[PATCH v2 00/16] imx9: switch to bootstd for i.MX93/1 EVK/QSB and i.MX8M EVK
Switch to bootstd for NXP i.MX9/8M boards with a bsp_bootcmd as fallback.
Some cleanups are also included together with this patchset
CI: https://dev.azure.com/pengfan/uboot-ci/_build/results?buildId=16&view=re...
Signed-off-by: Peng Fan peng.fan@nxp.com --- Changes in v2: - Separate cleanup headers to separate patch - Separate drop global data to separate patch - Drop CONFIG_ENV_SOURCE_FILE since same as default - Link to v1: https://lore.kernel.org/r/20250104-imx-bootstd-v1-0-e09618cc1d65@nxp.com
--- Peng Fan (16): imx: imx93_evk: switch to BOOTSTD imx: imx93_qsb: switch to BOOTSTD imx: imx91_evk: switch to BOOTSTD imx: imx8mp_evk: Enable dynamic settings to mmcdev and mmcroot imx: imx8mp_evk: Switch to BOOTSTD imx: imx8mn_evk: Cleanup headers imx: imx8mn_evk: Drop DECLARE_GLOBAL_DATA_PTR imx: imx8mn_evk: Enable dynamic settings to mmcdev and mmcroot imx: imx8mn_evk: Switch to BOOTSTD imx: imx8mm_evk: Enable dynamic settings to mmcdev and mmcroot imx: imx8mm_evk: Switch to BOOTSTD imx: imx8mq_evk: Cleanup headers imx: imx8mq_evk: Drop DECLARE_GLOBAL_DATA_PTR imx: imx8mq_evk: Enable dynamic settings to mmcdev and mmcroot imx: imx8mq_evk: Switch to BOOTSTD imx: imx93-11x11-evk: drop duplicated nodes
arch/arm/dts/imx93-11x11-evk-u-boot.dtsi | 118 --------------------------- arch/arm/mach-imx/imx8m/Kconfig | 8 ++ arch/arm/mach-imx/imx9/Kconfig | 6 ++ board/freescale/common/Makefile | 2 +- board/freescale/imx8mm_evk/imx8mm_evk.c | 3 + board/freescale/imx8mm_evk/imx8mm_evk.env | 67 +++++++++++++++ board/freescale/imx8mn_evk/imx8mn_evk.c | 12 +-- board/freescale/imx8mn_evk/imx8mn_evk.env | 67 +++++++++++++++ board/freescale/imx8mp_evk/imx8mp_evk.c | 5 ++ board/freescale/imx8mp_evk/imx8mp_evk.env | 57 +++++++++++++ board/freescale/imx8mq_evk/imx8mq_evk.c | 29 ++----- board/freescale/imx8mq_evk/imx8mq_evk.env | 60 ++++++++++++++ board/freescale/imx91_evk/imx91_evk.env | 29 ++++++- board/freescale/imx93_evk/imx93_evk.env | 88 ++++++++++++++++++++ board/freescale/imx93_qsb/imx93_qsb.env | 29 ++++++- configs/imx8mm_evk_defconfig | 3 +- configs/imx8mm_evk_fspi_defconfig | 4 +- configs/imx8mn_evk_defconfig | 2 +- configs/imx8mp_evk_defconfig | 2 +- configs/imx8mq_evk_defconfig | 3 +- configs/imx91_11x11_evk_defconfig | 3 +- configs/imx91_11x11_evk_inline_ecc_defconfig | 3 +- configs/imx93_11x11_evk_defconfig | 2 +- configs/imx93_9x9_qsb_defconfig | 3 +- configs/imx93_9x9_qsb_inline_ecc_defconfig | 3 +- drivers/gpio/adp5585_gpio.c | 2 +- include/configs/imx8mm_evk.h | 22 ----- include/configs/imx8mn_evk.h | 30 ------- include/configs/imx8mp_evk.h | 21 ----- include/configs/imx8mq_evk.h | 22 ----- include/configs/imx93_evk.h | 105 ------------------------ 31 files changed, 444 insertions(+), 366 deletions(-) --- base-commit: ec9263b4f15c4cf82eb6a211c67baa6385065b8e change-id: 20241231-imx-bootstd-abbf2e9e0d75
Switch to support BOOTSTD with a bsp bootcmd as fallback. Move the env to imx93_evk.env
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/mach-imx/imx9/Kconfig | 2 + board/freescale/imx93_evk/imx93_evk.env | 88 ++++++++++++++++++++++++++ configs/imx93_11x11_evk_defconfig | 2 +- include/configs/imx93_evk.h | 105 -------------------------------- 4 files changed, 91 insertions(+), 106 deletions(-)
diff --git a/arch/arm/mach-imx/imx9/Kconfig b/arch/arm/mach-imx/imx9/Kconfig index 54c6b117fcff21be5c3800ebd1dc30f8ea12ac42..c52546084394a7cc26f35c93ac8fb62d9c5fe795 100644 --- a/arch/arm/mach-imx/imx9/Kconfig +++ b/arch/arm/mach-imx/imx9/Kconfig @@ -47,6 +47,8 @@ config TARGET_IMX93_11X11_EVK select OF_BOARD_FIXUP select IMX93 imply OF_UPSTREAM + imply BOOTSTD_FULL + imply BOOTSTD_BOOTCOMMAND
config TARGET_IMX93_VAR_SOM bool "imx93_var_som" diff --git a/board/freescale/imx93_evk/imx93_evk.env b/board/freescale/imx93_evk/imx93_evk.env new file mode 100644 index 0000000000000000000000000000000000000000..f692f42f78ab67f004a483d886388218fadcbc15 --- /dev/null +++ b/board/freescale/imx93_evk/imx93_evk.env @@ -0,0 +1,88 @@ +/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ + +boot_targets=mmc0 mmc1 +boot_fit=no +bootm_size=0x10000000 +cntr_addr=0x98000000 +cntr_file=os_cntr_signed.bin +console=ttyLP0,115200 earlycon +fdt_addr_r=0x83000000 +fdt_addr=0x83000000 +fdtfile=CONFIG_DEFAULT_FDT_FILE +image=Image +mmcdev=CONFIG_SYS_MMC_ENV_DEV +mmcpart=1 +mmcroot=/dev/mmcblk1p2 rootwait rw +mmcautodetect=yes +mmcargs=setenv bootargs ${jh_clk} ${mcore_clk} console=${console} root=${mmcroot} +prepare_mcore=setenv mcore_clk clk-imx93.mcore_booted +loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image} +loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr_r} ${fdtfile} +loadcntr=fatload mmc ${mmcdev}:${mmcpart} ${cntr_addr} ${cntr_file} +auth_os=auth_cntr ${cntr_addr} +sec_boot=no +boot_os=booti ${loadaddr} - ${fdt_addr_r} +mmcboot= + echo Booting from mmc ...; + run mmcargs; + if test ${sec_boot} = yes; then + if true; then + run boot_os; + else + echo ERR: failed to authenticate; + fi; + else + if run loadfdt; then + run boot_os; + else + echo WARN: Cannot load the DT; + fi; + fi; +netargs=setenv bootargs ${jh_clk} ${mcore_clk} console=${console} root=/dev/nfs + ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp +netboot= + echo Booting from net ...; + run netargs; + if test ${ip_dyn} = yes; then + setenv get_cmd dhcp; + else + setenv get_cmd tftp; + fi; + if test ${sec_boot} = yes; then + ${get_cmd} ${cntr_addr} ${cntr_file}; + if true; then + run boot_os; + else + echo ERR: failed to authenticate; + fi; + else + ${get_cmd} ${loadaddr} ${image}; + if ${get_cmd} ${fdt_addr_r} ${fdtfile}; then + run boot_os; + else + echo WARN: Cannot load the DT; + fi; + fi; +bsp_bootcmd= + echo Running BSP bootcmd ...; + mmc dev ${mmcdev}; + if mmc rescan; then + if run loadbootscript; then + run bootscript; + else + if test ${sec_boot} = yes; then + if run loadcntr; then + run mmcboot; + else + run netboot; + fi; + else + if run loadimage; then + run mmcboot; + else + run netboot; + fi; + fi; + fi; + fi; +scriptaddr=0x83500000 diff --git a/configs/imx93_11x11_evk_defconfig b/configs/imx93_11x11_evk_defconfig index df62eecdde455af561a23a54fde5dfc0a66d1835..43a67232d045e6f308b7bf79998d707841d3886e 100644 --- a/configs/imx93_11x11_evk_defconfig +++ b/configs/imx93_11x11_evk_defconfig @@ -26,7 +26,7 @@ CONFIG_SPL_IMX_ROMAPI_LOADADDR=0x88000000 CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x90000000 CONFIG_REMAKE_ELF=y -CONFIG_DISTRO_DEFAULTS=y +CONFIG_BOOTCOMMAND="bootflow scan -lb; run bsp_bootcmd" CONFIG_DEFAULT_FDT_FILE="imx93-11x11-evk.dtb" CONFIG_SYS_CBSIZE=2048 CONFIG_SYS_PBSIZE=2074 diff --git a/include/configs/imx93_evk.h b/include/configs/imx93_evk.h index 260a5043d5370478a6245bd4eafcf5f1c24b495a..eb40a69d20cb0aeec973a9c1a32a6fcfd831b967 100644 --- a/include/configs/imx93_evk.h +++ b/include/configs/imx93_evk.h @@ -17,117 +17,12 @@ #define CFG_MALLOC_F_ADDR 0x204D0000 #endif
-#ifdef CONFIG_DISTRO_DEFAULTS -#define BOOT_TARGET_DEVICES(func) \ - func(MMC, mmc, 0) \ - func(MMC, mmc, 1) \ - -#include <config_distro_bootcmd.h> -#else -#define BOOTENV -#endif - #ifdef CONFIG_SYS_MMC_ENV_DEV #define IMX93_EVK_MMC_ENV_DEV CONFIG_SYS_MMC_ENV_DEV #else #define IMX93_EVK_MMC_ENV_DEV 0 #endif
-/* Initial environment variables */ -#define CFG_EXTRA_ENV_SETTINGS \ - BOOTENV \ - "scriptaddr=0x83500000\0" \ - "kernel_addr_r=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ - "image=Image\0" \ - "splashimage=0x90000000\0" \ - "console=ttyLP0,115200 earlycon\0" \ - "fdt_addr_r=0x83000000\0" \ - "fdt_addr=0x83000000\0" \ - "cntr_addr=0x98000000\0" \ - "cntr_file=os_cntr_signed.bin\0" \ - "boot_fit=no\0" \ - "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ - "bootm_size=0x10000000\0" \ - "mmcdev=" __stringify(IMX93_EVK_MMC_ENV_DEV)"\0" \ - "mmcpart=1\0" \ - "mmcroot=/dev/mmcblk1p2 rootwait rw\0" \ - "mmcautodetect=yes\0" \ - "mmcargs=setenv bootargs ${jh_clk} console=${console} root=${mmcroot}\0 " \ - "loadbootscript=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${script};\0" \ - "bootscript=echo Running bootscript from mmc ...; " \ - "source\0" \ - "loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image}\0" \ - "loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr_r} ${fdtfile}\0" \ - "loadcntr=fatload mmc ${mmcdev}:${mmcpart} ${cntr_addr} ${cntr_file}\0" \ - "auth_os=auth_cntr ${cntr_addr}\0" \ - "boot_os=booti ${loadaddr} - ${fdt_addr_r};\0" \ - "mmcboot=echo Booting from mmc ...; " \ - "run mmcargs; " \ - "if test ${sec_boot} = yes; then " \ - "if run auth_os; then " \ - "run boot_os; " \ - "else " \ - "echo ERR: failed to authenticate; " \ - "fi; " \ - "else " \ - "if test ${boot_fit} = yes || test ${boot_fit} = try; then " \ - "bootm ${loadaddr}; " \ - "else " \ - "if run loadfdt; then " \ - "run boot_os; " \ - "else " \ - "echo WARN: Cannot load the DT; " \ - "fi; " \ - "fi;" \ - "fi;\0" \ - "netargs=setenv bootargs ${jh_clk} console=${console} " \ - "root=/dev/nfs " \ - "ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp\0" \ - "netboot=echo Booting from net ...; " \ - "run netargs; " \ - "if test ${ip_dyn} = yes; then " \ - "setenv get_cmd dhcp; " \ - "else " \ - "setenv get_cmd tftp; " \ - "fi; " \ - "if test ${sec_boot} = yes; then " \ - "${get_cmd} ${cntr_addr} ${cntr_file}; " \ - "if run auth_os; then " \ - "run boot_os; " \ - "else " \ - "echo ERR: failed to authenticate; " \ - "fi; " \ - "else " \ - "${get_cmd} ${loadaddr} ${image}; " \ - "if test ${boot_fit} = yes || test ${boot_fit} = try; then " \ - "bootm ${loadaddr}; " \ - "else " \ - "if ${get_cmd} ${fdt_addr_r} ${fdtfile}; then " \ - "run boot_os; " \ - "else " \ - "echo WARN: Cannot load the DT; " \ - "fi; " \ - "fi;" \ - "fi;\0" \ - "bsp_bootcmd=echo Running BSP bootcmd ...; " \ - "mmc dev ${mmcdev}; if mmc rescan; then " \ - "if run loadbootscript; then " \ - "run bootscript; " \ - "else " \ - "if test ${sec_boot} = yes; then " \ - "if run loadcntr; then " \ - "run mmcboot; " \ - "else run netboot; " \ - "fi; " \ - "else " \ - "if run loadimage; then " \ - "run mmcboot; " \ - "else run netboot; " \ - "fi; " \ - "fi; " \ - "fi; " \ - "fi;" - /* Link Definitions */
#define CFG_SYS_INIT_RAM_ADDR 0x80000000
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/mach-imx/imx9/Kconfig | 2 ++ board/freescale/imx93_qsb/imx93_qsb.env | 29 +++++++++++++++++++++++++++-- configs/imx93_9x9_qsb_defconfig | 3 +-- configs/imx93_9x9_qsb_inline_ecc_defconfig | 3 +-- 4 files changed, 31 insertions(+), 6 deletions(-)
diff --git a/arch/arm/mach-imx/imx9/Kconfig b/arch/arm/mach-imx/imx9/Kconfig index c52546084394a7cc26f35c93ac8fb62d9c5fe795..d756f3dcad2e91172ecd885357b9d0adf2e387e3 100644 --- a/arch/arm/mach-imx/imx9/Kconfig +++ b/arch/arm/mach-imx/imx9/Kconfig @@ -41,6 +41,8 @@ config TARGET_IMX93_9X9_QSB select IMX93 select IMX9_LPDDR4X imply OF_UPSTREAM + imply BOOTSTD_FULL + imply BOOTSTD_BOOTCOMMAND
config TARGET_IMX93_11X11_EVK bool "imx93_11x11_evk" diff --git a/board/freescale/imx93_qsb/imx93_qsb.env b/board/freescale/imx93_qsb/imx93_qsb.env index 92486c6f74d2ec12f638443dcf598daa28f306b6..c972d3eb2511542c1a11812f879d7627cadef797 100644 --- a/board/freescale/imx93_qsb/imx93_qsb.env +++ b/board/freescale/imx93_qsb/imx93_qsb.env @@ -10,6 +10,7 @@ fdt_addr_r=0x83000000 fdt_addr=0x83000000 fdtfile=CONFIG_DEFAULT_FDT_FILE image=Image +mmcdev=CONFIG_SYS_MMC_ENV_DEV mmcpart=1 mmcroot=/dev/mmcblk1p2 rootwait rw mmcautodetect=yes @@ -19,12 +20,13 @@ loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image} loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr_r} ${fdtfile} loadcntr=fatload mmc ${mmcdev}:${mmcpart} ${cntr_addr} ${cntr_file} auth_os=auth_cntr ${cntr_addr} +sec_boot=no boot_os=booti ${loadaddr} - ${fdt_addr_r} mmcboot= echo Booting from mmc ...; run mmcargs; if test ${sec_boot} = yes; then - if run auth_os; then + if run true; then run boot_os; else echo ERR: failed to authenticate; @@ -48,7 +50,7 @@ netboot= fi; if test ${sec_boot} = yes; then ${get_cmd} ${cntr_addr} ${cntr_file}; - if run auth_os; then + if true; then run boot_os; else echo ERR: failed to authenticate; @@ -61,3 +63,26 @@ netboot= echo WARN: Cannot load the DT; fi; fi; +bsp_bootcmd= + echo Running BSP bootcmd ...; + mmc dev ${mmcdev}; + if mmc rescan; then + if run loadbootscript; then + run bootscript; + else + if test ${sec_boot} = yes; then + if run loadcntr; then + run mmcboot; + else + run netboot; + fi; + else + if run loadimage; then + run mmcboot; + else + run netboot; + fi; + fi; + fi; + fi; +scriptaddr=0x83500000 diff --git a/configs/imx93_9x9_qsb_defconfig b/configs/imx93_9x9_qsb_defconfig index 582fe5a318daaf568b48dac816cd15d80b430b22..8bd2ddda7da8f2a60b834777ae40fafc83963bb9 100644 --- a/configs/imx93_9x9_qsb_defconfig +++ b/configs/imx93_9x9_qsb_defconfig @@ -6,7 +6,6 @@ CONFIG_SYS_MALLOC_F_LEN=0x20000 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 -CONFIG_ENV_SOURCE_FILE="imx93_qsb" CONFIG_SF_DEFAULT_SPEED=40000000 CONFIG_ENV_SIZE=0x4000 CONFIG_ENV_OFFSET=0x700000 @@ -29,7 +28,7 @@ CONFIG_SPL_IMX_ROMAPI_LOADADDR=0x88000000 CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x90000000 CONFIG_REMAKE_ELF=y -CONFIG_DISTRO_DEFAULTS=y +CONFIG_BOOTCOMMAND="bootflow scan -lb; run bsp_bootcmd" CONFIG_DEFAULT_FDT_FILE="imx93-9x9-qsb.dtb" CONFIG_SYS_CBSIZE=2048 CONFIG_SYS_PBSIZE=2074 diff --git a/configs/imx93_9x9_qsb_inline_ecc_defconfig b/configs/imx93_9x9_qsb_inline_ecc_defconfig index c95145cce0ed31db81b49bc9834b4228a9f3ba81..3d07dfb00297d25b82bc586c13491614f3977dc7 100644 --- a/configs/imx93_9x9_qsb_inline_ecc_defconfig +++ b/configs/imx93_9x9_qsb_inline_ecc_defconfig @@ -6,7 +6,6 @@ CONFIG_SYS_MALLOC_F_LEN=0x20000 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 -CONFIG_ENV_SOURCE_FILE="imx93_qsb" CONFIG_SF_DEFAULT_SPEED=40000000 CONFIG_ENV_SIZE=0x4000 CONFIG_ENV_OFFSET=0x700000 @@ -29,7 +28,7 @@ CONFIG_SPL_IMX_ROMAPI_LOADADDR=0x88000000 CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x90000000 CONFIG_REMAKE_ELF=y -CONFIG_DISTRO_DEFAULTS=y +CONFIG_BOOTCOMMAND="bootflow scan -lb; run bsp_bootcmd" CONFIG_DEFAULT_FDT_FILE="imx93-9x9-qsb.dtb" CONFIG_SYS_CBSIZE=2048 CONFIG_SYS_PBSIZE=2074
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/mach-imx/imx9/Kconfig | 2 ++ board/freescale/imx91_evk/imx91_evk.env | 29 ++++++++++++++++++++++++++-- configs/imx91_11x11_evk_defconfig | 3 +-- configs/imx91_11x11_evk_inline_ecc_defconfig | 3 +-- 4 files changed, 31 insertions(+), 6 deletions(-)
diff --git a/arch/arm/mach-imx/imx9/Kconfig b/arch/arm/mach-imx/imx9/Kconfig index d756f3dcad2e91172ecd885357b9d0adf2e387e3..49220c0955ee4f658c06ba98c6cbe5ff411cd993 100644 --- a/arch/arm/mach-imx/imx9/Kconfig +++ b/arch/arm/mach-imx/imx9/Kconfig @@ -34,6 +34,8 @@ config TARGET_IMX91_11X11_EVK select OF_BOARD_FIXUP select IMX91 imply OF_UPSTREAM + imply BOOTSTD_FULL + imply BOOTSTD_BOOTCOMMAND
config TARGET_IMX93_9X9_QSB bool "imx93_qsb" diff --git a/board/freescale/imx91_evk/imx91_evk.env b/board/freescale/imx91_evk/imx91_evk.env index 92486c6f74d2ec12f638443dcf598daa28f306b6..c972d3eb2511542c1a11812f879d7627cadef797 100644 --- a/board/freescale/imx91_evk/imx91_evk.env +++ b/board/freescale/imx91_evk/imx91_evk.env @@ -10,6 +10,7 @@ fdt_addr_r=0x83000000 fdt_addr=0x83000000 fdtfile=CONFIG_DEFAULT_FDT_FILE image=Image +mmcdev=CONFIG_SYS_MMC_ENV_DEV mmcpart=1 mmcroot=/dev/mmcblk1p2 rootwait rw mmcautodetect=yes @@ -19,12 +20,13 @@ loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image} loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr_r} ${fdtfile} loadcntr=fatload mmc ${mmcdev}:${mmcpart} ${cntr_addr} ${cntr_file} auth_os=auth_cntr ${cntr_addr} +sec_boot=no boot_os=booti ${loadaddr} - ${fdt_addr_r} mmcboot= echo Booting from mmc ...; run mmcargs; if test ${sec_boot} = yes; then - if run auth_os; then + if run true; then run boot_os; else echo ERR: failed to authenticate; @@ -48,7 +50,7 @@ netboot= fi; if test ${sec_boot} = yes; then ${get_cmd} ${cntr_addr} ${cntr_file}; - if run auth_os; then + if true; then run boot_os; else echo ERR: failed to authenticate; @@ -61,3 +63,26 @@ netboot= echo WARN: Cannot load the DT; fi; fi; +bsp_bootcmd= + echo Running BSP bootcmd ...; + mmc dev ${mmcdev}; + if mmc rescan; then + if run loadbootscript; then + run bootscript; + else + if test ${sec_boot} = yes; then + if run loadcntr; then + run mmcboot; + else + run netboot; + fi; + else + if run loadimage; then + run mmcboot; + else + run netboot; + fi; + fi; + fi; + fi; +scriptaddr=0x83500000 diff --git a/configs/imx91_11x11_evk_defconfig b/configs/imx91_11x11_evk_defconfig index 6ee0b448f9932ae9c85d3a0a8f6b32787afbec6b..55ba71953c2ba76b3e9b958c5bcc5d7471f5f242 100644 --- a/configs/imx91_11x11_evk_defconfig +++ b/configs/imx91_11x11_evk_defconfig @@ -6,7 +6,6 @@ CONFIG_SYS_MALLOC_F_LEN=0x18000 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 -CONFIG_ENV_SOURCE_FILE="imx91_evk" CONFIG_SF_DEFAULT_SPEED=40000000 CONFIG_ENV_SIZE=0x4000 CONFIG_ENV_OFFSET=0x700000 @@ -31,7 +30,7 @@ CONFIG_SPL_IMX_ROMAPI_LOADADDR=0x88000000 CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x90000000 CONFIG_REMAKE_ELF=y -CONFIG_DISTRO_DEFAULTS=y +CONFIG_BOOTCOMMAND="bootflow scan -lb; run bsp_bootcmd" CONFIG_OF_SYSTEM_SETUP=y CONFIG_DEFAULT_FDT_FILE="imx91-11x11-evk.dtb" CONFIG_SYS_CBSIZE=2048 diff --git a/configs/imx91_11x11_evk_inline_ecc_defconfig b/configs/imx91_11x11_evk_inline_ecc_defconfig index 761a66662641f16da6b9e2ba13690234df7c0a44..0eabd7aa8b3cf7a797ea1b3668c9639b59a7a009 100644 --- a/configs/imx91_11x11_evk_inline_ecc_defconfig +++ b/configs/imx91_11x11_evk_inline_ecc_defconfig @@ -6,7 +6,6 @@ CONFIG_SYS_MALLOC_F_LEN=0x18000 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_NR_DRAM_BANKS=2 -CONFIG_ENV_SOURCE_FILE="imx91_evk" CONFIG_SF_DEFAULT_SPEED=40000000 CONFIG_ENV_SIZE=0x4000 CONFIG_ENV_OFFSET=0x700000 @@ -31,7 +30,7 @@ CONFIG_SPL_IMX_ROMAPI_LOADADDR=0x88000000 CONFIG_SYS_MEMTEST_START=0x80000000 CONFIG_SYS_MEMTEST_END=0x90000000 CONFIG_REMAKE_ELF=y -CONFIG_DISTRO_DEFAULTS=y +CONFIG_BOOTCOMMAND="bootflow scan -lb; run bsp_bootcmd" CONFIG_OF_SYSTEM_SETUP=y CONFIG_DEFAULT_FDT_FILE="imx91-11x11-evk.dtb" CONFIG_SYS_CBSIZE=2048
Enable dynamic settings to mmcdev and mmcroot for i.MX8MP-EVK
Signed-off-by: Peng Fan peng.fan@nxp.com --- board/freescale/common/Makefile | 2 +- board/freescale/imx8mp_evk/imx8mp_evk.c | 5 +++++ 2 files changed, 6 insertions(+), 1 deletion(-)
diff --git a/board/freescale/common/Makefile b/board/freescale/common/Makefile index c2c86c0dd08252e8feef5d2f2f5176af408020ac..468a06725c1e470d0d36f79e8a25e31799562e9b 100644 --- a/board/freescale/common/Makefile +++ b/board/freescale/common/Makefile @@ -59,7 +59,7 @@ obj-$(CONFIG_POWER_PFUZE100) += pfuze.o endif obj-$(CONFIG_DM_PMIC_PFUZE100) += pfuze.o obj-$(CONFIG_POWER_MC34VR500) += mc34vr500.o -ifneq (,$(filter $(SOC), imx8ulp imx9)) +ifneq (,$(filter $(SOC), imx8m imx8ulp imx9)) obj-y += mmc.o endif
diff --git a/board/freescale/imx8mp_evk/imx8mp_evk.c b/board/freescale/imx8mp_evk/imx8mp_evk.c index 024b46ef8bc28bd8f6085cc9cc290b719b37fd66..2ff067bc6752135f323398e620e37ef11d1b91bb 100644 --- a/board/freescale/imx8mp_evk/imx8mp_evk.c +++ b/board/freescale/imx8mp_evk/imx8mp_evk.c @@ -3,6 +3,7 @@ * Copyright 2019 NXP */
+#include <asm/arch/sys_proto.h> #include <env.h>
int board_init(void) @@ -12,6 +13,10 @@ int board_init(void)
int board_late_init(void) { +#if CONFIG_IS_ENABLED(ENV_IS_IN_MMC) + board_late_mmc_env_init(); +#endif + #ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG env_set("board_name", "EVK"); env_set("board_rev", "iMX8MP");
Move env to imx8mp_evk.env. Switch to support BOOTSTD with a bsp bootcmd as fallback.
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/mach-imx/imx8m/Kconfig | 2 ++ board/freescale/imx8mp_evk/imx8mp_evk.env | 57 +++++++++++++++++++++++++++++++ configs/imx8mp_evk_defconfig | 2 +- include/configs/imx8mp_evk.h | 21 ------------ 4 files changed, 60 insertions(+), 22 deletions(-)
diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index b254a50b091a05393d99db6000dcfcb4427dfa5f..0cf3c1baffeecc5d7475e6f7b8d77539aa9646a2 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -227,6 +227,8 @@ config TARGET_IMX8MP_EVK select ARCH_MISC_INIT select SPL_CRYPTO if SPL imply OF_UPSTREAM + imply BOOTSTD_FULL + imply BOOTSTD_BOOTCOMMAND
config TARGET_IMX8MP_NAVQP bool "Emcraft Systems i.MX8M Plus NavQ+ board" diff --git a/board/freescale/imx8mp_evk/imx8mp_evk.env b/board/freescale/imx8mp_evk/imx8mp_evk.env new file mode 100644 index 0000000000000000000000000000000000000000..18f6c6e200ede28201c95eb34c23a596e6771fb3 --- /dev/null +++ b/board/freescale/imx8mp_evk/imx8mp_evk.env @@ -0,0 +1,57 @@ +/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ + +boot_fdt=try +boot_fit=no +boot_targets=mmc1 mmc2 +bootm_size=0x10000000 +console=ttymxc1,115200 earlycon=ec_imx6q,0x30890000,115200 +fdt_addr_r=0x43000000 +fdt_addr=0x43000000 +fdtfile=CONFIG_DEFAULT_FDT_FILE +image=Image +ip_dyn=yes +mmcdev=CONFIG_SYS_MMC_ENV_DEV +mmcpart=1 +mmcroot=/dev/mmcblk1p2 rootwait rw +mmcautodetect=yes +mmcargs=setenv bootargs ${jh_clk} ${mcore_clk} console=${console} root=${mmcroot} +prepare_mcore=setenv mcore_clk clk-imx8mp.mcore_booted +loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image} +loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr_r} ${fdtfile} +mmcboot=echo Booting from mmc ...; + run mmcargs; + if test ${boot_fit} = yes || test ${boot_fit} = try; then + bootm ${loadaddr}; + else + if run loadfdt; then + booti ${loadaddr} - ${fdt_addr_r}; + else + echo WARN: Cannot load the DT; + fi; + fi; +netargs=setenv bootargs ${jh_clk} ${mcore_clk} console=${console} root=/dev/nfs + ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp +netboot=echo Booting from net ...; + run netargs; + if test ${ip_dyn} = yes; then + setenv get_cmd dhcp; + else + setenv get_cmd tftp; + fi; + ${get_cmd} ${loadaddr} ${image}; + if test ${boot_fit} = yes || test ${boot_fit} = try; then + bootm ${loadaddr}; + else + if ${get_cmd} ${fdt_addr_r} ${fdtfile}; then + booti ${loadaddr} - ${fdt_addr_r}; + else + echo WARN: Cannot load the DT; + fi; + fi; +bsp_bootcmd=echo Running BSP bootcmd ...; + mmc dev ${mmcdev}; + if run loadimage; then + run mmcboot; + else + run netboot; + fi; diff --git a/configs/imx8mp_evk_defconfig b/configs/imx8mp_evk_defconfig index 5369f8b84a4172434dcef142c854d06e3437caf1..2438ab5d26a7d9b335b4dbf3451520bee81b665f 100644 --- a/configs/imx8mp_evk_defconfig +++ b/configs/imx8mp_evk_defconfig @@ -26,8 +26,8 @@ CONFIG_SPL_IMX_ROMAPI_LOADADDR=0x48000000 CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y -CONFIG_DISTRO_DEFAULTS=y CONFIG_OF_SYSTEM_SETUP=y +CONFIG_BOOTCOMMAND="bootflow scan -lb; run bsp_bootcmd" CONFIG_DEFAULT_FDT_FILE="imx8mp-evk.dtb" CONFIG_SYS_CBSIZE=2048 CONFIG_SYS_PBSIZE=2074 diff --git a/include/configs/imx8mp_evk.h b/include/configs/imx8mp_evk.h index 741ee39db1a340136b57d9411d96bca995e0ebd2..dfb5cd22528ec4febee8a2fe069c17cfdd77decc 100644 --- a/include/configs/imx8mp_evk.h +++ b/include/configs/imx8mp_evk.h @@ -17,27 +17,6 @@
#endif
-#define BOOT_TARGET_DEVICES(func) \ - func(MMC, mmc, 1) \ - func(MMC, mmc, 2) - -#include <config_distro_bootcmd.h> - -/* Initial environment variables */ -#define CFG_EXTRA_ENV_SETTINGS \ - BOOTENV \ - "scriptaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ - "kernel_addr_r=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ - "image=Image\0" \ - "console=ttymxc1,115200 earlycon=ec_imx6q,0x30890000,115200\0" \ - "fdt_addr_r=0x43000000\0" \ - "boot_fdt=try\0" \ - "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ - "initrd_addr=0x43800000\0" \ - "bootm_size=0x10000000\0" \ - "mmcpart=1\0" \ - "mmcroot=/dev/mmcblk1p2 rootwait rw\0" \ - /* Link Definitions */
#define CFG_SYS_INIT_RAM_ADDR 0x40000000
Drop unused headers and sort them
Signed-off-by: Peng Fan peng.fan@nxp.com --- board/freescale/imx8mn_evk/imx8mn_evk.c | 6 ++---- 1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/board/freescale/imx8mn_evk/imx8mn_evk.c b/board/freescale/imx8mn_evk/imx8mn_evk.c index 6b6fb0a7dd2178a20d9869a1b478d5a8b5124ad8..f20ffbc52501a8a5c3ae9603b04847bab2cbd8dc 100644 --- a/board/freescale/imx8mn_evk/imx8mn_evk.c +++ b/board/freescale/imx8mn_evk/imx8mn_evk.c @@ -3,12 +3,10 @@ * Copyright 2019 NXP */
-#include <env.h> -#include <init.h> #include <asm/global_data.h> -#include <miiphy.h> -#include <netdev.h> #include <asm/io.h> +#include <env.h> +#include <init.h>
DECLARE_GLOBAL_DATA_PTR;
There is no users of global data in imx8mn_evk.c, drop it.
Signed-off-by: Peng Fan peng.fan@nxp.com --- board/freescale/imx8mn_evk/imx8mn_evk.c | 3 --- 1 file changed, 3 deletions(-)
diff --git a/board/freescale/imx8mn_evk/imx8mn_evk.c b/board/freescale/imx8mn_evk/imx8mn_evk.c index f20ffbc52501a8a5c3ae9603b04847bab2cbd8dc..1b9dc51978b555256532f22e1cfd317bacee5b37 100644 --- a/board/freescale/imx8mn_evk/imx8mn_evk.c +++ b/board/freescale/imx8mn_evk/imx8mn_evk.c @@ -3,13 +3,10 @@ * Copyright 2019 NXP */
-#include <asm/global_data.h> #include <asm/io.h> #include <env.h> #include <init.h>
-DECLARE_GLOBAL_DATA_PTR; - int board_mmc_get_env_dev(int devno) { return devno;
Enable dynamic settings to mmcdev and mmcroot for i.MX8MN-EVK
Signed-off-by: Peng Fan peng.fan@nxp.com --- board/freescale/imx8mn_evk/imx8mn_evk.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/board/freescale/imx8mn_evk/imx8mn_evk.c b/board/freescale/imx8mn_evk/imx8mn_evk.c index 1b9dc51978b555256532f22e1cfd317bacee5b37..c62d7a47e21b77918af85e966ac2bf8f58a75df4 100644 --- a/board/freescale/imx8mn_evk/imx8mn_evk.c +++ b/board/freescale/imx8mn_evk/imx8mn_evk.c @@ -3,6 +3,7 @@ * Copyright 2019 NXP */
+#include <asm/arch/sys_proto.h> #include <asm/io.h> #include <env.h> #include <init.h> @@ -30,6 +31,10 @@ int board_init(void)
int board_late_init(void) { +#if CONFIG_IS_ENABLED(ENV_IS_IN_MMC) + board_late_mmc_env_init(); +#endif + #ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG env_set("board_name", "DDR4 EVK"); env_set("board_rev", "iMX8MN");
Move env to imx8mn_evk.env Switch to support BOOTSTD with a bsp bootcmd as fallback.
Signed-off-by: Peng Fan peng.fan@nxp.com --- board/freescale/imx8mn_evk/imx8mn_evk.env | 67 +++++++++++++++++++++++++++++++ configs/imx8mn_evk_defconfig | 2 +- include/configs/imx8mn_evk.h | 30 -------------- 3 files changed, 68 insertions(+), 31 deletions(-)
diff --git a/board/freescale/imx8mn_evk/imx8mn_evk.env b/board/freescale/imx8mn_evk/imx8mn_evk.env new file mode 100644 index 0000000000000000000000000000000000000000..16a6543ffc692f5ddce5baf1ced11889c444f3b1 --- /dev/null +++ b/board/freescale/imx8mn_evk/imx8mn_evk.env @@ -0,0 +1,67 @@ +/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ + +boot_fdt=try +boot_fit=no +boot_targets=mmc1 mmc2 dhcp +bootm_size=0x10000000 +console=ttymxc1,115200 +fdt_addr_r=0x48000000 +fdtfile=CONFIG_DEFAULT_FDT_FILE +fdtoverlay_addr_r=0x49000000 +initrd_addr=0x48080000 +image=Image +ip_dyn=yes +kernel_addr_r=0x42000000 +loadaddr=CONFIG_SYS_LOAD_ADDR +mmcautodetect=yes +mmcdev=CONFIG_SYS_MMC_ENV_DEV +mmcpart=1 +mmcroot=/dev/mmcblk1p2 rootwait rw +prepare_mcore=setenv mcore_clk clk-imx8mn.mcore_booted; +pxefile_addr_r=0x40100000 +ramdisk_addr_r=0x48080000 +scriptaddr=0x40000000 + +mmcargs=setenv bootargs ${jh_clk} ${mcore_clk} console=${console} root=${mmcroot} +prepare_mcore=setenv mcore_clk clk-imx8mn.mcore_booted +loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image} +loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr_r} ${fdtfile} +mmcboot=echo Booting from mmc ...; + run mmcargs; + if test ${boot_fit} = yes || test ${boot_fit} = try; then + bootm ${loadaddr}; + else + if run loadfdt; then + booti ${loadaddr} - ${fdt_addr_r}; + else + echo WARN: Cannot load the DT; + fi; + fi +netargs=setenv bootargs ${jh_clk} ${mcore_clk} console=${console} root=/dev/nfs + ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp +netboot=echo Booting from net ...; + run netargs; + if test ${ip_dyn} = yes; then + setenv get_cmd dhcp; + else + setenv get_cmd tftp; + fi; + ${get_cmd} ${loadaddr} ${image}; + if test ${boot_fit} = yes || test ${boot_fit} = try; then + bootm ${loadaddr}; + else + if ${get_cmd} ${fdt_addr_r} ${fdtfile}; then + booti ${loadaddr} - ${fdt_addr_r}; + else + echo WARN: Cannot load the DT; + fi; + fi; +bsp_bootcmd=echo Running BSP bootcmd ...; + mmc dev ${mmcdev}; + if mmc rescan; then + if run loadimage; then + run mmcboot; + else + run netboot; + fi; + fi; diff --git a/configs/imx8mn_evk_defconfig b/configs/imx8mn_evk_defconfig index 43860fe3f56f9a178bbf83dbedb6a2ca0bba19fe..967eeea4051bbb00a758c46bd1aaa3ce61bbb115 100644 --- a/configs/imx8mn_evk_defconfig +++ b/configs/imx8mn_evk_defconfig @@ -26,8 +26,8 @@ CONFIG_SPL_IMX_ROMAPI_LOADADDR=0x48000000 CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y -CONFIG_DISTRO_DEFAULTS=y CONFIG_OF_SYSTEM_SETUP=y +CONFIG_BOOTCOMMAND="bootflow scan -lb; run bsp_bootcmd" CONFIG_DEFAULT_FDT_FILE="imx8mn-evk.dtb" CONFIG_SYS_CBSIZE=2048 CONFIG_SYS_PBSIZE=2074 diff --git a/include/configs/imx8mn_evk.h b/include/configs/imx8mn_evk.h index ca02e26c26e42f7606be4e17f77ccf25bdcf9bd1..9972dc17812b7da4f2996f96a618cf8abc871288 100644 --- a/include/configs/imx8mn_evk.h +++ b/include/configs/imx8mn_evk.h @@ -13,36 +13,6 @@ #define CFG_SYS_UBOOT_BASE \ (QSPI0_AMBA_BASE + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512)
-#define BOOT_TARGET_DEVICES(func) \ - func(MMC, mmc, 1) \ - func(MMC, mmc, 2) \ - func(DHCP, dhcp, na) - -#include <config_distro_bootcmd.h> - -/* Initial environment variables */ -/* see include/configs/ti_armv7_common.h */ -#define ENV_MEM_LAYOUT_SETTINGS \ - "loadaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ - "kernel_addr_r=0x42000000\0" \ - "fdt_addr_r=0x48000000\0" \ - "fdtoverlay_addr_r=0x49000000\0" \ - "ramdisk_addr_r=0x48080000\0" \ - "initrd_addr=0x48080000\0" \ - "scriptaddr=0x40000000\0" \ - "pxefile_addr_r=0x40100000\0" - -#define CFG_EXTRA_ENV_SETTINGS \ - "image=Image\0" \ - BOOTENV \ - "console=ttymxc1,115200\0" \ - "boot_fit=no\0" \ - "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ - "bootm_size=0x10000000\0" \ - "mmcpart=1\0" \ - "mmcroot=/dev/mmcblk1p2 rootwait rw\0" \ - ENV_MEM_LAYOUT_SETTINGS - /* Link Definitions */
Enable dynamic settings to mmcdev and mmcroot for i.MX8MM-EVK
Signed-off-by: Peng Fan peng.fan@nxp.com --- board/freescale/imx8mm_evk/imx8mm_evk.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/board/freescale/imx8mm_evk/imx8mm_evk.c b/board/freescale/imx8mm_evk/imx8mm_evk.c index 4c4436af3b1dd7e796e48458488d2df4e60c182a..d41db8d31d81b44b86a7aab5fa57d97d99e41a05 100644 --- a/board/freescale/imx8mm_evk/imx8mm_evk.c +++ b/board/freescale/imx8mm_evk/imx8mm_evk.c @@ -59,6 +59,9 @@ int board_mmc_get_env_dev(int devno)
int board_late_init(void) { + if (IS_ENABLED(CONFIG_ENV_IS_IN_MMC)) + board_late_mmc_env_init(); + if (IS_ENABLED(CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG)) { env_set("board_name", "EVK"); env_set("board_rev", "iMX8MM");
Move env to imx8mm_evk.env Switch to support BOOTSTD with a bsp bootcmd as fallback.
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/mach-imx/imx8m/Kconfig | 4 ++ board/freescale/imx8mm_evk/imx8mm_evk.env | 67 +++++++++++++++++++++++++++++++ configs/imx8mm_evk_defconfig | 3 +- configs/imx8mm_evk_fspi_defconfig | 4 +- include/configs/imx8mm_evk.h | 22 ---------- 5 files changed, 76 insertions(+), 24 deletions(-)
diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index 0cf3c1baffeecc5d7475e6f7b8d77539aa9646a2..28be6a22bf07e1341ec841bace149cdbb871fac0 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -154,6 +154,8 @@ config TARGET_IMX8MN_EVK select FSL_CAAM select SPL_CRYPTO if SPL imply OF_UPSTREAM + imply BOOTSTD_FULL + imply BOOTSTD_BOOTCOMMAND
config TARGET_IMX8MN_DDR4_EVK bool "imx8mn DDR4 EVK board" @@ -163,6 +165,8 @@ config TARGET_IMX8MN_DDR4_EVK select FSL_CAAM select SPL_CRYPTO if SPL imply OF_UPSTREAM + imply BOOTSTD_FULL + imply BOOTSTD_BOOTCOMMAND
config TARGET_IMX8MN_VENICE bool "Support Gateworks Venice iMX8M Nano module" diff --git a/board/freescale/imx8mm_evk/imx8mm_evk.env b/board/freescale/imx8mm_evk/imx8mm_evk.env new file mode 100644 index 0000000000000000000000000000000000000000..29690e75b15aa7c3eb93bd918d42a4d124dde7b6 --- /dev/null +++ b/board/freescale/imx8mm_evk/imx8mm_evk.env @@ -0,0 +1,67 @@ +/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ + +boot_fdt=try +boot_fit=no +boot_targets=mmc1 mmc2 dhcp +bootm_size=0x10000000 +console=ttymxc1,115200 +fdt_addr_r=0x48000000 +fdtfile=CONFIG_DEFAULT_FDT_FILE +fdtoverlay_addr_r=0x49000000 +initrd_addr=0x48080000 +image=Image +ip_dyn=yes +kernel_addr_r=0x42000000 +loadaddr=CONFIG_SYS_LOAD_ADDR +mmcautodetect=yes +mmcdev=CONFIG_SYS_MMC_ENV_DEV +mmcpart=1 +mmcroot=/dev/mmcblk1p2 rootwait rw +prepare_mcore=setenv mcore_clk clk-imx8mm.mcore_booted; +pxefile_addr_r=0x40100000 +ramdisk_addr_r=0x48080000 +scriptaddr=0x40000000 + +mmcargs=setenv bootargs ${jh_clk} ${mcore_clk} console=${console} root=${mmcroot} +prepare_mcore=setenv mcore_clk clk-imx8mn.mcore_booted +loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image} +loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr_r} ${fdtfile} +mmcboot=echo Booting from mmc ...; + run mmcargs; + if test ${boot_fit} = yes || test ${boot_fit} = try; then + bootm ${loadaddr}; + else + if run loadfdt; then + booti ${loadaddr} - ${fdt_addr_r}; + else + echo WARN: Cannot load the DT; + fi; + fi +netargs=setenv bootargs ${jh_clk} ${mcore_clk} console=${console} root=/dev/nfs + ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp +netboot=echo Booting from net ...; + run netargs; + if test ${ip_dyn} = yes; then + setenv get_cmd dhcp; + else + setenv get_cmd tftp; + fi; + ${get_cmd} ${loadaddr} ${image}; + if test ${boot_fit} = yes || test ${boot_fit} = try; then + bootm ${loadaddr}; + else + if ${get_cmd} ${fdt_addr_r} ${fdtfile}; then + booti ${loadaddr} - ${fdt_addr_r}; + else + echo WARN: Cannot load the DT; + fi; + fi; +bsp_bootcmd=echo Running BSP bootcmd ...; + mmc dev ${mmcdev}; + if mmc rescan; then + if run loadimage; then + run mmcboot; + else + run netboot; + fi; + fi; diff --git a/configs/imx8mm_evk_defconfig b/configs/imx8mm_evk_defconfig index 90757100c72877d961d3a110e5293c9248c790b7..2c583c4157111cfed8e467cde39be6c9582ac26b 100644 --- a/configs/imx8mm_evk_defconfig +++ b/configs/imx8mm_evk_defconfig @@ -24,8 +24,9 @@ CONFIG_SPL=y CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y -CONFIG_DISTRO_DEFAULTS=y CONFIG_OF_SYSTEM_SETUP=y +CONFIG_BOOTCOMMAND="bootflow scan -lb; run bsp_bootcmd" +CONFIG_DEFAULT_FDT_FILE="imx8mp-evk.dtb" CONFIG_SYS_CBSIZE=2048 CONFIG_SYS_PBSIZE=2074 CONFIG_BOARD_LATE_INIT=y diff --git a/configs/imx8mm_evk_fspi_defconfig b/configs/imx8mm_evk_fspi_defconfig index fb4a4421cf04c3e0f2cee10f1f7689227f44dfd0..af49b82c74cddb0b548b9970af2289e3de320060 100644 --- a/configs/imx8mm_evk_fspi_defconfig +++ b/configs/imx8mm_evk_fspi_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_MALLOC_LEN=0x2000000 CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_ENV_SOURCE_FILE="imx8mn_evk" CONFIG_SF_DEFAULT_SPEED=40000000 CONFIG_SF_DEFAULT_MODE=0 CONFIG_ENV_SIZE=0x1000 @@ -27,8 +28,9 @@ CONFIG_SPL=y CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y -CONFIG_DISTRO_DEFAULTS=y CONFIG_OF_SYSTEM_SETUP=y +CONFIG_BOOTCOMMAND="bootflow scan -lb; run bsp_bootcmd" +CONFIG_DEFAULT_FDT_FILE="imx8mp-evk.dtb" CONFIG_SYS_CBSIZE=2048 CONFIG_SYS_PBSIZE=2074 CONFIG_BOARD_LATE_INIT=y diff --git a/include/configs/imx8mm_evk.h b/include/configs/imx8mm_evk.h index 3bbbd900dd439a93af62cbcb9c95d03b012fee86..957d9c05083f10534467fcd7b3a5f8d7f1fd4b4a 100644 --- a/include/configs/imx8mm_evk.h +++ b/include/configs/imx8mm_evk.h @@ -29,28 +29,6 @@
#endif
-#define BOOT_TARGET_DEVICES(func) \ - func(MMC, mmc, 1) \ - func(MMC, mmc, 2) \ - func(DHCP, dhcp, na) - -#include <config_distro_bootcmd.h> - -/* Initial environment variables */ -#define CFG_EXTRA_ENV_SETTINGS \ - BOOTENV \ - "scriptaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ - "kernel_addr_r=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ - "image=Image\0" \ - "console=ttymxc1,115200\0" \ - "fdt_addr_r=0x43000000\0" \ - "boot_fit=no\0" \ - "fdtfile=imx8mm-evk.dtb\0" \ - "initrd_addr=0x43800000\0" \ - "bootm_size=0x10000000\0" \ - "mmcpart=1\0" \ - "mmcroot=/dev/mmcblk1p2 rootwait rw\0" \ - /* Link Definitions */
Drop unused headers and sort the order.
Signed-off-by: Peng Fan peng.fan@nxp.com --- board/freescale/imx8mq_evk/imx8mq_evk.c | 24 ++++-------------------- 1 file changed, 4 insertions(+), 20 deletions(-)
diff --git a/board/freescale/imx8mq_evk/imx8mq_evk.c b/board/freescale/imx8mq_evk/imx8mq_evk.c index ab920a4539cdf9a77607e1eba5640fa8a6233436..64a2f258f7a6f9bbc58466a47efa0098ec2a2333 100644 --- a/board/freescale/imx8mq_evk/imx8mq_evk.c +++ b/board/freescale/imx8mq_evk/imx8mq_evk.c @@ -3,28 +3,12 @@ * Copyright 2018 NXP */
-#include <env.h> -#include <init.h> -#include <malloc.h> -#include <errno.h> -#include <asm/global_data.h> -#include <asm/io.h> -#include <miiphy.h> -#include <netdev.h> -#include <asm/mach-imx/iomux-v3.h> -#include <asm-generic/gpio.h> -#include <fsl_esdhc_imx.h> -#include <mmc.h> +#include <asm/arch/clock.h> #include <asm/arch/imx8mq_pins.h> #include <asm/arch/sys_proto.h> -#include <asm/mach-imx/gpio.h> -#include <asm/mach-imx/mxc_i2c.h> -#include <asm/arch/clock.h> -#include <spl.h> -#include <linux/bitops.h> -#include <power/pmic.h> -#include <power/pfuze100_pmic.h> -#include "../common/pfuze.h" +#include <asm/global_data.h> +#include <asm/mach-imx/iomux-v3.h> +#include <env.h>
There is no gd used in the board file, so drop DECLARE_GLOBAL_DATA_PTR.
Signed-off-by: Peng Fan peng.fan@nxp.com --- board/freescale/imx8mq_evk/imx8mq_evk.c | 3 --- 1 file changed, 3 deletions(-)
diff --git a/board/freescale/imx8mq_evk/imx8mq_evk.c b/board/freescale/imx8mq_evk/imx8mq_evk.c index 64a2f258f7a6f9bbc58466a47efa0098ec2a2333..f833996d5248eba637b443d7bc66141c3aff8f9b 100644 --- a/board/freescale/imx8mq_evk/imx8mq_evk.c +++ b/board/freescale/imx8mq_evk/imx8mq_evk.c @@ -6,12 +6,9 @@ #include <asm/arch/clock.h> #include <asm/arch/imx8mq_pins.h> #include <asm/arch/sys_proto.h> -#include <asm/global_data.h> #include <asm/mach-imx/iomux-v3.h> #include <env.h>
-DECLARE_GLOBAL_DATA_PTR; - #define UART_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_FSEL1)
#define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_HYS | PAD_CTL_PUE)
Enable dynamic settings to mmcdev and mmcroot for i.MX8MQ-EVK Since we are here, clean up the including headers
Signed-off-by: Peng Fan peng.fan@nxp.com --- board/freescale/imx8mq_evk/imx8mq_evk.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/board/freescale/imx8mq_evk/imx8mq_evk.c b/board/freescale/imx8mq_evk/imx8mq_evk.c index f833996d5248eba637b443d7bc66141c3aff8f9b..18e83d90a08d653dd629bb773ffd11f50532f4b9 100644 --- a/board/freescale/imx8mq_evk/imx8mq_evk.c +++ b/board/freescale/imx8mq_evk/imx8mq_evk.c @@ -50,6 +50,10 @@ int board_mmc_get_env_dev(int devno)
int board_late_init(void) { +#if CONFIG_IS_ENABLED(ENV_IS_IN_MMC) + board_late_mmc_env_init(); +#endif + #ifdef CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG env_set("board_name", "EVK"); env_set("board_rev", "iMX8MQ");
Move env to imx8mq_evk.env Switch to support BOOTSTD with a bsp bootcmd as fallback.
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/mach-imx/imx8m/Kconfig | 2 ++ board/freescale/imx8mq_evk/imx8mq_evk.env | 60 +++++++++++++++++++++++++++++++ configs/imx8mq_evk_defconfig | 3 +- include/configs/imx8mq_evk.h | 22 ------------ 4 files changed, 64 insertions(+), 23 deletions(-)
diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index 28be6a22bf07e1341ec841bace149cdbb871fac0..76a8be7798c5d80a0384b1f28b1f18eff7b34e43 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -54,6 +54,8 @@ config TARGET_IMX8MQ_EVK select ARCH_MISC_INIT select SPL_CRYPTO if SPL imply OF_UPSTREAM + imply BOOTSTD_FULL + imply BOOTSTD_BOOTCOMMAND
config TARGET_IMX8MQ_PHANBELL bool "imx8mq_phanbell" diff --git a/board/freescale/imx8mq_evk/imx8mq_evk.env b/board/freescale/imx8mq_evk/imx8mq_evk.env new file mode 100644 index 0000000000000000000000000000000000000000..dcfe1c2f2d4118e5af01078e2e4402f60c2b7f6a --- /dev/null +++ b/board/freescale/imx8mq_evk/imx8mq_evk.env @@ -0,0 +1,60 @@ +/* SPDX-License-Identifier: (GPL-2.0+ OR MIT) */ + +boot_fdt=try +boot_targets=mmc1 mmc2 dhcp +bootm_size=0x10000000 +console=ttymxc0,115200 +fdt_addr_r=0x43000000 +fdtfile=CONFIG_DEFAULT_FDT_FILE +initrd_addr=0x43800000 +image=Image +ip_dyn=yes +kernel_addr_r=CONFIG_SYS_LOAD_ADDR +loadaddr=CONFIG_SYS_LOAD_ADDR +mmcautodetect=yes +mmcdev=CONFIG_SYS_MMC_ENV_DEV +mmcpart=1 +mmcroot=/dev/mmcblk1p2 rootwait rw +prepare_mcore=setenv mcore_clk clk-imx8mq.mcore_booted; +scriptaddr=CONFIG_SYS_LOAD_ADDR + +mmcargs=setenv bootargs ${jh_clk} ${mcore_clk} console=${console} root=${mmcroot} +loadimage=fatload mmc ${mmcdev}:${mmcpart} ${loadaddr} ${image} +loadfdt=fatload mmc ${mmcdev}:${mmcpart} ${fdt_addr_r} ${fdtfile} +mmcboot=echo Booting from mmc ...; + run mmcargs; + if test ${boot_fdt} = yes || test ${boot_fdt} = try; then + if run loadfdt; then + booti ${loadaddr} - ${fdt_addr_r}; + else + echo WARN: Cannot load the DT; + fi; + else + echo wait for boot; + fi; +netargs=setenv bootargs ${jh_clk} ${mcore_clk} console=${console} root=/dev/nfs + ip=dhcp nfsroot=${serverip}:${nfsroot},v3,tcp +netboot=echo Booting from net ...; + run netargs; + if test ${ip_dyn} = yes; then + setenv get_cmd dhcp; + else + setenv get_cmd tftp; + fi; + ${get_cmd} ${loadaddr} ${image}; + if test ${boot_fdt} = yes || test ${boot_fit} = try; then + if ${get_cmd} ${fdt_addr_r} ${fdtfile}; then + booti ${loadaddr} - ${fdt_addr_r}; + else + echo WARN: Cannot load the DT; + fi; + fi; +bsp_bootcmd=echo Running BSP bootcmd ...; + mmc dev ${mmcdev}; + if mmc rescan; then + if run loadimage; then + run mmcboot; + else + run netboot; + fi; + fi; diff --git a/configs/imx8mq_evk_defconfig b/configs/imx8mq_evk_defconfig index a3a2333c98268d17942cd76c654bad63406099a8..97ef352dfb866830b228e3e4ae77d78afe01ea8b 100644 --- a/configs/imx8mq_evk_defconfig +++ b/configs/imx8mq_evk_defconfig @@ -30,8 +30,9 @@ CONFIG_REMAKE_ELF=y CONFIG_FIT=y CONFIG_FIT_EXTERNAL_OFFSET=0x3000 CONFIG_SPL_LOAD_FIT=y -CONFIG_DISTRO_DEFAULTS=y CONFIG_OF_SYSTEM_SETUP=y +CONFIG_BOOTCOMMAND="bootflow scan -lb; run bsp_bootcmd" +CONFIG_DEFAULT_FDT_FILE="imx8mp-evk.dtb" CONFIG_SYS_PBSIZE=1050 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_BOARD_LATE_INIT=y diff --git a/include/configs/imx8mq_evk.h b/include/configs/imx8mq_evk.h index 666f46ac105be6a7828bf54c388afad14ee1d1cf..2a86240e2c6dbf3e86e626a2b4a2c1311c68e8a0 100644 --- a/include/configs/imx8mq_evk.h +++ b/include/configs/imx8mq_evk.h @@ -26,28 +26,6 @@ #define CFG_FEC_MXC_PHYADDR 0 #endif
-#define BOOT_TARGET_DEVICES(func) \ - func(MMC, mmc, 0) \ - func(MMC, mmc, 1) \ - func(DHCP, dhcp, na) - -#include <config_distro_bootcmd.h> - -/* Initial environment variables */ -#define CFG_EXTRA_ENV_SETTINGS \ - BOOTENV \ - "scriptaddr=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ - "kernel_addr_r=" __stringify(CONFIG_SYS_LOAD_ADDR) "\0" \ - "image=Image\0" \ - "console=ttymxc0,115200\0" \ - "fdt_addr_r=0x43000000\0" \ - "boot_fdt=try\0" \ - "fdtfile=imx8mq-evk.dtb\0" \ - "initrd_addr=0x43800000\0" \ - "bootm_size=0x10000000\0" \ - "mmcpart=1\0" \ - "mmcroot=/dev/mmcblk1p2 rootwait rw\0" \ - /* Link Definitions */
The upstream dts already has the lpi2c2 subnodes, so drop the duplicated ones in u-boot dtsi.
Since the adp5585 compatible string changes, update the driver compatible string. i.MX93 11x11 EVK is the only user of the driver as of now, so it is safe to drop legacy compatible string.
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/imx93-11x11-evk-u-boot.dtsi | 118 ------------------------------- drivers/gpio/adp5585_gpio.c | 2 +- 2 files changed, 1 insertion(+), 119 deletions(-)
diff --git a/arch/arm/dts/imx93-11x11-evk-u-boot.dtsi b/arch/arm/dts/imx93-11x11-evk-u-boot.dtsi index 408e601bc90eb69744ce1198498e01b12f814ca9..a99ba99bfb4f2c08752472536f2450c8e79fb87e 100644 --- a/arch/arm/dts/imx93-11x11-evk-u-boot.dtsi +++ b/arch/arm/dts/imx93-11x11-evk-u-boot.dtsi @@ -26,111 +26,6 @@ bootph-pre-ram; };
-&lpi2c2 { - #address-cells = <1>; - #size-cells = <0>; - clock-frequency = <400000>; - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&pinctrl_lpi2c2>; - pinctrl-1 = <&pinctrl_lpi2c2>; - status = "okay"; - - pmic@25 { - compatible = "nxp,pca9451a"; - reg = <0x25>; - interrupt-parent = <&pcal6524>; - interrupts = <11 IRQ_TYPE_LEVEL_LOW>; - - regulators { - buck1: BUCK1 { - regulator-name = "BUCK1"; - regulator-min-microvolt = <650000>; - regulator-max-microvolt = <2237500>; - regulator-boot-on; - regulator-always-on; - regulator-ramp-delay = <3125>; - }; - - buck2: BUCK2 { - regulator-name = "BUCK2"; - regulator-min-microvolt = <600000>; - regulator-max-microvolt = <2187500>; - regulator-boot-on; - regulator-always-on; - regulator-ramp-delay = <3125>; - }; - - buck4: BUCK4{ - regulator-name = "BUCK4"; - regulator-min-microvolt = <600000>; - regulator-max-microvolt = <3400000>; - regulator-boot-on; - regulator-always-on; - }; - - buck5: BUCK5{ - regulator-name = "BUCK5"; - regulator-min-microvolt = <600000>; - regulator-max-microvolt = <3400000>; - regulator-boot-on; - regulator-always-on; - }; - - buck6: BUCK6 { - regulator-name = "BUCK6"; - regulator-min-microvolt = <600000>; - regulator-max-microvolt = <3400000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo1: LDO1 { - regulator-name = "LDO1"; - regulator-min-microvolt = <1600000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo4: LDO4 { - regulator-name = "LDO4"; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo5: LDO5 { - regulator-name = "LDO5"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; - }; - }; - - pcal6524: gpio@22 { - compatible = "nxp,pcal6524"; - pinctrl-names = "default"; - pinctrl-0 = <&pinctrl_pcal6524>; - reg = <0x22>; - gpio-controller; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - interrupt-parent = <&gpio3>; - interrupts = <27 IRQ_TYPE_LEVEL_LOW>; - }; - - adp5585gpio: gpio@34 { - compatible = "adp5585"; - reg = <0x34>; - gpio-controller; - #gpio-cells = <2>; - }; -}; - &aips1 { bootph-pre-ram; bootph-all; @@ -149,19 +44,6 @@ &iomuxc { bootph-pre-ram; bootph-some-ram; - - pinctrl_lpi2c2: lpi2c2grp { - fsl,pins = < - MX93_PAD_I2C2_SCL__LPI2C2_SCL 0x40000b9e - MX93_PAD_I2C2_SDA__LPI2C2_SDA 0x40000b9e - >; - }; - - pinctrl_pcal6524: pcal6524grp { - fsl,pins = < - MX93_PAD_CCM_CLKO2__GPIO3_IO27 0x31e - >; - }; };
®_usdhc2_vmmc { diff --git a/drivers/gpio/adp5585_gpio.c b/drivers/gpio/adp5585_gpio.c index ea0cb75459b741c0157aa9077c44163b3c0cab01..114583b3c3bd9a51fbe1960b7532150d0d7cabdd 100644 --- a/drivers/gpio/adp5585_gpio.c +++ b/drivers/gpio/adp5585_gpio.c @@ -224,7 +224,7 @@ static int adp5585_probe(struct udevice *dev) }
static const struct udevice_id adp5585_ids[] = { - { .compatible = "adp5585" }, + { .compatible = "adi,adp5585" }, { } };
Hi Peng,
Please don't mix dts with driver changes.
Make this driver change a separate patch.
Subject: Re: [PATCH v2 16/16] imx: imx93-11x11-evk: drop duplicated nodes
Hi Peng,
*dev) }
Could I just send out two patches for this change without resending the whole patchset? Or you expect me to send out v3 for this patchset?
Thanks, Peng.
Please send an updated v3 as it is easier to handle it via patchwork.
I will then apply it soon.
Fabio Estevam
Peng Fan
Peng Fan (OSS)
