[PATCH] sunxi: H616: OrangePi Zero 2: enable USB power supply
The OrangePi Zero 2 has a USB VBUS regulator, controlled by pin PC16. This is correctly described in the DT, but the patches for supporting this are still pending.
Meanwhile add our good old CONFIG_USB1_VBUS_PIN to the defconfig file, to enable power on the USB port and allow using a USB flash drive, for instance.
Fixes: 6acc5fa581b4 ("sunxi: H616: enable USB support for H616 boards") Reported-by: Mikhail Kalashnikov iuncuim@gmail.com Signed-off-by: Andre Przywara andre.przywara@arm.com --- configs/orangepi_zero2_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/orangepi_zero2_defconfig b/configs/orangepi_zero2_defconfig index 127cf9e365a..98aed846f1f 100644 --- a/configs/orangepi_zero2_defconfig +++ b/configs/orangepi_zero2_defconfig @@ -8,6 +8,7 @@ CONFIG_DRAM_SUN50I_H616_CA_DRI=0x0e0e CONFIG_DRAM_SUN50I_H616_TPR10=0xf83438 CONFIG_MACH_SUN50I_H616=y CONFIG_SUNXI_DRAM_H616_DDR3_1333=y +CONFIG_USB1_VBUS_PIN="PC16" CONFIG_R_I2C_ENABLE=y CONFIG_SPL_SPI_SUNXI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set
Andre Przywara
