[U-Boot] [PATCH v2 4/6] cmd_ide: Eliminate build warnings in atapi_inquiry()
Eliminate the following build warning in atapi_inquiry(): "warning: assignment from incompatible pointer type [enabled by default]"
Signed-off-by: Bin Meng bmeng.cn@gmail.com
Changes in v2: - Correct the typo of 'Eliminate' in the commit message
common/cmd_ide.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/common/cmd_ide.c b/common/cmd_ide.c index 04a6d9b..ecd3e9d 100644 --- a/common/cmd_ide.c +++ b/common/cmd_ide.c @@ -79,7 +79,7 @@ static void ident_cpy (unsigned char *dest, unsigned char *src, unsigned int len
#ifdef CONFIG_ATAPI static void atapi_inquiry(block_dev_desc_t *dev_desc); -static ulong atapi_read(int device, ulong blknr, lbaint_t blkcnt, +static ulong atapi_read(int device, lbaint_t blknr, lbaint_t blkcnt, void *buffer); #endif
@@ -1388,13 +1388,13 @@ static void atapi_inquiry(block_dev_desc_t *dev_desc) #define ATAPI_READ_BLOCK_SIZE 2048 /* assuming CD part */ #define ATAPI_READ_MAX_BLOCK (ATAPI_READ_MAX_BYTES/ATAPI_READ_BLOCK_SIZE)
-ulong atapi_read(int device, ulong blknr, lbaint_t blkcnt, void *buffer) +ulong atapi_read(int device, lbaint_t blknr, lbaint_t blkcnt, void *buffer) { ulong n = 0; unsigned char ccb[12]; /* Command descriptor block */ ulong cnt;
- debug("atapi_read dev %d start %lX, blocks " LBAF " buffer at %lX\n", + debug("atapi_read dev %d start " LBAF " blocks " LBAF " buffer at %lX\n", device, blknr, blkcnt, (ulong) buffer);
do {
Changes in v2:
debug("atapi_read dev %d start " LBAF " blocks " LBAF " buffer at %lX\n", device, blknr, blkcnt, (ulong) buffer); do {
-- 1.8.2.1
Changes in v2:
-- 1.8.2.1
Applied to u-boot-x86, thanks!
Bin Meng
