[PATCH] net: add Amlogic Meson G12A MDIO MUX driver
The Amlogic G12A & compatible SoCs embeds a mux to either communicate with the external PHY or the internal 10/100 PHY.
This adds support for this mux as a MDIO MUX device.
Signed-off-by: Neil Armstrong narmstrong@baylibre.com --- drivers/net/Kconfig | 7 ++ drivers/net/Makefile | 1 + drivers/net/mdio_mux_meson_g12a.c | 149 ++++++++++++++++++++++++++++++ 3 files changed, 157 insertions(+) create mode 100644 drivers/net/mdio_mux_meson_g12a.c
diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index 41fa2fe566..e1d3b26687 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -797,4 +797,11 @@ config MDIO_MUX_MMIOREG This driver is used for MDIO muxes driven by writing to a register in the MMIO physical memory.
+config MDIO_MUX_MESON_G12A + bool "MDIO MUX for Amlogic Meson G12A SoCs" + depends on DM_MDIO_MUX + help + This driver is used for the MDIO mux found on the Amlogic G12A & compatible + SoCs. + endif # NETDEVICES diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 511c87c3a5..070ae7662c 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -43,6 +43,7 @@ obj-$(CONFIG_MACB) += macb.o obj-$(CONFIG_MCFFEC) += mcffec.o mcfmii.o obj-$(CONFIG_MDIO_IPQ4019) += mdio-ipq4019.o obj-$(CONFIG_MDIO_MUX_I2CREG) += mdio_mux_i2creg.o +obj-$(CONFIG_MDIO_MUX_MESON_G12A) += mdio_mux_meson_g12a.o obj-$(CONFIG_MDIO_MUX_MMIOREG) += mdio_mux_mmioreg.o obj-$(CONFIG_MDIO_MUX_SANDBOX) += mdio_mux_sandbox.o obj-$(CONFIG_MPC8XX_FEC) += mpc8xx_fec.o diff --git a/drivers/net/mdio_mux_meson_g12a.c b/drivers/net/mdio_mux_meson_g12a.c new file mode 100644 index 0000000000..b520bf98f0 --- /dev/null +++ b/drivers/net/mdio_mux_meson_g12a.c @@ -0,0 +1,149 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * (C) Copyright 2021 BayLibre, SAS + * Author: Neil Armstrong narmstrong@baylibre.com + */ + +#include <dm.h> +#include <errno.h> +#include <log.h> +#include <miiphy.h> +#include <asm/io.h> +#include <linux/bitfield.h> + +#define ETH_PLL_STS 0x40 +#define ETH_PLL_CTL0 0x44 +#define PLL_CTL0_LOCK_DIG BIT(30) +#define PLL_CTL0_RST BIT(29) +#define PLL_CTL0_EN BIT(28) +#define PLL_CTL0_SEL BIT(23) +#define PLL_CTL0_N GENMASK(14, 10) +#define PLL_CTL0_M GENMASK(8, 0) +#define PLL_LOCK_TIMEOUT 1000000 +#define PLL_MUX_NUM_PARENT 2 +#define ETH_PLL_CTL1 0x48 +#define ETH_PLL_CTL2 0x4c +#define ETH_PLL_CTL3 0x50 +#define ETH_PLL_CTL4 0x54 +#define ETH_PLL_CTL5 0x58 +#define ETH_PLL_CTL6 0x5c +#define ETH_PLL_CTL7 0x60 + +#define ETH_PHY_CNTL0 0x80 +#define EPHY_G12A_ID 0x33010180 +#define ETH_PHY_CNTL1 0x84 +#define PHY_CNTL1_ST_MODE GENMASK(2, 0) +#define PHY_CNTL1_ST_PHYADD GENMASK(7, 3) +#define EPHY_DFLT_ADD 8 +#define PHY_CNTL1_MII_MODE GENMASK(15, 14) +#define EPHY_MODE_RMII 0x1 +#define PHY_CNTL1_CLK_EN BIT(16) +#define PHY_CNTL1_CLKFREQ BIT(17) +#define PHY_CNTL1_PHY_ENB BIT(18) +#define ETH_PHY_CNTL2 0x88 +#define PHY_CNTL2_USE_INTERNAL BIT(5) +#define PHY_CNTL2_SMI_SRC_MAC BIT(6) +#define PHY_CNTL2_RX_CLK_EPHY BIT(9) + +#define MESON_G12A_MDIO_EXTERNAL_ID 0 +#define MESON_G12A_MDIO_INTERNAL_ID 1 + +struct mdio_mux_meson_g12a_priv { + struct udevice *chip; + phys_addr_t phys; +}; + +static int meson_g12a_ephy_pll_init(struct mdio_mux_meson_g12a_priv *priv) +{ + /* Fire up the PHY PLL */ + writel(0x29c0040a, priv->phys + ETH_PLL_CTL0); + writel(0x927e0000, priv->phys + ETH_PLL_CTL1); + writel(0xac5f49e5, priv->phys + ETH_PLL_CTL2); + writel(0x00000000, priv->phys + ETH_PLL_CTL3); + writel(0x00000000, priv->phys + ETH_PLL_CTL4); + writel(0x20200000, priv->phys + ETH_PLL_CTL5); + writel(0x0000c002, priv->phys + ETH_PLL_CTL6); + writel(0x00000023, priv->phys + ETH_PLL_CTL7); + writel(0x39c0040a, priv->phys + ETH_PLL_CTL0); + writel(0x19c0040a, priv->phys + ETH_PLL_CTL0); + + return 0; +} + +static int meson_g12a_enable_internal_mdio(struct mdio_mux_meson_g12a_priv *priv) +{ + /* Initialize ephy control */ + writel(EPHY_G12A_ID, priv->phys + ETH_PHY_CNTL0); + writel(FIELD_PREP(PHY_CNTL1_ST_MODE, 3) | + FIELD_PREP(PHY_CNTL1_ST_PHYADD, EPHY_DFLT_ADD) | + FIELD_PREP(PHY_CNTL1_MII_MODE, EPHY_MODE_RMII) | + PHY_CNTL1_CLK_EN | + PHY_CNTL1_CLKFREQ | + PHY_CNTL1_PHY_ENB, + priv->phys + ETH_PHY_CNTL1); + writel(PHY_CNTL2_USE_INTERNAL | + PHY_CNTL2_SMI_SRC_MAC | + PHY_CNTL2_RX_CLK_EPHY, + priv->phys + ETH_PHY_CNTL2); + + return 0; +} + +static int meson_g12a_enable_external_mdio(struct mdio_mux_meson_g12a_priv *priv) +{ + /* Reset the mdio bus mux */ + writel(0x0, priv->phys + ETH_PHY_CNTL2); + + return 0; +} + +static int mdio_mux_meson_g12a_select(struct udevice *mux, int cur, int sel) +{ + struct mdio_mux_meson_g12a_priv *priv = dev_get_priv(mux); + + debug("%s: %x -> %x\n", __func__, (u32)cur, (u32)sel); + + /* if last selection didn't change we're good to go */ + if (cur == sel) + return 0; + + switch (sel) { + case MESON_G12A_MDIO_EXTERNAL_ID: + return meson_g12a_enable_external_mdio(priv); + case MESON_G12A_MDIO_INTERNAL_ID: + return meson_g12a_enable_internal_mdio(priv); + default: + return -EINVAL; + } + + return 0; +} + +static const struct mdio_mux_ops mdio_mux_meson_g12a_ops = { + .select = mdio_mux_meson_g12a_select, +}; + +static int mdio_mux_meson_g12a_probe(struct udevice *dev) +{ + struct mdio_mux_meson_g12a_priv *priv = dev_get_priv(dev); + + priv->phys = dev_read_addr(dev); + + meson_g12a_ephy_pll_init(priv); + + return 0; +} + +static const struct udevice_id mdio_mux_meson_g12a_ids[] = { + { .compatible = "amlogic,g12a-mdio-mux" }, + { } +}; + +U_BOOT_DRIVER(mdio_mux_meson_g12a) = { + .name = "mdio_mux_meson_g12a", + .id = UCLASS_MDIO_MUX, + .of_match = mdio_mux_meson_g12a_ids, + .probe = mdio_mux_meson_g12a_probe, + .ops = &mdio_mux_meson_g12a_ops, + .priv_auto = sizeof(struct mdio_mux_meson_g12a_priv), +};
On Wed, Feb 24, 2021 at 6:31 PM Neil Armstrong narmstrong@baylibre.com wrote:
help
SoCs.
- (C) Copyright 2021 BayLibre, SAS
- Author: Neil Armstrong narmstrong@baylibre.com
phys_addr_t phys;
PHY_CNTL1_CLK_EN |
PHY_CNTL1_CLKFREQ |
PHY_CNTL1_PHY_ENB,
if (cur == sel)
switch (sel) {
default:
return -EINVAL;
2.25.1
Reviewed-by: Ramon Fried rfried.dev@gmail.com
help
SoCs.
phys_addr_t phys;
PHY_CNTL1_CLK_EN |
PHY_CNTL1_CLKFREQ |
PHY_CNTL1_PHY_ENB,
if (cur == sel)
switch (sel) {
default:
return -EINVAL;
2.25.1
Thanks !
Applied to u-boot-amlogic-next
Neil Armstrong
Ramon Fried
