[U-Boot] [PATCH] Fix console functions for U-Boot API
Commit 709ea54 made a subtle change to the way the U-Boot API jump table is set up. So at present putc(), getc(), tstc() and puts() do not work correctly from functions that use the U-Boot API.
Previously these were set to the stdio functions, but these now take a parameter specifying which stdio device to use. Instead, we should change them to use the global functions which do not have a parameter.
This is a slight change in behaviour. The functions will now output to all selected stdio devices - for example putc() will output a character to all devices selected by stdout. However in most cases there is only one, and it isn't necessarily incorrect behaviour anyway.
The API version is not changed since it is compatible with what was there before.
Reported-by: Martin Dorwig dorwig@tektronik.com Signed-off-by: Simon Glass sjg@chromium.org ---
common/console.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/common/console.c b/common/console.c index 4695386..29560c3 100644 --- a/common/console.c +++ b/common/console.c @@ -125,12 +125,12 @@ static int console_setfile(int file, struct stdio_dev * dev) */ switch (file) { case stdin: - gd->jt[XF_getc] = dev->getc; - gd->jt[XF_tstc] = dev->tstc; + gd->jt[XF_getc] = getc; + gd->jt[XF_tstc] = tstc; break; case stdout: - gd->jt[XF_putc] = dev->putc; - gd->jt[XF_puts] = dev->puts; + gd->jt[XF_putc] = putc; + gd->jt[XF_puts] = puts; gd->jt[XF_printf] = printf; break; }
