[PATCH] arm: dts: imx8mp: Import GPCv2 subset, HSIOMIX and USB PD
Add DT bindings for a subset of GPCv2 which handles USB and PCIe PDs, HSIOMIX PD controller and missing USB PD properties. This is required to bring up the DWC3 USB controller up.
This is based on linux next and patches which are still pending review, but which are likely going to be part of Linux 5.19: b2d67d7bdf74 ("arm64: dts: imx8mp: disable usb3_phy1") 290918c72a29 ("arm64: dts: imx8mp: Add memory for USB3 glue layer to usb3 nodes") https://www.spinics.net/lists/arm-kernel/msg958501.html
Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam festevam@gmail.com Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de --- arch/arm/dts/imx8mp.dtsi | 72 ++++++++++++++++++++++++++++++++++++++-- 1 file changed, 70 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/imx8mp.dtsi b/arch/arm/dts/imx8mp.dtsi index f9d64253c8a..79b65750da9 100644 --- a/arch/arm/dts/imx8mp.dtsi +++ b/arch/arm/dts/imx8mp.dtsi @@ -4,6 +4,7 @@ */
#include <dt-bindings/clock/imx8mp-clock.h> +#include <dt-bindings/power/imx8mp-power.h> #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/input/input.h> #include <dt-bindings/interrupt-controller/arm-gic.h> @@ -434,6 +435,44 @@ interrupts = <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>; #reset-cells = <1>; }; + + gpc: gpc@303a0000 { + compatible = "fsl,imx8mp-gpc"; + reg = <0x303a0000 0x1000>; + interrupt-parent = <&gic>; + interrupt-controller; + #interrupt-cells = <3>; + + pgc { + #address-cells = <1>; + #size-cells = <0>; + + pgc_pcie_phy: power-domain@1 { + #power-domain-cells = <0>; + reg = <IMX8MP_POWER_DOMAIN_PCIE_PHY>; + }; + + pgc_usb1_phy: power-domain@2 { + #power-domain-cells = <0>; + reg = <IMX8MP_POWER_DOMAIN_USB1_PHY>; + }; + + pgc_usb2_phy: power-domain@3 { + #power-domain-cells = <0>; + reg = <IMX8MP_POWER_DOMAIN_USB2_PHY>; + }; + + pgc_hsiomix: power-domains@17 { + #power-domain-cells = <0>; + reg = <IMX8MP_POWER_DOMAIN_HSIOMIX>; + clocks = <&clk IMX8MP_CLK_HSIO_AXI>, + <&clk IMX8MP_CLK_HSIO_ROOT>; + assigned-clocks = <&clk IMX8MP_CLK_HSIO_AXI>; + assigned-clock-parents = <&clk IMX8MP_SYS_PLL2_500M>; + assigned-clock-rates = <500000000>; + }; + }; + }; };
aips2: bus@30400000 { @@ -842,6 +881,28 @@ }; };
+ aips4: bus@32c00000 { + compatible = "fsl,aips-bus", "simple-bus"; + reg = <0x32c00000 0x400000>; + #address-cells = <1>; + #size-cells = <1>; + ranges; + + hsio_blk_ctrl: blk-ctrl@32f10000 { + compatible = "fsl,imx8mp-hsio-blk-ctrl", "syscon"; + reg = <0x32f10000 0x24>; + clocks = <&clk IMX8MP_CLK_USB_ROOT>, + <&clk IMX8MP_CLK_PCIE_ROOT>; + clock-names = "usb", "pcie"; + power-domains = <&pgc_hsiomix>, <&pgc_hsiomix>, + <&pgc_usb1_phy>, <&pgc_usb2_phy>, + <&pgc_hsiomix>, <&pgc_pcie_phy>; + power-domain-names = "bus", "usb", "usb-phy1", + "usb-phy2", "pcie", "pcie-phy"; + #power-domain-cells = <1>; + }; + }; + gic: interrupt-controller@38800000 { compatible = "arm,gic-v3"; reg = <0x38800000 0x10000>, @@ -865,17 +926,20 @@ clock-names = "phy"; assigned-clocks = <&clk IMX8MP_CLK_USB_PHY_REF>; assigned-clock-parents = <&clk IMX8MP_CLK_24M>; + power-domains = <&hsio_blk_ctrl IMX8MP_HSIOBLK_PD_USB_PHY1>; #phy-cells = <0>; status = "disabled"; };
usb3_0: usb@32f10100 { compatible = "fsl,imx8mp-dwc3"; - reg = <0x32f10100 0x8>; + reg = <0x32f10100 0x8>, + <0x381f0000 0x20>; clocks = <&clk IMX8MP_CLK_HSIO_ROOT>, <&clk IMX8MP_CLK_USB_ROOT>; clock-names = "hsio", "suspend"; interrupts = <GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&hsio_blk_ctrl IMX8MP_HSIOBLK_PD_USB>; #address-cells = <1>; #size-cells = <1>; dma-ranges = <0x40000000 0x40000000 0xc0000000>; @@ -907,16 +971,20 @@ clock-names = "phy"; assigned-clocks = <&clk IMX8MP_CLK_USB_PHY_REF>; assigned-clock-parents = <&clk IMX8MP_CLK_24M>; + power-domains = <&hsio_blk_ctrl IMX8MP_HSIOBLK_PD_USB_PHY2>; #phy-cells = <0>; + status = "disabled"; };
usb3_1: usb@32f10108 { compatible = "fsl,imx8mp-dwc3"; - reg = <0x32f10108 0x8>; + reg = <0x32f10108 0x8>, + <0x382f0000 0x20>; clocks = <&clk IMX8MP_CLK_HSIO_ROOT>, <&clk IMX8MP_CLK_USB_ROOT>; clock-names = "hsio", "suspend"; interrupts = <GIC_SPI 149 IRQ_TYPE_LEVEL_HIGH>; + power-domains = <&hsio_blk_ctrl IMX8MP_HSIOBLK_PD_USB>; #address-cells = <1>; #size-cells = <1>; dma-ranges = <0x40000000 0x40000000 0xc0000000>;
gpc: gpc@303a0000 {
pgc {
#size-cells = <0>;
}; }; aips2: bus@30400000 {
#size-cells = <1>;
ranges;
power-domains = <&hsio_blk_ctrl IMX8MP_HSIOBLK_PD_USB_PHY1>; #phy-cells = <0>; status = "disabled"; }; usb3_0: usb@32f10100 { compatible = "fsl,imx8mp-dwc3";
status = "disabled"; }; usb3_1: usb@32f10108 { compatible = "fsl,imx8mp-dwc3";
-- 2.35.1
Thanks for working on this!
This helps get DWC3 USB working on IMX8MP.
Tested-By: Tim Harvey tharvey@gateworks.com #imx8mp-venice-gw74xx
Best Regards,
Tim
Hi Marek,
after bisecting, rather this breaks some boards like imx8mm_beacon (it is not the only one):
+In file included from arch/arm/dts/.imx8mp-evk.dtb.pre.tmp:8:
+arch/arm/dts/imx8mp.dtsi:7:10: fatal error: dt-bindings/power/imx8mp-power.h: No such file or directory
+ 7 | #include <dt-bindings/power/imx8mp-power.h>
+compilation terminated.
Can you check and then repost ? Thanks !
Best regards, Stefano
gpc: gpc@303a0000 {
pgc {
#size-cells = <0>;
#size-cells = <1>;
ranges;
- gic: interrupt-controller@38800000 { compatible = "arm,gic-v3"; reg = <0x38800000 0x10000>,
On Mon, Apr 11, 2022 at 11:33 AM Stefano Babic sbabic@denx.de wrote:
Hi Marek,
Stefano,
I think your missing "imx: power-domain: Add i.MX8MP support" [1]
There is quite a queue of imx patches that have been waiting for review and merging and some have been broken due to Kconfig changes as you're seeing now. Others depend on one another in this situation here.
Is there any way you could review, merge to an imx-next, and issue a pull-request to Tom periodically between releases instead of waiting for the 1 merge window in between?
Best Regards,
Tim
Tim [1] https://patchwork.ozlabs.org/project/uboot/patch/20220401011213.701459-1-mar...
gpc: gpc@303a0000 {
pgc {
#size-cells = <0>;
#size-cells = <1>;
ranges;
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-53 Fax: +49-8142-66989-80 Email: sbabic@denx.de =====================================================================
Hi Tim,
Hi Marek,
Stefano,
Right - I confirm this, and I cannot apply it. This should be rebased and reposted.
Yes, I see they are currently broken, so I am trying first to apply all patches that are orthogonal and do not break build.
This depends more on the status of my projects than on a designed work-flow when to do it, and I can work on U-Boot's ML during spare times.
Best Regards,
Tim
gpc: gpc@303a0000 {
pgc {
#size-cells = <0>;
#size-cells = <1>;
ranges;
On 4/11/22 21:06, Stefano Babic wrote:
Hi Tim,
Hi Marek,
Stefano,
Yes, all those patches are now broken and must be rebased and retested.
Should I send out whatever is currently missing on top of u-boot-imx/master-next or what ?
Hi Marek,
Hi Tim,
Hi Marek,
Stefano,
I am splitting patches dropping patches that are clearly broken and then pushing this to u-boot-imx (and then to Tom). So just wait until I update u-boot-imx with the first big buch of patches.
Regards, Stefano
On 4/11/22 21:24, Stefano Babic wrote:
Hi Marek,
Hi Tim,
Hi Marek,
Stefano,
Here is the entire batch of patches, in the right order, with RB/TB collected.
Hi Marek,
Hi Tim,
Hi Marek,
Stefano,
https://patchwork.ozlabs.org/project/uboot/list/?series=294611
Stefano Babic
Tim Harvey
