[U-Boot] [PATCH v7 0/4] ARM: AT91: Add AT91 PIO4 pinctrl driver and gpio driver with DM
AT91 PIO4 controller is a combined gpio-controller, pin-mux and pin-config module.
This patch is to add the pinctrl driver, and rework the atmel-pio4 gpio driver to support driver model and device tree.
Changes in v7: - Change clk_client.h -> clk.h to adapt to clk API conversion. - Drop [PATCH]: configs: sama5d2_xplained: Add #ifndef before CONFIG_ATMEL_PIO4.
Changes in v6: - Add Reviewed-by tag. - Fixed the return value, -EINVAL -> ret.
Changes in v5: - Update the clk API based on [PATCH] clk: convert API to match reset/mailbox fstyle (http://patchwork.ozlabs.org/patch/625342/). - Use clrbits_le32() to replace readl()/writel(). - Fixed the return value, -ENODEV->-EINVAL. - Remove check on dev_get_parent() return. - Fixed the return value, -ENODEV->-EINVAL. - Remove check on dev_get_parent() return.
Changes in v4: - Remove the redundant log print.
Changes in v3: - Add bind callback to support the pinctl device regarding as a child of atmel_pio4 device. - Add clock support. - Rework due to the pinctrl device is regarded as atmel_pio4 device's child.
Changes in v2: - remove meaningless comment. - add else path for argument of pinconf. - add inline attribute for atmel_pio4_bank_base(). - add handle if the pinmux entries is greater maximum value. - add detailed example to show how to configure pinctrl for device. - remove interrupt and gpio property description. - add reviewed-by tag.
Wenyou Yang (4): gpio: atmel_pio4: Move PIO4 definitions to head file gpio: atmel_pio4: Rework to support DM & DT pinctrl: at91-pio4: Add pinctrl driver atmel: Bring in at91 pio4 device tree file and bindings
arch/arm/dts/sama5d2-pinfunc.h | 880 +++++++++++++++++++++ arch/arm/mach-at91/include/mach/atmel_pio4.h | 35 + .../pinctrl/atmel,at91-pio4-pinctrl.txt | 66 ++ drivers/gpio/Kconfig | 2 +- drivers/gpio/atmel_pio4.c | 201 +++-- drivers/pinctrl/Kconfig | 7 + drivers/pinctrl/Makefile | 1 + drivers/pinctrl/pinctrl-at91-pio4.c | 182 +++++ 8 files changed, 1302 insertions(+), 72 deletions(-) create mode 100644 arch/arm/dts/sama5d2-pinfunc.h create mode 100644 doc/device-tree-bindings/pinctrl/atmel,at91-pio4-pinctrl.txt create mode 100644 drivers/pinctrl/pinctrl-at91-pio4.c
In order to make these PIO4 definitions shared with AT91 PIO4 pinctrl driver, move them from the existing gpio driver to the head file, and rephrase them.
Signed-off-by: Wenyou Yang wenyou.yang@atmel.com Reviewed-by: Simon Glass sjg@chromium.org ---
Changes in v7: None Changes in v6: None Changes in v5: None Changes in v4: None Changes in v3: None Changes in v2: None
arch/arm/mach-at91/include/mach/atmel_pio4.h | 35 ++++++++++++++ drivers/gpio/atmel_pio4.c | 71 +++++++--------------------- 2 files changed, 53 insertions(+), 53 deletions(-)
diff --git a/arch/arm/mach-at91/include/mach/atmel_pio4.h b/arch/arm/mach-at91/include/mach/atmel_pio4.h index 8bb4b12..6760bec 100644 --- a/arch/arm/mach-at91/include/mach/atmel_pio4.h +++ b/arch/arm/mach-at91/include/mach/atmel_pio4.h @@ -29,6 +29,41 @@ struct atmel_pio4_port {
#endif
+/* + * PIO Configuration Register Fields + */ +#define ATMEL_PIO_CFGR_FUNC_MASK GENMASK(2, 0) +#define ATMEL_PIO_CFGR_FUNC_GPIO (0x0 << 0) +#define ATMEL_PIO_CFGR_FUNC_PERIPH_A (0x1 << 0) +#define ATMEL_PIO_CFGR_FUNC_PERIPH_B (0x2 << 0) +#define ATMEL_PIO_CFGR_FUNC_PERIPH_C (0x3 << 0) +#define ATMEL_PIO_CFGR_FUNC_PERIPH_D (0x4 << 0) +#define ATMEL_PIO_CFGR_FUNC_PERIPH_E (0x5 << 0) +#define ATMEL_PIO_CFGR_FUNC_PERIPH_F (0x6 << 0) +#define ATMEL_PIO_CFGR_FUNC_PERIPH_G (0x7 << 0) +#define ATMEL_PIO_DIR_MASK BIT(8) +#define ATMEL_PIO_PUEN_MASK BIT(9) +#define ATMEL_PIO_PDEN_MASK BIT(10) +#define ATMEL_PIO_IFEN_MASK BIT(12) +#define ATMEL_PIO_IFSCEN_MASK BIT(13) +#define ATMEL_PIO_OPD_MASK BIT(14) +#define ATMEL_PIO_SCHMITT_MASK BIT(15) +#define ATMEL_PIO_CFGR_EVTSEL_MASK GENMASK(26, 24) +#define ATMEL_PIO_CFGR_EVTSEL_FALLING (0 << 24) +#define ATMEL_PIO_CFGR_EVTSEL_RISING (1 << 24) +#define ATMEL_PIO_CFGR_EVTSEL_BOTH (2 << 24) +#define ATMEL_PIO_CFGR_EVTSEL_LOW (3 << 24) +#define ATMEL_PIO_CFGR_EVTSEL_HIGH (4 << 24) + +#define ATMEL_PIO_NPINS_PER_BANK 32 +#define ATMEL_PIO_BANK(pin_id) (pin_id / ATMEL_PIO_NPINS_PER_BANK) +#define ATMEL_PIO_LINE(pin_id) (pin_id % ATMEL_PIO_NPINS_PER_BANK) +#define ATMEL_PIO_BANK_OFFSET 0x40 + +#define ATMEL_GET_PIN_NO(pinfunc) ((pinfunc) & 0xff) +#define ATMEL_GET_PIN_FUNC(pinfunc) ((pinfunc >> 16) & 0xf) +#define ATMEL_GET_PIN_IOSET(pinfunc) ((pinfunc >> 20) & 0xf) + #define AT91_PIO_PORTA 0x0 #define AT91_PIO_PORTB 0x1 #define AT91_PIO_PORTC 0x2 diff --git a/drivers/gpio/atmel_pio4.c b/drivers/gpio/atmel_pio4.c index d71f525..84e8cc5 100644 --- a/drivers/gpio/atmel_pio4.c +++ b/drivers/gpio/atmel_pio4.c @@ -12,41 +12,6 @@ #include <mach/gpio.h> #include <mach/atmel_pio4.h>
-#define ATMEL_PIO4_PINS_PER_BANK 32 - -/* - * Register Field Definitions - */ -#define ATMEL_PIO4_CFGR_FUNC (0x7 << 0) -#define ATMEL_PIO4_CFGR_FUNC_GPIO (0x0 << 0) -#define ATMEL_PIO4_CFGR_FUNC_PERIPH_A (0x1 << 0) -#define ATMEL_PIO4_CFGR_FUNC_PERIPH_B (0x2 << 0) -#define ATMEL_PIO4_CFGR_FUNC_PERIPH_C (0x3 << 0) -#define ATMEL_PIO4_CFGR_FUNC_PERIPH_D (0x4 << 0) -#define ATMEL_PIO4_CFGR_FUNC_PERIPH_E (0x5 << 0) -#define ATMEL_PIO4_CFGR_FUNC_PERIPH_F (0x6 << 0) -#define ATMEL_PIO4_CFGR_FUNC_PERIPH_G (0x7 << 0) -#define ATMEL_PIO4_CFGR_DIR (0x1 << 8) -#define ATMEL_PIO4_CFGR_PUEN (0x1 << 9) -#define ATMEL_PIO4_CFGR_PDEN (0x1 << 10) -#define ATMEL_PIO4_CFGR_IFEN (0x1 << 12) -#define ATMEL_PIO4_CFGR_IFSCEN (0x1 << 13) -#define ATMEL_PIO4_CFGR_OPD (0x1 << 14) -#define ATMEL_PIO4_CFGR_SCHMITT (0x1 << 15) -#define ATMEL_PIO4_CFGR_DRVSTR (0x3 << 16) -#define ATMEL_PIO4_CFGR_DRVSTR_LOW0 (0x0 << 16) -#define ATMEL_PIO4_CFGR_DRVSTR_LOW1 (0x1 << 16) -#define ATMEL_PIO4_CFGR_DRVSTR_MEDIUM (0x2 << 16) -#define ATMEL_PIO4_CFGR_DRVSTR_HIGH (0x3 << 16) -#define ATMEL_PIO4_CFGR_EVTSEL (0x7 << 24) -#define ATMEL_PIO4_CFGR_EVTSEL_FALLING (0x0 << 24) -#define ATMEL_PIO4_CFGR_EVTSEL_RISING (0x1 << 24) -#define ATMEL_PIO4_CFGR_EVTSEL_BOTH (0x2 << 24) -#define ATMEL_PIO4_CFGR_EVTSEL_LOW (0x3 << 24) -#define ATMEL_PIO4_CFGR_EVTSEL_HIGH (0x4 << 24) -#define ATMEL_PIO4_CFGR_PCFS (0x1 << 29) -#define ATMEL_PIO4_CFGR_ICFS (0x1 << 30) - static struct atmel_pio4_port *atmel_pio4_port_base(u32 port) { struct atmel_pio4_port *base = NULL; @@ -79,7 +44,7 @@ static int atmel_pio4_config_io_func(u32 port, u32 pin, struct atmel_pio4_port *port_base; u32 reg, mask;
- if (pin >= ATMEL_PIO4_PINS_PER_BANK) + if (pin >= ATMEL_PIO_NPINS_PER_BANK) return -ENODEV;
port_base = atmel_pio4_port_base(port); @@ -88,7 +53,7 @@ static int atmel_pio4_config_io_func(u32 port, u32 pin,
mask = 1 << pin; reg = func; - reg |= use_pullup ? ATMEL_PIO4_CFGR_PUEN : 0; + reg |= use_pullup ? ATMEL_PIO_PUEN_MASK : 0;
writel(mask, &port_base->mskr); writel(reg, &port_base->cfgr); @@ -99,56 +64,56 @@ static int atmel_pio4_config_io_func(u32 port, u32 pin, int atmel_pio4_set_gpio(u32 port, u32 pin, u32 use_pullup) { return atmel_pio4_config_io_func(port, pin, - ATMEL_PIO4_CFGR_FUNC_GPIO, + ATMEL_PIO_CFGR_FUNC_GPIO, use_pullup); }
int atmel_pio4_set_a_periph(u32 port, u32 pin, u32 use_pullup) { return atmel_pio4_config_io_func(port, pin, - ATMEL_PIO4_CFGR_FUNC_PERIPH_A, + ATMEL_PIO_CFGR_FUNC_PERIPH_A, use_pullup); }
int atmel_pio4_set_b_periph(u32 port, u32 pin, u32 use_pullup) { return atmel_pio4_config_io_func(port, pin, - ATMEL_PIO4_CFGR_FUNC_PERIPH_B, + ATMEL_PIO_CFGR_FUNC_PERIPH_B, use_pullup); }
int atmel_pio4_set_c_periph(u32 port, u32 pin, u32 use_pullup) { return atmel_pio4_config_io_func(port, pin, - ATMEL_PIO4_CFGR_FUNC_PERIPH_C, + ATMEL_PIO_CFGR_FUNC_PERIPH_C, use_pullup); }
int atmel_pio4_set_d_periph(u32 port, u32 pin, u32 use_pullup) { return atmel_pio4_config_io_func(port, pin, - ATMEL_PIO4_CFGR_FUNC_PERIPH_D, + ATMEL_PIO_CFGR_FUNC_PERIPH_D, use_pullup); }
int atmel_pio4_set_e_periph(u32 port, u32 pin, u32 use_pullup) { return atmel_pio4_config_io_func(port, pin, - ATMEL_PIO4_CFGR_FUNC_PERIPH_E, + ATMEL_PIO_CFGR_FUNC_PERIPH_E, use_pullup); }
int atmel_pio4_set_f_periph(u32 port, u32 pin, u32 use_pullup) { return atmel_pio4_config_io_func(port, pin, - ATMEL_PIO4_CFGR_FUNC_PERIPH_F, + ATMEL_PIO_CFGR_FUNC_PERIPH_F, use_pullup); }
int atmel_pio4_set_g_periph(u32 port, u32 pin, u32 use_pullup) { return atmel_pio4_config_io_func(port, pin, - ATMEL_PIO4_CFGR_FUNC_PERIPH_G, + ATMEL_PIO_CFGR_FUNC_PERIPH_G, use_pullup); }
@@ -157,7 +122,7 @@ int atmel_pio4_set_pio_output(u32 port, u32 pin, u32 value) struct atmel_pio4_port *port_base; u32 reg, mask;
port_base = atmel_pio4_port_base(port); @@ -165,7 +130,7 @@ int atmel_pio4_set_pio_output(u32 port, u32 pin, u32 value) return -ENODEV;
mask = 0x01 << pin; - reg = ATMEL_PIO4_CFGR_FUNC_GPIO | ATMEL_PIO4_CFGR_DIR; + reg = ATMEL_PIO_CFGR_FUNC_GPIO | ATMEL_PIO_DIR_MASK;
writel(mask, &port_base->mskr); writel(reg, &port_base->cfgr); @@ -183,7 +148,7 @@ int atmel_pio4_get_pio_input(u32 port, u32 pin) struct atmel_pio4_port *port_base; u32 reg, mask;
port_base = atmel_pio4_port_base(port); @@ -191,7 +156,7 @@ int atmel_pio4_get_pio_input(u32 port, u32 pin) return -ENODEV;
mask = 0x01 << pin; - reg = ATMEL_PIO4_CFGR_FUNC_GPIO; + reg = ATMEL_PIO_CFGR_FUNC_GPIO;
writel(mask, &port_base->mskr); writel(reg, &port_base->cfgr); @@ -205,7 +170,7 @@ static int atmel_pio4_direction_input(struct udevice *dev, unsigned offset) struct at91_port_platdata *plat = dev_get_platdata(dev); struct atmel_pio4_port *port_base = (atmel_pio4_port *)plat->base_addr; u32 mask = 0x01 << offset; - u32 reg = ATMEL_PIO4_CFGR_FUNC_GPIO; + u32 reg = ATMEL_PIO_CFGR_FUNC_GPIO;
writel(mask, &port_base->mskr); writel(reg, &port_base->cfgr); @@ -219,7 +184,7 @@ static int atmel_pio4_direction_output(struct udevice *dev, struct at91_port_platdata *plat = dev_get_platdata(dev); struct atmel_pio4_port *port_base = (atmel_pio4_port *)plat->base_addr; u32 mask = 0x01 << offset; - u32 reg = ATMEL_PIO4_CFGR_FUNC_GPIO | ATMEL_PIO4_CFGR_DIR; + u32 reg = ATMEL_PIO_CFGR_FUNC_GPIO | ATMEL_PIO_DIR_MASK;
writel(mask, &port_base->mskr); writel(reg, &port_base->cfgr); @@ -265,7 +230,7 @@ static int atmel_pio4_get_function(struct udevice *dev, unsigned offset) writel(mask, &port_base->mskr);
return (readl(&port_base->cfgr) & - ATMEL_PIO4_CFGR_DIR) ? GPIOF_OUTPUT : GPIOF_INPUT; + ATMEL_PIO_DIR_MASK) ? GPIOF_OUTPUT : GPIOF_INPUT; }
static const struct dm_gpio_ops atmel_pio4_ops = { @@ -282,7 +247,7 @@ static int atmel_pio4_probe(struct udevice *dev) struct gpio_dev_priv *uc_priv = dev_get_uclass_priv(dev);
uc_priv->bank_name = plat->bank_name; - uc_priv->gpio_count = ATMEL_PIO4_PINS_PER_BANK; + uc_priv->gpio_count = ATMEL_PIO_NPINS_PER_BANK;
return 0; }
Dear Wenyou Yang,
Wenyou Yang wenyou.yang@atmel.com writes:
applied to u-boot-atmel/master, thanks!
Best regards, Andreas Bießmann
Rework the driver to support driver model and device tree, and support to regard the pio4 pinctrl device as a child of atmel_pio4 device.
Changes in v2: None
drivers/gpio/Kconfig | 2 +- drivers/gpio/atmel_pio4.c | 138 ++++++++++++++++++++++++++++++++++++++-------- 2 files changed, 117 insertions(+), 23 deletions(-)
diff --git a/drivers/gpio/Kconfig b/drivers/gpio/Kconfig index 73b862d..3332dab 100644 --- a/drivers/gpio/Kconfig +++ b/drivers/gpio/Kconfig @@ -30,7 +30,7 @@ config DWAPB_GPIO
config ATMEL_PIO4 bool "ATMEL PIO4 driver" - depends on DM + depends on DM_GPIO default n help Say yes here to support the Atmel PIO4 driver. diff --git a/drivers/gpio/atmel_pio4.c b/drivers/gpio/atmel_pio4.c index 84e8cc5..7adea88 100644 --- a/drivers/gpio/atmel_pio4.c +++ b/drivers/gpio/atmel_pio4.c @@ -7,11 +7,17 @@ * SPDX-License-Identifier: GPL-2.0+ */ #include <common.h> +#include <clk.h> #include <dm.h> +#include <fdtdec.h> +#include <dm/root.h> #include <asm/arch/hardware.h> +#include <asm/gpio.h> #include <mach/gpio.h> #include <mach/atmel_pio4.h>
+DECLARE_GLOBAL_DATA_PTR; + static struct atmel_pio4_port *atmel_pio4_port_base(u32 port) { struct atmel_pio4_port *base = NULL; @@ -165,15 +171,37 @@ int atmel_pio4_get_pio_input(u32 port, u32 pin) }
#ifdef CONFIG_DM_GPIO + +struct atmel_pioctrl_data { + u32 nbanks; +}; + +struct atmel_pio4_platdata { + struct atmel_pio4_port *reg_base; +}; + +static struct atmel_pio4_port *atmel_pio4_bank_base(struct udevice *dev, + u32 bank) +{ + struct atmel_pio4_platdata *plat = dev_get_platdata(dev); + struct atmel_pio4_port *port_base = + (struct atmel_pio4_port *)((u32)plat->reg_base + + ATMEL_PIO_BANK_OFFSET * bank); + + return port_base; +} + static int atmel_pio4_direction_input(struct udevice *dev, unsigned offset) { - struct at91_port_platdata *plat = dev_get_platdata(dev); - struct atmel_pio4_port *port_base = (atmel_pio4_port *)plat->base_addr; - u32 mask = 0x01 << offset; - u32 reg = ATMEL_PIO_CFGR_FUNC_GPIO; + u32 bank = ATMEL_PIO_BANK(offset); + u32 line = ATMEL_PIO_LINE(offset); + struct atmel_pio4_port *port_base = atmel_pio4_bank_base(dev, bank); + u32 mask = BIT(line);
writel(mask, &port_base->mskr); - writel(reg, &port_base->cfgr); + + clrbits_le32(&port_base->cfgr, + ATMEL_PIO_CFGR_FUNC_MASK | ATMEL_PIO_DIR_MASK);
return 0; } @@ -181,13 +209,15 @@ static int atmel_pio4_direction_input(struct udevice *dev, unsigned offset) static int atmel_pio4_direction_output(struct udevice *dev, unsigned offset, int value) { - struct at91_port_platdata *plat = dev_get_platdata(dev); - struct atmel_pio4_port *port_base = (atmel_pio4_port *)plat->base_addr; - u32 mask = 0x01 << offset; - u32 reg = ATMEL_PIO_CFGR_FUNC_GPIO | ATMEL_PIO_DIR_MASK; + u32 bank = ATMEL_PIO_BANK(offset); + u32 line = ATMEL_PIO_LINE(offset); + struct atmel_pio4_port *port_base = atmel_pio4_bank_base(dev, bank); + u32 mask = BIT(line);
writel(mask, &port_base->mskr); - writel(reg, &port_base->cfgr); + + clrsetbits_le32(&port_base->cfgr, + ATMEL_PIO_CFGR_FUNC_MASK, ATMEL_PIO_DIR_MASK);
if (value) writel(mask, &port_base->sodr); @@ -199,9 +229,10 @@ static int atmel_pio4_direction_output(struct udevice *dev,
static int atmel_pio4_get_value(struct udevice *dev, unsigned offset) { - struct at91_port_platdata *plat = dev_get_platdata(dev); - struct atmel_pio4_port *port_base = (atmel_pio4_port *)plat->base_addr; - u32 mask = 0x01 << offset; + u32 bank = ATMEL_PIO_BANK(offset); + u32 line = ATMEL_PIO_LINE(offset); + struct atmel_pio4_port *port_base = atmel_pio4_bank_base(dev, bank); + u32 mask = BIT(line);
return (readl(&port_base->pdsr) & mask) ? 1 : 0; } @@ -209,9 +240,10 @@ static int atmel_pio4_get_value(struct udevice *dev, unsigned offset) static int atmel_pio4_set_value(struct udevice *dev, unsigned offset, int value) { - struct at91_port_platdata *plat = dev_get_platdata(dev); - struct atmel_pio4_port *port_base = (atmel_pio4_port *)plat->base_addr; - u32 mask = 0x01 << offset; + u32 bank = ATMEL_PIO_BANK(offset); + u32 line = ATMEL_PIO_LINE(offset); + struct atmel_pio4_port *port_base = atmel_pio4_bank_base(dev, bank); + u32 mask = BIT(line);
if (value) writel(mask, &port_base->sodr); @@ -223,9 +255,10 @@ static int atmel_pio4_set_value(struct udevice *dev,
static int atmel_pio4_get_function(struct udevice *dev, unsigned offset) { - struct at91_port_platdata *plat = dev_get_platdata(dev); - struct atmel_pio4_port *port_base = (atmel_pio4_port *)plat->base_addr; - u32 mask = 0x01 << offset; + u32 bank = ATMEL_PIO_BANK(offset); + u32 line = ATMEL_PIO_LINE(offset); + struct atmel_pio4_port *port_base = atmel_pio4_bank_base(dev, bank); + u32 mask = BIT(line);
@@ -241,21 +274,82 @@ static const struct dm_gpio_ops atmel_pio4_ops = { .get_function = atmel_pio4_get_function, };
+static int atmel_pio4_bind(struct udevice *dev) +{ + return dm_scan_fdt_node(dev, gd->fdt_blob, dev->of_offset, false); +} + static int atmel_pio4_probe(struct udevice *dev) { - struct at91_port_platdata *plat = dev_get_platdata(dev); + struct atmel_pio4_platdata *plat = dev_get_platdata(dev); struct gpio_dev_priv *uc_priv = dev_get_uclass_priv(dev); + struct atmel_pioctrl_data *pioctrl_data; + struct udevice *dev_clk; + struct clk clk; + fdt_addr_t addr_base; + u32 nbanks; + int periph; + int ret; + + ret = clk_get_by_index(dev, 0, &clk); + if (ret) + return ret; + + periph = fdtdec_get_uint(gd->fdt_blob, clk.dev->of_offset, "reg", -1); + if (periph < 0) + return -EINVAL; + + dev_clk = dev_get_parent(clk.dev); + ret = clk_request(dev_clk, &clk); + if (ret) + return ret; + + clk.id = periph; + ret = clk_enable(&clk); + if (ret) + return ret; + + clk_free(&clk); + + addr_base = dev_get_addr(dev); + if (addr_base == FDT_ADDR_T_NONE) + return -EINVAL; + + plat->reg_base = (struct atmel_pio4_port *)addr_base;
- uc_priv->bank_name = plat->bank_name; - uc_priv->gpio_count = ATMEL_PIO_NPINS_PER_BANK; + pioctrl_data = (struct atmel_pioctrl_data *)dev_get_driver_data(dev); + nbanks = pioctrl_data->nbanks; + + uc_priv->bank_name = fdt_get_name(gd->fdt_blob, dev->of_offset, NULL); + uc_priv->gpio_count = nbanks * ATMEL_PIO_NPINS_PER_BANK;
return 0; }
+/* + * The number of banks can be different from a SoC to another one. + * We can have up to 16 banks. + */ +static const struct atmel_pioctrl_data atmel_sama5d2_pioctrl_data = { + .nbanks = 4, +}; + +static const struct udevice_id atmel_pio4_ids[] = { + { + .compatible = "atmel,sama5d2-gpio", + .data = (ulong)&atmel_sama5d2_pioctrl_data, + }, + {} +}; + U_BOOT_DRIVER(gpio_atmel_pio4) = { .name = "gpio_atmel_pio4", .id = UCLASS_GPIO, .ops = &atmel_pio4_ops, .probe = atmel_pio4_probe, + .bind = atmel_pio4_bind, + .of_match = atmel_pio4_ids, + .platdata_auto_alloc_size = sizeof(struct atmel_pio4_platdata), }; + #endif
Dear Wenyou Yang,
Changes in v7:
Changes in v6:
Changes in v5:
Changes in v4:
Changes in v3:
Changes in v2: None
AT91 PIO4 controller is a combined gpio-controller, pin-mux and pin-config module. The peripheral's pins are assigned through per-pin based muxing logic.
The pin configuration is performed on specific registers which are shared along with the gpio controller. So regard the pinctrl device as a child of atmel_pio4 device.
Changes in v7: None Changes in v6: None Changes in v5: - Fixed the return value, -ENODEV->-EINVAL. - Remove check on dev_get_parent() return.
Changes in v4: None Changes in v3: - Rework due to the pinctrl device is regarded as atmel_pio4 device's child.
drivers/pinctrl/Kconfig | 7 ++ drivers/pinctrl/Makefile | 1 + drivers/pinctrl/pinctrl-at91-pio4.c | 182 ++++++++++++++++++++++++++++++++++++ 3 files changed, 190 insertions(+) create mode 100644 drivers/pinctrl/pinctrl-at91-pio4.c
diff --git a/drivers/pinctrl/Kconfig b/drivers/pinctrl/Kconfig index 1785e3b..01ce740 100644 --- a/drivers/pinctrl/Kconfig +++ b/drivers/pinctrl/Kconfig @@ -123,6 +123,13 @@ config QCA953X_PINCTRL both the GPIO definitions and pin control functions for each available multiplex function.
+config PINCTRL_AT91PIO4 + bool "AT91 PIO4 pinctrl driver" + depends on DM + help + This option is to enable the AT91 pinctrl driver for AT91 PIO4 + controller which is available on SAMA5D2 SoC. + config ROCKCHIP_PINCTRL bool "Rockchip pin control driver" depends on DM diff --git a/drivers/pinctrl/Makefile b/drivers/pinctrl/Makefile index 7f94681..c92ab8c 100644 --- a/drivers/pinctrl/Makefile +++ b/drivers/pinctrl/Makefile @@ -5,6 +5,7 @@ obj-y += pinctrl-uclass.o obj-$(CONFIG_$(SPL_)PINCTRL_GENERIC) += pinctrl-generic.o
+obj-$(CONFIG_PINCTRL_AT91PIO4) += pinctrl-at91-pio4.o obj-y += nxp/ obj-$(CONFIG_ARCH_ATH79) += ath79/ obj-$(CONFIG_ARCH_ROCKCHIP) += rockchip/ diff --git a/drivers/pinctrl/pinctrl-at91-pio4.c b/drivers/pinctrl/pinctrl-at91-pio4.c new file mode 100644 index 0000000..6d4aadc --- /dev/null +++ b/drivers/pinctrl/pinctrl-at91-pio4.c @@ -0,0 +1,182 @@ +/* + * Atmel PIO4 pinctrl driver + * + * Copyright (C) 2016 Atmel Corporation + * Wenyou.Yang wenyou.yang@atmel.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm/device.h> +#include <dm/pinctrl.h> +#include <linux/io.h> +#include <linux/err.h> +#include <mach/atmel_pio4.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Warning: + * In order to not introduce confusion between Atmel PIO groups and pinctrl + * framework groups, Atmel PIO groups will be called banks. + */ + +struct atmel_pio4_platdata { + struct atmel_pio4_port *reg_base; +}; + +static const struct pinconf_param conf_params[] = { + { "bias-disable", PIN_CONFIG_BIAS_DISABLE, 0 }, + { "bias-pull-up", PIN_CONFIG_BIAS_PULL_UP, 1 }, + { "bias-pull-down", PIN_CONFIG_BIAS_PULL_DOWN, 1 }, + { "drive-open-drain", PIN_CONFIG_DRIVE_OPEN_DRAIN, 0 }, + { "input-schmitt-disable", PIN_CONFIG_INPUT_SCHMITT_ENABLE, 0 }, + { "input-schmitt-enable", PIN_CONFIG_INPUT_SCHMITT_ENABLE, 1 }, + { "input-debounce", PIN_CONFIG_INPUT_DEBOUNCE, 0 }, +}; + +static u32 atmel_pinctrl_get_pinconf(const void *blob, int node) +{ + const struct pinconf_param *params; + u32 param, arg, conf = 0; + u32 i; + + for (i = 0; i < ARRAY_SIZE(conf_params); i++) { + params = &conf_params[i]; + if (!fdt_get_property(blob, node, params->property, NULL)) + continue; + + param = params->param; + arg = params->default_value; + + switch (param) { + case PIN_CONFIG_BIAS_DISABLE: + conf &= (~ATMEL_PIO_PUEN_MASK); + conf &= (~ATMEL_PIO_PDEN_MASK); + break; + case PIN_CONFIG_BIAS_PULL_UP: + conf |= ATMEL_PIO_PUEN_MASK; + break; + case PIN_CONFIG_BIAS_PULL_DOWN: + conf |= ATMEL_PIO_PDEN_MASK; + break; + case PIN_CONFIG_DRIVE_OPEN_DRAIN: + if (arg == 0) + conf &= (~ATMEL_PIO_OPD_MASK); + else + conf |= ATMEL_PIO_OPD_MASK; + break; + case PIN_CONFIG_INPUT_SCHMITT_ENABLE: + if (arg == 0) + conf |= ATMEL_PIO_SCHMITT_MASK; + else + conf &= (~ATMEL_PIO_SCHMITT_MASK); + break; + case PIN_CONFIG_INPUT_DEBOUNCE: + if (arg == 0) { + conf &= (~ATMEL_PIO_IFEN_MASK); + conf &= (~ATMEL_PIO_IFSCEN_MASK); + } else { + conf |= ATMEL_PIO_IFEN_MASK; + conf |= ATMEL_PIO_IFSCEN_MASK; + } + break; + default: + printf("%s: Unsupported configuration parameter: %u\n", + __func__, param); + break; + } + } + + return conf; +} + +static inline struct atmel_pio4_port *atmel_pio4_bank_base(struct udevice *dev, + u32 bank) +{ + struct atmel_pio4_platdata *plat = dev_get_platdata(dev); + struct atmel_pio4_port *bank_base = + (struct atmel_pio4_port *)((u32)plat->reg_base + + ATMEL_PIO_BANK_OFFSET * bank); + + return bank_base; +} + +#define MAX_PINMUX_ENTRIES 40 + +static int atmel_pinctrl_set_state(struct udevice *dev, struct udevice *config) +{ + struct atmel_pio4_port *bank_base; + const void *blob = gd->fdt_blob; + int node = config->of_offset; + u32 offset, func, bank, line; + u32 cells[MAX_PINMUX_ENTRIES]; + u32 i, conf; + int count; + + conf = atmel_pinctrl_get_pinconf(blob, node); + + count = fdtdec_get_int_array_count(blob, node, "pinmux", + cells, ARRAY_SIZE(cells)); + if (count < 0) { + printf("%s: bad pinmux array %d\n", __func__, count); + return -EINVAL; + } + + if (count > MAX_PINMUX_ENTRIES) { + printf("%s: unsupported pinmux array count %d\n", + __func__, count); + return -EINVAL; + } + + for (i = 0 ; i < count; i++) { + offset = ATMEL_GET_PIN_NO(cells[i]); + func = ATMEL_GET_PIN_FUNC(cells[i]); + + bank = ATMEL_PIO_BANK(offset); + line = ATMEL_PIO_LINE(offset); + + bank_base = atmel_pio4_bank_base(dev, bank); + + writel(BIT(line), &bank_base->mskr); + conf &= (~ATMEL_PIO_CFGR_FUNC_MASK); + conf |= (func & ATMEL_PIO_CFGR_FUNC_MASK); + writel(conf, &bank_base->cfgr); + } + + return 0; +} + +const struct pinctrl_ops atmel_pinctrl_ops = { + .set_state = atmel_pinctrl_set_state, +}; + +static int atmel_pinctrl_probe(struct udevice *dev) +{ + struct atmel_pio4_platdata *plat = dev_get_platdata(dev); + fdt_addr_t addr_base; + + dev = dev_get_parent(dev); + addr_base = dev_get_addr(dev); + if (addr_base == FDT_ADDR_T_NONE) + return -EINVAL; + + plat->reg_base = (struct atmel_pio4_port *)addr_base; + + return 0; +} + +static const struct udevice_id atmel_pinctrl_match[] = { + { .compatible = "atmel,sama5d2-pinctrl" }, + {} +}; + +U_BOOT_DRIVER(atmel_pinctrl) = { + .name = "pinctrl_atmel_pio4", + .id = UCLASS_PINCTRL, + .of_match = atmel_pinctrl_match, + .probe = atmel_pinctrl_probe, + .platdata_auto_alloc_size = sizeof(struct atmel_pio4_platdata), + .ops = &atmel_pinctrl_ops, +};
Dear Wenyou Yang,
Signed-off-by: Wenyou Yang wenyou.yang@atmel.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Andreas Bießmann andreas@biessmann.org
Changes in v2:
I had to rebase this patch before applying.
Bring in required device tree file and bindings from Linux.
Signed-off-by: Wenyou Yang wenyou.yang@atmel.com Reviewed-by: Andreas Bießmann andreas@biessmann.org Reviewed-by: Simon Glass sjg@chromium.org ---
Changes in v7: - Drop [PATCH]: configs: sama5d2_xplained: Add #ifndef before CONFIG_ATMEL_PIO4.
Changes in v6: None Changes in v5: None Changes in v4: None Changes in v3: None Changes in v2: - add detailed example to show how to configure pinctrl for device. - remove interrupt and gpio property description. - add reviewed-by tag.
arch/arm/dts/sama5d2-pinfunc.h | 880 +++++++++++++++++++++ .../pinctrl/atmel,at91-pio4-pinctrl.txt | 66 ++ 2 files changed, 946 insertions(+) create mode 100644 arch/arm/dts/sama5d2-pinfunc.h create mode 100644 doc/device-tree-bindings/pinctrl/atmel,at91-pio4-pinctrl.txt
diff --git a/arch/arm/dts/sama5d2-pinfunc.h b/arch/arm/dts/sama5d2-pinfunc.h new file mode 100644 index 0000000..b0c912f --- /dev/null +++ b/arch/arm/dts/sama5d2-pinfunc.h @@ -0,0 +1,880 @@ +#define PINMUX_PIN(no, func, ioset) \ +(((no) & 0xffff) | (((func) & 0xf) << 16) | (((ioset) & 0xff) << 20)) + +#define PIN_PA0 0 +#define PIN_PA0__GPIO PINMUX_PIN(PIN_PA0, 0, 0) +#define PIN_PA0__SDMMC0_CK PINMUX_PIN(PIN_PA0, 1, 1) +#define PIN_PA0__QSPI0_SCK PINMUX_PIN(PIN_PA0, 2, 1) +#define PIN_PA0__D0 PINMUX_PIN(PIN_PA0, 6, 2) +#define PIN_PA1 1 +#define PIN_PA1__GPIO PINMUX_PIN(PIN_PA1, 0, 0) +#define PIN_PA1__SDMMC0_CMD PINMUX_PIN(PIN_PA1, 1, 1) +#define PIN_PA1__QSPI0_CS PINMUX_PIN(PIN_PA1, 2, 1) +#define PIN_PA1__D1 PINMUX_PIN(PIN_PA1, 6, 2) +#define PIN_PA2 2 +#define PIN_PA2__GPIO PINMUX_PIN(PIN_PA2, 0, 0) +#define PIN_PA2__SDMMC0_DAT0 PINMUX_PIN(PIN_PA2, 1, 1) +#define PIN_PA2__QSPI0_IO0 PINMUX_PIN(PIN_PA2, 2, 1) +#define PIN_PA2__D2 PINMUX_PIN(PIN_PA2, 6, 2) +#define PIN_PA3 3 +#define PIN_PA3__GPIO PINMUX_PIN(PIN_PA3, 0, 0) +#define PIN_PA3__SDMMC0_DAT1 PINMUX_PIN(PIN_PA3, 1, 1) +#define PIN_PA3__QSPI0_IO1 PINMUX_PIN(PIN_PA3, 2, 1) +#define PIN_PA3__D3 PINMUX_PIN(PIN_PA3, 6, 2) +#define PIN_PA4 4 +#define PIN_PA4__GPIO PINMUX_PIN(PIN_PA4, 0, 0) +#define PIN_PA4__SDMMC0_DAT2 PINMUX_PIN(PIN_PA4, 1, 1) +#define PIN_PA4__QSPI0_IO2 PINMUX_PIN(PIN_PA4, 2, 1) +#define PIN_PA4__D4 PINMUX_PIN(PIN_PA4, 6, 2) +#define PIN_PA5 5 +#define PIN_PA5__GPIO PINMUX_PIN(PIN_PA5, 0, 0) +#define PIN_PA5__SDMMC0_DAT3 PINMUX_PIN(PIN_PA5, 1, 1) +#define PIN_PA5__QSPI0_IO3 PINMUX_PIN(PIN_PA5, 2, 1) +#define PIN_PA5__D5 PINMUX_PIN(PIN_PA5, 6, 2) +#define PIN_PA6 6 +#define PIN_PA6__GPIO PINMUX_PIN(PIN_PA6, 0, 0) +#define PIN_PA6__SDMMC0_DAT4 PINMUX_PIN(PIN_PA6, 1, 1) +#define PIN_PA6__QSPI1_SCK PINMUX_PIN(PIN_PA6, 2, 1) +#define PIN_PA6__TIOA5 PINMUX_PIN(PIN_PA6, 4, 1) +#define PIN_PA6__FLEXCOM2_IO0 PINMUX_PIN(PIN_PA6, 5, 1) +#define PIN_PA6__D6 PINMUX_PIN(PIN_PA6, 6, 2) +#define PIN_PA7 7 +#define PIN_PA7__GPIO PINMUX_PIN(PIN_PA7, 0, 0) +#define PIN_PA7__SDMMC0_DAT5 PINMUX_PIN(PIN_PA7, 1, 1) +#define PIN_PA7__QSPI1_IO0 PINMUX_PIN(PIN_PA7, 2, 1) +#define PIN_PA7__TIOB5 PINMUX_PIN(PIN_PA7, 4, 1) +#define PIN_PA7__FLEXCOM2_IO1 PINMUX_PIN(PIN_PA7, 5, 1) +#define PIN_PA7__D7 PINMUX_PIN(PIN_PA7, 6, 2) +#define PIN_PA8 8 +#define PIN_PA8__GPIO PINMUX_PIN(PIN_PA8, 0, 0) +#define PIN_PA8__SDMMC0_DAT6 PINMUX_PIN(PIN_PA8, 1, 1) +#define PIN_PA8__QSPI1_IO1 PINMUX_PIN(PIN_PA8, 2, 1) +#define PIN_PA8__TCLK5 PINMUX_PIN(PIN_PA8, 4, 1) +#define PIN_PA8__FLEXCOM2_IO2 PINMUX_PIN(PIN_PA8, 5, 1) +#define PIN_PA8__NWE_NANDWE PINMUX_PIN(PIN_PA8, 6, 2) +#define PIN_PA9 9 +#define PIN_PA9__GPIO PINMUX_PIN(PIN_PA9, 0, 0) +#define PIN_PA9__SDMMC0_DAT7 PINMUX_PIN(PIN_PA9, 1, 1) +#define PIN_PA9__QSPI1_IO2 PINMUX_PIN(PIN_PA9, 2, 1) +#define PIN_PA9__TIOA4 PINMUX_PIN(PIN_PA9, 4, 1) +#define PIN_PA9__FLEXCOM2_IO3 PINMUX_PIN(PIN_PA9, 5, 1) +#define PIN_PA9__NCS3 PINMUX_PIN(PIN_PA9, 6, 2) +#define PIN_PA10 10 +#define PIN_PA10__GPIO PINMUX_PIN(PIN_PA10, 0, 0) +#define PIN_PA10__SDMMC0_RSTN PINMUX_PIN(PIN_PA10, 1, 1) +#define PIN_PA10__QSPI1_IO3 PINMUX_PIN(PIN_PA10, 2, 1) +#define PIN_PA10__TIOB4 PINMUX_PIN(PIN_PA10, 4, 1) +#define PIN_PA10__FLEXCOM2_IO4 PINMUX_PIN(PIN_PA10, 5, 1) +#define PIN_PA10__A21_NANDALE PINMUX_PIN(PIN_PA10, 6, 2) +#define PIN_PA11 11 +#define PIN_PA11__GPIO PINMUX_PIN(PIN_PA11, 0, 0) +#define PIN_PA11__SDMMC0_VDDSEL PINMUX_PIN(PIN_PA11, 1, 1) +#define PIN_PA11__QSPI1_CS PINMUX_PIN(PIN_PA11, 2, 1) +#define PIN_PA11__TCLK4 PINMUX_PIN(PIN_PA11, 4, 1) +#define PIN_PA11__A22_NANDCLE PINMUX_PIN(PIN_PA11, 6, 2) +#define PIN_PA12 12 +#define PIN_PA12__GPIO PINMUX_PIN(PIN_PA12, 0, 0) +#define PIN_PA12__SDMMC0_WP PINMUX_PIN(PIN_PA12, 1, 1) +#define PIN_PA12__IRQ PINMUX_PIN(PIN_PA12, 2, 1) +#define PIN_PA12__NRD_NANDOE PINMUX_PIN(PIN_PA12, 6, 2) +#define PIN_PA13 13 +#define PIN_PA13__GPIO PINMUX_PIN(PIN_PA13, 0, 0) +#define PIN_PA13__SDMMC0_CD PINMUX_PIN(PIN_PA13, 1, 1) +#define PIN_PA13__FLEXCOM3_IO1 PINMUX_PIN(PIN_PA13, 5, 1) +#define PIN_PA13__D8 PINMUX_PIN(PIN_PA13, 6, 2) +#define PIN_PA14 14 +#define PIN_PA14__GPIO PINMUX_PIN(PIN_PA14, 0, 0) +#define PIN_PA14__SPI0_SPCK PINMUX_PIN(PIN_PA14, 1, 1) +#define PIN_PA14__TK1 PINMUX_PIN(PIN_PA14, 2, 1) +#define PIN_PA14__QSPI0_SCK PINMUX_PIN(PIN_PA14, 3, 2) +#define PIN_PA14__I2SC1_MCK PINMUX_PIN(PIN_PA14, 4, 2) +#define PIN_PA14__FLEXCOM3_IO2 PINMUX_PIN(PIN_PA14, 5, 1) +#define PIN_PA14__D9 PINMUX_PIN(PIN_PA14, 6, 2) +#define PIN_PA15 15 +#define PIN_PA15__GPIO PINMUX_PIN(PIN_PA15, 0, 0) +#define PIN_PA15__SPI0_MOSI PINMUX_PIN(PIN_PA15, 1, 1) +#define PIN_PA15__TF1 PINMUX_PIN(PIN_PA15, 2, 1) +#define PIN_PA15__QSPI0_CS PINMUX_PIN(PIN_PA15, 3, 2) +#define PIN_PA15__I2SC1_CK PINMUX_PIN(PIN_PA15, 4, 2) +#define PIN_PA15__FLEXCOM3_IO0 PINMUX_PIN(PIN_PA15, 5, 1) +#define PIN_PA15__D10 PINMUX_PIN(PIN_PA15, 6, 2) +#define PIN_PA16 16 +#define PIN_PA16__GPIO PINMUX_PIN(PIN_PA16, 0, 0) +#define PIN_PA16__SPI0_MISO PINMUX_PIN(PIN_PA16, 1, 1) +#define PIN_PA16__TD1 PINMUX_PIN(PIN_PA16, 2, 1) +#define PIN_PA16__QSPI0_IO0 PINMUX_PIN(PIN_PA16, 3, 2) +#define PIN_PA16__I2SC1_WS PINMUX_PIN(PIN_PA16, 4, 2) +#define PIN_PA16__FLEXCOM3_IO3 PINMUX_PIN(PIN_PA16, 5, 1) +#define PIN_PA16__D11 PINMUX_PIN(PIN_PA16, 6, 2) +#define PIN_PA17 17 +#define PIN_PA17__GPIO PINMUX_PIN(PIN_PA17, 0, 0) +#define PIN_PA17__SPI0_NPCS0 PINMUX_PIN(PIN_PA17, 1, 1) +#define PIN_PA17__RD1 PINMUX_PIN(PIN_PA17, 2, 1) +#define PIN_PA17__QSPI0_IO1 PINMUX_PIN(PIN_PA17, 3, 2) +#define PIN_PA17__I2SC1_DI0 PINMUX_PIN(PIN_PA17, 4, 2) +#define PIN_PA17__FLEXCOM3_IO4 PINMUX_PIN(PIN_PA17, 5, 1) +#define PIN_PA17__D12 PINMUX_PIN(PIN_PA17, 6, 2) +#define PIN_PA18 18 +#define PIN_PA18__GPIO PINMUX_PIN(PIN_PA18, 0, 0) +#define PIN_PA18__SPI0_NPCS1 PINMUX_PIN(PIN_PA18, 1, 1) +#define PIN_PA18__RK1 PINMUX_PIN(PIN_PA18, 2, 1) +#define PIN_PA18__QSPI0_IO2 PINMUX_PIN(PIN_PA18, 3, 2) +#define PIN_PA18__I2SC1_DO0 PINMUX_PIN(PIN_PA18, 4, 2) +#define PIN_PA18__SDMMC1_DAT0 PINMUX_PIN(PIN_PA18, 5, 1) +#define PIN_PA18__D13 PINMUX_PIN(PIN_PA18, 6, 2) +#define PIN_PA19 19 +#define PIN_PA19__GPIO PINMUX_PIN(PIN_PA19, 0, 0) +#define PIN_PA19__SPI0_NPCS2 PINMUX_PIN(PIN_PA19, 1, 1) +#define PIN_PA19__RF1 PINMUX_PIN(PIN_PA19, 2, 1) +#define PIN_PA19__QSPI0_IO3 PINMUX_PIN(PIN_PA19, 3, 2) +#define PIN_PA19__TIOA0 PINMUX_PIN(PIN_PA19, 4, 1) +#define PIN_PA19__SDMMC1_DAT1 PINMUX_PIN(PIN_PA19, 5, 1) +#define PIN_PA19__D14 PINMUX_PIN(PIN_PA19, 6, 2) +#define PIN_PA20 20 +#define PIN_PA20__GPIO PINMUX_PIN(PIN_PA20, 0, 0) +#define PIN_PA20__SPI0_NPCS3 PINMUX_PIN(PIN_PA20, 1, 1) +#define PIN_PA20__TIOB0 PINMUX_PIN(PIN_PA20, 4, 1) +#define PIN_PA20__SDMMC1_DAT2 PINMUX_PIN(PIN_PA20, 5, 1) +#define PIN_PA20__D15 PINMUX_PIN(PIN_PA20, 6, 2) +#define PIN_PA21 21 +#define PIN_PA21__GPIO PINMUX_PIN(PIN_PA21, 0, 0) +#define PIN_PA21__IRQ PINMUX_PIN(PIN_PA21, 1, 2) +#define PIN_PA21__PCK2 PINMUX_PIN(PIN_PA21, 2, 3) +#define PIN_PA21__TCLK0 PINMUX_PIN(PIN_PA21, 4, 1) +#define PIN_PA21__SDMMC1_DAT3 PINMUX_PIN(PIN_PA21, 5, 1) +#define PIN_PA21__NANDRDY PINMUX_PIN(PIN_PA21, 6, 2) +#define PIN_PA22 22 +#define PIN_PA22__GPIO PINMUX_PIN(PIN_PA22, 0, 0) +#define PIN_PA22__FLEXCOM1_IO2 PINMUX_PIN(PIN_PA22, 1, 1) +#define PIN_PA22__D0 PINMUX_PIN(PIN_PA22, 2, 1) +#define PIN_PA22__TCK PINMUX_PIN(PIN_PA22, 3, 4) +#define PIN_PA22__SPI1_SPCK PINMUX_PIN(PIN_PA22, 4, 2) +#define PIN_PA22__SDMMC1_CK PINMUX_PIN(PIN_PA22, 5, 1) +#define PIN_PA22__QSPI0_SCK PINMUX_PIN(PIN_PA22, 6, 3) +#define PIN_PA23 23 +#define PIN_PA23__GPIO PINMUX_PIN(PIN_PA23, 0, 0) +#define PIN_PA23__FLEXCOM1_IO1 PINMUX_PIN(PIN_PA23, 1, 1) +#define PIN_PA23__D1 PINMUX_PIN(PIN_PA23, 2, 1) +#define PIN_PA23__TDI PINMUX_PIN(PIN_PA23, 3, 4) +#define PIN_PA23__SPI1_MOSI PINMUX_PIN(PIN_PA23, 4, 2) +#define PIN_PA23__QSPI0_CS PINMUX_PIN(PIN_PA23, 6, 3) +#define PIN_PA24 24 +#define PIN_PA24__GPIO PINMUX_PIN(PIN_PA24, 0, 0) +#define PIN_PA24__FLEXCOM1_IO0 PINMUX_PIN(PIN_PA24, 1, 1) +#define PIN_PA24__D2 PINMUX_PIN(PIN_PA24, 2, 1) +#define PIN_PA24__TDO PINMUX_PIN(PIN_PA24, 3, 4) +#define PIN_PA24__SPI1_MISO PINMUX_PIN(PIN_PA24, 4, 2) +#define PIN_PA24__QSPI0_IO0 PINMUX_PIN(PIN_PA24, 6, 3) +#define PIN_PA25 25 +#define PIN_PA25__GPIO PINMUX_PIN(PIN_PA25, 0, 0) +#define PIN_PA25__FLEXCOM1_IO3 PINMUX_PIN(PIN_PA25, 1, 1) +#define PIN_PA25__D3 PINMUX_PIN(PIN_PA25, 2, 1) +#define PIN_PA25__TMS PINMUX_PIN(PIN_PA25, 3, 4) +#define PIN_PA25__SPI1_NPCS0 PINMUX_PIN(PIN_PA25, 4, 2) +#define PIN_PA25__QSPI0_IO1 PINMUX_PIN(PIN_PA25, 6, 3) +#define PIN_PA26 26 +#define PIN_PA26__GPIO PINMUX_PIN(PIN_PA26, 0, 0) +#define PIN_PA26__FLEXCOM1_IO4 PINMUX_PIN(PIN_PA26, 1, 1) +#define PIN_PA26__D4 PINMUX_PIN(PIN_PA26, 2, 1) +#define PIN_PA26__NTRST PINMUX_PIN(PIN_PA26, 3, 4) +#define PIN_PA26__SPI1_NPCS1 PINMUX_PIN(PIN_PA26, 4, 2) +#define PIN_PA26__QSPI0_IO2 PINMUX_PIN(PIN_PA26, 6, 3) +#define PIN_PA27 27 +#define PIN_PA27__GPIO PINMUX_PIN(PIN_PA27, 0, 0) +#define PIN_PA27__TIOA1 PINMUX_PIN(PIN_PA27, 1, 2) +#define PIN_PA27__D5 PINMUX_PIN(PIN_PA27, 2, 1) +#define PIN_PA27__SPI0_NPCS2 PINMUX_PIN(PIN_PA27, 3, 2) +#define PIN_PA27__SPI1_NPCS2 PINMUX_PIN(PIN_PA27, 4, 2) +#define PIN_PA27__SDMMC1_RSTN PINMUX_PIN(PIN_PA27, 5, 1) +#define PIN_PA27__QSPI0_IO3 PINMUX_PIN(PIN_PA27, 6, 3) +#define PIN_PA28 28 +#define PIN_PA28__GPIO PINMUX_PIN(PIN_PA28, 0, 0) +#define PIN_PA28__TIOB1 PINMUX_PIN(PIN_PA28, 1, 2) +#define PIN_PA28__D6 PINMUX_PIN(PIN_PA28, 2, 1) +#define PIN_PA28__SPI0_NPCS3 PINMUX_PIN(PIN_PA28, 3, 2) +#define PIN_PA28__SPI1_NPCS3 PINMUX_PIN(PIN_PA28, 4, 2) +#define PIN_PA28__SDMMC1_CMD PINMUX_PIN(PIN_PA28, 5, 1) +#define PIN_PA28__CLASSD_L0 PINMUX_PIN(PIN_PA28, 6, 1) +#define PIN_PA29 29 +#define PIN_PA29__GPIO PINMUX_PIN(PIN_PA29, 0, 0) +#define PIN_PA29__TCLK1 PINMUX_PIN(PIN_PA29, 1, 2) +#define PIN_PA29__D7 PINMUX_PIN(PIN_PA29, 2, 1) +#define PIN_PA29__SPI0_NPCS1 PINMUX_PIN(PIN_PA29, 3, 2) +#define PIN_PA29__SDMMC1_WP PINMUX_PIN(PIN_PA29, 5, 1) +#define PIN_PA29__CLASSD_L1 PINMUX_PIN(PIN_PA29, 6, 1) +#define PIN_PA30 30 +#define PIN_PA30__GPIO PINMUX_PIN(PIN_PA30, 0, 0) +#define PIN_PA30__NWE_NANDWE PINMUX_PIN(PIN_PA30, 2, 1) +#define PIN_PA30__SPI0_NPCS0 PINMUX_PIN(PIN_PA30, 3, 2) +#define PIN_PA30__PWMH0 PINMUX_PIN(PIN_PA30, 4, 1) +#define PIN_PA30__SDMMC1_CD PINMUX_PIN(PIN_PA30, 5, 1) +#define PIN_PA30__CLASSD_L2 PINMUX_PIN(PIN_PA30, 6, 1) +#define PIN_PA31 31 +#define PIN_PA31__GPIO PINMUX_PIN(PIN_PA31, 0, 0) +#define PIN_PA31__NCS3 PINMUX_PIN(PIN_PA31, 2, 1) +#define PIN_PA31__SPI0_MISO PINMUX_PIN(PIN_PA31, 3, 2) +#define PIN_PA31__PWML0 PINMUX_PIN(PIN_PA31, 4, 1) +#define PIN_PA31__CLASSD_L3 PINMUX_PIN(PIN_PA31, 6, 1) +#define PIN_PB0 32 +#define PIN_PB0__GPIO PINMUX_PIN(PIN_PB0, 0, 0) +#define PIN_PB0__A21_NANDALE PINMUX_PIN(PIN_PB0, 2, 1) +#define PIN_PB0__SPI0_MOSI PINMUX_PIN(PIN_PB0, 3, 2) +#define PIN_PB0__PWMH1 PINMUX_PIN(PIN_PB0, 4, 1) +#define PIN_PB1 33 +#define PIN_PB1__GPIO PINMUX_PIN(PIN_PB1, 0, 0) +#define PIN_PB1__A22_NANDCLE PINMUX_PIN(PIN_PB1, 2, 1) +#define PIN_PB1__SPI0_SPCK PINMUX_PIN(PIN_PB1, 3, 2) +#define PIN_PB1__PWML1 PINMUX_PIN(PIN_PB1, 4, 1) +#define PIN_PB1__CLASSD_R0 PINMUX_PIN(PIN_PB1, 6, 1) +#define PIN_PB2 34 +#define PIN_PB2__GPIO PINMUX_PIN(PIN_PB2, 0, 0) +#define PIN_PB2__NRD_NANDOE PINMUX_PIN(PIN_PB2, 2, 1) +#define PIN_PB2__PWMFI0 PINMUX_PIN(PIN_PB2, 4, 1) +#define PIN_PB2__CLASSD_R1 PINMUX_PIN(PIN_PB2, 6, 1) +#define PIN_PB3 35 +#define PIN_PB3__GPIO PINMUX_PIN(PIN_PB3, 0, 0) +#define PIN_PB3__URXD4 PINMUX_PIN(PIN_PB3, 1, 1) +#define PIN_PB3__D8 PINMUX_PIN(PIN_PB3, 2, 1) +#define PIN_PB3__IRQ PINMUX_PIN(PIN_PB3, 3, 3) +#define PIN_PB3__PWMEXTRG0 PINMUX_PIN(PIN_PB3, 4, 1) +#define PIN_PB3__CLASSD_R2 PINMUX_PIN(PIN_PB3, 6, 1) +#define PIN_PB4 36 +#define PIN_PB4__GPIO PINMUX_PIN(PIN_PB4, 0, 0) +#define PIN_PB4__UTXD4 PINMUX_PIN(PIN_PB4, 1, 1) +#define PIN_PB4__D9 PINMUX_PIN(PIN_PB4, 2, 1) +#define PIN_PB4__FIQ PINMUX_PIN(PIN_PB4, 3, 4) +#define PIN_PB4__CLASSD_R3 PINMUX_PIN(PIN_PB4, 6, 1) +#define PIN_PB5 37 +#define PIN_PB5__GPIO PINMUX_PIN(PIN_PB5, 0, 0) +#define PIN_PB5__TCLK2 PINMUX_PIN(PIN_PB5, 1, 1) +#define PIN_PB5__D10 PINMUX_PIN(PIN_PB5, 2, 1) +#define PIN_PB5__PWMH2 PINMUX_PIN(PIN_PB5, 3, 1) +#define PIN_PB5__QSPI1_SCK PINMUX_PIN(PIN_PB5, 4, 2) +#define PIN_PB5__GTSUCOMP PINMUX_PIN(PIN_PB5, 6, 3) +#define PIN_PB6 38 +#define PIN_PB6__GPIO PINMUX_PIN(PIN_PB6, 0, 0) +#define PIN_PB6__TIOA2 PINMUX_PIN(PIN_PB6, 1, 1) +#define PIN_PB6__D11 PINMUX_PIN(PIN_PB6, 2, 1) +#define PIN_PB6__PWML2 PINMUX_PIN(PIN_PB6, 3, 1) +#define PIN_PB6__QSPI1_CS PINMUX_PIN(PIN_PB6, 4, 2) +#define PIN_PB6__GTXER PINMUX_PIN(PIN_PB6, 6, 3) +#define PIN_PB7 39 +#define PIN_PB7__GPIO PINMUX_PIN(PIN_PB7, 0, 0) +#define PIN_PB7__TIOB2 PINMUX_PIN(PIN_PB7, 1, 1) +#define PIN_PB7__D12 PINMUX_PIN(PIN_PB7, 2, 1) +#define PIN_PB7__PWMH3 PINMUX_PIN(PIN_PB7, 3, 1) +#define PIN_PB7__QSPI1_IO0 PINMUX_PIN(PIN_PB7, 4, 2) +#define PIN_PB7__GRXCK PINMUX_PIN(PIN_PB7, 6, 3) +#define PIN_PB8 40 +#define PIN_PB8__GPIO PINMUX_PIN(PIN_PB8, 0, 0) +#define PIN_PB8__TCLK3 PINMUX_PIN(PIN_PB8, 1, 1) +#define PIN_PB8__D13 PINMUX_PIN(PIN_PB8, 2, 1) +#define PIN_PB8__PWML3 PINMUX_PIN(PIN_PB8, 3, 1) +#define PIN_PB8__QSPI1_IO1 PINMUX_PIN(PIN_PB8, 4, 2) +#define PIN_PB8__GCRS PINMUX_PIN(PIN_PB8, 6, 3) +#define PIN_PB9 41 +#define PIN_PB9__GPIO PINMUX_PIN(PIN_PB9, 0, 0) +#define PIN_PB9__TIOA3 PINMUX_PIN(PIN_PB9, 1, 1) +#define PIN_PB9__D14 PINMUX_PIN(PIN_PB9, 2, 1) +#define PIN_PB9__PWMFI1 PINMUX_PIN(PIN_PB9, 3, 1) +#define PIN_PB9__QSPI1_IO2 PINMUX_PIN(PIN_PB9, 4, 2) +#define PIN_PB9__GCOL PINMUX_PIN(PIN_PB9, 6, 3) +#define PIN_PB10 42 +#define PIN_PB10__GPIO PINMUX_PIN(PIN_PB10, 0, 0) +#define PIN_PB10__TIOB3 PINMUX_PIN(PIN_PB10, 1, 1) +#define PIN_PB10__D15 PINMUX_PIN(PIN_PB10, 2, 1) +#define PIN_PB10__PWMEXTRG1 PINMUX_PIN(PIN_PB10, 3, 1) +#define PIN_PB10__QSPI1_IO3 PINMUX_PIN(PIN_PB10, 4, 2) +#define PIN_PB10__GRX2 PINMUX_PIN(PIN_PB10, 6, 3) +#define PIN_PB11 43 +#define PIN_PB11__GPIO PINMUX_PIN(PIN_PB11, 0, 0) +#define PIN_PB11__LCDDAT0 PINMUX_PIN(PIN_PB11, 1, 1) +#define PIN_PB11__A0_NBS0 PINMUX_PIN(PIN_PB11, 2, 1) +#define PIN_PB11__URXD3 PINMUX_PIN(PIN_PB11, 3, 3) +#define PIN_PB11__PDMIC_DAT PINMUX_PIN(PIN_PB11, 4, 2) +#define PIN_PB11__GRX3 PINMUX_PIN(PIN_PB11, 6, 3) +#define PIN_PB12 44 +#define PIN_PB12__GPIO PINMUX_PIN(PIN_PB12, 0, 0) +#define PIN_PB12__LCDDAT1 PINMUX_PIN(PIN_PB12, 1, 1) +#define PIN_PB12__A1 PINMUX_PIN(PIN_PB12, 2, 1) +#define PIN_PB12__UTXD3 PINMUX_PIN(PIN_PB12, 3, 3) +#define PIN_PB12__PDMIC_CLK PINMUX_PIN(PIN_PB12, 4, 2) +#define PIN_PB12__GTX2 PINMUX_PIN(PIN_PB12, 6, 3) +#define PIN_PB13 45 +#define PIN_PB13__GPIO PINMUX_PIN(PIN_PB13, 0, 0) +#define PIN_PB13__LCDDAT2 PINMUX_PIN(PIN_PB13, 1, 1) +#define PIN_PB13__A2 PINMUX_PIN(PIN_PB13, 2, 1) +#define PIN_PB13__PCK1 PINMUX_PIN(PIN_PB13, 3, 3) +#define PIN_PB13__GTX3 PINMUX_PIN(PIN_PB13, 6, 3) +#define PIN_PB14 46 +#define PIN_PB14__GPIO PINMUX_PIN(PIN_PB14, 0, 0) +#define PIN_PB14__LCDDAT3 PINMUX_PIN(PIN_PB14, 1, 1) +#define PIN_PB14__A3 PINMUX_PIN(PIN_PB14, 2, 1) +#define PIN_PB14__TK1 PINMUX_PIN(PIN_PB14, 3, 2) +#define PIN_PB14__I2SC1_MCK PINMUX_PIN(PIN_PB14, 4, 1) +#define PIN_PB14__QSPI1_SCK PINMUX_PIN(PIN_PB14, 5, 3) +#define PIN_PB14__GTXCK PINMUX_PIN(PIN_PB14, 6, 3) +#define PIN_PB15 47 +#define PIN_PB15__GPIO PINMUX_PIN(PIN_PB15, 0, 0) +#define PIN_PB15__LCDDAT4 PINMUX_PIN(PIN_PB15, 1, 1) +#define PIN_PB15__A4 PINMUX_PIN(PIN_PB15, 2, 1) +#define PIN_PB15__TF1 PINMUX_PIN(PIN_PB15, 3, 2) +#define PIN_PB15__I2SC1_CK PINMUX_PIN(PIN_PB15, 4, 1) +#define PIN_PB15__QSPI1_CS PINMUX_PIN(PIN_PB15, 5, 3) +#define PIN_PB15__GTXEN PINMUX_PIN(PIN_PB15, 6, 3) +#define PIN_PB16 48 +#define PIN_PB16__GPIO PINMUX_PIN(PIN_PB16, 0, 0) +#define PIN_PB16__LCDDAT5 PINMUX_PIN(PIN_PB16, 1, 1) +#define PIN_PB16__A5 PINMUX_PIN(PIN_PB16, 2, 1) +#define PIN_PB16__TD1 PINMUX_PIN(PIN_PB16, 3, 2) +#define PIN_PB16__I2SC1_WS PINMUX_PIN(PIN_PB16, 4, 1) +#define PIN_PB16__QSPI1_IO0 PINMUX_PIN(PIN_PB16, 5, 3) +#define PIN_PB16__GRXDV PINMUX_PIN(PIN_PB16, 6, 3) +#define PIN_PB17 49 +#define PIN_PB17__GPIO PINMUX_PIN(PIN_PB17, 0, 0) +#define PIN_PB17__LCDDAT6 PINMUX_PIN(PIN_PB17, 1, 1) +#define PIN_PB17__A6 PINMUX_PIN(PIN_PB17, 2, 1) +#define PIN_PB17__RD1 PINMUX_PIN(PIN_PB17, 3, 2) +#define PIN_PB17__I2SC1_DI0 PINMUX_PIN(PIN_PB17, 4, 1) +#define PIN_PB17__QSPI1_IO1 PINMUX_PIN(PIN_PB17, 5, 3) +#define PIN_PB17__GRXER PINMUX_PIN(PIN_PB17, 6, 3) +#define PIN_PB18 50 +#define PIN_PB18__GPIO PINMUX_PIN(PIN_PB18, 0, 0) +#define PIN_PB18__LCDDAT7 PINMUX_PIN(PIN_PB18, 1, 1) +#define PIN_PB18__A7 PINMUX_PIN(PIN_PB18, 2, 1) +#define PIN_PB18__RK1 PINMUX_PIN(PIN_PB18, 3, 2) +#define PIN_PB18__I2SC1_DO0 PINMUX_PIN(PIN_PB18, 4, 1) +#define PIN_PB18__QSPI1_IO2 PINMUX_PIN(PIN_PB18, 5, 3) +#define PIN_PB18__GRX0 PINMUX_PIN(PIN_PB18, 6, 3) +#define PIN_PB19 51 +#define PIN_PB19__GPIO PINMUX_PIN(PIN_PB19, 0, 0) +#define PIN_PB19__LCDDAT8 PINMUX_PIN(PIN_PB19, 1, 1) +#define PIN_PB19__A8 PINMUX_PIN(PIN_PB19, 2, 1) +#define PIN_PB19__RF1 PINMUX_PIN(PIN_PB19, 3, 2) +#define PIN_PB19__TIOA3 PINMUX_PIN(PIN_PB19, 4, 2) +#define PIN_PB19__QSPI1_IO3 PINMUX_PIN(PIN_PB19, 5, 3) +#define PIN_PB19__GRX1 PINMUX_PIN(PIN_PB19, 6, 3) +#define PIN_PB20 52 +#define PIN_PB20__GPIO PINMUX_PIN(PIN_PB20, 0, 0) +#define PIN_PB20__LCDDAT9 PINMUX_PIN(PIN_PB20, 1, 1) +#define PIN_PB20__A9 PINMUX_PIN(PIN_PB20, 2, 1) +#define PIN_PB20__TK0 PINMUX_PIN(PIN_PB20, 3, 1) +#define PIN_PB20__TIOB3 PINMUX_PIN(PIN_PB20, 4, 2) +#define PIN_PB20__PCK1 PINMUX_PIN(PIN_PB20, 5, 4) +#define PIN_PB20__GTX0 PINMUX_PIN(PIN_PB20, 6, 3) +#define PIN_PB21 53 +#define PIN_PB21__GPIO PINMUX_PIN(PIN_PB21, 0, 0) +#define PIN_PB21__LCDDAT10 PINMUX_PIN(PIN_PB21, 1, 1) +#define PIN_PB21__A10 PINMUX_PIN(PIN_PB21, 2, 1) +#define PIN_PB21__TF0 PINMUX_PIN(PIN_PB21, 3, 1) +#define PIN_PB21__TCLK3 PINMUX_PIN(PIN_PB21, 4, 2) +#define PIN_PB21__FLEXCOM3_IO2 PINMUX_PIN(PIN_PB21, 5, 3) +#define PIN_PB21__GTX1 PINMUX_PIN(PIN_PB21, 6, 3) +#define PIN_PB22 54 +#define PIN_PB22__GPIO PINMUX_PIN(PIN_PB22, 0, 0) +#define PIN_PB22__LCDDAT11 PINMUX_PIN(PIN_PB22, 1, 1) +#define PIN_PB22__A11 PINMUX_PIN(PIN_PB22, 2, 1) +#define PIN_PB22__TDO PINMUX_PIN(PIN_PB22, 3, 1) +#define PIN_PB22__TIOA2 PINMUX_PIN(PIN_PB22, 4, 2) +#define PIN_PB22__FLEXCOM3_IO1 PINMUX_PIN(PIN_PB22, 5, 3) +#define PIN_PB22__GMDC PINMUX_PIN(PIN_PB22, 6, 3) +#define PIN_PB23 55 +#define PIN_PB23__GPIO PINMUX_PIN(PIN_PB23, 0, 0) +#define PIN_PB23__LCDDAT12 PINMUX_PIN(PIN_PB23, 1, 1) +#define PIN_PB23__A12 PINMUX_PIN(PIN_PB23, 2, 1) +#define PIN_PB23__RD0 PINMUX_PIN(PIN_PB23, 3, 1) +#define PIN_PB23__TIOB2 PINMUX_PIN(PIN_PB23, 4, 2) +#define PIN_PB23__FLEXCOM3_IO0 PINMUX_PIN(PIN_PB23, 5, 3) +#define PIN_PB23__GMDIO PINMUX_PIN(PIN_PB23, 6, 3) +#define PIN_PB24 56 +#define PIN_PB24__GPIO PINMUX_PIN(PIN_PB24, 0, 0) +#define PIN_PB24__LCDDAT13 PINMUX_PIN(PIN_PB24, 1, 1) +#define PIN_PB24__A13 PINMUX_PIN(PIN_PB24, 2, 1) +#define PIN_PB24__RK0 PINMUX_PIN(PIN_PB24, 3, 1) +#define PIN_PB24__TCLK2 PINMUX_PIN(PIN_PB24, 4, 2) +#define PIN_PB24__FLEXCOM3_IO3 PINMUX_PIN(PIN_PB24, 5, 3) +#define PIN_PB24__ISC_D10 PINMUX_PIN(PIN_PB24, 6, 3) +#define PIN_PB25 57 +#define PIN_PB25__GPIO PINMUX_PIN(PIN_PB25, 0, 0) +#define PIN_PB25__LCDDAT14 PINMUX_PIN(PIN_PB25, 1, 1) +#define PIN_PB25__A14 PINMUX_PIN(PIN_PB25, 2, 1) +#define PIN_PB25__RF0 PINMUX_PIN(PIN_PB25, 3, 1) +#define PIN_PB25__FLEXCOM3_IO4 PINMUX_PIN(PIN_PB25, 5, 3) +#define PIN_PB25__ISC_D11 PINMUX_PIN(PIN_PB25, 6, 3) +#define PIN_PB26 58 +#define PIN_PB26__GPIO PINMUX_PIN(PIN_PB26, 0, 0) +#define PIN_PB26__LCDDAT15 PINMUX_PIN(PIN_PB26, 1, 1) +#define PIN_PB26__A15 PINMUX_PIN(PIN_PB26, 2, 1) +#define PIN_PB26__URXD0 PINMUX_PIN(PIN_PB26, 3, 1) +#define PIN_PB26__PDMIC_DAT PINMUX_PIN(PIN_PB26, 4, 1) +#define PIN_PB26__ISC_D0 PINMUX_PIN(PIN_PB26, 6, 3) +#define PIN_PB27 59 +#define PIN_PB27__GPIO PINMUX_PIN(PIN_PB27, 0, 0) +#define PIN_PB27__LCDDAT16 PINMUX_PIN(PIN_PB27, 1, 1) +#define PIN_PB27__A16 PINMUX_PIN(PIN_PB27, 2, 1) +#define PIN_PB27__UTXD0 PINMUX_PIN(PIN_PB27, 3, 1) +#define PIN_PB27__PDMIC_CLK PINMUX_PIN(PIN_PB27, 4, 1) +#define PIN_PB27__ISC_D1 PINMUX_PIN(PIN_PB27, 6, 3) +#define PIN_PB28 60 +#define PIN_PB28__GPIO PINMUX_PIN(PIN_PB28, 0, 0) +#define PIN_PB28__LCDDAT17 PINMUX_PIN(PIN_PB28, 1, 1) +#define PIN_PB28__A17 PINMUX_PIN(PIN_PB28, 2, 1) +#define PIN_PB28__FLEXCOM0_IO0 PINMUX_PIN(PIN_PB28, 3, 1) +#define PIN_PB28__TIOA5 PINMUX_PIN(PIN_PB28, 4, 2) +#define PIN_PB28__ISC_D2 PINMUX_PIN(PIN_PB28, 6, 3) +#define PIN_PB29 61 +#define PIN_PB29__GPIO PINMUX_PIN(PIN_PB29, 0, 0) +#define PIN_PB29__LCDDAT18 PINMUX_PIN(PIN_PB29, 1, 1) +#define PIN_PB29__A18 PINMUX_PIN(PIN_PB29, 2, 1) +#define PIN_PB29__FLEXCOM0_IO1 PINMUX_PIN(PIN_PB29, 3, 1) +#define PIN_PB29__TIOB5 PINMUX_PIN(PIN_PB29, 4, 2) +#define PIN_PB29__ISC_D3 PINMUX_PIN(PIN_PB29, 7, 3) +#define PIN_PB30 62 +#define PIN_PB30__GPIO PINMUX_PIN(PIN_PB30, 0, 0) +#define PIN_PB30__LCDDAT19 PINMUX_PIN(PIN_PB30, 1, 1) +#define PIN_PB30__A19 PINMUX_PIN(PIN_PB30, 2, 1) +#define PIN_PB30__FLEXCOM0_IO2 PINMUX_PIN(PIN_PB30, 3, 1) +#define PIN_PB30__TCLK5 PINMUX_PIN(PIN_PB30, 4, 2) +#define PIN_PB30__ISC_D4 PINMUX_PIN(PIN_PB30, 6, 3) +#define PIN_PB31 63 +#define PIN_PB31__GPIO PINMUX_PIN(PIN_PB31, 0, 0) +#define PIN_PB31__LCDDAT20 PINMUX_PIN(PIN_PB31, 1, 1) +#define PIN_PB31__A20 PINMUX_PIN(PIN_PB31, 2, 1) +#define PIN_PB31__FLEXCOM0_IO3 PINMUX_PIN(PIN_PB31, 3, 1) +#define PIN_PB31__TWD0 PINMUX_PIN(PIN_PB31, 4, 1) +#define PIN_PB31__ISC_D5 PINMUX_PIN(PIN_PB31, 6, 3) +#define PIN_PC0 64 +#define PIN_PC0__GPIO PINMUX_PIN(PIN_PC0, 0, 0) +#define PIN_PC0__LCDDAT21 PINMUX_PIN(PIN_PC0, 1, 1) +#define PIN_PC0__A23 PINMUX_PIN(PIN_PC0, 2, 1) +#define PIN_PC0__FLEXCOM0_IO4 PINMUX_PIN(PIN_PC0, 3, 1) +#define PIN_PC0__TWCK0 PINMUX_PIN(PIN_PC0, 4, 1) +#define PIN_PC0__ISC_D6 PINMUX_PIN(PIN_PC0, 6, 3) +#define PIN_PC1 65 +#define PIN_PC1__GPIO PINMUX_PIN(PIN_PC1, 0, 0) +#define PIN_PC1__LCDDAT22 PINMUX_PIN(PIN_PC1, 1, 1) +#define PIN_PC1__A24 PINMUX_PIN(PIN_PC1, 2, 1) +#define PIN_PC1__CANTX0 PINMUX_PIN(PIN_PC1, 3, 1) +#define PIN_PC1__SPI1_SPCK PINMUX_PIN(PIN_PC1, 4, 1) +#define PIN_PC1__I2SC0_CK PINMUX_PIN(PIN_PC1, 5, 1) +#define PIN_PC1__ISC_D7 PINMUX_PIN(PIN_PC1, 6, 3) +#define PIN_PC2 66 +#define PIN_PC2__GPIO PINMUX_PIN(PIN_PC2, 0, 0) +#define PIN_PC2__LCDDAT23 PINMUX_PIN(PIN_PC2, 1, 1) +#define PIN_PC2__A25 PINMUX_PIN(PIN_PC2, 2, 1) +#define PIN_PC2__CANRX0 PINMUX_PIN(PIN_PC2, 3, 1) +#define PIN_PC2__SPI1_MOSI PINMUX_PIN(PIN_PC2, 4, 1) +#define PIN_PC2__I2SC0_MCK PINMUX_PIN(PIN_PC2, 5, 1) +#define PIN_PC2__ISC_D8 PINMUX_PIN(PIN_PC2, 6, 3) +#define PIN_PC3 67 +#define PIN_PC3__GPIO PINMUX_PIN(PIN_PC3, 0, 0) +#define PIN_PC3__LCDPWM PINMUX_PIN(PIN_PC3, 1, 1) +#define PIN_PC3__NWAIT PINMUX_PIN(PIN_PC3, 2, 1) +#define PIN_PC3__TIOA1 PINMUX_PIN(PIN_PC3, 3, 1) +#define PIN_PC3__SPI1_MISO PINMUX_PIN(PIN_PC3, 4, 1) +#define PIN_PC3__I2SC0_WS PINMUX_PIN(PIN_PC3, 5, 1) +#define PIN_PC3__ISC_D9 PINMUX_PIN(PIN_PC3, 6, 3) +#define PIN_PC4 68 +#define PIN_PC4__GPIO PINMUX_PIN(PIN_PC4, 0, 0) +#define PIN_PC4__LCDDISP PINMUX_PIN(PIN_PC4, 1, 1) +#define PIN_PC4__NWR1_NBS1 PINMUX_PIN(PIN_PC4, 2, 1) +#define PIN_PC4__TIOB1 PINMUX_PIN(PIN_PC4, 3, 1) +#define PIN_PC4__SPI1_NPCS0 PINMUX_PIN(PIN_PC4, 4, 1) +#define PIN_PC4__I2SC0_DI0 PINMUX_PIN(PIN_PC4, 5, 1) +#define PIN_PC4__ISC_PCK PINMUX_PIN(PIN_PC4, 6, 3) +#define PIN_PC5 69 +#define PIN_PC5__GPIO PINMUX_PIN(PIN_PC5, 0, 0) +#define PIN_PC5__LCDVSYNC PINMUX_PIN(PIN_PC5, 1, 1) +#define PIN_PC5__NCS0 PINMUX_PIN(PIN_PC5, 2, 1) +#define PIN_PC5__TCLK1 PINMUX_PIN(PIN_PC5, 3, 1) +#define PIN_PC5__SPI1_NPCS1 PINMUX_PIN(PIN_PC5, 4, 1) +#define PIN_PC5__I2SC0_DO0 PINMUX_PIN(PIN_PC5, 5, 1) +#define PIN_PC5__ISC_VSYNC PINMUX_PIN(PIN_PC5, 6, 3) +#define PIN_PC6 70 +#define PIN_PC6__GPIO PINMUX_PIN(PIN_PC6, 0, 0) +#define PIN_PC6__LCDHSYNC PINMUX_PIN(PIN_PC6, 1, 1) +#define PIN_PC6__NCS1 PINMUX_PIN(PIN_PC6, 2, 1) +#define PIN_PC6__TWD1 PINMUX_PIN(PIN_PC6, 3, 1) +#define PIN_PC6__SPI1_NPCS2 PINMUX_PIN(PIN_PC6, 4, 1) +#define PIN_PC6__ISC_HSYNC PINMUX_PIN(PIN_PC6, 6, 3) +#define PIN_PC7 71 +#define PIN_PC7__GPIO PINMUX_PIN(PIN_PC7, 0, 0) +#define PIN_PC7__LCDPCK PINMUX_PIN(PIN_PC7, 1, 1) +#define PIN_PC7__NCS2 PINMUX_PIN(PIN_PC7, 2, 1) +#define PIN_PC7__TWCK1 PINMUX_PIN(PIN_PC7, 3, 1) +#define PIN_PC7__SPI1_NPCS3 PINMUX_PIN(PIN_PC7, 4, 1) +#define PIN_PC7__URXD1 PINMUX_PIN(PIN_PC7, 5, 2) +#define PIN_PC7__ISC_MCK PINMUX_PIN(PIN_PC7, 6, 3) +#define PIN_PC8 72 +#define PIN_PC8__GPIO PINMUX_PIN(PIN_PC8, 0, 0) +#define PIN_PC8__LCDDEN PINMUX_PIN(PIN_PC8, 1, 1) +#define PIN_PC8__NANDRDY PINMUX_PIN(PIN_PC8, 2, 1) +#define PIN_PC8__FIQ PINMUX_PIN(PIN_PC8, 3, 1) +#define PIN_PC8__PCK0 PINMUX_PIN(PIN_PC8, 4, 3) +#define PIN_PC8__UTXD1 PINMUX_PIN(PIN_PC8, 5, 2) +#define PIN_PC8__ISC_FIELD PINMUX_PIN(PIN_PC8, 6, 3) +#define PIN_PC9 73 +#define PIN_PC9__GPIO PINMUX_PIN(PIN_PC9, 0, 0) +#define PIN_PC9__FIQ PINMUX_PIN(PIN_PC9, 1, 3) +#define PIN_PC9__GTSUCOMP PINMUX_PIN(PIN_PC9, 2, 1) +#define PIN_PC9__ISC_D0 PINMUX_PIN(PIN_PC9, 2, 1) +#define PIN_PC9__TIOA4 PINMUX_PIN(PIN_PC9, 4, 2) +#define PIN_PC10 74 +#define PIN_PC10__GPIO PINMUX_PIN(PIN_PC10, 0, 0) +#define PIN_PC10__LCDDAT2 PINMUX_PIN(PIN_PC10, 1, 2) +#define PIN_PC10__GTXCK PINMUX_PIN(PIN_PC10, 2, 1) +#define PIN_PC10__ISC_D1 PINMUX_PIN(PIN_PC10, 3, 1) +#define PIN_PC10__TIOB4 PINMUX_PIN(PIN_PC10, 4, 2) +#define PIN_PC10__CANTX0 PINMUX_PIN(PIN_PC10, 5, 2) +#define PIN_PC11 75 +#define PIN_PC11__GPIO PINMUX_PIN(PIN_PC11, 0, 0) +#define PIN_PC11__LCDDAT3 PINMUX_PIN(PIN_PC11, 1, 2) +#define PIN_PC11__GTXEN PINMUX_PIN(PIN_PC11, 2, 1) +#define PIN_PC11__ISC_D2 PINMUX_PIN(PIN_PC11, 3, 1) +#define PIN_PC11__TCLK4 PINMUX_PIN(PIN_PC11, 4, 2) +#define PIN_PC11__CANRX0 PINMUX_PIN(PIN_PC11, 5, 2) +#define PIN_PC11__A0_NBS0 PINMUX_PIN(PIN_PC11, 6, 2) +#define PIN_PC12 76 +#define PIN_PC12__GPIO PINMUX_PIN(PIN_PC12, 0, 0) +#define PIN_PC12__LCDDAT4 PINMUX_PIN(PIN_PC12, 1, 2) +#define PIN_PC12__GRXDV PINMUX_PIN(PIN_PC12, 2, 1) +#define PIN_PC12__ISC_D3 PINMUX_PIN(PIN_PC12, 3, 1) +#define PIN_PC12__URXD3 PINMUX_PIN(PIN_PC12, 4, 1) +#define PIN_PC12__TK0 PINMUX_PIN(PIN_PC12, 5, 2) +#define PIN_PC12__A1 PINMUX_PIN(PIN_PC12, 6, 2) +#define PIN_PC13 77 +#define PIN_PC13__GPIO PINMUX_PIN(PIN_PC13, 0, 0) +#define PIN_PC13__LCDDAT5 PINMUX_PIN(PIN_PC13, 1, 2) +#define PIN_PC13__GRXER PINMUX_PIN(PIN_PC13, 2, 1) +#define PIN_PC13__ISC_D4 PINMUX_PIN(PIN_PC13, 3, 1) +#define PIN_PC13__UTXD3 PINMUX_PIN(PIN_PC13, 4, 1) +#define PIN_PC13__TF0 PINMUX_PIN(PIN_PC13, 5, 2) +#define PIN_PC13__A2 PINMUX_PIN(PIN_PC13, 6, 2) +#define PIN_PC14 78 +#define PIN_PC14__GPIO PINMUX_PIN(PIN_PC14, 0, 0) +#define PIN_PC14__LCDDAT6 PINMUX_PIN(PIN_PC14, 1, 2) +#define PIN_PC14__GRX0 PINMUX_PIN(PIN_PC14, 2, 1) +#define PIN_PC14__ISC_D5 PINMUX_PIN(PIN_PC14, 3, 1) +#define PIN_PC14__TDO PINMUX_PIN(PIN_PC14, 5, 2) +#define PIN_PC14__A3 PINMUX_PIN(PIN_PC14, 6, 2) +#define PIN_PC15 79 +#define PIN_PC15__GPIO PINMUX_PIN(PIN_PC15, 0, 0) +#define PIN_PC15__LCDDAT7 PINMUX_PIN(PIN_PC15, 1, 2) +#define PIN_PC15__GRX1 PINMUX_PIN(PIN_PC15, 2, 1) +#define PIN_PC15__ISC_D6 PINMUX_PIN(PIN_PC15, 3, 1) +#define PIN_PC15__RD0 PINMUX_PIN(PIN_PC15, 5, 2) +#define PIN_PC15__A4 PINMUX_PIN(PIN_PC15, 6, 2) +#define PIN_PC16 80 +#define PIN_PC16__GPIO PINMUX_PIN(PIN_PC16, 0, 0) +#define PIN_PC16__LCDDAT10 PINMUX_PIN(PIN_PC16, 1, 2) +#define PIN_PC16__GTX0 PINMUX_PIN(PIN_PC16, 2, 1) +#define PIN_PC16__ISC_D7 PINMUX_PIN(PIN_PC16, 3, 1) +#define PIN_PC16__RK0 PINMUX_PIN(PIN_PC16, 5, 2) +#define PIN_PC16__A5 PINMUX_PIN(PIN_PC16, 6, 2) +#define PIN_PC17 81 +#define PIN_PC17__GPIO PINMUX_PIN(PIN_PC17, 0, 0) +#define PIN_PC17__LCDDAT11 PINMUX_PIN(PIN_PC17, 1, 2) +#define PIN_PC17__GTX1 PINMUX_PIN(PIN_PC17, 2, 1) +#define PIN_PC17__ISC_D8 PINMUX_PIN(PIN_PC17, 3, 1) +#define PIN_PC17__RF0 PINMUX_PIN(PIN_PC17, 5, 2) +#define PIN_PC17__A6 PINMUX_PIN(PIN_PC17, 6, 2) +#define PIN_PC18 82 +#define PIN_PC18__GPIO PINMUX_PIN(PIN_PC18, 0, 0) +#define PIN_PC18__LCDDAT12 PINMUX_PIN(PIN_PC18, 1, 2) +#define PIN_PC18__GMDC PINMUX_PIN(PIN_PC18, 2, 1) +#define PIN_PC18__ISC_D9 PINMUX_PIN(PIN_PC18, 3, 1) +#define PIN_PC18__FLEXCOM3_IO2 PINMUX_PIN(PIN_PC18, 5, 2) +#define PIN_PC18__A7 PINMUX_PIN(PIN_PC18, 6, 2) +#define PIN_PC19 83 +#define PIN_PC19__GPIO PINMUX_PIN(PIN_PC19, 0, 0) +#define PIN_PC19__LCDDAT13 PINMUX_PIN(PIN_PC19, 1, 2) +#define PIN_PC19__GMDIO PINMUX_PIN(PIN_PC19, 2, 1) +#define PIN_PC19__ISC_D10 PINMUX_PIN(PIN_PC19, 3, 1) +#define PIN_PC19__FLEXCOM3_IO1 PINMUX_PIN(PIN_PC19, 5, 2) +#define PIN_PC19__A8 PINMUX_PIN(PIN_PC19, 6, 2) +#define PIN_PC20 84 +#define PIN_PC20__GPIO PINMUX_PIN(PIN_PC20, 0, 0) +#define PIN_PC20__LCDDAT14 PINMUX_PIN(PIN_PC20, 1, 2) +#define PIN_PC20__GRXCK PINMUX_PIN(PIN_PC20, 2, 1) +#define PIN_PC20__ISC_D11 PINMUX_PIN(PIN_PC20, 3, 1) +#define PIN_PC20__FLEXCOM3_IO0 PINMUX_PIN(PIN_PC20, 5, 2) +#define PIN_PC20__A9 PINMUX_PIN(PIN_PC20, 6, 2) +#define PIN_PC21 85 +#define PIN_PC21__GPIO PINMUX_PIN(PIN_PC21, 0, 0) +#define PIN_PC21__LCDDAT15 PINMUX_PIN(PIN_PC21, 1, 2) +#define PIN_PC21__GTXER PINMUX_PIN(PIN_PC21, 2, 1) +#define PIN_PC21__ISC_PCK PINMUX_PIN(PIN_PC21, 3, 1) +#define PIN_PC21__FLEXCOM3_IO3 PINMUX_PIN(PIN_PC21, 5, 2) +#define PIN_PC21__A10 PINMUX_PIN(PIN_PC21, 6, 2) +#define PIN_PC22 86 +#define PIN_PC22__GPIO PINMUX_PIN(PIN_PC22, 0, 0) +#define PIN_PC22__LCDDAT18 PINMUX_PIN(PIN_PC22, 1, 2) +#define PIN_PC22__GCRS PINMUX_PIN(PIN_PC22, 2, 1) +#define PIN_PC22__ISC_VSYNC PINMUX_PIN(PIN_PC22, 3, 1) +#define PIN_PC22__FLEXCOM3_IO4 PINMUX_PIN(PIN_PC22, 5, 2) +#define PIN_PC22__A11 PINMUX_PIN(PIN_PC22, 6, 2) +#define PIN_PC23 87 +#define PIN_PC23__GPIO PINMUX_PIN(PIN_PC23, 0, 0) +#define PIN_PC23__LCDDAT19 PINMUX_PIN(PIN_PC23, 1, 2) +#define PIN_PC23__GCOL PINMUX_PIN(PIN_PC23, 2, 1) +#define PIN_PC23__ISC_HSYNC PINMUX_PIN(PIN_PC23, 3, 1) +#define PIN_PC23__A12 PINMUX_PIN(PIN_PC23, 6, 2) +#define PIN_PC24 88 +#define PIN_PC24__GPIO PINMUX_PIN(PIN_PC24, 0, 0) +#define PIN_PC24__LCDDAT20 PINMUX_PIN(PIN_PC24, 1, 2) +#define PIN_PC24__GRX2 PINMUX_PIN(PIN_PC24, 2, 1) +#define PIN_PC24__ISC_MCK PINMUX_PIN(PIN_PC24, 3, 1) +#define PIN_PC24__A13 PINMUX_PIN(PIN_PC24, 6, 2) +#define PIN_PC25 89 +#define PIN_PC25__GPIO PINMUX_PIN(PIN_PC25, 0, 0) +#define PIN_PC25__LCDDAT21 PINMUX_PIN(PIN_PC25, 1, 2) +#define PIN_PC25__GRX3 PINMUX_PIN(PIN_PC25, 2, 1) +#define PIN_PC25__ISC_FIELD PINMUX_PIN(PIN_PC25, 3, 1) +#define PIN_PC25__A14 PINMUX_PIN(PIN_PC25, 6, 2) +#define PIN_PC26 90 +#define PIN_PC26__GPIO PINMUX_PIN(PIN_PC26, 0, 0) +#define PIN_PC26__LCDDAT22 PINMUX_PIN(PIN_PC26, 1, 2) +#define PIN_PC26__GTX2 PINMUX_PIN(PIN_PC26, 2, 1) +#define PIN_PC26__CANTX1 PINMUX_PIN(PIN_PC26, 4, 1) +#define PIN_PC26__A15 PINMUX_PIN(PIN_PC26, 6, 2) +#define PIN_PC27 91 +#define PIN_PC27__GPIO PINMUX_PIN(PIN_PC27, 0, 0) +#define PIN_PC27__LCDDAT23 PINMUX_PIN(PIN_PC27, 1, 2) +#define PIN_PC27__GTX3 PINMUX_PIN(PIN_PC27, 2, 1) +#define PIN_PC27__PCK1 PINMUX_PIN(PIN_PC27, 3, 2) +#define PIN_PC27__CANRX1 PINMUX_PIN(PIN_PC27, 4, 1) +#define PIN_PC27__TWD0 PINMUX_PIN(PIN_PC27, 5, 2) +#define PIN_PC27__A16 PINMUX_PIN(PIN_PC27, 6, 2) +#define PIN_PC28 92 +#define PIN_PC28__GPIO PINMUX_PIN(PIN_PC28, 0, 0) +#define PIN_PC28__LCDPWM PINMUX_PIN(PIN_PC28, 1, 2) +#define PIN_PC28__FLEXCOM4_IO0 PINMUX_PIN(PIN_PC28, 2, 1) +#define PIN_PC28__PCK2 PINMUX_PIN(PIN_PC28, 3, 2) +#define PIN_PC28__TWCK0 PINMUX_PIN(PIN_PC28, 5, 2) +#define PIN_PC28__A17 PINMUX_PIN(PIN_PC28, 6, 2) +#define PIN_PC29 93 +#define PIN_PC29__GPIO PINMUX_PIN(PIN_PC29, 0, 0) +#define PIN_PC29__LCDDISP PINMUX_PIN(PIN_PC29, 1, 2) +#define PIN_PC29__FLEXCOM4_IO1 PINMUX_PIN(PIN_PC29, 2, 1) +#define PIN_PC29__A18 PINMUX_PIN(PIN_PC29, 6, 2) +#define PIN_PC30 94 +#define PIN_PC30__GPIO PINMUX_PIN(PIN_PC30, 0, 0) +#define PIN_PC30__LCDVSYNC PINMUX_PIN(PIN_PC30, 1, 2) +#define PIN_PC30__FLEXCOM4_IO2 PINMUX_PIN(PIN_PC30, 2, 1) +#define PIN_PC30__A19 PINMUX_PIN(PIN_PC30, 6, 2) +#define PIN_PC31 95 +#define PIN_PC31__GPIO PINMUX_PIN(PIN_PC31, 0, 0) +#define PIN_PC31__LCDHSYNC PINMUX_PIN(PIN_PC31, 1, 2) +#define PIN_PC31__FLEXCOM4_IO3 PINMUX_PIN(PIN_PC31, 2, 1) +#define PIN_PC31__URXD3 PINMUX_PIN(PIN_PC31, 3, 2) +#define PIN_PC31__A20 PINMUX_PIN(PIN_PC31, 6, 2) +#define PIN_PD0 96 +#define PIN_PD0__GPIO PINMUX_PIN(PIN_PD0, 0, 0) +#define PIN_PD0__LCDPCK PINMUX_PIN(PIN_PD0, 1, 2) +#define PIN_PD0__FLEXCOM4_IO4 PINMUX_PIN(PIN_PD0, 2, 1) +#define PIN_PD0__UTXD3 PINMUX_PIN(PIN_PD0, 3, 2) +#define PIN_PD0__GTSUCOMP PINMUX_PIN(PIN_PD0, 4, 2) +#define PIN_PD0__A23 PINMUX_PIN(PIN_PD0, 6, 2) +#define PIN_PD1 97 +#define PIN_PD1__GPIO PINMUX_PIN(PIN_PD1, 0, 0) +#define PIN_PD1__LCDDEN PINMUX_PIN(PIN_PD1, 1, 2) +#define PIN_PD1__GRXCK PINMUX_PIN(PIN_PD1, 4, 2) +#define PIN_PD1__A24 PINMUX_PIN(PIN_PD1, 6, 2) +#define PIN_PD2 98 +#define PIN_PD2__GPIO PINMUX_PIN(PIN_PD2, 0, 0) +#define PIN_PD2__URXD1 PINMUX_PIN(PIN_PD2, 1, 1) +#define PIN_PD2__GTXER PINMUX_PIN(PIN_PD2, 4, 2) +#define PIN_PD2__ISC_MCK PINMUX_PIN(PIN_PD2, 5, 2) +#define PIN_PD2__A25 PINMUX_PIN(PIN_PD2, 6, 2) +#define PIN_PD3 99 +#define PIN_PD3__GPIO PINMUX_PIN(PIN_PD3, 0, 0) +#define PIN_PD3__UTXD1 PINMUX_PIN(PIN_PD3, 1, 1) +#define PIN_PD3__FIQ PINMUX_PIN(PIN_PD3, 2, 2) +#define PIN_PD3__GCRS PINMUX_PIN(PIN_PD3, 4, 2) +#define PIN_PD3__ISC_D11 PINMUX_PIN(PIN_PD3, 5, 2) +#define PIN_PD3__NWAIT PINMUX_PIN(PIN_PD3, 6, 2) +#define PIN_PD4 100 +#define PIN_PD4__GPIO PINMUX_PIN(PIN_PD4, 0, 0) +#define PIN_PD4__TWD1 PINMUX_PIN(PIN_PD4, 1, 2) +#define PIN_PD4__URXD2 PINMUX_PIN(PIN_PD4, 2, 1) +#define PIN_PD4__GCOL PINMUX_PIN(PIN_PD4, 4, 2) +#define PIN_PD4__ISC_D10 PINMUX_PIN(PIN_PD4, 5, 2) +#define PIN_PD4__NCS0 PINMUX_PIN(PIN_PD4, 6, 2) +#define PIN_PD5 101 +#define PIN_PD5__GPIO PINMUX_PIN(PIN_PD5, 0, 0) +#define PIN_PD5__TWCK1 PINMUX_PIN(PIN_PD5, 1, 2) +#define PIN_PD5__UTXD2 PINMUX_PIN(PIN_PD5, 2, 1) +#define PIN_PD5__GRX2 PINMUX_PIN(PIN_PD5, 4, 2) +#define PIN_PD5__ISC_D9 PINMUX_PIN(PIN_PD5, 5, 2) +#define PIN_PD5__NCS1 PINMUX_PIN(PIN_PD5, 6, 2) +#define PIN_PD6 102 +#define PIN_PD6__GPIO PINMUX_PIN(PIN_PD6, 0, 0) +#define PIN_PD6__TCK PINMUX_PIN(PIN_PD6, 1, 2) +#define PIN_PD6__PCK1 PINMUX_PIN(PIN_PD6, 2, 1) +#define PIN_PD6__GRX3 PINMUX_PIN(PIN_PD6, 4, 2) +#define PIN_PD6__ISC_D8 PINMUX_PIN(PIN_PD6, 5, 2) +#define PIN_PD6__NCS2 PINMUX_PIN(PIN_PD6, 6, 2) +#define PIN_PD7 103 +#define PIN_PD7__GPIO PINMUX_PIN(PIN_PD7, 0, 0) +#define PIN_PD7__TDI PINMUX_PIN(PIN_PD7, 1, 2) +#define PIN_PD7__UTMI_RXVAL PINMUX_PIN(PIN_PD7, 3, 1) +#define PIN_PD7__GTX2 PINMUX_PIN(PIN_PD7, 4, 2) +#define PIN_PD7__ISC_D0 PINMUX_PIN(PIN_PD7, 5, 2) +#define PIN_PD7__NWR1_NBS1 PINMUX_PIN(PIN_PD7, 6, 2) +#define PIN_PD8 104 +#define PIN_PD8__GPIO PINMUX_PIN(PIN_PD8, 0, 0) +#define PIN_PD8__TDO PINMUX_PIN(PIN_PD8, 1, 2) +#define PIN_PD8__UTMI_RXERR PINMUX_PIN(PIN_PD8, 3, 1) +#define PIN_PD8__GTX3 PINMUX_PIN(PIN_PD8, 4, 2) +#define PIN_PD8__ISC_D1 PINMUX_PIN(PIN_PD8, 5, 2) +#define PIN_PD8__NANDRDY PINMUX_PIN(PIN_PD8, 6, 2) +#define PIN_PD9 105 +#define PIN_PD9__GPIO PINMUX_PIN(PIN_PD9, 0, 0) +#define PIN_PD9__TMS PINMUX_PIN(PIN_PD9, 1, 2) +#define PIN_PD9__UTMI_RXACT PINMUX_PIN(PIN_PD9, 3, 1) +#define PIN_PD9__GTXCK PINMUX_PIN(PIN_PD9, 4, 2) +#define PIN_PD9__ISC_D2 PINMUX_PIN(PIN_PD9, 5, 2) +#define PIN_PD10 106 +#define PIN_PD10__GPIO PINMUX_PIN(PIN_PD10, 0, 0) +#define PIN_PD10__NTRST PINMUX_PIN(PIN_PD10, 1, 2) +#define PIN_PD10__UTMI_HDIS PINMUX_PIN(PIN_PD10, 3, 1) +#define PIN_PD10__GTXEN PINMUX_PIN(PIN_PD10, 4, 2) +#define PIN_PD10__ISC_D3 PINMUX_PIN(PIN_PD10, 5, 2) +#define PIN_PD11 107 +#define PIN_PD11__GPIO PINMUX_PIN(PIN_PD11, 0, 0) +#define PIN_PD11__TIOA1 PINMUX_PIN(PIN_PD11, 1, 3) +#define PIN_PD11__PCK2 PINMUX_PIN(PIN_PD11, 2, 2) +#define PIN_PD11__UTMI_LS0 PINMUX_PIN(PIN_PD11, 3, 1) +#define PIN_PD11__GRXDV PINMUX_PIN(PIN_PD11, 4, 2) +#define PIN_PD11__ISC_D4 PINMUX_PIN(PIN_PD11, 5, 2) +#define PIN_PD11__ISC_MCK PINMUX_PIN(PIN_PD11, 7, 4) +#define PIN_PD12 108 +#define PIN_PD12__GPIO PINMUX_PIN(PIN_PD12, 0, 0) +#define PIN_PD12__TIOB1 PINMUX_PIN(PIN_PD12, 1, 3) +#define PIN_PD12__FLEXCOM4_IO0 PINMUX_PIN(PIN_PD12, 2, 2) +#define PIN_PD12__UTMI_LS1 PINMUX_PIN(PIN_PD12, 3, 1) +#define PIN_PD12__GRXER PINMUX_PIN(PIN_PD12, 4, 2) +#define PIN_PD12__ISC_D5 PINMUX_PIN(PIN_PD12, 5, 2) +#define PIN_PD12__ISC_D4 PINMUX_PIN(PIN_PD12, 6, 4) +#define PIN_PD13 109 +#define PIN_PD13__GPIO PINMUX_PIN(PIN_PD13, 0, 0) +#define PIN_PD13__TCLK1 PINMUX_PIN(PIN_PD13, 1, 3) +#define PIN_PD13__FLEXCOM4_IO1 PINMUX_PIN(PIN_PD13, 2, 2) +#define PIN_PD13__UTMI_CDRPCSEL0 PINMUX_PIN(PIN_PD13, 3, 1) +#define PIN_PD13__GRX0 PINMUX_PIN(PIN_PD13, 4, 2) +#define PIN_PD13__ISC_D6 PINMUX_PIN(PIN_PD13, 5, 2) +#define PIN_PD13__ISC_D5 PINMUX_PIN(PIN_PD13, 6, 4) +#define PIN_PD14 110 +#define PIN_PD14__GPIO PINMUX_PIN(PIN_PD14, 0, 0) +#define PIN_PD14__TCK PINMUX_PIN(PIN_PD14, 1, 1) +#define PIN_PD14__FLEXCOM4_IO2 PINMUX_PIN(PIN_PD14, 2, 2) +#define PIN_PD14__UTMI_CDRPCSEL1 PINMUX_PIN(PIN_PD14, 3, 1) +#define PIN_PD14__GRX1 PINMUX_PIN(PIN_PD14, 4, 2) +#define PIN_PD14__ISC_D7 PINMUX_PIN(PIN_PD14, 5, 2) +#define PIN_PD14__ISC_D6 PINMUX_PIN(PIN_PD14, 6, 4) +#define PIN_PD15 111 +#define PIN_PD15__GPIO PINMUX_PIN(PIN_PD15, 0, 0) +#define PIN_PD15__TDI PINMUX_PIN(PIN_PD15, 1, 1) +#define PIN_PD15__FLEXCOM4_IO3 PINMUX_PIN(PIN_PD15, 2, 2) +#define PIN_PD15__UTMI_CDRCPDIVEN PINMUX_PIN(PIN_PD15, 3, 1) +#define PIN_PD15__GTX0 PINMUX_PIN(PIN_PD15, 4, 2) +#define PIN_PD15__ISC_PCK PINMUX_PIN(PIN_PD15, 5, 2) +#define PIN_PD15__ISC_D7 PINMUX_PIN(PIN_PD15, 6, 4) +#define PIN_PD16 112 +#define PIN_PD16__GPIO PINMUX_PIN(PIN_PD16, 0, 0) +#define PIN_PD16__TDO PINMUX_PIN(PIN_PD16, 1, 1) +#define PIN_PD16__FLEXCOM4_IO4 PINMUX_PIN(PIN_PD16, 2, 2) +#define PIN_PD16__UTMI_CDRBISTEN PINMUX_PIN(PIN_PD16, 3, 1) +#define PIN_PD16__GTX1 PINMUX_PIN(PIN_PD16, 4, 2) +#define PIN_PD16__ISC_VSYNC PINMUX_PIN(PIN_PD16, 5, 2) +#define PIN_PD16__ISC_D8 PINMUX_PIN(PIN_PD16, 6, 4) +#define PIN_PD17 113 +#define PIN_PD17__GPIO PINMUX_PIN(PIN_PD17, 0, 0) +#define PIN_PD17__TMS PINMUX_PIN(PIN_PD17, 1, 1) +#define PIN_PD17__UTMI_CDRCPSELDIV PINMUX_PIN(PIN_PD17, 3, 1) +#define PIN_PD17__GMDC PINMUX_PIN(PIN_PD17, 4, 2) +#define PIN_PD17__ISC_HSYNC PINMUX_PIN(PIN_PD17, 5, 2) +#define PIN_PD17__ISC_D9 PINMUX_PIN(PIN_PD17, 6, 4) +#define PIN_PD18 114 +#define PIN_PD18__GPIO PINMUX_PIN(PIN_PD18, 0, 0) +#define PIN_PD18__NTRST PINMUX_PIN(PIN_PD18, 1, 1) +#define PIN_PD18__GMDIO PINMUX_PIN(PIN_PD18, 4, 2) +#define PIN_PD18__ISC_FIELD PINMUX_PIN(PIN_PD18, 5, 2) +#define PIN_PD18__ISC_D10 PINMUX_PIN(PIN_PD18, 6, 4) +#define PIN_PD19 115 +#define PIN_PD19__GPIO PINMUX_PIN(PIN_PD19, 0, 0) +#define PIN_PD19__PCK0 PINMUX_PIN(PIN_PD19, 1, 1) +#define PIN_PD19__TWD1 PINMUX_PIN(PIN_PD19, 2, 3) +#define PIN_PD19__URXD2 PINMUX_PIN(PIN_PD19, 3, 3) +#define PIN_PD19__I2SC0_CK PINMUX_PIN(PIN_PD19, 5, 2) +#define PIN_PD19__ISC_D11 PINMUX_PIN(PIN_PD19, 6, 4) +#define PIN_PD20 116 +#define PIN_PD20__GPIO PINMUX_PIN(PIN_PD20, 0, 0) +#define PIN_PD20__TIOA2 PINMUX_PIN(PIN_PD20, 1, 3) +#define PIN_PD20__TWCK1 PINMUX_PIN(PIN_PD20, 2, 3) +#define PIN_PD20__UTXD2 PINMUX_PIN(PIN_PD20, 3, 3) +#define PIN_PD20__I2SC0_MCK PINMUX_PIN(PIN_PD20, 5, 2) +#define PIN_PD20__ISC_PCK PINMUX_PIN(PIN_PD20, 6, 4) +#define PIN_PD21 117 +#define PIN_PD21__GPIO PINMUX_PIN(PIN_PD21, 0, 0) +#define PIN_PD21__TIOB2 PINMUX_PIN(PIN_PD21, 1, 3) +#define PIN_PD21__TWD0 PINMUX_PIN(PIN_PD21, 2, 4) +#define PIN_PD21__FLEXCOM4_IO0 PINMUX_PIN(PIN_PD21, 3, 3) +#define PIN_PD21__I2SC0_WS PINMUX_PIN(PIN_PD21, 5, 2) +#define PIN_PD21__ISC_VSYNC PINMUX_PIN(PIN_PD21, 6, 4) +#define PIN_PD22 118 +#define PIN_PD22__GPIO PINMUX_PIN(PIN_PD22, 0, 0) +#define PIN_PD22__TCLK2 PINMUX_PIN(PIN_PD22, 1, 3) +#define PIN_PD22__TWCK0 PINMUX_PIN(PIN_PD22, 2, 4) +#define PIN_PD22__FLEXCOM4_IO1 PINMUX_PIN(PIN_PD22, 3, 3) +#define PIN_PD22__I2SC0_DI0 PINMUX_PIN(PIN_PD22, 5, 2) +#define PIN_PD22__ISC_HSYNC PINMUX_PIN(PIN_PD22, 6, 4) +#define PIN_PD23 119 +#define PIN_PD23__GPIO PINMUX_PIN(PIN_PD23, 0, 0) +#define PIN_PD23__URXD2 PINMUX_PIN(PIN_PD23, 1, 2) +#define PIN_PD23__FLEXCOM4_IO2 PINMUX_PIN(PIN_PD23, 3, 3) +#define PIN_PD23__I2SC0_DO0 PINMUX_PIN(PIN_PD23, 5, 2) +#define PIN_PD23__ISC_FIELD PINMUX_PIN(PIN_PD23, 6, 4) +#define PIN_PD24 120 +#define PIN_PD24__GPIO PINMUX_PIN(PIN_PD24, 0, 0) +#define PIN_PD24__UTXD2 PINMUX_PIN(PIN_PD23, 1, 2) +#define PIN_PD24__FLEXCOM4_IO3 PINMUX_PIN(PIN_PD23, 3, 3) +#define PIN_PD25 121 +#define PIN_PD25__GPIO PINMUX_PIN(PIN_PD25, 0, 0) +#define PIN_PD25__SPI1_SPCK PINMUX_PIN(PIN_PD25, 1, 3) +#define PIN_PD25__FLEXCOM4_IO4 PINMUX_PIN(PIN_PD25, 3, 3) +#define PIN_PD26 122 +#define PIN_PD26__GPIO PINMUX_PIN(PIN_PD26, 0, 0) +#define PIN_PD26__SPI1_MOSI PINMUX_PIN(PIN_PD26, 1, 3) +#define PIN_PD26__FLEXCOM2_IO0 PINMUX_PIN(PIN_PD26, 3, 2) +#define PIN_PD27 123 +#define PIN_PD27__GPIO PINMUX_PIN(PIN_PD27, 0, 0) +#define PIN_PD27__SPI1_MISO PINMUX_PIN(PIN_PD27, 1, 3) +#define PIN_PD27__TCK PINMUX_PIN(PIN_PD27, 2, 3) +#define PIN_PD27__FLEXCOM2_IO1 PINMUX_PIN(PIN_PD27, 3, 2) +#define PIN_PD28 124 +#define PIN_PD28__GPIO PINMUX_PIN(PIN_PD28, 0, 0) +#define PIN_PD28__SPI1_NPCS0 PINMUX_PIN(PIN_PD28, 1, 3) +#define PIN_PD28__TCI PINMUX_PIN(PIN_PD28, 2, 3) +#define PIN_PD28__FLEXCOM2_IO2 PINMUX_PIN(PIN_PD28, 3, 2) +#define PIN_PD29 125 +#define PIN_PD29__GPIO PINMUX_PIN(PIN_PD29, 0, 0) +#define PIN_PD29__SPI1_NPCS1 PINMUX_PIN(PIN_PD29, 1, 3) +#define PIN_PD29__TDO PINMUX_PIN(PIN_PD29, 2, 3) +#define PIN_PD29__FLEXCOM2_IO3 PINMUX_PIN(PIN_PD29, 3, 2) +#define PIN_PD29__TIOA3 PINMUX_PIN(PIN_PD29, 4, 3) +#define PIN_PD29__TWD0 PINMUX_PIN(PIN_PD29, 5, 3) +#define PIN_PD30 126 +#define PIN_PD30__GPIO PINMUX_PIN(PIN_PD30, 0, 0) +#define PIN_PD30__SPI1_NPCS2 PINMUX_PIN(PIN_PD30, 1, 3) +#define PIN_PD30__TMS PINMUX_PIN(PIN_PD30, 2, 3) +#define PIN_PD30__FLEXCOM2_IO4 PINMUX_PIN(PIN_PD30, 3, 2) +#define PIN_PD30__TIOB3 PINMUX_PIN(PIN_PD30, 4, 3) +#define PIN_PD30__TWCK0 PINMUX_PIN(PIN_PD30, 5, 3) +#define PIN_PD31 127 +#define PIN_PD31__GPIO PINMUX_PIN(PIN_PD31, 0, 0) +#define PIN_PD31__ADTRG PINMUX_PIN(PIN_PD31, 1, 1) +#define PIN_PD31__NTRST PINMUX_PIN(PIN_PD31, 2, 3) +#define PIN_PD31__IRQ PINMUX_PIN(PIN_PD31, 3, 4) +#define PIN_PD31__TCLK3 PINMUX_PIN(PIN_PD31, 4, 3) +#define PIN_PD31__PCK0 PINMUX_PIN(PIN_PD31, 5, 2) diff --git a/doc/device-tree-bindings/pinctrl/atmel,at91-pio4-pinctrl.txt b/doc/device-tree-bindings/pinctrl/atmel,at91-pio4-pinctrl.txt new file mode 100644 index 0000000..a1b5596 --- /dev/null +++ b/doc/device-tree-bindings/pinctrl/atmel,at91-pio4-pinctrl.txt @@ -0,0 +1,66 @@ +* Atmel PIO4 Controller + +The Atmel PIO4 controller is used to select the function of a pin and to +configure it. + +Required properties: +- compatible: "atmel,sama5d2-pinctrl". +- reg: base address and length of the PIO controller. + +Please refer to pinctrl-bindings.txt in this directory for details of the +common pinctrl bindings used by client devices. + +Subnode format +Each node (or subnode) will list the pins it needs and how to configured these +pins. + + node { + pinmux = <PIN_NUMBER_PINMUX>; + GENERIC_PINCONFIG; + }; + +Required properties: +- pinmux: integer array. Each integer represents a pin number plus mux and +ioset settings. Use the macros from boot/dts/<soc>-pinfunc.h file to get the +right representation of the pin. + +Optional properties: +- GENERIC_PINCONFIG: generic pinconfig options to use, bias-disable, +bias-pull-down, bias-pull-up, drive-open-drain, input-schmitt-enable, +input-debounce. + +Example: + +#include <sama5d2-pinfunc.h> + +... +{ + spi0: spi@f8000000 { + cs-gpios = <&pioA 17 0>, <0>, <0>, <0>; + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_spi0_default>; + status = "okay"; + + spi_flash@0 { + compatible = "spi-flash"; + reg = <0>; + spi-max-frequency = <50000000>; + }; + }; + + ... + + pioA: pinctrl@fc038000 { + compatible = "atmel,sama5d2-pinctrl"; + reg = <0xfc038000 0x600>; + + pinctrl_spi0_default: spi0_default { + pinmux = <PIN_PA14__SPI0_SPCK>, + <PIN_PA15__SPI0_MOSI>, + <PIN_PA16__SPI0_MISO>; + bias-disable; + }; + ... + }; +}; +...
Dear Wenyou Yang,
Changes in v7:
HI Andreas,
Do you have some comments on this series?
Best Regards, Wenyou Yang
-----Original Message----- From: Wenyou Yang [mailto:wenyou.yang@atmel.com] Sent: 2016年7月20日 17:16 To: U-Boot Mailing List u-boot@lists.denx.de Cc: Stephen Warren swarren@nvidia.com; Andreas Bießmann andreas@biessmann.org; Simon Glass sjg@chromium.org; Wenyou Yang wenyou.yang@atmel.com Subject: [PATCH v7 0/4] ARM: AT91: Add AT91 PIO4 pinctrl driver and gpio driver with DM
This patch is to add the pinctrl driver, and rework the atmel-pio4 gpio driver to support driver model and device tree.
Changes in v7:
- Change clk_client.h -> clk.h to adapt to clk API conversion.
Changes in v6:
- Add Reviewed-by tag.
- Fixed the return value, -EINVAL -> ret.
Changes in v5:
- Update the clk API based on [PATCH] clk: convert API to match reset/mailbox fstyle (http://patchwork.ozlabs.org/patch/625342/).
- Use clrbits_le32() to replace readl()/writel().
Changes in v4:
- Remove the redundant log print.
Changes in v3:
- Add bind callback to support the pinctl device regarding as a child of atmel_pio4 device.
- Add clock support.
Changes in v2:
- remove meaningless comment.
- add else path for argument of pinconf.
- add inline attribute for atmel_pio4_bank_base().
- add handle if the pinmux entries is greater maximum value.
Wenyou Yang (4): gpio: atmel_pio4: Move PIO4 definitions to head file gpio: atmel_pio4: Rework to support DM & DT pinctrl: at91-pio4: Add pinctrl driver atmel: Bring in at91 pio4 device tree file and bindings
arch/arm/dts/sama5d2-pinfunc.h | 880 +++++++++++++++++++++ arch/arm/mach-at91/include/mach/atmel_pio4.h | 35 + .../pinctrl/atmel,at91-pio4-pinctrl.txt | 66 ++ drivers/gpio/Kconfig | 2 +- drivers/gpio/atmel_pio4.c | 201 +++-- drivers/pinctrl/Kconfig | 7 + drivers/pinctrl/Makefile | 1 + drivers/pinctrl/pinctrl-at91-pio4.c | 182 +++++ 8 files changed, 1302 insertions(+), 72 deletions(-) create mode 100644 arch/arm/dts/sama5d2-pinfunc.h create mode 100644 doc/device-tree- bindings/pinctrl/atmel,at91-pio4-pinctrl.txt create mode 100644 drivers/pinctrl/pinctrl-at91-pio4.c
-- 2.7.4
Andreas Bießmann
Wenyou Yang
Wenyou.Yang@microchip.com
