[U-Boot] [PATCH] arm: mach-k3: common: Clean up ATF image startup function
Perform some cosmetic cleanup of the ATF image startup function, namely fixing a spelling mistake, capitalization of a few words, spacing, as well aligning how errors are printed and as using panic() for cases that were using a combination of printf() + hang().
Signed-off-by: Andreas Dannenberg dannenberg@ti.com --- arch/arm/mach-k3/common.c | 28 ++++++++++------------------ 1 file changed, 10 insertions(+), 18 deletions(-)
diff --git a/arch/arm/mach-k3/common.c b/arch/arm/mach-k3/common.c index e225458baf..79d4ffe988 100644 --- a/arch/arm/mach-k3/common.c +++ b/arch/arm/mach-k3/common.c @@ -45,33 +45,25 @@ void __noreturn jump_to_image_no_args(struct spl_image_info *spl_image)
/* * It is assumed that remoteproc device 1 is the corresponding - * cortex A core which runs ATF. Make sure DT reflects the same. + * Cortex-A core which runs ATF. Make sure DT reflects the same. */ ret = rproc_dev_init(1); - if (ret) { - printf("%s: ATF failed to Initialize on rproc: ret= %d\n", - __func__, ret); - hang(); - } + if (ret) + panic("%s: ATF failed to initialize on rproc (%d)\n", __func__, + ret);
ret = rproc_load(1, spl_image->entry_point, 0x200); - if (ret) { - printf("%s: ATF failed to load on rproc: ret= %d\n", - __func__, ret); - hang(); - } + if (ret) + panic("%s: ATF failed to load on rproc (%d)\n", __func__, ret);
- /* Add an extra newline to differentiate the ATF logs from SPL*/ + /* Add an extra newline to differentiate the ATF logs from SPL */ printf("Starting ATF on ARM64 core...\n\n");
ret = rproc_start(1); - if (ret) { - printf("%s: ATF failed to start on rproc: ret= %d\n", - __func__, ret); - hang(); - } + if (ret) + panic("%s: ATF failed to start on rproc (%d)\n", __func__, ret);
- debug("ATF started. Wait indefiniely\n"); + debug("ATF started. Waiting indefinitely...\n"); while (1) asm volatile("wfe"); }
Reviewed-by: Lokesh Vutla lokeshvutla@ti.com
Thanks and regards, Lokesh
Signed-off-by: Andreas Dannenberg dannenberg@ti.com Reviewed-by: Lokesh Vutla lokeshvutla@ti.com
Andreas Dannenberg
Lokesh Vutla
