[PULL] u-boot-mips fixes for v2021.01
Hi Tom,
please pull some bugfixes and some minor updates for compatibility with the Marvell Octeon MIPS64 boot header. Although this adds a new tool, everything is small and isolated to MIPS/Octeon.
Gitlab CI: https://gitlab.denx.de/u-boot/custodians/u-boot-mips/-/pipelines/5455 Azure: https://dev.azure.com/danielschwierzeck/u-boot/_build/results?buildId=10&...
The following changes since commit a7ab4b71d563b6e0b65f911a8bf7d6950625982e:
Merge tag 'mmc-2020-11-29' of https://gitlab.denx.de/u-boot/custodians/u-boot-mmc (2020-11-29 11:12:59 -0500)
https://gitlab.denx.de/u-boot/custodians/u-boot-mips.git tags/mips-fixes-for-v2021.01
for you to fetch changes up to 540a2bcec1389a3a31c23b5275e73186be6102b2:
mips: octeon: tools: Add update_octeon_header tool (2020-11-30 18:32:09 +0100)
---------------------------------------------------------------- - MIPS: octeon: fix allocation bug in DDR driver - MIPS: octeon: fix init of gd->ram_size - MIPS: octeon: add support for Octeon boot header
---------------------------------------------------------------- Stefan Roese (5): mips: start.S: Add Octeon boot header compatibility mips: octeon: Fix Octeon DDR driver to use the correct struct mips: octeon: Report full DDR size in dram_init() to gd->ram_size mips: octeon: bootoctlinux: Use gd->ram_size instead of ram_get_info() mips: octeon: tools: Add update_octeon_header tool
arch/mips/cpu/start.S | 10 +- arch/mips/mach-octeon/bootoctlinux.c | 21 +- arch/mips/mach-octeon/dram.c | 7 +- arch/mips/mach-octeon/include/mach/cvmx-bootinfo.h | 222 ---------- .../mach-octeon/include/mach/cvmx-bootloader.h | 172 ++++++++ drivers/ram/octeon/octeon_ddr.c | 2 +- tools/.gitignore | 1 + tools/Makefile | 3 + tools/update_octeon_header.c | 456 +++++++++++++++++++++ 9 files changed, 650 insertions(+), 244 deletions(-) create mode 100644 arch/mips/mach-octeon/include/mach/cvmx-bootloader.h create mode 100644 tools/update_octeon_header.c
On Mon, Nov 30, 2020 at 08:18:52PM +0100, Daniel Schwierzeck wrote:
Hi Tom,
Daniel Schwierzeck
