[U-Boot] [PULL] efi patch queue 2017-07-29
Hi Tom,
This is my current patch queue for efi. Please pull.
Alex
The following changes since commit 8d3a25685e4aac7070365a2b3c53c2c81b27930f:
Merge git://git.denx.de/u-boot-dm (2017-07-11 20:28:46 -0400)
git://github.com/agraf/u-boot.git tags/signed-efi-next
for you to fetch changes up to af65db85b82b161f037e0889ae58bf461217b3f1:
efi_loader: indent entry/exit prints to show nesting level (2017-07-29 00:18:46 +0200)
---------------------------------------------------------------- Patch queue for efi - 2017-07-29
A lot of EFI greatness this time around. Thanks a lot to the two amazing new contributors
Heinrich Schuchardt and Rob Clark
we now gain
- stable objects across multiple bootefi invocations - fixes for shim - fixes for ipxe - protocol installation - device path conversion to/from text - working "lsefi" support in grub - working notifiers - various bug fixes
---------------------------------------------------------------- Alexander Graf (2): efi_loader: Improve install_configuration_table efi_loader: Fix configuration table override
Heinrich Schuchardt (1): efi_loader: initalize EFI object list only once
Rob Clark (15): efi_loader: EFI file paths should be DOS style efi_loader: move guidcmp to header efi_loader: gop: fixes for CONFIG_DM_VIDEO without CONFIG_LCD efi_loader: workaround for grub lsefi bug efi_loader: log EFI return values too efi_loader: add helper macro to construct protocol objects efi_loader: expose protocols via GUID efi_loader: remove double EFI_EXIT() with efi_unsupported efi_loader: remove more double EFI_EXIT() in efi_disk.c efi_loader: fix bug in efi_get_memory_map efi_loader: add some missing breaks efi_loader: only evaluate EFI_EXIT()'s ret once efi_loader: Add an EFI_CALL() macro efi_loader: add checking for incorrect use of EFI_ENTRY/EXIT efi_loader: indent entry/exit prints to show nesting level
xypron.glpk@gmx.de (30): efi_loader: refactor efi_open_protocol efi_loader: efi_open_protocol: parameter checks efi_loader: implement InstallProtocolInterface efi_loader: implement UninstallProtocolInterface efi_loader: refactor efi_install_protocol_interface efi_loader: refactor efi_uninstall_protocol_interface efi_loader: implement InstallMultipleProtocolInterfaces efi_loader: refactor efi_locate_handle efi_loader: implement LocateHandleBuffer efi_loader: provide a sufficient number of protocols efi_loader: reimplement efi_locate_protocol efi_loader: implement EFI_DEVICE_PATH_TO_TEXT_PROTOCOL bootefi: allow return without EFI_BOOT_SERVICES.Exit efi_loader: define all known status codes efi_loader: provide meaningful status code efi_loader: disk: iterate only over valid block devices efi_memory: avoid NULL dereference in efi_free_pool efi_loader: use struct efi_event * instead of void * efi_loader: implement multiple event support efi_loader: correct size for tpl level efi_loader: refactor efi_create_event efi_loader: refactor efi_set_timer efi_console: set up events efi_loader: correctly implement 100ns conversion efi_memory: do parameter checks first efi_memory: return MapKey efi_loader: implement ConvertDeviceNodeToText efi_console: use EFIAPI for callback functions efi_loader: parameter types for CreateEvent, SetTimer efi_loader: implement ProtocolsPerHandle
cmd/bootefi.c | 135 +++--- include/efi.h | 50 ++- include/efi_api.h | 86 +++- include/efi_loader.h | 125 ++++-- lib/efi_loader/Makefile | 3 +- lib/efi_loader/efi_boottime.c | 706 +++++++++++++++++++++++++------ lib/efi_loader/efi_console.c | 55 ++- lib/efi_loader/efi_device_path_to_text.c | 130 ++++++ lib/efi_loader/efi_disk.c | 39 +- lib/efi_loader/efi_gop.c | 9 +- lib/efi_loader/efi_image_loader.c | 8 - lib/efi_loader/efi_memory.c | 11 +- lib/efi_loader/efi_net.c | 30 +- 13 files changed, 1057 insertions(+), 330 deletions(-) create mode 100644 lib/efi_loader/efi_device_path_to_text.c
Otherwise we get a warning about assignment about making a pointer from int without a cast.
Cc: Alexander Graf agraf@suse.de Signed-off-by: Tom Rini trini@konsulko.com --- lib/efi_loader/efi_gop.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/lib/efi_loader/efi_gop.c b/lib/efi_loader/efi_gop.c index 806cfaeea181..bd7ccccb93ff 100644 --- a/lib/efi_loader/efi_gop.c +++ b/lib/efi_loader/efi_gop.c @@ -131,7 +131,7 @@ int efi_gop_register(void) struct efi_gop_obj *gopobj; u32 bpix, col, row; u64 fb_base, fb_size; - void *fb; + uintptr_t *fb;
#ifdef CONFIG_DM_VIDEO struct udevice *vdev; @@ -155,7 +155,7 @@ int efi_gop_register(void) row = panel_info.vl_row; fb_base = gd->fb_base; fb_size = lcd_get_size(&line_len); - fb = gd->fb_base; + fb = (uintptr_t *)gd->fb_base; #endif
switch (bpix) {
From: Tom Rini trini@konsulko.com Date: Sat, 29 Jul 2017 11:43:21 -0400
That (uintptr_t *) cast makes no sense. Either leave the member as a "void *" and use a (void *) cast, or change it to uintptr_t and use a (uintptr_t) cast.
Cheers,
Mark
- void *fb;
- uintptr_t *fb;
- fb = gd->fb_base;
- fb = (uintptr_t *)gd->fb_base;
#endif
switch (bpix) {
1.9.1
On Sat, Jul 29, 2017 at 12:31:02AM +0200, Alexander Graf wrote:
Hi Tom,
Alex
Alexander Graf
Mark Kettenis
