[U-Boot] [PATCH v2] tools/mxsimage: Support building with LibreSSL
The mxsimage utility fails to compile against LibreSSL because LibreSSL says it is OpenSSL 2.0, but it does not support the complete OpenSSL 1.1 interface.
LibreSSL defines OPENSSL_VERSION_NUMBER with 0x20000000L and therefor claims to have an API compatible with OpenSSL 2.0, but it does not implement OPENSSL_zalloc() and some other functions in its most recent version. OpenSSL implements this function since version 1.1.0.
This commit will activate the compatibility code meant for OpenSSL < 1.1.0 also for all versions of LibreSSL, if some version of LibreSSL will support these functions in the future the version check should be adapted.
Signed-off-by: Hauke Mehrtens hauke@hauke-m.de --- tools/mxsimage.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/mxsimage.c b/tools/mxsimage.c index 32a7978cae..0cbf007dff 100644 --- a/tools/mxsimage.c +++ b/tools/mxsimage.c @@ -26,7 +26,7 @@ * OpenSSL 1.1.0 and newer compatibility functions: * https://wiki.openssl.org/index.php/1.1_API_Changes */ -#if OPENSSL_VERSION_NUMBER < 0x10100000L +#if OPENSSL_VERSION_NUMBER < 0x10100000L || defined(LIBRESSL_VERSION_NUMBER) static void *OPENSSL_zalloc(size_t num) { void *ret = OPENSSL_malloc(num);
Acked-by: Marek Vasut marex@denx.de
- OpenSSL 1.1.0 and newer compatibility functions:
- https://wiki.openssl.org/index.php/1.1_API_Changes
Hauke Mehrtens
