[U-Boot] [PATCH v2] pci: Allow for PCI addresses to be 64-bit
PCI bus is inherently 64-bit. While not all system require access to the full 64-bit PCI address range some do. This allows those systems to enable the full PCI address width via CONFIG_SYS_PCI_64BIT.
Signed-off-by: Kumar Gala galak@kernel.crashing.org ---
moved to CONFIG_SYS_PCI_64BIT instead of CONFIG_PCI_64BIT
- k
drivers/pci/pci.c | 4 ++-- drivers/pci/pci_auto.c | 22 +++++++++++----------- include/pci.h | 24 ++++++++++++++++-------- 3 files changed, 29 insertions(+), 21 deletions(-)
diff --git a/drivers/pci/pci.c b/drivers/pci/pci.c index 41780db..127d50f 100644 --- a/drivers/pci/pci.c +++ b/drivers/pci/pci.c @@ -223,7 +223,7 @@ unsigned long pci_hose_phys_to_bus (struct pci_controller *hose, unsigned long flags) { struct pci_region *res; - unsigned long bus_addr; + pci_addr_t bus_addr; int i;
if (!hose) { @@ -252,7 +252,7 @@ Done: }
phys_addr_t pci_hose_bus_to_phys(struct pci_controller* hose, - unsigned long bus_addr, + pci_addr_t bus_addr, unsigned long flags) { struct pci_region *res; diff --git a/drivers/pci/pci_auto.c b/drivers/pci/pci_auto.c index 3844359..547ce5b 100644 --- a/drivers/pci/pci_auto.c +++ b/drivers/pci/pci_auto.c @@ -52,7 +52,7 @@ void pciauto_region_align(struct pci_region *res, unsigned long size)
int pciauto_region_allocate(struct pci_region* res, unsigned int size, unsigned int *bar) { - unsigned long addr; + pci_addr_t addr;
if (!res) { DEBUGF("No resource"); @@ -68,7 +68,7 @@ int pciauto_region_allocate(struct pci_region* res, unsigned int size, unsigned
res->bus_lower = addr + size;
- DEBUGF("address=0x%lx bus_lower=%x", addr, res->bus_lower); + DEBUGF("address=0x%llx bus_lower=%llx", (u64)addr, (u64)res->bus_lower);
*bar = addr; return 0; @@ -289,10 +289,10 @@ void pciauto_config_init(struct pci_controller *hose) if (hose->pci_mem) { pciauto_region_init(hose->pci_mem);
- DEBUGF("PCI Autoconfig: Bus Memory region: [%lx-%lx],\n" + DEBUGF("PCI Autoconfig: Bus Memory region: [%llx-%llx],\n" "\t\tPhysical Memory [%x-%x]\n", - hose->pci_mem->bus_start, - hose->pci_mem->bus_start + hose->pci_mem->size - 1, + (u64)hose->pci_mem->bus_start, + (u64)(hose->pci_mem->bus_start + hose->pci_mem->size - 1), hose->pci_mem->phys_start, hose->pci_mem->phys_start + hose->pci_mem->size - 1); } @@ -300,10 +300,10 @@ void pciauto_config_init(struct pci_controller *hose) if (hose->pci_prefetch) { pciauto_region_init(hose->pci_prefetch);
- DEBUGF("PCI Autoconfig: Bus Prefetchable Mem: [%lx-%lx],\n" + DEBUGF("PCI Autoconfig: Bus Prefetchable Mem: [%llx-%llx],\n" "\t\tPhysical Memory [%x-%x]\n", - hose->pci_prefetch->bus_start, - hose->pci_prefetch->bus_start + hose->pci_prefetch->size - 1, + (u64)hose->pci_prefetch->bus_start, + (u64)(hose->pci_prefetch->bus_start + hose->pci_prefetch->size - 1), hose->pci_prefetch->phys_start, hose->pci_prefetch->phys_start + hose->pci_prefetch->size - 1); @@ -312,10 +312,10 @@ void pciauto_config_init(struct pci_controller *hose) if (hose->pci_io) { pciauto_region_init(hose->pci_io);
- DEBUGF("PCI Autoconfig: Bus I/O region: [%lx-%lx],\n" + DEBUGF("PCI Autoconfig: Bus I/O region: [%llx-%llx],\n" "\t\tPhysical Memory: [%x-%x]\n", - hose->pci_io->bus_start, - hose->pci_io->bus_start + hose->pci_io->size - 1, + (u64)hose->pci_io->bus_start, + (u64)(hose->pci_io->bus_start + hose->pci_io->size - 1), hose->pci_io->phys_start, hose->pci_io->phys_start + hose->pci_io->size - 1);
diff --git a/include/pci.h b/include/pci.h index 1c8e216..d79f26a 100644 --- a/include/pci.h +++ b/include/pci.h @@ -312,13 +312,21 @@
#include <pci_ids.h>
+#ifdef CONFIG_SYS_PCI_64BIT +typedef u64 pci_addr_t; +typedef u64 pci_size_t; +#else +typedef u32 pci_addr_t; +typedef u32 pci_size_t; +#endif + struct pci_region { - unsigned long bus_start; /* Start on the bus */ - phys_addr_t phys_start; /* Start in physical address space */ - unsigned long size; /* Size */ - unsigned long flags; /* Resource flags */ + pci_addr_t bus_start; /* Start on the bus */ + phys_addr_t phys_start; /* Start in physical address space */ + pci_size_t size; /* Size */ + unsigned long flags; /* Resource flags */
- unsigned long bus_lower; + pci_addr_t bus_lower; };
#define PCI_REGION_MEM 0x00000000 /* PCI memory space */ @@ -330,9 +338,9 @@ struct pci_region { #define PCI_REGION_RO 0x00000200 /* Read-only memory */
extern __inline__ void pci_set_region(struct pci_region *reg, - unsigned long bus_start, + pci_addr_t bus_start, phys_addr_t phys_start, - unsigned long size, + pci_size_t size, unsigned long flags) { reg->bus_start = bus_start; reg->phys_start = phys_start; @@ -433,7 +441,7 @@ extern __inline__ void pci_set_ops(struct pci_controller *hose, extern void pci_setup_indirect(struct pci_controller* hose, u32 cfg_addr, u32 cfg_data);
extern phys_addr_t pci_hose_bus_to_phys(struct pci_controller* hose, - unsigned long addr, unsigned long flags); + pci_addr_t addr, unsigned long flags); extern unsigned long pci_hose_phys_to_bus(struct pci_controller* hose, phys_addr_t addr, unsigned long flags);
I suspect this isn't complete, but I have no proof :) As an example, what are the mem and io args to pci_hose_config_device? Is unsigned long still OK there? (it may well be - I haven't looked at how they're used....).
A few comments below.
- k
if (!hose) {
Is there a reason pci_hose_phys_to_bus() isn't now returning a pci_addr_t?
Is this size really OK as an unsigned int? There are a lot of "unsigned int size" declarations in this file; I haven't looked at them all.
----- snip ------
struct pci_region {
- pci_addr_t bus_start; /* Start on the bus */
- pci_size_t size; /* Size */
- pci_addr_t bus_lower;
unsigned long size,
reg->bus_start = bus_start; reg->phys_start = phys_start;pci_size_t size, unsigned long flags) {
Should this return pci_addr_t?
Cheers, Becky
Becky Bruce
Kumar Gala
