[U-Boot] [PATCH 0/6] net: ASIX AX88772B enablement
Hi all,
This series supersedes the earlier posted patches to support the AX88772B chip. I've split this up into a series as what started as a small patch to get the chip working turned into a journey through the usbeth stack and now not only reworks a lot of the ASIX code, but also touches other parts of the stack.
I want to thank Marek, Joe and Mike for their review, valueable feedback and guidance.
I've verified that we are now actually able to override the MAC address from the environment. All review feedback so far has been incorporated.
Lucas Stach (6): net: introduce transparent driver private in ueth_data net: usbeth: remove misleading warning net: asix: split out basic reset function net: asix: add write_hwaddr function net: asix: add read_mac function net: asix: add AX88772B support
drivers/usb/eth/asix.c | 180 ++++++++++++++++++++++++++++++++------------- drivers/usb/eth/smsc95xx.c | 48 ++++++++---- include/usb_ether.h | 8 +- net/eth.c | 2 - 4 Dateien geändert, 165 Zeilen hinzugefügt(+), 73 Zeilen entfernt(-)
Avoid clutter in ueth_data. Individual drivers should not mess with structures belonging to the core like this.
Signed-off-by: Lucas Stach dev@lynxeye.de --- drivers/usb/eth/smsc95xx.c | 48 ++++++++++++++++++++++++++++++++-------------- include/usb_ether.h | 8 ++------ 2 Dateien geändert, 36 Zeilen hinzugefügt(+), 20 Zeilen entfernt(-)
diff --git a/drivers/usb/eth/smsc95xx.c b/drivers/usb/eth/smsc95xx.c index c62a8c1..4bf2a16 100644 --- a/drivers/usb/eth/smsc95xx.c +++ b/drivers/usb/eth/smsc95xx.c @@ -25,6 +25,7 @@ #include <usb.h> #include <linux/mii.h> #include "usb_ether.h" +#include "malloc.h"
/* SMSC LAN95xx based USB 2.0 Ethernet Devices */
@@ -146,6 +147,12 @@ /* local vars */ static int curr_eth_dev; /* index for name of next device detected */
+/* driver private */ +struct smsc95xx_private { + size_t rx_urb_size; /* maximum USB URB size */ + u32 mac_cr; /* MAC control register value */ + int have_hwaddr; /* 1 if we have a hardware MAC address */ +};
/* * Smsc95xx infrastructure commands @@ -377,6 +384,7 @@ static int smsc95xx_init_mac_address(struct eth_device *eth, static int smsc95xx_write_hwaddr(struct eth_device *eth) { struct ueth_data *dev = (struct ueth_data *)eth->priv; + struct smsc95xx_private *priv = dev->dev_priv; u32 addr_lo = __get_unaligned_le32(ð->enetaddr[0]); u32 addr_hi = __get_unaligned_le16(ð->enetaddr[4]); int ret; @@ -392,7 +400,7 @@ static int smsc95xx_write_hwaddr(struct eth_device *eth) return ret;
debug("MAC %pM\n", eth->enetaddr); - dev->have_hwaddr = 1; + priv->have_hwaddr = 1; return 0; }
@@ -425,19 +433,22 @@ static int smsc95xx_set_csums(struct ueth_data *dev,
static void smsc95xx_set_multicast(struct ueth_data *dev) { + struct smsc95xx_private *priv = dev->dev_priv; + /* No multicast in u-boot */ - dev->mac_cr &= ~(MAC_CR_PRMS_ | MAC_CR_MCPAS_ | MAC_CR_HPFILT_); + priv->mac_cr &= ~(MAC_CR_PRMS_ | MAC_CR_MCPAS_ | MAC_CR_HPFILT_); }
/* starts the TX path */ static void smsc95xx_start_tx_path(struct ueth_data *dev) { + struct smsc95xx_private *priv = dev->dev_priv; u32 reg_val;
/* Enable Tx at MAC */ - dev->mac_cr |= MAC_CR_TXEN_; + priv->mac_cr |= MAC_CR_TXEN_;
- smsc95xx_write_reg(dev, MAC_CR, dev->mac_cr); + smsc95xx_write_reg(dev, MAC_CR, priv->mac_cr);
/* Enable Tx at SCSRs */ reg_val = TX_CFG_ON_; @@ -447,8 +458,10 @@ static void smsc95xx_start_tx_path(struct ueth_data *dev) /* Starts the Receive path */ static void smsc95xx_start_rx_path(struct ueth_data *dev) { - dev->mac_cr |= MAC_CR_RXEN_; - smsc95xx_write_reg(dev, MAC_CR, dev->mac_cr); + struct smsc95xx_private *priv = dev->dev_priv; + + priv->mac_cr |= MAC_CR_RXEN_; + smsc95xx_write_reg(dev, MAC_CR, priv->mac_cr); }
/* @@ -462,6 +475,7 @@ static int smsc95xx_init(struct eth_device *eth, bd_t *bd) u32 burst_cap; int timeout; struct ueth_data *dev = (struct ueth_data *)eth->priv; + struct smsc95xx_private *priv = (struct smsc95xx_private *)dev->dev_priv; #define TIMEOUT_RESOLUTION 50 /* ms */ int link_detected;
@@ -504,9 +518,9 @@ static int smsc95xx_init(struct eth_device *eth, bd_t *bd) debug("timeout waiting for PHY Reset\n"); return -1; } - if (!dev->have_hwaddr && smsc95xx_init_mac_address(eth, dev) == 0) - dev->have_hwaddr = 1; - if (!dev->have_hwaddr) { + if (!priv->have_hwaddr && smsc95xx_init_mac_address(eth, dev) == 0) + priv->have_hwaddr = 1; + if (!priv->have_hwaddr) { puts("Error: SMSC95xx: No MAC address set - set usbethaddr\n"); return -1; } @@ -532,16 +546,16 @@ static int smsc95xx_init(struct eth_device *eth, bd_t *bd) #ifdef TURBO_MODE if (dev->pusb_dev->speed == USB_SPEED_HIGH) { burst_cap = DEFAULT_HS_BURST_CAP_SIZE / HS_USB_PKT_SIZE; - dev->rx_urb_size = DEFAULT_HS_BURST_CAP_SIZE; + priv->rx_urb_size = DEFAULT_HS_BURST_CAP_SIZE; } else { burst_cap = DEFAULT_FS_BURST_CAP_SIZE / FS_USB_PKT_SIZE; - dev->rx_urb_size = DEFAULT_FS_BURST_CAP_SIZE; + priv->rx_urb_size = DEFAULT_FS_BURST_CAP_SIZE; } #else burst_cap = 0; - dev->rx_urb_size = MAX_SINGLE_PACKET_SIZE; + priv->rx_urb_size = MAX_SINGLE_PACKET_SIZE; #endif - debug("rx_urb_size=%ld\n", (ulong)dev->rx_urb_size); + debug("rx_urb_size=%ld\n", (ulong)priv->rx_urb_size);
ret = smsc95xx_write_reg(dev, BURST_CAP, burst_cap); if (ret < 0) @@ -606,7 +620,7 @@ static int smsc95xx_init(struct eth_device *eth, bd_t *bd) if (ret < 0) return ret;
- ret = smsc95xx_read_reg(dev, MAC_CR, &dev->mac_cr); + ret = smsc95xx_read_reg(dev, MAC_CR, &priv->mac_cr); if (ret < 0) return ret;
@@ -857,6 +871,12 @@ int smsc95xx_eth_probe(struct usb_device *dev, unsigned int ifnum, return 0; } dev->privptr = (void *)ss; + + /* alloc driver private */ + ss->dev_priv = calloc(1, sizeof(struct smsc95xx_private)); + if (!ss->dev_priv) + return 0; + return 1; }
diff --git a/include/usb_ether.h b/include/usb_ether.h index a7fb26b..7c7aecb 100644 --- a/include/usb_ether.h +++ b/include/usb_ether.h @@ -50,12 +50,8 @@ struct ueth_data { unsigned char protocol; /* .............. */ unsigned char irqinterval; /* Intervall for IRQ Pipe */
- /* private fields for each driver can go here if needed */ -#ifdef CONFIG_USB_ETHER_SMSC95XX - size_t rx_urb_size; /* maximum USB URB size */ - u32 mac_cr; /* MAC control register value */ - int have_hwaddr; /* 1 if we have a hardware MAC address */ -#endif + /* driver private */ + void *dev_priv; };
Dear Lucas Stach,
Reviewed-by: Marek Vasut marex@denx.de Acked-by: Marek Vasut marex@denx.de
You might want to fix your locale ... but I'm surprised git was localised at all :)
- Smsc95xx infrastructure commands
- struct smsc95xx_private *priv = dev->dev_priv; u32 addr_lo = __get_unaligned_le32(ð->enetaddr[0]); u32 addr_hi = __get_unaligned_le16(ð->enetaddr[4]); int ret;
- priv->have_hwaddr = 1; return 0;
- /* No multicast in u-boot */
- priv->mac_cr &= ~(MAC_CR_PRMS_ | MAC_CR_MCPAS_ | MAC_CR_HPFILT_);
- priv->mac_cr |= MAC_CR_TXEN_;
- priv->mac_cr |= MAC_CR_RXEN_;
- smsc95xx_write_reg(dev, MAC_CR, priv->mac_cr);
- struct smsc95xx_private *priv = (struct smsc95xx_private *)dev-
- if (!priv->have_hwaddr && smsc95xx_init_mac_address(eth, dev) == 0)
- if (!priv->have_hwaddr) { puts("Error: SMSC95xx: No MAC address set - set usbethaddr\n"); return -1; }
} else { burst_cap = DEFAULT_FS_BURST_CAP_SIZE / FS_USB_PKT_SIZE;priv->rx_urb_size = DEFAULT_HS_BURST_CAP_SIZE;
}priv->rx_urb_size = DEFAULT_FS_BURST_CAP_SIZE;
- priv->rx_urb_size = MAX_SINGLE_PACKET_SIZE;
#endif
- ret = smsc95xx_read_reg(dev, MAC_CR, &priv->mac_cr); if (ret < 0) return ret;
- /* alloc driver private */
- ss->dev_priv = calloc(1, sizeof(struct smsc95xx_private));
- if (!ss->dev_priv)
- return 1;
-#endif
- /* driver private */
- void *dev_priv;
Hi Lucas,
If the environment doesn't provide a MAC address it's not an error to use the one provided by the eth adapter. Actually it should be the default case if the adapter exports it's own address during get_info().
So just remove the warning that gets printed in this case.
Signed-off-by: Lucas Stach dev@lynxeye.de --- net/eth.c | 2 -- 1 Datei geändert, 2 Zeilen entfernt(-)
diff --git a/net/eth.c b/net/eth.c index 1a11ce1..39cd5da 100644 --- a/net/eth.c +++ b/net/eth.c @@ -217,8 +217,6 @@ int eth_write_hwaddr(struct eth_device *dev, const char *base_name, } else if (is_valid_ether_addr(dev->enetaddr)) { eth_setenv_enetaddr_by_index(base_name, eth_number, dev->enetaddr); - printf("\nWarning: %s using MAC address from net device\n", - dev->name); }
if (dev->write_hwaddr &&
Dear Lucas Stach,
I think we should warn if the addr in env doesn't match the one in the device. Otherwise, if the env doesn't contain ethaddr (or eth1addr, eth2addr ...), pull one from the device and inform user.
dev->name);
Best regards, Marek Vasut
Am Mittwoch, den 22.08.2012, 20:22 +0200 schrieb Marek Vasut:
Dear Lucas Stach,
Sadly it's not obvious from the diff context, but the warning if MAC in env does not match the one from the device is just above this hunk. Joe explained to me that the ueth core should always pull the address from the device and if this succeeds it always sets this address back if none is found in env. As this is the default case (and we are not actually changing the MAC of the device) there is no point in bothering the user with this info.
This is the whole point of this patch. That no one has seen this warning with the current code is simply because no usb eth driver had implemented the mac fetch at the right spot. ASIX now does this.
dev->name);
Hi Lucas / Marek,
Dear Lucas Stach,
Agreed... we also do that.
That's a good thing. It's not saying "Error:"... it's a warning. It's just letting the user know that the MAC is coming from the EEPROM.
Nak.
-Joe
The basic device reset ensures that the device is ready to service commands and does not need to get redone before each network operation.
Split out the basic reset from asix_init() and instead call it from asix_eth_get_info(), so that it only gets called once.
Signed-off-by: Lucas Stach dev@lynxeye.de --- drivers/usb/eth/asix.c | 44 ++++++++++++++++++++++++++------------------ 1 Datei geändert, 26 Zeilen hinzugefügt(+), 18 Zeilen entfernt(-)
diff --git a/drivers/usb/eth/asix.c b/drivers/usb/eth/asix.c index 8fb7fc8..50cbbbd 100644 --- a/drivers/usb/eth/asix.c +++ b/drivers/usb/eth/asix.c @@ -310,55 +310,60 @@ static int mii_nway_restart(struct ueth_data *dev) return r; }
-/* - * Asix callbacks - */ -static int asix_init(struct eth_device *eth, bd_t *bd) +static int asix_basic_reset(struct ueth_data *dev) { int embd_phy; - ALLOC_CACHE_ALIGN_BUFFER(unsigned char, buf, ETH_ALEN); u16 rx_ctl; - struct ueth_data *dev = (struct ueth_data *)eth->priv; - int timeout = 0; -#define TIMEOUT_RESOLUTION 50 /* ms */ - int link_detected; - - debug("** %s()\n", __func__);
if (asix_write_gpio(dev, AX_GPIO_RSE | AX_GPIO_GPO_2 | AX_GPIO_GPO2EN, 5) < 0) - goto out_err; + return -1;
/* 0x10 is the phy id of the embedded 10/100 ethernet phy */ embd_phy = ((asix_get_phy_addr(dev) & 0x1f) == 0x10 ? 1 : 0); if (asix_write_cmd(dev, AX_CMD_SW_PHY_SELECT, embd_phy, 0, 0, NULL) < 0) { debug("Select PHY #1 failed\n"); - goto out_err; + return -1; }
if (asix_sw_reset(dev, AX_SWRESET_IPPD | AX_SWRESET_PRL) < 0) - goto out_err; + return -1;
if (asix_sw_reset(dev, AX_SWRESET_CLEAR) < 0) - goto out_err; + return -1;
if (embd_phy) { if (asix_sw_reset(dev, AX_SWRESET_IPRL) < 0) - goto out_err; + return -1; } else { if (asix_sw_reset(dev, AX_SWRESET_PRTE) < 0) - goto out_err; + return -1; }
rx_ctl = asix_read_rx_ctl(dev); debug("RX_CTL is 0x%04x after software reset\n", rx_ctl); if (asix_write_rx_ctl(dev, 0x0000) < 0) - goto out_err; + return -1;
rx_ctl = asix_read_rx_ctl(dev); debug("RX_CTL is 0x%04x setting to 0x0000\n", rx_ctl);
+ return 0; +} + +/* + * Asix callbacks + */ +static int asix_init(struct eth_device *eth, bd_t *bd) +{ + struct ueth_data *dev = (struct ueth_data *)eth->priv; + int timeout = 0; +#define TIMEOUT_RESOLUTION 50 /* ms */ + int link_detected; + + debug("** %s()\n", __func__); + /* Get the MAC address */ if (asix_read_cmd(dev, AX_CMD_READ_NODE_ID, 0, 0, ETH_ALEN, buf) < 0) { @@ -635,5 +640,8 @@ int asix_eth_get_info(struct usb_device *dev, struct ueth_data *ss, eth->halt = asix_halt; eth->priv = ss;
+ if (asix_basic_reset(ss)) + return 0; + return 1; }
Dear Lucas Stach,
- Asix callbacks
- int timeout = 0;
int link_detected;
goto out_err;
return -1;
You might want to use proper errno.h here ... like -ETIMEDOUT etc.
goto out_err;
return -1;
goto out_err;
return -1;
goto out_err;
return -1;
goto out_err;
} else { if (asix_sw_reset(dev, AX_SWRESET_PRTE) < 0)return -1;
goto out_err;
return -1;
goto out_err;
return -1;
- Asix callbacks
- int timeout = 0;
- /* Get the MAC address */ if (asix_read_cmd(dev, AX_CMD_READ_NODE_ID, 0, 0, ETH_ALEN, buf) < 0) {
- if (asix_basic_reset(ss))
- return 1;
Hi Lucas,
i'm afraid this is wrong. the register step (which asix_eth_get_info is afaict) should not touch the hardware (other than to extract the MAC address). the init func is supposed to bring up the hardware from scratch since the expectation is that the halt func brings it down completely. if it's not really possible to completely "bring down" the hardware, then have the asix_init func declare a local static int so that it does the "full" bring up only once.
so NAK this patch as is -mike
Hi Mike,
Am Mittwoch, den 22.08.2012, 23:01 -0400 schrieb Mike Frysinger:
I still think the patch does the right thing. Let's look at the call chain. When doing a usb start of the controller where the ethernet device is attached we do the following to register the device: 1. probe (just check if we found suitable hardware, don't touch it yet) 2. get_info (at this point we extract the MAC, which means we have to bring up the hardware at a basic level, to even be able to touch the registers) 3. write_hwaddr (eth core sets the MAC address of the device, remember this is only done _once_ for each device and also needs basic init)
Every network operation basically does first a init() and then a halt(). If we would bring down the device here to a point where it's completely reset, we would also lose the MAC address set in the register step. This is clearly not what we want, but also we don't want to set the MAC over and over again with each network operation. So IMHO halt() should only bring down the device to a state where the current ethernet connection is gone. Therefore init() only needs to bring up the ethernet connection from this state. The basic device initialisation (including the MAC) should be persistent across multiple network operations.
This is the behaviour this patch implements, aside from halt() not really doing it's job in the asix driver, but that is for another patch.
Thanks, Lucas
All ASIX chipsets aside from AX88172 are able to set the MAC address on the hardware level. Add a function to expose this ability.
To differentiate between chip types we now carry flags as driver private data. Also while touching the asix_dongles array constify this.
Signed-off-by: Lucas Stach dev@lynxeye.de --- drivers/usb/eth/asix.c | 61 +++++++++++++++++++++++++++++++++++++++++--------- 1 Datei geändert, 50 Zeilen hinzugefügt(+), 11 Zeilen entfernt(-)
diff --git a/drivers/usb/eth/asix.c b/drivers/usb/eth/asix.c index 50cbbbd..ce1483e 100644 --- a/drivers/usb/eth/asix.c +++ b/drivers/usb/eth/asix.c @@ -23,6 +23,7 @@ #include <usb.h> #include <linux/mii.h> #include "usb_ether.h" +#include "malloc.h"
/* ASIX AX8817X based USB 2.0 Ethernet Devices */ @@ -35,6 +36,7 @@ #define AX_CMD_WRITE_RX_CTL 0x10 #define AX_CMD_WRITE_IPG0 0x12 #define AX_CMD_READ_NODE_ID 0x13 +#define AX_CMD_WRITE_NODE_ID 0x14 #define AX_CMD_READ_PHY_ID 0x19 #define AX_CMD_WRITE_MEDIUM_MODE 0x1b #define AX_CMD_WRITE_GPIOS 0x1f @@ -97,9 +99,19 @@ #define AX_RX_URB_SIZE 2048 #define PHY_CONNECT_TIMEOUT 5000
+/* asix_flags defines */ +#define FLAG_NONE 0 +#define FLAG_TYPE_AX88172 (1U << 0) +#define FLAG_TYPE_AX88772 (1U << 1) +#define FLAG_TYPE_AX88772B (1U << 2) /* local vars */ static int curr_eth_dev; /* index for name of next device detected */
+/* driver private */ +struct asix_private { + int flags; +}; + /* * Asix infrastructure commands */ @@ -284,6 +296,21 @@ static int asix_write_gpio(struct ueth_data *dev, u16 value, int sleep) return ret; }
+static int asix_write_hwaddr(struct eth_device *eth) +{ + struct ueth_data *dev = (struct ueth_data *)eth->priv; + int ret; + ALLOC_CACHE_ALIGN_BUFFER(unsigned char, buf, ETH_ALEN); + + memcpy(buf, eth->enetaddr, ETH_ALEN); + + ret = asix_write_cmd(dev, AX_CMD_WRITE_NODE_ID, 0, 0, ETH_ALEN, buf); + if (ret < 0) + debug("Failed to set MAC address: %02x\n", ret); + + return ret; +} + /* * mii commands */ @@ -539,19 +566,20 @@ void asix_eth_before_probe(void) struct asix_dongle { unsigned short vendor; unsigned short product; + int flags; };
-static struct asix_dongle asix_dongles[] = { - { 0x05ac, 0x1402 }, /* Apple USB Ethernet Adapter */ - { 0x07d1, 0x3c05 }, /* D-Link DUB-E100 H/W Ver B1 */ - { 0x0b95, 0x772a }, /* Cables-to-Go USB Ethernet Adapter */ - { 0x0b95, 0x7720 }, /* Trendnet TU2-ET100 V3.0R */ - { 0x0b95, 0x1720 }, /* SMC */ - { 0x0db0, 0xa877 }, /* MSI - ASIX 88772a */ - { 0x13b1, 0x0018 }, /* Linksys 200M v2.1 */ - { 0x1557, 0x7720 }, /* 0Q0 cable ethernet */ - { 0x2001, 0x3c05 }, /* DLink DUB-E100 H/W Ver B1 Alternate */ - { 0x0000, 0x0000 } /* END - Do not remove */ +static const struct asix_dongle asix_dongles[] = { + { 0x05ac, 0x1402, FLAG_TYPE_AX88772 }, /* Apple USB Ethernet Adapter */ + { 0x07d1, 0x3c05, FLAG_TYPE_AX88772 }, /* D-Link DUB-E100 H/W Ver B1 */ + { 0x0b95, 0x772a, FLAG_TYPE_AX88772 }, /* Cables-to-Go USB Ethernet Adapter */ + { 0x0b95, 0x7720, FLAG_TYPE_AX88772 }, /* Trendnet TU2-ET100 V3.0R */ + { 0x0b95, 0x1720, FLAG_TYPE_AX88172 }, /* SMC */ + { 0x0db0, 0xa877, FLAG_TYPE_AX88772 }, /* MSI - ASIX 88772a */ + { 0x13b1, 0x0018, FLAG_TYPE_AX88172 }, /* Linksys 200M v2.1 */ + { 0x1557, 0x7720, FLAG_TYPE_AX88772 }, /* 0Q0 cable ethernet */ + { 0x2001, 0x3c05, FLAG_TYPE_AX88772 }, /* DLink DUB-E100 H/W Ver B1 Alternate */ + { 0x0000, 0x0000, FLAG_NONE } /* END - Do not remove */ };
/* Probe to see if a new device is actually an asix device */ @@ -588,6 +616,13 @@ int asix_eth_probe(struct usb_device *dev, unsigned int ifnum, ss->subclass = iface_desc->bInterfaceSubClass; ss->protocol = iface_desc->bInterfaceProtocol;
+ /* alloc driver private */ + ss->dev_priv = calloc(1, sizeof(struct asix_private)); + if (!ss->dev_priv) + return 0; + + ((struct asix_private *)ss->dev_priv)->flags = asix_dongles[i].flags; + /* * We are expecting a minimum of 3 endpoints - in, out (bulk), and * int. We will ignore any others. @@ -629,6 +664,8 @@ int asix_eth_probe(struct usb_device *dev, unsigned int ifnum, int asix_eth_get_info(struct usb_device *dev, struct ueth_data *ss, struct eth_device *eth) { + struct asix_private *priv = (struct asix_private *)ss->dev_priv; + if (!eth) { debug("%s: missing parameter.\n", __func__); return 0; @@ -638,6 +675,8 @@ int asix_eth_get_info(struct usb_device *dev, struct ueth_data *ss, eth->send = asix_send; eth->recv = asix_recv; eth->halt = asix_halt; + if (!(priv->flags & FLAG_TYPE_AX88172)) + eth->write_hwaddr = asix_write_hwaddr; eth->priv = ss;
Dear Lucas Stach,
#include <malloc.h>
- int flags;
- Asix infrastructure commands
- int ret;
- memcpy(buf, eth->enetaddr, ETH_ALEN);
- ret = asix_write_cmd(dev, AX_CMD_WRITE_NODE_ID, 0, 0, ETH_ALEN, buf);
- if (ret < 0)
- return ret;
- mii commands
- int flags;
Shouldn't this be static const __type const __name[] ?
- { 0x05ac, 0x1402, FLAG_TYPE_AX88772 }, /* Apple USB Ethernet Adapter */
- { 0x07d1, 0x3c05, FLAG_TYPE_AX88772 }, /* D-Link DUB-E100 H/W Ver B1 */
- { 0x0b95, 0x772a, FLAG_TYPE_AX88772 }, /* Cables-to-Go USB Ethernet
- { 0x0db0, 0xa877, FLAG_TYPE_AX88772 }, /* MSI - ASIX 88772a */
- { 0x13b1, 0x0018, FLAG_TYPE_AX88172 }, /* Linksys 200M v2.1 */
- { 0x1557, 0x7720, FLAG_TYPE_AX88772 }, /* 0Q0 cable ethernet */
- { 0x2001, 0x3c05, FLAG_TYPE_AX88772 }, /* DLink DUB-E100 H/W Ver B1
- ss->dev_priv = calloc(1, sizeof(struct asix_private));
- ((struct asix_private *)ss->dev_priv)->flags = asix_dongles[i].flags;
- We are expecting a minimum of 3 endpoints - in, out (bulk), and
- int. We will ignore any others.
- struct asix_private *priv = (struct asix_private *)ss->dev_priv;
- if (!eth) { debug("%s: missing parameter.\n", __func__); return 0;
eth->priv = ss;
Hi Lucas,
Add this flag in the last patch where you add support for this chip.
int flags;
int ret;
if (ret < 0)
return ret;
- mii commands
int flags;
Agreed with Marek... const array and const elements.
if (!ss->dev_priv)
eth->write_hwaddr = asix_write_hwaddr; eth->priv = ss; if (asix_basic_reset(ss))
Thanks, -Joe
Initial device MAC should be read while getting info about the device, so it's wrong to only read it in asix_init().
Add a dedicated function to read the initial MAC, which is also able to handle devices that have their initial MAC stored in EEPROM. Call this function inasix_eth_get_info().
Signed-off-by: Lucas Stach dev@lynxeye.de --- drivers/usb/eth/asix.c | 47 +++++++++++++++++++++++++++++++++++------------ 1 Datei geändert, 35 Zeilen hinzugefügt(+), 12 Zeilen entfernt(-)
diff --git a/drivers/usb/eth/asix.c b/drivers/usb/eth/asix.c index ce1483e..6ab3e82 100644 --- a/drivers/usb/eth/asix.c +++ b/drivers/usb/eth/asix.c @@ -32,6 +32,7 @@ #define AX_CMD_READ_MII_REG 0x07 #define AX_CMD_WRITE_MII_REG 0x08 #define AX_CMD_SET_HW_MII 0x0a +#define AX_CMD_READ_EEPROM 0x0b #define AX_CMD_READ_RX_CTL 0x0f #define AX_CMD_WRITE_RX_CTL 0x10 #define AX_CMD_WRITE_IPG0 0x12 @@ -104,6 +105,8 @@ #define FLAG_TYPE_AX88172 (1U << 0) #define FLAG_TYPE_AX88772 (1U << 1) #define FLAG_TYPE_AX88772B (1U << 2) +#define FLAG_EEPROM_MAC (1U << 3) /* initial mac address in eeprom */ + /* local vars */ static int curr_eth_dev; /* index for name of next device detected */
@@ -337,6 +340,33 @@ static int mii_nway_restart(struct ueth_data *dev) return r; }
+static int asix_read_mac(struct eth_device *eth) +{ + struct ueth_data *dev = (struct ueth_data *)eth->priv; + struct asix_private *priv = (struct asix_private *)dev->dev_priv; + int i; + ALLOC_CACHE_ALIGN_BUFFER(unsigned char, buf, ETH_ALEN); + + if (priv->flags & FLAG_EEPROM_MAC) { + for (i = 0; i < (ETH_ALEN >> 1); i++) { + if (asix_read_cmd(dev, AX_CMD_READ_EEPROM, + 0x04 + i, 0, 2, buf) < 0) { + debug("Failed to read SROM address 04h.\n"); + return -1; + } + memcpy((eth->enetaddr + i * 2), buf, 2); + } + } else { + if (asix_read_cmd(dev, AX_CMD_READ_NODE_ID, 0, 0, ETH_ALEN, buf) < 0) { + debug("Failed to read MAC address.\n"); + return -1; + } + memcpy(eth->enetaddr, buf, ETH_ALEN); + } + + return 0; +} + static int asix_basic_reset(struct ueth_data *dev) { int embd_phy; @@ -391,18 +421,6 @@ static int asix_init(struct eth_device *eth, bd_t *bd)
- /* Get the MAC address */ - if (asix_read_cmd(dev, AX_CMD_READ_NODE_ID, - 0, 0, ETH_ALEN, buf) < 0) { - debug("Failed to read MAC address.\n"); - goto out_err; - } - memcpy(eth->enetaddr, buf, ETH_ALEN); - debug("MAC %02x:%02x:%02x:%02x:%02x:%02x\n", - eth->enetaddr[0], eth->enetaddr[1], - eth->enetaddr[2], eth->enetaddr[3], - eth->enetaddr[4], eth->enetaddr[5]); - dev->phy_id = asix_get_phy_addr(dev); if (dev->phy_id < 0) debug("Failed to read phy id\n"); @@ -682,5 +700,10 @@ int asix_eth_get_info(struct usb_device *dev, struct ueth_data *ss, if (asix_basic_reset(ss)) return 0;
+ /* Get the MAC address */ + if (asix_read_mac(eth)) + return 0; + debug("MAC %pM\n", eth->enetaddr); + return 1; }
Dear Lucas Stach,
eeprom */
- struct asix_private *priv = (struct asix_private *)dev->dev_priv;
- int i;
- if (priv->flags & FLAG_EEPROM_MAC) {
return -1;
- } else {
< 0) {
return -1;
goto out_err;
- if (asix_read_mac(eth))
- debug("MAC %pM\n", eth->enetaddr);
- return 1;
Hi Lucas,
Add AX88772B ID together with two fixes needed to make this work.
1. The packet length check has to be adjusted, as all ASIX chips only use 11 bits to indicate the length. AX88772B uses the other bits to indicate unrelated things, which cause the check to fail. This fix is based on a fix for the Linux kernel by Marek Vasut. Linux upstream commit: bca0beb9363f8487ac902931a50eb00180a2d14a
2. AX88772B provides several bulk endpoints. Only the first IN/OUT endpoints work in the default configuration. So stop enumeration after we found them to avoid overwriting the endpoint config with a non-working one.
Signed-off-by: Lucas Stach dev@lynxeye.de --- drivers/usb/eth/asix.c | 30 +++++++++++++++++++----------- 1 Datei geändert, 19 Zeilen hinzugefügt(+), 11 Zeilen entfernt(-)
diff --git a/drivers/usb/eth/asix.c b/drivers/usb/eth/asix.c index 6ab3e82..79246d8 100644 --- a/drivers/usb/eth/asix.c +++ b/drivers/usb/eth/asix.c @@ -543,13 +543,13 @@ static int asix_recv(struct eth_device *eth) } memcpy(&packet_len, buf_ptr, sizeof(packet_len)); le32_to_cpus(&packet_len); - if (((packet_len >> 16) ^ 0xffff) != (packet_len & 0xffff)) { + if (((~packet_len >> 16) & 0x7ff) != (packet_len & 0x7ff)) { debug("Rx: malformed packet length: %#x (%#x:%#x)\n", - packet_len, (packet_len >> 16) ^ 0xffff, - packet_len & 0xffff); + packet_len, (~packet_len >> 16) & 0x7ff, + packet_len & 0x7ff); return -1; } - packet_len = packet_len & 0xffff; + packet_len = packet_len & 0x7ff; if (packet_len > actual_len - sizeof(packet_len)) { debug("Rx: too large packet: %d\n", packet_len); return -1; @@ -597,6 +597,7 @@ static const struct asix_dongle asix_dongles[] = { { 0x13b1, 0x0018, FLAG_TYPE_AX88172 }, /* Linksys 200M v2.1 */ { 0x1557, 0x7720, FLAG_TYPE_AX88772 }, /* 0Q0 cable ethernet */ { 0x2001, 0x3c05, FLAG_TYPE_AX88772 }, /* DLink DUB-E100 H/W Ver B1 Alternate */ + { 0x0b95, 0x772b, FLAG_TYPE_AX88772B | FLAG_EEPROM_MAC }, /* ASIX 88772B */ { 0x0000, 0x0000, FLAG_NONE } /* END - Do not remove */ };
@@ -606,6 +607,7 @@ int asix_eth_probe(struct usb_device *dev, unsigned int ifnum, { struct usb_interface *iface; struct usb_interface_descriptor *iface_desc; + int ep_in_found = 0, ep_out_found = 0; int i;
/* let's examine the device now */ @@ -649,13 +651,19 @@ int asix_eth_probe(struct usb_device *dev, unsigned int ifnum, /* is it an BULK endpoint? */ if ((iface->ep_desc[i].bmAttributes & USB_ENDPOINT_XFERTYPE_MASK) == USB_ENDPOINT_XFER_BULK) { - if (iface->ep_desc[i].bEndpointAddress & USB_DIR_IN) - ss->ep_in = iface->ep_desc[i].bEndpointAddress & - USB_ENDPOINT_NUMBER_MASK; - else - ss->ep_out = - iface->ep_desc[i].bEndpointAddress & - USB_ENDPOINT_NUMBER_MASK; + if (iface->ep_desc[i].bEndpointAddress & USB_DIR_IN) { + if (!ep_in_found) { + ss->ep_in = iface->ep_desc[i].bEndpointAddress & + USB_ENDPOINT_NUMBER_MASK; + ep_in_found = 1; + } + } else { + if (!ep_out_found) { + ss->ep_out = iface->ep_desc[i].bEndpointAddress & + USB_ENDPOINT_NUMBER_MASK; + ep_out_found = 1; + } + } }
/* is it an interrupt endpoint? */
Dear Lucas Stach,
- The packet length check has to be adjusted, as all ASIX chips
- AX88772B provides several bulk endpoints. Only the first
}packet_len & 0x7ff); return -1;
if (packet_len > actual_len - sizeof(packet_len)) { debug("Rx: too large packet: %d\n", packet_len); return -1;packet_len = packet_len & 0x7ff;
else
ss->ep_out =
if (!ep_in_found) {
ss->ep_in = iface-
ep_in_found = 1;
} else {
ss->ep_out = iface-
ep_out_found = 1;
Hi Lucas,
Dear Lucas Stach,
Hi all,
Marek blushes and his ego explodes ;-D
Anyway, thank _YOU_ for your effort, that's the important part here! It is, was and always will be the community that forges the project.
participants (5)
Joe Hershberger
Lucas Stach
Mike Frysinger
