image_info); - if (r != EFI_SUCCESS) + struct efi_loaded_image_obj *obj; + struct efi_loaded_image *image_prot; + + if (bootefi_test_prepare(&image_prot, &obj, "\selftest", + (uintptr_t)&efi_selftest)) return CMD_RET_FAILURE;
- efi_save_gd(); - /* Transfer environment variable efi_selftest as load options */ - set_load_options(loaded_image_info, "efi_selftest"); /* Execute the test */ - r = efi_selftest(image_handle, &systab); - efi_restore_gd(); - free(loaded_image_info->load_options); - efi_delete_handle(&image_handle->parent); + r = efi_selftest(obj, &systab); + bootefi_test_finish(image_prot, obj); return r != EFI_SUCCESS; } else #endif
This touches selftest, so I'd like to see at least an ack from Heinrich.
I personally would just extract all of the if (selftest) part into a function and then run your later cleanup over it. The end result should still be quite readable.
Alex
Changes in v12:
- bootefi_test_prepare() - prepare to run an EFI test
- This sets things up so we can call EFI functions. This involves preparing
- the 'gd' pointer and setting up the load ed image data structures.
- @image: Pointer to a struct which will hold the loaded image info.
- This struct will be inited by this function before use.
- @obj: Pointer to a struct which will hold the loaded image object
- @path: File path to the test being run (often just the test name with a
- backslash before it
- @test_func: Address of the test function that is being run
- @return 0 if OK, -ve on error
- efi_status_t r;
- /* Construct a dummy device path */
- bootefi_image_path = efi_dp_from_file(NULL, 0, path);
- r = efi_setup_loaded_image(bootefi_device_path, bootefi_image_path,
objp, imagep);
- if (r)
return r;
- efi_save_gd();
- set_load_options(*imagep, "efi_selftest");
- bootefi_test_finish() - finish up after running an EFI test
- @image: Pointer to a struct which holds the loaded image info
- @obj: Pointer to a struct which holds the loaded image object
- efi_restore_gd();
- free(image->load_options);
- efi_delete_handle(&obj->parent);
bootefi_image_path = efi_dp_from_file(NULL, 0, "\\selftest");
if (bootefi_test_prepare(&image_prot, &obj, "\\selftest",
efi_save_gd();
/* Execute the test */set_load_options(loaded_image_info, "efi_selftest");
efi_restore_gd();
return r != EFI_SUCCESS; } elsebootefi_test_finish(image_prot, obj);
#endif
There is still duplicated code in efi_loader for tests and normal operation.
Add a new bootefi_run_prepare() function which holds common code used to set up U-Boot to run EFI code. Make use of this from the existing bootefi_test_prepare() function, as well as do_bootefi_exec().
Also shorten a few variable names.
Changes in v12: None Changes in v11: None Changes in v9: None Changes in v7: None Changes in v5: - Drop call to efi_init_obj_list() which is now done in do_bootefi() - Introduce load_options_path to specifyc U-Boot env var for load_options_path
Changes in v3: - Add patch to create a function to set up for running EFI code
cmd/bootefi.c | 85 +++++++++++++++++++++++++++++---------------------- 1 file changed, 48 insertions(+), 37 deletions(-)
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index 0dd18d594d5..779c1f63fa8 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -327,6 +327,30 @@ static efi_status_t efi_install_fdt(ulong fdt_addr) return ret; }
+static efi_status_t bootefi_run_prepare(const char *load_options_path, + struct efi_device_path *device_path, + struct efi_device_path *image_path, + struct efi_loaded_image **imagep, + struct efi_loaded_image_obj **objp) +{ + efi_status_t ret; + + ret = efi_setup_loaded_image(device_path, image_path, objp, imagep); + if (ret != EFI_SUCCESS) + return ret; + + /* + * gd lives in a fixed register which may get clobbered while we execute + * the payload. So save it here and restore it on every callback entry + */ + efi_save_gd(); + + /* Transfer environment variable as load options */ + set_load_options(*imagep, load_options_path); + + return 0; +} + /** * do_bootefi_exec() - execute EFI binary * @@ -345,8 +369,8 @@ static efi_status_t do_bootefi_exec(void *efi, efi_handle_t mem_handle = NULL; struct efi_device_path *memdp = NULL; efi_status_t ret; - struct efi_loaded_image_obj *image_handle = NULL; - struct efi_loaded_image *loaded_image_info = NULL; + struct efi_loaded_image_obj *obj = NULL; + struct efi_loaded_image *image = NULL;
EFIAPI efi_status_t (*entry)(efi_handle_t image_handle, struct efi_system_table *st); @@ -376,15 +400,13 @@ static efi_status_t do_bootefi_exec(void *efi, assert(device_path && image_path); }
- ret = efi_setup_loaded_image(device_path, image_path, &image_handle, - &loaded_image_info); - if (ret != EFI_SUCCESS) - goto exit; + ret = bootefi_run_prepare("bootargs", device_path, image_path, + &image, &obj); + if (ret) + return ret;
- /* Transfer environment variable bootargs as load options */ - set_load_options(loaded_image_info, "bootargs"); /* Load the EFI payload */ - entry = efi_load_pe(image_handle, efi, loaded_image_info); + entry = efi_load_pe(obj, efi, image); if (!entry) { ret = EFI_LOAD_ERROR; goto exit; @@ -392,10 +414,9 @@ static efi_status_t do_bootefi_exec(void *efi,
if (memdp) { struct efi_device_path_memory *mdp = (void *)memdp; - mdp->memory_type = loaded_image_info->image_code_type; - mdp->start_address = (uintptr_t)loaded_image_info->image_base; - mdp->end_address = mdp->start_address + - loaded_image_info->image_size; + mdp->memory_type = image->image_code_type; + mdp->start_address = (uintptr_t)image->image_base; + mdp->end_address = mdp->start_address + image->image_size; }
/* we don't support much: */ @@ -405,8 +426,8 @@ static efi_status_t do_bootefi_exec(void *efi, /* Call our payload! */ debug("%s:%d Jumping to 0x%lx\n", __func__, __LINE__, (long)entry);
- if (setjmp(&image_handle->exit_jmp)) { - ret = image_handle->exit_status; + if (setjmp(&obj->exit_jmp)) { + ret = obj->exit_status; goto exit; }
@@ -418,7 +439,7 @@ static efi_status_t do_bootefi_exec(void *efi,
/* Move into EL2 and keep running there */ armv8_switch_to_el2((ulong)entry, - (ulong)image_handle, + (ulong)obj, (ulong)&systab, 0, (ulong)efi_run_in_el2, ES_TO_AARCH64);
@@ -435,7 +456,7 @@ static efi_status_t do_bootefi_exec(void *efi, secure_ram_addr(_do_nonsec_entry)( efi_run_in_hyp, (uintptr_t)entry, - (uintptr_t)image_handle, + (uintptr_t)obj, (uintptr_t)&systab);
/* Should never reach here, efi exits with longjmp */ @@ -443,12 +464,12 @@ static efi_status_t do_bootefi_exec(void *efi, } #endif
- ret = efi_do_enter(image_handle, &systab, entry); + ret = efi_do_enter(obj, &systab, entry);
exit: /* image has returned, loaded-image obj goes *poof*: */ - if (image_handle) - efi_delete_handle(&image_handle->parent); + if (obj) + efi_delete_handle(&obj->parent); if (mem_handle) efi_delete_handle(mem_handle);
@@ -469,33 +490,22 @@ exit: * @path: File path to the test being run (often just the test name with a * backslash before it * @test_func: Address of the test function that is being run + * @load_options_path: U-Boot environment variable to use as load options * @return 0 if OK, -ve on error */ static efi_status_t bootefi_test_prepare(struct efi_loaded_image **imagep, struct efi_loaded_image_obj **objp, - const char *path, ulong test_func) + const char *path, ulong test_func, + const char *load_options_path) { - efi_status_t r; - /* Construct a dummy device path */ bootefi_device_path = efi_dp_from_mem(EFI_RESERVED_MEMORY_TYPE, (uintptr_t)test_func, (uintptr_t)test_func); bootefi_image_path = efi_dp_from_file(NULL, 0, path); - r = efi_setup_loaded_image(bootefi_device_path, bootefi_image_path, - objp, imagep); - if (r) - return r; - /* - * gd lives in a fixed register which may get clobbered while we execute - * the payload. So save it here and restore it on every callback entry - */ - efi_save_gd(); - - /* Transfer environment variable efi_selftest as load options */ - set_load_options(*imagep, "efi_selftest");
- return 0; + return bootefi_run_prepare(load_options_path, bootefi_device_path, + bootefi_image_path, imagep, objp); }
/** @@ -589,7 +599,8 @@ static int do_bootefi(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) struct efi_loaded_image *image_prot;
if (bootefi_test_prepare(&image_prot, &obj, "\selftest", - (uintptr_t)&efi_selftest)) + (uintptr_t)&efi_selftest, + "efi_selftest")) return CMD_RET_FAILURE;
Changes in v4:
- Rebase to master
Changes in v3:
- efi_status_t ret;
- ret = efi_setup_loaded_image(device_path, image_path, objp, imagep);
return ret;
- efi_save_gd();
- /* Transfer environment variable as load options */
- set_load_options(*imagep, load_options_path);
- do_bootefi_exec() - execute EFI binary
This is called image handle in the UEFI spec, so I'd prefer we keep that name.
Same here.
Also, as a general rule of thumb, it's not good practice to do renames (something you could for example reproduce with sed or coccinelle) in the same patch as something else - code movement in your case. It makes review pretty hard and makes life harder on you to rebase the patch.
In a nutshell: I like the code movement into a function, that's a nice cleanup. I don't like the variable renames :). They make it confusing for people that want to know what these variables mean in context of an executed application.
Alex
goto exit;
- ret = bootefi_run_prepare("bootargs", device_path, image_path,
&image, &obj);
- if (ret)
return ret;
- entry = efi_load_pe(obj, efi, image); if (!entry) { ret = EFI_LOAD_ERROR; goto exit;
- if (setjmp(&obj->exit_jmp)) {
goto exit; }ret = obj->exit_status;
- ret = efi_do_enter(obj, &systab, entry);
- if (image_handle)
- if (obj)
if (mem_handle) efi_delete_handle(mem_handle);efi_delete_handle(&obj->parent);
- @load_options_path: U-Boot environment variable to use as load options
efi_status_t r;
objp, imagep);
if (r)
return r;
efi_save_gd();
- return bootefi_run_prepare(load_options_path, bootefi_device_path,
This function can be used from do_bootefi_exec() so that we use mostly the same code for a normal EFI application and an EFI test.
Rename the function and use it in both places.
Changes in v12: None Changes in v11: - Drop patches previously applied
Changes in v9: None Changes in v7: - Drop patch "efi: Init the 'rows' and 'cols' variables" - Drop patches previous applied
Changes in v5: - Rebase to master
cmd/bootefi.c | 33 ++++++++++++++++----------------- 1 file changed, 16 insertions(+), 17 deletions(-)
diff --git a/cmd/bootefi.c b/cmd/bootefi.c index 779c1f63fa8..7a077995dc5 100644 --- a/cmd/bootefi.c +++ b/cmd/bootefi.c @@ -351,6 +351,20 @@ static efi_status_t bootefi_run_prepare(const char *load_options_path, return 0; }
+/** + * bootefi_run_finish() - finish up after running an EFI test + * + * @image: Pointer to a struct which holds the loaded image info + * @obj: Pointer to a struct which holds the loaded image object + */ +static void bootefi_run_finish(struct efi_loaded_image *image, + struct efi_loaded_image_obj *obj) +{ + efi_restore_gd(); + free(image->load_options); + efi_delete_handle(&obj->parent); +} + /** * do_bootefi_exec() - execute EFI binary * @@ -468,8 +482,7 @@ static efi_status_t do_bootefi_exec(void *efi,
exit: /* image has returned, loaded-image obj goes *poof*: */ - if (obj) - efi_delete_handle(&obj->parent); + bootefi_run_finish(image, obj); if (mem_handle) efi_delete_handle(mem_handle);
@@ -507,20 +520,6 @@ static efi_status_t bootefi_test_prepare(struct efi_loaded_image **imagep, return bootefi_run_prepare(load_options_path, bootefi_device_path, bootefi_image_path, imagep, objp); } - -/** - * bootefi_test_finish() - finish up after running an EFI test - * - * @image: Pointer to a struct which holds the loaded image info - * @obj: Pointer to a struct which holds the loaded image object - */ -static void bootefi_test_finish(struct efi_loaded_image *image, - struct efi_loaded_image_obj *obj) -{ - efi_restore_gd(); - free(image->load_options); - efi_delete_handle(&obj->parent); -} #endif /* CONFIG_CMD_BOOTEFI_SELFTEST */
static int do_bootefi_bootmgr_exec(void) @@ -605,7 +604,7 @@ static int do_bootefi(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[])
/* Execute the test */ r = efi_selftest(obj, &systab); - bootefi_test_finish(image_prot, obj); + bootefi_run_finish(image_prot, obj); return r != EFI_SUCCESS; } else #endif
Changes in v12:
Any comments / reviews on this please?
Alexander Graf
