Re: [U-Boot] [PATCH V2 3/4] MX51: Add video support
Hello, Stefano,
It looks that your framebuffer patch supports one framebuffer only on IPU DI0. Could you please consider to add the support for framebuffer on IPU DI1, as someone may design a board whose primary display device is connected with IPU DI1.
And, it will be better if the following two points can be supported: 1) Two framebuffers on IPU DI0 and DI1 can be support at the same time, that is to say, users may see two pictures on two display devices respectively. 2) IPU DP module supports to combine two layers. The overlay layer can have a smaller resolution than the bottom layer. And, color space conversion, color key, global alpha and local alpha are supported by DP, too. I 'm not sure if these features are really needed in u-boot or not.
Best Regards, Liu Ying
From: Stefano Babic sbabic@denx.de Date: 2010/10/12 To: u-boot@lists.denx.de
Add framebuffer driver for the MX51 processor working on the IPUv3 internal graphic processor.
Signed-off-by: Stefano Babic sbabic@denx.de
drivers/video/Makefile | 1 + drivers/video/mxc_ipuv3_fb.c | 661 ++++++++++++++++++++++++++++++++++++++++++ drivers/video/mxcfb.h | 78 +++++ 3 files changed, 740 insertions(+), 0 deletions(-) create mode 100644 drivers/video/mxc_ipuv3_fb.c create mode 100644 drivers/video/mxcfb.h
diff --git a/drivers/video/Makefile b/drivers/video/Makefile index 4be82e7..5b7b261 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -34,6 +34,7 @@ COBJS-$(CONFIG_VIDEO_CT69000) += ct69000.o videomodes.o COBJS-$(CONFIG_VIDEO_MB862xx) += mb862xx.o videomodes.o COBJS-$(CONFIG_VIDEO_MB86R0xGDC) += mb86r0xgdc.o videomodes.o COBJS-$(CONFIG_VIDEO_MX3) += mx3fb.o +COBJS-$(CONFIG_VIDEO_MX5) += mxc_ipuv3_fb.o ipu_common.o ipu_disp.o COBJS-$(CONFIG_VIDEO_SED13806) += sed13806.o COBJS-$(CONFIG_SED156X) += sed156x.o COBJS-$(CONFIG_VIDEO_SM501) += sm501.o diff --git a/drivers/video/mxc_ipuv3_fb.c b/drivers/video/mxc_ipuv3_fb.c new file mode 100644 index 0000000..7a905c5 --- /dev/null +++ b/drivers/video/mxc_ipuv3_fb.c @@ -0,0 +1,661 @@ +/*
- Porting to u-boot:
- (C) Copyright 2010
- Stefano Babic, DENX Software Engineering, sbabic@denx.de
- MX51 Linux framebuffer:
- (C) Copyright 2004-2010 Freescale Semiconductor, Inc.
- project.
- MA 02111-1307 USA
+/* #define DEBUG */ +#include <common.h> +#include <asm/errno.h> +#include <linux/string.h> +#include <linux/list.h> +#include <linux/fb.h> +#include <asm/io.h> +#include <malloc.h> +#include <lcd.h> +#include "videomodes.h" +#include "ipu.h" +#include "mxcfb.h"
+DECLARE_GLOBAL_DATA_PTR;
+void *lcd_base; /* Start of framebuffer memory */ +void *lcd_console_address; /* Start of console buffer */
+int lcd_line_length; +int lcd_color_fg; +int lcd_color_bg;
+short console_col; +short console_row;
+vidinfo_t panel_info;
+static int mxcfb_map_video_memory(struct fb_info *fbi); +static int mxcfb_unmap_video_memory(struct fb_info *fbi);
+void lcd_initcolregs(void) +{ +}
+void lcd_setcolreg(ushort regno, ushort red, ushort green, ushort blue) +{ +}
+void lcd_disable(void) +{ +}
+void lcd_panel_disable(void) +{ +}
+void fb_videomode_to_var(struct fb_var_screeninfo *var,
- const struct fb_videomode *mode)
- var->xres = mode->xres;
- var->yres = mode->yres;
- var->xres_virtual = mode->xres;
- var->yres_virtual = mode->yres;
- var->xoffset = 0;
- var->yoffset = 0;
- var->pixclock = mode->pixclock;
- var->left_margin = mode->left_margin;
- var->right_margin = mode->right_margin;
- var->upper_margin = mode->upper_margin;
- var->lower_margin = mode->lower_margin;
- var->hsync_len = mode->hsync_len;
- var->vsync_len = mode->vsync_len;
- var->sync = mode->sync;
- var->vmode = mode->vmode & FB_VMODE_MASK;
- Structure containing the MXC specific framebuffer information.
+struct mxcfb_info {
- int blank;
- ipu_channel_t ipu_ch;
- int ipu_di;
- u32 ipu_di_pix_fmt;
- bool overlay;
- bool alpha_chan_en;
- dma_addr_t alpha_phy_addr0;
- dma_addr_t alpha_phy_addr1;
- void *alpha_virt_addr0;
- void *alpha_virt_addr1;
- uint32_t alpha_mem_len;
- uint32_t cur_ipu_buf;
- uint32_t cur_ipu_alpha_buf;
- u32 pseudo_palette[16];
+enum {
- BOTH_ON,
- SRC_ON,
- TGT_ON,
- BOTH_OFF
+static unsigned long default_bpp = 16; +static bool g_dp_in_use; +static struct fb_info *mxcfb_info[3]; +static int ext_clk_used;
+static uint32_t bpp_to_pixfmt(struct fb_info *fbi) +{
- uint32_t pixfmt = 0;
- debug("bpp_to_pixfmt: %d\n", fbi->var.bits_per_pixel);
- if (fbi->var.nonstd)
- return fbi->var.nonstd;
- switch (fbi->var.bits_per_pixel) {
- case 24:
- pixfmt = IPU_PIX_FMT_BGR24;
- break;
- case 32:
- pixfmt = IPU_PIX_FMT_BGR32;
- break;
- case 16:
- pixfmt = IPU_PIX_FMT_RGB565;
- break;
- return pixfmt;
- Set fixed framebuffer parameters based on variable settings.
- @param info framebuffer information pointer
+static int mxcfb_set_fix(struct fb_info *info) +{
- struct fb_fix_screeninfo *fix = &info->fix;
- struct fb_var_screeninfo *var = &info->var;
- fix->line_length = var->xres_virtual * var->bits_per_pixel / 8;
- fix->type = FB_TYPE_PACKED_PIXELS;
- fix->accel = FB_ACCEL_NONE;
- fix->visual = FB_VISUAL_TRUECOLOR;
- fix->xpanstep = 1;
- fix->ypanstep = 1;
+static int setup_disp_channel1(struct fb_info *fbi) +{
- ipu_channel_params_t params;
- struct mxcfb_info *mxc_fbi = (struct mxcfb_info *)fbi->par;
- memset(¶ms, 0, sizeof(params));
- params.mem_dp_bg_sync.di = mxc_fbi->ipu_di;
- debug("%s called\n", __func__);
- * Assuming interlaced means yuv output, below setting also
- * valid for mem_dc_sync. FG should have the same vmode as BG.
- if (fbi->var.vmode & FB_VMODE_INTERLACED) {
- params.mem_dp_bg_sync.interlaced = true;
- params.mem_dp_bg_sync.out_pixel_fmt =
- IPU_PIX_FMT_YUV444;
- } else {
- if (mxc_fbi->ipu_di_pix_fmt)
- mxc_fbi->ipu_di_pix_fmt;
- else
- IPU_PIX_FMT_RGB666;
- params.mem_dp_bg_sync.in_pixel_fmt = bpp_to_pixfmt(fbi);
- if (mxc_fbi->alpha_chan_en)
- params.mem_dp_bg_sync.alpha_chan_en = true;
- ipu_init_channel(mxc_fbi->ipu_ch, ¶ms);
+static int setup_disp_channel2(struct fb_info *fbi) +{
- int retval = 0;
- mxc_fbi->cur_ipu_buf = 1;
- if (mxc_fbi->alpha_chan_en) {
- mxc_fbi->cur_ipu_alpha_buf = 1;
- fbi->var.xoffset = fbi->var.yoffset = 0;
- debug("%s: %x %d %d %d %lx %lx\n",
- __func__,
- mxc_fbi->ipu_ch,
- fbi->var.xres,
- fbi->var.yres,
- fbi->fix.line_length,
- fbi->fix.smem_start,
- fbi->fix.smem_start +
- (fbi->fix.line_length * fbi->var.yres));
- retval = ipu_init_channel_buffer(mxc_fbi->ipu_ch, IPU_INPUT_BUFFER,
- bpp_to_pixfmt(fbi),
- fbi->var.xres, fbi->var.yres,
- (fbi->fix.line_length * fbi->var.yres),
- 0, 0);
- if (retval) {
- printf("ipu_init_channel_buffer error %d\n", retval);
- return retval;
- Set framebuffer parameters and change the operating mode.
+static int mxcfb_set_par(struct fb_info *fbi) +{
- int retval = 0;
- u32 mem_len;
- ipu_di_signal_cfg_t sig_cfg;
- uint32_t out_pixel_fmt;
- ipu_disable_channel(mxc_fbi->ipu_ch);
- ipu_uninit_channel(mxc_fbi->ipu_ch);
- mxcfb_set_fix(fbi);
- mem_len = fbi->var.yres_virtual * fbi->fix.line_length;
- if (!fbi->fix.smem_start || (mem_len > fbi->fix.smem_len)) {
- if (fbi->fix.smem_start)
- mxcfb_unmap_video_memory(fbi);
- if (mxcfb_map_video_memory(fbi) < 0)
- return -ENOMEM;
- setup_disp_channel1(fbi);
- memset(&sig_cfg, 0, sizeof(sig_cfg));
- sig_cfg.interlaced = true;
- out_pixel_fmt = IPU_PIX_FMT_YUV444;
- } else {
- out_pixel_fmt = mxc_fbi->ipu_di_pix_fmt;
- else
- out_pixel_fmt = IPU_PIX_FMT_RGB666;
- if (fbi->var.vmode & FB_VMODE_ODD_FLD_FIRST) /* PAL */
- sig_cfg.odd_field_first = true;
- if ((fbi->var.sync & FB_SYNC_EXT) || ext_clk_used)
- sig_cfg.ext_clk = true;
- if (fbi->var.sync & FB_SYNC_HOR_HIGH_ACT)
- sig_cfg.Hsync_pol = true;
- if (fbi->var.sync & FB_SYNC_VERT_HIGH_ACT)
- sig_cfg.Vsync_pol = true;
- if (!(fbi->var.sync & FB_SYNC_CLK_LAT_FALL))
- sig_cfg.clk_pol = true;
- if (fbi->var.sync & FB_SYNC_DATA_INVERT)
- sig_cfg.data_pol = true;
- if (!(fbi->var.sync & FB_SYNC_OE_LOW_ACT))
- sig_cfg.enable_pol = true;
- if (fbi->var.sync & FB_SYNC_CLK_IDLE_EN)
- sig_cfg.clkidle_en = true;
- debug("pixclock = %ul Hz\n",
- (u32) (PICOS2KHZ(fbi->var.pixclock) * 1000UL));
- if (ipu_init_sync_panel(mxc_fbi->ipu_di,
- (PICOS2KHZ(fbi->var.pixclock)) * 1000UL,
- out_pixel_fmt,
- fbi->var.left_margin,
- fbi->var.hsync_len,
- fbi->var.right_margin,
- fbi->var.upper_margin,
- fbi->var.vsync_len,
- fbi->var.lower_margin,
- 0, sig_cfg) != 0) {
- puts("mxcfb: Error initializing panel.\n");
- return -EINVAL;
- retval = setup_disp_channel2(fbi);
- if (retval)
- return retval;
- if (mxc_fbi->blank == FB_BLANK_UNBLANK) {
- ipu_enable_channel(mxc_fbi->ipu_ch);
- return retval;
- Check framebuffer variable parameters and adjust to valid values.
- @param var framebuffer variable parameters
+static int mxcfb_check_var(struct fb_var_screeninfo *var, struct fb_info *info) +{
- u32 vtotal;
- u32 htotal;
- if (var->xres_virtual < var->xres)
- var->xres_virtual = var->xres;
- if (var->yres_virtual < var->yres)
- var->yres_virtual = var->yres;
- if ((var->bits_per_pixel != 32) && (var->bits_per_pixel != 24) &&
- (var->bits_per_pixel != 16) && (var->bits_per_pixel != 8))
- var->bits_per_pixel = default_bpp;
- switch (var->bits_per_pixel) {
- case 8:
- var->red.length = 3;
- var->red.offset = 5;
- var->red.msb_right = 0;
- var->green.length = 3;
- var->green.offset = 2;
- var->green.msb_right = 0;
- var->blue.length = 2;
- var->blue.offset = 0;
- var->blue.msb_right = 0;
- var->transp.length = 0;
- var->transp.offset = 0;
- var->transp.msb_right = 0;
- break;
- case 16:
- var->red.length = 5;
- var->red.offset = 11;
- var->green.length = 6;
- var->green.offset = 5;
- var->blue.length = 5;
- break;
- case 24:
- var->red.length = 8;
- var->red.offset = 16;
- var->green.length = 8;
- var->green.offset = 8;
- var->blue.length = 8;
- break;
- case 32:
- var->transp.length = 8;
- var->transp.offset = 24;
- break;
- if (var->pixclock < 1000) {
- htotal = var->xres + var->right_margin + var->hsync_len +
- var->left_margin;
- vtotal = var->yres + var->lower_margin + var->vsync_len +
- var->upper_margin;
- var->pixclock = (vtotal * htotal * 6UL) / 100UL;
- var->pixclock = KHZ2PICOS(var->pixclock);
- printf("pixclock set for 60Hz refresh = %u ps\n",
- var->pixclock);
- var->height = -1;
- var->width = -1;
- var->grayscale = 0;
- Allocates the DRAM memory for the frame buffer. This buffer is remapped
- into a non-cached, non-buffered, memory region to allow palette and pixel
- writes to occur without flushing the cache. Once this area is remapped,
- all virtual memory access to the video memory should occur at the new region.
- @param fbi framebuffer information pointer
- @return Error code indicating success or failure
+static int mxcfb_map_video_memory(struct fb_info *fbi) +{
- if (fbi->fix.smem_len < fbi->var.yres_virtual * fbi->fix.line_length)
- fbi->fix.smem_len = fbi->var.yres_virtual *
- fbi->fix.line_length;
- fbi->screen_base = (char *)lcd_base;
- fbi->fix.smem_start = (unsigned long)lcd_base;
- if (fbi->screen_base == 0) {
- puts("Unable to allocate framebuffer memory\n");
- fbi->fix.smem_len = 0;
- fbi->fix.smem_start = 0;
- return -EBUSY;
- debug("allocated fb @ paddr=0x%08X, size=%d.\n",
- (uint32_t) fbi->fix.smem_start, fbi->fix.smem_len);
- fbi->screen_size = fbi->fix.smem_len;
- /* Clear the screen */
- memset((char *)fbi->screen_base, 0, fbi->fix.smem_len);
- De-allocates the DRAM memory for the frame buffer.
+static int mxcfb_unmap_video_memory(struct fb_info *fbi) +{
- fbi->screen_base = 0;
- Initializes the framebuffer information pointer. After allocating
- sufficient memory for the framebuffer structure, the fields are
- filled with custom information passed in from the configurable
- structures. This includes information such as bits per pixel,
- color maps, screen width/height and RGBA offsets.
- @return Framebuffer structure initialized with our information
+static struct fb_info *mxcfb_init_fbinfo(void) +{ +#define BYTES_PER_LONG 4 +#define PADDING (BYTES_PER_LONG - (sizeof(struct fb_info) % BYTES_PER_LONG))
- struct fb_info *fbi;
- struct mxcfb_info *mxcfbi;
- char *p;
- int size = sizeof(struct mxcfb_info) + PADDING +
- sizeof(struct fb_info);
- debug("%s: %d %d %d %d\n",
- __func__,
- PADDING,
- size,
- sizeof(struct mxcfb_info),
- sizeof(struct fb_info));
- * Allocate sufficient memory for the fb structure
- p = malloc(size);
- if (!p)
- return NULL;
- memset(p, 0, size);
- fbi = (struct fb_info *)p;
- fbi->par = p + sizeof(struct fb_info) + PADDING;
- mxcfbi = (struct mxcfb_info *)fbi->par;
- debug("Framebuffer structures at: fbi=0x%x mxcfbi=0x%x\n",
- (unsigned int)fbi, (unsigned int)mxcfbi);
- fbi->var.activate = FB_ACTIVATE_NOW;
- fbi->flags = FBINFO_FLAG_DEFAULT;
- fbi->pseudo_palette = mxcfbi->pseudo_palette;
- return fbi;
- Probe routine for the framebuffer driver. It is called during the
- driver binding process. The following functions are performed in
- this routine: Framebuffer initialization, Memory allocation and
- mapping, Framebuffer registration, IPU initialization.
- @return Appropriate error code to the kernel common code
+static int mxcfb_probe(u32 interface_pix_fmt, struct fb_videomode *mode) +{
- int ret = 0;
- * Initialize FB structures
- fbi = mxcfb_init_fbinfo();
- if (!fbi) {
- ret = -ENOMEM;
- goto err0;
- if (!g_dp_in_use) {
- mxcfbi->ipu_ch = MEM_BG_SYNC;
- mxcfbi->blank = FB_BLANK_UNBLANK;
- } else {
- mxcfbi->ipu_ch = MEM_DC_SYNC;
- mxcfbi->blank = FB_BLANK_POWERDOWN;
- mxcfbi->ipu_di = 0;
- ipu_disp_set_global_alpha(mxcfbi->ipu_ch, true, 0x80);
- ipu_disp_set_color_key(mxcfbi->ipu_ch, false, 0);
- strcpy(fbi->fix.id, "DISP3 BG");
- g_dp_in_use = true;
- mxcfb_info[mxcfbi->ipu_di] = fbi;
- /* Need dummy values until real panel is configured */
- fbi->var.xres = 640;
- fbi->var.yres = 480;
- fbi->var.bits_per_pixel = 16;
- mxcfbi->ipu_di_pix_fmt = interface_pix_fmt;
- fb_videomode_to_var(&fbi->var, mode);
- mxcfb_check_var(&fbi->var, fbi);
- /* Default Y virtual size is 2x panel size */
- fbi->var.yres_virtual = fbi->var.yres * 2;
- /* alocate fb first */
- return -ENOMEM;
- mxcfb_set_par(fbi);
- /* Setting panel_info for lcd */
- panel_info.cmap = NULL;
- panel_info.vl_col = fbi->var.xres;
- panel_info.vl_row = fbi->var.yres;
- panel_info.vl_bpix = LCD_BPP;
- lcd_line_length = (panel_info.vl_col * NBITS(panel_info.vl_bpix)) / 8;
- debug("MXC IPUV3 configured\n"
- "XRES = %d YRES = %d BitsXpixel = %d\n",
- panel_info.vl_col,
- panel_info.vl_row,
- panel_info.vl_bpix);
- ipu_dump_registers();
+err0:
- return ret;
+int overwrite_console(void) +{
- /* Keep stdout / stderr on serial, our LCD is for splashscreen only */
- return 1;
+void lcd_ctrl_init(void *lcdbase) +{
- u32 mem_len = panel_info.vl_col *
- panel_info.vl_row *
- NBITS(panel_info.vl_bpix) / 8;
- * We rely on lcdbase being a physical address, i.e., either MMU off,
- * or 1-to-1 mapping. Might want to add some virt2phys here.
- if (!lcdbase)
- return;
- memset(lcdbase, 0, mem_len);
+int mx51_fb_init(struct fb_videomode *mode) +{
- int ret;
- ret = ipu_probe();
- if (ret) {
- puts("Error initializing IPU\n");
- lcd_base += 56;
- debug("Framebuffet at 0x%x\n", (unsigned int)lcd_base);
- ret = mxcfb_probe(IPU_PIX_FMT_RGB666, mode);
- return ret;
+} diff --git a/drivers/video/mxcfb.h b/drivers/video/mxcfb.h new file mode 100644 index 0000000..e1c1d72 --- /dev/null +++ b/drivers/video/mxcfb.h @@ -0,0 +1,78 @@ +/*
- Copyright 2004-2009 Freescale Semiconductor, Inc. All Rights Reserved.
- The code contained herein is licensed under the GNU Lesser General
- Public License. You may obtain a copy of the GNU Lesser General
- Public License Version 2.1 or later at the following locations:
- @file arch-mxc/ mxcfb.h
- @brief Global header file for the MXC Frame buffer
- @ingroup Framebuffer
+#ifndef __ASM_ARCH_MXCFB_H__ +#define __ASM_ARCH_MXCFB_H__
+#define FB_SYNC_OE_LOW_ACT 0x80000000 +#define FB_SYNC_CLK_LAT_FALL 0x40000000 +#define FB_SYNC_DATA_INVERT 0x20000000 +#define FB_SYNC_CLK_IDLE_EN 0x10000000 +#define FB_SYNC_SHARP_MODE 0x08000000 +#define FB_SYNC_SWAP_RGB 0x04000000
+struct mxcfb_gbl_alpha {
- int enable;
- int alpha;
+struct mxcfb_loc_alpha {
- int enable;
- int alpha_in_pixel;
- unsigned long alpha_phy_addr0;
- unsigned long alpha_phy_addr1;
+struct mxcfb_color_key {
- int enable;
- __u32 color_key;
+struct mxcfb_pos {
- __u16 x;
- __u16 y;
+struct mxcfb_gamma {
- int enable;
- int constk[16];
- int slopek[16];
+#ifdef __KERNEL__
+extern struct fb_videomode mxcfb_modedb[]; +extern int mxcfb_modedb_sz;
+enum {
- MXCFB_REFRESH_OFF,
- MXCFB_REFRESH_AUTO,
- MXCFB_REFRESH_PARTIAL,
+struct mxcfb_rect {
- u32 top;
- u32 left;
- u32 width;
- u32 height;
+#endif /* __KERNEL__ */
1.6.3.3
On 10/22/2010 05:54 AM, Liu Ying wrote:
Hello, Stefano,
Hi Liu,
That is correct. As I stated in the commit message, the goal was to add LCD support to allow to display a splashscreen in u-boot. On the board I used to test, LCD is connected to DI0.
Well, now the driver is in mainline. Patches are welcome !
- Two framebuffers on IPU DI0 and DI1 can be support at the same
I understand this is a feature for Linux, but in u-boot ? Two splashscreens at the same time ? At the moment I do not know a board in u-boot managing two display and I do not see a reason.
- IPU DP module supports to combine two layers. The overlay layer can
All these features were dropped because they are not used in u-boot. We have no GUI programming, and only a small subset of commands to manage the display. I understand they are a bunch of important features in Linux, but in my understanding we need in u-boot only to show more or less fixed images.
Best regards, Stefano Babic
Liu Ying
Stefano Babic
