[U-Boot] [PATCH] m68k: m5253evbe: Remove this board
The m5253evbe board has been marked as orphan since June of 2014 and should have been dropped a while ago. Do so now.
Signed-off-by: Tom Rini trini@konsulko.com --- arch/m68k/Kconfig | 5 -- board/freescale/m5253evbe/Kconfig | 15 ---- board/freescale/m5253evbe/MAINTAINERS | 6 -- board/freescale/m5253evbe/Makefile | 6 -- board/freescale/m5253evbe/README | 102 --------------------- board/freescale/m5253evbe/m5253evbe.c | 128 -------------------------- configs/M5253EVBE_defconfig | 16 ---- include/configs/M5253EVBE.h | 163 ---------------------------------- 8 files changed, 441 deletions(-) delete mode 100644 board/freescale/m5253evbe/Kconfig delete mode 100644 board/freescale/m5253evbe/MAINTAINERS delete mode 100644 board/freescale/m5253evbe/Makefile delete mode 100644 board/freescale/m5253evbe/README delete mode 100644 board/freescale/m5253evbe/m5253evbe.c delete mode 100644 configs/M5253EVBE_defconfig delete mode 100644 include/configs/M5253EVBE.h
diff --git a/arch/m68k/Kconfig b/arch/m68k/Kconfig index 42fb91539af6..1f6df5c87044 100644 --- a/arch/m68k/Kconfig +++ b/arch/m68k/Kconfig @@ -144,10 +144,6 @@ config TARGET_M5253DEMO bool "Support M5253DEMO" select M5253
-config TARGET_M5253EVBE - bool "Support M5253EVBE" - select M5253 - config TARGET_M5272C3 bool "Support M5272C3" select M5272 @@ -214,7 +210,6 @@ source "board/freescale/m52277evb/Kconfig" source "board/freescale/m5235evb/Kconfig" source "board/freescale/m5249evb/Kconfig" source "board/freescale/m5253demo/Kconfig" -source "board/freescale/m5253evbe/Kconfig" source "board/freescale/m5272c3/Kconfig" source "board/freescale/m5275evb/Kconfig" source "board/freescale/m5282evb/Kconfig" diff --git a/board/freescale/m5253evbe/Kconfig b/board/freescale/m5253evbe/Kconfig deleted file mode 100644 index d97b87c4caec..000000000000 --- a/board/freescale/m5253evbe/Kconfig +++ /dev/null @@ -1,15 +0,0 @@ -if TARGET_M5253EVBE - -config SYS_CPU - default "mcf52x2" - -config SYS_BOARD - default "m5253evbe" - -config SYS_VENDOR - default "freescale" - -config SYS_CONFIG_NAME - default "M5253EVBE" - -endif diff --git a/board/freescale/m5253evbe/MAINTAINERS b/board/freescale/m5253evbe/MAINTAINERS deleted file mode 100644 index 74acd1eee504..000000000000 --- a/board/freescale/m5253evbe/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -M5253EVBE BOARD -#M: Hayden Fraser Hayden.Fraser@freescale.com -S: Orphan (since 2014-06) -F: board/freescale/m5253evbe/ -F: include/configs/M5253EVBE.h -F: configs/M5253EVBE_defconfig diff --git a/board/freescale/m5253evbe/Makefile b/board/freescale/m5253evbe/Makefile deleted file mode 100644 index 79e20b7365b8..000000000000 --- a/board/freescale/m5253evbe/Makefile +++ /dev/null @@ -1,6 +0,0 @@ -# SPDX-License-Identifier: GPL-2.0+ -# -# (C) Copyright 2000-2006 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. - -obj-y = m5253evbe.o diff --git a/board/freescale/m5253evbe/README b/board/freescale/m5253evbe/README deleted file mode 100644 index f4eae67fc010..000000000000 --- a/board/freescale/m5253evbe/README +++ /dev/null @@ -1,102 +0,0 @@ -Freescale Amadeus Plus M5253EVBE board -====================================== - -Hayden Fraser(Hayden.Fraser@freescale.com) -Created 06/05/2007 -=========================================== - - -1. SWITCH SETTINGS -================== -1.1 N/A - - -2. MEMORY MAP UNDER U-BOOT AND LINUX KERNEL -=========================================== -2.1. For the initial bringup, we adopted a consistent memory scheme between U-Boot and - linux kernel, you can customize it based on your system requirements: - SDR: 0x00000000-0x00ffffff - SRAM0: 0x20010000-0x20017fff - SRAM1: 0x20000000-0x2000ffff - MBAR1: 0x10000000-0x4fffffff - MBAR2: 0x80000000-0xCfffffff - Flash: 0xffe00000-0xffffffff - -3. DEFINITIONS AND COMPILATION -============================== -3.1 Explanation on NEW definitions in include/configs/M5253EVBE.h - CONFIG_MCF52x2 Processor family - CONFIG_MCF5253 MCF5253 specific - CONFIG_SYS_CLK Define Amadeus Plus CPU Clock - CONFIG_SYS_MBAR MBAR base address - CONFIG_SYS_MBAR2 MBAR2 base address - -3.2 Compilation - export CROSS_COMPILE=/usr/local/freescale-coldfire-4.1-elf/bin/m68k-elf- - cd u-boot-1-2-x - make distclean - make M5253EVBE_config - make - - -4. SCREEN DUMP -============== -4.1 U-Boot 1.2.0 (Jun 18 2007 - 18:20:00) - -CPU: Freescale Coldfire MCF5253 at 62 MHz -Board: Freescale MCF5253 EVBE -DRAM: 16 MB -FLASH: 2 MB -In: serial -Out: serial -Err: serial -=> flinfo - -Bank # 1: CFI conformant FLASH (16 x 16) Size: 2 MB in 35 Sectors - AMD Standard command set, Manufacturer ID: 0x01, Device ID: 0x49 - Erase timeout: 16384 ms, write timeout: 1 ms - - Sector Start Addresses: - FFE00000 RO FFE04000 RO FFE06000 RO FFE08000 RO FFE10000 RO - FFE20000 FFE30000 FFE40000 FFE50000 FFE60000 - FFE70000 FFE80000 FFE90000 FFEA0000 FFEB0000 - FFEC0000 FFED0000 FFEE0000 FFEF0000 FFF00000 - FFF10000 FFF20000 FFF30000 FFF40000 FFF50000 - FFF60000 FFF70000 FFF80000 FFF90000 FFFA0000 - FFFB0000 FFFC0000 FFFD0000 FFFE0000 FFFF0000 - -=> bdinfo -boot_params = 0x00F62F90 -memstart = 0x00000000 -memsize = 0x01000000 -flashstart = 0xFFE00000 -flashsize = 0x00200000 -flashoffset = 0x00000000 -baudrate = 19200 bps - -=> printenv -bootdelay=5 -baudrate=19200 -stdin=serial -stdout=serial -stderr=serial - -Environment size: 134/8188 bytes -=> saveenv -Saving Environment to Flash... -Un-Protected 1 sectors -Erasing Flash... -. done -Erased 1 sectors -Writing to Flash... done -Protected 1 sectors -=> - -5. COMPILER ------------ -To create U-Boot the CodeSourcery's version of the GNU Toolchain for the ColdFire architecture -compiler set (freescale-coldfire-4.1-elf) from www.codesourcery.com was used. -You can download it from:http://www.codesourcery.com/gnu_toolchains/coldfire/download.html - -compiler that you used - for example, codesourcery_elf requires -MQ in rules.mk, old M68K 2.95.3 just -M -codesourcery_elf requires -MQ in rules.mk, old M68K 2.95.3 just -M diff --git a/board/freescale/m5253evbe/m5253evbe.c b/board/freescale/m5253evbe/m5253evbe.c deleted file mode 100644 index 04447faaa4ce..000000000000 --- a/board/freescale/m5253evbe/m5253evbe.c +++ /dev/null @@ -1,128 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0+ -/* - * (C) Copyright 2000-2003 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * Copyright (C) 2004-2007, 2012 Freescale Semiconductor, Inc. - * Hayden Fraser (Hayden.Fraser@freescale.com) - */ - -#include <common.h> -#include <asm/immap.h> -#include <asm/io.h> - -DECLARE_GLOBAL_DATA_PTR; - -int checkboard(void) -{ - puts("Board: "); - puts("Freescale MCF5253 EVBE\n"); - return 0; -}; - -int dram_init(void) -{ - /* - * Check to see if the SDRAM has already been initialized - * by a run control tool - */ - if (!(mbar_readLong(MCFSIM_DCR) & 0x8000)) { - u32 RC, dramsize; - - RC = (CONFIG_SYS_CLK / 1000000) >> 1; - RC = (RC * 15) >> 4; - - /* Initialize DRAM Control Register: DCR */ - mbar_writeShort(MCFSIM_DCR, (0x8400 | RC)); - asm("nop"); - - mbar_writeLong(MCFSIM_DACR0, 0x00002320); - asm("nop"); - - /* Initialize DMR0 */ - dramsize = ((CONFIG_SYS_SDRAM_SIZE << 20) - 1) & 0xFFFC0000; - mbar_writeLong(MCFSIM_DMR0, dramsize | 1); - asm("nop"); - - mbar_writeLong(MCFSIM_DACR0, 0x00002328); - asm("nop"); - - /* Write to this block to initiate precharge */ - *(u32 *) (CONFIG_SYS_SDRAM_BASE) = 0xa5a5a5a5; - asm("nop"); - - /* Set RE bit in DACR */ - mbar_writeLong(MCFSIM_DACR0, - mbar_readLong(MCFSIM_DACR0) | 0x8000); - asm("nop"); - - /* Wait for at least 8 auto refresh cycles to occur */ - udelay(500); - - /* Finish the configuration by issuing the MRS */ - mbar_writeLong(MCFSIM_DACR0, - mbar_readLong(MCFSIM_DACR0) | 0x0040); - asm("nop"); - - *(u32 *) (CONFIG_SYS_SDRAM_BASE + 0x800) = 0xa5a5a5a5; - } - - gd->ram_size = CONFIG_SYS_SDRAM_SIZE * 1024 * 1024; - - return 0; -} - -int testdram(void) -{ - /* TODO: XXX XXX XXX */ - printf("DRAM test not implemented!\n"); - - return (0); -} - -#ifdef CONFIG_IDE -#include <ata.h> -int ide_preinit(void) -{ - return (0); -} - -void ide_set_reset(int idereset) -{ - atac_t *ata = (atac_t *) CONFIG_SYS_ATA_BASE_ADDR; - long period; - /* t1, t2, t3, t4, t5, t6, t9, tRD, tA */ - int piotms[5][9] = { {70, 165, 60, 30, 50, 5, 20, 0, 35}, /* PIO 0 */ - {50, 125, 45, 20, 35, 5, 15, 0, 35}, /* PIO 1 */ - {30, 100, 30, 15, 20, 5, 10, 0, 35}, /* PIO 2 */ - {30, 80, 30, 10, 20, 5, 10, 0, 35}, /* PIO 3 */ - {25, 70, 20, 10, 20, 5, 10, 0, 35} /* PIO 4 */ - }; - - if (idereset) { - /* control reset */ - out_8(&ata->cr, 0); - udelay(100); - } else { - mbar2_writeLong(CIM_MISCCR, CIM_MISCCR_CPUEND); - -#define CALC_TIMING(t) (t + period - 1) / period - period = 1000000000 / (CONFIG_SYS_CLK / 2); /* period in ns */ - - /*ata->ton = CALC_TIMING (180); */ - out_8(&ata->t1, CALC_TIMING(piotms[2][0])); - out_8(&ata->t2w, CALC_TIMING(piotms[2][1])); - out_8(&ata->t2r, CALC_TIMING(piotms[2][1])); - out_8(&ata->ta, CALC_TIMING(piotms[2][8])); - out_8(&ata->trd, CALC_TIMING(piotms[2][7])); - out_8(&ata->t4, CALC_TIMING(piotms[2][3])); - out_8(&ata->t9, CALC_TIMING(piotms[2][6])); - - /* IORDY enable */ - out_8(&ata->cr, 0x40); - udelay(2000); - /* IORDY enable */ - setbits_8(&ata->cr, 0x01); - } -} -#endif /* CONFIG_IDE */ diff --git a/configs/M5253EVBE_defconfig b/configs/M5253EVBE_defconfig deleted file mode 100644 index 754787c7d8ea..000000000000 --- a/configs/M5253EVBE_defconfig +++ /dev/null @@ -1,16 +0,0 @@ -CONFIG_M68K=y -CONFIG_SYS_TEXT_BASE=0xFFE00000 -CONFIG_TARGET_M5253EVBE=y -CONFIG_BOOTDELAY=5 -# CONFIG_DISPLAY_BOARDINFO is not set -# CONFIG_CMDLINE_EDITING is not set -# CONFIG_AUTO_COMPLETE is not set -CONFIG_CMD_IMLS=y -CONFIG_CMD_IDE=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_CACHE=y -CONFIG_CMD_EXT2=y -CONFIG_CMD_FAT=y -CONFIG_MAC_PARTITION=y -# CONFIG_NET is not set -CONFIG_MTD_NOR_FLASH=y diff --git a/include/configs/M5253EVBE.h b/include/configs/M5253EVBE.h deleted file mode 100644 index f7bac2bf0e9d..000000000000 --- a/include/configs/M5253EVBE.h +++ /dev/null @@ -1,163 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright (C) 2004-2007 Freescale Semiconductor, Inc. - * Hayden Fraser (Hayden.Fraser@freescale.com) - */ - -#ifndef _M5253EVBE_H -#define _M5253EVBE_H - -#define CONFIG_MCFTMR - -#define CONFIG_MCFUART -#define CONFIG_SYS_UART_PORT (0) - -#undef CONFIG_WATCHDOG /* disable watchdog */ - - -/* Configuration for environment - * Environment is embedded in u-boot in the second sector of the flash - */ -#ifndef CONFIG_MONITOR_IS_IN_RAM -#define CONFIG_ENV_OFFSET 0x4000 -#define CONFIG_ENV_SECT_SIZE 0x2000 -#else -#define CONFIG_ENV_ADDR 0xffe04000 -#define CONFIG_ENV_SECT_SIZE 0x2000 -#endif - -#define LDS_BOARD_TEXT \ - . = DEFINED(env_offset) ? env_offset : .; \ - env/embedded.o(.text) - -/* - * BOOTP options - */ -#undef CONFIG_BOOTP_BOOTFILESIZE - -/* - * Command line configuration. - */ - -/* ATA */ -#define CONFIG_IDE_RESET 1 -#define CONFIG_IDE_PREINIT 1 -#define CONFIG_ATAPI -#undef CONFIG_LBA48 - -#define CONFIG_SYS_IDE_MAXBUS 1 -#define CONFIG_SYS_IDE_MAXDEVICE 2 - -#define CONFIG_SYS_ATA_BASE_ADDR (CONFIG_SYS_MBAR2 + 0x800) -#define CONFIG_SYS_ATA_IDE0_OFFSET 0 - -#define CONFIG_SYS_ATA_DATA_OFFSET 0xA0 /* Offset for data I/O */ -#define CONFIG_SYS_ATA_REG_OFFSET 0xA0 /* Offset for normal register accesses */ -#define CONFIG_SYS_ATA_ALT_OFFSET 0xC0 /* Offset for alternate registers */ -#define CONFIG_SYS_ATA_STRIDE 4 /* Interval between registers */ - -#define CONFIG_SYS_LOAD_ADDR 0x00100000 - -#define CONFIG_SYS_MEMTEST_START 0x400 -#define CONFIG_SYS_MEMTEST_END 0x380000 - -#undef CONFIG_SYS_PLL_BYPASS /* bypass PLL for test purpose */ -#define CONFIG_SYS_FAST_CLK -#ifdef CONFIG_SYS_FAST_CLK -# define CONFIG_SYS_PLLCR 0x1243E054 -# define CONFIG_SYS_CLK 140000000 -#else -# define CONFIG_SYS_PLLCR 0x135a4140 -# define CONFIG_SYS_CLK 70000000 -#endif - -/* - * Low Level Configuration Settings - * (address mappings, register initial values, etc.) - * You should know what you are doing if you make changes here. - */ - -#define CONFIG_SYS_MBAR 0x10000000 /* Register Base Addrs */ -#define CONFIG_SYS_MBAR2 0x80000000 /* Module Base Addrs 2 */ - -/* - * Definitions for initial stack pointer and data area (in DPRAM) - */ -#define CONFIG_SYS_INIT_RAM_ADDR 0x20000000 -#define CONFIG_SYS_INIT_RAM_SIZE 0x10000 /* Size of used area in internal SRAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -/* - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - */ -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_SDRAM_SIZE 8 /* SDRAM size in MB */ - -#ifdef CONFIG_MONITOR_IS_IN_RAM -#define CONFIG_SYS_MONITOR_BASE 0x20000 -#else -#define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_FLASH_BASE + 0x400) -#endif - -#define CONFIG_SYS_MONITOR_LEN 0x40000 -#define CONFIG_SYS_MALLOC_LEN (256 << 10) -#define CONFIG_SYS_BOOTPARAMS_LEN (64*1024) - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization ?? - */ -#define CONFIG_SYS_BOOTMAPSZ (CONFIG_SYS_SDRAM_BASE + (CONFIG_SYS_SDRAM_SIZE << 20)) -#define CONFIG_SYS_BOOTM_LEN (CONFIG_SYS_SDRAM_SIZE << 20) - -/* FLASH organization */ -#define CONFIG_SYS_FLASH_BASE CONFIG_SYS_CS0_BASE -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max number of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 35 /* max number of sectors on one chip */ -#define CONFIG_SYS_FLASH_ERASE_TOUT 1000 - -#define CONFIG_SYS_FLASH_CFI 1 -#define CONFIG_FLASH_CFI_DRIVER 1 -#define CONFIG_SYS_FLASH_SIZE 0x200000 -#define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT - -/* Cache Configuration */ -#define CONFIG_SYS_CACHELINE_SIZE 16 - -#define ICACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_SIZE - 8) -#define DCACHE_STATUS (CONFIG_SYS_INIT_RAM_ADDR + \ - CONFIG_SYS_INIT_RAM_SIZE - 4) -#define CONFIG_SYS_ICACHE_INV (CF_CACR_DCM) -#define CONFIG_SYS_CACHE_ACR0 (CONFIG_SYS_FLASH_BASE | \ - CF_ADDRMASK(2) | \ - CF_ACR_EN | CF_ACR_SM_ALL) -#define CONFIG_SYS_CACHE_ACR1 (CONFIG_SYS_SDRAM_BASE | \ - CF_ADDRMASK(CONFIG_SYS_SDRAM_SIZE) | \ - CF_ACR_EN | CF_ACR_SM_ALL) -#define CONFIG_SYS_CACHE_ICACR (CF_CACR_CENB | CF_CACR_CEIB | \ - CF_CACR_DBWE) - -/* Port configuration */ -#define CONFIG_SYS_FECI2C 0xF0 - -#define CONFIG_SYS_CS0_BASE 0xFFE00000 -#define CONFIG_SYS_CS0_MASK 0x001F0021 -#define CONFIG_SYS_CS0_CTRL 0x00001D80 - -/*----------------------------------------------------------------------- - * Port configuration - */ -#define CONFIG_SYS_GPIO_FUNC 0x00000008 /* Set gpio pins: none */ -#define CONFIG_SYS_GPIO1_FUNC 0x00df00f0 /* 36-39(SWITCH),48-52(FPGAs),54 */ -#define CONFIG_SYS_GPIO_EN 0x00000008 /* Set gpio output enable */ -#define CONFIG_SYS_GPIO1_EN 0x00c70000 /* Set gpio output enable */ -#define CONFIG_SYS_GPIO_OUT 0x00000008 /* Set outputs to default state */ -#define CONFIG_SYS_GPIO1_OUT 0x00c70000 /* Set outputs to default state */ -#define CONFIG_SYS_GPIO1_LED 0x00400000 /* user led */ - -#endif /* _M5253EVB_H */
