[PATCH 1/1] k210: fix k210_pll_calc_config()
The k210 driver is selected by sandbox_defconfig. Building the sandbox on 32bit systems fails with:
test/dm/k210_pll.c: In function ‘dm_test_k210_pll_calc_config’: include/linux/bitops.h:11:38: warning: left shift count >= width of type [-Wshift-count-overflow] 11 | #define BIT(nr) (1UL << (nr)) | ^~ test/dm/k210_pll.c:36:54: note: in expansion of macro ‘BIT’ 36 | error = abs((error - BIT(32))) >> 16; | ^~~
Use the BIT_ULL() macro to create a u64 value.
Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- drivers/clk/clk_k210.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/clk/clk_k210.c b/drivers/clk/clk_k210.c index 1961efaa5e..89195bdda6 100644 --- a/drivers/clk/clk_k210.c +++ b/drivers/clk/clk_k210.c @@ -846,7 +846,7 @@ again:
error = DIV_ROUND_CLOSEST_ULL(f * inv_ratio, r * od); /* The lower 16 bits are spurious */ - error = abs((error - BIT(32))) >> 16; + error = abs((error - BIT_ULL(32))) >> 16;
if (error < best_error) { best->r = r;
To get correct results on 32bit systems we must use abs64() instead of abs(). There is also a unit test to fix.
See review comments in https://lists.denx.de/pipermail/u-boot/2022-October/497373.html
Best regards
Heinrich
