[U-Boot-Users] U-boot Port issue on MPC8280 board
Dear all,
I am trying to port U-boot 1.1.2 onto a MPC8280 based Rattler board. After a long struggle I was able to map the board properly and I am able to get till display_options (where u-boot gets a reset in printf statement). I have the following questions:
1) Are there any patches to support CPM2 (Just like the one floating around for Linux) for U-boot? (Our board requires cpm2 support)
2) Whenever we try to access the serial routines (serial_putc, printf), we get a continous reset and we are unable to proceed.
I request you all to kindly help me with this problem. Any pointers would be of great help.
Thanks and Best Regards, C.R.Srivatsan
In message 000001c541a1$c815d020$1269cb0a@bgc.flextronics.com you wrote:
- Are there any patches to support CPM2 (Just like the one floating
No patch is needed, all support for the CPM you need is already available in U-Boot. ["cpm2" ist just a term for a specific Linux implementation. None of this is needed for U-Boot. U-Boot uses the "old" or "classic" approach to support the CPM.]
- Whenever we try to access the serial routines (serial_putc, printf),
Check your memory map, and if your board config file correctly implements this memory map. Then attach a debugger and check why the accesses are failing.
Hi all,
I am trying to port U-boot onto MPC8280 based Rattler board. I am getting the following messages and U-boot resets. Can anyone please give me some pointers to the problem? Thanks.
U-Boot 1.1.2 (Apr 20 2005 - 17:26:27)
MPC8260 Reset Status: External Soft, External Hard
MPC8260 Clock Configuration - Bus-to-Core Mult 4.5x, VCO Div 2, 60x Bus Freq 22-65 , Core Freq 100-300 - dfbrg 1, corecnf 0x07, busdf 5, cpmdf 1, plldf 0, pllmf 7 - vco_out 800000000, scc_clk 200000000, brg_clk 50000000 - cpu_clk 450000000, cpm_clk 400000000, bus_clk 100000000
CPU: MPC8260 (HiP7 Rev 13, Mask 0.1 1K49M) at 450 MHz DRAM: 16 MÀ
With Thanks and Regards, C.R.Srivatsan
***************************NOTE*********************************************** Deccanet Designs Ltd is now Flextronics Design Ltd, India ******************************************************************************
*************************DISCLAIMER******************************************* This e-mail and any attachment is for authorised use by the intended recipient(s) only. It may contain proprietary material, confidential information and/or be subject to legal privilege of Flextronics Design Ltd. If you have received this message in error, please notify the originator immediately. If you are not the intended recipient, you are notified that you are strictly prohibited from retaining, using, copying, altering or disclosing the contents of this message. ******************************************************************************
Your SDRAM initialization sequence is broken and/or incomplete.
... [legal crap deleted]
Will you please turn off this when posting to public mailing lists?
Hi all,
The porting of U-boot 1.1.2 onto the Rattler MPC8280 board is done but for the following problem:
When I try to ping from Target (Rattler MPC8280), it says the host (PC running TFTP server) is alive. But when the target (MPc8280) is pinged from host, then it says "request timed out".
I am using the ETHERNET_ON_FCC. Hope somebody can help me out of this problem.
With Regards, C.R.Srivatsan
This is ok.
There is no problem. This is the expected behaviour.
Srivatsan
