[U-Boot] [PATCH] imx: mx25: Remove SION bit in all pin-mux
SION bit should be used in the situation that we need to read back the value of a pin and should be set by default. This can generate any kind of random malfunction as described in this thread.
According to this thread: https://www.spinics.net/lists/linux-usb/msg162574.html
We consider this an early bug so all the boards running imx25 with a minimimal set of functionalities can be affected.
As reported by this application note: https://www.nxp.com/docs/en/application-note/AN5078.pdf
The software input on (SION) bit is an option to force an input path to be active regardless of the value driven by the corresponding module. It is used when the nature direction of a pin depending on selected alternative function is an output, but it is needed to read the real logic value on a pin.
The SION bit can be used in: • Loopback: the module of a selected alternative function drives the pad and also receives the pad value as an input • GPIO capture: the module of a selected alternative function drives the pin and the value is captured by the GPIO
Signed-off-by: Michael Trimarchi michael@amarulasolutions.com --- Refer-to: MX25 USB timeout on ID 0951:1665 Kingston Technology Digital DataTraveler SE9 64GB
--- arch/arm/include/asm/arch-mx25/iomux-mx25.h | 680 ++++++++++++++-------------- 1 file changed, 340 insertions(+), 340 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx25/iomux-mx25.h b/arch/arm/include/asm/arch-mx25/iomux-mx25.h index 5b2863e..2fcaf60 100644 --- a/arch/arm/include/asm/arch-mx25/iomux-mx25.h +++ b/arch/arm/include/asm/arch-mx25/iomux-mx25.h @@ -30,481 +30,481 @@
/* PAD MUX ALT INPSE PATH PADCTRL */ enum { - MX25_PAD_A10__A10 = IOMUX_PAD(0x000, 0x008, 0x00, 0, 0, NO_PAD_CTRL), - MX25_PAD_A10__GPIO_4_0 = IOMUX_PAD(0x000, 0x008, 0x05, 0, 0, NO_PAD_CTRL), + MX25_PAD_A10__A10 = IOMUX_PAD(0x000, 0x008, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_A10__GPIO_4_0 = IOMUX_PAD(0x000, 0x008, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_A13__A13 = IOMUX_PAD(0x22C, 0x00c, 0x00, 0, 0, NO_PAD_CTRL), - MX25_PAD_A13__GPIO_4_1 = IOMUX_PAD(0x22C, 0x00c, 0x05, 0, 0, NO_PAD_CTRL), + MX25_PAD_A13__A13 = IOMUX_PAD(0x22C, 0x00c, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_A13__GPIO_4_1 = IOMUX_PAD(0x22C, 0x00c, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_A14__A14 = IOMUX_PAD(0x230, 0x010, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_A14__GPIO_2_0 = IOMUX_PAD(0x230, 0x010, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_A14__A14 = IOMUX_PAD(0x230, 0x010, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_A14__GPIO_2_0 = IOMUX_PAD(0x230, 0x010, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_A15__A15 = IOMUX_PAD(0x234, 0x014, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_A15__GPIO_2_1 = IOMUX_PAD(0x234, 0x014, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_A15__A15 = IOMUX_PAD(0x234, 0x014, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_A15__GPIO_2_1 = IOMUX_PAD(0x234, 0x014, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_A16__A16 = IOMUX_PAD(0x000, 0x018, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_A16__GPIO_2_2 = IOMUX_PAD(0x000, 0x018, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_A16__A16 = IOMUX_PAD(0x000, 0x018, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_A16__GPIO_2_2 = IOMUX_PAD(0x000, 0x018, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_A17__A17 = IOMUX_PAD(0x238, 0x01c, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_A17__GPIO_2_3 = IOMUX_PAD(0x238, 0x01c, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_A17__A17 = IOMUX_PAD(0x238, 0x01c, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_A17__GPIO_2_3 = IOMUX_PAD(0x238, 0x01c, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_A18__A18 = IOMUX_PAD(0x23c, 0x020, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_A18__GPIO_2_4 = IOMUX_PAD(0x23c, 0x020, 0x15, 0, 0, NO_PAD_CTRL), - MX25_PAD_A18__FEC_COL = IOMUX_PAD(0x23c, 0x020, 0x17, 0x504, 0, NO_PAD_CTRL), + MX25_PAD_A18__A18 = IOMUX_PAD(0x23c, 0x020, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_A18__GPIO_2_4 = IOMUX_PAD(0x23c, 0x020, 5, 0, 0, NO_PAD_CTRL), + MX25_PAD_A18__FEC_COL = IOMUX_PAD(0x23c, 0x020, 7, 0x504, 0, NO_PAD_CTRL),
- MX25_PAD_A19__A19 = IOMUX_PAD(0x240, 0x024, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_A19__FEC_RX_ER = IOMUX_PAD(0x240, 0x024, 0x17, 0x518, 0, NO_PAD_CTRL), - MX25_PAD_A19__GPIO_2_5 = IOMUX_PAD(0x240, 0x024, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_A19__A19 = IOMUX_PAD(0x240, 0x024, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_A19__FEC_RX_ER = IOMUX_PAD(0x240, 0x024, 7, 0x518, 0, NO_PAD_CTRL), + MX25_PAD_A19__GPIO_2_5 = IOMUX_PAD(0x240, 0x024, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_A20__A20 = IOMUX_PAD(0x244, 0x028, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_A20__GPIO_2_6 = IOMUX_PAD(0x244, 0x028, 0x15, 0, 0, NO_PAD_CTRL), - MX25_PAD_A20__FEC_RDATA2 = IOMUX_PAD(0x244, 0x028, 0x17, 0x50c, 0, NO_PAD_CTRL), + MX25_PAD_A20__A20 = IOMUX_PAD(0x244, 0x028, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_A20__GPIO_2_6 = IOMUX_PAD(0x244, 0x028, 5, 0, 0, NO_PAD_CTRL), + MX25_PAD_A20__FEC_RDATA2 = IOMUX_PAD(0x244, 0x028, 7, 0x50c, 0, NO_PAD_CTRL),
- MX25_PAD_A21__A21 = IOMUX_PAD(0x248, 0x02c, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_A21__GPIO_2_7 = IOMUX_PAD(0x248, 0x02c, 0x15, 0, 0, NO_PAD_CTRL), - MX25_PAD_A21__FEC_RDATA3 = IOMUX_PAD(0x248, 0x02c, 0x17, 0x510, 0, NO_PAD_CTRL), + MX25_PAD_A21__A21 = IOMUX_PAD(0x248, 0x02c, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_A21__GPIO_2_7 = IOMUX_PAD(0x248, 0x02c, 5, 0, 0, NO_PAD_CTRL), + MX25_PAD_A21__FEC_RDATA3 = IOMUX_PAD(0x248, 0x02c, 7, 0x510, 0, NO_PAD_CTRL),
- MX25_PAD_A22__A22 = IOMUX_PAD(0x000, 0x030, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_A22__GPIO_2_8 = IOMUX_PAD(0x000, 0x030, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_A22__A22 = IOMUX_PAD(0x000, 0x030, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_A22__GPIO_2_8 = IOMUX_PAD(0x000, 0x030, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_A23__A23 = IOMUX_PAD(0x24c, 0x034, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_A23__GPIO_2_9 = IOMUX_PAD(0x24c, 0x034, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_A23__A23 = IOMUX_PAD(0x24c, 0x034, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_A23__GPIO_2_9 = IOMUX_PAD(0x24c, 0x034, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_A24__A24 = IOMUX_PAD(0x250, 0x038, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_A24__GPIO_2_10 = IOMUX_PAD(0x250, 0x038, 0x15, 0, 0, NO_PAD_CTRL), - MX25_PAD_A24__FEC_RX_CLK = IOMUX_PAD(0x250, 0x038, 0x17, 0x514, 0, NO_PAD_CTRL), + MX25_PAD_A24__A24 = IOMUX_PAD(0x250, 0x038, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_A24__GPIO_2_10 = IOMUX_PAD(0x250, 0x038, 5, 0, 0, NO_PAD_CTRL), + MX25_PAD_A24__FEC_RX_CLK = IOMUX_PAD(0x250, 0x038, 7, 0x514, 0, NO_PAD_CTRL),
- MX25_PAD_A25__A25 = IOMUX_PAD(0x254, 0x03c, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_A25__GPIO_2_11 = IOMUX_PAD(0x254, 0x03c, 0x15, 0, 0, NO_PAD_CTRL), - MX25_PAD_A25__FEC_CRS = IOMUX_PAD(0x254, 0x03c, 0x17, 0x508, 0, NO_PAD_CTRL), + MX25_PAD_A25__A25 = IOMUX_PAD(0x254, 0x03c, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_A25__GPIO_2_11 = IOMUX_PAD(0x254, 0x03c, 5, 0, 0, NO_PAD_CTRL), + MX25_PAD_A25__FEC_CRS = IOMUX_PAD(0x254, 0x03c, 7, 0x508, 0, NO_PAD_CTRL),
- MX25_PAD_EB0__EB0 = IOMUX_PAD(0x258, 0x040, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_EB0__AUD4_TXD = IOMUX_PAD(0x258, 0x040, 0x14, 0x464, 0, NO_PAD_CTRL), - MX25_PAD_EB0__GPIO_2_12 = IOMUX_PAD(0x258, 0x040, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_EB0__EB0 = IOMUX_PAD(0x258, 0x040, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_EB0__AUD4_TXD = IOMUX_PAD(0x258, 0x040, 4, 0x464, 0, NO_PAD_CTRL), + MX25_PAD_EB0__GPIO_2_12 = IOMUX_PAD(0x258, 0x040, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_EB1__EB1 = IOMUX_PAD(0x25c, 0x044, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_EB1__AUD4_RXD = IOMUX_PAD(0x25c, 0x044, 0x14, 0x460, 0, NO_PAD_CTRL), - MX25_PAD_EB1__GPIO_2_13 = IOMUX_PAD(0x25c, 0x044, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_EB1__EB1 = IOMUX_PAD(0x25c, 0x044, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_EB1__AUD4_RXD = IOMUX_PAD(0x25c, 0x044, 4, 0x460, 0, NO_PAD_CTRL), + MX25_PAD_EB1__GPIO_2_13 = IOMUX_PAD(0x25c, 0x044, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_OE__OE = IOMUX_PAD(0x260, 0x048, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_OE__AUD4_TXC = IOMUX_PAD(0x260, 0x048, 0x14, 0, 0, NO_PAD_CTRL), - MX25_PAD_OE__GPIO_2_14 = IOMUX_PAD(0x260, 0x048, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_OE__OE = IOMUX_PAD(0x260, 0x048, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_OE__AUD4_TXC = IOMUX_PAD(0x260, 0x048, 4, 0, 0, NO_PAD_CTRL), + MX25_PAD_OE__GPIO_2_14 = IOMUX_PAD(0x260, 0x048, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CS0__CS0 = IOMUX_PAD(0x000, 0x04c, 0x00, 0, 0, NO_PAD_CTRL), - MX25_PAD_CS0__GPIO_4_2 = IOMUX_PAD(0x000, 0x04c, 0x05, 0, 0, NO_PAD_CTRL), + MX25_PAD_CS0__CS0 = IOMUX_PAD(0x000, 0x04c, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_CS0__GPIO_4_2 = IOMUX_PAD(0x000, 0x04c, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CS1__CS1 = IOMUX_PAD(0x000, 0x050, 0x00, 0, 0, NO_PAD_CTRL), - MX25_PAD_CS1__NF_CE3 = IOMUX_PAD(0x000, 0x050, 0x01, 0, 0, NO_PAD_CTRL), - MX25_PAD_CS1__GPIO_4_3 = IOMUX_PAD(0x000, 0x050, 0x05, 0, 0, NO_PAD_CTRL), + MX25_PAD_CS1__CS1 = IOMUX_PAD(0x000, 0x050, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_CS1__NF_CE3 = IOMUX_PAD(0x000, 0x050, 1, 0, 0, NO_PAD_CTRL), + MX25_PAD_CS1__GPIO_4_3 = IOMUX_PAD(0x000, 0x050, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CS4__CS4 = IOMUX_PAD(0x264, 0x054, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_CS4__NF_CE1 = IOMUX_PAD(0x264, 0x054, 0x01, 0, 0, NO_PAD_CTRL), - MX25_PAD_CS4__UART5_CTS = IOMUX_PAD(0x264, 0x054, 0x13, 0, 0, NO_PAD_CTRL), - MX25_PAD_CS4__GPIO_3_20 = IOMUX_PAD(0x264, 0x054, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CS4__CS4 = IOMUX_PAD(0x264, 0x054, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_CS4__NF_CE1 = IOMUX_PAD(0x264, 0x054, 1, 0, 0, NO_PAD_CTRL), + MX25_PAD_CS4__UART5_CTS = IOMUX_PAD(0x264, 0x054, 3, 0, 0, NO_PAD_CTRL), + MX25_PAD_CS4__GPIO_3_20 = IOMUX_PAD(0x264, 0x054, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CS5__CS5 = IOMUX_PAD(0x268, 0x058, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_CS5__NF_CE2 = IOMUX_PAD(0x268, 0x058, 0x01, 0, 0, NO_PAD_CTRL), - MX25_PAD_CS5__UART5_RTS = IOMUX_PAD(0x268, 0x058, 0x13, 0x574, 0, NO_PAD_CTRL), - MX25_PAD_CS5__GPIO_3_21 = IOMUX_PAD(0x268, 0x058, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CS5__CS5 = IOMUX_PAD(0x268, 0x058, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_CS5__NF_CE2 = IOMUX_PAD(0x268, 0x058, 1, 0, 0, NO_PAD_CTRL), + MX25_PAD_CS5__UART5_RTS = IOMUX_PAD(0x268, 0x058, 3, 0x574, 0, NO_PAD_CTRL), + MX25_PAD_CS5__GPIO_3_21 = IOMUX_PAD(0x268, 0x058, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_NF_CE0__NF_CE0 = IOMUX_PAD(0x26c, 0x05c, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_NF_CE0__GPIO_3_22 = IOMUX_PAD(0x26c, 0x05c, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_NF_CE0__NF_CE0 = IOMUX_PAD(0x26c, 0x05c, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_NF_CE0__GPIO_3_22 = IOMUX_PAD(0x26c, 0x05c, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_ECB__ECB = IOMUX_PAD(0x270, 0x060, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_ECB__UART5_TXD_MUX = IOMUX_PAD(0x270, 0x060, 0x13, 0, 0, NO_PAD_CTRL), - MX25_PAD_ECB__GPIO_3_23 = IOMUX_PAD(0x270, 0x060, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_ECB__ECB = IOMUX_PAD(0x270, 0x060, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_ECB__UART5_TXD_MUX = IOMUX_PAD(0x270, 0x060, 3, 0, 0, NO_PAD_CTRL), + MX25_PAD_ECB__GPIO_3_23 = IOMUX_PAD(0x270, 0x060, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_LBA__LBA = IOMUX_PAD(0x274, 0x064, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_LBA__UART5_RXD_MUX = IOMUX_PAD(0x274, 0x064, 0x13, 0x578, 0, NO_PAD_CTRL), - MX25_PAD_LBA__GPIO_3_24 = IOMUX_PAD(0x274, 0x064, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_LBA__LBA = IOMUX_PAD(0x274, 0x064, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_LBA__UART5_RXD_MUX = IOMUX_PAD(0x274, 0x064, 3, 0x578, 0, NO_PAD_CTRL), + MX25_PAD_LBA__GPIO_3_24 = IOMUX_PAD(0x274, 0x064, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_BCLK__BCLK = IOMUX_PAD(0x000, 0x068, 0x00, 0, 0, NO_PAD_CTRL), - MX25_PAD_BCLK__GPIO_4_4 = IOMUX_PAD(0x000, 0x068, 0x05, 0, 0, NO_PAD_CTRL), + MX25_PAD_BCLK__BCLK = IOMUX_PAD(0x000, 0x068, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_BCLK__GPIO_4_4 = IOMUX_PAD(0x000, 0x068, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_RW__RW = IOMUX_PAD(0x278, 0x06c, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_RW__AUD4_TXFS = IOMUX_PAD(0x278, 0x06c, 0x14, 0x474, 0, NO_PAD_CTRL), - MX25_PAD_RW__GPIO_3_25 = IOMUX_PAD(0x278, 0x06c, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_RW__RW = IOMUX_PAD(0x278, 0x06c, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_RW__AUD4_TXFS = IOMUX_PAD(0x278, 0x06c, 4, 0x474, 0, NO_PAD_CTRL), + MX25_PAD_RW__GPIO_3_25 = IOMUX_PAD(0x278, 0x06c, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_NFWE_B__NFWE_B = IOMUX_PAD(0x000, 0x070, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_NFWE_B__GPIO_3_26 = IOMUX_PAD(0x000, 0x070, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_NFWE_B__NFWE_B = IOMUX_PAD(0x000, 0x070, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_NFWE_B__GPIO_3_26 = IOMUX_PAD(0x000, 0x070, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_NFRE_B__NFRE_B = IOMUX_PAD(0x000, 0x074, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_NFRE_B__GPIO_3_27 = IOMUX_PAD(0x000, 0x074, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_NFRE_B__NFRE_B = IOMUX_PAD(0x000, 0x074, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_NFRE_B__GPIO_3_27 = IOMUX_PAD(0x000, 0x074, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_NFALE__NFALE = IOMUX_PAD(0x000, 0x078, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_NFALE__GPIO_3_28 = IOMUX_PAD(0x000, 0x078, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_NFALE__NFALE = IOMUX_PAD(0x000, 0x078, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_NFALE__GPIO_3_28 = IOMUX_PAD(0x000, 0x078, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_NFCLE__NFCLE = IOMUX_PAD(0x000, 0x07c, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_NFCLE__GPIO_3_29 = IOMUX_PAD(0x000, 0x07c, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_NFCLE__NFCLE = IOMUX_PAD(0x000, 0x07c, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_NFCLE__GPIO_3_29 = IOMUX_PAD(0x000, 0x07c, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_NFWP_B__NFWP_B = IOMUX_PAD(0x000, 0x080, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_NFWP_B__GPIO_3_30 = IOMUX_PAD(0x000, 0x080, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_NFWP_B__NFWP_B = IOMUX_PAD(0x000, 0x080, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_NFWP_B__GPIO_3_30 = IOMUX_PAD(0x000, 0x080, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_NFRB__NFRB = IOMUX_PAD(0x27c, 0x084, 0x10, 0, 0, PAD_CTL_PKE), - MX25_PAD_NFRB__GPIO_3_31 = IOMUX_PAD(0x27c, 0x084, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_NFRB__NFRB = IOMUX_PAD(0x27c, 0x084, 0, 0, 0, PAD_CTL_PKE), + MX25_PAD_NFRB__GPIO_3_31 = IOMUX_PAD(0x27c, 0x084, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_D15__D15 = IOMUX_PAD(0x280, 0x088, 0x00, 0, 0, NO_PAD_CTRL), - MX25_PAD_D15__LD16 = IOMUX_PAD(0x280, 0x088, 0x01, 0, 0, PAD_CTL_SRE_FAST), - MX25_PAD_D15__GPIO_4_5 = IOMUX_PAD(0x280, 0x088, 0x05, 0, 0, NO_PAD_CTRL), + MX25_PAD_D15__D15 = IOMUX_PAD(0x280, 0x088, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_D15__LD16 = IOMUX_PAD(0x280, 0x088, 1, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_D15__GPIO_4_5 = IOMUX_PAD(0x280, 0x088, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_D14__D14 = IOMUX_PAD(0x284, 0x08c, 0x00, 0, 0, NO_PAD_CTRL), - MX25_PAD_D14__LD17 = IOMUX_PAD(0x284, 0x08c, 0x01, 0, 0, PAD_CTL_SRE_FAST), - MX25_PAD_D14__GPIO_4_6 = IOMUX_PAD(0x284, 0x08c, 0x05, 0, 0, NO_PAD_CTRL), + MX25_PAD_D14__D14 = IOMUX_PAD(0x284, 0x08c, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_D14__LD17 = IOMUX_PAD(0x284, 0x08c, 1, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_D14__GPIO_4_6 = IOMUX_PAD(0x284, 0x08c, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_D13__D13 = IOMUX_PAD(0x288, 0x090, 0x00, 0, 0, NO_PAD_CTRL), - MX25_PAD_D13__LD18 = IOMUX_PAD(0x288, 0x090, 0x01, 0, 0, PAD_CTL_SRE_FAST), - MX25_PAD_D13__GPIO_4_7 = IOMUX_PAD(0x288, 0x090, 0x05, 0, 0, NO_PAD_CTRL), + MX25_PAD_D13__D13 = IOMUX_PAD(0x288, 0x090, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_D13__LD18 = IOMUX_PAD(0x288, 0x090, 1, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_D13__GPIO_4_7 = IOMUX_PAD(0x288, 0x090, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_D12__D12 = IOMUX_PAD(0x28c, 0x094, 0x00, 0, 0, NO_PAD_CTRL), - MX25_PAD_D12__GPIO_4_8 = IOMUX_PAD(0x28c, 0x094, 0x05, 0, 0, NO_PAD_CTRL), + MX25_PAD_D12__D12 = IOMUX_PAD(0x28c, 0x094, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_D12__GPIO_4_8 = IOMUX_PAD(0x28c, 0x094, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_D11__D11 = IOMUX_PAD(0x290, 0x098, 0x00, 0, 0, NO_PAD_CTRL), - MX25_PAD_D11__GPIO_4_9 = IOMUX_PAD(0x290, 0x098, 0x05, 0, 0, NO_PAD_CTRL), + MX25_PAD_D11__D11 = IOMUX_PAD(0x290, 0x098, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_D11__GPIO_4_9 = IOMUX_PAD(0x290, 0x098, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_D10__D10 = IOMUX_PAD(0x294, 0x09c, 0x00, 0, 0, NO_PAD_CTRL), - MX25_PAD_D10__GPIO_4_10 = IOMUX_PAD(0x294, 0x09c, 0x05, 0, 0, NO_PAD_CTRL), - MX25_PAD_D10__USBOTG_OC = IOMUX_PAD(0x294, 0x09c, 0x06, 0x57c, 0, PAD_CTL_PUS_100K_UP), + MX25_PAD_D10__D10 = IOMUX_PAD(0x294, 0x09c, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_D10__GPIO_4_10 = IOMUX_PAD(0x294, 0x09c, 5, 0, 0, NO_PAD_CTRL), + MX25_PAD_D10__USBOTG_OC = IOMUX_PAD(0x294, 0x09c, 6, 0x57c, 0, PAD_CTL_PUS_100K_UP),
- MX25_PAD_D9__D9 = IOMUX_PAD(0x298, 0x0a0, 0x00, 0, 0, NO_PAD_CTRL), - MX25_PAD_D9__GPIO_4_11 = IOMUX_PAD(0x298, 0x0a0, 0x05, 0, 0, NO_PAD_CTRL), - MX25_PAD_D9__USBH2_PWR = IOMUX_PAD(0x298, 0x0a0, 0x06, 0, 0, PAD_CTL_PKE), + MX25_PAD_D9__D9 = IOMUX_PAD(0x298, 0x0a0, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_D9__GPIO_4_11 = IOMUX_PAD(0x298, 0x0a0, 5, 0, 0, NO_PAD_CTRL), + MX25_PAD_D9__USBH2_PWR = IOMUX_PAD(0x298, 0x0a0, 6, 0, 0, PAD_CTL_PKE),
- MX25_PAD_D8__D8 = IOMUX_PAD(0x29c, 0x0a4, 0x00, 0, 0, NO_PAD_CTRL), - MX25_PAD_D8__GPIO_4_12 = IOMUX_PAD(0x29c, 0x0a4, 0x05, 0, 0, NO_PAD_CTRL), - MX25_PAD_D8__USBH2_OC = IOMUX_PAD(0x29c, 0x0a4, 0x06, 0x580, 0, PAD_CTL_PUS_100K_UP), + MX25_PAD_D8__D8 = IOMUX_PAD(0x29c, 0x0a4, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_D8__GPIO_4_12 = IOMUX_PAD(0x29c, 0x0a4, 5, 0, 0, NO_PAD_CTRL), + MX25_PAD_D8__USBH2_OC = IOMUX_PAD(0x29c, 0x0a4, 6, 0x580, 0, PAD_CTL_PUS_100K_UP),
- MX25_PAD_D7__D7 = IOMUX_PAD(0x2a0, 0x0a8, 0x00, 0, 0, NO_PAD_CTRL), - MX25_PAD_D7__GPIO_4_13 = IOMUX_PAD(0x2a0, 0x0a8, 0x05, 0, 0, NO_PAD_CTRL), + MX25_PAD_D7__D7 = IOMUX_PAD(0x2a0, 0x0a8, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_D7__GPIO_4_13 = IOMUX_PAD(0x2a0, 0x0a8, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_D6__D6 = IOMUX_PAD(0x2a4, 0x0ac, 0x00, 0, 0, NO_PAD_CTRL), - MX25_PAD_D6__GPIO_4_14 = IOMUX_PAD(0x2a4, 0x0ac, 0x05, 0, 0, NO_PAD_CTRL), + MX25_PAD_D6__D6 = IOMUX_PAD(0x2a4, 0x0ac, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_D6__GPIO_4_14 = IOMUX_PAD(0x2a4, 0x0ac, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_D5__D5 = IOMUX_PAD(0x2a8, 0x0b0, 0x00, 0, 0, NO_PAD_CTRL), - MX25_PAD_D5__GPIO_4_15 = IOMUX_PAD(0x2a8, 0x0b0, 0x05, 0, 0, NO_PAD_CTRL), + MX25_PAD_D5__D5 = IOMUX_PAD(0x2a8, 0x0b0, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_D5__GPIO_4_15 = IOMUX_PAD(0x2a8, 0x0b0, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_D4__D4 = IOMUX_PAD(0x2ac, 0x0b4, 0x00, 0, 0, NO_PAD_CTRL), - MX25_PAD_D4__GPIO_4_16 = IOMUX_PAD(0x2ac, 0x0b4, 0x05, 0, 0, NO_PAD_CTRL), + MX25_PAD_D4__D4 = IOMUX_PAD(0x2ac, 0x0b4, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_D4__GPIO_4_16 = IOMUX_PAD(0x2ac, 0x0b4, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_D3__D3 = IOMUX_PAD(0x2b0, 0x0b8, 0x00, 0, 0, NO_PAD_CTRL), - MX25_PAD_D3__GPIO_4_17 = IOMUX_PAD(0x2b0, 0x0b8, 0x05, 0, 0, NO_PAD_CTRL), + MX25_PAD_D3__D3 = IOMUX_PAD(0x2b0, 0x0b8, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_D3__GPIO_4_17 = IOMUX_PAD(0x2b0, 0x0b8, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_D2__D2 = IOMUX_PAD(0x2b4, 0x0bc, 0x00, 0, 0, NO_PAD_CTRL), - MX25_PAD_D2__GPIO_4_18 = IOMUX_PAD(0x2b4, 0x0bc, 0x05, 0, 0, NO_PAD_CTRL), + MX25_PAD_D2__D2 = IOMUX_PAD(0x2b4, 0x0bc, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_D2__GPIO_4_18 = IOMUX_PAD(0x2b4, 0x0bc, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_D1__D1 = IOMUX_PAD(0x2b8, 0x0c0, 0x00, 0, 0, NO_PAD_CTRL), - MX25_PAD_D1__GPIO_4_19 = IOMUX_PAD(0x2b8, 0x0c0, 0x05, 0, 0, NO_PAD_CTRL), + MX25_PAD_D1__D1 = IOMUX_PAD(0x2b8, 0x0c0, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_D1__GPIO_4_19 = IOMUX_PAD(0x2b8, 0x0c0, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_D0__D0 = IOMUX_PAD(0x2bc, 0x0c4, 0x00, 0, 0, NO_PAD_CTRL), - MX25_PAD_D0__GPIO_4_20 = IOMUX_PAD(0x2bc, 0x0c4, 0x05, 0, 0, NO_PAD_CTRL), + MX25_PAD_D0__D0 = IOMUX_PAD(0x2bc, 0x0c4, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_D0__GPIO_4_20 = IOMUX_PAD(0x2bc, 0x0c4, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_LD0__LD0 = IOMUX_PAD(0x2c0, 0x0c8, 0x10, 0, 0, PAD_CTL_SRE_FAST), - MX25_PAD_LD0__CSI_D0 = IOMUX_PAD(0x2c0, 0x0c8, 0x12, 0x488, 0, NO_PAD_CTRL), - MX25_PAD_LD0__GPIO_2_15 = IOMUX_PAD(0x2c0, 0x0c8, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_LD0__LD0 = IOMUX_PAD(0x2c0, 0x0c8, 0, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD0__CSI_D0 = IOMUX_PAD(0x2c0, 0x0c8, 2, 0x488, 0, NO_PAD_CTRL), + MX25_PAD_LD0__GPIO_2_15 = IOMUX_PAD(0x2c0, 0x0c8, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_LD1__LD1 = IOMUX_PAD(0x2c4, 0x0cc, 0x10, 0, 0, PAD_CTL_SRE_FAST), - MX25_PAD_LD1__CSI_D1 = IOMUX_PAD(0x2c4, 0x0cc, 0x12, 0x48c, 0, NO_PAD_CTRL), - MX25_PAD_LD1__GPIO_2_16 = IOMUX_PAD(0x2c4, 0x0cc, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_LD1__LD1 = IOMUX_PAD(0x2c4, 0x0cc, 0, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD1__CSI_D1 = IOMUX_PAD(0x2c4, 0x0cc, 2, 0x48c, 0, NO_PAD_CTRL), + MX25_PAD_LD1__GPIO_2_16 = IOMUX_PAD(0x2c4, 0x0cc, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_LD2__LD2 = IOMUX_PAD(0x2c8, 0x0d0, 0x10, 0, 0, PAD_CTL_SRE_FAST), - MX25_PAD_LD2__GPIO_2_17 = IOMUX_PAD(0x2c8, 0x0d0, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_LD2__LD2 = IOMUX_PAD(0x2c8, 0x0d0, 0, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD2__GPIO_2_17 = IOMUX_PAD(0x2c8, 0x0d0, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_LD3__LD3 = IOMUX_PAD(0x2cc, 0x0d4, 0x10, 0, 0, PAD_CTL_SRE_FAST), - MX25_PAD_LD3__GPIO_2_18 = IOMUX_PAD(0x2cc, 0x0d4, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_LD3__LD3 = IOMUX_PAD(0x2cc, 0x0d4, 0, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD3__GPIO_2_18 = IOMUX_PAD(0x2cc, 0x0d4, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_LD4__LD4 = IOMUX_PAD(0x2d0, 0x0d8, 0x10, 0, 0, PAD_CTL_SRE_FAST), - MX25_PAD_LD4__GPIO_2_19 = IOMUX_PAD(0x2d0, 0x0d8, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_LD4__LD4 = IOMUX_PAD(0x2d0, 0x0d8, 0, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD4__GPIO_2_19 = IOMUX_PAD(0x2d0, 0x0d8, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_LD5__LD5 = IOMUX_PAD(0x2d4, 0x0dc, 0x10, 0, 0, PAD_CTL_SRE_FAST), - MX25_PAD_LD5__GPIO_1_19 = IOMUX_PAD(0x2d4, 0x0dc, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_LD5__LD5 = IOMUX_PAD(0x2d4, 0x0dc, 0, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD5__GPIO_1_19 = IOMUX_PAD(0x2d4, 0x0dc, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_LD6__LD6 = IOMUX_PAD(0x2d8, 0x0e0, 0x10, 0, 0, PAD_CTL_SRE_FAST), - MX25_PAD_LD6__GPIO_1_20 = IOMUX_PAD(0x2d8, 0x0e0, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_LD6__LD6 = IOMUX_PAD(0x2d8, 0x0e0, 0, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD6__GPIO_1_20 = IOMUX_PAD(0x2d8, 0x0e0, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_LD7__LD7 = IOMUX_PAD(0x2dc, 0x0e4, 0x10, 0, 0, PAD_CTL_SRE_FAST), - MX25_PAD_LD7__GPIO_1_21 = IOMUX_PAD(0x2dc, 0x0e4, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_LD7__LD7 = IOMUX_PAD(0x2dc, 0x0e4, 0, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD7__GPIO_1_21 = IOMUX_PAD(0x2dc, 0x0e4, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_LD8__LD8 = IOMUX_PAD(0x2e0, 0x0e8, 0x10, 0, 0, PAD_CTL_SRE_FAST), - MX25_PAD_LD8__FEC_TX_ERR = IOMUX_PAD(0x2e0, 0x0e8, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_LD8__LD8 = IOMUX_PAD(0x2e0, 0x0e8, 0, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD8__FEC_TX_ERR = IOMUX_PAD(0x2e0, 0x0e8, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_LD9__LD9 = IOMUX_PAD(0x2e4, 0x0ec, 0x10, 0, 0, PAD_CTL_SRE_FAST), - MX25_PAD_LD9__FEC_COL = IOMUX_PAD(0x2e4, 0x0ec, 0x15, 0x504, 1, NO_PAD_CTRL), + MX25_PAD_LD9__LD9 = IOMUX_PAD(0x2e4, 0x0ec, 0, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD9__FEC_COL = IOMUX_PAD(0x2e4, 0x0ec, 5, 0x504, 1, NO_PAD_CTRL),
- MX25_PAD_LD10__LD10 = IOMUX_PAD(0x2e8, 0x0f0, 0x10, 0, 0, PAD_CTL_SRE_FAST), - MX25_PAD_LD10__FEC_RX_ER = IOMUX_PAD(0x2e8, 0x0f0, 0x15, 0x518, 1, NO_PAD_CTRL), + MX25_PAD_LD10__LD10 = IOMUX_PAD(0x2e8, 0x0f0, 0, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD10__FEC_RX_ER = IOMUX_PAD(0x2e8, 0x0f0, 5, 0x518, 1, NO_PAD_CTRL),
- MX25_PAD_LD11__LD11 = IOMUX_PAD(0x2ec, 0x0f4, 0x10, 0, 0, PAD_CTL_SRE_FAST), - MX25_PAD_LD11__FEC_RDATA2 = IOMUX_PAD(0x2ec, 0x0f4, 0x15, 0x50c, 1, NO_PAD_CTRL), + MX25_PAD_LD11__LD11 = IOMUX_PAD(0x2ec, 0x0f4, 0, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD11__FEC_RDATA2 = IOMUX_PAD(0x2ec, 0x0f4, 5, 0x50c, 1, NO_PAD_CTRL),
- MX25_PAD_LD12__LD12 = IOMUX_PAD(0x2f0, 0x0f8, 0x10, 0, 0, PAD_CTL_SRE_FAST), - MX25_PAD_LD12__FEC_RDATA3 = IOMUX_PAD(0x2f0, 0x0f8, 0x15, 0x510, 1, NO_PAD_CTRL), + MX25_PAD_LD12__LD12 = IOMUX_PAD(0x2f0, 0x0f8, 0, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD12__FEC_RDATA3 = IOMUX_PAD(0x2f0, 0x0f8, 5, 0x510, 1, NO_PAD_CTRL),
- MX25_PAD_LD13__LD13 = IOMUX_PAD(0x2f4, 0x0fc, 0x10, 0, 0, PAD_CTL_SRE_FAST), - MX25_PAD_LD13__FEC_TDATA2 = IOMUX_PAD(0x2f4, 0x0fc, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_LD13__LD13 = IOMUX_PAD(0x2f4, 0x0fc, 0, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD13__FEC_TDATA2 = IOMUX_PAD(0x2f4, 0x0fc, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_LD14__LD14 = IOMUX_PAD(0x2f8, 0x100, 0x10, 0, 0, PAD_CTL_SRE_FAST), - MX25_PAD_LD14__FEC_TDATA3 = IOMUX_PAD(0x2f8, 0x100, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_LD14__LD14 = IOMUX_PAD(0x2f8, 0x100, 0, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD14__FEC_TDATA3 = IOMUX_PAD(0x2f8, 0x100, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_LD15__LD15 = IOMUX_PAD(0x2fc, 0x104, 0x10, 0, 0, PAD_CTL_SRE_FAST), - MX25_PAD_LD15__FEC_RX_CLK = IOMUX_PAD(0x2fc, 0x104, 0x15, 0x514, 1, NO_PAD_CTRL), + MX25_PAD_LD15__LD15 = IOMUX_PAD(0x2fc, 0x104, 0, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_LD15__FEC_RX_CLK = IOMUX_PAD(0x2fc, 0x104, 5, 0x514, 1, NO_PAD_CTRL),
- MX25_PAD_HSYNC__HSYNC = IOMUX_PAD(0x300, 0x108, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_HSYNC__GPIO_1_22 = IOMUX_PAD(0x300, 0x108, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_HSYNC__HSYNC = IOMUX_PAD(0x300, 0x108, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_HSYNC__GPIO_1_22 = IOMUX_PAD(0x300, 0x108, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_VSYNC__VSYNC = IOMUX_PAD(0x304, 0x10c, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_VSYNC__GPIO_1_23 = IOMUX_PAD(0x304, 0x10c, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_VSYNC__VSYNC = IOMUX_PAD(0x304, 0x10c, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_VSYNC__GPIO_1_23 = IOMUX_PAD(0x304, 0x10c, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_LSCLK__LSCLK = IOMUX_PAD(0x308, 0x110, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_LSCLK__GPIO_1_24 = IOMUX_PAD(0x308, 0x110, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_LSCLK__LSCLK = IOMUX_PAD(0x308, 0x110, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_LSCLK__GPIO_1_24 = IOMUX_PAD(0x308, 0x110, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_OE_ACD__OE_ACD = IOMUX_PAD(0x30c, 0x114, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_OE_ACD__GPIO_1_25 = IOMUX_PAD(0x30c, 0x114, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_OE_ACD__OE_ACD = IOMUX_PAD(0x30c, 0x114, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_OE_ACD__GPIO_1_25 = IOMUX_PAD(0x30c, 0x114, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CONTRAST__CONTRAST = IOMUX_PAD(0x310, 0x118, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_CONTRAST__PWM4_PWMO = IOMUX_PAD(0x310, 0x118, 0x14, 0, 0, NO_PAD_CTRL), - MX25_PAD_CONTRAST__FEC_CRS = IOMUX_PAD(0x310, 0x118, 0x15, 0x508, 1, NO_PAD_CTRL), + MX25_PAD_CONTRAST__CONTRAST = IOMUX_PAD(0x310, 0x118, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_CONTRAST__PWM4_PWMO = IOMUX_PAD(0x310, 0x118, 4, 0, 0, NO_PAD_CTRL), + MX25_PAD_CONTRAST__FEC_CRS = IOMUX_PAD(0x310, 0x118, 5, 0x508, 1, NO_PAD_CTRL),
- MX25_PAD_PWM__PWM = IOMUX_PAD(0x314, 0x11c, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_PWM__GPIO_1_26 = IOMUX_PAD(0x314, 0x11c, 0x15, 0, 0, NO_PAD_CTRL), - MX25_PAD_PWM__USBH2_OC = IOMUX_PAD(0x314, 0x11c, 0x16, 0x580, 1, PAD_CTL_PUS_100K_UP), + MX25_PAD_PWM__PWM = IOMUX_PAD(0x314, 0x11c, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_PWM__GPIO_1_26 = IOMUX_PAD(0x314, 0x11c, 5, 0, 0, NO_PAD_CTRL), + MX25_PAD_PWM__USBH2_OC = IOMUX_PAD(0x314, 0x11c, 6, 0x580, 1, PAD_CTL_PUS_100K_UP),
- MX25_PAD_CSI_D2__CSI_D2 = IOMUX_PAD(0x318, 0x120, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSI_D2__UART5_RXD_MUX = IOMUX_PAD(0x318, 0x120, 0x11, 0x578, 1, NO_PAD_CTRL), - MX25_PAD_CSI_D2__GPIO_1_27 = IOMUX_PAD(0x318, 0x120, 0x15, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSI_D2__CSPI3_MOSI = IOMUX_PAD(0x318, 0x120, 0x17, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D2__CSI_D2 = IOMUX_PAD(0x318, 0x120, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D2__UART5_RXD_MUX = IOMUX_PAD(0x318, 0x120, 1, 0x578, 1, NO_PAD_CTRL), + MX25_PAD_CSI_D2__GPIO_1_27 = IOMUX_PAD(0x318, 0x120, 5, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D2__CSPI3_MOSI = IOMUX_PAD(0x318, 0x120, 7, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CSI_D3__CSI_D3 = IOMUX_PAD(0x31c, 0x124, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSI_D3__GPIO_1_28 = IOMUX_PAD(0x31c, 0x124, 0x15, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSI_D3__CSPI3_MISO = IOMUX_PAD(0x31c, 0x124, 0x17, 0x4b4, 1, NO_PAD_CTRL), + MX25_PAD_CSI_D3__CSI_D3 = IOMUX_PAD(0x31c, 0x124, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D3__GPIO_1_28 = IOMUX_PAD(0x31c, 0x124, 5, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D3__CSPI3_MISO = IOMUX_PAD(0x31c, 0x124, 7, 0x4b4, 1, NO_PAD_CTRL),
- MX25_PAD_CSI_D4__CSI_D4 = IOMUX_PAD(0x320, 0x128, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSI_D4__UART5_RTS = IOMUX_PAD(0x320, 0x128, 0x11, 0x574, 1, NO_PAD_CTRL), - MX25_PAD_CSI_D4__GPIO_1_29 = IOMUX_PAD(0x320, 0x128, 0x15, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSI_D4__CSPI3_SCLK = IOMUX_PAD(0x320, 0x128, 0x17, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D4__CSI_D4 = IOMUX_PAD(0x320, 0x128, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D4__UART5_RTS = IOMUX_PAD(0x320, 0x128, 1, 0x574, 1, NO_PAD_CTRL), + MX25_PAD_CSI_D4__GPIO_1_29 = IOMUX_PAD(0x320, 0x128, 5, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D4__CSPI3_SCLK = IOMUX_PAD(0x320, 0x128, 7, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CSI_D5__CSI_D5 = IOMUX_PAD(0x324, 0x12c, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSI_D5__GPIO_1_30 = IOMUX_PAD(0x324, 0x12c, 0x15, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSI_D5__CSPI3_RDY = IOMUX_PAD(0x324, 0x12c, 0x17, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D5__CSI_D5 = IOMUX_PAD(0x324, 0x12c, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D5__GPIO_1_30 = IOMUX_PAD(0x324, 0x12c, 5, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D5__CSPI3_RDY = IOMUX_PAD(0x324, 0x12c, 7, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CSI_D6__CSI_D6 = IOMUX_PAD(0x328, 0x130, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSI_D6__GPIO_1_31 = IOMUX_PAD(0x328, 0x130, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D6__CSI_D6 = IOMUX_PAD(0x328, 0x130, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D6__GPIO_1_31 = IOMUX_PAD(0x328, 0x130, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CSI_D7__CSI_D7 = IOMUX_PAD(0x32c, 0x134, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSI_D7__GPIO_1_6 = IOMUX_PAD(0x32c, 0x134, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D7__CSI_D7 = IOMUX_PAD(0x32c, 0x134, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D7__GPIO_1_6 = IOMUX_PAD(0x32c, 0x134, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CSI_D8__CSI_D8 = IOMUX_PAD(0x330, 0x138, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSI_D8__GPIO_1_7 = IOMUX_PAD(0x330, 0x138, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D8__CSI_D8 = IOMUX_PAD(0x330, 0x138, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D8__GPIO_1_7 = IOMUX_PAD(0x330, 0x138, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CSI_D9__CSI_D9 = IOMUX_PAD(0x334, 0x13c, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSI_D9__GPIO_4_21 = IOMUX_PAD(0x334, 0x13c, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D9__CSI_D9 = IOMUX_PAD(0x334, 0x13c, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_D9__GPIO_4_21 = IOMUX_PAD(0x334, 0x13c, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CSI_MCLK__CSI_MCLK = IOMUX_PAD(0x338, 0x140, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSI_MCLK__GPIO_1_8 = IOMUX_PAD(0x338, 0x140, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_MCLK__CSI_MCLK = IOMUX_PAD(0x338, 0x140, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_MCLK__GPIO_1_8 = IOMUX_PAD(0x338, 0x140, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CSI_VSYNC__CSI_VSYNC = IOMUX_PAD(0x33c, 0x144, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSI_VSYNC__GPIO_1_9 = IOMUX_PAD(0x33c, 0x144, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_VSYNC__CSI_VSYNC = IOMUX_PAD(0x33c, 0x144, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_VSYNC__GPIO_1_9 = IOMUX_PAD(0x33c, 0x144, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CSI_HSYNC__CSI_HSYNC = IOMUX_PAD(0x340, 0x148, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSI_HSYNC__GPIO_1_10 = IOMUX_PAD(0x340, 0x148, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_HSYNC__CSI_HSYNC = IOMUX_PAD(0x340, 0x148, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_HSYNC__GPIO_1_10 = IOMUX_PAD(0x340, 0x148, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CSI_PIXCLK__CSI_PIXCLK = IOMUX_PAD(0x344, 0x14c, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSI_PIXCLK__GPIO_1_11 = IOMUX_PAD(0x344, 0x14c, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_PIXCLK__CSI_PIXCLK = IOMUX_PAD(0x344, 0x14c, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSI_PIXCLK__GPIO_1_11 = IOMUX_PAD(0x344, 0x14c, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_I2C1_CLK__I2C1_CLK = IOMUX_PAD(0x348, 0x150, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_I2C1_CLK__GPIO_1_12 = IOMUX_PAD(0x348, 0x150, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_I2C1_CLK__I2C1_CLK = IOMUX_PAD(0x348, 0x150, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_I2C1_CLK__GPIO_1_12 = IOMUX_PAD(0x348, 0x150, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_I2C1_DAT__I2C1_DAT = IOMUX_PAD(0x34c, 0x154, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_I2C1_DAT__GPIO_1_13 = IOMUX_PAD(0x34c, 0x154, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_I2C1_DAT__I2C1_DAT = IOMUX_PAD(0x34c, 0x154, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_I2C1_DAT__GPIO_1_13 = IOMUX_PAD(0x34c, 0x154, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CSPI1_MOSI__CSPI1_MOSI = IOMUX_PAD(0x350, 0x158, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSPI1_MOSI__GPIO_1_14 = IOMUX_PAD(0x350, 0x158, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSPI1_MOSI__CSPI1_MOSI = IOMUX_PAD(0x350, 0x158, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSPI1_MOSI__GPIO_1_14 = IOMUX_PAD(0x350, 0x158, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CSPI1_MISO__CSPI1_MISO = IOMUX_PAD(0x354, 0x15c, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSPI1_MISO__GPIO_1_15 = IOMUX_PAD(0x354, 0x15c, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSPI1_MISO__CSPI1_MISO = IOMUX_PAD(0x354, 0x15c, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSPI1_MISO__GPIO_1_15 = IOMUX_PAD(0x354, 0x15c, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CSPI1_SS0__CSPI1_SS0 = IOMUX_PAD(0x358, 0x160, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSPI1_SS0__GPIO_1_16 = IOMUX_PAD(0x358, 0x160, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSPI1_SS0__CSPI1_SS0 = IOMUX_PAD(0x358, 0x160, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSPI1_SS0__GPIO_1_16 = IOMUX_PAD(0x358, 0x160, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CSPI1_SS1__CSPI1_SS1 = IOMUX_PAD(0x35c, 0x164, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSPI1_SS1__I2C3_DAT = IOMUX_PAD(0x35c, 0x164, 0x11, 0x528, 1, NO_PAD_CTRL), - MX25_PAD_CSPI1_SS1__GPIO_1_17 = IOMUX_PAD(0x35c, 0x164, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSPI1_SS1__CSPI1_SS1 = IOMUX_PAD(0x35c, 0x164, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSPI1_SS1__I2C3_DAT = IOMUX_PAD(0x35c, 0x164, 1, 0x528, 1, NO_PAD_CTRL), + MX25_PAD_CSPI1_SS1__GPIO_1_17 = IOMUX_PAD(0x35c, 0x164, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CSPI1_SCLK__CSPI1_SCLK = IOMUX_PAD(0x360, 0x168, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_CSPI1_SCLK__GPIO_1_18 = IOMUX_PAD(0x360, 0x168, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSPI1_SCLK__CSPI1_SCLK = IOMUX_PAD(0x360, 0x168, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSPI1_SCLK__GPIO_1_18 = IOMUX_PAD(0x360, 0x168, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CSPI1_RDY__CSPI1_RDY = IOMUX_PAD(0x364, 0x16c, 0x10, 0, 0, PAD_CTL_PKE), - MX25_PAD_CSPI1_RDY__GPIO_2_22 = IOMUX_PAD(0x364, 0x16c, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CSPI1_RDY__CSPI1_RDY = IOMUX_PAD(0x364, 0x16c, 0, 0, 0, PAD_CTL_PKE), + MX25_PAD_CSPI1_RDY__GPIO_2_22 = IOMUX_PAD(0x364, 0x16c, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_UART1_RXD__UART1_RXD = IOMUX_PAD(0x368, 0x170, 0x10, 0, 0, PAD_CTL_PUS_100K_DOWN), - MX25_PAD_UART1_RXD__GPIO_4_22 = IOMUX_PAD(0x368, 0x170, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_UART1_RXD__UART1_RXD = IOMUX_PAD(0x368, 0x170, 0, 0, 0, PAD_CTL_PUS_100K_DOWN), + MX25_PAD_UART1_RXD__GPIO_4_22 = IOMUX_PAD(0x368, 0x170, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_UART1_TXD__UART1_TXD = IOMUX_PAD(0x36c, 0x174, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_UART1_TXD__GPIO_4_23 = IOMUX_PAD(0x36c, 0x174, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_UART1_TXD__UART1_TXD = IOMUX_PAD(0x36c, 0x174, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_UART1_TXD__GPIO_4_23 = IOMUX_PAD(0x36c, 0x174, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_UART1_RTS__UART1_RTS = IOMUX_PAD(0x370, 0x178, 0x10, 0, 0, PAD_CTL_PUS_100K_UP), - MX25_PAD_UART1_RTS__CSI_D0 = IOMUX_PAD(0x370, 0x178, 0x11, 0x488, 1, NO_PAD_CTRL), - MX25_PAD_UART1_RTS__GPIO_4_24 = IOMUX_PAD(0x370, 0x178, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_UART1_RTS__UART1_RTS = IOMUX_PAD(0x370, 0x178, 0, 0, 0, PAD_CTL_PUS_100K_UP), + MX25_PAD_UART1_RTS__CSI_D0 = IOMUX_PAD(0x370, 0x178, 1, 0x488, 1, NO_PAD_CTRL), + MX25_PAD_UART1_RTS__GPIO_4_24 = IOMUX_PAD(0x370, 0x178, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_UART1_CTS__UART1_CTS = IOMUX_PAD(0x374, 0x17c, 0x10, 0, 0, PAD_CTL_PUS_100K_UP), - MX25_PAD_UART1_CTS__CSI_D1 = IOMUX_PAD(0x374, 0x17c, 0x11, 0x48c, 1, NO_PAD_CTRL), - MX25_PAD_UART1_CTS__GPIO_4_25 = IOMUX_PAD(0x374, 0x17c, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_UART1_CTS__UART1_CTS = IOMUX_PAD(0x374, 0x17c, 0, 0, 0, PAD_CTL_PUS_100K_UP), + MX25_PAD_UART1_CTS__CSI_D1 = IOMUX_PAD(0x374, 0x17c, 1, 0x48c, 1, NO_PAD_CTRL), + MX25_PAD_UART1_CTS__GPIO_4_25 = IOMUX_PAD(0x374, 0x17c, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_UART2_RXD__UART2_RXD = IOMUX_PAD(0x378, 0x180, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_UART2_RXD__GPIO_4_26 = IOMUX_PAD(0x378, 0x180, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_UART2_RXD__UART2_RXD = IOMUX_PAD(0x378, 0x180, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_UART2_RXD__GPIO_4_26 = IOMUX_PAD(0x378, 0x180, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_UART2_TXD__UART2_TXD = IOMUX_PAD(0x37c, 0x184, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_UART2_TXD__GPIO_4_27 = IOMUX_PAD(0x37c, 0x184, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_UART2_TXD__UART2_TXD = IOMUX_PAD(0x37c, 0x184, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_UART2_TXD__GPIO_4_27 = IOMUX_PAD(0x37c, 0x184, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_UART2_RTS__UART2_RTS = IOMUX_PAD(0x380, 0x188, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_UART2_RTS__FEC_COL = IOMUX_PAD(0x380, 0x188, 0x12, 0x504, 2, NO_PAD_CTRL), - MX25_PAD_UART2_RTS__GPIO_4_28 = IOMUX_PAD(0x380, 0x188, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_UART2_RTS__UART2_RTS = IOMUX_PAD(0x380, 0x188, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_UART2_RTS__FEC_COL = IOMUX_PAD(0x380, 0x188, 2, 0x504, 2, NO_PAD_CTRL), + MX25_PAD_UART2_RTS__GPIO_4_28 = IOMUX_PAD(0x380, 0x188, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_UART2_CTS__FEC_RX_ER = IOMUX_PAD(0x384, 0x18c, 0x12, 0x518, 2, NO_PAD_CTRL), - MX25_PAD_UART2_CTS__UART2_CTS = IOMUX_PAD(0x384, 0x18c, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_UART2_CTS__GPIO_4_29 = IOMUX_PAD(0x384, 0x18c, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_UART2_CTS__FEC_RX_ER = IOMUX_PAD(0x384, 0x18c, 2, 0x518, 2, NO_PAD_CTRL), + MX25_PAD_UART2_CTS__UART2_CTS = IOMUX_PAD(0x384, 0x18c, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_UART2_CTS__GPIO_4_29 = IOMUX_PAD(0x384, 0x18c, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_SD1_CMD__SD1_CMD = IOMUX_PAD(0x388, 0x190, 0x10, 0, 0, PAD_CTL_PUS_47K_UP), - MX25_PAD_SD1_CMD__FEC_RDATA2 = IOMUX_PAD(0x388, 0x190, 0x12, 0x50c, 2, NO_PAD_CTRL), - MX25_PAD_SD1_CMD__GPIO_2_23 = IOMUX_PAD(0x388, 0x190, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_SD1_CMD__SD1_CMD = IOMUX_PAD(0x388, 0x190, 0, 0, 0, PAD_CTL_PUS_47K_UP), + MX25_PAD_SD1_CMD__FEC_RDATA2 = IOMUX_PAD(0x388, 0x190, 2, 0x50c, 2, NO_PAD_CTRL), + MX25_PAD_SD1_CMD__GPIO_2_23 = IOMUX_PAD(0x388, 0x190, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_SD1_CLK__SD1_CLK = IOMUX_PAD(0x38c, 0x194, 0x10, 0, 0, PAD_CTL_PUS_47K_UP), - MX25_PAD_SD1_CLK__FEC_RDATA3 = IOMUX_PAD(0x38c, 0x194, 0x12, 0x510, 2, NO_PAD_CTRL), - MX25_PAD_SD1_CLK__GPIO_2_24 = IOMUX_PAD(0x38c, 0x194, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_SD1_CLK__SD1_CLK = IOMUX_PAD(0x38c, 0x194, 0, 0, 0, PAD_CTL_PUS_47K_UP), + MX25_PAD_SD1_CLK__FEC_RDATA3 = IOMUX_PAD(0x38c, 0x194, 2, 0x510, 2, NO_PAD_CTRL), + MX25_PAD_SD1_CLK__GPIO_2_24 = IOMUX_PAD(0x38c, 0x194, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_SD1_DATA0__SD1_DATA0 = IOMUX_PAD(0x390, 0x198, 0x10, 0, 0, PAD_CTL_PUS_47K_UP), - MX25_PAD_SD1_DATA0__GPIO_2_25 = IOMUX_PAD(0x390, 0x198, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_SD1_DATA0__SD1_DATA0 = IOMUX_PAD(0x390, 0x198, 0, 0, 0, PAD_CTL_PUS_47K_UP), + MX25_PAD_SD1_DATA0__GPIO_2_25 = IOMUX_PAD(0x390, 0x198, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_SD1_DATA1__SD1_DATA1 = IOMUX_PAD(0x394, 0x19c, 0x10, 0, 0, PAD_CTL_PUS_47K_UP), - MX25_PAD_SD1_DATA1__AUD7_RXD = IOMUX_PAD(0x394, 0x19c, 0x13, 0x478, 0, NO_PAD_CTRL), - MX25_PAD_SD1_DATA1__GPIO_2_26 = IOMUX_PAD(0x394, 0x19c, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_SD1_DATA1__SD1_DATA1 = IOMUX_PAD(0x394, 0x19c, 0, 0, 0, PAD_CTL_PUS_47K_UP), + MX25_PAD_SD1_DATA1__AUD7_RXD = IOMUX_PAD(0x394, 0x19c, 3, 0x478, 0, NO_PAD_CTRL), + MX25_PAD_SD1_DATA1__GPIO_2_26 = IOMUX_PAD(0x394, 0x19c, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_SD1_DATA2__SD1_DATA2 = IOMUX_PAD(0x398, 0x1a0, 0x10, 0, 0, PAD_CTL_PUS_47K_UP), - MX25_PAD_SD1_DATA2__FEC_RX_CLK = IOMUX_PAD(0x398, 0x1a0, 0x15, 0x514, 2, NO_PAD_CTRL), - MX25_PAD_SD1_DATA2__GPIO_2_27 = IOMUX_PAD(0x398, 0x1a0, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_SD1_DATA2__SD1_DATA2 = IOMUX_PAD(0x398, 0x1a0, 0, 0, 0, PAD_CTL_PUS_47K_UP), + MX25_PAD_SD1_DATA2__FEC_RX_CLK = IOMUX_PAD(0x398, 0x1a0, 5, 0x514, 2, NO_PAD_CTRL), + MX25_PAD_SD1_DATA2__GPIO_2_27 = IOMUX_PAD(0x398, 0x1a0, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_SD1_DATA3__SD1_DATA3 = IOMUX_PAD(0x39c, 0x1a4, 0x10, 0, 0, PAD_CTL_PUS_47K_UP), - MX25_PAD_SD1_DATA3__FEC_CRS = IOMUX_PAD(0x39c, 0x1a4, 0x10, 0x508, 2, NO_PAD_CTRL), - MX25_PAD_SD1_DATA3__GPIO_2_28 = IOMUX_PAD(0x39c, 0x1a4, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_SD1_DATA3__SD1_DATA3 = IOMUX_PAD(0x39c, 0x1a4, 0, 0, 0, PAD_CTL_PUS_47K_UP), + MX25_PAD_SD1_DATA3__FEC_CRS = IOMUX_PAD(0x39c, 0x1a4, 0, 0x508, 2, NO_PAD_CTRL), + MX25_PAD_SD1_DATA3__GPIO_2_28 = IOMUX_PAD(0x39c, 0x1a4, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_KPP_ROW0__KPP_ROW0 = IOMUX_PAD(0x3a0, 0x1a8, 0x10, 0, 0, MX25_KPP_ROW_PAD_CTRL), - MX25_PAD_KPP_ROW0__GPIO_2_29 = IOMUX_PAD(0x3a0, 0x1a8, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_KPP_ROW0__KPP_ROW0 = IOMUX_PAD(0x3a0, 0x1a8, 0, 0, 0, MX25_KPP_ROW_PAD_CTRL), + MX25_PAD_KPP_ROW0__GPIO_2_29 = IOMUX_PAD(0x3a0, 0x1a8, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_KPP_ROW1__KPP_ROW1 = IOMUX_PAD(0x3a4, 0x1ac, 0x10, 0, 0, MX25_KPP_ROW_PAD_CTRL), - MX25_PAD_KPP_ROW1__GPIO_2_30 = IOMUX_PAD(0x3a4, 0x1ac, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_KPP_ROW1__KPP_ROW1 = IOMUX_PAD(0x3a4, 0x1ac, 0, 0, 0, MX25_KPP_ROW_PAD_CTRL), + MX25_PAD_KPP_ROW1__GPIO_2_30 = IOMUX_PAD(0x3a4, 0x1ac, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_KPP_ROW2__KPP_ROW2 = IOMUX_PAD(0x3a8, 0x1b0, 0x10, 0, 0, MX25_KPP_ROW_PAD_CTRL), - MX25_PAD_KPP_ROW2__CSI_D0 = IOMUX_PAD(0x3a8, 0x1b0, 0x13, 0x488, 2, NO_PAD_CTRL), - MX25_PAD_KPP_ROW2__GPIO_2_31 = IOMUX_PAD(0x3a8, 0x1b0, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_KPP_ROW2__KPP_ROW2 = IOMUX_PAD(0x3a8, 0x1b0, 0, 0, 0, MX25_KPP_ROW_PAD_CTRL), + MX25_PAD_KPP_ROW2__CSI_D0 = IOMUX_PAD(0x3a8, 0x1b0, 3, 0x488, 2, NO_PAD_CTRL), + MX25_PAD_KPP_ROW2__GPIO_2_31 = IOMUX_PAD(0x3a8, 0x1b0, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_KPP_ROW3__KPP_ROW3 = IOMUX_PAD(0x3ac, 0x1b4, 0x10, 0, 0, MX25_KPP_ROW_PAD_CTRL), - MX25_PAD_KPP_ROW3__CSI_LD1 = IOMUX_PAD(0x3ac, 0x1b4, 0x13, 0x48c, 2, NO_PAD_CTRL), - MX25_PAD_KPP_ROW3__GPIO_3_0 = IOMUX_PAD(0x3ac, 0x1b4, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_KPP_ROW3__KPP_ROW3 = IOMUX_PAD(0x3ac, 0x1b4, 0, 0, 0, MX25_KPP_ROW_PAD_CTRL), + MX25_PAD_KPP_ROW3__CSI_LD1 = IOMUX_PAD(0x3ac, 0x1b4, 3, 0x48c, 2, NO_PAD_CTRL), + MX25_PAD_KPP_ROW3__GPIO_3_0 = IOMUX_PAD(0x3ac, 0x1b4, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_KPP_COL0__KPP_COL0 = IOMUX_PAD(0x3b0, 0x1b8, 0x10, 0, 0, MX25_KPP_COL_PAD_CTRL), - MX25_PAD_KPP_COL0__UART4_RXD_MUX = IOMUX_PAD(0x3b0, 0x1b8, 0x11, 0x570, 1, NO_PAD_CTRL), - MX25_PAD_KPP_COL0__AUD5_TXD = IOMUX_PAD(0x3b0, 0x1b8, 0x12, 0, 0, PAD_CTL_PUS_100K_UP), - MX25_PAD_KPP_COL0__GPIO_3_1 = IOMUX_PAD(0x3b0, 0x1b8, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_KPP_COL0__KPP_COL0 = IOMUX_PAD(0x3b0, 0x1b8, 0, 0, 0, MX25_KPP_COL_PAD_CTRL), + MX25_PAD_KPP_COL0__UART4_RXD_MUX = IOMUX_PAD(0x3b0, 0x1b8, 1, 0x570, 1, NO_PAD_CTRL), + MX25_PAD_KPP_COL0__AUD5_TXD = IOMUX_PAD(0x3b0, 0x1b8, 2, 0, 0, PAD_CTL_PUS_100K_UP), + MX25_PAD_KPP_COL0__GPIO_3_1 = IOMUX_PAD(0x3b0, 0x1b8, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_KPP_COL1__KPP_COL1 = IOMUX_PAD(0x3b4, 0x1bc, 0x10, 0, 0, MX25_KPP_COL_PAD_CTRL), - MX25_PAD_KPP_COL1__UART4_TXD_MUX = IOMUX_PAD(0x3b4, 0x1bc, 0x11, 0, 0, NO_PAD_CTRL), - MX25_PAD_KPP_COL1__AUD5_RXD = IOMUX_PAD(0x3b4, 0x1bc, 0x12, 0, 0, PAD_CTL_PUS_100K_UP), - MX25_PAD_KPP_COL1__GPIO_3_2 = IOMUX_PAD(0x3b4, 0x1bc, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_KPP_COL1__KPP_COL1 = IOMUX_PAD(0x3b4, 0x1bc, 0, 0, 0, MX25_KPP_COL_PAD_CTRL), + MX25_PAD_KPP_COL1__UART4_TXD_MUX = IOMUX_PAD(0x3b4, 0x1bc, 1, 0, 0, NO_PAD_CTRL), + MX25_PAD_KPP_COL1__AUD5_RXD = IOMUX_PAD(0x3b4, 0x1bc, 2, 0, 0, PAD_CTL_PUS_100K_UP), + MX25_PAD_KPP_COL1__GPIO_3_2 = IOMUX_PAD(0x3b4, 0x1bc, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_KPP_COL2__KPP_COL2 = IOMUX_PAD(0x3b8, 0x1c0, 0x10, 0, 0, MX25_KPP_COL_PAD_CTRL), - MX25_PAD_KPP_COL2__UART4_RTS = IOMUX_PAD(0x3b8, 0x1c0, 0x11, 0, 0, NO_PAD_CTRL), - MX25_PAD_KPP_COL2__AUD5_TXC = IOMUX_PAD(0x3b8, 0x1c0, 0x12, 0, 0, PAD_CTL_PUS_100K_UP), - MX25_PAD_KPP_COL2__GPIO_3_3 = IOMUX_PAD(0x3b8, 0x1c0, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_KPP_COL2__KPP_COL2 = IOMUX_PAD(0x3b8, 0x1c0, 0, 0, 0, MX25_KPP_COL_PAD_CTRL), + MX25_PAD_KPP_COL2__UART4_RTS = IOMUX_PAD(0x3b8, 0x1c0, 1, 0, 0, NO_PAD_CTRL), + MX25_PAD_KPP_COL2__AUD5_TXC = IOMUX_PAD(0x3b8, 0x1c0, 2, 0, 0, PAD_CTL_PUS_100K_UP), + MX25_PAD_KPP_COL2__GPIO_3_3 = IOMUX_PAD(0x3b8, 0x1c0, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_KPP_COL3__KPP_COL3 = IOMUX_PAD(0x3bc, 0x1c4, 0x10, 0, 0, MX25_KPP_COL_PAD_CTRL), - MX25_PAD_KPP_COL3__UART4_CTS = IOMUX_PAD(0x3bc, 0x1c4, 0x11, 0, 0, NO_PAD_CTRL), - MX25_PAD_KPP_COL3__AUD5_TXFS = IOMUX_PAD(0x3bc, 0x1c4, 0x12, 0, 0, PAD_CTL_PUS_100K_UP), - MX25_PAD_KPP_COL3__GPIO_3_4 = IOMUX_PAD(0x3bc, 0x1c4, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_KPP_COL3__KPP_COL3 = IOMUX_PAD(0x3bc, 0x1c4, 0, 0, 0, MX25_KPP_COL_PAD_CTRL), + MX25_PAD_KPP_COL3__UART4_CTS = IOMUX_PAD(0x3bc, 0x1c4, 1, 0, 0, NO_PAD_CTRL), + MX25_PAD_KPP_COL3__AUD5_TXFS = IOMUX_PAD(0x3bc, 0x1c4, 2, 0, 0, PAD_CTL_PUS_100K_UP), + MX25_PAD_KPP_COL3__GPIO_3_4 = IOMUX_PAD(0x3bc, 0x1c4, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_FEC_MDC__FEC_MDC = IOMUX_PAD(0x3c0, 0x1c8, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_FEC_MDC__AUD4_TXD = IOMUX_PAD(0x3c0, 0x1c8, 0x12, 0x464, 1, NO_PAD_CTRL), - MX25_PAD_FEC_MDC__GPIO_3_5 = IOMUX_PAD(0x3c0, 0x1c8, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_FEC_MDC__FEC_MDC = IOMUX_PAD(0x3c0, 0x1c8, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_FEC_MDC__AUD4_TXD = IOMUX_PAD(0x3c0, 0x1c8, 2, 0x464, 1, NO_PAD_CTRL), + MX25_PAD_FEC_MDC__GPIO_3_5 = IOMUX_PAD(0x3c0, 0x1c8, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_FEC_MDIO__FEC_MDIO = IOMUX_PAD(0x3c4, 0x1cc, 0x10, 0, 0, PAD_CTL_HYS | PAD_CTL_PUS_22K_UP), - MX25_PAD_FEC_MDIO__AUD4_RXD = IOMUX_PAD(0x3c4, 0x1cc, 0x12, 0x460, 1, NO_PAD_CTRL), - MX25_PAD_FEC_MDIO__GPIO_3_6 = IOMUX_PAD(0x3c4, 0x1cc, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_FEC_MDIO__FEC_MDIO = IOMUX_PAD(0x3c4, 0x1cc, 0, 0, 0, PAD_CTL_HYS | PAD_CTL_PUS_22K_UP), + MX25_PAD_FEC_MDIO__AUD4_RXD = IOMUX_PAD(0x3c4, 0x1cc, 2, 0x460, 1, NO_PAD_CTRL), + MX25_PAD_FEC_MDIO__GPIO_3_6 = IOMUX_PAD(0x3c4, 0x1cc, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_FEC_TDATA0__FEC_TDATA0 = IOMUX_PAD(0x3c8, 0x1d0, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_FEC_TDATA0__GPIO_3_7 = IOMUX_PAD(0x3c8, 0x1d0, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_FEC_TDATA0__FEC_TDATA0 = IOMUX_PAD(0x3c8, 0x1d0, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_FEC_TDATA0__GPIO_3_7 = IOMUX_PAD(0x3c8, 0x1d0, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_FEC_TDATA1__FEC_TDATA1 = IOMUX_PAD(0x3cc, 0x1d4, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_FEC_TDATA1__AUD4_TXFS = IOMUX_PAD(0x3cc, 0x1d4, 0x12, 0x474, 1, NO_PAD_CTRL), - MX25_PAD_FEC_TDATA1__GPIO_3_8 = IOMUX_PAD(0x3cc, 0x1d4, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_FEC_TDATA1__FEC_TDATA1 = IOMUX_PAD(0x3cc, 0x1d4, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_FEC_TDATA1__AUD4_TXFS = IOMUX_PAD(0x3cc, 0x1d4, 2, 0x474, 1, NO_PAD_CTRL), + MX25_PAD_FEC_TDATA1__GPIO_3_8 = IOMUX_PAD(0x3cc, 0x1d4, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_FEC_TX_EN__FEC_TX_EN = IOMUX_PAD(0x3d0, 0x1d8, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_FEC_TX_EN__GPIO_3_9 = IOMUX_PAD(0x3d0, 0x1d8, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_FEC_TX_EN__FEC_TX_EN = IOMUX_PAD(0x3d0, 0x1d8, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_FEC_TX_EN__GPIO_3_9 = IOMUX_PAD(0x3d0, 0x1d8, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_FEC_RDATA0__FEC_RDATA0 = IOMUX_PAD(0x3d4, 0x1dc, 0x10, 0, 0, PAD_CTL_HYS | PAD_CTL_PUS_100K_DOWN), - MX25_PAD_FEC_RDATA0__GPIO_3_10 = IOMUX_PAD(0x3d4, 0x1dc, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_FEC_RDATA0__FEC_RDATA0 = IOMUX_PAD(0x3d4, 0x1dc, 0, 0, 0, PAD_CTL_HYS | PAD_CTL_PUS_100K_DOWN), + MX25_PAD_FEC_RDATA0__GPIO_3_10 = IOMUX_PAD(0x3d4, 0x1dc, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_FEC_RDATA1__FEC_RDATA1 = IOMUX_PAD(0x3d8, 0x1e0, 0x10, 0, 0, PAD_CTL_HYS | PAD_CTL_PUS_100K_DOWN), - MX25_PAD_FEC_RDATA1__GPIO_3_11 = IOMUX_PAD(0x3d8, 0x1e0, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_FEC_RDATA1__FEC_RDATA1 = IOMUX_PAD(0x3d8, 0x1e0, 0, 0, 0, PAD_CTL_HYS | PAD_CTL_PUS_100K_DOWN), + MX25_PAD_FEC_RDATA1__GPIO_3_11 = IOMUX_PAD(0x3d8, 0x1e0, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_FEC_RX_DV__FEC_RX_DV = IOMUX_PAD(0x3dc, 0x1e4, 0x10, 0, 0, PAD_CTL_HYS | PAD_CTL_PUS_100K_DOWN), - MX25_PAD_FEC_RX_DV__CAN2_RX = IOMUX_PAD(0x3dc, 0x1e4, 0x14, 0x484, 0, PAD_CTL_PUS_22K_UP), - MX25_PAD_FEC_RX_DV__GPIO_3_12 = IOMUX_PAD(0x3dc, 0x1e4, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_FEC_RX_DV__FEC_RX_DV = IOMUX_PAD(0x3dc, 0x1e4, 0, 0, 0, PAD_CTL_HYS | PAD_CTL_PUS_100K_DOWN), + MX25_PAD_FEC_RX_DV__CAN2_RX = IOMUX_PAD(0x3dc, 0x1e4, 4, 0x484, 0, PAD_CTL_PUS_22K_UP), + MX25_PAD_FEC_RX_DV__GPIO_3_12 = IOMUX_PAD(0x3dc, 0x1e4, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_FEC_TX_CLK__FEC_TX_CLK = IOMUX_PAD(0x3e0, 0x1e8, 0x10, 0, 0, PAD_CTL_HYS | PAD_CTL_PUS_100K_DOWN), - MX25_PAD_FEC_TX_CLK__GPIO_3_13 = IOMUX_PAD(0x3e0, 0x1e8, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_FEC_TX_CLK__FEC_TX_CLK = IOMUX_PAD(0x3e0, 0x1e8, 0, 0, 0, PAD_CTL_HYS | PAD_CTL_PUS_100K_DOWN), + MX25_PAD_FEC_TX_CLK__GPIO_3_13 = IOMUX_PAD(0x3e0, 0x1e8, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_RTCK__RTCK = IOMUX_PAD(0x3e4, 0x1ec, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_RTCK__OWIRE = IOMUX_PAD(0x3e4, 0x1ec, 0x11, 0, 0, NO_PAD_CTRL), - MX25_PAD_RTCK__GPIO_3_14 = IOMUX_PAD(0x3e4, 0x1ec, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_RTCK__RTCK = IOMUX_PAD(0x3e4, 0x1ec, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_RTCK__OWIRE = IOMUX_PAD(0x3e4, 0x1ec, 1, 0, 0, NO_PAD_CTRL), + MX25_PAD_RTCK__GPIO_3_14 = IOMUX_PAD(0x3e4, 0x1ec, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_DE_B__DE_B = IOMUX_PAD(0x3ec, 0x1f0, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_DE_B__GPIO_2_20 = IOMUX_PAD(0x3ec, 0x1f0, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_DE_B__DE_B = IOMUX_PAD(0x3ec, 0x1f0, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_DE_B__GPIO_2_20 = IOMUX_PAD(0x3ec, 0x1f0, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_TDO__TDO = IOMUX_PAD(0x3e8, 0x000, 0x00, 0, 0, NO_PAD_CTRL), + MX25_PAD_TDO__TDO = IOMUX_PAD(0x3e8, 0x000, 0, 0, 0, NO_PAD_CTRL),
- MX25_PAD_GPIO_A__GPIO_A = IOMUX_PAD(0x3f0, 0x1f4, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_GPIO_A__CAN1_TX = IOMUX_PAD(0x3f0, 0x1f4, 0x16, 0, 0, PAD_CTL_PUS_22K_UP), - MX25_PAD_GPIO_A__USBOTG_PWR = IOMUX_PAD(0x3f0, 0x1f4, 0x12, 0, 0, PAD_CTL_PKE), + MX25_PAD_GPIO_A__GPIO_A = IOMUX_PAD(0x3f0, 0x1f4, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_GPIO_A__CAN1_TX = IOMUX_PAD(0x3f0, 0x1f4, 6, 0, 0, PAD_CTL_PUS_22K_UP), + MX25_PAD_GPIO_A__USBOTG_PWR = IOMUX_PAD(0x3f0, 0x1f4, 2, 0, 0, PAD_CTL_PKE),
- MX25_PAD_GPIO_B__GPIO_B = IOMUX_PAD(0x3f4, 0x1f8, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_GPIO_B__CAN1_RX = IOMUX_PAD(0x3f4, 0x1f8, 0x16, 0x480, 1, PAD_CTL_PUS_22K_UP), - MX25_PAD_GPIO_B__USBOTG_OC = IOMUX_PAD(0x3f4, 0x1f8, 0x12, 0x57c, 1, PAD_CTL_PUS_100K_UP), + MX25_PAD_GPIO_B__GPIO_B = IOMUX_PAD(0x3f4, 0x1f8, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_GPIO_B__CAN1_RX = IOMUX_PAD(0x3f4, 0x1f8, 6, 0x480, 1, PAD_CTL_PUS_22K_UP), + MX25_PAD_GPIO_B__USBOTG_OC = IOMUX_PAD(0x3f4, 0x1f8, 2, 0x57c, 1, PAD_CTL_PUS_100K_UP),
- MX25_PAD_GPIO_C__GPIO_C = IOMUX_PAD(0x3f8, 0x1fc, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_GPIO_C__CAN2_TX = IOMUX_PAD(0x3f8, 0x1fc, 0x16, 0, 0, PAD_CTL_PUS_22K_UP), + MX25_PAD_GPIO_C__GPIO_C = IOMUX_PAD(0x3f8, 0x1fc, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_GPIO_C__CAN2_TX = IOMUX_PAD(0x3f8, 0x1fc, 6, 0, 0, PAD_CTL_PUS_22K_UP),
- MX25_PAD_GPIO_D__GPIO_D = IOMUX_PAD(0x3fc, 0x200, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_GPIO_E__LD16 = IOMUX_PAD(0x400, 0x204, 0x02, 0, 0, PAD_CTL_SRE_FAST), - MX25_PAD_GPIO_D__CAN2_RX = IOMUX_PAD(0x3fc, 0x200, 0x16, 0x484, 1, PAD_CTL_PUS_22K_UP), + MX25_PAD_GPIO_D__GPIO_D = IOMUX_PAD(0x3fc, 0x200, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_GPIO_E__LD16 = IOMUX_PAD(0x400, 0x204, 2, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_GPIO_D__CAN2_RX = IOMUX_PAD(0x3fc, 0x200, 6, 0x484, 1, PAD_CTL_PUS_22K_UP),
- MX25_PAD_GPIO_E__GPIO_E = IOMUX_PAD(0x400, 0x204, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_GPIO_F__LD17 = IOMUX_PAD(0x404, 0x208, 0x02, 0, 0, PAD_CTL_SRE_FAST), - MX25_PAD_GPIO_E__I2C3_CLK = IOMUX_PAD(0x400, 0x204, 0x11, 0x524, 2, NO_PAD_CTRL), - MX25_PAD_GPIO_E__AUD7_TXD = IOMUX_PAD(0x400, 0x204, 0x14, 0, 0, NO_PAD_CTRL), + MX25_PAD_GPIO_E__GPIO_E = IOMUX_PAD(0x400, 0x204, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_GPIO_F__LD17 = IOMUX_PAD(0x404, 0x208, 2, 0, 0, PAD_CTL_SRE_FAST), + MX25_PAD_GPIO_E__I2C3_CLK = IOMUX_PAD(0x400, 0x204, 1, 0x524, 2, NO_PAD_CTRL), + MX25_PAD_GPIO_E__AUD7_TXD = IOMUX_PAD(0x400, 0x204, 4, 0, 0, NO_PAD_CTRL),
- MX25_PAD_GPIO_F__GPIO_F = IOMUX_PAD(0x404, 0x208, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_GPIO_F__AUD7_TXC = IOMUX_PAD(0x404, 0x208, 0x14, 0, 0, NO_PAD_CTRL), + MX25_PAD_GPIO_F__GPIO_F = IOMUX_PAD(0x404, 0x208, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_GPIO_F__AUD7_TXC = IOMUX_PAD(0x404, 0x208, 4, 0, 0, NO_PAD_CTRL),
- MX25_PAD_EXT_ARMCLK__EXT_ARMCLK = IOMUX_PAD(0x000, 0x20c, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_EXT_ARMCLK__GPIO_3_15 = IOMUX_PAD(0x000, 0x20c, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_EXT_ARMCLK__EXT_ARMCLK = IOMUX_PAD(0x000, 0x20c, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_EXT_ARMCLK__GPIO_3_15 = IOMUX_PAD(0x000, 0x20c, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_UPLL_BYPCLK__UPLL_BYPCLK = IOMUX_PAD(0x000, 0x210, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_UPLL_BYPCLK__GPIO_3_16 = IOMUX_PAD(0x000, 0x210, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_UPLL_BYPCLK__UPLL_BYPCLK = IOMUX_PAD(0x000, 0x210, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_UPLL_BYPCLK__GPIO_3_16 = IOMUX_PAD(0x000, 0x210, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_VSTBY_REQ__VSTBY_REQ = IOMUX_PAD(0x408, 0x214, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_VSTBY_REQ__AUD7_TXFS = IOMUX_PAD(0x408, 0x214, 0x14, 0, 0, NO_PAD_CTRL), - MX25_PAD_VSTBY_REQ__GPIO_3_17 = IOMUX_PAD(0x408, 0x214, 0x15, 0, 0, NO_PAD_CTRL), - MX25_PAD_VSTBY_ACK__VSTBY_ACK = IOMUX_PAD(0x40c, 0x218, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_VSTBY_ACK__GPIO_3_18 = IOMUX_PAD(0x40c, 0x218, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_VSTBY_REQ__VSTBY_REQ = IOMUX_PAD(0x408, 0x214, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_VSTBY_REQ__AUD7_TXFS = IOMUX_PAD(0x408, 0x214, 4, 0, 0, NO_PAD_CTRL), + MX25_PAD_VSTBY_REQ__GPIO_3_17 = IOMUX_PAD(0x408, 0x214, 5, 0, 0, NO_PAD_CTRL), + MX25_PAD_VSTBY_ACK__VSTBY_ACK = IOMUX_PAD(0x40c, 0x218, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_VSTBY_ACK__GPIO_3_18 = IOMUX_PAD(0x40c, 0x218, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_POWER_FAIL__POWER_FAIL = IOMUX_PAD(0x410, 0x21c, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_POWER_FAIL__AUD7_RXD = IOMUX_PAD(0x410, 0x21c, 0x14, 0x478, 1, NO_PAD_CTRL), - MX25_PAD_POWER_FAIL__GPIO_3_19 = IOMUX_PAD(0x410, 0x21c, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_POWER_FAIL__POWER_FAIL = IOMUX_PAD(0x410, 0x21c, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_POWER_FAIL__AUD7_RXD = IOMUX_PAD(0x410, 0x21c, 4, 0x478, 1, NO_PAD_CTRL), + MX25_PAD_POWER_FAIL__GPIO_3_19 = IOMUX_PAD(0x410, 0x21c, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_CLKO__CLKO = IOMUX_PAD(0x414, 0x220, 0x10, 0, 0, NO_PAD_CTRL), - MX25_PAD_CLKO__GPIO_2_21 = IOMUX_PAD(0x414, 0x220, 0x15, 0, 0, NO_PAD_CTRL), + MX25_PAD_CLKO__CLKO = IOMUX_PAD(0x414, 0x220, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_CLKO__GPIO_2_21 = IOMUX_PAD(0x414, 0x220, 5, 0, 0, NO_PAD_CTRL),
- MX25_PAD_BOOT_MODE0__BOOT_MODE0 = IOMUX_PAD(0x000, 0x224, 0x00, 0, 0, NO_PAD_CTRL), - MX25_PAD_BOOT_MODE0__GPIO_4_30 = IOMUX_PAD(0x000, 0x224, 0x05, 0, 0, NO_PAD_CTRL), - MX25_PAD_BOOT_MODE1__BOOT_MODE1 = IOMUX_PAD(0x000, 0x228, 0x00, 0, 0, NO_PAD_CTRL), - MX25_PAD_BOOT_MODE1__GPIO_4_31 = IOMUX_PAD(0x000, 0x228, 0x05, 0, 0, NO_PAD_CTRL), + MX25_PAD_BOOT_MODE0__BOOT_MODE0 = IOMUX_PAD(0x000, 0x224, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_BOOT_MODE0__GPIO_4_30 = IOMUX_PAD(0x000, 0x224, 5, 0, 0, NO_PAD_CTRL), + MX25_PAD_BOOT_MODE1__BOOT_MODE1 = IOMUX_PAD(0x000, 0x228, 0, 0, 0, NO_PAD_CTRL), + MX25_PAD_BOOT_MODE1__GPIO_4_31 = IOMUX_PAD(0x000, 0x228, 5, 0, 0, NO_PAD_CTRL),
MX25_PAD_CTL_GRP_DVS_MISC = IOMUX_PAD(0x418, 0x000, 0, 0, 0, NO_PAD_CTRL), MX25_PAD_CTL_GRP_DSE_FEC = IOMUX_PAD(0x41c, 0x000, 0, 0, 0, NO_PAD_CTRL),
Hi Michael,
On Wed, Jan 24, 2018 at 12:56 PM, Michael Trimarchi michael@amarulasolutions.com wrote:
Glad you found a fix for the issue!
In many places in this patch you are only changing things like 0x00 --> 0 or 0x05--> 5, which just makes it harder to review.
Please send a new version that only removes the SION bit.
Hi Fabio
On Wed, Jan 24, 2018 at 4:14 PM, Fabio Estevam festevam@gmail.com wrote:
Hi Michael,
The idea was to align to the other freescale architecture. I can create two patches on it
Michael
Hi Michael,
You remove this bit because it should be set by default? This sentence is confusing.
I can't find details about SION on a specific pin in this thread. Please elaborate.
Michael
Please make sure that these changes are not breaking anything for any board (NEW_PAD_CTRL() can be used for these boards to restore SION if it really has to be removed by default). SION is required in some cases, and it's unlikely to be harmful, its main side effect being an increased power consumption.
Best regards, Benoît
Michael
Actually, NEW_PAD_CTRL() cannot act upon SION, so removing it by default is all the more risky.
Benoît
Hi
English is wrong ;)
SION bit as a specific purpose to read back value that is set in output. You don't need and it's not set in any freescale board. If you need to set you need to add to your peripheral. The only case you need maybe is the data[0] of sdcard.
Tihs is the reason that in this thread we have NXP people. We have 2 board with mx25 right now so this will not an high risk break.
Michael
Michael
Benoît
English is wrong ;)
Unless there is a NEW_PAD_CTRL()-like mechanism for SION, all these definitions should be kept in iomux-mx25.h in order not to redefine the register offsets everywhere. AFAIK, all the Freescale boards use the definitions from iomux-mx25.h too.
And eSDHC CMD, and I²C probably too. Yet, you are also removing SION in these cases. I have 3 i.M25-based boards working fine with SION. ;) Can you explain the precise issue that you are trying to fix (which pin)?
Hi
On Wed, Jan 24, 2018 at 12:56 PM, Michael Trimarchi michael@amarulasolutions.com wrote: > SION bit should be used in the situation that we need > to read back the value of a pin and should be set by > default.
English is wrong ;)
Let me summarize for you: - was having a board with linux 2.6.x and uboot from 2009 working fine on a usb pen driver (look on thread in linux-usb) - was having the same board with any version of linux from 3.18 to 4.15 and fail with this pen drive - check back all the changes from linux 2.6.x to linux 4.15.x and compare every single register and all the usb code and was just confirm a better implementation of new kernel. but with a result of a usb stuck on the host port - swap the boot-loader and having a working board - go in deep in boot-loader and compare everything - Understand the difference was the SION bit that was enable on all the mux
In general when a board start from reset it has default pin muxing. Each peripheral need to setup the pin muxing according to the real usage. SION by default is not the right way to do it. What is the concept of working board in your side? Just pass your testcase? Ok even this board was passing all test cases apart this usb pen drive. We was having in the field some customer with usb issue time to time and only this proof that somenthing was not real ok.
Michael
On Wed, Jan 24, 2018 at 4:14 PM, Fabio Estevam festevam@gmail.com wrote: > On Wed, Jan 24, 2018 at 12:56 PM, Michael Trimarchi > michael@amarulasolutions.com wrote: >> SION bit should be used in the situation that we need >> to read back the value of a pin and should be set by >> default.
English is wrong ;)
Thanks for these details. All the test cases should of course work. I'm just trying to figure out the root cause of your issue, and maybe it's not SION itself but a power issue triggered by SION, or maybe it's SION only for some specific pads and not for all the pads, or something else. So what I'm saying is that this change might be too large, and care should be taken.
Some Freescale boards actually do use SION. E.g., see MX25_PAD_FEC_MDIO__FEC_MDIO in https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/arch... . SION is required to read back the actual state of a GPIO in output mode. It is also required for some bidirectional alternate functions (such as I²C SDA/SCL, SD CMD/DATn, etc.) on some i.MXs (not all i.MXs behave in the same way for the same peripheral), but which ones are affected is not always documented, so please double check and test all these cases.
Hi Fabio
On Wed, Jan 24, 2018 at 4:26 PM, Michael Nazzareno Trimarchi michael@amarulasolutions.com wrote:
Hi Fabio
Hi Michael,
Can you check where SION bit is mandatory for mx25? I have on IMX51 some PINMUX where sion is enabled. I can clean up a bit the patch to just minimize the change. We have for example:
arch/arm/include/asm/arch-mx5/iomux-mx51.h: MX51_PAD_SD1_CMD__SD1_CMD = IOMUX_PAD(0x79c, 0x394, 0x10, __NA_, 0, MX51_SDHCI_PAD_CTRL), arch/arm/include/asm/arch-mx5/iomux-mx51.h: MX51_PAD_SD1_CLK__SD1_CLK = IOMUX_PAD(0x7a0, 0x398, 0x10, __NA_, 0, MX51_SDHCI_PAD_CTRL | PAD_CTL_HYS), arch/arm/include/asm/arch-mx5/iomux-mx51.h: MX51_PAD_SD1_DATA0__SD1_DATA0 = IOMUX_PAD(0x7a4, 0x39c, 0x10, __NA_, 0, MX51_SDHCI_PAD_CTRL), arch/arm/include/asm/arch-mx5/iomux-mx51.h: MX51_PAD_SD1_DATA1__SD1_DATA1 = IOMUX_PAD(0x7a8, 0x3a0, 0x10, __NA_, 0, MX51_SDHCI_PAD_CTRL), arch/arm/include/asm/arch-mx5/iomux-mx51.h: MX51_PAD_SD1_DATA2__SD1_DATA2 = IOMUX_PAD(0x7ac, 0x3a4, 0x10, __NA_, 0, MX51_SDHCI_PAD_CTRL), arch/arm/include/asm/arch-mx5/iomux-mx51.h: MX51_PAD_SD1_DATA3__SD1_DATA3 = IOMUX_PAD(0x7b0, 0x3a8, 0x10, __NA_, 0, MX51_SDHCI_PAD_CTRL), arch/arm/include/asm/arch-mx5/iomux-mx51.h: MX51_PAD_SD2_CMD__SD2_CMD = IOMUX_PAD(0x7bc, 0x3b4, 0x10, __NA_, 0, MX51_SDHCI_PAD_CTRL), arch/arm/include/asm/arch-mx5/iomux-mx51.h: MX51_PAD_SD2_CLK__SD2_CLK = IOMUX_PAD(0x7c0, 0x3b8, 0x10, __NA_, 0, MX51_SDHCI_PAD_CTRL | PAD_CTL_HYS), arch/arm/include/asm/arch-mx5/iomux-mx51.h: MX51_PAD_SD2_DATA0__SD2_DATA0 = IOMUX_PAD(0x7c4, 0x3bc, 0x10, __NA_, 0, MX51_SDHCI_PAD_CTRL), arch/arm/include/asm/arch-mx5/iomux-mx51.h: MX51_PAD_SD2_DATA1__SD2_DATA1 = IOMUX_PAD(0x7c8, 0x3c0, 0x10, __NA_, 0, MX51_SDHCI_PAD_CTRL), arch/arm/include/asm/arch-mx5/iomux-mx51.h: MX51_PAD_SD2_DATA2__SD2_DATA2 = IOMUX_PAD(0x7cc, 0x3c4, 0x10, __NA_, 0, MX51_SDHCI_PAD_CTRL), arch/arm/include/asm/arch-mx5/iomux-mx51.h: MX51_PAD_SD2_DATA3__SD2_DATA3 = IOMUX_PAD(0x7d0, 0x3c8, 0x10, __NA_, 0, MX51_SDHCI_PAD_CTRL),
In this way we can be sure that we have done in proper way
Michael
SION bit should be used in the situation that we need to read back the value of a pin and should be set by default. This can generate any kind of random malfunction as described in this thread.
According to this thread: https://www.spinics.net/lists/linux-usb/msg162574.html
We consider this an early bug so all the boards running imx25 with a minimimal set of functionalities can be affected.
As reported by this application note: https://www.nxp.com/docs/en/application-note/AN5078.pdf
The software input on (SION) bit is an option to force an input path to be active regardless of the value driven by the corresponding module. It is used when the nature direction of a pin depending on selected alternative function is an output, but it is needed to read the real logic value on a pin.
The SION bit can be used in: • Loopback: the module of a selected alternative function drives the pad and also receives the pad value as an input • GPIO capture: the module of a selected alternative function drives the pin and the value is captured by the GPIO
Signed-off-by: Michael Trimarchi michael@amarulasolutions.com
Refer-to: MX25 USB timeout on ID 0951:1665 Kingston Technology Digital DataTraveler SE9 64GB
Michael
arch/arm/include/asm/arch-mx25/iomux-mx25.h | 680 ++++++++++++++-------------- 1 file changed, 340 insertions(+), 340 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx25/iomux-mx25.h b/arch/arm/include/asm/arch-mx25/iomux-mx25.h index 5b2863e..2fcaf60 100644 --- a/arch/arm/include/asm/arch-mx25/iomux-mx25.h +++ b/arch/arm/include/asm/arch-mx25/iomux-mx25.h @@ -30,481 +30,481 @@
/* PAD MUX ALT INPSE PATH PADCTRL */ enum {
MX25_PAD_A10__A10 = IOMUX_PAD(0x000, 0x008, 0x00, 0, 0, NO_PAD_CTRL),
MX25_PAD_A10__GPIO_4_0 = IOMUX_PAD(0x000, 0x008, 0x05, 0, 0, NO_PAD_CTRL),
MX25_PAD_A10__A10 = IOMUX_PAD(0x000, 0x008, 0, 0, 0, NO_PAD_CTRL),
MX25_PAD_A10__GPIO_4_0 = IOMUX_PAD(0x000, 0x008, 5, 0, 0, NO_PAD_CTRL),
-- | Michael Nazzareno Trimarchi Amarula Solutions BV | | COO - Founder Cruquiuskade 47 | | +31(0)851119172 Amsterdam 1018 AM NL | | [`as] http://www.amarulasolutions.com |
Hi Michael,
[Removed usb list as this is off-topic for them]
On Wed, Jan 24, 2018 at 2:31 PM, Michael Nazzareno Trimarchi michael@amarulasolutions.com wrote:
I think it depends on the pin function per board design, no?
Benoît brings a good point: what is the exact pin that causes the USB failure on your case?
Let's try to understand the exact pin that is causing the problem on your board.
Thanks
Hi Fabio
On Wed, Jan 24, 2018 at 5:38 PM, Fabio Estevam festevam@gmail.com wrote:
Hi Michael,
I don't have a pdk and it's difficult to find them so I need to check. Anyway some revision of the firmware on this pendrive are working but the latest one is not working. I have a lot of pen drives and all of them are fully working.
I have tested only with uart and already it does not let it work properly. So I can try to limit in my boot case but I don't think that having SION bit pre-defined it's valid at all. We have a limited number of pin mux with SION enable on any nxp architecture right now for every architecture.
* Benoit * can you test them? I will provide a better changeset let sdcard and some ethernet pin in the right configuation (even ethernet was working without SION enable)
I will check it out. This was an initial patch proposal
Thanks
Hi Michael,
Hi Michael,
- Benoit * can you test them? I will provide a better changeset let
Not sure I can find time for that. Perhaps in a few days.
Hi
On Wed, Jan 24, 2018 at 6:05 PM, Benoît Thébaudeau benoit@wsystem.com wrote:
Hi Michael,
Hi Michael,
From the datasheet I have:
Software Input On Field. Force the selected mux mode Input path no matter of MUX_MODE functionality. 1: Force input path of pad A14. 0: Input Path is determined by functionality of the selected mux mode (regular).
So i think that in case of some peripheral this is not relevant but I need confirmation
Michael
Hi Michael,
Hi Michael,
I think I remember people on the U-Boot mailing list having had issues after having dropped SION for some bidirectional alternate functions on some i.MXs (maybe I²C SDA/SCL on i.MX51, which is very close to i.MX25). It is not possible to assume that all peripherals drive the input circuitry properly without SION for bidirectional signals.
Hi Michael,
On Wed, Jan 24, 2018 at 3:12 PM, Michael Nazzareno Trimarchi michael@amarulasolutions.com wrote:
Looking at arch/arm/boot/dts/imx25-pinfunc.h I see that there is only one pin that sets the SION bit in the common pin definition:
/* * Removing the SION bit from MX25_PAD_SD1_CMD__SD1_CMD breaks detecting an SD * card. According to the i.MX25 reference manual (e.g. Figure 23-2 in IMX25RM * Rev. 2 from 01/2011) this pin is bidirectional. So it seems to be a silicon * bug that configuring the SD1_CMD function doesn't enable the input path for * this pin. * This might have side effects for other hardware units that are connected to * that pin and use the respective function as input. */ #define MX25_PAD_SD1_CMD__SD1_CMD 0x190 0x388 0x000 0x10 0x000
Hi Fabio,
- Removing the SION bit from MX25_PAD_SD1_CMD__SD1_CMD breaks detecting an SD
- card. According to the i.MX25 reference manual (e.g. Figure 23-2 in IMX25RM
- Rev. 2 from 01/2011) this pin is bidirectional. So it seems to be a silicon
- bug that configuring the SD1_CMD function doesn't enable the input path for
- this pin.
- This might have side effects for other hardware units that are connected to
- that pin and use the respective function as input.
In mainline Linux, SION is also set by some DTS files (MX25_PAD_* 0x40000000 flag) for FEC MDIO and SD CMD/CLK/DATAn.
Hi
On Wed, Jan 24, 2018 at 6:29 PM, Benoît Thébaudeau benoit@wsystem.com wrote:
Hi Fabio,
- this pin.
Think that is not needed . I will check
Michael
Hi Benoît,
Which I think it is fine as it is set on a per board basis.
Maybe we could do the same in U-Boot.
Thanks
Hi
On Wed, Jan 24, 2018 at 6:36 PM, Fabio Estevam festevam@gmail.com wrote:
Hi Benoît,
This is exactly my initial propose. Can we give a try and manage on board level?
Michael
Thanks
Hi Michael,
On Wed, Jan 24, 2018 at 3:46 PM, Michael Nazzareno Trimarchi michael@amarulasolutions.com wrote:
The kernel should not rely on the IOMUX setting done by the bootloader.
Do you use 0x80000000 in your dts IOMUX configuration by any chance?
0x80000000 means that the kernel will not do IOMUX configuration and will use the IOMUX value that comes from the bootloader.
It seems you can fix your USB problem by not using the IOMUX value from the bootloader and just use the good IOMUX (without SION) explicitly in your dts.
Does it fix the problem?
Hi
On 25 Jan. 2018 12:07 am, "Fabio Estevam" festevam@gmail.com wrote:
Hi Michael,
level?
Yes but those should not be even wrong. We can not be sure if the state machine of any logic as already corrupted. Remember that we have already this problem with the clock in general that most of the time are already enabled and so logic can be up.
I think that the way to fix in a specific case could be more then one. I will do the best on my side but I will include to not touch iomux without any reason. I already point out that just with few pins configured like console I get the problem . I can check two extra gpio too.
To be clear, my board was "working". We are talking about a product in the field since years with one minimal USB mulfuction . Other boards can have the same problem but just not rise in the field. If the host port is direct connected to the pen drive without an hub the USB reset can most of the time recover the connection.
Michael
Hi Michael,
On 25/01/2018 at 06:47, Michael Nazzareno Trimarchi wrote:
On 25 Jan. 2018 12:07 am, "Fabio Estevam" <festevam@gmail.com mailto:festevam@gmail.com> wrote:
Hi Michael, On Wed, Jan 24, 2018 at 3:46 PM, Michael Nazzareno Trimarchi <michael@amarulasolutions.com <mailto:michael@amarulasolutions.com>> wrote: > This is exactly my initial propose. Can we give a try and manage on board level? The kernel should not rely on the IOMUX setting done by the bootloader. Do you use 0x80000000 in your dts IOMUX configuration by any chance? 0x80000000 means that the kernel will not do IOMUX configuration and will use the IOMUX value that comes from the bootloader.
It seems you can fix your USB problem by not using the IOMUX value from the bootloader and just use the good IOMUX (without SION) explicitly in your dts. Does it fix the problem?
I agree with Fabio: Linux should not rely on the pad configurations performed by U-Boot. But as you say, U-Boot should work fine itself too. Have you tested the problematic USB pen drive with U-Boot?
Besides your USB issue, in order to optimize power consumption, iomux-mx25.h should not set SION by default, except for the pad functions that can in no way work without it (still to be identified/tested). For the other use cases, the board files can set SION themselves, thanks to a NEW_PAD_CTRL()-like mechanism (apparently yet to be introduced into U-Boot). The changes introduced here should not break anything for the current in-tree boards.
You said that setting SION only for a UART is enough to trigger your USB issue. Of course, there is no reason to set SION by default for a UART, but I was thinking about a possible link between UART and USB, as this behavior is very strange. Which USB host port are use using with the problematic pen drive, and with which PHY (SoC-internal/external, bus)? Have you checked that this port is properly configured for this PHY and PWR/OC (on/off + polarity) in both U-Boot and Linux? For instance, if this port is configured to use OC but no OC signal is actually wired, this can probably do weird things.
Hi
On Thu, Jan 25, 2018 at 11:02 AM, Benoît Thébaudeau benoit@wsystem.com wrote:
Hi Michael,
This is not the linux mailing list
ehci phy of imx25 is not supported in uboot I think and it's not in the scope of this change
yes I know.
Nothing of above is connected. Pen drive is in the linux thread described in the commit message. All the usb stack is fully functional with a lot of pen drive. OC, PWR are not managed on USB/serial ehci port so they are not involved and I can check. I have posted some patches on linux mailing list to fix minor stuff. Let's say any permutation bit on phy configuration does not solve the problem. It's not a problem of usb suspend etc. I think that approch should be:
- align the pin mux mx25 file to the other architecture. So drop all the sion bit expect for the one where we know that silicon is buggy - apply SION when is needed in the board that are already in uboot - send patches on pin mux for board that are in mainline and we can test
On my side. I will restrict the change on my board to full isolate the configuration. Force the reset of SION bit anyway in linux if this solve.
Agree?
Michael
Agree?
Looks good to me.
Benoît
Benoît Thébaudeau
Fabio Estevam
Michael Trimarchi
