[U-Boot] [PATCH] sunxi: Fix memory 2-rank initialization for a33 cpu
When we initialize the memory we need to autodetect rank and size but this can happen only if we send the proper reset to both memory module including cke signal. For this reason we need initialize the physical on both channel because we need to presume that both are connected. This way let the CLKE to be activated at the right time with the memory reset coming from the cpu
Signed-off-by: Michael Trimarchi michael@amarulasolutions.com --- arch/arm/mach-sunxi/dram_sun8i_a33.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-sunxi/dram_sun8i_a33.c b/arch/arm/mach-sunxi/dram_sun8i_a33.c index d9aa0c6d7e..1da2727f98 100644 --- a/arch/arm/mach-sunxi/dram_sun8i_a33.c +++ b/arch/arm/mach-sunxi/dram_sun8i_a33.c @@ -334,7 +334,7 @@ unsigned long sunxi_dram_init(void) struct dram_para para = { .cs1 = 0, .bank = 1, - .rank = 1, + .rank = 2, .rows = 15, .bus_width = 16, .page_size = 2048,
Hi Maxime
On Wed, Oct 31, 2018 at 8:03 PM Michael Trimarchi michael@amarulasolutions.com wrote:
Does enough clear?
Michael
.rank = 1,
-- 2.17.1
Acked-by: Maxime Ripard maxime.ripard@bootlin.com
Maxime
Hi Jagan
On Mon, Nov 5, 2018 at 10:02 AM Maxime Ripard maxime.ripard@bootlin.com wrote:
Can you test on a consumer board with A33? I have tested over oscilloscope on my device
Michael
Maxime
-- Maxime Ripard, Bootlin Embedded Linux and Kernel engineering https://bootlin.com
On Thu, Nov 1, 2018 at 12:33 AM Michael Trimarchi michael@amarulasolutions.com wrote:
Applied to u-boot-sunxi/master
Jagan Teki
Maxime Ripard
Michael Nazzareno Trimarchi
Michael Trimarchi
