[U-Boot] [PATCH v2] imx: drop warning: unused variable 'max_freq'
28 May
2015
28 May
'15
5:38 p.m.
max_freq in print_cpuinfo is used only with imx6.
Signed-off-by: Stefano Babic sbabic@denx.de ---
Changes in v2: - fix breakage of mx6 boards
Changes in v1: - broken, please ignore
arch/arm/imx-common/cpu.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/arch/arm/imx-common/cpu.c b/arch/arm/imx-common/cpu.c index 275befd..5e56cfe 100644 --- a/arch/arm/imx-common/cpu.c +++ b/arch/arm/imx-common/cpu.c @@ -145,7 +145,8 @@ const char *get_imx_type(u32 imxtype)
int print_cpuinfo(void) { - u32 cpurev, max_freq; + u32 cpurev; + __maybe_unused u32 max_freq;
#if defined(CONFIG_MX6) && defined(CONFIG_IMX6_THERMAL) struct udevice *thermal_dev;
1.9.1
3637
Stefano Babic
