[U-Boot] [PATCH] arm/ls102xa: Add STANDBY implement based on PSCI
Base on PSCI services, implement CPU_SUSPEND for ls102xa platform.
Signed-off-by: Wang Dongsheng dongsheng.wang@freescale.com
diff --git a/arch/arm/cpu/armv7/ls102xa/psci.S b/arch/arm/cpu/armv7/ls102xa/psci.S index cf5cd48..1bc7e45 100644 --- a/arch/arm/cpu/armv7/ls102xa/psci.S +++ b/arch/arm/cpu/armv7/ls102xa/psci.S @@ -14,10 +14,13 @@
#define SCFG_CORE0_SFT_RST 0x130 #define SCFG_CORESRENCR 0x204 +#define SCFG_CLUSTERPMCR 0x904
#define DCFG_CCSR_BRR 0x0E4 #define DCFG_CCSR_SCRATCHRW1 0x200
+#define RCPM_POWMGTCSR 0x130 + .pushsection ._secure.text, "ax"
.arch_extension sec @@ -111,6 +114,41 @@ psci_cpu_off: 1: wfi b 1b
+.globl psci_cpu_suspend +psci_cpu_suspend: + push {lr} + + @ Get Power State + mov r0, r2, lsr #16 + ands r0, r0, #1 + bne out + + @ STANDBY Power State + @ Get RCPM base address + movw r0, #(CONFIG_SYS_FSL_RCPM_ADDR & 0xffff) + movt r0, #(CONFIG_SYS_FSL_RCPM_ADDR >> 16) + + @ Get POWMGTCSR + ldr r1, [r0, #RCPM_POWMGTCSR] + rev r1, r1 + + movw r2, #0 + movt r2, #(1 << 4) + + orr r1, r1, r2 + rev r1, r1 + str r1, [r0, #RCPM_POWMGTCSR] + + dsb + wfi + +out: + @ Return + mov r0, #ARM_PSCI_RET_SUCCESS + + pop {lr} + bx lr + .globl psci_arch_init psci_arch_init: mov r6, lr @@ -121,6 +159,6 @@ psci_arch_init:
bx r6
- .globl psci_text_end +.globl psci_text_end psci_text_end: .popsection diff --git a/arch/arm/include/asm/arch-ls102xa/config.h b/arch/arm/include/asm/arch-ls102xa/config.h index c55cdef..e314c35 100644 --- a/arch/arm/include/asm/arch-ls102xa/config.h +++ b/arch/arm/include/asm/arch-ls102xa/config.h @@ -32,6 +32,7 @@ #define CONFIG_SYS_FSL_SERDES_ADDR (CONFIG_SYS_IMMR + 0x00ea0000) #define CONFIG_SYS_FSL_GUTS_ADDR (CONFIG_SYS_IMMR + 0x00ee0000) #define CONFIG_SYS_FSL_LS1_CLK_ADDR (CONFIG_SYS_IMMR + 0x00ee1000) +#define CONFIG_SYS_FSL_RCPM_ADDR (CONFIG_SYS_IMMR + 0x00ee2000) #define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_IMMR + 0x011c0500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_IMMR + 0x011d0500) #define CONFIG_SYS_DCU_ADDR (CONFIG_SYS_IMMR + 0x01ce0000)
Dongsheng Wang
