[U-Boot] [PATCH] ARM: uniphier: remove BLK select
This is a user configurable option, but "select BLK" forces users to enable it.
Even with this commit, BLK is still enabled by "default y if DM_MMC" for UniPhier SoCs; the difference is users can disable it if they do not need it.
Signed-off-by: Masahiro Yamada yamada.masahiro@socionext.com ---
arch/arm/Kconfig | 1 - 1 file changed, 1 deletion(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 7203d63..714dd8b 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -829,7 +829,6 @@ config TARGET_COLIBRI_PXA270
config ARCH_UNIPHIER bool "Socionext UniPhier SoCs" - select BLK select CLK_UNIPHIER select DM select DM_GPIO
2016-12-10 10:52 GMT+09:00 Masahiro Yamada yamada.masahiro@socionext.com:
Applied to u-boot-uniphier/master.
Masahiro Yamada
